[PATCH 10/11] Add tests for USB keyboard and mouse as well as EVDEV
Kevin Kirspel kevin-kirspel at idexx.com
Mon May 15 17:26:37 UTC 2017
 testsuite/evdev01/init.c    | 764 ++++++++++++++++++++++++++++++++++++++++++++
 testsuite/usbkbd01/init.c   | 278 ++++++++++++++++
 testsuite/usbmouse01/init.c | 283 ++++++++++++++++
 3 files changed, 1325 insertions(+)
 create mode 100644 testsuite/evdev01/init.c
 create mode 100644 testsuite/usbkbd01/init.c
 create mode 100644 testsuite/usbmouse01/init.c
diff --git a/testsuite/evdev01/init.c b/testsuite/evdev01/init.c
new file mode 100644
index 0000000..6daf581
--- /dev/null
+++ b/testsuite/evdev01/init.c
@@ -0,0 +1,764 @@
+ * COPYRIGHT (c) 2017 Kevin Kirspel
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/malloc.h>
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <errno.h>
+#include <sys/stat.h>
+#include <dev/evdev/input.h>
+#include <dev/evdev/evdev.h>
+#include <fcntl.h>
+#include <dirent.h>
+#include <rtems/console.h>
+#include <rtems/shell.h>
+#include <rtems/bsd/bsd.h>
+#define TEST_NAME "LIBBSD EVDEV"
+#define PRIO_OPEN           (RTEMS_MAXIMUM_PRIORITY - 12)
+#define PRIO_KEYBOARD       (RTEMS_MAXIMUM_PRIORITY - 11)
+#define PRIO_MOUSE          (RTEMS_MAXIMUM_PRIORITY - 10)
+#define PRIO_TOUCH          (RTEMS_MAXIMUM_PRIORITY - 9)
+#define MAX_ACTIVE_DEVICES  256
+#define DEVICE_INPUT_DIR "/dev/input"
+#define LONG_BITS (sizeof(long) * 8)
+#define LONG_FIELD_SIZE(bits) ((bits / LONG_BITS) + 1)
+struct evdev_test_message {
+	int fd;
+	char device[256];
+static rtems_id oid, omid, kid, kmid, mid, mmid, tid, tmid, psema;
+static volatile bool kill_otask, kill_ktask, kill_mtask, kill_ttask;
+static volatile bool otask_active, ktask_active, mtask_active, ttask_active;
+static char* active_devices[MAX_ACTIVE_DEVICES];
+static int active_device_count = 0;
+static void evdev_keyboard_task(rtems_task_argument arg);
+static void evdev_mouse_task(rtems_task_argument arg);
+static void evdev_touch_task(rtems_task_argument arg);
+static void
+add_active_device(char* dev)
+	rtems_semaphore_obtain(psema, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+	if (active_device_count < MAX_ACTIVE_DEVICES) {
+		active_devices[active_device_count++] = strdup(dev);
+	rtems_semaphore_release(psema);
+static void
+remove_active_device(char* dev)
+	int ii;
+	bool found = false;
+	for (ii = 0; ii < active_device_count; ii++) {
+		if (strcmp(dev, active_devices[ii]) == 0) {
+			free(active_devices[ii]);
+			found = true;
+			break;
+	if (found) {
+		ii++;
+		for (; ii < active_device_count; ii++) {
+			active_devices[ii] = active_devices[ii + 1];
+		active_device_count--;
+static bool
+check_device_active(char* dev)
+	int ii;
+			return true;
+	return false;
+static void
+delete_active_devices(void)
+	int ii;
+static void
+print_message(char *fmt, ...)
