TMS570LC43x - what should be done before coding
Nikolay Komashinskiy nikolay.komashinskiy at yandex.ru
Fri May 19 16:19:04 UTC 2017
Hello,
I've started to investigate how to launch RTEMS on top of the TMS570LC43x processor
and it seems that some additional work should be done.
I can't understand to what extent HalCoGen should be used. It seem these two processors
(TMS570LC43x and TMS570LS3731) differ in their memory maps, in caches (LC43x has it).
Also, LC43X has only MibSPI which is extended version of SPI.
Also, these boards have a bit different Vector Interrupt Managers (different number of interrupts).
Could you explain what should be done in order to get a working RTEMS port on top
of the board?
Regards,
