[PATCH 4/7] benchmarks/whetstone: Import
Tue Mar 28 12:55:59 UTC 2017
Import whetstone sources from:
http://www.netlib.org/benchmark/whetstone.c
 testsuites/benchmarks/whetstone/whetstone.c | 433 ++++++++++++++++++++++++++++
 1 file changed, 433 insertions(+)
 create mode 100644 testsuites/benchmarks/whetstone/whetstone.c
diff --git a/testsuites/benchmarks/whetstone/whetstone.c b/testsuites/benchmarks/whetstone/whetstone.c
new file mode 100644
index 0000000..159a11a
--- /dev/null
+++ b/testsuites/benchmarks/whetstone/whetstone.c
@@ -0,0 +1,433 @@
+ * C Converted Whetstone Double Precision Benchmark
+ *		Version 1.2	22 March 1998
+ *	(c) Copyright 1998 Painter Engineering, Inc.
+ *		All Rights Reserved.
+ *		Permission is granted to use, duplicate, and
+ *		publish this text and program as long as it
+ *		includes this entire comment block and limited
+ *		rights reference.
+ * Converted by Rich Painter, Painter Engineering, Inc. based on the
+ * www.netlib.org benchmark/whetstoned version obtained 16 March 1998.
+ * A novel approach was used here to keep the look and feel of the
+ * FORTRAN version.  Altering the FORTRAN-based array indices,
+ * starting at element 1, to start at element 0 for C, would require
+ * numerous changes, including decrementing the variable indices by 1.
+ * Instead, the array E1[] was declared 1 element larger in C.  This
+ * allows the FORTRAN index range to function without any literal or
+ * variable indices changes.  The array element E1[0] is simply never
+ * used and does not alter the benchmark results.
+ * The major FORTRAN comment blocks were retained to minimize
+ * differences between versions.  Modules N5 and N12, like in the
+ * FORTRAN version, have been eliminated here.
+ * An optional command-line argument has been provided [-c] to
+ * offer continuous repetition of the entire benchmark.
+ * An optional argument for setting an alternate LOOP count is also
+ * provided.  Define PRINTOUT to cause the POUT() function to print
+ * outputs at various stages.  Final timing measurements should be
+ * made with the PRINTOUT undefined.
+ * Questions and comments may be directed to the author at
+ *			r.painter at ieee.org
+C**********************************************************************
+C     Benchmark #2 -- Double  Precision Whetstone (A001)
+C
+C     o	This is a REAL*8 version of
+C	the Whetstone benchmark program.
+C
+C     o	DO-loop semantics are ANSI-66 compatible.
+C
+C     o	Final measurements are to be made with all
+C	WRITE statements and FORMAT sttements removed.
+C
+/* standard C library headers required */
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <math.h>
+/* the following is optional depending on the timing function used */
+#include <time.h>
+/* map the FORTRAN math functions, etc. to the C versions */
+#define DSIN	sin
+#define DCOS	cos
+#define DATAN	atan
+#define DLOG	log
+#define DEXP	exp
+#define DSQRT	sqrt
+#define IF		if
+/* function prototypes */
+void POUT(long N, long J, long K, double X1, double X2, double X3, double X4);
+void PA(double E[]);
+void P0(void);
+void P3(double X, double Y, double *Z);
+#define USAGE	"usage: whetdc [-c] [loops]\n"
+	COMMON T,T1,T2,E1(4),J,K,L
+double T,T1,T2,E1[5];
+int J,K,L;
+int
+main(int argc, char *argv[])
+	/* used in the FORTRAN version */
+	long I;
+	long N1, N2, N3, N4, N6, N7, N8, N9, N10, N11;
+	double X1,X2,X3,X4,X,Y,Z;
+	long LOOP;
+	int II, JJ;
+	/* added for this version */
+	long loopstart;
+	long startsec, finisec;
+	float KIPS;
+	int continuous;
+	loopstart = 1000;		/* see the note about LOOP below */
+	continuous = 0;
+	II = 1;		/* start at the first arg (temp use of II here) */
+	while (II < argc) {
+		if (strncmp(argv[II], "-c", 2) == 0 || argv[II][0] == 'c') {
+			continuous = 1;
+		} else if (atol(argv[II]) > 0) {
+			loopstart = atol(argv[II]);
+		} else {
+			fprintf(stderr, USAGE);
+			return(1);
+		II++;
+LCONT:
+C
+C	Start benchmark timing at this point.
