GCC 7.1 Released
Daniel Hellstrom daniel at gaisler.com
Tue May 9 12:54:01 UTC 2017
On 2017-05-03 07:11, Sebastian Huber wrote:
> On 03/05/17 03:33, Chris Johns wrote:
>> On 3/5/17 3:04 am, Joel Sherrill wrote:
>>> >Thoughts on upgrading the 4.12 tools?
>> Looks good with updated dependent packages for gcc and with
>> binutils-2.28. There are no build failures for just the tests. Attached
>> is the warnings report which looks good if the networking warnings are
>> ignored.
> I would rather use the GCC 6 which received some bug fix releases in
> the mean time and was used most of the time of the RTEMS 4.12
> development. For RTEMS 5 I would use GCC 8.
For the gaisler toolchain we are currently planning on using GCC 7.1.
