[PATCH] tests: CONFIGURE_DISABLE_SMP_CONFIGURATION
Sebastian Huber
Fri May 12 10:24:14 UTC 2017
Mark tests that require review due to
CONFIGURE_DISABLE_SMP_CONFIGURATION.
Update #3020.
testsuites/libtests/block08/system.h | 1 +
testsuites/libtests/cpuuse/system.h | 1 +
testsuites/libtests/rtmonuse/system.h | 1 +
testsuites/libtests/termios05/init.c | 1 +
testsuites/psxtests/psx05/system.h | 1 +
testsuites/sptests/sp01/system.h | 1 +
testsuites/sptests/sp04/system.h | 1 +
testsuites/sptests/sp07/system.h | 1 +
testsuites/sptests/sp08/init.c | 1 +
testsuites/sptests/sp12/system.h | 1 +
testsuites/sptests/sp13/system.h | 1 +
testsuites/sptests/sp14/system.h | 1 +
testsuites/sptests/sp16/system.h | 1 +
testsuites/sptests/sp20/system.h | 1 +
testsuites/sptests/sp37/system.h | 1 +
testsuites/sptests/sp65/init.c | 1 +
testsuites/sptests/spcbssched01/system.h | 1 +
testsuites/sptests/spcbssched02/system.h | 1 +
testsuites/sptests/spcbssched03/system.h | 1 +
testsuites/sptests/spedfsched01/system.h | 1 +
testsuites/sptests/spedfsched02/system.h | 1 +
testsuites/sptests/spedfsched03/system.h | 1 +
testsuites/sptests/spfatal29/testcase.h | 1 +
testsuites/sptests/spfifo03/init.c | 1 +
testsuites/sptests/spfifo05/init.c | 1 +
testsuites/sptests/spintrcritical06/init.c | 1 +
testsuites/sptests/spintrcritical15/init.c | 1 +
testsuites/sptests/spmrsp01/init.c | 1 +
testsuites/sptests/spsimplesched02/init.c | 1 +
testsuites/tmtests/tm04/system.h | 1 +
testsuites/tmtests/tm08/system.h | 1 +
testsuites/tmtests/tm15/system.h | 1 +
testsuites/tmtests/tm20/system.h | 1 +
testsuites/tmtests/tm22/system.h | 1 +
testsuites/tmtests/tm24/system.h | 1 +
35 files changed, 35 insertions(+)
diff --git a/testsuites/libtests/block08/system.h b/testsuites/libtests/block08/system.h
index f2ba2ec..5c734cd 100644
--- a/testsuites/libtests/block08/system.h
+++ b/testsuites/libtests/block08/system.h
@@ -54,6 +54,7 @@ rtems_task Init(
#define CONFIGURE_EXTRA_TASK_STACKS (13 * RTEMS_MINIMUM_STACK_SIZE)
+#warning "https://devel.rtems.org/ticket/3020"
#define CONFIGURE_DISABLE_SMP_CONFIGURATION
#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/cpuuse/system.h b/testsuites/libtests/cpuuse/system.h
index 562f2db..78c2553 100644
--- a/testsuites/libtests/cpuuse/system.h
+++ b/testsuites/libtests/cpuuse/system.h
@@ -50,6 +50,7 @@ void Task_switch(
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/libtests/rtmonuse/system.h b/testsuites/libtests/rtmonuse/system.h
index b7bb5f1..eb66fb1 100644
--- a/testsuites/libtests/rtmonuse/system.h
+++ b/testsuites/libtests/rtmonuse/system.h
@@ -48,6 +48,7 @@ void Get_all_counters( void );
#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/libtests/termios05/init.c b/testsuites/libtests/termios05/init.c
index e9f1531..ae72e91 100644
--- a/testsuites/libtests/termios05/init.c
+++ b/testsuites/libtests/termios05/init.c
@@ -166,6 +166,7 @@ rtems_task Init(
#define CONFIGURE_INIT
diff --git a/testsuites/psxtests/psx05/system.h b/testsuites/psxtests/psx05/system.h
index a3615d4..ab726ea 100644
--- a/testsuites/psxtests/psx05/system.h
+++ b/testsuites/psxtests/psx05/system.h
@@ -43,6 +43,7 @@ void *Task_3(
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index 68f8277..5104327 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -31,6 +31,7 @@ rtems_task Task_1_through_3(
#define CONFIGURE_EXTRA_TASK_STACKS (4 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_MAXIMUM_TASKS 4
diff --git a/testsuites/sptests/sp04/system.h b/testsuites/sptests/sp04/system.h
index 9606368..6aca983 100644
