[PATCH 2/2] Beagle i2c: Update Beaglebone i2c driver code
Sichen Zhao
1473996754 at qq.com
Fri Mar 31 05:42:22 UTC 2017
This patch modify the i2c code for Beaglebone Black based on PV works:
- bbb-i2c.c: Modify the interrupt handler, transfer funciton, read function, am335x_i2c_busbusy function etc. Add flush_fifo function
- include/i2c.h: Modify some macros, such as BBB_I2C_IRQ_ERROR
Now the i2c is working on Beaglebone Black, it can read the EEPROM information.
c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 378 +++++++++++-------------------
c/src/lib/libbsp/arm/beagle/include/i2c.h | 11 +-
2 files changed, 150 insertions(+), 239 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
index 6b790e5..4d22831 100644
--- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
+++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -21,88 +21,8 @@
#include <bsp/bbb-gpio.h>
-static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
- bool status =true;
- // We will check i2c_bus_id in am335x_i2c_bus_register
- // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
- if (bus->i2c_bus_id == I2C1) {
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- } else if (bus->i2c_bus_id == I2C2) {
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- } else {
- status = false;
- return status;
-/* ref. Table 21-4 I2C Clock Signals */
- For I2C1/2
- Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
- Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
-static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
-/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
-transition on the domain. */
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
- while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
-/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
-used for functions) may be gated according to the clock domain
-state. Functional clocks are guarantied to stay present. As long as in
-this configuration, power domain sleep transition cannot happen.*/
- /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
- AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
- while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
- AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
-/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
- AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
- while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
- AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
- AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
- while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
- AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
- while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
- (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
+static void flush_fifo(i2c_bus *base);
static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
@@ -303,43 +223,59 @@ static void I2C0ModuleClkConfig(void)
CM_WKUP_I2C0_CLKCTRL_IDLEST));
-void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
- // am335x_i2c_pinmux()
- // am335x_i2c1_i2c2_module_clk_config
static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
bool status;
+ int stat;
+ int timeout=I2C_TIMEOUT;
+ while ((stat = readw(®s->BBB_I2C_IRQSTATUS_RAW) &
+ AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--) {
+ writew(stat, ®s->BBB_I2C_IRQSTATUS);
+ udelay(100);
- if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
+ if (timeout <= 0) {
+ printf("Timed out in wait_for_bb: status=%04x\n",
+ stat);
+ status = true;
+ else
- status = true;
- } else {
- status = false;
+ writew(0xFFFF, ®s->BBB_I2C_IRQSTATUS); /* clear delayed stuff*/
+ status = false;
return status;
static void am335x_i2c_reset(bbb_i2c_bus *bus)
volatile bbb_i2c_regs *regs = bus->regs;
- printk("reset bus->reg is %x \n",bus->regs);
- /* Disable I2C module at the time of initialization*/
- /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
- printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
- mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
- mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
- //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
- //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
- can I clear all the interrupt here ?
- mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR), ??)
+ int timeout = I2C_TIMEOUT;
+ if (readw(®s->BBB_I2C_CON) & I2C_CON_EN) {
+ writew(0, ®s->BBB_I2C_CON);
+ udelay(50000);
+ writew(0x2, ®s->BBB_I2C_SYSC); /* for ES2 after soft reset */
+ udelay(1000);
+ writew(I2C_CON_EN, ®s->BBB_I2C_CON);
+ while (!(readw(®s->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
+ puts("ERROR: Timeout in soft-reset\n");
+ return;
+ udelay(1000);
@@ -368,7 +304,7 @@ static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
i2c_msg *msg;
- printk("Enter next_byte\n");
++bus->msgs;
--bus->msg_todo;
@@ -410,61 +346,26 @@ static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs, const i2c_msg *msgs, bool send_stop)
volatile unsigned int no_bytes;
- //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
- // No of data to be transmitted at a time
- REG(®s->BBB_I2C_CNT) = 0x02;
- no_bytes = REG(®s->BBB_I2C_CNT);
- // I2C Controller in Master Mode
- REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
- printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
+ int status;
- // Set Slave address & Master enable, bring out of reset
- REG(®s->BBB_I2C_SA) = msgs->addr;
- printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
- // clear status of all interrupts
- am335x_clean_interrupts(regs);
- printk("\n set memory address to read\n");
- // transmit interrupt is enabled
- am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
- printk("Enable transmit interrupt \n");
- //start condition
- REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
- printk("start transmission \n");
- while(am335x_i2c_busbusy(regs) == 0);
- printk("bus is free \n");
- printk("CNT : %x\n", no_bytes);
- while(0 != no_bytes);
- printk("total msg count for tranmission is zero \n");
- while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
+ REG(®s->BBB_I2C_CNT) = bus->current_msg_todo;
- printk("Enter read transfer \n");
- // No of data to be received at a time(msg_count!!)
