arm/rtl22xx_t build failures
Tue May 23 08:43:11 UTC 2017
On 23/05/17 10:35, Chris Johns wrote:
> On 23/5/17 6:31 pm, Chris Johns wrote:
>> On 23/5/17 6:26 pm, Chris Johns wrote:
>>> On 23/5/17 5:49 pm, Sebastian Huber wrote:
>>>> On 23/05/17 09:34, Chris Johns wrote:
>>>>> Here is the build failures for ARM with current tools. Note, there are
>>>>> 2 failures in the list. The new one is in failure 17:
>>>>>        error: lpc32xx_mzx/lib/include/bsp/lpc32xx.h:27:25: fatal error:
>>>>>               bsp/utility.h: No such file or directory
>>>> Could this be a race condition in the build system on a parallel build?
>>> Yes it could be, it is with a parallel build patch I am testing. The box
>>> is loaded with parallel build jobs with make jobs.
>> The stand alone build works so there is something here I will need to
>> look into.
> The build was not with my changes, it is the standard build system so
> this looks like something that exists in the current build system.
I cannot reproduce this problem. A build with your command line worked here.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