--- a/testsuites/sptests/sp04/system.h
+++ b/testsuites/sptests/sp04/system.h
@@ -52,6 +52,7 @@ void Task_switch(
#define CONFIGURE_MAXIMUM_TIMERS 1
diff --git a/testsuites/sptests/sp07/system.h b/testsuites/sptests/sp07/system.h
index 3f8cb26..acadd35 100644
--- a/testsuites/sptests/sp07/system.h
+++ b/testsuites/sptests/sp07/system.h
@@ -74,6 +74,7 @@ void Task_exit_extension(
#define CONFIGURE_MAXIMUM_TASKS 5
diff --git a/testsuites/sptests/sp08/init.c b/testsuites/sptests/sp08/init.c
index 2364c70..45afb60 100644
--- a/testsuites/sptests/sp08/init.c
+++ b/testsuites/sptests/sp08/init.c
@@ -300,6 +300,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp12/system.h b/testsuites/sptests/sp12/system.h
index 299169f..0767ea5 100644
--- a/testsuites/sptests/sp12/system.h
+++ b/testsuites/sptests/sp12/system.h
@@ -65,6 +65,7 @@ rtems_task Task5(
#define CONFIGURE_EXTRA_TASK_STACKS (6 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index e8632e4..a515856 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -97,6 +97,7 @@ TEST_EXTERN rtems_name Queue_name[ 4 ]; /* array of queue names */
#define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp14/system.h b/testsuites/sptests/sp14/system.h
index 3a63a8d..3822175 100644
--- a/testsuites/sptests/sp14/system.h
+++ b/testsuites/sptests/sp14/system.h
@@ -51,6 +51,7 @@ rtems_task Task_2(
#define CONFIGURE_EXTRA_TASK_STACKS (1 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp16/system.h b/testsuites/sptests/sp16/system.h
index a812663..70e5837 100644
--- a/testsuites/sptests/sp16/system.h
+++ b/testsuites/sptests/sp16/system.h
@@ -54,6 +54,7 @@ rtems_task Task5(
diff --git a/testsuites/sptests/sp20/system.h b/testsuites/sptests/sp20/system.h
index cbc926a..3cd24a3 100644
--- a/testsuites/sptests/sp20/system.h
+++ b/testsuites/sptests/sp20/system.h
@@ -47,6 +47,7 @@ void Get_all_counters( void );
diff --git a/testsuites/sptests/sp37/system.h b/testsuites/sptests/sp37/system.h
index 67a62d2..964cd6b 100644
--- a/testsuites/sptests/sp37/system.h
+++ b/testsuites/sptests/sp37/system.h
@@ -39,6 +39,7 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_TASKS 2
diff --git a/testsuites/sptests/sp65/init.c b/testsuites/sptests/sp65/init.c
index 09c64b9..e2b2189 100644
--- a/testsuites/sptests/sp65/init.c
+++ b/testsuites/sptests/sp65/init.c
@@ -145,6 +145,7 @@ rtems_task Task_1(
diff --git a/testsuites/sptests/spcbssched01/system.h b/testsuites/sptests/spcbssched01/system.h
index 813a7a0..20788d1 100644
--- a/testsuites/sptests/spcbssched01/system.h
+++ b/testsuites/sptests/spcbssched01/system.h
@@ -37,6 +37,7 @@ rtems_task Task_1_through_3(
diff --git a/testsuites/sptests/spcbssched02/system.h b/testsuites/sptests/spcbssched02/system.h
index 302b9b5..601ae75 100644
--- a/testsuites/sptests/spcbssched02/system.h
+++ b/testsuites/sptests/spcbssched02/system.h
@@ -43,6 +43,7 @@ rtems_task Task_Periodic(
#define CONFIGURE_SCHEDULER_CBS
diff --git a/testsuites/sptests/spcbssched03/system.h b/testsuites/sptests/spcbssched03/system.h
index 7ce4884..009954f 100644
--- a/testsuites/sptests/spcbssched03/system.h
+++ b/testsuites/sptests/spcbssched03/system.h
@@ -47,6 +47,7 @@ rtems_task Tasks_Aperiodic(
diff --git a/testsuites/sptests/spedfsched01/system.h b/testsuites/sptests/spedfsched01/system.h
index e673b1f..1db191f 100644
--- a/testsuites/sptests/spedfsched01/system.h
+++ b/testsuites/sptests/spedfsched01/system.h
diff --git a/testsuites/sptests/spedfsched02/system.h b/testsuites/sptests/spedfsched02/system.h
index cbdb7ad..afc4466 100644
