[PATCH] Always use GCC provided zlib
Sebastian Huber
Fri Mar 31 07:56:21 UTC 2017
Always use the GCC provided zlib to make the compiler as independent of
the host system as possible.
source-builder/config/gcc-common-1.cfg | 7 -------
1 file changed, 7 deletions(-)
diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
index e5bee9d..a07e844 100644
--- a/source-builder/config/gcc-common-1.cfg
+++ b/source-builder/config/gcc-common-1.cfg
@@ -129,12 +129,6 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
languages="$languages,objc"
%endif
-%if %{_host_os} == mingw32
- zlib_option=""
-%else
- zlib_option="--with-system-zlib"
-%endif
%{host_build_flags}
../${source_dir_gcc}/configure \
@@ -152,7 +146,6 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
--disable-libstdcxx-pch \
--with-gnu-as --with-gnu-ld --verbose \
--with-newlib \
- "$zlib_option" \
--disable-nls --without-included-gettext \
--disable-win32-registry \
--enable-version-specific-runtime-libs \
1.8.4.5
