[PATCH 01/10] Import wpa from FreeBSD
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Nov 8 12:33:00 UTC 2017
 freebsd/contrib/wpa/src/ap/ap_config.h             |  692 ++
 freebsd/contrib/wpa/src/ap/ap_drv_ops.c            |  844 ++
 freebsd/contrib/wpa/src/ap/ap_drv_ops.h            |  340 +
 freebsd/contrib/wpa/src/ap/hostapd.h               |  494 +
 freebsd/contrib/wpa/src/ap/hs20.c                  |  179 +
 freebsd/contrib/wpa/src/ap/hs20.h                  |   22 +
 freebsd/contrib/wpa/src/ap/ieee802_11.h            |  107 +
 freebsd/contrib/wpa/src/ap/ieee802_11_auth.h       |   29 +
 freebsd/contrib/wpa/src/ap/ieee802_11_shared.c     |  510 ++
 freebsd/contrib/wpa/src/ap/p2p_hostapd.h           |   35 +
 freebsd/contrib/wpa/src/ap/sta_info.h              |  241 +
 freebsd/contrib/wpa/src/common/defs.h              |  337 +
 freebsd/contrib/wpa/src/common/eapol_common.h      |   92 +
 freebsd/contrib/wpa/src/common/gas.c               |  275 +
 freebsd/contrib/wpa/src/common/gas.h               |   37 +
 .../contrib/wpa/src/common/hw_features_common.c    |  457 +
 .../contrib/wpa/src/common/hw_features_common.h    |   39 +
 freebsd/contrib/wpa/src/common/ieee802_11_common.c | 1149 +++
 freebsd/contrib/wpa/src/common/ieee802_11_common.h |  128 +
 freebsd/contrib/wpa/src/common/ieee802_11_defs.h   | 1436 +++
 freebsd/contrib/wpa/src/common/qca-vendor.h        |  357 +
 freebsd/contrib/wpa/src/common/sae.h               |   70 +
 freebsd/contrib/wpa/src/common/version.h           |   10 +
 freebsd/contrib/wpa/src/common/wpa_common.c        | 1666 ++++
 freebsd/contrib/wpa/src/common/wpa_common.h        |  451 +
 freebsd/contrib/wpa/src/common/wpa_ctrl.h          |  472 +
 freebsd/contrib/wpa/src/crypto/aes-ctr.c           |   57 +
 freebsd/contrib/wpa/src/crypto/aes-eax.c           |  147 +
 freebsd/contrib/wpa/src/crypto/aes-encblock.c      |   34 +
 freebsd/contrib/wpa/src/crypto/aes-omac1.c         |  172 +
 freebsd/contrib/wpa/src/crypto/aes-unwrap.c        |   82 +
 freebsd/contrib/wpa/src/crypto/aes.h               |   21 +
 freebsd/contrib/wpa/src/crypto/aes_wrap.h          |   71 +
 freebsd/contrib/wpa/src/crypto/crypto.h            |  809 ++
 freebsd/contrib/wpa/src/crypto/crypto_openssl.c    | 1444 +++
 freebsd/contrib/wpa/src/crypto/dh_group5.h         |   18 +
 freebsd/contrib/wpa/src/crypto/md5.h               |   19 +
 freebsd/contrib/wpa/src/crypto/ms_funcs.c          |  526 ++
 freebsd/contrib/wpa/src/crypto/ms_funcs.h          |   60 +
 freebsd/contrib/wpa/src/crypto/random.c            |  441 +
 freebsd/contrib/wpa/src/crypto/random.h            |   28 +
 freebsd/contrib/wpa/src/crypto/rc4.c               |   56 +
 freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c       |   94 +
 freebsd/contrib/wpa/src/crypto/sha1-prf.c          |   69 +
 freebsd/contrib/wpa/src/crypto/sha1.c              |  109 +
 freebsd/contrib/wpa/src/crypto/sha1.h              |   27 +
 freebsd/contrib/wpa/src/crypto/sha256-internal.c   |  228 +
 freebsd/contrib/wpa/src/crypto/sha256-prf.c        |  102 +
 freebsd/contrib/wpa/src/crypto/sha256.h            |   30 +
 freebsd/contrib/wpa/src/crypto/sha256_i.h          |   25 +
 freebsd/contrib/wpa/src/crypto/sha384.h            |   24 +
 freebsd/contrib/wpa/src/crypto/tls.h               |  588 ++
 freebsd/contrib/wpa/src/crypto/tls_internal.c      |  735 ++
 freebsd/contrib/wpa/src/drivers/driver.h           | 4704 ++++++++++
 freebsd/contrib/wpa/src/drivers/driver_bsd.c       | 1675 ++++
 freebsd/contrib/wpa/src/drivers/driver_common.c    |  222 +
 freebsd/contrib/wpa/src/drivers/driver_ndis.c      | 3221 +++++++
 freebsd/contrib/wpa/src/drivers/driver_ndis.h      |   59 +
 freebsd/contrib/wpa/src/drivers/driver_nl80211.h   |  277 +
 freebsd/contrib/wpa/src/drivers/driver_wired.c     |  681 ++
 freebsd/contrib/wpa/src/drivers/drivers.c          |   88 +
 freebsd/contrib/wpa/src/drivers/linux_defines.h    |   46 +
 freebsd/contrib/wpa/src/eap_common/chap.c          |   30 +
 freebsd/contrib/wpa/src/eap_common/chap.h          |   17 +
 freebsd/contrib/wpa/src/eap_common/eap_common.c    |  290 +
 freebsd/contrib/wpa/src/eap_common/eap_common.h    |   33 +
 freebsd/contrib/wpa/src/eap_common/eap_defs.h      |  118 +
 .../contrib/wpa/src/eap_common/eap_peap_common.c   |   87 +
 .../contrib/wpa/src/eap_common/eap_peap_common.h   |   16 +
 .../contrib/wpa/src/eap_common/eap_psk_common.c    |   70 +
 .../contrib/wpa/src/eap_common/eap_psk_common.h    |   72 +
 .../contrib/wpa/src/eap_common/eap_tlv_common.h    |  112 +
 freebsd/contrib/wpa/src/eap_common/eap_ttls.h      |   65 +
 .../contrib/wpa/src/eap_common/eap_wsc_common.h    |   27 +
 freebsd/contrib/wpa/src/eap_peer/eap.c             | 2952 ++++++
 freebsd/contrib/wpa/src/eap_peer/eap.h             |  354 +
 freebsd/contrib/wpa/src/eap_peer/eap_config.h      |  774 ++
 freebsd/contrib/wpa/src/eap_peer/eap_gtc.c         |  147 +
 freebsd/contrib/wpa/src/eap_peer/eap_i.h           |  389 +
 freebsd/contrib/wpa/src/eap_peer/eap_leap.c        |  415 +
 freebsd/contrib/wpa/src/eap_peer/eap_md5.c         |  122 +
 freebsd/contrib/wpa/src/eap_peer/eap_methods.c     |  371 +
 freebsd/contrib/wpa/src/eap_peer/eap_methods.h     |  111 +
 freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c    |  903 ++
 freebsd/contrib/wpa/src/eap_peer/eap_otp.c         |  103 +
 freebsd/contrib/wpa/src/eap_peer/eap_peap.c        | 1264 +++
 freebsd/contrib/wpa/src/eap_peer/eap_proxy.h       |   49 +
 freebsd/contrib/wpa/src/eap_peer/eap_psk.c         |  504 ++
 freebsd/contrib/wpa/src/eap_peer/eap_tls.c         |  441 +
 freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c  | 1110 +++
 freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h  |  132 +
 freebsd/contrib/wpa/src/eap_peer/eap_ttls.c        | 1723 ++++
 freebsd/contrib/wpa/src/eap_peer/mschapv2.c        |  126 +
 freebsd/contrib/wpa/src/eap_peer/mschapv2.h        |   28 +
 freebsd/contrib/wpa/src/eap_peer/tncc.h            |   36 +
 freebsd/contrib/wpa/src/eap_server/eap_methods.h   |   51 +
 freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c | 2152 +++++
 freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h |  443 +
 freebsd/contrib/wpa/src/fst/fst.h                  |  296 +
 freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h         |   91 +
 freebsd/contrib/wpa/src/fst/fst_ctrl_iface.h       |   45 +
 freebsd/contrib/wpa/src/l2_packet/l2_packet.h      |  154 +
 .../contrib/wpa/src/l2_packet/l2_packet_freebsd.c  |  331 +
 freebsd/contrib/wpa/src/p2p/p2p.h                  | 2343 +++++
 freebsd/contrib/wpa/src/rsn_supp/peerkey.c         | 1157 +++
 freebsd/contrib/wpa/src/rsn_supp/peerkey.h         |   82 +
 freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c     |  539 ++
 freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h     |  134 +
 freebsd/contrib/wpa/src/rsn_supp/preauth.c         |  543 ++
 freebsd/contrib/wpa/src/rsn_supp/preauth.h         |   79 +
 freebsd/contrib/wpa/src/rsn_supp/wpa.c             | 2979 ++++++
 freebsd/contrib/wpa/src/rsn_supp/wpa.h             |  421 +
 freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c          |  849 ++
 freebsd/contrib/wpa/src/rsn_supp/wpa_i.h           |  371 +
 freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c          |  607 ++
 freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h          |   72 +
 freebsd/contrib/wpa/src/tls/tlsv1_client.h         |   54 +
 freebsd/contrib/wpa/src/tls/tlsv1_cred.h           |   40 +
 freebsd/contrib/wpa/src/tls/tlsv1_server.h         |   53 +
 freebsd/contrib/wpa/src/utils/base64.c             |  159 +
 freebsd/contrib/wpa/src/utils/base64.h             |   17 +
 freebsd/contrib/wpa/src/utils/build_config.h       |   50 +
 freebsd/contrib/wpa/src/utils/common.c             | 1127 +++
 freebsd/contrib/wpa/src/utils/common.h             |  559 ++
 freebsd/contrib/wpa/src/utils/eloop.c              | 1144 +++
 freebsd/contrib/wpa/src/utils/eloop.h              |  359 +
 freebsd/contrib/wpa/src/utils/ext_password.h       |   33 +
 freebsd/contrib/wpa/src/utils/includes.h           |   45 +
 freebsd/contrib/wpa/src/utils/ip_addr.h            |   27 +
 freebsd/contrib/wpa/src/utils/list.h               |   97 +
 freebsd/contrib/wpa/src/utils/os.h                 |  664 ++
 freebsd/contrib/wpa/src/utils/os_unix.c            |  851 ++
 freebsd/contrib/wpa/src/utils/pcsc_funcs.h         |   42 +
 freebsd/contrib/wpa/src/utils/platform.h           |   21 +
 freebsd/contrib/wpa/src/utils/state_machine.h      |  138 +
 freebsd/contrib/wpa/src/utils/trace.h              |   69 +
 freebsd/contrib/wpa/src/utils/uuid.c               |   73 +
 freebsd/contrib/wpa/src/utils/uuid.h               |   18 +
 freebsd/contrib/wpa/src/utils/wpa_debug.c          |  862 ++
 freebsd/contrib/wpa/src/utils/wpa_debug.h          |  370 +
 freebsd/contrib/wpa/src/utils/wpabuf.c             |  314 +
 freebsd/contrib/wpa/src/utils/wpabuf.h             |  163 +
 freebsd/contrib/wpa/src/wps/http.h                 |   29 +
 freebsd/contrib/wpa/src/wps/http_client.c          |  364 +
 freebsd/contrib/wpa/src/wps/http_client.h          |   40 +
 freebsd/contrib/wpa/src/wps/http_server.c          |  316 +
 freebsd/contrib/wpa/src/wps/http_server.h          |   33 +
 freebsd/contrib/wpa/src/wps/httpread.c             |  850 ++
 freebsd/contrib/wpa/src/wps/httpread.h             |  117 +
 freebsd/contrib/wpa/src/wps/upnp_xml.c             |  254 +
 freebsd/contrib/wpa/src/wps/upnp_xml.h             |   25 +
 freebsd/contrib/wpa/src/wps/wps.c                  |  664 ++
 freebsd/contrib/wpa/src/wps/wps.h                  | 1041 +++
 freebsd/contrib/wpa/src/wps/wps_attr_build.c       |  487 +
 freebsd/contrib/wpa/src/wps/wps_attr_parse.c       |  665 ++
 freebsd/contrib/wpa/src/wps/wps_attr_parse.h       |  104 +
 freebsd/contrib/wpa/src/wps/wps_attr_process.c     |  274 +
 freebsd/contrib/wpa/src/wps/wps_common.c           |  911 ++
 freebsd/contrib/wpa/src/wps/wps_defs.h             |  379 +
 freebsd/contrib/wpa/src/wps/wps_dev_attr.c         |  421 +
 freebsd/contrib/wpa/src/wps/wps_dev_attr.h         |   39 +
 freebsd/contrib/wpa/src/wps/wps_enrollee.c         | 1510 ++++
 freebsd/contrib/wpa/src/wps/wps_er.h               |  112 +
 freebsd/contrib/wpa/src/wps/wps_i.h                |  218 +
 freebsd/contrib/wpa/src/wps/wps_registrar.c        | 3672 ++++++++
 freebsd/contrib/wpa/src/wps/wps_upnp.c             | 1214 +++
 freebsd/contrib/wpa/src/wps/wps_upnp.h             |   48 +
 freebsd/contrib/wpa/src/wps/wps_upnp_ap.c          |   85 +
 freebsd/contrib/wpa/src/wps/wps_upnp_event.c       |  423 +
 freebsd/contrib/wpa/src/wps/wps_upnp_i.h           |  193 +
 freebsd/contrib/wpa/src/wps/wps_upnp_ssdp.c        |  950 ++
 freebsd/contrib/wpa/src/wps/wps_upnp_web.c         | 1352 +++
 freebsd/contrib/wpa/wpa_supplicant/ap.h            |   98 +
 freebsd/contrib/wpa/wpa_supplicant/autoscan.h      |   49 +
 freebsd/contrib/wpa/wpa_supplicant/bgscan.h        |   73 +
 freebsd/contrib/wpa/wpa_supplicant/blacklist.c     |  143 +
 freebsd/contrib/wpa/wpa_supplicant/blacklist.h     |   24 +
 freebsd/contrib/wpa/wpa_supplicant/bss.c           | 1238 +++
 freebsd/contrib/wpa/wpa_supplicant/bss.h           |  150 +
 freebsd/contrib/wpa/wpa_supplicant/config.c        | 4359 +++++++++
 freebsd/contrib/wpa/wpa_supplicant/config.h        | 1342 +++
 freebsd/contrib/wpa/wpa_supplicant/config_file.c   | 1389 +++
 freebsd/contrib/wpa/wpa_supplicant/config_ssid.h   |  724 ++
 freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c    | 9480 ++++++++++++++++++++
 freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.h    |  159 +
 .../contrib/wpa/wpa_supplicant/ctrl_iface_unix.c   | 1220 +++
 .../contrib/wpa/wpa_supplicant/dbus/dbus_common.h  |   20 +
 freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_new.h |  557 ++
 freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_old.h |  142 +
 freebsd/contrib/wpa/wpa_supplicant/driver_i.h      |  915 ++
 freebsd/contrib/wpa/wpa_supplicant/eap_register.c  |  263 +
 freebsd/contrib/wpa/wpa_supplicant/events.c        | 3829 ++++++++
 freebsd/contrib/wpa/wpa_supplicant/gas_query.c     |  721 ++
 freebsd/contrib/wpa/wpa_supplicant/gas_query.h     |   59 +
 .../contrib/wpa/wpa_supplicant/hs20_supplicant.c   | 1011 +++
 .../contrib/wpa/wpa_supplicant/hs20_supplicant.h   |   41 +
 freebsd/contrib/wpa/wpa_supplicant/ibss_rsn.h      |   64 +
 freebsd/contrib/wpa/wpa_supplicant/interworking.c  | 3059 +++++++
 freebsd/contrib/wpa/wpa_supplicant/interworking.h  |   36 +
 freebsd/contrib/wpa/wpa_supplicant/main.c          |  361 +
 freebsd/contrib/wpa/wpa_supplicant/mesh.h          |   44 +
 freebsd/contrib/wpa/wpa_supplicant/mesh_mpm.h      |   43 +
 freebsd/contrib/wpa/wpa_supplicant/mesh_rsn.h      |   36 +
 freebsd/contrib/wpa/wpa_supplicant/notify.c        |  833 ++
 freebsd/contrib/wpa/wpa_supplicant/notify.h        |  144 +
 freebsd/contrib/wpa/wpa_supplicant/offchannel.c    |  449 +
 freebsd/contrib/wpa/wpa_supplicant/offchannel.h    |   35 +
 .../contrib/wpa/wpa_supplicant/p2p_supplicant.h    |  335 +
 freebsd/contrib/wpa/wpa_supplicant/scan.c          | 2466 +++++
 freebsd/contrib/wpa/wpa_supplicant/scan.h          |   58 +
 freebsd/contrib/wpa/wpa_supplicant/sme.h           |  118 +
 freebsd/contrib/wpa/wpa_supplicant/wifi_display.h  |   24 +
 freebsd/contrib/wpa/wpa_supplicant/wmm_ac.c        |  997 ++
 freebsd/contrib/wpa/wpa_supplicant/wmm_ac.h        |  176 +
 freebsd/contrib/wpa/wpa_supplicant/wnm_sta.h       |   77 +
 .../contrib/wpa/wpa_supplicant/wpa_supplicant.c    | 5872 ++++++++++++
 .../contrib/wpa/wpa_supplicant/wpa_supplicant_i.h  | 1170 +++
 freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c     | 1131 +++
 freebsd/contrib/wpa/wpa_supplicant/wpas_glue.h     |   28 +
 freebsd/contrib/wpa/wpa_supplicant/wpas_kay.h      |   41 +
 .../contrib/wpa/wpa_supplicant/wps_supplicant.c    | 2904 ++++++
 .../contrib/wpa/wpa_supplicant/wps_supplicant.h    |  152 +
 freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.c     |  415 +
 freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.h     |   67 +
 freebsd/usr.sbin/wpa/wpa_supplicant/ntddndis.h     |   31 +
 225 files changed, 127499 insertions(+)
 create mode 100644 freebsd/contrib/wpa/src/ap/ap_config.h
 create mode 100644 freebsd/contrib/wpa/src/ap/ap_drv_ops.c
 create mode 100644 freebsd/contrib/wpa/src/ap/ap_drv_ops.h
 create mode 100644 freebsd/contrib/wpa/src/ap/hostapd.h
 create mode 100644 freebsd/contrib/wpa/src/ap/hs20.c
 create mode 100644 freebsd/contrib/wpa/src/ap/hs20.h
 create mode 100644 freebsd/contrib/wpa/src/ap/ieee802_11.h
 create mode 100644 freebsd/contrib/wpa/src/ap/ieee802_11_auth.h
 create mode 100644 freebsd/contrib/wpa/src/ap/ieee802_11_shared.c
 create mode 100644 freebsd/contrib/wpa/src/ap/p2p_hostapd.h
 create mode 100644 freebsd/contrib/wpa/src/ap/sta_info.h
 create mode 100644 freebsd/contrib/wpa/src/common/defs.h
 create mode 100644 freebsd/contrib/wpa/src/common/eapol_common.h
 create mode 100644 freebsd/contrib/wpa/src/common/gas.c
 create mode 100644 freebsd/contrib/wpa/src/common/gas.h
 create mode 100644 freebsd/contrib/wpa/src/common/hw_features_common.c
 create mode 100644 freebsd/contrib/wpa/src/common/hw_features_common.h
 create mode 100644 freebsd/contrib/wpa/src/common/ieee802_11_common.c
 create mode 100644 freebsd/contrib/wpa/src/common/ieee802_11_common.h
 create mode 100644 freebsd/contrib/wpa/src/common/ieee802_11_defs.h
 create mode 100644 freebsd/contrib/wpa/src/common/qca-vendor.h
 create mode 100644 freebsd/contrib/wpa/src/common/sae.h
 create mode 100644 freebsd/contrib/wpa/src/common/version.h
 create mode 100644 freebsd/contrib/wpa/src/common/wpa_common.c
 create mode 100644 freebsd/contrib/wpa/src/common/wpa_common.h
 create mode 100644 freebsd/contrib/wpa/src/common/wpa_ctrl.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes-ctr.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes-eax.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes-encblock.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes-omac1.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes-unwrap.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/aes_wrap.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/crypto.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/crypto_openssl.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/dh_group5.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/md5.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/ms_funcs.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/ms_funcs.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/random.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/random.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/rc4.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha1-prf.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha1.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha1.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha256-internal.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha256-prf.c
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha256.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha256_i.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/sha384.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/tls.h
 create mode 100644 freebsd/contrib/wpa/src/crypto/tls_internal.c
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver.h
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver_bsd.c
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver_common.c
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver_ndis.c
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver_ndis.h
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver_nl80211.h
 create mode 100644 freebsd/contrib/wpa/src/drivers/driver_wired.c
 create mode 100644 freebsd/contrib/wpa/src/drivers/drivers.c
 create mode 100644 freebsd/contrib/wpa/src/drivers/linux_defines.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/chap.c
 create mode 100644 freebsd/contrib/wpa/src/eap_common/chap.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_common.c
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_common.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_defs.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_peap_common.c
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_peap_common.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_psk_common.c
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_psk_common.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_tlv_common.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_ttls.h
 create mode 100644 freebsd/contrib/wpa/src/eap_common/eap_wsc_common.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_config.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_gtc.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_i.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_leap.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_md5.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_methods.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_methods.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_otp.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_peap.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_proxy.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_psk.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_tls.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/eap_ttls.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/mschapv2.c
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/mschapv2.h
 create mode 100644 freebsd/contrib/wpa/src/eap_peer/tncc.h
 create mode 100644 freebsd/contrib/wpa/src/eap_server/eap_methods.h
 create mode 100644 freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c
 create mode 100644 freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h
 create mode 100644 freebsd/contrib/wpa/src/fst/fst.h
 create mode 100644 freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h
 create mode 100644 freebsd/contrib/wpa/src/fst/fst_ctrl_iface.h
 create mode 100644 freebsd/contrib/wpa/src/l2_packet/l2_packet.h
 create mode 100644 freebsd/contrib/wpa/src/l2_packet/l2_packet_freebsd.c
 create mode 100644 freebsd/contrib/wpa/src/p2p/p2p.h
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/peerkey.c
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/peerkey.h
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/preauth.c
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/preauth.h
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/wpa.c
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/wpa.h
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/wpa_i.h
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c
 create mode 100644 freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h
 create mode 100644 freebsd/contrib/wpa/src/tls/tlsv1_client.h
 create mode 100644 freebsd/contrib/wpa/src/tls/tlsv1_cred.h
 create mode 100644 freebsd/contrib/wpa/src/tls/tlsv1_server.h
 create mode 100644 freebsd/contrib/wpa/src/utils/base64.c
 create mode 100644 freebsd/contrib/wpa/src/utils/base64.h
 create mode 100644 freebsd/contrib/wpa/src/utils/build_config.h
 create mode 100644 freebsd/contrib/wpa/src/utils/common.c
 create mode 100644 freebsd/contrib/wpa/src/utils/common.h
 create mode 100644 freebsd/contrib/wpa/src/utils/eloop.c
 create mode 100644 freebsd/contrib/wpa/src/utils/eloop.h
 create mode 100644 freebsd/contrib/wpa/src/utils/ext_password.h
 create mode 100644 freebsd/contrib/wpa/src/utils/includes.h
 create mode 100644 freebsd/contrib/wpa/src/utils/ip_addr.h
 create mode 100644 freebsd/contrib/wpa/src/utils/list.h
 create mode 100644 freebsd/contrib/wpa/src/utils/os.h
 create mode 100644 freebsd/contrib/wpa/src/utils/os_unix.c
 create mode 100644 freebsd/contrib/wpa/src/utils/pcsc_funcs.h
 create mode 100644 freebsd/contrib/wpa/src/utils/platform.h
 create mode 100644 freebsd/contrib/wpa/src/utils/state_machine.h
 create mode 100644 freebsd/contrib/wpa/src/utils/trace.h
 create mode 100644 freebsd/contrib/wpa/src/utils/uuid.c
 create mode 100644 freebsd/contrib/wpa/src/utils/uuid.h
 create mode 100644 freebsd/contrib/wpa/src/utils/wpa_debug.c
 create mode 100644 freebsd/contrib/wpa/src/utils/wpa_debug.h
 create mode 100644 freebsd/contrib/wpa/src/utils/wpabuf.c
 create mode 100644 freebsd/contrib/wpa/src/utils/wpabuf.h
 create mode 100644 freebsd/contrib/wpa/src/wps/http.h
 create mode 100644 freebsd/contrib/wpa/src/wps/http_client.c
 create mode 100644 freebsd/contrib/wpa/src/wps/http_client.h
 create mode 100644 freebsd/contrib/wpa/src/wps/http_server.c
 create mode 100644 freebsd/contrib/wpa/src/wps/http_server.h
 create mode 100644 freebsd/contrib/wpa/src/wps/httpread.c
 create mode 100644 freebsd/contrib/wpa/src/wps/httpread.h
 create mode 100644 freebsd/contrib/wpa/src/wps/upnp_xml.c
 create mode 100644 freebsd/contrib/wpa/src/wps/upnp_xml.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_attr_build.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_attr_parse.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_attr_parse.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_attr_process.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_common.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_defs.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_dev_attr.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_dev_attr.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_enrollee.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_er.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_i.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_registrar.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp_ap.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp_event.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp_i.h
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp_ssdp.c
 create mode 100644 freebsd/contrib/wpa/src/wps/wps_upnp_web.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/ap.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/autoscan.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/bgscan.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/blacklist.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/blacklist.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/bss.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/bss.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/config.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/config.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/config_file.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/config_ssid.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/ctrl_iface_unix.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_common.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_new.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/dbus/dbus_old.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/driver_i.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/eap_register.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/events.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/gas_query.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/gas_query.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/ibss_rsn.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/interworking.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/interworking.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/main.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/mesh.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/mesh_mpm.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/mesh_rsn.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/notify.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/notify.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/offchannel.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/offchannel.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/p2p_supplicant.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/scan.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/scan.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/sme.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wifi_display.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wmm_ac.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wmm_ac.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wnm_sta.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant_i.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wpas_glue.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wpas_kay.h
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.c
 create mode 100644 freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.h
 create mode 100644 freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.c
 create mode 100644 freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.h
 create mode 100644 freebsd/usr.sbin/wpa/wpa_supplicant/ntddndis.h
diff --git a/freebsd/contrib/wpa/src/ap/ap_config.h b/freebsd/contrib/wpa/src/ap/ap_config.h
new file mode 100644
index 00000000000..de470a969b5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/ap_config.h
@@ -0,0 +1,692 @@
+ * hostapd / Configuration definitions and helpers functions
+ * Copyright (c) 2003-2015, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef HOSTAPD_CONFIG_H
+#define HOSTAPD_CONFIG_H
+#include "common/defs.h"
+#include "ip_addr.h"
+#include "common/wpa_common.h"
+#include "common/ieee802_11_defs.h"
+#include "common/ieee802_11_common.h"
+#include "wps/wps.h"
+#include "fst/fst.h"
+ * mesh_conf - local MBSS state and settings
+struct mesh_conf {
+	u8 meshid[32];
+	u8 meshid_len;
+	/* Active Path Selection Protocol Identifier */
+	u8 mesh_pp_id;
+	/* Active Path Selection Metric Identifier */
+	u8 mesh_pm_id;
+	/* Congestion Control Mode Identifier */
+	u8 mesh_cc_id;
+	/* Synchronization Protocol Identifier */
+	u8 mesh_sp_id;
+	/* Authentication Protocol Identifier */
+	u8 mesh_auth_id;
+	u8 *rsn_ie;
+	int rsn_ie_len;
+#define MESH_CONF_SEC_NONE BIT(0)
+#define MESH_CONF_SEC_AUTH BIT(1)
+#define MESH_CONF_SEC_AMPE BIT(2)
+	unsigned int security;
+	int dot11MeshMaxRetries;
+	int dot11MeshRetryTimeout; /* msec */
+	int dot11MeshConfirmTimeout; /* msec */
+	int dot11MeshHoldingTimeout; /* msec */
+#define MAX_STA_COUNT 2007
+#define MAX_VLAN_ID 4094
+typedef u8 macaddr[ETH_ALEN];
+struct mac_acl_entry {
+	macaddr addr;
+	int vlan_id;
+struct hostapd_radius_servers;
+struct ft_remote_r0kh;
+struct ft_remote_r1kh;
+#define NUM_WEP_KEYS 4
+struct hostapd_wep_keys {
+	u8 idx;
+	u8 *key[NUM_WEP_KEYS];
+	size_t len[NUM_WEP_KEYS];
+	int keys_set;
+	size_t default_len; /* key length used for dynamic key generation */
+typedef enum hostap_security_policy {
+	SECURITY_PLAINTEXT = 0,
+	SECURITY_STATIC_WEP = 1,
+	SECURITY_IEEE_802_1X = 2,
+	SECURITY_WPA_PSK = 3,
+	SECURITY_WPA = 4,
+	SECURITY_OSEN = 5
+} secpolicy;
+struct hostapd_ssid {
+	u8 ssid[SSID_MAX_LEN];
+	size_t ssid_len;
+	unsigned int ssid_set:1;
+	unsigned int utf8_ssid:1;
+	unsigned int wpa_passphrase_set:1;
+	unsigned int wpa_psk_set:1;
+	char vlan[IFNAMSIZ + 1];
+	secpolicy security_policy;
+	struct hostapd_wpa_psk *wpa_psk;
+	char *wpa_passphrase;
+	char *wpa_psk_file;
+	struct hostapd_wep_keys wep;
+#define DYNAMIC_VLAN_DISABLED 0
+#define DYNAMIC_VLAN_OPTIONAL 1
+#define DYNAMIC_VLAN_REQUIRED 2
+	int dynamic_vlan;
+#define DYNAMIC_VLAN_NAMING_WITHOUT_DEVICE 0
+#define DYNAMIC_VLAN_NAMING_WITH_DEVICE 1
+#define DYNAMIC_VLAN_NAMING_END 2
+	int vlan_naming;
+#ifdef CONFIG_FULL_DYNAMIC_VLAN
+	char *vlan_tagged_interface;
+#endif /* CONFIG_FULL_DYNAMIC_VLAN */
+#define VLAN_ID_WILDCARD -1
+struct hostapd_vlan {
+	struct hostapd_vlan *next;
+	int vlan_id; /* VLAN ID or -1 (VLAN_ID_WILDCARD) for wildcard entry */
+	char ifname[IFNAMSIZ + 1];
+	int configured;
+	int dynamic_vlan;
+#define DVLAN_CLEAN_WLAN_PORT	0x8
+	int clean;
+#define PMK_LEN 32
+struct hostapd_sta_wpa_psk_short {
+	struct hostapd_sta_wpa_psk_short *next;
+	u8 psk[PMK_LEN];
+struct hostapd_wpa_psk {
+	struct hostapd_wpa_psk *next;
+	int group;
+	u8 psk[PMK_LEN];
+	u8 addr[ETH_ALEN];
+	u8 p2p_dev_addr[ETH_ALEN];
+struct hostapd_eap_user {
+	struct hostapd_eap_user *next;
+	u8 *identity;
+	size_t identity_len;
+	struct {
+		int vendor;
+		u32 method;
+	} methods[EAP_MAX_METHODS];
+	u8 *password;
+	size_t password_len;
+	int phase2;
+	int force_version;
+	unsigned int wildcard_prefix:1;
+	unsigned int password_hash:1; /* whether password is hashed with
+				       * nt_password_hash() */
+	unsigned int remediation:1;
+	unsigned int macacl:1;
+	int ttls_auth; /* EAP_TTLS_AUTH_* bitfield */
+	struct hostapd_radius_attr *accept_attr;
+struct hostapd_radius_attr {
+	u8 type;
+	struct wpabuf *val;
+	struct hostapd_radius_attr *next;
+#define NUM_TX_QUEUES 4
+struct hostapd_tx_queue_params {
+	int aifs;
+	int cwmin;
+	int cwmax;
+	int burst; /* maximum burst time in 0.1 ms, i.e., 10 = 1 ms */
+#define MAX_ROAMING_CONSORTIUM_LEN 15
+struct hostapd_roaming_consortium {
+	u8 len;
+	u8 oi[MAX_ROAMING_CONSORTIUM_LEN];
+struct hostapd_lang_string {
+	u8 lang[3];
+	u8 name_len;
+	u8 name[252];
+#define MAX_NAI_REALMS 10
+#define MAX_NAI_REALMLEN 255
+#define MAX_NAI_EAP_METHODS 5
+#define MAX_NAI_AUTH_TYPES 4
+struct hostapd_nai_realm_data {
+	u8 encoding;
+	char realm_buf[MAX_NAI_REALMLEN + 1];
+	char *realm[MAX_NAI_REALMS];
+	u8 eap_method_count;
+	struct hostapd_nai_realm_eap {
+		u8 eap_method;
+		u8 num_auths;
+		u8 auth_id[MAX_NAI_AUTH_TYPES];
+		u8 auth_val[MAX_NAI_AUTH_TYPES];
+	} eap_method[MAX_NAI_EAP_METHODS];
+ * struct hostapd_bss_config - Per-BSS configuration
+struct hostapd_bss_config {
+	char iface[IFNAMSIZ + 1];
+	char bridge[IFNAMSIZ + 1];
+	char vlan_bridge[IFNAMSIZ + 1];
+	char wds_bridge[IFNAMSIZ + 1];
+	enum hostapd_logger_level logger_syslog_level, logger_stdout_level;
+	unsigned int logger_syslog; /* module bitfield */
+	unsigned int logger_stdout; /* module bitfield */
+	int max_num_sta; /* maximum number of STAs in station table */
+	int dtim_period;
+	int bss_load_update_period;
+	int ieee802_1x; /* use IEEE 802.1X */
+	int eapol_version;
+	int eap_server; /* Use internal EAP server instead of external
+			 * RADIUS server */
+	struct hostapd_eap_user *eap_user;
+	char *eap_user_sqlite;
+	char *eap_sim_db;
+	int eap_server_erp; /* Whether ERP is enabled on internal EAP server */
+	struct hostapd_ip_addr own_ip_addr;
+	char *nas_identifier;
+	struct hostapd_radius_servers *radius;
+	int acct_interim_interval;
+	int radius_request_cui;
+	struct hostapd_radius_attr *radius_auth_req_attr;
+	struct hostapd_radius_attr *radius_acct_req_attr;
+	int radius_das_port;
+	unsigned int radius_das_time_window;
+	int radius_das_require_event_timestamp;
+	struct hostapd_ip_addr radius_das_client_addr;
+	u8 *radius_das_shared_secret;
+	size_t radius_das_shared_secret_len;
+	struct hostapd_ssid ssid;
+	char *eap_req_id_text; /* optional displayable message sent with
+				* EAP Request-Identity */
+	size_t eap_req_id_text_len;
+	int eapol_key_index_workaround;
+	size_t default_wep_key_len;
+	int individual_wep_key_len;
+	int wep_rekeying_period;
+	int broadcast_key_idx_min, broadcast_key_idx_max;
+	int eap_reauth_period;
+	int erp_send_reauth_start;
+	char *erp_domain;
+	int ieee802_11f; /* use IEEE 802.11f (IAPP) */
+	char iapp_iface[IFNAMSIZ + 1]; /* interface used with IAPP broadcast
+					* frames */
+	enum {
+		ACCEPT_UNLESS_DENIED = 0,
+		DENY_UNLESS_ACCEPTED = 1,
+		USE_EXTERNAL_RADIUS_AUTH = 2
+	} macaddr_acl;
+	struct mac_acl_entry *accept_mac;
+	int num_accept_mac;
+	struct mac_acl_entry *deny_mac;
+	int num_deny_mac;
+	int wds_sta;
+	int isolate;
+	int start_disabled;
+	int auth_algs; /* bitfield of allowed IEEE 802.11 authentication
+			* algorithms, WPA_AUTH_ALG_{OPEN,SHARED,LEAP} */
+	int wpa; /* bitfield of WPA_PROTO_WPA, WPA_PROTO_RSN */
+	int wpa_key_mgmt;
+#ifdef CONFIG_IEEE80211W
+	enum mfp_options ieee80211w;
+	int group_mgmt_cipher;
+	/* dot11AssociationSAQueryMaximumTimeout (in TUs) */
+	unsigned int assoc_sa_query_max_timeout;
+	/* dot11AssociationSAQueryRetryTimeout (in TUs) */
+	int assoc_sa_query_retry_timeout;
+#endif /* CONFIG_IEEE80211W */
+	enum {
+		PSK_RADIUS_IGNORED = 0,
+		PSK_RADIUS_ACCEPTED = 1,
+		PSK_RADIUS_REQUIRED = 2
+	} wpa_psk_radius;
+	int wpa_pairwise;
+	int wpa_group;
+	int wpa_group_rekey;
+	int wpa_strict_rekey;
+	int wpa_gmk_rekey;
+	int wpa_ptk_rekey;
+	int rsn_pairwise;
+	int rsn_preauth;
+	char *rsn_preauth_interfaces;
+	int peerkey;
+#ifdef CONFIG_IEEE80211R
+	/* IEEE 802.11r - Fast BSS Transition */
+	u8 mobility_domain[MOBILITY_DOMAIN_ID_LEN];
+	u8 r1_key_holder[FT_R1KH_ID_LEN];
+	u32 r0_key_lifetime;
+	u32 reassociation_deadline;
+	struct ft_remote_r0kh *r0kh_list;
+	struct ft_remote_r1kh *r1kh_list;
+	int pmk_r1_push;
+	int ft_over_ds;
+#endif /* CONFIG_IEEE80211R */
+	char *ctrl_interface; /* directory for UNIX domain sockets */
+#ifndef CONFIG_NATIVE_WINDOWS
+	gid_t ctrl_interface_gid;
+#endif /* CONFIG_NATIVE_WINDOWS */
+	int ctrl_interface_gid_set;
+	char *ca_cert;
+	char *server_cert;
+	char *private_key;
+	char *private_key_passwd;
+	int check_crl;
+	unsigned int tls_session_lifetime;
+	char *ocsp_stapling_response;
+	char *dh_file;
+	char *openssl_ciphers;
+	u8 *pac_opaque_encr_key;
+	u8 *eap_fast_a_id;
+	size_t eap_fast_a_id_len;
+	char *eap_fast_a_id_info;
+	int eap_fast_prov;
+	int pac_key_lifetime;
+	int pac_key_refresh_time;
+	int eap_sim_aka_result_ind;
+	int tnc;
+	int fragment_size;
+	u16 pwd_group;
+	char *radius_server_clients;
+	int radius_server_auth_port;
+	int radius_server_acct_port;
+	int radius_server_ipv6;
+	int use_pae_group_addr; /* Whether to send EAPOL frames to PAE group
+				 * address instead of individual address
+				 * (for driver_wired.c).
+	int ap_max_inactivity;
+	int ignore_broadcast_ssid;
+	int wmm_enabled;
+	int wmm_uapsd;
+	struct hostapd_vlan *vlan;
+	macaddr bssid;
+	 * Maximum listen interval that STAs can use when associating with this
+	 * BSS. If a STA tries to use larger value, the association will be
+	 * denied with status code 51.
+	u16 max_listen_interval;
+	int disable_pmksa_caching;
+	int okc; /* Opportunistic Key Caching */
+	int wps_state;
+#ifdef CONFIG_WPS
+	int wps_independent;
+	int ap_setup_locked;
+	u8 uuid[16];
+	char *wps_pin_requests;
+	char *device_name;
+	char *manufacturer;
+	char *model_name;
+	char *model_number;
+	char *serial_number;
+	u8 device_type[WPS_DEV_TYPE_LEN];
+	char *config_methods;
+	u8 os_version[4];
+	char *ap_pin;
+	int skip_cred_build;
+	u8 *extra_cred;
+	size_t extra_cred_len;
+	int wps_cred_processing;
+	int force_per_enrollee_psk;
+	u8 *ap_settings;
+	size_t ap_settings_len;
+	char *upnp_iface;
+	char *friendly_name;
+	char *manufacturer_url;
+	char *model_description;
+	char *model_url;
+	char *upc;
+	struct wpabuf *wps_vendor_ext[MAX_WPS_VENDOR_EXTENSIONS];
+	int wps_nfc_pw_from_config;
+	int wps_nfc_dev_pw_id;
+	struct wpabuf *wps_nfc_dh_pubkey;
+	struct wpabuf *wps_nfc_dh_privkey;
+	struct wpabuf *wps_nfc_dev_pw;
+#endif /* CONFIG_WPS */
+	int pbc_in_m1;
+	char *server_id;
+#define P2P_ENABLED BIT(0)
+#define P2P_GROUP_OWNER BIT(1)
+#define P2P_GROUP_FORMATION BIT(2)
+#define P2P_MANAGE BIT(3)
+#define P2P_ALLOW_CROSS_CONNECTION BIT(4)
+	int p2p;
+#ifdef CONFIG_P2P
+	u8 ip_addr_go[4];
+	u8 ip_addr_mask[4];
+	u8 ip_addr_start[4];
+	u8 ip_addr_end[4];
+#endif /* CONFIG_P2P */
+	int disassoc_low_ack;
+	int skip_inactivity_poll;
+#define TDLS_PROHIBIT BIT(0)
+#define TDLS_PROHIBIT_CHAN_SWITCH BIT(1)
+	int tdls;
+	int disable_11n;
+	int disable_11ac;
+	/* IEEE 802.11v */
+	int time_advertisement;
+	char *time_zone;
+	int wnm_sleep_mode;
+	int bss_transition;
+	/* IEEE 802.11u - Interworking */
+	int interworking;
+	int access_network_type;
+	int internet;
+	int asra;
+	int esr;
+	int uesa;
+	int venue_info_set;
+	u8 venue_group;
+	u8 venue_type;
+	u8 hessid[ETH_ALEN];
+	/* IEEE 802.11u - Roaming Consortium list */
+	unsigned int roaming_consortium_count;
+	struct hostapd_roaming_consortium *roaming_consortium;
+	/* IEEE 802.11u - Venue Name duples */
+	unsigned int venue_name_count;
+	struct hostapd_lang_string *venue_name;
+	/* IEEE 802.11u - Network Authentication Type */
+	u8 *network_auth_type;
+	size_t network_auth_type_len;
+	/* IEEE 802.11u - IP Address Type Availability */
+	u8 ipaddr_type_availability;
+	u8 ipaddr_type_configured;
+	/* IEEE 802.11u - 3GPP Cellular Network */
+	u8 *anqp_3gpp_cell_net;
+	size_t anqp_3gpp_cell_net_len;
+	/* IEEE 802.11u - Domain Name */
+	u8 *domain_name;
+	size_t domain_name_len;
+	unsigned int nai_realm_count;
+	struct hostapd_nai_realm_data *nai_realm_data;
+	u16 gas_comeback_delay;
+	int gas_frag_limit;
+	u8 qos_map_set[16 + 2 * 21];
+	unsigned int qos_map_set_len;
+	int osen;
+	int proxy_arp;
+	int na_mcast_to_ucast;
+#ifdef CONFIG_HS20
+	int hs20;
+	int disable_dgaf;
+	u16 anqp_domain_id;
+	unsigned int hs20_oper_friendly_name_count;
+	struct hostapd_lang_string *hs20_oper_friendly_name;
+	u8 *hs20_wan_metrics;
+	u8 *hs20_connection_capability;
+	size_t hs20_connection_capability_len;
+	u8 *hs20_operating_class;
+	u8 hs20_operating_class_len;
+	struct hs20_icon {
+		u16 width;
+		u16 height;
+		char language[3];
+		char type[256];
+		char name[256];
+		char file[256];
+	} *hs20_icons;
+	size_t hs20_icons_count;
+	u8 osu_ssid[SSID_MAX_LEN];
+	size_t osu_ssid_len;
+	struct hs20_osu_provider {
+		unsigned int friendly_name_count;
+		struct hostapd_lang_string *friendly_name;
+		char *server_uri;
+		int *method_list;
+		char **icons;
+		size_t icons_count;
+		char *osu_nai;
+		unsigned int service_desc_count;
+		struct hostapd_lang_string *service_desc;
+	} *hs20_osu_providers, *last_osu;
+	size_t hs20_osu_providers_count;
+	unsigned int hs20_deauth_req_timeout;
+	char *subscr_remediation_url;
+	u8 subscr_remediation_method;
+#endif /* CONFIG_HS20 */
+	u8 wps_rf_bands; /* RF bands for WPS (WPS_RF_*) */
+#ifdef CONFIG_RADIUS_TEST
+	char *dump_msk_file;
+#endif /* CONFIG_RADIUS_TEST */
+	struct wpabuf *vendor_elements;
+	unsigned int sae_anti_clogging_threshold;
+	int *sae_groups;
+	char *wowlan_triggers; /* Wake-on-WLAN triggers */
+#ifdef CONFIG_TESTING_OPTIONS
+	u8 bss_load_test[5];
+	u8 bss_load_test_set;
+	struct wpabuf *own_ie_override;
+#endif /* CONFIG_TESTING_OPTIONS */
+#define MESH_ENABLED BIT(0)
+	int mesh;
+	int radio_measurements;
+	int vendor_vht;
+	char *no_probe_resp_if_seen_on;
+	char *no_auth_if_seen_on;
+ * struct hostapd_config - Per-radio interface configuration
+struct hostapd_config {
+	struct hostapd_bss_config **bss, *last_bss;
+	size_t num_bss;
+	u16 beacon_int;
+	int rts_threshold;
+	int fragm_threshold;
+	u8 send_probe_response;
+	u8 channel;
+	u8 acs;
+	struct wpa_freq_range_list acs_ch_list;
+	enum hostapd_hw_mode hw_mode; /* HOSTAPD_MODE_IEEE80211A, .. */
+	enum {
+		LONG_PREAMBLE = 0,
+		SHORT_PREAMBLE = 1
+	} preamble;
+	int *supported_rates;
+	int *basic_rates;
+	const struct wpa_driver_ops *driver;
+	char *driver_params;
+	int ap_table_max_size;
+	int ap_table_expiration_time;
+	unsigned int track_sta_max_num;
+	unsigned int track_sta_max_age;
+	char country[3]; /* first two octets: country code as described in
+			  * ISO/IEC 3166-1. Third octet:
+			  * ' ' (ascii 32): all environments
+			  * 'O': Outdoor environemnt only
+			  * 'I': Indoor environment only
+	int ieee80211d;
+	int ieee80211h; /* DFS */
+	 * Local power constraint is an octet encoded as an unsigned integer in
+	 * units of decibels. Invalid value -1 indicates that Power Constraint
+	 * element will not be added.
+	int local_pwr_constraint;
+	/* Control Spectrum Management bit */
+	int spectrum_mgmt_required;
+	struct hostapd_tx_queue_params tx_queue[NUM_TX_QUEUES];
+	 * WMM AC parameters, in same order as 802.1D, i.e.
+	 * 0 = BE (best effort)
+	 * 1 = BK (background)
+	 * 2 = VI (video)
+	 * 3 = VO (voice)
+	struct hostapd_wmm_ac_params wmm_ac_params[4];
+	int ht_op_mode_fixed;
+	u16 ht_capab;
+	int ieee80211n;
+	int secondary_channel;
+	int no_pri_sec_switch;
+	int require_ht;
+	int obss_interval;
+	u32 vht_capab;
+	int ieee80211ac;
+	int require_vht;
+	u8 vht_oper_chwidth;
+	u8 vht_oper_centr_freq_seg0_idx;
+	u8 vht_oper_centr_freq_seg1_idx;
+#ifdef CONFIG_FST
+	struct fst_iface_cfg fst_cfg;
+#endif /* CONFIG_FST */
+#ifdef CONFIG_P2P
+	u8 p2p_go_ctwindow;
+	double ignore_probe_probability;
+	double ignore_auth_probability;
+	double ignore_assoc_probability;
+	double ignore_reassoc_probability;
+	double corrupt_gtk_rekey_mic_probability;
+#ifdef CONFIG_ACS
+	unsigned int acs_num_scans;
+	struct acs_bias {
+		int channel;
+		double bias;
+	} *acs_chan_bias;
+	unsigned int num_acs_chan_bias;
+#endif /* CONFIG_ACS */
+int hostapd_mac_comp(const void *a, const void *b);
+int hostapd_mac_comp_empty(const void *a);
+struct hostapd_config * hostapd_config_defaults(void);
+void hostapd_config_defaults_bss(struct hostapd_bss_config *bss);
+void hostapd_config_free_eap_user(struct hostapd_eap_user *user);
+void hostapd_config_clear_wpa_psk(struct hostapd_wpa_psk **p);
+void hostapd_config_free_bss(struct hostapd_bss_config *conf);
+void hostapd_config_free(struct hostapd_config *conf);
+int hostapd_maclist_found(struct mac_acl_entry *list, int num_entries,
+			  const u8 *addr, int *vlan_id);
+int hostapd_rate_found(int *list, int rate);
+const u8 * hostapd_get_psk(const struct hostapd_bss_config *conf,
+			   const u8 *addr, const u8 *p2p_dev_addr,
+			   const u8 *prev_psk);
+int hostapd_setup_wpa_psk(struct hostapd_bss_config *conf);
+int hostapd_vlan_id_valid(struct hostapd_vlan *vlan, int vlan_id);
+const char * hostapd_get_vlan_id_ifname(struct hostapd_vlan *vlan,
+					int vlan_id);
+struct hostapd_radius_attr *
+hostapd_config_get_radius_attr(struct hostapd_radius_attr *attr, u8 type);
+int hostapd_config_check(struct hostapd_config *conf, int full_config);
+void hostapd_set_security_params(struct hostapd_bss_config *bss,
+				 int full_config);
+#endif /* HOSTAPD_CONFIG_H */
diff --git a/freebsd/contrib/wpa/src/ap/ap_drv_ops.c b/freebsd/contrib/wpa/src/ap/ap_drv_ops.c
index 00000000000..d20ee93fcbf
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/ap_drv_ops.c
@@ -0,0 +1,844 @@
+#include <machine/rtems-bsd-user-space.h>
+ * hostapd - Driver operations
+ * Copyright (c) 2009-2010, Jouni Malinen <j at w1.fi>
+#include "utils/includes.h"
+#include "utils/common.h"
+#include "common/hw_features_common.h"
+#include "p2p/p2p.h"
+#include "hostapd.h"
+#include "ieee802_11.h"
+#include "sta_info.h"
+#include "ap_config.h"
+#include "p2p_hostapd.h"
+#include "hs20.h"
+#include "ap_drv_ops.h"
+u32 hostapd_sta_flags_to_drv(u32 flags)
+	int res = 0;
+	if (flags & WLAN_STA_AUTHORIZED)
+		res |= WPA_STA_AUTHORIZED;
+	if (flags & WLAN_STA_WMM)
+		res |= WPA_STA_WMM;
+	if (flags & WLAN_STA_SHORT_PREAMBLE)
+		res |= WPA_STA_SHORT_PREAMBLE;
+	if (flags & WLAN_STA_MFP)
+		res |= WPA_STA_MFP;
+	return res;
+int hostapd_build_ap_extra_ies(struct hostapd_data *hapd,
+			       struct wpabuf **beacon_ret,
+			       struct wpabuf **proberesp_ret,
+			       struct wpabuf **assocresp_ret)
+	struct wpabuf *beacon = NULL, *proberesp = NULL, *assocresp = NULL;
+	u8 buf[200], *pos;
+	*beacon_ret = *proberesp_ret = *assocresp_ret = NULL;
+	pos = buf;
+	pos = hostapd_eid_time_adv(hapd, pos);
+	if (pos != buf) {
+		if (wpabuf_resize(&beacon, pos - buf) != 0)
+			goto fail;
+		wpabuf_put_data(beacon, buf, pos - buf);
+	pos = hostapd_eid_time_zone(hapd, pos);
+	if (pos != buf) {
+		if (wpabuf_resize(&proberesp, pos - buf) != 0)
+			goto fail;
+		wpabuf_put_data(proberesp, buf, pos - buf);
+	pos = buf;
+	pos = hostapd_eid_ext_capab(hapd, pos);
+	if (pos != buf) {
+		if (wpabuf_resize(&assocresp, pos - buf) != 0)
+			goto fail;
+		wpabuf_put_data(assocresp, buf, pos - buf);
+	pos = hostapd_eid_interworking(hapd, pos);
+	pos = hostapd_eid_adv_proto(hapd, pos);
+	pos = hostapd_eid_roaming_consortium(hapd, pos);
+	if (pos != buf) {
+			goto fail;
+			goto fail;
+#ifdef CONFIG_FST
+	if (hapd->iface->fst_ies) {
+		size_t add = wpabuf_len(hapd->iface->fst_ies);
+		if (wpabuf_resize(&beacon, add) < 0)
+			goto fail;
+		wpabuf_put_buf(beacon, hapd->iface->fst_ies);
+		if (wpabuf_resize(&proberesp, add) < 0)
+			goto fail;
+		wpabuf_put_buf(proberesp, hapd->iface->fst_ies);
+		if (wpabuf_resize(&assocresp, add) < 0)
+			goto fail;
+		wpabuf_put_buf(assocresp, hapd->iface->fst_ies);
+	if (hapd->wps_beacon_ie) {
+		if (wpabuf_resize(&beacon, wpabuf_len(hapd->wps_beacon_ie)) <
+		    0)
+			goto fail;
+		wpabuf_put_buf(beacon, hapd->wps_beacon_ie);
+	if (hapd->wps_probe_resp_ie) {
+				  wpabuf_len(hapd->wps_probe_resp_ie)) < 0)
+			goto fail;
+		wpabuf_put_buf(proberesp, hapd->wps_probe_resp_ie);
+#ifdef CONFIG_P2P
+	if (hapd->p2p_beacon_ie) {
+		if (wpabuf_resize(&beacon, wpabuf_len(hapd->p2p_beacon_ie)) <
+		    0)
+			goto fail;
+		wpabuf_put_buf(beacon, hapd->p2p_beacon_ie);
+	if (hapd->p2p_probe_resp_ie) {
+				  wpabuf_len(hapd->p2p_probe_resp_ie)) < 0)
+			goto fail;
+		wpabuf_put_buf(proberesp, hapd->p2p_probe_resp_ie);
+#ifdef CONFIG_P2P_MANAGER
+	if (hapd->conf->p2p & P2P_MANAGE) {
+		if (wpabuf_resize(&beacon, 100) == 0) {
+			u8 *start, *p;
+			start = wpabuf_put(beacon, 0);
+			p = hostapd_eid_p2p_manage(hapd, start);
+			wpabuf_put(beacon, p - start);
+		if (wpabuf_resize(&proberesp, 100) == 0) {
+			u8 *start, *p;
+			start = wpabuf_put(proberesp, 0);
+			wpabuf_put(proberesp, p - start);
+#endif /* CONFIG_P2P_MANAGER */
+#ifdef CONFIG_WPS
+	if (hapd->conf->wps_state) {
+		struct wpabuf *a = wps_build_assoc_resp_ie();
+		if (a && wpabuf_resize(&assocresp, wpabuf_len(a)) == 0)
+			wpabuf_put_buf(assocresp, a);
+		wpabuf_free(a);
+		if (wpabuf_resize(&assocresp, 100) == 0) {
+			u8 *start, *p;
+			start = wpabuf_put(assocresp, 0);
+			wpabuf_put(assocresp, p - start);
+#ifdef CONFIG_WIFI_DISPLAY
+	if (hapd->p2p_group) {
+		struct wpabuf *a;
+		a = p2p_group_assoc_resp_ie(hapd->p2p_group, P2P_SC_SUCCESS);
+		wpabuf_free(a);
+#endif /* CONFIG_WIFI_DISPLAY */
+#ifdef CONFIG_HS20
+	pos = buf;
+	pos = hostapd_eid_hs20_indication(hapd, pos);
+	if (pos != buf) {
+			goto fail;
+			goto fail;
+	pos = hostapd_eid_osen(hapd, buf);
+	if (pos != buf) {
+			goto fail;
+			goto fail;
+	if (hapd->conf->vendor_elements) {
+		size_t add = wpabuf_len(hapd->conf->vendor_elements);
+		if (wpabuf_resize(&beacon, add) == 0)
+			wpabuf_put_buf(beacon, hapd->conf->vendor_elements);
+		if (wpabuf_resize(&proberesp, add) == 0)
+			wpabuf_put_buf(proberesp, hapd->conf->vendor_elements);
+	*beacon_ret = beacon;
+	*proberesp_ret = proberesp;
+	*assocresp_ret = assocresp;
+	return 0;
+fail:
+	wpabuf_free(beacon);
+	wpabuf_free(proberesp);
+	wpabuf_free(assocresp);
+	return -1;
+void hostapd_free_ap_extra_ies(struct hostapd_data *hapd,
+			       struct wpabuf *beacon,
+			       struct wpabuf *proberesp,
+			       struct wpabuf *assocresp)
+int hostapd_reset_ap_wps_ie(struct hostapd_data *hapd)
+	if (hapd->driver == NULL || hapd->driver->set_ap_wps_ie == NULL)
+		return 0;
+	return hapd->driver->set_ap_wps_ie(hapd->drv_priv, NULL, NULL, NULL);
+int hostapd_set_ap_wps_ie(struct hostapd_data *hapd)
+	struct wpabuf *beacon, *proberesp, *assocresp;
+	int ret;
+		return 0;
+	if (hostapd_build_ap_extra_ies(hapd, &beacon, &proberesp, &assocresp) <
+	    0)
+		return -1;
+	ret = hapd->driver->set_ap_wps_ie(hapd->drv_priv, beacon, proberesp,
+					  assocresp);
+	hostapd_free_ap_extra_ies(hapd, beacon, proberesp, assocresp);
+	return ret;
+int hostapd_set_authorized(struct hostapd_data *hapd,
+			   struct sta_info *sta, int authorized)
+	if (authorized) {
+		return hostapd_sta_set_flags(hapd, sta->addr,
+					     hostapd_sta_flags_to_drv(
+						     sta->flags),
+					     WPA_STA_AUTHORIZED, ~0);
+				     hostapd_sta_flags_to_drv(sta->flags),
+				     0, ~WPA_STA_AUTHORIZED);
+int hostapd_set_sta_flags(struct hostapd_data *hapd, struct sta_info *sta)
+	int set_flags, total_flags, flags_and, flags_or;
+	total_flags = hostapd_sta_flags_to_drv(sta->flags);
+	set_flags = WPA_STA_SHORT_PREAMBLE | WPA_STA_WMM | WPA_STA_MFP;
+	if (((!hapd->conf->ieee802_1x && !hapd->conf->wpa) ||
+	     sta->auth_alg == WLAN_AUTH_FT) &&
+	    sta->flags & WLAN_STA_AUTHORIZED)
+		set_flags |= WPA_STA_AUTHORIZED;
+	flags_or = total_flags & set_flags;
+	flags_and = total_flags | ~set_flags;
+	return hostapd_sta_set_flags(hapd, sta->addr, total_flags,
+				     flags_or, flags_and);
+int hostapd_set_drv_ieee8021x(struct hostapd_data *hapd, const char *ifname,
+			      int enabled)
+	struct wpa_bss_params params;
+	os_memset(&params, 0, sizeof(params));
+	params.ifname = ifname;
+	params.enabled = enabled;
+	if (enabled) {
+		params.wpa = hapd->conf->wpa;
+		params.ieee802_1x = hapd->conf->ieee802_1x;
+		params.wpa_group = hapd->conf->wpa_group;
+		if ((hapd->conf->wpa & (WPA_PROTO_WPA | WPA_PROTO_RSN)) ==
+		    (WPA_PROTO_WPA | WPA_PROTO_RSN))
+			params.wpa_pairwise = hapd->conf->wpa_pairwise |
+				hapd->conf->rsn_pairwise;
+		else if (hapd->conf->wpa & WPA_PROTO_RSN)
+			params.wpa_pairwise = hapd->conf->rsn_pairwise;
+		else if (hapd->conf->wpa & WPA_PROTO_WPA)
+			params.wpa_pairwise = hapd->conf->wpa_pairwise;
+		params.wpa_key_mgmt = hapd->conf->wpa_key_mgmt;
+		params.rsn_preauth = hapd->conf->rsn_preauth;
+		params.ieee80211w = hapd->conf->ieee80211w;
+	return hostapd_set_ieee8021x(hapd, &params);
+int hostapd_vlan_if_add(struct hostapd_data *hapd, const char *ifname)
+	char force_ifname[IFNAMSIZ];
+	u8 if_addr[ETH_ALEN];
+	return hostapd_if_add(hapd, WPA_IF_AP_VLAN, ifname, hapd->own_addr,
+			      NULL, NULL, force_ifname, if_addr, NULL, 0);
+int hostapd_vlan_if_remove(struct hostapd_data *hapd, const char *ifname)
+	return hostapd_if_remove(hapd, WPA_IF_AP_VLAN, ifname);
+int hostapd_set_wds_sta(struct hostapd_data *hapd, char *ifname_wds,
+			const u8 *addr, int aid, int val)
+	const char *bridge = NULL;
+	if (hapd->driver == NULL || hapd->driver->set_wds_sta == NULL)
+		return -1;
+	if (hapd->conf->wds_bridge[0])
+		bridge = hapd->conf->wds_bridge;
+	else if (hapd->conf->bridge[0])
+		bridge = hapd->conf->bridge;
+	return hapd->driver->set_wds_sta(hapd->drv_priv, addr, aid, val,
+					 bridge, ifname_wds);
+int hostapd_add_sta_node(struct hostapd_data *hapd, const u8 *addr,
+			 u16 auth_alg)
+	if (hapd->driver == NULL || hapd->driver->add_sta_node == NULL)
+		return 0;
+	return hapd->driver->add_sta_node(hapd->drv_priv, addr, auth_alg);
+int hostapd_sta_auth(struct hostapd_data *hapd, const u8 *addr,
+		     u16 seq, u16 status, const u8 *ie, size_t len)
+	if (hapd->driver == NULL || hapd->driver->sta_auth == NULL)
+		return 0;
+	return hapd->driver->sta_auth(hapd->drv_priv, hapd->own_addr, addr,
+				      seq, status, ie, len);
+int hostapd_sta_assoc(struct hostapd_data *hapd, const u8 *addr,
+		      int reassoc, u16 status, const u8 *ie, size_t len)
+	if (hapd->driver == NULL || hapd->driver->sta_assoc == NULL)
+		return 0;
+	return hapd->driver->sta_assoc(hapd->drv_priv, hapd->own_addr, addr,
+				       reassoc, status, ie, len);
+int hostapd_sta_add(struct hostapd_data *hapd,
+		    const u8 *addr, u16 aid, u16 capability,
+		    const u8 *supp_rates, size_t supp_rates_len,
+		    u16 listen_interval,
+		    const struct ieee80211_ht_capabilities *ht_capab,
+		    const struct ieee80211_vht_capabilities *vht_capab,
+		    u32 flags, u8 qosinfo, u8 vht_opmode)
+	struct hostapd_sta_add_params params;
+	if (hapd->driver == NULL)
+		return 0;
+	if (hapd->driver->sta_add == NULL)
+		return 0;
+	params.addr = addr;
+	params.aid = aid;
+	params.capability = capability;
+	params.supp_rates = supp_rates;
+	params.supp_rates_len = supp_rates_len;
+	params.listen_interval = listen_interval;
+	params.ht_capabilities = ht_capab;
+	params.vht_capabilities = vht_capab;
+	params.vht_opmode_enabled = !!(flags & WLAN_STA_VHT_OPMODE_ENABLED);
+	params.vht_opmode = vht_opmode;
+	params.flags = hostapd_sta_flags_to_drv(flags);
+	params.qosinfo = qosinfo;
+	return hapd->driver->sta_add(hapd->drv_priv, &params);
+int hostapd_add_tspec(struct hostapd_data *hapd, const u8 *addr,
+		      u8 *tspec_ie, size_t tspec_ielen)
+	if (hapd->driver == NULL || hapd->driver->add_tspec == NULL)
+		return 0;
+	return hapd->driver->add_tspec(hapd->drv_priv, addr, tspec_ie,
+				       tspec_ielen);
+int hostapd_set_privacy(struct hostapd_data *hapd, int enabled)
+	if (hapd->driver == NULL || hapd->driver->set_privacy == NULL)
+		return 0;
+	return hapd->driver->set_privacy(hapd->drv_priv, enabled);
+int hostapd_set_generic_elem(struct hostapd_data *hapd, const u8 *elem,
+			     size_t elem_len)
+	if (hapd->driver == NULL || hapd->driver->set_generic_elem == NULL)
+		return 0;
+	return hapd->driver->set_generic_elem(hapd->drv_priv, elem, elem_len);
+int hostapd_get_ssid(struct hostapd_data *hapd, u8 *buf, size_t len)
+	if (hapd->driver == NULL || hapd->driver->hapd_get_ssid == NULL)
+		return 0;
+	return hapd->driver->hapd_get_ssid(hapd->drv_priv, buf, len);
+int hostapd_set_ssid(struct hostapd_data *hapd, const u8 *buf, size_t len)
+	if (hapd->driver == NULL || hapd->driver->hapd_set_ssid == NULL)
+		return 0;
+	return hapd->driver->hapd_set_ssid(hapd->drv_priv, buf, len);
+int hostapd_if_add(struct hostapd_data *hapd, enum wpa_driver_if_type type,
+		   const char *ifname, const u8 *addr, void *bss_ctx,
+		   void **drv_priv, char *force_ifname, u8 *if_addr,
+		   const char *bridge, int use_existing)
+	if (hapd->driver == NULL || hapd->driver->if_add == NULL)
+		return -1;
+	return hapd->driver->if_add(hapd->drv_priv, type, ifname, addr,
+				    bss_ctx, drv_priv, force_ifname, if_addr,
+				    bridge, use_existing);
+int hostapd_if_remove(struct hostapd_data *hapd, enum wpa_driver_if_type type,
+		      const char *ifname)
+	if (hapd->driver == NULL || hapd->drv_priv == NULL ||
+	    hapd->driver->if_remove == NULL)
+		return -1;
+	return hapd->driver->if_remove(hapd->drv_priv, type, ifname);
+int hostapd_set_ieee8021x(struct hostapd_data *hapd,
+			  struct wpa_bss_params *params)
+	if (hapd->driver == NULL || hapd->driver->set_ieee8021x == NULL)
+		return 0;
+	return hapd->driver->set_ieee8021x(hapd->drv_priv, params);
+int hostapd_get_seqnum(const char *ifname, struct hostapd_data *hapd,
+		       const u8 *addr, int idx, u8 *seq)
+	if (hapd->driver == NULL || hapd->driver->get_seqnum == NULL)
+		return 0;
+	return hapd->driver->get_seqnum(ifname, hapd->drv_priv, addr, idx,
+					seq);
+int hostapd_flush(struct hostapd_data *hapd)
+	if (hapd->driver == NULL || hapd->driver->flush == NULL)
+		return 0;
+	return hapd->driver->flush(hapd->drv_priv);
+int hostapd_set_freq(struct hostapd_data *hapd, enum hostapd_hw_mode mode,
+		     int freq, int channel, int ht_enabled, int vht_enabled,
+		     int sec_channel_offset, int vht_oper_chwidth,
+		     int center_segment0, int center_segment1)
+	struct hostapd_freq_params data;
+	if (hostapd_set_freq_params(&data, mode, freq, channel, ht_enabled,
+				    vht_enabled, sec_channel_offset,
+				    vht_oper_chwidth,
+				    center_segment0, center_segment1,
+				    hapd->iface->current_mode ?
+				    hapd->iface->current_mode->vht_capab : 0))
+		return -1;
+		return 0;
+	if (hapd->driver->set_freq == NULL)
+		return 0;
+	return hapd->driver->set_freq(hapd->drv_priv, &data);
+int hostapd_set_rts(struct hostapd_data *hapd, int rts)
+	if (hapd->driver == NULL || hapd->driver->set_rts == NULL)
+		return 0;
+	return hapd->driver->set_rts(hapd->drv_priv, rts);
+int hostapd_set_frag(struct hostapd_data *hapd, int frag)
+	if (hapd->driver == NULL || hapd->driver->set_frag == NULL)
+		return 0;
+	return hapd->driver->set_frag(hapd->drv_priv, frag);
+int hostapd_sta_set_flags(struct hostapd_data *hapd, u8 *addr,
+			  int total_flags, int flags_or, int flags_and)
+	if (hapd->driver == NULL || hapd->driver->sta_set_flags == NULL)
+		return 0;
+	return hapd->driver->sta_set_flags(hapd->drv_priv, addr, total_flags,
+int hostapd_set_country(struct hostapd_data *hapd, const char *country)
+	    hapd->driver->set_country == NULL)
+		return 0;
+	return hapd->driver->set_country(hapd->drv_priv, country);
+int hostapd_set_tx_queue_params(struct hostapd_data *hapd, int queue, int aifs,
+				int cw_min, int cw_max, int burst_time)
+	if (hapd->driver == NULL || hapd->driver->set_tx_queue_params == NULL)
+		return 0;
+	return hapd->driver->set_tx_queue_params(hapd->drv_priv, queue, aifs,
+						 cw_min, cw_max, burst_time);
+struct hostapd_hw_modes *
+hostapd_get_hw_feature_data(struct hostapd_data *hapd, u16 *num_modes,
+			    u16 *flags)
+	    hapd->driver->get_hw_feature_data == NULL)
+		return NULL;
+	return hapd->driver->get_hw_feature_data(hapd->drv_priv, num_modes,
+						 flags);
+int hostapd_driver_commit(struct hostapd_data *hapd)
+	if (hapd->driver == NULL || hapd->driver->commit == NULL)
+		return 0;
+	return hapd->driver->commit(hapd->drv_priv);
+int hostapd_drv_none(struct hostapd_data *hapd)
+	return hapd->driver && os_strcmp(hapd->driver->name, "none") == 0;
+int hostapd_driver_scan(struct hostapd_data *hapd,
+			struct wpa_driver_scan_params *params)
+	if (hapd->driver && hapd->driver->scan2)
+		return hapd->driver->scan2(hapd->drv_priv, params);
+	return -1;
+struct wpa_scan_results * hostapd_driver_get_scan_results(
+	struct hostapd_data *hapd)
+	if (hapd->driver && hapd->driver->get_scan_results2)
+		return hapd->driver->get_scan_results2(hapd->drv_priv);
+	return NULL;
+int hostapd_driver_set_noa(struct hostapd_data *hapd, u8 count, int start,
+			   int duration)
+	if (hapd->driver && hapd->driver->set_noa)
+		return hapd->driver->set_noa(hapd->drv_priv, count, start,
+					     duration);
+	return -1;
+int hostapd_drv_set_key(const char *ifname, struct hostapd_data *hapd,
+			enum wpa_alg alg, const u8 *addr,
+			int key_idx, int set_tx,
+			const u8 *seq, size_t seq_len,
+			const u8 *key, size_t key_len)
+	if (hapd->driver == NULL || hapd->driver->set_key == NULL)
+		return 0;
+	return hapd->driver->set_key(ifname, hapd->drv_priv, alg, addr,
+				     key_idx, set_tx, seq, seq_len, key,
+				     key_len);
+int hostapd_drv_send_mlme(struct hostapd_data *hapd,
+			  const void *msg, size_t len, int noack)
+	if (hapd->driver == NULL || hapd->driver->send_mlme == NULL)
+		return 0;
+	return hapd->driver->send_mlme(hapd->drv_priv, msg, len, noack, 0);
+int hostapd_drv_sta_deauth(struct hostapd_data *hapd,
+			   const u8 *addr, int reason)
+	if (hapd->driver == NULL || hapd->driver->sta_deauth == NULL)
+		return 0;
+	return hapd->driver->sta_deauth(hapd->drv_priv, hapd->own_addr, addr,
+					reason);
+int hostapd_drv_sta_disassoc(struct hostapd_data *hapd,
+	if (hapd->driver == NULL || hapd->driver->sta_disassoc == NULL)
+		return 0;
+	return hapd->driver->sta_disassoc(hapd->drv_priv, hapd->own_addr, addr,
+					  reason);
+int hostapd_drv_wnm_oper(struct hostapd_data *hapd, enum wnm_oper oper,
+			 const u8 *peer, u8 *buf, u16 *buf_len)
+	if (hapd->driver == NULL || hapd->driver->wnm_oper == NULL)
+		return -1;
+	return hapd->driver->wnm_oper(hapd->drv_priv, oper, peer, buf,
+				      buf_len);
+int hostapd_drv_send_action(struct hostapd_data *hapd, unsigned int freq,
+			    unsigned int wait, const u8 *dst, const u8 *data,
+			    size_t len)
+	if (hapd->driver == NULL || hapd->driver->send_action == NULL)
+		return 0;
+	return hapd->driver->send_action(hapd->drv_priv, freq, wait, dst,
+					 hapd->own_addr, hapd->own_addr, data,
+					 len, 0);
+int hostapd_start_dfs_cac(struct hostapd_iface *iface,
+			  enum hostapd_hw_mode mode, int freq,
+			  int channel, int ht_enabled, int vht_enabled,
+	struct hostapd_data *hapd = iface->bss[0];
+	int res;
+	if (!hapd->driver || !hapd->driver->start_dfs_cac)
+		return 0;
+	if (!iface->conf->ieee80211h) {
+		wpa_printf(MSG_ERROR, "Can't start DFS CAC, DFS functionality "
+			   "is not enabled");
+		return -1;
+				    vht_oper_chwidth, center_segment0,
+				    center_segment1,
+				    iface->current_mode->vht_capab)) {
+		wpa_printf(MSG_ERROR, "Can't set freq params");
+		return -1;
+	res = hapd->driver->start_dfs_cac(hapd->drv_priv, &data);
+	if (!res) {
+		iface->cac_started = 1;
+		os_get_reltime(&iface->dfs_cac_start);
+	return res;
+int hostapd_drv_set_qos_map(struct hostapd_data *hapd,
+			    const u8 *qos_map_set, u8 qos_map_set_len)
+	if (hapd->driver == NULL || hapd->driver->set_qos_map == NULL)
+		return 0;
+	return hapd->driver->set_qos_map(hapd->drv_priv, qos_map_set,
+					 qos_map_set_len);
+static void hostapd_get_hw_mode_any_channels(struct hostapd_data *hapd,
+					     struct hostapd_hw_modes *mode,
+					     int acs_ch_list_all,
+					     int **freq_list)
+	int i;
+	for (i = 0; i < mode->num_channels; i++) {
+		struct hostapd_channel_data *chan = &mode->channels[i];
+		if ((acs_ch_list_all ||
+		     freq_range_list_includes(&hapd->iface->conf->acs_ch_list,
+					      chan->chan)) &&
+		    !(chan->flag & HOSTAPD_CHAN_DISABLED))
+			int_array_add_unique(freq_list, chan->freq);
+int hostapd_drv_do_acs(struct hostapd_data *hapd)
+	struct drv_acs_params params;
+	int ret, i, acs_ch_list_all = 0;
+	u8 *channels = NULL;
+	unsigned int num_channels = 0;
+	struct hostapd_hw_modes *mode;
+	int *freq_list = NULL;
+	if (hapd->driver == NULL || hapd->driver->do_acs == NULL)
+		return 0;
+	params.hw_mode = hapd->iface->conf->hw_mode;
+	 * If no chanlist config parameter is provided, include all enabled
+	 * channels of the selected hw_mode.
+	if (!hapd->iface->conf->acs_ch_list.num)
+		acs_ch_list_all = 1;
+	mode = hapd->iface->current_mode;
+	if (mode) {
+		channels = os_malloc(mode->num_channels);
+		if (channels == NULL)
+			return -1;
+			if (!acs_ch_list_all &&
+			    !freq_range_list_includes(
+				    &hapd->iface->conf->acs_ch_list,
+				    chan->chan))
+				continue;
+			if (!(chan->flag & HOSTAPD_CHAN_DISABLED)) {
+				channels[num_channels++] = chan->chan;
+				int_array_add_unique(&freq_list, chan->freq);
+	} else {
+		for (i = 0; i < hapd->iface->num_hw_features; i++) {
+			mode = &hapd->iface->hw_features[i];
+			hostapd_get_hw_mode_any_channels(hapd, mode,
+							 acs_ch_list_all,
+							 &freq_list);
+	params.ch_list = channels;
+	params.ch_list_len = num_channels;
+	params.freq_list = freq_list;
+	params.ht_enabled = !!(hapd->iface->conf->ieee80211n);
+	params.ht40_enabled = !!(hapd->iface->conf->ht_capab &
+				 HT_CAP_INFO_SUPP_CHANNEL_WIDTH_SET);
+	params.vht_enabled = !!(hapd->iface->conf->ieee80211ac);
+	params.ch_width = 20;
+	if (hapd->iface->conf->ieee80211n && params.ht40_enabled)
+		params.ch_width = 40;
+	/* Note: VHT20 is defined by combination of ht_capab & vht_oper_chwidth
+	if (hapd->iface->conf->ieee80211ac && params.ht40_enabled) {
+		if (hapd->iface->conf->vht_oper_chwidth == VHT_CHANWIDTH_80MHZ)
+			params.ch_width = 80;
+		else if (hapd->iface->conf->vht_oper_chwidth ==
+			 VHT_CHANWIDTH_160MHZ ||
+			 hapd->iface->conf->vht_oper_chwidth ==
+			 VHT_CHANWIDTH_80P80MHZ)
+			params.ch_width = 160;
+	ret = hapd->driver->do_acs(hapd->drv_priv, &params);
+	os_free(channels);
+	return ret;
diff --git a/freebsd/contrib/wpa/src/ap/ap_drv_ops.h b/freebsd/contrib/wpa/src/ap/ap_drv_ops.h
index 00000000000..82eaf3f08bb
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/ap_drv_ops.h
@@ -0,0 +1,340 @@
+ * Copyright (c) 2009-2014, Jouni Malinen <j at w1.fi>
+#ifndef AP_DRV_OPS
+#define AP_DRV_OPS
+enum wpa_driver_if_type;
+struct wpa_bss_params;
+struct wpa_driver_scan_params;
+struct ieee80211_ht_capabilities;
+struct ieee80211_vht_capabilities;
+struct hostapd_freq_params;
+u32 hostapd_sta_flags_to_drv(u32 flags);
+			       struct wpabuf **beacon,
+			       struct wpabuf **proberesp,
+			       struct wpabuf **assocresp);
+void hostapd_free_ap_extra_ies(struct hostapd_data *hapd, struct wpabuf *beacon,
+			       struct wpabuf *assocresp);
+int hostapd_reset_ap_wps_ie(struct hostapd_data *hapd);
+int hostapd_set_ap_wps_ie(struct hostapd_data *hapd);
+			   struct sta_info *sta, int authorized);
+int hostapd_set_sta_flags(struct hostapd_data *hapd, struct sta_info *sta);
+			      int enabled);
+int hostapd_vlan_if_add(struct hostapd_data *hapd, const char *ifname);
+int hostapd_vlan_if_remove(struct hostapd_data *hapd, const char *ifname);
+			const u8 *addr, int aid, int val);
+		    u32 flags, u8 qosinfo, u8 vht_opmode);
+int hostapd_set_privacy(struct hostapd_data *hapd, int enabled);
+			     size_t elem_len);
+int hostapd_get_ssid(struct hostapd_data *hapd, u8 *buf, size_t len);
+int hostapd_set_ssid(struct hostapd_data *hapd, const u8 *buf, size_t len);
+		   const char *bridge, int use_existing);
+		      const char *ifname);
+			  struct wpa_bss_params *params);
+		       const u8 *addr, int idx, u8 *seq);
+int hostapd_flush(struct hostapd_data *hapd);
+		     int center_segment0, int center_segment1);
+int hostapd_set_rts(struct hostapd_data *hapd, int rts);
+int hostapd_set_frag(struct hostapd_data *hapd, int frag);
+			  int total_flags, int flags_or, int flags_and);
+int hostapd_set_country(struct hostapd_data *hapd, const char *country);
+				int cw_min, int cw_max, int burst_time);
+			    u16 *flags);
+int hostapd_driver_commit(struct hostapd_data *hapd);
+int hostapd_drv_none(struct hostapd_data *hapd);
+			struct wpa_driver_scan_params *params);
+	struct hostapd_data *hapd);
+			   int duration);
+			struct hostapd_data *hapd,
+			const u8 *key, size_t key_len);
+			  const void *msg, size_t len, int noack);
+			   const u8 *addr, int reason);
+			    size_t len);
+			 u16 auth_alg);
+		     u16 seq, u16 status, const u8 *ie, size_t len);
+		      int reassoc, u16 status, const u8 *ie, size_t len);
+		      u8 *tspec_ie, size_t tspec_ielen);
+int hostapd_drv_do_acs(struct hostapd_data *hapd);
+#include "drivers/driver.h"
+			 enum wnm_oper oper, const u8 *peer,
+			 u8 *buf, u16 *buf_len);
+int hostapd_drv_set_qos_map(struct hostapd_data *hapd, const u8 *qos_map_set,
+			    u8 qos_map_set_len);
+static inline int hostapd_drv_set_countermeasures(struct hostapd_data *hapd,
+						  int enabled)
+	    hapd->driver->hapd_set_countermeasures == NULL)
+		return 0;
+	return hapd->driver->hapd_set_countermeasures(hapd->drv_priv, enabled);
+static inline int hostapd_drv_set_sta_vlan(const char *ifname,
+					   const u8 *addr, int vlan_id)
+	if (hapd->driver == NULL || hapd->driver->set_sta_vlan == NULL)
+		return 0;
+	return hapd->driver->set_sta_vlan(hapd->drv_priv, addr, ifname,
+					  vlan_id);
+static inline int hostapd_drv_get_inact_sec(struct hostapd_data *hapd,
+					    const u8 *addr)
+	if (hapd->driver == NULL || hapd->driver->get_inact_sec == NULL)
+		return 0;
+	return hapd->driver->get_inact_sec(hapd->drv_priv, addr);
+static inline int hostapd_drv_sta_remove(struct hostapd_data *hapd,
+					 const u8 *addr)
+	if (hapd->driver == NULL || hapd->driver->sta_remove == NULL)
+		return 0;
+	return hapd->driver->sta_remove(hapd->drv_priv, addr);
+static inline int hostapd_drv_hapd_send_eapol(struct hostapd_data *hapd,
+					      const u8 *addr, const u8 *data,
+					      size_t data_len, int encrypt,
+					      u32 flags)
+	if (hapd->driver == NULL || hapd->driver->hapd_send_eapol == NULL)
+		return 0;
+	return hapd->driver->hapd_send_eapol(hapd->drv_priv, addr, data,
+					     data_len, encrypt,
+					     hapd->own_addr, flags);
+static inline int hostapd_drv_read_sta_data(
+	struct hostapd_data *hapd, struct hostap_sta_driver_data *data,
+	const u8 *addr)
+	if (hapd->driver == NULL || hapd->driver->read_sta_data == NULL)
+		return -1;
+	return hapd->driver->read_sta_data(hapd->drv_priv, data, addr);
+static inline int hostapd_drv_sta_clear_stats(struct hostapd_data *hapd,
+					      const u8 *addr)
+	if (hapd->driver == NULL || hapd->driver->sta_clear_stats == NULL)
+		return 0;
+	return hapd->driver->sta_clear_stats(hapd->drv_priv, addr);
+static inline int hostapd_drv_set_acl(struct hostapd_data *hapd,
+				      struct hostapd_acl_params *params)
+	if (hapd->driver == NULL || hapd->driver->set_acl == NULL)
+		return 0;
+	return hapd->driver->set_acl(hapd->drv_priv, params);
+static inline int hostapd_drv_set_ap(struct hostapd_data *hapd,
+				     struct wpa_driver_ap_params *params)
+	if (hapd->driver == NULL || hapd->driver->set_ap == NULL)
+		return 0;
+	return hapd->driver->set_ap(hapd->drv_priv, params);
+static inline int hostapd_drv_set_radius_acl_auth(struct hostapd_data *hapd,
+						  const u8 *mac, int accepted,
+						  u32 session_timeout)
+	if (hapd->driver == NULL || hapd->driver->set_radius_acl_auth == NULL)
+		return 0;
+	return hapd->driver->set_radius_acl_auth(hapd->drv_priv, mac, accepted,
+						 session_timeout);
+static inline int hostapd_drv_set_radius_acl_expire(struct hostapd_data *hapd,
+						    const u8 *mac)
+	    hapd->driver->set_radius_acl_expire == NULL)
+		return 0;
+	return hapd->driver->set_radius_acl_expire(hapd->drv_priv, mac);
+static inline int hostapd_drv_set_authmode(struct hostapd_data *hapd,
+					   int auth_algs)
+	if (hapd->driver == NULL || hapd->driver->set_authmode == NULL)
+		return 0;
+	return hapd->driver->set_authmode(hapd->drv_priv, auth_algs);
+static inline void hostapd_drv_poll_client(struct hostapd_data *hapd,
+					   const u8 *own_addr, const u8 *addr,
+					   int qos)
+	if (hapd->driver == NULL || hapd->driver->poll_client == NULL)
+		return;
+	hapd->driver->poll_client(hapd->drv_priv, own_addr, addr, qos);
+static inline int hostapd_drv_get_survey(struct hostapd_data *hapd,
+					 unsigned int freq)
+		return -1;
+	if (!hapd->driver->get_survey)
+		return -1;
+	return hapd->driver->get_survey(hapd->drv_priv, freq);
+static inline int hostapd_get_country(struct hostapd_data *hapd, char *alpha2)
+	if (hapd->driver == NULL || hapd->driver->get_country == NULL)
+		return -1;
+	return hapd->driver->get_country(hapd->drv_priv, alpha2);
+static inline const char * hostapd_drv_get_radio_name(struct hostapd_data *hapd)
+	    hapd->driver->get_radio_name == NULL)
+		return NULL;
+	return hapd->driver->get_radio_name(hapd->drv_priv);
+static inline int hostapd_drv_switch_channel(struct hostapd_data *hapd,
+					     struct csa_settings *settings)
+	if (hapd->driver == NULL || hapd->driver->switch_channel == NULL)
+		return -ENOTSUP;
+	return hapd->driver->switch_channel(hapd->drv_priv, settings);
+static inline int hostapd_drv_status(struct hostapd_data *hapd, char *buf,
+				     size_t buflen)
+	if (hapd->driver == NULL || hapd->driver->status == NULL)
+		return -1;
+	return hapd->driver->status(hapd->drv_priv, buf, buflen);
+static inline int hostapd_drv_br_add_ip_neigh(struct hostapd_data *hapd,
+					      int version, const u8 *ipaddr,
+					      int prefixlen, const u8 *addr)
+	    hapd->driver->br_add_ip_neigh == NULL)
+		return -1;
+	return hapd->driver->br_add_ip_neigh(hapd->drv_priv, version, ipaddr,
+					     prefixlen, addr);
+static inline int hostapd_drv_br_delete_ip_neigh(struct hostapd_data *hapd,
+						 u8 version, const u8 *ipaddr)
+	    hapd->driver->br_delete_ip_neigh == NULL)
+		return -1;
+	return hapd->driver->br_delete_ip_neigh(hapd->drv_priv, version,
+						ipaddr);
+static inline int hostapd_drv_br_port_set_attr(struct hostapd_data *hapd,
+					       enum drv_br_port_attr attr,
+					       unsigned int val)
+	    hapd->driver->br_port_set_attr == NULL)
+		return -1;
+	return hapd->driver->br_port_set_attr(hapd->drv_priv, attr, val);
+static inline int hostapd_drv_br_set_net_param(struct hostapd_data *hapd,
+					       enum drv_br_net_param param,
+					       unsigned int val)
+	    hapd->driver->br_set_net_param == NULL)
+		return -1;
+	return hapd->driver->br_set_net_param(hapd->drv_priv, param, val);
+static inline int hostapd_drv_vendor_cmd(struct hostapd_data *hapd,
+					 int vendor_id, int subcmd,
+					 const u8 *data, size_t data_len,
+					 struct wpabuf *buf)
+	if (hapd->driver == NULL || hapd->driver->vendor_cmd == NULL)
+		return -1;
+	return hapd->driver->vendor_cmd(hapd->drv_priv, vendor_id, subcmd, data,
+					data_len, buf);
+static inline int hostapd_drv_stop_ap(struct hostapd_data *hapd)
+	if (hapd->driver == NULL || hapd->driver->stop_ap == NULL)
+		return 0;
+	return hapd->driver->stop_ap(hapd->drv_priv);
+#endif /* AP_DRV_OPS */
diff --git a/freebsd/contrib/wpa/src/ap/hostapd.h b/freebsd/contrib/wpa/src/ap/hostapd.h
index 00000000000..dcf51f00f78
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/hostapd.h
@@ -0,0 +1,494 @@
+ * hostapd / Initialization and configuration
+ * Copyright (c) 2002-2014, Jouni Malinen <j at w1.fi>
+#ifndef HOSTAPD_H
+#define HOSTAPD_H
+#include "utils/list.h"
+struct wpa_ctrl_dst;
+struct radius_server_data;
+struct upnp_wps_device_sm;
+struct hostapd_data;
+struct sta_info;
+struct full_dynamic_vlan;
+enum wps_event;
+union wps_event_data;
+#ifdef CONFIG_MESH
+struct mesh_conf;
+#endif /* CONFIG_MESH */
+struct hostapd_iface;
+struct hapd_interfaces {
+	int (*reload_config)(struct hostapd_iface *iface);
+	struct hostapd_config * (*config_read_cb)(const char *config_fname);
+	int (*ctrl_iface_init)(struct hostapd_data *hapd);
+	void (*ctrl_iface_deinit)(struct hostapd_data *hapd);
+	int (*for_each_interface)(struct hapd_interfaces *interfaces,
+				  int (*cb)(struct hostapd_iface *iface,
+					    void *ctx), void *ctx);
+	int (*driver_init)(struct hostapd_iface *iface);
+	size_t count;
+	int global_ctrl_sock;
+	struct wpa_ctrl_dst *global_ctrl_dst;
+	char *global_iface_path;
+	char *global_iface_name;
+	gid_t ctrl_iface_group;
+	struct hostapd_iface **iface;
+	size_t terminate_on_error;
+#ifndef CONFIG_NO_VLAN
+	struct dynamic_iface *vlan_priv;
+#endif /* CONFIG_NO_VLAN */
+enum hostapd_chan_status {
+	HOSTAPD_CHAN_VALID = 0, /* channel is ready */
+	HOSTAPD_CHAN_INVALID = 1, /* no usable channel found */
+	HOSTAPD_CHAN_ACS = 2, /* ACS work being performed */
+struct hostapd_probereq_cb {
+	int (*cb)(void *ctx, const u8 *sa, const u8 *da, const u8 *bssid,
+		  const u8 *ie, size_t ie_len, int ssi_signal);
+	void *ctx;
+#define HOSTAPD_RATE_BASIC 0x00000001
+struct hostapd_rate_data {
+	int rate; /* rate in 100 kbps */
+	int flags; /* HOSTAPD_RATE_ flags */
+struct hostapd_frame_info {
+	u32 channel;
+	u32 datarate;
+	int ssi_signal; /* dBm */
+enum wps_status {
+	WPS_STATUS_SUCCESS = 1,
+	WPS_STATUS_FAILURE
+enum pbc_status {
+	WPS_PBC_STATUS_DISABLE,
+	WPS_PBC_STATUS_ACTIVE,
+	WPS_PBC_STATUS_TIMEOUT,
+	WPS_PBC_STATUS_OVERLAP
+struct wps_stat {
+	enum wps_status status;
+	enum wps_error_indication failure_reason;
+	enum pbc_status pbc_status;
+	u8 peer_addr[ETH_ALEN];
+ * struct hostapd_data - hostapd per-BSS data structure
+struct hostapd_data {
+	struct hostapd_iface *iface;
+	struct hostapd_config *iconf;
+	struct hostapd_bss_config *conf;
+	int interface_added; /* virtual interface added for this BSS */
+	unsigned int started:1;
+	unsigned int disabled:1;
+	unsigned int reenable_beacon:1;
+	u8 own_addr[ETH_ALEN];
+	int num_sta; /* number of entries in sta_list */
+	struct sta_info *sta_list; /* STA info list head */
+#define STA_HASH_SIZE 256
+#define STA_HASH(sta) (sta[5])
+	struct sta_info *sta_hash[STA_HASH_SIZE];
+	 * Bitfield for indicating which AIDs are allocated. Only AID values
+	 * 1-2007 are used and as such, the bit at index 0 corresponds to AID
+	 * 1.
+#define AID_WORDS ((2008 + 31) / 32)
+	u32 sta_aid[AID_WORDS];
+	void *drv_priv;
+	void (*new_assoc_sta_cb)(struct hostapd_data *hapd,
+				 struct sta_info *sta, int reassoc);
+	void *msg_ctx; /* ctx for wpa_msg() calls */
+	void *msg_ctx_parent; /* parent interface ctx for wpa_msg() calls */
+	struct radius_client_data *radius;
+	u32 acct_session_id_hi, acct_session_id_lo;
+	struct radius_das_data *radius_das;
+	struct iapp_data *iapp;
+	struct hostapd_cached_radius_acl *acl_cache;
+	struct hostapd_acl_query_data *acl_queries;
+	struct wpa_authenticator *wpa_auth;
+	struct eapol_authenticator *eapol_auth;
+	struct rsn_preauth_interface *preauth_iface;
+	struct os_reltime michael_mic_failure;
+	int michael_mic_failures;
+	int tkip_countermeasures;
+	int ctrl_sock;
+	struct wpa_ctrl_dst *ctrl_dst;
+	void *ssl_ctx;
+	void *eap_sim_db_priv;
+	struct radius_server_data *radius_srv;
+	struct dl_list erp_keys; /* struct eap_server_erp_key */
+	int parameter_set_count;
+	/* Time Advertisement */
+	u8 time_update_counter;
+	struct wpabuf *time_adv;
+	struct full_dynamic_vlan *full_dynamic_vlan;
+	struct l2_packet_data *l2;
+	struct wps_context *wps;
+	int beacon_set_done;
+	struct wpabuf *wps_beacon_ie;
+	struct wpabuf *wps_probe_resp_ie;
+#ifdef CONFIG_WPS
+	unsigned int ap_pin_failures;
+	unsigned int ap_pin_failures_consecutive;
+	struct upnp_wps_device_sm *wps_upnp;
+	unsigned int ap_pin_lockout_time;
+	struct wps_stat wps_stats;
+	struct hostapd_probereq_cb *probereq_cb;
+	size_t num_probereq_cb;
+	void (*public_action_cb)(void *ctx, const u8 *buf, size_t len,
+				 int freq);
+	void *public_action_cb_ctx;
+	void (*public_action_cb2)(void *ctx, const u8 *buf, size_t len,
+				  int freq);
+	void *public_action_cb2_ctx;
+	int (*vendor_action_cb)(void *ctx, const u8 *buf, size_t len,
+				int freq);
+	void *vendor_action_cb_ctx;
+	void (*wps_reg_success_cb)(void *ctx, const u8 *mac_addr,
+				   const u8 *uuid_e);
+	void *wps_reg_success_cb_ctx;
+	void (*wps_event_cb)(void *ctx, enum wps_event event,
+			     union wps_event_data *data);
+	void *wps_event_cb_ctx;
+	void (*sta_authorized_cb)(void *ctx, const u8 *mac_addr,
+				  int authorized, const u8 *p2p_dev_addr);
+	void *sta_authorized_cb_ctx;
+	void (*setup_complete_cb)(void *ctx);
+	void *setup_complete_cb_ctx;
+	void (*new_psk_cb)(void *ctx, const u8 *mac_addr,
+			   const u8 *p2p_dev_addr, const u8 *psk,
+			   size_t psk_len);
+	void *new_psk_cb_ctx;
+	/* channel switch parameters */
+	struct hostapd_freq_params cs_freq_params;
+	u8 cs_count;
+	int cs_block_tx;
+	unsigned int cs_c_off_beacon;
+	unsigned int cs_c_off_proberesp;
+	int csa_in_progress;
+	/* BSS Load */
+	unsigned int bss_load_update_timeout;
+#ifdef CONFIG_P2P
+	struct p2p_data *p2p;
+	struct p2p_group *p2p_group;
+	struct wpabuf *p2p_beacon_ie;
+	struct wpabuf *p2p_probe_resp_ie;
+	/* Number of non-P2P association stations */
+	int num_sta_no_p2p;
+	/* Periodic NoA (used only when no non-P2P clients in the group) */
+	int noa_enabled;
+	int noa_start;
+	int noa_duration;
+#ifdef CONFIG_INTERWORKING
+	size_t gas_frag_limit;
+#endif /* CONFIG_INTERWORKING */
+#ifdef CONFIG_PROXYARP
+	struct l2_packet_data *sock_dhcp;
+	struct l2_packet_data *sock_ndisc;
+#endif /* CONFIG_PROXYARP */
+#ifdef CONFIG_MESH
+	int num_plinks;
+	int max_plinks;
+	void (*mesh_sta_free_cb)(struct sta_info *sta);
+	struct wpabuf *mesh_pending_auth;
+	struct os_reltime mesh_pending_auth_time;
+#ifdef CONFIG_SQLITE
+	struct hostapd_eap_user tmp_eap_user;
+#endif /* CONFIG_SQLITE */
+#ifdef CONFIG_SAE
+	/** Key used for generating SAE anti-clogging tokens */
+	u8 sae_token_key[8];
+	struct os_reltime last_sae_token_key_update;
+	int dot11RSNASAERetransPeriod; /* msec */
+#endif /* CONFIG_SAE */
+	unsigned int ext_mgmt_frame_handling:1;
+	unsigned int ext_eapol_frame_io:1;
+	struct l2_packet_data *l2_test;
+struct hostapd_sta_info {
+	struct dl_list list;
+	struct os_reltime last_seen;
+ * struct hostapd_iface - hostapd per-interface data structure
+struct hostapd_iface {
+	struct hapd_interfaces *interfaces;
+	void *owner;
+	char *config_fname;
+	struct hostapd_config *conf;
+	char phy[16]; /* Name of the PHY (radio) */
+	enum hostapd_iface_state {
+		HAPD_IFACE_UNINITIALIZED,
+		HAPD_IFACE_DISABLED,
+		HAPD_IFACE_COUNTRY_UPDATE,
+		HAPD_IFACE_ACS,
+		HAPD_IFACE_HT_SCAN,
+		HAPD_IFACE_DFS,
+		HAPD_IFACE_ENABLED
+	} state;
+#ifdef CONFIG_MESH
+	struct mesh_conf *mconf;
+	size_t num_bss;
+	struct hostapd_data **bss;
+	unsigned int wait_channel_update:1;
+	unsigned int cac_started:1;
+#ifdef CONFIG_FST
+	struct fst_iface *fst;
+	const struct wpabuf *fst_ies;
+	 * When set, indicates that the driver will handle the AP
+	 * teardown: delete global keys, station keys, and stations.
+	unsigned int driver_ap_teardown:1;
+	int num_ap; /* number of entries in ap_list */
+	struct ap_info *ap_list; /* AP info list head */
+	struct ap_info *ap_hash[STA_HASH_SIZE];
+	u64 drv_flags;
+	/* SMPS modes supported by the driver (WPA_DRIVER_SMPS_MODE_*) */
+	unsigned int smps_modes;
+	 * A bitmap of supported protocols for probe response offload. See
+	 * struct wpa_driver_capa in driver.h
+	unsigned int probe_resp_offloads;
+	/* extended capabilities supported by the driver */
+	const u8 *extended_capa, *extended_capa_mask;
+	unsigned int extended_capa_len;
+	unsigned int drv_max_acl_mac_addrs;
+	struct hostapd_hw_modes *hw_features;
+	int num_hw_features;
+	struct hostapd_hw_modes *current_mode;
+	/* Rates that are currently used (i.e., filtered copy of
+	 * current_mode->channels */
+	int num_rates;
+	struct hostapd_rate_data *current_rates;
+	int *basic_rates;
+	int freq;
+	u16 hw_flags;
+	/* Number of associated Non-ERP stations (i.e., stations using 802.11b
+	 * in 802.11g BSS) */
+	int num_sta_non_erp;
+	/* Number of associated stations that do not support Short Slot Time */
+	int num_sta_no_short_slot_time;
+	/* Number of associated stations that do not support Short Preamble */
+	int num_sta_no_short_preamble;
+	int olbc; /* Overlapping Legacy BSS Condition */
+	/* Number of HT associated stations that do not support greenfield */
+	int num_sta_ht_no_gf;
+	/* Number of associated non-HT stations */
+	int num_sta_no_ht;
+	/* Number of HT associated stations 20 MHz */
+	int num_sta_ht_20mhz;
+	/* Number of HT40 intolerant stations */
+	int num_sta_ht40_intolerant;
+	/* Overlapping BSS information */
+	int olbc_ht;
+	u16 ht_op_mode;
+	/* surveying helpers */
+	/* number of channels surveyed */
+	unsigned int chans_surveyed;
+	/* lowest observed noise floor in dBm */
+	s8 lowest_nf;
+	/* channel utilization calculation */
+	u64 last_channel_time;
+	u64 last_channel_time_busy;
+	u8 channel_utilization;
+	unsigned int dfs_cac_ms;
+	struct os_reltime dfs_cac_start;
+	/* Latched with the actual secondary channel information and will be
+	 * used while juggling between HT20 and HT40 modes. */
+	int secondary_ch;
+#ifdef CONFIG_ACS
+	unsigned int acs_num_completed_scans;
+	void (*scan_cb)(struct hostapd_iface *iface);
+	int num_ht40_scan_tries;
+	struct dl_list sta_seen; /* struct hostapd_sta_info */
+	unsigned int num_sta_seen;
+/* hostapd.c */
+int hostapd_for_each_interface(struct hapd_interfaces *interfaces,
+int hostapd_reload_config(struct hostapd_iface *iface);
+struct hostapd_data *
+hostapd_alloc_bss_data(struct hostapd_iface *hapd_iface,
+		       struct hostapd_config *conf,
+		       struct hostapd_bss_config *bss);
+int hostapd_setup_interface(struct hostapd_iface *iface);
+int hostapd_setup_interface_complete(struct hostapd_iface *iface, int err);
+void hostapd_interface_deinit(struct hostapd_iface *iface);
+void hostapd_interface_free(struct hostapd_iface *iface);
+struct hostapd_iface * hostapd_init(struct hapd_interfaces *interfaces,
+				    const char *config_file);
+hostapd_interface_init_bss(struct hapd_interfaces *interfaces, const char *phy,
+			   const char *config_fname, int debug);
+void hostapd_new_assoc_sta(struct hostapd_data *hapd, struct sta_info *sta,
+			   int reassoc);
+void hostapd_interface_deinit_free(struct hostapd_iface *iface);
+int hostapd_enable_iface(struct hostapd_iface *hapd_iface);
+int hostapd_reload_iface(struct hostapd_iface *hapd_iface);
+int hostapd_disable_iface(struct hostapd_iface *hapd_iface);
+int hostapd_add_iface(struct hapd_interfaces *ifaces, char *buf);
+int hostapd_remove_iface(struct hapd_interfaces *ifaces, char *buf);
+void hostapd_channel_list_updated(struct hostapd_iface *iface, int initiator);
+void hostapd_set_state(struct hostapd_iface *iface, enum hostapd_iface_state s);
+const char * hostapd_state_text(enum hostapd_iface_state s);
+int hostapd_switch_channel(struct hostapd_data *hapd,
+			   struct csa_settings *settings);
+void
+hostapd_switch_channel_fallback(struct hostapd_iface *iface,
+				const struct hostapd_freq_params *freq_params);
+void hostapd_cleanup_cs_params(struct hostapd_data *hapd);
+void hostapd_periodic_iface(struct hostapd_iface *iface);
+/* utils.c */
+int hostapd_register_probereq_cb(struct hostapd_data *hapd,
+					   const u8 *da, const u8 *bssid,
+					   int ssi_signal),
+				 void *ctx);
+void hostapd_prune_associations(struct hostapd_data *hapd, const u8 *addr);
+/* drv_callbacks.c (TODO: move to somewhere else?) */
+int hostapd_notif_assoc(struct hostapd_data *hapd, const u8 *addr,
+			const u8 *ie, size_t ielen, int reassoc);
+void hostapd_notif_disassoc(struct hostapd_data *hapd, const u8 *addr);
+void hostapd_event_sta_low_ack(struct hostapd_data *hapd, const u8 *addr);
+void hostapd_event_connect_failed_reason(struct hostapd_data *hapd,
+					 const u8 *addr, int reason_code);
+int hostapd_probe_req_rx(struct hostapd_data *hapd, const u8 *sa, const u8 *da,
+			 const u8 *bssid, const u8 *ie, size_t ie_len,
+			 int ssi_signal);
+void hostapd_event_ch_switch(struct hostapd_data *hapd, int freq, int ht,
+			     int offset, int width, int cf1, int cf2);
+const struct hostapd_eap_user *
+hostapd_get_eap_user(struct hostapd_data *hapd, const u8 *identity,
+		     size_t identity_len, int phase2);
+struct hostapd_data * hostapd_get_iface(struct hapd_interfaces *interfaces,
+#ifdef CONFIG_FST
+void fst_hostapd_fill_iface_obj(struct hostapd_data *hapd,
+				struct fst_wpa_obj *iface_obj);
+#endif /* HOSTAPD_H */
diff --git a/freebsd/contrib/wpa/src/ap/hs20.c b/freebsd/contrib/wpa/src/ap/hs20.c
index 00000000000..1a836666471
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/hs20.c
@@ -0,0 +1,179 @@
+ * Hotspot 2.0 AP ANQP processing
+ * Copyright (c) 2009, Atheros Communications, Inc.
+ * Copyright (c) 2011-2013, Qualcomm Atheros, Inc.
