Offlist - Introduce Yourself to Community
aditya upadhyay aadit0402 at gmail.com
Mon May 15 19:38:31 UTC 2017
Hello All,
I have ported the code of inttypes library and i have tested methods
related to inttypes.h in hello world test. It is working. Then i made a
separate test for psxinttypes01 in samples directory and it's also working.
I made this test within the psxtests directory then how would i check
whether test is working or not ? The location of psxinttypes01 is :
/development/rtems4.12-1/testsuits/psxtests/psxinttypes01.
Just for learning purpose, if i put psxtests instead of samples in this
command : ../rtems4.12-1/configure --target=sparc-rtems4.12
--enable-rtemsbsp=erc32  --enable-tests=samples --disable-posix
and after make command, Will it generate .exe files related to psxtests ?
do i  have to send the ported code or can i submit the ported code to my
github repository.. ? Any suggestion ?
Please find the attached patch and review the tested methods.
patch1 is for methods tested within the hello world file.
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 1987586..5c4dc15 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -7,6 +7,7 @@ include $(top_srcdir)/automake/multilib.am
 SUBDIRS = . score rtems sapi posix
 SUBDIRS += dev
 SUBDIRS += dtc/libfdt
+SUBDIRS += inttypes
 SUBDIRS += libcrypt
 SUBDIRS += libcsupport libblock libfs
 SUBDIRS += libdrvmgr
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 67237e9..5110c07 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -479,6 +479,7 @@ libstdthreads/Makefile
 libdebugger/Makefile
 zlib/Makefile
 ftpd/Makefile
+inttypes/Makefile
 telnetd/Makefile
 pppd/Makefile
 mghttpd/Makefile
diff --git a/cpukit/include/rtems/inttypes.h
b/cpukit/include/rtems/inttypes.h
index 2e23c8c..d2f9f55 100644
--- a/cpukit/include/rtems/inttypes.h
+++ b/cpukit/include/rtems/inttypes.h
@@ -153,3 +153,4 @@ extern "C" {
 #endif
 #endif
diff --git a/testsuites/psxtests/Makefile.am
b/testsuites/psxtests/Makefile.am
index 7bcea46..65325da 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -58,6 +58,7 @@ _SUBDIRS += psxhdrs
 _SUBDIRS += psxintrcritical01
 _SUBDIRS += psxitimer
 endif
+_SUBDIRS += psxinttypes01
 _SUBDIRS += psxkey01
 _SUBDIRS += psxkey02
 _SUBDIRS += psxkey03
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
configure.ac
index 1de1312..227bda9 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -163,6 +163,7 @@ psximfs01/Makefile
 psximfs02/Makefile
 psxintrcritical01/Makefile
 psxitimer/Makefile
+psxinttypes01/Makefile
 psxkey01/Makefile
 psxkey02/Makefile
 psxkey03/Makefile
diff --git a/testsuites/samples/hello/Makefile.am
b/testsuites/samples/hello/Makefile.am
index 234a27e..c7f7e2a 100644
--- a/testsuites/samples/hello/Makefile.am
+++ b/testsuites/samples/hello/Makefile.am
@@ -9,9 +9,10 @@ include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
 include $(top_srcdir)/../automake/compile.am
 include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(hello_OBJECTS)
-LINK_LIBS = $(hello_LDLIBS)
+LINK_OBJS = $(hello_OBJECTS) $(hello_LDADD)
+LINK_LIBS = $(hello_LDLIBS)
/home/aditya/development/b-sparc/sparc-rtems4.12/c/erc32/cpukit/inttypes/libinttypes.a
 hello$(EXEEXT): $(hello_OBJECTS) $(hello_DEPENDENCIES)
     @rm -f hello$(EXEEXT)
diff --git a/testsuites/samples/hello/init.c
b/testsuites/samples/hello/init.c
index a2d6c30..51f4451 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -18,6 +18,7 @@
+#include <rtems/inttypes.h>
 /* forward declarations to avoid warnings */
 rtems_task Init(rtems_task_argument argument);
@@ -31,7 +32,34 @@ rtems_task Init(
   rtems_print_printer_printf(&rtems_test_printer);
   rtems_test_begin();
+  char* endptr;
+  uintmax_t j,k;
+  int base = 10;
+  char *nptr;
+  wchar_t *nptr1, *endptr1;
+  intmax_t m;
+  nptr1 = L"10110134932";
+  nptr = "20690239864abc";
+  m = wcstoimax(nptr1, &endptr1,
base);
