RTEMS MAP_SHARED support expansion
Kirspel, Kevin Kevin-Kirspel at idexx.com
Wed May 17 11:42:14 UTC 2017
OK.  I will just stick with approach 1.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
Sent: Wednesday, May 17, 2017 1:32 AM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
Subject: Re: RTEMS MAP_SHARED support expansion
On 16/05/17 21:28, Kirspel, Kevin wrote:
> The second approach includes the first approach but adds support for
> RTEMS device drivers.  We would need to add a mmap handler to
> "rtems_driver_address_table".  The "IMFS_device_handlers" would add a
> mmap handler to device_mmap(). We would need a new
> rtems_deviceio_mmap() function to call the drivers mmap handler.  I
> don't think any BSPs will be affected because the mmap handler of
> "rtems_driver_address_table" should initialize to NULL.  Any BSP would
> them be free to add a handler to process mmap calls.
I would not touch the legacy RTEMS device drivers. With the IMFS generic nodes we have something more flexible with lower overhead.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=LvIJSxMOfKUmtQhAsLZm_KkVvgeGT75H5TZ06fzmwiw&s=LB8V3jvtD878rxyGZSjR_VoEbJii-JWdjaw4a3GaFYk&e=