+#include "includes.h"
+#include "common.h"
+#include "hs20.h"
+u8 * hostapd_eid_hs20_indication(struct hostapd_data *hapd, u8 *eid)
+	u8 conf;
+	if (!hapd->conf->hs20)
+		return eid;
+	*eid++ = WLAN_EID_VENDOR_SPECIFIC;
+	*eid++ = 7;
+	WPA_PUT_BE24(eid, OUI_WFA);
+	eid += 3;
+	*eid++ = HS20_INDICATION_OUI_TYPE;
+	conf = HS20_VERSION; /* Release Number */
+	conf |= HS20_ANQP_DOMAIN_ID_PRESENT;
+	if (hapd->conf->disable_dgaf)
+		conf |= HS20_DGAF_DISABLED;
+	*eid++ = conf;
+	WPA_PUT_LE16(eid, hapd->conf->anqp_domain_id);
+	eid += 2;
+	return eid;
+u8 * hostapd_eid_osen(struct hostapd_data *hapd, u8 *eid)
+	u8 *len;
+	u16 capab;
+	if (!hapd->conf->osen)
+		return eid;
+	len = eid++; /* to be filled */
+	eid += 3;
+	*eid++ = HS20_OSEN_OUI_TYPE;
+	/* Group Data Cipher Suite */
+	RSN_SELECTOR_PUT(eid, RSN_CIPHER_SUITE_NO_GROUP_ADDRESSED);
+	eid += RSN_SELECTOR_LEN;
+	/* Pairwise Cipher Suite Count and List */
+	WPA_PUT_LE16(eid, 1);
+	eid += 2;
+	RSN_SELECTOR_PUT(eid, RSN_CIPHER_SUITE_CCMP);
+	/* AKM Suite Count and List */
+	eid += 2;
+	RSN_SELECTOR_PUT(eid, RSN_AUTH_KEY_MGMT_OSEN);
+	/* RSN Capabilities */
+	capab = 0;
+	if (hapd->conf->wmm_enabled) {
+		/* 4 PTKSA replay counters when using WMM */
+		capab |= (RSN_NUM_REPLAY_COUNTERS_16 << 2);
+	if (hapd->conf->ieee80211w != NO_MGMT_FRAME_PROTECTION) {
+		capab |= WPA_CAPABILITY_MFPC;
+		if (hapd->conf->ieee80211w == MGMT_FRAME_PROTECTION_REQUIRED)
+			capab |= WPA_CAPABILITY_MFPR;
+	WPA_PUT_LE16(eid, capab);
+	eid += 2;
+	*len = eid - len - 1;
+	return eid;
+int hs20_send_wnm_notification(struct hostapd_data *hapd, const u8 *addr,
+			       u8 osu_method, const char *url)
+	struct wpabuf *buf;
+	size_t len = 0;
+	int ret;
+	/* TODO: should refuse to send notification if the STA is not associated
+	 * or if the STA did not indicate support for WNM-Notification */
+	if (url) {
+		len = 1 + os_strlen(url);
+		if (5 + len > 255) {
+			wpa_printf(MSG_INFO, "HS 2.0: Too long URL for "
+				   "WNM-Notification: '%s'", url);
+			return -1;
+	buf = wpabuf_alloc(4 + 7 + len);
+	if (buf == NULL)
+		return -1;
+	wpabuf_put_u8(buf, WLAN_ACTION_WNM);
+	wpabuf_put_u8(buf, WNM_NOTIFICATION_REQ);
+	wpabuf_put_u8(buf, 1); /* Dialog token */
+	wpabuf_put_u8(buf, 1); /* Type - 1 reserved for WFA */
+	/* Subscription Remediation subelement */
+	wpabuf_put_u8(buf, WLAN_EID_VENDOR_SPECIFIC);
+	wpabuf_put_u8(buf, 5 + len);
+	wpabuf_put_be24(buf, OUI_WFA);
+	wpabuf_put_u8(buf, HS20_WNM_SUB_REM_NEEDED);
+	if (url) {
+		wpabuf_put_u8(buf, len - 1);
+		wpabuf_put_data(buf, url, len - 1);
+		wpabuf_put_u8(buf, osu_method);
+	} else {
+		/* Server URL and Server Method fields not included */
+		wpabuf_put_u8(buf, 0);
+	ret = hostapd_drv_send_action(hapd, hapd->iface->freq, 0, addr,
+				      wpabuf_head(buf), wpabuf_len(buf));
+	wpabuf_free(buf);
+	return ret;
+int hs20_send_wnm_notification_deauth_req(struct hostapd_data *hapd,
+					  const u8 *addr,
+					  const struct wpabuf *payload)
+	int ret;
+	buf = wpabuf_alloc(4 + 6 + wpabuf_len(payload));
+	if (buf == NULL)
+		return -1;
+	/* Deauthentication Imminent Notice subelement */
+	wpabuf_put_u8(buf, 4 + wpabuf_len(payload));
+	wpabuf_put_u8(buf, HS20_WNM_DEAUTH_IMMINENT_NOTICE);
+	wpabuf_put_buf(buf, payload);
+	wpabuf_free(buf);
+	return ret;
diff --git a/freebsd/contrib/wpa/src/ap/hs20.h b/freebsd/contrib/wpa/src/ap/hs20.h
new file mode 100644
index 00000000000..152439f4dcb
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/hs20.h
@@ -0,0 +1,22 @@
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef HS20_H
+#define HS20_H
+u8 * hostapd_eid_hs20_indication(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_osen(struct hostapd_data *hapd, u8 *eid);
+			       u8 osu_method, const char *url);
+					  const u8 *addr,
+					  const struct wpabuf *payload);
+#endif /* HS20_H */
diff --git a/freebsd/contrib/wpa/src/ap/ieee802_11.h b/freebsd/contrib/wpa/src/ap/ieee802_11.h
index 00000000000..44c1bff364a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/ieee802_11.h
@@ -0,0 +1,107 @@
+ * hostapd / IEEE 802.11 Management
+ * Copyright (c) 2002-2009, Jouni Malinen <j at w1.fi>
+#ifndef IEEE802_11_H
+#define IEEE802_11_H
+struct sta_info;
+struct hostapd_frame_info;
+struct ieee80211_mgmt;
+int ieee802_11_mgmt(struct hostapd_data *hapd, const u8 *buf, size_t len,
+		    struct hostapd_frame_info *fi);
+void ieee802_11_mgmt_cb(struct hostapd_data *hapd, const u8 *buf, size_t len,
+			u16 stype, int ok);
+void hostapd_2040_coex_action(struct hostapd_data *hapd,
+			      const struct ieee80211_mgmt *mgmt, size_t len);
+#ifdef NEED_AP_MLME
+int ieee802_11_get_mib(struct hostapd_data *hapd, char *buf, size_t buflen);
+int ieee802_11_get_mib_sta(struct hostapd_data *hapd, struct sta_info *sta,
+			   char *buf, size_t buflen);
+#else /* NEED_AP_MLME */
+static inline int ieee802_11_get_mib(struct hostapd_data *hapd, char *buf,
+				     size_t buflen)
+	return 0;
+static inline int ieee802_11_get_mib_sta(struct hostapd_data *hapd,
+	return 0;
+#endif /* NEED_AP_MLME */
+u16 hostapd_own_capab_info(struct hostapd_data *hapd);
+void ap_ht2040_timeout(void *eloop_data, void *user_data);
+u8 * hostapd_eid_ext_capab(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_qos_map_set(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_supp_rates(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_ext_supp_rates(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_ht_capabilities(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_ht_operation(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_vht_capabilities(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_vht_operation(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_vendor_vht(struct hostapd_data *hapd, u8 *eid);
+int hostapd_ht_operation_update(struct hostapd_iface *iface);
+void ieee802_11_send_sa_query_req(struct hostapd_data *hapd,
+				  const u8 *addr, const u8 *trans_id);
+void hostapd_get_ht_capab(struct hostapd_data *hapd,
+			  struct ieee80211_ht_capabilities *ht_cap,
+			  struct ieee80211_ht_capabilities *neg_ht_cap);
+void hostapd_get_vht_capab(struct hostapd_data *hapd,
+			   struct ieee80211_vht_capabilities *vht_cap,
+			   struct ieee80211_vht_capabilities *neg_vht_cap);
+u16 copy_sta_ht_capab(struct hostapd_data *hapd, struct sta_info *sta,
+		      const u8 *ht_capab);
+u16 copy_sta_vendor_vht(struct hostapd_data *hapd, struct sta_info *sta,
+			const u8 *ie, size_t len);
+void update_ht_state(struct hostapd_data *hapd, struct sta_info *sta);
+void ht40_intolerant_add(struct hostapd_iface *iface, struct sta_info *sta);
+void ht40_intolerant_remove(struct hostapd_iface *iface, struct sta_info *sta);
+u16 copy_sta_vht_capab(struct hostapd_data *hapd, struct sta_info *sta,
+		       const u8 *vht_capab);
+u16 set_sta_vht_opmode(struct hostapd_data *hapd, struct sta_info *sta,
+		       const u8 *vht_opmode);
+void hostapd_tx_status(struct hostapd_data *hapd, const u8 *addr,
+		       const u8 *buf, size_t len, int ack);
+void hostapd_eapol_tx_status(struct hostapd_data *hapd, const u8 *dst,
+			     const u8 *data, size_t len, int ack);
+void ieee802_11_rx_from_unknown(struct hostapd_data *hapd, const u8 *src,
+				int wds);
+u8 * hostapd_eid_assoc_comeback_time(struct hostapd_data *hapd,
+				     struct sta_info *sta, u8 *eid);
+void ieee802_11_sa_query_action(struct hostapd_data *hapd,
+				const u8 *sa, const u8 action_type,
+				const u8 *trans_id);
+u8 * hostapd_eid_interworking(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_adv_proto(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_roaming_consortium(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_time_adv(struct hostapd_data *hapd, u8 *eid);
+u8 * hostapd_eid_time_zone(struct hostapd_data *hapd, u8 *eid);
+int hostapd_update_time_adv(struct hostapd_data *hapd);
+void hostapd_client_poll_ok(struct hostapd_data *hapd, const u8 *addr);
+u8 * hostapd_eid_bss_max_idle_period(struct hostapd_data *hapd, u8 *eid);
+int auth_sae_init_committed(struct hostapd_data *hapd, struct sta_info *sta);
+#ifdef CONFIG_SAE
+void sae_clear_retransmit_timer(struct hostapd_data *hapd,
+				struct sta_info *sta);
+#else /* CONFIG_SAE */
+static inline void sae_clear_retransmit_timer(struct hostapd_data *hapd,
+#endif /* IEEE802_11_H */
diff --git a/freebsd/contrib/wpa/src/ap/ieee802_11_auth.h b/freebsd/contrib/wpa/src/ap/ieee802_11_auth.h
index 00000000000..b66f244b3eb
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/ieee802_11_auth.h
@@ -0,0 +1,29 @@
+ * hostapd / IEEE 802.11 authentication (ACL)
+ * Copyright (c) 2003-2005, Jouni Malinen <j at w1.fi>
+#ifndef IEEE802_11_AUTH_H
+#define IEEE802_11_AUTH_H
+enum {
+	HOSTAPD_ACL_REJECT = 0,
+	HOSTAPD_ACL_ACCEPT = 1,
+	HOSTAPD_ACL_PENDING = 2,
+	HOSTAPD_ACL_ACCEPT_TIMEOUT = 3
+int hostapd_allowed_address(struct hostapd_data *hapd, const u8 *addr,
+			    const u8 *msg, size_t len, u32 *session_timeout,
+			    u32 *acct_interim_interval, int *vlan_id,
+			    struct hostapd_sta_wpa_psk_short **psk,
+			    char **identity, char **radius_cui);
+int hostapd_acl_init(struct hostapd_data *hapd);
+void hostapd_acl_deinit(struct hostapd_data *hapd);
+void hostapd_free_psk_list(struct hostapd_sta_wpa_psk_short *psk);
+void hostapd_acl_expire(struct hostapd_data *hapd);
+#endif /* IEEE802_11_AUTH_H */
diff --git a/freebsd/contrib/wpa/src/ap/ieee802_11_shared.c b/freebsd/contrib/wpa/src/ap/ieee802_11_shared.c
index 00000000000..ec6deaf5800
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/ieee802_11_shared.c
@@ -0,0 +1,510 @@
+ * Copyright (c) 2002-2012, Jouni Malinen <j at w1.fi>
+#include "common/ieee802_11_defs.h"
+#ifdef CONFIG_IEEE80211W
+	u8 *pos = eid;
+	u32 timeout, tu;
+	struct os_reltime now, passed;
+	*pos++ = WLAN_EID_TIMEOUT_INTERVAL;
+	*pos++ = 5;
+	*pos++ = WLAN_TIMEOUT_ASSOC_COMEBACK;
+	os_get_reltime(&now);
+	os_reltime_sub(&now, &sta->sa_query_start, &passed);
+	tu = (passed.sec * 1000000 + passed.usec) / 1024;
+	if (hapd->conf->assoc_sa_query_max_timeout > tu)
+		timeout = hapd->conf->assoc_sa_query_max_timeout - tu;
+	else
+		timeout = 0;
+	if (timeout < hapd->conf->assoc_sa_query_max_timeout)
+		timeout++; /* add some extra time for local timers */
+	WPA_PUT_LE32(pos, timeout);
+	pos += 4;
+	return pos;
+/* MLME-SAQuery.request */
+	struct ieee80211_mgmt mgmt;
+	u8 *end;
+	wpa_printf(MSG_DEBUG, "IEEE 802.11: Sending SA Query Request to "
+		   MACSTR, MAC2STR(addr));
+	wpa_hexdump(MSG_DEBUG, "IEEE 802.11: SA Query Transaction ID",
+		    trans_id, WLAN_SA_QUERY_TR_ID_LEN);
+	os_memset(&mgmt, 0, sizeof(mgmt));
+	mgmt.frame_control = IEEE80211_FC(WLAN_FC_TYPE_MGMT,
+					  WLAN_FC_STYPE_ACTION);
+	os_memcpy(mgmt.da, addr, ETH_ALEN);
+	os_memcpy(mgmt.sa, hapd->own_addr, ETH_ALEN);
+	os_memcpy(mgmt.bssid, hapd->own_addr, ETH_ALEN);
+	mgmt.u.action.category = WLAN_ACTION_SA_QUERY;
+	mgmt.u.action.u.sa_query_req.action = WLAN_SA_QUERY_REQUEST;
+	os_memcpy(mgmt.u.action.u.sa_query_req.trans_id, trans_id,
+		  WLAN_SA_QUERY_TR_ID_LEN);
+	end = mgmt.u.action.u.sa_query_req.trans_id + WLAN_SA_QUERY_TR_ID_LEN;
+	if (hostapd_drv_send_mlme(hapd, &mgmt, end - (u8 *) &mgmt, 0) < 0)
+		wpa_printf(MSG_INFO, "ieee802_11_send_sa_query_req: send failed");
+static void ieee802_11_send_sa_query_resp(struct hostapd_data *hapd,
+					  const u8 *sa, const u8 *trans_id)
+	struct sta_info *sta;
+	struct ieee80211_mgmt resp;
+	u8 *end;
+	wpa_printf(MSG_DEBUG, "IEEE 802.11: Received SA Query Request from "
+		   MACSTR, MAC2STR(sa));
+	sta = ap_get_sta(hapd, sa);
+	if (sta == NULL || !(sta->flags & WLAN_STA_ASSOC)) {
+		wpa_printf(MSG_DEBUG, "IEEE 802.11: Ignore SA Query Request "
+			   "from unassociated STA " MACSTR, MAC2STR(sa));
+		return;
+	wpa_printf(MSG_DEBUG, "IEEE 802.11: Sending SA Query Response to "
+	os_memset(&resp, 0, sizeof(resp));
+	resp.frame_control = IEEE80211_FC(WLAN_FC_TYPE_MGMT,
+	os_memcpy(resp.da, sa, ETH_ALEN);
+	os_memcpy(resp.sa, hapd->own_addr, ETH_ALEN);
+	os_memcpy(resp.bssid, hapd->own_addr, ETH_ALEN);
+	resp.u.action.category = WLAN_ACTION_SA_QUERY;
+	resp.u.action.u.sa_query_req.action = WLAN_SA_QUERY_RESPONSE;
+	os_memcpy(resp.u.action.u.sa_query_req.trans_id, trans_id,
+	end = resp.u.action.u.sa_query_req.trans_id + WLAN_SA_QUERY_TR_ID_LEN;
+	if (hostapd_drv_send_mlme(hapd, &resp, end - (u8 *) &resp, 0) < 0)
+		wpa_printf(MSG_INFO, "ieee80211_mgmt_sa_query_request: send failed");
+void ieee802_11_sa_query_action(struct hostapd_data *hapd, const u8 *sa,
+				const u8 action_type, const u8 *trans_id)
+	int i;
+	if (action_type == WLAN_SA_QUERY_REQUEST) {
+		ieee802_11_send_sa_query_resp(hapd, sa, trans_id);
+		return;
+	if (action_type != WLAN_SA_QUERY_RESPONSE) {
+		wpa_printf(MSG_DEBUG, "IEEE 802.11: Unexpected SA Query "
+			   "Action %d", action_type);
+		return;
+	wpa_printf(MSG_DEBUG, "IEEE 802.11: Received SA Query Response from "
+	/* MLME-SAQuery.confirm */
+	if (sta == NULL || sta->sa_query_trans_id == NULL) {
+		wpa_printf(MSG_DEBUG, "IEEE 802.11: No matching STA with "
+			   "pending SA Query request found");
+		return;
+	for (i = 0; i < sta->sa_query_count; i++) {
+		if (os_memcmp(sta->sa_query_trans_id +
+			      i * WLAN_SA_QUERY_TR_ID_LEN,
+			      trans_id, WLAN_SA_QUERY_TR_ID_LEN) == 0)
+			break;
+	if (i >= sta->sa_query_count) {
+		wpa_printf(MSG_DEBUG, "IEEE 802.11: No matching SA Query "
+			   "transaction identifier found");
+		return;
+	hostapd_logger(hapd, sta->addr, HOSTAPD_MODULE_IEEE80211,
+		       HOSTAPD_LEVEL_DEBUG,
+		       "Reply to pending SA Query received");
+	ap_sta_stop_sa_query(hapd, sta);
+#endif /* CONFIG_IEEE80211W */
+static void hostapd_ext_capab_byte(struct hostapd_data *hapd, u8 *pos, int idx)
+	*pos = 0x00;
+	switch (idx) {
+	case 0: /* Bits 0-7 */
+		if (hapd->iconf->obss_interval)
+			*pos |= 0x01; /* Bit 0 - Coexistence management */
+		break;
+	case 1: /* Bits 8-15 */
+		if (hapd->conf->proxy_arp)
+			*pos |= 0x10; /* Bit 12 - Proxy ARP */
+		break;
+	case 2: /* Bits 16-23 */
+		if (hapd->conf->wnm_sleep_mode)
+			*pos |= 0x02; /* Bit 17 - WNM-Sleep Mode */
+		if (hapd->conf->bss_transition)
+			*pos |= 0x08; /* Bit 19 - BSS Transition */
+		break;
+	case 3: /* Bits 24-31 */
+#ifdef CONFIG_WNM
+		*pos |= 0x02; /* Bit 25 - SSID List */
+#endif /* CONFIG_WNM */
+		if (hapd->conf->time_advertisement == 2)
+			*pos |= 0x08; /* Bit 27 - UTC TSF Offset */
+		if (hapd->conf->interworking)
+			*pos |= 0x80; /* Bit 31 - Interworking */
+		break;
+	case 4: /* Bits 32-39 */
+		if (hapd->conf->qos_map_set_len)
+			*pos |= 0x01; /* Bit 32 - QoS Map */
+		if (hapd->conf->tdls & TDLS_PROHIBIT)
+			*pos |= 0x40; /* Bit 38 - TDLS Prohibited */
+		if (hapd->conf->tdls & TDLS_PROHIBIT_CHAN_SWITCH) {
+			/* Bit 39 - TDLS Channel Switching Prohibited */
+			*pos |= 0x80;
+		break;
+	case 5: /* Bits 40-47 */
+#ifdef CONFIG_HS20
+		if (hapd->conf->hs20)
+			*pos |= 0x40; /* Bit 46 - WNM-Notification */
+#endif /* CONFIG_HS20 */
+		break;
+	case 6: /* Bits 48-55 */
+		if (hapd->conf->ssid.utf8_ssid)
+			*pos |= 0x01; /* Bit 48 - UTF-8 SSID */
+		break;
+	u8 *pos = eid;
+	u8 len = 0, i;
+	if (hapd->conf->tdls & (TDLS_PROHIBIT | TDLS_PROHIBIT_CHAN_SWITCH))
+		len = 5;
+	if (len < 4 && hapd->conf->interworking)
+		len = 4;
+	if (len < 3 && hapd->conf->wnm_sleep_mode)
+		len = 3;
+	if (len < 1 && hapd->iconf->obss_interval)
+		len = 1;
+	if (len < 7 && hapd->conf->ssid.utf8_ssid)
+		len = 7;
+#ifdef CONFIG_WNM
+	if (len < 4)
+		len = 4;
+#ifdef CONFIG_HS20
+	if (hapd->conf->hs20 && len < 6)
+		len = 6;
+	if (len < hapd->iface->extended_capa_len)
+		len = hapd->iface->extended_capa_len;
+	if (len == 0)
+		return eid;
+	*pos++ = WLAN_EID_EXT_CAPAB;
+	*pos++ = len;
+	for (i = 0; i < len; i++, pos++) {
+		hostapd_ext_capab_byte(hapd, pos, i);
+		if (i < hapd->iface->extended_capa_len) {
+			*pos &= ~hapd->iface->extended_capa_mask[i];
+			*pos |= hapd->iface->extended_capa[i];
+	while (len > 0 && eid[1 + len] == 0) {
+		len--;
+		eid[1] = len;
+	if (len == 0)
+		return eid;
+	return eid + 2 + len;
+	u8 *pos = eid;
+	u8 len = hapd->conf->qos_map_set_len;
+	if (!len)
+		return eid;
+	*pos++ = WLAN_EID_QOS_MAP_SET;
+	*pos++ = len;
+	os_memcpy(pos, hapd->conf->qos_map_set, len);
+	pos += len;
+	return pos;
+	u8 *pos = eid;
+	u8 *len;
+	if (!hapd->conf->interworking)
+		return eid;
+	*pos++ = WLAN_EID_INTERWORKING;
+	len = pos++;
+	*pos = hapd->conf->access_network_type;
+	if (hapd->conf->internet)
+		*pos |= INTERWORKING_ANO_INTERNET;
+	if (hapd->conf->asra)
+		*pos |= INTERWORKING_ANO_ASRA;
+	if (hapd->conf->esr)
+		*pos |= INTERWORKING_ANO_ESR;
+	if (hapd->conf->uesa)
+		*pos |= INTERWORKING_ANO_UESA;
+	pos++;
+	if (hapd->conf->venue_info_set) {
+		*pos++ = hapd->conf->venue_group;
+		*pos++ = hapd->conf->venue_type;
+	if (!is_zero_ether_addr(hapd->conf->hessid)) {
+		os_memcpy(pos, hapd->conf->hessid, ETH_ALEN);
+		pos += ETH_ALEN;
+	*len = pos - len - 1;
+	return pos;
+	u8 *pos = eid;
+	/* TODO: Separate configuration for ANQP? */
+		return eid;
+	*pos++ = WLAN_EID_ADV_PROTO;
+	*pos++ = 2;
+	*pos++ = 0x7F; /* Query Response Length Limit | PAME-BI */
+	*pos++ = ACCESS_NETWORK_QUERY_PROTOCOL;
+	return pos;
+	u8 *pos = eid;
+	u8 *len;
+	unsigned int i, count;
+	if (!hapd->conf->interworking ||
+	    hapd->conf->roaming_consortium == NULL ||
+	    hapd->conf->roaming_consortium_count == 0)
+		return eid;
+	*pos++ = WLAN_EID_ROAMING_CONSORTIUM;
+	len = pos++;
+	/* Number of ANQP OIs (in addition to the max 3 listed here) */
+	if (hapd->conf->roaming_consortium_count > 3 + 255)
+		*pos++ = 255;
+	else if (hapd->conf->roaming_consortium_count > 3)
+		*pos++ = hapd->conf->roaming_consortium_count - 3;
+	else
+		*pos++ = 0;
+	/* OU #1 and #2 Lengths */
+	*pos = hapd->conf->roaming_consortium[0].len;
+	if (hapd->conf->roaming_consortium_count > 1)
+		*pos |= hapd->conf->roaming_consortium[1].len << 4;
+	pos++;
+	if (hapd->conf->roaming_consortium_count > 3)
+		count = 3;
+	else
+		count = hapd->conf->roaming_consortium_count;
+	for (i = 0; i < count; i++) {
+		os_memcpy(pos, hapd->conf->roaming_consortium[i].oi,
+			  hapd->conf->roaming_consortium[i].len);
+		pos += hapd->conf->roaming_consortium[i].len;
+	return pos;
+	if (hapd->conf->time_advertisement != 2)
+		return eid;
+	if (hapd->time_adv == NULL &&
+	    hostapd_update_time_adv(hapd) < 0)
+		return eid;
+	if (hapd->time_adv == NULL)
+		return eid;
+	os_memcpy(eid, wpabuf_head(hapd->time_adv),
+		  wpabuf_len(hapd->time_adv));
+	eid += wpabuf_len(hapd->time_adv);
+	return eid;
+	size_t len;
+		return eid;
+	len = os_strlen(hapd->conf->time_zone);
+	*eid++ = WLAN_EID_TIME_ZONE;
+	*eid++ = len;
+	os_memcpy(eid, hapd->conf->time_zone, len);
+	eid += len;
+	return eid;
+	const int elen = 2 + 1 + 10 + 5 + 1;
+	struct os_time t;
+	struct os_tm tm;
+	u8 *pos;
+		return 0;
+	if (os_get_time(&t) < 0 || os_gmtime(t.sec, &tm) < 0)
+		return -1;
+	if (!hapd->time_adv) {
+		hapd->time_adv = wpabuf_alloc(elen);
+			return -1;
+		pos = wpabuf_put(hapd->time_adv, elen);
+	} else
+		pos = wpabuf_mhead_u8(hapd->time_adv);
+	*pos++ = WLAN_EID_TIME_ADVERTISEMENT;
+	*pos++ = 1 + 10 + 5 + 1;
+	*pos++ = 2; /* UTC time at which the TSF timer is 0 */
+	/* Time Value at TSF 0 */
+	/* FIX: need to calculate this based on the current TSF value */
+	WPA_PUT_LE16(pos, tm.year); /* Year */
+	pos += 2;
+	*pos++ = tm.month; /* Month */
+	*pos++ = tm.day; /* Day of month */
+	*pos++ = tm.hour; /* Hours */
+	*pos++ = tm.min; /* Minutes */
+	*pos++ = tm.sec; /* Seconds */
+	WPA_PUT_LE16(pos, 0); /* Milliseconds (not used) */
+	pos += 2;
+	*pos++ = 0; /* Reserved */
+	/* Time Error */
+	/* TODO: fill in an estimate on the error */
+	*pos++ = 0;
+	*pos++ = 0;
+	*pos++ = 0;
+	*pos++ = 0;
+	*pos++ = 0;
+	*pos++ = hapd->time_update_counter++;
+	return 0;
+	u8 *pos = eid;
+#ifdef CONFIG_WNM
+	if (hapd->conf->ap_max_inactivity > 0) {
+		unsigned int val;
+		*pos++ = WLAN_EID_BSS_MAX_IDLE_PERIOD;
+		*pos++ = 3;
+		val = hapd->conf->ap_max_inactivity;
+		if (val > 68000)
+			val = 68000;
+		val *= 1000;
+		val /= 1024;
+		if (val == 0)
+			val = 1;
+		if (val > 65535)
+			val = 65535;
+		WPA_PUT_LE16(pos, val);
+		pos += 2;
+		*pos++ = 0x00; /* TODO: Protected Keep-Alive Required */
+	return pos;
diff --git a/freebsd/contrib/wpa/src/ap/p2p_hostapd.h b/freebsd/contrib/wpa/src/ap/p2p_hostapd.h
index 00000000000..0e3921c6146
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/p2p_hostapd.h
@@ -0,0 +1,35 @@
+ * hostapd / P2P integration
+ * Copyright (c) 2009-2010, Atheros Communications
+#ifndef P2P_HOSTAPD_H
+#define P2P_HOSTAPD_H
+#ifdef CONFIG_P2P
+int hostapd_p2p_get_mib_sta(struct hostapd_data *hapd, struct sta_info *sta,
+int hostapd_p2p_set_noa(struct hostapd_data *hapd, u8 count, int start,
+			int duration);
+void hostapd_p2p_non_p2p_sta_connected(struct hostapd_data *hapd);
+void hostapd_p2p_non_p2p_sta_disconnected(struct hostapd_data *hapd);
+#else /* CONFIG_P2P */
+static inline int hostapd_p2p_get_mib_sta(struct hostapd_data *hapd,
+	return 0;
+#endif /* CONFIG_P2P */
+u8 * hostapd_eid_p2p_manage(struct hostapd_data *hapd, u8 *eid);
+#endif /* P2P_HOSTAPD_H */
diff --git a/freebsd/contrib/wpa/src/ap/sta_info.h b/freebsd/contrib/wpa/src/ap/sta_info.h
index 00000000000..420d64e5793
--- /dev/null
+++ b/freebsd/contrib/wpa/src/ap/sta_info.h
@@ -0,0 +1,241 @@
+ * hostapd / Station table
+ * Copyright (c) 2002-2011, Jouni Malinen <j at w1.fi>
+#ifndef STA_INFO_H
+#define STA_INFO_H
+#ifdef CONFIG_MESH
+/* needed for mesh_plink_state enum */
+#include "common/defs.h"
+#include "list.h"
+/* STA flags */
+#define WLAN_STA_AUTH BIT(0)
+#define WLAN_STA_ASSOC BIT(1)
+#define WLAN_STA_AUTHORIZED BIT(5)
+#define WLAN_STA_PENDING_POLL BIT(6) /* pending activity poll not ACKed */
+#define WLAN_STA_SHORT_PREAMBLE BIT(7)
+#define WLAN_STA_PREAUTH BIT(8)
+#define WLAN_STA_WMM BIT(9)
+#define WLAN_STA_MFP BIT(10)
+#define WLAN_STA_HT BIT(11)
+#define WLAN_STA_WPS BIT(12)
+#define WLAN_STA_MAYBE_WPS BIT(13)
+#define WLAN_STA_WDS BIT(14)
+#define WLAN_STA_ASSOC_REQ_OK BIT(15)
+#define WLAN_STA_WPS2 BIT(16)
+#define WLAN_STA_GAS BIT(17)
+#define WLAN_STA_VHT BIT(18)
+#define WLAN_STA_WNM_SLEEP_MODE BIT(19)
+#define WLAN_STA_VHT_OPMODE_ENABLED BIT(20)
+#define WLAN_STA_VENDOR_VHT BIT(21)
+#define WLAN_STA_PENDING_DISASSOC_CB BIT(29)
+#define WLAN_STA_PENDING_DEAUTH_CB BIT(30)
+#define WLAN_STA_NONERP BIT(31)
+/* Maximum number of supported rates (from both Supported Rates and Extended
+ * Supported Rates IEs). */
+#define WLAN_SUPP_RATES_MAX 32
+struct sta_info {
+	struct sta_info *next; /* next entry in sta list */
+	struct sta_info *hnext; /* next entry in hash table list */
+	u8 addr[6];
+	be32 ipaddr;
+	struct dl_list ip6addr; /* list head for struct ip6addr */
+	u16 aid; /* STA's unique AID (1 .. 2007) or 0 if not yet assigned */
+	u32 flags; /* Bitfield of WLAN_STA_* */
+	u16 capability;
+	u16 listen_interval; /* or beacon_int for APs */
+	u8 supported_rates[WLAN_SUPP_RATES_MAX];
+	int supported_rates_len;
+	u8 qosinfo; /* Valid when WLAN_STA_WMM is set */
+#ifdef CONFIG_MESH
+	enum mesh_plink_state plink_state;
+	u16 peer_lid;
+	u16 my_lid;
+	u16 mpm_close_reason;
+	int mpm_retries;
+	u8 my_nonce[32];
+	u8 peer_nonce[32];
+	u8 aek[32];	/* SHA256 digest length */
+	u8 mtk[16];
+	u8 mgtk[16];
+	u8 sae_auth_retry;
+	unsigned int nonerp_set:1;
+	unsigned int no_short_slot_time_set:1;
+	unsigned int no_short_preamble_set:1;
+	unsigned int no_ht_gf_set:1;
+	unsigned int no_ht_set:1;
+	unsigned int ht40_intolerant_set:1;
+	unsigned int ht_20mhz_set:1;
+	unsigned int no_p2p_set:1;
+	unsigned int qos_map_enabled:1;
+	unsigned int remediation:1;
+	unsigned int hs20_deauth_requested:1;
+	unsigned int session_timeout_set:1;
+	unsigned int radius_das_match:1;
+	u16 auth_alg;
+	enum {
+		STA_NULLFUNC = 0, STA_DISASSOC, STA_DEAUTH, STA_REMOVE,
+		STA_DISASSOC_FROM_CLI
+	} timeout_next;
+	u16 deauth_reason;
+	u16 disassoc_reason;
+	/* IEEE 802.1X related data */
+	struct eapol_state_machine *eapol_sm;
+	u32 acct_session_id_hi;
+	u32 acct_session_id_lo;
+	struct os_reltime acct_session_start;
+	int acct_session_started;
+	int acct_terminate_cause; /* Acct-Terminate-Cause */
+	int acct_interim_interval; /* Acct-Interim-Interval */
+	unsigned long last_rx_bytes;
+	unsigned long last_tx_bytes;
+	u32 acct_input_gigawords; /* Acct-Input-Gigawords */
+	u32 acct_output_gigawords; /* Acct-Output-Gigawords */
+	u8 *challenge; /* IEEE 802.11 Shared Key Authentication Challenge */
+	struct wpa_state_machine *wpa_sm;
+	int vlan_id; /* 0: none, >0: VID */
+	int vlan_id_bound; /* updated by ap_sta_bind_vlan() */
+	 /* PSKs from RADIUS authentication server */
+	struct hostapd_sta_wpa_psk_short *psk;
+	char *identity; /* User-Name from RADIUS */
+	char *radius_cui; /* Chargeable-User-Identity from RADIUS */
+	struct ieee80211_ht_capabilities *ht_capabilities;
+	struct ieee80211_vht_capabilities *vht_capabilities;
+	u8 vht_opmode;
+	int sa_query_count; /* number of pending SA Query requests;
+			     * 0 = no SA Query in progress */
+	int sa_query_timed_out;
+	u8 *sa_query_trans_id; /* buffer of WLAN_SA_QUERY_TR_ID_LEN *
+				* sa_query_count octets of pending SA Query
+				* transaction identifiers */
+	struct os_reltime sa_query_start;
+#define GAS_DIALOG_MAX 8 /* Max concurrent dialog number */
+	struct gas_dialog_info *gas_dialog;
+	u8 gas_dialog_next;
+	struct wpabuf *wps_ie; /* WPS IE from (Re)Association Request */
+	struct wpabuf *p2p_ie; /* P2P IE from (Re)Association Request */
+	struct wpabuf *hs20_ie; /* HS 2.0 IE from (Re)Association Request */
+	u8 remediation_method;
+	char *remediation_url; /* HS 2.0 Subscription Remediation Server URL */
+	struct wpabuf *hs20_deauth_req;
+	char *hs20_session_info_url;
+	int hs20_disassoc_timer;
+#ifdef CONFIG_FST
+	struct wpabuf *mb_ies; /* MB IEs from (Re)Association Request */
+#endif /* CONFIG_FST */
+	struct os_reltime connected_time;
+#ifdef CONFIG_SAE
+	struct sae_data *sae;
+	u32 session_timeout; /* valid only if session_timeout_set == 1 */
+	/* Last Authentication/(Re)Association Request/Action frame sequence
+	 * control */
+	u16 last_seq_ctrl;
+	/* Last Authentication/(Re)Association Request/Action frame subtype */
+	u8 last_subtype;
+/* Default value for maximum station inactivity. After AP_MAX_INACTIVITY has
+ * passed since last received frame from the station, a nullfunc data frame is
+ * sent to the station. If this frame is not acknowledged and no other frames
+ * have been received, the station will be disassociated after
+ * AP_DISASSOC_DELAY seconds. Similarly, the station will be deauthenticated
+ * after AP_DEAUTH_DELAY seconds has passed after disassociation. */
+#define AP_MAX_INACTIVITY (5 * 60)
+#define AP_DISASSOC_DELAY (1)
+#define AP_DEAUTH_DELAY (1)
+/* Number of seconds to keep STA entry with Authenticated flag after it has
+ * been disassociated. */
+#define AP_MAX_INACTIVITY_AFTER_DISASSOC (1 * 30)
+/* Number of seconds to keep STA entry after it has been deauthenticated. */
+#define AP_MAX_INACTIVITY_AFTER_DEAUTH (1 * 5)
+int ap_for_each_sta(struct hostapd_data *hapd,
+		    int (*cb)(struct hostapd_data *hapd, struct sta_info *sta,
+			      void *ctx),
+		    void *ctx);
+struct sta_info * ap_get_sta(struct hostapd_data *hapd, const u8 *sta);
+struct sta_info * ap_get_sta_p2p(struct hostapd_data *hapd, const u8 *addr);
+void ap_sta_hash_add(struct hostapd_data *hapd, struct sta_info *sta);
+void ap_free_sta(struct hostapd_data *hapd, struct sta_info *sta);
+void ap_sta_ip6addr_del(struct hostapd_data *hapd, struct sta_info *sta);
+void hostapd_free_stas(struct hostapd_data *hapd);
+void ap_handle_timer(void *eloop_ctx, void *timeout_ctx);
+void ap_sta_replenish_timeout(struct hostapd_data *hapd, struct sta_info *sta,
+			      u32 session_timeout);
+void ap_sta_session_timeout(struct hostapd_data *hapd, struct sta_info *sta,
+void ap_sta_no_session_timeout(struct hostapd_data *hapd,
+void ap_sta_session_warning_timeout(struct hostapd_data *hapd,
+				    struct sta_info *sta, int warning_time);
+struct sta_info * ap_sta_add(struct hostapd_data *hapd, const u8 *addr);
+void ap_sta_disassociate(struct hostapd_data *hapd, struct sta_info *sta,
+			 u16 reason);
+void ap_sta_deauthenticate(struct hostapd_data *hapd, struct sta_info *sta,
+			   u16 reason);
+#ifdef CONFIG_WPS
+int ap_sta_wps_cancel(struct hostapd_data *hapd,
+		      struct sta_info *sta, void *ctx);
+#endif /* CONFIG_WPS */
+int ap_sta_bind_vlan(struct hostapd_data *hapd, struct sta_info *sta);
+void ap_sta_start_sa_query(struct hostapd_data *hapd, struct sta_info *sta);
+void ap_sta_stop_sa_query(struct hostapd_data *hapd, struct sta_info *sta);
+int ap_check_sa_query_timeout(struct hostapd_data *hapd, struct sta_info *sta);
+void ap_sta_disconnect(struct hostapd_data *hapd, struct sta_info *sta,
+		       const u8 *addr, u16 reason);
+void ap_sta_set_authorized(struct hostapd_data *hapd,
+static inline int ap_sta_is_authorized(struct sta_info *sta)
+	return sta->flags & WLAN_STA_AUTHORIZED;
+void ap_sta_deauth_cb(struct hostapd_data *hapd, struct sta_info *sta);
+void ap_sta_disassoc_cb(struct hostapd_data *hapd, struct sta_info *sta);
+int ap_sta_flags_txt(u32 flags, char *buf, size_t buflen);
+#endif /* STA_INFO_H */
diff --git a/freebsd/contrib/wpa/src/common/defs.h b/freebsd/contrib/wpa/src/common/defs.h
index 00000000000..6aea3751a2b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/defs.h
@@ -0,0 +1,337 @@
+ * WPA Supplicant - Common definitions
+ * Copyright (c) 2004-2015, Jouni Malinen <j at w1.fi>
+#ifndef DEFS_H
+#define DEFS_H
+#ifdef FALSE
+#undef FALSE
+#endif
+#ifdef TRUE
+#undef TRUE
+#endif
+typedef enum { FALSE = 0, TRUE = 1 } Boolean;
+#define WPA_CIPHER_NONE BIT(0)
+#define WPA_CIPHER_WEP40 BIT(1)
+#define WPA_CIPHER_WEP104 BIT(2)
+#define WPA_CIPHER_TKIP BIT(3)
+#define WPA_CIPHER_CCMP BIT(4)
+#define WPA_CIPHER_AES_128_CMAC BIT(5)
+#define WPA_CIPHER_GCMP BIT(6)
+#define WPA_CIPHER_SMS4 BIT(7)
+#define WPA_CIPHER_GCMP_256 BIT(8)
+#define WPA_CIPHER_CCMP_256 BIT(9)
+#define WPA_CIPHER_BIP_GMAC_128 BIT(11)
+#define WPA_CIPHER_BIP_GMAC_256 BIT(12)
+#define WPA_CIPHER_BIP_CMAC_256 BIT(13)
+#define WPA_CIPHER_GTK_NOT_USED BIT(14)
+#define WPA_KEY_MGMT_IEEE8021X BIT(0)
+#define WPA_KEY_MGMT_PSK BIT(1)
+#define WPA_KEY_MGMT_NONE BIT(2)
+#define WPA_KEY_MGMT_IEEE8021X_NO_WPA BIT(3)
+#define WPA_KEY_MGMT_WPA_NONE BIT(4)
+#define WPA_KEY_MGMT_FT_IEEE8021X BIT(5)
+#define WPA_KEY_MGMT_FT_PSK BIT(6)
+#define WPA_KEY_MGMT_IEEE8021X_SHA256 BIT(7)
+#define WPA_KEY_MGMT_PSK_SHA256 BIT(8)
+#define WPA_KEY_MGMT_WPS BIT(9)
+#define WPA_KEY_MGMT_SAE BIT(10)
+#define WPA_KEY_MGMT_FT_SAE BIT(11)
+#define WPA_KEY_MGMT_WAPI_PSK BIT(12)
+#define WPA_KEY_MGMT_WAPI_CERT BIT(13)
+#define WPA_KEY_MGMT_CCKM BIT(14)
+#define WPA_KEY_MGMT_OSEN BIT(15)
+#define WPA_KEY_MGMT_IEEE8021X_SUITE_B BIT(16)
+#define WPA_KEY_MGMT_IEEE8021X_SUITE_B_192 BIT(17)
+static inline int wpa_key_mgmt_wpa_ieee8021x(int akm)
+	return !!(akm & (WPA_KEY_MGMT_IEEE8021X |
+			 WPA_KEY_MGMT_FT_IEEE8021X |
+			 WPA_KEY_MGMT_CCKM |
+			 WPA_KEY_MGMT_OSEN |
+			 WPA_KEY_MGMT_IEEE8021X_SHA256 |
+			 WPA_KEY_MGMT_IEEE8021X_SUITE_B |
+			 WPA_KEY_MGMT_IEEE8021X_SUITE_B_192));
+static inline int wpa_key_mgmt_wpa_psk(int akm)
+	return !!(akm & (WPA_KEY_MGMT_PSK |
+			 WPA_KEY_MGMT_FT_PSK |
+			 WPA_KEY_MGMT_PSK_SHA256 |
+			 WPA_KEY_MGMT_SAE |
+			 WPA_KEY_MGMT_FT_SAE));
+static inline int wpa_key_mgmt_ft(int akm)
+	return !!(akm & (WPA_KEY_MGMT_FT_PSK |
+static inline int wpa_key_mgmt_sae(int akm)
+	return !!(akm & (WPA_KEY_MGMT_SAE |
+static inline int wpa_key_mgmt_sha256(int akm)
+	return !!(akm & (WPA_KEY_MGMT_PSK_SHA256 |
+			 WPA_KEY_MGMT_IEEE8021X_SUITE_B));
+static inline int wpa_key_mgmt_sha384(int akm)
+	return !!(akm & WPA_KEY_MGMT_IEEE8021X_SUITE_B_192);
+static inline int wpa_key_mgmt_suite_b(int akm)
+	return !!(akm & (WPA_KEY_MGMT_IEEE8021X_SUITE_B |
+static inline int wpa_key_mgmt_wpa(int akm)
+	return wpa_key_mgmt_wpa_ieee8021x(akm) ||
+		wpa_key_mgmt_wpa_psk(akm) ||
+		wpa_key_mgmt_sae(akm);
+static inline int wpa_key_mgmt_wpa_any(int akm)
+	return wpa_key_mgmt_wpa(akm) || (akm & WPA_KEY_MGMT_WPA_NONE);
+static inline int wpa_key_mgmt_cckm(int akm)
+	return akm == WPA_KEY_MGMT_CCKM;
+#define WPA_PROTO_WPA BIT(0)
+#define WPA_PROTO_RSN BIT(1)
+#define WPA_PROTO_WAPI BIT(2)
+#define WPA_PROTO_OSEN BIT(3)
+#define WPA_AUTH_ALG_OPEN BIT(0)
+#define WPA_AUTH_ALG_SHARED BIT(1)
+#define WPA_AUTH_ALG_LEAP BIT(2)
+#define WPA_AUTH_ALG_FT BIT(3)
+#define WPA_AUTH_ALG_SAE BIT(4)
+enum wpa_alg {
+	WPA_ALG_NONE,
+	WPA_ALG_WEP,
+	WPA_ALG_TKIP,
+	WPA_ALG_CCMP,
+	WPA_ALG_IGTK,
+	WPA_ALG_PMK,
+	WPA_ALG_GCMP,
+	WPA_ALG_SMS4,
+	WPA_ALG_KRK,
+	WPA_ALG_GCMP_256,
+	WPA_ALG_CCMP_256,
+	WPA_ALG_BIP_GMAC_128,
+	WPA_ALG_BIP_GMAC_256,
+	WPA_ALG_BIP_CMAC_256
+ * enum wpa_states - wpa_supplicant state
+ * These enumeration values are used to indicate the current wpa_supplicant
+ * state (wpa_s->wpa_state). The current state can be retrieved with
+ * wpa_supplicant_get_state() function and the state can be changed by calling
+ * wpa_supplicant_set_state(). In WPA state machine (wpa.c and preauth.c), the
+ * wrapper functions wpa_sm_get_state() and wpa_sm_set_state() should be used
+ * to access the state variable.
+enum wpa_states {
+	 * WPA_DISCONNECTED - Disconnected state
+	 * This state indicates that client is not associated, but is likely to
+	 * start looking for an access point. This state is entered when a
+	 * connection is lost.
+	WPA_DISCONNECTED,
+	 * WPA_INTERFACE_DISABLED - Interface disabled
+	 * This state is entered if the network interface is disabled, e.g.,
+	 * due to rfkill. wpa_supplicant refuses any new operations that would
+	 * use the radio until the interface has been enabled.
+	WPA_INTERFACE_DISABLED,
+	 * WPA_INACTIVE - Inactive state (wpa_supplicant disabled)
+	 * This state is entered if there are no enabled networks in the
+	 * configuration. wpa_supplicant is not trying to associate with a new
+	 * network and external interaction (e.g., ctrl_iface call to add or
+	 * enable a network) is needed to start association.
+	WPA_INACTIVE,
+	 * WPA_SCANNING - Scanning for a network
+	 * This state is entered when wpa_supplicant starts scanning for a
+	 * network.
+	WPA_SCANNING,
+	 * WPA_AUTHENTICATING - Trying to authenticate with a BSS/SSID
+	 * This state is entered when wpa_supplicant has found a suitable BSS
+	 * to authenticate with and the driver is configured to try to
+	 * authenticate with this BSS. This state is used only with drivers
+	 * that use wpa_supplicant as the SME.
+	WPA_AUTHENTICATING,
+	 * WPA_ASSOCIATING - Trying to associate with a BSS/SSID
+	 * to associate with and the driver is configured to try to associate
+	 * with this BSS in ap_scan=1 mode. When using ap_scan=2 mode, this
+	 * state is entered when the driver is configured to try to associate
+	 * with a network using the configured SSID and security policy.
+	WPA_ASSOCIATING,
+	 * WPA_ASSOCIATED - Association completed
+	 * This state is entered when the driver reports that association has
+	 * been successfully completed with an AP. If IEEE 802.1X is used
+	 * (with or without WPA/WPA2), wpa_supplicant remains in this state
+	 * until the IEEE 802.1X/EAPOL authentication has been completed.
+	WPA_ASSOCIATED,
+	 * WPA_4WAY_HANDSHAKE - WPA 4-Way Key Handshake in progress
+	 * This state is entered when WPA/WPA2 4-Way Handshake is started. In
+	 * case of WPA-PSK, this happens when receiving the first EAPOL-Key
+	 * frame after association. In case of WPA-EAP, this state is entered
+	 * when the IEEE 802.1X/EAPOL authentication has been completed.
+	WPA_4WAY_HANDSHAKE,
+	 * WPA_GROUP_HANDSHAKE - WPA Group Key Handshake in progress
+	 * This state is entered when 4-Way Key Handshake has been completed
+	 * (i.e., when the supplicant sends out message 4/4) and when Group
+	 * Key rekeying is started by the AP (i.e., when supplicant receives
+	 * message 1/2).
+	WPA_GROUP_HANDSHAKE,
+	 * WPA_COMPLETED - All authentication completed
+	 * This state is entered when the full authentication process is
+	 * completed. In case of WPA2, this happens when the 4-Way Handshake is
+	 * successfully completed. With WPA, this state is entered after the
+	 * Group Key Handshake; with IEEE 802.1X (non-WPA) connection is
+	 * completed after dynamic keys are received (or if not used, after
+	 * the EAP authentication has been completed). With static WEP keys and
+	 * plaintext connections, this state is entered when an association
+	 * has been completed.
+	 * This state indicates that the supplicant has completed its
+	 * processing for the association phase and that data connection is
+	 * fully configured.
+	WPA_COMPLETED
+#define MLME_SETPROTECTION_PROTECT_TYPE_NONE 0
+#define MLME_SETPROTECTION_PROTECT_TYPE_RX 1
+#define MLME_SETPROTECTION_PROTECT_TYPE_TX 2
+#define MLME_SETPROTECTION_PROTECT_TYPE_RX_TX 3
+#define MLME_SETPROTECTION_KEY_TYPE_GROUP 0
+#define MLME_SETPROTECTION_KEY_TYPE_PAIRWISE 1
+ * enum mfp_options - Management frame protection (IEEE 802.11w) options
+enum mfp_options {
+	NO_MGMT_FRAME_PROTECTION = 0,
+	MGMT_FRAME_PROTECTION_OPTIONAL = 1,
+	MGMT_FRAME_PROTECTION_REQUIRED = 2,
+#define MGMT_FRAME_PROTECTION_DEFAULT 3
+ * enum hostapd_hw_mode - Hardware mode
+enum hostapd_hw_mode {
+	HOSTAPD_MODE_IEEE80211B,
+	HOSTAPD_MODE_IEEE80211G,
+	HOSTAPD_MODE_IEEE80211A,
+	HOSTAPD_MODE_IEEE80211AD,
+	HOSTAPD_MODE_IEEE80211ANY,
+	NUM_HOSTAPD_MODES
+ * enum wpa_ctrl_req_type - Control interface request types
+enum wpa_ctrl_req_type {
+	WPA_CTRL_REQ_UNKNOWN,
+	WPA_CTRL_REQ_EAP_IDENTITY,
+	WPA_CTRL_REQ_EAP_PASSWORD,
+	WPA_CTRL_REQ_EAP_NEW_PASSWORD,
+	WPA_CTRL_REQ_EAP_PIN,
+	WPA_CTRL_REQ_EAP_OTP,
+	WPA_CTRL_REQ_EAP_PASSPHRASE,
+	WPA_CTRL_REQ_SIM,
+	WPA_CTRL_REQ_PSK_PASSPHRASE,
+	NUM_WPA_CTRL_REQS
+/* Maximum number of EAP methods to store for EAP server user information */
+#define EAP_MAX_METHODS 8
+enum mesh_plink_state {
+	PLINK_LISTEN = 1,
+	PLINK_OPEN_SENT,
+	PLINK_OPEN_RCVD,
+	PLINK_CNF_RCVD,
+	PLINK_ESTAB,
+	PLINK_HOLDING,
+	PLINK_BLOCKED,
+enum set_band {
+	WPA_SETBAND_AUTO,
+	WPA_SETBAND_5G,
+	WPA_SETBAND_2G
+#endif /* DEFS_H */
diff --git a/freebsd/contrib/wpa/src/common/eapol_common.h b/freebsd/contrib/wpa/src/common/eapol_common.h
index 00000000000..6958661f78b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/eapol_common.h
@@ -0,0 +1,92 @@
+ * EAPOL definitions shared between hostapd and wpa_supplicant
+ * Copyright (c) 2002-2007, Jouni Malinen <j at w1.fi>
+#ifndef EAPOL_COMMON_H
+#define EAPOL_COMMON_H
+/* IEEE Std 802.1X-2004 */
+#ifdef _MSC_VER
+#pragma pack(push, 1)
+#endif /* _MSC_VER */
+struct ieee802_1x_hdr {
+	u8 version;
+	u8 type;
+	be16 length;
+	/* followed by length octets of data */
+} STRUCT_PACKED;
+struct ieee8023_hdr {
+	u8 dest[ETH_ALEN];
+	u8 src[ETH_ALEN];
+	u16 ethertype;
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+#ifdef CONFIG_MACSEC
+#define EAPOL_VERSION 3
+#else /* CONFIG_MACSEC */
+#define EAPOL_VERSION 2
+#endif /* CONFIG_MACSEC */
+enum { IEEE802_1X_TYPE_EAP_PACKET = 0,
+       IEEE802_1X_TYPE_EAPOL_START = 1,
+       IEEE802_1X_TYPE_EAPOL_LOGOFF = 2,
+       IEEE802_1X_TYPE_EAPOL_KEY = 3,
+       IEEE802_1X_TYPE_EAPOL_ENCAPSULATED_ASF_ALERT = 4,
+       IEEE802_1X_TYPE_EAPOL_MKA = 5,
+enum { EAPOL_KEY_TYPE_RC4 = 1, EAPOL_KEY_TYPE_RSN = 2,
+       EAPOL_KEY_TYPE_WPA = 254 };
+#define IEEE8021X_REPLAY_COUNTER_LEN 8
+#define IEEE8021X_KEY_SIGN_LEN 16
+#define IEEE8021X_KEY_IV_LEN 16
+#define IEEE8021X_KEY_INDEX_FLAG 0x80
+#define IEEE8021X_KEY_INDEX_MASK 0x03
+#ifdef _MSC_VER
+struct ieee802_1x_eapol_key {
+	u8 type;
+	/* Note: key_length is unaligned */
+	u8 key_length[2];
+	/* does not repeat within the life of the keying material used to
+	 * encrypt the Key field; 64-bit NTP timestamp MAY be used here */
+	u8 replay_counter[IEEE8021X_REPLAY_COUNTER_LEN];
+	u8 key_iv[IEEE8021X_KEY_IV_LEN]; /* cryptographically random number */
+	u8 key_index; /* key flag in the most significant bit:
+		       * 0 = broadcast (default key),
+		       * 1 = unicast (key mapping key); key index is in the
+		       * 7 least significant bits */
+	/* HMAC-MD5 message integrity check computed with MS-MPPE-Send-Key as
+	 * the key */
+	u8 key_signature[IEEE8021X_KEY_SIGN_LEN];
+	/* followed by key: if packet body length = 44 + key length, then the
+	 * key field (of key_length bytes) contains the key in encrypted form;
+	 * if packet body length = 44, key field is absent and key_length
+	 * represents the number of least significant octets from
+	 * MS-MPPE-Send-Key attribute to be used as the keying material;
+	 * RC4 key used in encryption = Key-IV + MS-MPPE-Recv-Key */
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+#endif /* EAPOL_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/common/gas.c b/freebsd/contrib/wpa/src/common/gas.c
index 00000000000..1aa3c8065ee
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/gas.c
@@ -0,0 +1,275 @@
+#include <machine/rtems-bsd-user-space.h>
+ * Generic advertisement service (GAS) (IEEE 802.11u)
+ * Copyright (c) 2011-2012, Qualcomm Atheros
+#include "ieee802_11_defs.h"
+#include "gas.h"
+static struct wpabuf *
+gas_build_req(u8 action, u8 dialog_token, size_t size)
+	buf = wpabuf_alloc(100 + size);
+	if (buf == NULL)
+		return NULL;
+	wpabuf_put_u8(buf, WLAN_ACTION_PUBLIC);
+	wpabuf_put_u8(buf, action);
+	wpabuf_put_u8(buf, dialog_token);
+	return buf;
+struct wpabuf * gas_build_initial_req(u8 dialog_token, size_t size)
+	return gas_build_req(WLAN_PA_GAS_INITIAL_REQ, dialog_token,
+			     size);
+struct wpabuf * gas_build_comeback_req(u8 dialog_token)
+	return gas_build_req(WLAN_PA_GAS_COMEBACK_REQ, dialog_token, 0);
+gas_build_resp(u8 action, u8 dialog_token, u16 status_code, u8 frag_id,
+	       u8 more, u16 comeback_delay, size_t size)
+	if (buf == NULL)
+		return NULL;
+	wpabuf_put_le16(buf, status_code);
+	if (action == WLAN_PA_GAS_COMEBACK_RESP)
+		wpabuf_put_u8(buf, frag_id | (more ? 0x80 : 0));
+	wpabuf_put_le16(buf, comeback_delay);
+	return buf;
+struct wpabuf *
+gas_build_initial_resp(u8 dialog_token, u16 status_code, u16 comeback_delay,
+		       size_t size)
+	return gas_build_resp(WLAN_PA_GAS_INITIAL_RESP, dialog_token,
+			      status_code, 0, 0, comeback_delay, size);
+gas_build_comeback_resp(u8 dialog_token, u16 status_code, u8 frag_id, u8 more,
+			u16 comeback_delay, size_t size)
+	return gas_build_resp(WLAN_PA_GAS_COMEBACK_RESP, dialog_token,
+			      status_code, frag_id, more, comeback_delay,
+			      size);
+ * gas_add_adv_proto_anqp - Add an Advertisement Protocol element
+ * @buf: Buffer to which the element is added
+ * @query_resp_len_limit: Query Response Length Limit in units of 256 octets
+ * @pame_bi: Pre-Association Message Exchange BSSID Independent (0/1)
+ * @query_resp_len_limit is 0 for request and 1-0x7f for response. 0x7f means
+ * that the maximum limit is determined by the maximum allowable number of
+ * fragments in the GAS Query Response Fragment ID.
+static void gas_add_adv_proto_anqp(struct wpabuf *buf, u8 query_resp_len_limit,
+				   u8 pame_bi)
+	/* Advertisement Protocol IE */
+	wpabuf_put_u8(buf, WLAN_EID_ADV_PROTO);
+	wpabuf_put_u8(buf, 2); /* Length */
+	wpabuf_put_u8(buf, (query_resp_len_limit & 0x7f) |
+		      (pame_bi ? 0x80 : 0));
+	/* Advertisement Protocol */
+	wpabuf_put_u8(buf, ACCESS_NETWORK_QUERY_PROTOCOL);
+struct wpabuf * gas_anqp_build_initial_req(u8 dialog_token, size_t size)
+	buf = gas_build_initial_req(dialog_token, 4 + size);
+	if (buf == NULL)
+		return NULL;
+	gas_add_adv_proto_anqp(buf, 0, 0);
+	wpabuf_put(buf, 2); /* Query Request Length to be filled */
+	return buf;
+struct wpabuf * gas_anqp_build_initial_resp(u8 dialog_token, u16 status_code,
+	buf = gas_build_initial_resp(dialog_token, status_code, comeback_delay,
+				     4 + size);
+	if (buf == NULL)
+		return NULL;
+	gas_add_adv_proto_anqp(buf, 0x7f, 0);
+	wpabuf_put(buf, 2); /* Query Response Length to be filled */
+	return buf;
+struct wpabuf * gas_anqp_build_initial_resp_buf(u8 dialog_token,
+						u16 status_code,
+						struct wpabuf *payload)
+	buf = gas_anqp_build_initial_resp(dialog_token, status_code,
+					  comeback_delay,
+					  payload ? wpabuf_len(payload) : 0);
+	if (buf == NULL)
+		return NULL;
+	if (payload)
+	gas_anqp_set_len(buf);
+	return buf;
+struct wpabuf * gas_anqp_build_comeback_resp(u8 dialog_token, u16 status_code,
+					     u8 frag_id, u8 more,
+	buf = gas_build_comeback_resp(dialog_token, status_code,
+				      frag_id, more, comeback_delay, 4 + size);
+	if (buf == NULL)
+		return NULL;
+	return buf;
+struct wpabuf * gas_anqp_build_comeback_resp_buf(u8 dialog_token,
+						 u16 status_code,
+	buf = gas_anqp_build_comeback_resp(dialog_token, status_code, frag_id,
+					   more, comeback_delay,
+	if (buf == NULL)
+		return NULL;
+	if (payload)
+	return buf;
+ * gas_anqp_set_len - Set Query Request/Response Length
+ * @buf: GAS message
+ * This function is used to update the Query Request/Response Length field once
+ * the payload has been filled.
+void gas_anqp_set_len(struct wpabuf *buf)
+	u8 action;
+	size_t offset;
+	u8 *len;
+	if (buf == NULL || wpabuf_len(buf) < 2)
+		return;
+	action = *(wpabuf_head_u8(buf) + 1);
+	switch (action) {
+	case WLAN_PA_GAS_INITIAL_REQ:
+		offset = 3 + 4;
+		break;
+	case WLAN_PA_GAS_INITIAL_RESP:
+		offset = 7 + 4;
+		break;
+	case WLAN_PA_GAS_COMEBACK_RESP:
+		offset = 8 + 4;
+		break;
+	default:
+		return;
+	if (wpabuf_len(buf) < offset + 2)
+		return;
+	len = wpabuf_mhead_u8(buf) + offset;
+	WPA_PUT_LE16(len, (u8 *) wpabuf_put(buf, 0) - len - 2);
+ * gas_anqp_add_element - Add ANQP element header
+ * @info_id: ANQP Info ID
+ * Returns: Pointer to the Length field for gas_anqp_set_element_len()
+u8 * gas_anqp_add_element(struct wpabuf *buf, u16 info_id)
+	wpabuf_put_le16(buf, info_id);
+	return wpabuf_put(buf, 2); /* Length to be filled */
+ * gas_anqp_set_element_len - Update ANQP element Length field
+ * @len_pos: Length field position from gas_anqp_add_element()
+ * This function is called after the ANQP element payload has been added to the
+ * buffer.
+void gas_anqp_set_element_len(struct wpabuf *buf, u8 *len_pos)
+	WPA_PUT_LE16(len_pos, (u8 *) wpabuf_put(buf, 0) - len_pos - 2);
diff --git a/freebsd/contrib/wpa/src/common/gas.h b/freebsd/contrib/wpa/src/common/gas.h
index 00000000000..306adc58c6e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/gas.h
@@ -0,0 +1,37 @@
+#ifndef GAS_H
+#define GAS_H
+struct wpabuf * gas_build_initial_req(u8 dialog_token, size_t size);
+struct wpabuf * gas_build_comeback_req(u8 dialog_token);
+struct wpabuf * gas_build_initial_resp(u8 dialog_token, u16 status_code,
+				       u16 comeback_delay, size_t size);
+struct wpabuf * gas_anqp_build_initial_req(u8 dialog_token, size_t size);
+						u16 status_code,
+						struct wpabuf *payload);
+						 u16 status_code,
+void gas_anqp_set_len(struct wpabuf *buf);
+u8 * gas_anqp_add_element(struct wpabuf *buf, u16 info_id);
+void gas_anqp_set_element_len(struct wpabuf *buf, u8 *len_pos);
+#endif /* GAS_H */
diff --git a/freebsd/contrib/wpa/src/common/hw_features_common.c b/freebsd/contrib/wpa/src/common/hw_features_common.c
index 00000000000..81b8e695e21
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/hw_features_common.c
@@ -0,0 +1,457 @@
+ * Common hostapd/wpa_supplicant HW features
+ * Copyright (c) 2002-2013, Jouni Malinen <j at w1.fi>
+ * Copyright (c) 2015, Qualcomm Atheros, Inc.
+#include "defs.h"
+#include "ieee802_11_common.h"
+#include "hw_features_common.h"
+struct hostapd_channel_data * hw_get_channel_chan(struct hostapd_hw_modes *mode,
+						  int chan, int *freq)
+	int i;
+	if (freq)
+		*freq = 0;
+	if (!mode)
+		return NULL;
+	for (i = 0; i < mode->num_channels; i++) {
+		struct hostapd_channel_data *ch = &mode->channels[i];
+		if (ch->chan == chan) {
+			if (freq)
+				*freq = ch->freq;
+			return ch;
+	return NULL;
+struct hostapd_channel_data * hw_get_channel_freq(struct hostapd_hw_modes *mode,
+						  int freq, int *chan)
+	int i;
+	if (chan)
+		*chan = 0;
+	if (!mode)
+		return NULL;
+		if (ch->freq == freq) {
+			if (chan)
+				*chan = ch->chan;
+			return ch;
+	return NULL;
+int hw_get_freq(struct hostapd_hw_modes *mode, int chan)
+	int freq;
+	hw_get_channel_chan(mode, chan, &freq);
+	return freq;
+int hw_get_chan(struct hostapd_hw_modes *mode, int freq)
+	int chan;
+	hw_get_channel_freq(mode, freq, &chan);
+	return chan;
+int allowed_ht40_channel_pair(struct hostapd_hw_modes *mode, int pri_chan,
+			      int sec_chan)
+	int ok, j, first;
+	int allowed[] = { 36, 44, 52, 60, 100, 108, 116, 124, 132, 140,
+			  149, 157, 184, 192 };
+	size_t k;
+	if (pri_chan == sec_chan || !sec_chan)
+		return 1; /* HT40 not used */
+		   "HT40: control channel: %d  secondary channel: %d",
+		   pri_chan, sec_chan);
+	/* Verify that HT40 secondary channel is an allowed 20 MHz
+	 * channel */
+	ok = 0;
+	for (j = 0; j < mode->num_channels; j++) {
+		struct hostapd_channel_data *chan = &mode->channels[j];
+		if (!(chan->flag & HOSTAPD_CHAN_DISABLED) &&
+		    chan->chan == sec_chan) {
+			ok = 1;
+			break;
+	if (!ok) {
+		wpa_printf(MSG_ERROR, "HT40 secondary channel %d not allowed",
+			   sec_chan);
+		return 0;
+	 * Verify that HT40 primary,secondary channel pair is allowed per
+	 * IEEE 802.11n Annex J. This is only needed for 5 GHz band since
+	 * 2.4 GHz rules allow all cases where the secondary channel fits into
+	 * the list of allowed channels (already checked above).
+	if (mode->mode != HOSTAPD_MODE_IEEE80211A)
+		return 1;
+	first = pri_chan < sec_chan ? pri_chan : sec_chan;
+	ok = 0;
+	for (k = 0; k < ARRAY_SIZE(allowed); k++) {
+		if (first == allowed[k]) {
+			ok = 1;
+			break;
+	if (!ok) {
+		wpa_printf(MSG_ERROR, "HT40 channel pair (%d, %d) not allowed",
+		return 0;
+	return 1;
+void get_pri_sec_chan(struct wpa_scan_res *bss, int *pri_chan, int *sec_chan)
+	struct ieee80211_ht_operation *oper;
+	struct ieee802_11_elems elems;
+	*pri_chan = *sec_chan = 0;
+	ieee802_11_parse_elems((u8 *) (bss + 1), bss->ie_len, &elems, 0);
+	if (elems.ht_operation) {
+		oper = (struct ieee80211_ht_operation *) elems.ht_operation;
+		*pri_chan = oper->primary_chan;
+		if (oper->ht_param & HT_INFO_HT_PARAM_STA_CHNL_WIDTH) {
+			int sec = oper->ht_param &
+				HT_INFO_HT_PARAM_SECONDARY_CHNL_OFF_MASK;
+			if (sec == HT_INFO_HT_PARAM_SECONDARY_CHNL_ABOVE)
+				*sec_chan = *pri_chan + 4;
+			else if (sec == HT_INFO_HT_PARAM_SECONDARY_CHNL_BELOW)
+				*sec_chan = *pri_chan - 4;
+int check_40mhz_5g(struct hostapd_hw_modes *mode,
+		   struct wpa_scan_results *scan_res, int pri_chan,
+		   int sec_chan)
+	int pri_freq, sec_freq, pri_bss, sec_bss;
+	int bss_pri_chan, bss_sec_chan;
+	size_t i;
+	int match;
+	if (!mode || !scan_res || !pri_chan || !sec_chan ||
+	    pri_chan == sec_chan)
+		return 0;
+	pri_freq = hw_get_freq(mode, pri_chan);
+	sec_freq = hw_get_freq(mode, sec_chan);
+	 * Switch PRI/SEC channels if Beacons were detected on selected SEC
+	 * channel, but not on selected PRI channel.
+	pri_bss = sec_bss = 0;
+	for (i = 0; i < scan_res->num; i++) {
+		struct wpa_scan_res *bss = scan_res->res[i];
+		if (bss->freq == pri_freq)
+			pri_bss++;
+		else if (bss->freq == sec_freq)
+			sec_bss++;
+	if (sec_bss && !pri_bss) {
+			   "Switch own primary and secondary channel to get secondary channel with no Beacons from other BSSes");
+		return 2;
+	 * Match PRI/SEC channel with any existing HT40 BSS on the same
+	 * channels that we are about to use (if already mixed order in
+	 * existing BSSes, use own preference).
+	match = 0;
+		get_pri_sec_chan(bss, &bss_pri_chan, &bss_sec_chan);
+		if (pri_chan == bss_pri_chan &&
+		    sec_chan == bss_sec_chan) {
+			match = 1;
+			break;
+	if (!match) {
+			if (pri_chan == bss_sec_chan &&
+			    sec_chan == bss_pri_chan) {
+				wpa_printf(MSG_INFO, "Switch own primary and "
+					   "secondary channel due to BSS "
+					   "overlap with " MACSTR,
+					   MAC2STR(bss->bssid));
+				return 2;
+	return 1;
+static int check_20mhz_bss(struct wpa_scan_res *bss, int pri_freq, int start,
+			   int end)
+	if (bss->freq < start || bss->freq > end || bss->freq == pri_freq)
+		return 0;
+	if (!elems.ht_capabilities) {
+		wpa_printf(MSG_DEBUG, "Found overlapping legacy BSS: "
+			   MACSTR " freq=%d", MAC2STR(bss->bssid), bss->freq);
+		return 1;
+		if (oper->ht_param & HT_INFO_HT_PARAM_SECONDARY_CHNL_OFF_MASK)
+			return 0;
+		wpa_printf(MSG_DEBUG, "Found overlapping 20 MHz HT BSS: "
+		return 1;
+	return 0;
+int check_40mhz_2g4(struct hostapd_hw_modes *mode,
+		    int sec_chan)
+	int pri_freq, sec_freq;
+	int affected_start, affected_end;
+	size_t i;
+		return 0;
+	affected_start = (pri_freq + sec_freq) / 2 - 25;
+	affected_end = (pri_freq + sec_freq) / 2 + 25;
+	wpa_printf(MSG_DEBUG, "40 MHz affected channel range: [%d,%d] MHz",
+		   affected_start, affected_end);
+		int pri = bss->freq;
+		int sec = pri;
+		/* Check for overlapping 20 MHz BSS */
+		if (check_20mhz_bss(bss, pri_freq, affected_start,
+				    affected_end)) {
+				   "Overlapping 20 MHz BSS is found");
+			return 0;
+		get_pri_sec_chan(bss, &pri_chan, &sec_chan);
+		if (sec_chan) {
+			if (sec_chan < pri_chan)
+				sec = pri - 20;
+			else
+				sec = pri + 20;
+		if ((pri < affected_start || pri > affected_end) &&
+		    (sec < affected_start || sec > affected_end))
+			continue; /* not within affected channel range */
+		wpa_printf(MSG_DEBUG, "Neighboring BSS: " MACSTR
+			   " freq=%d pri=%d sec=%d",
+			   MAC2STR(bss->bssid), bss->freq, pri_chan, sec_chan);
+		if (sec_chan) {
+			if (pri_freq != pri || sec_freq != sec) {
+					   "40 MHz pri/sec mismatch with BSS "
+					   MACSTR
+					   " <%d,%d> (chan=%d%c) vs. <%d,%d>",
+					   pri, sec, pri_chan,
+					   sec > pri ? '+' : '-',
+					   pri_freq, sec_freq);
+				return 0;
+				       0);
+		if (elems.ht_capabilities) {
+			struct ieee80211_ht_capabilities *ht_cap =
+				(struct ieee80211_ht_capabilities *)
+				elems.ht_capabilities;
+			if (le_to_host16(ht_cap->ht_capabilities_info) &
+			    HT_CAP_INFO_40MHZ_INTOLERANT) {
+					   "40 MHz Intolerant is set on channel %d in BSS "
+					   MACSTR, pri, MAC2STR(bss->bssid));
+				return 0;
+	return 1;
+int hostapd_set_freq_params(struct hostapd_freq_params *data,
+			    enum hostapd_hw_mode mode,
+			    int freq, int channel, int ht_enabled,
+			    int vht_enabled, int sec_channel_offset,
+			    int vht_oper_chwidth, int center_segment0,
+			    int center_segment1, u32 vht_caps)
+	os_memset(data, 0, sizeof(*data));
+	data->mode = mode;
+	data->freq = freq;
+	data->channel = channel;
+	data->ht_enabled = ht_enabled;
+	data->vht_enabled = vht_enabled;
+	data->sec_channel_offset = sec_channel_offset;
+	data->center_freq1 = freq + sec_channel_offset * 10;
+	data->center_freq2 = 0;
+	data->bandwidth = sec_channel_offset ? 40 : 20;
+	if (data->vht_enabled) switch (vht_oper_chwidth) {
+	case VHT_CHANWIDTH_USE_HT:
+		if (center_segment1 ||
+		    (center_segment0 != 0 &&
+		     5000 + center_segment0 * 5 != data->center_freq1 &&
+		     2407 + center_segment0 * 5 != data->center_freq1))
+			return -1;
+		break;
+	case VHT_CHANWIDTH_80P80MHZ:
+		if (!(vht_caps & VHT_CAP_SUPP_CHAN_WIDTH_160_80PLUS80MHZ)) {
+				   "80+80 channel width is not supported!");
+			return -1;
+		if (center_segment1 == center_segment0 + 4 ||
+		    center_segment1 == center_segment0 - 4)
+			return -1;
+		data->center_freq2 = 5000 + center_segment1 * 5;
+		/* fall through */
+	case VHT_CHANWIDTH_80MHZ:
+		data->bandwidth = 80;
+		if ((vht_oper_chwidth == 1 && center_segment1) ||
+		    (vht_oper_chwidth == 3 && !center_segment1) ||
+		    !sec_channel_offset)
+			return -1;
+		if (!center_segment0) {
+			if (channel <= 48)
+				center_segment0 = 42;
+			else if (channel <= 64)
+				center_segment0 = 58;
+			else if (channel <= 112)
+				center_segment0 = 106;
+			else if (channel <= 128)
+				center_segment0 = 122;
+			else if (channel <= 144)
+				center_segment0 = 138;
+			else if (channel <= 161)
+				center_segment0 = 155;
+			data->center_freq1 = 5000 + center_segment0 * 5;
+		} else {
+			 * Note: HT/VHT config and params are coupled. Check if
+			 * HT40 channel band is in VHT80 Pri channel band
+			 * configuration.
+			if (center_segment0 == channel + 6 ||
+			    center_segment0 == channel + 2 ||
+			    center_segment0 == channel - 2 ||
+			    center_segment0 == channel - 6)
+			else
+				return -1;
+		break;
+	case VHT_CHANWIDTH_160MHZ:
+		data->bandwidth = 160;
+		if (!(vht_caps & (VHT_CAP_SUPP_CHAN_WIDTH_160MHZ |
+				  VHT_CAP_SUPP_CHAN_WIDTH_160_80PLUS80MHZ))) {
+				   "160MHZ channel width is not supported!");
+			return -1;
+		if (center_segment1)
+			return -1;
+		if (!sec_channel_offset)
+			return -1;
+		 * HT40 channel band is in VHT160 channel band configuration.
+		if (center_segment0 == channel + 14 ||
+		    center_segment0 == channel + 10 ||
+		    center_segment0 == channel + 6 ||
+		    center_segment0 == channel - 6 ||
+		    center_segment0 == channel - 10 ||
+		    center_segment0 == channel - 14)
+		else
+			return -1;
+		break;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/common/hw_features_common.h b/freebsd/contrib/wpa/src/common/hw_features_common.h
index 00000000000..7360b4e3efe
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/hw_features_common.h
@@ -0,0 +1,39 @@
+#ifndef HW_FEATURES_COMMON_H
+#define HW_FEATURES_COMMON_H
+#include "drivers/driver.h"
+						  int chan, int *freq);
+						  int freq, int *chan);
+int hw_get_freq(struct hostapd_hw_modes *mode, int chan);
+int hw_get_chan(struct hostapd_hw_modes *mode, int freq);
+			      int sec_chan);
+void get_pri_sec_chan(struct wpa_scan_res *bss, int *pri_chan, int *sec_chan);
+		   int sec_chan);
+		    int sec_chan);
+			    int center_segment1, u32 vht_caps);
+#endif /* HW_FEATURES_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/common/ieee802_11_common.c b/freebsd/contrib/wpa/src/common/ieee802_11_common.c
index 00000000000..ba7ef0a8ec8
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/ieee802_11_common.c
@@ -0,0 +1,1149 @@
+ * IEEE 802.11 Common routines
+ * Copyright (c) 2002-2015, Jouni Malinen <j at w1.fi>
+#include "defs.h"
+#include "wpa_common.h"
+#include "qca-vendor.h"
+static int ieee802_11_parse_vendor_specific(const u8 *pos, size_t elen,
+					    struct ieee802_11_elems *elems,
+					    int show_errors)
+	unsigned int oui;
+	/* first 3 bytes in vendor specific information element are the IEEE
+	 * OUI of the vendor. The following byte is used a vendor specific
+	 * sub-type. */
+	if (elen < 4) {
+		if (show_errors) {
+			wpa_printf(MSG_MSGDUMP, "short vendor specific "
+				   "information element ignored (len=%lu)",
+				   (unsigned long) elen);
+		return -1;
+	oui = WPA_GET_BE24(pos);
+	switch (oui) {
+	case OUI_MICROSOFT:
+		/* Microsoft/Wi-Fi information elements are further typed and
+		 * subtyped */
+		switch (pos[3]) {
+		case 1:
+			/* Microsoft OUI (00:50:F2) with OUI Type 1:
+			 * real WPA information element */
+			elems->wpa_ie = pos;
+			elems->wpa_ie_len = elen;
+			break;
+		case WMM_OUI_TYPE:
+			/* WMM information element */
+			if (elen < 5) {
+				wpa_printf(MSG_MSGDUMP, "short WMM "
+					   "information element ignored "
+					   "(len=%lu)",
+				return -1;
+			switch (pos[4]) {
+			case WMM_OUI_SUBTYPE_INFORMATION_ELEMENT:
+			case WMM_OUI_SUBTYPE_PARAMETER_ELEMENT:
+				 * Share same pointer since only one of these
+				 * is used and they start with same data.
+				 * Length field can be used to distinguish the
+				 * IEs.
+				elems->wmm = pos;
+				elems->wmm_len = elen;
+				break;
+			case WMM_OUI_SUBTYPE_TSPEC_ELEMENT:
+				elems->wmm_tspec = pos;
+				elems->wmm_tspec_len = elen;
+				break;
+			default:
+				wpa_printf(MSG_EXCESSIVE, "unknown WMM "
+					   "(subtype=%d len=%lu)",
+					   pos[4], (unsigned long) elen);
+				return -1;
+			break;
+		case 4:
+			/* Wi-Fi Protected Setup (WPS) IE */
+			elems->wps_ie = pos;
+			elems->wps_ie_len = elen;
+			break;
+		default:
+			wpa_printf(MSG_EXCESSIVE, "Unknown Microsoft "
+				   "(type=%d len=%lu)",
+				   pos[3], (unsigned long) elen);
+			return -1;
+		break;
+	case OUI_WFA:
+		switch (pos[3]) {
+		case P2P_OUI_TYPE:
+			/* Wi-Fi Alliance - P2P IE */
+			elems->p2p = pos;
+			elems->p2p_len = elen;
+			break;
+		case WFD_OUI_TYPE:
+			/* Wi-Fi Alliance - WFD IE */
+			elems->wfd = pos;
+			elems->wfd_len = elen;
+			break;
+		case HS20_INDICATION_OUI_TYPE:
+			/* Hotspot 2.0 */
+			elems->hs20 = pos;
+			elems->hs20_len = elen;
+			break;
+		case HS20_OSEN_OUI_TYPE:
+			/* Hotspot 2.0 OSEN */
+			elems->osen = pos;
+			elems->osen_len = elen;
+			break;
+		default:
+			wpa_printf(MSG_MSGDUMP, "Unknown WFA "
+			return -1;
+		break;
+	case OUI_BROADCOM:
+		switch (pos[3]) {
+		case VENDOR_HT_CAPAB_OUI_TYPE:
+			elems->vendor_ht_cap = pos;
+			elems->vendor_ht_cap_len = elen;
+			break;
+		case VENDOR_VHT_TYPE:
+			if (elen > 4 &&
+			    (pos[4] == VENDOR_VHT_SUBTYPE ||
+			     pos[4] == VENDOR_VHT_SUBTYPE2)) {
+				elems->vendor_vht = pos;
+				elems->vendor_vht_len = elen;
+			} else
+				return -1;
+			break;
+		default:
+			wpa_printf(MSG_EXCESSIVE, "Unknown Broadcom "
+			return -1;
+		break;
+	case OUI_QCA:
+		switch (pos[3]) {
+		case QCA_VENDOR_ELEM_P2P_PREF_CHAN_LIST:
+			elems->pref_freq_list = pos;
+			elems->pref_freq_list_len = elen;
+			break;
+		default:
+				   "Unknown QCA information element ignored (type=%d len=%lu)",
+			return -1;
+		break;
+	default:
+		wpa_printf(MSG_EXCESSIVE, "unknown vendor specific "
+			   "information element ignored (vendor OUI "
+			   "%02x:%02x:%02x len=%lu)",
+			   pos[0], pos[1], pos[2], (unsigned long) elen);
+		return -1;
+	return 0;
+ * ieee802_11_parse_elems - Parse information elements in management frames
+ * @start: Pointer to the start of IEs
+ * @len: Length of IE buffer in octets
+ * @elems: Data structure for parsed elements
+ * @show_errors: Whether to show parsing errors in debug log
+ * Returns: Parsing result
+ParseRes ieee802_11_parse_elems(const u8 *start, size_t len,
+				int show_errors)
+	size_t left = len;
+	const u8 *pos = start;
+	int unknown = 0;
+	os_memset(elems, 0, sizeof(*elems));
+	while (left >= 2) {
+		u8 id, elen;
+		id = *pos++;
+		elen = *pos++;
+		left -= 2;
+		if (elen > left) {
+				wpa_printf(MSG_DEBUG, "IEEE 802.11 element "
+					   "parse failed (id=%d elen=%d "
+					   "left=%lu)",
+					   id, elen, (unsigned long) left);
+				wpa_hexdump(MSG_MSGDUMP, "IEs", start, len);
+			return ParseFailed;
+		switch (id) {
+		case WLAN_EID_SSID:
+			if (elen > SSID_MAX_LEN) {
+					   "Ignored too long SSID element (elen=%u)",
+					   elen);
+				break;
+			elems->ssid = pos;
+			elems->ssid_len = elen;
+			break;
+		case WLAN_EID_SUPP_RATES:
+			elems->supp_rates = pos;
+			elems->supp_rates_len = elen;
+			break;
+		case WLAN_EID_DS_PARAMS:
+			if (elen < 1)
+				break;
+			elems->ds_params = pos;
+			break;
+		case WLAN_EID_CF_PARAMS:
+		case WLAN_EID_TIM:
+			break;
+		case WLAN_EID_CHALLENGE:
+			elems->challenge = pos;
+			elems->challenge_len = elen;
+			break;
+		case WLAN_EID_ERP_INFO:
+			if (elen < 1)
+				break;
+			elems->erp_info = pos;
+			break;
+		case WLAN_EID_EXT_SUPP_RATES:
+			elems->ext_supp_rates = pos;
+			elems->ext_supp_rates_len = elen;
+			break;
+		case WLAN_EID_VENDOR_SPECIFIC:
+			if (ieee802_11_parse_vendor_specific(pos, elen,
+							     elems,
+							     show_errors))
+				unknown++;
+			break;
+		case WLAN_EID_RSN:
+			elems->rsn_ie = pos;
+			elems->rsn_ie_len = elen;
+			break;
+		case WLAN_EID_PWR_CAPABILITY:
+			break;
+		case WLAN_EID_SUPPORTED_CHANNELS:
+			elems->supp_channels = pos;
+			elems->supp_channels_len = elen;
+			break;
+		case WLAN_EID_MOBILITY_DOMAIN:
+			if (elen < sizeof(struct rsn_mdie))
+				break;
+			elems->mdie = pos;
+			elems->mdie_len = elen;
+			break;
+		case WLAN_EID_FAST_BSS_TRANSITION:
+			if (elen < sizeof(struct rsn_ftie))
+				break;
+			elems->ftie = pos;
+			elems->ftie_len = elen;
+			break;
+		case WLAN_EID_TIMEOUT_INTERVAL:
+			if (elen != 5)
+				break;
+			elems->timeout_int = pos;
+			break;
+		case WLAN_EID_HT_CAP:
+			if (elen < sizeof(struct ieee80211_ht_capabilities))
+				break;
+			elems->ht_capabilities = pos;
+			break;
+		case WLAN_EID_HT_OPERATION:
+			if (elen < sizeof(struct ieee80211_ht_operation))
+				break;
+			elems->ht_operation = pos;
+			break;
+		case WLAN_EID_MESH_CONFIG:
+			elems->mesh_config = pos;
+			elems->mesh_config_len = elen;
+			break;
+		case WLAN_EID_MESH_ID:
+			elems->mesh_id = pos;
+			elems->mesh_id_len = elen;
+			break;
+		case WLAN_EID_PEER_MGMT:
+			elems->peer_mgmt = pos;
+			elems->peer_mgmt_len = elen;
+			break;
+		case WLAN_EID_VHT_CAP:
+			if (elen < sizeof(struct ieee80211_vht_capabilities))
+				break;
+			elems->vht_capabilities = pos;
+			break;
+		case WLAN_EID_VHT_OPERATION:
+			if (elen < sizeof(struct ieee80211_vht_operation))
+				break;
+			elems->vht_operation = pos;
+			break;
+		case WLAN_EID_VHT_OPERATING_MODE_NOTIFICATION:
+			if (elen != 1)
+				break;
+			elems->vht_opmode_notif = pos;
+			break;
+		case WLAN_EID_LINK_ID:
+			if (elen < 18)
+				break;
+			elems->link_id = pos;
+			break;
+		case WLAN_EID_INTERWORKING:
+			elems->interworking = pos;
+			elems->interworking_len = elen;
+			break;
+		case WLAN_EID_QOS_MAP_SET:
+			if (elen < 16)
+				break;
+			elems->qos_map_set = pos;
+			elems->qos_map_set_len = elen;
+			break;
+		case WLAN_EID_EXT_CAPAB:
+			elems->ext_capab = pos;
+			elems->ext_capab_len = elen;
+			break;
+		case WLAN_EID_BSS_MAX_IDLE_PERIOD:
+			if (elen < 3)
+				break;
+			elems->bss_max_idle_period = pos;
+			break;
+		case WLAN_EID_SSID_LIST:
+			elems->ssid_list = pos;
+			elems->ssid_list_len = elen;
+			break;
+		case WLAN_EID_AMPE:
+			elems->ampe = pos;
+			elems->ampe_len = elen;
+			break;
+		case WLAN_EID_MIC:
+			elems->mic = pos;
+			elems->mic_len = elen;
+			/* after mic everything is encrypted, so stop. */
+			left = elen;
+			break;
+		case WLAN_EID_MULTI_BAND:
+			if (elems->mb_ies.nof_ies >= MAX_NOF_MB_IES_SUPPORTED) {
+					   "IEEE 802.11 element parse ignored MB IE (id=%d elen=%d)",
+					   id, elen);
+				break;
+			elems->mb_ies.ies[elems->mb_ies.nof_ies].ie = pos;
+			elems->mb_ies.ies[elems->mb_ies.nof_ies].ie_len = elen;
+			elems->mb_ies.nof_ies++;
+			break;
+		default:
+			unknown++;
+			if (!show_errors)
+				break;
+			wpa_printf(MSG_MSGDUMP, "IEEE 802.11 element parse "
+				   "ignored unknown element (id=%d elen=%d)",
+				   id, elen);
+			break;
+		left -= elen;
+		pos += elen;
+	if (left)
+	return unknown ? ParseUnknown : ParseOK;
+int ieee802_11_ie_count(const u8 *ies, size_t ies_len)
+	int count = 0;
+	const u8 *pos, *end;
+	if (ies == NULL)
+		return 0;
+	pos = ies;
+	end = ies + ies_len;
+	while (pos + 2 <= end) {
+		if (pos + 2 + pos[1] > end)
+			break;
+		count++;
+		pos += 2 + pos[1];
+	return count;
+struct wpabuf * ieee802_11_vendor_ie_concat(const u8 *ies, size_t ies_len,
+					    u32 oui_type)
+	struct wpabuf *buf;
+	const u8 *end, *pos, *ie;
+	pos = ies;
+	ie = NULL;
+	while (pos + 1 < end) {
+			return NULL;
+		if (pos[0] == WLAN_EID_VENDOR_SPECIFIC && pos[1] >= 4 &&
+		    WPA_GET_BE32(&pos[2]) == oui_type) {
+			ie = pos;
+			break;
+	if (ie == NULL)
+		return NULL; /* No specified vendor IE found */
+	buf = wpabuf_alloc(ies_len);
+	if (buf == NULL)
+		return NULL;
+	 * There may be multiple vendor IEs in the message, so need to
+	 * concatenate their data fields.
+			break;
+			wpabuf_put_data(buf, pos + 6, pos[1] - 4);
+	return buf;
+const u8 * get_hdr_bssid(const struct ieee80211_hdr *hdr, size_t len)
+	u16 fc, type, stype;
+	 * PS-Poll frames are 16 bytes. All other frames are
+	 * 24 bytes or longer.
+	if (len < 16)
+		return NULL;
+	fc = le_to_host16(hdr->frame_control);
+	type = WLAN_FC_GET_TYPE(fc);
+	stype = WLAN_FC_GET_STYPE(fc);
+	switch (type) {
+	case WLAN_FC_TYPE_DATA:
+		if (len < 24)
+			return NULL;
+		switch (fc & (WLAN_FC_FROMDS | WLAN_FC_TODS)) {
+		case WLAN_FC_FROMDS | WLAN_FC_TODS:
+		case WLAN_FC_TODS:
+			return hdr->addr1;
+		case WLAN_FC_FROMDS:
+			return hdr->addr2;
+		default:
+			return NULL;
+	case WLAN_FC_TYPE_CTRL:
+		if (stype != WLAN_FC_STYPE_PSPOLL)
+			return NULL;
+	case WLAN_FC_TYPE_MGMT:
+		return hdr->addr3;
+	default:
+		return NULL;
+int hostapd_config_wmm_ac(struct hostapd_wmm_ac_params wmm_ac_params[],
+			  const char *name, const char *val)
+	int num, v;
+	const char *pos;
+	struct hostapd_wmm_ac_params *ac;
+	/* skip 'wme_ac_' or 'wmm_ac_' prefix */
+	pos = name + 7;
+	if (os_strncmp(pos, "be_", 3) == 0) {
+		num = 0;
+		pos += 3;
+	} else if (os_strncmp(pos, "bk_", 3) == 0) {
+		num = 1;
+		pos += 3;
+	} else if (os_strncmp(pos, "vi_", 3) == 0) {
+		num = 2;
+		pos += 3;
+	} else if (os_strncmp(pos, "vo_", 3) == 0) {
+		num = 3;
+		pos += 3;
+	} else {
+		wpa_printf(MSG_ERROR, "Unknown WMM name '%s'", pos);
+		return -1;
+	ac = &wmm_ac_params[num];
+	if (os_strcmp(pos, "aifs") == 0) {
+		v = atoi(val);
+		if (v < 1 || v > 255) {
+			wpa_printf(MSG_ERROR, "Invalid AIFS value %d", v);
+			return -1;
+		ac->aifs = v;
+	} else if (os_strcmp(pos, "cwmin") == 0) {
+		v = atoi(val);
+		if (v < 0 || v > 15) {
+			wpa_printf(MSG_ERROR, "Invalid cwMin value %d", v);
+			return -1;
+		ac->cwmin = v;
+	} else if (os_strcmp(pos, "cwmax") == 0) {
+		v = atoi(val);
+			wpa_printf(MSG_ERROR, "Invalid cwMax value %d", v);
+			return -1;
+		ac->cwmax = v;
+	} else if (os_strcmp(pos, "txop_limit") == 0) {
+		v = atoi(val);
+		if (v < 0 || v > 0xffff) {
+			wpa_printf(MSG_ERROR, "Invalid txop value %d", v);
+			return -1;
+		ac->txop_limit = v;
+	} else if (os_strcmp(pos, "acm") == 0) {
+		v = atoi(val);
+		if (v < 0 || v > 1) {
+			wpa_printf(MSG_ERROR, "Invalid acm value %d", v);
+			return -1;
+		ac->admission_control_mandatory = v;
+	} else {
+		wpa_printf(MSG_ERROR, "Unknown wmm_ac_ field '%s'", pos);
+		return -1;
+	return 0;
+enum hostapd_hw_mode ieee80211_freq_to_chan(int freq, u8 *channel)
+	u8 op_class;
+	return ieee80211_freq_to_channel_ext(freq, 0, 0, &op_class, channel);
+ * ieee80211_freq_to_channel_ext - Convert frequency into channel info
+ * for HT40 and VHT. DFS channels are not covered.