+	va_list ap;
+	va_start(ap, fmt);
+	vprintf(fmt, ap);
+	va_end(ap);
+static int
+get_input_device_count(void)
+	DIR *dir;
+	struct dirent *entry;
+	struct stat sbuf;
+	int file_count = 0;
+	int rv;
+	char fname[256];
+	if ((dir = opendir(DEVICE_INPUT_DIR)) != NULL) {
+		/* print all the files and directories within directory */
+		while ((entry = readdir(dir)) != NULL) {
+			if (strcmp(entry->d_name, ".") == 0 || strcmp(entry->d_name, "..") == 0)
+				continue;
+			strcpy(fname, DEVICE_INPUT_DIR);
+			strcat(fname, "/");
+			strcat(fname, entry->d_name);
+			rv = stat(fname, &sbuf);
+			assert(rv != -1);
+			if (S_ISCHR(sbuf.st_mode)) {
+				file_count++;
+		closedir (dir);
+	return file_count;
+static char**
+get_input_device_names(int file_count)
+	DIR *dir;
+	struct stat sbuf;
+	char** s_arr = NULL;
+	int current_count = 0;
+	int rv;
+	char fname[256];
+	if (file_count > 0) {
+		s_arr = malloc(file_count * sizeof(char*));
+					continue;
+				assert(rv != -1);
+					s_arr[current_count] = malloc((strlen(fname) + 1) * sizeof(char));
+					strcpy(s_arr[current_count], fname);
+					current_count++;
+			closedir (dir);
+	return s_arr;
+static bool
+test_bit(long bit, const long *field)
+	return (field[bit / LONG_BITS] >> bit % LONG_BITS) & 1;
+static int
+check_device_type(char* device)
+	rtems_status_code sc;
+	struct evdev_test_message msg;
+	long bitsAbs[LONG_FIELD_SIZE(ABS_CNT)];
+	long bitsKey[LONG_FIELD_SIZE(KEY_CNT)];
+	long bitsRel[LONG_FIELD_SIZE(REL_CNT)];
+	int ret = -1;
+	int rv;
+	int fd;
+	if (!check_device_active(device)) {
+		fd = open(device, O_RDONLY);
+		if (fd != -1) {
+			memset(bitsAbs, 0, sizeof(bitsAbs));
+			memset(bitsKey, 0, sizeof(bitsKey));
+			memset(bitsRel, 0, sizeof(bitsRel));
+			rv = ioctl(fd, EVIOCGBIT(EV_ABS, sizeof(bitsAbs)), bitsAbs);
+			assert(rv != -1);
+			rv = ioctl(fd, EVIOCGBIT(EV_KEY, sizeof(bitsKey)), bitsKey);
+			assert(rv != -1);
+			rv = ioctl(fd, EVIOCGBIT(EV_REL, sizeof(bitsRel)), bitsRel);
+			assert(rv != -1);
+			close(fd);
+			if (test_bit(KEY_Q, bitsKey)) {
+				printf("Found keyboard(%d) at %s\n", fd, device);
+				add_active_device(device);
+				strcpy(msg.device, device);
+				sc = rtems_message_queue_send(kmid, &msg, sizeof(msg));
+				assert(sc == RTEMS_SUCCESSFUL);
+				ret = 0;
+			if (test_bit(REL_X, bitsRel) && test_bit(REL_Y, bitsRel) && test_bit(BTN_MOUSE, bitsKey)) {
+				printf("Found mouse(%d) at %s\n", fd, device);
+				sc = rtems_message_queue_send(mmid, &msg, sizeof(msg));
+				ret = 0;
+			if (test_bit(ABS_X, bitsAbs) && test_bit(ABS_Y, bitsAbs)) {
+				if (test_bit(BTN_TOOL_FINGER, bitsKey)) {
+					printf("Found touchpad(%d) at %s\n", fd, device);
+					ret = 0;
+				} else if (test_bit(BTN_TOUCH, bitsKey)) {
+					printf("Found touchscreen(%d) at %s\n", fd, device);
+					sc = rtems_message_queue_send(tmid, &msg, sizeof(msg));
+					ret = 0;
+				} else if ((test_bit(BTN_STYLUS, bitsKey) || test_bit(BTN_TOOL_PEN, bitsKey))) {
+					printf("Found tablet(%d) at %s\n", fd, device);
+					ret = 0;
+			} else if (test_bit(ABS_MT_POSITION_X, bitsAbs) && test_bit(ABS_MT_POSITION_Y, bitsAbs)) {
+				printf("Found new-style touchscreen(%d) at %s\n", fd, device);
+				ret = 0;