+C
+	startsec = time(0);
+C
+C	The actual benchmark starts here.
+C
+	T  = .499975;
+	T1 = 0.50025;
+	T2 = 2.0;
+C
+C	With loopcount LOOP=10, one million Whetstone instructions
+C	will be executed in EACH MAJOR LOOP..A MAJOR LOOP IS EXECUTED
+C	'II' TIMES TO INCREASE WALL-CLOCK TIMING ACCURACY.
+C
+	LOOP = 1000;
+	LOOP = loopstart;
+	II   = 1;
+	JJ = 1;
+IILOOP:
+	N1  = 0;
+	N2  = 12 * LOOP;
+	N3  = 14 * LOOP;
+	N4  = 345 * LOOP;
+	N6  = 210 * LOOP;
+	N7  = 32 * LOOP;
+	N8  = 899 * LOOP;
+	N9  = 616 * LOOP;
+	N10 = 0;
+	N11 = 93 * LOOP;
+C
+C	Module 1: Simple identifiers
+C
+	X1  =  1.0;
+	X2  = -1.0;
+	X3  = -1.0;
+	X4  = -1.0;
+	for (I = 1; I <= N1; I++) {
+	    X1 = (X1 + X2 + X3 - X4) * T;
+	    X2 = (X1 + X2 - X3 + X4) * T;
+	    X3 = (X1 - X2 + X3 + X4) * T;
+	    X4 = (-X1+ X2 + X3 + X4) * T;
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N1,N1,N1,X1,X2,X3,X4);
+#endif
+C
+C	Module 2: Array elements
+C
+	E1[1] =  1.0;
+	E1[2] = -1.0;
+	E1[3] = -1.0;
+	E1[4] = -1.0;
+	for (I = 1; I <= N2; I++) {
+	    E1[1] = ( E1[1] + E1[2] + E1[3] - E1[4]) * T;
+	    E1[2] = ( E1[1] + E1[2] - E1[3] + E1[4]) * T;
+	    E1[3] = ( E1[1] - E1[2] + E1[3] + E1[4]) * T;
+	    E1[4] = (-E1[1] + E1[2] + E1[3] + E1[4]) * T;
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N2,N3,N2,E1[1],E1[2],E1[3],E1[4]);
+#endif
+C
+C	Module 3: Array as parameter
+C
+	for (I = 1; I <= N3; I++)
+		PA(E1);
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N3,N2,N2,E1[1],E1[2],E1[3],E1[4]);
+#endif
+C
+C	Module 4: Conditional jumps
+C
+	J = 1;
+	for (I = 1; I <= N4; I++) {
+		if (J == 1)
+			J = 2;
+		else
+			J = 3;
+		if (J > 2)
+			J = 0;
+		else
+			J = 1;
+		if (J < 1)
+			J = 1;
+		else
+			J = 0;
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N4,J,J,X1,X2,X3,X4);
+#endif
+C
+C	Module 5: Omitted
+C 	Module 6: Integer arithmetic
+C
+	J = 1;
+	K = 2;
+	L = 3;
+	for (I = 1; I <= N6; I++) {
+	    J = J * (K-J) * (L-K);
+	    K = L * K - (L-J) * K;
+	    L = (L-K) * (K+J);
+	    E1[L-1] = J + K + L;
+	    E1[K-1] = J * K * L;
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N6,J,K,E1[1],E1[2],E1[3],E1[4]);
+#endif
+C
+C	Module 7: Trigonometric functions
+C
+	X = 0.5;
+	Y = 0.5;
+	for (I = 1; I <= N7; I++) {
+		X = T * DATAN(T2*DSIN(X)*DCOS(X)/(DCOS(X+Y)+DCOS(X-Y)-1.0));
+		Y = T * DATAN(T2*DSIN(Y)*DCOS(Y)/(DCOS(X+Y)+DCOS(X-Y)-1.0));
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N7,J,K,X,X,Y,Y);
