arm/rtl22xx_t build failures
Wed May 24 00:00:24 UTC 2017
On 24/05/2017 07:31, Chris Johns wrote:
>     5 tests m32c/m32csim build:
>        configure: /opt/work/chris/rtems/kernel/rtems.git/configure --target\
>        =m32c-rtems4.12 --enable-rtemsbsp=m32csim --prefix=/opt/rtems/4.12\
>        --enable-tests
>       error: testsuites/fstests/jffs2_support/fs_support.c:37:17: error:
>              size of array 'area' is too large
The `fsjffs2gc01` test is missing from
testsuites/testdata/disable-jffs2-tests.tcfg.