+ * @freq: Frequency (MHz) to convert
+ * @sec_channel: 0 = non-HT40, 1 = sec. channel above, -1 = sec. channel below
+ * @vht: 0 - non-VHT, 1 - 80 MHz
+ * @op_class: Buffer for returning operating class
+ * @channel: Buffer for returning channel number
+ * Returns: hw_mode on success, NUM_HOSTAPD_MODES on failure
+enum hostapd_hw_mode ieee80211_freq_to_channel_ext(unsigned int freq,
+						   int sec_channel, int vht,
+						   u8 *op_class, u8 *channel)
+	/* TODO: more operating classes */
+	if (sec_channel > 1 || sec_channel < -1)
+		return NUM_HOSTAPD_MODES;
+	if (freq >= 2412 && freq <= 2472) {
+		if ((freq - 2407) % 5)
+		if (vht)
+		/* 2.407 GHz, channels 1..13 */
+		if (sec_channel == 1)
+			*op_class = 83;
+		else if (sec_channel == -1)
+			*op_class = 84;
+		else
+			*op_class = 81;
+		*channel = (freq - 2407) / 5;
+		return HOSTAPD_MODE_IEEE80211G;
+	if (freq == 2484) {
+		if (sec_channel || vht)
+		*op_class = 82; /* channel 14 */
+		*channel = 14;
+		return HOSTAPD_MODE_IEEE80211B;
+	if (freq >= 4900 && freq < 5000) {
+		if ((freq - 4000) % 5)
+		*channel = (freq - 4000) / 5;
+		*op_class = 0; /* TODO */
+		return HOSTAPD_MODE_IEEE80211A;
+	/* 5 GHz, channels 36..48 */
+	if (freq >= 5180 && freq <= 5240) {
+		if ((freq - 5000) % 5)
+			*op_class = 116;
+			*op_class = 117;
+		else if (vht)
+			*op_class = 128;
+		else
+			*op_class = 115;
+		*channel = (freq - 5000) / 5;
+	/* 5 GHz, channels 149..161 */
+	if (freq >= 5745 && freq <= 5805) {
+			*op_class = 126;
+			*op_class = 127;
+		else if (vht)
+			*op_class = 128;
+		else
+			*op_class = 124;
+	/* 5 GHz, channels 149..169 */
+	if (freq >= 5745 && freq <= 5845) {
+		*op_class = 125;
+	if (freq >= 5000 && freq < 5900) {
+	/* 56.16 GHz, channel 1..4 */
+	if (freq >= 56160 + 2160 * 1 && freq <= 56160 + 2160 * 4) {
+		*channel = (freq - 56160) / 2160;
+		*op_class = 180;
+		return HOSTAPD_MODE_IEEE80211AD;
+static const char *const us_op_class_cc[] = {
+	"US", "CA", NULL
+static const char *const eu_op_class_cc[] = {
+	"AL", "AM", "AT", "AZ", "BA", "BE", "BG", "BY", "CH", "CY", "CZ", "DE",
+	"DK", "EE", "EL", "ES", "FI", "FR", "GE", "HR", "HU", "IE", "IS", "IT",
+	"LI", "LT", "LU", "LV", "MD", "ME", "MK", "MT", "NL", "NO", "PL", "PT",
+	"RO", "RS", "RU", "SE", "SI", "SK", "TR", "UA", "UK", NULL
+static const char *const jp_op_class_cc[] = {
+	"JP", NULL
+static const char *const cn_op_class_cc[] = {
+	"CN", NULL
+static int country_match(const char *const cc[], const char *const country)
+	int i;
+	if (country == NULL)
+		return 0;
+	for (i = 0; cc[i]; i++) {
+		if (cc[i][0] == country[0] && cc[i][1] == country[1])
+			return 1;
+	return 0;
+static int ieee80211_chan_to_freq_us(u8 op_class, u8 chan)
+	switch (op_class) {
+	case 12: /* channels 1..11 */
+	case 32: /* channels 1..7; 40 MHz */
+	case 33: /* channels 5..11; 40 MHz */
+		if (chan < 1 || chan > 11)
+			return -1;
+		return 2407 + 5 * chan;
+	case 1: /* channels 36,40,44,48 */
+	case 2: /* channels 52,56,60,64; dfs */
+	case 22: /* channels 36,44; 40 MHz */
+	case 23: /* channels 52,60; 40 MHz */
+	case 27: /* channels 40,48; 40 MHz */
+	case 28: /* channels 56,64; 40 MHz */
+		if (chan < 36 || chan > 64)
+			return -1;
+		return 5000 + 5 * chan;
+	case 4: /* channels 100-144 */
+	case 24: /* channels 100-140; 40 MHz */
+		if (chan < 100 || chan > 144)
+			return -1;
+	case 3: /* channels 149,153,157,161 */
+	case 25: /* channels 149,157; 40 MHz */
+	case 26: /* channels 149,157; 40 MHz */
+	case 30: /* channels 153,161; 40 MHz */
+	case 31: /* channels 153,161; 40 MHz */
+		if (chan < 149 || chan > 161)
+			return -1;
+	case 5: /* channels 149,153,157,161,165 */
+		if (chan < 149 || chan > 165)
+			return -1;
+	case 34: /* 60 GHz band, channels 1..3 */
+		if (chan < 1 || chan > 3)
+			return -1;
+		return 56160 + 2160 * chan;
+	return -1;
+static int ieee80211_chan_to_freq_eu(u8 op_class, u8 chan)
+	case 4: /* channels 1..13 */
+	case 11: /* channels 1..9; 40 MHz */
+	case 12: /* channels 5..13; 40 MHz */
+		if (chan < 1 || chan > 13)
+			return -1;
+	case 5: /* channels 36,44; 40 MHz */
+	case 6: /* channels 52,60; 40 MHz */
+	case 8: /* channels 40,48; 40 MHz */
+	case 9: /* channels 56,64; 40 MHz */
+			return -1;
+	case 3: /* channels 100-140 */
+	case 7: /* channels 100-132; 40 MHz */
+	case 10: /* channels 104-136; 40 MHz */
+	case 16: /* channels 100-140 */
+		if (chan < 100 || chan > 140)
+			return -1;
+	case 17: /* channels 149,153,157,161,165,169 */
+		if (chan < 149 || chan > 169)
+			return -1;
+	case 18: /* 60 GHz band, channels 1..4 */
+		if (chan < 1 || chan > 4)
+			return -1;
+	return -1;
+static int ieee80211_chan_to_freq_jp(u8 op_class, u8 chan)
+	case 30: /* channels 1..13 */
+	case 56: /* channels 1..9; 40 MHz */
+	case 57: /* channels 5..13; 40 MHz */
+			return -1;
+	case 31: /* channel 14 */
+		if (chan != 14)
+			return -1;
+		return 2414 + 5 * chan;
+	case 1: /* channels 34,38,42,46(old) or 36,40,44,48 */
+	case 32: /* channels 52,56,60,64 */
+	case 33: /* channels 52,56,60,64 */
+	case 36: /* channels 36,44; 40 MHz */
+	case 37: /* channels 52,60; 40 MHz */
+	case 38: /* channels 52,60; 40 MHz */
+	case 41: /* channels 40,48; 40 MHz */
+	case 42: /* channels 56,64; 40 MHz */
+	case 43: /* channels 56,64; 40 MHz */
+		if (chan < 34 || chan > 64)
+			return -1;
+	case 34: /* channels 100-140 */
+	case 35: /* channels 100-140 */
+	case 39: /* channels 100-132; 40 MHz */
+	case 40: /* channels 100-132; 40 MHz */
+	case 44: /* channels 104-136; 40 MHz */
+	case 45: /* channels 104-136; 40 MHz */
+	case 58: /* channels 100-140 */
+			return -1;
+	case 59: /* 60 GHz band, channels 1..4 */
+			return -1;
+	return -1;
+static int ieee80211_chan_to_freq_cn(u8 op_class, u8 chan)
+	case 7: /* channels 1..13 */
+	case 8: /* channels 1..9; 40 MHz */
+	case 9: /* channels 5..13; 40 MHz */
+			return -1;
+	case 4: /* channels 36,44; 40 MHz */
+	case 5: /* channels 52,60; 40 MHz */
+			return -1;
+	case 3: /* channels 149,153,157,161,165 */
+	case 6: /* channels 149,157; 40 MHz */
+			return -1;
+	return -1;
+static int ieee80211_chan_to_freq_global(u8 op_class, u8 chan)
+	/* Table E-4 in IEEE Std 802.11-2012 - Global operating classes */
+	case 81:
+		/* channels 1..13 */
+			return -1;
+	case 82:
+		/* channel 14 */
+		if (chan != 14)
+			return -1;
+	case 83: /* channels 1..9; 40 MHz */
+	case 84: /* channels 5..13; 40 MHz */
+			return -1;
+	case 115: /* channels 36,40,44,48; indoor only */
+	case 116: /* channels 36,44; 40 MHz; indoor only */
+	case 117: /* channels 40,48; 40 MHz; indoor only */
+	case 118: /* channels 52,56,60,64; dfs */
+	case 119: /* channels 52,60; 40 MHz; dfs */
+	case 120: /* channels 56,64; 40 MHz; dfs */
+			return -1;
+	case 121: /* channels 100-140 */
+	case 122: /* channels 100-142; 40 MHz */
+	case 123: /* channels 104-136; 40 MHz */
+			return -1;
+	case 124: /* channels 149,153,157,161 */
+	case 126: /* channels 149,157; 40 MHz */
+	case 127: /* channels 153,161; 40 MHz */
+			return -1;
+	case 125: /* channels 149,153,157,161,165,169 */
+			return -1;
+	case 128: /* center freqs 42, 58, 106, 122, 138, 155; 80 MHz */
+	case 130: /* center freqs 42, 58, 106, 122, 138, 155; 80 MHz */
+		if (chan < 36 || chan > 161)
+			return -1;
+	case 129: /* center freqs 50, 114; 160 MHz */
+		if (chan < 50 || chan > 114)
+			return -1;
+	case 180: /* 60 GHz band, channels 1..4 */
+			return -1;
+	return -1;
+ * ieee80211_chan_to_freq - Convert channel info to frequency
+ * @country: Country code, if known; otherwise, global operating class is used
+ * @op_class: Operating class
+ * @chan: Channel number
+ * Returns: Frequency in MHz or -1 if the specified channel is unknown
+int ieee80211_chan_to_freq(const char *country, u8 op_class, u8 chan)
+	int freq;
+	if (country_match(us_op_class_cc, country)) {
+		freq = ieee80211_chan_to_freq_us(op_class, chan);
+		if (freq > 0)
+			return freq;
+	if (country_match(eu_op_class_cc, country)) {
+		freq = ieee80211_chan_to_freq_eu(op_class, chan);
+		if (freq > 0)
+			return freq;
+	if (country_match(jp_op_class_cc, country)) {
+		freq = ieee80211_chan_to_freq_jp(op_class, chan);
+		if (freq > 0)
+			return freq;
+	if (country_match(cn_op_class_cc, country)) {
+		freq = ieee80211_chan_to_freq_cn(op_class, chan);
+		if (freq > 0)
+			return freq;
+	return ieee80211_chan_to_freq_global(op_class, chan);
+int ieee80211_is_dfs(int freq)
+	/* TODO: this could be more accurate to better cover all domains */
+	return (freq >= 5260 && freq <= 5320) || (freq >= 5500 && freq <= 5700);
+static int is_11b(u8 rate)
+	return rate == 0x02 || rate == 0x04 || rate == 0x0b || rate == 0x16;
+int supp_rates_11b_only(struct ieee802_11_elems *elems)
+	int num_11b = 0, num_others = 0;
+	int i;
+	if (elems->supp_rates == NULL && elems->ext_supp_rates == NULL)
+		return 0;
+	for (i = 0; elems->supp_rates && i < elems->supp_rates_len; i++) {
+		if (is_11b(elems->supp_rates[i]))
+			num_11b++;
+		else
+			num_others++;
+	for (i = 0; elems->ext_supp_rates && i < elems->ext_supp_rates_len;
+	     i++) {
+		if (is_11b(elems->ext_supp_rates[i]))
+			num_11b++;
+		else
+			num_others++;
+	return num_11b > 0 && num_others == 0;
+const char * fc2str(u16 fc)
+	u16 stype = WLAN_FC_GET_STYPE(fc);
+#define C2S(x) case x: return #x;
+	switch (WLAN_FC_GET_TYPE(fc)) {
+		switch (stype) {
+		C2S(WLAN_FC_STYPE_ASSOC_REQ)
+		C2S(WLAN_FC_STYPE_ASSOC_RESP)
+		C2S(WLAN_FC_STYPE_REASSOC_REQ)
+		C2S(WLAN_FC_STYPE_REASSOC_RESP)
+		C2S(WLAN_FC_STYPE_PROBE_REQ)
+		C2S(WLAN_FC_STYPE_PROBE_RESP)
+		C2S(WLAN_FC_STYPE_BEACON)
+		C2S(WLAN_FC_STYPE_ATIM)
+		C2S(WLAN_FC_STYPE_DISASSOC)
+		C2S(WLAN_FC_STYPE_AUTH)
+		C2S(WLAN_FC_STYPE_DEAUTH)
+		C2S(WLAN_FC_STYPE_ACTION)
+		break;
+		switch (stype) {
+		C2S(WLAN_FC_STYPE_PSPOLL)
+		C2S(WLAN_FC_STYPE_RTS)
+		C2S(WLAN_FC_STYPE_CTS)
+		C2S(WLAN_FC_STYPE_ACK)
+		C2S(WLAN_FC_STYPE_CFEND)
+		C2S(WLAN_FC_STYPE_CFENDACK)
+		break;
+		switch (stype) {
+		C2S(WLAN_FC_STYPE_DATA)
+		C2S(WLAN_FC_STYPE_DATA_CFACK)
+		C2S(WLAN_FC_STYPE_DATA_CFPOLL)
+		C2S(WLAN_FC_STYPE_DATA_CFACKPOLL)
+		C2S(WLAN_FC_STYPE_NULLFUNC)
+		C2S(WLAN_FC_STYPE_CFACK)
+		C2S(WLAN_FC_STYPE_CFPOLL)
+		C2S(WLAN_FC_STYPE_CFACKPOLL)
+		C2S(WLAN_FC_STYPE_QOS_DATA)
+		C2S(WLAN_FC_STYPE_QOS_DATA_CFACK)
+		C2S(WLAN_FC_STYPE_QOS_DATA_CFPOLL)
+		C2S(WLAN_FC_STYPE_QOS_DATA_CFACKPOLL)
+		C2S(WLAN_FC_STYPE_QOS_NULL)
+		C2S(WLAN_FC_STYPE_QOS_CFPOLL)
+		C2S(WLAN_FC_STYPE_QOS_CFACKPOLL)
+		break;
+	return "WLAN_FC_TYPE_UNKNOWN";
+#undef C2S
+int mb_ies_info_by_ies(struct mb_ies_info *info, const u8 *ies_buf,
+		       size_t ies_len)
+	os_memset(info, 0, sizeof(*info));
+	while (ies_buf && ies_len >= 2 &&
+	       info->nof_ies < MAX_NOF_MB_IES_SUPPORTED) {
+		size_t len = 2 + ies_buf[1];
+		if (len > ies_len) {
+			wpa_hexdump(MSG_DEBUG, "Truncated IEs",
+				    ies_buf, ies_len);
+			return -1;
+		if (ies_buf[0] == WLAN_EID_MULTI_BAND) {
+			wpa_printf(MSG_DEBUG, "MB IE of %zu bytes found", len);
+			info->ies[info->nof_ies].ie = ies_buf + 2;
+			info->ies[info->nof_ies].ie_len = ies_buf[1];
+			info->nof_ies++;
+		ies_len -= len;
+		ies_buf += len;
+	return 0;
+struct wpabuf * mb_ies_by_info(struct mb_ies_info *info)
+	struct wpabuf *mb_ies = NULL;
+	WPA_ASSERT(info != NULL);
+	if (info->nof_ies) {
+		u8 i;
+		size_t mb_ies_size = 0;
+		for (i = 0; i < info->nof_ies; i++)
+			mb_ies_size += 2 + info->ies[i].ie_len;
+		mb_ies = wpabuf_alloc(mb_ies_size);
+		if (mb_ies) {
+			for (i = 0; i < info->nof_ies; i++) {
+				wpabuf_put_u8(mb_ies, WLAN_EID_MULTI_BAND);
+				wpabuf_put_u8(mb_ies, info->ies[i].ie_len);
+				wpabuf_put_data(mb_ies,
+						info->ies[i].ie,
+						info->ies[i].ie_len);
+	return mb_ies;
diff --git a/freebsd/contrib/wpa/src/common/ieee802_11_common.h b/freebsd/contrib/wpa/src/common/ieee802_11_common.h
new file mode 100644
index 00000000000..55ce0223d92
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/ieee802_11_common.h
@@ -0,0 +1,128 @@
+ * Copyright (c) 2002-2012, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef IEEE802_11_COMMON_H
+#define IEEE802_11_COMMON_H
+#define MAX_NOF_MB_IES_SUPPORTED 5
+struct mb_ies_info {
+	struct {
+		const u8 *ie;
+		u8 ie_len;
+	} ies[MAX_NOF_MB_IES_SUPPORTED];
+	u8 nof_ies;
+/* Parsed Information Elements */
+struct ieee802_11_elems {
+	const u8 *ssid;
+	const u8 *supp_rates;
+	const u8 *ds_params;
+	const u8 *challenge;
+	const u8 *erp_info;
+	const u8 *ext_supp_rates;
+	const u8 *wpa_ie;
+	const u8 *rsn_ie;
+	const u8 *wmm; /* WMM Information or Parameter Element */
+	const u8 *wmm_tspec;
+	const u8 *wps_ie;
+	const u8 *supp_channels;
+	const u8 *mdie;
+	const u8 *ftie;
+	const u8 *timeout_int;
+	const u8 *ht_capabilities;
+	const u8 *ht_operation;
+	const u8 *mesh_config;
+	const u8 *mesh_id;
+	const u8 *peer_mgmt;
+	const u8 *vht_capabilities;
+	const u8 *vht_operation;
+	const u8 *vht_opmode_notif;
+	const u8 *vendor_ht_cap;
+	const u8 *vendor_vht;
+	const u8 *p2p;
+	const u8 *wfd;
+	const u8 *link_id;
+	const u8 *interworking;
+	const u8 *qos_map_set;
+	const u8 *hs20;
+	const u8 *ext_capab;
+	const u8 *bss_max_idle_period;
+	const u8 *ssid_list;
+	const u8 *osen;
+	const u8 *ampe;
+	const u8 *mic;
+	const u8 *pref_freq_list;
+	u8 ssid_len;
+	u8 supp_rates_len;
+	u8 challenge_len;
+	u8 ext_supp_rates_len;
+	u8 wpa_ie_len;
+	u8 rsn_ie_len;
+	u8 wmm_len; /* 7 = WMM Information; 24 = WMM Parameter */
+	u8 wmm_tspec_len;
+	u8 wps_ie_len;
+	u8 supp_channels_len;
+	u8 mdie_len;
+	u8 ftie_len;
+	u8 mesh_config_len;
+	u8 mesh_id_len;
+	u8 peer_mgmt_len;
+	u8 vendor_ht_cap_len;
+	u8 vendor_vht_len;
+	u8 p2p_len;
+	u8 wfd_len;
+	u8 interworking_len;
+	u8 qos_map_set_len;
+	u8 hs20_len;
+	u8 ext_capab_len;
+	u8 ssid_list_len;
+	u8 osen_len;
+	u8 ampe_len;
+	u8 mic_len;
+	u8 pref_freq_list_len;
+	struct mb_ies_info mb_ies;
+typedef enum { ParseOK = 0, ParseUnknown = 1, ParseFailed = -1 } ParseRes;
+				int show_errors);
+int ieee802_11_ie_count(const u8 *ies, size_t ies_len);
+					    u32 oui_type);
+struct ieee80211_hdr;
+const u8 * get_hdr_bssid(const struct ieee80211_hdr *hdr, size_t len);
+struct hostapd_wmm_ac_params {
+	int cwmin;
+	int cwmax;
+	int aifs;
+	int txop_limit; /* in units of 32us */
+	int admission_control_mandatory;
+			  const char *name, const char *val);
+enum hostapd_hw_mode ieee80211_freq_to_chan(int freq, u8 *channel);
+int ieee80211_chan_to_freq(const char *country, u8 op_class, u8 chan);
+						   u8 *op_class, u8 *channel);
+int ieee80211_is_dfs(int freq);
+int supp_rates_11b_only(struct ieee802_11_elems *elems);
+		       size_t ies_len);
+struct wpabuf * mb_ies_by_info(struct mb_ies_info *info);
+const char * fc2str(u16 fc);
+#endif /* IEEE802_11_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/common/ieee802_11_defs.h b/freebsd/contrib/wpa/src/common/ieee802_11_defs.h
index 00000000000..44530ce3cee
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/ieee802_11_defs.h
@@ -0,0 +1,1436 @@
+ * IEEE 802.11 Frame type definitions
+ * Copyright (c) 2007-2008 Intel Corporation
+#ifndef IEEE802_11_DEFS_H
+#define IEEE802_11_DEFS_H
+#include <utils/common.h>
+/* IEEE 802.11 defines */
+#define WLAN_FC_PVER		0x0003
+#define WLAN_FC_TODS		0x0100
+#define WLAN_FC_FROMDS		0x0200
+#define WLAN_FC_MOREFRAG	0x0400
+#define WLAN_FC_RETRY		0x0800
+#define WLAN_FC_PWRMGT		0x1000
+#define WLAN_FC_MOREDATA	0x2000
+#define WLAN_FC_ISWEP		0x4000
+#define WLAN_FC_ORDER		0x8000
+#define WLAN_FC_GET_TYPE(fc)	(((fc) & 0x000c) >> 2)
+#define WLAN_FC_GET_STYPE(fc)	(((fc) & 0x00f0) >> 4)
+#define WLAN_INVALID_MGMT_SEQ   0xFFFF
+#define WLAN_GET_SEQ_FRAG(seq) ((seq) & (BIT(3) | BIT(2) | BIT(1) | BIT(0)))
+#define WLAN_GET_SEQ_SEQ(seq) \
+	(((seq) & (~(BIT(3) | BIT(2) | BIT(1) | BIT(0)))) >> 4)
+#define WLAN_FC_TYPE_MGMT		0
+#define WLAN_FC_TYPE_CTRL		1
+#define WLAN_FC_TYPE_DATA		2
+/* management */
+#define WLAN_FC_STYPE_ASSOC_REQ		0
+#define WLAN_FC_STYPE_ASSOC_RESP	1
+#define WLAN_FC_STYPE_REASSOC_REQ	2
+#define WLAN_FC_STYPE_REASSOC_RESP	3
+#define WLAN_FC_STYPE_PROBE_REQ		4
+#define WLAN_FC_STYPE_PROBE_RESP	5
+#define WLAN_FC_STYPE_BEACON		8
+#define WLAN_FC_STYPE_ATIM		9
+#define WLAN_FC_STYPE_DISASSOC		10
+#define WLAN_FC_STYPE_AUTH		11
+#define WLAN_FC_STYPE_DEAUTH		12
+#define WLAN_FC_STYPE_ACTION		13
+/* control */
+#define WLAN_FC_STYPE_PSPOLL		10
+#define WLAN_FC_STYPE_RTS		11
+#define WLAN_FC_STYPE_CTS		12
+#define WLAN_FC_STYPE_ACK		13
+#define WLAN_FC_STYPE_CFEND		14
+#define WLAN_FC_STYPE_CFENDACK		15
+/* data */
+#define WLAN_FC_STYPE_DATA		0
+#define WLAN_FC_STYPE_DATA_CFACK	1
+#define WLAN_FC_STYPE_DATA_CFPOLL	2
+#define WLAN_FC_STYPE_DATA_CFACKPOLL	3
+#define WLAN_FC_STYPE_NULLFUNC		4
+#define WLAN_FC_STYPE_CFACK		5
+#define WLAN_FC_STYPE_CFPOLL		6
+#define WLAN_FC_STYPE_CFACKPOLL		7
+#define WLAN_FC_STYPE_QOS_DATA		8
+#define WLAN_FC_STYPE_QOS_DATA_CFACK	9
+#define WLAN_FC_STYPE_QOS_DATA_CFPOLL	10
+#define WLAN_FC_STYPE_QOS_DATA_CFACKPOLL	11
+#define WLAN_FC_STYPE_QOS_NULL		12
+#define WLAN_FC_STYPE_QOS_CFPOLL	14
+#define WLAN_FC_STYPE_QOS_CFACKPOLL	15
+/* Authentication algorithms */
+#define WLAN_AUTH_OPEN			0
+#define WLAN_AUTH_SHARED_KEY		1
+#define WLAN_AUTH_FT			2
+#define WLAN_AUTH_SAE			3
+#define WLAN_AUTH_LEAP			128
+#define WLAN_AUTH_CHALLENGE_LEN 128
+#define WLAN_CAPABILITY_ESS BIT(0)
+#define WLAN_CAPABILITY_IBSS BIT(1)
+#define WLAN_CAPABILITY_CF_POLLABLE BIT(2)
+#define WLAN_CAPABILITY_CF_POLL_REQUEST BIT(3)
+#define WLAN_CAPABILITY_PRIVACY BIT(4)
+#define WLAN_CAPABILITY_SHORT_PREAMBLE BIT(5)
+#define WLAN_CAPABILITY_PBCC BIT(6)
+#define WLAN_CAPABILITY_CHANNEL_AGILITY BIT(7)
+#define WLAN_CAPABILITY_SPECTRUM_MGMT BIT(8)
+#define WLAN_CAPABILITY_SHORT_SLOT_TIME BIT(10)
+#define WLAN_CAPABILITY_DSSS_OFDM BIT(13)
+/* Status codes (IEEE 802.11-2007, 7.3.1.9, Table 7-23) */
+#define WLAN_STATUS_SUCCESS 0
+#define WLAN_STATUS_UNSPECIFIED_FAILURE 1
+#define WLAN_STATUS_TDLS_WAKEUP_ALTERNATE 2
+#define WLAN_STATUS_TDLS_WAKEUP_REJECT 3
+#define WLAN_STATUS_SECURITY_DISABLED 5
+#define WLAN_STATUS_UNACCEPTABLE_LIFETIME 6
+#define WLAN_STATUS_NOT_IN_SAME_BSS 7
+#define WLAN_STATUS_CAPS_UNSUPPORTED 10
+#define WLAN_STATUS_REASSOC_NO_ASSOC 11
+#define WLAN_STATUS_ASSOC_DENIED_UNSPEC 12
+#define WLAN_STATUS_NOT_SUPPORTED_AUTH_ALG 13
+#define WLAN_STATUS_UNKNOWN_AUTH_TRANSACTION 14
+#define WLAN_STATUS_CHALLENGE_FAIL 15
+#define WLAN_STATUS_AUTH_TIMEOUT 16
+#define WLAN_STATUS_AP_UNABLE_TO_HANDLE_NEW_STA 17
+#define WLAN_STATUS_ASSOC_DENIED_RATES 18
+/* IEEE 802.11b */
+#define WLAN_STATUS_ASSOC_DENIED_NOSHORT 19
+#define WLAN_STATUS_ASSOC_DENIED_NOPBCC 20
+#define WLAN_STATUS_ASSOC_DENIED_NOAGILITY 21
+/* IEEE 802.11h */
+#define WLAN_STATUS_SPEC_MGMT_REQUIRED 22
+#define WLAN_STATUS_PWR_CAPABILITY_NOT_VALID 23
+#define WLAN_STATUS_SUPPORTED_CHANNEL_NOT_VALID 24
+/* IEEE 802.11g */
+#define WLAN_STATUS_ASSOC_DENIED_NO_SHORT_SLOT_TIME 25
+#define WLAN_STATUS_ASSOC_DENIED_NO_DSSS_OFDM 26
+#define WLAN_STATUS_ASSOC_DENIED_NO_HT 27
+#define WLAN_STATUS_R0KH_UNREACHABLE 28
+#define WLAN_STATUS_ASSOC_DENIED_NO_PCO 29
+/* IEEE 802.11w */
+#define WLAN_STATUS_ASSOC_REJECTED_TEMPORARILY 30
+#define WLAN_STATUS_ROBUST_MGMT_FRAME_POLICY_VIOLATION 31
+#define WLAN_STATUS_UNSPECIFIED_QOS_FAILURE 32
+#define WLAN_STATUS_REQUEST_DECLINED 37
+#define WLAN_STATUS_INVALID_PARAMETERS 38
+/* IEEE 802.11i */
+#define WLAN_STATUS_INVALID_IE 40
+#define WLAN_STATUS_GROUP_CIPHER_NOT_VALID 41
+#define WLAN_STATUS_PAIRWISE_CIPHER_NOT_VALID 42
+#define WLAN_STATUS_AKMP_NOT_VALID 43
+#define WLAN_STATUS_UNSUPPORTED_RSN_IE_VERSION 44
+#define WLAN_STATUS_INVALID_RSN_IE_CAPAB 45
+#define WLAN_STATUS_CIPHER_REJECTED_PER_POLICY 46
+#define WLAN_STATUS_TS_NOT_CREATED 47
+#define WLAN_STATUS_DIRECT_LINK_NOT_ALLOWED 48
+#define WLAN_STATUS_DEST_STA_NOT_PRESENT 49
+#define WLAN_STATUS_DEST_STA_NOT_QOS_STA 50
+#define WLAN_STATUS_ASSOC_DENIED_LISTEN_INT_TOO_LARGE 51
+/* IEEE 802.11r */
+#define WLAN_STATUS_INVALID_FT_ACTION_FRAME_COUNT 52
+#define WLAN_STATUS_INVALID_PMKID 53
+#define WLAN_STATUS_INVALID_MDIE 54
+#define WLAN_STATUS_INVALID_FTIE 55
+#define WLAN_STATUS_GAS_ADV_PROTO_NOT_SUPPORTED 59
+#define WLAN_STATUS_NO_OUTSTANDING_GAS_REQ 60
+#define WLAN_STATUS_GAS_RESP_NOT_RECEIVED 61
+#define WLAN_STATUS_STA_TIMED_OUT_WAITING_FOR_GAS_RESP 62
+#define WLAN_STATUS_GAS_RESP_LARGER_THAN_LIMIT 63
+#define WLAN_STATUS_REQ_REFUSED_HOME 64
+#define WLAN_STATUS_ADV_SRV_UNREACHABLE 65
+#define WLAN_STATUS_REQ_REFUSED_SSPN 67
+#define WLAN_STATUS_REQ_REFUSED_UNAUTH_ACCESS 68
+#define WLAN_STATUS_INVALID_RSNIE 72
+#define WLAN_STATUS_ANTI_CLOGGING_TOKEN_REQ 76
+#define WLAN_STATUS_FINITE_CYCLIC_GROUP_NOT_SUPPORTED 77
+#define WLAN_STATUS_TRANSMISSION_FAILURE 79
+#define WLAN_STATUS_REJECTED_WITH_SUGGESTED_BSS_TRANSITION 82
+#define WLAN_STATUS_PENDING_ADMITTING_FST_SESSION 86
+#define WLAN_STATUS_QUERY_RESP_OUTSTANDING 95
+#define WLAN_STATUS_DENIED_WITH_SUGGESTED_BAND_AND_CHANNEL 99
+#define WLAN_STATUS_ASSOC_DENIED_NO_VHT 104
+/* Reason codes (IEEE 802.11-2007, 7.3.1.7, Table 7-22) */
+#define WLAN_REASON_UNSPECIFIED 1
+#define WLAN_REASON_PREV_AUTH_NOT_VALID 2
+#define WLAN_REASON_DEAUTH_LEAVING 3
+#define WLAN_REASON_DISASSOC_DUE_TO_INACTIVITY 4
+#define WLAN_REASON_DISASSOC_AP_BUSY 5
+#define WLAN_REASON_CLASS2_FRAME_FROM_NONAUTH_STA 6
+#define WLAN_REASON_CLASS3_FRAME_FROM_NONASSOC_STA 7
+#define WLAN_REASON_DISASSOC_STA_HAS_LEFT 8
+#define WLAN_REASON_STA_REQ_ASSOC_WITHOUT_AUTH 9
+/* IEEE 802.11h */
+#define WLAN_REASON_PWR_CAPABILITY_NOT_VALID 10
+#define WLAN_REASON_SUPPORTED_CHANNEL_NOT_VALID 11
+/* IEEE 802.11i */
+#define WLAN_REASON_INVALID_IE 13
+#define WLAN_REASON_MICHAEL_MIC_FAILURE 14
+#define WLAN_REASON_4WAY_HANDSHAKE_TIMEOUT 15
+#define WLAN_REASON_GROUP_KEY_UPDATE_TIMEOUT 16
+#define WLAN_REASON_IE_IN_4WAY_DIFFERS 17
+#define WLAN_REASON_GROUP_CIPHER_NOT_VALID 18
+#define WLAN_REASON_PAIRWISE_CIPHER_NOT_VALID 19
+#define WLAN_REASON_AKMP_NOT_VALID 20
+#define WLAN_REASON_UNSUPPORTED_RSN_IE_VERSION 21
+#define WLAN_REASON_INVALID_RSN_IE_CAPAB 22
+#define WLAN_REASON_IEEE_802_1X_AUTH_FAILED 23
+#define WLAN_REASON_CIPHER_SUITE_REJECTED 24
+#define WLAN_REASON_TDLS_TEARDOWN_UNREACHABLE 25
+#define WLAN_REASON_TDLS_TEARDOWN_UNSPECIFIED 26
+/* IEEE 802.11e */
+#define WLAN_REASON_DISASSOC_LOW_ACK 34
+/* IEEE 802.11s */
+#define WLAN_REASON_MESH_PEERING_CANCELLED 52
+#define WLAN_REASON_MESH_MAX_PEERS 53
+#define WLAN_REASON_MESH_CONFIG_POLICY_VIOLATION 54
+#define WLAN_REASON_MESH_CLOSE_RCVD 55
+#define WLAN_REASON_MESH_MAX_RETRIES 56
+#define WLAN_REASON_MESH_CONFIRM_TIMEOUT 57
+#define WLAN_REASON_MESH_INVALID_GTK 58
+#define WLAN_REASON_MESH_INCONSISTENT_PARAMS 59
+#define WLAN_REASON_MESH_INVALID_SECURITY_CAP 60
+/* Information Element IDs */
+#define WLAN_EID_SSID 0
+#define WLAN_EID_SUPP_RATES 1
+#define WLAN_EID_FH_PARAMS 2
+#define WLAN_EID_DS_PARAMS 3
+#define WLAN_EID_CF_PARAMS 4
+#define WLAN_EID_TIM 5
+#define WLAN_EID_IBSS_PARAMS 6
+#define WLAN_EID_COUNTRY 7
+#define WLAN_EID_BSS_LOAD 11
+#define WLAN_EID_CHALLENGE 16
+/* EIDs defined by IEEE 802.11h - START */
+#define WLAN_EID_PWR_CONSTRAINT 32
+#define WLAN_EID_PWR_CAPABILITY 33
+#define WLAN_EID_TPC_REQUEST 34
+#define WLAN_EID_TPC_REPORT 35
+#define WLAN_EID_SUPPORTED_CHANNELS 36
+#define WLAN_EID_CHANNEL_SWITCH 37
+#define WLAN_EID_MEASURE_REQUEST 38
+#define WLAN_EID_MEASURE_REPORT 39
+#define WLAN_EID_QUITE 40
+#define WLAN_EID_IBSS_DFS 41
+/* EIDs defined by IEEE 802.11h - END */
+#define WLAN_EID_ERP_INFO 42
+#define WLAN_EID_HT_CAP 45
+#define WLAN_EID_QOS 46
+#define WLAN_EID_RSN 48
+#define WLAN_EID_EXT_SUPP_RATES 50
+#define WLAN_EID_NEIGHBOR_REPORT 52
+#define WLAN_EID_MOBILITY_DOMAIN 54
+#define WLAN_EID_FAST_BSS_TRANSITION 55
+#define WLAN_EID_TIMEOUT_INTERVAL 56
+#define WLAN_EID_RIC_DATA 57
+#define WLAN_EID_SUPPORTED_OPERATING_CLASSES 59
+#define WLAN_EID_HT_OPERATION 61
+#define WLAN_EID_SECONDARY_CHANNEL_OFFSET 62
+#define WLAN_EID_WAPI 68
+#define WLAN_EID_TIME_ADVERTISEMENT 69
+#define WLAN_EID_RRM_ENABLED_CAPABILITIES 70
+#define WLAN_EID_20_40_BSS_COEXISTENCE 72
+#define WLAN_EID_20_40_BSS_INTOLERANT 73
+#define WLAN_EID_OVERLAPPING_BSS_SCAN_PARAMS 74
+#define WLAN_EID_MMIE 76
+#define WLAN_EID_SSID_LIST 84
+#define WLAN_EID_BSS_MAX_IDLE_PERIOD 90
+#define WLAN_EID_TFS_REQ 91
+#define WLAN_EID_TFS_RESP 92
+#define WLAN_EID_WNMSLEEP 93
+#define WLAN_EID_TIME_ZONE 98
+#define WLAN_EID_LINK_ID 101
+#define WLAN_EID_INTERWORKING 107
+#define WLAN_EID_ADV_PROTO 108
+#define WLAN_EID_QOS_MAP_SET 110
+#define WLAN_EID_ROAMING_CONSORTIUM 111
+#define WLAN_EID_MESH_CONFIG 113
+#define WLAN_EID_MESH_ID 114
+#define WLAN_EID_PEER_MGMT 117
+#define WLAN_EID_EXT_CAPAB 127
+#define WLAN_EID_AMPE 139
+#define WLAN_EID_MIC 140
+#define WLAN_EID_CCKM 156
+#define WLAN_EID_MULTI_BAND 158
+#define WLAN_EID_SESSION_TRANSITION 164
+#define WLAN_EID_VHT_CAP 191
+#define WLAN_EID_VHT_OPERATION 192
+#define WLAN_EID_VHT_EXTENDED_BSS_LOAD 193
+#define WLAN_EID_VHT_WIDE_BW_CHSWITCH  194
+#define WLAN_EID_VHT_TRANSMIT_POWER_ENVELOPE 195
+#define WLAN_EID_VHT_CHANNEL_SWITCH_WRAPPER 196
+#define WLAN_EID_VHT_AID 197
+#define WLAN_EID_VHT_QUIET_CHANNEL 198
+#define WLAN_EID_VHT_OPERATING_MODE_NOTIFICATION 199
+#define WLAN_EID_VENDOR_SPECIFIC 221
+/* Action frame categories (IEEE 802.11-2007, 7.3.1.11, Table 7-24) */
+#define WLAN_ACTION_SPECTRUM_MGMT 0
+#define WLAN_ACTION_QOS 1
+#define WLAN_ACTION_DLS 2
+#define WLAN_ACTION_BLOCK_ACK 3
+#define WLAN_ACTION_PUBLIC 4
+#define WLAN_ACTION_RADIO_MEASUREMENT 5
+#define WLAN_ACTION_FT 6
+#define WLAN_ACTION_HT 7
+#define WLAN_ACTION_SA_QUERY 8
+#define WLAN_ACTION_PROTECTED_DUAL 9
+#define WLAN_ACTION_WNM 10
+#define WLAN_ACTION_UNPROTECTED_WNM 11
+#define WLAN_ACTION_TDLS 12
+#define WLAN_ACTION_SELF_PROTECTED 15
+#define WLAN_ACTION_WMM 17 /* WMM Specification 1.1 */
+#define WLAN_ACTION_FST 18
+#define WLAN_ACTION_VENDOR_SPECIFIC 127
+/* Public action codes */
+#define WLAN_PA_20_40_BSS_COEX 0
+#define WLAN_PA_VENDOR_SPECIFIC 9
+#define WLAN_PA_GAS_INITIAL_REQ 10
+#define WLAN_PA_GAS_INITIAL_RESP 11
+#define WLAN_PA_GAS_COMEBACK_REQ 12
+#define WLAN_PA_GAS_COMEBACK_RESP 13
+#define WLAN_TDLS_DISCOVERY_RESPONSE 14
+/* Protected Dual of Public Action frames */
+#define WLAN_PROT_DSE_ENABLEMENT 1
+#define WLAN_PROT_DSE_DEENABLEMENT 2
+#define WLAN_PROT_EXT_CSA 4
+#define WLAN_PROT_MEASUREMENT_REQ 5
+#define WLAN_PROT_MEASUREMENT_REPORT 6
+#define WLAN_PROT_DSE_POWER_CONSTRAINT 8
+#define WLAN_PROT_VENDOR_SPECIFIC 9
+#define WLAN_PROT_GAS_INITIAL_REQ 10
+#define WLAN_PROT_GAS_INITIAL_RESP 11
+#define WLAN_PROT_GAS_COMEBACK_REQ 12
+#define WLAN_PROT_GAS_COMEBACK_RESP 13
+/* SA Query Action frame (IEEE 802.11w/D8.0, 7.4.9) */
+#define WLAN_SA_QUERY_REQUEST 0
+#define WLAN_SA_QUERY_RESPONSE 1
+#define WLAN_SA_QUERY_TR_ID_LEN 2
+/* TDLS action codes */
+#define WLAN_TDLS_SETUP_REQUEST 0
+#define WLAN_TDLS_SETUP_RESPONSE 1
+#define WLAN_TDLS_SETUP_CONFIRM 2
+#define WLAN_TDLS_TEARDOWN 3
+#define WLAN_TDLS_PEER_TRAFFIC_INDICATION 4
+#define WLAN_TDLS_CHANNEL_SWITCH_REQUEST 5
+#define WLAN_TDLS_CHANNEL_SWITCH_RESPONSE 6
+#define WLAN_TDLS_PEER_PSM_REQUEST 7
+#define WLAN_TDLS_PEER_PSM_RESPONSE 8
+#define WLAN_TDLS_PEER_TRAFFIC_RESPONSE 9
+#define WLAN_TDLS_DISCOVERY_REQUEST 10
+/* Radio Measurement Action codes */
+#define WLAN_RRM_RADIO_MEASUREMENT_REQUEST 0
+#define WLAN_RRM_RADIO_MEASUREMENT_REPORT 1
+#define WLAN_RRM_LINK_MEASUREMENT_REQUEST 2
+#define WLAN_RRM_LINK_MEASUREMENT_REPORT 3
+#define WLAN_RRM_NEIGHBOR_REPORT_REQUEST 4
+#define WLAN_RRM_NEIGHBOR_REPORT_RESPONSE 5
+/* Radio Measurement capabilities (from RRM Capabilities IE) */
+/* byte 1 (out of 5) */
+#define WLAN_RRM_CAPS_LINK_MEASUREMENT BIT(0)
+#define WLAN_RRM_CAPS_NEIGHBOR_REPORT BIT(1)
+/* Timeout Interval Type */
+#define WLAN_TIMEOUT_REASSOC_DEADLINE 1
+#define WLAN_TIMEOUT_KEY_LIFETIME 2
+#define WLAN_TIMEOUT_ASSOC_COMEBACK 3
+/* Interworking element (IEEE 802.11u) - Access Network Options */
+#define INTERWORKING_ANO_ACCESS_NETWORK_MASK 0x0f
+#define INTERWORKING_ANO_INTERNET 0x10
+#define INTERWORKING_ANO_ASRA 0x20
+#define INTERWORKING_ANO_ESR 0x40
+#define INTERWORKING_ANO_UESA 0x80
+#define INTERWORKING_ANT_PRIVATE 0
+#define INTERWORKING_ANT_PRIVATE_WITH_GUEST 1
+#define INTERWORKING_ANT_CHARGEABLE_PUBLIC 2
+#define INTERWORKING_ANT_FREE_PUBLIC 3
+#define INTERWORKING_ANT_PERSONAL_DEVICE 4
+#define INTERWORKING_ANT_EMERGENCY_SERVICES 5
+#define INTERWORKING_ANT_TEST 6
+#define INTERWORKING_ANT_WILDCARD 15
+/* Advertisement Protocol ID definitions (IEEE Std 802.11u-2011) */
+enum adv_proto_id {
+	ACCESS_NETWORK_QUERY_PROTOCOL = 0,
+	MIH_INFO_SERVICE = 1,
+	MIH_CMD_AND_EVENT_DISCOVERY = 2,
+	EMERGENCY_ALERT_SYSTEM = 3,
+	ADV_PROTO_VENDOR_SPECIFIC = 221
+/* Access Network Query Protocol info ID definitions (IEEE Std 802.11u-2011) */
+enum anqp_info_id {
+	ANQP_QUERY_LIST = 256,
+	ANQP_CAPABILITY_LIST = 257,
+	ANQP_VENUE_NAME = 258,
+	ANQP_EMERGENCY_CALL_NUMBER = 259,
+	ANQP_NETWORK_AUTH_TYPE = 260,
+	ANQP_ROAMING_CONSORTIUM = 261,
+	ANQP_IP_ADDR_TYPE_AVAILABILITY = 262,
+	ANQP_NAI_REALM = 263,
+	ANQP_3GPP_CELLULAR_NETWORK = 264,
+	ANQP_AP_GEOSPATIAL_LOCATION = 265,
+	ANQP_AP_CIVIC_LOCATION = 266,
+	ANQP_AP_LOCATION_PUBLIC_URI = 267,
+	ANQP_DOMAIN_NAME = 268,
+	ANQP_EMERGENCY_ALERT_URI = 269,
+	ANQP_EMERGENCY_NAI = 271,
+	ANQP_VENDOR_SPECIFIC = 56797
+/* NAI Realm list - EAP Method subfield - Authentication Parameter ID */
+enum nai_realm_eap_auth_param {
+	NAI_REALM_EAP_AUTH_EXPANDED_EAP_METHOD = 1,
+	NAI_REALM_EAP_AUTH_NON_EAP_INNER_AUTH = 2,
+	NAI_REALM_EAP_AUTH_INNER_AUTH_EAP_METHOD = 3,
+	NAI_REALM_EAP_AUTH_EXPANDED_INNER_EAP_METHOD = 4,
+	NAI_REALM_EAP_AUTH_CRED_TYPE = 5,
+	NAI_REALM_EAP_AUTH_TUNNELED_CRED_TYPE = 6,
+	NAI_REALM_EAP_AUTH_VENDOR_SPECIFIC = 221
+enum nai_realm_eap_auth_inner_non_eap {
+	NAI_REALM_INNER_NON_EAP_PAP = 1,
+	NAI_REALM_INNER_NON_EAP_CHAP = 2,
+	NAI_REALM_INNER_NON_EAP_MSCHAP = 3,
+	NAI_REALM_INNER_NON_EAP_MSCHAPV2 = 4
+enum nai_realm_eap_cred_type {
+	NAI_REALM_CRED_TYPE_SIM = 1,
+	NAI_REALM_CRED_TYPE_USIM = 2,
+	NAI_REALM_CRED_TYPE_NFC_SECURE_ELEMENT = 3,
+	NAI_REALM_CRED_TYPE_HARDWARE_TOKEN = 4,
+	NAI_REALM_CRED_TYPE_SOFTOKEN = 5,
+	NAI_REALM_CRED_TYPE_CERTIFICATE = 6,
+	NAI_REALM_CRED_TYPE_USERNAME_PASSWORD = 7,
+	NAI_REALM_CRED_TYPE_NONE = 8,
+	NAI_REALM_CRED_TYPE_ANONYMOUS = 9,
+	NAI_REALM_CRED_TYPE_VENDOR_SPECIFIC = 10
+#ifdef _MSC_VER
+#pragma pack(push, 1)
+#endif /* _MSC_VER */
+struct ieee80211_hdr {
+	le16 frame_control;
+	le16 duration_id;
+	u8 addr1[6];
+	u8 addr2[6];
+	u8 addr3[6];
+	le16 seq_ctrl;
+	/* followed by 'u8 addr4[6];' if ToDS and FromDS is set in data frame
+} STRUCT_PACKED;
+#define IEEE80211_DA_FROMDS addr1
+#define IEEE80211_BSSID_FROMDS addr2
+#define IEEE80211_SA_FROMDS addr3
+#define IEEE80211_HDRLEN (sizeof(struct ieee80211_hdr))
+#define IEEE80211_FC(type, stype) host_to_le16((type << 2) | (stype << 4))
+struct ieee80211_mgmt {
+	le16 duration;
+	u8 da[6];
+	u8 sa[6];
+	u8 bssid[6];
+	le16 seq_ctrl;
+	union {
+		struct {
+			le16 auth_alg;
+			le16 auth_transaction;
+			le16 status_code;
+			/* possibly followed by Challenge text */
+			u8 variable[];
+		} STRUCT_PACKED auth;
+		struct {
+			le16 reason_code;
+			u8 variable[];
+		} STRUCT_PACKED deauth;
+		struct {
+			le16 capab_info;
+			le16 listen_interval;
+			/* followed by SSID and Supported rates */
+			u8 variable[];
+		} STRUCT_PACKED assoc_req;
+		struct {
+			le16 capab_info;
+			le16 status_code;
+			le16 aid;
+			/* followed by Supported rates */
+			u8 variable[];
+		} STRUCT_PACKED assoc_resp, reassoc_resp;
+		struct {
+			le16 capab_info;
+			u8 current_ap[6];
+			u8 variable[];
+		} STRUCT_PACKED reassoc_req;
+		struct {
+			le16 reason_code;
+			u8 variable[];
+		} STRUCT_PACKED disassoc;
+		struct {
+			u8 timestamp[8];
+			le16 beacon_int;
+			le16 capab_info;
+			/* followed by some of SSID, Supported rates,
+			 * FH Params, DS Params, CF Params, IBSS Params, TIM */
+			u8 variable[];
+		} STRUCT_PACKED beacon;
+		struct {
+			/* only variable items: SSID, Supported rates */
+			u8 variable[0];
+		} STRUCT_PACKED probe_req;
+		struct {
+			u8 timestamp[8];
+			le16 beacon_int;
+			le16 capab_info;
+			 * FH Params, DS Params, CF Params, IBSS Params */
+			u8 variable[];
+		} STRUCT_PACKED probe_resp;
+		struct {
+			u8 category;
+			union {
+				struct {
+					u8 action_code;
+					u8 dialog_token;
+					u8 status_code;
+					u8 variable[];
+				} STRUCT_PACKED wmm_action;
+				struct{
+					u8 action_code;
+					u8 element_id;
+					u8 length;
+					u8 switch_mode;
+					u8 new_chan;
+					u8 switch_count;
+				} STRUCT_PACKED chan_switch;
+				struct {
+					u8 action;
+					u8 sta_addr[ETH_ALEN];
+					u8 target_ap_addr[ETH_ALEN];
+					u8 variable[]; /* FT Request */
+				} STRUCT_PACKED ft_action_req;
+				struct {
+					u8 action;
+					le16 status_code;
+				} STRUCT_PACKED ft_action_resp;
+				struct {
+					u8 action;
+					u8 trans_id[WLAN_SA_QUERY_TR_ID_LEN];
+				} STRUCT_PACKED sa_query_req;
+				struct {
+					u8 action; /* */
+				} STRUCT_PACKED sa_query_resp;
+				struct {
+					u8 action;
+					u8 dialogtoken;
+					u8 variable[];
+				} STRUCT_PACKED wnm_sleep_req;
+				struct {
+					u8 action;
+					u8 dialogtoken;
+					le16 keydata_len;
+					u8 variable[];
+				} STRUCT_PACKED wnm_sleep_resp;
+				struct {
+					u8 action;
+					u8 variable[];
+				} STRUCT_PACKED public_action;
+				struct {
+					u8 action; /* 9 */
+					u8 oui[3];
+					/* Vendor-specific content */
+					u8 variable[];
+				} STRUCT_PACKED vs_public_action;
+				struct {
+					u8 action; /* 7 */
+					u8 dialog_token;
+					u8 req_mode;
+					le16 disassoc_timer;
+					u8 validity_interval;
+					/* BSS Termination Duration (optional),
+					 * Session Information URL (optional),
+					 * BSS Transition Candidate List
+					 * Entries */
+					u8 variable[];
+				} STRUCT_PACKED bss_tm_req;
+				struct {
+					u8 action; /* 8 */
+					u8 dialog_token;
+					u8 status_code;
+					u8 bss_termination_delay;
+					/* Target BSSID (optional),
+					 * Entries (optional) */
+					u8 variable[];
+				} STRUCT_PACKED bss_tm_resp;
+				struct {
+					u8 action; /* 6 */
+					u8 dialog_token;
+					u8 query_reason;
+					/* BSS Transition Candidate List
+					u8 variable[];
+				} STRUCT_PACKED bss_tm_query;
+				struct {
+					u8 action; /* 15 */
+					u8 variable[];
+				} STRUCT_PACKED slf_prot_action;
+				struct {
+					u8 action;
+					u8 variable[];
+				} STRUCT_PACKED fst_action;
+			} u;
+		} STRUCT_PACKED action;
+	} u;
+} STRUCT_PACKED;
+/* Rx MCS bitmask is in the first 77 bits of supported_mcs_set */
+#define IEEE80211_HT_MCS_MASK_LEN 10
+/* HT Capabilities element */
+struct ieee80211_ht_capabilities {
+	le16 ht_capabilities_info;
+	u8 a_mpdu_params; /* Maximum A-MPDU Length Exponent B0..B1
+			   * Minimum MPDU Start Spacing B2..B4
+			   * Reserved B5..B7 */
+	u8 supported_mcs_set[16];
+	le16 ht_extended_capabilities;
+	le32 tx_bf_capability_info;
+	u8 asel_capabilities;
+} STRUCT_PACKED;
+/* HT Operation element */
+struct ieee80211_ht_operation {
+	u8 primary_chan;
+	/* Five octets of HT Operation Information */
+	u8 ht_param; /* B0..B7 */
+	le16 operation_mode; /* B8..B23 */
+	le16 param; /* B24..B39 */
+	u8 basic_mcs_set[16];
+} STRUCT_PACKED;
+struct ieee80211_obss_scan_parameters {
+	le16 scan_passive_dwell;
+	le16 scan_active_dwell;
+	le16 width_trigger_scan_interval;
+	le16 scan_passive_total_per_channel;
+	le16 scan_active_total_per_channel;
+	le16 channel_transition_delay_factor;
+	le16 scan_activity_threshold;
+} STRUCT_PACKED;
+struct ieee80211_vht_capabilities {
+	le32 vht_capabilities_info;
+	struct {
+		le16 rx_map;
+		le16 rx_highest;
+		le16 tx_map;
+		le16 tx_highest;
+	} vht_supported_mcs_set;
+} STRUCT_PACKED;
+struct ieee80211_vht_operation {
+	u8 vht_op_info_chwidth;
+	u8 vht_op_info_chan_center_freq_seg0_idx;
+	u8 vht_op_info_chan_center_freq_seg1_idx;
+	le16 vht_basic_mcs_set;
+} STRUCT_PACKED;
+struct ieee80211_ampe_ie {
+	u8 selected_pairwise_suite[4];
+	u8 local_nonce[32];
+	u8 peer_nonce[32];
+	u8 mgtk[16];
+	u8 key_rsc[8];
+	u8 key_expiration[4];
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+#define ERP_INFO_NON_ERP_PRESENT BIT(0)
+#define ERP_INFO_USE_PROTECTION BIT(1)
+#define ERP_INFO_BARKER_PREAMBLE_MODE BIT(2)
+#define OVERLAPPING_BSS_TRANS_DELAY_FACTOR 5
+/* HT Capabilities Info field within HT Capabilities element */
+#define HT_CAP_INFO_LDPC_CODING_CAP		((u16) BIT(0))
+#define HT_CAP_INFO_SUPP_CHANNEL_WIDTH_SET	((u16) BIT(1))
+#define HT_CAP_INFO_SMPS_MASK			((u16) (BIT(2) | BIT(3)))
+#define HT_CAP_INFO_SMPS_STATIC			((u16) 0)
+#define HT_CAP_INFO_SMPS_DYNAMIC		((u16) BIT(2))
+#define HT_CAP_INFO_SMPS_DISABLED		((u16) (BIT(2) | BIT(3)))
+#define HT_CAP_INFO_GREEN_FIELD			((u16) BIT(4))
+#define HT_CAP_INFO_SHORT_GI20MHZ		((u16) BIT(5))
+#define HT_CAP_INFO_SHORT_GI40MHZ		((u16) BIT(6))
+#define HT_CAP_INFO_TX_STBC			((u16) BIT(7))
+#define HT_CAP_INFO_RX_STBC_MASK		((u16) (BIT(8) | BIT(9)))
+#define HT_CAP_INFO_RX_STBC_1			((u16) BIT(8))
+#define HT_CAP_INFO_RX_STBC_12			((u16) BIT(9))
+#define HT_CAP_INFO_RX_STBC_123			((u16) (BIT(8) | BIT(9)))
+#define HT_CAP_INFO_DELAYED_BA			((u16) BIT(10))
+#define HT_CAP_INFO_MAX_AMSDU_SIZE		((u16) BIT(11))
+#define HT_CAP_INFO_DSSS_CCK40MHZ		((u16) BIT(12))
+/* B13 - Reserved (was PSMP support during P802.11n development) */
+#define HT_CAP_INFO_40MHZ_INTOLERANT		((u16) BIT(14))
+#define HT_CAP_INFO_LSIG_TXOP_PROTECT_SUPPORT	((u16) BIT(15))
+/* HT Extended Capabilities field within HT Capabilities element */
+#define EXT_HT_CAP_INFO_PCO			((u16) BIT(0))
+#define EXT_HT_CAP_INFO_PCO_TRANS_TIME_MASK	((u16) (BIT(1) | BIT(2)))
+#define EXT_HT_CAP_INFO_TRANS_TIME_OFFSET	1
+/* B3..B7 - Reserved */
+#define EXT_HT_CAP_INFO_MCS_FEEDBACK_MASK	((u16) (BIT(8) | BIT(9)))
+#define EXT_HT_CAP_INFO_MCS_FEEDBACK_OFFSET	8
+#define EXT_HT_CAP_INFO_HTC_SUPPORT		((u16) BIT(10))
+#define EXT_HT_CAP_INFO_RD_RESPONDER		((u16) BIT(11))
+/* B12..B15 - Reserved */
+/* Transmit Beanforming Capabilities within HT Capabilities element */
+#define TX_BF_CAP_IMPLICIT_TXBF_RX_CAP ((u32) BIT(0))
+#define TX_BF_CAP_RX_STAGGERED_SOUNDING_CAP ((u32) BIT(1))
+#define TX_BF_CAP_TX_STAGGERED_SOUNDING_CAP ((u32) BIT(2))
+#define TX_BF_CAP_RX_NDP_CAP ((u32) BIT(3))
+#define TX_BF_CAP_TX_NDP_CAP ((u32) BIT(4))
+#define TX_BF_CAP_IMPLICIT_TX_BF_CAP ((u32) BIT(5))
+#define TX_BF_CAP_CALIBRATION_MASK ((u32) (BIT(6) | BIT(7))
+#define TX_BF_CAP_CALIB_OFFSET 6
+#define TX_BF_CAP_EXPLICIT_CSI_TXBF_CAP ((u32) BIT(8))
+#define TX_BF_CAP_EXPLICIT_NONCOMPR_STEERING_CAP ((u32) BIT(9))
+#define TX_BF_CAP_EXPLICIT_COMPR_STEERING_CAP ((u32) BIT(10))
+#define TX_BF_CAP_EXPLICIT_TX_BF_CSI_FEEDBACK_MASK ((u32) (BIT(10) | BIT(11)))
+#define TX_BF_CAP_EXPLICIT_BF_CSI_FEEDBACK_OFFSET 11
+#define TX_BF_CAP_EXPLICIT_UNCOMPR_STEERING_MATRIX_FEEDBACK_OFFSET 13
+#define TX_BF_CAP_EXPLICIT_COMPRESSED_STEERING_MATRIX_FEEDBACK_OFFSET 15
+#define TX_BF_CAP_MINIMAL_GROUPING_OFFSET 17
+#define TX_BF_CAP_CSI_NUM_BEAMFORMER_ANT_OFFSET 19
+#define TX_BF_CAP_UNCOMPRESSED_STEERING_MATRIX_BEAMFORMER_ANT_OFFSET 21
+#define TX_BF_CAP_COMPRESSED_STEERING_MATRIX_BEAMFORMER_ANT_OFFSET 23
+#define TX_BF_CAP_SCI_MAX_OF_ROWS_BEANFORMER_SUPPORTED_OFFSET 25
+#define TX_BF_CAP_CHANNEL_ESTIMATION_CAP_MASK ((u32) (BIT(27) | BIT(28)))
+#define TX_BF_CAP_CHANNEL_ESTIMATION_CAP_OFFSET 27
+/* B29..B31 - Reserved */
+/* ASEL Capability field within HT Capabilities element */
+#define ASEL_CAP_ASEL_CAPABLE ((u8) BIT(0))
+#define ASEL_CAP_EXPLICIT_CSI_FEEDBACK_BASED_TX_AS_CAP ((u8) BIT(1))
+#define ASEL_CAP_ANT_INDICES_FEEDBACK_BASED_TX_AS_CAP ((u8) BIT(2))
+#define ASEL_CAP_EXPLICIT_CSI_FEEDBACK_CAP ((u8) BIT(3))
+#define ASEL_CAP_ANT_INDICES_FEEDBACK_CAP ((u8) BIT(4))
+#define ASEL_CAP_RX_AS_CAP ((u8) BIT(5))
+#define ASEL_CAP_TX_SOUNDING_PPDUS_CAP ((u8) BIT(6))
+/* B7 - Reserved */
+/* First octet of HT Operation Information within HT Operation element */
+#define HT_INFO_HT_PARAM_SECONDARY_CHNL_OFF_MASK	((u8) BIT(0) | BIT(1))
+#define HT_INFO_HT_PARAM_SECONDARY_CHNL_ABOVE		((u8) BIT(0))
+#define HT_INFO_HT_PARAM_SECONDARY_CHNL_BELOW		((u8) BIT(0) | BIT(1))
+#define HT_INFO_HT_PARAM_STA_CHNL_WIDTH			((u8) BIT(2))
+#define HT_INFO_HT_PARAM_RIFS_MODE			((u8) BIT(3))
+/* B4..B7 - Reserved */
+/* HT Protection (B8..B9 of HT Operation Information) */
+#define HT_PROT_NO_PROTECTION           0
+#define HT_PROT_NONMEMBER_PROTECTION    1
+#define HT_PROT_20MHZ_PROTECTION        2
+#define HT_PROT_NON_HT_MIXED            3
+/* Bits within ieee80211_ht_operation::operation_mode (BIT(0) maps to B8 in
+ * HT Operation Information) */
+#define HT_OPER_OP_MODE_HT_PROT_MASK ((u16) (BIT(0) | BIT(1))) /* B8..B9 */
+#define HT_OPER_OP_MODE_NON_GF_HT_STAS_PRESENT	((u16) BIT(2)) /* B10 */
+/* BIT(3), i.e., B11 in HT Operation Information field - Reserved */
+#define HT_OPER_OP_MODE_OBSS_NON_HT_STAS_PRESENT	((u16) BIT(4)) /* B12 */
+/* BIT(5)..BIT(15), i.e., B13..B23 - Reserved */
+/* Last two octets of HT Operation Information (BIT(0) = B24) */
+/* B24..B29 - Reserved */
+#define HT_OPER_PARAM_DUAL_BEACON			((u16) BIT(6))
+#define HT_OPER_PARAM_DUAL_CTS_PROTECTION		((u16) BIT(7))
+#define HT_OPER_PARAM_STBC_BEACON			((u16) BIT(8))
+#define HT_OPER_PARAM_LSIG_TXOP_PROT_FULL_SUPP		((u16) BIT(9))
+#define HT_OPER_PARAM_PCO_ACTIVE			((u16) BIT(10))
+#define HT_OPER_PARAM_PCO_PHASE				((u16) BIT(11))
+/* B36..B39 - Reserved */
+#define BSS_MEMBERSHIP_SELECTOR_VHT_PHY 126
+#define BSS_MEMBERSHIP_SELECTOR_HT_PHY 127
+/* VHT Defines */
+#define VHT_CAP_MAX_MPDU_LENGTH_7991                ((u32) BIT(0))
+#define VHT_CAP_MAX_MPDU_LENGTH_11454               ((u32) BIT(1))
+#define VHT_CAP_MAX_MPDU_LENGTH_MASK                ((u32) BIT(0) | BIT(1))
+#define VHT_CAP_MAX_MPDU_LENGTH_MASK_SHIFT          0
+#define VHT_CAP_SUPP_CHAN_WIDTH_160MHZ              ((u32) BIT(2))
+#define VHT_CAP_SUPP_CHAN_WIDTH_160_80PLUS80MHZ     ((u32) BIT(3))
+#define VHT_CAP_SUPP_CHAN_WIDTH_MASK                ((u32) BIT(2) | BIT(3))
+#define VHT_CAP_RXLDPC                              ((u32) BIT(4))
+#define VHT_CAP_SHORT_GI_80                         ((u32) BIT(5))
+#define VHT_CAP_SHORT_GI_160                        ((u32) BIT(6))
+#define VHT_CAP_TXSTBC                              ((u32) BIT(7))
+#define VHT_CAP_RXSTBC_1                            ((u32) BIT(8))
+#define VHT_CAP_RXSTBC_2                            ((u32) BIT(9))
+#define VHT_CAP_RXSTBC_3                            ((u32) BIT(8) | BIT(9))
+#define VHT_CAP_RXSTBC_4                            ((u32) BIT(10))
+#define VHT_CAP_RXSTBC_MASK                         ((u32) BIT(8) | BIT(9) | \
+							   BIT(10))
+#define VHT_CAP_RXSTBC_MASK_SHIFT                   8
+#define VHT_CAP_SU_BEAMFORMER_CAPABLE               ((u32) BIT(11))
+#define VHT_CAP_SU_BEAMFORMEE_CAPABLE               ((u32) BIT(12))
+#define VHT_CAP_BEAMFORMEE_STS_MAX                  ((u32) BIT(13) | \
+							   BIT(14) | BIT(15))
+#define VHT_CAP_BEAMFORMEE_STS_MAX_SHIFT            13
+#define VHT_CAP_BEAMFORMEE_STS_OFFSET               13
+#define VHT_CAP_SOUNDING_DIMENSION_MAX              ((u32) BIT(16) | \
+							   BIT(17) | BIT(18))
+#define VHT_CAP_SOUNDING_DIMENSION_MAX_SHIFT        16
+#define VHT_CAP_SOUNDING_DIMENSION_OFFSET           16
+#define VHT_CAP_MU_BEAMFORMER_CAPABLE               ((u32) BIT(19))
+#define VHT_CAP_MU_BEAMFORMEE_CAPABLE               ((u32) BIT(20))
+#define VHT_CAP_VHT_TXOP_PS                         ((u32) BIT(21))
+#define VHT_CAP_HTC_VHT                             ((u32) BIT(22))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_1        ((u32) BIT(23))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_2        ((u32) BIT(24))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_3        ((u32) BIT(23) | BIT(24))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_4        ((u32) BIT(25))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_5        ((u32) BIT(23) | BIT(25))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_6        ((u32) BIT(24) | BIT(25))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_MAX      ((u32) BIT(23) | \
+							   BIT(24) | BIT(25))
+#define VHT_CAP_MAX_A_MPDU_LENGTH_EXPONENT_MAX_SHIFT 23
+#define VHT_CAP_VHT_LINK_ADAPTATION_VHT_UNSOL_MFB   ((u32) BIT(27))
+#define VHT_CAP_VHT_LINK_ADAPTATION_VHT_MRQ_MFB     ((u32) BIT(26) | BIT(27))
+#define VHT_CAP_RX_ANTENNA_PATTERN                  ((u32) BIT(28))
+#define VHT_CAP_TX_ANTENNA_PATTERN                  ((u32) BIT(29))
+#define VHT_OPMODE_CHANNEL_WIDTH_MASK		    ((u8) BIT(0) | BIT(1))
+#define VHT_OPMODE_CHANNEL_RxNSS_MASK		    ((u8) BIT(4) | BIT(5) | \
+						     BIT(6))
+#define VHT_OPMODE_NOTIF_RX_NSS_SHIFT		    4
+#define VHT_RX_NSS_MAX_STREAMS			    8
+/* VHT channel widths */
+#define VHT_CHANWIDTH_USE_HT	0
+#define VHT_CHANWIDTH_80MHZ	1
+#define VHT_CHANWIDTH_160MHZ	2
+#define VHT_CHANWIDTH_80P80MHZ	3
+#define OUI_MICROSOFT 0x0050f2 /* Microsoft (also used in Wi-Fi specs)
+				* 00:50:F2 */
+#define WPA_IE_VENDOR_TYPE 0x0050f201
+#define WMM_IE_VENDOR_TYPE 0x0050f202
+#define WPS_IE_VENDOR_TYPE 0x0050f204
+#define OUI_WFA 0x506f9a
+#define P2P_IE_VENDOR_TYPE 0x506f9a09
+#define WFD_IE_VENDOR_TYPE 0x506f9a0a
+#define WFD_OUI_TYPE 10
+#define HS20_IE_VENDOR_TYPE 0x506f9a10
+#define OSEN_IE_VENDOR_TYPE 0x506f9a12
+#define WMM_OUI_TYPE 2
+#define WMM_OUI_SUBTYPE_INFORMATION_ELEMENT 0
+#define WMM_OUI_SUBTYPE_PARAMETER_ELEMENT 1
+#define WMM_OUI_SUBTYPE_TSPEC_ELEMENT 2
+#define WMM_VERSION 1
+#define WMM_ACTION_CODE_ADDTS_REQ 0
+#define WMM_ACTION_CODE_ADDTS_RESP 1
+#define WMM_ACTION_CODE_DELTS 2
+#define WMM_ADDTS_STATUS_ADMISSION_ACCEPTED 0
+#define WMM_ADDTS_STATUS_INVALID_PARAMETERS 1
+/* 2 - Reserved */
+#define WMM_ADDTS_STATUS_REFUSED 3
+/* 4-255 - Reserved */
+/* WMM TSPEC Direction Field Values */
+#define WMM_TSPEC_DIRECTION_UPLINK 0
+#define WMM_TSPEC_DIRECTION_DOWNLINK 1
+/* 2 - Reserved */
+#define WMM_TSPEC_DIRECTION_BI_DIRECTIONAL 3
+ * WMM Information Element (used in (Re)Association Request frames; may also be
+ * used in Beacon frames)
+struct wmm_information_element {
+	/* Element ID: 221 (0xdd); Length: 7 */
+	/* required fields for WMM version 1 */
+	u8 oui[3]; /* 00:50:f2 */
+	u8 oui_type; /* 2 */
+	u8 oui_subtype; /* 0 */
+	u8 version; /* 1 for WMM version 1.0 */
+	u8 qos_info; /* AP/STA specific QoS info */
+} STRUCT_PACKED;
+#define WMM_QOSINFO_AP_UAPSD 0x80
+#define WMM_QOSINFO_STA_AC_MASK 0x0f
+#define WMM_QOSINFO_STA_SP_MASK 0x03
+#define WMM_QOSINFO_STA_SP_SHIFT 5
+#define WMM_AC_AIFSN_MASK 0x0f
+#define WMM_AC_AIFNS_SHIFT 0
+#define WMM_AC_ACM 0x10
+#define WMM_AC_ACI_MASK 0x60
+#define WMM_AC_ACI_SHIFT 5
+#define WMM_AC_ECWMIN_MASK 0x0f
+#define WMM_AC_ECWMIN_SHIFT 0
+#define WMM_AC_ECWMAX_MASK 0xf0
+#define WMM_AC_ECWMAX_SHIFT 4
+struct wmm_ac_parameter {
+	u8 aci_aifsn; /* AIFSN, ACM, ACI */
+	u8 cw; /* ECWmin, ECWmax (CW = 2^ECW - 1) */
+	le16 txop_limit;
+}  STRUCT_PACKED;
+ * WMM Parameter Element (used in Beacon, Probe Response, and (Re)Association
+ * Response frmaes)
+struct wmm_parameter_element {
+	/* Element ID: 221 (0xdd); Length: 24 */
+	u8 oui_subtype; /* 1 */
+	u8 reserved; /* 0 */
+	struct wmm_ac_parameter ac[4]; /* AC_BE, AC_BK, AC_VI, AC_VO */
+} STRUCT_PACKED;
+/* WMM TSPEC Element */
+struct wmm_tspec_element {
+	u8 eid; /* 221 = 0xdd */
+	u8 length; /* 6 + 55 = 61 */
+	u8 oui_subtype; /* 2 */
+	u8 version; /* 1 */
+	/* WMM TSPEC body (55 octets): */
+	u8 ts_info[3];
+	le16 nominal_msdu_size;
+	le16 maximum_msdu_size;
+	le32 minimum_service_interval;
+	le32 maximum_service_interval;
+	le32 inactivity_interval;
+	le32 suspension_interval;
+	le32 service_start_time;
+	le32 minimum_data_rate;
+	le32 mean_data_rate;
+	le32 peak_data_rate;
+	le32 maximum_burst_size;
+	le32 delay_bound;
+	le32 minimum_phy_rate;
+	le16 surplus_bandwidth_allowance;
+	le16 medium_time;
+} STRUCT_PACKED;
+/* Access Categories / ACI to AC coding */
+enum wmm_ac {
+	WMM_AC_BE = 0 /* Best Effort */,
+	WMM_AC_BK = 1 /* Background */,
+	WMM_AC_VI = 2 /* Video */,
+	WMM_AC_VO = 3 /* Voice */,
+	WMM_AC_NUM = 4
+#define HS20_INDICATION_OUI_TYPE 16
+#define HS20_ANQP_OUI_TYPE 17
+#define HS20_OSEN_OUI_TYPE 18
+#define HS20_STYPE_QUERY_LIST 1
+#define HS20_STYPE_CAPABILITY_LIST 2
+#define HS20_STYPE_OPERATOR_FRIENDLY_NAME 3
+#define HS20_STYPE_WAN_METRICS 4
+#define HS20_STYPE_CONNECTION_CAPABILITY 5
+#define HS20_STYPE_NAI_HOME_REALM_QUERY 6
+#define HS20_STYPE_OPERATING_CLASS 7
+#define HS20_STYPE_OSU_PROVIDERS_LIST 8
+#define HS20_STYPE_ICON_REQUEST 10
+#define HS20_STYPE_ICON_BINARY_FILE 11
+#define HS20_DGAF_DISABLED 0x01
+#define HS20_PPS_MO_ID_PRESENT 0x02
+#define HS20_ANQP_DOMAIN_ID_PRESENT 0x04
+#define HS20_VERSION 0x10 /* Release 2 */
+/* WNM-Notification WFA vendors specific subtypes */
+#define HS20_WNM_SUB_REM_NEEDED 0
+#define HS20_WNM_DEAUTH_IMMINENT_NOTICE 1
+#define HS20_DEAUTH_REASON_CODE_BSS 0
+#define HS20_DEAUTH_REASON_CODE_ESS 1
+/* Wi-Fi Direct (P2P) */
+#define P2P_OUI_TYPE 9
+enum p2p_attr_id {
+	P2P_ATTR_STATUS = 0,
+	P2P_ATTR_MINOR_REASON_CODE = 1,
+	P2P_ATTR_CAPABILITY = 2,
+	P2P_ATTR_DEVICE_ID = 3,
+	P2P_ATTR_GROUP_OWNER_INTENT = 4,
+	P2P_ATTR_CONFIGURATION_TIMEOUT = 5,
+	P2P_ATTR_LISTEN_CHANNEL = 6,
+	P2P_ATTR_GROUP_BSSID = 7,
+	P2P_ATTR_EXT_LISTEN_TIMING = 8,
+	P2P_ATTR_INTENDED_INTERFACE_ADDR = 9,
+	P2P_ATTR_MANAGEABILITY = 10,
+	P2P_ATTR_CHANNEL_LIST = 11,
+	P2P_ATTR_NOTICE_OF_ABSENCE = 12,
+	P2P_ATTR_DEVICE_INFO = 13,
+	P2P_ATTR_GROUP_INFO = 14,
+	P2P_ATTR_GROUP_ID = 15,
+	P2P_ATTR_INTERFACE = 16,
+	P2P_ATTR_OPERATING_CHANNEL = 17,
+	P2P_ATTR_INVITATION_FLAGS = 18,
+	P2P_ATTR_OOB_GO_NEG_CHANNEL = 19,
+	P2P_ATTR_SERVICE_HASH = 21,
+	P2P_ATTR_SESSION_INFORMATION_DATA = 22,
+	P2P_ATTR_CONNECTION_CAPABILITY = 23,
+	P2P_ATTR_ADVERTISEMENT_ID = 24,
+	P2P_ATTR_ADVERTISED_SERVICE = 25,
+	P2P_ATTR_SESSION_ID = 26,
+	P2P_ATTR_FEATURE_CAPABILITY = 27,
+	P2P_ATTR_PERSISTENT_GROUP = 28,
+	P2P_ATTR_VENDOR_SPECIFIC = 221
+#define P2P_MAX_GO_INTENT 15
+/* P2P Capability - Device Capability bitmap */
+#define P2P_DEV_CAPAB_SERVICE_DISCOVERY BIT(0)
+#define P2P_DEV_CAPAB_CLIENT_DISCOVERABILITY BIT(1)
+#define P2P_DEV_CAPAB_CONCURRENT_OPER BIT(2)
+#define P2P_DEV_CAPAB_INFRA_MANAGED BIT(3)
+#define P2P_DEV_CAPAB_DEVICE_LIMIT BIT(4)
+#define P2P_DEV_CAPAB_INVITATION_PROCEDURE BIT(5)
+/* P2P Capability - Group Capability bitmap */
+#define P2P_GROUP_CAPAB_GROUP_OWNER BIT(0)
+#define P2P_GROUP_CAPAB_PERSISTENT_GROUP BIT(1)
+#define P2P_GROUP_CAPAB_GROUP_LIMIT BIT(2)
+#define P2P_GROUP_CAPAB_INTRA_BSS_DIST BIT(3)
+#define P2P_GROUP_CAPAB_CROSS_CONN BIT(4)
+#define P2P_GROUP_CAPAB_PERSISTENT_RECONN BIT(5)
+#define P2P_GROUP_CAPAB_GROUP_FORMATION BIT(6)
+#define P2P_GROUP_CAPAB_IP_ADDR_ALLOCATION BIT(7)
+/* P2PS Coordination Protocol Transport Bitmap */
+#define P2PS_FEATURE_CAPAB_UDP_TRANSPORT BIT(0)
+#define P2PS_FEATURE_CAPAB_MAC_TRANSPORT BIT(1)
+struct p2ps_feature_capab {
+	u8 cpt;
+	u8 reserved;
+} STRUCT_PACKED;
+/* Invitation Flags */
+#define P2P_INVITATION_FLAGS_TYPE BIT(0)
+/* P2P Manageability */
+#define P2P_MAN_DEVICE_MANAGEMENT BIT(0)
+#define P2P_MAN_CROSS_CONNECTION_PERMITTED BIT(1)
+#define P2P_MAN_COEXISTENCE_OPTIONAL BIT(2)
+enum p2p_status_code {
+	P2P_SC_SUCCESS = 0,
+	P2P_SC_FAIL_INFO_CURRENTLY_UNAVAILABLE = 1,
+	P2P_SC_FAIL_INCOMPATIBLE_PARAMS = 2,
+	P2P_SC_FAIL_LIMIT_REACHED = 3,
+	P2P_SC_FAIL_INVALID_PARAMS = 4,
+	P2P_SC_FAIL_UNABLE_TO_ACCOMMODATE = 5,
+	P2P_SC_FAIL_PREV_PROTOCOL_ERROR = 6,
+	P2P_SC_FAIL_NO_COMMON_CHANNELS = 7,
+	P2P_SC_FAIL_UNKNOWN_GROUP = 8,
+	P2P_SC_FAIL_BOTH_GO_INTENT_15 = 9,
+	P2P_SC_FAIL_INCOMPATIBLE_PROV_METHOD = 10,
+	P2P_SC_FAIL_REJECTED_BY_USER = 11,
+	P2P_SC_SUCCESS_DEFERRED = 12,
+enum p2p_role_indication {
+	P2P_DEVICE_NOT_IN_GROUP = 0x00,
+	P2P_CLIENT_IN_A_GROUP = 0x01,
+	P2P_GO_IN_A_GROUP = 0x02,
+#define P2P_WILDCARD_SSID "DIRECT-"
+#define P2P_WILDCARD_SSID_LEN 7
+/* P2P action frames */
+enum p2p_act_frame_type {
+	P2P_NOA = 0,
+	P2P_PRESENCE_REQ = 1,
+	P2P_PRESENCE_RESP = 2,
+	P2P_GO_DISC_REQ = 3
+/* P2P public action frames */
+enum p2p_action_frame_type {
+	P2P_GO_NEG_REQ = 0,
+	P2P_GO_NEG_RESP = 1,
+	P2P_GO_NEG_CONF = 2,
+	P2P_INVITATION_REQ = 3,
+	P2P_INVITATION_RESP = 4,
+	P2P_DEV_DISC_REQ = 5,
+	P2P_DEV_DISC_RESP = 6,
+	P2P_PROV_DISC_REQ = 7,
+	P2P_PROV_DISC_RESP = 8
+enum p2p_service_protocol_type {
+	P2P_SERV_ALL_SERVICES = 0,
+	P2P_SERV_BONJOUR = 1,
+	P2P_SERV_UPNP = 2,
+	P2P_SERV_WS_DISCOVERY = 3,
+	P2P_SERV_WIFI_DISPLAY = 4,
+	P2P_SERV_P2PS = 11,
+	P2P_SERV_VENDOR_SPECIFIC = 255
+enum p2p_sd_status {
+	P2P_SD_SUCCESS = 0,
+	P2P_SD_PROTO_NOT_AVAILABLE = 1,
+	P2P_SD_REQUESTED_INFO_NOT_AVAILABLE = 2,
+	P2P_SD_BAD_REQUEST = 3
+enum wifi_display_subelem {
+	WFD_SUBELEM_DEVICE_INFO = 0,
+	WFD_SUBELEM_ASSOCIATED_BSSID = 1,
+	WFD_SUBELEM_AUDIO_FORMATS = 2,
+	WFD_SUBELEM_VIDEO_FORMATS = 3,
+	WFD_SUBELEM_3D_VIDEO_FORMATS = 4,
+	WFD_SUBELEM_CONTENT_PROTECTION = 5,
+	WFD_SUBELEM_COUPLED_SINK = 6,
+	WFD_SUBELEM_EXT_CAPAB = 7,
+	WFD_SUBELEM_LOCAL_IP_ADDRESS = 8,
+	WFD_SUBELEM_SESSION_INFO = 9
+/* 802.11s */
+#define MESH_SYNC_METHOD_NEIGHBOR_OFFSET 1
+#define MESH_SYNC_METHOD_VENDOR		255
+#define MESH_PATH_PROTOCOL_HWMP		1
+#define MESH_PATH_PROTOCOL_VENDOR	255
+#define MESH_PATH_METRIC_AIRTIME	1
+#define MESH_PATH_METRIC_VENDOR		255
+enum plink_action_field {
+	PLINK_OPEN = 1,
+	PLINK_CONFIRM,
+	PLINK_CLOSE
+#define OUI_BROADCOM 0x00904c /* Broadcom (Epigram) */
+#define VENDOR_VHT_TYPE		0x04
+#define VENDOR_VHT_SUBTYPE	0x08
+#define VENDOR_VHT_SUBTYPE2	0x00
+#define VENDOR_HT_CAPAB_OUI_TYPE 0x33 /* 00-90-4c:0x33 */
+/* cipher suite selectors */
+#define WLAN_CIPHER_SUITE_USE_GROUP	0x000FAC00
+#define WLAN_CIPHER_SUITE_WEP40		0x000FAC01
+#define WLAN_CIPHER_SUITE_TKIP		0x000FAC02
+/* reserved: 				0x000FAC03 */
+#define WLAN_CIPHER_SUITE_CCMP		0x000FAC04
+#define WLAN_CIPHER_SUITE_WEP104	0x000FAC05
+#define WLAN_CIPHER_SUITE_AES_CMAC	0x000FAC06
+#define WLAN_CIPHER_SUITE_NO_GROUP_ADDR	0x000FAC07
+#define WLAN_CIPHER_SUITE_GCMP		0x000FAC08
+#define WLAN_CIPHER_SUITE_GCMP_256	0x000FAC09
+#define WLAN_CIPHER_SUITE_CCMP_256	0x000FAC0A
+#define WLAN_CIPHER_SUITE_BIP_GMAC_128	0x000FAC0B
+#define WLAN_CIPHER_SUITE_BIP_GMAC_256	0x000FAC0C
+#define WLAN_CIPHER_SUITE_BIP_CMAC_256	0x000FAC0D
+#define WLAN_CIPHER_SUITE_SMS4		0x00147201
+#define WLAN_CIPHER_SUITE_CKIP		0x00409600
+#define WLAN_CIPHER_SUITE_CKIP_CMIC	0x00409601
+#define WLAN_CIPHER_SUITE_CMIC		0x00409602
+#define WLAN_CIPHER_SUITE_KRK		0x004096FF /* for nl80211 use only */
+/* AKM suite selectors */
+#define WLAN_AKM_SUITE_8021X		0x000FAC01
+#define WLAN_AKM_SUITE_PSK		0x000FAC02
+#define WLAN_AKM_SUITE_FT_8021X		0x000FAC03
+#define WLAN_AKM_SUITE_FT_PSK		0x000FAC04
+#define WLAN_AKM_SUITE_8021X_SHA256	0x000FAC05
+#define WLAN_AKM_SUITE_PSK_SHA256	0x000FAC06
+#define WLAN_AKM_SUITE_8021X_SUITE_B	0x000FAC11
+#define WLAN_AKM_SUITE_8021X_SUITE_B_192	0x000FAC12
+#define WLAN_AKM_SUITE_CCKM		0x00409600
+#define WLAN_AKM_SUITE_OSEN		0x506f9a01
+/* IEEE 802.11v - WNM Action field values */
+enum wnm_action {
+	WNM_EVENT_REQ = 0,
+	WNM_EVENT_REPORT = 1,
+	WNM_DIAGNOSTIC_REQ = 2,
+	WNM_DIAGNOSTIC_REPORT = 3,
+	WNM_LOCATION_CFG_REQ = 4,
+	WNM_LOCATION_CFG_RESP = 5,
+	WNM_BSS_TRANS_MGMT_QUERY = 6,
+	WNM_BSS_TRANS_MGMT_REQ = 7,
+	WNM_BSS_TRANS_MGMT_RESP = 8,
+	WNM_FMS_REQ = 9,
+	WNM_FMS_RESP = 10,
+	WNM_COLLOCATED_INTERFERENCE_REQ = 11,
+	WNM_COLLOCATED_INTERFERENCE_REPORT = 12,
+	WNM_TFS_REQ = 13,
+	WNM_TFS_RESP = 14,
+	WNM_TFS_NOTIFY = 15,
+	WNM_SLEEP_MODE_REQ = 16,
+	WNM_SLEEP_MODE_RESP = 17,
+	WNM_TIM_BROADCAST_REQ = 18,
+	WNM_TIM_BROADCAST_RESP = 19,
+	WNM_QOS_TRAFFIC_CAPAB_UPDATE = 20,
+	WNM_CHANNEL_USAGE_REQ = 21,
+	WNM_CHANNEL_USAGE_RESP = 22,
+	WNM_DMS_REQ = 23,
+	WNM_DMS_RESP = 24,
+	WNM_TIMING_MEASUREMENT_REQ = 25,
+	WNM_NOTIFICATION_REQ = 26,
+	WNM_NOTIFICATION_RESP = 27
+/* IEEE 802.11v - BSS Transition Management Request - Request Mode */
+#define WNM_BSS_TM_REQ_PREF_CAND_LIST_INCLUDED BIT(0)
+#define WNM_BSS_TM_REQ_ABRIDGED BIT(1)
+#define WNM_BSS_TM_REQ_DISASSOC_IMMINENT BIT(2)
+#define WNM_BSS_TM_REQ_BSS_TERMINATION_INCLUDED BIT(3)
+#define WNM_BSS_TM_REQ_ESS_DISASSOC_IMMINENT BIT(4)
+/* IEEE Std 802.11-2012 - Table 8-253 */
+enum bss_trans_mgmt_status_code {
+	WNM_BSS_TM_ACCEPT = 0,
+	WNM_BSS_TM_REJECT_UNSPECIFIED = 1,
+	WNM_BSS_TM_REJECT_INSUFFICIENT_BEACON = 2,
+	WNM_BSS_TM_REJECT_INSUFFICIENT_CAPABITY = 3,
+	WNM_BSS_TM_REJECT_UNDESIRED = 4,
+	WNM_BSS_TM_REJECT_DELAY_REQUEST = 5,
+	WNM_BSS_TM_REJECT_STA_CANDIDATE_LIST_PROVIDED = 6,
+	WNM_BSS_TM_REJECT_NO_SUITABLE_CANDIDATES = 7,
+	WNM_BSS_TM_REJECT_LEAVING_ESS = 8
+#define WNM_NEIGHBOR_TSF                         1
+#define WNM_NEIGHBOR_CONDENSED_COUNTRY_STRING    2
+#define WNM_NEIGHBOR_BSS_TRANSITION_CANDIDATE    3
+#define WNM_NEIGHBOR_BSS_TERMINATION_DURATION    4
+#define WNM_NEIGHBOR_BEARING                     5
+#define WNM_NEIGHBOR_MEASUREMENT_PILOT          66
+#define WNM_NEIGHBOR_RRM_ENABLED_CAPABILITIES   70
+#define WNM_NEIGHBOR_MULTIPLE_BSSID             71
+/* QoS action */
+enum qos_action {
+	QOS_ADDTS_REQ = 0,
+	QOS_ADDTS_RESP = 1,
+	QOS_DELTS = 2,
+	QOS_SCHEDULE = 3,
+	QOS_QOS_MAP_CONFIG = 4,
+/* IEEE Std 802.11-2012, 8.4.2.62 20/40 BSS Coexistence element */
+#define WLAN_20_40_BSS_COEX_INFO_REQ            BIT(0)
+#define WLAN_20_40_BSS_COEX_40MHZ_INTOL         BIT(1)
+#define WLAN_20_40_BSS_COEX_20MHZ_WIDTH_REQ     BIT(2)
+#define WLAN_20_40_BSS_COEX_OBSS_EXEMPT_REQ     BIT(3)
+#define WLAN_20_40_BSS_COEX_OBSS_EXEMPT_GRNT    BIT(4)
+struct ieee80211_2040_bss_coex_ie {
+	u8 element_id;
+	u8 length;
+	u8 coex_param;
+} STRUCT_PACKED;
+struct ieee80211_2040_intol_chan_report {
+	u8 element_id;
+	u8 length;
+	u8 op_class;
+	u8 variable[0];	/* Channel List */
+} STRUCT_PACKED;
+/* IEEE 802.11v - WNM-Sleep Mode element */
+struct wnm_sleep_element {
+	u8 eid;     /* WLAN_EID_WNMSLEEP */
+	u8 len;
+	u8 action_type; /* WNM_SLEEP_ENTER/WNM_SLEEP_MODE_EXIT */
+	u8 status;
+	le16 intval;
+} STRUCT_PACKED;
+#define WNM_SLEEP_MODE_ENTER 0
+#define WNM_SLEEP_MODE_EXIT 1
+enum wnm_sleep_mode_response_status {
+	WNM_STATUS_SLEEP_ACCEPT = 0,
+	WNM_STATUS_SLEEP_EXIT_ACCEPT_GTK_UPDATE = 1,
+	WNM_STATUS_DENIED_ACTION = 2,
+	WNM_STATUS_DENIED_TMP = 3,
+	WNM_STATUS_DENIED_KEY = 4,
+	WNM_STATUS_DENIED_OTHER_WNM_SERVICE = 5
+/* WNM-Sleep Mode subelement IDs */
+enum wnm_sleep_mode_subelement_id {
+	WNM_SLEEP_SUBELEM_GTK = 0,
+	WNM_SLEEP_SUBELEM_IGTK = 1
+/* Channel Switch modes (802.11h) */
+#define CHAN_SWITCH_MODE_ALLOW_TX	0
+#define CHAN_SWITCH_MODE_BLOCK_TX	1
+struct tpc_report {
+	u8 eid;
+	u8 len;
+	u8 tx_power;
+	u8 link_margin;
+} STRUCT_PACKED;
+/* IEEE Std 802.11-2012, 8.5.7.4 - Link Measurement Request frame format */
+struct rrm_link_measurement_request {
+	u8 dialog_token;
+	s8 tx_power;
+	s8 max_tp;
+	u8 variable[0];
+} STRUCT_PACKED;
+/* IEEE Std 802.11-2012, 8.5.7.5 - Link Measurement Report frame format */
+struct rrm_link_measurement_report {
+	u8 dialog_token;
+	struct tpc_report tpc;
+	u8 rx_ant_id;
+	u8 tx_ant_id;
+	u8 rcpi;
+	u8 rsni;
+	u8 variable[0];
+} STRUCT_PACKED;
+#define SSID_MAX_LEN 32
+/* IEEE Std 802.11ad-2012 - Multi-band element */
+struct multi_band_ie {
+	u8 eid; /* WLAN_EID_MULTI_BAND */
+	u8 len;
+	u8 mb_ctrl;
+	u8 band_id;
+	u8 op_class;
+	u8 chan;
+	u8 bssid[ETH_ALEN];
+	le16 beacon_int;
+	u8 tsf_offs[8];
+	u8 mb_connection_capability;
+	u8 fst_session_tmout;
+	/* Optional:
+	 *   STA MAC Address
+	 *   Pairwise Cipher Suite Count
+	 *   Pairwise Cipher Suite List
+	u8 variable[0];
+} STRUCT_PACKED;
+enum mb_ctrl_sta_role {
+	MB_STA_ROLE_AP = 0,
+	MB_STA_ROLE_TDLS_STA = 1,
+	MB_STA_ROLE_IBSS_STA = 2,
+	MB_STA_ROLE_PCP = 3,
+	MB_STA_ROLE_NON_PCP_NON_AP = 4
+#define MB_CTRL_ROLE_MASK (BIT(0) | BIT(1) | BIT(2))
+#define MB_CTRL_ROLE(ctrl) ((u8) ((ctrl) & MB_CTRL_ROLE_MASK))
+#define MB_CTRL_STA_MAC_PRESENT ((u8) (BIT(3)))
+#define MB_CTRL_PAIRWISE_CIPHER_SUITE_PRESENT ((u8) (BIT(4)))
+enum mb_band_id {
+	MB_BAND_ID_WIFI_2_4GHZ = 2, /* 2.4 GHz */
+	MB_BAND_ID_WIFI_5GHZ = 4, /* 4.9 and 5 GHz */
+	MB_BAND_ID_WIFI_60GHZ = 5, /* 60 GHz */
+#define MB_CONNECTION_CAPABILITY_AP ((u8) (BIT(0)))
+#define MB_CONNECTION_CAPABILITY_PCP ((u8) (BIT(1)))
+#define MB_CONNECTION_CAPABILITY_DLS ((u8) (BIT(2)))
+#define MB_CONNECTION_CAPABILITY_TDLS ((u8) (BIT(3)))
+#define MB_CONNECTION_CAPABILITY_IBSS ((u8) (BIT(4)))
+/* IEEE Std 802.11ad-2014 - FST Action field */
+enum fst_action {
+	FST_ACTION_SETUP_REQUEST = 0,
+	FST_ACTION_SETUP_RESPONSE = 1,
+	FST_ACTION_TEAR_DOWN = 2,
+	FST_ACTION_ACK_REQUEST = 3,
+	FST_ACTION_ACK_RESPONSE = 4,
+	FST_ACTION_ON_CHANNEL_TUNNEL = 5,
+#endif /* IEEE802_11_DEFS_H */
diff --git a/freebsd/contrib/wpa/src/common/qca-vendor.h b/freebsd/contrib/wpa/src/common/qca-vendor.h
index 00000000000..28985f5194e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/qca-vendor.h
@@ -0,0 +1,357 @@
+ * Qualcomm Atheros OUI and vendor specific assignments
+ * Copyright (c) 2014-2015, Qualcomm Atheros, Inc.
+#ifndef QCA_VENDOR_H
+#define QCA_VENDOR_H
+ * This file is a registry of identifier assignments from the Qualcomm Atheros
+ * OUI 00:13:74 for purposes other than MAC address assignment. New identifiers
+ * can be assigned through normal review process for changes to the upstream
+ * hostap.git repository.
+#define OUI_QCA 0x001374
+ * enum qca_radiotap_vendor_ids - QCA radiotap vendor namespace IDs
+enum qca_radiotap_vendor_ids {
+	QCA_RADIOTAP_VID_WLANTEST = 0,
+ * enum qca_nl80211_vendor_subcmds - QCA nl80211 vendor command identifiers
+ * @QCA_NL80211_VENDOR_SUBCMD_UNSPEC: Reserved value 0
+ * @QCA_NL80211_VENDOR_SUBCMD_TEST: Test command/event
+ * @QCA_NL80211_VENDOR_SUBCMD_ROAMING: Set roaming policy for drivers that use
+ *	internal BSS-selection. This command uses
+ *	@QCA_WLAN_VENDOR_ATTR_ROAMING_POLICY to specify the new roaming policy
+ *	for the current connection (i.e., changes policy set by the nl80211
+ *	Connect command). @QCA_WLAN_VENDOR_ATTR_MAC_ADDR may optionally be
+ *	included to indicate which BSS to use in case roaming is disabled.
+ * @QCA_NL80211_VENDOR_SUBCMD_AVOID_FREQUENCY: Recommendation of frequency
+ *	ranges to avoid to reduce issues due to interference or internal
+ *	co-existence information in the driver. The event data structure is
+ *	defined in struct qca_avoid_freq_list.
+ * @QCA_NL80211_VENDOR_SUBCMD_DFS_CAPABILITY: Command to check driver support
+ *	for DFS offloading.
+ * @QCA_NL80211_VENDOR_SUBCMD_NAN: NAN command/event which is used to pass
+ *	NAN Request/Response and NAN Indication messages. These messages are
+ *	interpreted between the framework and the firmware component.
+ * @QCA_NL80211_VENDOR_SUBCMD_KEY_MGMT_SET_KEY: Set key operation that can be
+ *	used to configure PMK to the driver even when not connected. This can
+ *	be used to request offloading of key management operations. Only used
+ *	if device supports QCA_WLAN_VENDOR_FEATURE_KEY_MGMT_OFFLOAD.
+ * @QCA_NL80211_VENDOR_SUBCMD_KEY_MGMT_ROAM_AUTH: An extended version of
+ *	NL80211_CMD_ROAM event with optional attributes including information
+ *	from offloaded key management operation. Uses
+ *	enum qca_wlan_vendor_attr_roam_auth attributes. Only used
+ * @QCA_NL80211_VENDOR_SUBCMD_DO_ACS: ACS command/event which is used to
+ *	invoke the ACS function in device and pass selected channels to
+ *	hostapd.
+ * @QCA_NL80211_VENDOR_SUBCMD_GET_FEATURES: Command to get the features
+ *	supported by the driver. enum qca_wlan_vendor_features defines
+ *	the possible features.
+ * @QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_STARTED: Event used by driver,
+ *	which supports DFS offloading, to indicate a channel availability check
+ *	start.
+ * @QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_FINISHED: Event used by driver,
+ *	completion.
+ * @QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_ABORTED: Event used by driver,
+ *	which supports DFS offloading, to indicate that the channel availability
+ *	check aborted, no change to the channel status.
+ * @QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_NOP_FINISHED: Event used by
+ *	driver, which supports DFS offloading, to indicate that the
+ *	Non-Occupancy Period for this channel is over, channel becomes usable.
+ * @QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_RADAR_DETECTED: Event used by driver,
+ *	which supports DFS offloading, to indicate a radar pattern has been
+ *	detected. The channel is now unusable.
+enum qca_nl80211_vendor_subcmds {
+	QCA_NL80211_VENDOR_SUBCMD_UNSPEC = 0,
+	QCA_NL80211_VENDOR_SUBCMD_TEST = 1,
+	/* subcmds 2..8 not yet allocated */
+	QCA_NL80211_VENDOR_SUBCMD_ROAMING = 9,
+	QCA_NL80211_VENDOR_SUBCMD_AVOID_FREQUENCY = 10,
+	QCA_NL80211_VENDOR_SUBCMD_DFS_CAPABILITY =  11,
+	QCA_NL80211_VENDOR_SUBCMD_NAN =  12,
+	QCA_NL80211_VENDOR_SUBMCD_STATS_EXT = 13,
+	QCA_NL80211_VENDOR_SUBCMD_LL_STATS_SET = 14,
+	QCA_NL80211_VENDOR_SUBCMD_LL_STATS_GET = 15,
+	QCA_NL80211_VENDOR_SUBCMD_LL_STATS_CLR = 16,
+	QCA_NL80211_VENDOR_SUBCMD_LL_STATS_RADIO_RESULTS = 17,
+	QCA_NL80211_VENDOR_SUBCMD_LL_STATS_IFACE_RESULTS = 18,
+	QCA_NL80211_VENDOR_SUBCMD_LL_STATS_PEERS_RESULTS = 19,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_START = 20,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_STOP = 21,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_GET_VALID_CHANNELS = 22,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_GET_CAPABILITIES = 23,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_GET_CACHED_RESULTS = 24,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_SCAN_RESULTS_AVAILABLE = 25,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_FULL_SCAN_RESULT = 26,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_SCAN_EVENT = 27,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_HOTLIST_AP_FOUND = 28,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_SET_BSSID_HOTLIST = 29,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_RESET_BSSID_HOTLIST = 30,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_SIGNIFICANT_CHANGE = 31,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_SET_SIGNIFICANT_CHANGE = 32,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_RESET_SIGNIFICANT_CHANGE = 33,
+	QCA_NL80211_VENDOR_SUBCMD_TDLS_ENABLE = 34,
+	QCA_NL80211_VENDOR_SUBCMD_TDLS_DISABLE = 35,
+	QCA_NL80211_VENDOR_SUBCMD_TDLS_GET_STATUS = 36,
+	QCA_NL80211_VENDOR_SUBCMD_TDLS_STATE = 37,
+	QCA_NL80211_VENDOR_SUBCMD_GET_SUPPORTED_FEATURES = 38,
+	QCA_NL80211_VENDOR_SUBCMD_SCANNING_MAC_OUI = 39,
+	QCA_NL80211_VENDOR_SUBCMD_NO_DFS_FLAG = 40,
+	QCA_NL80211_VENDOR_SUBCMD_GSCAN_HOTLIST_AP_LOST = 41,
+	QCA_NL80211_VENDOR_SUBCMD_GET_CONCURRENCY_MATRIX = 42,
+	/* 43..49 - reserved for QCA */
+	QCA_NL80211_VENDOR_SUBCMD_KEY_MGMT_SET_KEY = 50,
+	QCA_NL80211_VENDOR_SUBCMD_KEY_MGMT_ROAM_AUTH = 51,
+	QCA_NL80211_VENDOR_SUBCMD_APFIND = 52,
+	/* 53 - reserved - was used by QCA, but not in use anymore */
+	QCA_NL80211_VENDOR_SUBCMD_DO_ACS = 54,
+	QCA_NL80211_VENDOR_SUBCMD_GET_FEATURES = 55,
+	QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_STARTED = 56,
+	QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_FINISHED = 57,
+	QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_ABORTED = 58,
+	QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_CAC_NOP_FINISHED = 59,
+	QCA_NL80211_VENDOR_SUBCMD_DFS_OFFLOAD_RADAR_DETECTED = 60,
+	/* 61-90 - reserved for QCA */
+	QCA_NL80211_VENDOR_SUBCMD_DATA_OFFLOAD = 91,
+	QCA_NL80211_VENDOR_SUBCMD_OCB_SET_CONFIG = 92,
+	QCA_NL80211_VENDOR_SUBCMD_OCB_SET_UTC_TIME = 93,
+	QCA_NL80211_VENDOR_SUBCMD_OCB_START_TIMING_ADVERT = 94,
+	QCA_NL80211_VENDOR_SUBCMD_OCB_STOP_TIMING_ADVERT = 95,
+	QCA_NL80211_VENDOR_SUBCMD_OCB_GET_TSF_TIMER = 96,
+	QCA_NL80211_VENDOR_SUBCMD_DCC_GET_STATS = 97,
+	QCA_NL80211_VENDOR_SUBCMD_DCC_CLEAR_STATS = 98,
+	QCA_NL80211_VENDOR_SUBCMD_DCC_UPDATE_NDL = 99,
+	QCA_NL80211_VENDOR_SUBCMD_DCC_STATS_EVENT = 100,
+	QCA_NL80211_VENDOR_SUBCMD_LINK_PROPERTIES = 101,
+	QCA_NL80211_VENDOR_SUBCMD_GW_PARAM_CONFIG = 102,
+	QCA_NL80211_VENDOR_SUBCMD_GET_PREFERRED_FREQ_LIST = 103,
+	QCA_NL80211_VENDOR_SUBCMD_SET_PROBABLE_OPER_CHANNEL = 104,
+	QCA_NL80211_VENDOR_SUBCMD_SETBAND = 105,
+enum qca_wlan_vendor_attr {
+	QCA_WLAN_VENDOR_ATTR_INVALID = 0,
+	/* used by QCA_NL80211_VENDOR_SUBCMD_DFS_CAPABILITY */
+	QCA_WLAN_VENDOR_ATTR_DFS     = 1,
+	/* used by QCA_NL80211_VENDOR_SUBCMD_NAN */
+	QCA_WLAN_VENDOR_ATTR_NAN     = 2,
+	/* used by QCA_NL80211_VENDOR_SUBCMD_STATS_EXT */
+	QCA_WLAN_VENDOR_ATTR_STATS_EXT     = 3,
+	QCA_WLAN_VENDOR_ATTR_IFINDEX     = 4,
+	/* used by QCA_NL80211_VENDOR_SUBCMD_ROAMING, u32 with values defined
+	 * by enum qca_roaming_policy. */
+	QCA_WLAN_VENDOR_ATTR_ROAMING_POLICY = 5,
+	QCA_WLAN_VENDOR_ATTR_MAC_ADDR = 6,
+	/* used by QCA_NL80211_VENDOR_SUBCMD_GET_FEATURES */
+	QCA_WLAN_VENDOR_ATTR_FEATURE_FLAGS = 7,
+	QCA_WLAN_VENDOR_ATTR_TEST = 8,
+	/* Unsigned 32-bit value. */
+	QCA_WLAN_VENDOR_ATTR_CONCURRENCY_CAPA = 9,
+	/* Unsigned 32-bit value */
+	QCA_WLAN_VENDOR_ATTR_MAX_CONCURRENT_CHANNELS_2_4_BAND = 10,
+	QCA_WLAN_VENDOR_ATTR_MAX_CONCURRENT_CHANNELS_5_0_BAND = 11,
+	/* Unsigned 32-bit value from enum qca_set_band. */
+	QCA_WLAN_VENDOR_ATTR_SETBAND_VALUE = 12,
+	/* keep last */
+	QCA_WLAN_VENDOR_ATTR_AFTER_LAST,
+	QCA_WLAN_VENDOR_ATTR_MAX	= QCA_WLAN_VENDOR_ATTR_AFTER_LAST - 1,
+enum qca_roaming_policy {
+	QCA_ROAMING_NOT_ALLOWED,
+	QCA_ROAMING_ALLOWED_WITHIN_ESS,
+enum qca_wlan_vendor_attr_roam_auth {
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_INVALID = 0,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_BSSID,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_REQ_IE,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_RESP_IE,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_AUTHORIZED,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_KEY_REPLAY_CTR,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_PTK_KCK,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_PTK_KEK,
+	/* keep last */
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_AFTER_LAST,
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_MAX =
+	QCA_WLAN_VENDOR_ATTR_ROAM_AUTH_AFTER_LAST - 1
+enum qca_wlan_vendor_attr_acs_offload {
+	QCA_WLAN_VENDOR_ATTR_ACS_CHANNEL_INVALID = 0,
+	QCA_WLAN_VENDOR_ATTR_ACS_PRIMARY_CHANNEL,
+	QCA_WLAN_VENDOR_ATTR_ACS_SECONDARY_CHANNEL,
+	QCA_WLAN_VENDOR_ATTR_ACS_HW_MODE,
+	QCA_WLAN_VENDOR_ATTR_ACS_HT_ENABLED,
+	QCA_WLAN_VENDOR_ATTR_ACS_HT40_ENABLED,
+	QCA_WLAN_VENDOR_ATTR_ACS_VHT_ENABLED,
+	QCA_WLAN_VENDOR_ATTR_ACS_CHWIDTH,
+	QCA_WLAN_VENDOR_ATTR_ACS_CH_LIST,
+	QCA_WLAN_VENDOR_ATTR_ACS_VHT_SEG0_CENTER_CHANNEL,
+	QCA_WLAN_VENDOR_ATTR_ACS_VHT_SEG1_CENTER_CHANNEL,
+	QCA_WLAN_VENDOR_ATTR_ACS_FREQ_LIST,
+	/* keep last */
+	QCA_WLAN_VENDOR_ATTR_ACS_AFTER_LAST,
+	QCA_WLAN_VENDOR_ATTR_ACS_MAX =
+	QCA_WLAN_VENDOR_ATTR_ACS_AFTER_LAST - 1
+enum qca_wlan_vendor_acs_hw_mode {
+	QCA_ACS_MODE_IEEE80211B,
+	QCA_ACS_MODE_IEEE80211G,
+	QCA_ACS_MODE_IEEE80211A,
+	QCA_ACS_MODE_IEEE80211AD,
+	QCA_ACS_MODE_IEEE80211ANY,
+ * enum qca_wlan_vendor_features - Vendor device/driver feature flags
+ * @QCA_WLAN_VENDOR_FEATURE_KEY_MGMT_OFFLOAD: Device supports key
+ *	management offload, a mechanism where the station's firmware
+ *	does the exchange with the AP to establish the temporal keys
+ *	after roaming, rather than having the user space wpa_supplicant do it.
+ * @QCA_WLAN_VENDOR_FEATURE_SUPPORT_HW_MODE_ANY: Device supports automatic
+ *	band selection based on channel selection results.
+ * @NUM_QCA_WLAN_VENDOR_FEATURES: Number of assigned feature bits
+enum qca_wlan_vendor_features {
+	QCA_WLAN_VENDOR_FEATURE_KEY_MGMT_OFFLOAD	= 0,
+	QCA_WLAN_VENDOR_FEATURE_SUPPORT_HW_MODE_ANY     = 1,
+	NUM_QCA_WLAN_VENDOR_FEATURES /* keep last */
+ * enum qca_wlan_vendor_attr_data_offload_ind - Vendor Data Offload Indication
+ * @QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_SESSION: Session corresponding to
+ *	the offloaded data.
+ * @QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_PROTOCOL: Protocol of the offloaded
+ *	data.
+ * @QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_EVENT: Event type for the data offload
+ *	indication.
+enum qca_wlan_vendor_attr_data_offload_ind {
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_INVALID = 0,
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_SESSION,
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_PROTOCOL,
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_EVENT,
+	/* keep last */
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_AFTER_LAST,
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_MAX =
+	QCA_WLAN_VENDOR_ATTR_DATA_OFFLOAD_IND_AFTER_LAST - 1
+enum qca_vendor_attr_get_preferred_freq_list {
+	QCA_WLAN_VENDOR_ATTR_GET_PREFERRED_FREQ_LIST_INVALID,
+	/* A 32-unsigned value; the interface type/mode for which the preferred
+	 * frequency list is requested (see enum qca_iface_type for possible
+	 * values); used in GET_PREFERRED_FREQ_LIST command from user-space to
+	 * kernel and in the kernel response back to user-space.
+	QCA_WLAN_VENDOR_ATTR_GET_PREFERRED_FREQ_LIST_IFACE_TYPE,
+	/* An array of 32-unsigned values; values are frequency (MHz); sent
+	 * from kernel space to user space.
+	QCA_WLAN_VENDOR_ATTR_GET_PREFERRED_FREQ_LIST,
+	/* keep last */
+	QCA_WLAN_VENDOR_ATTR_GET_PREFERRED_FREQ_LIST_AFTER_LAST,
+	QCA_WLAN_VENDOR_ATTR_GET_PREFERRED_FREQ_LIST_MAX =
+	QCA_WLAN_VENDOR_ATTR_GET_PREFERRED_FREQ_LIST_AFTER_LAST - 1
+enum qca_vendor_attr_probable_oper_channel {
+	QCA_WLAN_VENDOR_ATTR_PROBABLE_OPER_CHANNEL_INVALID,
+	/* 32-bit unsigned value; indicates the connection/iface type likely to
+	 * come on this channel (see enum qca_iface_type).
+	QCA_WLAN_VENDOR_ATTR_PROBABLE_OPER_CHANNEL_IFACE_TYPE,
+	/* 32-bit unsigned value; the frequency (MHz) of the probable channel */
+	QCA_WLAN_VENDOR_ATTR_PROBABLE_OPER_CHANNEL_FREQ,
+	/* keep last */
+	QCA_WLAN_VENDOR_ATTR_PROBABLE_OPER_CHANNEL_AFTER_LAST,
+	QCA_WLAN_VENDOR_ATTR_PROBABLE_OPER_CHANNEL_MAX =
+	QCA_WLAN_VENDOR_ATTR_PROBABLE_OPER_CHANNEL_AFTER_LAST - 1
+enum qca_iface_type {
+	QCA_IFACE_TYPE_STA,
+	QCA_IFACE_TYPE_AP,
+	QCA_IFACE_TYPE_P2P_CLIENT,
+	QCA_IFACE_TYPE_P2P_GO,
+	QCA_IFACE_TYPE_IBSS,
+	QCA_IFACE_TYPE_TDLS,
+enum qca_set_band {
+	QCA_SETBAND_AUTO,
+	QCA_SETBAND_5G,
+	QCA_SETBAND_2G,
+/* IEEE 802.11 Vendor Specific elements */
+ * enum qca_vendor_element_id - QCA Vendor Specific element types
+ * These values are used to identify QCA Vendor Specific elements. The
+ * payload of the element starts with the three octet OUI (OUI_QCA) and
+ * is followed by a single octet type which is defined by this enum.
+ * @QCA_VENDOR_ELEM_P2P_PREF_CHAN_LIST: P2P preferred channel list.
+ *	This element can be used to specify preference order for supported
+ *	channels. The channels in this list are in preference order (the first
+ *	one has the highest preference) and are described as a pair of
+ *	(global) Operating Class and Channel Number (each one octet) fields.
+ *	This extends the standard P2P functionality by providing option to have
+ *	more than one preferred operating channel. When this element is present,
+ *	it replaces the preference indicated in the Operating Channel attribute.
+ *	For supporting other implementations, the Operating Channel attribute is
+ *	expected to be used with the highest preference channel. Similarly, all
+ *	the channels included in this Preferred channel list element are
+ *	expected to be included in the Channel List attribute.
+ *	This vendor element may be included in GO Negotiation Request, P2P
+ *	Invitation Request, and Provision Discovery Request frames.
