Failures with rtems-bsp-builder
Wed Nov 1 22:05:59 UTC 2017
On 01/11/2017 22:32, Joel Sherrill wrote:
> Well there are different failures:
> /usr/bin/install -c -m 644
> /home/joel/rtems-work/rtems/c/src/libchip/i2c/spi-flash-m25p40.h
> ../../../altcycv_devkit/lib/include/libchip/spi-flash-m25p40.h
> /usr/bin/install: cannot create regular file
> ‘../../../altcycv_devkit/lib/include/libchip/spi-memdrv.h’: File exists
> /home/joel/rtems-work/rtems/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
> ../../../../.././altcycv_devkit/lib/linkcmds.base
> gmake[4]: *** [../../../altcycv_devkit/lib/include/libchip/spi-memdrv.h] Error 1
> gmake[4]: Leaving directory
> `/data/home/joel/rtems-work/build/arm/altcycv_devkit.no-posix/arm-rtems4.12/c/altcycv_devkit/libchip'
> gmake[3]: *** [preinstall-libchip] Error 1
> gmake[3]: *** Waiting for unfinished jobs....
> Looks like something in the -j12 on rtbf64c.
Is this a build system failure?