+			if (test_bit(BTN_A, bitsKey) || test_bit(BTN_TRIGGER, bitsKey) || test_bit(ABS_RX, bitsAbs)) {
+				printf("Found joystick/gamepad(%d) at %s\n", fd, device);
+				ret = 0;
+			if (ret == -1) {
+				printf("Unknown device(%d) at %s\n", fd, device);
+	return ret;
+static int
+scan_for_devices(void)
+	int device_count;
+	char** s_arr;
+	int ii;
+	device_count = get_input_device_count();
+	if (device_count > 0) {
+		s_arr = get_input_device_names(device_count);
+		if (s_arr != NULL) {
+			for (ii = 0; ii < device_count; ii++) {
+				check_device_type(s_arr[ii]);
+				free(s_arr[ii]);
+			free(s_arr);
+static void
+evdev_scan_task(rtems_task_argument arg)
+	uint32_t size;
+	otask_active = true;
+	kill_otask = false;
+	while (!kill_otask) {
+		sc = rtems_message_queue_receive(omid, &msg, &size, RTEMS_WAIT, RTEMS_MILLISECONDS_TO_TICKS(1000));
+		if (sc == RTEMS_SUCCESSFUL) {
+				scan_for_devices();
+				rtems_task_wake_after(RTEMS_MILLISECONDS_TO_TICKS(1000));
+	otask_active = false;
+	rtems_task_delete(RTEMS_SELF);
+static void
+process_keyboard_input_event(struct input_event *data)
+	if (data->type != EV_KEY)
+		return;
+	print_message("Keyboard: %d,%d\n", data->code, data->value);
+static void
+evdev_keyboard_task(rtems_task_argument arg)
+	int fd, bytes, n, i, rv, grab;
+	struct input_event buffer[32];
+	uint32_t size;
+	ktask_active = true;
+	kill_ktask = false;
+	while (!kill_ktask) {
+		sc = rtems_message_queue_receive(kmid, &msg, &size, RTEMS_WAIT, RTEMS_MILLISECONDS_TO_TICKS(1000));
+			fd = open(msg.device, O_RDONLY | O_NONBLOCK);
+			if (fd != -1) {
+				grab = 1;
+				rv = ioctl(fd, EVIOCGRAB, &grab);
+				assert(rv == 0);
+				while (!kill_ttask) {
+					n = 0;
+						bytes = read(fd, (char*)buffer + n, sizeof(buffer) - n);
+						if (bytes == 0) {
+							print_message("evdevkeyboard: Got EOF from the input device\n");
+						} else if (bytes < 0) {
+							if (errno != EINTR && errno != EAGAIN) {
+								print_message("evdevkeyboard: Could not read from input device\n");
+								goto err;
+							rtems_task_wake_after(RTEMS_MILLISECONDS_TO_TICKS(10));
+						} else {
+							n += bytes;
+							if (n % sizeof(buffer[0]) == 0)
+								break;
+					n /= sizeof(buffer[0]);
+					for (i = 0; i < n; ++i)
+						process_keyboard_input_event(&buffer[i]);
+err:
+				close(fd);
+			remove_active_device(msg.device);
+	ktask_active = false;
+static void
+process_mouse_input_event(struct input_event *data)
+	if (data->type == EV_ABS) {
+		/*Touchpads: store the absolute position for now, will calculate a relative one later.*/
+		if (data->code == ABS_X) {
+			print_message("Mouse ABS: X = %d\n", data->value);
+		} else if (data->code == ABS_Y) {
+			print_message("Mouse ABS: Y = %d\n", data->value);
+	} else if (data->type == EV_REL) {
+		if (data->code == REL_X) {
+			print_message("Mouse REL: X = %d\n", data->value);
+		} else if (data->code == REL_Y) {
+			print_message("Mouse REL: Y = %d\n", data->value);
+		} else if (data->code == ABS_WHEEL) { /* vertical scroll */
+			print_message("Mouse REL: W = %d\n", data->value);
+		} else if (data->code == ABS_THROTTLE) { /* horizontal scroll */
+			print_message("Mouse REL: T = %d\n", data->value);
