[PATCH] Added documentation for rtems-tester in rtems-docs
Tanu Hari Dixit tokencolour at gmail.com
Wed May 31 13:52:38 UTC 2017
Hello Chris, Gedare,
I have revised the patch and sent it again. Thank you.
Tanu.
On Wed, May 31, 2017 at 6:09 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 31/05/2017 03:10, Tanu Hari Dixit wrote:
>> I just added the image following what was already in rtems-tools.git
>> repo. Maybe it is not really needed there. Maybe it was added to the
>> previous doc because it was a stand-alone doc.
> Yes this is correct. The User Manual is newer and has a consistent feel we
> must maintain.
>> I will pull that out.
>> What do you think? What does Chris think?
> The text needs to be merged into the User Manual converting it to ReST
> format. I suggest you review the RTEMS BSP Builder [1] command as an
> example. That format _must_ be followed for the Tools. Please create a new
> file for this command and include after the RTEMS BSP Builder command.
> Thanks
> Chris
> [1]
> https://docs.rtems.org/branches/master/user/tools/index.html#rtems-bsp-builder