+enum qca_vendor_element_id {
+	QCA_VENDOR_ELEM_P2P_PREF_CHAN_LIST = 0,
+#endif /* QCA_VENDOR_H */
diff --git a/freebsd/contrib/wpa/src/common/sae.h b/freebsd/contrib/wpa/src/common/sae.h
new file mode 100644
index 00000000000..c07026cd497
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/sae.h
@@ -0,0 +1,70 @@
+ * Simultaneous authentication of equals
+ * Copyright (c) 2012-2013, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef SAE_H
+#define SAE_H
+#define SAE_KCK_LEN 32
+#define SAE_PMK_LEN 32
+#define SAE_PMKID_LEN 16
+#define SAE_KEYSEED_KEY_LEN 32
+#define SAE_MAX_PRIME_LEN 512
+#define SAE_MAX_ECC_PRIME_LEN 66
+#define SAE_COMMIT_MAX_LEN (2 + 3 * SAE_MAX_PRIME_LEN)
+#define SAE_CONFIRM_MAX_LEN (2 + SAE_MAX_PRIME_LEN)
+/* Special value returned by sae_parse_commit() */
+#define SAE_SILENTLY_DISCARD 65535
+struct sae_temporary_data {
+	u8 kck[SAE_KCK_LEN];
+	struct crypto_bignum *own_commit_scalar;
+	struct crypto_bignum *own_commit_element_ffc;
+	struct crypto_ec_point *own_commit_element_ecc;
+	struct crypto_bignum *peer_commit_element_ffc;
+	struct crypto_ec_point *peer_commit_element_ecc;
+	struct crypto_ec_point *pwe_ecc;
+	struct crypto_bignum *pwe_ffc;
+	struct crypto_bignum *sae_rand;
+	struct crypto_ec *ec;
+	int prime_len;
+	const struct dh_group *dh;
+	const struct crypto_bignum *prime;
+	const struct crypto_bignum *order;
+	struct crypto_bignum *prime_buf;
+	struct crypto_bignum *order_buf;
+	struct wpabuf *anti_clogging_token;
+struct sae_data {
+	enum { SAE_NOTHING, SAE_COMMITTED, SAE_CONFIRMED, SAE_ACCEPTED } state;
+	u16 send_confirm;
+	u8 pmk[SAE_PMK_LEN];
+	struct crypto_bignum *peer_commit_scalar;
+	int group;
+	int sync;
+	struct sae_temporary_data *tmp;
+int sae_set_group(struct sae_data *sae, int group);
+void sae_clear_temp_data(struct sae_data *sae);
+void sae_clear_data(struct sae_data *sae);
+int sae_prepare_commit(const u8 *addr1, const u8 *addr2,
+		       const u8 *password, size_t password_len,
+		       struct sae_data *sae);
+int sae_process_commit(struct sae_data *sae);
+void sae_write_commit(struct sae_data *sae, struct wpabuf *buf,
+		      const struct wpabuf *token);
+u16 sae_parse_commit(struct sae_data *sae, const u8 *data, size_t len,
+		     const u8 **token, size_t *token_len, int *allowed_groups);
+void sae_write_confirm(struct sae_data *sae, struct wpabuf *buf);
+int sae_check_confirm(struct sae_data *sae, const u8 *data, size_t len);
+u16 sae_group_allowed(struct sae_data *sae, int *allowed_groups, u16 group);
+#endif /* SAE_H */
diff --git a/freebsd/contrib/wpa/src/common/version.h b/freebsd/contrib/wpa/src/common/version.h
index 00000000000..a5cc5b7b5bc
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/version.h
@@ -0,0 +1,10 @@
+#ifndef VERSION_H
+#define VERSION_H
+#ifndef VERSION_STR_POSTFIX
+#define VERSION_STR_POSTFIX ""
+#endif /* VERSION_STR_POSTFIX */
+#define VERSION_STR "2.5" VERSION_STR_POSTFIX
+#endif /* VERSION_H */
diff --git a/freebsd/contrib/wpa/src/common/wpa_common.c b/freebsd/contrib/wpa/src/common/wpa_common.c
index 00000000000..f2c2d56d8bf
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/wpa_common.c
@@ -0,0 +1,1666 @@
+#include <machine/rtems-bsd-user-space.h>
+ * WPA/RSN - Shared functions for supplicant and authenticator
+ * Copyright (c) 2002-2015, Jouni Malinen <j at w1.fi>
+#include "includes.h"
+#include "common.h"
+#include "crypto/md5.h"
+#include "crypto/sha1.h"
+#include "crypto/sha256.h"
+#include "crypto/sha384.h"
+#include "crypto/aes_wrap.h"
+#include "crypto/crypto.h"
+#include "ieee802_11_defs.h"
+#include "defs.h"
+#include "wpa_common.h"
+static unsigned int wpa_kck_len(int akmp)
+	if (akmp == WPA_KEY_MGMT_IEEE8021X_SUITE_B_192)
+		return 24;
+	return 16;
+static unsigned int wpa_kek_len(int akmp)
+		return 32;
+	return 16;
+unsigned int wpa_mic_len(int akmp)
+		return 24;
+	return 16;
+ * wpa_eapol_key_mic - Calculate EAPOL-Key MIC
+ * @key: EAPOL-Key Key Confirmation Key (KCK)
+ * @key_len: KCK length in octets
+ * @akmp: WPA_KEY_MGMT_* used in key derivation
+ * @ver: Key descriptor version (WPA_KEY_INFO_TYPE_*)
+ * @buf: Pointer to the beginning of the EAPOL header (version field)
+ * @len: Length of the EAPOL frame (from EAPOL header to the end of the frame)
+ * @mic: Pointer to the buffer to which the EAPOL-Key MIC is written
+ * Returns: 0 on success, -1 on failure
+ * Calculate EAPOL-Key MIC for an EAPOL-Key packet. The EAPOL-Key MIC field has
+ * to be cleared (all zeroes) when calling this function.
+ * Note: 'IEEE Std 802.11i-2004 - 8.5.2 EAPOL-Key frames' has an error in the
+ * description of the Key MIC calculation. It includes packet data from the
+ * beginning of the EAPOL-Key header, not EAPOL header. This incorrect change
+ * happened during final editing of the standard and the correct behavior is
+ * defined in the last draft (IEEE 802.11i/D10).
+int wpa_eapol_key_mic(const u8 *key, size_t key_len, int akmp, int ver,
+		      const u8 *buf, size_t len, u8 *mic)
+	u8 hash[SHA384_MAC_LEN];
+	switch (ver) {
+#ifndef CONFIG_FIPS
+	case WPA_KEY_INFO_TYPE_HMAC_MD5_RC4:
+		return hmac_md5(key, key_len, buf, len, mic);
+#endif /* CONFIG_FIPS */
+	case WPA_KEY_INFO_TYPE_HMAC_SHA1_AES:
+		if (hmac_sha1(key, key_len, buf, len, hash))
+			return -1;
+		os_memcpy(mic, hash, MD5_MAC_LEN);
+		break;
+#if defined(CONFIG_IEEE80211R) || defined(CONFIG_IEEE80211W)
+	case WPA_KEY_INFO_TYPE_AES_128_CMAC:
+		return omac1_aes_128(key, buf, len, mic);
+#endif /* CONFIG_IEEE80211R || CONFIG_IEEE80211W */
+	case WPA_KEY_INFO_TYPE_AKM_DEFINED:
+		switch (akmp) {
+#ifdef CONFIG_HS20
+		case WPA_KEY_MGMT_OSEN:
+#endif /* CONFIG_HS20 */
+#ifdef CONFIG_SUITEB
+		case WPA_KEY_MGMT_IEEE8021X_SUITE_B:
+			if (hmac_sha256(key, key_len, buf, len, hash))
+				return -1;
+			break;
+#endif /* CONFIG_SUITEB */
+#ifdef CONFIG_SUITEB192
+		case WPA_KEY_MGMT_IEEE8021X_SUITE_B_192:
+			if (hmac_sha384(key, key_len, buf, len, hash))
+				return -1;
+			os_memcpy(mic, hash, 24);
+			break;
+#endif /* CONFIG_SUITEB192 */
+		default:
+			return -1;
+		break;
+	default:
+		return -1;
+	return 0;
+ * wpa_pmk_to_ptk - Calculate PTK from PMK, addresses, and nonces
+ * @pmk: Pairwise master key
+ * @pmk_len: Length of PMK
+ * @label: Label to use in derivation
+ * @addr1: AA or SA
+ * @addr2: SA or AA
+ * @nonce1: ANonce or SNonce
+ * @nonce2: SNonce or ANonce
+ * @ptk: Buffer for pairwise transient key
+ * @akmp: Negotiated AKM
+ * @cipher: Negotiated pairwise cipher
+ * IEEE Std 802.11i-2004 - 8.5.1.2 Pairwise key hierarchy
+ * PTK = PRF-X(PMK, "Pairwise key expansion",
+ *             Min(AA, SA) || Max(AA, SA) ||
+ *             Min(ANonce, SNonce) || Max(ANonce, SNonce))
+ * STK = PRF-X(SMK, "Peer key expansion",
+ *             Min(MAC_I, MAC_P) || Max(MAC_I, MAC_P) ||
+ *             Min(INonce, PNonce) || Max(INonce, PNonce))
+int wpa_pmk_to_ptk(const u8 *pmk, size_t pmk_len, const char *label,
+		   const u8 *addr1, const u8 *addr2,
+		   const u8 *nonce1, const u8 *nonce2,
+		   struct wpa_ptk *ptk, int akmp, int cipher)
+	u8 data[2 * ETH_ALEN + 2 * WPA_NONCE_LEN];
+	u8 tmp[WPA_KCK_MAX_LEN + WPA_KEK_MAX_LEN + WPA_TK_MAX_LEN];
+	size_t ptk_len;
+	if (os_memcmp(addr1, addr2, ETH_ALEN) < 0) {
+		os_memcpy(data, addr1, ETH_ALEN);
+		os_memcpy(data + ETH_ALEN, addr2, ETH_ALEN);
+	} else {
+		os_memcpy(data, addr2, ETH_ALEN);
+		os_memcpy(data + ETH_ALEN, addr1, ETH_ALEN);
+	if (os_memcmp(nonce1, nonce2, WPA_NONCE_LEN) < 0) {
+		os_memcpy(data + 2 * ETH_ALEN, nonce1, WPA_NONCE_LEN);
+		os_memcpy(data + 2 * ETH_ALEN + WPA_NONCE_LEN, nonce2,
+			  WPA_NONCE_LEN);
+	} else {
+		os_memcpy(data + 2 * ETH_ALEN, nonce2, WPA_NONCE_LEN);
+		os_memcpy(data + 2 * ETH_ALEN + WPA_NONCE_LEN, nonce1,
+			  WPA_NONCE_LEN);
+	ptk->kck_len = wpa_kck_len(akmp);
+	ptk->kek_len = wpa_kek_len(akmp);
+	ptk->tk_len = wpa_cipher_key_len(cipher);
+	ptk_len = ptk->kck_len + ptk->kek_len + ptk->tk_len;
+	if (wpa_key_mgmt_sha384(akmp))
+		sha384_prf(pmk, pmk_len, label, data, sizeof(data),
+			   tmp, ptk_len);
+	else
+#ifdef CONFIG_IEEE80211W
+	if (wpa_key_mgmt_sha256(akmp))
+		sha256_prf(pmk, pmk_len, label, data, sizeof(data),
+			   tmp, ptk_len);
+	else
+#endif /* CONFIG_IEEE80211W */
+		sha1_prf(pmk, pmk_len, label, data, sizeof(data), tmp, ptk_len);
+	wpa_printf(MSG_DEBUG, "WPA: PTK derivation - A1=" MACSTR " A2=" MACSTR,
+		   MAC2STR(addr1), MAC2STR(addr2));
+	wpa_hexdump(MSG_DEBUG, "WPA: Nonce1", nonce1, WPA_NONCE_LEN);
+	wpa_hexdump(MSG_DEBUG, "WPA: Nonce2", nonce2, WPA_NONCE_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "WPA: PMK", pmk, pmk_len);
+	wpa_hexdump_key(MSG_DEBUG, "WPA: PTK", tmp, ptk_len);
+	os_memcpy(ptk->kck, tmp, ptk->kck_len);
+	wpa_hexdump_key(MSG_DEBUG, "WPA: KCK", ptk->kck, ptk->kck_len);
+	os_memcpy(ptk->kek, tmp + ptk->kck_len, ptk->kek_len);
+	wpa_hexdump_key(MSG_DEBUG, "WPA: KEK", ptk->kek, ptk->kek_len);
+	os_memcpy(ptk->tk, tmp + ptk->kck_len + ptk->kek_len, ptk->tk_len);
+	wpa_hexdump_key(MSG_DEBUG, "WPA: TK", ptk->tk, ptk->tk_len);
+	os_memset(tmp, 0, sizeof(tmp));
+	return 0;
+#ifdef CONFIG_IEEE80211R
+int wpa_ft_mic(const u8 *kck, size_t kck_len, const u8 *sta_addr,
+	       const u8 *ap_addr, u8 transaction_seqnum,
+	       const u8 *mdie, size_t mdie_len,
+	       const u8 *ftie, size_t ftie_len,
+	       const u8 *rsnie, size_t rsnie_len,
+	       const u8 *ric, size_t ric_len, u8 *mic)
+	const u8 *addr[9];
+	size_t len[9];
+	size_t i, num_elem = 0;
+	u8 zero_mic[16];
+	if (kck_len != 16) {
+		wpa_printf(MSG_WARNING, "FT: Unsupported KCK length %u",
+			   (unsigned int) kck_len);
+		return -1;
+	addr[num_elem] = sta_addr;
+	len[num_elem] = ETH_ALEN;
+	num_elem++;
+	addr[num_elem] = ap_addr;
+	num_elem++;
+	addr[num_elem] = &transaction_seqnum;
+	len[num_elem] = 1;
+	num_elem++;
+	if (rsnie) {
+		addr[num_elem] = rsnie;
+		len[num_elem] = rsnie_len;
+		num_elem++;
+	if (mdie) {
+		addr[num_elem] = mdie;
+		len[num_elem] = mdie_len;
+		num_elem++;
+	if (ftie) {
+		if (ftie_len < 2 + sizeof(struct rsn_ftie))
+			return -1;
+		/* IE hdr and mic_control */
+		addr[num_elem] = ftie;
+		len[num_elem] = 2 + 2;
+		num_elem++;
+		/* MIC field with all zeros */
+		os_memset(zero_mic, 0, sizeof(zero_mic));
+		addr[num_elem] = zero_mic;
+		len[num_elem] = sizeof(zero_mic);
+		num_elem++;
+		/* Rest of FTIE */
+		addr[num_elem] = ftie + 2 + 2 + 16;
+		len[num_elem] = ftie_len - (2 + 2 + 16);
+		num_elem++;
+	if (ric) {
+		addr[num_elem] = ric;
+		len[num_elem] = ric_len;
+		num_elem++;
+	for (i = 0; i < num_elem; i++)
+		wpa_hexdump(MSG_MSGDUMP, "FT: MIC data", addr[i], len[i]);
+	if (omac1_aes_128_vector(kck, num_elem, addr, len, mic))
+		return -1;
+	return 0;
+static int wpa_ft_parse_ftie(const u8 *ie, size_t ie_len,
+			     struct wpa_ft_ies *parse)
+	const u8 *end, *pos;
+	parse->ftie = ie;
+	parse->ftie_len = ie_len;
+	pos = ie + sizeof(struct rsn_ftie);
+	end = ie + ie_len;
+	while (pos + 2 <= end && pos + 2 + pos[1] <= end) {
+		switch (pos[0]) {
+		case FTIE_SUBELEM_R1KH_ID:
+			if (pos[1] != FT_R1KH_ID_LEN) {
+				wpa_printf(MSG_DEBUG, "FT: Invalid R1KH-ID "
+					   "length in FTIE: %d", pos[1]);
+				return -1;
+			parse->r1kh_id = pos + 2;
+			break;
+		case FTIE_SUBELEM_GTK:
+			parse->gtk = pos + 2;
+			parse->gtk_len = pos[1];
+			break;
+		case FTIE_SUBELEM_R0KH_ID:
+			if (pos[1] < 1 || pos[1] > FT_R0KH_ID_MAX_LEN) {
+				wpa_printf(MSG_DEBUG, "FT: Invalid R0KH-ID "
+				return -1;
+			parse->r0kh_id = pos + 2;
+			parse->r0kh_id_len = pos[1];
+			break;
+		case FTIE_SUBELEM_IGTK:
+			parse->igtk = pos + 2;
+			parse->igtk_len = pos[1];
+			break;
+		pos += 2 + pos[1];
+	return 0;
+int wpa_ft_parse_ies(const u8 *ies, size_t ies_len,
+	struct wpa_ie_data data;
+	int ret;
+	const struct rsn_ftie *ftie;
+	int prot_ie_count = 0;
+	os_memset(parse, 0, sizeof(*parse));
+	if (ies == NULL)
+		return 0;
+	pos = ies;
+	end = ies + ies_len;
+		switch (pos[0]) {
+		case WLAN_EID_RSN:
+			parse->rsn = pos + 2;
+			parse->rsn_len = pos[1];
+			ret = wpa_parse_wpa_ie_rsn(parse->rsn - 2,
+						   parse->rsn_len + 2,
+						   &data);
+			if (ret < 0) {
+				wpa_printf(MSG_DEBUG, "FT: Failed to parse "
+					   "RSN IE: %d", ret);
+				return -1;
+			if (data.num_pmkid == 1 && data.pmkid)
+				parse->rsn_pmkid = data.pmkid;
+			break;
+		case WLAN_EID_MOBILITY_DOMAIN:
+			if (pos[1] < sizeof(struct rsn_mdie))
+				return -1;
+			parse->mdie = pos + 2;
+			parse->mdie_len = pos[1];
+			break;
+		case WLAN_EID_FAST_BSS_TRANSITION:
+			if (pos[1] < sizeof(*ftie))
+				return -1;
+			ftie = (const struct rsn_ftie *) (pos + 2);
+			prot_ie_count = ftie->mic_control[1];
+			if (wpa_ft_parse_ftie(pos + 2, pos[1], parse) < 0)
+				return -1;
+			break;
+		case WLAN_EID_TIMEOUT_INTERVAL:
+			if (pos[1] != 5)
+				break;
+			parse->tie = pos + 2;
+			parse->tie_len = pos[1];
+			break;
+		case WLAN_EID_RIC_DATA:
+			if (parse->ric == NULL)
+				parse->ric = pos;
+			break;
+	if (prot_ie_count == 0)
+		return 0; /* no MIC */
+	 * Check that the protected IE count matches with IEs included in the
+	 * frame.
+	if (parse->rsn)
+		prot_ie_count--;
+	if (parse->mdie)
+		prot_ie_count--;
+	if (parse->ftie)
+		prot_ie_count--;
+	if (prot_ie_count < 0) {
+		wpa_printf(MSG_DEBUG, "FT: Some required IEs not included in "
+			   "the protected IE count");
+		return -1;
+	if (prot_ie_count == 0 && parse->ric) {
+		wpa_printf(MSG_DEBUG, "FT: RIC IE(s) in the frame, but not "
+			   "included in protected IE count");
+		return -1;
+	/* Determine the end of the RIC IE(s) */
+	pos = parse->ric;
+	while (pos && pos + 2 <= end && pos + 2 + pos[1] <= end &&
+	       prot_ie_count) {
+		prot_ie_count--;
+	parse->ric_len = pos - parse->ric;
+	if (prot_ie_count) {
+		wpa_printf(MSG_DEBUG, "FT: %d protected IEs missing from "
+			   "frame", (int) prot_ie_count);
+		return -1;
+	return 0;
+#endif /* CONFIG_IEEE80211R */
+static int rsn_selector_to_bitfield(const u8 *s)
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_NONE)
+		return WPA_CIPHER_NONE;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_TKIP)
+		return WPA_CIPHER_TKIP;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_CCMP)
+		return WPA_CIPHER_CCMP;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_AES_128_CMAC)
+		return WPA_CIPHER_AES_128_CMAC;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_GCMP)
+		return WPA_CIPHER_GCMP;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_CCMP_256)
+		return WPA_CIPHER_CCMP_256;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_GCMP_256)
+		return WPA_CIPHER_GCMP_256;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_BIP_GMAC_128)
+		return WPA_CIPHER_BIP_GMAC_128;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_BIP_GMAC_256)
+		return WPA_CIPHER_BIP_GMAC_256;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_BIP_CMAC_256)
+		return WPA_CIPHER_BIP_CMAC_256;
+	if (RSN_SELECTOR_GET(s) == RSN_CIPHER_SUITE_NO_GROUP_ADDRESSED)
+		return WPA_CIPHER_GTK_NOT_USED;
+	return 0;
+static int rsn_key_mgmt_to_bitfield(const u8 *s)
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_UNSPEC_802_1X)
+		return WPA_KEY_MGMT_IEEE8021X;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_PSK_OVER_802_1X)
+		return WPA_KEY_MGMT_PSK;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_FT_802_1X)
+		return WPA_KEY_MGMT_FT_IEEE8021X;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_FT_PSK)
+		return WPA_KEY_MGMT_FT_PSK;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_802_1X_SHA256)
+		return WPA_KEY_MGMT_IEEE8021X_SHA256;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_PSK_SHA256)
+		return WPA_KEY_MGMT_PSK_SHA256;
+#ifdef CONFIG_SAE
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_SAE)
+		return WPA_KEY_MGMT_SAE;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_FT_SAE)
+		return WPA_KEY_MGMT_FT_SAE;
+#endif /* CONFIG_SAE */
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_802_1X_SUITE_B)
+		return WPA_KEY_MGMT_IEEE8021X_SUITE_B;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_802_1X_SUITE_B_192)
+		return WPA_KEY_MGMT_IEEE8021X_SUITE_B_192;
+	if (RSN_SELECTOR_GET(s) == RSN_AUTH_KEY_MGMT_OSEN)
+		return WPA_KEY_MGMT_OSEN;
+	return 0;
+int wpa_cipher_valid_group(int cipher)
+	return wpa_cipher_valid_pairwise(cipher) ||
+		cipher == WPA_CIPHER_GTK_NOT_USED;
+int wpa_cipher_valid_mgmt_group(int cipher)
+	return cipher == WPA_CIPHER_AES_128_CMAC ||
+		cipher == WPA_CIPHER_BIP_GMAC_128 ||
+		cipher == WPA_CIPHER_BIP_GMAC_256 ||
+		cipher == WPA_CIPHER_BIP_CMAC_256;
+ * wpa_parse_wpa_ie_rsn - Parse RSN IE
+ * @rsn_ie: Buffer containing RSN IE
+ * @rsn_ie_len: RSN IE buffer length (including IE number and length octets)
+ * @data: Pointer to structure that will be filled in with parsed data
+ * Returns: 0 on success, <0 on failure
+int wpa_parse_wpa_ie_rsn(const u8 *rsn_ie, size_t rsn_ie_len,
+			 struct wpa_ie_data *data)
+	const u8 *pos;
+	int left;
+	int i, count;
+	os_memset(data, 0, sizeof(*data));
+	data->proto = WPA_PROTO_RSN;
+	data->pairwise_cipher = WPA_CIPHER_CCMP;
+	data->group_cipher = WPA_CIPHER_CCMP;
+	data->key_mgmt = WPA_KEY_MGMT_IEEE8021X;
+	data->capabilities = 0;
+	data->pmkid = NULL;
+	data->num_pmkid = 0;
+	data->mgmt_group_cipher = WPA_CIPHER_AES_128_CMAC;
+#else /* CONFIG_IEEE80211W */
+	data->mgmt_group_cipher = 0;
+	if (rsn_ie_len == 0) {
+		/* No RSN IE - fail silently */
+		return -1;
+	if (rsn_ie_len < sizeof(struct rsn_ie_hdr)) {
+		wpa_printf(MSG_DEBUG, "%s: ie len too short %lu",
+			   __func__, (unsigned long) rsn_ie_len);
+		return -1;
+	if (rsn_ie_len >= 6 && rsn_ie[1] >= 4 &&
+	    rsn_ie[1] == rsn_ie_len - 2 &&
+	    WPA_GET_BE32(&rsn_ie[2]) == OSEN_IE_VENDOR_TYPE) {
+		pos = rsn_ie + 6;
+		left = rsn_ie_len - 6;
+		data->proto = WPA_PROTO_OSEN;
+	} else {
+		const struct rsn_ie_hdr *hdr;
+		hdr = (const struct rsn_ie_hdr *) rsn_ie;
+		if (hdr->elem_id != WLAN_EID_RSN ||
+		    hdr->len != rsn_ie_len - 2 ||
+		    WPA_GET_LE16(hdr->version) != RSN_VERSION) {
+			wpa_printf(MSG_DEBUG, "%s: malformed ie or unknown version",
+				   __func__);
+			return -2;
+		pos = (const u8 *) (hdr + 1);
+		left = rsn_ie_len - sizeof(*hdr);
+	if (left >= RSN_SELECTOR_LEN) {
+		data->group_cipher = rsn_selector_to_bitfield(pos);
+		if (!wpa_cipher_valid_group(data->group_cipher)) {
+			wpa_printf(MSG_DEBUG, "%s: invalid group cipher 0x%x",
+				   __func__, data->group_cipher);
+			return -1;
+		pos += RSN_SELECTOR_LEN;
+		left -= RSN_SELECTOR_LEN;
+	} else if (left > 0) {
+		wpa_printf(MSG_DEBUG, "%s: ie length mismatch, %u too much",
+			   __func__, left);
+		return -3;
+	if (left >= 2) {
+		data->pairwise_cipher = 0;
+		count = WPA_GET_LE16(pos);
+		pos += 2;
+		left -= 2;
+		if (count == 0 || count > left / RSN_SELECTOR_LEN) {
+			wpa_printf(MSG_DEBUG, "%s: ie count botch (pairwise), "
+				   "count %u left %u", __func__, count, left);
+			return -4;
+		for (i = 0; i < count; i++) {
+			data->pairwise_cipher |= rsn_selector_to_bitfield(pos);
+		if (data->pairwise_cipher & WPA_CIPHER_AES_128_CMAC) {
+			wpa_printf(MSG_DEBUG, "%s: AES-128-CMAC used as "
+				   "pairwise cipher", __func__);
+			return -1;
+	} else if (left == 1) {
+		wpa_printf(MSG_DEBUG, "%s: ie too short (for key mgmt)",
+			   __func__);
+		return -5;
+	if (left >= 2) {
+		data->key_mgmt = 0;
+		pos += 2;
+		left -= 2;
+			wpa_printf(MSG_DEBUG, "%s: ie count botch (key mgmt), "
+			return -6;
+			data->key_mgmt |= rsn_key_mgmt_to_bitfield(pos);
+		wpa_printf(MSG_DEBUG, "%s: ie too short (for capabilities)",
+			   __func__);
+		return -7;
+	if (left >= 2) {
+		data->capabilities = WPA_GET_LE16(pos);
+		pos += 2;
+		left -= 2;
+	if (left >= 2) {
+		u16 num_pmkid = WPA_GET_LE16(pos);
+		pos += 2;
+		left -= 2;
+		if (num_pmkid > (unsigned int) left / PMKID_LEN) {
+			wpa_printf(MSG_DEBUG, "%s: PMKID underflow "
+				   "(num_pmkid=%u left=%d)",
+				   __func__, num_pmkid, left);
+			return -9;
+		} else {
+			data->num_pmkid = num_pmkid;
+			data->pmkid = pos;
+			pos += data->num_pmkid * PMKID_LEN;
+			left -= data->num_pmkid * PMKID_LEN;
+	if (left >= 4) {
+		data->mgmt_group_cipher = rsn_selector_to_bitfield(pos);
+		if (!wpa_cipher_valid_mgmt_group(data->mgmt_group_cipher)) {
+			wpa_printf(MSG_DEBUG, "%s: Unsupported management "
+				   "group cipher 0x%x", __func__,
+				   data->mgmt_group_cipher);
+			return -10;
+	if (left > 0) {
+			    "wpa_parse_wpa_ie_rsn: ignore trailing bytes",
+			    pos, left);
+	return 0;
+static int wpa_selector_to_bitfield(const u8 *s)
+	if (RSN_SELECTOR_GET(s) == WPA_CIPHER_SUITE_NONE)
+	if (RSN_SELECTOR_GET(s) == WPA_CIPHER_SUITE_TKIP)
+	if (RSN_SELECTOR_GET(s) == WPA_CIPHER_SUITE_CCMP)
+	return 0;
+static int wpa_key_mgmt_to_bitfield(const u8 *s)
+	if (RSN_SELECTOR_GET(s) == WPA_AUTH_KEY_MGMT_UNSPEC_802_1X)
+	if (RSN_SELECTOR_GET(s) == WPA_AUTH_KEY_MGMT_PSK_OVER_802_1X)
+	if (RSN_SELECTOR_GET(s) == WPA_AUTH_KEY_MGMT_NONE)
+		return WPA_KEY_MGMT_WPA_NONE;
+	return 0;
+int wpa_parse_wpa_ie_wpa(const u8 *wpa_ie, size_t wpa_ie_len,
+	const struct wpa_ie_hdr *hdr;
+	const u8 *pos;
+	int left;
+	int i, count;
+	data->proto = WPA_PROTO_WPA;
+	data->pairwise_cipher = WPA_CIPHER_TKIP;
+	data->group_cipher = WPA_CIPHER_TKIP;
+	if (wpa_ie_len < sizeof(struct wpa_ie_hdr)) {
+			   __func__, (unsigned long) wpa_ie_len);
+		return -1;
+	hdr = (const struct wpa_ie_hdr *) wpa_ie;
+	if (hdr->elem_id != WLAN_EID_VENDOR_SPECIFIC ||
+	    hdr->len != wpa_ie_len - 2 ||
+	    RSN_SELECTOR_GET(hdr->oui) != WPA_OUI_TYPE ||
+	    WPA_GET_LE16(hdr->version) != WPA_VERSION) {
+			   __func__);
+		return -2;
+	left = wpa_ie_len - sizeof(*hdr);
+	if (left >= WPA_SELECTOR_LEN) {
+		data->group_cipher = wpa_selector_to_bitfield(pos);
+		pos += WPA_SELECTOR_LEN;
+		left -= WPA_SELECTOR_LEN;
+			   __func__, left);
+		return -3;
+	if (left >= 2) {
+		pos += 2;
+		left -= 2;
+		if (count == 0 || count > left / WPA_SELECTOR_LEN) {
+			return -4;
+			data->pairwise_cipher |= wpa_selector_to_bitfield(pos);
+			   __func__);
+		return -5;
+	if (left >= 2) {
+		pos += 2;
+		left -= 2;
+			return -6;
+			data->key_mgmt |= wpa_key_mgmt_to_bitfield(pos);
+			   __func__);
+		return -7;
+	if (left >= 2) {
+		pos += 2;
+		left -= 2;
+	if (left > 0) {
+			    "wpa_parse_wpa_ie_wpa: ignore trailing bytes",
+			    pos, left);
+	return 0;
+ * wpa_derive_pmk_r0 - Derive PMK-R0 and PMKR0Name
+ * IEEE Std 802.11r-2008 - 8.5.1.5.3
+void wpa_derive_pmk_r0(const u8 *xxkey, size_t xxkey_len,
+		       const u8 *ssid, size_t ssid_len,
+		       const u8 *mdid, const u8 *r0kh_id, size_t r0kh_id_len,
+		       const u8 *s0kh_id, u8 *pmk_r0, u8 *pmk_r0_name)
+	u8 buf[1 + SSID_MAX_LEN + MOBILITY_DOMAIN_ID_LEN + 1 +
+	       FT_R0KH_ID_MAX_LEN + ETH_ALEN];
+	u8 *pos, r0_key_data[48], hash[32];
+	const u8 *addr[2];
+	size_t len[2];
+	 * R0-Key-Data = KDF-384(XXKey, "FT-R0",
+	 *                       SSIDlength || SSID || MDID || R0KHlength ||
+	 *                       R0KH-ID || S0KH-ID)
+	 * XXKey is either the second 256 bits of MSK or PSK.
+	 * PMK-R0 = L(R0-Key-Data, 0, 256)
+	 * PMK-R0Name-Salt = L(R0-Key-Data, 256, 128)
+	if (ssid_len > SSID_MAX_LEN || r0kh_id_len > FT_R0KH_ID_MAX_LEN)
+		return;
+	pos = buf;
+	*pos++ = ssid_len;
+	os_memcpy(pos, ssid, ssid_len);
+	pos += ssid_len;
+	os_memcpy(pos, mdid, MOBILITY_DOMAIN_ID_LEN);
+	pos += MOBILITY_DOMAIN_ID_LEN;
+	*pos++ = r0kh_id_len;
+	os_memcpy(pos, r0kh_id, r0kh_id_len);
+	pos += r0kh_id_len;
+	os_memcpy(pos, s0kh_id, ETH_ALEN);
+	pos += ETH_ALEN;
+	sha256_prf(xxkey, xxkey_len, "FT-R0", buf, pos - buf,
+		   r0_key_data, sizeof(r0_key_data));
+	os_memcpy(pmk_r0, r0_key_data, PMK_LEN);
+	 * PMKR0Name = Truncate-128(SHA-256("FT-R0N" || PMK-R0Name-Salt)
+	addr[0] = (const u8 *) "FT-R0N";
+	len[0] = 6;
+	addr[1] = r0_key_data + PMK_LEN;
+	len[1] = 16;
+	sha256_vector(2, addr, len, hash);
+	os_memcpy(pmk_r0_name, hash, WPA_PMK_NAME_LEN);
+ * wpa_derive_pmk_r1_name - Derive PMKR1Name
+ * IEEE Std 802.11r-2008 - 8.5.1.5.4
+void wpa_derive_pmk_r1_name(const u8 *pmk_r0_name, const u8 *r1kh_id,
+			    const u8 *s1kh_id, u8 *pmk_r1_name)
+	u8 hash[32];
+	const u8 *addr[4];
+	size_t len[4];
+	 * PMKR1Name = Truncate-128(SHA-256("FT-R1N" || PMKR0Name ||
+	 *                                  R1KH-ID || S1KH-ID))
+	addr[0] = (const u8 *) "FT-R1N";
+	len[0] = 6;
+	addr[1] = pmk_r0_name;
+	len[1] = WPA_PMK_NAME_LEN;
+	addr[2] = r1kh_id;
+	len[2] = FT_R1KH_ID_LEN;
+	addr[3] = s1kh_id;
+	len[3] = ETH_ALEN;
+	sha256_vector(4, addr, len, hash);
+	os_memcpy(pmk_r1_name, hash, WPA_PMK_NAME_LEN);
+ * wpa_derive_pmk_r1 - Derive PMK-R1 and PMKR1Name from PMK-R0
+void wpa_derive_pmk_r1(const u8 *pmk_r0, const u8 *pmk_r0_name,
+		       const u8 *r1kh_id, const u8 *s1kh_id,
+		       u8 *pmk_r1, u8 *pmk_r1_name)
+	u8 buf[FT_R1KH_ID_LEN + ETH_ALEN];
+	u8 *pos;
+	/* PMK-R1 = KDF-256(PMK-R0, "FT-R1", R1KH-ID || S1KH-ID) */
+	pos = buf;
+	os_memcpy(pos, r1kh_id, FT_R1KH_ID_LEN);
+	pos += FT_R1KH_ID_LEN;
+	os_memcpy(pos, s1kh_id, ETH_ALEN);
+	pos += ETH_ALEN;
+	sha256_prf(pmk_r0, PMK_LEN, "FT-R1", buf, pos - buf, pmk_r1, PMK_LEN);
+	wpa_derive_pmk_r1_name(pmk_r0_name, r1kh_id, s1kh_id, pmk_r1_name);
+ * wpa_pmk_r1_to_ptk - Derive PTK and PTKName from PMK-R1
+ * IEEE Std 802.11r-2008 - 8.5.1.5.5
+int wpa_pmk_r1_to_ptk(const u8 *pmk_r1, const u8 *snonce, const u8 *anonce,
+		      const u8 *sta_addr, const u8 *bssid,
+		      const u8 *pmk_r1_name,
+		      struct wpa_ptk *ptk, u8 *ptk_name, int akmp, int cipher)
+	u8 buf[2 * WPA_NONCE_LEN + 2 * ETH_ALEN];
+	u8 *pos, hash[32];
+	const u8 *addr[6];
+	size_t len[6];
+	size_t ptk_len;
+	 * PTK = KDF-PTKLen(PMK-R1, "FT-PTK", SNonce || ANonce ||
+	 *                  BSSID || STA-ADDR)
+	pos = buf;
+	os_memcpy(pos, snonce, WPA_NONCE_LEN);
+	pos += WPA_NONCE_LEN;
+	os_memcpy(pos, anonce, WPA_NONCE_LEN);
+	os_memcpy(pos, bssid, ETH_ALEN);
+	pos += ETH_ALEN;
+	os_memcpy(pos, sta_addr, ETH_ALEN);
+	pos += ETH_ALEN;
+	sha256_prf(pmk_r1, PMK_LEN, "FT-PTK", buf, pos - buf, tmp, ptk_len);
+	 * PTKName = Truncate-128(SHA-256(PMKR1Name || "FT-PTKN" || SNonce ||
+	 *                                ANonce || BSSID || STA-ADDR))
+	addr[0] = pmk_r1_name;
+	len[0] = WPA_PMK_NAME_LEN;
+	addr[1] = (const u8 *) "FT-PTKN";
+	len[1] = 7;
+	addr[2] = snonce;
+	len[2] = WPA_NONCE_LEN;
+	addr[3] = anonce;
+	len[3] = WPA_NONCE_LEN;
+	addr[4] = bssid;
+	len[4] = ETH_ALEN;
+	addr[5] = sta_addr;
+	len[5] = ETH_ALEN;
+	sha256_vector(6, addr, len, hash);
+	os_memcpy(ptk_name, hash, WPA_PMK_NAME_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "FT: KCK", ptk->kck, ptk->kck_len);
+	wpa_hexdump_key(MSG_DEBUG, "FT: KEK", ptk->kek, ptk->kek_len);
+	wpa_hexdump_key(MSG_DEBUG, "FT: TK", ptk->tk, ptk->tk_len);
+	wpa_hexdump(MSG_DEBUG, "FT: PTKName", ptk_name, WPA_PMK_NAME_LEN);
+	return 0;
+ * rsn_pmkid - Calculate PMK identifier
+ * @pmk_len: Length of pmk in bytes
+ * @aa: Authenticator address
+ * @spa: Supplicant address
+ * @pmkid: Buffer for PMKID
+ * @use_sha256: Whether to use SHA256-based KDF
+ * PMKID = HMAC-SHA1-128(PMK, "PMK Name" || AA || SPA)
+void rsn_pmkid(const u8 *pmk, size_t pmk_len, const u8 *aa, const u8 *spa,
+	       u8 *pmkid, int use_sha256)
+	char *title = "PMK Name";
+	const u8 *addr[3];
+	const size_t len[3] = { 8, ETH_ALEN, ETH_ALEN };
+	unsigned char hash[SHA256_MAC_LEN];
+	addr[0] = (u8 *) title;
+	addr[1] = aa;
+	addr[2] = spa;
+	if (use_sha256)
+		hmac_sha256_vector(pmk, pmk_len, 3, addr, len, hash);
+	else
+		hmac_sha1_vector(pmk, pmk_len, 3, addr, len, hash);
+	os_memcpy(pmkid, hash, PMKID_LEN);
+ * rsn_pmkid_suite_b - Calculate PMK identifier for Suite B AKM
+ * @kck: Key confirmation key
+ * @kck_len: Length of kck in bytes
+ * IEEE Std 802.11ac-2013 - 11.6.1.3 Pairwise key hierarchy
+ * PMKID = Truncate(HMAC-SHA-256(KCK, "PMK Name" || AA || SPA))
+int rsn_pmkid_suite_b(const u8 *kck, size_t kck_len, const u8 *aa,
+		      const u8 *spa, u8 *pmkid)
+	addr[1] = aa;
+	addr[2] = spa;
+	if (hmac_sha256_vector(kck, kck_len, 3, addr, len, hash) < 0)
+		return -1;
+	return 0;
+ * rsn_pmkid_suite_b_192 - Calculate PMK identifier for Suite B AKM
+ * PMKID = Truncate(HMAC-SHA-384(KCK, "PMK Name" || AA || SPA))
+int rsn_pmkid_suite_b_192(const u8 *kck, size_t kck_len, const u8 *aa,
+	unsigned char hash[SHA384_MAC_LEN];
+	addr[1] = aa;
+	addr[2] = spa;
+	if (hmac_sha384_vector(kck, kck_len, 3, addr, len, hash) < 0)
+		return -1;
+	return 0;
+ * wpa_cipher_txt - Convert cipher suite to a text string
+ * @cipher: Cipher suite (WPA_CIPHER_* enum)
+ * Returns: Pointer to a text string of the cipher suite name
+const char * wpa_cipher_txt(int cipher)
+	switch (cipher) {
+	case WPA_CIPHER_NONE:
+		return "NONE";
+	case WPA_CIPHER_WEP40:
+		return "WEP-40";
+	case WPA_CIPHER_WEP104:
+		return "WEP-104";
+	case WPA_CIPHER_TKIP:
+		return "TKIP";
+	case WPA_CIPHER_CCMP:
+		return "CCMP";
+	case WPA_CIPHER_CCMP | WPA_CIPHER_TKIP:
+		return "CCMP+TKIP";
+	case WPA_CIPHER_GCMP:
+		return "GCMP";
+	case WPA_CIPHER_GCMP_256:
+		return "GCMP-256";
+	case WPA_CIPHER_CCMP_256:
+		return "CCMP-256";
+	case WPA_CIPHER_GTK_NOT_USED:
+		return "GTK_NOT_USED";
+	default:
+		return "UNKNOWN";
+ * wpa_key_mgmt_txt - Convert key management suite to a text string
+ * @key_mgmt: Key management suite (WPA_KEY_MGMT_* enum)
+ * @proto: WPA/WPA2 version (WPA_PROTO_*)
+ * Returns: Pointer to a text string of the key management suite name
+const char * wpa_key_mgmt_txt(int key_mgmt, int proto)
+	switch (key_mgmt) {
+	case WPA_KEY_MGMT_IEEE8021X:
+		if (proto == (WPA_PROTO_RSN | WPA_PROTO_WPA))
+			return "WPA2+WPA/IEEE 802.1X/EAP";
+		return proto == WPA_PROTO_RSN ?
+			"WPA2/IEEE 802.1X/EAP" : "WPA/IEEE 802.1X/EAP";
+	case WPA_KEY_MGMT_PSK:
+			return "WPA2-PSK+WPA-PSK";
+			"WPA2-PSK" : "WPA-PSK";
+	case WPA_KEY_MGMT_NONE:
+		return "NONE";
+	case WPA_KEY_MGMT_IEEE8021X_NO_WPA:
+		return "IEEE 802.1X (no WPA)";
+	case WPA_KEY_MGMT_FT_IEEE8021X:
+		return "FT-EAP";
+	case WPA_KEY_MGMT_FT_PSK:
+		return "FT-PSK";
+	case WPA_KEY_MGMT_IEEE8021X_SHA256:
+		return "WPA2-EAP-SHA256";
+	case WPA_KEY_MGMT_PSK_SHA256:
+		return "WPA2-PSK-SHA256";
+	case WPA_KEY_MGMT_WPS:
+		return "WPS";
+	case WPA_KEY_MGMT_SAE:
+		return "SAE";
+	case WPA_KEY_MGMT_FT_SAE:
+		return "FT-SAE";
+		return "OSEN";
+		return "WPA2-EAP-SUITE-B";
+		return "WPA2-EAP-SUITE-B-192";
+	default:
+		return "UNKNOWN";
+u32 wpa_akm_to_suite(int akm)
+	if (akm & WPA_KEY_MGMT_FT_IEEE8021X)
+		return WLAN_AKM_SUITE_FT_8021X;
+	if (akm & WPA_KEY_MGMT_FT_PSK)
+		return WLAN_AKM_SUITE_FT_PSK;
+	if (akm & WPA_KEY_MGMT_IEEE8021X)
+		return WLAN_AKM_SUITE_8021X;
+	if (akm & WPA_KEY_MGMT_IEEE8021X_SHA256)
+		return WLAN_AKM_SUITE_8021X_SHA256;
+	if (akm & WPA_KEY_MGMT_PSK_SHA256)
+		return WLAN_AKM_SUITE_PSK_SHA256;
+	if (akm & WPA_KEY_MGMT_PSK)
+		return WLAN_AKM_SUITE_PSK;
+	if (akm & WPA_KEY_MGMT_CCKM)
+		return WLAN_AKM_SUITE_CCKM;
+	if (akm & WPA_KEY_MGMT_OSEN)
+		return WLAN_AKM_SUITE_OSEN;
+	if (akm & WPA_KEY_MGMT_IEEE8021X_SUITE_B)
+		return WLAN_AKM_SUITE_8021X_SUITE_B;
+	if (akm & WPA_KEY_MGMT_IEEE8021X_SUITE_B_192)
+		return WLAN_AKM_SUITE_8021X_SUITE_B_192;
+	return 0;
+int wpa_compare_rsn_ie(int ft_initial_assoc,
+		       const u8 *ie1, size_t ie1len,
+		       const u8 *ie2, size_t ie2len)
+	if (ie1 == NULL || ie2 == NULL)
+		return -1;
+	if (ie1len == ie2len && os_memcmp(ie1, ie2, ie1len) == 0)
+		return 0; /* identical IEs */
+	if (ft_initial_assoc) {
+		struct wpa_ie_data ie1d, ie2d;
+		 * The PMKID-List in RSN IE is different between Beacon/Probe
+		 * Response/(Re)Association Request frames and EAPOL-Key
+		 * messages in FT initial mobility domain association. Allow
+		 * for this, but verify that other parts of the RSN IEs are
+		 * identical.
+		if (wpa_parse_wpa_ie_rsn(ie1, ie1len, &ie1d) < 0 ||
+		    wpa_parse_wpa_ie_rsn(ie2, ie2len, &ie2d) < 0)
+			return -1;
+		if (ie1d.proto == ie2d.proto &&
+		    ie1d.pairwise_cipher == ie2d.pairwise_cipher &&
+		    ie1d.group_cipher == ie2d.group_cipher &&
+		    ie1d.key_mgmt == ie2d.key_mgmt &&
+		    ie1d.capabilities == ie2d.capabilities &&
+		    ie1d.mgmt_group_cipher == ie2d.mgmt_group_cipher)
+			return 0;
+	return -1;
+int wpa_insert_pmkid(u8 *ies, size_t ies_len, const u8 *pmkid)
+	u8 *start, *end, *rpos, *rend;
+	int added = 0;
+	start = ies;
+	while (start < end) {
+		if (*start == WLAN_EID_RSN)
+			break;
+		start += 2 + start[1];
+	if (start >= end) {
+		wpa_printf(MSG_ERROR, "FT: Could not find RSN IE in "
+			   "IEs data");
+		return -1;
+	wpa_hexdump(MSG_DEBUG, "FT: RSN IE before modification",
+		    start, 2 + start[1]);
+	/* Find start of PMKID-Count */
+	rpos = start + 2;
+	rend = rpos + start[1];
+	/* Skip Version and Group Data Cipher Suite */
+	rpos += 2 + 4;
+	/* Skip Pairwise Cipher Suite Count and List */
+	rpos += 2 + WPA_GET_LE16(rpos) * RSN_SELECTOR_LEN;
+	/* Skip AKM Suite Count and List */
+	if (rpos == rend) {
+		/* Add RSN Capabilities */
+		os_memmove(rpos + 2, rpos, end - rpos);
+		*rpos++ = 0;
+		*rpos++ = 0;
+		added += 2;
+		start[1] += 2;
+		rend = rpos;
+	} else {
+		/* Skip RSN Capabilities */
+		rpos += 2;
+		if (rpos > rend) {
+			wpa_printf(MSG_ERROR, "FT: Could not parse RSN IE in "
+				   "IEs data");
+			return -1;
+		/* No PMKID-Count field included; add it */
+		os_memmove(rpos + 2 + PMKID_LEN, rpos, end + added - rpos);
+		WPA_PUT_LE16(rpos, 1);
+		rpos += 2;
+		os_memcpy(rpos, pmkid, PMKID_LEN);
+		added += 2 + PMKID_LEN;
+		start[1] += 2 + PMKID_LEN;
+	} else {
+		/* PMKID-Count was included; use it */
+		if (WPA_GET_LE16(rpos) != 0) {
+			wpa_printf(MSG_ERROR, "FT: Unexpected PMKID "
+				   "in RSN IE in EAPOL-Key data");
+			return -1;
+		rpos += 2;
+		os_memmove(rpos + PMKID_LEN, rpos, end + added - rpos);
+		added += PMKID_LEN;
+		start[1] += PMKID_LEN;
+	wpa_hexdump(MSG_DEBUG, "FT: RSN IE after modification "
+		    "(PMKID inserted)", start, 2 + start[1]);
+	return added;
+int wpa_cipher_key_len(int cipher)
+	switch (cipher) {
+	case WPA_CIPHER_BIP_GMAC_256:
+	case WPA_CIPHER_BIP_CMAC_256:
+		return 32;
+	case WPA_CIPHER_AES_128_CMAC:
+	case WPA_CIPHER_BIP_GMAC_128:
+		return 16;
+		return 32;
+	return 0;
+int wpa_cipher_rsc_len(int cipher)
+	switch (cipher) {
+		return 6;
+	return 0;
+int wpa_cipher_to_alg(int cipher)
+	switch (cipher) {
+		return WPA_ALG_CCMP_256;
+		return WPA_ALG_GCMP_256;
+		return WPA_ALG_CCMP;
+		return WPA_ALG_GCMP;
+		return WPA_ALG_TKIP;
+		return WPA_ALG_IGTK;
+		return WPA_ALG_BIP_GMAC_128;
+		return WPA_ALG_BIP_GMAC_256;
+		return WPA_ALG_BIP_CMAC_256;
+	return WPA_ALG_NONE;
+int wpa_cipher_valid_pairwise(int cipher)
+	return cipher == WPA_CIPHER_CCMP_256 ||
+		cipher == WPA_CIPHER_GCMP_256 ||
+		cipher == WPA_CIPHER_CCMP ||
+		cipher == WPA_CIPHER_GCMP ||
+		cipher == WPA_CIPHER_TKIP;
+u32 wpa_cipher_to_suite(int proto, int cipher)
+	if (cipher & WPA_CIPHER_CCMP_256)
+		return RSN_CIPHER_SUITE_CCMP_256;
+	if (cipher & WPA_CIPHER_GCMP_256)
+		return RSN_CIPHER_SUITE_GCMP_256;
+	if (cipher & WPA_CIPHER_CCMP)
+		return (proto == WPA_PROTO_RSN ?
+			RSN_CIPHER_SUITE_CCMP : WPA_CIPHER_SUITE_CCMP);
+	if (cipher & WPA_CIPHER_GCMP)
+		return RSN_CIPHER_SUITE_GCMP;
+	if (cipher & WPA_CIPHER_TKIP)
+			RSN_CIPHER_SUITE_TKIP : WPA_CIPHER_SUITE_TKIP);
+	if (cipher & WPA_CIPHER_NONE)
+			RSN_CIPHER_SUITE_NONE : WPA_CIPHER_SUITE_NONE);
+	if (cipher & WPA_CIPHER_GTK_NOT_USED)
+		return RSN_CIPHER_SUITE_NO_GROUP_ADDRESSED;
+	if (cipher & WPA_CIPHER_AES_128_CMAC)
+		return RSN_CIPHER_SUITE_AES_128_CMAC;
+	if (cipher & WPA_CIPHER_BIP_GMAC_128)
+		return RSN_CIPHER_SUITE_BIP_GMAC_128;
+	if (cipher & WPA_CIPHER_BIP_GMAC_256)
+		return RSN_CIPHER_SUITE_BIP_GMAC_256;
+	if (cipher & WPA_CIPHER_BIP_CMAC_256)
+		return RSN_CIPHER_SUITE_BIP_CMAC_256;
+	return 0;
+int rsn_cipher_put_suites(u8 *start, int ciphers)
+	u8 *pos = start;
+	if (ciphers & WPA_CIPHER_CCMP_256) {
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_CCMP_256);
+	if (ciphers & WPA_CIPHER_GCMP_256) {
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_GCMP_256);
+	if (ciphers & WPA_CIPHER_CCMP) {
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_CCMP);
+	if (ciphers & WPA_CIPHER_GCMP) {
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_GCMP);
+	if (ciphers & WPA_CIPHER_TKIP) {
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_TKIP);
+	if (ciphers & WPA_CIPHER_NONE) {
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_NONE);
+	return (pos - start) / RSN_SELECTOR_LEN;
+int wpa_cipher_put_suites(u8 *start, int ciphers)
+	u8 *pos = start;
+		RSN_SELECTOR_PUT(pos, WPA_CIPHER_SUITE_CCMP);
+		RSN_SELECTOR_PUT(pos, WPA_CIPHER_SUITE_TKIP);
+		RSN_SELECTOR_PUT(pos, WPA_CIPHER_SUITE_NONE);
+int wpa_pick_pairwise_cipher(int ciphers, int none_allowed)
+	if (none_allowed && (ciphers & WPA_CIPHER_NONE))
+	return -1;
+int wpa_pick_group_cipher(int ciphers)
+	if (ciphers & WPA_CIPHER_GTK_NOT_USED)
+	return -1;
+int wpa_parse_cipher(const char *value)
+	int val = 0, last;
+	char *start, *end, *buf;
+	buf = os_strdup(value);
+	if (buf == NULL)
+		return -1;
+	start = buf;
+	while (*start != '\0') {
+		while (*start == ' ' || *start == '\t')
+			start++;
+		if (*start == '\0')
+			break;
+		end = start;
+		while (*end != ' ' && *end != '\t' && *end != '\0')
+			end++;
+		last = *end == '\0';
+		*end = '\0';
+		if (os_strcmp(start, "CCMP-256") == 0)
+			val |= WPA_CIPHER_CCMP_256;
+		else if (os_strcmp(start, "GCMP-256") == 0)
+			val |= WPA_CIPHER_GCMP_256;
+		else if (os_strcmp(start, "CCMP") == 0)
+			val |= WPA_CIPHER_CCMP;
+		else if (os_strcmp(start, "GCMP") == 0)
+			val |= WPA_CIPHER_GCMP;
+		else if (os_strcmp(start, "TKIP") == 0)
+			val |= WPA_CIPHER_TKIP;
+		else if (os_strcmp(start, "WEP104") == 0)
+			val |= WPA_CIPHER_WEP104;
+		else if (os_strcmp(start, "WEP40") == 0)
+			val |= WPA_CIPHER_WEP40;
+		else if (os_strcmp(start, "NONE") == 0)
+			val |= WPA_CIPHER_NONE;
+		else if (os_strcmp(start, "GTK_NOT_USED") == 0)
+			val |= WPA_CIPHER_GTK_NOT_USED;
+		else {
+			os_free(buf);
+			return -1;
+		if (last)
+			break;
+		start = end + 1;
+	os_free(buf);
+	return val;
+int wpa_write_ciphers(char *start, char *end, int ciphers, const char *delim)
+	char *pos = start;
+	int ret;
+		ret = os_snprintf(pos, end - pos, "%sCCMP-256",
+				  pos == start ? "" : delim);
+		if (os_snprintf_error(end - pos, ret))
+			return -1;
+		pos += ret;
+		ret = os_snprintf(pos, end - pos, "%sGCMP-256",
+			return -1;
+		pos += ret;
+		ret = os_snprintf(pos, end - pos, "%sCCMP",
+			return -1;
+		pos += ret;
+		ret = os_snprintf(pos, end - pos, "%sGCMP",
+			return -1;
+		pos += ret;
+		ret = os_snprintf(pos, end - pos, "%sTKIP",
+			return -1;
+		pos += ret;
+		ret = os_snprintf(pos, end - pos, "%sNONE",
+			return -1;
+		pos += ret;
+	return pos - start;
+int wpa_select_ap_group_cipher(int wpa, int wpa_pairwise, int rsn_pairwise)
+	int pairwise = 0;
+	/* Select group cipher based on the enabled pairwise cipher suites */
+	if (wpa & 1)
+		pairwise |= wpa_pairwise;
+	if (wpa & 2)
+		pairwise |= rsn_pairwise;
+	if (pairwise & WPA_CIPHER_TKIP)
+	if ((pairwise & (WPA_CIPHER_CCMP | WPA_CIPHER_GCMP)) == WPA_CIPHER_GCMP)
+	if ((pairwise & (WPA_CIPHER_GCMP_256 | WPA_CIPHER_CCMP |
+			 WPA_CIPHER_GCMP)) == WPA_CIPHER_GCMP_256)
+	if ((pairwise & (WPA_CIPHER_CCMP_256 | WPA_CIPHER_CCMP |
+			 WPA_CIPHER_GCMP)) == WPA_CIPHER_CCMP_256)
diff --git a/freebsd/contrib/wpa/src/common/wpa_common.h b/freebsd/contrib/wpa/src/common/wpa_common.h
index 00000000000..c08f6514ab5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/wpa_common.h
@@ -0,0 +1,451 @@
+ * WPA definitions shared between hostapd and wpa_supplicant
+#ifndef WPA_COMMON_H
+#define WPA_COMMON_H
+/* IEEE 802.11i */
+#define PMKID_LEN 16
+#define PMK_LEN 32
+#define WPA_REPLAY_COUNTER_LEN 8
+#define WPA_NONCE_LEN 32
+#define WPA_KEY_RSC_LEN 8
+#define WPA_GMK_LEN 32
+#define WPA_GTK_MAX_LEN 32
+#define WPA_ALLOWED_PAIRWISE_CIPHERS \
+(WPA_CIPHER_CCMP | WPA_CIPHER_GCMP | WPA_CIPHER_TKIP | WPA_CIPHER_NONE | \
+WPA_CIPHER_GCMP_256 | WPA_CIPHER_CCMP_256)
+#define WPA_ALLOWED_GROUP_CIPHERS \
+(WPA_CIPHER_CCMP | WPA_CIPHER_GCMP | WPA_CIPHER_TKIP | \
+WPA_CIPHER_GCMP_256 | WPA_CIPHER_CCMP_256 | \
+WPA_CIPHER_GTK_NOT_USED)
+#define WPA_SELECTOR_LEN 4
+#define WPA_VERSION 1
+#define RSN_SELECTOR_LEN 4
+#define RSN_VERSION 1
+#define RSN_SELECTOR(a, b, c, d) \
+	((((u32) (a)) << 24) | (((u32) (b)) << 16) | (((u32) (c)) << 8) | \
+	 (u32) (d))
+#define WPA_AUTH_KEY_MGMT_NONE RSN_SELECTOR(0x00, 0x50, 0xf2, 0)
+#define WPA_AUTH_KEY_MGMT_UNSPEC_802_1X RSN_SELECTOR(0x00, 0x50, 0xf2, 1)
+#define WPA_AUTH_KEY_MGMT_PSK_OVER_802_1X RSN_SELECTOR(0x00, 0x50, 0xf2, 2)
+#define WPA_AUTH_KEY_MGMT_CCKM RSN_SELECTOR(0x00, 0x40, 0x96, 0)
+#define WPA_CIPHER_SUITE_NONE RSN_SELECTOR(0x00, 0x50, 0xf2, 0)
+#define WPA_CIPHER_SUITE_TKIP RSN_SELECTOR(0x00, 0x50, 0xf2, 2)
+#define WPA_CIPHER_SUITE_CCMP RSN_SELECTOR(0x00, 0x50, 0xf2, 4)
+#define RSN_AUTH_KEY_MGMT_UNSPEC_802_1X RSN_SELECTOR(0x00, 0x0f, 0xac, 1)
+#define RSN_AUTH_KEY_MGMT_PSK_OVER_802_1X RSN_SELECTOR(0x00, 0x0f, 0xac, 2)
+#define RSN_AUTH_KEY_MGMT_FT_802_1X RSN_SELECTOR(0x00, 0x0f, 0xac, 3)
+#define RSN_AUTH_KEY_MGMT_FT_PSK RSN_SELECTOR(0x00, 0x0f, 0xac, 4)
+#define RSN_AUTH_KEY_MGMT_802_1X_SHA256 RSN_SELECTOR(0x00, 0x0f, 0xac, 5)
+#define RSN_AUTH_KEY_MGMT_PSK_SHA256 RSN_SELECTOR(0x00, 0x0f, 0xac, 6)
+#define RSN_AUTH_KEY_MGMT_TPK_HANDSHAKE RSN_SELECTOR(0x00, 0x0f, 0xac, 7)
+#define RSN_AUTH_KEY_MGMT_SAE RSN_SELECTOR(0x00, 0x0f, 0xac, 8)
+#define RSN_AUTH_KEY_MGMT_FT_SAE RSN_SELECTOR(0x00, 0x0f, 0xac, 9)
+#define RSN_AUTH_KEY_MGMT_802_1X_SUITE_B RSN_SELECTOR(0x00, 0x0f, 0xac, 11)
+#define RSN_AUTH_KEY_MGMT_802_1X_SUITE_B_192 RSN_SELECTOR(0x00, 0x0f, 0xac, 12)
+#define RSN_AUTH_KEY_MGMT_FT_802_1X_SUITE_B_192 \
+RSN_SELECTOR(0x00, 0x0f, 0xac, 13)
+#define RSN_AUTH_KEY_MGMT_CCKM RSN_SELECTOR(0x00, 0x40, 0x96, 0x00)
+#define RSN_AUTH_KEY_MGMT_OSEN RSN_SELECTOR(0x50, 0x6f, 0x9a, 0x01)
+#define RSN_CIPHER_SUITE_NONE RSN_SELECTOR(0x00, 0x0f, 0xac, 0)
+#define RSN_CIPHER_SUITE_TKIP RSN_SELECTOR(0x00, 0x0f, 0xac, 2)
+#if 0
+#define RSN_CIPHER_SUITE_WRAP RSN_SELECTOR(0x00, 0x0f, 0xac, 3)
+#endif
+#define RSN_CIPHER_SUITE_CCMP RSN_SELECTOR(0x00, 0x0f, 0xac, 4)
+#define RSN_CIPHER_SUITE_AES_128_CMAC RSN_SELECTOR(0x00, 0x0f, 0xac, 6)
+#define RSN_CIPHER_SUITE_NO_GROUP_ADDRESSED RSN_SELECTOR(0x00, 0x0f, 0xac, 7)
+#define RSN_CIPHER_SUITE_GCMP RSN_SELECTOR(0x00, 0x0f, 0xac, 8)
+#define RSN_CIPHER_SUITE_GCMP_256 RSN_SELECTOR(0x00, 0x0f, 0xac, 9)
+#define RSN_CIPHER_SUITE_CCMP_256 RSN_SELECTOR(0x00, 0x0f, 0xac, 10)
+#define RSN_CIPHER_SUITE_BIP_GMAC_128 RSN_SELECTOR(0x00, 0x0f, 0xac, 11)
+#define RSN_CIPHER_SUITE_BIP_GMAC_256 RSN_SELECTOR(0x00, 0x0f, 0xac, 12)
+#define RSN_CIPHER_SUITE_BIP_CMAC_256 RSN_SELECTOR(0x00, 0x0f, 0xac, 13)
+/* EAPOL-Key Key Data Encapsulation
+ * GroupKey and PeerKey require encryption, otherwise, encryption is optional.
+#define RSN_KEY_DATA_GROUPKEY RSN_SELECTOR(0x00, 0x0f, 0xac, 1)
+#if 0
+#define RSN_KEY_DATA_STAKEY RSN_SELECTOR(0x00, 0x0f, 0xac, 2)
+#endif
+#define RSN_KEY_DATA_MAC_ADDR RSN_SELECTOR(0x00, 0x0f, 0xac, 3)
+#define RSN_KEY_DATA_PMKID RSN_SELECTOR(0x00, 0x0f, 0xac, 4)
+#ifdef CONFIG_PEERKEY
+#define RSN_KEY_DATA_SMK RSN_SELECTOR(0x00, 0x0f, 0xac, 5)
+#define RSN_KEY_DATA_NONCE RSN_SELECTOR(0x00, 0x0f, 0xac, 6)
+#define RSN_KEY_DATA_LIFETIME RSN_SELECTOR(0x00, 0x0f, 0xac, 7)
+#define RSN_KEY_DATA_ERROR RSN_SELECTOR(0x00, 0x0f, 0xac, 8)
+#endif /* CONFIG_PEERKEY */
+#define RSN_KEY_DATA_IGTK RSN_SELECTOR(0x00, 0x0f, 0xac, 9)
+#define RSN_KEY_DATA_KEYID RSN_SELECTOR(0x00, 0x0f, 0xac, 10)
+#define RSN_KEY_DATA_MULTIBAND_GTK RSN_SELECTOR(0x00, 0x0f, 0xac, 11)
+#define RSN_KEY_DATA_MULTIBAND_KEYID RSN_SELECTOR(0x00, 0x0f, 0xac, 12)
+#define WFA_KEY_DATA_IP_ADDR_REQ RSN_SELECTOR(0x50, 0x6f, 0x9a, 4)
+#define WFA_KEY_DATA_IP_ADDR_ALLOC RSN_SELECTOR(0x50, 0x6f, 0x9a, 5)
+#define WPA_OUI_TYPE RSN_SELECTOR(0x00, 0x50, 0xf2, 1)
+#define RSN_SELECTOR_PUT(a, val) WPA_PUT_BE32((u8 *) (a), (val))
+#define RSN_SELECTOR_GET(a) WPA_GET_BE32((const u8 *) (a))
+#define RSN_NUM_REPLAY_COUNTERS_1 0
+#define RSN_NUM_REPLAY_COUNTERS_2 1
+#define RSN_NUM_REPLAY_COUNTERS_4 2
+#define RSN_NUM_REPLAY_COUNTERS_16 3
+#ifdef _MSC_VER
+#pragma pack(push, 1)
+#endif /* _MSC_VER */
+#define WPA_IGTK_LEN 16
+#define WPA_IGTK_MAX_LEN 32
+/* IEEE 802.11, 7.3.2.25.3 RSN Capabilities */
+#define WPA_CAPABILITY_PREAUTH BIT(0)
+#define WPA_CAPABILITY_NO_PAIRWISE BIT(1)
+/* B2-B3: PTKSA Replay Counter */
+/* B4-B5: GTKSA Replay Counter */
+#define WPA_CAPABILITY_MFPR BIT(6)
+#define WPA_CAPABILITY_MFPC BIT(7)
+/* B8: Reserved */
+#define WPA_CAPABILITY_PEERKEY_ENABLED BIT(9)
+#define WPA_CAPABILITY_SPP_A_MSDU_CAPABLE BIT(10)
+#define WPA_CAPABILITY_SPP_A_MSDU_REQUIRED BIT(11)
+#define WPA_CAPABILITY_PBAC BIT(12)
+#define WPA_CAPABILITY_EXT_KEY_ID_FOR_UNICAST BIT(13)
+/* B14-B15: Reserved */
+/* IEEE 802.11r */
+#define MOBILITY_DOMAIN_ID_LEN 2
+#define FT_R0KH_ID_MAX_LEN 48
+#define FT_R1KH_ID_LEN 6
+#define WPA_PMK_NAME_LEN 16
+/* IEEE 802.11, 8.5.2 EAPOL-Key frames */
+#define WPA_KEY_INFO_TYPE_MASK ((u16) (BIT(0) | BIT(1) | BIT(2)))
+#define WPA_KEY_INFO_TYPE_AKM_DEFINED 0
+#define WPA_KEY_INFO_TYPE_HMAC_MD5_RC4 BIT(0)
+#define WPA_KEY_INFO_TYPE_HMAC_SHA1_AES BIT(1)
+#define WPA_KEY_INFO_TYPE_AES_128_CMAC 3
+#define WPA_KEY_INFO_KEY_TYPE BIT(3) /* 1 = Pairwise, 0 = Group key */
+/* bit4..5 is used in WPA, but is reserved in IEEE 802.11i/RSN */
+#define WPA_KEY_INFO_KEY_INDEX_MASK (BIT(4) | BIT(5))
+#define WPA_KEY_INFO_KEY_INDEX_SHIFT 4
+#define WPA_KEY_INFO_INSTALL BIT(6) /* pairwise */
+#define WPA_KEY_INFO_TXRX BIT(6) /* group */
+#define WPA_KEY_INFO_ACK BIT(7)
+#define WPA_KEY_INFO_MIC BIT(8)
+#define WPA_KEY_INFO_SECURE BIT(9)
+#define WPA_KEY_INFO_ERROR BIT(10)
+#define WPA_KEY_INFO_REQUEST BIT(11)
+#define WPA_KEY_INFO_ENCR_KEY_DATA BIT(12) /* IEEE 802.11i/RSN only */
+#define WPA_KEY_INFO_SMK_MESSAGE BIT(13)
+struct wpa_eapol_key {
+	u8 type;
+	/* Note: key_info, key_length, and key_data_length are unaligned */
+	u8 key_info[2]; /* big endian */
+	u8 key_length[2]; /* big endian */
+	u8 replay_counter[WPA_REPLAY_COUNTER_LEN];
+	u8 key_nonce[WPA_NONCE_LEN];
+	u8 key_iv[16];
+	u8 key_rsc[WPA_KEY_RSC_LEN];
+	u8 key_id[8]; /* Reserved in IEEE 802.11i/RSN */
+	u8 key_mic[16];
+	u8 key_data_length[2]; /* big endian */
+	/* followed by key_data_length bytes of key_data */
+} STRUCT_PACKED;
+struct wpa_eapol_key_192 {
+	u8 type;
+	u8 key_iv[16];
+	u8 key_mic[24];
+} STRUCT_PACKED;
+#define WPA_EAPOL_KEY_MIC_MAX_LEN 24
+#define WPA_KCK_MAX_LEN 24
+#define WPA_KEK_MAX_LEN 32
+#define WPA_TK_MAX_LEN 32
+ * struct wpa_ptk - WPA Pairwise Transient Key
+struct wpa_ptk {
+	u8 kck[WPA_KCK_MAX_LEN]; /* EAPOL-Key Key Confirmation Key (KCK) */
+	u8 kek[WPA_KEK_MAX_LEN]; /* EAPOL-Key Key Encryption Key (KEK) */
+	u8 tk[WPA_TK_MAX_LEN]; /* Temporal Key (TK) */
+	size_t kck_len;
+	size_t kek_len;
+	size_t tk_len;
+/* WPA IE version 1
+ * 00-50-f2:1 (OUI:OUI type)
+ * 0x01 0x00 (version; little endian)
+ * (all following fields are optional:)
+ * Group Suite Selector (4 octets) (default: TKIP)
+ * Pairwise Suite Count (2 octets, little endian) (default: 1)
+ * Pairwise Suite List (4 * n octets) (default: TKIP)
+ * Authenticated Key Management Suite Count (2 octets, little endian)
+ *    (default: 1)
+ * Authenticated Key Management Suite List (4 * n octets)
+ *    (default: unspec 802.1X)
+ * WPA Capabilities (2 octets, little endian) (default: 0)
+struct wpa_ie_hdr {
+	u8 elem_id;
+	u8 len;
+	u8 oui[4]; /* 24-bit OUI followed by 8-bit OUI type */
+	u8 version[2]; /* little endian */
+} STRUCT_PACKED;
+/* 1/4: PMKID
+ * 2/4: RSN IE
+ * 3/4: one or two RSN IEs + GTK IE (encrypted)
+ * 4/4: empty
+ * 1/2: GTK IE (encrypted)
+ * 2/2: empty
+/* RSN IE version 1
+ * Group Suite Selector (4 octets) (default: CCMP)
+ * Pairwise Suite List (4 * n octets) (default: CCMP)
+ *    (default: 1)
+ * RSN Capabilities (2 octets, little endian) (default: 0)
+ * PMKID Count (2 octets) (default: 0)
+ * PMKID List (16 * n octets)
+ * Management Group Cipher Suite (4 octets) (default: AES-128-CMAC)
+struct rsn_ie_hdr {
+	u8 elem_id; /* WLAN_EID_RSN */
+	u8 len;
+} STRUCT_PACKED;
+enum {
+	STK_MUI_4WAY_STA_AP = 1,
+	STK_MUI_4WAY_STAT_STA = 2,
+	STK_MUI_GTK = 3,
+	STK_MUI_SMK = 4
+enum {
+	STK_ERR_STA_NR = 1,
+	STK_ERR_STA_NRSN = 2,
+	STK_ERR_CPHR_NS = 3,
+	STK_ERR_NO_STSL = 4
+struct rsn_error_kde {
+	be16 mui;
+	be16 error_type;
+} STRUCT_PACKED;
+#define WPA_IGTK_KDE_PREFIX_LEN (2 + 6)
+struct wpa_igtk_kde {
+	u8 keyid[2];
+	u8 pn[6];
+	u8 igtk[WPA_IGTK_MAX_LEN];
+} STRUCT_PACKED;
+struct rsn_mdie {
+	u8 mobility_domain[MOBILITY_DOMAIN_ID_LEN];
+	u8 ft_capab;
+} STRUCT_PACKED;
+#define RSN_FT_CAPAB_FT_OVER_DS BIT(0)
+#define RSN_FT_CAPAB_FT_RESOURCE_REQ_SUPP BIT(1)
+struct rsn_ftie {
+	u8 mic_control[2];
+	u8 mic[16];
+	u8 anonce[WPA_NONCE_LEN];
+	u8 snonce[WPA_NONCE_LEN];
+	/* followed by optional parameters */
+} STRUCT_PACKED;
+#define FTIE_SUBELEM_R1KH_ID 1
+#define FTIE_SUBELEM_GTK 2
+#define FTIE_SUBELEM_R0KH_ID 3
+#define FTIE_SUBELEM_IGTK 4
+struct rsn_rdie {
+	u8 id;
+	u8 descr_count;
+	le16 status_code;
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+		      const u8 *buf, size_t len, u8 *mic);
+		   struct wpa_ptk *ptk, int akmp, int cipher);
+	       const u8 *ric, size_t ric_len, u8 *mic);
+		       const u8 *s0kh_id, u8 *pmk_r0, u8 *pmk_r0_name);
+			    const u8 *s1kh_id, u8 *pmk_r1_name);
+		       u8 *pmk_r1, u8 *pmk_r1_name);
+		      struct wpa_ptk *ptk, u8 *ptk_name, int akmp, int cipher);
+struct wpa_ie_data {
+	int proto;
+	int pairwise_cipher;
+	int group_cipher;
+	int key_mgmt;
+	int capabilities;
+	size_t num_pmkid;
+	const u8 *pmkid;
+	int mgmt_group_cipher;
+			 struct wpa_ie_data *data);
+	       u8 *pmkid, int use_sha256);
+		       const u8 *spa, u8 *pmkid);
+#else /* CONFIG_SUITEB */
+static inline int rsn_pmkid_suite_b(const u8 *kck, size_t kck_len, const u8 *aa,
+	return -1;
+#else /* CONFIG_SUITEB192 */
+static inline int rsn_pmkid_suite_b_192(const u8 *kck, size_t kck_len,
+					const u8 *aa, const u8 *spa, u8 *pmkid)
+	return -1;
+const char * wpa_cipher_txt(int cipher);
+const char * wpa_key_mgmt_txt(int key_mgmt, int proto);
+u32 wpa_akm_to_suite(int akm);
+		       const u8 *ie2, size_t ie2len);
+int wpa_insert_pmkid(u8 *ies, size_t ies_len, const u8 *pmkid);
+struct wpa_ft_ies {
+	const u8 *mdie;
+	size_t mdie_len;
+	const u8 *ftie;
+	size_t ftie_len;
+	const u8 *r1kh_id;
+	const u8 *gtk;
+	size_t gtk_len;
+	const u8 *r0kh_id;
+	size_t r0kh_id_len;
+	const u8 *rsn;
+	size_t rsn_len;
+	const u8 *rsn_pmkid;
+	const u8 *tie;
+	size_t tie_len;
+	const u8 *igtk;
+	size_t igtk_len;
+	const u8 *ric;
+	size_t ric_len;
+int wpa_ft_parse_ies(const u8 *ies, size_t ies_len, struct wpa_ft_ies *parse);
+int wpa_cipher_key_len(int cipher);
+int wpa_cipher_rsc_len(int cipher);
+int wpa_cipher_to_alg(int cipher);
+int wpa_cipher_valid_group(int cipher);
+int wpa_cipher_valid_pairwise(int cipher);
+int wpa_cipher_valid_mgmt_group(int cipher);
+u32 wpa_cipher_to_suite(int proto, int cipher);
+int rsn_cipher_put_suites(u8 *pos, int ciphers);
+int wpa_cipher_put_suites(u8 *pos, int ciphers);
+int wpa_pick_pairwise_cipher(int ciphers, int none_allowed);
+int wpa_pick_group_cipher(int ciphers);
+int wpa_parse_cipher(const char *value);
+int wpa_write_ciphers(char *start, char *end, int ciphers, const char *delim);
+int wpa_select_ap_group_cipher(int wpa, int wpa_pairwise, int rsn_pairwise);
+unsigned int wpa_mic_len(int akmp);
+#endif /* WPA_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/common/wpa_ctrl.h b/freebsd/contrib/wpa/src/common/wpa_ctrl.h
index 00000000000..3de46823588
--- /dev/null
+++ b/freebsd/contrib/wpa/src/common/wpa_ctrl.h
@@ -0,0 +1,472 @@
+ * wpa_supplicant/hostapd control interface library
+ * Copyright (c) 2004-2006, Jouni Malinen <j at w1.fi>
+#ifndef WPA_CTRL_H
+#define WPA_CTRL_H
+#ifdef  __cplusplus
+extern "C" {
+#endif
+/* wpa_supplicant control interface - fixed message prefixes */
+/** Interactive request for identity/password/pin */
+#define WPA_CTRL_REQ "CTRL-REQ-"
+/** Response to identity/password/pin request */
+#define WPA_CTRL_RSP "CTRL-RSP-"
+/* Event messages with fixed prefix */
+/** Authentication completed successfully and data connection enabled */
+#define WPA_EVENT_CONNECTED "CTRL-EVENT-CONNECTED "
+/** Disconnected, data connection is not available */
+#define WPA_EVENT_DISCONNECTED "CTRL-EVENT-DISCONNECTED "
+/** Association rejected during connection attempt */
+#define WPA_EVENT_ASSOC_REJECT "CTRL-EVENT-ASSOC-REJECT "
+/** Authentication rejected during connection attempt */
+#define WPA_EVENT_AUTH_REJECT "CTRL-EVENT-AUTH-REJECT "
+/** wpa_supplicant is exiting */
+#define WPA_EVENT_TERMINATING "CTRL-EVENT-TERMINATING "
+/** Password change was completed successfully */
+#define WPA_EVENT_PASSWORD_CHANGED "CTRL-EVENT-PASSWORD-CHANGED "
+/** EAP-Request/Notification received */
+#define WPA_EVENT_EAP_NOTIFICATION "CTRL-EVENT-EAP-NOTIFICATION "
+/** EAP authentication started (EAP-Request/Identity received) */
+#define WPA_EVENT_EAP_STARTED "CTRL-EVENT-EAP-STARTED "
+/** EAP method proposed by the server */
+#define WPA_EVENT_EAP_PROPOSED_METHOD "CTRL-EVENT-EAP-PROPOSED-METHOD "
+/** EAP method selected */
+#define WPA_EVENT_EAP_METHOD "CTRL-EVENT-EAP-METHOD "
+/** EAP peer certificate from TLS */
+#define WPA_EVENT_EAP_PEER_CERT "CTRL-EVENT-EAP-PEER-CERT "
+/** EAP peer certificate alternative subject name component from TLS */
+#define WPA_EVENT_EAP_PEER_ALT "CTRL-EVENT-EAP-PEER-ALT "
+/** EAP TLS certificate chain validation error */
+#define WPA_EVENT_EAP_TLS_CERT_ERROR "CTRL-EVENT-EAP-TLS-CERT-ERROR "
+/** EAP status */
+#define WPA_EVENT_EAP_STATUS "CTRL-EVENT-EAP-STATUS "
+/** EAP authentication completed successfully */
+#define WPA_EVENT_EAP_SUCCESS "CTRL-EVENT-EAP-SUCCESS "
+/** EAP authentication failed (EAP-Failure received) */
+#define WPA_EVENT_EAP_FAILURE "CTRL-EVENT-EAP-FAILURE "
+/** Network block temporarily disabled (e.g., due to authentication failure) */
+#define WPA_EVENT_TEMP_DISABLED "CTRL-EVENT-SSID-TEMP-DISABLED "
+/** Temporarily disabled network block re-enabled */
+#define WPA_EVENT_REENABLED "CTRL-EVENT-SSID-REENABLED "
+/** New scan started */
+#define WPA_EVENT_SCAN_STARTED "CTRL-EVENT-SCAN-STARTED "
+/** New scan results available */
+#define WPA_EVENT_SCAN_RESULTS "CTRL-EVENT-SCAN-RESULTS "
+/** Scan command failed */
+#define WPA_EVENT_SCAN_FAILED "CTRL-EVENT-SCAN-FAILED "
+/** wpa_supplicant state change */
+#define WPA_EVENT_STATE_CHANGE "CTRL-EVENT-STATE-CHANGE "
+/** A new BSS entry was added (followed by BSS entry id and BSSID) */
+#define WPA_EVENT_BSS_ADDED "CTRL-EVENT-BSS-ADDED "
+/** A BSS entry was removed (followed by BSS entry id and BSSID) */
+#define WPA_EVENT_BSS_REMOVED "CTRL-EVENT-BSS-REMOVED "
+/** No suitable network was found */
+#define WPA_EVENT_NETWORK_NOT_FOUND "CTRL-EVENT-NETWORK-NOT-FOUND "
+/** Change in the signal level was reported by the driver */
+#define WPA_EVENT_SIGNAL_CHANGE "CTRL-EVENT-SIGNAL-CHANGE "
+/** Regulatory domain channel */
+#define WPA_EVENT_REGDOM_CHANGE "CTRL-EVENT-REGDOM-CHANGE "
+/** RSN IBSS 4-way handshakes completed with specified peer */
+#define IBSS_RSN_COMPLETED "IBSS-RSN-COMPLETED "
+/** Notification of frequency conflict due to a concurrent operation.
+ * The indicated network is disabled and needs to be re-enabled before it can
+ * be used again.
+#define WPA_EVENT_FREQ_CONFLICT "CTRL-EVENT-FREQ-CONFLICT "
+/** Frequency ranges that the driver recommends to avoid */
+#define WPA_EVENT_AVOID_FREQ "CTRL-EVENT-AVOID-FREQ "
+/** WPS overlap detected in PBC mode */
+#define WPS_EVENT_OVERLAP "WPS-OVERLAP-DETECTED "
+/** Available WPS AP with active PBC found in scan results */
+#define WPS_EVENT_AP_AVAILABLE_PBC "WPS-AP-AVAILABLE-PBC "
+/** Available WPS AP with our address as authorized in scan results */
+#define WPS_EVENT_AP_AVAILABLE_AUTH "WPS-AP-AVAILABLE-AUTH "
+/** Available WPS AP with recently selected PIN registrar found in scan results
+#define WPS_EVENT_AP_AVAILABLE_PIN "WPS-AP-AVAILABLE-PIN "
+/** Available WPS AP found in scan results */
+#define WPS_EVENT_AP_AVAILABLE "WPS-AP-AVAILABLE "
+/** A new credential received */
+#define WPS_EVENT_CRED_RECEIVED "WPS-CRED-RECEIVED "
+/** M2D received */
+#define WPS_EVENT_M2D "WPS-M2D "
+/** WPS registration failed after M2/M2D */
+#define WPS_EVENT_FAIL "WPS-FAIL "
+/** WPS registration completed successfully */
+#define WPS_EVENT_SUCCESS "WPS-SUCCESS "
+/** WPS enrollment attempt timed out and was terminated */
+#define WPS_EVENT_TIMEOUT "WPS-TIMEOUT "
+/* PBC mode was activated */
+#define WPS_EVENT_ACTIVE "WPS-PBC-ACTIVE "
+/* PBC mode was disabled */
+#define WPS_EVENT_DISABLE "WPS-PBC-DISABLE "
+#define WPS_EVENT_ENROLLEE_SEEN "WPS-ENROLLEE-SEEN "
+#define WPS_EVENT_OPEN_NETWORK "WPS-OPEN-NETWORK "
+/* WPS ER events */
+#define WPS_EVENT_ER_AP_ADD "WPS-ER-AP-ADD "
+#define WPS_EVENT_ER_AP_REMOVE "WPS-ER-AP-REMOVE "
+#define WPS_EVENT_ER_ENROLLEE_ADD "WPS-ER-ENROLLEE-ADD "
+#define WPS_EVENT_ER_ENROLLEE_REMOVE "WPS-ER-ENROLLEE-REMOVE "
+#define WPS_EVENT_ER_AP_SETTINGS "WPS-ER-AP-SETTINGS "
+#define WPS_EVENT_ER_SET_SEL_REG "WPS-ER-AP-SET-SEL-REG "
+/* MESH events */
+#define MESH_GROUP_STARTED "MESH-GROUP-STARTED "
+#define MESH_GROUP_REMOVED "MESH-GROUP-REMOVED "
+#define MESH_PEER_CONNECTED "MESH-PEER-CONNECTED "
+#define MESH_PEER_DISCONNECTED "MESH-PEER-DISCONNECTED "
+/** Mesh SAE authentication failure. Wrong password suspected. */
+#define MESH_SAE_AUTH_FAILURE "MESH-SAE-AUTH-FAILURE "
+#define MESH_SAE_AUTH_BLOCKED "MESH-SAE-AUTH-BLOCKED "
+/* WMM AC events */
+#define WMM_AC_EVENT_TSPEC_ADDED "TSPEC-ADDED "
+#define WMM_AC_EVENT_TSPEC_REMOVED "TSPEC-REMOVED "
+#define WMM_AC_EVENT_TSPEC_REQ_FAILED "TSPEC-REQ-FAILED "
+/** P2P device found */
+#define P2P_EVENT_DEVICE_FOUND "P2P-DEVICE-FOUND "
+/** P2P device lost */
+#define P2P_EVENT_DEVICE_LOST "P2P-DEVICE-LOST "
+/** A P2P device requested GO negotiation, but we were not ready to start the
+ * negotiation */
+#define P2P_EVENT_GO_NEG_REQUEST "P2P-GO-NEG-REQUEST "
+#define P2P_EVENT_GO_NEG_SUCCESS "P2P-GO-NEG-SUCCESS "
+#define P2P_EVENT_GO_NEG_FAILURE "P2P-GO-NEG-FAILURE "
+#define P2P_EVENT_GROUP_FORMATION_SUCCESS "P2P-GROUP-FORMATION-SUCCESS "
+#define P2P_EVENT_GROUP_FORMATION_FAILURE "P2P-GROUP-FORMATION-FAILURE "
+#define P2P_EVENT_GROUP_STARTED "P2P-GROUP-STARTED "
+#define P2P_EVENT_GROUP_REMOVED "P2P-GROUP-REMOVED "
+#define P2P_EVENT_CROSS_CONNECT_ENABLE "P2P-CROSS-CONNECT-ENABLE "
+#define P2P_EVENT_CROSS_CONNECT_DISABLE "P2P-CROSS-CONNECT-DISABLE "
+/* parameters: <peer address> <PIN> */
+#define P2P_EVENT_PROV_DISC_SHOW_PIN "P2P-PROV-DISC-SHOW-PIN "
+/* parameters: <peer address> */
+#define P2P_EVENT_PROV_DISC_ENTER_PIN "P2P-PROV-DISC-ENTER-PIN "
+#define P2P_EVENT_PROV_DISC_PBC_REQ "P2P-PROV-DISC-PBC-REQ "
+#define P2P_EVENT_PROV_DISC_PBC_RESP "P2P-PROV-DISC-PBC-RESP "
+/* parameters: <peer address> <status> */
+#define P2P_EVENT_PROV_DISC_FAILURE "P2P-PROV-DISC-FAILURE"
+/* parameters: <freq> <src addr> <dialog token> <update indicator> <TLVs> */
+#define P2P_EVENT_SERV_DISC_REQ "P2P-SERV-DISC-REQ "
+/* parameters: <src addr> <update indicator> <TLVs> */
+#define P2P_EVENT_SERV_DISC_RESP "P2P-SERV-DISC-RESP "
+#define P2P_EVENT_SERV_ASP_RESP "P2P-SERV-ASP-RESP "
+#define P2P_EVENT_INVITATION_RECEIVED "P2P-INVITATION-RECEIVED "
+#define P2P_EVENT_INVITATION_RESULT "P2P-INVITATION-RESULT "
+#define P2P_EVENT_FIND_STOPPED "P2P-FIND-STOPPED "
+#define P2P_EVENT_PERSISTENT_PSK_FAIL "P2P-PERSISTENT-PSK-FAIL id="
+#define P2P_EVENT_PRESENCE_RESPONSE "P2P-PRESENCE-RESPONSE "
+#define P2P_EVENT_NFC_BOTH_GO "P2P-NFC-BOTH-GO "
+#define P2P_EVENT_NFC_PEER_CLIENT "P2P-NFC-PEER-CLIENT "
+#define P2P_EVENT_NFC_WHILE_CLIENT "P2P-NFC-WHILE-CLIENT "
+#define P2P_EVENT_FALLBACK_TO_GO_NEG "P2P-FALLBACK-TO-GO-NEG "
+#define P2P_EVENT_FALLBACK_TO_GO_NEG_ENABLED "P2P-FALLBACK-TO-GO-NEG-ENABLED "
+/* parameters: <PMF enabled> <timeout in ms> <Session Information URL> */
+#define ESS_DISASSOC_IMMINENT "ESS-DISASSOC-IMMINENT "
+#define P2P_EVENT_REMOVE_AND_REFORM_GROUP "P2P-REMOVE-AND-REFORM-GROUP "
+#define P2P_EVENT_P2PS_PROVISION_START "P2PS-PROV-START "
+#define P2P_EVENT_P2PS_PROVISION_DONE "P2PS-PROV-DONE "
+#define INTERWORKING_AP "INTERWORKING-AP "
+#define INTERWORKING_BLACKLISTED "INTERWORKING-BLACKLISTED "
+#define INTERWORKING_NO_MATCH "INTERWORKING-NO-MATCH "
+#define INTERWORKING_ALREADY_CONNECTED "INTERWORKING-ALREADY-CONNECTED "
+#define INTERWORKING_SELECTED "INTERWORKING-SELECTED "
+/* Credential block added; parameters: <id> */
+#define CRED_ADDED "CRED-ADDED "
+/* Credential block modified; parameters: <id> <field> */
+#define CRED_MODIFIED "CRED-MODIFIED "
+/* Credential block removed; parameters: <id> */
+#define CRED_REMOVED "CRED-REMOVED "
+#define GAS_RESPONSE_INFO "GAS-RESPONSE-INFO "
+/* parameters: <addr> <dialog_token> <freq> */
+#define GAS_QUERY_START "GAS-QUERY-START "
+/* parameters: <addr> <dialog_token> <freq> <status_code> <result> */
+#define GAS_QUERY_DONE "GAS-QUERY-DONE "
+/* parameters: <addr> <result> */
+#define ANQP_QUERY_DONE "ANQP-QUERY-DONE "
+#define HS20_SUBSCRIPTION_REMEDIATION "HS20-SUBSCRIPTION-REMEDIATION "
+#define HS20_DEAUTH_IMMINENT_NOTICE "HS20-DEAUTH-IMMINENT-NOTICE "
+#define EXT_RADIO_WORK_START "EXT-RADIO-WORK-START "
+#define EXT_RADIO_WORK_TIMEOUT "EXT-RADIO-WORK-TIMEOUT "
+#define RRM_EVENT_NEIGHBOR_REP_RXED "RRM-NEIGHBOR-REP-RECEIVED "
+#define RRM_EVENT_NEIGHBOR_REP_FAILED "RRM-NEIGHBOR-REP-REQUEST-FAILED "
+/* hostapd control interface - fixed message prefixes */
+#define WPS_EVENT_PIN_NEEDED "WPS-PIN-NEEDED "
+#define WPS_EVENT_NEW_AP_SETTINGS "WPS-NEW-AP-SETTINGS "
+#define WPS_EVENT_REG_SUCCESS "WPS-REG-SUCCESS "
+#define WPS_EVENT_AP_SETUP_LOCKED "WPS-AP-SETUP-LOCKED "
+#define WPS_EVENT_AP_SETUP_UNLOCKED "WPS-AP-SETUP-UNLOCKED "
+#define WPS_EVENT_AP_PIN_ENABLED "WPS-AP-PIN-ENABLED "
+#define WPS_EVENT_AP_PIN_DISABLED "WPS-AP-PIN-DISABLED "
+#define AP_STA_CONNECTED "AP-STA-CONNECTED "
+#define AP_STA_DISCONNECTED "AP-STA-DISCONNECTED "
+#define AP_STA_POSSIBLE_PSK_MISMATCH "AP-STA-POSSIBLE-PSK-MISMATCH "
+#define AP_REJECTED_MAX_STA "AP-REJECTED-MAX-STA "
+#define AP_REJECTED_BLOCKED_STA "AP-REJECTED-BLOCKED-STA "
+#define AP_EVENT_ENABLED "AP-ENABLED "
+#define AP_EVENT_DISABLED "AP-DISABLED "
+#define INTERFACE_ENABLED "INTERFACE-ENABLED "
+#define INTERFACE_DISABLED "INTERFACE-DISABLED "
+#define ACS_EVENT_STARTED "ACS-STARTED "
+#define ACS_EVENT_COMPLETED "ACS-COMPLETED "
+#define ACS_EVENT_FAILED "ACS-FAILED "
+#define DFS_EVENT_RADAR_DETECTED "DFS-RADAR-DETECTED "
+#define DFS_EVENT_NEW_CHANNEL "DFS-NEW-CHANNEL "
+#define DFS_EVENT_CAC_START "DFS-CAC-START "
+#define DFS_EVENT_CAC_COMPLETED "DFS-CAC-COMPLETED "
+#define DFS_EVENT_NOP_FINISHED "DFS-NOP-FINISHED "
+#define AP_CSA_FINISHED "AP-CSA-FINISHED "
+/* BSS Transition Management Response frame received */
+#define BSS_TM_RESP "BSS-TM-RESP "
+/* BSS command information masks */
+#define WPA_BSS_MASK_ALL		0xFFFDFFFF
+#define WPA_BSS_MASK_ID			BIT(0)
+#define WPA_BSS_MASK_BSSID		BIT(1)
+#define WPA_BSS_MASK_FREQ		BIT(2)
+#define WPA_BSS_MASK_BEACON_INT		BIT(3)
+#define WPA_BSS_MASK_CAPABILITIES	BIT(4)
+#define WPA_BSS_MASK_QUAL		BIT(5)
+#define WPA_BSS_MASK_NOISE		BIT(6)
+#define WPA_BSS_MASK_LEVEL		BIT(7)
+#define WPA_BSS_MASK_TSF		BIT(8)
+#define WPA_BSS_MASK_AGE		BIT(9)
+#define WPA_BSS_MASK_IE			BIT(10)
+#define WPA_BSS_MASK_FLAGS		BIT(11)
+#define WPA_BSS_MASK_SSID		BIT(12)
+#define WPA_BSS_MASK_WPS_SCAN		BIT(13)
+#define WPA_BSS_MASK_P2P_SCAN		BIT(14)
+#define WPA_BSS_MASK_INTERNETW		BIT(15)
+#define WPA_BSS_MASK_WIFI_DISPLAY	BIT(16)
+#define WPA_BSS_MASK_DELIM		BIT(17)
+#define WPA_BSS_MASK_MESH_SCAN		BIT(18)
+#define WPA_BSS_MASK_SNR		BIT(19)
+#define WPA_BSS_MASK_EST_THROUGHPUT	BIT(20)
+#define WPA_BSS_MASK_FST		BIT(21)
+/* VENDOR_ELEM_* frame id values */
+enum wpa_vendor_elem_frame {
+	VENDOR_ELEM_PROBE_REQ_P2P = 0,
+	VENDOR_ELEM_PROBE_RESP_P2P = 1,
+	VENDOR_ELEM_PROBE_RESP_P2P_GO = 2,
+	VENDOR_ELEM_BEACON_P2P_GO = 3,
+	VENDOR_ELEM_P2P_PD_REQ = 4,
+	VENDOR_ELEM_P2P_PD_RESP = 5,
+	VENDOR_ELEM_P2P_GO_NEG_REQ = 6,
+	VENDOR_ELEM_P2P_GO_NEG_RESP = 7,
+	VENDOR_ELEM_P2P_GO_NEG_CONF = 8,
+	VENDOR_ELEM_P2P_INV_REQ = 9,
+	VENDOR_ELEM_P2P_INV_RESP = 10,
+	VENDOR_ELEM_P2P_ASSOC_REQ = 11,
+	VENDOR_ELEM_P2P_ASSOC_RESP = 12,
+	VENDOR_ELEM_ASSOC_REQ = 13,
+	NUM_VENDOR_ELEM_FRAMES
+/* wpa_supplicant/hostapd control interface access */
+ * wpa_ctrl_open - Open a control interface to wpa_supplicant/hostapd
+ * @ctrl_path: Path for UNIX domain sockets; ignored if UDP sockets are used.
+ * Returns: Pointer to abstract control interface data or %NULL on failure
+ * This function is used to open a control interface to wpa_supplicant/hostapd.
+ * ctrl_path is usually /var/run/wpa_supplicant or /var/run/hostapd. This path
+ * is configured in wpa_supplicant/hostapd and other programs using the control
+ * interface need to use matching path configuration.
+struct wpa_ctrl * wpa_ctrl_open(const char *ctrl_path);
+ * wpa_ctrl_open2 - Open a control interface to wpa_supplicant/hostapd
+ * @cli_path: Path for client UNIX domain sockets; ignored if UDP socket
+ *            is used.
+ * when the socket path for client need to be specified explicitly. Default
+ * ctrl_path is usually /var/run/wpa_supplicant or /var/run/hostapd and client
+ * socket path is /tmp.
+struct wpa_ctrl * wpa_ctrl_open2(const char *ctrl_path, const char *cli_path);
+ * wpa_ctrl_close - Close a control interface to wpa_supplicant/hostapd
+ * @ctrl: Control interface data from wpa_ctrl_open()
+ * This function is used to close a control interface.
+void wpa_ctrl_close(struct wpa_ctrl *ctrl);
+ * wpa_ctrl_request - Send a command to wpa_supplicant/hostapd
+ * @cmd: Command; usually, ASCII text, e.g., "PING"
+ * @cmd_len: Length of the cmd in bytes
+ * @reply: Buffer for the response
+ * @reply_len: Reply buffer length
+ * @msg_cb: Callback function for unsolicited messages or %NULL if not used
+ * Returns: 0 on success, -1 on error (send or receive failed), -2 on timeout
+ * This function is used to send commands to wpa_supplicant/hostapd. Received
+ * response will be written to reply and reply_len is set to the actual length
+ * of the reply. This function will block for up to two seconds while waiting
+ * for the reply. If unsolicited messages are received, the blocking time may
+ * be longer.
+ * msg_cb can be used to register a callback function that will be called for
+ * unsolicited messages received while waiting for the command response. These
+ * messages may be received if wpa_ctrl_request() is called at the same time as
+ * wpa_supplicant/hostapd is sending such a message. This can happen only if
+ * the program has used wpa_ctrl_attach() to register itself as a monitor for
+ * event messages. Alternatively to msg_cb, programs can register two control
+ * interface connections and use one of them for commands and the other one for
+ * receiving event messages, in other words, call wpa_ctrl_attach() only for
+ * the control interface connection that will be used for event messages.
+int wpa_ctrl_request(struct wpa_ctrl *ctrl, const char *cmd, size_t cmd_len,
+		     char *reply, size_t *reply_len,
+		     void (*msg_cb)(char *msg, size_t len));
+ * wpa_ctrl_attach - Register as an event monitor for the control interface
+ * Returns: 0 on success, -1 on failure, -2 on timeout
+ * This function registers the control interface connection as a monitor for
+ * wpa_supplicant/hostapd events. After a success wpa_ctrl_attach() call, the
+ * control interface connection starts receiving event messages that can be
+ * read with wpa_ctrl_recv().
+int wpa_ctrl_attach(struct wpa_ctrl *ctrl);
+ * wpa_ctrl_detach - Unregister event monitor from the control interface
+ * This function unregisters the control interface connection as a monitor for
+ * wpa_supplicant/hostapd events, i.e., cancels the registration done with
+ * wpa_ctrl_attach().
+int wpa_ctrl_detach(struct wpa_ctrl *ctrl);
+ * wpa_ctrl_recv - Receive a pending control interface message
+ * @reply: Buffer for the message data
+ * @reply_len: Length of the reply buffer
+ * This function will receive a pending control interface message. The received
+ * of the reply.
+ * wpa_ctrl_recv() is only used for event messages, i.e., wpa_ctrl_attach()
+ * must have been used to register the control interface as an event monitor.
+int wpa_ctrl_recv(struct wpa_ctrl *ctrl, char *reply, size_t *reply_len);
+ * wpa_ctrl_pending - Check whether there are pending event messages
+ * Returns: 1 if there are pending messages, 0 if no, or -1 on error
+ * This function will check whether there are any pending control interface
+ * message available to be received with wpa_ctrl_recv(). wpa_ctrl_pending() is
+ * only used for event messages, i.e., wpa_ctrl_attach() must have been used to
+ * register the control interface as an event monitor.
+int wpa_ctrl_pending(struct wpa_ctrl *ctrl);
+ * wpa_ctrl_get_fd - Get file descriptor used by the control interface
+ * Returns: File descriptor used for the connection
+ * This function can be used to get the file descriptor that is used for the
+ * control interface connection. The returned value can be used, e.g., with
+ * select() while waiting for multiple events.
+ * The returned file descriptor must not be used directly for sending or
+ * receiving packets; instead, the library functions wpa_ctrl_request() and
+ * wpa_ctrl_recv() must be used for this.
+int wpa_ctrl_get_fd(struct wpa_ctrl *ctrl);
+#ifdef ANDROID
+ * wpa_ctrl_cleanup() - Delete any local UNIX domain socket files that
+ * may be left over from clients that were previously connected to
+ * wpa_supplicant. This keeps these files from being orphaned in the
+ * event of crashes that prevented them from being removed as part
+ * of the normal orderly shutdown.
+void wpa_ctrl_cleanup(void);
+#endif /* ANDROID */
+#ifdef CONFIG_CTRL_IFACE_UDP
+/* Port range for multiple wpa_supplicant instances and multiple VIFs */
+#define WPA_CTRL_IFACE_PORT 9877
+#define WPA_CTRL_IFACE_PORT_LIMIT 50 /* decremented from start */
+#define WPA_GLOBAL_CTRL_IFACE_PORT 9878
+#define WPA_GLOBAL_CTRL_IFACE_PORT_LIMIT 20 /* incremented from start */
+char * wpa_ctrl_get_remote_ifname(struct wpa_ctrl *ctrl);
+#endif /* CONFIG_CTRL_IFACE_UDP */
+#ifdef  __cplusplus
+#endif
+#endif /* WPA_CTRL_H */
diff --git a/freebsd/contrib/wpa/src/crypto/aes-ctr.c b/freebsd/contrib/wpa/src/crypto/aes-ctr.c
new file mode 100644
index 00000000000..f92be0224a4
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes-ctr.c
@@ -0,0 +1,57 @@
+#include <machine/rtems-bsd-user-space.h>
+ * AES-128 CTR
+ * Copyright (c) 2003-2007, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "includes.h"
+#include "common.h"
+#include "aes.h"
+#include "aes_wrap.h"
+ * aes_128_ctr_encrypt - AES-128 CTR mode encryption
+ * @key: Key for encryption (16 bytes)
+ * @nonce: Nonce for counter mode (16 bytes)
+ * @data: Data to encrypt in-place
+ * @data_len: Length of data in bytes
+int aes_128_ctr_encrypt(const u8 *key, const u8 *nonce,
+			u8 *data, size_t data_len)
+	void *ctx;
+	size_t j, len, left = data_len;
+	int i;
+	u8 *pos = data;
+	u8 counter[AES_BLOCK_SIZE], buf[AES_BLOCK_SIZE];
+	ctx = aes_encrypt_init(key, 16);
+	if (ctx == NULL)
+		return -1;
+	os_memcpy(counter, nonce, AES_BLOCK_SIZE);
+	while (left > 0) {
+		aes_encrypt(ctx, counter, buf);
+		len = (left < AES_BLOCK_SIZE) ? left : AES_BLOCK_SIZE;
+		for (j = 0; j < len; j++)
+			pos[j] ^= buf[j];
+		pos += len;
+		left -= len;
+		for (i = AES_BLOCK_SIZE - 1; i >= 0; i--) {
+			counter[i]++;
+			if (counter[i])
+				break;
+	aes_encrypt_deinit(ctx);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/aes-eax.c b/freebsd/contrib/wpa/src/crypto/aes-eax.c
index 00000000000..db3cf0895d8
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes-eax.c
@@ -0,0 +1,147 @@
+ * AES-128 EAX
+#include "aes.h"
+ * aes_128_eax_encrypt - AES-128 EAX mode encryption
+ * @nonce_len: Nonce length in bytes
+ * @hdr: Header data to be authenticity protected
+ * @hdr_len: Length of the header data bytes
+ * @tag: 16-byte tag value
+int aes_128_eax_encrypt(const u8 *key, const u8 *nonce, size_t nonce_len,
+			const u8 *hdr, size_t hdr_len,
+			u8 *data, size_t data_len, u8 *tag)
+	u8 *buf;
+	size_t buf_len;
+	u8 nonce_mac[AES_BLOCK_SIZE], hdr_mac[AES_BLOCK_SIZE],
+		data_mac[AES_BLOCK_SIZE];
+	int i, ret = -1;
+	if (nonce_len > data_len)
+		buf_len = nonce_len;
+	else
+		buf_len = data_len;
+	if (hdr_len > buf_len)
+		buf_len = hdr_len;
+	buf_len += 16;
+	buf = os_malloc(buf_len);
+	if (buf == NULL)
+		return -1;
+	os_memset(buf, 0, 15);
+	buf[15] = 0;
+	os_memcpy(buf + 16, nonce, nonce_len);
+	if (omac1_aes_128(key, buf, 16 + nonce_len, nonce_mac))
+		goto fail;
+	buf[15] = 1;
+	os_memcpy(buf + 16, hdr, hdr_len);
+	if (omac1_aes_128(key, buf, 16 + hdr_len, hdr_mac))
+		goto fail;
+	if (aes_128_ctr_encrypt(key, nonce_mac, data, data_len))
+		goto fail;
+	buf[15] = 2;
+	os_memcpy(buf + 16, data, data_len);
+	if (omac1_aes_128(key, buf, 16 + data_len, data_mac))
+		goto fail;
+	for (i = 0; i < AES_BLOCK_SIZE; i++)
+		tag[i] = nonce_mac[i] ^ data_mac[i] ^ hdr_mac[i];
+	ret = 0;
+fail:
+	bin_clear_free(buf, buf_len);
+	return ret;
+ * aes_128_eax_decrypt - AES-128 EAX mode decryption
+ * @key: Key for decryption (16 bytes)
+ * Returns: 0 on success, -1 on failure, -2 if tag does not match
+int aes_128_eax_decrypt(const u8 *key, const u8 *nonce, size_t nonce_len,
+			u8 *data, size_t data_len, const u8 *tag)
+	u8 *buf;
+	size_t buf_len;
+	int i;
+	else
+	buf_len += 16;
+	if (buf == NULL)
+		return -1;
+	buf[15] = 0;
+	if (omac1_aes_128(key, buf, 16 + nonce_len, nonce_mac)) {
+		os_free(buf);
+		return -1;
+	buf[15] = 1;
+	if (omac1_aes_128(key, buf, 16 + hdr_len, hdr_mac)) {
+		os_free(buf);
+		return -1;
+	buf[15] = 2;
+	if (omac1_aes_128(key, buf, 16 + data_len, data_mac)) {
+		os_free(buf);
+		return -1;
+	os_free(buf);
+	for (i = 0; i < AES_BLOCK_SIZE; i++) {
+		if (tag[i] != (nonce_mac[i] ^ data_mac[i] ^ hdr_mac[i]))
+			return -2;
+	return aes_128_ctr_encrypt(key, nonce_mac, data, data_len);
diff --git a/freebsd/contrib/wpa/src/crypto/aes-encblock.c b/freebsd/contrib/wpa/src/crypto/aes-encblock.c
index 00000000000..059f1e2d998
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes-encblock.c
@@ -0,0 +1,34 @@
+ * AES encrypt_block
+#include "aes.h"
+ * aes_128_encrypt_block - Perform one AES 128-bit block operation
+ * @key: Key for AES
+ * @in: Input data (16 bytes)
+ * @out: Output of the AES block operation (16 bytes)
+int aes_128_encrypt_block(const u8 *key, const u8 *in, u8 *out)
+	void *ctx;
+	if (ctx == NULL)
+		return -1;
+	aes_encrypt(ctx, in, out);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/aes-omac1.c b/freebsd/contrib/wpa/src/crypto/aes-omac1.c
index 00000000000..7e62ef85cb5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes-omac1.c
@@ -0,0 +1,172 @@
+ * One-key CBC MAC (OMAC1) hash with AES
+#include "aes.h"
+static void gf_mulx(u8 *pad)
+	int i, carry;
+	carry = pad[0] & 0x80;
+	for (i = 0; i < AES_BLOCK_SIZE - 1; i++)
+		pad[i] = (pad[i] << 1) | (pad[i + 1] >> 7);
+	pad[AES_BLOCK_SIZE - 1] <<= 1;
+	if (carry)
+		pad[AES_BLOCK_SIZE - 1] ^= 0x87;
+ * omac1_aes_vector - One-Key CBC MAC (OMAC1) hash with AES
+ * @key: Key for the hash operation
+ * @key_len: Key length in octets
+ * @num_elem: Number of elements in the data vector
+ * @addr: Pointers to the data areas
+ * @len: Lengths of the data blocks
+ * @mac: Buffer for MAC (128 bits, i.e., 16 bytes)
+ * This is a mode for using block cipher (AES in this case) for authentication.
