arm/rtl22xx_t build failures
Tue May 23 08:35:35 UTC 2017
On 23/5/17 6:31 pm, Chris Johns wrote:
> On 23/5/17 6:26 pm, Chris Johns wrote:
>> On 23/5/17 5:49 pm, Sebastian Huber wrote:
>>> On 23/05/17 09:34, Chris Johns wrote:
>>>> Here is the build failures for ARM with current tools. Note, there are
>>>> 2 failures in the list. The new one is in failure 17:
>>>>       error: lpc32xx_mzx/lib/include/bsp/lpc32xx.h:27:25: fatal error:
>>>>              bsp/utility.h: No such file or directory
>>> Could this be a race condition in the build system on a parallel build?
>> Yes it could be, it is with a parallel build patch I am testing. The box
>> is loaded with parallel build jobs with make jobs.
> The stand alone build works so there is something here I will need to
> look into.
The build was not with my changes, it is the standard build system so
this looks like something that exists in the current build system.
