arm/rtl22xx_t build failures
Tue May 23 08:26:56 UTC 2017
On 23/5/17 5:49 pm, Sebastian Huber wrote:
> On 23/05/17 09:34, Chris Johns wrote:
> I have a fix for the assembler errors.
Thanks.
>> Here is the build failures for ARM with current tools. Note, there are
>> 2 failures in the list. The new one is in failure 17:
>>       error: lpc32xx_mzx/lib/include/bsp/lpc32xx.h:27:25: fatal error:
>>              bsp/utility.h: No such file or directory
> Could this be a race condition in the build system on a parallel build?
Yes it could be, it is with a parallel build patch I am testing. The box
is loaded with parallel build jobs with make jobs. I am seeing ...
Average BSP Build Time: 0:00:18.645844