+ * OMAC1 was standardized with the name CMAC by NIST in a Special Publication
+ * (SP) 800-38B.
+int omac1_aes_vector(const u8 *key, size_t key_len, size_t num_elem,
+		     const u8 *addr[], const size_t *len, u8 *mac)
+	void *ctx;
+	u8 cbc[AES_BLOCK_SIZE], pad[AES_BLOCK_SIZE];
+	const u8 *pos, *end;
+	size_t i, e, left, total_len;
+	ctx = aes_encrypt_init(key, key_len);
+	if (ctx == NULL)
+		return -1;
+	os_memset(cbc, 0, AES_BLOCK_SIZE);
+	total_len = 0;
+	for (e = 0; e < num_elem; e++)
+		total_len += len[e];
+	left = total_len;
+	e = 0;
+	pos = addr[0];
+	end = pos + len[0];
+	while (left >= AES_BLOCK_SIZE) {
+			cbc[i] ^= *pos++;
+			if (pos >= end) {
+				 * Stop if there are no more bytes to process
+				 * since there are no more entries in the array.
+				if (i + 1 == AES_BLOCK_SIZE &&
+				    left == AES_BLOCK_SIZE)
+					break;
+				e++;
+				pos = addr[e];
+				end = pos + len[e];
+		if (left > AES_BLOCK_SIZE)
+			aes_encrypt(ctx, cbc, cbc);
+		left -= AES_BLOCK_SIZE;
+	os_memset(pad, 0, AES_BLOCK_SIZE);
+	aes_encrypt(ctx, pad, pad);
+	gf_mulx(pad);
+	if (left || total_len == 0) {
+		for (i = 0; i < left; i++) {
+			cbc[i] ^= *pos++;
+			if (pos >= end) {
+				if (i + 1 == left)
+					break;
+				e++;
+				pos = addr[e];
+		cbc[left] ^= 0x80;
+		gf_mulx(pad);
+		pad[i] ^= cbc[i];
+	aes_encrypt(ctx, pad, mac);
+	return 0;
+ * omac1_aes_128_vector - One-Key CBC MAC (OMAC1) hash with AES-128
+ * @key: 128-bit key for the hash operation
+ * (SP) 800-38B.
+int omac1_aes_128_vector(const u8 *key, size_t num_elem,
+	return omac1_aes_vector(key, 16, num_elem, addr, len, mac);
+ * omac1_aes_128 - One-Key CBC MAC (OMAC1) hash with AES-128 (aka AES-CMAC)
+ * @data: Data buffer for which a MAC is determined
+ * @data_len: Length of data buffer in bytes
+ * (SP) 800-38B.
+int omac1_aes_128(const u8 *key, const u8 *data, size_t data_len, u8 *mac)
+	return omac1_aes_128_vector(key, 1, &data, &data_len, mac);
+ * omac1_aes_256 - One-Key CBC MAC (OMAC1) hash with AES-256 (aka AES-CMAC)
+ * @key: 256-bit key for the hash operation
+ * (SP) 800-38B.
+int omac1_aes_256(const u8 *key, const u8 *data, size_t data_len, u8 *mac)
+	return omac1_aes_vector(key, 32, 1, &data, &data_len, mac);
diff --git a/freebsd/contrib/wpa/src/crypto/aes-unwrap.c b/freebsd/contrib/wpa/src/crypto/aes-unwrap.c
index 00000000000..63e6c34efab
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes-unwrap.c
@@ -0,0 +1,82 @@
+ * AES key unwrap (RFC3394)
+#include "aes.h"
+ * aes_unwrap - Unwrap key with AES Key Wrap Algorithm (RFC3394)
+ * @kek: Key encryption key (KEK)
+ * @kek_len: Length of KEK in octets
+ * @n: Length of the plaintext key in 64-bit units; e.g., 2 = 128-bit = 16
+ * bytes
+ * @cipher: Wrapped key to be unwrapped, (n + 1) * 64 bits
+ * @plain: Plaintext key, n * 64 bits
+ * Returns: 0 on success, -1 on failure (e.g., integrity verification failed)
+int aes_unwrap(const u8 *kek, size_t kek_len, int n, const u8 *cipher,
+	       u8 *plain)
+	u8 a[8], *r, b[AES_BLOCK_SIZE];
+	int i, j;
+	void *ctx;
+	unsigned int t;
+	/* 1) Initialize variables. */
+	os_memcpy(a, cipher, 8);
+	r = plain;
+	os_memcpy(r, cipher + 8, 8 * n);
+	ctx = aes_decrypt_init(kek, kek_len);
+	if (ctx == NULL)
+		return -1;
+	/* 2) Compute intermediate values.
+	 * For j = 5 to 0
+	 *     For i = n to 1
+	 *         B = AES-1(K, (A ^ t) | R[i]) where t = n*j+i
+	 *         A = MSB(64, B)
+	 *         R[i] = LSB(64, B)
+	for (j = 5; j >= 0; j--) {
+		r = plain + (n - 1) * 8;
+		for (i = n; i >= 1; i--) {
+			os_memcpy(b, a, 8);
+			t = n * j + i;
+			b[7] ^= t;
+			b[6] ^= t >> 8;
+			b[5] ^= t >> 16;
+			b[4] ^= t >> 24;
+			os_memcpy(b + 8, r, 8);
+			aes_decrypt(ctx, b, b);
+			os_memcpy(a, b, 8);
+			os_memcpy(r, b + 8, 8);
+			r -= 8;
+	aes_decrypt_deinit(ctx);
+	/* 3) Output results.
+	 * These are already in @plain due to the location of temporary
+	 * variables. Just verify that the IV matches with the expected value.
+	for (i = 0; i < 8; i++) {
+		if (a[i] != 0xa6)
+			return -1;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/aes.h b/freebsd/contrib/wpa/src/crypto/aes.h
index 00000000000..2de59e04efa
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes.h
@@ -0,0 +1,21 @@
+ * AES functions
+ * Copyright (c) 2003-2006, Jouni Malinen <j at w1.fi>
+#ifndef AES_H
+#define AES_H
+#define AES_BLOCK_SIZE 16
+void * aes_encrypt_init(const u8 *key, size_t len);
+void aes_encrypt(void *ctx, const u8 *plain, u8 *crypt);
+void aes_encrypt_deinit(void *ctx);
+void * aes_decrypt_init(const u8 *key, size_t len);
+void aes_decrypt(void *ctx, const u8 *crypt, u8 *plain);
+void aes_decrypt_deinit(void *ctx);
+#endif /* AES_H */
diff --git a/freebsd/contrib/wpa/src/crypto/aes_wrap.h b/freebsd/contrib/wpa/src/crypto/aes_wrap.h
index 00000000000..4a142093b0d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/aes_wrap.h
@@ -0,0 +1,71 @@
+ * AES-based functions
+ * - AES Key Wrap Algorithm (RFC3394)
+ * - One-Key CBC MAC (OMAC1) hash with AES-128 and AES-256
+ * - AES-128 CTR mode encryption
+ * - AES-128 EAX mode encryption/decryption
+ * - AES-128 CBC
+ * - AES-GCM
+ * - AES-CCM
+ * Copyright (c) 2003-2012, Jouni Malinen <j at w1.fi>
+#ifndef AES_WRAP_H
+#define AES_WRAP_H
+int __must_check aes_wrap(const u8 *kek, size_t kek_len, int n, const u8 *plain,
+			  u8 *cipher);
+int __must_check aes_unwrap(const u8 *kek, size_t kek_len, int n,
+			    const u8 *cipher, u8 *plain);
+int __must_check omac1_aes_vector(const u8 *key, size_t key_len,
+				  size_t num_elem, const u8 *addr[],
+				  const size_t *len, u8 *mac);
+int __must_check omac1_aes_128_vector(const u8 *key, size_t num_elem,
+				      u8 *mac);
+int __must_check omac1_aes_128(const u8 *key, const u8 *data, size_t data_len,
+			       u8 *mac);
+int __must_check omac1_aes_256(const u8 *key, const u8 *data, size_t data_len,
+			       u8 *mac);
+int __must_check aes_128_encrypt_block(const u8 *key, const u8 *in, u8 *out);
+int __must_check aes_128_ctr_encrypt(const u8 *key, const u8 *nonce,
+				     u8 *data, size_t data_len);
+int __must_check aes_128_eax_encrypt(const u8 *key,
+				     const u8 *nonce, size_t nonce_len,
+				     u8 *data, size_t data_len, u8 *tag);
+int __must_check aes_128_eax_decrypt(const u8 *key,
+				     u8 *data, size_t data_len, const u8 *tag);
+int __must_check aes_128_cbc_encrypt(const u8 *key, const u8 *iv, u8 *data,
+				     size_t data_len);
+int __must_check aes_128_cbc_decrypt(const u8 *key, const u8 *iv, u8 *data,
+				     size_t data_len);
+int __must_check aes_gcm_ae(const u8 *key, size_t key_len,
+			    const u8 *iv, size_t iv_len,
+			    const u8 *plain, size_t plain_len,
+			    const u8 *aad, size_t aad_len,
+			    u8 *crypt, u8 *tag);
+int __must_check aes_gcm_ad(const u8 *key, size_t key_len,
+			    const u8 *crypt, size_t crypt_len,
+			    const u8 *aad, size_t aad_len, const u8 *tag,
+			    u8 *plain);
+int __must_check aes_gmac(const u8 *key, size_t key_len,
+			  const u8 *aad, size_t aad_len, u8 *tag);
+int __must_check aes_ccm_ae(const u8 *key, size_t key_len, const u8 *nonce,
+			    size_t M, const u8 *plain, size_t plain_len,
+			    const u8 *aad, size_t aad_len, u8 *crypt, u8 *auth);
+int __must_check aes_ccm_ad(const u8 *key, size_t key_len, const u8 *nonce,
+			    size_t M, const u8 *crypt, size_t crypt_len,
+			    const u8 *aad, size_t aad_len, const u8 *auth,
+			    u8 *plain);
+#endif /* AES_WRAP_H */
diff --git a/freebsd/contrib/wpa/src/crypto/crypto.h b/freebsd/contrib/wpa/src/crypto/crypto.h
index 00000000000..534c4bd7865
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/crypto.h
@@ -0,0 +1,809 @@
+ * Wrapper functions for crypto libraries
+ * Copyright (c) 2004-2013, Jouni Malinen <j at w1.fi>
+ * This file defines the cryptographic functions that need to be implemented
+ * for wpa_supplicant and hostapd. When TLS is not used, internal
+ * implementation of MD5, SHA1, and AES is used and no external libraries are
+ * required. When TLS is enabled (e.g., by enabling EAP-TLS or EAP-PEAP), the
+ * crypto library used by the TLS implementation is expected to be used for
+ * non-TLS needs, too, in order to save space by not implementing these
+ * functions twice.
+ * Wrapper code for using each crypto library is in its own file (crypto*.c)
+ * and one of these files is build and linked in to provide the functions
+ * defined here.
+#ifndef CRYPTO_H
+#define CRYPTO_H
+ * md4_vector - MD4 hash for data vector
+ * @mac: Buffer for the hash
+int md4_vector(size_t num_elem, const u8 *addr[], const size_t *len, u8 *mac);
+ * md5_vector - MD5 hash for data vector
+int md5_vector(size_t num_elem, const u8 *addr[], const size_t *len, u8 *mac);
+ * sha1_vector - SHA-1 hash for data vector
+int sha1_vector(size_t num_elem, const u8 *addr[], const size_t *len,
+		u8 *mac);
+ * fips186_2-prf - NIST FIPS Publication 186-2 change notice 1 PRF
+ * @seed: Seed/key for the PRF
+ * @seed_len: Seed length in bytes
+ * @x: Buffer for PRF output
+ * @xlen: Output length in bytes
+ * This function implements random number generation specified in NIST FIPS
+ * Publication 186-2 for EAP-SIM. This PRF uses a function that is similar to
+ * SHA-1, but has different message padding.
+int __must_check fips186_2_prf(const u8 *seed, size_t seed_len, u8 *x,
+			       size_t xlen);
+ * sha256_vector - SHA256 hash for data vector
+int sha256_vector(size_t num_elem, const u8 *addr[], const size_t *len,
+		  u8 *mac);
+ * des_encrypt - Encrypt one block with DES
+ * @clear: 8 octets (in)
+ * @key: 7 octets (in) (no parity bits included)
+ * @cypher: 8 octets (out)
+void des_encrypt(const u8 *clear, const u8 *key, u8 *cypher);
+ * aes_encrypt_init - Initialize AES for encryption
+ * @key: Encryption key
+ * @len: Key length in bytes (usually 16, i.e., 128 bits)
+ * Returns: Pointer to context data or %NULL on failure
+ * aes_encrypt - Encrypt one AES block
+ * @ctx: Context pointer from aes_encrypt_init()
+ * @plain: Plaintext data to be encrypted (16 bytes)
+ * @crypt: Buffer for the encrypted data (16 bytes)
+ * aes_encrypt_deinit - Deinitialize AES encryption
+ * aes_decrypt_init - Initialize AES for decryption
+ * @key: Decryption key
+ * aes_decrypt - Decrypt one AES block
+ * @crypt: Encrypted data (16 bytes)
+ * @plain: Buffer for the decrypted data (16 bytes)
+ * aes_decrypt_deinit - Deinitialize AES decryption
+enum crypto_hash_alg {
+	CRYPTO_HASH_ALG_MD5, CRYPTO_HASH_ALG_SHA1,
+	CRYPTO_HASH_ALG_HMAC_MD5, CRYPTO_HASH_ALG_HMAC_SHA1,
+	CRYPTO_HASH_ALG_SHA256, CRYPTO_HASH_ALG_HMAC_SHA256
+struct crypto_hash;
+ * crypto_hash_init - Initialize hash/HMAC function
+ * @alg: Hash algorithm
+ * @key: Key for keyed hash (e.g., HMAC) or %NULL if not needed
+ * @key_len: Length of the key in bytes
+ * Returns: Pointer to hash context to use with other hash functions or %NULL
+ * on failure
+ * This function is only used with internal TLSv1 implementation
+ * (CONFIG_TLS=internal). If that is not used, the crypto wrapper does not need
+ * to implement this.
+struct crypto_hash * crypto_hash_init(enum crypto_hash_alg alg, const u8 *key,
+				      size_t key_len);
+ * crypto_hash_update - Add data to hash calculation
+ * @ctx: Context pointer from crypto_hash_init()
+ * @data: Data buffer to add
+ * @len: Length of the buffer
+void crypto_hash_update(struct crypto_hash *ctx, const u8 *data, size_t len);
+ * crypto_hash_finish - Complete hash calculation
+ * @hash: Buffer for hash value or %NULL if caller is just freeing the hash
+ * context
+ * @len: Pointer to length of the buffer or %NULL if caller is just freeing the
+ * hash context; on return, this is set to the actual length of the hash value
+ * Returns: 0 on success, -1 if buffer is too small (len set to needed length),
+ * or -2 on other failures (including failed crypto_hash_update() operations)
+ * This function calculates the hash value and frees the context buffer that
+ * was used for hash calculation.
+int crypto_hash_finish(struct crypto_hash *ctx, u8 *hash, size_t *len);
+enum crypto_cipher_alg {
+	CRYPTO_CIPHER_NULL = 0, CRYPTO_CIPHER_ALG_AES, CRYPTO_CIPHER_ALG_3DES,
+	CRYPTO_CIPHER_ALG_DES, CRYPTO_CIPHER_ALG_RC2, CRYPTO_CIPHER_ALG_RC4
+struct crypto_cipher;
+ * crypto_cipher_init - Initialize block/stream cipher function
+ * @alg: Cipher algorithm
+ * @iv: Initialization vector for block ciphers or %NULL for stream ciphers
+ * @key: Cipher key
+ * @key_len: Length of key in bytes
+ * Returns: Pointer to cipher context to use with other cipher functions or
+ * %NULL on failure
+struct crypto_cipher * crypto_cipher_init(enum crypto_cipher_alg alg,
+					  const u8 *iv, const u8 *key,
+					  size_t key_len);
+ * crypto_cipher_encrypt - Cipher encrypt
+ * @ctx: Context pointer from crypto_cipher_init()
+ * @plain: Plaintext to cipher
+ * @crypt: Resulting ciphertext
+ * @len: Length of the plaintext
+int __must_check crypto_cipher_encrypt(struct crypto_cipher *ctx,
+				       const u8 *plain, u8 *crypt, size_t len);
+ * crypto_cipher_decrypt - Cipher decrypt
+ * @crypt: Ciphertext to decrypt
+ * @plain: Resulting plaintext
+ * @len: Length of the cipher text
+int __must_check crypto_cipher_decrypt(struct crypto_cipher *ctx,
+				       const u8 *crypt, u8 *plain, size_t len);
+ * crypto_cipher_decrypt - Free cipher context
+void crypto_cipher_deinit(struct crypto_cipher *ctx);
+struct crypto_public_key;
+struct crypto_private_key;
+ * crypto_public_key_import - Import an RSA public key
+ * @key: Key buffer (DER encoded RSA public key)
+ * @len: Key buffer length in bytes
+ * Returns: Pointer to the public key or %NULL on failure
+ * This function can just return %NULL if the crypto library supports X.509
+ * parsing. In that case, crypto_public_key_from_cert() is used to import the
+ * public key from a certificate.
+struct crypto_public_key * crypto_public_key_import(const u8 *key, size_t len);
+crypto_public_key_import_parts(const u8 *n, size_t n_len,
+			       const u8 *e, size_t e_len);
+ * crypto_private_key_import - Import an RSA private key
+ * @key: Key buffer (DER encoded RSA private key)
+ * @passwd: Key encryption password or %NULL if key is not encrypted
+ * Returns: Pointer to the private key or %NULL on failure
+struct crypto_private_key * crypto_private_key_import(const u8 *key,
+						      size_t len,
+						      const char *passwd);
+ * crypto_public_key_from_cert - Import an RSA public key from a certificate
+ * @buf: DER encoded X.509 certificate
+ * @len: Certificate buffer length in bytes
+ * Returns: Pointer to public key or %NULL on failure
+ * This function can just return %NULL if the crypto library does not support
+ * X.509 parsing. In that case, internal code will be used to parse the
+ * certificate and public key is imported using crypto_public_key_import().
+struct crypto_public_key * crypto_public_key_from_cert(const u8 *buf,
+						       size_t len);
+ * crypto_public_key_encrypt_pkcs1_v15 - Public key encryption (PKCS #1 v1.5)
+ * @key: Public key
+ * @in: Plaintext buffer
+ * @inlen: Length of plaintext buffer in bytes
+ * @out: Output buffer for encrypted data
+ * @outlen: Length of output buffer in bytes; set to used length on success
+int __must_check crypto_public_key_encrypt_pkcs1_v15(
+	struct crypto_public_key *key, const u8 *in, size_t inlen,
+	u8 *out, size_t *outlen);
+ * crypto_private_key_decrypt_pkcs1_v15 - Private key decryption (PKCS #1 v1.5)
+ * @key: Private key
+ * @in: Encrypted buffer
+ * @inlen: Length of encrypted buffer in bytes
+int __must_check crypto_private_key_decrypt_pkcs1_v15(
+	struct crypto_private_key *key, const u8 *in, size_t inlen,
+ * crypto_private_key_sign_pkcs1 - Sign with private key (PKCS #1)
+ * @key: Private key from crypto_private_key_import()
+ * @out: Output buffer for encrypted (signed) data
+int __must_check crypto_private_key_sign_pkcs1(struct crypto_private_key *key,
+					       const u8 *in, size_t inlen,
+ * crypto_public_key_free - Free public key
+void crypto_public_key_free(struct crypto_public_key *key);
+ * crypto_private_key_free - Free private key
+void crypto_private_key_free(struct crypto_private_key *key);
+ * crypto_public_key_decrypt_pkcs1 - Decrypt PKCS #1 signature
+ * @crypt: Encrypted signature data (using the private key)
+ * @crypt_len: Encrypted signature data length
+ * @plain: Buffer for plaintext (at least crypt_len bytes)
+ * @plain_len: Plaintext length (max buffer size on input, real len on output);
+int __must_check crypto_public_key_decrypt_pkcs1(
+	struct crypto_public_key *key, const u8 *crypt, size_t crypt_len,
+	u8 *plain, size_t *plain_len);
+ * crypto_global_init - Initialize crypto wrapper
+int __must_check crypto_global_init(void);
+ * crypto_global_deinit - Deinitialize crypto wrapper
+void crypto_global_deinit(void);
+ * crypto_mod_exp - Modular exponentiation of large integers
+ * @base: Base integer (big endian byte array)
+ * @base_len: Length of base integer in bytes
+ * @power: Power integer (big endian byte array)
+ * @power_len: Length of power integer in bytes
+ * @modulus: Modulus integer (big endian byte array)
+ * @modulus_len: Length of modulus integer in bytes
+ * @result: Buffer for the result
+ * @result_len: Result length (max buffer size on input, real len on output)
+ * This function calculates result = base ^ power mod modulus. modules_len is
+ * used as the maximum size of modulus buffer. It is set to the used size on
+ * success.
+int __must_check crypto_mod_exp(const u8 *base, size_t base_len,
+				const u8 *power, size_t power_len,
+				const u8 *modulus, size_t modulus_len,
+				u8 *result, size_t *result_len);
+ * rc4_skip - XOR RC4 stream to given data with skip-stream-start
+ * @key: RC4 key
+ * @keylen: RC4 key length
+ * @skip: number of bytes to skip from the beginning of the RC4 stream
+ * @data: data to be XOR'ed with RC4 stream
+ * @data_len: buf length
+ * Generate RC4 pseudo random stream for the given key, skip beginning of the
+ * stream, and XOR the end result with the data buffer to perform RC4
+ * encryption/decryption.
+int rc4_skip(const u8 *key, size_t keylen, size_t skip,
+ * crypto_get_random - Generate cryptographically strong pseudy-random bytes
+ * @buf: Buffer for data
+ * @len: Number of bytes to generate
+ * If the PRNG does not have enough entropy to ensure unpredictable byte
+ * sequence, this functions must return -1.
+int crypto_get_random(void *buf, size_t len);
+ * struct crypto_bignum - bignum
+ * Internal data structure for bignum implementation. The contents is specific
+ * to the used crypto library.
+struct crypto_bignum;
+ * crypto_bignum_init - Allocate memory for bignum
+ * Returns: Pointer to allocated bignum or %NULL on failure
+struct crypto_bignum * crypto_bignum_init(void);
+ * crypto_bignum_init_set - Allocate memory for bignum and set the value
+ * @buf: Buffer with unsigned binary value
+ * @len: Length of buf in octets
+struct crypto_bignum * crypto_bignum_init_set(const u8 *buf, size_t len);
+ * crypto_bignum_deinit - Free bignum
+ * @n: Bignum from crypto_bignum_init() or crypto_bignum_init_set()
+ * @clear: Whether to clear the value from memory
+void crypto_bignum_deinit(struct crypto_bignum *n, int clear);
+ * crypto_bignum_to_bin - Set binary buffer to unsigned bignum
+ * @a: Bignum
+ * @buf: Buffer for the binary number
+ * @len: Length of @buf in octets
+ * @padlen: Length in octets to pad the result to or 0 to indicate no padding
+ * Returns: Number of octets written on success, -1 on failure
+int crypto_bignum_to_bin(const struct crypto_bignum *a,
+			 u8 *buf, size_t buflen, size_t padlen);
+ * crypto_bignum_add - c = a + b
+ * @a: Bignum
+ * @b: Bignum
+ * @c: Bignum; used to store the result of a + b
+int crypto_bignum_add(const struct crypto_bignum *a,
+		      const struct crypto_bignum *b,
+		      struct crypto_bignum *c);
+ * crypto_bignum_mod - c = a % b
+ * @a: Bignum
+ * @b: Bignum
+ * @c: Bignum; used to store the result of a % b
+int crypto_bignum_mod(const struct crypto_bignum *a,
+ * crypto_bignum_exptmod - Modular exponentiation: d = a^b (mod c)
+ * @a: Bignum; base
+ * @b: Bignum; exponent
+ * @c: Bignum; modulus
+ * @d: Bignum; used to store the result of a^b (mod c)
+int crypto_bignum_exptmod(const struct crypto_bignum *a,
+			  const struct crypto_bignum *c,
+			  struct crypto_bignum *d);
+ * crypto_bignum_inverse - Inverse a bignum so that a * c = 1 (mod b)
+ * @a: Bignum
+ * @b: Bignum
+int crypto_bignum_inverse(const struct crypto_bignum *a,
+ * crypto_bignum_sub - c = a - b
+ * @a: Bignum
+ * @b: Bignum
+ * @c: Bignum; used to store the result of a - b
+int crypto_bignum_sub(const struct crypto_bignum *a,
+ * crypto_bignum_div - c = a / b
+ * @a: Bignum
+ * @b: Bignum
+ * @c: Bignum; used to store the result of a / b
+int crypto_bignum_div(const struct crypto_bignum *a,
+ * crypto_bignum_mulmod - d = a * b (mod c)
+ * @a: Bignum
+ * @b: Bignum
+ * @c: Bignum
+ * @d: Bignum; used to store the result of (a * b) % c
+int crypto_bignum_mulmod(const struct crypto_bignum *a,
+ * crypto_bignum_cmp - Compare two bignums
+ * @a: Bignum
+ * @b: Bignum
+ * Returns: -1 if a < b, 0 if a == b, or 1 if a > b
+int crypto_bignum_cmp(const struct crypto_bignum *a,
+		      const struct crypto_bignum *b);
+ * crypto_bignum_bits - Get size of a bignum in bits
+ * @a: Bignum
+ * Returns: Number of bits in the bignum
+int crypto_bignum_bits(const struct crypto_bignum *a);
+ * crypto_bignum_is_zero - Is the given bignum zero
+ * @a: Bignum
+ * Returns: 1 if @a is zero or 0 if not
+int crypto_bignum_is_zero(const struct crypto_bignum *a);
+ * crypto_bignum_is_one - Is the given bignum one
+ * @a: Bignum
+ * Returns: 1 if @a is one or 0 if not
+int crypto_bignum_is_one(const struct crypto_bignum *a);
+ * crypto_bignum_legendre - Compute the Legendre symbol (a/p)
+ * @a: Bignum
+ * @p: Bignum
+ * Returns: Legendre symbol -1,0,1 on success; -2 on calculation failure
+int crypto_bignum_legendre(const struct crypto_bignum *a,
+			   const struct crypto_bignum *p);
+ * struct crypto_ec - Elliptic curve context
+ * Internal data structure for EC implementation. The contents is specific
+struct crypto_ec;
+ * crypto_ec_init - Initialize elliptic curve context
+ * @group: Identifying number for the ECC group (IANA "Group Description"
+ *	attribute registrty for RFC 2409)
+ * Returns: Pointer to EC context or %NULL on failure
+struct crypto_ec * crypto_ec_init(int group);
+ * crypto_ec_deinit - Deinitialize elliptic curve context
+ * @e: EC context from crypto_ec_init()
+void crypto_ec_deinit(struct crypto_ec *e);
+ * crypto_ec_prime_len - Get length of the prime in octets
+ * Returns: Length of the prime defining the group
+size_t crypto_ec_prime_len(struct crypto_ec *e);
+ * crypto_ec_prime_len_bits - Get length of the prime in bits
+ * Returns: Length of the prime defining the group in bits
+size_t crypto_ec_prime_len_bits(struct crypto_ec *e);
+ * crypto_ec_get_prime - Get prime defining an EC group
+ * Returns: Prime (bignum) defining the group
+const struct crypto_bignum * crypto_ec_get_prime(struct crypto_ec *e);
+ * crypto_ec_get_order - Get order of an EC group
+ * Returns: Order (bignum) of the group
+const struct crypto_bignum * crypto_ec_get_order(struct crypto_ec *e);
+ * struct crypto_ec_point - Elliptic curve point
+ * Internal data structure for EC implementation to represent a point. The
+ * contents is specific to the used crypto library.
+struct crypto_ec_point;
+ * crypto_ec_point_init - Initialize data for an EC point
+ * Returns: Pointer to EC point data or %NULL on failure
+struct crypto_ec_point * crypto_ec_point_init(struct crypto_ec *e);
+ * crypto_ec_point_deinit - Deinitialize EC point data
+ * @p: EC point data from crypto_ec_point_init()
+ * @clear: Whether to clear the EC point value from memory
+void crypto_ec_point_deinit(struct crypto_ec_point *p, int clear);
+ * crypto_ec_point_to_bin - Write EC point value as binary data
+ * @x: Buffer for writing the binary data for x coordinate or %NULL if not used
+ * @y: Buffer for writing the binary data for y coordinate or %NULL if not used
+ * This function can be used to write an EC point as binary data in a format
+ * that has the x and y coordinates in big endian byte order fields padded to
+ * the length of the prime defining the group.
+int crypto_ec_point_to_bin(struct crypto_ec *e,
+			   const struct crypto_ec_point *point, u8 *x, u8 *y);
+ * crypto_ec_point_from_bin - Create EC point from binary data
+ * @val: Binary data to read the EC point from
+ * This function readers x and y coordinates of the EC point from the provided
+ * buffer assuming the values are in big endian byte order with fields padded to
+struct crypto_ec_point * crypto_ec_point_from_bin(struct crypto_ec *e,
+						  const u8 *val);
+ * @a: Bignum
+ * @b: Bignum
+int crypto_ec_point_add(struct crypto_ec *e, const struct crypto_ec_point *a,
+			const struct crypto_ec_point *b,
+			struct crypto_ec_point *c);
+ * crypto_bignum_mul - res = b * p
+ * @p: EC point
+ * @b: Bignum
+ * @res: EC point; used to store the result of b * p
+int crypto_ec_point_mul(struct crypto_ec *e, const struct crypto_ec_point *p,
+			struct crypto_ec_point *res);
+ * crypto_ec_point_invert - Compute inverse of an EC point
+ * @p: EC point to invert (and result of the operation)
+int crypto_ec_point_invert(struct crypto_ec *e, struct crypto_ec_point *p);
+ * crypto_ec_point_solve_y_coord - Solve y coordinate for an x coordinate
+ * @p: EC point to use for the returning the result
+ * @x: x coordinate
+ * @y_bit: y-bit (0 or 1) for selecting the y value to use
+int crypto_ec_point_solve_y_coord(struct crypto_ec *e,
+				  struct crypto_ec_point *p,
+				  const struct crypto_bignum *x, int y_bit);
+ * crypto_ec_point_compute_y_sqr - Compute y^2 = x^3 + ax + b
+ * Returns: y^2 on success, %NULL failure
+crypto_ec_point_compute_y_sqr(struct crypto_ec *e,
+			      const struct crypto_bignum *x);
+ * crypto_ec_point_is_at_infinity - Check whether EC point is neutral element
+ * @p: EC point
+ * Returns: 1 if the specified EC point is the neutral element of the group or
+ *	0 if not
+int crypto_ec_point_is_at_infinity(struct crypto_ec *e,
+				   const struct crypto_ec_point *p);
+ * crypto_ec_point_is_on_curve - Check whether EC point is on curve
+ * @p: EC point
+ * Returns: 1 if the specified EC point is on the curve or 0 if not
+int crypto_ec_point_is_on_curve(struct crypto_ec *e,
+ * crypto_ec_point_cmp - Compare two EC points
+ * @a: EC point
+ * @b: EC point
+ * Returns: 0 on equal, non-zero otherwise
+int crypto_ec_point_cmp(const struct crypto_ec *e,
+			const struct crypto_ec_point *a,
+			const struct crypto_ec_point *b);
+#endif /* CRYPTO_H */
diff --git a/freebsd/contrib/wpa/src/crypto/crypto_openssl.c b/freebsd/contrib/wpa/src/crypto/crypto_openssl.c
index 00000000000..836304226ed
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/crypto_openssl.c
@@ -0,0 +1,1444 @@
+ * Wrapper functions for OpenSSL libcrypto
+ * Copyright (c) 2004-2015, Jouni Malinen <j at w1.fi>
+#include <openssl/opensslv.h>
+#include <openssl/err.h>
+#include <openssl/des.h>
+#include <openssl/aes.h>
+#include <openssl/bn.h>
+#include <openssl/evp.h>
+#include <openssl/dh.h>
+#include <openssl/hmac.h>
+#include <openssl/rand.h>
+#ifdef CONFIG_OPENSSL_CMAC
+#include <openssl/cmac.h>
+#endif /* CONFIG_OPENSSL_CMAC */
+#ifdef CONFIG_ECC
+#include <openssl/ec.h>
+#endif /* CONFIG_ECC */
+#include "wpabuf.h"
+#include "dh_group5.h"
+#include "sha1.h"
+#include "sha256.h"
+#include "sha384.h"
+#include "crypto.h"
+static BIGNUM * get_group5_prime(void)
+#ifdef OPENSSL_IS_BORINGSSL
+	static const unsigned char RFC3526_PRIME_1536[] = {
+		0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC9,0x0F,0xDA,0xA2,
+		0x21,0x68,0xC2,0x34,0xC4,0xC6,0x62,0x8B,0x80,0xDC,0x1C,0xD1,
+		0x29,0x02,0x4E,0x08,0x8A,0x67,0xCC,0x74,0x02,0x0B,0xBE,0xA6,
+		0x3B,0x13,0x9B,0x22,0x51,0x4A,0x08,0x79,0x8E,0x34,0x04,0xDD,
+		0xEF,0x95,0x19,0xB3,0xCD,0x3A,0x43,0x1B,0x30,0x2B,0x0A,0x6D,
+		0xF2,0x5F,0x14,0x37,0x4F,0xE1,0x35,0x6D,0x6D,0x51,0xC2,0x45,
+		0xE4,0x85,0xB5,0x76,0x62,0x5E,0x7E,0xC6,0xF4,0x4C,0x42,0xE9,
+		0xA6,0x37,0xED,0x6B,0x0B,0xFF,0x5C,0xB6,0xF4,0x06,0xB7,0xED,
+		0xEE,0x38,0x6B,0xFB,0x5A,0x89,0x9F,0xA5,0xAE,0x9F,0x24,0x11,
+		0x7C,0x4B,0x1F,0xE6,0x49,0x28,0x66,0x51,0xEC,0xE4,0x5B,0x3D,
+		0xC2,0x00,0x7C,0xB8,0xA1,0x63,0xBF,0x05,0x98,0xDA,0x48,0x36,
+		0x1C,0x55,0xD3,0x9A,0x69,0x16,0x3F,0xA8,0xFD,0x24,0xCF,0x5F,
+		0x83,0x65,0x5D,0x23,0xDC,0xA3,0xAD,0x96,0x1C,0x62,0xF3,0x56,
+		0x20,0x85,0x52,0xBB,0x9E,0xD5,0x29,0x07,0x70,0x96,0x96,0x6D,
+		0x67,0x0C,0x35,0x4E,0x4A,0xBC,0x98,0x04,0xF1,0x74,0x6C,0x08,
+		0xCA,0x23,0x73,0x27,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
+        return BN_bin2bn(RFC3526_PRIME_1536, sizeof(RFC3526_PRIME_1536), NULL);
+#else /* OPENSSL_IS_BORINGSSL */
+	return get_rfc3526_prime_1536(NULL);
+#endif /* OPENSSL_IS_BORINGSSL */
+#ifdef OPENSSL_NO_SHA256
+#define NO_SHA256_WRAPPER
+#endif
+static int openssl_digest_vector(const EVP_MD *type, size_t num_elem,
+	EVP_MD_CTX ctx;
+	size_t i;
+	unsigned int mac_len;
+	EVP_MD_CTX_init(&ctx);
+	if (!EVP_DigestInit_ex(&ctx, type, NULL)) {
+		wpa_printf(MSG_ERROR, "OpenSSL: EVP_DigestInit_ex failed: %s",
+			   ERR_error_string(ERR_get_error(), NULL));
+		return -1;
+	for (i = 0; i < num_elem; i++) {
+		if (!EVP_DigestUpdate(&ctx, addr[i], len[i])) {
+			wpa_printf(MSG_ERROR, "OpenSSL: EVP_DigestUpdate "
+				   "failed: %s",
+			return -1;
+	if (!EVP_DigestFinal(&ctx, mac, &mac_len)) {
+		wpa_printf(MSG_ERROR, "OpenSSL: EVP_DigestFinal failed: %s",
+		return -1;
+	return 0;
+#ifndef CONFIG_FIPS
+	return openssl_digest_vector(EVP_md4(), num_elem, addr, len, mac);
+#endif /* CONFIG_FIPS */
+	u8 pkey[8], next, tmp;
+	int i;
+	DES_key_schedule ks;
+	/* Add parity bits to the key */
+	next = 0;
+	for (i = 0; i < 7; i++) {
+		tmp = key[i];
+		pkey[i] = (tmp >> i) | next | 1;
+		next = tmp << (7 - i);
+	pkey[i] = next | 1;
+	DES_set_key((DES_cblock *) &pkey, &ks);
+	DES_ecb_encrypt((DES_cblock *) clear, (DES_cblock *) cypher, &ks,
+			DES_ENCRYPT);
+#ifndef CONFIG_NO_RC4
+#ifdef OPENSSL_NO_RC4
+	return -1;
+#else /* OPENSSL_NO_RC4 */
+	EVP_CIPHER_CTX ctx;
+	int outl;
+	int res = -1;
+	unsigned char skip_buf[16];
+	EVP_CIPHER_CTX_init(&ctx);
+	if (!EVP_CIPHER_CTX_set_padding(&ctx, 0) ||
+	    !EVP_CipherInit_ex(&ctx, EVP_rc4(), NULL, NULL, NULL, 1) ||
+	    !EVP_CIPHER_CTX_set_key_length(&ctx, keylen) ||
+	    !EVP_CipherInit_ex(&ctx, NULL, NULL, key, NULL, 1))
+		goto out;
+	while (skip >= sizeof(skip_buf)) {
+		size_t len = skip;
+		if (len > sizeof(skip_buf))
+			len = sizeof(skip_buf);
+		if (!EVP_CipherUpdate(&ctx, skip_buf, &outl, skip_buf, len))
+			goto out;
+		skip -= len;
+	if (EVP_CipherUpdate(&ctx, data, &outl, data, data_len))
+		res = 0;
+out:
+	EVP_CIPHER_CTX_cleanup(&ctx);
+	return res;
+#endif /* OPENSSL_NO_RC4 */
+#endif /* CONFIG_NO_RC4 */
+	return openssl_digest_vector(EVP_md5(), num_elem, addr, len, mac);
+int sha1_vector(size_t num_elem, const u8 *addr[], const size_t *len, u8 *mac)
+	return openssl_digest_vector(EVP_sha1(), num_elem, addr, len, mac);
+#ifndef NO_SHA256_WRAPPER
+		  u8 *mac)
+	return openssl_digest_vector(EVP_sha256(), num_elem, addr, len, mac);
+#endif /* NO_SHA256_WRAPPER */
+static const EVP_CIPHER * aes_get_evp_cipher(size_t keylen)
+	switch (keylen) {
+	case 16:
+		return EVP_aes_128_ecb();
+#ifndef OPENSSL_IS_BORINGSSL
+	case 24:
+		return EVP_aes_192_ecb();
+	case 32:
+		return EVP_aes_256_ecb();
+	return NULL;
+	EVP_CIPHER_CTX *ctx;
+	const EVP_CIPHER *type;
+	type = aes_get_evp_cipher(len);
+	if (type == NULL)
+		return NULL;
+	ctx = os_malloc(sizeof(*ctx));
+	if (ctx == NULL)
+		return NULL;
+	EVP_CIPHER_CTX_init(ctx);
+	if (EVP_EncryptInit_ex(ctx, type, NULL, key, NULL) != 1) {
+		os_free(ctx);
+		return NULL;
+	EVP_CIPHER_CTX_set_padding(ctx, 0);
+	return ctx;
+	EVP_CIPHER_CTX *c = ctx;
+	int clen = 16;
+	if (EVP_EncryptUpdate(c, crypt, &clen, plain, 16) != 1) {
+		wpa_printf(MSG_ERROR, "OpenSSL: EVP_EncryptUpdate failed: %s",
+	u8 buf[16];
+	int len = sizeof(buf);
+	if (EVP_EncryptFinal_ex(c, buf, &len) != 1) {
+		wpa_printf(MSG_ERROR, "OpenSSL: EVP_EncryptFinal_ex failed: "
+			   "%s", ERR_error_string(ERR_get_error(), NULL));
+	if (len != 0) {
+		wpa_printf(MSG_ERROR, "OpenSSL: Unexpected padding length %d "
+			   "in AES encrypt", len);
+	EVP_CIPHER_CTX_cleanup(c);
+	bin_clear_free(c, sizeof(*c));
+	if (type == NULL)
+		return NULL;
+	if (ctx == NULL)
+		return NULL;
+	if (EVP_DecryptInit_ex(ctx, type, NULL, key, NULL) != 1) {
+		os_free(ctx);
+		return NULL;
+	return ctx;
+	int plen = 16;
+	if (EVP_DecryptUpdate(c, plain, &plen, crypt, 16) != 1) {
+		wpa_printf(MSG_ERROR, "OpenSSL: EVP_DecryptUpdate failed: %s",
+	u8 buf[16];
+	if (EVP_DecryptFinal_ex(c, buf, &len) != 1) {
+		wpa_printf(MSG_ERROR, "OpenSSL: EVP_DecryptFinal_ex failed: "
+	if (len != 0) {
+			   "in AES decrypt", len);
+#ifndef CONFIG_OPENSSL_INTERNAL_AES_WRAP
+int aes_wrap(const u8 *kek, size_t kek_len, int n, const u8 *plain, u8 *cipher)
+	AES_KEY actx;
+	int res;
+	if (AES_set_encrypt_key(kek, kek_len << 3, &actx))
+		return -1;
+	res = AES_wrap_key(&actx, NULL, cipher, plain, n * 8);
+	OPENSSL_cleanse(&actx, sizeof(actx));
+	return res <= 0 ? -1 : 0;
+	       u8 *plain)
+	AES_KEY actx;
+	int res;
+	if (AES_set_decrypt_key(kek, kek_len << 3, &actx))
+		return -1;
+	res = AES_unwrap_key(&actx, NULL, plain, cipher, (n + 1) * 8);
+#endif /* CONFIG_OPENSSL_INTERNAL_AES_WRAP */
+int aes_128_cbc_encrypt(const u8 *key, const u8 *iv, u8 *data, size_t data_len)
+	int clen, len;
+	u8 buf[16];
+	if (EVP_EncryptInit_ex(&ctx, EVP_aes_128_cbc(), NULL, key, iv) != 1)
+		return -1;
+	EVP_CIPHER_CTX_set_padding(&ctx, 0);
+	clen = data_len;
+	if (EVP_EncryptUpdate(&ctx, data, &clen, data, data_len) != 1 ||
+	    clen != (int) data_len)
+		return -1;
+	len = sizeof(buf);
+	if (EVP_EncryptFinal_ex(&ctx, buf, &len) != 1 || len != 0)
+		return -1;
+	return 0;
+int aes_128_cbc_decrypt(const u8 *key, const u8 *iv, u8 *data, size_t data_len)
+	int plen, len;
+	u8 buf[16];
+	if (EVP_DecryptInit_ex(&ctx, EVP_aes_128_cbc(), NULL, key, iv) != 1)
+		return -1;
+	plen = data_len;
+	if (EVP_DecryptUpdate(&ctx, data, &plen, data, data_len) != 1 ||
+	    plen != (int) data_len)
+		return -1;
+	if (EVP_DecryptFinal_ex(&ctx, buf, &len) != 1 || len != 0)
+		return -1;
+	return 0;
+int crypto_mod_exp(const u8 *base, size_t base_len,
+	BIGNUM *bn_base, *bn_exp, *bn_modulus, *bn_result;
+	int ret = -1;
+	BN_CTX *ctx;
+	ctx = BN_CTX_new();
+	if (ctx == NULL)
+		return -1;
+	bn_base = BN_bin2bn(base, base_len, NULL);
+	bn_exp = BN_bin2bn(power, power_len, NULL);
+	bn_modulus = BN_bin2bn(modulus, modulus_len, NULL);
+	bn_result = BN_new();
+	if (bn_base == NULL || bn_exp == NULL || bn_modulus == NULL ||
+	    bn_result == NULL)
+		goto error;
+	if (BN_mod_exp(bn_result, bn_base, bn_exp, bn_modulus, ctx) != 1)
+		goto error;
+	*result_len = BN_bn2bin(bn_result, result);
+	ret = 0;
+error:
+	BN_clear_free(bn_base);
+	BN_clear_free(bn_exp);
+	BN_clear_free(bn_modulus);
+	BN_clear_free(bn_result);
+	BN_CTX_free(ctx);
+	return ret;
+struct crypto_cipher {
+	EVP_CIPHER_CTX enc;
+	EVP_CIPHER_CTX dec;
+					  size_t key_len)
+	struct crypto_cipher *ctx;
+	const EVP_CIPHER *cipher;
+	ctx = os_zalloc(sizeof(*ctx));
+	if (ctx == NULL)
+		return NULL;
+	switch (alg) {
+#ifndef OPENSSL_NO_RC4
+	case CRYPTO_CIPHER_ALG_RC4:
+		cipher = EVP_rc4();
+		break;
+#ifndef OPENSSL_NO_AES
+	case CRYPTO_CIPHER_ALG_AES:
+		switch (key_len) {
+		case 16:
+			cipher = EVP_aes_128_cbc();
+			break;
+		case 24:
+			cipher = EVP_aes_192_cbc();
+			break;
+		case 32:
+			cipher = EVP_aes_256_cbc();
+			break;
+		default:
+			os_free(ctx);
+			return NULL;
+		break;
+#endif /* OPENSSL_NO_AES */
+#ifndef OPENSSL_NO_DES
+	case CRYPTO_CIPHER_ALG_3DES:
+		cipher = EVP_des_ede3_cbc();
+		break;
+	case CRYPTO_CIPHER_ALG_DES:
+		cipher = EVP_des_cbc();
+		break;
+#endif /* OPENSSL_NO_DES */
+#ifndef OPENSSL_NO_RC2
+	case CRYPTO_CIPHER_ALG_RC2:
+		cipher = EVP_rc2_ecb();
+		break;
+#endif /* OPENSSL_NO_RC2 */
+	default:
+		os_free(ctx);
+		return NULL;
+	EVP_CIPHER_CTX_init(&ctx->enc);
+	EVP_CIPHER_CTX_set_padding(&ctx->enc, 0);
+	if (!EVP_EncryptInit_ex(&ctx->enc, cipher, NULL, NULL, NULL) ||
+	    !EVP_CIPHER_CTX_set_key_length(&ctx->enc, key_len) ||
+	    !EVP_EncryptInit_ex(&ctx->enc, NULL, NULL, key, iv)) {
+		EVP_CIPHER_CTX_cleanup(&ctx->enc);
+		os_free(ctx);
+		return NULL;
+	EVP_CIPHER_CTX_init(&ctx->dec);
+	EVP_CIPHER_CTX_set_padding(&ctx->dec, 0);
+	if (!EVP_DecryptInit_ex(&ctx->dec, cipher, NULL, NULL, NULL) ||
+	    !EVP_CIPHER_CTX_set_key_length(&ctx->dec, key_len) ||
+	    !EVP_DecryptInit_ex(&ctx->dec, NULL, NULL, key, iv)) {
+		EVP_CIPHER_CTX_cleanup(&ctx->dec);
+		os_free(ctx);
+		return NULL;
+	return ctx;
+int crypto_cipher_encrypt(struct crypto_cipher *ctx, const u8 *plain,
+			  u8 *crypt, size_t len)
+	int outl;
+	if (!EVP_EncryptUpdate(&ctx->enc, crypt, &outl, plain, len))
+		return -1;
+	return 0;
+int crypto_cipher_decrypt(struct crypto_cipher *ctx, const u8 *crypt,
+			  u8 *plain, size_t len)
+	int outl;
+	outl = len;
+	if (!EVP_DecryptUpdate(&ctx->dec, plain, &outl, crypt, len))
+		return -1;
+	return 0;
+	os_free(ctx);
+void * dh5_init(struct wpabuf **priv, struct wpabuf **publ)
+	DH *dh;
+	struct wpabuf *pubkey = NULL, *privkey = NULL;
+	size_t publen, privlen;
+	*priv = NULL;
+	*publ = NULL;
+	dh = DH_new();
+	if (dh == NULL)
+		return NULL;
+	dh->g = BN_new();
+	if (dh->g == NULL || BN_set_word(dh->g, 2) != 1)
+		goto err;
+	dh->p = get_group5_prime();
+	if (dh->p == NULL)
+		goto err;
+	if (DH_generate_key(dh) != 1)
+		goto err;
+	publen = BN_num_bytes(dh->pub_key);
+	pubkey = wpabuf_alloc(publen);
+	if (pubkey == NULL)
+		goto err;
+	privlen = BN_num_bytes(dh->priv_key);
+	privkey = wpabuf_alloc(privlen);
+	if (privkey == NULL)
+		goto err;
+	BN_bn2bin(dh->pub_key, wpabuf_put(pubkey, publen));
+	BN_bn2bin(dh->priv_key, wpabuf_put(privkey, privlen));
+	*priv = privkey;
+	*publ = pubkey;
+	return dh;
+err:
+	wpabuf_clear_free(pubkey);
+	wpabuf_clear_free(privkey);
+	DH_free(dh);
+	return NULL;
+void * dh5_init_fixed(const struct wpabuf *priv, const struct wpabuf *publ)
+	DH *dh;
+	dh = DH_new();
+	if (dh == NULL)
+		return NULL;
+	dh->g = BN_new();
+		goto err;
+		goto err;
+	dh->priv_key = BN_bin2bn(wpabuf_head(priv), wpabuf_len(priv), NULL);
+	if (dh->priv_key == NULL)
+		goto err;
+	dh->pub_key = BN_bin2bn(wpabuf_head(publ), wpabuf_len(publ), NULL);
+	if (dh->pub_key == NULL)
+		goto err;
+		goto err;
+	return dh;
+err:
+	DH_free(dh);
+	return NULL;
+struct wpabuf * dh5_derive_shared(void *ctx, const struct wpabuf *peer_public,
+				  const struct wpabuf *own_private)
+	BIGNUM *pub_key;
+	struct wpabuf *res = NULL;
+	size_t rlen;
+	DH *dh = ctx;
+	int keylen;
+	if (ctx == NULL)
+		return NULL;
+	pub_key = BN_bin2bn(wpabuf_head(peer_public), wpabuf_len(peer_public),
+			    NULL);
+	if (pub_key == NULL)
+		return NULL;
+	rlen = DH_size(dh);
+	res = wpabuf_alloc(rlen);
+	if (res == NULL)
+		goto err;
+	keylen = DH_compute_key(wpabuf_mhead(res), pub_key, dh);
+	if (keylen < 0)
+		goto err;
+	wpabuf_put(res, keylen);
+	BN_clear_free(pub_key);
+	return res;
+err:
+	wpabuf_clear_free(res);
+	return NULL;
+void dh5_free(void *ctx)
+	DH *dh;
+	if (ctx == NULL)
+		return;
+	dh = ctx;
+	DH_free(dh);
+struct crypto_hash {
+	HMAC_CTX ctx;
+				      size_t key_len)
+	struct crypto_hash *ctx;
+	const EVP_MD *md;
+	switch (alg) {
+#ifndef OPENSSL_NO_MD5
+	case CRYPTO_HASH_ALG_HMAC_MD5:
+		md = EVP_md5();
+		break;
+#endif /* OPENSSL_NO_MD5 */
+#ifndef OPENSSL_NO_SHA
+	case CRYPTO_HASH_ALG_HMAC_SHA1:
+		md = EVP_sha1();
+		break;
+#endif /* OPENSSL_NO_SHA */
+#ifndef OPENSSL_NO_SHA256
+#ifdef CONFIG_SHA256
+	case CRYPTO_HASH_ALG_HMAC_SHA256:
+		md = EVP_sha256();
+		break;
+#endif /* CONFIG_SHA256 */
+#endif /* OPENSSL_NO_SHA256 */
+	default:
+		return NULL;
+	if (ctx == NULL)
+		return NULL;
+	HMAC_CTX_init(&ctx->ctx);
+#if OPENSSL_VERSION_NUMBER < 0x00909000
+	HMAC_Init_ex(&ctx->ctx, key, key_len, md, NULL);
+#else /* openssl < 0.9.9 */
+	if (HMAC_Init_ex(&ctx->ctx, key, key_len, md, NULL) != 1) {
+		bin_clear_free(ctx, sizeof(*ctx));
+		return NULL;
+#endif /* openssl < 0.9.9 */
+	return ctx;
+	if (ctx == NULL)
+		return;
+	HMAC_Update(&ctx->ctx, data, len);
+int crypto_hash_finish(struct crypto_hash *ctx, u8 *mac, size_t *len)
+	unsigned int mdlen;
+	int res;
+	if (ctx == NULL)
+		return -2;
+	if (mac == NULL || len == NULL) {
+		return 0;
+	mdlen = *len;
+	HMAC_Final(&ctx->ctx, mac, &mdlen);
+	res = 1;
+	res = HMAC_Final(&ctx->ctx, mac, &mdlen);
+	HMAC_CTX_cleanup(&ctx->ctx);
+	if (res == 1) {
+		*len = mdlen;
+		return 0;
+	return -1;
+static int openssl_hmac_vector(const EVP_MD *type, const u8 *key,
+			       size_t key_len, size_t num_elem,
+			       const u8 *addr[], const size_t *len, u8 *mac,
+			       unsigned int mdlen)
+	HMAC_CTX ctx;
+	size_t i;
+	int res;
+	HMAC_CTX_init(&ctx);
+	HMAC_Init_ex(&ctx, key, key_len, type, NULL);
+	if (HMAC_Init_ex(&ctx, key, key_len, type, NULL) != 1)
+		return -1;
+		HMAC_Update(&ctx, addr[i], len[i]);
+	HMAC_Final(&ctx, mac, &mdlen);
+	res = 1;
+	res = HMAC_Final(&ctx, mac, &mdlen);
+	HMAC_CTX_cleanup(&ctx);
+	return res == 1 ? 0 : -1;
+int hmac_md5_vector(const u8 *key, size_t key_len, size_t num_elem,
+	return openssl_hmac_vector(EVP_md5(), key ,key_len, num_elem, addr, len,
+				   mac, 16);
+int hmac_md5(const u8 *key, size_t key_len, const u8 *data, size_t data_len,
+	     u8 *mac)
+	return hmac_md5_vector(key, key_len, 1, &data, &data_len, mac);
+int pbkdf2_sha1(const char *passphrase, const u8 *ssid, size_t ssid_len,
+		int iterations, u8 *buf, size_t buflen)
+	if (PKCS5_PBKDF2_HMAC_SHA1(passphrase, os_strlen(passphrase), ssid,
+				   ssid_len, iterations, buflen, buf) != 1)
+		return -1;
+	return 0;
+int hmac_sha1_vector(const u8 *key, size_t key_len, size_t num_elem,
+	return openssl_hmac_vector(EVP_sha1(), key, key_len, num_elem, addr,
+				   len, mac, 20);
+int hmac_sha1(const u8 *key, size_t key_len, const u8 *data, size_t data_len,
+	       u8 *mac)
+	return hmac_sha1_vector(key, key_len, 1, &data, &data_len, mac);
+int hmac_sha256_vector(const u8 *key, size_t key_len, size_t num_elem,
+	return openssl_hmac_vector(EVP_sha256(), key, key_len, num_elem, addr,
+				   len, mac, 32);
+int hmac_sha256(const u8 *key, size_t key_len, const u8 *data,
+		size_t data_len, u8 *mac)
+	return hmac_sha256_vector(key, key_len, 1, &data, &data_len, mac);
+#ifdef CONFIG_SHA384
+int hmac_sha384_vector(const u8 *key, size_t key_len, size_t num_elem,
+	return openssl_hmac_vector(EVP_sha384(), key, key_len, num_elem, addr,
+				   len, mac, 32);
+int hmac_sha384(const u8 *key, size_t key_len, const u8 *data,
+	return hmac_sha384_vector(key, key_len, 1, &data, &data_len, mac);
+#endif /* CONFIG_SHA384 */
+	if (RAND_bytes(buf, len) != 1)
+		return -1;
+	return 0;
+	CMAC_CTX *ctx;
+	int ret = -1;
+	size_t outlen, i;
+	ctx = CMAC_CTX_new();
+	if (ctx == NULL)
+		return -1;
+	if (key_len == 32) {
+		if (!CMAC_Init(ctx, key, 32, EVP_aes_256_cbc(), NULL))
+			goto fail;
+	} else if (key_len == 16) {
+		if (!CMAC_Init(ctx, key, 16, EVP_aes_128_cbc(), NULL))
+			goto fail;
+	} else {
+		goto fail;
+		if (!CMAC_Update(ctx, addr[i], len[i]))
+			goto fail;
+	if (!CMAC_Final(ctx, mac, &outlen) || outlen != 16)
+		goto fail;
+	ret = 0;
+fail:
+	CMAC_CTX_free(ctx);
+	return ret;
+	return (struct crypto_bignum *) BN_new();
+	BIGNUM *bn = BN_bin2bn(buf, len, NULL);
+	return (struct crypto_bignum *) bn;
+	if (clear)
+		BN_clear_free((BIGNUM *) n);
+	else
+		BN_free((BIGNUM *) n);
+	int num_bytes, offset;
+	if (padlen > buflen)
+		return -1;
+	num_bytes = BN_num_bytes((const BIGNUM *) a);
+	if ((size_t) num_bytes > buflen)
+		return -1;
+	if (padlen > (size_t) num_bytes)
+		offset = padlen - num_bytes;
+	else
+		offset = 0;
+	os_memset(buf, 0, offset);
+	BN_bn2bin((const BIGNUM *) a, buf + offset);
+	return num_bytes + offset;
+	return BN_add((BIGNUM *) c, (const BIGNUM *) a, (const BIGNUM *) b) ?
+		0 : -1;
+	int res;
+	BN_CTX *bnctx;
+	bnctx = BN_CTX_new();
+	if (bnctx == NULL)
+		return -1;
+	res = BN_mod((BIGNUM *) c, (const BIGNUM *) a, (const BIGNUM *) b,
+		     bnctx);
+	BN_CTX_free(bnctx);
+	return res ? 0 : -1;
+	int res;
+	BN_CTX *bnctx;
+		return -1;
+	res = BN_mod_exp((BIGNUM *) d, (const BIGNUM *) a, (const BIGNUM *) b,
+			 (const BIGNUM *) c, bnctx);
+	BIGNUM *res;
+	BN_CTX *bnctx;
+		return -1;
+	res = BN_mod_inverse((BIGNUM *) c, (const BIGNUM *) a,
+			     (const BIGNUM *) b, bnctx);
+	return BN_sub((BIGNUM *) c, (const BIGNUM *) a, (const BIGNUM *) b) ?
+		0 : -1;
+	int res;
+	BN_CTX *bnctx;
+		return -1;
+	res = BN_div((BIGNUM *) c, NULL, (const BIGNUM *) a,
+	int res;
+	BN_CTX *bnctx;
+		return -1;
+	res = BN_mod_mul((BIGNUM *) d, (const BIGNUM *) a, (const BIGNUM *) b,
+	return BN_cmp((const BIGNUM *) a, (const BIGNUM *) b);
+	return BN_num_bits((const BIGNUM *) a);
+	return BN_is_zero((const BIGNUM *) a);
+	return BN_is_one((const BIGNUM *) a);
+	BN_CTX *bnctx;
+	BIGNUM *exp = NULL, *tmp = NULL;
+	int res = -2;
+		return -2;
+	exp = BN_new();
+	tmp = BN_new();
+	if (!exp || !tmp ||
+	    /* exp = (p-1) / 2 */
+	    !BN_sub(exp, (const BIGNUM *) p, BN_value_one()) ||
+	    !BN_rshift1(exp, exp) ||
+	    !BN_mod_exp(tmp, (const BIGNUM *) a, exp, (const BIGNUM *) p,
+			bnctx))
+		goto fail;
+	if (BN_is_word(tmp, 1))
+		res = 1;
+	else if (BN_is_zero(tmp))
+		res = 0;
+	else
+		res = -1;
+fail:
+	BN_clear_free(tmp);
+	BN_clear_free(exp);
+	return res;
+#ifdef CONFIG_ECC
+struct crypto_ec {
+	EC_GROUP *group;
+	BN_CTX *bnctx;
+	BIGNUM *prime;
+	BIGNUM *order;
+	BIGNUM *a;
+	BIGNUM *b;
+	struct crypto_ec *e;
+	int nid;
+	/* Map from IANA registry for IKE D-H groups to OpenSSL NID */
+	switch (group) {
+	case 19:
+		nid = NID_X9_62_prime256v1;
+		break;
+	case 20:
+		nid = NID_secp384r1;
+		break;
+	case 21:
+		nid = NID_secp521r1;
+		break;
+	case 25:
+		nid = NID_X9_62_prime192v1;
+		break;
+	case 26:
+		nid = NID_secp224r1;
+		break;
+#ifdef NID_brainpoolP224r1
+	case 27:
+		nid = NID_brainpoolP224r1;
+		break;
+#endif /* NID_brainpoolP224r1 */
+#ifdef NID_brainpoolP256r1
+	case 28:
+		nid = NID_brainpoolP256r1;
+		break;
+#endif /* NID_brainpoolP256r1 */
+#ifdef NID_brainpoolP384r1
+	case 29:
+		nid = NID_brainpoolP384r1;
+		break;
+#endif /* NID_brainpoolP384r1 */
+#ifdef NID_brainpoolP512r1
+	case 30:
+		nid = NID_brainpoolP512r1;
+		break;
+#endif /* NID_brainpoolP512r1 */
+	default:
+		return NULL;
+	e = os_zalloc(sizeof(*e));
+	if (e == NULL)
+		return NULL;
+	e->bnctx = BN_CTX_new();
+	e->group = EC_GROUP_new_by_curve_name(nid);
+	e->prime = BN_new();
+	e->order = BN_new();
+	e->a = BN_new();
+	e->b = BN_new();
+	if (e->group == NULL || e->bnctx == NULL || e->prime == NULL ||
+	    e->order == NULL || e->a == NULL || e->b == NULL ||
+	    !EC_GROUP_get_curve_GFp(e->group, e->prime, e->a, e->b, e->bnctx) ||
+	    !EC_GROUP_get_order(e->group, e->order, e->bnctx)) {
+		crypto_ec_deinit(e);
+		e = NULL;
+	return e;
+	if (e == NULL)
+		return;
+	BN_clear_free(e->b);
+	BN_clear_free(e->a);
+	BN_clear_free(e->order);
+	BN_clear_free(e->prime);
+	EC_GROUP_free(e->group);
+	BN_CTX_free(e->bnctx);
+	os_free(e);
+	if (e == NULL)
+		return NULL;
+	return (struct crypto_ec_point *) EC_POINT_new(e->group);
+	return BN_num_bytes(e->prime);
+	return BN_num_bits(e->prime);
+	return (const struct crypto_bignum *) e->prime;
+	return (const struct crypto_bignum *) e->order;
+	if (clear)
+		EC_POINT_clear_free((EC_POINT *) p);
+	else
+		EC_POINT_free((EC_POINT *) p);
+	BIGNUM *x_bn, *y_bn;
+	int ret = -1;
+	int len = BN_num_bytes(e->prime);
+	x_bn = BN_new();
+	y_bn = BN_new();
+	if (x_bn && y_bn &&
+	    EC_POINT_get_affine_coordinates_GFp(e->group, (EC_POINT *) point,
+						x_bn, y_bn, e->bnctx)) {
+		if (x) {
+			crypto_bignum_to_bin((struct crypto_bignum *) x_bn,
+					     x, len, len);
+		if (y) {
+			crypto_bignum_to_bin((struct crypto_bignum *) y_bn,
+					     y, len, len);
+		ret = 0;
+	BN_clear_free(x_bn);
+	BN_clear_free(y_bn);
+	return ret;
+						  const u8 *val)
+	BIGNUM *x, *y;
+	EC_POINT *elem;
+	x = BN_bin2bn(val, len, NULL);
+	y = BN_bin2bn(val + len, len, NULL);
+	elem = EC_POINT_new(e->group);
+	if (x == NULL || y == NULL || elem == NULL) {
+		BN_clear_free(x);
+		BN_clear_free(y);
+		EC_POINT_clear_free(elem);
+		return NULL;
+	if (!EC_POINT_set_affine_coordinates_GFp(e->group, elem, x, y,
+						 e->bnctx)) {
+		elem = NULL;
+	BN_clear_free(x);
+	BN_clear_free(y);
+	return (struct crypto_ec_point *) elem;
+	return EC_POINT_add(e->group, (EC_POINT *) c, (const EC_POINT *) a,
+			    (const EC_POINT *) b, e->bnctx) ? 0 : -1;
+	return EC_POINT_mul(e->group, (EC_POINT *) res, NULL,
+			    (const EC_POINT *) p, (const BIGNUM *) b, e->bnctx)
+		? 0 : -1;
+	return EC_POINT_invert(e->group, (EC_POINT *) p, e->bnctx) ? 0 : -1;
+	if (!EC_POINT_set_compressed_coordinates_GFp(e->group, (EC_POINT *) p,
+						     (const BIGNUM *) x, y_bit,
+						     e->bnctx) ||
+	    !EC_POINT_is_on_curve(e->group, (EC_POINT *) p, e->bnctx))
+		return -1;
+	return 0;
+	BIGNUM *tmp, *tmp2, *y_sqr = NULL;
+	tmp = BN_new();
+	tmp2 = BN_new();
+	/* y^2 = x^3 + ax + b */
+	if (tmp && tmp2 &&
+	    BN_mod_sqr(tmp, (const BIGNUM *) x, e->prime, e->bnctx) &&
+	    BN_mod_mul(tmp, tmp, (const BIGNUM *) x, e->prime, e->bnctx) &&
+	    BN_mod_mul(tmp2, e->a, (const BIGNUM *) x, e->prime, e->bnctx) &&
+	    BN_mod_add_quick(tmp2, tmp2, tmp, e->prime) &&
+	    BN_mod_add_quick(tmp2, tmp2, e->b, e->prime)) {
+		y_sqr = tmp2;
+		tmp2 = NULL;
+	BN_clear_free(tmp2);
+	return (struct crypto_bignum *) y_sqr;
+	return EC_POINT_is_at_infinity(e->group, (const EC_POINT *) p);
+	return EC_POINT_is_on_curve(e->group, (const EC_POINT *) p,
+				    e->bnctx) == 1;
+	return EC_POINT_cmp(e->group, (const EC_POINT *) a,
+			    (const EC_POINT *) b, e->bnctx);
diff --git a/freebsd/contrib/wpa/src/crypto/dh_group5.h b/freebsd/contrib/wpa/src/crypto/dh_group5.h
index 00000000000..abee8eaafbd
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/dh_group5.h
@@ -0,0 +1,18 @@
+ * Diffie-Hellman group 5 operations
+ * Copyright (c) 2009, 2012, Jouni Malinen <j at w1.fi>
+#ifndef DH_GROUP5_H
+#define DH_GROUP5_H
+void * dh5_init(struct wpabuf **priv, struct wpabuf **publ);
+void * dh5_init_fixed(const struct wpabuf *priv, const struct wpabuf *publ);
+				  const struct wpabuf *own_private);
+void dh5_free(void *ctx);
+#endif /* DH_GROUP5_H */
diff --git a/freebsd/contrib/wpa/src/crypto/md5.h b/freebsd/contrib/wpa/src/crypto/md5.h
index 00000000000..33f8426c57c
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/md5.h
@@ -0,0 +1,19 @@
+ * MD5 hash implementation and interface functions
+ * Copyright (c) 2003-2009, Jouni Malinen <j at w1.fi>
+#ifndef MD5_H
+#define MD5_H
+#define MD5_MAC_LEN 16
+		    const u8 *addr[], const size_t *len, u8 *mac);
+	     u8 *mac);
+#endif /* MD5_H */
diff --git a/freebsd/contrib/wpa/src/crypto/ms_funcs.c b/freebsd/contrib/wpa/src/crypto/ms_funcs.c
index 00000000000..dda2ba7c1ff
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/ms_funcs.c
@@ -0,0 +1,526 @@
+ * WPA Supplicant / shared MSCHAPV2 helper functions / RFC 2433 / RFC 2759
+ * Copyright (c) 2004-2012, Jouni Malinen <j at w1.fi>
+#include "sha1.h"
+#include "ms_funcs.h"
+ * utf8_to_ucs2 - Convert UTF-8 string to UCS-2 encoding
+ * @utf8_string: UTF-8 string (IN)
+ * @utf8_string_len: Length of utf8_string (IN)
+ * @ucs2_buffer: UCS-2 buffer (OUT)
+ * @ucs2_buffer_size: Length of UCS-2 buffer (IN)
+ * @ucs2_string_size: Number of 2-byte words in the resulting UCS-2 string
+static int utf8_to_ucs2(const u8 *utf8_string, size_t utf8_string_len,
+                        u8 *ucs2_buffer, size_t ucs2_buffer_size,
+                        size_t *ucs2_string_size)
+	size_t i, j;
+	for (i = 0, j = 0; i < utf8_string_len; i++) {
+		u8 c = utf8_string[i];
+		if (j >= ucs2_buffer_size) {
+			/* input too long */
+			return -1;
+		if (c <= 0x7F) {
+			WPA_PUT_LE16(ucs2_buffer + j, c);
+			j += 2;
+		} else if (i == utf8_string_len - 1 ||
+			   j >= ucs2_buffer_size - 1) {
+			/* incomplete surrogate */
+			return -1;
+		} else {
+			u8 c2 = utf8_string[++i];
+			if ((c & 0xE0) == 0xC0) {
+				/* two-byte encoding */
+					     ((c & 0x1F) << 6) | (c2 & 0x3F));
+				j += 2;
+			} else if (i == utf8_string_len ||
+				return -1;
+			} else {
+				/* three-byte encoding */
+				u8 c3 = utf8_string[++i];
+					     ((c & 0xF) << 12) |
+					     ((c2 & 0x3F) << 6) | (c3 & 0x3F));
+				j += 2;
+	if (ucs2_string_size)
+		*ucs2_string_size = j / 2;
+	return 0;
+ * challenge_hash - ChallengeHash() - RFC 2759, Sect. 8.2
+ * @peer_challenge: 16-octet PeerChallenge (IN)
+ * @auth_challenge: 16-octet AuthenticatorChallenge (IN)
+ * @username: 0-to-256-char UserName (IN)
+ * @username_len: Length of username
+ * @challenge: 8-octet Challenge (OUT)
+int challenge_hash(const u8 *peer_challenge, const u8 *auth_challenge,
+		   const u8 *username, size_t username_len, u8 *challenge)
+	u8 hash[SHA1_MAC_LEN];
+	const unsigned char *addr[3];
+	size_t len[3];
+	addr[0] = peer_challenge;
+	len[0] = 16;
+	addr[1] = auth_challenge;
+	len[1] = 16;
+	addr[2] = username;
+	len[2] = username_len;
+	if (sha1_vector(3, addr, len, hash))
+		return -1;
+	os_memcpy(challenge, hash, 8);
+	return 0;
+ * nt_password_hash - NtPasswordHash() - RFC 2759, Sect. 8.3
+ * @password: 0-to-256-unicode-char Password (IN; UTF-8)
+ * @password_len: Length of password
+ * @password_hash: 16-octet PasswordHash (OUT)
+int nt_password_hash(const u8 *password, size_t password_len,
+		      u8 *password_hash)
+	u8 buf[512], *pos;
+	size_t len, max_len;
+	max_len = sizeof(buf);
+	if (utf8_to_ucs2(password, password_len, buf, max_len, &len) < 0)
+		return -1;
+	len *= 2;
+	pos = buf;
+	return md4_vector(1, (const u8 **) &pos, &len, password_hash);
+ * hash_nt_password_hash - HashNtPasswordHash() - RFC 2759, Sect. 8.4
+ * @password_hash: 16-octet PasswordHash (IN)
+ * @password_hash_hash: 16-octet PasswordHashHash (OUT)
+int hash_nt_password_hash(const u8 *password_hash, u8 *password_hash_hash)
+	size_t len = 16;
+	return md4_vector(1, &password_hash, &len, password_hash_hash);
+ * challenge_response - ChallengeResponse() - RFC 2759, Sect. 8.5
+ * @challenge: 8-octet Challenge (IN)
+ * @response: 24-octet Response (OUT)
+void challenge_response(const u8 *challenge, const u8 *password_hash,
+			u8 *response)
+	u8 zpwd[7];
+	des_encrypt(challenge, password_hash, response);
+	des_encrypt(challenge, password_hash + 7, response + 8);
+	zpwd[0] = password_hash[14];
+	zpwd[1] = password_hash[15];
+	os_memset(zpwd + 2, 0, 5);
+	des_encrypt(challenge, zpwd, response + 16);
+ * generate_nt_response - GenerateNTResponse() - RFC 2759, Sect. 8.1
+int generate_nt_response(const u8 *auth_challenge, const u8 *peer_challenge,
+			 const u8 *password, size_t password_len,
+			 u8 *response)
+	u8 challenge[8];
+	u8 password_hash[16];
+	if (challenge_hash(peer_challenge, auth_challenge, username,
+			   username_len, challenge) ||
+	    nt_password_hash(password, password_len, password_hash))
+		return -1;
+	challenge_response(challenge, password_hash, response);
+	return 0;
+ * generate_nt_response_pwhash - GenerateNTResponse() - RFC 2759, Sect. 8.1
+int generate_nt_response_pwhash(const u8 *auth_challenge,
+				const u8 *peer_challenge,
+				const u8 *password_hash,
+				u8 *response)
+	u8 challenge[8];
+			   username, username_len,
+			   challenge))
+		return -1;
+	return 0;
+ * generate_authenticator_response_pwhash - GenerateAuthenticatorResponse() - RFC 2759, Sect. 8.7
+ * @nt_response: 24-octet NT-Response (IN)
+ * @response: 20-octet AuthenticatorResponse (OUT) (note: this value is usually
+ * encoded as a 42-octet ASCII string (S=hexdump_of_response)
+int generate_authenticator_response_pwhash(
+	const u8 *peer_challenge, const u8 *auth_challenge,
+	const u8 *nt_response, u8 *response)
+	static const u8 magic1[39] = {
+		0x4D, 0x61, 0x67, 0x69, 0x63, 0x20, 0x73, 0x65, 0x72, 0x76,
+		0x65, 0x72, 0x20, 0x74, 0x6F, 0x20, 0x63, 0x6C, 0x69, 0x65,
+		0x6E, 0x74, 0x20, 0x73, 0x69, 0x67, 0x6E, 0x69, 0x6E, 0x67,
+		0x20, 0x63, 0x6F, 0x6E, 0x73, 0x74, 0x61, 0x6E, 0x74
+	static const u8 magic2[41] = {
+		0x50, 0x61, 0x64, 0x20, 0x74, 0x6F, 0x20, 0x6D, 0x61, 0x6B,
+		0x65, 0x20, 0x69, 0x74, 0x20, 0x64, 0x6F, 0x20, 0x6D, 0x6F,
+		0x72, 0x65, 0x20, 0x74, 0x68, 0x61, 0x6E, 0x20, 0x6F, 0x6E,
+		0x65, 0x20, 0x69, 0x74, 0x65, 0x72, 0x61, 0x74, 0x69, 0x6F,
+		0x6E
+	u8 password_hash_hash[16], challenge[8];
+	const unsigned char *addr1[3];
+	const size_t len1[3] = { 16, 24, sizeof(magic1) };
+	const unsigned char *addr2[3];
+	const size_t len2[3] = { SHA1_MAC_LEN, 8, sizeof(magic2) };
+	addr1[0] = password_hash_hash;
+	addr1[1] = nt_response;
+	addr1[2] = magic1;
+	addr2[0] = response;
+	addr2[1] = challenge;
+	addr2[2] = magic2;
+	if (hash_nt_password_hash(password_hash, password_hash_hash) ||
+	    sha1_vector(3, addr1, len1, response) ||
+	    challenge_hash(peer_challenge, auth_challenge, username,
+			   username_len, challenge))
+		return -1;
+	return sha1_vector(3, addr2, len2, response);
+ * generate_authenticator_response - GenerateAuthenticatorResponse() - RFC 2759, Sect. 8.7
+int generate_authenticator_response(const u8 *password, size_t password_len,
+				    const u8 *auth_challenge,
+	if (nt_password_hash(password, password_len, password_hash))
+		return -1;
+	return generate_authenticator_response_pwhash(
+		password_hash, peer_challenge, auth_challenge,
+		username, username_len, nt_response, response);
+ * nt_challenge_response - NtChallengeResponse() - RFC 2433, Sect. A.5
+int nt_challenge_response(const u8 *challenge, const u8 *password,
+			  size_t password_len, u8 *response)
+		return -1;
+	return 0;
+ * get_master_key - GetMasterKey() - RFC 3079, Sect. 3.4
+ * @password_hash_hash: 16-octet PasswordHashHash (IN)
+ * @nt_response: 24-octet NTResponse (IN)
+ * @master_key: 16-octet MasterKey (OUT)
+int get_master_key(const u8 *password_hash_hash, const u8 *nt_response,
+		   u8 *master_key)
+	static const u8 magic1[27] = {
+		0x54, 0x68, 0x69, 0x73, 0x20, 0x69, 0x73, 0x20, 0x74,
+		0x68, 0x65, 0x20, 0x4d, 0x50, 0x50, 0x45, 0x20, 0x4d,
+		0x61, 0x73, 0x74, 0x65, 0x72, 0x20, 0x4b, 0x65, 0x79
+	const size_t len[3] = { 16, 24, sizeof(magic1) };
+	addr[0] = password_hash_hash;
+	addr[1] = nt_response;
+	addr[2] = magic1;
+		return -1;
+	os_memcpy(master_key, hash, 16);
+	return 0;
+ * get_asymetric_start_key - GetAsymetricStartKey() - RFC 3079, Sect. 3.4
+ * @master_key: 16-octet MasterKey (IN)
+ * @session_key: 8-to-16 octet SessionKey (OUT)
+ * @session_key_len: SessionKeyLength (Length of session_key) (IN)
+ * @is_send: IsSend (IN, BOOLEAN)
+ * @is_server: IsServer (IN, BOOLEAN)
+int get_asymetric_start_key(const u8 *master_key, u8 *session_key,
+			    size_t session_key_len, int is_send,
+			    int is_server)
+	static const u8 magic2[84] = {
+		0x4f, 0x6e, 0x20, 0x74, 0x68, 0x65, 0x20, 0x63, 0x6c, 0x69,
+		0x65, 0x6e, 0x74, 0x20, 0x73, 0x69, 0x64, 0x65, 0x2c, 0x20,
+		0x74, 0x68, 0x69, 0x73, 0x20, 0x69, 0x73, 0x20, 0x74, 0x68,
+		0x65, 0x20, 0x73, 0x65, 0x6e, 0x64, 0x20, 0x6b, 0x65, 0x79,
+		0x3b, 0x20, 0x6f, 0x6e, 0x20, 0x74, 0x68, 0x65, 0x20, 0x73,
+		0x65, 0x72, 0x76, 0x65, 0x72, 0x20, 0x73, 0x69, 0x64, 0x65,
+		0x2c, 0x20, 0x69, 0x74, 0x20, 0x69, 0x73, 0x20, 0x74, 0x68,
+		0x65, 0x20, 0x72, 0x65, 0x63, 0x65, 0x69, 0x76, 0x65, 0x20,
+		0x6b, 0x65, 0x79, 0x2e
+	static const u8 magic3[84] = {
+		0x6b, 0x65, 0x79, 0x3b, 0x20, 0x6f, 0x6e, 0x20, 0x74, 0x68,
+		0x65, 0x20, 0x73, 0x65, 0x72, 0x76, 0x65, 0x72, 0x20, 0x73,
+		0x69, 0x64, 0x65, 0x2c, 0x20, 0x69, 0x74, 0x20, 0x69, 0x73,
+		0x20, 0x74, 0x68, 0x65, 0x20, 0x73, 0x65, 0x6e, 0x64, 0x20,
+	static const u8 shs_pad1[40] = {
+		0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+	static const u8 shs_pad2[40] = {
+		0xf2, 0xf2, 0xf2, 0xf2, 0xf2, 0xf2, 0xf2, 0xf2, 0xf2, 0xf2,
+	u8 digest[SHA1_MAC_LEN];
+	const unsigned char *addr[4];
+	const size_t len[4] = { 16, 40, 84, 40 };
+	addr[0] = master_key;
+	addr[1] = shs_pad1;
+	if (is_send) {
+		addr[2] = is_server ? magic3 : magic2;
+	} else {
+		addr[2] = is_server ? magic2 : magic3;
+	addr[3] = shs_pad2;
+	if (sha1_vector(4, addr, len, digest))
+		return -1;
+	if (session_key_len > SHA1_MAC_LEN)
+		session_key_len = SHA1_MAC_LEN;
+	os_memcpy(session_key, digest, session_key_len);
+	return 0;
+#define PWBLOCK_LEN 516
+ * encrypt_pw_block_with_password_hash - EncryptPwBlockWithPasswordHash() - RFC 2759, Sect. 8.10
+ * @pw_block: 516-byte PwBlock (OUT)
+int encrypt_pw_block_with_password_hash(
+	const u8 *password_hash, u8 *pw_block)
+	size_t ucs2_len, offset;
+	u8 *pos;
+	os_memset(pw_block, 0, PWBLOCK_LEN);
+	if (utf8_to_ucs2(password, password_len, pw_block, 512, &ucs2_len) < 0
+	    || ucs2_len > 256)
+		return -1;
+	offset = (256 - ucs2_len) * 2;
+	if (offset != 0) {
+		os_memmove(pw_block + offset, pw_block, ucs2_len * 2);
+		if (os_get_random(pw_block, offset) < 0)
+			return -1;
+	 * PasswordLength is 4 octets, but since the maximum password length is
+	 * 256, only first two (in little endian byte order) can be non-zero.
+	pos = &pw_block[2 * 256];
+	WPA_PUT_LE16(pos, password_len * 2);
+	rc4_skip(password_hash, 16, 0, pw_block, PWBLOCK_LEN);
+	return 0;
+ * new_password_encrypted_with_old_nt_password_hash - NewPasswordEncryptedWithOldNtPasswordHash() - RFC 2759, Sect. 8.9
+ * @new_password: 0-to-256-unicode-char NewPassword (IN; UTF-8)
+ * @new_password_len: Length of new_password
+ * @old_password: 0-to-256-unicode-char OldPassword (IN; UTF-8)
+ * @old_password_len: Length of old_password
+ * @encrypted_pw_block: 516-octet EncryptedPwBlock (OUT)
+int new_password_encrypted_with_old_nt_password_hash(
+	const u8 *new_password, size_t new_password_len,
+	const u8 *old_password, size_t old_password_len,
+	u8 *encrypted_pw_block)
+	if (nt_password_hash(old_password, old_password_len, password_hash))
+		return -1;
+	if (encrypt_pw_block_with_password_hash(new_password, new_password_len,
+						password_hash,
+						encrypted_pw_block))
+		return -1;
+	return 0;
+ * nt_password_hash_encrypted_with_block - NtPasswordHashEncryptedWithBlock() - RFC 2759, Sect 8.13
+ * @password_hash: 16-octer PasswordHash (IN)
+ * @block: 16-octet Block (IN)
+ * @cypher: 16-octer Cypher (OUT)
+void nt_password_hash_encrypted_with_block(const u8 *password_hash,
+					   const u8 *block, u8 *cypher)
+	des_encrypt(password_hash, block, cypher);
+	des_encrypt(password_hash + 8, block + 7, cypher + 8);
+ * old_nt_password_hash_encrypted_with_new_nt_password_hash - OldNtPasswordHashEncryptedWithNewNtPasswordHash() - RFC 2759, Sect. 8.12
+ * @encrypted_password_hash: 16-octet EncryptedPasswordHash (OUT)
+int old_nt_password_hash_encrypted_with_new_nt_password_hash(
+	u8 *encrypted_password_hash)
+	u8 old_password_hash[16], new_password_hash[16];
+			     old_password_hash) ||
+	    nt_password_hash(new_password, new_password_len,
+			     new_password_hash))
+		return -1;
+	nt_password_hash_encrypted_with_block(old_password_hash,
+					      new_password_hash,
+					      encrypted_password_hash);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/ms_funcs.h b/freebsd/contrib/wpa/src/crypto/ms_funcs.h
new file mode 100644
index 00000000000..b5b5918e1a5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/ms_funcs.h
@@ -0,0 +1,60 @@
+ * Copyright (c) 2004-2009, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef MS_FUNCS_H
+#define MS_FUNCS_H
+			 u8 *response);
+				u8 *response);
+				    const u8 *nt_response, u8 *response);
+			  size_t password_len, u8 *response);
+			u8 *response);
+		   const u8 *username, size_t username_len, u8 *challenge);
+		     u8 *password_hash);
+int hash_nt_password_hash(const u8 *password_hash, u8 *password_hash_hash);
+		   u8 *master_key);
+			    int is_server);
+int __must_check encrypt_pw_block_with_password_hash(
+	const u8 *password_hash, u8 *pw_block);
+int __must_check new_password_encrypted_with_old_nt_password_hash(
+	u8 *encrypted_pw_block);
+					   const u8 *block, u8 *cypher);
+	u8 *encrypted_password_hash);
+#endif /* MS_FUNCS_H */
diff --git a/freebsd/contrib/wpa/src/crypto/random.c b/freebsd/contrib/wpa/src/crypto/random.c
index 00000000000..57880e31653
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/random.c
@@ -0,0 +1,441 @@
+#include <machine/rtems-bsd-user-space.h>
+ * Random number generator
+ * Copyright (c) 2010-2011, Jouni Malinen <j at w1.fi>
+ * This random number generator is used to provide additional entropy to the
+ * one provided by the operating system (os_get_random()) for session key
+ * generation. The os_get_random() output is expected to be secure and the
+ * implementation here is expected to provide only limited protection against
+ * cases where os_get_random() cannot provide strong randomness. This
+ * implementation shall not be assumed to be secure as the sole source of
+ * randomness. The random_get_bytes() function mixes in randomness from
+ * os_get_random() and as such, calls to os_get_random() can be replaced with
+ * calls to random_get_bytes() without reducing security.
+ * The design here follows partially the design used in the Linux
+ * drivers/char/random.c, but the implementation here is simpler and not as
+ * strong. This is a compromise to reduce duplicated CPU effort and to avoid
+ * extra code/memory size. As pointed out above, os_get_random() needs to be
+ * guaranteed to be secure for any of the security assumptions to hold.
+#include "utils/includes.h"
+#ifdef __linux__
+#include <fcntl.h>
+#endif /* __linux__ */
+#include "utils/common.h"
+#include "utils/eloop.h"
+#include "crypto/crypto.h"
+#include "sha1.h"
+#include "random.h"
+#define POOL_WORDS 32
+#define POOL_WORDS_MASK (POOL_WORDS - 1)
+#define POOL_TAP1 26
+#define POOL_TAP2 20
+#define POOL_TAP3 14
+#define POOL_TAP4 7
+#define POOL_TAP5 1
+#define EXTRACT_LEN 16
+#define MIN_READY_MARK 2
+static u32 pool[POOL_WORDS];
+static unsigned int input_rotate = 0;
+static unsigned int pool_pos = 0;
+static u8 dummy_key[20];
+#ifdef __linux__
+static size_t dummy_key_avail = 0;
+static int random_fd = -1;
+static unsigned int own_pool_ready = 0;
+#define RANDOM_ENTROPY_SIZE 20
+static char *random_entropy_file = NULL;
+static int random_entropy_file_read = 0;
+#define MIN_COLLECT_ENTROPY 1000
+static unsigned int entropy = 0;
+static unsigned int total_collected = 0;
+static void random_write_entropy(void);
+static u32 __ROL32(u32 x, u32 y)
+	return (x << (y & 31)) | (x >> (32 - (y & 31)));
+static void random_mix_pool(const void *buf, size_t len)
+	static const u32 twist[8] = {
+		0x00000000, 0x3b6e20c8, 0x76dc4190, 0x4db26158,
+		0xedb88320, 0xd6d6a3e8, 0x9b64c2b0, 0xa00ae278
+	const u8 *pos = buf;
+	u32 w;
+	wpa_hexdump_key(MSG_EXCESSIVE, "random_mix_pool", buf, len);
+	while (len--) {
+		w = __ROL32(*pos++, input_rotate & 31);
+		input_rotate += pool_pos ? 7 : 14;
+		pool_pos = (pool_pos - 1) & POOL_WORDS_MASK;
+		w ^= pool[pool_pos];
+		w ^= pool[(pool_pos + POOL_TAP1) & POOL_WORDS_MASK];
+		w ^= pool[(pool_pos + POOL_TAP2) & POOL_WORDS_MASK];
+		w ^= pool[(pool_pos + POOL_TAP3) & POOL_WORDS_MASK];
+		w ^= pool[(pool_pos + POOL_TAP4) & POOL_WORDS_MASK];
+		w ^= pool[(pool_pos + POOL_TAP5) & POOL_WORDS_MASK];
+		pool[pool_pos] = (w >> 3) ^ twist[w & 7];
+static void random_extract(u8 *out)
+	unsigned int i;
+	u32 *hash_ptr;
+	u32 buf[POOL_WORDS / 2];
+	/* First, add hash back to pool to make backtracking more difficult. */
+	hmac_sha1(dummy_key, sizeof(dummy_key), (const u8 *) pool,
+		  sizeof(pool), hash);
+	random_mix_pool(hash, sizeof(hash));
+	/* Hash half the pool to extra data */
+	for (i = 0; i < POOL_WORDS / 2; i++)
+		buf[i] = pool[(pool_pos - i) & POOL_WORDS_MASK];
+	hmac_sha1(dummy_key, sizeof(dummy_key), (const u8 *) buf,
+		  sizeof(buf), hash);
+	 * Fold the hash to further reduce any potential output pattern.
+	 * Though, compromise this to reduce CPU use for the most common output
+	 * length (32) and return 16 bytes from instead of only half.
+	hash_ptr = (u32 *) hash;
+	hash_ptr[0] ^= hash_ptr[4];
+	os_memcpy(out, hash, EXTRACT_LEN);
+void random_add_randomness(const void *buf, size_t len)
+	struct os_time t;
+	static unsigned int count = 0;
+	count++;
+	if (entropy > MIN_COLLECT_ENTROPY && (count & 0x3ff) != 0) {
+		 * No need to add more entropy at this point, so save CPU and
+		 * skip the update.
+		return;
+	wpa_printf(MSG_EXCESSIVE, "Add randomness: count=%u entropy=%u",
+		   count, entropy);
+	os_get_time(&t);
+	wpa_hexdump_key(MSG_EXCESSIVE, "random pool",
+			(const u8 *) pool, sizeof(pool));
+	random_mix_pool(&t, sizeof(t));
+	random_mix_pool(buf, len);
+	entropy++;
+	total_collected++;
+int random_get_bytes(void *buf, size_t len)
+	int ret;
+	u8 *bytes = buf;
+	size_t left;
+	wpa_printf(MSG_MSGDUMP, "Get randomness: len=%u entropy=%u",
+		   (unsigned int) len, entropy);
+	/* Start with assumed strong randomness from OS */
+	ret = os_get_random(buf, len);
+	wpa_hexdump_key(MSG_EXCESSIVE, "random from os_get_random",
+			buf, len);
+	/* Mix in additional entropy extracted from the internal pool */
+	left = len;
+	while (left) {
+		size_t siz, i;
+		u8 tmp[EXTRACT_LEN];
+		random_extract(tmp);
+		wpa_hexdump_key(MSG_EXCESSIVE, "random from internal pool",
+				tmp, sizeof(tmp));
+		siz = left > EXTRACT_LEN ? EXTRACT_LEN : left;
+		for (i = 0; i < siz; i++)
+			*bytes++ ^= tmp[i];
+		left -= siz;
+#ifdef CONFIG_FIPS
+	/* Mix in additional entropy from the crypto module */
+	bytes = buf;
+	left = len;
+	while (left) {
+		size_t siz, i;
+		if (crypto_get_random(tmp, sizeof(tmp)) < 0) {
+			wpa_printf(MSG_ERROR, "random: No entropy available "
+				   "for generating strong random bytes");
+			return -1;
+		wpa_hexdump_key(MSG_EXCESSIVE, "random from crypto module",
+		left -= siz;
+	wpa_hexdump_key(MSG_EXCESSIVE, "mixed random", buf, len);
+	if (entropy < len)
+		entropy = 0;
+	else
+		entropy -= len;
+	return ret;
+int random_pool_ready(void)
+#ifdef __linux__
+	int fd;
+	ssize_t res;
+	 * Make sure that there is reasonable entropy available before allowing
+	 * some key derivation operations to proceed.
+	if (dummy_key_avail == sizeof(dummy_key))
+		return 1; /* Already initialized - good to continue */
+	 * Try to fetch some more data from the kernel high quality
+	 * /dev/random. There may not be enough data available at this point,
+	 * so use non-blocking read to avoid blocking the application
+	 * completely.
+	fd = open("/dev/random", O_RDONLY | O_NONBLOCK);
+	if (fd < 0) {
+		wpa_printf(MSG_ERROR, "random: Cannot open /dev/random: %s",
+			   strerror(errno));
+		return -1;
+	res = read(fd, dummy_key + dummy_key_avail,
+		   sizeof(dummy_key) - dummy_key_avail);
+	if (res < 0) {
+		wpa_printf(MSG_ERROR, "random: Cannot read from /dev/random: "
+			   "%s", strerror(errno));
+		res = 0;
+	wpa_printf(MSG_DEBUG, "random: Got %u/%u bytes from "
+		   "/dev/random", (unsigned) res,
+		   (unsigned) (sizeof(dummy_key) - dummy_key_avail));
+	dummy_key_avail += res;
+	close(fd);
+	if (dummy_key_avail == sizeof(dummy_key)) {
+		if (own_pool_ready < MIN_READY_MARK)
+			own_pool_ready = MIN_READY_MARK;
+		random_write_entropy();
+		return 1;
+	wpa_printf(MSG_INFO, "random: Only %u/%u bytes of strong "
+		   "random data available from /dev/random",
+		   (unsigned) dummy_key_avail, (unsigned) sizeof(dummy_key));
+	if (own_pool_ready >= MIN_READY_MARK ||
+	    total_collected + 10 * own_pool_ready > MIN_COLLECT_ENTROPY) {
+		wpa_printf(MSG_INFO, "random: Allow operation to proceed "
+			   "based on internal entropy");
+		return 1;
+	wpa_printf(MSG_INFO, "random: Not enough entropy pool available for "
+		   "secure operations");
+	return 0;
+#else /* __linux__ */
+	/* TODO: could do similar checks on non-Linux platforms */
+	return 1;
+void random_mark_pool_ready(void)
+	own_pool_ready++;
+	wpa_printf(MSG_DEBUG, "random: Mark internal entropy pool to be "
+		   "ready (count=%u/%u)", own_pool_ready, MIN_READY_MARK);
+#ifdef __linux__
+static void random_close_fd(void)
+	if (random_fd >= 0) {
+		eloop_unregister_read_sock(random_fd);
+		close(random_fd);
+		random_fd = -1;
+static void random_read_fd(int sock, void *eloop_ctx, void *sock_ctx)
+	ssize_t res;
+		random_close_fd();
+		return;
+	res = read(sock, dummy_key + dummy_key_avail,
+	if (res < 0) {
+		return;
+	wpa_printf(MSG_DEBUG, "random: Got %u/%u bytes from /dev/random",
+		   (unsigned) res,
+static void random_read_entropy(void)
+	char *buf;
+	size_t len;
+	if (!random_entropy_file)
+		return;
+	buf = os_readfile(random_entropy_file, &len);
+	if (buf == NULL)
+		return; /* entropy file not yet available */
+	if (len != 1 + RANDOM_ENTROPY_SIZE) {
+		wpa_printf(MSG_DEBUG, "random: Invalid entropy file %s",
+			   random_entropy_file);
+		os_free(buf);
+		return;
+	own_pool_ready = (u8) buf[0];
+	random_add_randomness(buf + 1, RANDOM_ENTROPY_SIZE);
+	random_entropy_file_read = 1;
+	os_free(buf);
+	wpa_printf(MSG_DEBUG, "random: Added entropy from %s "
+		   "(own_pool_ready=%u)",
+		   random_entropy_file, own_pool_ready);
+	char buf[RANDOM_ENTROPY_SIZE];
+	FILE *f;
+	u8 opr;
+	int fail = 0;
+		return;
+	if (random_get_bytes(buf, RANDOM_ENTROPY_SIZE) < 0)
+		return;
+	f = fopen(random_entropy_file, "wb");
+	if (f == NULL) {
+		wpa_printf(MSG_ERROR, "random: Could not open entropy file %s "
+			   "for writing", random_entropy_file);
+		return;
+	opr = own_pool_ready > 0xff ? 0xff : own_pool_ready;
+	if (fwrite(&opr, 1, 1, f) != 1 ||
+	    fwrite(buf, RANDOM_ENTROPY_SIZE, 1, f) != 1)
+		fail = 1;
+	fclose(f);
+	if (fail) {
+		wpa_printf(MSG_ERROR, "random: Could not write entropy data "
+			   "to %s", random_entropy_file);
+		return;
+	wpa_printf(MSG_DEBUG, "random: Updated entropy file %s "
+void random_init(const char *entropy_file)
+	os_free(random_entropy_file);
+	if (entropy_file)
+		random_entropy_file = os_strdup(entropy_file);
+	else
+		random_entropy_file = NULL;
+	random_read_entropy();
+#ifdef __linux__
+		return;
+	random_fd = open("/dev/random", O_RDONLY | O_NONBLOCK);
+	if (random_fd < 0) {
+			   strerror(errno));
+		return;
+	wpa_printf(MSG_DEBUG, "random: Trying to read entropy from "
+		   "/dev/random");
+	eloop_register_read_sock(random_fd, random_read_fd, NULL, NULL);
+void random_deinit(void)
+#ifdef __linux__
diff --git a/freebsd/contrib/wpa/src/crypto/random.h b/freebsd/contrib/wpa/src/crypto/random.h
index 00000000000..d13e1c49292
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/random.h
@@ -0,0 +1,28 @@
+#ifndef RANDOM_H
+#define RANDOM_H
+#ifdef CONFIG_NO_RANDOM_POOL
+#define random_init(e) do { } while (0)
+#define random_deinit() do { } while (0)
+#define random_add_randomness(b, l) do { } while (0)
+#define random_get_bytes(b, l) os_get_random((b), (l))
+#define random_pool_ready() 1
+#define random_mark_pool_ready() do { } while (0)
+#else /* CONFIG_NO_RANDOM_POOL */
+void random_init(const char *entropy_file);
+void random_deinit(void);
+void random_add_randomness(const void *buf, size_t len);
+int random_get_bytes(void *buf, size_t len);
+int random_pool_ready(void);
+void random_mark_pool_ready(void);
+#endif /* CONFIG_NO_RANDOM_POOL */
+#endif /* RANDOM_H */
diff --git a/freebsd/contrib/wpa/src/crypto/rc4.c b/freebsd/contrib/wpa/src/crypto/rc4.c
index 00000000000..061160ea2da
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/rc4.c
@@ -0,0 +1,56 @@
+ * RC4 stream cipher
+ * Copyright (c) 2002-2005, Jouni Malinen <j at w1.fi>
+#include "includes.h"
+#include "common.h"
+#define S_SWAP(a,b) do { u8 t = S[a]; S[a] = S[b]; S[b] = t; } while(0)
+	     u8 *data, size_t data_len)
+	u32 i, j, k;
+	u8 S[256], *pos;
+	size_t kpos;
+	/* Setup RC4 state */
+	for (i = 0; i < 256; i++)
+		S[i] = i;
+	j = 0;
+	kpos = 0;
+	for (i = 0; i < 256; i++) {
+		j = (j + S[i] + key[kpos]) & 0xff;
+		kpos++;
+		if (kpos >= keylen)
+			kpos = 0;
+		S_SWAP(i, j);
+	/* Skip the start of the stream */
+	i = j = 0;
+	for (k = 0; k < skip; k++) {
+		i = (i + 1) & 0xff;
+		j = (j + S[i]) & 0xff;
+		S_SWAP(i, j);
+	/* Apply RC4 to data */
+	pos = data;
+	for (k = 0; k < data_len; k++) {
+		S_SWAP(i, j);
+		*pos++ ^= S[(S[i] + S[j]) & 0xff];
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c b/freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c
index 00000000000..121b642ef7e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c
@@ -0,0 +1,94 @@
+ * SHA1-based key derivation function (PBKDF2) for IEEE 802.11i
+ * Copyright (c) 2003-2005, Jouni Malinen <j at w1.fi>
+#include "sha1.h"
+static int pbkdf2_sha1_f(const char *passphrase, const u8 *ssid,
+			 size_t ssid_len, int iterations, unsigned int count,
+			 u8 *digest)
+	unsigned char tmp[SHA1_MAC_LEN], tmp2[SHA1_MAC_LEN];
+	int i, j;
+	unsigned char count_buf[4];
+	const u8 *addr[2];
+	size_t len[2];
+	size_t passphrase_len = os_strlen(passphrase);
+	addr[0] = ssid;
+	len[0] = ssid_len;
+	addr[1] = count_buf;
+	len[1] = 4;
+	/* F(P, S, c, i) = U1 xor U2 xor ... Uc
+	 * U1 = PRF(P, S || i)
+	 * U2 = PRF(P, U1)
+	 * Uc = PRF(P, Uc-1)
+	count_buf[0] = (count >> 24) & 0xff;
+	count_buf[1] = (count >> 16) & 0xff;
+	count_buf[2] = (count >> 8) & 0xff;
+	count_buf[3] = count & 0xff;
+	if (hmac_sha1_vector((u8 *) passphrase, passphrase_len, 2, addr, len,
+			     tmp))
+		return -1;
+	os_memcpy(digest, tmp, SHA1_MAC_LEN);
+	for (i = 1; i < iterations; i++) {
+		if (hmac_sha1((u8 *) passphrase, passphrase_len, tmp,
+			      SHA1_MAC_LEN, tmp2))
+			return -1;
+		os_memcpy(tmp, tmp2, SHA1_MAC_LEN);
+		for (j = 0; j < SHA1_MAC_LEN; j++)
+			digest[j] ^= tmp2[j];
+	return 0;
+ * pbkdf2_sha1 - SHA1-based key derivation function (PBKDF2) for IEEE 802.11i
+ * @passphrase: ASCII passphrase
+ * @ssid: SSID
+ * @ssid_len: SSID length in bytes
+ * @iterations: Number of iterations to run
+ * @buf: Buffer for the generated key
+ * @buflen: Length of the buffer in bytes
+ * Returns: 0 on success, -1 of failure
+ * This function is used to derive PSK for WPA-PSK. For this protocol,
+ * iterations is set to 4096 and buflen to 32. This function is described in
+ * IEEE Std 802.11-2004, Clause H.4. The main construction is from PKCS#5 v2.0.
+	unsigned int count = 0;
+	unsigned char *pos = buf;
+	size_t left = buflen, plen;
+	unsigned char digest[SHA1_MAC_LEN];
+	while (left > 0) {
+		count++;
+		if (pbkdf2_sha1_f(passphrase, ssid, ssid_len, iterations,
+				  count, digest))
+			return -1;
+		plen = left > SHA1_MAC_LEN ? SHA1_MAC_LEN : left;
+		os_memcpy(pos, digest, plen);
+		pos += plen;
+		left -= plen;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/sha1-prf.c b/freebsd/contrib/wpa/src/crypto/sha1-prf.c
index 00000000000..004260d7442
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha1-prf.c
@@ -0,0 +1,69 @@
+ * SHA1-based PRF
+#include "sha1.h"
+ * sha1_prf - SHA1-based Pseudo-Random Function (PRF) (IEEE 802.11i, 8.5.1.1)
+ * @key: Key for PRF
+ * @key_len: Length of the key in bytes
+ * @label: A unique label for each purpose of the PRF
+ * @data: Extra data to bind into the key
+ * @data_len: Length of the data
+ * @buf: Buffer for the generated pseudo-random key
+ * @buf_len: Number of bytes of key to generate
+ * This function is used to derive new, cryptographically separate keys from a
+ * given key (e.g., PMK in IEEE 802.11i).
