[PATCH] tests: CONFIGURE_DISABLE_SMP_CONFIGURATION
Tue May 16 22:39:24 UTC 2017
On 16/05/2017 18:32, Sebastian Huber wrote:
> On 16/05/17 10:28, Chris Johns wrote:
>>> >You
>>> >wanted more tests to run in the SMP mode if SMP is enabled. Now only 36
>>> >tests are left over.
>> I think it is a reasonable expectation when you build an SMP RTEMS the
>> tests run with SMP enabled using all available cores.
> No, we don't run the tests using all available cores. This would break a
> lot of tests which assume that the highest priority thread runs alone.
> It would also make it considerable harder to write some tests.
This make sense. I would assume the test explicitly handles this so it
is clear this is the case. I am missing how this relates.
