[PATCH 29/30] leon, greth: SMP support by using spin-lock protection
Tue May 2 08:00:27 UTC 2017
On 02/05/17 09:32, Daniel Hellstrom wrote:
> On 2017-05-02 07:48, Sebastian Huber wrote:
>> On 13/04/17 21:31, Daniel Hellstrom wrote:
>>>   c/src/lib/libbsp/sparc/shared/net/greth.c | 134
>>>   1 file changed, 71 insertions(+), 63 deletions(-)
>>> diff --git a/c/src/lib/libbsp/sparc/shared/net/greth.c
>>> b/c/src/lib/libbsp/sparc/shared/net/greth.c
>>> index 7726799..9af2de2 100644
>>> --- a/c/src/lib/libbsp/sparc/shared/net/greth.c
>>> +++ b/c/src/lib/libbsp/sparc/shared/net/greth.c
>>> @@ -41,6 +41,18 @@
>>>   #include <netinet/in.h>
>>>   #include <netinet/if_ether.h>
>>>   +#include <rtems/score/isrlock.h> /* spin-lock */
>>> +/* map via ISR lock: */
>>> +#define SPIN_DECLARE(lock) ISR_LOCK_MEMBER(lock)
>>> +#define SPIN_INIT(lock, name) _ISR_lock_Initialize(lock, name)
>>> +#define SPIN_LOCK(lock, level) _ISR_lock_Acquire_inline(lock, &level)
>>> +#define SPIN_LOCK_IRQ(lock, level)
>>> _ISR_lock_ISR_disable_and_acquire(lock, &level)
>>> +#define SPIN_UNLOCK(lock, level) _ISR_lock_Release_inline(lock,
>>> &level)
>>> +#define SPIN_UNLOCK_IRQ(lock, level)
>>> _ISR_lock_Release_and_ISR_enable(lock, &level)
>>> +#define SPIN_IRQFLAGS(k) ISR_lock_Context k
>>> +#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
>> Could you please use the rtems_interrupt_lock_*() API and not the
>> internal _ISR_lock_*() stuff.
> Thanks. I think the reason for this may come from that the inline
> equivalent. I will add a patch which adds inline macros to the
> rtems_interrupt_lock interface instead. I can't see any reason why
> that can not be supported?
What do you mean with inline equivalent?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
