[PATCH] cpukit: Fix __RTEMS_REVISION__ define
    Chris Johns
    chrisj at rtems.org
    Wed May  3 06:17:56 UTC 2017
On 3/5/17 3:40 pm, Sebastian Huber wrote:
> On 03/05/17 07:28, Chris Johns wrote:
>> On 3/5/17 3:09 pm, Sebastian Huber wrote:
>>> On 02/05/17 23:30, Chris Johns wrote:
>>>> On 2/5/17 6:20 pm, Sebastian Huber wrote:
>>>> If you want to add this test please extract the version details from
>>>> the
>>>> build system
>>> Can we trust the build system?
>> Given the header file with the values it created by the build system yes
>> we can.
> I don't think we can trust the build system. The requirement for a
> release is that the version macros should have specific values. We
> should test that this is the case.
We have to trust the build system for a clean or fresh build and if we
cannot not it is a bug. To state otherwise expands the scope of
uncertainty and I do not believe we need too.
I will state again, doing this breaks the release process. I am sorry
but this is just now the release model and supporting configuration
control structures exist.
> Maybe we have some time in the future something like this:
> Requirement 2341: There shall be a C pre-processor define
> __RTEMS_MAJOR__ available via #include <rtems.h> defined to 123.
I doubt this would be in the RTEMS Project's requirements. It might be
in a qualification package for the specific qualification effort. How
that define it created is for the RTEMS Project to determine.
