RTEMS Tier Allocations.
Joel Sherrill
joel at rtems.org
Tue Nov 7 15:34:47 UTC 2017
On Tue, Nov 7, 2017 at 9:30 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 8/11/17 2:18 am, Joel Sherrill wrote:
> > Nothing specifically. Just noting that the GCC community has been testing
> > and sending results to a mailing list for a LONG time. They have
> developed
> > a process and use cases. It is doubtful that we will find a use case they
> > haven't already encountered.
> > Their process allows for:
> > + running tests (make check) and not sending results
> > + running tests and sending results immediately
> > + running tests and then later sending results
> > + without running tests, resending results (helpful to send to
> > two mailing lists or if first send fails).
> Thanks, this helps.
No problem. It just felt like we were wandering along figuring out the
same use cases again when we could learn from others.
> > The results sending script doesn't have many options:
> > https://github.com/gcc-mirror/gcc/blob/master/contrib/test_summary
> > All I am suggesting is that those four use cases are sufficient for the
> > GCC Community so if the RTEMS tester can do that, then we should
> > be covered as well. Just using them to give us use cases.
> I think we are covered or close. I will add a section to the doco on this.
I agree we are close. Just thought the GCC view of testing would help.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171107/9ffbd3c5/attachment.html>