+int sha1_prf(const u8 *key, size_t key_len, const char *label,
+	     const u8 *data, size_t data_len, u8 *buf, size_t buf_len)
+	u8 counter = 0;
+	size_t pos, plen;
+	size_t label_len = os_strlen(label) + 1;
+	size_t len[3];
+	addr[0] = (u8 *) label;
+	len[0] = label_len;
+	addr[1] = data;
+	len[1] = data_len;
+	addr[2] = &counter;
+	len[2] = 1;
+	pos = 0;
+	while (pos < buf_len) {
+		plen = buf_len - pos;
+		if (plen >= SHA1_MAC_LEN) {
+			if (hmac_sha1_vector(key, key_len, 3, addr, len,
+					     &buf[pos]))
+				return -1;
+			pos += SHA1_MAC_LEN;
+		} else {
+					     hash))
+				return -1;
+			os_memcpy(&buf[pos], hash, plen);
+			break;
+		counter++;
+	os_memset(hash, 0, sizeof(hash));
+	return 0;
diff --git a/freebsd/contrib/wpa/src/crypto/sha1.c b/freebsd/contrib/wpa/src/crypto/sha1.c
index 00000000000..de751fb976d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha1.c
@@ -0,0 +1,109 @@
+ * SHA1 hash implementation and interface functions
+#include "sha1.h"
+ * hmac_sha1_vector - HMAC-SHA1 over data vector (RFC 2104)
+ * @key: Key for HMAC operations
+ * @num_elem: Number of elements in the data vector
+ * @addr: Pointers to the data areas
+ * @len: Lengths of the data blocks
+ * @mac: Buffer for the hash (20 bytes)
+ * Returns: 0 on success, -1 on failure
+	unsigned char k_pad[64]; /* padding - key XORd with ipad/opad */
+	unsigned char tk[20];
+	const u8 *_addr[6];
+	size_t _len[6], i;
+	int ret;
+	if (num_elem > 5) {
+		 * Fixed limit on the number of fragments to avoid having to
+		 * allocate memory (which could fail).
+		return -1;
+        /* if key is longer than 64 bytes reset it to key = SHA1(key) */
+        if (key_len > 64) {
+		if (sha1_vector(1, &key, &key_len, tk))
+			return -1;
+		key = tk;
+		key_len = 20;
+	/* the HMAC_SHA1 transform looks like:
+	 * SHA1(K XOR opad, SHA1(K XOR ipad, text))
+	 * where K is an n byte key
+	 * ipad is the byte 0x36 repeated 64 times
+	 * opad is the byte 0x5c repeated 64 times
+	 * and text is the data being protected */
+	/* start out by storing key in ipad */
+	os_memset(k_pad, 0, sizeof(k_pad));
+	os_memcpy(k_pad, key, key_len);
+	/* XOR key with ipad values */
+	for (i = 0; i < 64; i++)
+		k_pad[i] ^= 0x36;
+	/* perform inner SHA1 */
+	_addr[0] = k_pad;
+	_len[0] = 64;
+		_addr[i + 1] = addr[i];
+		_len[i + 1] = len[i];
+	if (sha1_vector(1 + num_elem, _addr, _len, mac))
+		return -1;
+	/* XOR key with opad values */
+		k_pad[i] ^= 0x5c;
+	/* perform outer SHA1 */
+	_addr[0] = k_pad;
+	_len[0] = 64;
+	_addr[1] = mac;
+	_len[1] = SHA1_MAC_LEN;
+	ret = sha1_vector(2, _addr, _len, mac);
+	return ret;
+ * hmac_sha1 - HMAC-SHA1 over data buffer (RFC 2104)
+ * @data: Pointers to the data area
+ * @data_len: Length of the data area
+	       u8 *mac)
diff --git a/freebsd/contrib/wpa/src/crypto/sha1.h b/freebsd/contrib/wpa/src/crypto/sha1.h
index 00000000000..933cd81b95b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha1.h
@@ -0,0 +1,27 @@
+#ifndef SHA1_H
+#define SHA1_H
+#define SHA1_MAC_LEN 20
+	       u8 *mac);
+	     const u8 *data, size_t data_len, u8 *buf, size_t buf_len);
+int sha1_t_prf(const u8 *key, size_t key_len, const char *label,
+	       const u8 *seed, size_t seed_len, u8 *buf, size_t buf_len);
+int __must_check tls_prf_sha1_md5(const u8 *secret, size_t secret_len,
+				  const char *label, const u8 *seed,
+				  size_t seed_len, u8 *out, size_t outlen);
+		int iterations, u8 *buf, size_t buflen);
+#endif /* SHA1_H */
diff --git a/freebsd/contrib/wpa/src/crypto/sha256-internal.c b/freebsd/contrib/wpa/src/crypto/sha256-internal.c
index 00000000000..c2ef31543d5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha256-internal.c
@@ -0,0 +1,228 @@
+ * SHA-256 hash implementation and interface functions
+ * Copyright (c) 2003-2011, Jouni Malinen <j at w1.fi>
+#include "sha256_i.h"
+ * sha256_vector - SHA256 hash for data vector
+int sha256_vector(size_t num_elem, const u8 *addr[], const size_t *len,
+		  u8 *mac)
+	struct sha256_state ctx;
+	size_t i;
+	sha256_init(&ctx);
+		if (sha256_process(&ctx, addr[i], len[i]))
+			return -1;
+	if (sha256_done(&ctx, mac))
+		return -1;
+	return 0;
+/* ===== start - public domain SHA256 implementation ===== */
+/* This is based on SHA256 implementation in LibTomCrypt that was released into
+ * public domain by Tom St Denis. */
+/* the K array */
+static const unsigned long K[64] = {
+	0x428a2f98UL, 0x71374491UL, 0xb5c0fbcfUL, 0xe9b5dba5UL, 0x3956c25bUL,
+	0x59f111f1UL, 0x923f82a4UL, 0xab1c5ed5UL, 0xd807aa98UL, 0x12835b01UL,
+	0x243185beUL, 0x550c7dc3UL, 0x72be5d74UL, 0x80deb1feUL, 0x9bdc06a7UL,
+	0xc19bf174UL, 0xe49b69c1UL, 0xefbe4786UL, 0x0fc19dc6UL, 0x240ca1ccUL,
+	0x2de92c6fUL, 0x4a7484aaUL, 0x5cb0a9dcUL, 0x76f988daUL, 0x983e5152UL,
+	0xa831c66dUL, 0xb00327c8UL, 0xbf597fc7UL, 0xc6e00bf3UL, 0xd5a79147UL,
+	0x06ca6351UL, 0x14292967UL, 0x27b70a85UL, 0x2e1b2138UL, 0x4d2c6dfcUL,
+	0x53380d13UL, 0x650a7354UL, 0x766a0abbUL, 0x81c2c92eUL, 0x92722c85UL,
+	0xa2bfe8a1UL, 0xa81a664bUL, 0xc24b8b70UL, 0xc76c51a3UL, 0xd192e819UL,
+	0xd6990624UL, 0xf40e3585UL, 0x106aa070UL, 0x19a4c116UL, 0x1e376c08UL,
+	0x2748774cUL, 0x34b0bcb5UL, 0x391c0cb3UL, 0x4ed8aa4aUL, 0x5b9cca4fUL,
+	0x682e6ff3UL, 0x748f82eeUL, 0x78a5636fUL, 0x84c87814UL, 0x8cc70208UL,
+	0x90befffaUL, 0xa4506cebUL, 0xbef9a3f7UL, 0xc67178f2UL
+/* Various logical functions */
+#define RORc(x, y) \
+( ((((unsigned long) (x) & 0xFFFFFFFFUL) >> (unsigned long) ((y) & 31)) | \
+   ((unsigned long) (x) << (unsigned long) (32 - ((y) & 31)))) & 0xFFFFFFFFUL)
+#define Ch(x,y,z)       (z ^ (x & (y ^ z)))
+#define Maj(x,y,z)      (((x | y) & z) | (x & y))
+#define S(x, n)         RORc((x), (n))
+#define R(x, n)         (((x)&0xFFFFFFFFUL)>>(n))
+#define Sigma0(x)       (S(x, 2) ^ S(x, 13) ^ S(x, 22))
+#define Sigma1(x)       (S(x, 6) ^ S(x, 11) ^ S(x, 25))
+#define Gamma0(x)       (S(x, 7) ^ S(x, 18) ^ R(x, 3))
+#define Gamma1(x)       (S(x, 17) ^ S(x, 19) ^ R(x, 10))
+#ifndef MIN
+#define MIN(x, y) (((x) < (y)) ? (x) : (y))
+#endif
+/* compress 512-bits */
+static int sha256_compress(struct sha256_state *md, unsigned char *buf)
+	u32 S[8], W[64], t0, t1;
+	u32 t;
+	int i;
+	/* copy state into S */
+	for (i = 0; i < 8; i++) {
+		S[i] = md->state[i];
+	/* copy the state into 512-bits into W[0..15] */
+	for (i = 0; i < 16; i++)
+		W[i] = WPA_GET_BE32(buf + (4 * i));
+	/* fill W[16..63] */
+	for (i = 16; i < 64; i++) {
+		W[i] = Gamma1(W[i - 2]) + W[i - 7] + Gamma0(W[i - 15]) +
+			W[i - 16];
+	/* Compress */
+#define RND(a,b,c,d,e,f,g,h,i)                          \
+	t0 = h + Sigma1(e) + Ch(e, f, g) + K[i] + W[i];	\
+	t1 = Sigma0(a) + Maj(a, b, c);			\
+	d += t0;					\
+	h  = t0 + t1;
+	for (i = 0; i < 64; ++i) {
+		RND(S[0], S[1], S[2], S[3], S[4], S[5], S[6], S[7], i);
+		t = S[7]; S[7] = S[6]; S[6] = S[5]; S[5] = S[4];
+		S[4] = S[3]; S[3] = S[2]; S[2] = S[1]; S[1] = S[0]; S[0] = t;
+	/* feedback */
+		md->state[i] = md->state[i] + S[i];
+	return 0;
+/* Initialize the hash state */
+void sha256_init(struct sha256_state *md)
+	md->curlen = 0;
+	md->length = 0;
+	md->state[0] = 0x6A09E667UL;
+	md->state[1] = 0xBB67AE85UL;
+	md->state[2] = 0x3C6EF372UL;
+	md->state[3] = 0xA54FF53AUL;
+	md->state[4] = 0x510E527FUL;
+	md->state[5] = 0x9B05688CUL;
+	md->state[6] = 0x1F83D9ABUL;
+	md->state[7] = 0x5BE0CD19UL;
+   Process a block of memory though the hash
+   @param md     The hash state
+   @param in     The data to hash
+   @param inlen  The length of the data (octets)
+   @return CRYPT_OK if successful
+int sha256_process(struct sha256_state *md, const unsigned char *in,
+		   unsigned long inlen)
+	unsigned long n;
+	if (md->curlen >= sizeof(md->buf))
+		return -1;
+	while (inlen > 0) {
+		if (md->curlen == 0 && inlen >= SHA256_BLOCK_SIZE) {
+			if (sha256_compress(md, (unsigned char *) in) < 0)
+				return -1;
+			md->length += SHA256_BLOCK_SIZE * 8;
+			in += SHA256_BLOCK_SIZE;
+			inlen -= SHA256_BLOCK_SIZE;
+		} else {
+			n = MIN(inlen, (SHA256_BLOCK_SIZE - md->curlen));
+			os_memcpy(md->buf + md->curlen, in, n);
+			md->curlen += n;
+			in += n;
+			inlen -= n;
+			if (md->curlen == SHA256_BLOCK_SIZE) {
+				if (sha256_compress(md, md->buf) < 0)
+					return -1;
+				md->length += 8 * SHA256_BLOCK_SIZE;
+				md->curlen = 0;
+	return 0;
+   Terminate the hash to get the digest
+   @param out [out] The destination of the hash (32 bytes)
+int sha256_done(struct sha256_state *md, unsigned char *out)
+	int i;
+		return -1;
+	/* increase the length of the message */
+	md->length += md->curlen * 8;
+	/* append the '1' bit */
+	md->buf[md->curlen++] = (unsigned char) 0x80;
+	/* if the length is currently above 56 bytes we append zeros
+	 * then compress.  Then we can fall back to padding zeros and length
+	 * encoding like normal.
+	if (md->curlen > 56) {
+		while (md->curlen < SHA256_BLOCK_SIZE) {
+			md->buf[md->curlen++] = (unsigned char) 0;
+		sha256_compress(md, md->buf);
+		md->curlen = 0;
+	/* pad up to 56 bytes of zeroes */
+	while (md->curlen < 56) {
+	/* store length */
+	WPA_PUT_BE64(md->buf + 56, md->length);
+	/* copy output */
+		WPA_PUT_BE32(out + (4 * i), md->state[i]);
+	return 0;
+/* ===== end - public domain SHA256 implementation ===== */
diff --git a/freebsd/contrib/wpa/src/crypto/sha256-prf.c b/freebsd/contrib/wpa/src/crypto/sha256-prf.c
index 00000000000..764962142da
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha256-prf.c
@@ -0,0 +1,102 @@
+ * SHA256-based PRF (IEEE 802.11r)
+ * Copyright (c) 2003-2013, Jouni Malinen <j at w1.fi>
+ * sha256_prf - SHA256-based Pseudo-Random Function (IEEE 802.11r, 8.5.1.5.2)
+ * given key.
+void sha256_prf(const u8 *key, size_t key_len, const char *label,
+	sha256_prf_bits(key, key_len, label, data, data_len, buf, buf_len * 8);
+ * sha256_prf_bits - IEEE Std 802.11-2012, 11.6.1.7.2 Key derivation function
+ * @key: Key for KDF
+ * @buf_len: Number of bits of key to generate
+ * given key. If the requested buf_len is not divisible by eight, the least
+ * significant 1-7 bits of the last octet in the output are not part of the
+ * requested output.
+void sha256_prf_bits(const u8 *key, size_t key_len, const char *label,
+		     size_t buf_len_bits)
+	u16 counter = 1;
+	size_t pos, plen;
+	u8 hash[SHA256_MAC_LEN];
+	const u8 *addr[4];
+	size_t len[4];
+	u8 counter_le[2], length_le[2];
+	size_t buf_len = (buf_len_bits + 7) / 8;
+	addr[0] = counter_le;
+	len[0] = 2;
+	addr[1] = (u8 *) label;
+	len[1] = os_strlen(label);
+	addr[2] = data;
+	len[2] = data_len;
+	addr[3] = length_le;
+	len[3] = sizeof(length_le);
+	WPA_PUT_LE16(length_le, buf_len_bits);
+	pos = 0;
+		WPA_PUT_LE16(counter_le, counter);
+		if (plen >= SHA256_MAC_LEN) {
+			hmac_sha256_vector(key, key_len, 4, addr, len,
+					   &buf[pos]);
+			pos += SHA256_MAC_LEN;
+		} else {
+			hmac_sha256_vector(key, key_len, 4, addr, len, hash);
+			pos += plen;
+			break;
+		counter++;
+	 * Mask out unused bits in the last octet if it does not use all the
+	 * bits.
+	if (buf_len_bits % 8) {
+		u8 mask = 0xff << (8 - buf_len_bits % 8);
+		buf[pos - 1] &= mask;
diff --git a/freebsd/contrib/wpa/src/crypto/sha256.h b/freebsd/contrib/wpa/src/crypto/sha256.h
index 00000000000..b15f51158f3
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha256.h
@@ -0,0 +1,30 @@
+ * SHA256 hash implementation and interface functions
+ * Copyright (c) 2003-2014, Jouni Malinen <j at w1.fi>
+#ifndef SHA256_H
+#define SHA256_H
+#define SHA256_MAC_LEN 32
+		size_t data_len, u8 *mac);
+		     size_t buf_len_bits);
+void tls_prf_sha256(const u8 *secret, size_t secret_len,
+		    const char *label, const u8 *seed, size_t seed_len,
+		    u8 *out, size_t outlen);
+int hmac_sha256_kdf(const u8 *secret, size_t secret_len,
+#endif /* SHA256_H */
diff --git a/freebsd/contrib/wpa/src/crypto/sha256_i.h b/freebsd/contrib/wpa/src/crypto/sha256_i.h
index 00000000000..a502d2ba5d6
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha256_i.h
@@ -0,0 +1,25 @@
+ * SHA-256 internal definitions
+#ifndef SHA256_I_H
+#define SHA256_I_H
+#define SHA256_BLOCK_SIZE 64
+struct sha256_state {
+	u64 length;
+	u32 state[8], curlen;
+	u8 buf[SHA256_BLOCK_SIZE];
+void sha256_init(struct sha256_state *md);
+		   unsigned long inlen);
+int sha256_done(struct sha256_state *md, unsigned char *out);
+#endif /* SHA256_I_H */
diff --git a/freebsd/contrib/wpa/src/crypto/sha384.h b/freebsd/contrib/wpa/src/crypto/sha384.h
index 00000000000..3deafa59ec2
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/sha384.h
@@ -0,0 +1,24 @@
+ * SHA384 hash implementation and interface functions
+ * Copyright (c) 2015, Jouni Malinen <j at w1.fi>
+#ifndef SHA384_H
+#define SHA384_H
+#define SHA384_MAC_LEN 48
+void sha384_prf(const u8 *key, size_t key_len, const char *label,
+void sha384_prf_bits(const u8 *key, size_t key_len, const char *label,
+#endif /* SHA384_H */
diff --git a/freebsd/contrib/wpa/src/crypto/tls.h b/freebsd/contrib/wpa/src/crypto/tls.h
index 00000000000..2e562339cc5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/tls.h
@@ -0,0 +1,588 @@
+ * SSL/TLS interface definition
+ * Copyright (c) 2004-2013, Jouni Malinen <j at w1.fi>
+#ifndef TLS_H
+#define TLS_H
+struct tls_connection;
+struct tls_random {
+	const u8 *client_random;
+	size_t client_random_len;
+	const u8 *server_random;
+	size_t server_random_len;
+enum tls_event {
+	TLS_CERT_CHAIN_SUCCESS,
+	TLS_CERT_CHAIN_FAILURE,
+	TLS_PEER_CERTIFICATE,
+	TLS_ALERT
+ * Note: These are used as identifier with external programs and as such, the
+ * values must not be changed.
+enum tls_fail_reason {
+	TLS_FAIL_UNSPECIFIED = 0,
+	TLS_FAIL_UNTRUSTED = 1,
+	TLS_FAIL_REVOKED = 2,
+	TLS_FAIL_NOT_YET_VALID = 3,
+	TLS_FAIL_EXPIRED = 4,
+	TLS_FAIL_SUBJECT_MISMATCH = 5,
+	TLS_FAIL_ALTSUBJECT_MISMATCH = 6,
+	TLS_FAIL_BAD_CERTIFICATE = 7,
+	TLS_FAIL_SERVER_CHAIN_PROBE = 8,
+	TLS_FAIL_DOMAIN_SUFFIX_MISMATCH = 9,
+	TLS_FAIL_DOMAIN_MISMATCH = 10,
+#define TLS_MAX_ALT_SUBJECT 10
+union tls_event_data {
+	struct {
+		int depth;
+		const char *subject;
+		enum tls_fail_reason reason;
+		const char *reason_txt;
+		const struct wpabuf *cert;
+	} cert_fail;
+	struct {
+		int depth;
+		const u8 *hash;
+		size_t hash_len;
+		const char *altsubject[TLS_MAX_ALT_SUBJECT];
+		int num_altsubject;
+	} peer_cert;
+	struct {
+		int is_local;
+		const char *type;
+		const char *description;
+	} alert;
+struct tls_config {
+	const char *opensc_engine_path;
+	const char *pkcs11_engine_path;
+	const char *pkcs11_module_path;
+	int fips_mode;
+	int cert_in_cb;
+	const char *openssl_ciphers;
+	unsigned int tls_session_lifetime;
+	void (*event_cb)(void *ctx, enum tls_event ev,
+			 union tls_event_data *data);
+	void *cb_ctx;
+#define TLS_CONN_ALLOW_SIGN_RSA_MD5 BIT(0)
+#define TLS_CONN_DISABLE_TIME_CHECKS BIT(1)
+#define TLS_CONN_DISABLE_SESSION_TICKET BIT(2)
+#define TLS_CONN_REQUEST_OCSP BIT(3)
+#define TLS_CONN_REQUIRE_OCSP BIT(4)
+#define TLS_CONN_DISABLE_TLSv1_1 BIT(5)
+#define TLS_CONN_DISABLE_TLSv1_2 BIT(6)
+#define TLS_CONN_EAP_FAST BIT(7)
+#define TLS_CONN_DISABLE_TLSv1_0 BIT(8)
+ * struct tls_connection_params - Parameters for TLS connection
+ * @ca_cert: File or reference name for CA X.509 certificate in PEM or DER
+ * format
+ * @ca_cert_blob: ca_cert as inlined data or %NULL if not used
+ * @ca_cert_blob_len: ca_cert_blob length
+ * @ca_path: Path to CA certificates (OpenSSL specific)
+ * @subject_match: String to match in the subject of the peer certificate or
+ * %NULL to allow all subjects
+ * @altsubject_match: String to match in the alternative subject of the peer
+ * certificate or %NULL to allow all alternative subjects
+ * @suffix_match: String to suffix match in the dNSName or CN of the peer
+ * certificate or %NULL to allow all domain names. This may allow subdomains an
+ * wildcard certificates. Each domain name label must have a full match.
+ * @domain_match: String to match in the dNSName or CN of the peer
+ * certificate or %NULL to allow all domain names. This requires a full,
+ * case-insensitive match.
+ * @client_cert: File or reference name for client X.509 certificate in PEM or
+ * DER format
+ * @client_cert_blob: client_cert as inlined data or %NULL if not used
+ * @client_cert_blob_len: client_cert_blob length
+ * @private_key: File or reference name for client private key in PEM or DER
+ * format (traditional format (RSA PRIVATE KEY) or PKCS#8 (PRIVATE KEY)
+ * @private_key_blob: private_key as inlined data or %NULL if not used
+ * @private_key_blob_len: private_key_blob length
+ * @private_key_passwd: Passphrase for decrypted private key, %NULL if no
+ * passphrase is used.
+ * @dh_file: File name for DH/DSA data in PEM format, or %NULL if not used
+ * @dh_blob: dh_file as inlined data or %NULL if not used
+ * @dh_blob_len: dh_blob length
+ * @engine: 1 = use engine (e.g., a smartcard) for private key operations
+ * (this is OpenSSL specific for now)
+ * @engine_id: engine id string (this is OpenSSL specific for now)
+ * @ppin: pointer to the pin variable in the configuration
+ * @key_id: the private key's id when using engine (this is OpenSSL
+ * specific for now)
+ * @cert_id: the certificate's id when using engine
+ * @ca_cert_id: the CA certificate's id when using engine
+ * @openssl_ciphers: OpenSSL cipher configuration
+ * @flags: Parameter options (TLS_CONN_*)
+ * @ocsp_stapling_response: DER encoded file with cached OCSP stapling response
+ *	or %NULL if OCSP is not enabled
+ * TLS connection parameters to be configured with tls_connection_set_params()
+ * and tls_global_set_params().
+ * Certificates and private key can be configured either as a reference name
+ * (file path or reference to certificate store) or by providing the same data
+ * as a pointer to the data in memory. Only one option will be used for each
+ * field.
+struct tls_connection_params {
+	const char *ca_cert;
+	const u8 *ca_cert_blob;
+	size_t ca_cert_blob_len;
+	const char *ca_path;
+	const char *subject_match;
+	const char *altsubject_match;
+	const char *suffix_match;
+	const char *domain_match;
+	const char *client_cert;
+	const u8 *client_cert_blob;
+	size_t client_cert_blob_len;
+	const char *private_key;
+	const u8 *private_key_blob;
+	size_t private_key_blob_len;
+	const char *private_key_passwd;
+	const char *dh_file;
+	const u8 *dh_blob;
+	size_t dh_blob_len;
+	/* OpenSSL specific variables */
+	int engine;
+	const char *engine_id;
+	const char *pin;
+	const char *key_id;
+	const char *cert_id;
+	const char *ca_cert_id;
+	unsigned int flags;
+	const char *ocsp_stapling_response;
+ * tls_init - Initialize TLS library
+ * @conf: Configuration data for TLS library
+ * Returns: Context data to be used as tls_ctx in calls to other functions,
+ * or %NULL on failure.
+ * Called once during program startup and once for each RSN pre-authentication
+ * session. In other words, there can be two concurrent TLS contexts. If global
+ * library initialization is needed (i.e., one that is shared between both
+ * authentication types), the TLS library wrapper should maintain a reference
+ * counter and do global initialization only when moving from 0 to 1 reference.
+void * tls_init(const struct tls_config *conf);
+ * tls_deinit - Deinitialize TLS library
+ * @tls_ctx: TLS context data from tls_init()
+ * Called once during program shutdown and once for each RSN pre-authentication
+ * session. If global library deinitialization is needed (i.e., one that is
+ * shared between both authentication types), the TLS library wrapper should
+ * maintain a reference counter and do global deinitialization only when moving
+ * from 1 to 0 references.
+void tls_deinit(void *tls_ctx);
+ * tls_get_errors - Process pending errors
+ * Returns: Number of found error, 0 if no errors detected.
+ * Process all pending TLS errors.
+int tls_get_errors(void *tls_ctx);
+ * tls_connection_init - Initialize a new TLS connection
+ * Returns: Connection context data, conn for other function calls
+struct tls_connection * tls_connection_init(void *tls_ctx);
+ * tls_connection_deinit - Free TLS connection data
+ * @conn: Connection context data from tls_connection_init()
+ * Release all resources allocated for TLS connection.
+void tls_connection_deinit(void *tls_ctx, struct tls_connection *conn);
+ * tls_connection_established - Has the TLS connection been completed?
+ * Returns: 1 if TLS connection has been completed, 0 if not.
+int tls_connection_established(void *tls_ctx, struct tls_connection *conn);
+ * tls_connection_shutdown - Shutdown TLS connection
+ * Shutdown current TLS connection without releasing all resources. New
+ * connection can be started by using the same conn without having to call
+ * tls_connection_init() or setting certificates etc. again. The new
+ * connection should try to use session resumption.
+int tls_connection_shutdown(void *tls_ctx, struct tls_connection *conn);
+enum {
+	TLS_SET_PARAMS_ENGINE_PRV_BAD_PIN = -4,
+	TLS_SET_PARAMS_ENGINE_PRV_VERIFY_FAILED = -3,
+	TLS_SET_PARAMS_ENGINE_PRV_INIT_FAILED = -2
+ * tls_connection_set_params - Set TLS connection parameters
+ * @params: Connection parameters
+ * Returns: 0 on success, -1 on failure,
+ * TLS_SET_PARAMS_ENGINE_PRV_INIT_FAILED (-2) on error causing PKCS#11 engine
+ * failure, or
+ * TLS_SET_PARAMS_ENGINE_PRV_VERIFY_FAILED (-3) on failure to verify the
+ * PKCS#11 engine private key, or
+ * TLS_SET_PARAMS_ENGINE_PRV_BAD_PIN (-4) on PIN error causing PKCS#11 engine
+ * failure.
+int __must_check
+tls_connection_set_params(void *tls_ctx, struct tls_connection *conn,
+			  const struct tls_connection_params *params);
+ * tls_global_set_params - Set TLS parameters for all TLS connection
+ * @params: Global TLS parameters
+ * failure, or
+ * failure.
+int __must_check tls_global_set_params(
+	void *tls_ctx, const struct tls_connection_params *params);
+ * tls_global_set_verify - Set global certificate verification options
+ * @check_crl: 0 = do not verify CRLs, 1 = verify CRL for the user certificate,
+ * 2 = verify CRL for all certificates
+int __must_check tls_global_set_verify(void *tls_ctx, int check_crl);
+ * tls_connection_set_verify - Set certificate verification options
+ * @verify_peer: 1 = verify peer certificate
+ * @flags: Connection flags (TLS_CONN_*)
+ * @session_ctx: Session caching context or %NULL to use default
+ * @session_ctx_len: Length of @session_ctx in bytes.
+int __must_check tls_connection_set_verify(void *tls_ctx,
+					   struct tls_connection *conn,
+					   int verify_peer,
+					   unsigned int flags,
+					   const u8 *session_ctx,
+					   size_t session_ctx_len);
+ * tls_connection_get_random - Get random data from TLS connection
+ * @data: Structure of client/server random data (filled on success)
+int __must_check tls_connection_get_random(void *tls_ctx,
+					 struct tls_random *data);
+ * tls_connection_prf - Use TLS-PRF to derive keying material
+ * @label: Label (e.g., description of the key) for PRF
+ * @server_random_first: seed is 0 = client_random|server_random,
+ * 1 = server_random|client_random
+ * @skip_keyblock: Skip TLS key block from the beginning of PRF output
+ * @out: Buffer for output data from TLS-PRF
+ * @out_len: Length of the output buffer
+ * tls_connection_prf() is required so that further keying material can be
+ * derived from the master secret. Example implementation of this function is in
+ * tls_prf_sha1_md5() when it is called with seed set to
+ * client_random|server_random (or server_random|client_random). For TLSv1.2 and
+ * newer, a different PRF is needed, though.
+int __must_check  tls_connection_prf(void *tls_ctx,
+				     int server_random_first,
+				     int skip_keyblock,
+				     u8 *out, size_t out_len);
+ * tls_connection_handshake - Process TLS handshake (client side)
+ * @in_data: Input data from TLS server
+ * @appl_data: Pointer to application data pointer, or %NULL if dropped
+ * Returns: Output data, %NULL on failure
+ * The caller is responsible for freeing the returned output data. If the final
+ * handshake message includes application data, this is decrypted and
+ * appl_data (if not %NULL) is set to point this data. The caller is
+ * responsible for freeing appl_data.
+ * This function is used during TLS handshake. The first call is done with
+ * in_data == %NULL and the library is expected to return ClientHello packet.
+ * This packet is then send to the server and a response from server is given
+ * to TLS library by calling this function again with in_data pointing to the
+ * TLS message from the server.
+ * If the TLS handshake fails, this function may return %NULL. However, if the
+ * TLS library has a TLS alert to send out, that should be returned as the
+ * output data. In this case, tls_connection_get_failed() must return failure
+ * (> 0).
+ * tls_connection_established() should return 1 once the TLS handshake has been
+ * completed successfully.
+struct wpabuf * tls_connection_handshake(void *tls_ctx,
+					 const struct wpabuf *in_data,
+					 struct wpabuf **appl_data);
+struct wpabuf * tls_connection_handshake2(void *tls_ctx,
+					  struct wpabuf **appl_data,
+					  int *more_data_needed);
+ * tls_connection_server_handshake - Process TLS handshake (server side)
+ * @in_data: Input data from TLS peer
+struct wpabuf * tls_connection_server_handshake(void *tls_ctx,
+ * tls_connection_encrypt - Encrypt data into TLS tunnel
+ * @in_data: Plaintext data to be encrypted
+ * Returns: Encrypted TLS data or %NULL on failure
+ * This function is used after TLS handshake has been completed successfully to
+ * send data in the encrypted tunnel. The caller is responsible for freeing the
+ * returned output data.
+struct wpabuf * tls_connection_encrypt(void *tls_ctx,
+				       const struct wpabuf *in_data);
+ * tls_connection_decrypt - Decrypt data from TLS tunnel
+ * @in_data: Encrypted TLS data
+ * Returns: Decrypted TLS data or %NULL on failure
+ * receive data from the encrypted tunnel. The caller is responsible for
+ * freeing the returned output data.
+struct wpabuf * tls_connection_decrypt(void *tls_ctx,
+struct wpabuf * tls_connection_decrypt2(void *tls_ctx,
+ * tls_connection_resumed - Was session resumption used
+ * Returns: 1 if current session used session resumption, 0 if not
+int tls_connection_resumed(void *tls_ctx, struct tls_connection *conn);
+enum {
+	TLS_CIPHER_NONE,
+	TLS_CIPHER_RC4_SHA /* 0x0005 */,
+	TLS_CIPHER_AES128_SHA /* 0x002f */,
+	TLS_CIPHER_RSA_DHE_AES128_SHA /* 0x0031 */,
+	TLS_CIPHER_ANON_DH_AES128_SHA /* 0x0034 */
+ * tls_connection_set_cipher_list - Configure acceptable cipher suites
+ * @ciphers: Zero (TLS_CIPHER_NONE) terminated list of allowed ciphers
+ * (TLS_CIPHER_*).
+int __must_check tls_connection_set_cipher_list(void *tls_ctx,
+						u8 *ciphers);
+ * tls_get_version - Get the current TLS version number
+ * @buf: Buffer for returning the TLS version number
+ * @buflen: buf size
+ * Get the currently used TLS version number.
+int __must_check tls_get_version(void *tls_ctx, struct tls_connection *conn,
+				 char *buf, size_t buflen);
+ * tls_get_cipher - Get current cipher name
+ * @buf: Buffer for the cipher name
+ * Get the name of the currently used cipher.
+int __must_check tls_get_cipher(void *tls_ctx, struct tls_connection *conn,
+ * tls_connection_enable_workaround - Enable TLS workaround options
+ * This function is used to enable connection-specific workaround options for
+ * buffer SSL/TLS implementations.
+int __must_check tls_connection_enable_workaround(void *tls_ctx,
+						  struct tls_connection *conn);
+ * tls_connection_client_hello_ext - Set TLS extension for ClientHello
+ * @ext_type: Extension type
+ * @data: Extension payload (%NULL to remove extension)
+ * @data_len: Extension payload length
+int __must_check tls_connection_client_hello_ext(void *tls_ctx,
+						 int ext_type, const u8 *data,
+						 size_t data_len);
+ * tls_connection_get_failed - Get connection failure status
+ * Returns >0 if connection has failed, 0 if not.
+int tls_connection_get_failed(void *tls_ctx, struct tls_connection *conn);
+ * tls_connection_get_read_alerts - Get connection read alert status
+ * Returns: Number of times a fatal read (remote end reported error) has
+ * happened during this connection.
+int tls_connection_get_read_alerts(void *tls_ctx, struct tls_connection *conn);
+ * tls_connection_get_write_alerts - Get connection write alert status
+ * Returns: Number of times a fatal write (locally detected error) has happened
+ * during this connection.
+int tls_connection_get_write_alerts(void *tls_ctx,
+typedef int (*tls_session_ticket_cb)
+(void *ctx, const u8 *ticket, size_t len, const u8 *client_random,
+ const u8 *server_random, u8 *master_secret);
+int __must_check  tls_connection_set_session_ticket_cb(
+	void *tls_ctx, struct tls_connection *conn,
+	tls_session_ticket_cb cb, void *ctx);
+void tls_connection_set_log_cb(struct tls_connection *conn,
+			       void (*log_cb)(void *ctx, const char *msg),
+			       void *ctx);
+#define TLS_BREAK_VERIFY_DATA BIT(0)
+#define TLS_BREAK_SRV_KEY_X_HASH BIT(1)
+#define TLS_BREAK_SRV_KEY_X_SIGNATURE BIT(2)
+#define TLS_DHE_PRIME_511B BIT(3)
+#define TLS_DHE_PRIME_767B BIT(4)
+#define TLS_DHE_PRIME_15 BIT(5)
+#define TLS_DHE_PRIME_58B BIT(6)
+#define TLS_DHE_NON_PRIME BIT(7)
+void tls_connection_set_test_flags(struct tls_connection *conn, u32 flags);
+int tls_get_library_version(char *buf, size_t buf_len);
+void tls_connection_set_success_data(struct tls_connection *conn,
+				     struct wpabuf *data);
+void tls_connection_set_success_data_resumed(struct tls_connection *conn);
+const struct wpabuf *
+tls_connection_get_success_data(struct tls_connection *conn);
+void tls_connection_remove_session(struct tls_connection *conn);
+#endif /* TLS_H */
diff --git a/freebsd/contrib/wpa/src/crypto/tls_internal.c b/freebsd/contrib/wpa/src/crypto/tls_internal.c
index 00000000000..6a91f49752a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/crypto/tls_internal.c
@@ -0,0 +1,735 @@
+ * TLS interface functions and an internal TLS implementation
+ * Copyright (c) 2004-2011, Jouni Malinen <j at w1.fi>
+ * This file interface functions for hostapd/wpa_supplicant to use the
+ * integrated TLSv1 implementation.
+#include "tls.h"
+#include "tls/tlsv1_client.h"
+#include "tls/tlsv1_server.h"
+static int tls_ref_count = 0;
+struct tls_global {
+	int server;
+	struct tlsv1_credentials *server_cred;
+	int check_crl;
+struct tls_connection {
+	struct tlsv1_client *client;
+	struct tlsv1_server *server;
+	struct tls_global *global;
+	if (tls_ref_count == 0) {
+#ifdef CONFIG_TLS_INTERNAL_CLIENT
+		if (tlsv1_client_global_init())
+			return NULL;
+#endif /* CONFIG_TLS_INTERNAL_CLIENT */
+#ifdef CONFIG_TLS_INTERNAL_SERVER
+		if (tlsv1_server_global_init())
+			return NULL;
+#endif /* CONFIG_TLS_INTERNAL_SERVER */
+	tls_ref_count++;
+	global = os_zalloc(sizeof(*global));
+	if (global == NULL)
+		return NULL;
+	return global;
+void tls_deinit(void *ssl_ctx)
+	struct tls_global *global = ssl_ctx;
+	tls_ref_count--;
+		tlsv1_client_global_deinit();
+		tlsv1_cred_free(global->server_cred);
+		tlsv1_server_global_deinit();
+	os_free(global);
+	return 0;
+	struct tls_connection *conn;
+	struct tls_global *global = tls_ctx;
+	conn = os_zalloc(sizeof(*conn));
+	if (conn == NULL)
+		return NULL;
+	conn->global = global;
+	if (!global->server) {
+		conn->client = tlsv1_client_init();
+		if (conn->client == NULL) {
+			os_free(conn);
+			return NULL;
+	if (global->server) {
+		conn->server = tlsv1_server_init(global->server_cred);
+		if (conn->server == NULL) {
+			os_free(conn);
+			return NULL;
+	return conn;
+#ifdef CONFIG_TESTING_OPTIONS
+	if (conn->server)
+		tlsv1_server_set_test_flags(conn->server, flags);
+#endif /* CONFIG_TESTING_OPTIONS */
+			       void *ctx)
+	if (conn->server)
+		tlsv1_server_set_log_cb(conn->server, log_cb, ctx);
+	if (conn == NULL)
+		return;
+	if (conn->client)
+		tlsv1_client_deinit(conn->client);
+	if (conn->server)
+		tlsv1_server_deinit(conn->server);
+	os_free(conn);
+	if (conn->client)
+		return tlsv1_client_established(conn->client);
+	if (conn->server)
+		return tlsv1_server_established(conn->server);
+	return 0;
+	if (conn->client)
+		return tlsv1_client_shutdown(conn->client);
+	if (conn->server)
+		return tlsv1_server_shutdown(conn->server);
+	return -1;
+int tls_connection_set_params(void *tls_ctx, struct tls_connection *conn,
+	struct tlsv1_credentials *cred;
+		return -1;
+	cred = tlsv1_cred_alloc();
+	if (cred == NULL)
+		return -1;
+	if (params->subject_match) {
+		wpa_printf(MSG_INFO, "TLS: subject_match not supported");
+		tlsv1_cred_free(cred);
+		return -1;
+	if (params->altsubject_match) {
+		wpa_printf(MSG_INFO, "TLS: altsubject_match not supported");
+		return -1;
+	if (params->suffix_match) {
+		wpa_printf(MSG_INFO, "TLS: suffix_match not supported");
+		return -1;
+	if (params->domain_match) {
+		wpa_printf(MSG_INFO, "TLS: domain_match not supported");
+		return -1;
+	if (params->openssl_ciphers) {
+		wpa_printf(MSG_INFO, "TLS: openssl_ciphers not supported");
+		return -1;
+	if (tlsv1_set_ca_cert(cred, params->ca_cert,
+			      params->ca_cert_blob, params->ca_cert_blob_len,
+			      params->ca_path)) {
+		wpa_printf(MSG_INFO, "TLS: Failed to configure trusted CA "
+			   "certificates");
+		return -1;
+	if (tlsv1_set_cert(cred, params->client_cert,
+			   params->client_cert_blob,
+			   params->client_cert_blob_len)) {
+		wpa_printf(MSG_INFO, "TLS: Failed to configure client "
+			   "certificate");
+		return -1;
+	if (tlsv1_set_private_key(cred, params->private_key,
+				  params->private_key_passwd,
+				  params->private_key_blob,
+				  params->private_key_blob_len)) {
+		wpa_printf(MSG_INFO, "TLS: Failed to load private key");
+		return -1;
+	if (tlsv1_set_dhparams(cred, params->dh_file, params->dh_blob,
+			       params->dh_blob_len)) {
+		wpa_printf(MSG_INFO, "TLS: Failed to load DH parameters");
+		return -1;
+	if (tlsv1_client_set_cred(conn->client, cred) < 0) {
+		return -1;
+	tlsv1_client_set_time_checks(
+		conn->client, !(params->flags & TLS_CONN_DISABLE_TIME_CHECKS));
+	return 0;
+#else /* CONFIG_TLS_INTERNAL_CLIENT */
+	return -1;
+int tls_global_set_params(void *tls_ctx,
+	/* Currently, global parameters are only set when running in server
+	 * mode. */
+	global->server = 1;
+	global->server_cred = cred = tlsv1_cred_alloc();
+	if (cred == NULL)
+		return -1;
+	if (tlsv1_set_ca_cert(cred, params->ca_cert, params->ca_cert_blob,
+			      params->ca_cert_blob_len, params->ca_path)) {
+			   "certificates");
+		return -1;
+	if (tlsv1_set_cert(cred, params->client_cert, params->client_cert_blob,
+		wpa_printf(MSG_INFO, "TLS: Failed to configure server "
+			   "certificate");
+		return -1;
+		return -1;
+		return -1;
+	return 0;
+#else /* CONFIG_TLS_INTERNAL_SERVER */
+	return -1;
+int tls_global_set_verify(void *tls_ctx, int check_crl)
+	global->check_crl = check_crl;
+	return 0;
+int tls_connection_set_verify(void *tls_ctx, struct tls_connection *conn,
+			      int verify_peer, unsigned int flags,
+			      const u8 *session_ctx, size_t session_ctx_len)
+	if (conn->server)
+		return tlsv1_server_set_verify(conn->server, verify_peer);
+	return -1;
+int tls_connection_get_random(void *tls_ctx, struct tls_connection *conn,
+	if (conn->client)
+		return tlsv1_client_get_random(conn->client, data);
+	if (conn->server)
+		return tlsv1_server_get_random(conn->server, data);
+	return -1;
+static int tls_get_keyblock_size(struct tls_connection *conn)
+	if (conn->client)
+		return tlsv1_client_get_keyblock_size(conn->client);
+	if (conn->server)
+		return tlsv1_server_get_keyblock_size(conn->server);
+	return -1;
+int tls_connection_prf(void *tls_ctx, struct tls_connection *conn,
+		       const char *label, int server_random_first,
+		       int skip_keyblock, u8 *out, size_t out_len)
+	int ret = -1, skip = 0;
+	u8 *tmp_out = NULL;
+	u8 *_out = out;
+	if (skip_keyblock) {
+		skip = tls_get_keyblock_size(conn);
+		if (skip < 0)
+			return -1;
+		tmp_out = os_malloc(skip + out_len);
+		if (!tmp_out)
+			return -1;
+		_out = tmp_out;
+	if (conn->client) {
+		ret = tlsv1_client_prf(conn->client, label,
+				       server_random_first,
+				       _out, out_len);
+	if (conn->server) {
+		ret = tlsv1_server_prf(conn->server, label,
+				       _out, out_len);
+	if (ret == 0 && skip_keyblock)
+		os_memcpy(out, _out + skip, out_len);
+	bin_clear_free(tmp_out, skip);
+	return ret;
+	return tls_connection_handshake2(tls_ctx, conn, in_data, appl_data,
+					 NULL);
+					  int *need_more_data)
+	u8 *res, *ad;
+	size_t res_len, ad_len;
+	struct wpabuf *out;
+		return NULL;
+	ad = NULL;
+	res = tlsv1_client_handshake(conn->client,
+				     in_data ? wpabuf_head(in_data) : NULL,
+				     in_data ? wpabuf_len(in_data) : 0,
+				     &res_len, &ad, &ad_len, need_more_data);
+	if (res == NULL)
+		return NULL;
+	out = wpabuf_alloc_ext_data(res, res_len);
+	if (out == NULL) {
+		os_free(res);
+		os_free(ad);
+		return NULL;
+	if (appl_data) {
+		if (ad) {
+			*appl_data = wpabuf_alloc_ext_data(ad, ad_len);
+			if (*appl_data == NULL)
+				os_free(ad);
+		} else
+			*appl_data = NULL;
+	} else
+		os_free(ad);
+	return out;
+	return NULL;
+	u8 *res;
+	size_t res_len;
+		return NULL;
+	if (appl_data)
+	res = tlsv1_server_handshake(conn->server, wpabuf_head(in_data),
+				     wpabuf_len(in_data), &res_len);
+	if (res == NULL && tlsv1_server_established(conn->server))
+		return wpabuf_alloc(0);
+	if (res == NULL)
+		return NULL;
+		os_free(res);
+		return NULL;
+	return out;
+	return NULL;
+		struct wpabuf *buf;
+		int res;
+		buf = wpabuf_alloc(wpabuf_len(in_data) + 300);
+		if (buf == NULL)
+			return NULL;
+		res = tlsv1_client_encrypt(conn->client, wpabuf_head(in_data),
+					   wpabuf_mhead(buf),
+					   wpabuf_size(buf));
+		if (res < 0) {
+			wpabuf_free(buf);
+			return NULL;
+		wpabuf_put(buf, res);
+		return buf;
+		int res;
+		if (buf == NULL)
+			return NULL;
+		res = tlsv1_server_encrypt(conn->server, wpabuf_head(in_data),
+		if (res < 0) {
+			wpabuf_free(buf);
+			return NULL;
+		return buf;
+	return NULL;
+	return tls_connection_decrypt2(tls_ctx, conn, in_data, NULL);
+	if (need_more_data)
+		*need_more_data = 0;
+		return tlsv1_client_decrypt(conn->client, wpabuf_head(in_data),
+					    need_more_data);
+		int res;
+		buf = wpabuf_alloc((wpabuf_len(in_data) + 500) * 3);
+		if (buf == NULL)
+			return NULL;
+		res = tlsv1_server_decrypt(conn->server, wpabuf_head(in_data),
+		if (res < 0) {
+			wpabuf_free(buf);
+			return NULL;
+		return buf;
+	return NULL;
+	if (conn->client)
+		return tlsv1_client_resumed(conn->client);
+	if (conn->server)
+		return tlsv1_server_resumed(conn->server);
+	return -1;
+int tls_connection_set_cipher_list(void *tls_ctx, struct tls_connection *conn,
+				   u8 *ciphers)
+	if (conn->client)
+		return tlsv1_client_set_cipher_list(conn->client, ciphers);
+	if (conn->server)
+		return tlsv1_server_set_cipher_list(conn->server, ciphers);
+	return -1;
+int tls_get_version(void *ssl_ctx, struct tls_connection *conn,
+	/* TODO */
+	return -1;
+int tls_get_cipher(void *tls_ctx, struct tls_connection *conn,
+	if (conn == NULL)
+		return -1;
+	if (conn->client)
+		return tlsv1_client_get_cipher(conn->client, buf, buflen);
+	if (conn->server)
+		return tlsv1_server_get_cipher(conn->server, buf, buflen);
+	return -1;
+int tls_connection_enable_workaround(void *tls_ctx,
+	return -1;
+int tls_connection_client_hello_ext(void *tls_ctx, struct tls_connection *conn,
+				    size_t data_len)
+		return tlsv1_client_hello_ext(conn->client, ext_type,
+					      data, data_len);
+	return -1;
+	return 0;
+	return 0;
+	return 0;
+int tls_connection_set_session_ticket_cb(void *tls_ctx,
+					 void *ctx)
+		tlsv1_client_set_session_ticket_cb(conn->client, cb, ctx);
+		return 0;
+		tlsv1_server_set_session_ticket_cb(conn->server, cb, ctx);
+		return 0;
+	return -1;
+	return os_snprintf(buf, buf_len, "internal");
+	return NULL;
diff --git a/freebsd/contrib/wpa/src/drivers/driver.h b/freebsd/contrib/wpa/src/drivers/driver.h
index 00000000000..3cdab5a7a87
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver.h
@@ -0,0 +1,4704 @@
+ * Driver interface definition
+ * Copyright (c) 2003-2015, Jouni Malinen <j at w1.fi>
+ * This file defines a driver interface used by both %wpa_supplicant and
+ * hostapd. The first part of the file defines data structures used in various
+ * driver operations. This is followed by the struct wpa_driver_ops that each
+ * driver wrapper will beed to define with callback functions for requesting
+ * driver operations. After this, there are definitions for driver event
+ * reporting with wpa_supplicant_event() and some convenience helper functions
+ * that can be used to report events.
+#ifndef DRIVER_H
+#define DRIVER_H
+#define WPA_SUPPLICANT_DRIVER_VERSION 4
+#include "common/defs.h"
+#include "common/ieee802_11_defs.h"
+#include "utils/list.h"
+#define HOSTAPD_CHAN_DISABLED 0x00000001
+#define HOSTAPD_CHAN_NO_IR 0x00000002
+#define HOSTAPD_CHAN_RADAR 0x00000008
+#define HOSTAPD_CHAN_HT40PLUS 0x00000010
+#define HOSTAPD_CHAN_HT40MINUS 0x00000020
+#define HOSTAPD_CHAN_HT40 0x00000040
+#define HOSTAPD_CHAN_SURVEY_LIST_INITIALIZED 0x00000080
+#define HOSTAPD_CHAN_DFS_UNKNOWN 0x00000000
+#define HOSTAPD_CHAN_DFS_USABLE 0x00000100
+#define HOSTAPD_CHAN_DFS_UNAVAILABLE 0x00000200
+#define HOSTAPD_CHAN_DFS_AVAILABLE 0x00000300
+#define HOSTAPD_CHAN_DFS_MASK 0x00000300
+#define HOSTAPD_CHAN_VHT_10_70 0x00000800
+#define HOSTAPD_CHAN_VHT_30_50 0x00001000
+#define HOSTAPD_CHAN_VHT_50_30 0x00002000
+#define HOSTAPD_CHAN_VHT_70_10 0x00004000
+#define HOSTAPD_CHAN_INDOOR_ONLY 0x00010000
+#define HOSTAPD_CHAN_GO_CONCURRENT 0x00020000
+ * enum reg_change_initiator - Regulatory change initiator
+enum reg_change_initiator {
+	REGDOM_SET_BY_CORE,
+	REGDOM_SET_BY_USER,
+	REGDOM_SET_BY_DRIVER,
+	REGDOM_SET_BY_COUNTRY_IE,
+	REGDOM_BEACON_HINT,
+ * enum reg_type - Regulatory change types
+enum reg_type {
+	REGDOM_TYPE_UNKNOWN,
+	REGDOM_TYPE_COUNTRY,
+	REGDOM_TYPE_WORLD,
+	REGDOM_TYPE_CUSTOM_WORLD,
+	REGDOM_TYPE_INTERSECTION,
+ * struct hostapd_channel_data - Channel information
+struct hostapd_channel_data {
+	 * chan - Channel number (IEEE 802.11)
+	short chan;
+	 * freq - Frequency in MHz
+	int freq;
+	 * flag - Channel flags (HOSTAPD_CHAN_*)
+	int flag;
+	 * max_tx_power - Regulatory transmit power limit in dBm
+	u8 max_tx_power;
+	 * survey_list - Linked list of surveys (struct freq_survey)
+	struct dl_list survey_list;
+	 * min_nf - Minimum observed noise floor, in dBm, based on all
+	 * surveyed channel data
+	s8 min_nf;
+#ifdef CONFIG_ACS
+	 * interference_factor - Computed interference factor on this
+	 * channel (used internally in src/ap/acs.c; driver wrappers do not
+	 * need to set this)
+	long double interference_factor;
+#endif /* CONFIG_ACS */
+	 * dfs_cac_ms - DFS CAC time in milliseconds
+	unsigned int dfs_cac_ms;
+#define HOSTAPD_MODE_FLAG_HT_INFO_KNOWN BIT(0)
+#define HOSTAPD_MODE_FLAG_VHT_INFO_KNOWN BIT(1)
+ * struct hostapd_hw_modes - Supported hardware mode information
+struct hostapd_hw_modes {
+	 * mode - Hardware mode
+	enum hostapd_hw_mode mode;
+	 * num_channels - Number of entries in the channels array
+	int num_channels;
+	 * channels - Array of supported channels
+	struct hostapd_channel_data *channels;
+	 * num_rates - Number of entries in the rates array
+	int num_rates;
+	 * rates - Array of supported rates in 100 kbps units
+	int *rates;
+	 * ht_capab - HT (IEEE 802.11n) capabilities
+	u16 ht_capab;
+	 * mcs_set - MCS (IEEE 802.11n) rate parameters
+	u8 mcs_set[16];
+	 * a_mpdu_params - A-MPDU (IEEE 802.11n) parameters
+	u8 a_mpdu_params;
+	 * vht_capab - VHT (IEEE 802.11ac) capabilities
+	u32 vht_capab;
+	 * vht_mcs_set - VHT MCS (IEEE 802.11ac) rate parameters
+	u8 vht_mcs_set[8];
+	unsigned int flags; /* HOSTAPD_MODE_FLAG_* */
+#define IEEE80211_MODE_INFRA	0
+#define IEEE80211_MODE_IBSS	1
+#define IEEE80211_MODE_AP	2
+#define IEEE80211_MODE_MESH	5
+#define IEEE80211_CAP_ESS	0x0001
+#define IEEE80211_CAP_IBSS	0x0002
+#define IEEE80211_CAP_PRIVACY	0x0010
+#define IEEE80211_CAP_RRM	0x1000
+/* DMG (60 GHz) IEEE 802.11ad */
+/* type - bits 0..1 */
+#define IEEE80211_CAP_DMG_MASK	0x0003
+#define IEEE80211_CAP_DMG_IBSS	0x0001 /* Tx by: STA */
+#define IEEE80211_CAP_DMG_PBSS	0x0002 /* Tx by: PCP */
+#define IEEE80211_CAP_DMG_AP	0x0003 /* Tx by: AP */
+#define WPA_SCAN_QUAL_INVALID		BIT(0)
+#define WPA_SCAN_NOISE_INVALID		BIT(1)
+#define WPA_SCAN_LEVEL_INVALID		BIT(2)
+#define WPA_SCAN_LEVEL_DBM		BIT(3)
+#define WPA_SCAN_ASSOCIATED		BIT(5)
+ * struct wpa_scan_res - Scan result for an BSS/IBSS
+ * @flags: information flags about the BSS/IBSS (WPA_SCAN_*)
+ * @bssid: BSSID
+ * @freq: frequency of the channel in MHz (e.g., 2412 = channel 1)
+ * @beacon_int: beacon interval in TUs (host byte order)
+ * @caps: capability information field in host byte order
+ * @qual: signal quality
+ * @noise: noise level
+ * @level: signal level
+ * @tsf: Timestamp
+ * @age: Age of the information in milliseconds (i.e., how many milliseconds
+ * ago the last Beacon or Probe Response frame was received)
+ * @est_throughput: Estimated throughput in kbps (this is calculated during
+ * scan result processing if left zero by the driver wrapper)
+ * @snr: Signal-to-noise ratio in dB (calculated during scan result processing)
+ * @ie_len: length of the following IE field in octets
+ * @beacon_ie_len: length of the following Beacon IE field in octets
+ * This structure is used as a generic format for scan results from the
+ * driver. Each driver interface implementation is responsible for converting
+ * the driver or OS specific scan results into this format.
+ * If the driver does not support reporting all IEs, the IE data structure is
+ * constructed of the IEs that are available. This field will also need to
+ * include SSID in IE format. All drivers are encouraged to be extended to
+ * report all IEs to make it easier to support future additions.
+ * This structure data is followed by ie_len octets of IEs from Probe Response
+ * frame (or if the driver does not indicate source of IEs, these may also be
+ * from Beacon frame). After the first set of IEs, another set of IEs may follow
+ * (with beacon_ie_len octets of data) if the driver provides both IE sets.
+struct wpa_scan_res {
+	u8 bssid[ETH_ALEN];
+	int freq;
+	u16 beacon_int;
+	u16 caps;
+	int qual;
+	int noise;
+	int level;
+	u64 tsf;
+	unsigned int age;
+	unsigned int est_throughput;
+	int snr;
+	size_t ie_len;
+	size_t beacon_ie_len;
+	/* Followed by ie_len + beacon_ie_len octets of IE data */
+ * struct wpa_scan_results - Scan results
+ * @res: Array of pointers to allocated variable length scan result entries
+ * @num: Number of entries in the scan result array
+ * @fetch_time: Time when the results were fetched from the driver
+struct wpa_scan_results {
+	struct wpa_scan_res **res;
+	size_t num;
+	struct os_reltime fetch_time;
+ * struct wpa_interface_info - Network interface information
+ * @next: Pointer to the next interface or NULL if this is the last one
+ * @ifname: Interface name that can be used with init() or init2()
+ * @desc: Human readable adapter description (e.g., vendor/model) or NULL if
+ *	not available
+ * @drv_name: struct wpa_driver_ops::name (note: unlike other strings, this one
+ *	is not an allocated copy, i.e., get_interfaces() caller will not free
+ *	this)
+struct wpa_interface_info {
+	struct wpa_interface_info *next;
+	char *ifname;
+	char *desc;
+	const char *drv_name;
+#define WPAS_MAX_SCAN_SSIDS 16
+ * struct wpa_driver_scan_params - Scan parameters
+ * Data for struct wpa_driver_ops::scan2().
+struct wpa_driver_scan_params {
+	 * ssids - SSIDs to scan for
+	struct wpa_driver_scan_ssid {
+		 * ssid - specific SSID to scan for (ProbeReq)
+		 * %NULL or zero-length SSID is used to indicate active scan
+		 * with wildcard SSID.
+		const u8 *ssid;
+		 * ssid_len: Length of the SSID in octets
+		size_t ssid_len;
+	} ssids[WPAS_MAX_SCAN_SSIDS];
+	 * num_ssids - Number of entries in ssids array
+	 * Zero indicates a request for a passive scan.
+	size_t num_ssids;
+	 * extra_ies - Extra IE(s) to add into Probe Request or %NULL
+	const u8 *extra_ies;
+	 * extra_ies_len - Length of extra_ies in octets
+	size_t extra_ies_len;
+	 * freqs - Array of frequencies to scan or %NULL for all frequencies
+	 * The frequency is set in MHz. The array is zero-terminated.
+	int *freqs;
+	 * filter_ssids - Filter for reporting SSIDs
+	 * This optional parameter can be used to request the driver wrapper to
+	 * filter scan results to include only the specified SSIDs. %NULL
+	 * indicates that no filtering is to be done. This can be used to
+	 * reduce memory needs for scan results in environments that have large
+	 * number of APs with different SSIDs.
+	 * The driver wrapper is allowed to take this allocated buffer into its
+	 * own use by setting the pointer to %NULL. In that case, the driver
+	 * wrapper is responsible for freeing the buffer with os_free() once it
+	 * is not needed anymore.
+	struct wpa_driver_scan_filter {
+		u8 ssid[SSID_MAX_LEN];
+		size_t ssid_len;
+	} *filter_ssids;
+	 * num_filter_ssids - Number of entries in filter_ssids array
+	size_t num_filter_ssids;
+	 * filter_rssi - Filter by RSSI
+	 * The driver may filter scan results in firmware to reduce host
+	 * wakeups and thereby save power. Specify the RSSI threshold in s32
+	 * dBm.
+	s32 filter_rssi;
+	 * p2p_probe - Used to disable CCK (802.11b) rates for P2P probes
+	 * When set, the driver is expected to remove rates 1, 2, 5.5, and 11
+	 * Mbps from the support rates element(s) in the Probe Request frames
+	 * and not to transmit the frames at any of those rates.
+	unsigned int p2p_probe:1;
+	 * only_new_results - Request driver to report only new results
+	 * This is used to request the driver to report only BSSes that have
+	 * been detected after this scan request has been started, i.e., to
+	 * flush old cached BSS entries.
+	unsigned int only_new_results:1;
+	 * low_priority - Requests driver to use a lower scan priority
+	 * This is used to request the driver to use a lower scan priority
+	 * if it supports such a thing.
+	unsigned int low_priority:1;
+	 * mac_addr_rand - Requests driver to randomize MAC address
+	unsigned int mac_addr_rand:1;
+	 * mac_addr - MAC address used with randomization. The address cannot be
+	 * a multicast one, i.e., bit 0 of byte 0 should not be set.
+	const u8 *mac_addr;
+	 * mac_addr_mask - MAC address mask used with randomization.
+	 * Bits that are 0 in the mask should be randomized. Bits that are 1 in
+	 * the mask should be taken as is from mac_addr. The mask should not
+	 * allow the generation of a multicast address, i.e., bit 0 of byte 0
+	 * must be set.
+	const u8 *mac_addr_mask;
+	 * NOTE: Whenever adding new parameters here, please make sure
+	 * wpa_scan_clone_params() and wpa_scan_free_params() get updated with
+	 * matching changes.
+ * struct wpa_driver_auth_params - Authentication parameters
+ * Data for struct wpa_driver_ops::authenticate().
+struct wpa_driver_auth_params {
+	int freq;
+	const u8 *bssid;
+	const u8 *ssid;
+	size_t ssid_len;
+	int auth_alg;
+	const u8 *ie;
+	size_t ie_len;
+	const u8 *wep_key[4];
+	size_t wep_key_len[4];
+	int wep_tx_keyidx;
+	int local_state_change;
+	 * p2p - Whether this connection is a P2P group
+	int p2p;
+	 * sae_data - SAE elements for Authentication frame
+	 * This buffer starts with the Authentication transaction sequence
+	 * number field. If SAE is not used, this pointer is %NULL.
+	const u8 *sae_data;
+	 * sae_data_len - Length of sae_data buffer in octets
+	size_t sae_data_len;
+ * enum wps_mode - WPS mode
+enum wps_mode {
+	 * WPS_MODE_NONE - No WPS provisioning being used
+	WPS_MODE_NONE,
+	 * WPS_MODE_OPEN - WPS provisioning with AP that is in open mode
+	WPS_MODE_OPEN,
+	 * WPS_MODE_PRIVACY - WPS provisioning with AP that is using protection
+	WPS_MODE_PRIVACY
+ * struct hostapd_freq_params - Channel parameters
+struct hostapd_freq_params {
+	 * mode - Mode/band (HOSTAPD_MODE_IEEE80211A, ..)
+	 * freq - Primary channel center frequency in MHz
+	int freq;
+	 * channel - Channel number
+	int channel;
+	 * ht_enabled - Whether HT is enabled
+	int ht_enabled;
+	 * sec_channel_offset - Secondary channel offset for HT40
+	 * 0 = HT40 disabled,
+	 * -1 = HT40 enabled, secondary channel below primary,
+	 * 1 = HT40 enabled, secondary channel above primary
+	int sec_channel_offset;
+	 * vht_enabled - Whether VHT is enabled
+	int vht_enabled;
+	 * center_freq1 - Segment 0 center frequency in MHz
+	 * Valid for both HT and VHT.
+	int center_freq1;
+	 * center_freq2 - Segment 1 center frequency in MHz
+	 * Non-zero only for bandwidth 80 and an 80+80 channel
+	int center_freq2;
+	 * bandwidth - Channel bandwidth in MHz (20, 40, 80, 160)
+	int bandwidth;
+ * struct wpa_driver_associate_params - Association parameters
+ * Data for struct wpa_driver_ops::associate().
+struct wpa_driver_associate_params {
+	 * bssid - BSSID of the selected AP
+	 * This can be %NULL, if ap_scan=2 mode is used and the driver is
+	 * responsible for selecting with which BSS to associate. */
+	const u8 *bssid;
+	 * bssid_hint - BSSID of a proposed AP
+	 * This indicates which BSS has been found a suitable candidate for
+	 * initial association for drivers that use driver/firmwate-based BSS
+	 * selection. Unlike the @bssid parameter, @bssid_hint does not limit
+	 * the driver from selecting other BSSes in the ESS.
+	const u8 *bssid_hint;
+	 * ssid - The selected SSID
+	const u8 *ssid;
+	 * ssid_len - Length of the SSID (1..32)
+	size_t ssid_len;
+	 * freq - channel parameters
+	struct hostapd_freq_params freq;
+	 * freq_hint - Frequency of the channel the proposed AP is using
+	 * This provides a channel on which a suitable BSS has been found as a
+	 * hint for the driver. Unlike the @freq parameter, @freq_hint does not
+	 * limit the driver from selecting other channels for
+	 * driver/firmware-based BSS selection.
+	int freq_hint;
+	 * bg_scan_period - Background scan period in seconds, 0 to disable
+	 * background scan, or -1 to indicate no change to default driver
+	 * configuration
+	int bg_scan_period;
+	 * beacon_int - Beacon interval for IBSS or 0 to use driver default
+	int beacon_int;
+	 * wpa_ie - WPA information element for (Re)Association Request
+	 * WPA information element to be included in (Re)Association
+	 * Request (including information element id and length). Use
+	 * of this WPA IE is optional. If the driver generates the WPA
+	 * IE, it can use pairwise_suite, group_suite, and
+	 * key_mgmt_suite to select proper algorithms. In this case,
+	 * the driver has to notify wpa_supplicant about the used WPA
+	 * IE by generating an event that the interface code will
+	 * convert into EVENT_ASSOCINFO data (see below).
+	 * When using WPA2/IEEE 802.11i, wpa_ie is used for RSN IE
+	 * instead. The driver can determine which version is used by
+	 * looking at the first byte of the IE (0xdd for WPA, 0x30 for
+	 * WPA2/RSN).
+	 * When using WPS, wpa_ie is used for WPS IE instead of WPA/RSN IE.
+	const u8 *wpa_ie;
+	 * wpa_ie_len - length of the wpa_ie
+	size_t wpa_ie_len;
+	 * wpa_proto - Bitfield of WPA_PROTO_* values to indicate WPA/WPA2
+	unsigned int wpa_proto;
+	 * pairwise_suite - Selected pairwise cipher suite (WPA_CIPHER_*)
+	 * This is usually ignored if @wpa_ie is used.
+	unsigned int pairwise_suite;
+	 * group_suite - Selected group cipher suite (WPA_CIPHER_*)
+	unsigned int group_suite;
+	 * key_mgmt_suite - Selected key management suite (WPA_KEY_MGMT_*)
+	unsigned int key_mgmt_suite;
+	 * auth_alg - Allowed authentication algorithms
+	 * Bit field of WPA_AUTH_ALG_*
+	int auth_alg;
+	 * mode - Operation mode (infra/ibss) IEEE80211_MODE_*
+	int mode;
+	 * wep_key - WEP keys for static WEP configuration
+	 * wep_key_len - WEP key length for static WEP configuration
+	 * wep_tx_keyidx - WEP TX key index for static WEP configuration
+	 * mgmt_frame_protection - IEEE 802.11w management frame protection
+	enum mfp_options mgmt_frame_protection;
+	 * ft_ies - IEEE 802.11r / FT information elements
+	 * If the supplicant is using IEEE 802.11r (FT) and has the needed keys
+	 * for fast transition, this parameter is set to include the IEs that
+	 * are to be sent in the next FT Authentication Request message.
+	 * update_ft_ies() handler is called to update the IEs for further
+	 * FT messages in the sequence.
+	 * The driver should use these IEs only if the target AP is advertising
+	 * the same mobility domain as the one included in the MDIE here.
+	 * In ap_scan=2 mode, the driver can use these IEs when moving to a new
+	 * AP after the initial association. These IEs can only be used if the
+	 * target AP is advertising support for FT and is using the same MDIE
+	 * and SSID as the current AP.
+	 * The driver is responsible for reporting the FT IEs received from the
+	 * AP's response using wpa_supplicant_event() with EVENT_FT_RESPONSE
+	 * type. update_ft_ies() handler will then be called with the FT IEs to
+	 * include in the next frame in the authentication sequence.
+	const u8 *ft_ies;
+	 * ft_ies_len - Length of ft_ies in bytes
+	size_t ft_ies_len;
+	 * ft_md - FT Mobility domain (6 octets) (also included inside ft_ies)
+	 * This value is provided to allow the driver interface easier access
+	 * to the current mobility domain. This value is set to %NULL if no
+	 * mobility domain is currently active.
+	const u8 *ft_md;
+	 * passphrase - RSN passphrase for PSK
+	 * This value is made available only for WPA/WPA2-Personal (PSK) and
+	 * only for drivers that set WPA_DRIVER_FLAGS_4WAY_HANDSHAKE. This is
+	 * the 8..63 character ASCII passphrase, if available. Please note that
+	 * this can be %NULL if passphrase was not used to generate the PSK. In
+	 * that case, the psk field must be used to fetch the PSK.
+	const char *passphrase;
+	 * psk - RSN PSK (alternative for passphrase for PSK)
+	 * the 32-octet (256-bit) PSK, if available. The driver wrapper should
+	 * be prepared to handle %NULL value as an error.
+	const u8 *psk;
+	 * drop_unencrypted - Enable/disable unencrypted frame filtering
+	 * Configure the driver to drop all non-EAPOL frames (both receive and
+	 * transmit paths). Unencrypted EAPOL frames (ethertype 0x888e) must
+	 * still be allowed for key negotiation.
+	int drop_unencrypted;
+	 * prev_bssid - Previously used BSSID in this ESS
+	 * When not %NULL, this is a request to use reassociation instead of
+	 * association.
+	const u8 *prev_bssid;
+	 * wps - WPS mode
+	 * If the driver needs to do special configuration for WPS association,
+	 * this variable provides more information on what type of association
+	 * is being requested. Most drivers should not need ot use this.
+	enum wps_mode wps;
+	int p2p;
+	 * uapsd - UAPSD parameters for the network
+	 * -1 = do not change defaults
+	 * AP mode: 1 = enabled, 0 = disabled
+	 * STA mode: bits 0..3 UAPSD enabled for VO,VI,BK,BE
+	int uapsd;
+	 * fixed_bssid - Whether to force this BSSID in IBSS mode
+	 * 1 = Fix this BSSID and prevent merges.
+	 * 0 = Do not fix BSSID.
+	int fixed_bssid;
+	 * fixed_freq - Fix control channel in IBSS mode
+	 * 0 = don't fix control channel (default)
+	 * 1 = fix control channel; this prevents IBSS merging with another
+	 *	channel
+	int fixed_freq;
+	 * disable_ht - Disable HT (IEEE 802.11n) for this connection
+	int disable_ht;
+	 * htcaps - HT Capabilities over-rides
+	 * Only bits set in the mask will be used, and not all values are used
+	 * by the kernel anyway. Currently, MCS, MPDU and MSDU fields are used.
+	 * Pointer to struct ieee80211_ht_capabilities.
+	const u8 *htcaps;
+	 * htcaps_mask - HT Capabilities over-rides mask
+	const u8 *htcaps_mask;
+#ifdef CONFIG_VHT_OVERRIDES
+	 * disable_vht - Disable VHT for this connection
+	int disable_vht;
+	 * VHT capability overrides.
+	const struct ieee80211_vht_capabilities *vhtcaps;
+	const struct ieee80211_vht_capabilities *vhtcaps_mask;
+#endif /* CONFIG_VHT_OVERRIDES */
+	 * req_key_mgmt_offload - Request key management offload for connection
+	 * Request key management offload for this connection if the device
+	 * supports it.
+	int req_key_mgmt_offload;
+	 * Flag for indicating whether this association includes support for
+	 * RRM (Radio Resource Measurements)
+	int rrm_used;
+enum hide_ssid {
+	NO_SSID_HIDING,
+	HIDDEN_SSID_ZERO_LEN,
+	HIDDEN_SSID_ZERO_CONTENTS
+struct wowlan_triggers {
+	u8 any;
+	u8 disconnect;
+	u8 magic_pkt;
+	u8 gtk_rekey_failure;
+	u8 eap_identity_req;
+	u8 four_way_handshake;
+	u8 rfkill_release;
+struct wpa_driver_ap_params {
+	 * head - Beacon head from IEEE 802.11 header to IEs before TIM IE
+	u8 *head;
+	 * head_len - Length of the head buffer in octets
+	size_t head_len;
+	 * tail - Beacon tail following TIM IE
+	u8 *tail;
+	 * tail_len - Length of the tail buffer in octets
+	size_t tail_len;
+	 * dtim_period - DTIM period
+	int dtim_period;
+	int beacon_int;
+	 * basic_rates: -1 terminated array of basic rates in 100 kbps
+	 * This parameter can be used to set a specific basic rate set for the
+	 * BSS. If %NULL, default basic rate set is used.
+	int *basic_rates;
+	 * proberesp - Probe Response template
+	 * This is used by drivers that reply to Probe Requests internally in
+	 * AP mode and require the full Probe Response template.
+	u8 *proberesp;
+	 * proberesp_len - Length of the proberesp buffer in octets
+	size_t proberesp_len;
+	 * ssid - The SSID to use in Beacon/Probe Response frames
+	const u8 *ssid;
+	size_t ssid_len;
+	 * hide_ssid - Whether to hide the SSID
+	enum hide_ssid hide_ssid;
+	 * pairwise_ciphers - WPA_CIPHER_* bitfield
+	unsigned int pairwise_ciphers;
+	 * group_cipher - WPA_CIPHER_*
+	unsigned int group_cipher;
+	 * key_mgmt_suites - WPA_KEY_MGMT_* bitfield
+	unsigned int key_mgmt_suites;
+	 * auth_algs - WPA_AUTH_ALG_* bitfield
+	unsigned int auth_algs;
+	 * wpa_version - WPA_PROTO_* bitfield
+	unsigned int wpa_version;
+	 * privacy - Whether privacy is used in the BSS
+	int privacy;
+	 * beacon_ies - WPS/P2P IE(s) for Beacon frames
+	 * This is used to add IEs like WPS IE and P2P IE by drivers that do
+	 * not use the full Beacon template.
+	const struct wpabuf *beacon_ies;
+	 * proberesp_ies - P2P/WPS IE(s) for Probe Response frames
+	 * reply to Probe Request frames internally.
+	const struct wpabuf *proberesp_ies;
+	 * assocresp_ies - WPS IE(s) for (Re)Association Response frames
+	 * This is used to add IEs like WPS IE by drivers that reply to
+	 * (Re)Association Request frames internally.
+	const struct wpabuf *assocresp_ies;
+	 * isolate - Whether to isolate frames between associated stations
+	 * If this is non-zero, the AP is requested to disable forwarding of
+	 * frames between associated stations.
+	int isolate;
+	 * cts_protect - Whether CTS protection is enabled
+	int cts_protect;
+	 * preamble - Whether short preamble is enabled
+	int preamble;
+	 * short_slot_time - Whether short slot time is enabled
+	 * 0 = short slot time disable, 1 = short slot time enabled, -1 = do
+	 * not set (e.g., when 802.11g mode is not in use)
+	int short_slot_time;
+	 * ht_opmode - HT operation mode or -1 if HT not in use
+	int ht_opmode;
+	 * interworking - Whether Interworking is enabled
+	int interworking;
+	 * hessid - Homogeneous ESS identifier or %NULL if not set
+	const u8 *hessid;
+	 * access_network_type - Access Network Type (0..15)
+	 * This is used for filtering Probe Request frames when Interworking is
+	 * enabled.
+	u8 access_network_type;
+	 * ap_max_inactivity - Timeout in seconds to detect STA's inactivity
+	 * This is used by driver which advertises this capability.
+	int ap_max_inactivity;
+	 * ctwindow - Client Traffic Window (in TUs)
+	u8 p2p_go_ctwindow;
+	 * smps_mode - SMPS mode
+	 * SMPS mode to be used by the AP, specified as the relevant bits of
+	 * ht_capab (i.e. HT_CAP_INFO_SMPS_*).
+	unsigned int smps_mode;
+	 * disable_dgaf - Whether group-addressed frames are disabled
+	int disable_dgaf;
+	 * osen - Whether OSEN security is enabled
+	int osen;
+	 * freq - Channel parameters for dynamic bandwidth changes
+	struct hostapd_freq_params *freq;
+	 * reenable - Whether this is to re-enable beaconing
+	int reenable;
+struct wpa_driver_mesh_bss_params {
+#define WPA_DRIVER_MESH_CONF_FLAG_AUTO_PLINKS	0x00000001
+	 * TODO: Other mesh configuration parameters would go here.
+	 * See NL80211_MESHCONF_* for all the mesh config parameters.
+	int peer_link_timeout;
+struct wpa_driver_mesh_join_params {
+	const u8 *meshid;
+	int meshid_len;
+	const int *basic_rates;
+	const u8 *ies;
+	int ie_len;
+	int beacon_int;
+	int max_peer_links;
+	struct wpa_driver_mesh_bss_params conf;
+#define WPA_DRIVER_MESH_FLAG_USER_MPM	0x00000001
+#define WPA_DRIVER_MESH_FLAG_DRIVER_MPM	0x00000002
+#define WPA_DRIVER_MESH_FLAG_SAE_AUTH	0x00000004
+#define WPA_DRIVER_MESH_FLAG_AMPE	0x00000008
+ * struct wpa_driver_capa - Driver capability information
+struct wpa_driver_capa {
+#define WPA_DRIVER_CAPA_KEY_MGMT_WPA		0x00000001
+#define WPA_DRIVER_CAPA_KEY_MGMT_WPA2		0x00000002
+#define WPA_DRIVER_CAPA_KEY_MGMT_WPA_PSK	0x00000004
+#define WPA_DRIVER_CAPA_KEY_MGMT_WPA2_PSK	0x00000008
+#define WPA_DRIVER_CAPA_KEY_MGMT_WPA_NONE	0x00000010
+#define WPA_DRIVER_CAPA_KEY_MGMT_FT		0x00000020
+#define WPA_DRIVER_CAPA_KEY_MGMT_FT_PSK		0x00000040
+#define WPA_DRIVER_CAPA_KEY_MGMT_WAPI_PSK	0x00000080
+#define WPA_DRIVER_CAPA_KEY_MGMT_SUITE_B	0x00000100
+#define WPA_DRIVER_CAPA_KEY_MGMT_SUITE_B_192	0x00000200
+	/** Bitfield of supported key management suites */
+	unsigned int key_mgmt;
+#define WPA_DRIVER_CAPA_ENC_WEP40	0x00000001
+#define WPA_DRIVER_CAPA_ENC_WEP104	0x00000002
+#define WPA_DRIVER_CAPA_ENC_TKIP	0x00000004
+#define WPA_DRIVER_CAPA_ENC_CCMP	0x00000008
+#define WPA_DRIVER_CAPA_ENC_WEP128	0x00000010
+#define WPA_DRIVER_CAPA_ENC_GCMP	0x00000020
+#define WPA_DRIVER_CAPA_ENC_GCMP_256	0x00000040
+#define WPA_DRIVER_CAPA_ENC_CCMP_256	0x00000080
+#define WPA_DRIVER_CAPA_ENC_BIP		0x00000100
+#define WPA_DRIVER_CAPA_ENC_BIP_GMAC_128	0x00000200
+#define WPA_DRIVER_CAPA_ENC_BIP_GMAC_256	0x00000400
+#define WPA_DRIVER_CAPA_ENC_BIP_CMAC_256	0x00000800
+#define WPA_DRIVER_CAPA_ENC_GTK_NOT_USED	0x00001000
+	/** Bitfield of supported cipher suites */
+	unsigned int enc;
+#define WPA_DRIVER_AUTH_OPEN		0x00000001
+#define WPA_DRIVER_AUTH_SHARED		0x00000002
+#define WPA_DRIVER_AUTH_LEAP		0x00000004
+	/** Bitfield of supported IEEE 802.11 authentication algorithms */
+	unsigned int auth;
+/** Driver generated WPA/RSN IE */
+#define WPA_DRIVER_FLAGS_DRIVER_IE	0x00000001
+/** Driver needs static WEP key setup after association command */
+#define WPA_DRIVER_FLAGS_SET_KEYS_AFTER_ASSOC 0x00000002
+/** Driver takes care of all DFS operations */
+#define WPA_DRIVER_FLAGS_DFS_OFFLOAD			0x00000004
+/** Driver takes care of RSN 4-way handshake internally; PMK is configured with
+ * struct wpa_driver_ops::set_key using alg = WPA_ALG_PMK */
+#define WPA_DRIVER_FLAGS_4WAY_HANDSHAKE 0x00000008
+/** Driver is for a wired Ethernet interface */
+#define WPA_DRIVER_FLAGS_WIRED		0x00000010
+/** Driver provides separate commands for authentication and association (SME in
+ * wpa_supplicant). */
+#define WPA_DRIVER_FLAGS_SME		0x00000020
+/** Driver supports AP mode */
+#define WPA_DRIVER_FLAGS_AP		0x00000040
+/** Driver needs static WEP key setup after association has been completed */
+#define WPA_DRIVER_FLAGS_SET_KEYS_AFTER_ASSOC_DONE	0x00000080
+/** Driver supports dynamic HT 20/40 MHz channel changes during BSS lifetime */
+#define WPA_DRIVER_FLAGS_HT_2040_COEX			0x00000100
+/** Driver supports concurrent P2P operations */
+#define WPA_DRIVER_FLAGS_P2P_CONCURRENT	0x00000200
+ * Driver uses the initial interface as a dedicated management interface, i.e.,
+ * it cannot be used for P2P group operations or non-P2P purposes.
+#define WPA_DRIVER_FLAGS_P2P_DEDICATED_INTERFACE	0x00000400
+/** This interface is P2P capable (P2P GO or P2P Client) */
+#define WPA_DRIVER_FLAGS_P2P_CAPABLE	0x00000800
+/** Driver supports station and key removal when stopping an AP */
+#define WPA_DRIVER_FLAGS_AP_TEARDOWN_SUPPORT		0x00001000
+ * Driver uses the initial interface for P2P management interface and non-P2P
+ * purposes (e.g., connect to infra AP), but this interface cannot be used for
+ * P2P group operations.
+#define WPA_DRIVER_FLAGS_P2P_MGMT_AND_NON_P2P		0x00002000
+ * Driver is known to use sane error codes, i.e., when it indicates that
+ * something (e.g., association) fails, there was indeed a failure and the
+ * operation does not end up getting completed successfully later.
+#define WPA_DRIVER_FLAGS_SANE_ERROR_CODES		0x00004000
+/** Driver supports off-channel TX */
+#define WPA_DRIVER_FLAGS_OFFCHANNEL_TX			0x00008000
+/** Driver indicates TX status events for EAPOL Data frames */
+#define WPA_DRIVER_FLAGS_EAPOL_TX_STATUS		0x00010000
+/** Driver indicates TX status events for Deauth/Disassoc frames */
+#define WPA_DRIVER_FLAGS_DEAUTH_TX_STATUS		0x00020000
+/** Driver supports roaming (BSS selection) in firmware */
+#define WPA_DRIVER_FLAGS_BSS_SELECTION			0x00040000
+/** Driver supports operating as a TDLS peer */
+#define WPA_DRIVER_FLAGS_TDLS_SUPPORT			0x00080000
+/** Driver requires external TDLS setup/teardown/discovery */
+#define WPA_DRIVER_FLAGS_TDLS_EXTERNAL_SETUP		0x00100000
+/** Driver indicates support for Probe Response offloading in AP mode */
+#define WPA_DRIVER_FLAGS_PROBE_RESP_OFFLOAD		0x00200000
+/** Driver supports U-APSD in AP mode */
+#define WPA_DRIVER_FLAGS_AP_UAPSD			0x00400000
+/** Driver supports inactivity timer in AP mode */
+#define WPA_DRIVER_FLAGS_INACTIVITY_TIMER		0x00800000
+/** Driver expects user space implementation of MLME in AP mode */
+#define WPA_DRIVER_FLAGS_AP_MLME			0x01000000
+/** Driver supports SAE with user space SME */
+#define WPA_DRIVER_FLAGS_SAE				0x02000000
+/** Driver makes use of OBSS scan mechanism in wpa_supplicant */
+#define WPA_DRIVER_FLAGS_OBSS_SCAN			0x04000000
+/** Driver supports IBSS (Ad-hoc) mode */
+#define WPA_DRIVER_FLAGS_IBSS				0x08000000
+/** Driver supports radar detection */
+#define WPA_DRIVER_FLAGS_RADAR				0x10000000
+/** Driver supports a dedicated interface for P2P Device */
+#define WPA_DRIVER_FLAGS_DEDICATED_P2P_DEVICE		0x20000000
+/** Driver supports QoS Mapping */
+#define WPA_DRIVER_FLAGS_QOS_MAPPING			0x40000000
+/** Driver supports CSA in AP mode */
+#define WPA_DRIVER_FLAGS_AP_CSA				0x80000000
+/** Driver supports mesh */
+#define WPA_DRIVER_FLAGS_MESH			0x0000000100000000ULL
+/** Driver support ACS offload */
+#define WPA_DRIVER_FLAGS_ACS_OFFLOAD		0x0000000200000000ULL
+/** Driver supports key management offload */
+#define WPA_DRIVER_FLAGS_KEY_MGMT_OFFLOAD	0x0000000400000000ULL
+/** Driver supports TDLS channel switching */
+#define WPA_DRIVER_FLAGS_TDLS_CHANNEL_SWITCH	0x0000000800000000ULL
+/** Driver supports IBSS with HT datarates */
+#define WPA_DRIVER_FLAGS_HT_IBSS		0x0000001000000000ULL
+/** Driver supports IBSS with VHT datarates */
+#define WPA_DRIVER_FLAGS_VHT_IBSS		0x0000002000000000ULL
+/** Driver supports automatic band selection */
+#define WPA_DRIVER_FLAGS_SUPPORT_HW_MODE_ANY	0x0000004000000000ULL
+	u64 flags;
+#define WPA_DRIVER_SMPS_MODE_STATIC			0x00000001
+#define WPA_DRIVER_SMPS_MODE_DYNAMIC			0x00000002
+	unsigned int smps_modes;
+	unsigned int wmm_ac_supported:1;
+	unsigned int mac_addr_rand_scan_supported:1;
+	unsigned int mac_addr_rand_sched_scan_supported:1;
+	/** Maximum number of supported active probe SSIDs */
+	int max_scan_ssids;
+	/** Maximum number of supported active probe SSIDs for sched_scan */
+	int max_sched_scan_ssids;
+	/** Whether sched_scan (offloaded scanning) is supported */
+	int sched_scan_supported;
+	/** Maximum number of supported match sets for sched_scan */
+	int max_match_sets;
+	 * max_remain_on_chan - Maximum remain-on-channel duration in msec
+	unsigned int max_remain_on_chan;
+	 * max_stations - Maximum number of associated stations the driver
+	 * supports in AP mode
+	unsigned int max_stations;
+	 * probe_resp_offloads - Bitmap of supported protocols by the driver
+	 * for Probe Response offloading.
+/** Driver Probe Response offloading support for WPS ver. 1 */
+#define WPA_DRIVER_PROBE_RESP_OFFLOAD_WPS		0x00000001
+/** Driver Probe Response offloading support for WPS ver. 2 */
+#define WPA_DRIVER_PROBE_RESP_OFFLOAD_WPS2		0x00000002
+/** Driver Probe Response offloading support for P2P */
+#define WPA_DRIVER_PROBE_RESP_OFFLOAD_P2P		0x00000004
+/** Driver Probe Response offloading support for IEEE 802.11u (Interworking) */
+#define WPA_DRIVER_PROBE_RESP_OFFLOAD_INTERWORKING	0x00000008
+	unsigned int probe_resp_offloads;
+	unsigned int max_acl_mac_addrs;
+	 * Number of supported concurrent channels
+	unsigned int num_multichan_concurrent;
+	 * extended_capa - extended capabilities in driver/device
+	 * Must be allocated and freed by driver and the pointers must be
+	 * valid for the lifetime of the driver, i.e., freed in deinit()
+	const u8 *extended_capa, *extended_capa_mask;
+	unsigned int extended_capa_len;
+	struct wowlan_triggers wowlan_triggers;
+/** Driver adds the DS Params Set IE in Probe Request frames */
+#define WPA_DRIVER_FLAGS_DS_PARAM_SET_IE_IN_PROBES	0x00000001
+/** Driver adds the WFA TPC IE in Probe Request frames */
+#define WPA_DRIVER_FLAGS_WFA_TPC_IE_IN_PROBES		0x00000002
+/** Driver handles quiet period requests */
+#define WPA_DRIVER_FLAGS_QUIET				0x00000004
+ * Driver is capable of inserting the current TX power value into the body of
+ * transmitted frames.
+ * Background: Some Action frames include a TPC Report IE. This IE contains a
+ * TX power field, which has to be updated by lower layers. One such Action
+ * frame is Link Measurement Report (part of RRM). Another is TPC Report (part
+ * of spectrum management). Note that this insertion takes place at a fixed
+ * offset, namely the 6th byte in the Action frame body.
+#define WPA_DRIVER_FLAGS_TX_POWER_INSERTION		0x00000008
+	u32 rrm_flags;
+	/* Driver concurrency capabilities */
+	unsigned int conc_capab;
+	/* Maximum number of concurrent channels on 2.4 GHz */
+	unsigned int max_conc_chan_2_4;
+	/* Maximum number of concurrent channels on 5 GHz */
+	unsigned int max_conc_chan_5_0;
+struct hostapd_data;
+struct hostap_sta_driver_data {
+	unsigned long rx_packets, tx_packets, rx_bytes, tx_bytes;
+	unsigned long current_tx_rate;
+	unsigned long inactive_msec;
+	unsigned long flags;
+	unsigned long num_ps_buf_frames;
+	unsigned long tx_retry_failed;
+	unsigned long tx_retry_count;
+	int last_rssi;
+	int last_ack_rssi;
+struct hostapd_sta_add_params {
+	const u8 *addr;
+	u16 aid;
+	u16 capability;
+	const u8 *supp_rates;
+	size_t supp_rates_len;
+	u16 listen_interval;
+	const struct ieee80211_ht_capabilities *ht_capabilities;
+	const struct ieee80211_vht_capabilities *vht_capabilities;
+	int vht_opmode_enabled;
+	u8 vht_opmode;
+	u32 flags; /* bitmask of WPA_STA_* flags */
+	u32 flags_mask; /* unset bits in flags */
+#ifdef CONFIG_MESH
+	enum mesh_plink_state plink_state;
+#endif /* CONFIG_MESH */
+	int set; /* Set STA parameters instead of add */
+	u8 qosinfo;
+	const u8 *ext_capab;
+	size_t ext_capab_len;
+	const u8 *supp_channels;
+	size_t supp_channels_len;
+	const u8 *supp_oper_classes;
+	size_t supp_oper_classes_len;
+struct mac_address {
+	u8 addr[ETH_ALEN];
+struct hostapd_acl_params {
+	u8 acl_policy;
+	unsigned int num_mac_acl;
+	struct mac_address mac_acl[0];
+enum wpa_driver_if_type {
+	 * WPA_IF_STATION - Station mode interface
+	WPA_IF_STATION,
+	 * WPA_IF_AP_VLAN - AP mode VLAN interface
+	 * This interface shares its address and Beacon frame with the main
+	 * BSS.
+	WPA_IF_AP_VLAN,
+	 * WPA_IF_AP_BSS - AP mode BSS interface
+	 * This interface has its own address and Beacon frame.
+	WPA_IF_AP_BSS,
+	 * WPA_IF_P2P_GO - P2P Group Owner
+	WPA_IF_P2P_GO,
+	 * WPA_IF_P2P_CLIENT - P2P Client
+	WPA_IF_P2P_CLIENT,
+	 * WPA_IF_P2P_GROUP - P2P Group interface (will become either
+	 * WPA_IF_P2P_GO or WPA_IF_P2P_CLIENT, but the role is not yet known)
+	WPA_IF_P2P_GROUP,
+	 * WPA_IF_P2P_DEVICE - P2P Device interface is used to indentify the
+	 * abstracted P2P Device function in the driver
+	WPA_IF_P2P_DEVICE,
+	 * WPA_IF_MESH - Mesh interface
+	WPA_IF_MESH,
+	 * WPA_IF_TDLS - TDLS offchannel interface (used for pref freq only)
+	WPA_IF_TDLS,
+	 * WPA_IF_IBSS - IBSS interface (used for pref freq only)
+	WPA_IF_IBSS,
+struct wpa_init_params {
+	void *global_priv;
+	const u8 *bssid;
+	const char *ifname;
+	const char *driver_params;
+	int use_pae_group_addr;
+	char **bridge;
+	size_t num_bridge;
+	u8 *own_addr; /* buffer for writing own MAC address */
+struct wpa_bss_params {
+	/** Interface name (for multi-SSID/VLAN support) */
+	/** Whether IEEE 802.1X or WPA/WPA2 is enabled */
+	int enabled;
+	int wpa;
+	int ieee802_1x;
+	int wpa_group;
+	int wpa_pairwise;
+	int wpa_key_mgmt;
+	int rsn_preauth;
+	enum mfp_options ieee80211w;
+#define WPA_STA_AUTHORIZED BIT(0)
+#define WPA_STA_WMM BIT(1)
+#define WPA_STA_SHORT_PREAMBLE BIT(2)
+#define WPA_STA_MFP BIT(3)
+#define WPA_STA_TDLS_PEER BIT(4)
+#define WPA_STA_AUTHENTICATED BIT(5)
+enum tdls_oper {
+	TDLS_DISCOVERY_REQ,
+	TDLS_SETUP,
+	TDLS_TEARDOWN,
+	TDLS_ENABLE_LINK,
+	TDLS_DISABLE_LINK,
+	TDLS_ENABLE,
+	TDLS_DISABLE
+enum wnm_oper {
+	WNM_SLEEP_ENTER_CONFIRM,
+	WNM_SLEEP_ENTER_FAIL,
+	WNM_SLEEP_EXIT_CONFIRM,
+	WNM_SLEEP_EXIT_FAIL,
+	WNM_SLEEP_TFS_REQ_IE_ADD,   /* STA requests driver to add TFS req IE */
+	WNM_SLEEP_TFS_REQ_IE_NONE,  /* STA requests empty TFS req IE */
+	WNM_SLEEP_TFS_REQ_IE_SET,   /* AP requests driver to set TFS req IE for
+				     * a STA */
+	WNM_SLEEP_TFS_RESP_IE_ADD,  /* AP requests driver to add TFS resp IE
+				     * for a STA */
+	WNM_SLEEP_TFS_RESP_IE_NONE, /* AP requests empty TFS resp IE */
+	WNM_SLEEP_TFS_RESP_IE_SET,  /* AP requests driver to set TFS resp IE
+				     * for a STA */
+	WNM_SLEEP_TFS_IE_DEL        /* AP delete the TFS IE */
+/* enum chan_width - Channel width definitions */
+enum chan_width {
+	CHAN_WIDTH_20_NOHT,
+	CHAN_WIDTH_20,
+	CHAN_WIDTH_40,
+	CHAN_WIDTH_80,
+	CHAN_WIDTH_80P80,
+	CHAN_WIDTH_160,
+	CHAN_WIDTH_UNKNOWN
+ * struct wpa_signal_info - Information about channel signal quality
+struct wpa_signal_info {
+	u32 frequency;
+	int above_threshold;
+	int current_signal;
+	int avg_signal;
+	int avg_beacon_signal;
+	int current_noise;
+	int current_txrate;
+	enum chan_width chanwidth;
+	int center_frq1;
+	int center_frq2;
+ * struct beacon_data - Beacon data
+ * @head: Head portion of Beacon frame (before TIM IE)
+ * @tail: Tail portion of Beacon frame (after TIM IE)
+ * @beacon_ies: Extra information element(s) to add into Beacon frames or %NULL
+ * @proberesp_ies: Extra information element(s) to add into Probe Response
+ *	frames or %NULL
+ * @assocresp_ies: Extra information element(s) to add into (Re)Association
+ *	Response frames or %NULL
+ * @probe_resp: Probe Response frame template
+ * @head_len: Length of @head
+ * @tail_len: Length of @tail
+ * @beacon_ies_len: Length of beacon_ies in octets
+ * @proberesp_ies_len: Length of proberesp_ies in octets
+ * @probe_resp_len: Length of probe response template (@probe_resp)
+struct beacon_data {
+	u8 *head, *tail;
+	u8 *beacon_ies;
+	u8 *proberesp_ies;
+	u8 *assocresp_ies;
+	u8 *probe_resp;
+	size_t head_len, tail_len;
+	size_t beacon_ies_len;
+	size_t proberesp_ies_len;
+	size_t assocresp_ies_len;
+	size_t probe_resp_len;
+ * struct csa_settings - Settings for channel switch command
+ * @cs_count: Count in Beacon frames (TBTT) to perform the switch
+ * @block_tx: 1 - block transmission for CSA period
+ * @freq_params: Next channel frequency parameter
+ * @beacon_csa: Beacon/probe resp/asooc resp info for CSA period
+ * @beacon_after: Next beacon/probe resp/asooc resp info
+ * @counter_offset_beacon: Offset to the count field in beacon's tail
+ * @counter_offset_presp: Offset to the count field in probe resp.
+struct csa_settings {
+	u8 cs_count;
+	u8 block_tx;
+	struct hostapd_freq_params freq_params;
+	struct beacon_data beacon_csa;
+	struct beacon_data beacon_after;
+	u16 counter_offset_beacon;
+	u16 counter_offset_presp;
+/* TDLS peer capabilities for send_tdls_mgmt() */
+enum tdls_peer_capability {
+	TDLS_PEER_HT = BIT(0),
+	TDLS_PEER_VHT = BIT(1),
+	TDLS_PEER_WMM = BIT(2),
+/* valid info in the wmm_params struct */
+enum wmm_params_valid_info {
+	WMM_PARAMS_UAPSD_QUEUES_INFO = BIT(0),
+ * struct wmm_params - WMM parameterss configured for this association
+ * @info_bitmap: Bitmap of valid wmm_params info; indicates what fields
+ *	of the struct contain valid information.
+ * @uapsd_queues: Bitmap of ACs configured for uapsd (valid only if
+ *	%WMM_PARAMS_UAPSD_QUEUES_INFO is set)
+struct wmm_params {
+	u8 info_bitmap;
+	u8 uapsd_queues;
+#ifdef CONFIG_MACSEC
+struct macsec_init_params {
+	Boolean always_include_sci;
+	Boolean use_es;
+	Boolean use_scb;
+#endif /* CONFIG_MACSEC */
+enum drv_br_port_attr {
+	DRV_BR_PORT_ATTR_PROXYARP,
+	DRV_BR_PORT_ATTR_HAIRPIN_MODE,
+enum drv_br_net_param {
+	DRV_BR_NET_PARAM_GARP_ACCEPT,
+	DRV_BR_MULTICAST_SNOOPING,
+struct drv_acs_params {
+	/* Selected mode (HOSTAPD_MODE_*) */
+	enum hostapd_hw_mode hw_mode;
+	/* Indicates whether HT is enabled */
+	int ht_enabled;
+	/* Indicates whether HT40 is enabled */
+	int ht40_enabled;
+	/* Indicates whether VHT is enabled */
+	int vht_enabled;
+	/* Configured ACS channel width */
+	u16 ch_width;
+	/* ACS channel list info */
+	unsigned int ch_list_len;
+	const u8 *ch_list;
+	const int *freq_list;
+ * struct wpa_driver_ops - Driver interface API definition
+ * This structure defines the API that each driver interface needs to implement
+ * for core wpa_supplicant code. All driver specific functionality is captured
+ * in this wrapper.
+struct wpa_driver_ops {
+	/** Name of the driver interface */
+	const char *name;
+	/** One line description of the driver interface */
+	const char *desc;
+	 * get_bssid - Get the current BSSID
+	 * @priv: private driver interface data
+	 * @bssid: buffer for BSSID (ETH_ALEN = 6 bytes)
+	 * Returns: 0 on success, -1 on failure
+	 * Query kernel driver for the current BSSID and copy it to bssid.
+	 * Setting bssid to 00:00:00:00:00:00 is recommended if the STA is not
+	 * associated.
+	int (*get_bssid)(void *priv, u8 *bssid);
+	 * get_ssid - Get the current SSID
+	 * @ssid: buffer for SSID (at least 32 bytes)
+	 * Returns: Length of the SSID on success, -1 on failure
+	 * Query kernel driver for the current SSID and copy it to ssid.
+	 * Returning zero is recommended if the STA is not associated.
+	 * Note: SSID is an array of octets, i.e., it is not nul terminated and
+	 * can, at least in theory, contain control characters (including nul)
+	 * and as such, should be processed as binary data, not a printable
+	 * string.
+	int (*get_ssid)(void *priv, u8 *ssid);
+	 * set_key - Configure encryption key
+	 * @ifname: Interface name (for multi-SSID/VLAN support)
+	 * @alg: encryption algorithm (%WPA_ALG_NONE, %WPA_ALG_WEP,
+	 *	%WPA_ALG_TKIP, %WPA_ALG_CCMP, %WPA_ALG_IGTK, %WPA_ALG_PMK,
+	 *	%WPA_ALG_GCMP, %WPA_ALG_GCMP_256, %WPA_ALG_CCMP_256,
+	 *	%WPA_ALG_BIP_GMAC_128, %WPA_ALG_BIP_GMAC_256,
+	 *	%WPA_ALG_BIP_CMAC_256);
+	 *	%WPA_ALG_NONE clears the key.
+	 * @addr: Address of the peer STA (BSSID of the current AP when setting
+	 *	pairwise key in station mode), ff:ff:ff:ff:ff:ff for
+	 *	broadcast keys, %NULL for default keys that are used both for
+	 *	broadcast and unicast; when clearing keys, %NULL is used to
+	 *	indicate that both the broadcast-only and default key of the
+	 *	specified key index is to be cleared
+	 * @key_idx: key index (0..3), usually 0 for unicast keys; 0..4095 for
+	 *	IGTK
+	 * @set_tx: configure this key as the default Tx key (only used when
+	 *	driver does not support separate unicast/individual key
+	 * @seq: sequence number/packet number, seq_len octets, the next
+	 *	packet number to be used for in replay protection; configured
+	 *	for Rx keys (in most cases, this is only used with broadcast
+	 *	keys and set to zero for unicast keys); %NULL if not set
+	 * @seq_len: length of the seq, depends on the algorithm:
+	 *	TKIP: 6 octets, CCMP/GCMP: 6 octets, IGTK: 6 octets
+	 * @key: key buffer; TKIP: 16-byte temporal key, 8-byte Tx Mic key,
+	 *	8-byte Rx Mic Key
+	 * @key_len: length of the key buffer in octets (WEP: 5 or 13,
+	 *	TKIP: 32, CCMP/GCMP: 16, IGTK: 16)
+	 * Configure the given key for the kernel driver. If the driver
+	 * supports separate individual keys (4 default keys + 1 individual),
+	 * addr can be used to determine whether the key is default or
+	 * individual. If only 4 keys are supported, the default key with key
+	 * index 0 is used as the individual key. STA must be configured to use
+	 * it as the default Tx key (set_tx is set) and accept Rx for all the
+	 * key indexes. In most cases, WPA uses only key indexes 1 and 2 for
+	 * broadcast keys, so key index 0 is available for this kind of
+	 * configuration.
+	 * Please note that TKIP keys include separate TX and RX MIC keys and
+	 * some drivers may expect them in different order than wpa_supplicant
+	 * is using. If the TX/RX keys are swapped, all TKIP encrypted packets
+	 * will trigger Michael MIC errors. This can be fixed by changing the
+	 * order of MIC keys by swapping te bytes 16..23 and 24..31 of the key
+	 * in driver_*.c set_key() implementation, see driver_ndis.c for an
+	 * example on how this can be done.
+	int (*set_key)(const char *ifname, void *priv, enum wpa_alg alg,
+		       const u8 *addr, int key_idx, int set_tx,
+		       const u8 *seq, size_t seq_len,
+		       const u8 *key, size_t key_len);
+	 * init - Initialize driver interface
+	 * @ctx: context to be used when calling wpa_supplicant functions,
+	 * e.g., wpa_supplicant_event()
+	 * @ifname: interface name, e.g., wlan0
+	 * Returns: Pointer to private data, %NULL on failure
+	 * Initialize driver interface, including event processing for kernel
+	 * driver events (e.g., associated, scan results, Michael MIC failure).
+	 * This function can allocate a private configuration data area for
+	 * @ctx, file descriptor, interface name, etc. information that may be
+	 * needed in future driver operations. If this is not used, non-NULL
+	 * value will need to be returned because %NULL is used to indicate
+	 * failure. The returned value will be used as 'void *priv' data for
+	 * all other driver_ops functions.
+	 * The main event loop (eloop.c) of wpa_supplicant can be used to
+	 * register callback for read sockets (eloop_register_read_sock()).
+	 * See below for more information about events and
+	 * wpa_supplicant_event() function.
+	void * (*init)(void *ctx, const char *ifname);
+	 * deinit - Deinitialize driver interface
+	 * @priv: private driver interface data from init()
+	 * Shut down driver interface and processing of driver events. Free
+	 * private data buffer if one was allocated in init() handler.
+	void (*deinit)(void *priv);
+	 * set_param - Set driver configuration parameters
+	 * @param: driver specific configuration parameters
+	 * Optional handler for notifying driver interface about configuration
+	 * parameters (driver_param).
+	int (*set_param)(void *priv, const char *param);
+	 * set_countermeasures - Enable/disable TKIP countermeasures
+	 * @enabled: 1 = countermeasures enabled, 0 = disabled
+	 * Configure TKIP countermeasures. When these are enabled, the driver
+	 * should drop all received and queued frames that are using TKIP.
