rtems-tools build errors after coverage tools patches
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat May 27 22:28:51 UTC 2017
Ok sorry I've just realised the const strings split(...) function is
obviously something else with the split bit.
For the problem line void write_lines (const rld::strings& ss);
If I remove 'const' I get
../rtl-host/rld-process.h:175:30: error: ‘rld::strings’ has not been
declared
void write_lines (rld::strings& ss);
If I change to 'const' to 'void' I get
../rtl-host/rld-process.h:175:42: error: expected unqualified-id before ‘&’
token
void write_lines (void rld::strings& ss);
../rtl-host/rld-process.h:175:42: error: expected ‘)’ before ‘&’ token
../rtl-host/rld-process.h:175:42: error: expected ‘;’ at end of member
declaration
../rtl-host/rld-process.h:175:44: error: ‘ss’ does not name a type
If I remove the line completely just to see will it run without it
[146/147] Linking build/tester/covoar/covoar
/usr/bin/ld: cannot find -lrld
/usr/bin/ld: cannot find -liberty
/usr/bin/ld: cannot find -lelf
collect2: error: ld returned 1 exit status
I can't really think of anything else to try, any hints at all would be
great.
Thanks,
Cillian.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170527/dd4f4f41/attachment.html>