+	} else if (data->type == EV_KEY && data->code == BTN_TOUCH) {
+		print_message("Mouse Key: B = %d\n", data->value);
+	} else if (data->type == EV_KEY && data->code >= BTN_LEFT && data->code <= BTN_JOYSTICK) {
+		print_message("Mouse Key: %d,%d\n", data->code, data->value);
+	} else if (data->type == EV_SYN && data->code == SYN_REPORT) {
+		print_message("Mouse Sync Report: %d\n", data->value);
+	} else if (data->type == EV_MSC && data->code == MSC_SCAN) {
+		print_message("Mouse MSC: %d,%d\n", data->code, data->value);
+static void
+evdev_mouse_task(rtems_task_argument arg)
+	uint32_t size;
+	mtask_active = true;
+	kill_mtask = false;
+	while (!kill_mtask) {
+		sc = rtems_message_queue_receive(mmid, &msg, &size, RTEMS_WAIT, RTEMS_MILLISECONDS_TO_TICKS(1000));
+			if (fd != -1) {
+				grab = 1;
+				assert(rv == 0);
+					n = 0;
+						if (bytes == 0) {
+							print_message("evdevmouse: Got EOF from the input device\n");
+								print_message("evdevmouse: Could not read from input device\n");
+								goto err;
+						} else {
+							n += bytes;
+								break;
+						process_mouse_input_event(&buffer[i]);
+err:
+				close(fd);
+	mtask_active = false;
+static void
+process_touch_input_event(struct input_event *data)
+		if (data->code == ABS_MT_POSITION_X || (data->code == ABS_X)) {
+			print_message("Touch ABS: X = %d\n", data->value);
+		} else if (data->code == ABS_MT_POSITION_Y || (data->code == ABS_Y)) {
+			print_message("Touch ABS: Y = %d\n", data->value);
+		} else if (data->code == ABS_MT_TRACKING_ID) {
+			print_message("Touch ABS: T = %d\n", data->value);
+		} else if (data->code == ABS_MT_TOUCH_MAJOR) {
+			print_message("Touch ABS: TM = %d\n", data->value);
+		} else if (data->code == ABS_PRESSURE) {
+			print_message("Touch ABS: P = %d\n", data->value);
+		} else if (data->code == ABS_MT_SLOT) {
+			print_message("Touch ABS: S = %d\n", data->value);
+	} else if (data->type == EV_KEY) {
+		if (data->code == BTN_TOUCH)
+			print_message("Touch Key: %d\n", data->value);
+		print_message("Touch Sync Report: %d\n", data->value);
+static void
+evdev_touch_task(rtems_task_argument arg)
+	int fd, n, i, bytes, rv, grab;
+	uint32_t size;
+	ttask_active = true;
+	kill_ttask = false;
+		sc = rtems_message_queue_receive(tmid, &msg, &size, RTEMS_WAIT, RTEMS_MILLISECONDS_TO_TICKS(1000));
+			if (fd != -1) {
+				grab = 1;
+				assert(rv == 0);
+					n = 0;
+						if (bytes == 0) {
+							print_message("evdevtouch: Got EOF from the input device\n");
+								print_message("evdevtouch: Could not read from input device\n");
+								goto err;
+						} else {
+							n += bytes;
+							if (n % sizeof(struct input_event) == 0)
+								break;
+					n /= sizeof(struct input_event);
+						process_touch_input_event(&buffer[i]);
+err:
+				close(fd);
+	ttask_active = false;
+static void
+Init(rtems_task_argument arg)
+	(void) arg;
+	puts("*** " TEST_NAME " TEST ***");
+	sc = rtems_semaphore_create(
+		rtems_build_name('E', 'V', 'D', 'S'),
+		1,
+		RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+		RTEMS_NO_PRIORITY,
+		&psema);
+	sc = rtems_message_queue_create(
+		rtems_build_name ('E', 'V', 'O', 'M'),
+		16,
+		sizeof(struct evdev_test_message),