+	int (*set_countermeasures)(void *priv, int enabled);
+	 * deauthenticate - Request driver to deauthenticate
+	 * @addr: peer address (BSSID of the AP)
+	 * @reason_code: 16-bit reason code to be sent in the deauthentication
+	 *	frame
+	int (*deauthenticate)(void *priv, const u8 *addr, int reason_code);
+	 * associate - Request driver to associate
+	 * @params: association parameters
+	int (*associate)(void *priv,
+			 struct wpa_driver_associate_params *params);
+	 * add_pmkid - Add PMKSA cache entry to the driver
+	 * @bssid: BSSID for the PMKSA cache entry
+	 * @pmkid: PMKID for the PMKSA cache entry
+	 * This function is called when a new PMK is received, as a result of
+	 * either normal authentication or RSN pre-authentication.
+	 * If the driver generates RSN IE, i.e., it does not use wpa_ie in
+	 * associate(), add_pmkid() can be used to add new PMKSA cache entries
+	 * in the driver. If the driver uses wpa_ie from wpa_supplicant, this
+	 * driver_ops function does not need to be implemented. Likewise, if
+	 * the driver does not support WPA, this function is not needed.
+	int (*add_pmkid)(void *priv, const u8 *bssid, const u8 *pmkid);
+	 * remove_pmkid - Remove PMKSA cache entry to the driver
+	 * This function is called when the supplicant drops a PMKSA cache
+	 * entry for any reason.
+	 * associate(), remove_pmkid() can be used to synchronize PMKSA caches
+	 * between the driver and wpa_supplicant. If the driver uses wpa_ie
+	 * from wpa_supplicant, this driver_ops function does not need to be
+	 * implemented. Likewise, if the driver does not support WPA, this
+	 * function is not needed.
+	int (*remove_pmkid)(void *priv, const u8 *bssid, const u8 *pmkid);
+	 * flush_pmkid - Flush PMKSA cache
+	 * This function is called when the supplicant drops all PMKSA cache
+	 * entries for any reason.
+	int (*flush_pmkid)(void *priv);
+	 * get_capa - Get driver capabilities
+	 * Get driver/firmware/hardware capabilities.
+	int (*get_capa)(void *priv, struct wpa_driver_capa *capa);
+	 * poll - Poll driver for association information
+	 * This is an option callback that can be used when the driver does not
+	 * provide event mechanism for association events. This is called when
+	 * receiving WPA EAPOL-Key messages that require association
+	 * information. The driver interface is supposed to generate associnfo
+	 * event before returning from this callback function. In addition, the
+	 * driver interface should generate an association event after having
+	 * sent out associnfo.
+	void (*poll)(void *priv);
+	 * get_ifname - Get interface name
+	 * Returns: Pointer to the interface name. This can differ from the
+	 * interface name used in init() call. Init() is called first.
+	 * This optional function can be used to allow the driver interface to
+	 * replace the interface name with something else, e.g., based on an
+	 * interface mapping from a more descriptive name.
+	const char * (*get_ifname)(void *priv);
+	 * get_mac_addr - Get own MAC address
+	 * Returns: Pointer to own MAC address or %NULL on failure
+	 * This optional function can be used to get the own MAC address of the
+	 * device from the driver interface code. This is only needed if the
+	 * l2_packet implementation for the OS does not provide easy access to
+	 * a MAC address. */
+	const u8 * (*get_mac_addr)(void *priv);
+	 * set_operstate - Sets device operating state to DORMANT or UP
+	 * @state: 0 = dormant, 1 = up
+	 * This is an optional function that can be used on operating systems
+	 * that support a concept of controlling network device state from user
+	 * space applications. This function, if set, gets called with
+	 * state = 1 when authentication has been completed and with state = 0
+	 * when connection is lost.
+	int (*set_operstate)(void *priv, int state);
+	 * mlme_setprotection - MLME-SETPROTECTION.request primitive
+	 * @priv: Private driver interface data
+	 * @addr: Address of the station for which to set protection (may be
+	 * %NULL for group keys)
+	 * @protect_type: MLME_SETPROTECTION_PROTECT_TYPE_*
+	 * @key_type: MLME_SETPROTECTION_KEY_TYPE_*
+	 * This is an optional function that can be used to set the driver to
+	 * require protection for Tx and/or Rx frames. This uses the layer
+	 * interface defined in IEEE 802.11i-2004 clause 10.3.22.1
+	 * (MLME-SETPROTECTION.request). Many drivers do not use explicit
+	 * set protection operation; instead, they set protection implicitly
+	 * based on configured keys.
+	int (*mlme_setprotection)(void *priv, const u8 *addr, int protect_type,
+				  int key_type);
+	 * get_hw_feature_data - Get hardware support data (channels and rates)
+	 * @num_modes: Variable for returning the number of returned modes
+	 * flags: Variable for returning hardware feature flags
+	 * Returns: Pointer to allocated hardware data on success or %NULL on
+	 * failure. Caller is responsible for freeing this.
+	struct hostapd_hw_modes * (*get_hw_feature_data)(void *priv,
+							 u16 *num_modes,
+							 u16 *flags);
+	 * send_mlme - Send management frame from MLME
+	 * @data: IEEE 802.11 management frame with IEEE 802.11 header
+	 * @data_len: Size of the management frame
+	 * @noack: Do not wait for this frame to be acked (disable retries)
+	 * @freq: Frequency (in MHz) to send the frame on, or 0 to let the
+	 * driver decide
+	int (*send_mlme)(void *priv, const u8 *data, size_t data_len,
+			 int noack, unsigned int freq);
+	 * update_ft_ies - Update FT (IEEE 802.11r) IEs
+	 * @md: Mobility domain (2 octets) (also included inside ies)
+	 * @ies: FT IEs (MDIE, FTIE, ...) or %NULL to remove IEs
+	 * @ies_len: Length of FT IEs in bytes
+	 * The supplicant uses this callback to let the driver know that keying
+	 * material for FT is available and that the driver can use the
+	 * provided IEs in the next message in FT authentication sequence.
+	 * This function is only needed for driver that support IEEE 802.11r
+	 * (Fast BSS Transition).
+	int (*update_ft_ies)(void *priv, const u8 *md, const u8 *ies,
+			     size_t ies_len);
+	 * get_scan_results2 - Fetch the latest scan results
+	 * Returns: Allocated buffer of scan results (caller is responsible for
+	 * freeing the data structure) on success, NULL on failure
+	 struct wpa_scan_results * (*get_scan_results2)(void *priv);
+	 * set_country - Set country
+	 * @alpha2: country to which to switch to
+	 * This function is for drivers which support some form
+	 * of setting a regulatory domain.
+	int (*set_country)(void *priv, const char *alpha2);
+	 * get_country - Get country
+	 * @alpha2: Buffer for returning country code (at least 3 octets)
+	int (*get_country)(void *priv, char *alpha2);
+	 * global_init - Global driver initialization
+	 * Returns: Pointer to private data (global), %NULL on failure
+	 * This optional function is called to initialize the driver wrapper
+	 * for global data, i.e., data that applies to all interfaces. If this
+	 * function is implemented, global_deinit() will also need to be
+	 * implemented to free the private data. The driver will also likely
+	 * use init2() function instead of init() to get the pointer to global
+	 * data available to per-interface initializer.
+	void * (*global_init)(void);
+	 * global_deinit - Global driver deinitialization
+	 * @priv: private driver global data from global_init()
+	 * Terminate any global driver related functionality and free the
+	 * global data structure.
+	void (*global_deinit)(void *priv);
+	 * init2 - Initialize driver interface (with global data)
+	 * @global_priv: private driver global data from global_init()
+	 * This function can be used instead of init() if the driver wrapper
+	 * uses global data.
+	void * (*init2)(void *ctx, const char *ifname, void *global_priv);
+	 * get_interfaces - Get information about available interfaces
+	 * Returns: Allocated buffer of interface information (caller is
+	 * responsible for freeing the data structure) on success, NULL on
+	 * failure
+	struct wpa_interface_info * (*get_interfaces)(void *global_priv);
+	 * scan2 - Request the driver to initiate scan
+	 * @params: Scan parameters
+	 * Once the scan results are ready, the driver should report scan
+	 * results event for wpa_supplicant which will eventually request the
+	 * results with wpa_driver_get_scan_results2().
+	int (*scan2)(void *priv, struct wpa_driver_scan_params *params);
+	 * authenticate - Request driver to authenticate
+	 * @params: authentication parameters
+	 * This is an optional function that can be used with drivers that
+	 * support separate authentication and association steps, i.e., when
+	 * wpa_supplicant can act as the SME. If not implemented, associate()
+	 * function is expected to take care of IEEE 802.11 authentication,
+	 * too.
+	int (*authenticate)(void *priv,
+			    struct wpa_driver_auth_params *params);
+	 * set_ap - Set Beacon and Probe Response information for AP mode
+	 * @params: Parameters to use in AP mode
+	 * This function is used to configure Beacon template and/or extra IEs
+	 * to add for Beacon and Probe Response frames for the driver in
+	 * AP mode. The driver is responsible for building the full Beacon
+	 * frame by concatenating the head part with TIM IE generated by the
+	 * driver/firmware and finishing with the tail part. Depending on the
+	 * driver architectue, this can be done either by using the full
+	 * template or the set of additional IEs (e.g., WPS and P2P IE).
+	 * Similarly, Probe Response processing depends on the driver design.
+	 * If the driver (or firmware) takes care of replying to Probe Request
+	 * frames, the extra IEs provided here needs to be added to the Probe
+	 * Response frames.
+	int (*set_ap)(void *priv, struct wpa_driver_ap_params *params);
+	 * set_acl - Set ACL in AP mode
+	 * @params: Parameters to configure ACL
+	 * This is used only for the drivers which support MAC address ACL.
+	int (*set_acl)(void *priv, struct hostapd_acl_params *params);
+	 * hapd_init - Initialize driver interface (hostapd only)
+	 * @hapd: Pointer to hostapd context
+	 * @params: Configuration for the driver wrapper
+	 * This function is used instead of init() or init2() when the driver
+	 * wrapper is used with hostapd.
+	void * (*hapd_init)(struct hostapd_data *hapd,
+			    struct wpa_init_params *params);
+	 * hapd_deinit - Deinitialize driver interface (hostapd only)
+	 * @priv: Private driver interface data from hapd_init()
+	void (*hapd_deinit)(void *priv);
+	 * set_ieee8021x - Enable/disable IEEE 802.1X support (AP only)
+	 * @params: BSS parameters
+	 * This is an optional function to configure the kernel driver to
+	 * enable/disable IEEE 802.1X support and set WPA/WPA2 parameters. This
+	 * can be left undefined (set to %NULL) if IEEE 802.1X support is
+	 * always enabled and the driver uses set_ap() to set WPA/RSN IE
+	 * for Beacon frames.
+	 * DEPRECATED - use set_ap() instead
+	int (*set_ieee8021x)(void *priv, struct wpa_bss_params *params);
+	 * set_privacy - Enable/disable privacy (AP only)
+	 * @enabled: 1 = privacy enabled, 0 = disabled
+	 * This is an optional function to configure privacy field in the
+	 * kernel driver for Beacon frames. This can be left undefined (set to
+	 * %NULL) if the driver uses the Beacon template from set_ap().
+	int (*set_privacy)(void *priv, int enabled);
+	 * get_seqnum - Fetch the current TSC/packet number (AP only)
+	 * @ifname: The interface name (main or virtual)
+	 * @addr: MAC address of the station or %NULL for group keys
+	 * @idx: Key index
+	 * @seq: Buffer for returning the latest used TSC/packet number
+	 * This function is used to fetch the last used TSC/packet number for
+	 * a TKIP, CCMP, GCMP, or BIP/IGTK key. It is mainly used with group
+	 * keys, so there is no strict requirement on implementing support for
+	 * unicast keys (i.e., addr != %NULL).
+	int (*get_seqnum)(const char *ifname, void *priv, const u8 *addr,
+			  int idx, u8 *seq);
+	 * flush - Flush all association stations (AP only)
+	 * This function requests the driver to disassociate all associated
+	 * stations. This function does not need to be implemented if the
+	 * driver does not process association frames internally.
+	int (*flush)(void *priv);
+	 * set_generic_elem - Add IEs into Beacon/Probe Response frames (AP)
+	 * @elem: Information elements
+	 * @elem_len: Length of the elem buffer in octets
+	 * This is an optional function to add information elements in the
+	 * kernel driver for Beacon and Probe Response frames. This can be left
+	 * undefined (set to %NULL) if the driver uses the Beacon template from
+	 * set_ap().
+	int (*set_generic_elem)(void *priv, const u8 *elem, size_t elem_len);
+	 * read_sta_data - Fetch station data
+	 * @data: Buffer for returning station information
+	int (*read_sta_data)(void *priv, struct hostap_sta_driver_data *data,
+			     const u8 *addr);
+	 * hapd_send_eapol - Send an EAPOL packet (AP only)
+	 * @addr: Destination MAC address
+	 * @data: EAPOL packet starting with IEEE 802.1X header
+	 * @data_len: Length of the EAPOL packet in octets
+	 * @encrypt: Whether the frame should be encrypted
+	 * @own_addr: Source MAC address
+	 * @flags: WPA_STA_* flags for the destination station
+	int (*hapd_send_eapol)(void *priv, const u8 *addr, const u8 *data,
+			       size_t data_len, int encrypt,
+			       const u8 *own_addr, u32 flags);
+	 * sta_deauth - Deauthenticate a station (AP only)
+	 * @own_addr: Source address and BSSID for the Deauthentication frame
+	 * @addr: MAC address of the station to deauthenticate
+	 * @reason: Reason code for the Deauthentiation frame
+	 * This function requests a specific station to be deauthenticated and
+	 * a Deauthentication frame to be sent to it.
+	int (*sta_deauth)(void *priv, const u8 *own_addr, const u8 *addr,
+			  int reason);
+	 * sta_disassoc - Disassociate a station (AP only)
+	 * @own_addr: Source address and BSSID for the Disassociation frame
+	 * @addr: MAC address of the station to disassociate
+	 * @reason: Reason code for the Disassociation frame
+	 * This function requests a specific station to be disassociated and
+	 * a Disassociation frame to be sent to it.
+	int (*sta_disassoc)(void *priv, const u8 *own_addr, const u8 *addr,
+			    int reason);
+	 * sta_remove - Remove a station entry (AP only)
+	 * @addr: MAC address of the station to be removed
+	int (*sta_remove)(void *priv, const u8 *addr);
+	 * hapd_get_ssid - Get the current SSID (AP only)
+	 * @buf: Buffer for returning the SSID
+	 * @len: Maximum length of the buffer
+	 * This function need not be implemented if the driver uses Beacon
+	 * template from set_ap() and does not reply to Probe Request frames.
+	int (*hapd_get_ssid)(void *priv, u8 *buf, int len);
+	 * hapd_set_ssid - Set SSID (AP only)
+	 * @buf: SSID
+	 * @len: Length of the SSID in octets
+	int (*hapd_set_ssid)(void *priv, const u8 *buf, int len);
+	 * hapd_set_countermeasures - Enable/disable TKIP countermeasures (AP)
+	 * This need not be implemented if the driver does not take care of
+	 * association processing.
+	int (*hapd_set_countermeasures)(void *priv, int enabled);
+	 * sta_add - Add a station entry
+	 * @params: Station parameters
+	 * This function is used to add a station entry to the driver once the
+	 * station has completed association. This is only used if the driver
+	 * does not take care of association processing.
+	 * With TDLS, this function is also used to add or set (params->set 1)
+	 * TDLS peer entries.
+	int (*sta_add)(void *priv, struct hostapd_sta_add_params *params);
+	 * get_inact_sec - Get station inactivity duration (AP only)
+	 * @addr: Station address
+	 * Returns: Number of seconds station has been inactive, -1 on failure
+	int (*get_inact_sec)(void *priv, const u8 *addr);
+	 * sta_clear_stats - Clear station statistics (AP only)
+	int (*sta_clear_stats)(void *priv, const u8 *addr);
+	 * set_freq - Set channel/frequency (AP only)
+	 * @freq: Channel parameters
+	int (*set_freq)(void *priv, struct hostapd_freq_params *freq);
+	 * set_rts - Set RTS threshold
+	 * @rts: RTS threshold in octets
+	int (*set_rts)(void *priv, int rts);
+	 * set_frag - Set fragmentation threshold
+	 * @frag: Fragmentation threshold in octets
+	int (*set_frag)(void *priv, int frag);
+	 * sta_set_flags - Set station flags (AP only)
+	 * @total_flags: Bitmap of all WPA_STA_* flags currently set
+	 * @flags_or: Bitmap of WPA_STA_* flags to add
+	 * @flags_and: Bitmap of WPA_STA_* flags to us as a mask
+	int (*sta_set_flags)(void *priv, const u8 *addr,
+			     unsigned int total_flags, unsigned int flags_or,
+			     unsigned int flags_and);
+	 * set_tx_queue_params - Set TX queue parameters
+	 * @queue: Queue number (0 = VO, 1 = VI, 2 = BE, 3 = BK)
+	 * @aifs: AIFS
+	 * @cw_min: cwMin
+	 * @cw_max: cwMax
+	 * @burst_time: Maximum length for bursting in 0.1 msec units
+	int (*set_tx_queue_params)(void *priv, int queue, int aifs, int cw_min,
+				   int cw_max, int burst_time);
+	 * if_add - Add a virtual interface
+	 * @type: Interface type
+	 * @ifname: Interface name for the new virtual interface
+	 * @addr: Local address to use for the interface or %NULL to use the
+	 *	parent interface address
+	 * @bss_ctx: BSS context for %WPA_IF_AP_BSS interfaces
+	 * @drv_priv: Pointer for overwriting the driver context or %NULL if
+	 *	not allowed (applies only to %WPA_IF_AP_BSS type)
+	 * @force_ifname: Buffer for returning an interface name that the
+	 *	driver ended up using if it differs from the requested ifname
+	 * @if_addr: Buffer for returning the allocated interface address
+	 *	(this may differ from the requested addr if the driver cannot
+	 *	change interface address)
+	 * @bridge: Bridge interface to use or %NULL if no bridge configured
+	 * @use_existing: Whether to allow existing interface to be used
+	int (*if_add)(void *priv, enum wpa_driver_if_type type,
+		      const char *ifname, const u8 *addr, void *bss_ctx,
+		      void **drv_priv, char *force_ifname, u8 *if_addr,
+		      const char *bridge, int use_existing);
+	 * if_remove - Remove a virtual interface
+	 * @ifname: Interface name of the virtual interface to be removed
+	int (*if_remove)(void *priv, enum wpa_driver_if_type type,
+			 const char *ifname);
+	 * set_sta_vlan - Bind a station into a specific interface (AP only)
+	 * @ifname: Interface (main or virtual BSS or VLAN)
+	 * @addr: MAC address of the associated station
+	 * @vlan_id: VLAN ID
+	 * This function is used to bind a station to a specific virtual
+	 * interface. It is only used if when virtual interfaces are supported,
+	 * e.g., to assign stations to different VLAN interfaces based on
+	 * information from a RADIUS server. This allows separate broadcast
+	 * domains to be used with a single BSS.
+	int (*set_sta_vlan)(void *priv, const u8 *addr, const char *ifname,
+			    int vlan_id);
+	 * commit - Optional commit changes handler (AP only)
+	 * @priv: driver private data
+	 * This optional handler function can be registered if the driver
+	 * interface implementation needs to commit changes (e.g., by setting
+	 * network interface up) at the end of initial configuration. If set,
+	 * this handler will be called after initial setup has been completed.
+	int (*commit)(void *priv);
+	 * send_ether - Send an ethernet packet (AP only)
+	 * @dst: Destination MAC address
+	 * @src: Source MAC address
+	 * @proto: Ethertype
+	int (*send_ether)(void *priv, const u8 *dst, const u8 *src, u16 proto,
+			  const u8 *data, size_t data_len);
+	 * set_radius_acl_auth - Notification of RADIUS ACL change
+	 * @mac: MAC address of the station
+	 * @accepted: Whether the station was accepted
+	 * @session_timeout: Session timeout for the station
+	int (*set_radius_acl_auth)(void *priv, const u8 *mac, int accepted,
+				   u32 session_timeout);
+	 * set_radius_acl_expire - Notification of RADIUS ACL expiration
+	int (*set_radius_acl_expire)(void *priv, const u8 *mac);
+	 * set_ap_wps_ie - Add WPS IE(s) into Beacon/Probe Response frames (AP)
+	 * @beacon: WPS IE(s) for Beacon frames or %NULL to remove extra IE(s)
+	 * @proberesp: WPS IE(s) for Probe Response frames or %NULL to remove
+	 *	extra IE(s)
+	 * @assocresp: WPS IE(s) for (Re)Association Response frames or %NULL
+	 *	to remove extra IE(s)
+	 * This is an optional function to add WPS IE in the kernel driver for
+	 * Beacon and Probe Response frames. This can be left undefined (set
+	 * to %NULL) if the driver uses the Beacon template from set_ap()
+	 * and does not process Probe Request frames. If the driver takes care
+	 * of (Re)Association frame processing, the assocresp buffer includes
+	 * WPS IE(s) that need to be added to (Re)Association Response frames
+	 * whenever a (Re)Association Request frame indicated use of WPS.
+	 * This will also be used to add P2P IE(s) into Beacon/Probe Response
+	 * frames when operating as a GO. The driver is responsible for adding
+	 * timing related attributes (e.g., NoA) in addition to the IEs
+	 * included here by appending them after these buffers. This call is
+	 * also used to provide Probe Response IEs for P2P Listen state
+	 * operations for drivers that generate the Probe Response frames
+	 * internally.
+	int (*set_ap_wps_ie)(void *priv, const struct wpabuf *beacon,
+			     const struct wpabuf *proberesp,
+			     const struct wpabuf *assocresp);
+	 * set_supp_port - Set IEEE 802.1X Supplicant Port status
+	 * @authorized: Whether the port is authorized
+	int (*set_supp_port)(void *priv, int authorized);
+	 * set_wds_sta - Bind a station into a 4-address WDS (AP only)
+	 * @aid: Association ID
+	 * @val: 1 = bind to 4-address WDS; 0 = unbind
+	 * @bridge_ifname: Bridge interface to use for the WDS station or %NULL
+	 *	to indicate that bridge is not to be used
+	 * @ifname_wds: Buffer to return the interface name for the new WDS
+	 *	station or %NULL to indicate name is not returned.
+	int (*set_wds_sta)(void *priv, const u8 *addr, int aid, int val,
+			   const char *bridge_ifname, char *ifname_wds);
+	 * send_action - Transmit an Action frame
+	 * @freq: Frequency (in MHz) of the channel
+	 * @wait: Time to wait off-channel for a response (in ms), or zero
+	 * @dst: Destination MAC address (Address 1)
+	 * @src: Source MAC address (Address 2)
+	 * @bssid: BSSID (Address 3)
+	 * @data: Frame body
+	 * @data_len: data length in octets
+	 @ @no_cck: Whether CCK rates must not be used to transmit this frame
+	 * This command can be used to request the driver to transmit an action
+	 * frame to the specified destination.
+	 * If the %WPA_DRIVER_FLAGS_OFFCHANNEL_TX flag is set, the frame will
+	 * be transmitted on the given channel and the device will wait for a
+	 * response on that channel for the given wait time.
+	 * If the flag is not set, the wait time will be ignored. In this case,
+	 * if a remain-on-channel duration is in progress, the frame must be
+	 * transmitted on that channel; alternatively the frame may be sent on
+	 * the current operational channel (if in associated state in station
+	 * mode or while operating as an AP.)
+	int (*send_action)(void *priv, unsigned int freq, unsigned int wait,
+			   const u8 *dst, const u8 *src, const u8 *bssid,
+			   const u8 *data, size_t data_len, int no_cck);
+	 * send_action_cancel_wait - Cancel action frame TX wait
+	 * This command cancels the wait time associated with sending an action
+	 * frame. It is only available when %WPA_DRIVER_FLAGS_OFFCHANNEL_TX is
+	 * set in the driver flags.
+	void (*send_action_cancel_wait)(void *priv);
+	 * remain_on_channel - Remain awake on a channel
+	 * @duration: Duration in milliseconds
+	 * This command is used to request the driver to remain awake on the
+	 * specified channel for the specified duration and report received
+	 * Action frames with EVENT_RX_MGMT events. Optionally, received
+	 * Probe Request frames may also be requested to be reported by calling
+	 * probe_req_report(). These will be reported with EVENT_RX_PROBE_REQ.
+	 * The driver may not be at the requested channel when this function
+	 * returns, i.e., the return code is only indicating whether the
+	 * request was accepted. The caller will need to wait until the
+	 * EVENT_REMAIN_ON_CHANNEL event indicates that the driver has
+	 * completed the channel change. This may take some time due to other
+	 * need for the radio and the caller should be prepared to timing out
+	 * its wait since there are no guarantees on when this request can be
+	 * executed.
+	int (*remain_on_channel)(void *priv, unsigned int freq,
+				 unsigned int duration);
+	 * cancel_remain_on_channel - Cancel remain-on-channel operation
+	 * This command can be used to cancel a remain-on-channel operation
+	 * before its originally requested duration has passed. This could be
+	 * used, e.g., when remain_on_channel() is used to request extra time
+	 * to receive a response to an Action frame and the response is
+	 * received when there is still unneeded time remaining on the
+	 * remain-on-channel operation.
+	int (*cancel_remain_on_channel)(void *priv);
+	 * probe_req_report - Request Probe Request frames to be indicated
+	 * @report: Whether to report received Probe Request frames
+	 * Returns: 0 on success, -1 on failure (or if not supported)
+	 * This command can be used to request the driver to indicate when
+	 * Probe Request frames are received with EVENT_RX_PROBE_REQ events.
+	 * Since this operation may require extra resources, e.g., due to less
+	 * optimal hardware/firmware RX filtering, many drivers may disable
+	 * Probe Request reporting at least in station mode. This command is
+	 * used to notify the driver when the Probe Request frames need to be
+	 * reported, e.g., during remain-on-channel operations.
+	int (*probe_req_report)(void *priv, int report);
+	 * deinit_ap - Deinitialize AP mode
+	 * This optional function can be used to disable AP mode related
+	 * configuration. If the interface was not dynamically added,
+	 * change the driver mode to station mode to allow normal station
+	 * operations like scanning to be completed.
+	int (*deinit_ap)(void *priv);
+	 * deinit_p2p_cli - Deinitialize P2P client mode
+	 * This optional function can be used to disable P2P client mode. If the
+	 * interface was not dynamically added, change the interface type back
+	 * to station mode.
+	int (*deinit_p2p_cli)(void *priv);
+	 * suspend - Notification on system suspend/hibernate event
+	void (*suspend)(void *priv);
+	 * resume - Notification on system resume/thaw event
+	void (*resume)(void *priv);
+	 * signal_monitor - Set signal monitoring parameters
+	 * @threshold: Threshold value for signal change events; 0 = disabled
+	 * @hysteresis: Minimum change in signal strength before indicating a
+	 *	new event
+	 * This function can be used to configure monitoring of signal strength
+	 * with the current AP. Whenever signal strength drops below the
+	 * %threshold value or increases above it, EVENT_SIGNAL_CHANGE event
+	 * should be generated assuming the signal strength has changed at
+	 * least %hysteresis from the previously indicated signal change event.
+	int (*signal_monitor)(void *priv, int threshold, int hysteresis);
+	 * send_frame - Send IEEE 802.11 frame (testing use only)
+	 * @data: IEEE 802.11 frame with IEEE 802.11 header
+	 * @data_len: Size of the frame
+	 * @encrypt: Whether to encrypt the frame (if keys are set)
+	 * This function is only used for debugging purposes and is not
+	 * required to be implemented for normal operations.
+	int (*send_frame)(void *priv, const u8 *data, size_t data_len,
+			  int encrypt);
+	 * get_noa - Get current Notice of Absence attribute payload
+	 * @buf: Buffer for returning NoA
+	 * @buf_len: Buffer length in octets
+	 * Returns: Number of octets used in buf, 0 to indicate no NoA is being
+	 * advertized, or -1 on failure
+	 * This function is used to fetch the current Notice of Absence
+	 * attribute value from GO.
+	int (*get_noa)(void *priv, u8 *buf, size_t buf_len);
+	 * set_noa - Set Notice of Absence parameters for GO (testing)
+	 * @count: Count
+	 * @start: Start time in ms from next TBTT
+	 * @duration: Duration in ms
+	 * Returns: 0 on success or -1 on failure
+	 * This function is used to set Notice of Absence parameters for GO. It
+	 * is used only for testing. To disable NoA, all parameters are set to
+	 * 0.
+	int (*set_noa)(void *priv, u8 count, int start, int duration);
+	 * set_p2p_powersave - Set P2P power save options
+	 * @legacy_ps: 0 = disable, 1 = enable, 2 = maximum PS, -1 = no change
+	 * @opp_ps: 0 = disable, 1 = enable, -1 = no change
+	 * @ctwindow: 0.. = change (msec), -1 = no change
+	int (*set_p2p_powersave)(void *priv, int legacy_ps, int opp_ps,
+				 int ctwindow);
+	 * ampdu - Enable/disable aggregation
+	 * @ampdu: 1/0 = enable/disable A-MPDU aggregation
+	int (*ampdu)(void *priv, int ampdu);
+	 * get_radio_name - Get physical radio name for the device
+	 * Returns: Radio name or %NULL if not known
+	 * The returned data must not be modified by the caller. It is assumed
+	 * that any interface that has the same radio name as another is
+	 * sharing the same physical radio. This information can be used to
+	 * share scan results etc. information between the virtual interfaces
+	 * to speed up various operations.
+	const char * (*get_radio_name)(void *priv);
+	 * send_tdls_mgmt - for sending TDLS management packets
+	 * @dst: Destination (peer) MAC address
+	 * @action_code: TDLS action code for the mssage
+	 * @dialog_token: Dialog Token to use in the message (if needed)
+	 * @status_code: Status Code or Reason Code to use (if needed)
+	 * @peer_capab: TDLS peer capability (TDLS_PEER_* bitfield)
+	 * @initiator: Is the current end the TDLS link initiator
+	 * @buf: TDLS IEs to add to the message
+	 * @len: Length of buf in octets
+	 * Returns: 0 on success, negative (<0) on failure
+	 * This optional function can be used to send packet to driver which is
+	 * responsible for receiving and sending all TDLS packets.
+	int (*send_tdls_mgmt)(void *priv, const u8 *dst, u8 action_code,
+			      u8 dialog_token, u16 status_code, u32 peer_capab,
+			      int initiator, const u8 *buf, size_t len);
+	 * tdls_oper - Ask the driver to perform high-level TDLS operations
+	 * @oper: TDLS high-level operation. See %enum tdls_oper
+	 * @peer: Destination (peer) MAC address
+	 * This optional function can be used to send high-level TDLS commands
+	 * to the driver.
+	int (*tdls_oper)(void *priv, enum tdls_oper oper, const u8 *peer);
+	 * wnm_oper - Notify driver of the WNM frame reception
+	 * @oper: WNM operation. See %enum wnm_oper
+	 * @buf: Buffer for the driver to fill in (for getting IE)
+	 * @buf_len: Return the len of buf
+	int (*wnm_oper)(void *priv, enum wnm_oper oper, const u8 *peer,
+			u8 *buf, u16 *buf_len);
+	 * set_qos_map - Set QoS Map
+	 * @qos_map_set: QoS Map
+	 * @qos_map_set_len: Length of QoS Map
+	int (*set_qos_map)(void *priv, const u8 *qos_map_set,
+			   u8 qos_map_set_len);
+	 * br_add_ip_neigh - Add a neigh to the bridge ip neigh table
+	 * @version: IP version of the IP address, 4 or 6
+	 * @ipaddr: IP address for the neigh entry
+	 * @prefixlen: IP address prefix length
+	 * @addr: Corresponding MAC address
+	int (*br_add_ip_neigh)(void *priv, u8 version, const u8 *ipaddr,
+			       int prefixlen, const u8 *addr);
+	 * br_delete_ip_neigh - Remove a neigh from the bridge ip neigh table
+	int (*br_delete_ip_neigh)(void *priv, u8 version, const u8 *ipaddr);
+	 * br_port_set_attr - Set a bridge port attribute
+	 * @attr: Bridge port attribute to set
+	 * @val: Value to be set
+	int (*br_port_set_attr)(void *priv, enum drv_br_port_attr attr,
+				unsigned int val);
+	 * br_port_set_attr - Set a bridge network parameter
+	 * @param: Bridge parameter to set
+	int (*br_set_net_param)(void *priv, enum drv_br_net_param param,
+	 * set_wowlan - Set wake-on-wireless triggers
+	 * @triggers: wowlan triggers
+	int (*set_wowlan)(void *priv, const struct wowlan_triggers *triggers);
+	 * signal_poll - Get current connection information
+	 * @signal_info: Connection info structure
+	int (*signal_poll)(void *priv, struct wpa_signal_info *signal_info);
+	 * set_authmode - Set authentication algorithm(s) for static WEP
+	 * @authmode: 1=Open System, 2=Shared Key, 3=both
+	 * This function can be used to set authentication algorithms for AP
+	 * mode when static WEP is used. If the driver uses user space MLME/SME
+	 * implementation, there is no need to implement this function.
+	int (*set_authmode)(void *priv, int authmode);
+#ifdef ANDROID
+	 * driver_cmd - Execute driver-specific command
+	 * @cmd: Command to execute
+	 * @buf: Return buffer
+	int (*driver_cmd)(void *priv, char *cmd, char *buf, size_t buf_len);
+#endif /* ANDROID */
+	 * vendor_cmd - Execute vendor specific command
+	 * @vendor_id: Vendor id
+	 * @subcmd: Vendor command id
+	 * @data: Vendor command parameters (%NULL if no parameters)
+	 * @data_len: Data length
+	 * @buf: Return buffer (%NULL to ignore reply)
+	 * This function handles vendor specific commands that are passed to
+	 * the driver/device. The command is identified by vendor id and
+	 * command id. Parameters can be passed as argument to the command
+	 * in the data buffer. Reply (if any) will be filled in the supplied
+	 * return buffer.
+	 * The exact driver behavior is driver interface and vendor specific. As
+	 * an example, this will be converted to a vendor specific cfg80211
+	 * command in case of the nl80211 driver interface.
+	int (*vendor_cmd)(void *priv, unsigned int vendor_id,
+			  unsigned int subcmd, const u8 *data, size_t data_len,
+			  struct wpabuf *buf);
+	 * set_rekey_info - Set rekey information
+	 * @kek: Current KEK
+	 * @kek_len: KEK length in octets
+	 * @kck: Current KCK
+	 * @kck_len: KCK length in octets
+	 * @replay_ctr: Current EAPOL-Key Replay Counter
+	 * This optional function can be used to provide information for the
+	 * driver/firmware to process EAPOL-Key frames in Group Key Handshake
+	 * while the host (including wpa_supplicant) is sleeping.
+	void (*set_rekey_info)(void *priv, const u8 *kek, size_t kek_len,
+			       const u8 *kck, size_t kck_len,
+			       const u8 *replay_ctr);
+	 * sta_assoc - Station association indication
+	 * @own_addr: Source address and BSSID for association frame
+	 * @addr: MAC address of the station to associate
+	 * @reassoc: flag to indicate re-association
+	 * @status: association response status code
+	 * @ie: assoc response ie buffer
+	 * @len: ie buffer length
+	 * This function indicates the driver to send (Re)Association
+	 * Response frame to the station.
+	 int (*sta_assoc)(void *priv, const u8 *own_addr, const u8 *addr,
+			  int reassoc, u16 status, const u8 *ie, size_t len);
+	 * sta_auth - Station authentication indication
+	 * @own_addr: Source address and BSSID for authentication frame
+	 * @seq: authentication sequence number
+	 * @status: authentication response status code
+	 * @ie: authentication frame ie buffer
+	 * This function indicates the driver to send Authentication frame
+	 * to the station.
+	 int (*sta_auth)(void *priv, const u8 *own_addr, const u8 *addr,
+			 u16 seq, u16 status, const u8 *ie, size_t len);
+	 * add_tspec - Add traffic stream
+	 * @tspec_ie: tspec ie buffer
+	 * @tspec_ielen: tspec ie length
+	 * This function adds the traffic steam for the station
+	 * and fills the medium_time in tspec_ie.
+	 int (*add_tspec)(void *priv, const u8 *addr, u8 *tspec_ie,
+			  size_t tspec_ielen);
+	 * add_sta_node - Add a station node in the driver
+	 * @addr: MAC address of the station to add
+	 * @auth_alg: authentication algorithm used by the station
+	 * This function adds the station node in the driver, when
+	 * the station gets added by FT-over-DS.
+	int (*add_sta_node)(void *priv, const u8 *addr, u16 auth_alg);
+	 * sched_scan - Request the driver to initiate scheduled scan
+	 * @interval: Interval between scan cycles in milliseconds
+	 * This operation should be used for scheduled scan offload to
+	 * the hardware. Every time scan results are available, the
+	 * driver should report scan results event for wpa_supplicant
+	 * which will eventually request the results with
+	 * wpa_driver_get_scan_results2(). This operation is optional
+	 * and if not provided or if it returns -1, we fall back to
+	 * normal host-scheduled scans.
+	int (*sched_scan)(void *priv, struct wpa_driver_scan_params *params,
+			  u32 interval);
+	 * stop_sched_scan - Request the driver to stop a scheduled scan
+	 * This should cause the scheduled scan to be stopped and
+	 * results should stop being sent. Must be supported if
+	 * sched_scan is supported.
+	int (*stop_sched_scan)(void *priv);
+	 * poll_client - Probe (null data or such) the given station
+	 * @own_addr: MAC address of sending interface
+	 * @addr: MAC address of the station to probe
+	 * @qos: Indicates whether station is QoS station
+	 * This function is used to verify whether an associated station is
+	 * still present. This function does not need to be implemented if the
+	 * driver provides such inactivity polling mechanism.
+	void (*poll_client)(void *priv, const u8 *own_addr,
+			    const u8 *addr, int qos);
+	 * radio_disable - Disable/enable radio
+	 * @disabled: 1=disable 0=enable radio
+	 * This optional command is for testing purposes. It can be used to
+	 * disable the radio on a testbed device to simulate out-of-radio-range
+	 * conditions.
+	int (*radio_disable)(void *priv, int disabled);
+	 * switch_channel - Announce channel switch and migrate the GO to the
+	 * given frequency
+	 * @settings: Settings for CSA period and new channel
+	 * This function is used to move the GO to the legacy STA channel to
+	 * avoid frequency conflict in single channel concurrency.
+	int (*switch_channel)(void *priv, struct csa_settings *settings);
+	 * add_tx_ts - Add traffic stream
+	 * @tsid: Traffic stream ID
+	 * @addr: Receiver address
+	 * @user_prio: User priority of the traffic stream
+	 * @admitted_time: Admitted time for this TS in units of
+	 *	32 microsecond periods (per second).
+	int (*add_tx_ts)(void *priv, u8 tsid, const u8 *addr, u8 user_prio,
+			 u16 admitted_time);
+	 * del_tx_ts - Delete traffic stream
+	int (*del_tx_ts)(void *priv, u8 tsid, const u8 *addr);
+	 * Enable channel-switching with TDLS peer
+	 * @addr: MAC address of the TDLS peer
+	 * @oper_class: Operating class of the switch channel
+	 * @params: Channel specification
+	 * The function indicates to driver that it can start switching to a
+	 * different channel with a specified TDLS peer. The switching is
+	 * assumed on until canceled with tdls_disable_channel_switch().
+	int (*tdls_enable_channel_switch)(
+		void *priv, const u8 *addr, u8 oper_class,
+		const struct hostapd_freq_params *params);
+	 * Disable channel switching with TDLS peer
+	 * This function indicates to the driver that it should stop switching
+	 * with a given TDLS peer.
+	int (*tdls_disable_channel_switch)(void *priv, const u8 *addr);
+	 * start_dfs_cac - Listen for radar interference on the channel
+	int (*start_dfs_cac)(void *priv, struct hostapd_freq_params *freq);
+	 * stop_ap - Removes beacon from AP
+	 * configuration. Unlike deinit_ap, it does not change to station
+	 * mode.
+	int (*stop_ap)(void *priv);
+	 * get_survey - Retrieve survey data
+	 * @freq: If set, survey data for the specified frequency is only
+	 *	being requested. If not set, all survey data is requested.
+	 * Use this to retrieve:
+	 * - the observed channel noise floor
+	 * - the amount of time we have spent on the channel
+	 * - the amount of time during which we have spent on the channel that
+	 *   the radio has determined the medium is busy and we cannot
+	 *   transmit
+	 * - the amount of time we have spent receiving data
+	 * - the amount of time we have spent transmitting data
+	 * This data can be used for spectrum heuristics. One example is
+	 * Automatic Channel Selection (ACS). The channel survey data is
+	 * kept on a linked list on the channel data, one entry is added
+	 * for each survey. The min_nf of the channel is updated for each
+	 * survey.
+	int (*get_survey)(void *priv, unsigned int freq);
+	 * status - Get driver interface status information
+	 * @buf: Buffer for printing tou the status information
+	 * @buflen: Maximum length of the buffer
+	 * Returns: Length of written status information or -1 on failure
+	int (*status)(void *priv, char *buf, size_t buflen);
+	 * roaming - Set roaming policy for driver-based BSS selection
+	 * @allowed: Whether roaming within ESS is allowed
+	 * @bssid: Forced BSSID if roaming is disabled or %NULL if not set
+	 * This optional callback can be used to update roaming policy from the
+	 * associate() command (bssid being set there indicates that the driver
+	 * should not roam before getting this roaming() call to allow roaming.
+	 * If the driver does not indicate WPA_DRIVER_FLAGS_BSS_SELECTION
+	 * capability, roaming policy is handled within wpa_supplicant and there
+	 * is no need to implement or react to this callback.
+	int (*roaming)(void *priv, int allowed, const u8 *bssid);
+	 * set_mac_addr - Set MAC address
+	 * @addr: MAC address to use or %NULL for setting back to permanent
+	int (*set_mac_addr)(void *priv, const u8 *addr);
+	int (*macsec_init)(void *priv, struct macsec_init_params *params);
+	int (*macsec_deinit)(void *priv);
+	 * enable_protect_frames - Set protect frames status
+	 * @enabled: TRUE = protect frames enabled
+	 *           FALSE = protect frames disabled
+	int (*enable_protect_frames)(void *priv, Boolean enabled);
+	 * set_replay_protect - Set replay protect status and window size
+	 * @enabled: TRUE = replay protect enabled
+	 *           FALSE = replay protect disabled
+	 * @window: replay window size, valid only when replay protect enabled
+	int (*set_replay_protect)(void *priv, Boolean enabled, u32 window);
+	 * set_current_cipher_suite - Set current cipher suite
+	 * @cs: EUI64 identifier
+	 * @cs_len: Length of the cs buffer in octets
+	int (*set_current_cipher_suite)(void *priv, const u8 *cs,
+					size_t cs_len);
+	 * enable_controlled_port - Set controlled port status
+	 * @enabled: TRUE = controlled port enabled
+	 *           FALSE = controlled port disabled
+	int (*enable_controlled_port)(void *priv, Boolean enabled);
+	 * get_receive_lowest_pn - Get receive lowest pn
+	 * @channel: secure channel
+	 * @an: association number
+	 * @lowest_pn: lowest accept pn
+	int (*get_receive_lowest_pn)(void *priv, u32 channel, u8 an,
+				     u32 *lowest_pn);
+	 * get_transmit_next_pn - Get transmit next pn
+	 * @next_pn: next pn
+	int (*get_transmit_next_pn)(void *priv, u32 channel, u8 an,
+				    u32 *next_pn);
+	 * set_transmit_next_pn - Set transmit next pn
+	int (*set_transmit_next_pn)(void *priv, u32 channel, u8 an,
+				    u32 next_pn);
+	 * get_available_receive_sc - get available receive channel
+	int (*get_available_receive_sc)(void *priv, u32 *channel);
+	 * create_receive_sc - create secure channel for receiving
+	 * @sci_addr: secure channel identifier - address
+	 * @sci_port: secure channel identifier - port
+	 * @conf_offset: confidentiality offset (0, 30, or 50)
+	 * @validation: frame validation policy (0 = Disabled, 1 = Checked,
+	 *	2 = Strict)
+	int (*create_receive_sc)(void *priv, u32 channel, const u8 *sci_addr,
+				 u16 sci_port, unsigned int conf_offset,
+				 int validation);
+	 * delete_receive_sc - delete secure connection for receiving
+	int (*delete_receive_sc)(void *priv, u32 channel);
+	 * create_receive_sa - create secure association for receive
+	 * @lowest_pn: the lowest packet number can be received
+	 * @sak: the secure association key
+	int (*create_receive_sa)(void *priv, u32 channel, u8 an,
+				 u32 lowest_pn, const u8 *sak);
+	 * enable_receive_sa - enable the SA for receive
+	int (*enable_receive_sa)(void *priv, u32 channel, u8 an);
+	 * disable_receive_sa - disable SA for receive
+	 * @channel: secure channel index
+	int (*disable_receive_sa)(void *priv, u32 channel, u8 an);
+	 * get_available_transmit_sc - get available transmit channel
+	int (*get_available_transmit_sc)(void *priv, u32 *channel);
+	 * create_transmit_sc - create secure connection for transmit
+	int (*create_transmit_sc)(void *priv, u32 channel, const u8 *sci_addr,
+				  u16 sci_port, unsigned int conf_offset);
+	 * delete_transmit_sc - delete secure connection for transmit
+	int (*delete_transmit_sc)(void *priv, u32 channel);
+	 * create_transmit_sa - create secure association for transmit
+	 * @next_pn: the packet number used as next transmit packet
+	 * @confidentiality: True if the SA is to provide confidentiality
+	 *                   as well as integrity
+	int (*create_transmit_sa)(void *priv, u32 channel, u8 an, u32 next_pn,
+				  Boolean confidentiality, const u8 *sak);
+	 * enable_transmit_sa - enable SA for transmit
+	int (*enable_transmit_sa)(void *priv, u32 channel, u8 an);
+	 * disable_transmit_sa - disable SA for transmit
+	int (*disable_transmit_sa)(void *priv, u32 channel, u8 an);
+	 * init_mesh - Driver specific initialization for mesh
+	int (*init_mesh)(void *priv);
+	 * join_mesh - Join a mesh network
+	 * @params: Mesh configuration parameters
+	int (*join_mesh)(void *priv,
+			 struct wpa_driver_mesh_join_params *params);
+	 * leave_mesh - Leave a mesh network
+	 * Returns 0 on success, -1 on failure
+	int (*leave_mesh)(void *priv);
+	 * do_acs - Automatically select channel
+	 * @params: Parameters for ACS
+	 * This command can be used to offload ACS to the driver if the driver
+	 * indicates support for such offloading (WPA_DRIVER_FLAGS_ACS_OFFLOAD).
+	int (*do_acs)(void *priv, struct drv_acs_params *params);
+	 * set_band - Notify driver of band selection
+	 * @band: The selected band(s)
+	int (*set_band)(void *priv, enum set_band band);
+	 * get_pref_freq_list - Get preferred frequency list for an interface
+	 * @if_type: Interface type
+	 * @num: Number of channels
+	 * @freq_list: Preferred channel frequency list encoded in MHz values
+	 * This command can be used to query the preferred frequency list from
+	 * the driver specific to a particular interface type.
+	int (*get_pref_freq_list)(void *priv, enum wpa_driver_if_type if_type,
+				  unsigned int *num, unsigned int *freq_list);
+	 * set_prob_oper_freq - Indicate probable P2P operating channel
+	 * @freq: Channel frequency in MHz
+	 * This command can be used to inform the driver of the operating
+	 * frequency that an ongoing P2P group formation is likely to come up
+	 * on. Local device is assuming P2P Client role.
+	int (*set_prob_oper_freq)(void *priv, unsigned int freq);
+ * enum wpa_event_type - Event type for wpa_supplicant_event() calls
+enum wpa_event_type {
+	 * EVENT_ASSOC - Association completed
+	 * This event needs to be delivered when the driver completes IEEE
+	 * 802.11 association or reassociation successfully.
+	 * wpa_driver_ops::get_bssid() is expected to provide the current BSSID
+	 * after this event has been generated. In addition, optional
+	 * EVENT_ASSOCINFO may be generated just before EVENT_ASSOC to provide
+	 * more information about the association. If the driver interface gets
+	 * both of these events at the same time, it can also include the
+	 * assoc_info data in EVENT_ASSOC call.
+	EVENT_ASSOC,
+	 * EVENT_DISASSOC - Association lost
+	 * This event should be called when association is lost either due to
+	 * receiving deauthenticate or disassociate frame from the AP or when
+	 * sending either of these frames to the current AP. If the driver
+	 * supports separate deauthentication event, EVENT_DISASSOC should only
+	 * be used for disassociation and EVENT_DEAUTH for deauthentication.
+	 * In AP mode, union wpa_event_data::disassoc_info is required.
+	EVENT_DISASSOC,
+	 * EVENT_MICHAEL_MIC_FAILURE - Michael MIC (TKIP) detected
+	 * This event must be delivered when a Michael MIC error is detected by
+	 * the local driver. Additional data for event processing is
+	 * provided with union wpa_event_data::michael_mic_failure. This
+	 * information is used to request new encyption key and to initiate
+	 * TKIP countermeasures if needed.
+	EVENT_MICHAEL_MIC_FAILURE,
+	 * EVENT_SCAN_RESULTS - Scan results available
+	 * This event must be called whenever scan results are available to be
+	 * fetched with struct wpa_driver_ops::get_scan_results(). This event
+	 * is expected to be used some time after struct wpa_driver_ops::scan()
+	 * is called. If the driver provides an unsolicited event when the scan
+	 * has been completed, this event can be used to trigger
+	 * EVENT_SCAN_RESULTS call. If such event is not available from the
+	 * driver, the driver wrapper code is expected to use a registered
+	 * timeout to generate EVENT_SCAN_RESULTS call after the time that the
+	 * scan is expected to be completed. Optional information about
+	 * completed scan can be provided with union wpa_event_data::scan_info.
+	EVENT_SCAN_RESULTS,
+	 * EVENT_ASSOCINFO - Report optional extra information for association
+	 * This event can be used to report extra association information for
+	 * EVENT_ASSOC processing. This extra information includes IEs from
+	 * association frames and Beacon/Probe Response frames in union
+	 * wpa_event_data::assoc_info. EVENT_ASSOCINFO must be send just before
+	 * EVENT_ASSOC. Alternatively, the driver interface can include
+	 * assoc_info data in the EVENT_ASSOC call if it has all the
+	 * information available at the same point.
+	EVENT_ASSOCINFO,
+	 * EVENT_INTERFACE_STATUS - Report interface status changes
+	 * This optional event can be used to report changes in interface
+	 * status (interface added/removed) using union
+	 * wpa_event_data::interface_status. This can be used to trigger
+	 * wpa_supplicant to stop and re-start processing for the interface,
+	 * e.g., when a cardbus card is ejected/inserted.
+	EVENT_INTERFACE_STATUS,
+	 * EVENT_PMKID_CANDIDATE - Report a candidate AP for pre-authentication
+	 * This event can be used to inform wpa_supplicant about candidates for
+	 * RSN (WPA2) pre-authentication. If wpa_supplicant is not responsible
+	 * for scan request (ap_scan=2 mode), this event is required for
+	 * pre-authentication. If wpa_supplicant is performing scan request
+	 * (ap_scan=1), this event is optional since scan results can be used
+	 * to add pre-authentication candidates. union
+	 * wpa_event_data::pmkid_candidate is used to report the BSSID of the
+	 * candidate and priority of the candidate, e.g., based on the signal
+	 * strength, in order to try to pre-authenticate first with candidates
+	 * that are most likely targets for re-association.
+	 * EVENT_PMKID_CANDIDATE can be called whenever the driver has updates
+	 * on the candidate list. In addition, it can be called for the current
+	 * AP and APs that have existing PMKSA cache entries. wpa_supplicant
+	 * will automatically skip pre-authentication in cases where a valid
+	 * PMKSA exists. When more than one candidate exists, this event should
+	 * be generated once for each candidate.
+	 * Driver will be notified about successful pre-authentication with
+	 * struct wpa_driver_ops::add_pmkid() calls.
+	EVENT_PMKID_CANDIDATE,
+	 * EVENT_STKSTART - Request STK handshake (MLME-STKSTART.request)
+	 * This event can be used to inform wpa_supplicant about desire to set
+	 * up secure direct link connection between two stations as defined in
+	 * IEEE 802.11e with a new PeerKey mechanism that replaced the original
+	 * STAKey negotiation. The caller will need to set peer address for the
+	 * event.
+	EVENT_STKSTART,
+	 * EVENT_TDLS - Request TDLS operation
+	 * This event can be used to request a TDLS operation to be performed.
+	EVENT_TDLS,
+	 * EVENT_FT_RESPONSE - Report FT (IEEE 802.11r) response IEs
+	 * The driver is expected to report the received FT IEs from
+	 * FT authentication sequence from the AP. The FT IEs are included in
+	 * the extra information in union wpa_event_data::ft_ies.
+	EVENT_FT_RESPONSE,
+	 * EVENT_IBSS_RSN_START - Request RSN authentication in IBSS
+	 * The driver can use this event to inform wpa_supplicant about a STA
+	 * in an IBSS with which protected frames could be exchanged. This
+	 * event starts RSN authentication with the other STA to authenticate
+	 * the STA and set up encryption keys with it.
+	EVENT_IBSS_RSN_START,
+	 * EVENT_AUTH - Authentication result
+	 * This event should be called when authentication attempt has been
+	 * completed. This is only used if the driver supports separate
+	 * authentication step (struct wpa_driver_ops::authenticate).
+	 * Information about authentication result is included in
+	 * union wpa_event_data::auth.
+	EVENT_AUTH,
+	 * EVENT_DEAUTH - Authentication lost
+	 * This event should be called when authentication is lost either due
+	 * to receiving deauthenticate frame from the AP or when sending that
+	 * frame to the current AP.
+	 * In AP mode, union wpa_event_data::deauth_info is required.
+	EVENT_DEAUTH,
+	 * EVENT_ASSOC_REJECT - Association rejected
+	 * This event should be called when (re)association attempt has been
+	 * rejected by the AP. Information about the association response is
+	 * included in union wpa_event_data::assoc_reject.
+	EVENT_ASSOC_REJECT,
+	 * EVENT_AUTH_TIMED_OUT - Authentication timed out
+	EVENT_AUTH_TIMED_OUT,
+	 * EVENT_ASSOC_TIMED_OUT - Association timed out
+	EVENT_ASSOC_TIMED_OUT,
+	 * EVENT_WPS_BUTTON_PUSHED - Report hardware push button press for WPS
+	EVENT_WPS_BUTTON_PUSHED,
+	 * EVENT_TX_STATUS - Report TX status
+	EVENT_TX_STATUS,
+	 * EVENT_RX_FROM_UNKNOWN - Report RX from unknown STA
+	EVENT_RX_FROM_UNKNOWN,
+	 * EVENT_RX_MGMT - Report RX of a management frame
+	EVENT_RX_MGMT,
+	 * EVENT_REMAIN_ON_CHANNEL - Remain-on-channel duration started
+	 * This event is used to indicate when the driver has started the
+	 * requested remain-on-channel duration. Information about the
+	 * operation is included in union wpa_event_data::remain_on_channel.
+	EVENT_REMAIN_ON_CHANNEL,
+	 * EVENT_CANCEL_REMAIN_ON_CHANNEL - Remain-on-channel timed out
+	 * This event is used to indicate when the driver has completed
+	 * remain-on-channel duration, i.e., may noot be available on the
+	 * requested channel anymore. Information about the
+	EVENT_CANCEL_REMAIN_ON_CHANNEL,
+	 * EVENT_RX_PROBE_REQ - Indicate received Probe Request frame
+	 * This event is used to indicate when a Probe Request frame has been
+	 * received. Information about the received frame is included in
+	 * union wpa_event_data::rx_probe_req. The driver is required to report
+	 * these events only after successfully completed probe_req_report()
+	 * commands to request the events (i.e., report parameter is non-zero)
+	 * in station mode. In AP mode, Probe Request frames should always be
+	 * reported.
+	EVENT_RX_PROBE_REQ,
+	 * EVENT_NEW_STA - New wired device noticed
+	 * This event is used to indicate that a new device has been detected
+	 * in a network that does not use association-like functionality (i.e.,
+	 * mainly wired Ethernet). This can be used to start EAPOL
+	 * authenticator when receiving a frame from a device. The address of
+	 * the device is included in union wpa_event_data::new_sta.
+	EVENT_NEW_STA,
+	 * EVENT_EAPOL_RX - Report received EAPOL frame
+	 * When in AP mode with hostapd, this event is required to be used to
+	 * deliver the receive EAPOL frames from the driver.
+	EVENT_EAPOL_RX,
+	 * EVENT_SIGNAL_CHANGE - Indicate change in signal strength
+	 * This event is used to indicate changes in the signal strength
+	 * observed in frames received from the current AP if signal strength
+	 * monitoring has been enabled with signal_monitor().
+	EVENT_SIGNAL_CHANGE,
+	 * EVENT_INTERFACE_ENABLED - Notify that interface was enabled
+	 * This event is used to indicate that the interface was enabled after
+	 * having been previously disabled, e.g., due to rfkill.
+	EVENT_INTERFACE_ENABLED,
+	 * EVENT_INTERFACE_DISABLED - Notify that interface was disabled
+	 * This event is used to indicate that the interface was disabled,
+	 * e.g., due to rfkill.
+	EVENT_INTERFACE_DISABLED,
+	 * EVENT_CHANNEL_LIST_CHANGED - Channel list changed
+	 * This event is used to indicate that the channel list has changed,
+	 * e.g., because of a regulatory domain change triggered by scan
+	 * results including an AP advertising a country code.
+	EVENT_CHANNEL_LIST_CHANGED,
+	 * EVENT_INTERFACE_UNAVAILABLE - Notify that interface is unavailable
+	 * This event is used to indicate that the driver cannot maintain this
+	 * interface in its operation mode anymore. The most likely use for
+	 * this is to indicate that AP mode operation is not available due to
+	 * operating channel would need to be changed to a DFS channel when
+	 * the driver does not support radar detection and another virtual
+	 * interfaces caused the operating channel to change. Other similar
+	 * resource conflicts could also trigger this for station mode
+	 * interfaces. This event can be propagated when channel switching
+	 * fails.
+	EVENT_INTERFACE_UNAVAILABLE,
+	 * EVENT_BEST_CHANNEL
+	 * Driver generates this event whenever it detects a better channel
+	 * (e.g., based on RSSI or channel use). This information can be used
+	 * to improve channel selection for a new AP/P2P group.
+	EVENT_BEST_CHANNEL,
+	 * EVENT_UNPROT_DEAUTH - Unprotected Deauthentication frame received
+	 * This event should be called when a Deauthentication frame is dropped
+	 * due to it not being protected (MFP/IEEE 802.11w).
+	 * union wpa_event_data::unprot_deauth is required to provide more
+	 * details of the frame.
+	EVENT_UNPROT_DEAUTH,
+	 * EVENT_UNPROT_DISASSOC - Unprotected Disassociation frame received
+	 * This event should be called when a Disassociation frame is dropped
+	 * union wpa_event_data::unprot_disassoc is required to provide more
+	EVENT_UNPROT_DISASSOC,
+	 * EVENT_STATION_LOW_ACK
+	 * Driver generates this event whenever it detected that a particular
+	 * station was lost. Detection can be through massive transmission
+	 * failures for example.
+	EVENT_STATION_LOW_ACK,
+	 * EVENT_IBSS_PEER_LOST - IBSS peer not reachable anymore
+	EVENT_IBSS_PEER_LOST,
+	 * EVENT_DRIVER_GTK_REKEY - Device/driver did GTK rekey
+	 * This event carries the new replay counter to notify wpa_supplicant
+	 * of the current EAPOL-Key Replay Counter in case the driver/firmware
+	 * completed Group Key Handshake while the host (including
+	 * wpa_supplicant was sleeping).
+	EVENT_DRIVER_GTK_REKEY,
+	 * EVENT_SCHED_SCAN_STOPPED - Scheduled scan was stopped
+	EVENT_SCHED_SCAN_STOPPED,
+	 * EVENT_DRIVER_CLIENT_POLL_OK - Station responded to poll
+	 * This event indicates that the station responded to the poll
+	 * initiated with @poll_client.
+	EVENT_DRIVER_CLIENT_POLL_OK,
+	 * EVENT_EAPOL_TX_STATUS - notify of EAPOL TX status
+	EVENT_EAPOL_TX_STATUS,
+	 * EVENT_CH_SWITCH - AP or GO decided to switch channels
+	 * Described in wpa_event_data.ch_switch
+	EVENT_CH_SWITCH,
+	 * EVENT_WNM - Request WNM operation
+	 * This event can be used to request a WNM operation to be performed.
+	EVENT_WNM,
+	 * EVENT_CONNECT_FAILED_REASON - Connection failure reason in AP mode
+	 * This event indicates that the driver reported a connection failure
+	 * with the specified client (for example, max client reached, etc.) in
+	 * AP mode.
+	EVENT_CONNECT_FAILED_REASON,
+	 * EVENT_DFS_RADAR_DETECTED - Notify of radar detection
+	 * A radar has been detected on the supplied frequency, hostapd should
+	 * react accordingly (e.g., change channel).
+	EVENT_DFS_RADAR_DETECTED,
+	 * EVENT_DFS_CAC_FINISHED - Notify that channel availability check has been completed
+	 * After a successful CAC, the channel can be marked clear and used.
+	EVENT_DFS_CAC_FINISHED,
+	 * EVENT_DFS_CAC_ABORTED - Notify that channel availability check has been aborted
+	 * The CAC was not successful, and the channel remains in the previous
+	 * state. This may happen due to a radar beeing detected or other
+	 * external influences.
+	EVENT_DFS_CAC_ABORTED,
+	 * EVENT_DFS_NOP_FINISHED - Notify that non-occupancy period is over
+	 * The channel which was previously unavailable is now available again.
+	EVENT_DFS_NOP_FINISHED,
+	 * EVENT_SURVEY - Received survey data
+	 * This event gets triggered when a driver query is issued for survey
+	 * data and the requested data becomes available. The returned data is
+	 * stored in struct survey_results. The results provide at most one
+	 * survey entry for each frequency and at minimum will provide one
+	 * survey entry for one frequency. The survey data can be os_malloc()'d
+	 * and then os_free()'d, so the event callback must only copy data.
+	EVENT_SURVEY,
+	 * EVENT_SCAN_STARTED - Scan started
+	 * This indicates that driver has started a scan operation either based
+	 * on a request from wpa_supplicant/hostapd or from another application.
+	 * EVENT_SCAN_RESULTS is used to indicate when the scan has been
+	 * completed (either successfully or by getting cancelled).
+	EVENT_SCAN_STARTED,
+	 * EVENT_AVOID_FREQUENCIES - Received avoid frequency range
+	 * This event indicates a set of frequency ranges that should be avoided
+	 * to reduce issues due to interference or internal co-existence
+	 * information in the driver.
+	EVENT_AVOID_FREQUENCIES,
+	 * EVENT_NEW_PEER_CANDIDATE - new (unknown) mesh peer notification
+	EVENT_NEW_PEER_CANDIDATE,
+	 * EVENT_ACS_CHANNEL_SELECTED - Received selected channels by ACS
+	 * Indicates a pair of primary and secondary channels chosen by ACS
+	 * in device.
+	EVENT_ACS_CHANNEL_SELECTED,
+	 * EVENT_DFS_CAC_STARTED - Notify that channel availability check has
+	 * been started.
+	 * This event indicates that channel availability check has been started
+	 * on a DFS frequency by a driver that supports DFS Offload.
+	EVENT_DFS_CAC_STARTED,
+ * struct freq_survey - Channel survey info
+ * @ifidx: Interface index in which this survey was observed
+ * @freq: Center of frequency of the surveyed channel
+ * @nf: Channel noise floor in dBm
+ * @channel_time: Amount of time in ms the radio spent on the channel
+ * @channel_time_busy: Amount of time in ms the radio detected some signal
+ *     that indicated to the radio the channel was not clear
+ * @channel_time_rx: Amount of time the radio spent receiving data
+ * @channel_time_tx: Amount of time the radio spent transmitting data
+ * @filled: bitmask indicating which fields have been reported, see
+ *     SURVEY_HAS_* defines.
+ * @list: Internal list pointers
+struct freq_survey {
+	u32 ifidx;
+	unsigned int freq;
+	s8 nf;
+	u64 channel_time;
+	u64 channel_time_busy;
+	u64 channel_time_rx;
+	u64 channel_time_tx;
+	unsigned int filled;
+	struct dl_list list;
+#define SURVEY_HAS_NF BIT(0)
+#define SURVEY_HAS_CHAN_TIME BIT(1)
+#define SURVEY_HAS_CHAN_TIME_BUSY BIT(2)
+#define SURVEY_HAS_CHAN_TIME_RX BIT(3)
+#define SURVEY_HAS_CHAN_TIME_TX BIT(4)
+ * union wpa_event_data - Additional data for wpa_supplicant_event() calls
+union wpa_event_data {
+	 * struct assoc_info - Data for EVENT_ASSOC and EVENT_ASSOCINFO events
+	 * This structure is optional for EVENT_ASSOC calls and required for
+	 * EVENT_ASSOCINFO calls. By using EVENT_ASSOC with this data, the
+	 * driver interface does not need to generate separate EVENT_ASSOCINFO
+	 * calls.
+	struct assoc_info {
+		 * reassoc - Flag to indicate association or reassociation
+		int reassoc;
+		 * req_ies - (Re)Association Request IEs
+		 * If the driver generates WPA/RSN IE, this event data must be
+		 * returned for WPA handshake to have needed information. If
+		 * wpa_supplicant-generated WPA/RSN IE is used, this
+		 * information event is optional.
+		 * This should start with the first IE (fixed fields before IEs
+		 * are not included).
+		const u8 *req_ies;
+		 * req_ies_len - Length of req_ies in bytes
+		size_t req_ies_len;
+		 * resp_ies - (Re)Association Response IEs
+		 * Optional association data from the driver. This data is not
+		 * required WPA, but may be useful for some protocols and as
+		 * such, should be reported if this is available to the driver
+		 * interface.
+		const u8 *resp_ies;
+		 * resp_ies_len - Length of resp_ies in bytes
+		size_t resp_ies_len;
+		 * beacon_ies - Beacon or Probe Response IEs
+		 * Optional Beacon/ProbeResp data: IEs included in Beacon or
+		 * Probe Response frames from the current AP (i.e., the one
+		 * that the client just associated with). This information is
+		 * used to update WPA/RSN IE for the AP. If this field is not
+		 * set, the results from previous scan will be used. If no
+		 * data for the new AP is found, scan results will be requested
+		 * again (without scan request). At this point, the driver is
+		 * expected to provide WPA/RSN IE for the AP (if WPA/WPA2 is
+		 * used).
+		const u8 *beacon_ies;
+		 * beacon_ies_len - Length of beacon_ies */
+		size_t beacon_ies_len;
+		 * freq - Frequency of the operational channel in MHz
+		 * wmm_params - WMM parameters used in this association.
+		struct wmm_params wmm_params;
+		 * addr - Station address (for AP mode)
+		const u8 *addr;
+		 * The following is the key management offload information
+		 * @authorized
+		 * @key_replay_ctr
+		 * @key_replay_ctr_len
+		 * @ptk_kck
+		 * @ptk_kek_len
+		 * @ptk_kek
+		 * @ptk_kek_len
+		 * authorized - Status of key management offload,
+		 * 1 = successful
+		int authorized;
+		 * key_replay_ctr - Key replay counter value last used
+		 * in a valid EAPOL-Key frame
+		const u8 *key_replay_ctr;
+		 * key_replay_ctr_len - The length of key_replay_ctr
+		size_t key_replay_ctr_len;
+		 * ptk_kck - The derived PTK KCK
+		const u8 *ptk_kck;
+		 * ptk_kek_len - The length of ptk_kck
+		size_t ptk_kck_len;
+		 * ptk_kek - The derived PTK KEK
+		const u8 *ptk_kek;
+		 * ptk_kek_len - The length of ptk_kek
+		size_t ptk_kek_len;
+	} assoc_info;
+	 * struct disassoc_info - Data for EVENT_DISASSOC events
+	struct disassoc_info {
+		const u8 *addr;
+		 * reason_code - Reason Code (host byte order) used in
+		 *	Deauthentication frame
+		u16 reason_code;
+		 * ie - Optional IE(s) in Disassociation frame
+		const u8 *ie;
+		 * ie_len - Length of ie buffer in octets
+		size_t ie_len;
+		 * locally_generated - Whether the frame was locally generated
+		int locally_generated;
+	} disassoc_info;
+	 * struct deauth_info - Data for EVENT_DEAUTH events
+	struct deauth_info {
+		const u8 *addr;
+		u16 reason_code;
+		 * ie - Optional IE(s) in Deauthentication frame
+		const u8 *ie;
+		size_t ie_len;
+	} deauth_info;
+	 * struct michael_mic_failure - Data for EVENT_MICHAEL_MIC_FAILURE
+	struct michael_mic_failure {
+		int unicast;
+		const u8 *src;
+	} michael_mic_failure;
+	 * struct interface_status - Data for EVENT_INTERFACE_STATUS
+	struct interface_status {
+		char ifname[100];
+		enum {
+			EVENT_INTERFACE_ADDED, EVENT_INTERFACE_REMOVED
+		} ievent;
+	} interface_status;
+	 * struct pmkid_candidate - Data for EVENT_PMKID_CANDIDATE
+	struct pmkid_candidate {
+		/** BSSID of the PMKID candidate */
+		u8 bssid[ETH_ALEN];
+		/** Smaller the index, higher the priority */
+		int index;
+		/** Whether RSN IE includes pre-authenticate flag */
+		int preauth;
+	} pmkid_candidate;
+	 * struct stkstart - Data for EVENT_STKSTART
+	struct stkstart {
+		u8 peer[ETH_ALEN];
+	} stkstart;
+	 * struct tdls - Data for EVENT_TDLS
+	struct tdls {
+		enum {
+			TDLS_REQUEST_SETUP,
+			TDLS_REQUEST_TEARDOWN,
+			TDLS_REQUEST_DISCOVER,
+		} oper;
+		u16 reason_code; /* for teardown */
+	} tdls;
+	 * struct wnm - Data for EVENT_WNM
+	struct wnm {
+		u8 addr[ETH_ALEN];
+		enum {
+			WNM_OPER_SLEEP,
+		} oper;
+		enum {
+			WNM_SLEEP_ENTER,
+			WNM_SLEEP_EXIT
+		} sleep_action;
+		int sleep_intval;
+		u16 reason_code;
+		u8 *buf;
+		u16 buf_len;
+	} wnm;
+	 * struct ft_ies - FT information elements (EVENT_FT_RESPONSE)
+	 * During FT (IEEE 802.11r) authentication sequence, the driver is
+	 * expected to use this event to report received FT IEs (MDIE, FTIE,
+	 * RSN IE, TIE, possible resource request) to the supplicant. The FT
+	 * IEs for the next message will be delivered through the
+	 * struct wpa_driver_ops::update_ft_ies() callback.
+	struct ft_ies {
+		const u8 *ies;
+		size_t ies_len;
+		int ft_action;
+		u8 target_ap[ETH_ALEN];
+		/** Optional IE(s), e.g., WMM TSPEC(s), for RIC-Request */
+		const u8 *ric_ies;
+		/** Length of ric_ies buffer in octets */
+		size_t ric_ies_len;
+	} ft_ies;
+	 * struct ibss_rsn_start - Data for EVENT_IBSS_RSN_START
+	struct ibss_rsn_start {
+	} ibss_rsn_start;
+	 * struct auth_info - Data for EVENT_AUTH events
+	struct auth_info {
+		u16 auth_type;
+		u16 auth_transaction;
+		u16 status_code;
+		const u8 *ies;
+		size_t ies_len;
+	} auth;
+	 * struct assoc_reject - Data for EVENT_ASSOC_REJECT events
+	struct assoc_reject {
+		 * bssid - BSSID of the AP that rejected association
+		const u8 *bssid;
+		 * interface.
+		 * status_code - Status Code from (Re)association Response
+		u16 status_code;
+	} assoc_reject;
+	struct timeout_event {
+	} timeout_event;
+	 * struct tx_status - Data for EVENT_TX_STATUS events
+	struct tx_status {
+		u16 type;
+		u16 stype;
+		const u8 *dst;
+		const u8 *data;
+		size_t data_len;
+		int ack;
+	} tx_status;
+	 * struct rx_from_unknown - Data for EVENT_RX_FROM_UNKNOWN events
+	struct rx_from_unknown {
+		const u8 *bssid;
+		const u8 *addr;
+		int wds;
+	} rx_from_unknown;
+	 * struct rx_mgmt - Data for EVENT_RX_MGMT events
+	struct rx_mgmt {
+		const u8 *frame;
+		size_t frame_len;
+		u32 datarate;
+		 * drv_priv - Pointer to store driver private BSS information
+		 * If not set to NULL, this is used for comparison with
+		 * hostapd_data->drv_priv to determine which BSS should process
+		 * the frame.
+		void *drv_priv;
+		 * freq - Frequency (in MHz) on which the frame was received
+		int freq;
+		 * ssi_signal - Signal strength in dBm (or 0 if not available)
+		int ssi_signal;
+	} rx_mgmt;
+	 * struct remain_on_channel - Data for EVENT_REMAIN_ON_CHANNEL events
+	 * This is also used with EVENT_CANCEL_REMAIN_ON_CHANNEL events.
+	struct remain_on_channel {
+		 * freq - Channel frequency in MHz
+		 * duration - Duration to remain on the channel in milliseconds
+		unsigned int duration;
+	} remain_on_channel;
+	 * struct scan_info - Optional data for EVENT_SCAN_RESULTS events
+	 * @aborted: Whether the scan was aborted
+	 * @freqs: Scanned frequencies in MHz (%NULL = all channels scanned)
+	 * @num_freqs: Number of entries in freqs array
+	 * @ssids: Scanned SSIDs (%NULL or zero-length SSID indicates wildcard
+	 *	SSID)
+	 * @num_ssids: Number of entries in ssids array
+	struct scan_info {
+		int aborted;
+		const int *freqs;
+		size_t num_freqs;
+		struct wpa_driver_scan_ssid ssids[WPAS_MAX_SCAN_SSIDS];
+		size_t num_ssids;
+	} scan_info;
+	 * struct rx_probe_req - Data for EVENT_RX_PROBE_REQ events
+	struct rx_probe_req {
+		 * sa - Source address of the received Probe Request frame
+		const u8 *sa;
+		 * da - Destination address of the received Probe Request frame
+		 *	or %NULL if not available
+		const u8 *da;
+		 * bssid - BSSID of the received Probe Request frame or %NULL
+		 *	if not available
+		const u8 *bssid;
+		 * ie - IEs from the Probe Request body
+		const u8 *ie;
+		size_t ie_len;
+		 * signal - signal strength in dBm (or 0 if not available)
+		int ssi_signal;
+	} rx_probe_req;
+	 * struct new_sta - Data for EVENT_NEW_STA events
+	struct new_sta {
+		const u8 *addr;
+	} new_sta;
+	 * struct eapol_rx - Data for EVENT_EAPOL_RX events
+	struct eapol_rx {
+		const u8 *src;
+		const u8 *data;
+		size_t data_len;
+	} eapol_rx;
+	 * signal_change - Data for EVENT_SIGNAL_CHANGE events
+	struct wpa_signal_info signal_change;
+	 * struct best_channel - Data for EVENT_BEST_CHANNEL events
+	 * @freq_24: Best 2.4 GHz band channel frequency in MHz
+	 * @freq_5: Best 5 GHz band channel frequency in MHz
+	 * @freq_overall: Best channel frequency in MHz
+	 * 0 can be used to indicate no preference in either band.
+	struct best_channel {
+		int freq_24;
+		int freq_5;
+		int freq_overall;
+	} best_chan;
+	struct unprot_deauth {
+		const u8 *sa;
+		const u8 *da;
+		u16 reason_code;
+	} unprot_deauth;
+	struct unprot_disassoc {
+		const u8 *sa;
+		const u8 *da;
+		u16 reason_code;
+	} unprot_disassoc;
+	 * struct low_ack - Data for EVENT_STATION_LOW_ACK events
+	 * @addr: station address
+	struct low_ack {
+	} low_ack;
+	 * struct ibss_peer_lost - Data for EVENT_IBSS_PEER_LOST
+	struct ibss_peer_lost {
+	} ibss_peer_lost;
+	 * struct driver_gtk_rekey - Data for EVENT_DRIVER_GTK_REKEY
+	struct driver_gtk_rekey {
+		const u8 *bssid;
+		const u8 *replay_ctr;
+	} driver_gtk_rekey;
+	 * struct client_poll - Data for EVENT_DRIVER_CLIENT_POLL_OK events
+	struct client_poll {
+	} client_poll;
+	 * struct eapol_tx_status
+	 * @dst: Original destination
+	 * @data: Data starting with IEEE 802.1X header (!)
+	 * @data_len: Length of data
+	 * @ack: Indicates ack or lost frame
+	 * This corresponds to hapd_send_eapol if the frame sent
+	 * there isn't just reported as EVENT_TX_STATUS.
+	struct eapol_tx_status {
+		const u8 *dst;
+		const u8 *data;
+		int data_len;
+		int ack;
+	} eapol_tx_status;
+	 * struct ch_switch
+	 * @freq: Frequency of new channel in MHz
+	 * @ht_enabled: Whether this is an HT channel
+	 * @ch_offset: Secondary channel offset
+	 * @ch_width: Channel width
+	 * @cf1: Center frequency 1
+	 * @cf2: Center frequency 2
+	struct ch_switch {
+		int freq;
+		int ht_enabled;
+		int ch_offset;
+		enum chan_width ch_width;
+		int cf1;
+		int cf2;
+	} ch_switch;
+	 * struct connect_failed - Data for EVENT_CONNECT_FAILED_REASON
+	 * @addr: Remote client address
+	 * @code: Reason code for connection failure
+	struct connect_failed_reason {
+		enum {
+			MAX_CLIENT_REACHED,
+			BLOCKED_CLIENT
+		} code;
+	} connect_failed_reason;
+	 * struct dfs_event - Data for radar detected events
+	 * @freq: Frequency of the channel in MHz
+	struct dfs_event {
+		int freq;
+		int ht_enabled;
+		int chan_offset;
+		enum chan_width chan_width;
+		int cf1;
+		int cf2;
+	} dfs_event;
+	 * survey_results - Survey result data for EVENT_SURVEY
+	 * @freq_filter: Requested frequency survey filter, 0 if request
+	 *	was for all survey data
+	 * @survey_list: Linked list of survey data (struct freq_survey)
+	struct survey_results {
+		unsigned int freq_filter;
+		struct dl_list survey_list; /* struct freq_survey */
+	} survey_results;
+	 * channel_list_changed - Data for EVENT_CHANNEL_LIST_CHANGED
+	 * @initiator: Initiator of the regulatory change
+	 * @type: Regulatory change type
+	 * @alpha2: Country code (or "" if not available)
+	struct channel_list_changed {
+		enum reg_change_initiator initiator;
+		enum reg_type type;
+		char alpha2[3];
+	} channel_list_changed;
+	 * freq_range - List of frequency ranges
+	 * This is used as the data with EVENT_AVOID_FREQUENCIES.
+	struct wpa_freq_range_list freq_range;
+	 * struct mesh_peer
+	 * @peer: Peer address
+	 * @ies: Beacon IEs
+	 * @ie_len: Length of @ies
+	 * Notification of new candidate mesh peer.
+	struct mesh_peer {
+		const u8 *peer;
+		const u8 *ies;
+		size_t ie_len;
+	} mesh_peer;
+	 * struct acs_selected_channels - Data for EVENT_ACS_CHANNEL_SELECTED
+	 * @pri_channel: Selected primary channel
+	 * @sec_channel: Selected secondary channel
+	 * @vht_seg0_center_ch: VHT mode Segment0 center channel
+	 * @vht_seg1_center_ch: VHT mode Segment1 center channel
+	 * @ch_width: Selected Channel width by driver. Driver may choose to
+	 *	change hostapd configured ACS channel width due driver internal
+	 *	channel restrictions.
+	 * hw_mode: Selected band (used with hw_mode=any)
+	struct acs_selected_channels {
+		u8 pri_channel;
+		u8 sec_channel;
+		u8 vht_seg0_center_ch;
+		u8 vht_seg1_center_ch;
+		u16 ch_width;
+		enum hostapd_hw_mode hw_mode;
+	} acs_selected_channels;
+ * wpa_supplicant_event - Report a driver event for wpa_supplicant
+ * @ctx: Context pointer (wpa_s); this is the ctx variable registered
+ *	with struct wpa_driver_ops::init()
+ * @event: event type (defined above)
+ * @data: possible extra data for the event
+ * Driver wrapper code should call this function whenever an event is received
+ * from the driver.
+void wpa_supplicant_event(void *ctx, enum wpa_event_type event,
+			  union wpa_event_data *data);
+ * The following inline functions are provided for convenience to simplify
+ * event indication for some of the common events.
+static inline void drv_event_assoc(void *ctx, const u8 *addr, const u8 *ie,
+				   size_t ielen, int reassoc)
+	union wpa_event_data event;
+	os_memset(&event, 0, sizeof(event));
+	event.assoc_info.reassoc = reassoc;
+	event.assoc_info.req_ies = ie;
+	event.assoc_info.req_ies_len = ielen;
+	event.assoc_info.addr = addr;
+	wpa_supplicant_event(ctx, EVENT_ASSOC, &event);
+static inline void drv_event_disassoc(void *ctx, const u8 *addr)
+	event.disassoc_info.addr = addr;
+	wpa_supplicant_event(ctx, EVENT_DISASSOC, &event);
+static inline void drv_event_eapol_rx(void *ctx, const u8 *src, const u8 *data,
+				      size_t data_len)
+	event.eapol_rx.src = src;
+	event.eapol_rx.data = data;
+	event.eapol_rx.data_len = data_len;
+	wpa_supplicant_event(ctx, EVENT_EAPOL_RX, &event);
+/* driver_common.c */
+void wpa_scan_results_free(struct wpa_scan_results *res);
+/* Convert wpa_event_type to a string for logging */
+const char * event_to_string(enum wpa_event_type event);
+/* Convert chan_width to a string for logging and control interfaces */
+const char * channel_width_to_string(enum chan_width width);
+int ht_supported(const struct hostapd_hw_modes *mode);
+int vht_supported(const struct hostapd_hw_modes *mode);
+struct wowlan_triggers *
+wpa_get_wowlan_triggers(const char *wowlan_triggers,
+			const struct wpa_driver_capa *capa);
+/* NULL terminated array of linked in driver wrappers */
+extern const struct wpa_driver_ops *const wpa_drivers[];
+#endif /* DRIVER_H */
diff --git a/freebsd/contrib/wpa/src/drivers/driver_bsd.c b/freebsd/contrib/wpa/src/drivers/driver_bsd.c
new file mode 100644
index 00000000000..5f6e129d05f
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver_bsd.c
@@ -0,0 +1,1675 @@
+#include <machine/rtems-bsd-user-space.h>
+ * WPA Supplicant - driver interaction with BSD net80211 layer
+ * Copyright (c) 2004, Sam Leffler <sam at errno.com>
+ * Copyright (c) 2004, 2Wire, Inc
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "includes.h"
+#include <sys/ioctl.h>
+#include <sys/sysctl.h>
+#include "common.h"
+#include "driver.h"
+#include "eloop.h"
+#include "common/ieee802_11_defs.h"
+#include "common/wpa_common.h"
+#include <net/if.h>
+#include <net/if_media.h>
+#ifdef __NetBSD__
+#include <net/if_ether.h>
+#else
+#include <net/ethernet.h>
+#endif
+#include <net/route.h>
+#ifdef __DragonFly__
+#include <netproto/802_11/ieee80211_ioctl.h>
+#include <netproto/802_11/ieee80211_dragonfly.h>
+#else /* __DragonFly__ */
+#ifdef __GLIBC__
+#include <netinet/ether.h>
+#endif /* __GLIBC__ */
+#include <net80211/ieee80211.h>
+#include <net80211/ieee80211_ioctl.h>
+#include <net80211/ieee80211_crypto.h>
+#endif /* __DragonFly__ || __GLIBC__ */
+#if defined(__FreeBSD__) || defined(__FreeBSD_kernel__)
+#include <net80211/ieee80211_freebsd.h>
+#endif
+#if __NetBSD__
+#include <net80211/ieee80211_netbsd.h>
+#endif
+#include "l2_packet/l2_packet.h"
+struct bsd_driver_data {
+	struct hostapd_data *hapd;	/* back pointer */
+	int	sock;			/* open socket for 802.11 ioctls */
+	struct l2_packet_data *sock_xmit;/* raw packet xmit socket */
+	int	route;			/* routing socket for events */
+	char	ifname[IFNAMSIZ+1];	/* interface name */
+	unsigned int ifindex;		/* interface index */
+	void	*ctx;
+	struct wpa_driver_capa capa;	/* driver capability */
+	int	is_ap;			/* Access point mode */
+	int	prev_roaming;	/* roaming state to restore on deinit */
+	int	prev_privacy;	/* privacy state to restore on deinit */
+	int	prev_wpa;	/* wpa state to restore on deinit */
+	enum ieee80211_opmode opmode;	/* operation mode */
+	char	*event_buf;
+	size_t	event_buf_len;
+/* Generic functions for hostapd and wpa_supplicant */
+static int
+bsd_set80211(void *priv, int op, int val, const void *arg, int arg_len)
+	struct bsd_driver_data *drv = priv;
+	struct ieee80211req ireq;
+	os_memset(&ireq, 0, sizeof(ireq));
+	os_strlcpy(ireq.i_name, drv->ifname, sizeof(ireq.i_name));
+	ireq.i_type = op;
+	ireq.i_val = val;
+	ireq.i_data = (void *) arg;
+	ireq.i_len = arg_len;
+	if (ioctl(drv->sock, SIOCS80211, &ireq) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCS80211, op=%u, val=%u, "
+			   "arg_len=%u]: %s", op, val, arg_len,
+			   strerror(errno));
+		return -1;
+	return 0;
+static int
+bsd_get80211(void *priv, struct ieee80211req *ireq, int op, void *arg,
+	     int arg_len)
+	os_memset(ireq, 0, sizeof(*ireq));
+	os_strlcpy(ireq->i_name, drv->ifname, sizeof(ireq->i_name));
+	ireq->i_type = op;
+	ireq->i_len = arg_len;
+	ireq->i_data = arg;
+	if (ioctl(drv->sock, SIOCG80211, ireq) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCS80211, op=%u, "
+			   "arg_len=%u]: %s", op, arg_len, strerror(errno));
+		return -1;
+	return 0;
+static int
+get80211var(struct bsd_driver_data *drv, int op, void *arg, int arg_len)
+	if (bsd_get80211(drv, &ireq, op, arg, arg_len) < 0)
+		return -1;
+	return ireq.i_len;
+static int
+set80211var(struct bsd_driver_data *drv, int op, const void *arg, int arg_len)
+	return bsd_set80211(drv, op, 0, arg, arg_len);
+static int
+set80211param(struct bsd_driver_data *drv, int op, int arg)
+	return bsd_set80211(drv, op, arg, NULL, 0);
+static int
+bsd_get_ssid(void *priv, u8 *ssid, int len)
+#ifdef SIOCG80211NWID
+	struct ieee80211_nwid nwid;
+	struct ifreq ifr;
+	os_memset(&ifr, 0, sizeof(ifr));
+	os_strlcpy(ifr.ifr_name, drv->ifname, sizeof(ifr.ifr_name));
+	ifr.ifr_data = (void *)&nwid;
+	if (ioctl(drv->sock, SIOCG80211NWID, &ifr) < 0 ||
+	    nwid.i_len > IEEE80211_NWID_LEN)
+		return -1;
+	os_memcpy(ssid, nwid.i_nwid, nwid.i_len);
+	return nwid.i_len;
+#else
+	return get80211var(drv, IEEE80211_IOC_SSID, ssid, IEEE80211_NWID_LEN);
+#endif
+static int
+bsd_set_ssid(void *priv, const u8 *ssid, int ssid_len)
+#ifdef SIOCS80211NWID
+	struct ifreq ifr;
+	os_memcpy(nwid.i_nwid, ssid, ssid_len);
+	nwid.i_len = ssid_len;
+	return ioctl(drv->sock, SIOCS80211NWID, &ifr);
+#else
+	return set80211var(drv, IEEE80211_IOC_SSID, ssid, ssid_len);
+#endif
+static int
+bsd_get_if_media(void *priv)
+	struct ifmediareq ifmr;
+	os_memset(&ifmr, 0, sizeof(ifmr));
+	os_strlcpy(ifmr.ifm_name, drv->ifname, sizeof(ifmr.ifm_name));
+	if (ioctl(drv->sock, SIOCGIFMEDIA, &ifmr) < 0) {
+		wpa_printf(MSG_ERROR, "%s: SIOCGIFMEDIA %s", __func__,
+			   strerror(errno));
+		return -1;
+	return ifmr.ifm_current;
+static int
+bsd_set_if_media(void *priv, int media)
+	struct ifreq ifr;
+	ifr.ifr_media = media;
+	if (ioctl(drv->sock, SIOCSIFMEDIA, &ifr) < 0) {
+		wpa_printf(MSG_ERROR, "%s: SIOCSIFMEDIA %s", __func__,
+			   strerror(errno));
+		return -1;
+	return 0;
+static int
+bsd_set_mediaopt(void *priv, uint32_t mask, uint32_t mode)
+	int media = bsd_get_if_media(priv);
+	if (media < 0)
+		return -1;
+	media &= ~mask;
+	media |= mode;
+	if (bsd_set_if_media(priv, media) < 0)
+		return -1;
+	return 0;
+static int
+bsd_del_key(void *priv, const u8 *addr, int key_idx)
+	struct ieee80211req_del_key wk;
+	os_memset(&wk, 0, sizeof(wk));
+	if (addr == NULL) {
+		wpa_printf(MSG_DEBUG, "%s: key_idx=%d", __func__, key_idx);
+		wk.idk_keyix = key_idx;
+	} else {
+		wpa_printf(MSG_DEBUG, "%s: addr=" MACSTR, __func__,
+			   MAC2STR(addr));
+		os_memcpy(wk.idk_macaddr, addr, IEEE80211_ADDR_LEN);
+		wk.idk_keyix = (u_int8_t) IEEE80211_KEYIX_NONE;	/* XXX */
+	return set80211var(priv, IEEE80211_IOC_DELKEY, &wk, sizeof(wk));
+static int
+bsd_send_mlme_param(void *priv, const u8 op, const u16 reason, const u8 *addr)
+	struct ieee80211req_mlme mlme;
+	os_memset(&mlme, 0, sizeof(mlme));
+	mlme.im_op = op;
+	mlme.im_reason = reason;
+	os_memcpy(mlme.im_macaddr, addr, IEEE80211_ADDR_LEN);
+	return set80211var(priv, IEEE80211_IOC_MLME, &mlme, sizeof(mlme));
+static int
+bsd_ctrl_iface(void *priv, int enable)
+	struct ifreq ifr;
+	if (ioctl(drv->sock, SIOCGIFFLAGS, &ifr) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCGIFFLAGS]: %s",
+			   strerror(errno));
+		return -1;
+	if (enable) {
+		if (ifr.ifr_flags & IFF_UP)
+			return 0;
+		ifr.ifr_flags |= IFF_UP;
+	} else {
+		if (!(ifr.ifr_flags & IFF_UP))
+			return 0;
+		ifr.ifr_flags &= ~IFF_UP;
+	if (ioctl(drv->sock, SIOCSIFFLAGS, &ifr) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCSIFFLAGS]: %s",
+			   strerror(errno));
+		return -1;
+	return 0;
+static int
+bsd_set_key(const char *ifname, void *priv, enum wpa_alg alg,
+	    const unsigned char *addr, int key_idx, int set_tx, const u8 *seq,
+	    size_t seq_len, const u8 *key, size_t key_len)
+	struct ieee80211req_key wk;
+#ifdef IEEE80211_KEY_NOREPLAY
+#endif /* IEEE80211_KEY_NOREPLAY */
+	wpa_printf(MSG_DEBUG, "%s: alg=%d addr=%p key_idx=%d set_tx=%d "
+		   "seq_len=%zu key_len=%zu", __func__, alg, addr, key_idx,
+		   set_tx, seq_len, key_len);
+	if (alg == WPA_ALG_NONE) {
+#ifndef HOSTAPD
+		if (addr == NULL || is_broadcast_ether_addr(addr))
+			return bsd_del_key(priv, NULL, key_idx);
+		else
+#endif /* HOSTAPD */
+			return bsd_del_key(priv, addr, key_idx);
+	switch (alg) {
+	case WPA_ALG_WEP:
+		wk.ik_type = IEEE80211_CIPHER_WEP;
+		break;
+	case WPA_ALG_TKIP:
+		wk.ik_type = IEEE80211_CIPHER_TKIP;
+		break;
+	case WPA_ALG_CCMP:
+		wk.ik_type = IEEE80211_CIPHER_AES_CCM;
+		break;
+	default:
+		wpa_printf(MSG_ERROR, "%s: unknown alg=%d", __func__, alg);
+		return -1;
+	wk.ik_flags = IEEE80211_KEY_RECV;
+	if (set_tx)
+		wk.ik_flags |= IEEE80211_KEY_XMIT;
+		os_memset(wk.ik_macaddr, 0xff, IEEE80211_ADDR_LEN);
+		wk.ik_keyix = key_idx;
+	} else {
+		os_memcpy(wk.ik_macaddr, addr, IEEE80211_ADDR_LEN);
+		 * Deduce whether group/global or unicast key by checking
+		 * the address (yech).  Note also that we can only mark global
+		 * keys default; doing this for a unicast key is an error.
+		if (is_broadcast_ether_addr(addr)) {
+			wk.ik_flags |= IEEE80211_KEY_GROUP;
+		} else {
+			wk.ik_keyix = key_idx == 0 ? IEEE80211_KEYIX_NONE :
+				key_idx;
+	if (wk.ik_keyix != IEEE80211_KEYIX_NONE && set_tx)
+		wk.ik_flags |= IEEE80211_KEY_DEFAULT;
+#ifndef HOSTAPD
+	 * Ignore replay failures in IBSS and AHDEMO mode.
+	if (drv->opmode == IEEE80211_M_IBSS ||
+	    drv->opmode == IEEE80211_M_AHDEMO)
+		wk.ik_flags |= IEEE80211_KEY_NOREPLAY;
+	wk.ik_keylen = key_len;
+	if (seq) {
+#ifdef WORDS_BIGENDIAN
+		 * wk.ik_keyrsc is in host byte order (big endian), need to
+		 * swap it to match with the byte order used in WPA.
+		int i;
+		u8 *keyrsc = (u8 *) &wk.ik_keyrsc;
+		for (i = 0; i < seq_len; i++)
+			keyrsc[WPA_KEY_RSC_LEN - i - 1] = seq[i];
+#else /* WORDS_BIGENDIAN */
+		os_memcpy(&wk.ik_keyrsc, seq, seq_len);
+#endif /* WORDS_BIGENDIAN */
+	os_memcpy(wk.ik_keydata, key, key_len);
+	return set80211var(priv, IEEE80211_IOC_WPAKEY, &wk, sizeof(wk));
+static int
+bsd_configure_wpa(void *priv, struct wpa_bss_params *params)
+#ifndef IEEE80211_IOC_APPIE
+	static const char *ciphernames[] =
+		{ "WEP", "TKIP", "AES-OCB", "AES-CCM", "CKIP", "NONE" };
+	int v;
+	switch (params->wpa_group) {
+	case WPA_CIPHER_CCMP:
+		v = IEEE80211_CIPHER_AES_CCM;
+		break;
+	case WPA_CIPHER_TKIP:
+		v = IEEE80211_CIPHER_TKIP;
+		break;
+	case WPA_CIPHER_WEP104:
+		v = IEEE80211_CIPHER_WEP;
+		break;
+	case WPA_CIPHER_WEP40:
+		break;
+	case WPA_CIPHER_NONE:
+		v = IEEE80211_CIPHER_NONE;
+		break;
+	default:
+		wpa_printf(MSG_INFO, "Unknown group key cipher %u",
+			   params->wpa_group);
+		return -1;
+	wpa_printf(MSG_DEBUG, "%s: group key cipher=%s (%u)",
+		   __func__, ciphernames[v], v);
+	if (set80211param(priv, IEEE80211_IOC_MCASTCIPHER, v)) {
+			   "Unable to set group key cipher to %u (%s)",
+			   v, ciphernames[v]);
+		return -1;
+	if (v == IEEE80211_CIPHER_WEP) {
+		/* key length is done only for specific ciphers */
+		v = (params->wpa_group == WPA_CIPHER_WEP104 ? 13 : 5);
+		if (set80211param(priv, IEEE80211_IOC_MCASTKEYLEN, v)) {
+				   "Unable to set group key length to %u", v);
+			return -1;
+	v = 0;
+	if (params->wpa_pairwise & WPA_CIPHER_CCMP)
+		v |= 1<<IEEE80211_CIPHER_AES_CCM;
+	if (params->wpa_pairwise & WPA_CIPHER_TKIP)
+		v |= 1<<IEEE80211_CIPHER_TKIP;
+	if (params->wpa_pairwise & WPA_CIPHER_NONE)
+		v |= 1<<IEEE80211_CIPHER_NONE;
+	wpa_printf(MSG_DEBUG, "%s: pairwise key ciphers=0x%x", __func__, v);
+	if (set80211param(priv, IEEE80211_IOC_UCASTCIPHERS, v)) {
+			   "Unable to set pairwise key ciphers to 0x%x", v);
+		return -1;
+	wpa_printf(MSG_DEBUG, "%s: key management algorithms=0x%x",
+		   __func__, params->wpa_key_mgmt);
+	if (set80211param(priv, IEEE80211_IOC_KEYMGTALGS,
+			  params->wpa_key_mgmt)) {
+			   "Unable to set key management algorithms to 0x%x",
+			   params->wpa_key_mgmt);
+		return -1;
+	v = 0;
+	if (params->rsn_preauth)
+		v |= BIT(0);
+	wpa_printf(MSG_DEBUG, "%s: rsn capabilities=0x%x",
+		   __func__, params->rsn_preauth);
+	if (set80211param(priv, IEEE80211_IOC_RSNCAPS, v)) {
+		wpa_printf(MSG_INFO, "Unable to set RSN capabilities to 0x%x",
+			   v);
+		return -1;
+#endif /* IEEE80211_IOC_APPIE */
+	wpa_printf(MSG_DEBUG, "%s: enable WPA= 0x%x", __func__, params->wpa);
+	if (set80211param(priv, IEEE80211_IOC_WPA, params->wpa)) {
+		wpa_printf(MSG_INFO, "Unable to set WPA to %u", params->wpa);
+		return -1;
+	return 0;
+static int
+bsd_set_ieee8021x(void *priv, struct wpa_bss_params *params)
+	wpa_printf(MSG_DEBUG, "%s: enabled=%d", __func__, params->enabled);
+	if (!params->enabled) {
+		/* XXX restore state */
+		return set80211param(priv, IEEE80211_IOC_AUTHMODE,
+				     IEEE80211_AUTH_AUTO);
+	if (!params->wpa && !params->ieee802_1x) {
+		wpa_printf(MSG_ERROR, "%s: No 802.1X or WPA enabled",
+			   __func__);
+		return -1;
+	if (params->wpa && bsd_configure_wpa(priv, params) != 0) {
+		wpa_printf(MSG_ERROR, "%s: Failed to configure WPA state",
+			   __func__);
+		return -1;
+	if (set80211param(priv, IEEE80211_IOC_AUTHMODE,
+		(params->wpa ? IEEE80211_AUTH_WPA : IEEE80211_AUTH_8021X))) {
+		wpa_printf(MSG_ERROR, "%s: Failed to enable WPA/802.1X",
+			   __func__);
+		return -1;
+	return bsd_ctrl_iface(priv, 1);
+static void
+bsd_new_sta(void *priv, void *ctx, u8 addr[IEEE80211_ADDR_LEN])
+	struct ieee80211req_wpaie ie;
+	int ielen = 0;
+	u8 *iebuf = NULL;
+	 * Fetch and validate any negotiated WPA/RSN parameters.
+	memset(&ie, 0, sizeof(ie));
+	memcpy(ie.wpa_macaddr, addr, IEEE80211_ADDR_LEN);
+	if (get80211var(priv, IEEE80211_IOC_WPAIE, &ie, sizeof(ie)) < 0) {
+			   "Failed to get WPA/RSN information element");
+		goto no_ie;
+	iebuf = ie.wpa_ie;
+	ielen = ie.wpa_ie[1];
+	if (ielen == 0)
+		iebuf = NULL;
+	else
+		ielen += 2;
+no_ie:
+	drv_event_assoc(ctx, addr, iebuf, ielen, 0);
+static int
+bsd_send_eapol(void *priv, const u8 *addr, const u8 *data, size_t data_len,
+	       int encrypt, const u8 *own_addr, u32 flags)
+	wpa_hexdump(MSG_MSGDUMP, "TX EAPOL", data, data_len);
+	return l2_packet_send(drv->sock_xmit, addr, ETH_P_EAPOL, data,
+			      data_len);
+static int
+bsd_set_freq(void *priv, struct hostapd_freq_params *freq)
+#ifdef SIOCS80211CHANNEL
+	struct ieee80211chanreq creq;
+#endif /* SIOCS80211CHANNEL */
+	u32 mode;
+	int channel = freq->channel;
+	if (channel < 14) {
+		mode =
+#ifdef CONFIG_IEEE80211N
+			freq->ht_enabled ? IFM_IEEE80211_11NG :
+#endif /* CONFIG_IEEE80211N */
+		        IFM_IEEE80211_11G;
+	} else if (channel == 14) {
+		mode = IFM_IEEE80211_11B;
+	} else {
+		mode =
+			freq->ht_enabled ? IFM_IEEE80211_11NA :
+			IFM_IEEE80211_11A;
+	if (bsd_set_mediaopt(drv, IFM_MMASK, mode) < 0) {
+		wpa_printf(MSG_ERROR, "%s: failed to set modulation mode",
+			   __func__);
+		return -1;
+	os_memset(&creq, 0, sizeof(creq));
+	os_strlcpy(creq.i_name, drv->ifname, sizeof(creq.i_name));
+	creq.i_channel = (u_int16_t)channel;
+	return ioctl(drv->sock, SIOCS80211CHANNEL, &creq);
+#else /* SIOCS80211CHANNEL */
+	return set80211param(priv, IEEE80211_IOC_CHANNEL, channel);
+static int
+bsd_set_opt_ie(void *priv, const u8 *ie, size_t ie_len)
+#ifdef IEEE80211_IOC_APPIE
+	wpa_printf(MSG_DEBUG, "%s: set WPA+RSN ie (len %lu)", __func__,
+		   (unsigned long)ie_len);
+	return bsd_set80211(priv, IEEE80211_IOC_APPIE, IEEE80211_APPIE_WPA,
+			    ie, ie_len);
+	return 0;
+static size_t
+rtbuf_len(void)
+	size_t len;
+	int mib[6] = {CTL_NET, AF_ROUTE, 0, AF_INET, NET_RT_DUMP, 0};
+	if (sysctl(mib, 6, NULL, &len, NULL, 0) < 0) {
+		wpa_printf(MSG_WARNING, "%s failed: %s", __func__,
+			   strerror(errno));
+		len = 2048;
+	return len;
+#ifdef HOSTAPD
+ * Avoid conflicts with hostapd definitions by undefining couple of defines
+ * from net80211 header files.
