RTEMS 4.11.2 milestone date
    Gedare Bloom
    gedare at rtems.org
    Thu Mar 16 23:58:35 UTC 2017
On Thu, Mar 16, 2017 at 7:52 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 16, 2017 at 6:22 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 17/03/2017 07:48, Joel Sherrill wrote:
>>> On Thu, Mar 16, 2017 at 3:22 PM, Chris Johns <chrisj at rtems.org
>>> <mailto:chrisj at rtems.org>> wrote:
>>>     On 17/03/2017 01:06, Joel Sherrill wrote:
>>>         On Thu, Mar 16, 2017 at 4:43 AM, Chris Johns <chrisj at rtems.org
>>>         <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>>>             If you have anything you would like in the release please
>>>         make sure you
>>>             have created a ticket and assigned it to the milestone.
>>>         Are the 4.11 tools buildable on the newer hosts that you and I
>>>         have had troubles with the 4.12 tools? I think specifically
>>>         qemu and gdb are troublesome.
>>>     Good point, I am not sure. I will check FreeBSD 11.0 and raise a
>>>     ticket if there is a problem.
>>> FWIW assuming qemu on the master is the same as on 4.11, it built find
>>> on a new CentOS 7 install.
>> I do not know if they are the same. I will check what there is in 4.11 on
>> FreeBSD 10.3 and 11.0.
>>> But that's still at gcc 4.8. Something with a new
>>> enough gcc will have trouble.
>> If tickets are raised and patches supplied in time they may make RC1
>> otherwise they will have to wait for the next release.
> Agreed.
>>> And you have the gdb powerpc issue on FreeBSD which might occur.
>> Is there a ticket for this? I am struggling to remember what the problem
>> is. I do not use any PPC devices and it is not a primary focus for me.
> You couldn't build powerpc gdb because of the error symbol. There was
> something
> with max_align_t but I think that got resolved.
https://sourceware.org/bugzilla/show_bug.cgi?id=21206
>>> I don't know of any code issues. We all are good at filing those. :)
>> I would like to package and release what we have at the set dates rather
>> than hold the release while everything possible is fixed.
> +1
4.12 should be on the table, too
>> Chris
> devel mailing list
> devel at rtems.org
