arm/rtl22xx_t build failures
Tue May 23 08:31:14 UTC 2017
On 23/5/17 6:26 pm, Chris Johns wrote:
> On 23/5/17 5:49 pm, Sebastian Huber wrote:
>> On 23/05/17 09:34, Chris Johns wrote:
>>> Here is the build failures for ARM with current tools. Note, there are
>>> 2 failures in the list. The new one is in failure 17:
>>>       error: lpc32xx_mzx/lib/include/bsp/lpc32xx.h:27:25: fatal error:
>>>              bsp/utility.h: No such file or directory
>> Could this be a race condition in the build system on a parallel build?
> Yes it could be, it is with a parallel build patch I am testing. The box
> is loaded with parallel build jobs with make jobs.
The stand alone build works so there is something here I will need to
look into.