- printk("msg_todo for read is %d \n",bus->msg_todo);
- REG(®s->BBB_I2C_CNT) = bus->msg_todo;
- //am335x_clean_interrupts(regs);
REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_MST;
- printk("Set master to receiver mode %x \n", REG(®s->BBB_I2C_CON));
// receive interrupt is enabled
am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY | AM335X_I2C_INT_STOP_CONDITION);
if (send_stop) {
// stop condition
- printk("stop to read\n");
REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
} else {
// start condition
- printk("start to read\n");
- printk("Exit read transfer\n");
@@ -473,85 +374,63 @@ static void am335x_i2c_continue_read_transfer(
- printk("enter continue read transfer \n");
bus->current_msg_byte[bus->already_transferred] = REG(®s->BBB_I2C_DATA);
bus->already_transferred++;
am335x_int_clear(regs,AM335X_I2C_INT_RECV_READY);
- printk("clear RRDY in continue read transfer\n");
if (bus->already_transferred == REG(®s->BBB_I2C_CNT)) {
- printk("continue read transfer finished \n");
- //am335x_i2c_setup_read_transfer(bus,regs,false);
am335x_i2c_masterint_disable(regs, AM335X_I2C_INT_RECV_READY);
- printk("disable RRDY in continue read transfer\n");
- printk("stop condition in continue read transfer %x\n",REG(®s->BBB_I2C_CON));
static void am335x_i2c_continue_write(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs)
- REG(®s->BBB_I2C_DATA) = 0x00;
- am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
- printk("clear XRDY continue write\n");
- if (bus->already_transferred == REG(®s->BBB_I2C_CNT)) {
- printk("\n finished transfer \n");
- am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
- printk("disable XRDY continue write \n");
- REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
- } else {
- printk("write memory address \n");
- REG(®s->BBB_I2C_DATA) = *bus->current_msg_byte;
- if (bus->already_transferred == bus->msg_todo) {
- printk("finished transfer \n");
- } else {
- printk("remaining byte \n");
- REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
- printk("%s",REG(®s->BBB_I2C_DATA));
- bus->already_transferred++;
+ writeb(0x0,®s->BBB_I2C_DATA);
+ writew(AM335X_I2C_IRQSTATUS_XRDY, ®s->BBB_I2C_IRQSTATUS);
-static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs)
+static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
- printk(" \n Enter write transfer \n");
// Following data count specify bytes to be transmitted
- // Already cleaned during reset
+ REG(®s->BBB_I2C_SA) = msgs->addr;
// I2C Controller in Master transmitter Mode
REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
- printk("enable master in transmiter mode setup write %x\n",REG(®s->BBB_I2C_CON));
+ am335x_clean_interrupts(regs);
- printk("enable XRDY setup write\n");
+ am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
//start condition
- printk("set start condition in setup write %x \n",REG(®s->BBB_I2C_CON));
- printk("CNT in setup write : %x \n",REG(®s->BBB_I2C_CNT));
- printk("setup write msg_todo %x \n",bus->current_todo);
- printk("check whether ???\n");
- printk("RAW = %x",REG(®s->BBB_I2C_IRQSTATUS_RAW));
+ while(am335x_i2c_busbusy(regs)==0);
while( !((am335x_i2c_intrawstatus(regs)) & (AM335X_I2C_IRQSTATUS_ARDY)));
- printk("exit setup write \n");
@@ -562,9 +441,7 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
bool send_stop = false;
uint32_t i;
- printk("Enter setup transfer\n");
bus->current_todo = msgs[0].len;
for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
bus->current_todo += msgs[i].len;
@@ -574,18 +451,22 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
am335x_i2c_set_address_size(msgs,regs);
- bus->read = ((bus->read == true) ? 0:1);
+ bus->read = (msgs->flags & I2C_M_RD) != 0;
bus->already_transferred = (bus->read == true) ? 0 : 1;
if (bus->read) {
if (REG(®s->BBB_I2C_CNT) == 1) {
send_stop = true;
- printk("configure to read bus\n");
am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
} else {
- printk("configure to write bus\n");
- am335x_i2c_setup_write_transfer(bus,regs);
+ am335x_i2c_setup_write_transfer(bus,regs,msgs);
@@ -597,42 +478,45 @@ static void am335x_i2c_interrupt(void *arg)
/* get status of enabled interrupts */
uint32_t irqstatus = REG(®s->BBB_I2C_IRQSTATUS);
bool done = false;
- printk("\n inside interrupt function \n");
/* Clear all enabled interrupt except receive ready and transmit ready interrupt in status register */
- REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~(AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
- printk("\n irqstatus = %x \n",REG(®s->BBB_I2C_IRQSTATUS));
+ REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
if (irqstatus & AM335X_I2C_INT_RECV_READY) {
- printk("\nInside receive interrupt\n");
+ delay_bbb_i2c
am335x_i2c_continue_read_transfer(bus, regs);
if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
- printk("\ninside transmit interrupt \n");
am335x_i2c_continue_write(bus,regs);