+#endif
+C
+C	Module 8: Procedure calls
+C
+	X = 1.0;
+	Y = 1.0;
+	Z = 1.0;
+	for (I = 1; I <= N8; I++)
+		P3(X,Y,&Z);
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N8,J,K,X,Y,Z,Z);
+#endif
+C
+C	Module 9: Array references
+C
+	J = 1;
+	K = 2;
+	L = 3;
+	E1[1] = 1.0;
+	E1[2] = 2.0;
+	E1[3] = 3.0;
+	for (I = 1; I <= N9; I++)
+		P0();
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N9,J,K,E1[1],E1[2],E1[3],E1[4]);
+#endif
+C
+C	Module 10: Integer arithmetic
+C
+	J = 2;
+	K = 3;
+	for (I = 1; I <= N10; I++) {
+	    J = J + K;
+	    K = J + K;
+	    J = K - J;
+	    K = K - J - J;
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N10,J,K,X1,X2,X3,X4);
+#endif
+C
+C	Module 11: Standard functions
+C
+	X = 0.75;
+	for (I = 1; I <= N11; I++)
+		X = DSQRT(DEXP(DLOG(X)/T1));
+#ifdef PRINTOUT
+	IF (JJ==II)POUT(N11,J,K,X,X,X,X);
+#endif
+C
+C      THIS IS THE END OF THE MAJOR LOOP.
+C
+	if (++JJ <= II)
+		goto IILOOP;
+C
+C      Stop benchmark timing at this point.
+C
+	finisec = time(0);
+C----------------------------------------------------------------
+C      Performance in Whetstone KIP's per second is given by
+C
+C	(100*LOOP*II)/TIME
+C
+C      where TIME is in seconds.
+C--------------------------------------------------------------------
+	printf("\n");
+	if (finisec-startsec <= 0) {
+		printf("Insufficient duration- Increase the LOOP count\n");
+		return(1);
+	printf("Loops: %ld, Iterations: %d, Duration: %ld sec.\n",
+			LOOP, II, finisec-startsec);
+	KIPS = (100.0*LOOP*II)/(float)(finisec-startsec);
+	if (KIPS >= 1000.0)
+		printf("C Converted Double Precision Whetstones: %.1f MIPS\n", KIPS/1000.0);
+	else
+		printf("C Converted Double Precision Whetstones: %.1f KIPS\n", KIPS);
+	if (continuous)
+		goto LCONT;
+	return(0);
+void
+PA(double E[])
+	J = 0;
+L10:
+	E[1] = ( E[1] + E[2] + E[3] - E[4]) * T;
+	E[2] = ( E[1] + E[2] - E[3] + E[4]) * T;
+	E[3] = ( E[1] - E[2] + E[3] + E[4]) * T;
+	E[4] = (-E[1] + E[2] + E[3] + E[4]) / T2;
+	J += 1;
+	if (J < 6)
+		goto L10;
+void
+P0(void)
+	E1[J] = E1[K];
+	E1[K] = E1[L];
+	E1[L] = E1[J];
+void
+P3(double X, double Y, double *Z)
+	double X1, Y1;
+	X1 = X;
+	Y1 = Y;
+	X1 = T * (X1 + Y1);
+	Y1 = T * (X1 + Y1);
+	*Z  = (X1 + Y1) / T2;
+#ifdef PRINTOUT
+void
+POUT(long N, long J, long K, double X1, double X2, double X3, double X4)
+	printf("%7ld %7ld %7ld %12.4e %12.4e %12.4e %12.4e\n",
+						N, J, K, X1, X2, X3, X4);
+#endif
1.8.4.5
