rtems-test runtime errors qemu.cfg
Tue May 30 23:31:57 UTC 2017
Does it work without --coverage flag?
On Tue, May 30, 2017 at 5:23 PM, Cillian O'Donnell
<cpodonnell8 at gmail.com> wrote:
> Ah nevermind.. just realised its already printing them out.
> On 30 May 2017 9:50 pm, "Cillian O'Donnell" <cpodonnell8 at gmail.com> wrote:
>> Hi Tanu,
>> Thanks for the help, I had been grepping through the files and
>> backtracking through the definitions. I was just wondering was there a quick
>> way to just print it out that I didn't know about.
>> I also couldn't find the recipe for the bsp but the previous work I'm
>> continuing on from worked for pc386 and leon2, the command I'm using is the
>> standard command with an extra --coverage flag thats added in the work I'm
>> continuing, it definitely worked in 2015.
>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>> --rtems-bsp=pc386 \
>> --log=log_pc386 --coverage \
>> --rtems-tools=$HOME/development/rtems/4.12 \
>> $HOME/development/rtems/pc386/i386-rtems4.12/c/pc386/testsuites/
>> On 30 May 2017 at 20:34, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>>> Hi Cillian,
>>> I usually do a git grep -i "<string>" to find out where possibly a
>>> macro or variable is used elsewhere in the code. Not the best way, but
>>> works mostly.
>>> Also %{qemu_cmd} has been defined here in the same file
>>> (https://devel.rtems.org/browser/rtems-tools/tester/rtems/testing/qemu.cfg#L60).
>>> I also sometimes use winpdb to see what value a macro has but this is
>>> a long process to step into each line.
>>> I wanted to ask what command did you use exactly with rtems-test? I
>>> couldn't find a recipe for qemu simulation for pc386 in
>>> rtems-tools.git/tester/rtems/testing/bsps.
>>> Regards,
>>> Tanu Hari Dixit.
>>> On Wed, May 31, 2017 at 12:42 AM, Cillian O'Donnell
>>> > Hi,
>>> > I'm trying to run rtems-test for pc386 with the added --coverage tag
>>> > for
>>> > couverture-qemu. All tests default to dry-run because of errors in
>>> > qemu.cfg
>>> > error: qemu.cfg:81: execute failed: qemu-system-i386 -m 128 -boot b
>>> > -hda
>>> > /home/cpod/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/rtems-boot.img
>>> > -no-reboot -serial null -serial mon:stdio -nographic -append
>>> > "--console=com1;boot;" -kernel
>>> > /home/cpod/development/rtems/pc386/i386-rtems4.12/c/pc386/testsuites/samples/unlimited/unlimited.exe
>>> > -exec-trace coverage/unlimited.exe.cov: exit-code:2
>>> > warning: switched to dry run due to errors
>>> > The exit code I believe refers to 'no such file or directory'. In
>>> > qemu.cfg
>>> > the line is:
>>> > %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>> > %{coverage_arg}
>>> > It's a bit tricky to trace those macros back to different files and see
>>> > what
>>> > they have. Is there any way to just print those out when it runs so I
>>> > can
>>> > take a look at them.
>>> > I tried %print %{qemu_cmd} and  %echo %{qemu_cmd}. Is there any way to
>>> > do
>>> > this in a config file?
>>> > Thanks,
>>> > Cillian.
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
