rtems_fatal() as inline in a header file
Thu May 18 05:16:26 UTC 2017
On 18/05/17 01:08, Pham, Phong wrote:
> Hi Developers,
> Currently:
> …\rtems\cpukit\sapi\include\rtems\fatal.h
> <file:///%5C%5Ccentos%5Crtems-dev%5Crtems_0508%5Crtems%5Ccpukit%5Csapi%5Cinclude%5Crtems%5Cfatal.h>
> is implemented as
> RTEMS_NO_RETURN RTEMS_INLINE_ROUTINE void rtems_fatal(
>   rtems_fatal_source fatal_source,
>   rtems_fatal_code   error_code
>   _Terminate( fatal_source, error_code );
> I suggest to move the implementation to fatal.c and remove
> RTEMS_INLINE_ROUTINE.  I just don’t see a benefit to implement it as
> inline.
The rtems_fatal() is an API function documented in the user manual. The
_Terminate() is an internal function.
> Besides, it has disadvantages.  That is besides code size, during
> debugging, it simplifies the number of rtems_fatal symbol occurrences
> to 1.  Don’t have to figure out which one is which.
Yes, for debugging you have to know that _Terminate() is the right
function to set the break point. This is not really great. Maybe we
should remove this indirection.
> bsp_fatal() is another one.
> Phong.
>           Notice: This e-mail and any files transmitted with it may
>           contain Data Device Corporation's privileged and proprietary
>           information. It is intended solely for the use of the
>           individual or entity to whom it is addressed. If you are not
>           the named recipient of this transmission, any disclosure,
>           copying, distribution or reliance on the contents of this
>           message is prohibited. If you received this e-mail in error,
>           please destroy it and any attached files and notify me
>           immediately.
Do you take this message serious?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
