[PATCH 1/7] benchmarks: Add benchmark templates
Sebastian Huber
Tue Mar 28 12:55:56 UTC 2017
testsuites/benchmarks/Makefile.am | 9 +++++
testsuites/benchmarks/configure.ac | 29 ++++++++++++++++
testsuites/benchmarks/dhrystone/Makefile.am | 19 +++++++++++
testsuites/benchmarks/dhrystone/dhrystone.doc | 11 ++++++
testsuites/benchmarks/dhrystone/dhrystone.scn | 0
testsuites/benchmarks/dhrystone/init.c | 48 +++++++++++++++++++++++++++
testsuites/benchmarks/linpack/Makefile.am | 19 +++++++++++
testsuites/benchmarks/linpack/init.c | 48 +++++++++++++++++++++++++++
testsuites/benchmarks/linpack/linpack.doc | 11 ++++++
testsuites/benchmarks/linpack/linpack.scn | 0
testsuites/benchmarks/whetstone/Makefile.am | 19 +++++++++++
testsuites/benchmarks/whetstone/init.c | 48 +++++++++++++++++++++++++++
testsuites/benchmarks/whetstone/whetstone.doc | 11 ++++++
testsuites/benchmarks/whetstone/whetstone.scn | 0
testsuites/configure.ac | 2 +-
15 files changed, 273 insertions(+), 1 deletion(-)
create mode 100644 testsuites/benchmarks/Makefile.am
create mode 100644 testsuites/benchmarks/configure.ac
create mode 100644 testsuites/benchmarks/dhrystone/Makefile.am
create mode 100644 testsuites/benchmarks/dhrystone/dhrystone.doc
create mode 100644 testsuites/benchmarks/dhrystone/dhrystone.scn
create mode 100644 testsuites/benchmarks/dhrystone/init.c
create mode 100644 testsuites/benchmarks/linpack/Makefile.am
create mode 100644 testsuites/benchmarks/linpack/init.c
create mode 100644 testsuites/benchmarks/linpack/linpack.doc
create mode 100644 testsuites/benchmarks/linpack/linpack.scn
create mode 100644 testsuites/benchmarks/whetstone/Makefile.am
create mode 100644 testsuites/benchmarks/whetstone/init.c
create mode 100644 testsuites/benchmarks/whetstone/whetstone.doc
create mode 100644 testsuites/benchmarks/whetstone/whetstone.scn
diff --git a/testsuites/benchmarks/Makefile.am b/testsuites/benchmarks/Makefile.am
new file mode 100644
index 0000000..3d95ecd
--- /dev/null
+++ b/testsuites/benchmarks/Makefile.am
@@ -0,0 +1,9 @@
+ACLOCAL_AMFLAGS = -I ../aclocal
+SUBDIRS =
+SUBDIRS += linpack
+SUBDIRS += whetstone
+SUBDIRS += dhrystone
+include $(top_srcdir)/../automake/subdirs.am
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/benchmarks/configure.ac b/testsuites/benchmarks/configure.ac
index 0000000..18af749
--- /dev/null
+++ b/testsuites/benchmarks/configure.ac
@@ -0,0 +1,29 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-tests-benchmarks],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+AC_CONFIG_HEADER([config.h])
+RTEMS_TOP([../..],[..])
