[PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
Kirspel, Kevin Kevin-Kirspel at idexx.com
Mon Mar 20 18:01:45 UTC 2017
Actually the best thing to do is change the structure member name and fix up any access to that member.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Kirspel, Kevin
Sent: Monday, March 20, 2017 1:50 PM
To: devel at rtems.org
Subject: RE: [PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
I tracked the arm failure down to a header file (s3c2410.h) that contains a structure that has a member with the same name as a termios #define. Re-ordering the include file declarations in each affected C file will fix the problem (I’m not sure that’s the best solution but it will do for now).  I am going to build all the tool chains so I can check the rest of the BSPs.  Sebastian found another issue with a SH BSP.
Kevin Kirspel
Idexx Roswell
Roswell GA 30076
Fax: (770)-510-4445
Sent: Monday, March 20, 2017 1:33 PM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com<mailto:Kevin-Kirspel at idexx.com>>
Cc: devel at rtems.org<mailto:devel at rtems.org>
Subject: Re: [PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
I just built all BSPs and didn't see any failures.
Sebastian.. what was going on with the build you saw fail?
--joel
On Mon, Mar 20, 2017 at 9:19 AM, Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
On Tue, Mar 14, 2017 at 8:54 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com<mailto:Kevin-Kirspel at idexx.com>> wrote:
I tested it against xilinx_zynq_a9_qemu.  I'm not sure it exists, but if there is a way to compile the patch against every (or most) BSP then we could ensure no BSP is broken.
There are scripts in rtems-testing/rtems to ease testing of a single configuation
on all BSPs. Or a variety of configurations on a single BSP. I use them to
generate the warnings reports that I periodically announce.
I am seeing if all BSPs build now. Give me a few hours.
--joel
Kevin Kirspel
Idexx Roswell
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642<tel:%28770%29-510-4444%20ext.%2081642>
Direct: (770)-688-1642<tel:%28770%29-688-1642>
Fax: (770)-510-4445<tel:%28770%29-510-4445>
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>]
Sent: Tuesday, March 14, 2017 9:42 AM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com<mailto:Kevin-Kirspel at idexx.com>>; devel at rtems.org<mailto:devel at rtems.org>
The patch set looks good after a rough review. I will check this in in two or three days if nobody objects.
Phone   : +49 89 189 47 41-16<tel:%2B49%2089%20189%2047%2041-16>
Fax     : +49 89 189 47 41-09<tel:%2B49%2089%20189%2047%2041-09>
E-Mail  : sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>
devel mailing list
http://lists.rtems.org/mailman/listinfo/devel<https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=Rh9qB1wyRTbNNWuecoD2ZnxQG4zzUt_g-GM295-SibA&s=DM2kkkY3t3lj7LgOPBCejJ85dfSKMbJxO7971XSRMJI&e=>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170320/8b937b45/attachment-0002.html>
