[PATCH 11/11] Update scripts to include support for input devices - USB Keyboard, USB mouse, touch, and EVDEV
Kevin Kirspel
kevin-kirspel at idexx.com
Mon May 15 17:26:38 UTC 2017
libbsd.py | 79 +++++++++++++++++++++++++++++++++++++++++++----------------
libbsd_waf.py | 43 ++++++++++++++++++++++++++++++++
2 files changed, 101 insertions(+), 21 deletions(-)
diff --git a/libbsd.py b/libbsd.py
index 3129266..de94304 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -151,6 +151,7 @@ def rtems(mm):
'pppd/sys-rtems.c',
'pppd/upap.c',
'pppd/utils.c',
+ 'sys/dev/input/touchscreen/tsc_lpc32xx.c',
'sys/dev/usb/controller/ehci_mpc83xx.c',
'sys/dev/usb/controller/ohci_lpc.c',
'sys/dev/usb/controller/ohci_lpc32xx.c',
@@ -500,6 +501,53 @@ def mmc(mm):
return mod
+# Input
+def dev_input(mm):
+ mod = builder.Module('dev_input')
+ mod.addKernelSpaceHeaderFiles(
+ 'sys/sys/kbio.h',
+ 'sys/dev/kbd/kbdreg.h',
+ 'sys/dev/kbd/kbdtables.h',
+ 'sys/sys/mouse.h',
+ mod.addKernelSpaceSourceFiles(
+ 'sys/dev/kbd/kbd.c',
+ mm.generator['source']()
+ return mod
+# EVDEV
+def evdev(mm):
+ mod = builder.Module('evdev')
+ 'sys/dev/evdev/evdev.h',
+ 'sys/dev/evdev/evdev_private.h',
+ 'sys/dev/evdev/input.h',
+ 'sys/dev/evdev/input-event-codes.h',
+ 'sys/dev/evdev/uinput.h',
+ 'sys/dev/evdev/cdev.c',
+ 'sys/dev/evdev/evdev.c',
+ 'sys/dev/evdev/evdev_mt.c',
+ 'sys/dev/evdev/evdev_utils.c',
+ 'sys/dev/evdev/uinput.c',
+ return mod
# USB
def dev_usb(mm):
@@ -671,32 +719,17 @@ def dev_usb_input(mm):
mod.addDependency(mm['dev_usb'])
- 'sys/dev/usb/input/usb_rdesc.h',
+ 'sys/dev/usb/input/usb_rdesc.h',
+ 'sys/dev/usb/input/atp.c',
+ 'sys/dev/usb/input/uep.c',
'sys/dev/usb/input/uhid.c',
'sys/dev/usb/input/ukbd.c',
- mm.generator['source']()
- return mod
-# USB Mouse
-def dev_usb_mouse(mm):
- mod = builder.Module('dev_usb_mouse')
- mod.addDependency(mm['dev_usb'])
- mod.addKernelSpaceHeaderFiles(
- 'sys/sys/mouse.h',
- mod.addKernelSpaceSourceFiles(
'sys/dev/usb/input/ums.c',
+ 'sys/dev/usb/input/wsp.c',
@@ -3021,6 +3054,9 @@ def tests(mm):
mod.addTest(mm.generator['test']('commands01', ['test_main']))
mod.addTest(mm.generator['test']('usb01', ['init'], False))
mod.addTest(mm.generator['test']('usbserial01', ['init'], False))
+ mod.addTest(mm.generator['test']('usbkbd01', ['init'], False))
+ mod.addTest(mm.generator['test']('usbmouse01', ['init'], False))
+ mod.addTest(mm.generator['test']('evdev01', ['init'], False))
mod.addTest(mm.generator['test']('loopback01', ['test_main']))
mod.addTest(mm.generator['test']('netshell01', ['test_main', 'shellconfig'], False))
mod.addTest(mm.generator['test']('swi01', ['init', 'swi_test']))
@@ -3151,6 +3187,8 @@ def sources(mm):
mm.addModule(fdt(mm))
mm.addModule(tty(mm))
mm.addModule(mmc(mm))
+ mm.addModule(dev_input(mm))
+ mm.addModule(evdev(mm))