if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
done = true;
- printk("inside NACK\n");
am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
+ done = true;
+ writew(I2C_STAT_ARDY, ®s->BBB_I2C_IRQSTATUS);
if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
done = true;
- printk("inside BF \n ");
if (done) {
uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
- printk("interrupt done \n");
am335x_i2c_next_byte(bus);
- if (bus->msg_todo == 0 || err != 0) {
+ if (bus->msg_todo == 0 ) {
rtems_status_code sc;
- // am335x_i2c_disable_interrupts(regs);
am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY | AM335X_I2C_IRQSTATUS_BF));
REG(®s->BBB_I2C_IRQSTATUS) = err;
@@ -641,6 +525,7 @@ static void am335x_i2c_interrupt(void *arg)
_Assert(sc == RTEMS_SUCCESSFUL);
(void) sc;
} else {
am335x_i2c_setup_transfer(bus, regs);
@@ -652,7 +537,6 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
volatile bbb_i2c_regs *regs;
uint32_t i;
- printk("\n enter transfer ");
rtems_task_wake_after(1);
@@ -668,11 +552,11 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
bus->msgs = &msgs[0];
bus->msg_todo = msg_count;
- printk("total msg = msg_count : %x \n",bus->msg_todo);
bus->current_msg_todo = msgs[0].len;// current data size
bus->current_msg_byte = msgs[0].buf;// current data
- printk("\n current_msg_todo %x \n ",msgs[0].len);
- printk("\n current_msg_byte %x \n ",msgs[0].buf);
bus->task_id = rtems_task_self();
regs = bus->regs;
@@ -688,8 +572,6 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
return -ETIMEDOUT;
- printk("exit transfer\n");
- // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
return 0;
@@ -699,21 +581,17 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
uint32_t prescaler,divider;
- printk("set clock start\n");
prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
- printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
- printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
- //mmio_write((®s->BBB_I2C_PSC), prescaler);
REG(&bus->regs->BBB_I2C_PSC) = prescaler;
divider = BBB_I2C_INTERNAL_CLK/(2*clock);
- printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
- //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
- //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
- printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
- printk("set clock end \n");
return 0;
@@ -721,11 +599,11 @@ static void am335x_i2c_destroy(i2c_bus *base)
bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
- printk(" starting destroy\n");
sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
(void)sc;
- printk("end destroy\n");
i2c_bus_destroy_and_free(&bus->base);
@@ -759,7 +637,7 @@ int am335x_i2c_bus_register(
// 4. configure bus speed
bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
- printk("Before set clock \n");
err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
if (err != 0) {
@@ -771,7 +649,11 @@ int am335x_i2c_bus_register(
//bring I2C out of reset
- REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
+ udelay(1000);
+ flush_fifo(&bus->base);
+ writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
// 5. Start interrupt service routine & one interrupt at a time
sc = rtems_interrupt_handler_install(
@@ -791,6 +673,30 @@ int am335x_i2c_bus_register(
bus->base.transfer = am335x_i2c_transfer;
bus->base.set_clock = am335x_i2c_set_clock;
bus->base.destroy = am335x_i2c_destroy;
- printk("exit register\n");
return i2c_bus_register(&bus->base,bus_path);
+ bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
+ volatile bbb_i2c_regs *regs = bus->regs;
+ int stat;
+ * note: if you try and read data when its not there or ready
+ * you get a bus error
+ while (1) {
+ stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
+ if (stat == I2C_STAT_RRDY) {
+ readb(&bus->regs->BBB_I2C_DATA);
+ writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
+ udelay(1000);
+ } else
+ break;
diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
index d4a9e32..a4fcf21 100644
--- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
+++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
@@ -132,11 +132,11 @@ extern "C" {
#define DISP_LINE_LEN 128
-#define I2C_TIMEOUT 1000
+#define I2C_TIMEOUT 500
#define I2C_BUS_MAX 3
-#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
+#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
#define I2C_DEFAULT_BASE I2C_BASE1
@@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
| AM335X_I2C_IRQSTATUS_ARDY \
| AM335X_I2C_IRQSTATUS_RRDY \
| AM335X_I2C_IRQSTATUS_XRDY \
- | AM335X_I2C_IRQSTATUS_XUDF)
+ | AM335X_I2C_IRQSTATUS_XUDF )
#define BBB_I2C_IRQ_USED \
( BBB_I2C_IRQ_ERROR \
@@ -378,6 +378,8 @@ static inline rtems_status_code beagle_i2c_read(
#define MODE2 2
#define MODE3 3
+#define delay_bbb_i2c printf(" ");
typedef enum {
I2C0,
I2C1,
@@ -478,6 +480,9 @@ static inline int bbb_register_i2c_2(void)
#ifdef __cplusplus
#endif /* __cplusplus */
2.7.4
