rtems-test runtime errors qemu.cfg
Cillian O'Donnell
cpodonnell8 at gmail.com
Tue May 30 21:23:48 UTC 2017
Ah nevermind.. just realised its already printing them out.
On 30 May 2017 9:50 pm, "Cillian O'Donnell" <cpodonnell8 at gmail.com> wrote:
> Hi Tanu,
> Thanks for the help, I had been grepping through the files and
> backtracking through the definitions. I was just wondering was there a
> quick way to just print it out that I didn't know about.
> I also couldn't find the recipe for the bsp but the previous work I'm
> continuing on from worked for pc386 and leon2, the command I'm using is the
> standard command with an extra --coverage flag thats added in the work I'm
> continuing, it definitely worked in 2015.
> $HOME/development/rtems/test/rtems-tools/tester/rtems-test --rtems-bsp=pc386 \
> --log=log_pc386 --coverage \
> --rtems-tools=$HOME/development/rtems/4.12 \
> $HOME/development/rtems/pc386/i386-rtems4.12/c/pc386/testsuites/
> On 30 May 2017 at 20:34, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>> Hi Cillian,
>> I usually do a git grep -i "<string>" to find out where possibly a
>> macro or variable is used elsewhere in the code. Not the best way, but
>> works mostly.
>> Also %{qemu_cmd} has been defined here in the same file
>> (https://devel.rtems.org/browser/rtems-tools/tester/rtems/
>> testing/qemu.cfg#L60).
>> I also sometimes use winpdb to see what value a macro has but this is
>> a long process to step into each line.
>> I wanted to ask what command did you use exactly with rtems-test? I
>> couldn't find a recipe for qemu simulation for pc386 in
>> rtems-tools.git/tester/rtems/testing/bsps.
>> Regards,
>> Tanu Hari Dixit.
>> On Wed, May 31, 2017 at 12:42 AM, Cillian O'Donnell
>> > Hi,
>> > I'm trying to run rtems-test for pc386 with the added --coverage tag for
>> > couverture-qemu. All tests default to dry-run because of errors in
>> qemu.cfg
>> > error: qemu.cfg:81: execute failed: qemu-system-i386 -m 128 -boot b -hda
>> > /home/cpod/development/rtems/test/rtems-tools/tester/rtems/t
>> esting/coverage/rtems-boot.img
>> > -no-reboot -serial null -serial mon:stdio -nographic -append
>> > "--console=com1;boot;" -kernel
>> > /home/cpod/development/rtems/pc386/i386-rtems4.12/c/pc386/te
>> stsuites/samples/unlimited/unlimited.exe
>> > -exec-trace coverage/unlimited.exe.cov: exit-code:2
>> > warning: switched to dry run due to errors
>> > The exit code I believe refers to 'no such file or directory'. In
>> qemu.cfg
>> > the line is:
>> > %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>> %{coverage_arg}
>> > It's a bit tricky to trace those macros back to different files and see
>> what
>> > they have. Is there any way to just print those out when it runs so I
>> can
>> > take a look at them.
>> > I tried %print %{qemu_cmd} and %echo %{qemu_cmd}. Is there any way to
>> do
>> > this in a config file?
>> > Thanks,
>> > Cillian.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170530/ddf0d0ae/attachment.html>