+  printf("string = %s\n", nptr);
+  j = strtoumax(nptr, &endptr, base);
+  printf("wcstoimax = %jd\n", m);
+  k = wcstoumax(nptr1, &endptr1, base);
+  printf("wcstoumax = %ju\n", k);
+  printf("strtoumax = %ju (base %d)\n", j, base);
+  printf("Stopped scan at %s\n\n", endptr);
+  imaxdiv_t retrival = imaxdiv(27, 4);
   printf( "Hello World\n" );
+  printf(" Strtoimax values \n");
+  printf("%jd\n", strtoimax(" -123junk",&endptr,10)); /* base
10                    */
+  printf("%jd\n", strtoimax("11111111",&endptr,2));   /* base
2                     */
+  printf("%jd\n", strtoimax("XyZ",&endptr,36));       /* base
36                    */
+  printf("%jd\n", strtoimax("010",&endptr,0));        /* octal
auto-detection       */
+  printf("%jd\n", strtoimax("10",&endptr,0));         /* decimal
auto-detection     */
+  printf("%jd\n", strtoimax("0x10",&endptr,0));       /* hexadecimal
auto-detection */
+  printf( "imaxabs_value = %jd\n", imaxabs(-1234));
+  printf("strtoimax value = %jd\n", strtoimax("11111111",&endptr,2));
+  printf( "imax div value = %jd\n", retrival.rem);
   rtems_test_end();
   exit( 0 );
patch2 is for separate test psxinttypes01 within the samples directory.
 SUBDIRS += dev
 SUBDIRS += libcrypt
 zlib/Makefile
 ftpd/Makefile
+inttypes/Makefile
 telnetd/Makefile
 pppd/Makefile
 mghttpd/Makefile
 #endif
 #endif
diff --git a/cpukit/rtems/src/ratemonreportstatistics.c
b/cpukit/rtems/src/ratemonreportstatistics.c
index 0ea7790..76f032e 100644
--- a/cpukit/rtems/src/ratemonreportstatistics.c
+++ b/cpukit/rtems/src/ratemonreportstatistics.c
@@ -156,3 +156,4 @@ void rtems_rate_monotonic_report_statistics( void )
   rtems_print_printer_printk( &printer );
   rtems_rate_monotonic_report_statistics_with_plugin( &printer );
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index 85e89a5..f710aab 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -9,6 +9,7 @@ _SUBDIRS += minimum
 _SUBDIRS += nsecs
 _SUBDIRS += paranoia
 _SUBDIRS += ticker
 _SUBDIRS += unlimited
 if MPTESTS
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/
configure.ac
index ffe1bad..95ff87a 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -75,6 +75,7 @@ nsecs/Makefile
 paranoia/Makefile
 pppd/Makefile
 ticker/Makefile
 unlimited/Makefile
 AC_OUTPUT
index 234a27e..3a05a39 100644
@@ -1,6 +1,6 @@
 rtems_tests_PROGRAMS = hello
-hello_SOURCES = init.c
+hello_SOURCES = init.c libinttypes.a
 dist_rtems_tests_DATA = hello.scn
 dist_rtems_tests_DATA += hello.doc
index a2d6c30..d1fd577 100644
@@ -18,6 +18,7 @@
Thanks & Regards,
Aditya
On Mon, May 15, 2017 at 9:55 PM, Joel Sherrill <joel at rtems.org> wrote:
> I am not in a good position to review this today but patches should go to
> the community for review. Also this one has a ticket.
> --joel
> On May 14, 2017 11:33 PM, "aditya upadhyay" <aadit0402 at gmail.com> wrote:
>> Hello Joel, Gedare,
>> related to inttypes.h in hello world test. It is working. I have made a
>> test related to inttypes methods named as psxinttype01. where i have tested
>> these method. The location of psxinttypes01 is :
>> I am sending you the patch of tested code. please review the tested
>> methods.
>> Thanks & Regards,
>> Aditya
>> On Fri, May 12, 2017 at 9:41 PM, aditya upadhyay <aadit0402 at gmail.com>
>> wrote:
>>> Hello Joe, Gedare,
>>>  I was busy with my end semester project. I will introduce myself there.
>>> Apart from that now i am trying to make a test for inttypes library as You
>>> have told me in previous mail. I will do it by tonight.
>>> Thanks & Regards,
>>> Aditya
>>> On Fri, May 12, 2017 at 9:33 PM, Joel Sherrill <joel at rtems.org> wrote:
>>>> Hi
>>>> Gedare sent an email asking all students to introduce themselves and
>>>> their project to the community. You haven't done it yet.
>>>> Thanks
>>>> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170516/ef5beb21/attachment-0001.html>
