[PATCH v2 0/2] Zynq7000 series device configuration driver
Patrick Gauvin
pggauvin at gmail.com
Wed May 3 19:51:17 UTC 2017
v2 Change Summary (primarily from Chris's feedback):
SLCR:
- Clean up register accesses.
- Add mask for FPGA clock resets.
Device Config:
- Remove DMA buffer static global.
- Remove register map as an argument (only one instance ever).
- Remove bitfile length related code.
- Add bitfile header check.
- Default the write behavior to writing an entire bitfile.
- Add BIN file header check in default write mode.
- Added ioctl to switch write mode to to unrestricted.
- Remove non-symbolic '| 1' for DMA source and destination addresses.
- Use RTEMS system events instead of semaphores for interrupt waits.
- Fix PCAP init failure when the PL is already programmed.
General:
- More documentation and error values.
These changes do not include a secure loading check. The check I saw was
to use the PCAP to read the PART_SECURED bit in the internal STAT register
after the PL is programmed. I still need to test if that sort of access is
allowed when a secure bitfile is loaded. For now I just have warnings in
comments that secure loading is not supported.
Please let me know if I've missed anything or you spot anything new.
Patrick Gauvin (2):
bsp/xilinx-zynq: Add SLCR driver
bsp/xilinx-zynq: Add device configuration driver
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 10 +
.../libbsp/arm/xilinx-zynq/devcfg/zynq-devcfg.c | 896 +++++++++++++++++++++
.../arm/xilinx-zynq/include/zynq-devcfg-regs.h | 197 +++++
.../libbsp/arm/xilinx-zynq/include/zynq-devcfg.h | 152 ++++
.../arm/xilinx-zynq/include/zynq-slcr-regs.h | 111 +++
.../lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h | 91 +++
c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am | 16 +
c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c | 101 +++
8 files changed, 1574 insertions(+)
create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/devcfg/zynq-devcfg.c
create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-devcfg-regs.h
create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-devcfg.h
create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr-regs.h
create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-slcr.h
create mode 100644 c/src/lib/libbsp/arm/xilinx-zynq/slcr/zynq-slcr.c
2.7.4