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
+AM_MAINTAINER_MODE
+RTEMS_ENV_RTEMSBSP
+RTEMS_PROJECT_ROOT
+RTEMS_PROG_CC_FOR_TARGET
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP)
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile
+linpack/Makefile
+whetstone/Makefile
+dhrystone/Makefile
+AC_OUTPUT
diff --git a/testsuites/benchmarks/dhrystone/Makefile.am b/testsuites/benchmarks/dhrystone/Makefile.am
index 0000000..0354012
--- /dev/null
+++ b/testsuites/benchmarks/dhrystone/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = dhrystone
+dhrystone_SOURCES = init.c
+dist_rtems_tests_DATA = dhrystone.scn dhrystone.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(dhrystone_OBJECTS)
+LINK_LIBS = $(dhrystone_LDLIBS)
+dhrystone$(EXEEXT): $(dhrystone_OBJECTS) $(dhrystone_DEPENDENCIES)
+ @rm -f dhrystone$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/benchmarks/dhrystone/dhrystone.doc b/testsuites/benchmarks/dhrystone/dhrystone.doc
index 0000000..aac6f23
--- /dev/null
+++ b/testsuites/benchmarks/dhrystone/dhrystone.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: dhrystone
+directives:
+ TBD
+concepts:
+ TBD
diff --git a/testsuites/benchmarks/dhrystone/dhrystone.scn b/testsuites/benchmarks/dhrystone/dhrystone.scn
index 0000000..e69de29
diff --git a/testsuites/benchmarks/dhrystone/init.c b/testsuites/benchmarks/dhrystone/init.c
index 0000000..6e339d4
--- /dev/null
+++ b/testsuites/benchmarks/dhrystone/init.c
@@ -0,0 +1,48 @@
+ * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tmacros.h"
+const char rtems_test_name[] = "DHRYSTONE";
+static void test(void)
+static void Init(rtems_task_argument arg)
+ TEST_BEGIN();
+ test();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/benchmarks/linpack/Makefile.am b/testsuites/benchmarks/linpack/Makefile.am
index 0000000..d947cd6
--- /dev/null
+++ b/testsuites/benchmarks/linpack/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = linpack
+linpack_SOURCES = init.c
+dist_rtems_tests_DATA = linpack.scn linpack.doc
+LINK_OBJS = $(linpack_OBJECTS)
+LINK_LIBS = $(linpack_LDLIBS)
+linpack$(EXEEXT): $(linpack_OBJECTS) $(linpack_DEPENDENCIES)
+ @rm -f linpack$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/benchmarks/linpack/init.c b/testsuites/benchmarks/linpack/init.c
index 0000000..8b67e52
--- /dev/null
+++ b/testsuites/benchmarks/linpack/init.c
@@ -0,0 +1,48 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+const char rtems_test_name[] = "LINPACK";
+ TEST_BEGIN();
+ test();
+ TEST_END();
diff --git a/testsuites/benchmarks/linpack/linpack.doc b/testsuites/benchmarks/linpack/linpack.doc
index 0000000..af38058
--- /dev/null
+++ b/testsuites/benchmarks/linpack/linpack.doc
@@ -0,0 +1,11 @@
+test set name: linpack
+directives:
+ TBD
+concepts:
+ TBD
diff --git a/testsuites/benchmarks/linpack/linpack.scn b/testsuites/benchmarks/linpack/linpack.scn
diff --git a/testsuites/benchmarks/whetstone/Makefile.am b/testsuites/benchmarks/whetstone/Makefile.am
index 0000000..6146952
--- /dev/null
+++ b/testsuites/benchmarks/whetstone/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = whetstone
+whetstone_SOURCES = init.c
+dist_rtems_tests_DATA = whetstone.scn whetstone.doc
+LINK_OBJS = $(whetstone_OBJECTS)
+LINK_LIBS = $(whetstone_LDLIBS)
+whetstone$(EXEEXT): $(whetstone_OBJECTS) $(whetstone_DEPENDENCIES)
+ @rm -f whetstone$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/benchmarks/whetstone/init.c b/testsuites/benchmarks/whetstone/init.c
index 0000000..075facc
--- /dev/null
+++ b/testsuites/benchmarks/whetstone/init.c
@@ -0,0 +1,48 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#endif
+const char rtems_test_name[] = "WHETSTONE";
+ TEST_BEGIN();
+ test();
+ TEST_END();
diff --git a/testsuites/benchmarks/whetstone/whetstone.doc b/testsuites/benchmarks/whetstone/whetstone.doc
index 0000000..b6c3383
--- /dev/null
+++ b/testsuites/benchmarks/whetstone/whetstone.doc
@@ -0,0 +1,11 @@
+test set name: whetstone
+directives:
+ TBD
+concepts:
+ TBD
diff --git a/testsuites/benchmarks/whetstone/whetstone.scn b/testsuites/benchmarks/whetstone/whetstone.scn
diff --git a/testsuites/configure.ac b/testsuites/configure.ac
index 086f636..ab8aab8e 100644
--- a/testsuites/configure.ac
+++ b/testsuites/configure.ac
@@ -45,7 +45,7 @@ if test "$enable_tests" = "yes"; then
AC_CONFIG_SUBDIRS(smptests)
fi
# Now do performance tests
- AC_CONFIG_SUBDIRS(tmtests psxtmtests rhealstone)
+ AC_CONFIG_SUBDIRS(tmtests psxtmtests benchmarks rhealstone)
fi
1.8.4.5
