[PATCH 29/30] leon, greth: SMP support by using spin-lock protection
Daniel Hellstrom daniel at gaisler.com
Tue May 2 08:16:08 UTC 2017
On 2017-05-02 10:00, Sebastian Huber wrote:
> On 02/05/17 09:32, Daniel Hellstrom wrote:
>> On 2017-05-02 07:48, Sebastian Huber wrote:
>>> On 13/04/17 21:31, Daniel Hellstrom wrote:
>>>>   c/src/lib/libbsp/sparc/shared/net/greth.c | 134
>>>>   1 file changed, 71 insertions(+), 63 deletions(-)
>>>> diff --git a/c/src/lib/libbsp/sparc/shared/net/greth.c
>>>> b/c/src/lib/libbsp/sparc/shared/net/greth.c
>>>> index 7726799..9af2de2 100644
>>>> --- a/c/src/lib/libbsp/sparc/shared/net/greth.c
>>>> +++ b/c/src/lib/libbsp/sparc/shared/net/greth.c
>>>> @@ -41,6 +41,18 @@
>>>>   #include <netinet/in.h>
>>>>   #include <netinet/if_ether.h>
>>>>   +#include <rtems/score/isrlock.h> /* spin-lock */
>>>> +/* map via ISR lock: */
>>>> +#define SPIN_DECLARE(lock) ISR_LOCK_MEMBER(lock)
>>>> +#define SPIN_INIT(lock, name) _ISR_lock_Initialize(lock, name)
>>>> +#define SPIN_LOCK(lock, level) _ISR_lock_Acquire_inline(lock, &level)
>>>> +#define SPIN_LOCK_IRQ(lock, level)
>>>> _ISR_lock_ISR_disable_and_acquire(lock, &level)
>>>> +#define SPIN_UNLOCK(lock, level) _ISR_lock_Release_inline(lock,
>>>> &level)
>>>> +#define SPIN_UNLOCK_IRQ(lock, level)
>>>> _ISR_lock_Release_and_ISR_enable(lock, &level)
>>>> +#define SPIN_IRQFLAGS(k) ISR_lock_Context k
>>>> +#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
>>> Could you please use the rtems_interrupt_lock_*() API and not the
>>> internal _ISR_lock_*() stuff.
>> Thanks. I think the reason for this may come from that the inline
>> equivalent. I will add a patch which adds inline macros to the
>> rtems_interrupt_lock interface instead. I can't see any reason why
>> that can not be supported?
> What do you mean with inline equivalent?
I mean we use _ISR_lock_Acquire_inline(lock, &level) from the ISR to
avoid an extra function call. But there is only a
rtems_interrupt_lock_acquire_isr() no
rtems_interrupt_lock_acquire_INLINE_isr() which we would like to use.
