Failures with rtems-bsp-builder
Joel Sherrill
joel at rtems.org
Wed Nov 1 11:28:27 UTC 2017
Looks like some variation of the %%s issue is still present:
[ 1/1565] arm/altcycv_devkit (debug) Start
[ 1/1565] arm/altcycv_devkit (debug) Creating:
build/arm/altcycv_devkit.debug
[ 1/1565] arm/altcycv_devkit (debug) Configuring
run: %s: arm/altcycv_devkit.debug\
/home/joel/rtems-work/rtems/configure --target=arm-rtems4.12\
--enable-rtemsbsp=altcycv_devkit --prefix=/home/joel/rtems-\
work/bsps --enable-debug
[ 1/1565] arm/altcycv_devkit (debug) Building
make -j 12
I will let it go and see if it picks up the build failures I know
currently exist.
--joel
On Tue, Oct 31, 2017 at 10:31 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 01/11/2017 10:06, Chris Johns wrote:
> > I am seeing this as well and will fix it today.
> Fixed. I have pushed a fix. I can build tier-1 BSPs.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171101/0a58a2f8/attachment.html>
