arm/rtl22xx_t build failures
Wed May 24 05:30:26 UTC 2017
On 23/05/17 23:31, Chris Johns wrote:
> The build log shows this happening with the lpc1768_mbed where the headers bootcard.h and utility.h are being installed again. The utility.h had been installed during the preinstall phase. It is only when this second install happens does the error appear:
> arm-rtems4.12-gcc --pipe -B../../../../../.././lib/  -B../../../../../.././lpc1768_mbed/lib/  -specs bsp_specs -qrtems -DHAVE_CONFIG_H   -I/opt/work/chris/rtems/kernel/rtems.git/c/src/lib/libbsp/arm/lpc176x/../../../libcpu/arm/shared/include -march=armv7-m -mthumb -O2 -ggdb3
> -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
> -MT libbsp_a-bspstarthooks.o -MD -MP -MF
> .deps/libbsp_a-bspstarthooks.Tpo -c -o libbsp_a-bspstarthooks.o `test
> -f 'startup/bspstarthooks.c' || echo
> '/opt/work/chris/rtems/kernel/rtems.git/c/src/lib/libbsp/arm/lpc176x/'`startup/bspstarthooks.c
> /usr/bin/install -c -m 644 start.o ../../../../../.././lpc1768_mbed/lib/start.o
> mv -f .deps/libbsp_a-timer.Tpo .deps/libbsp_a-timer.Po
> mv -f .deps/libbsp_a-bspidle.Tpo .deps/libbsp_a-bspidle.Po
> mv -f .deps/libbsp_a-dma-copy.Tpo .deps/libbsp_a-dma-copy.Po
> mv -f .deps/libbsp_a-dma.Tpo .deps/libbsp_a-dma.Po
> mv -f .deps/libbsp_a-system-clocks.Tpo .deps/libbsp_a-system-clocks.Po
> mv -f .deps/libbsp_a-adc.Tpo .deps/libbsp_a-adc.Po
> /usr/bin/install -c -m 644 startup/linkcmds ../../../../../.././lpc1768_mbed/lib/linkcmds
> mv -f .deps/libbsp_a-restart.Tpo .deps/libbsp_a-restart.Po
> /opt/work/chris/rtems/kernel/rtems.git/c/src/lib/libbsp/arm/lpc176x/../../shared/include/bootcard.h ../../../../../.././lpc1768_mbed/lib/include/bsp/bootcard.h
> /opt/work/chris/rtems/kernel/rtems.git/c/src/lib/libbsp/arm/lpc176x/../../shared/include/utility.h ../../../../../.././lpc1768_mbed/lib/include/bsp/utility.h
> rm -f libbspstart.a
> In file included from ../../../../../.././lpc1768_mbed/lib/include/bsp/lpc176x.h:25:0,
>                   from ../../../../../.././lpc1768_mbed/lib/include/bsp/io-defs.h:25,
>                   from ../../../../../.././lpc1768_mbed/lib/include/bsp/io.h:27,
>                   from /opt/work/chris/rtems/kernel/rtems.git/c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c:25:
> ../../../../../.././lpc1768_mbed/lib/include/bsp/lpc-i2s.h:26:25: fatal error: bsp/utility.h: No such file or directory
>   #include <bsp/utility.h>
> compilation terminated.
Maybe its time to get rid of the make preinstall.
> There are a few warnings related to the dirstamp:
> Makefile:1602: warning: overriding recipe for target '../cpukit/../../../lpc17xx_plx800_rom_int/lib/include/.dirstamp'
> Makefile:1573: warning: ignoring old recipe for target '../cpukit/../../../lpc17xx_plx800_rom_int/lib/include/.dirstamp'
I noticed this before, but I have no idea how to fix this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
