[PATCH] tests: CONFIGURE_DISABLE_SMP_CONFIGURATION
Tue May 16 08:32:04 UTC 2017
On 16/05/17 10:28, Chris Johns wrote:
>> >You
>> >wanted more tests to run in the SMP mode if SMP is enabled. Now only 36
>> >tests are left over.
> I think it is a reasonable expectation when you build an SMP RTEMS the
> tests run with SMP enabled using all available cores.
No, we don't run the tests using all available cores. This would break a
lot of tests which assume that the highest priority thread runs alone.
It would also make it considerable harder to write some tests.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
