RTEMS 4.11.2 milestone date
Thu Mar 16 23:52:28 UTC 2017
On Thu, Mar 16, 2017 at 6:22 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/03/2017 07:48, Joel Sherrill wrote:
>> On Thu, Mar 16, 2017 at 3:22 PM, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>     On 17/03/2017 01:06, Joel Sherrill wrote:
>>         On Thu, Mar 16, 2017 at 4:43 AM, Chris Johns <chrisj at rtems.org
>>         <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>>             If you have anything you would like in the release please
>>         make sure you
>>             have created a ticket and assigned it to the milestone.
>>         Are the 4.11 tools buildable on the newer hosts that you and I
>>         have had troubles with the 4.12 tools? I think specifically
>>         qemu and gdb are troublesome.
>>     Good point, I am not sure. I will check FreeBSD 11.0 and raise a
>>     ticket if there is a problem.
>> FWIW assuming qemu on the master is the same as on 4.11, it built find
>> on a new CentOS 7 install.
> I do not know if they are the same. I will check what there is in 4.11 on
> FreeBSD 10.3 and 11.0.
> But that's still at gcc 4.8. Something with a new
>> enough gcc will have trouble.
> If tickets are raised and patches supplied in time they may make RC1
> otherwise they will have to wait for the next release.
Agreed.
>> And you have the gdb powerpc issue on FreeBSD which might occur.
> Is there a ticket for this? I am struggling to remember what the problem
> is. I do not use any PPC devices and it is not a primary focus for me.
You couldn't build powerpc gdb because of the error symbol. There was
something
with max_align_t but I think that got resolved.
> I don't know of any code issues. We all are good at filing those. :)
> I would like to package and release what we have at the set dates rather
> than hold the release while everything possible is fixed.
+1
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170316/d00fbc03/attachment-0002.html>