mm.addModule(dev_usb(mm))
#mm.addModule(dev_usb_add_on(mm))
@@ -3160,8 +3198,7 @@ def sources(mm):
#mm.addModule(dev_usb_misc(mm))
#mm.addModule(dev_usb_bluetooth(mm))
- #mm.addModule(dev_usb_input(mm))
- #mm.addModule(dev_usb_mouse(mm))
+ mm.addModule(dev_usb_input(mm))
mm.addModule(dev_usb_serial(mm))
mm.addModule(dev_usb_net(mm))
mm.addModule(dev_usb_wlan(mm))
diff --git a/libbsd_waf.py b/libbsd_waf.py
index c73f1dd..30765de 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -780,9 +780,15 @@ def build(bld):
'freebsd/sys/dev/e1000/em_txrx.c',
'freebsd/sys/dev/e1000/if_em.c',
'freebsd/sys/dev/e1000/igb_txrx.c',
+ 'freebsd/sys/dev/evdev/cdev.c',
+ 'freebsd/sys/dev/evdev/evdev.c',
+ 'freebsd/sys/dev/evdev/evdev_mt.c',
+ 'freebsd/sys/dev/evdev/evdev_utils.c',
+ 'freebsd/sys/dev/evdev/uinput.c',
'freebsd/sys/dev/fdt/fdt_common.c',
'freebsd/sys/dev/fdt/simplebus.c',
'freebsd/sys/dev/fxp/if_fxp.c',
+ 'freebsd/sys/dev/kbd/kbd.c',
'freebsd/sys/dev/led/led.c',
'freebsd/sys/dev/mii/brgphy.c',
'freebsd/sys/dev/mii/e1000phy.c',
@@ -892,6 +898,12 @@ def build(bld):
'freebsd/sys/dev/usb/controller/ehci.c',
'freebsd/sys/dev/usb/controller/ohci.c',
'freebsd/sys/dev/usb/controller/usb_controller.c',
+ 'freebsd/sys/dev/usb/input/atp.c',
+ 'freebsd/sys/dev/usb/input/uep.c',
+ 'freebsd/sys/dev/usb/input/uhid.c',
+ 'freebsd/sys/dev/usb/input/ukbd.c',
+ 'freebsd/sys/dev/usb/input/ums.c',
+ 'freebsd/sys/dev/usb/input/wsp.c',
'freebsd/sys/dev/usb/net/if_aue.c',
'freebsd/sys/dev/usb/net/if_axe.c',
'freebsd/sys/dev/usb/net/if_axge.c',
@@ -1370,6 +1382,7 @@ def build(bld):
'rtemsbsd/rtems/syslog.c',
'rtemsbsd/sys/dev/dw_mmc/dw_mmc.c',
'rtemsbsd/sys/dev/ffec/if_ffec_mcf548x.c',
+ 'rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c',
'rtemsbsd/sys/dev/smc/if_smc_nexus.c',
'rtemsbsd/sys/dev/tsec/if_tsec_nexus.c',
'rtemsbsd/sys/dev/usb/controller/dwc_otg_nexus.c',
@@ -1535,6 +1548,16 @@ def build(bld):
lib = ["m", "z"],
install_path = None)
+ test_evdev01 = ['testsuite/evdev01/init.c']
+ bld.program(target = "evdev01.exe",
+ features = "cprogram",
+ cflags = cflags,
+ includes = includes,
+ source = test_evdev01,
+ use = ["bsd"],
+ lib = ["m", "z"],
+ install_path = None)
test_foobarclient = ['testsuite/foobarclient/test_main.c']
bld.program(target = "foobarclient.exe",
@@ -1922,6 +1945,26 @@ def build(bld):
lib = ["m", "z"],
+ test_usbkbd01 = ['testsuite/usbkbd01/init.c']
+ bld.program(target = "usbkbd01.exe",
+ cflags = cflags,
+ source = test_usbkbd01,
+ use = ["bsd"],
+ lib = ["m", "z"],
+ test_usbmouse01 = ['testsuite/usbmouse01/init.c']
+ bld.program(target = "usbmouse01.exe",
+ cflags = cflags,
+ source = test_usbmouse01,
+ use = ["bsd"],
+ lib = ["m", "z"],
test_usbserial01 = ['testsuite/usbserial01/init.c']
bld.program(target = "usbserial01.exe",
1.9.1