--- a/testsuites/sptests/spedfsched02/system.h
+++ b/testsuites/sptests/spedfsched02/system.h
@@ -49,6 +49,7 @@ void Get_all_counters( void );
#define CONFIGURE_SCHEDULER_EDF
diff --git a/testsuites/sptests/spedfsched03/system.h b/testsuites/sptests/spedfsched03/system.h
index ec5af82..98beddd 100644
--- a/testsuites/sptests/spedfsched03/system.h
+++ b/testsuites/sptests/spedfsched03/system.h
diff --git a/testsuites/sptests/spfatal29/testcase.h b/testsuites/sptests/spfatal29/testcase.h
index 87545f7..4217df5 100644
--- a/testsuites/sptests/spfatal29/testcase.h
+++ b/testsuites/sptests/spfatal29/testcase.h
@@ -19,6 +19,7 @@
static void timer(rtems_id id, void *arg)
diff --git a/testsuites/sptests/spfifo03/init.c b/testsuites/sptests/spfifo03/init.c
index 5aa4800..e8205cd 100644
--- a/testsuites/sptests/spfifo03/init.c
+++ b/testsuites/sptests/spfifo03/init.c
@@ -217,6 +217,7 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_FIFOS 1
diff --git a/testsuites/sptests/spfifo05/init.c b/testsuites/sptests/spfifo05/init.c
index a5ce313..fde6664 100644
--- a/testsuites/sptests/spfifo05/init.c
+++ b/testsuites/sptests/spfifo05/init.c
@@ -272,6 +272,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical06/init.c b/testsuites/sptests/spintrcritical06/init.c
index 423e4b5..f7ec5e4 100644
--- a/testsuites/sptests/spintrcritical06/init.c
+++ b/testsuites/sptests/spintrcritical06/init.c
@@ -139,6 +139,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical15/init.c b/testsuites/sptests/spintrcritical15/init.c
index 72e4832..09c0175 100644
--- a/testsuites/sptests/spintrcritical15/init.c
+++ b/testsuites/sptests/spintrcritical15/init.c
@@ -111,6 +111,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spmrsp01/init.c b/testsuites/sptests/spmrsp01/init.c
index bf144a9..db03e91 100644
--- a/testsuites/sptests/spmrsp01/init.c
+++ b/testsuites/sptests/spmrsp01/init.c
@@ -335,6 +335,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index 884a3ab..174c13d 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
@@ -156,6 +156,7 @@ rtems_task Init(
#define CONFIGURE_INIT_TASK_PRIORITY 4
diff --git a/testsuites/tmtests/tm04/system.h b/testsuites/tmtests/tm04/system.h
index 9147efb..a4bd9f4 100644
--- a/testsuites/tmtests/tm04/system.h
+++ b/testsuites/tmtests/tm04/system.h
@@ -33,6 +33,7 @@ rtems_task Init(
diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
index e6af3c1..b1fb719 100644
--- a/testsuites/tmtests/tm08/system.h
+++ b/testsuites/tmtests/tm08/system.h
@@ -32,6 +32,7 @@ rtems_task Init(
diff --git a/testsuites/tmtests/tm15/system.h b/testsuites/tmtests/tm15/system.h
index 47d0121..41f67c0 100644
--- a/testsuites/tmtests/tm15/system.h
+++ b/testsuites/tmtests/tm15/system.h
@@ -34,6 +34,7 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of task ids */
diff --git a/testsuites/tmtests/tm20/system.h b/testsuites/tmtests/tm20/system.h
index 4344d53..ffdeea2 100644
--- a/testsuites/tmtests/tm20/system.h
+++ b/testsuites/tmtests/tm20/system.h
@@ -37,6 +37,7 @@ rtems_id Task_id[ OPERATION_COUNT+1 ]; /* array of task ids */
diff --git a/testsuites/tmtests/tm22/system.h b/testsuites/tmtests/tm22/system.h
index 89c7138..4e421e9 100644
--- a/testsuites/tmtests/tm22/system.h
+++ b/testsuites/tmtests/tm22/system.h
@@ -38,6 +38,7 @@ rtems_task Init(
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(100, MESSAGE_SIZE )
diff --git a/testsuites/tmtests/tm24/system.h b/testsuites/tmtests/tm24/system.h
index dc4fac4..efbf502 100644
--- a/testsuites/tmtests/tm24/system.h
+++ b/testsuites/tmtests/tm24/system.h
1.8.4.5