+		RTEMS_PRIORITY,
+		&omid
+		rtems_build_name ('E', 'V', 'K', 'M'),
+		16,
+		RTEMS_PRIORITY,
+		&kmid
+		rtems_build_name ('E', 'V', 'M', 'M'),
+		16,
+		RTEMS_PRIORITY,
+		&mmid
+		rtems_build_name ('E', 'V', 'T', 'M'),
+		16,
+		RTEMS_PRIORITY,
+		&tmid
+	sc = rtems_task_create(
+		rtems_build_name('E', 'V', 'D', 'K'),
+		PRIO_KEYBOARD,
+		RTEMS_MINIMUM_STACK_SIZE,
+		RTEMS_DEFAULT_MODES,
+		RTEMS_FLOATING_POINT,
+		&kid
+		rtems_build_name('E', 'V', 'D', 'M'),
+		PRIO_MOUSE,
+		&mid
+		rtems_build_name('E', 'V', 'D', 'T'),
+		PRIO_TOUCH,
+		&tid
+		rtems_build_name('E', 'V', 'D', 'O'),
+		PRIO_OPEN,
+		&oid
+	sc = rtems_task_start(oid, evdev_scan_task, NULL);
+	sc = rtems_task_start(kid, evdev_keyboard_task, NULL);
+	sc = rtems_task_start(mid, evdev_mouse_task, NULL);
+	sc = rtems_task_start(tid, evdev_touch_task, NULL);
+	sc = rtems_bsd_initialize();
+	msg.fd = -1;
+	rtems_message_queue_send(omid, &msg, sizeof(msg));
+	sc = rtems_shell_init("SHLL", 16 * 1024, 1, CONSOLE_DEVICE_NAME,
+	    false, true, NULL);
+	kill_otask = true;
+	kill_ktask = true;
+	kill_mtask = true;
+	kill_ttask = true;
+	while (otask_active || ktask_active || mtask_active || ttask_active) {
+	delete_active_devices();
+	sc = rtems_message_queue_delete(omid);
+	sc = rtems_message_queue_delete(kmid);
+	sc = rtems_message_queue_delete(mmid);
+	sc = rtems_message_queue_delete(tmid);
+	sc = rtems_semaphore_delete(psema);
+	exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_MAXIMUM_DRIVERS 32
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_STACK_CHECKER_ENABLED
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#include <rtems/confdefs.h>
+#include <bsp/nexus-devices.h>
+SYSINIT_DRIVER_REFERENCE(ukbd, uhub);
+SYSINIT_DRIVER_REFERENCE(ums, uhub);
+#define CONFIGURE_SHELL_COMMANDS_INIT
+#include <bsp/irq-info.h>
+#include <rtems/netcmds-config.h>
+#define CONFIGURE_SHELL_USER_COMMANDS \
+  &bsp_interrupt_shell_command, \
+  &rtems_shell_SYSCTL_Command
+#define CONFIGURE_SHELL_COMMAND_CPUUSE
+#define CONFIGURE_SHELL_COMMAND_PERIODUSE
+#define CONFIGURE_SHELL_COMMAND_STACKUSE
+#define CONFIGURE_SHELL_COMMAND_PROFREPORT
+#define CONFIGURE_SHELL_COMMAND_PWD
+#define CONFIGURE_SHELL_COMMAND_LS
+#define CONFIGURE_SHELL_COMMAND_LN
+#define CONFIGURE_SHELL_COMMAND_LSOF
+#define CONFIGURE_SHELL_COMMAND_CHDIR
+#define CONFIGURE_SHELL_COMMAND_CD
+#define CONFIGURE_SHELL_COMMAND_MKDIR
+#define CONFIGURE_SHELL_COMMAND_RMDIR
+#define CONFIGURE_SHELL_COMMAND_CAT
+#define CONFIGURE_SHELL_COMMAND_MV
+#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
+#include <rtems/shellconfig.h>
diff --git a/testsuite/usbkbd01/init.c b/testsuite/usbkbd01/init.c
index 0000000..07fb5c3
--- /dev/null
+++ b/testsuite/usbkbd01/init.c
@@ -0,0 +1,278 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#define TEST_NAME "LIBBSD USB KEYBOARD"
+#define USB_SERIAL_TEST_BUFFER_SIZE 48
+#define PRIO_READ  (RTEMS_MAXIMUM_PRIORITY - 11)
+struct usb_test_message {
+	int fd;
+	char rbuf[USB_SERIAL_TEST_BUFFER_SIZE];
+static rtems_id oid, rid, omid, rmid;
+static volatile bool kill_otask, kill_rtask;
+static volatile bool otask_active, rtask_active;
+static void
