rtems-test runtime errors qemu.cfg
Cillian O'Donnell
cpodonnell8 at gmail.com
Tue May 30 20:50:33 UTC 2017
Hi Tanu,
Thanks for the help, I had been grepping through the files and backtracking
through the definitions. I was just wondering was there a quick way to just
print it out that I didn't know about.
I also couldn't find the recipe for the bsp but the previous work I'm
continuing on from worked for pc386 and leon2, the command I'm using is the
standard command with an extra --coverage flag thats added in the work I'm
continuing, it definitely worked in 2015.
$HOME/development/rtems/test/rtems-tools/tester/rtems-test --rtems-bsp=pc386 \
--log=log_pc386 --coverage \
--rtems-tools=$HOME/development/rtems/4.12 \
$HOME/development/rtems/pc386/i386-rtems4.12/c/pc386/testsuites/
On 30 May 2017 at 20:34, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> Hi Cillian,
> I usually do a git grep -i "<string>" to find out where possibly a
> macro or variable is used elsewhere in the code. Not the best way, but
> works mostly.
> Also %{qemu_cmd} has been defined here in the same file
> (https://devel.rtems.org/browser/rtems-tools/tester/
> rtems/testing/qemu.cfg#L60).
> I also sometimes use winpdb to see what value a macro has but this is
> a long process to step into each line.
> I wanted to ask what command did you use exactly with rtems-test? I
> couldn't find a recipe for qemu simulation for pc386 in
> rtems-tools.git/tester/rtems/testing/bsps.
> Regards,
> Tanu Hari Dixit.
> On Wed, May 31, 2017 at 12:42 AM, Cillian O'Donnell
> <cpodonnell8 at gmail.com> wrote:
> > Hi,
> > I'm trying to run rtems-test for pc386 with the added --coverage tag for
> > couverture-qemu. All tests default to dry-run because of errors in
> qemu.cfg
> > error: qemu.cfg:81: execute failed: qemu-system-i386 -m 128 -boot b -hda
> > /home/cpod/development/rtems/test/rtems-tools/tester/rtems/
> testing/coverage/rtems-boot.img
> > -no-reboot -serial null -serial mon:stdio -nographic -append
> > "--console=com1;boot;" -kernel
> > /home/cpod/development/rtems/pc386/i386-rtems4.12/c/pc386/
> testsuites/samples/unlimited/unlimited.exe
> > -exec-trace coverage/unlimited.exe.cov: exit-code:2
> > warning: switched to dry run due to errors
> > The exit code I believe refers to 'no such file or directory'. In
> qemu.cfg
> > the line is:
> > %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
> %{coverage_arg}
> > It's a bit tricky to trace those macros back to different files and see
> what
> > they have. Is there any way to just print those out when it runs so I can
> > take a look at them.
> > I tried %print %{qemu_cmd} and %echo %{qemu_cmd}. Is there any way to do
> > this in a config file?
> > Thanks,
> > Cillian.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170530/c18a011a/attachment.html>
