RTEMS Tier Allocations.
Tue Nov 7 15:30:23 UTC 2017
On 8/11/17 2:18 am, Joel Sherrill wrote:
> Nothing specifically. Just noting that the GCC community has been testing
> and sending results to a mailing list for a LONG time. They have developed
> a process and use cases. It is doubtful that we will find a use case they
> haven't already encountered.
> Their process allows for:
> + running tests (make check) and not sending results
> + running tests and sending results immediately
> + running tests and then later sending results
> + without running tests, resending results (helpful to send to
>    two mailing lists or if first send fails).
Thanks, this helps.
> The results sending script doesn't have many options:
> https://github.com/gcc-mirror/gcc/blob/master/contrib/test_summary
> All I am suggesting is that those four use cases are sufficient for the
> GCC Community so if the RTEMS tester can do that, then we should
> be covered as well. Just using them to give us use cases.
I think we are covered or close. I will add a section to the doco on this.