+usb_keyboard_read_task(rtems_task_argument arg)
+	struct usb_test_message msg;
+	uint32_t size;
+	int bytes;
+	rtask_active = true;
+	kill_rtask = false;
+	while (!kill_rtask) {
+			sc = rtems_message_queue_receive(rmid, &msg, &size, RTEMS_WAIT, RTEMS_MILLISECONDS_TO_TICKS(1000));
+				if (msg.fd > 0) {
+					break;
+				} else {
+					printf("Invalid file descriptor\n");
+			msg.rbuf[0] = 0;
+			bytes = read(msg.fd, &msg.rbuf[0], 1);
+			if (bytes == 0) {
+				printf("Got EOF from the input device\n");
+					printf("Could not read from input device\n");
+					break;
+			} else {
+				printf("%c", msg.rbuf[0]);
+				fflush(stdout);
+	  msg.fd = -1;
+	rtask_active = false;
+static void
+usb_keyboard_open_task(rtems_task_argument arg)
+	struct termios t;
+	uint32_t size;
+	int fd, iret;
+	fd = -2;
+			if (fd >= 0) {
+				close(fd);
+				printf("keyboard device closed\n");
+			fd = msg.fd;
+		if (fd == -1) {
+			fd = open("/dev/ukbd0", O_RDWR | O_NONBLOCK);
+			if (fd != -1) {
+				printf("keyboard device opened: %d\n", fd);
+				msg.fd = fd;
+				rtems_message_queue_send(rmid, &msg, sizeof(msg));
+			else {
+				/*printf("keyboard device open failed: %d\n", errno);*/
+	if (fd >= 0) {
+		close(fd);
+static void
+	(void) arg;
+		rtems_build_name ('M', 'U', 'O', 'P'),
+		16,
+		sizeof(struct usb_test_message),
+		RTEMS_PRIORITY,
+		&omid
+		rtems_build_name ('M', 'U', 'R', 'D'),
+		16,
+		RTEMS_PRIORITY,
+		&rmid
+		rtems_build_name('U', 'S', 'B', 'R'),
+		PRIO_READ,
+		&rid
+		rtems_build_name('U', 'S', 'B', 'O'),
+		PRIO_OPEN,
+		&oid
+	sc = rtems_task_start(rid, usb_keyboard_read_task, NULL);
+	sc = rtems_task_start(oid, usb_keyboard_open_task, NULL);
+	msg.fd = -1;
+	kill_rtask = true;
+	while (otask_active || rtask_active) {
+	sc = rtems_message_queue_delete(rmid);
+	exit(0);
diff --git a/testsuite/usbmouse01/init.c b/testsuite/usbmouse01/init.c
index 0000000..b607c2a
--- /dev/null
+++ b/testsuite/usbmouse01/init.c
@@ -0,0 +1,283 @@
+ * are met:
+ * SUCH DAMAGE.
+ * This test requires a USB mouse to be attached to a USB port.
+#include <stdio.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <sys/mouse.h>
+#define TEST_NAME "LIBBSD USB MOUSE"
+	int fd;
+static void
+usb_mouse_read_task(rtems_task_argument arg)
+	uint32_t size;
+	int bytes;
+				if (msg.fd > 0) {
+					break;
+				} else {
+			msg.rbuf[0] = 0;
+			if (bytes == 0) {
+					break;
+			} else {
+				printf("received char: 0x%02X\n", msg.rbuf[0]);
+	  msg.fd = -1;
+static void
+usb_mouse_open_task(rtems_task_argument arg)
+	struct termios t;
+	uint32_t size;
+	int fd, iret;
+	fd = -2;
+			if (fd >= 0) {
+				close(fd);
+				printf("mouse device closed\n");
+			fd = msg.fd;
+		if (fd == -1) {
+			fd = open("/dev/ums0", O_RDWR | O_NONBLOCK);
+			if (fd != -1) {
+				printf("mouse device opened: %d\n", fd);
+				msg.fd = fd;
+			else {
+				/*printf("mouse device open failed: %d\n", errno);*/
+	if (fd >= 0) {
+		close(fd);
+static void
+	(void) arg;
+		16,
+		RTEMS_PRIORITY,
+		&omid
+		16,
+		RTEMS_PRIORITY,
+		&rmid
+		PRIO_READ,
+		&rid
+		PRIO_OPEN,
+		&oid
+	sc = rtems_task_start(rid, usb_mouse_read_task, NULL);
+	sc = rtems_task_start(oid, usb_mouse_open_task, NULL);
+	msg.fd = -1;
+	exit(0);
1.9.1