+#undef RSN_VERSION
+#undef WPA_VERSION
+#undef WPA_OUI_TYPE
+static int bsd_sta_deauth(void *priv, const u8 *own_addr, const u8 *addr,
+			  int reason_code);
+static const char *
+ether_sprintf(const u8 *addr)
+	static char buf[sizeof(MACSTR)];
+	if (addr != NULL)
+		snprintf(buf, sizeof(buf), MACSTR, MAC2STR(addr));
+	else
+		snprintf(buf, sizeof(buf), MACSTR, 0,0,0,0,0,0);
+	return buf;
+static int
+bsd_set_privacy(void *priv, int enabled)
+	wpa_printf(MSG_DEBUG, "%s: enabled=%d", __func__, enabled);
+	return set80211param(priv, IEEE80211_IOC_PRIVACY, enabled);
+static int
+bsd_get_seqnum(const char *ifname, void *priv, const u8 *addr, int idx,
+	       u8 *seq)
+	wpa_printf(MSG_DEBUG, "%s: addr=%s idx=%d",
+		   __func__, ether_sprintf(addr), idx);
+	memset(&wk, 0, sizeof(wk));
+	if (addr == NULL)
+		memset(wk.ik_macaddr, 0xff, IEEE80211_ADDR_LEN);
+	else
+		memcpy(wk.ik_macaddr, addr, IEEE80211_ADDR_LEN);
+	wk.ik_keyix = idx;
+	if (get80211var(priv, IEEE80211_IOC_WPAKEY, &wk, sizeof(wk)) < 0) {
+		wpa_printf(MSG_INFO, "Failed to get encryption");
+		return -1;
+		 * wk.ik_keytsc is in host byte order (big endian), need to
+		int i;
+		u8 tmp[WPA_KEY_RSC_LEN];
+		memcpy(tmp, &wk.ik_keytsc, sizeof(wk.ik_keytsc));
+		for (i = 0; i < WPA_KEY_RSC_LEN; i++) {
+			seq[i] = tmp[WPA_KEY_RSC_LEN - i - 1];
+	memcpy(seq, &wk.ik_keytsc, sizeof(wk.ik_keytsc));
+	return 0;
+static int
+bsd_flush(void *priv)
+	u8 allsta[IEEE80211_ADDR_LEN];
+	memset(allsta, 0xff, IEEE80211_ADDR_LEN);
+	return bsd_sta_deauth(priv, NULL, allsta, IEEE80211_REASON_AUTH_LEAVE);
+static int
+bsd_read_sta_driver_data(void *priv, struct hostap_sta_driver_data *data,
+			 const u8 *addr)
+	struct ieee80211req_sta_stats stats;
+	memcpy(stats.is_u.macaddr, addr, IEEE80211_ADDR_LEN);
+	if (get80211var(priv, IEEE80211_IOC_STA_STATS, &stats, sizeof(stats))
+	    > 0) {
+		/* XXX? do packets counts include non-data frames? */
+		data->rx_packets = stats.is_stats.ns_rx_data;
+		data->rx_bytes = stats.is_stats.ns_rx_bytes;
+		data->tx_packets = stats.is_stats.ns_tx_data;
+		data->tx_bytes = stats.is_stats.ns_tx_bytes;
+	return 0;
+static int
+bsd_sta_deauth(void *priv, const u8 *own_addr, const u8 *addr, int reason_code)
+	return bsd_send_mlme_param(priv, IEEE80211_MLME_DEAUTH, reason_code,
+				   addr);
+static int
+bsd_sta_disassoc(void *priv, const u8 *own_addr, const u8 *addr,
+		 int reason_code)
+	return bsd_send_mlme_param(priv, IEEE80211_MLME_DISASSOC, reason_code,
+				   addr);
+static void
+bsd_wireless_event_receive(int sock, void *ctx, void *sock_ctx)
+	struct bsd_driver_data *drv = ctx;
+	struct if_announcemsghdr *ifan;
+	struct rt_msghdr *rtm;
+	struct ieee80211_michael_event *mic;
+	struct ieee80211_join_event *join;
+	struct ieee80211_leave_event *leave;
+	int n;
+	union wpa_event_data data;
+	n = read(sock, drv->event_buf, drv->event_buf_len);
+	if (n < 0) {
+		if (errno != EINTR && errno != EAGAIN)
+			wpa_printf(MSG_ERROR, "%s read() failed: %s",
+				   __func__, strerror(errno));
+		return;
+	rtm = (struct rt_msghdr *) drv->event_buf;
+	if (rtm->rtm_version != RTM_VERSION) {
+		wpa_printf(MSG_DEBUG, "Invalid routing message version=%d",
+			   rtm->rtm_version);
+		return;
+	ifan = (struct if_announcemsghdr *) rtm;
+	switch (rtm->rtm_type) {
+	case RTM_IEEE80211:
+		switch (ifan->ifan_what) {
+		case RTM_IEEE80211_ASSOC:
+		case RTM_IEEE80211_REASSOC:
+		case RTM_IEEE80211_DISASSOC:
+		case RTM_IEEE80211_SCAN:
+			break;
+		case RTM_IEEE80211_LEAVE:
+			leave = (struct ieee80211_leave_event *) &ifan[1];
+			drv_event_disassoc(drv->hapd, leave->iev_addr);
+			break;
+		case RTM_IEEE80211_JOIN:
+#ifdef RTM_IEEE80211_REJOIN
+		case RTM_IEEE80211_REJOIN:
+#endif
+			join = (struct ieee80211_join_event *) &ifan[1];
+			bsd_new_sta(drv, drv->hapd, join->iev_addr);
+			break;
+		case RTM_IEEE80211_REPLAY:
+			/* ignore */
+			break;
+		case RTM_IEEE80211_MICHAEL:
+			mic = (struct ieee80211_michael_event *) &ifan[1];
+				"Michael MIC failure wireless event: "
+				"keyix=%u src_addr=" MACSTR, mic->iev_keyix,
+				MAC2STR(mic->iev_src));
+			os_memset(&data, 0, sizeof(data));
+			data.michael_mic_failure.unicast = 1;
+			data.michael_mic_failure.src = mic->iev_src;
+			wpa_supplicant_event(drv->hapd,
+					     EVENT_MICHAEL_MIC_FAILURE, &data);
+			break;
+		break;
+static void
+handle_read(void *ctx, const u8 *src_addr, const u8 *buf, size_t len)
+	drv_event_eapol_rx(drv->hapd, src_addr, buf, len);
+static void *
+bsd_init(struct hostapd_data *hapd, struct wpa_init_params *params)
+	struct bsd_driver_data *drv;
+	drv = os_zalloc(sizeof(struct bsd_driver_data));
+	if (drv == NULL) {
+		wpa_printf(MSG_ERROR, "Could not allocate memory for bsd driver data");
+		return NULL;
+	drv->event_buf_len = rtbuf_len();
+	drv->event_buf = os_malloc(drv->event_buf_len);
+	if (drv->event_buf == NULL) {
+		wpa_printf(MSG_ERROR, "%s: os_malloc() failed", __func__);
+		goto bad;
+	drv->hapd = hapd;
+	drv->sock = socket(PF_INET, SOCK_DGRAM, 0);
+	if (drv->sock < 0) {
+		wpa_printf(MSG_ERROR, "socket[PF_INET,SOCK_DGRAM]: %s",
+			   strerror(errno));
+		goto bad;
+	os_strlcpy(drv->ifname, params->ifname, sizeof(drv->ifname));
+	drv->sock_xmit = l2_packet_init(drv->ifname, NULL, ETH_P_EAPOL,
+					handle_read, drv, 0);
+	if (drv->sock_xmit == NULL)
+		goto bad;
+	if (l2_packet_get_own_addr(drv->sock_xmit, params->own_addr))
+		goto bad;
+	/* mark down during setup */
+	if (bsd_ctrl_iface(drv, 0) < 0)
+		goto bad;
+	drv->route = socket(PF_ROUTE, SOCK_RAW, 0);
+	if (drv->route < 0) {
+		wpa_printf(MSG_ERROR, "socket(PF_ROUTE,SOCK_RAW): %s",
+			   strerror(errno));
+		goto bad;
+	eloop_register_read_sock(drv->route, bsd_wireless_event_receive, drv,
+				 NULL);
+	if (bsd_set_mediaopt(drv, IFM_OMASK, IFM_IEEE80211_HOSTAP) < 0) {
+		wpa_printf(MSG_ERROR, "%s: failed to set operation mode",
+			   __func__);
+		goto bad;
+	return drv;
+bad:
+	if (drv->sock_xmit != NULL)
+		l2_packet_deinit(drv->sock_xmit);
+	if (drv->sock >= 0)
+		close(drv->sock);
+	os_free(drv->event_buf);
+	os_free(drv);
+	return NULL;
+static void
+bsd_deinit(void *priv)
+	if (drv->route >= 0) {
+		eloop_unregister_read_sock(drv->route);
+		close(drv->route);
+	bsd_ctrl_iface(drv, 0);
+		close(drv->sock);
+	os_free(drv);
+static int
+bsd_commit(void *priv)
+static int
+bsd_set_sta_authorized(void *priv, const u8 *addr,
+		       unsigned int total_flags, unsigned int flags_or,
+		       unsigned int flags_and)
+	int authorized = -1;
+	/* For now, only support setting Authorized flag */
+	if (flags_or & WPA_STA_AUTHORIZED)
+		authorized = 1;
+	if (!(flags_and & WPA_STA_AUTHORIZED))
+		authorized = 0;
+	if (authorized < 0)
+		return 0;
+	return bsd_send_mlme_param(priv, authorized ?
+				   IEEE80211_MLME_AUTHORIZE :
+				   IEEE80211_MLME_UNAUTHORIZE, 0, addr);
+#else /* HOSTAPD */
+static int
+get80211param(struct bsd_driver_data *drv, int op)
+	if (bsd_get80211(drv, &ireq, op, NULL, 0) < 0)
+		return -1;
+	return ireq.i_val;
+static int
+wpa_driver_bsd_get_bssid(void *priv, u8 *bssid)
+#ifdef SIOCG80211BSSID
+	struct ieee80211_bssid bs;
+	os_strlcpy(bs.i_name, drv->ifname, sizeof(bs.i_name));
+	if (ioctl(drv->sock, SIOCG80211BSSID, &bs) < 0)
+		return -1;
+	os_memcpy(bssid, bs.i_bssid, sizeof(bs.i_bssid));
+	return 0;
+#else
+	return get80211var(drv, IEEE80211_IOC_BSSID,
+		bssid, IEEE80211_ADDR_LEN) < 0 ? -1 : 0;
+#endif
+static int
+wpa_driver_bsd_get_ssid(void *priv, u8 *ssid)
+	return bsd_get_ssid(drv, ssid, 0);
+static int
+wpa_driver_bsd_set_wpa_ie(struct bsd_driver_data *drv, const u8 *wpa_ie,
+			  size_t wpa_ie_len)
+	return bsd_set_opt_ie(drv, wpa_ie, wpa_ie_len);
+#else /* IEEE80211_IOC_APPIE */
+	return set80211var(drv, IEEE80211_IOC_OPTIE, wpa_ie, wpa_ie_len);
+static int
+wpa_driver_bsd_set_wpa_internal(void *priv, int wpa, int privacy)
+	int ret = 0;
+	wpa_printf(MSG_DEBUG, "%s: wpa=%d privacy=%d",
+		__FUNCTION__, wpa, privacy);
+	if (!wpa && wpa_driver_bsd_set_wpa_ie(priv, NULL, 0) < 0)
+		ret = -1;
+	if (set80211param(priv, IEEE80211_IOC_PRIVACY, privacy) < 0)
+		ret = -1;
+	if (set80211param(priv, IEEE80211_IOC_WPA, wpa) < 0)
+		ret = -1;
+	return ret;
+static int
+wpa_driver_bsd_set_wpa(void *priv, int enabled)
+	wpa_printf(MSG_DEBUG, "%s: enabled=%d", __FUNCTION__, enabled);
+	return wpa_driver_bsd_set_wpa_internal(priv, enabled ? 3 : 0, enabled);
+static int
+wpa_driver_bsd_set_countermeasures(void *priv, int enabled)
+	return set80211param(priv, IEEE80211_IOC_COUNTERMEASURES, enabled);
+static int
+wpa_driver_bsd_set_drop_unencrypted(void *priv, int enabled)
+	return set80211param(priv, IEEE80211_IOC_DROPUNENCRYPTED, enabled);
+static int
+wpa_driver_bsd_deauthenticate(void *priv, const u8 *addr, int reason_code)
+				   addr);
+static int
+wpa_driver_bsd_set_auth_alg(void *priv, int auth_alg)
+	int authmode;
+	if ((auth_alg & WPA_AUTH_ALG_OPEN) &&
+	    (auth_alg & WPA_AUTH_ALG_SHARED))
+		authmode = IEEE80211_AUTH_AUTO;
+	else if (auth_alg & WPA_AUTH_ALG_SHARED)
+		authmode = IEEE80211_AUTH_SHARED;
+	else
+		authmode = IEEE80211_AUTH_OPEN;
+	return set80211param(priv, IEEE80211_IOC_AUTHMODE, authmode);
+static void
+	drv_event_eapol_rx(drv->ctx, src_addr, buf, len);
+static int
+wpa_driver_bsd_associate(void *priv, struct wpa_driver_associate_params *params)
+	u32 mode;
+	int privacy;
+	int ret = 0;
+		"%s: ssid '%.*s' wpa ie len %u pairwise %u group %u key mgmt %u"
+		, __func__
+		   , (unsigned int) params->ssid_len, params->ssid
+		, (unsigned int) params->wpa_ie_len
+		, params->pairwise_suite
+		, params->group_suite
+		, params->key_mgmt_suite
+	switch (params->mode) {
+	case IEEE80211_MODE_INFRA:
+		mode = 0 /* STA */;
+		break;
+	case IEEE80211_MODE_IBSS:
+		 * Ref bin/203086 - FreeBSD's net80211 currently uses
+		 * IFM_IEEE80211_ADHOC.
+#if 0
+		mode = IFM_IEEE80211_IBSS;
+#endif
+		mode = IFM_IEEE80211_ADHOC;
+		break;
+	case IEEE80211_MODE_AP:
+		mode = IFM_IEEE80211_HOSTAP;
+		break;
+	default:
+		wpa_printf(MSG_ERROR, "%s: unknown operation mode", __func__);
+		return -1;
+	if (bsd_set_mediaopt(drv, IFM_OMASK, mode) < 0) {
+			   __func__);
+		return -1;
+	if (params->mode == IEEE80211_MODE_AP) {
+			return -1;
+		drv->is_ap = 1;
+		return 0;
+	if (wpa_driver_bsd_set_drop_unencrypted(drv, params->drop_unencrypted)
+	    < 0)
+		ret = -1;
+	if (wpa_driver_bsd_set_auth_alg(drv, params->auth_alg) < 0)
+		ret = -1;
+	/* XXX error handling is wrong but unclear what to do... */
+	if (wpa_driver_bsd_set_wpa_ie(drv, params->wpa_ie, params->wpa_ie_len) < 0)
+		return -1;
+	privacy = !(params->pairwise_suite == WPA_CIPHER_NONE &&
+	    params->group_suite == WPA_CIPHER_NONE &&
+	    params->key_mgmt_suite == WPA_KEY_MGMT_NONE &&
+	    params->wpa_ie_len == 0);
+	wpa_printf(MSG_DEBUG, "%s: set PRIVACY %u", __func__, privacy);
+	if (set80211param(drv, IEEE80211_IOC_PRIVACY, privacy) < 0)
+		return -1;
+	if (params->wpa_ie_len &&
+	    set80211param(drv, IEEE80211_IOC_WPA,
+			  params->wpa_ie[0] == WLAN_EID_RSN ? 2 : 1) < 0)
+		return -1;
+	 * NB: interface must be marked UP for association
+	 * or scanning (ap_scan=2)
+	if (bsd_ctrl_iface(drv, 1) < 0)
+		return -1;
+	mlme.im_op = IEEE80211_MLME_ASSOC;
+	if (params->ssid != NULL)
+		os_memcpy(mlme.im_ssid, params->ssid, params->ssid_len);
+	mlme.im_ssid_len = params->ssid_len;
+	if (params->bssid != NULL)
+		os_memcpy(mlme.im_macaddr, params->bssid, IEEE80211_ADDR_LEN);
+	if (set80211var(drv, IEEE80211_IOC_MLME, &mlme, sizeof(mlme)) < 0)
+		return -1;
+	return ret;
+static int
+wpa_driver_bsd_scan(void *priv, struct wpa_driver_scan_params *params)
+#ifdef IEEE80211_IOC_SCAN_MAX_SSID
+	struct ieee80211_scan_req sr;
+	int i;
+#endif /* IEEE80211_IOC_SCAN_MAX_SSID */
+	if (bsd_set_mediaopt(drv, IFM_OMASK, 0 /* STA */) < 0) {
+			   __func__);
+		return -1;
+	if (set80211param(drv, IEEE80211_IOC_ROAMING,
+			  IEEE80211_ROAMING_MANUAL) < 0) {
+		wpa_printf(MSG_ERROR, "%s: failed to set "
+			   "wpa_supplicant-based roaming: %s", __func__,
+			   strerror(errno));
+		return -1;
+	if (wpa_driver_bsd_set_wpa(drv, 1) < 0) {
+		wpa_printf(MSG_ERROR, "%s: failed to set wpa: %s", __func__,
+			   strerror(errno));
+		return -1;
+	/* NB: interface must be marked UP to do a scan */
+		return -1;
+	os_memset(&sr, 0, sizeof(sr));
+	sr.sr_flags = IEEE80211_IOC_SCAN_ACTIVE | IEEE80211_IOC_SCAN_ONCE |
+		IEEE80211_IOC_SCAN_NOJOIN;
+	sr.sr_duration = IEEE80211_IOC_SCAN_FOREVER;
+	if (params->num_ssids > 0) {
+		sr.sr_nssid = params->num_ssids;
+#if 0
+		/* Boundary check is done by upper layer */
+		if (sr.sr_nssid > IEEE80211_IOC_SCAN_MAX_SSID)
+			sr.sr_nssid = IEEE80211_IOC_SCAN_MAX_SSID;
+#endif
+		/* NB: check scan cache first */
+		sr.sr_flags |= IEEE80211_IOC_SCAN_CHECK;
+	for (i = 0; i < sr.sr_nssid; i++) {
+		sr.sr_ssid[i].len = params->ssids[i].ssid_len;
+		os_memcpy(sr.sr_ssid[i].ssid, params->ssids[i].ssid,
+			  sr.sr_ssid[i].len);
+	/* NB: net80211 delivers a scan complete event so no need to poll */
+	return set80211var(drv, IEEE80211_IOC_SCAN_REQ, &sr, sizeof(sr));
+#else /* IEEE80211_IOC_SCAN_MAX_SSID */
+	/* set desired ssid before scan */
+	if (bsd_set_ssid(drv, params->ssids[0].ssid,
+			 params->ssids[0].ssid_len) < 0)
+		return -1;
+	return set80211param(drv, IEEE80211_IOC_SCAN_REQ, 0);
+static void
+wpa_driver_bsd_event_receive(int sock, void *ctx, void *sock_ctx)
+	struct bsd_driver_data *drv = sock_ctx;
+	struct if_msghdr *ifm;
+	int n;
+	if (n < 0) {
+		return;
+		return;
+	case RTM_IFANNOUNCE:
+		if (ifan->ifan_index != drv->ifindex)
+			break;
+		os_strlcpy(event.interface_status.ifname, drv->ifname,
+			   sizeof(event.interface_status.ifname));
+		case IFAN_DEPARTURE:
+			event.interface_status.ievent = EVENT_INTERFACE_REMOVED;
+		default:
+			return;
+		wpa_printf(MSG_DEBUG, "RTM_IFANNOUNCE: Interface '%s' %s",
+			   event.interface_status.ifname,
+			   ifan->ifan_what == IFAN_DEPARTURE ?
+				"removed" : "added");
+		wpa_supplicant_event(ctx, EVENT_INTERFACE_STATUS, &event);
+		break;
+			break;
+			if (drv->is_ap)
+				break;
+			wpa_supplicant_event(ctx, EVENT_ASSOC, NULL);
+			break;
+			if (drv->is_ap)
+				break;
+			wpa_supplicant_event(ctx, EVENT_DISASSOC, NULL);
+			break;
+			if (drv->is_ap)
+				break;
+			wpa_supplicant_event(ctx, EVENT_SCAN_RESULTS, NULL);
+			break;
+			drv_event_disassoc(ctx, leave->iev_addr);
+			break;
+#endif
+			bsd_new_sta(drv, ctx, join->iev_addr);
+			break;
+			/* ignore */
+			break;
+			event.michael_mic_failure.unicast =
+				!IEEE80211_IS_MULTICAST(mic->iev_dst);
+			wpa_supplicant_event(ctx, EVENT_MICHAEL_MIC_FAILURE,
+				&event);
+			break;
+		break;
+	case RTM_IFINFO:
+		ifm = (struct if_msghdr *) rtm;
+		if (ifm->ifm_index != drv->ifindex)
+			break;
+		if ((rtm->rtm_flags & RTF_UP) == 0) {
+			wpa_printf(MSG_DEBUG, "RTM_IFINFO: Interface '%s' DOWN",
+				   event.interface_status.ifname);
+		break;
+static void
+wpa_driver_bsd_add_scan_entry(struct wpa_scan_results *res,
+			      struct ieee80211req_scan_result *sr)
+	struct wpa_scan_res *result, **tmp;
+	size_t extra_len;
+	u8 *pos;
+	extra_len = 2 + sr->isr_ssid_len;
+	extra_len += 2 + sr->isr_nrates;
+	extra_len += 3; /* ERP IE */
+	extra_len += sr->isr_ie_len;
+	result = os_zalloc(sizeof(*result) + extra_len);
+	if (result == NULL)
+		return;
+	os_memcpy(result->bssid, sr->isr_bssid, ETH_ALEN);
+	result->freq = sr->isr_freq;
+	result->beacon_int = sr->isr_intval;
+	result->caps = sr->isr_capinfo;
+	result->qual = sr->isr_rssi;
+	result->noise = sr->isr_noise;
+	 * the rssi value reported by the kernel is in 0.5dB steps relative to
+	 * the reported noise floor. see ieee80211_node.h for details.
+	result->level = sr->isr_rssi / 2 + sr->isr_noise;
+	pos = (u8 *)(result + 1);
+	*pos++ = WLAN_EID_SSID;
+	*pos++ = sr->isr_ssid_len;
+	os_memcpy(pos, sr + 1, sr->isr_ssid_len);
+	pos += sr->isr_ssid_len;
+	 * Deal all rates as supported rate.
+	 * Because net80211 doesn't report extended supported rate or not.
+	*pos++ = WLAN_EID_SUPP_RATES;
+	*pos++ = sr->isr_nrates;
+	os_memcpy(pos, sr->isr_rates, sr->isr_nrates);
+	pos += sr->isr_nrates;
+	*pos++ = WLAN_EID_ERP_INFO;
+	*pos++ = 1;
+	*pos++ = sr->isr_erp;
+#if defined(__DragonFly__) || defined(__FreeBSD__) || defined(__FreeBSD_kernel__)
+	os_memcpy(pos, (u8 *)(sr + 1) + sr->isr_ssid_len + sr->isr_meshid_len,
+		  sr->isr_ie_len);
+#else
+	os_memcpy(pos, (u8 *)(sr + 1) + sr->isr_ssid_len, sr->isr_ie_len);
+#endif
+	pos += sr->isr_ie_len;
+	result->ie_len = pos - (u8 *)(result + 1);
+	tmp = os_realloc_array(res->res, res->num + 1,
+			       sizeof(struct wpa_scan_res *));
+	if (tmp == NULL) {
+		os_free(result);
+		return;
+	tmp[res->num++] = result;
+	res->res = tmp;
+struct wpa_scan_results *
+wpa_driver_bsd_get_scan_results2(void *priv)
+	struct ieee80211req_scan_result *sr;
+	struct wpa_scan_results *res;
+	int len, rest;
+	uint8_t buf[24*1024], *pos;
+	len = get80211var(priv, IEEE80211_IOC_SCAN_RESULTS, buf, 24*1024);
+	if (len < 0)
+		return NULL;
+	res = os_zalloc(sizeof(*res));
+	if (res == NULL)
+		return NULL;
+	pos = buf;
+	rest = len;
+	while (rest >= sizeof(struct ieee80211req_scan_result)) {
+		sr = (struct ieee80211req_scan_result *)pos;
+		wpa_driver_bsd_add_scan_entry(res, sr);
+		pos += sr->isr_len;
+		rest -= sr->isr_len;
+	wpa_printf(MSG_DEBUG, "Received %d bytes of scan results (%lu BSSes)",
+		   len, (unsigned long)res->num);
+	return res;
+static int wpa_driver_bsd_capa(struct bsd_driver_data *drv)
+#ifdef IEEE80211_IOC_DEVCAPS
+/* kernel definitions copied from net80211/ieee80211_var.h */
+#define IEEE80211_CIPHER_WEP            0
+#define IEEE80211_CIPHER_TKIP           1
+#define IEEE80211_CIPHER_AES_CCM        3
+#define IEEE80211_CRYPTO_WEP            (1<<IEEE80211_CIPHER_WEP)
+#define IEEE80211_CRYPTO_TKIP           (1<<IEEE80211_CIPHER_TKIP)
+#define IEEE80211_CRYPTO_AES_CCM        (1<<IEEE80211_CIPHER_AES_CCM)
+#define IEEE80211_C_HOSTAP      0x00000400      /* CAPABILITY: HOSTAP avail */
+#define IEEE80211_C_WPA1        0x00800000      /* CAPABILITY: WPA1 avail */
+#define IEEE80211_C_WPA2        0x01000000      /* CAPABILITY: WPA2 avail */
+	struct ieee80211_devcaps_req devcaps;
+	if (get80211var(drv, IEEE80211_IOC_DEVCAPS, &devcaps,
+			sizeof(devcaps)) < 0) {
+		wpa_printf(MSG_ERROR, "failed to IEEE80211_IOC_DEVCAPS: %s",
+			   strerror(errno));
+		return -1;
+	wpa_printf(MSG_DEBUG, "%s: drivercaps=0x%08x,cryptocaps=0x%08x",
+		   __func__, devcaps.dc_drivercaps, devcaps.dc_cryptocaps);
+	if (devcaps.dc_drivercaps & IEEE80211_C_WPA1)
+		drv->capa.key_mgmt = WPA_DRIVER_CAPA_KEY_MGMT_WPA |
+			WPA_DRIVER_CAPA_KEY_MGMT_WPA_PSK;
+	if (devcaps.dc_drivercaps & IEEE80211_C_WPA2)
+		drv->capa.key_mgmt = WPA_DRIVER_CAPA_KEY_MGMT_WPA2 |
+			WPA_DRIVER_CAPA_KEY_MGMT_WPA2_PSK;
+#ifdef __FreeBSD__
+	drv->capa.enc |= WPA_DRIVER_CAPA_ENC_WEP40 |
+	    WPA_DRIVER_CAPA_ENC_WEP104 |
+	    WPA_DRIVER_CAPA_ENC_TKIP |
+	    WPA_DRIVER_CAPA_ENC_CCMP;
+#else
+	 * XXX
+	 * FreeBSD exports hardware cryptocaps.  These have no meaning for wpa
+	 * since net80211 performs software crypto.
+	if (devcaps.dc_cryptocaps & IEEE80211_CRYPTO_WEP)
+			WPA_DRIVER_CAPA_ENC_WEP104;
+	if (devcaps.dc_cryptocaps & IEEE80211_CRYPTO_TKIP)
+		drv->capa.enc |= WPA_DRIVER_CAPA_ENC_TKIP;
+	if (devcaps.dc_cryptocaps & IEEE80211_CRYPTO_AES_CCM)
+		drv->capa.enc |= WPA_DRIVER_CAPA_ENC_CCMP;
+#endif
+	if (devcaps.dc_drivercaps & IEEE80211_C_HOSTAP)
+		drv->capa.flags |= WPA_DRIVER_FLAGS_AP;
+#undef IEEE80211_CIPHER_WEP
+#undef IEEE80211_CIPHER_TKIP
+#undef IEEE80211_CIPHER_AES_CCM
+#undef IEEE80211_CRYPTO_WEP
+#undef IEEE80211_CRYPTO_TKIP
+#undef IEEE80211_CRYPTO_AES_CCM
+#undef IEEE80211_C_HOSTAP
+#undef IEEE80211_C_WPA1
+#undef IEEE80211_C_WPA2
+#else /* IEEE80211_IOC_DEVCAPS */
+	/* For now, assume TKIP, CCMP, WPA, WPA2 are supported */
+		WPA_DRIVER_CAPA_KEY_MGMT_WPA_PSK |
+		WPA_DRIVER_CAPA_KEY_MGMT_WPA2 |
+	drv->capa.enc = WPA_DRIVER_CAPA_ENC_WEP40 |
+#endif /* IEEE80211_IOC_DEVCAPS */
+	drv->capa.max_scan_ssids = IEEE80211_IOC_SCAN_MAX_SSID;
+	drv->capa.max_scan_ssids = 1;
+	drv->capa.auth = WPA_DRIVER_AUTH_OPEN |
+		WPA_DRIVER_AUTH_SHARED |
+		WPA_DRIVER_AUTH_LEAP;
+	return 0;
+static enum ieee80211_opmode
+get80211opmode(struct bsd_driver_data *drv)
+	(void) memset(&ifmr, 0, sizeof(ifmr));
+	(void) os_strlcpy(ifmr.ifm_name, drv->ifname, sizeof(ifmr.ifm_name));
+	if (ioctl(drv->sock, SIOCGIFMEDIA, (caddr_t)&ifmr) >= 0) {
+		if (ifmr.ifm_current & IFM_IEEE80211_ADHOC) {
+			if (ifmr.ifm_current & IFM_FLAG0)
+				return IEEE80211_M_AHDEMO;
+			else
+				return IEEE80211_M_IBSS;
+		if (ifmr.ifm_current & IFM_IEEE80211_HOSTAP)
+			return IEEE80211_M_HOSTAP;
+		if (ifmr.ifm_current & IFM_IEEE80211_IBSS)
+		if (ifmr.ifm_current & IFM_IEEE80211_MONITOR)
+			return IEEE80211_M_MONITOR;
+#ifdef IEEE80211_M_MBSS
+		if (ifmr.ifm_current & IFM_IEEE80211_MBSS)
+			return IEEE80211_M_MBSS;
+#endif /* IEEE80211_M_MBSS */
+	return IEEE80211_M_STA;
+static void *
+wpa_driver_bsd_init(void *ctx, const char *ifname)
+#define	GETPARAM(drv, param, v) \
+	(((v) = get80211param(drv, param)) != -1)
+	drv = os_zalloc(sizeof(*drv));
+	if (drv == NULL)
+		return NULL;
+		goto fail1;
+	 * NB: We require the interface name be mappable to an index.
+	 *     This implies we do not support having wpa_supplicant
+	 *     wait for an interface to appear.  This seems ok; that
+	 *     doesn't belong here; it's really the job of devd.
+	drv->ifindex = if_nametoindex(ifname);
+	if (drv->ifindex == 0) {
+		wpa_printf(MSG_DEBUG, "%s: interface %s does not exist",
+			   __func__, ifname);
+		goto fail1;
+		goto fail1;
+	os_strlcpy(drv->ifname, ifname, sizeof(drv->ifname));
+	/* Down interface during setup. */
+		goto fail;
+		goto fail;
+		wpa_driver_bsd_event_receive, ctx, drv);
+	drv->ctx = ctx;
+	if (!GETPARAM(drv, IEEE80211_IOC_ROAMING, drv->prev_roaming)) {
+		wpa_printf(MSG_DEBUG, "%s: failed to get roaming state: %s",
+		goto fail;
+	if (!GETPARAM(drv, IEEE80211_IOC_PRIVACY, drv->prev_privacy)) {
+		wpa_printf(MSG_DEBUG, "%s: failed to get privacy state: %s",
+		goto fail;
+	if (!GETPARAM(drv, IEEE80211_IOC_WPA, drv->prev_wpa)) {
+		wpa_printf(MSG_DEBUG, "%s: failed to get wpa state: %s",
+		goto fail;
+	if (wpa_driver_bsd_capa(drv))
+		goto fail;
+	drv->opmode = get80211opmode(drv);
+	return drv;
+fail:
+	close(drv->sock);
+fail1:
+	os_free(drv);
+	return NULL;
+#undef GETPARAM
+static void
+wpa_driver_bsd_deinit(void *priv)
+	wpa_driver_bsd_set_wpa(drv, 0);
+	/* NB: mark interface down */
+	wpa_driver_bsd_set_wpa_internal(drv, drv->prev_wpa, drv->prev_privacy);
+	if (set80211param(drv, IEEE80211_IOC_ROAMING, drv->prev_roaming) < 0)
+		wpa_printf(MSG_DEBUG, "%s: failed to restore roaming state",
+			__func__);
+	(void) close(drv->route);		/* ioctl socket */
+	(void) close(drv->sock);		/* event socket */
+	os_free(drv);
+static int
+wpa_driver_bsd_get_capa(void *priv, struct wpa_driver_capa *capa)
+	os_memcpy(capa, &drv->capa, sizeof(*capa));
+	return 0;
+const struct wpa_driver_ops wpa_driver_bsd_ops = {
+	.name			= "bsd",
+	.desc			= "BSD 802.11 support",
+#ifdef HOSTAPD
+	.hapd_init		= bsd_init,
+	.hapd_deinit		= bsd_deinit,
+	.set_privacy		= bsd_set_privacy,
+	.get_seqnum		= bsd_get_seqnum,
+	.flush			= bsd_flush,
+	.read_sta_data		= bsd_read_sta_driver_data,
+	.sta_disassoc		= bsd_sta_disassoc,
+	.sta_deauth		= bsd_sta_deauth,
+	.sta_set_flags		= bsd_set_sta_authorized,
+	.commit			= bsd_commit,
+	.init			= wpa_driver_bsd_init,
+	.deinit			= wpa_driver_bsd_deinit,
+	.get_bssid		= wpa_driver_bsd_get_bssid,
+	.get_ssid		= wpa_driver_bsd_get_ssid,
+	.set_countermeasures	= wpa_driver_bsd_set_countermeasures,
+	.scan2			= wpa_driver_bsd_scan,
+	.get_scan_results2	= wpa_driver_bsd_get_scan_results2,
+	.deauthenticate		= wpa_driver_bsd_deauthenticate,
+	.associate		= wpa_driver_bsd_associate,
+	.get_capa		= wpa_driver_bsd_get_capa,
+	.set_freq		= bsd_set_freq,
+	.set_key		= bsd_set_key,
+	.set_ieee8021x		= bsd_set_ieee8021x,
+	.hapd_set_ssid		= bsd_set_ssid,
+	.hapd_get_ssid		= bsd_get_ssid,
+	.hapd_send_eapol	= bsd_send_eapol,
+	.set_generic_elem	= bsd_set_opt_ie,
diff --git a/freebsd/contrib/wpa/src/drivers/driver_common.c b/freebsd/contrib/wpa/src/drivers/driver_common.c
index 00000000000..28f483e935e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver_common.c
@@ -0,0 +1,222 @@
+ * Common driver-related functions
+ * Copyright (c) 2003-2011, Jouni Malinen <j at w1.fi>
+#include "utils/common.h"
+	size_t i;
+	if (res == NULL)
+		return;
+	for (i = 0; i < res->num; i++)
+		os_free(res->res[i]);
+	os_free(res->res);
+	os_free(res);
+#define E2S(n) case EVENT_ ## n: return #n
+	switch (event) {
+	E2S(ASSOC);
+	E2S(DISASSOC);
+	E2S(MICHAEL_MIC_FAILURE);
+	E2S(SCAN_RESULTS);
+	E2S(ASSOCINFO);
+	E2S(INTERFACE_STATUS);
+	E2S(PMKID_CANDIDATE);
+	E2S(STKSTART);
+	E2S(TDLS);
+	E2S(FT_RESPONSE);
+	E2S(IBSS_RSN_START);
+	E2S(AUTH);
+	E2S(DEAUTH);
+	E2S(ASSOC_REJECT);
+	E2S(AUTH_TIMED_OUT);
+	E2S(ASSOC_TIMED_OUT);
+	E2S(WPS_BUTTON_PUSHED);
+	E2S(TX_STATUS);
+	E2S(RX_FROM_UNKNOWN);
+	E2S(RX_MGMT);
+	E2S(REMAIN_ON_CHANNEL);
+	E2S(CANCEL_REMAIN_ON_CHANNEL);
+	E2S(RX_PROBE_REQ);
+	E2S(NEW_STA);
+	E2S(EAPOL_RX);
+	E2S(SIGNAL_CHANGE);
+	E2S(INTERFACE_ENABLED);
+	E2S(INTERFACE_DISABLED);
+	E2S(CHANNEL_LIST_CHANGED);
+	E2S(INTERFACE_UNAVAILABLE);
+	E2S(BEST_CHANNEL);
+	E2S(UNPROT_DEAUTH);
+	E2S(UNPROT_DISASSOC);
+	E2S(STATION_LOW_ACK);
+	E2S(IBSS_PEER_LOST);
+	E2S(DRIVER_GTK_REKEY);
+	E2S(SCHED_SCAN_STOPPED);
+	E2S(DRIVER_CLIENT_POLL_OK);
+	E2S(EAPOL_TX_STATUS);
+	E2S(CH_SWITCH);
+	E2S(WNM);
+	E2S(CONNECT_FAILED_REASON);
+	E2S(DFS_RADAR_DETECTED);
+	E2S(DFS_CAC_FINISHED);
+	E2S(DFS_CAC_ABORTED);
+	E2S(DFS_NOP_FINISHED);
+	E2S(SURVEY);
+	E2S(SCAN_STARTED);
+	E2S(AVOID_FREQUENCIES);
+	E2S(NEW_PEER_CANDIDATE);
+	E2S(ACS_CHANNEL_SELECTED);
+	E2S(DFS_CAC_STARTED);
+	return "UNKNOWN";
+#undef E2S
+	switch (width) {
+	case CHAN_WIDTH_20_NOHT:
+		return "20 MHz (no HT)";
+	case CHAN_WIDTH_20:
+		return "20 MHz";
+	case CHAN_WIDTH_40:
+		return "40 MHz";
+	case CHAN_WIDTH_80:
+		return "80 MHz";
+	case CHAN_WIDTH_80P80:
+		return "80+80 MHz";
+	case CHAN_WIDTH_160:
+		return "160 MHz";
+	default:
+		return "unknown";
+	if (!(mode->flags & HOSTAPD_MODE_FLAG_HT_INFO_KNOWN)) {
+		 * The driver did not indicate whether it supports HT. Assume
+		 * it does to avoid connection issues.
+		return 1;
+	 * IEEE Std 802.11n-2009 20.1.1:
+	 * An HT non-AP STA shall support all EQM rates for one spatial stream.
+	return mode->mcs_set[0] == 0xff;
+	if (!(mode->flags & HOSTAPD_MODE_FLAG_VHT_INFO_KNOWN)) {
+		 * The driver did not indicate whether it supports VHT. Assume
+		return 1;
+	 * A VHT non-AP STA shall support MCS 0-7 for one spatial stream.
+	 * TODO: Verify if this complies with the standard
+	return (mode->vht_mcs_set[0] & 0x3) != 3;
+static int wpa_check_wowlan_trigger(const char *start, const char *trigger,
+				    int capa_trigger, u8 *param_trigger)
+	if (os_strcmp(start, trigger) != 0)
+		return 0;
+	if (!capa_trigger)
+		return 0;
+	*param_trigger = 1;
+	return 1;
+	struct wowlan_triggers *triggers;
+	char *start, *end, *buf;
+	int last;
+	if (!wowlan_triggers)
+		return NULL;
+	buf = os_strdup(wowlan_triggers);
+	if (buf == NULL)
+		return NULL;
+	triggers = os_zalloc(sizeof(*triggers));
+	if (triggers == NULL)
+		goto out;
+#define CHECK_TRIGGER(trigger) \
+	wpa_check_wowlan_trigger(start, #trigger,			\
+				  capa->wowlan_triggers.trigger,	\
+				  &triggers->trigger)
+	start = buf;
+	while (*start != '\0') {
+		while (isblank(*start))
+			start++;
+		if (*start == '\0')
+			break;
+		end = start;
+		while (!isblank(*end) && *end != '\0')
+			end++;
+		last = *end == '\0';
+		*end = '\0';
+		if (!CHECK_TRIGGER(any) &&
+		    !CHECK_TRIGGER(disconnect) &&
+		    !CHECK_TRIGGER(magic_pkt) &&
+		    !CHECK_TRIGGER(gtk_rekey_failure) &&
+		    !CHECK_TRIGGER(eap_identity_req) &&
+		    !CHECK_TRIGGER(four_way_handshake) &&
+		    !CHECK_TRIGGER(rfkill_release)) {
+				   "Unknown/unsupported wowlan trigger '%s'",
+				   start);
+			os_free(triggers);
+			triggers = NULL;
+			goto out;
+		if (last)
+			break;
+		start = end + 1;
+#undef CHECK_TRIGGER
+out:
+	os_free(buf);
+	return triggers;
diff --git a/freebsd/contrib/wpa/src/drivers/driver_ndis.c b/freebsd/contrib/wpa/src/drivers/driver_ndis.c
index 00000000000..6b3b26bc5c6
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver_ndis.c
@@ -0,0 +1,3221 @@
+ * WPA Supplicant - Windows/NDIS driver interface
+ * Copyright (c) 2004-2007, Jouni Malinen <j at w1.fi>
+#ifdef __CYGWIN__
+/* Avoid some header file conflicts by not including standard headers for
+ * cygwin builds when Packet32.h is included. */
+#include "build_config.h"
+int close(int fd);
+#else /* __CYGWIN__ */
+#endif /* __CYGWIN__ */
+#ifdef CONFIG_USE_NDISUIO
+#include <winsock2.h>
+#else /* CONFIG_USE_NDISUIO */
+#include <Packet32.h>
+#endif /* CONFIG_USE_NDISUIO */
+#ifdef __MINGW32_VERSION
+#include <ddk/ntddndis.h>
+#else /* __MINGW32_VERSION */
+#include <ntddndis.h>
+#endif /* __MINGW32_VERSION */
+#ifdef _WIN32_WCE
+#include <winioctl.h>
+#include <nuiouser.h>
+#include <devload.h>
+#endif /* _WIN32_WCE */
+#include "eloop.h"
+#include "driver_ndis.h"
+int wpa_driver_register_event_cb(struct wpa_driver_ndis_data *drv);
+#ifdef CONFIG_NDIS_EVENTS_INTEGRATED
+void wpa_driver_ndis_event_pipe_cb(void *eloop_data, void *user_data);
+#endif /* CONFIG_NDIS_EVENTS_INTEGRATED */
+static void wpa_driver_ndis_deinit(void *priv);
+static void wpa_driver_ndis_poll(void *drv);
+static void wpa_driver_ndis_poll_timeout(void *eloop_ctx, void *timeout_ctx);
+static int wpa_driver_ndis_adapter_init(struct wpa_driver_ndis_data *drv);
+static int wpa_driver_ndis_adapter_open(struct wpa_driver_ndis_data *drv);
+static void wpa_driver_ndis_adapter_close(struct wpa_driver_ndis_data *drv);
+static const u8 pae_group_addr[ETH_ALEN] =
+{ 0x01, 0x80, 0xc2, 0x00, 0x00, 0x03 };
+/* FIX: to be removed once this can be compiled with the complete NDIS
+ * header files */
+#ifndef OID_802_11_BSSID
+#define OID_802_3_MULTICAST_LIST                0x01010103
+#define OID_802_11_BSSID 			0x0d010101
+#define OID_802_11_SSID 			0x0d010102
+#define OID_802_11_INFRASTRUCTURE_MODE		0x0d010108
+#define OID_802_11_ADD_WEP			0x0D010113
+#define OID_802_11_REMOVE_WEP			0x0D010114
+#define OID_802_11_DISASSOCIATE			0x0D010115
+#define OID_802_11_BSSID_LIST 			0x0d010217
+#define OID_802_11_AUTHENTICATION_MODE		0x0d010118
+#define OID_802_11_PRIVACY_FILTER		0x0d010119
+#define OID_802_11_BSSID_LIST_SCAN 		0x0d01011A
+#define OID_802_11_WEP_STATUS	 		0x0d01011B
+#define OID_802_11_ENCRYPTION_STATUS OID_802_11_WEP_STATUS
+#define OID_802_11_ADD_KEY 			0x0d01011D
+#define OID_802_11_REMOVE_KEY 			0x0d01011E
+#define OID_802_11_ASSOCIATION_INFORMATION	0x0d01011F
+#define OID_802_11_TEST 			0x0d010120
+#define OID_802_11_CAPABILITY 			0x0d010122
+#define OID_802_11_PMKID 			0x0d010123
+#define NDIS_802_11_LENGTH_SSID 32
+#define NDIS_802_11_LENGTH_RATES 8
+#define NDIS_802_11_LENGTH_RATES_EX 16
+typedef UCHAR NDIS_802_11_MAC_ADDRESS[6];
+typedef struct NDIS_802_11_SSID {
+	ULONG SsidLength;
+	UCHAR Ssid[NDIS_802_11_LENGTH_SSID];
+} NDIS_802_11_SSID;
+typedef LONG NDIS_802_11_RSSI;
+typedef enum NDIS_802_11_NETWORK_TYPE {
+	Ndis802_11FH,
+	Ndis802_11DS,
+	Ndis802_11OFDM5,
+	Ndis802_11OFDM24,
+	Ndis802_11NetworkTypeMax
+} NDIS_802_11_NETWORK_TYPE;
+typedef struct NDIS_802_11_CONFIGURATION_FH {
+	ULONG Length;
+	ULONG HopPattern;
+	ULONG HopSet;
+	ULONG DwellTime;
+} NDIS_802_11_CONFIGURATION_FH;
+typedef struct NDIS_802_11_CONFIGURATION {
+	ULONG Length;
+	ULONG BeaconPeriod;
+	ULONG ATIMWindow;
+	ULONG DSConfig;
+	NDIS_802_11_CONFIGURATION_FH FHConfig;
+} NDIS_802_11_CONFIGURATION;
+typedef enum NDIS_802_11_NETWORK_INFRASTRUCTURE {
+	Ndis802_11IBSS,
+	Ndis802_11Infrastructure,
+	Ndis802_11AutoUnknown,
+	Ndis802_11InfrastructureMax
+} NDIS_802_11_NETWORK_INFRASTRUCTURE;
+typedef enum NDIS_802_11_AUTHENTICATION_MODE {
+	Ndis802_11AuthModeOpen,
+	Ndis802_11AuthModeShared,
+	Ndis802_11AuthModeAutoSwitch,
+	Ndis802_11AuthModeWPA,
+	Ndis802_11AuthModeWPAPSK,
+	Ndis802_11AuthModeWPANone,
+	Ndis802_11AuthModeWPA2,
+	Ndis802_11AuthModeWPA2PSK,
+	Ndis802_11AuthModeMax
+} NDIS_802_11_AUTHENTICATION_MODE;
+typedef enum NDIS_802_11_WEP_STATUS {
+	Ndis802_11WEPEnabled,
+	Ndis802_11Encryption1Enabled = Ndis802_11WEPEnabled,
+	Ndis802_11WEPDisabled,
+	Ndis802_11EncryptionDisabled = Ndis802_11WEPDisabled,
+	Ndis802_11WEPKeyAbsent,
+	Ndis802_11Encryption1KeyAbsent = Ndis802_11WEPKeyAbsent,
+	Ndis802_11WEPNotSupported,
+	Ndis802_11EncryptionNotSupported = Ndis802_11WEPNotSupported,
+	Ndis802_11Encryption2Enabled,
+	Ndis802_11Encryption2KeyAbsent,
+	Ndis802_11Encryption3Enabled,
+	Ndis802_11Encryption3KeyAbsent
+} NDIS_802_11_WEP_STATUS, NDIS_802_11_ENCRYPTION_STATUS;
+typedef enum NDIS_802_11_PRIVACY_FILTER {
+	Ndis802_11PrivFilterAcceptAll,
+	Ndis802_11PrivFilter8021xWEP
+} NDIS_802_11_PRIVACY_FILTER;
+typedef UCHAR NDIS_802_11_RATES[NDIS_802_11_LENGTH_RATES];
+typedef UCHAR NDIS_802_11_RATES_EX[NDIS_802_11_LENGTH_RATES_EX];
+typedef struct NDIS_WLAN_BSSID_EX {
+	ULONG Length;
+	NDIS_802_11_MAC_ADDRESS MacAddress; /* BSSID */
+	UCHAR Reserved[2];
+	NDIS_802_11_SSID Ssid;
+	ULONG Privacy;
+	NDIS_802_11_RSSI Rssi;
+	NDIS_802_11_NETWORK_TYPE NetworkTypeInUse;
+	NDIS_802_11_CONFIGURATION Configuration;
+	NDIS_802_11_NETWORK_INFRASTRUCTURE InfrastructureMode;
+	NDIS_802_11_RATES_EX SupportedRates;
+	ULONG IELength;
+	UCHAR IEs[1];
+} NDIS_WLAN_BSSID_EX;
+typedef struct NDIS_802_11_BSSID_LIST_EX {
+	ULONG NumberOfItems;
+	NDIS_WLAN_BSSID_EX Bssid[1];
+} NDIS_802_11_BSSID_LIST_EX;
+typedef struct NDIS_802_11_FIXED_IEs {
+	UCHAR Timestamp[8];
+	USHORT BeaconInterval;
+	USHORT Capabilities;
+} NDIS_802_11_FIXED_IEs;
+typedef struct NDIS_802_11_WEP {
+	ULONG Length;
+	ULONG KeyIndex;
+	ULONG KeyLength;
+	UCHAR KeyMaterial[1];
+} NDIS_802_11_WEP;
+typedef ULONG NDIS_802_11_KEY_INDEX;
+typedef ULONGLONG NDIS_802_11_KEY_RSC;
+typedef struct NDIS_802_11_KEY {
+	ULONG Length;
+	ULONG KeyIndex;
+	ULONG KeyLength;
+	NDIS_802_11_MAC_ADDRESS BSSID;
+	NDIS_802_11_KEY_RSC KeyRSC;
+} NDIS_802_11_KEY;
+typedef struct NDIS_802_11_REMOVE_KEY {
+	ULONG Length;
+	ULONG KeyIndex;
+} NDIS_802_11_REMOVE_KEY;
+typedef struct NDIS_802_11_AI_REQFI {
+	USHORT ListenInterval;
+	NDIS_802_11_MAC_ADDRESS CurrentAPAddress;
+} NDIS_802_11_AI_REQFI;
+typedef struct NDIS_802_11_AI_RESFI {
+	USHORT StatusCode;
+	USHORT AssociationId;
+} NDIS_802_11_AI_RESFI;
+typedef struct NDIS_802_11_ASSOCIATION_INFORMATION {
+	ULONG Length;
+	USHORT AvailableRequestFixedIEs;
+	NDIS_802_11_AI_REQFI RequestFixedIEs;
+	ULONG RequestIELength;
+	ULONG OffsetRequestIEs;
+	USHORT AvailableResponseFixedIEs;
+	NDIS_802_11_AI_RESFI ResponseFixedIEs;
+	ULONG ResponseIELength;
+	ULONG OffsetResponseIEs;
+} NDIS_802_11_ASSOCIATION_INFORMATION;
+typedef struct NDIS_802_11_AUTHENTICATION_ENCRYPTION {
+	NDIS_802_11_AUTHENTICATION_MODE AuthModeSupported;
+	NDIS_802_11_ENCRYPTION_STATUS EncryptStatusSupported;
+} NDIS_802_11_AUTHENTICATION_ENCRYPTION;
+typedef struct NDIS_802_11_CAPABILITY {
+	ULONG Length;
+	ULONG Version;
+	ULONG NoOfPMKIDs;
+	ULONG NoOfAuthEncryptPairsSupported;
+	NDIS_802_11_AUTHENTICATION_ENCRYPTION
+		AuthenticationEncryptionSupported[1];
+} NDIS_802_11_CAPABILITY;
+typedef UCHAR NDIS_802_11_PMKID_VALUE[16];
+typedef struct BSSID_INFO {
+	NDIS_802_11_PMKID_VALUE PMKID;
+} BSSID_INFO;
+typedef struct NDIS_802_11_PMKID {
+	ULONG Length;
+	ULONG BSSIDInfoCount;
+	BSSID_INFO BSSIDInfo[1];
+} NDIS_802_11_PMKID;
+typedef enum NDIS_802_11_STATUS_TYPE {
+	Ndis802_11StatusType_Authentication,
+	Ndis802_11StatusType_PMKID_CandidateList = 2,
+	Ndis802_11StatusTypeMax
+} NDIS_802_11_STATUS_TYPE;
+typedef struct NDIS_802_11_STATUS_INDICATION {
+	NDIS_802_11_STATUS_TYPE StatusType;
+} NDIS_802_11_STATUS_INDICATION;
+typedef struct PMKID_CANDIDATE {
+	ULONG Flags;
+} PMKID_CANDIDATE;
+#define NDIS_802_11_PMKID_CANDIDATE_PREAUTH_ENABLED 0x01
+typedef struct NDIS_802_11_PMKID_CANDIDATE_LIST {
+	ULONG Version;
+	ULONG NumCandidates;
+	PMKID_CANDIDATE CandidateList[1];
+} NDIS_802_11_PMKID_CANDIDATE_LIST;
+typedef struct NDIS_802_11_AUTHENTICATION_REQUEST {
+	ULONG Length;
+	NDIS_802_11_MAC_ADDRESS Bssid;
+	ULONG Flags;
+} NDIS_802_11_AUTHENTICATION_REQUEST;
+#define NDIS_802_11_AUTH_REQUEST_REAUTH			0x01
+#define NDIS_802_11_AUTH_REQUEST_KEYUPDATE		0x02
+#define NDIS_802_11_AUTH_REQUEST_PAIRWISE_ERROR		0x06
+#define NDIS_802_11_AUTH_REQUEST_GROUP_ERROR		0x0E
+#endif /* OID_802_11_BSSID */
+#ifndef OID_802_11_PMKID
+/* Platform SDK for XP did not include WPA2, so add needed definitions */
+#define Ndis802_11AuthModeWPA2 6
+#define Ndis802_11AuthModeWPA2PSK 7
+#define Ndis802_11StatusType_PMKID_CandidateList 2
+	ULONG Length;
+	ULONG Version;
+	ULONG NoOfPMKIDs;
+} BSSID_INFO;
+	ULONG Length;
+	ULONG Flags;
+} PMKID_CANDIDATE;
+	ULONG Version;
+#endif /* OID_802_11_CAPABILITY */
+#ifndef OID_DOT11_CURRENT_OPERATION_MODE
+/* Native 802.11 OIDs */
+#define OID_DOT11_NDIS_START 0x0D010300
+#define OID_DOT11_CURRENT_OPERATION_MODE (OID_DOT11_NDIS_START + 8)
+#define OID_DOT11_SCAN_REQUEST (OID_DOT11_NDIS_START + 11)
+typedef enum _DOT11_BSS_TYPE {
+	dot11_BSS_type_infrastructure = 1,
+	dot11_BSS_type_independent = 2,
+	dot11_BSS_type_any = 3
+} DOT11_BSS_TYPE, * PDOT11_BSS_TYPE;
+typedef UCHAR DOT11_MAC_ADDRESS[6];
+typedef DOT11_MAC_ADDRESS * PDOT11_MAC_ADDRESS;
+typedef enum _DOT11_SCAN_TYPE {
+	dot11_scan_type_active = 1,
+	dot11_scan_type_passive = 2,
+	dot11_scan_type_auto = 3,
+	dot11_scan_type_forced = 0x80000000
+} DOT11_SCAN_TYPE, * PDOT11_SCAN_TYPE;
+typedef struct _DOT11_SCAN_REQUEST_V2 {
+	DOT11_BSS_TYPE dot11BSSType;
+	DOT11_MAC_ADDRESS dot11BSSID;
+	DOT11_SCAN_TYPE dot11ScanType;
+	BOOLEAN bRestrictedScan;
+	ULONG udot11SSIDsOffset;
+	ULONG uNumOfdot11SSIDs;
+	BOOLEAN bUseRequestIE;
+	ULONG uRequestIDsOffset;
+	ULONG uNumOfRequestIDs;
+	ULONG uPhyTypeInfosOffset;
+	ULONG uNumOfPhyTypeInfos;
+	ULONG uIEsOffset;
+	ULONG uIEsLength;
+	UCHAR ucBuffer[1];
+} DOT11_SCAN_REQUEST_V2, * PDOT11_SCAN_REQUEST_V2;
+#endif /* OID_DOT11_CURRENT_OPERATION_MODE */
+#ifndef _WIN32_WCE
+typedef ULONG NDIS_OID;
+/* from nuiouser.h */
+#define FSCTL_NDISUIO_BASE      FILE_DEVICE_NETWORK
+#define _NDISUIO_CTL_CODE(_Function, _Method, _Access) \
+	CTL_CODE(FSCTL_NDISUIO_BASE, _Function, _Method, _Access)
+#define IOCTL_NDISUIO_OPEN_DEVICE \
+	_NDISUIO_CTL_CODE(0x200, METHOD_BUFFERED, \
+			  FILE_READ_ACCESS | FILE_WRITE_ACCESS)
+#define IOCTL_NDISUIO_QUERY_OID_VALUE \
+	_NDISUIO_CTL_CODE(0x201, METHOD_BUFFERED, \
+#define IOCTL_NDISUIO_SET_OID_VALUE \
+	_NDISUIO_CTL_CODE(0x205, METHOD_BUFFERED, \
+#define IOCTL_NDISUIO_SET_ETHER_TYPE \
+	_NDISUIO_CTL_CODE(0x202, METHOD_BUFFERED, \
+#define IOCTL_NDISUIO_QUERY_BINDING \
+	_NDISUIO_CTL_CODE(0x203, METHOD_BUFFERED, \
+#define IOCTL_NDISUIO_BIND_WAIT \
+	_NDISUIO_CTL_CODE(0x204, METHOD_BUFFERED, \
+typedef struct _NDISUIO_QUERY_OID
+    NDIS_OID Oid;
+    UCHAR Data[sizeof(ULONG)];
+} NDISUIO_QUERY_OID, *PNDISUIO_QUERY_OID;
+typedef struct _NDISUIO_SET_OID
+    NDIS_OID Oid;
+} NDISUIO_SET_OID, *PNDISUIO_SET_OID;
+typedef struct _NDISUIO_QUERY_BINDING
+	ULONG BindingIndex;
+	ULONG DeviceNameOffset;
+	ULONG DeviceNameLength;
+	ULONG DeviceDescrOffset;
+	ULONG DeviceDescrLength;
+} NDISUIO_QUERY_BINDING, *PNDISUIO_QUERY_BINDING;
+static int ndis_get_oid(struct wpa_driver_ndis_data *drv, unsigned int oid,
+			char *data, size_t len)
+	NDISUIO_QUERY_OID *o;
+	size_t buflen = sizeof(*o) + len;
+	DWORD written;
+	int ret;
+	size_t hdrlen;
+	o = os_zalloc(buflen);
+	if (o == NULL)
+		return -1;
+	o->Oid = oid;
+#ifdef _WIN32_WCE
+	o->ptcDeviceName = drv->adapter_name;
+	if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_QUERY_OID_VALUE,
+			     o, sizeof(NDISUIO_QUERY_OID), o, buflen, &written,
+			     NULL)) {
+		wpa_printf(MSG_DEBUG, "NDIS: IOCTL_NDISUIO_QUERY_OID_VALUE "
+			   "failed (oid=%08x): %d", oid, (int) GetLastError());
+		os_free(o);
+		return -1;
+	hdrlen = sizeof(NDISUIO_QUERY_OID) - sizeof(o->Data);
+	if (written < hdrlen) {
+		wpa_printf(MSG_DEBUG, "NDIS: query oid=%08x written (%d); "
+			   "too short", oid, (unsigned int) written);
+		os_free(o);
+		return -1;
+	written -= hdrlen;
+	if (written > len) {
+		wpa_printf(MSG_DEBUG, "NDIS: query oid=%08x written (%d) > "
+			   "len (%d)",oid, (unsigned int) written, len);
+		os_free(o);
+		return -1;
+	os_memcpy(data, o->Data, written);
+	ret = written;
+	os_free(o);
+	return ret;
+	char *buf;
+	PACKET_OID_DATA *o;
+	int ret;
+	buf = os_zalloc(sizeof(*o) + len);
+	if (buf == NULL)
+		return -1;
+	o = (PACKET_OID_DATA *) buf;
+	o->Oid = oid;
+	o->Length = len;
+	if (!PacketRequest(drv->adapter, FALSE, o)) {
+		wpa_printf(MSG_DEBUG, "%s: oid=0x%x len (%d) failed",
+			   __func__, oid, len);
+		os_free(buf);
+		return -1;
+	if (o->Length > len) {
+		wpa_printf(MSG_DEBUG, "%s: oid=0x%x Length (%d) > len (%d)",
+			   __func__, oid, (unsigned int) o->Length, len);
+		os_free(buf);
+		return -1;
+	os_memcpy(data, o->Data, o->Length);
+	ret = o->Length;
+	os_free(buf);
+	return ret;
+static int ndis_set_oid(struct wpa_driver_ndis_data *drv, unsigned int oid,
+			const char *data, size_t len)
+	NDISUIO_SET_OID *o;
+	size_t buflen, reallen;
+	DWORD written;
+	char txt[50];
+	os_snprintf(txt, sizeof(txt), "NDIS: Set OID %08x", oid);
+	wpa_hexdump_key(MSG_MSGDUMP, txt, (const u8 *) data, len);
+	buflen = sizeof(*o) + len;
+	reallen = buflen - sizeof(o->Data);
+	if (o == NULL)
+		return -1;
+	o->Oid = oid;
+#ifdef _WIN32_WCE
+	if (data)
+		os_memcpy(o->Data, data, len);
+	if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_SET_OID_VALUE,
+			     o, reallen, NULL, 0, &written, NULL)) {
+		wpa_printf(MSG_DEBUG, "NDIS: IOCTL_NDISUIO_SET_OID_VALUE "
+			   "(oid=%08x) failed: %d", oid, (int) GetLastError());
+		os_free(o);
+		return -1;
+	os_free(o);
+	return 0;
+	char *buf;
+	char txt[50];
+	if (buf == NULL)
+		return -1;
+	o->Oid = oid;
+	o->Length = len;
+	if (data)
+	if (!PacketRequest(drv->adapter, TRUE, o)) {
+		os_free(buf);
+		return -1;
+	os_free(buf);
+	return 0;
+static int ndis_set_auth_mode(struct wpa_driver_ndis_data *drv, int mode)
+	u32 auth_mode = mode;
+	if (ndis_set_oid(drv, OID_802_11_AUTHENTICATION_MODE,
+			 (char *) &auth_mode, sizeof(auth_mode)) < 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: Failed to set "
+			   "OID_802_11_AUTHENTICATION_MODE (%d)",
+			   (int) auth_mode);
+		return -1;
+	return 0;
+static int ndis_get_auth_mode(struct wpa_driver_ndis_data *drv)
+	u32 auth_mode;
+	int res;
+	res = ndis_get_oid(drv, OID_802_11_AUTHENTICATION_MODE,
+			   (char *) &auth_mode, sizeof(auth_mode));
+	if (res != sizeof(auth_mode)) {
+		wpa_printf(MSG_DEBUG, "NDIS: Failed to get "
+			   "OID_802_11_AUTHENTICATION_MODE");
+		return -1;
+	return auth_mode;
+static int ndis_set_encr_status(struct wpa_driver_ndis_data *drv, int encr)
+	u32 encr_status = encr;
+	if (ndis_set_oid(drv, OID_802_11_ENCRYPTION_STATUS,
+			 (char *) &encr_status, sizeof(encr_status)) < 0) {
+			   "OID_802_11_ENCRYPTION_STATUS (%d)", encr);
+		return -1;
+	return 0;
+static int ndis_get_encr_status(struct wpa_driver_ndis_data *drv)
+	u32 encr;
+	int res;
+	res = ndis_get_oid(drv, OID_802_11_ENCRYPTION_STATUS,
+			   (char *) &encr, sizeof(encr));
+	if (res != sizeof(encr)) {
+			   "OID_802_11_ENCRYPTION_STATUS");
+		return -1;
+	return encr;
+static int wpa_driver_ndis_get_bssid(void *priv, u8 *bssid)
+	struct wpa_driver_ndis_data *drv = priv;
+	if (drv->wired) {
+		 * Report PAE group address as the "BSSID" for wired
+		 * connection.
+		os_memcpy(bssid, pae_group_addr, ETH_ALEN);
+		return 0;
+	return ndis_get_oid(drv, OID_802_11_BSSID, (char *) bssid, ETH_ALEN) <
+		0 ? -1 : 0;
+static int wpa_driver_ndis_get_ssid(void *priv, u8 *ssid)
+	NDIS_802_11_SSID buf;
+	int res;
+	res = ndis_get_oid(drv, OID_802_11_SSID, (char *) &buf, sizeof(buf));
+	if (res < 4) {
+		wpa_printf(MSG_DEBUG, "NDIS: Failed to get SSID");
+		if (drv->wired) {
+			wpa_printf(MSG_DEBUG, "NDIS: Allow get_ssid failure "
+				   "with a wired interface");
+			return 0;
+		return -1;
+	os_memcpy(ssid, buf.Ssid, buf.SsidLength);
+	return buf.SsidLength;
+static int wpa_driver_ndis_set_ssid(struct wpa_driver_ndis_data *drv,
+				    const u8 *ssid, size_t ssid_len)
+	os_memset(&buf, 0, sizeof(buf));
+	buf.SsidLength = ssid_len;
+	os_memcpy(buf.Ssid, ssid, ssid_len);
+	 * Make sure radio is marked enabled here so that scan request will not
+	 * force SSID to be changed to a random one in order to enable radio at
+	 * that point.
+	drv->radio_enabled = 1;
+	return ndis_set_oid(drv, OID_802_11_SSID, (char *) &buf, sizeof(buf));
+/* Disconnect using OID_802_11_DISASSOCIATE. This will also turn the radio off.
+static int wpa_driver_ndis_radio_off(struct wpa_driver_ndis_data *drv)
+	drv->radio_enabled = 0;
+	return ndis_set_oid(drv, OID_802_11_DISASSOCIATE, "    ", 4);
+/* Disconnect by setting SSID to random (i.e., likely not used). */
+static int wpa_driver_ndis_disconnect(struct wpa_driver_ndis_data *drv)
+	char ssid[SSID_MAX_LEN];
+	int i;
+	for (i = 0; i < SSID_MAX_LEN; i++)
+		ssid[i] = rand() & 0xff;
+	return wpa_driver_ndis_set_ssid(drv, (u8 *) ssid, SSID_MAX_LEN);
+static int wpa_driver_ndis_deauthenticate(void *priv, const u8 *addr,
+					  int reason_code)
+	return wpa_driver_ndis_disconnect(drv);
+static void wpa_driver_ndis_scan_timeout(void *eloop_ctx, void *timeout_ctx)
+	wpa_printf(MSG_DEBUG, "Scan timeout - try to get results");
+	wpa_supplicant_event(timeout_ctx, EVENT_SCAN_RESULTS, NULL);
+static int wpa_driver_ndis_scan_native80211(
+	struct wpa_driver_ndis_data *drv,
+	struct wpa_driver_scan_params *params)
+	DOT11_SCAN_REQUEST_V2 req;
+	int res;
+	os_memset(&req, 0, sizeof(req));
+	req.dot11BSSType = dot11_BSS_type_any;
+	os_memset(req.dot11BSSID, 0xff, ETH_ALEN);
+	req.dot11ScanType = dot11_scan_type_auto;
+	res = ndis_set_oid(drv, OID_DOT11_SCAN_REQUEST, (char *) &req,
+			   sizeof(req));
+	eloop_cancel_timeout(wpa_driver_ndis_scan_timeout, drv, drv->ctx);
+	eloop_register_timeout(7, 0, wpa_driver_ndis_scan_timeout, drv,
+			       drv->ctx);
+	return res;
+static int wpa_driver_ndis_scan(void *priv,
+	int res;
+	if (drv->native80211)
+		return wpa_driver_ndis_scan_native80211(drv, params);
+	if (!drv->radio_enabled) {
+		wpa_printf(MSG_DEBUG, "NDIS: turning radio on before the first"
+			   " scan");
+		if (wpa_driver_ndis_disconnect(drv) < 0) {
+			wpa_printf(MSG_DEBUG, "NDIS: failed to enable radio");
+	res = ndis_set_oid(drv, OID_802_11_BSSID_LIST_SCAN, "    ", 4);
+			       drv->ctx);
+	return res;
+static const u8 * wpa_scan_get_ie(const struct wpa_scan_res *res, u8 ie)
+	const u8 *end, *pos;
+	pos = (const u8 *) (res + 1);
+	end = pos + res->ie_len;
+	while (pos + 1 < end) {
+		if (pos + 2 + pos[1] > end)
+			break;
+		if (pos[0] == ie)
+			return pos;
+		pos += 2 + pos[1];
+	return NULL;
+static struct wpa_scan_res * wpa_driver_ndis_add_scan_ssid(
+	struct wpa_scan_res *r, NDIS_802_11_SSID *ssid)
+	struct wpa_scan_res *nr;
+	u8 *pos;
+	if (wpa_scan_get_ie(r, WLAN_EID_SSID))
+		return r; /* SSID IE already present */
+	if (ssid->SsidLength == 0 || ssid->SsidLength > SSID_MAX_LEN)
+		return r; /* No valid SSID inside scan data */
+	nr = os_realloc(r, sizeof(*r) + r->ie_len + 2 + ssid->SsidLength);
+	if (nr == NULL)
+		return r;
+	pos = ((u8 *) (nr + 1)) + nr->ie_len;
+	*pos++ = ssid->SsidLength;
+	os_memcpy(pos, ssid->Ssid, ssid->SsidLength);
+	nr->ie_len += 2 + ssid->SsidLength;
+	return nr;
+static struct wpa_scan_results * wpa_driver_ndis_get_scan_results(void *priv)
+	NDIS_802_11_BSSID_LIST_EX *b;
+	size_t blen, count, i;
+	int len;
+	char *pos;
+	struct wpa_scan_results *results;
+	struct wpa_scan_res *r;
+	blen = 65535;
+	b = os_zalloc(blen);
+	if (b == NULL)
+		return NULL;
+	len = ndis_get_oid(drv, OID_802_11_BSSID_LIST, (char *) b, blen);
+	if (len < 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: failed to get scan results");
+		os_free(b);
+		return NULL;
+	count = b->NumberOfItems;
+	results = os_zalloc(sizeof(*results));
+	if (results == NULL) {
+		os_free(b);
+		return NULL;
+	results->res = os_calloc(count, sizeof(struct wpa_scan_res *));
+	if (results->res == NULL) {
+		os_free(results);
+		os_free(b);
+		return NULL;
+	pos = (char *) &b->Bssid[0];
+	for (i = 0; i < count; i++) {
+		NDIS_WLAN_BSSID_EX *bss = (NDIS_WLAN_BSSID_EX *) pos;
+		NDIS_802_11_FIXED_IEs *fixed;
+		if (bss->IELength < sizeof(NDIS_802_11_FIXED_IEs)) {
+			wpa_printf(MSG_DEBUG, "NDIS: too small IELength=%d",
+				   (int) bss->IELength);
+			break;
+		if (((char *) bss->IEs) + bss->IELength  > (char *) b + blen) {
+			 * Some NDIS drivers have been reported to include an
+			 * entry with an invalid IELength in scan results and
+			 * this has crashed wpa_supplicant, so validate the
+			 * returned value before using it.
+			wpa_printf(MSG_DEBUG, "NDIS: skipped invalid scan "
+				   "result IE (BSSID=" MACSTR ") IELength=%d",
+				   MAC2STR(bss->MacAddress),
+			break;
+		r = os_zalloc(sizeof(*r) + bss->IELength -
+			      sizeof(NDIS_802_11_FIXED_IEs));
+		if (r == NULL)
+			break;
+		os_memcpy(r->bssid, bss->MacAddress, ETH_ALEN);
+		r->level = (int) bss->Rssi;
+		r->freq = bss->Configuration.DSConfig / 1000;
+		fixed = (NDIS_802_11_FIXED_IEs *) bss->IEs;
+		r->beacon_int = WPA_GET_LE16((u8 *) &fixed->BeaconInterval);
+		r->caps = WPA_GET_LE16((u8 *) &fixed->Capabilities);
+		r->tsf = WPA_GET_LE64(fixed->Timestamp);
+		os_memcpy(r + 1, bss->IEs + sizeof(NDIS_802_11_FIXED_IEs),
+			  bss->IELength - sizeof(NDIS_802_11_FIXED_IEs));
+		r->ie_len = bss->IELength - sizeof(NDIS_802_11_FIXED_IEs);
+		r = wpa_driver_ndis_add_scan_ssid(r, &bss->Ssid);
+		results->res[results->num++] = r;
+		pos += bss->Length;
+		if (pos > (char *) b + blen)
+			break;
+	os_free(b);
+	return results;
+static int wpa_driver_ndis_remove_key(struct wpa_driver_ndis_data *drv,
+				      int key_idx, const u8 *addr,
+				      const u8 *bssid, int pairwise)
+	NDIS_802_11_REMOVE_KEY rkey;
+	NDIS_802_11_KEY_INDEX index;
+	int res, res2;
+	os_memset(&rkey, 0, sizeof(rkey));
+	rkey.Length = sizeof(rkey);
+	rkey.KeyIndex = key_idx;
+	if (pairwise)
+		rkey.KeyIndex |= 1 << 30;
+	os_memcpy(rkey.BSSID, bssid, ETH_ALEN);
+	res = ndis_set_oid(drv, OID_802_11_REMOVE_KEY, (char *) &rkey,
+			   sizeof(rkey));
+	if (!pairwise) {
+		index = key_idx;
+		res2 = ndis_set_oid(drv, OID_802_11_REMOVE_WEP,
+				    (char *) &index, sizeof(index));
+	} else
+		res2 = 0;
+	if (res < 0 && res2 < 0)
+		return -1;
+	return 0;
+static int wpa_driver_ndis_add_wep(struct wpa_driver_ndis_data *drv,
+				   int pairwise, int key_idx, int set_tx,
+				   const u8 *key, size_t key_len)
+	NDIS_802_11_WEP *wep;
+	size_t len;
+	int res;
+	len = 12 + key_len;
+	wep = os_zalloc(len);
+	if (wep == NULL)
+		return -1;
+	wep->Length = len;
+	wep->KeyIndex = key_idx;
+	if (set_tx)
+		wep->KeyIndex |= 1 << 31;
+#if 0 /* Setting bit30 does not seem to work with some NDIS drivers */
+	if (pairwise)
+		wep->KeyIndex |= 1 << 30;
+#endif
+	wep->KeyLength = key_len;
+	os_memcpy(wep->KeyMaterial, key, key_len);
+	wpa_hexdump_key(MSG_MSGDUMP, "NDIS: OID_802_11_ADD_WEP",
+			(u8 *) wep, len);
+	res = ndis_set_oid(drv, OID_802_11_ADD_WEP, (char *) wep, len);
+	os_free(wep);
+	return res;
+static int wpa_driver_ndis_set_key(const char *ifname, void *priv,
+				   enum wpa_alg alg, const u8 *addr,
+				   int key_idx, int set_tx,
+				   const u8 *seq, size_t seq_len,
+	size_t len, i;
+	NDIS_802_11_KEY *nkey;
+	int res, pairwise;
+	u8 bssid[ETH_ALEN];
+	if (addr == NULL || is_broadcast_ether_addr(addr)) {
+		/* Group Key */
+		pairwise = 0;
+		if (wpa_driver_ndis_get_bssid(drv, bssid) < 0)
+			os_memset(bssid, 0xff, ETH_ALEN);
+	} else {
+		/* Pairwise Key */
+		pairwise = 1;
+		os_memcpy(bssid, addr, ETH_ALEN);
+	if (alg == WPA_ALG_NONE || key_len == 0) {
+		return wpa_driver_ndis_remove_key(drv, key_idx, addr, bssid,
+						  pairwise);
+	if (alg == WPA_ALG_WEP) {
+		return wpa_driver_ndis_add_wep(drv, pairwise, key_idx, set_tx,
+					       key, key_len);
+	len = 12 + 6 + 6 + 8 + key_len;
+	nkey = os_zalloc(len);
+	if (nkey == NULL)
+		return -1;
+	nkey->Length = len;
+	nkey->KeyIndex = key_idx;
+	if (set_tx)
+		nkey->KeyIndex |= 1 << 31;
+	if (pairwise)
+		nkey->KeyIndex |= 1 << 30;
+	if (seq && seq_len)
+		nkey->KeyIndex |= 1 << 29;
+	nkey->KeyLength = key_len;
+	os_memcpy(nkey->BSSID, bssid, ETH_ALEN);
+	if (seq && seq_len) {
+			nkey->KeyRSC |= (ULONGLONG) seq[i] << (i * 8);
+	if (alg == WPA_ALG_TKIP && key_len == 32) {
+		os_memcpy(nkey->KeyMaterial, key, 16);
+		os_memcpy(nkey->KeyMaterial + 16, key + 24, 8);
+		os_memcpy(nkey->KeyMaterial + 24, key + 16, 8);
+	} else {
+		os_memcpy(nkey->KeyMaterial, key, key_len);
+	wpa_hexdump_key(MSG_MSGDUMP, "NDIS: OID_802_11_ADD_KEY",
+			(u8 *) nkey, len);
+	res = ndis_set_oid(drv, OID_802_11_ADD_KEY, (char *) nkey, len);
+	os_free(nkey);
+	return res;
+static int
+wpa_driver_ndis_associate(void *priv,
+			  struct wpa_driver_associate_params *params)
+	u32 auth_mode, encr, priv_mode, mode;
+	u8 bcast[ETH_ALEN] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff };
+	drv->mode = params->mode;
+	/* Note: Setting OID_802_11_INFRASTRUCTURE_MODE clears current keys,
+	 * so static WEP keys needs to be set again after this. */
+	if (params->mode == IEEE80211_MODE_IBSS) {
+		mode = Ndis802_11IBSS;
+		/* Need to make sure that BSSID polling is enabled for
+		 * IBSS mode. */
+		eloop_cancel_timeout(wpa_driver_ndis_poll_timeout, drv, NULL);
+		eloop_register_timeout(1, 0, wpa_driver_ndis_poll_timeout,
+				       drv, NULL);
+	} else
+		mode = Ndis802_11Infrastructure;
+	if (ndis_set_oid(drv, OID_802_11_INFRASTRUCTURE_MODE,
+			 (char *) &mode, sizeof(mode)) < 0) {
+			   "OID_802_11_INFRASTRUCTURE_MODE (%d)",
+			   (int) mode);
+		/* Try to continue anyway */
+	if (params->key_mgmt_suite == WPA_KEY_MGMT_NONE ||
+	    params->key_mgmt_suite == WPA_KEY_MGMT_IEEE8021X_NO_WPA) {
+		/* Re-set WEP keys if static WEP configuration is used. */
+		int i;
+		for (i = 0; i < 4; i++) {
+			if (!params->wep_key[i])
+				continue;
+			wpa_printf(MSG_DEBUG, "NDIS: Re-setting static WEP "
+				   "key %d", i);
+			wpa_driver_ndis_set_key(drv->ifname, drv, WPA_ALG_WEP,
+						bcast, i,
+						i == params->wep_tx_keyidx,
+						NULL, 0, params->wep_key[i],
+						params->wep_key_len[i]);
+	if (params->wpa_ie == NULL || params->wpa_ie_len == 0) {
+		if (params->auth_alg & WPA_AUTH_ALG_SHARED) {
+			if (params->auth_alg & WPA_AUTH_ALG_OPEN)
+				auth_mode = Ndis802_11AuthModeAutoSwitch;
+			else
+				auth_mode = Ndis802_11AuthModeShared;
+		} else
+			auth_mode = Ndis802_11AuthModeOpen;
+		priv_mode = Ndis802_11PrivFilterAcceptAll;
+	} else if (params->wpa_ie[0] == WLAN_EID_RSN) {
+		priv_mode = Ndis802_11PrivFilter8021xWEP;
+		if (params->key_mgmt_suite == WPA_KEY_MGMT_PSK)
+			auth_mode = Ndis802_11AuthModeWPA2PSK;
+		else
+			auth_mode = Ndis802_11AuthModeWPA2;
+#ifdef CONFIG_WPS
+	} else if (params->key_mgmt_suite == WPA_KEY_MGMT_WPS) {
+		if (params->wps == WPS_MODE_PRIVACY) {
+			u8 dummy_key[5] = { 0x11, 0x22, 0x33, 0x44, 0x55 };
+			 * Some NDIS drivers refuse to associate in open mode
+			 * configuration due to Privacy field mismatch, so use
+			 * a workaround to make the configuration look like
+			 * matching one for WPS provisioning.
+			wpa_printf(MSG_DEBUG, "NDIS: Set dummy WEP key as a "
+				   "workaround to allow driver to associate "
+				   "for WPS");
+						bcast, 0, 1,
+						NULL, 0, dummy_key,
+						sizeof(dummy_key));
+#endif /* CONFIG_WPS */
+	} else {
+		if (params->key_mgmt_suite == WPA_KEY_MGMT_WPA_NONE)
+			auth_mode = Ndis802_11AuthModeWPANone;
+		else if (params->key_mgmt_suite == WPA_KEY_MGMT_PSK)
+			auth_mode = Ndis802_11AuthModeWPAPSK;
+		else
+			auth_mode = Ndis802_11AuthModeWPA;
+	switch (params->pairwise_suite) {
+		encr = Ndis802_11Encryption3Enabled;
+		break;
+		encr = Ndis802_11Encryption2Enabled;
+		break;
+		encr = Ndis802_11Encryption1Enabled;
+		break;
+#ifdef CONFIG_WPS
+			break;
+		if (params->group_suite == WPA_CIPHER_CCMP)
+		else if (params->group_suite == WPA_CIPHER_TKIP)
+		else
+			encr = Ndis802_11EncryptionDisabled;
+		break;
+	default:
+#ifdef CONFIG_WPS
+			break;
+		break;
+	if (ndis_set_oid(drv, OID_802_11_PRIVACY_FILTER,
+			 (char *) &priv_mode, sizeof(priv_mode)) < 0) {
+			   "OID_802_11_PRIVACY_FILTER (%d)",
+			   (int) priv_mode);
+	ndis_set_auth_mode(drv, auth_mode);
+	ndis_set_encr_status(drv, encr);
+	if (params->bssid) {
+		ndis_set_oid(drv, OID_802_11_BSSID, (char *) params->bssid,
+			     ETH_ALEN);
+		drv->oid_bssid_set = 1;
+	} else if (drv->oid_bssid_set) {
+		ndis_set_oid(drv, OID_802_11_BSSID, "\xff\xff\xff\xff\xff\xff",
+			     ETH_ALEN);
+		drv->oid_bssid_set = 0;
+	return wpa_driver_ndis_set_ssid(drv, params->ssid, params->ssid_len);
+static int wpa_driver_ndis_set_pmkid(struct wpa_driver_ndis_data *drv)
+	int len, count, i, ret;
+	struct ndis_pmkid_entry *entry;
+	NDIS_802_11_PMKID *p;
+	count = 0;
+	entry = drv->pmkid;
+	while (entry) {
+		count++;
+		if (count >= drv->no_of_pmkid)
+			break;
+		entry = entry->next;
+	len = 8 + count * sizeof(BSSID_INFO);
+	p = os_zalloc(len);
+	if (p == NULL)
+		return -1;
+	p->Length = len;
+	p->BSSIDInfoCount = count;
+		os_memcpy(&p->BSSIDInfo[i].BSSID, entry->bssid, ETH_ALEN);
+		os_memcpy(&p->BSSIDInfo[i].PMKID, entry->pmkid, 16);
+	wpa_hexdump(MSG_MSGDUMP, "NDIS: OID_802_11_PMKID", (u8 *) p, len);
+	ret = ndis_set_oid(drv, OID_802_11_PMKID, (char *) p, len);
+	os_free(p);
+	return ret;
+static int wpa_driver_ndis_add_pmkid(void *priv, const u8 *bssid,
+				     const u8 *pmkid)
+	struct ndis_pmkid_entry *entry, *prev;
+	if (drv->no_of_pmkid == 0)
+		return 0;
+	prev = NULL;
+	while (entry) {
+		if (os_memcmp(entry->bssid, bssid, ETH_ALEN) == 0)
+			break;
+		prev = entry;
+	if (entry) {
+		/* Replace existing entry for this BSSID and move it into the
+		 * beginning of the list. */
+		os_memcpy(entry->pmkid, pmkid, 16);
+		if (prev) {
+			prev->next = entry->next;
+			entry->next = drv->pmkid;
+			drv->pmkid = entry;
+	} else {
+		entry = os_malloc(sizeof(*entry));
+		if (entry) {
+			os_memcpy(entry->bssid, bssid, ETH_ALEN);
+	return wpa_driver_ndis_set_pmkid(drv);
+static int wpa_driver_ndis_remove_pmkid(void *priv, const u8 *bssid,
+		 			const u8 *pmkid)
+		return 0;
+	prev = NULL;
+	while (entry) {
+		if (os_memcmp(entry->bssid, bssid, ETH_ALEN) == 0 &&
+		    os_memcmp(entry->pmkid, pmkid, 16) == 0) {
+			if (prev)
+			else
+				drv->pmkid = entry->next;
+			os_free(entry);
+			break;
+		prev = entry;
+static int wpa_driver_ndis_flush_pmkid(void *priv)
+	NDIS_802_11_PMKID p;
+	struct ndis_pmkid_entry *pmkid, *prev;
+	int prev_authmode, ret;
+		return 0;
+	pmkid = drv->pmkid;
+	drv->pmkid = NULL;
+	while (pmkid) {
+		prev = pmkid;
+		pmkid = pmkid->next;
+		os_free(prev);
+	 * Some drivers may refuse OID_802_11_PMKID if authMode is not set to
+	 * WPA2, so change authMode temporarily, if needed.
+	prev_authmode = ndis_get_auth_mode(drv);
+	if (prev_authmode != Ndis802_11AuthModeWPA2)
+		ndis_set_auth_mode(drv, Ndis802_11AuthModeWPA2);
+	os_memset(&p, 0, sizeof(p));
+	p.Length = 8;
+	p.BSSIDInfoCount = 0;
+	wpa_hexdump(MSG_MSGDUMP, "NDIS: OID_802_11_PMKID (flush)",
+		    (u8 *) &p, 8);
+	ret = ndis_set_oid(drv, OID_802_11_PMKID, (char *) &p, 8);
+		ndis_set_auth_mode(drv, prev_authmode);
+	return ret;
+static int wpa_driver_ndis_get_associnfo(struct wpa_driver_ndis_data *drv)
+	char buf[512], *pos;
+	NDIS_802_11_ASSOCIATION_INFORMATION *ai;
+	int len;
+	size_t blen, i;
+	len = ndis_get_oid(drv, OID_802_11_ASSOCIATION_INFORMATION, buf,
+			   sizeof(buf));
+	if (len < 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: failed to get association "
+			   "information");
+		return -1;
+	if (len > sizeof(buf)) {
+		/* Some drivers seem to be producing incorrect length for this
+		 * data. Limit the length to the current buffer size to avoid
+		 * crashing in hexdump. The data seems to be otherwise valid,
+		 * so better try to use it. */
+		wpa_printf(MSG_DEBUG, "NDIS: ignored bogus association "
+			   "information length %d", len);
+				   buf, sizeof(buf));
+		if (len < -1) {
+			wpa_printf(MSG_DEBUG, "NDIS: re-reading association "
+				   "information failed");
+			return -1;
+			wpa_printf(MSG_DEBUG, "NDIS: ignored bogus association"
+				   " information length %d (re-read)", len);
+			len = sizeof(buf);
+	wpa_hexdump(MSG_MSGDUMP, "NDIS: association information",
+		    (u8 *) buf, len);
+	if (len < sizeof(*ai)) {
+		wpa_printf(MSG_DEBUG, "NDIS: too short association "
+			   "information");
+		return -1;
+	ai = (NDIS_802_11_ASSOCIATION_INFORMATION *) buf;
+	wpa_printf(MSG_DEBUG, "NDIS: ReqFixed=0x%x RespFixed=0x%x off_req=%d "
+		   "off_resp=%d len_req=%d len_resp=%d",
+		   ai->AvailableRequestFixedIEs, ai->AvailableResponseFixedIEs,
+		   (int) ai->OffsetRequestIEs, (int) ai->OffsetResponseIEs,
+		   (int) ai->RequestIELength, (int) ai->ResponseIELength);
+	if (ai->OffsetRequestIEs + ai->RequestIELength > (unsigned) len ||
+	    ai->OffsetResponseIEs + ai->ResponseIELength > (unsigned) len) {
+		wpa_printf(MSG_DEBUG, "NDIS: association information - "
+			   "IE overflow");
+		return -1;
+	wpa_hexdump(MSG_MSGDUMP, "NDIS: Request IEs",
+		    (u8 *) buf + ai->OffsetRequestIEs, ai->RequestIELength);
+	wpa_hexdump(MSG_MSGDUMP, "NDIS: Response IEs",
+		    (u8 *) buf + ai->OffsetResponseIEs, ai->ResponseIELength);
+	data.assoc_info.req_ies = (u8 *) buf + ai->OffsetRequestIEs;
+	data.assoc_info.req_ies_len = ai->RequestIELength;
+	data.assoc_info.resp_ies = (u8 *) buf + ai->OffsetResponseIEs;
+	data.assoc_info.resp_ies_len = ai->ResponseIELength;
+	blen = 65535;
+	if (b == NULL)
+		goto skip_scan_results;
+	if (len < 0) {
+		os_free(b);
+		b = NULL;
+	wpa_printf(MSG_DEBUG, "NDIS: %d BSSID items to process for AssocInfo",
+		   (unsigned int) b->NumberOfItems);
+	for (i = 0; i < b->NumberOfItems; i++) {
+		if (os_memcmp(drv->bssid, bss->MacAddress, ETH_ALEN) == 0 &&
+		    bss->IELength > sizeof(NDIS_802_11_FIXED_IEs)) {
+			data.assoc_info.beacon_ies =
+				((u8 *) bss->IEs) +
+				sizeof(NDIS_802_11_FIXED_IEs);
+			data.assoc_info.beacon_ies_len =
+				bss->IELength - sizeof(NDIS_802_11_FIXED_IEs);
+			wpa_hexdump(MSG_MSGDUMP, "NDIS: Beacon IEs",
+				    data.assoc_info.beacon_ies,
+				    data.assoc_info.beacon_ies_len);
+			break;
+			break;
+skip_scan_results:
+	wpa_supplicant_event(drv->ctx, EVENT_ASSOCINFO, &data);
+	os_free(b);
+	return 0;
+	struct wpa_driver_ndis_data *drv = eloop_ctx;
+	int poll;
+	if (drv->wired)
+		return;
+	if (wpa_driver_ndis_get_bssid(drv, bssid)) {
+		/* Disconnected */
+		if (!is_zero_ether_addr(drv->bssid)) {
+			os_memset(drv->bssid, 0, ETH_ALEN);
+			wpa_supplicant_event(drv->ctx, EVENT_DISASSOC, NULL);
+	} else {
+		/* Connected */
+		if (os_memcmp(drv->bssid, bssid, ETH_ALEN) != 0) {
+			os_memcpy(drv->bssid, bssid, ETH_ALEN);
+			wpa_driver_ndis_get_associnfo(drv);
+			wpa_supplicant_event(drv->ctx, EVENT_ASSOC, NULL);
+	/* When using integrated NDIS event receiver, we can skip BSSID
+	 * polling when using infrastructure network. However, when using
+	 * IBSS mode, many driver do not seem to generate connection event,
+	 * so we need to enable BSSID polling to figure out when IBSS network
+	 * has been formed.
+	poll = drv->mode == IEEE80211_MODE_IBSS;
+#ifndef CONFIG_NDIS_EVENTS_INTEGRATED
+#ifndef _WIN32_WCE
+	poll = 1;
+	if (poll) {
+					drv, NULL);
+static void wpa_driver_ndis_poll(void *priv)
+	wpa_driver_ndis_poll_timeout(drv, NULL);
+/* Called when driver generates Media Connect Event by calling
+ * NdisMIndicateStatus() with NDIS_STATUS_MEDIA_CONNECT */
+void wpa_driver_ndis_event_connect(struct wpa_driver_ndis_data *drv)
+	wpa_printf(MSG_DEBUG, "NDIS: Media Connect Event");
+	if (wpa_driver_ndis_get_bssid(drv, drv->bssid) == 0) {
+/* Called when driver generates Media Disconnect Event by calling
+ * NdisMIndicateStatus() with NDIS_STATUS_MEDIA_DISCONNECT */
+void wpa_driver_ndis_event_disconnect(struct wpa_driver_ndis_data *drv)
+	wpa_printf(MSG_DEBUG, "NDIS: Media Disconnect Event");
+static void wpa_driver_ndis_event_auth(struct wpa_driver_ndis_data *drv,
+				       const u8 *data, size_t data_len)
+	NDIS_802_11_AUTHENTICATION_REQUEST *req;
+	int pairwise = 0, group = 0;
+	union wpa_event_data event;
+	if (data_len < sizeof(*req)) {
+		wpa_printf(MSG_DEBUG, "NDIS: Too short Authentication Request "
+			   "Event (len=%d)", data_len);
+		return;
+	req = (NDIS_802_11_AUTHENTICATION_REQUEST *) data;
+	wpa_printf(MSG_DEBUG, "NDIS: Authentication Request Event: "
+		   "Bssid " MACSTR " Flags 0x%x",
+		   MAC2STR(req->Bssid), (int) req->Flags);
+	if ((req->Flags & NDIS_802_11_AUTH_REQUEST_PAIRWISE_ERROR) ==
+	    NDIS_802_11_AUTH_REQUEST_PAIRWISE_ERROR)
+		pairwise = 1;
+	else if ((req->Flags & NDIS_802_11_AUTH_REQUEST_GROUP_ERROR) ==
+	    NDIS_802_11_AUTH_REQUEST_GROUP_ERROR)
+		group = 1;
+	if (pairwise || group) {
+		os_memset(&event, 0, sizeof(event));
+		event.michael_mic_failure.unicast = pairwise;
+		wpa_supplicant_event(drv->ctx, EVENT_MICHAEL_MIC_FAILURE,
+				     &event);
+static void wpa_driver_ndis_event_pmkid(struct wpa_driver_ndis_data *drv,
+	NDIS_802_11_PMKID_CANDIDATE_LIST *pmkid;
+	size_t i;
+	if (data_len < 8) {
+		wpa_printf(MSG_DEBUG, "NDIS: Too short PMKID Candidate List "
+		return;
+	pmkid = (NDIS_802_11_PMKID_CANDIDATE_LIST *) data;
+	wpa_printf(MSG_DEBUG, "NDIS: PMKID Candidate List Event - Version %d "
+		   "NumCandidates %d",
+		   (int) pmkid->Version, (int) pmkid->NumCandidates);
+	if (pmkid->Version != 1) {
+		wpa_printf(MSG_DEBUG, "NDIS: Unsupported PMKID Candidate List "
+			   "Version %d", (int) pmkid->Version);
+		return;
+	if (data_len < 8 + pmkid->NumCandidates * sizeof(PMKID_CANDIDATE)) {
+		wpa_printf(MSG_DEBUG, "NDIS: PMKID Candidate List underflow");
+		return;
+	for (i = 0; i < pmkid->NumCandidates; i++) {
+		PMKID_CANDIDATE *p = &pmkid->CandidateList[i];
+		wpa_printf(MSG_DEBUG, "NDIS: %d: " MACSTR " Flags 0x%x",
+			   i, MAC2STR(p->BSSID), (int) p->Flags);
+		os_memcpy(event.pmkid_candidate.bssid, p->BSSID, ETH_ALEN);
+		event.pmkid_candidate.index = i;
+		event.pmkid_candidate.preauth =
+			p->Flags & NDIS_802_11_PMKID_CANDIDATE_PREAUTH_ENABLED;
+		wpa_supplicant_event(drv->ctx, EVENT_PMKID_CANDIDATE,
+				     &event);
+/* Called when driver calls NdisMIndicateStatus() with
+ * NDIS_STATUS_MEDIA_SPECIFIC_INDICATION */
+void wpa_driver_ndis_event_media_specific(struct wpa_driver_ndis_data *drv,
+	NDIS_802_11_STATUS_INDICATION *status;
+	if (data == NULL || data_len < sizeof(*status))
+		return;
+	wpa_hexdump(MSG_DEBUG, "NDIS: Media Specific Indication",
+		    data, data_len);
+	status = (NDIS_802_11_STATUS_INDICATION *) data;
+	data += sizeof(status);
+	data_len -= sizeof(status);
+	switch (status->StatusType) {
+	case Ndis802_11StatusType_Authentication:
+		wpa_driver_ndis_event_auth(drv, data, data_len);
+		break;
+	case Ndis802_11StatusType_PMKID_CandidateList:
+		wpa_driver_ndis_event_pmkid(drv, data, data_len);
+		break;
+	default:
+		wpa_printf(MSG_DEBUG, "NDIS: Unknown StatusType %d",
+			   (int) status->StatusType);
+		break;
+/* Called when an adapter is added */
+void wpa_driver_ndis_event_adapter_arrival(struct wpa_driver_ndis_data *drv)
+	int i;
+	wpa_printf(MSG_DEBUG, "NDIS: Notify Adapter Arrival");
+	for (i = 0; i < 30; i++) {
+		/* Re-open Packet32/NDISUIO connection */
+		wpa_driver_ndis_adapter_close(drv);
+		if (wpa_driver_ndis_adapter_init(drv) < 0 ||
+		    wpa_driver_ndis_adapter_open(drv) < 0) {
+			wpa_printf(MSG_DEBUG, "NDIS: Driver re-initialization "
+				   "(%d) failed", i);
+			os_sleep(1, 0);
+		} else {
+			wpa_printf(MSG_DEBUG, "NDIS: Driver re-initialized");
+			break;
+	event.interface_status.ievent = EVENT_INTERFACE_ADDED;
+	wpa_supplicant_event(drv->ctx, EVENT_INTERFACE_STATUS, &event);
+/* Called when an adapter is removed */
+void wpa_driver_ndis_event_adapter_removal(struct wpa_driver_ndis_data *drv)
+	wpa_printf(MSG_DEBUG, "NDIS: Notify Adapter Removal");
+static void
+wpa_driver_ndis_get_wpa_capability(struct wpa_driver_ndis_data *drv)
+	wpa_printf(MSG_DEBUG, "NDIS: verifying driver WPA capability");
+	if (ndis_set_auth_mode(drv, Ndis802_11AuthModeWPA) == 0 &&
+	    ndis_get_auth_mode(drv) == Ndis802_11AuthModeWPA) {
+		wpa_printf(MSG_DEBUG, "NDIS: WPA key management supported");
+		drv->capa.key_mgmt |= WPA_DRIVER_CAPA_KEY_MGMT_WPA;
+	if (ndis_set_auth_mode(drv, Ndis802_11AuthModeWPAPSK) == 0 &&
+	    ndis_get_auth_mode(drv) == Ndis802_11AuthModeWPAPSK) {
+		wpa_printf(MSG_DEBUG, "NDIS: WPA-PSK key management "
+			   "supported");
+		drv->capa.key_mgmt |= WPA_DRIVER_CAPA_KEY_MGMT_WPA_PSK;
+	if (ndis_set_encr_status(drv, Ndis802_11Encryption3Enabled) == 0 &&
+	    ndis_get_encr_status(drv) == Ndis802_11Encryption3KeyAbsent) {
+		wpa_printf(MSG_DEBUG, "NDIS: CCMP encryption supported");
+	if (ndis_set_encr_status(drv, Ndis802_11Encryption2Enabled) == 0 &&
+	    ndis_get_encr_status(drv) == Ndis802_11Encryption2KeyAbsent) {
+		wpa_printf(MSG_DEBUG, "NDIS: TKIP encryption supported");
+	if (ndis_set_encr_status(drv, Ndis802_11Encryption1Enabled) == 0 &&
+	    ndis_get_encr_status(drv) == Ndis802_11Encryption1KeyAbsent) {
+		wpa_printf(MSG_DEBUG, "NDIS: WEP encryption supported");
+	if (ndis_set_auth_mode(drv, Ndis802_11AuthModeShared) == 0 &&
+	    ndis_get_auth_mode(drv) == Ndis802_11AuthModeShared) {
+		drv->capa.auth |= WPA_DRIVER_AUTH_SHARED;
+	if (ndis_set_auth_mode(drv, Ndis802_11AuthModeOpen) == 0 &&
+	    ndis_get_auth_mode(drv) == Ndis802_11AuthModeOpen) {
+		drv->capa.auth |= WPA_DRIVER_AUTH_OPEN;
+	ndis_set_encr_status(drv, Ndis802_11EncryptionDisabled);
+	/* Could also verify OID_802_11_ADD_KEY error reporting and
+	 * support for OID_802_11_ASSOCIATION_INFORMATION. */
+	if (drv->capa.key_mgmt & WPA_DRIVER_CAPA_KEY_MGMT_WPA &&
+	    drv->capa.enc & (WPA_DRIVER_CAPA_ENC_TKIP |
+			     WPA_DRIVER_CAPA_ENC_CCMP)) {
+		wpa_printf(MSG_DEBUG, "NDIS: driver supports WPA");
+		drv->has_capability = 1;
+	} else {
+		wpa_printf(MSG_DEBUG, "NDIS: no WPA support found");
+	wpa_printf(MSG_DEBUG, "NDIS: driver capabilities: key_mgmt 0x%x "
+		   "enc 0x%x auth 0x%x",
+		   drv->capa.key_mgmt, drv->capa.enc, drv->capa.auth);
+static void wpa_driver_ndis_get_capability(struct wpa_driver_ndis_data *drv)
+	char buf[512];
+	int len;
+	size_t i;
+	NDIS_802_11_CAPABILITY *c;
+	drv->capa.flags = WPA_DRIVER_FLAGS_DRIVER_IE;
+	len = ndis_get_oid(drv, OID_802_11_CAPABILITY, buf, sizeof(buf));
+	if (len < 0) {
+		wpa_driver_ndis_get_wpa_capability(drv);
+		return;
+	wpa_hexdump(MSG_MSGDUMP, "OID_802_11_CAPABILITY", (u8 *) buf, len);
+	c = (NDIS_802_11_CAPABILITY *) buf;
+	if (len < sizeof(*c) || c->Version != 2) {
+		wpa_printf(MSG_DEBUG, "NDIS: unsupported "
+			   "OID_802_11_CAPABILITY data");
+		return;
+	wpa_printf(MSG_DEBUG, "NDIS: Driver supports OID_802_11_CAPABILITY - "
+		   "NoOfPMKIDs %d NoOfAuthEncrPairs %d",
+		   (int) c->NoOfPMKIDs,
+		   (int) c->NoOfAuthEncryptPairsSupported);
+	drv->no_of_pmkid = c->NoOfPMKIDs;
+	for (i = 0; i < c->NoOfAuthEncryptPairsSupported; i++) {
+		NDIS_802_11_AUTHENTICATION_ENCRYPTION *ae;
+		ae = &c->AuthenticationEncryptionSupported[i];
+		if ((char *) (ae + 1) > buf + len) {
+			wpa_printf(MSG_DEBUG, "NDIS: auth/encr pair list "
+				   "overflow");
+			break;
+		wpa_printf(MSG_MSGDUMP, "NDIS: %d - auth %d encr %d",
+			   i, (int) ae->AuthModeSupported,
+			   (int) ae->EncryptStatusSupported);
+		switch (ae->AuthModeSupported) {
+		case Ndis802_11AuthModeOpen:
+			break;
+		case Ndis802_11AuthModeShared:
+			break;
+		case Ndis802_11AuthModeWPA:
+			break;
+		case Ndis802_11AuthModeWPAPSK:
+			break;
+		case Ndis802_11AuthModeWPA2:
+			drv->capa.key_mgmt |= WPA_DRIVER_CAPA_KEY_MGMT_WPA2;
+			break;
+		case Ndis802_11AuthModeWPA2PSK:
+			break;
+		case Ndis802_11AuthModeWPANone:
+				WPA_DRIVER_CAPA_KEY_MGMT_WPA_NONE;
+			break;
+		default:
+			break;
+		switch (ae->EncryptStatusSupported) {
+		case Ndis802_11Encryption1Enabled:
+			drv->capa.enc |= WPA_DRIVER_CAPA_ENC_WEP40;
+			drv->capa.enc |= WPA_DRIVER_CAPA_ENC_WEP104;
+			break;
+		case Ndis802_11Encryption2Enabled:
+			break;
+		case Ndis802_11Encryption3Enabled:
+			break;
+		default:
+			break;
+static int wpa_driver_ndis_get_capa(void *priv, struct wpa_driver_capa *capa)
+	if (!drv->has_capability)
+		return -1;
+	return 0;
+static const char * wpa_driver_ndis_get_ifname(void *priv)
+	return drv->ifname;
+static const u8 * wpa_driver_ndis_get_mac_addr(void *priv)
+	return drv->own_addr;
+#ifdef _WIN32_WCE
+#define NDISUIO_MSG_SIZE (sizeof(NDISUIO_DEVICE_NOTIFICATION) + 512)
+static void ndisuio_notification_receive(void *eloop_data, void *user_ctx)
+	struct wpa_driver_ndis_data *drv = eloop_data;
+	NDISUIO_DEVICE_NOTIFICATION *hdr;
+	u8 buf[NDISUIO_MSG_SIZE];
+	DWORD len, flags;
+	if (!ReadMsgQueue(drv->event_queue, buf, NDISUIO_MSG_SIZE, &len, 0,
+			  &flags)) {
+		wpa_printf(MSG_DEBUG, "ndisuio_notification_receive: "
+			   "ReadMsgQueue failed: %d", (int) GetLastError());
+		return;
+	if (len < sizeof(NDISUIO_DEVICE_NOTIFICATION)) {
+			   "Too short message (len=%d)", (int) len);
+		return;
+	hdr = (NDISUIO_DEVICE_NOTIFICATION *) buf;
+	wpa_printf(MSG_DEBUG, "NDIS: Notification received: len=%d type=0x%x",
+		   (int) len, hdr->dwNotificationType);
+	switch (hdr->dwNotificationType) {
+#ifdef NDISUIO_NOTIFICATION_ADAPTER_ARRIVAL
+	case NDISUIO_NOTIFICATION_ADAPTER_ARRIVAL:
+		wpa_printf(MSG_DEBUG, "NDIS: ADAPTER_ARRIVAL");
+		wpa_driver_ndis_event_adapter_arrival(drv);
+		break;
+#endif
+#ifdef NDISUIO_NOTIFICATION_ADAPTER_REMOVAL
+	case NDISUIO_NOTIFICATION_ADAPTER_REMOVAL:
+		wpa_printf(MSG_DEBUG, "NDIS: ADAPTER_REMOVAL");
+		wpa_driver_ndis_event_adapter_removal(drv);
+		break;
+#endif
+	case NDISUIO_NOTIFICATION_MEDIA_CONNECT:
+		wpa_printf(MSG_DEBUG, "NDIS: MEDIA_CONNECT");
+		SetEvent(drv->connected_event);
+		wpa_driver_ndis_event_connect(drv);
+		break;
+	case NDISUIO_NOTIFICATION_MEDIA_DISCONNECT:
+		ResetEvent(drv->connected_event);
+		wpa_printf(MSG_DEBUG, "NDIS: MEDIA_DISCONNECT");
+		wpa_driver_ndis_event_disconnect(drv);
+		break;
+	case NDISUIO_NOTIFICATION_MEDIA_SPECIFIC_NOTIFICATION:
+		wpa_printf(MSG_DEBUG, "NDIS: MEDIA_SPECIFIC_NOTIFICATION");
+#if _WIN32_WCE == 420 || _WIN32_WCE == 0x420
+		wpa_driver_ndis_event_media_specific(
+			drv, hdr->pvStatusBuffer, hdr->uiStatusBufferSize);
+#else
+			drv, ((const u8 *) hdr) + hdr->uiOffsetToStatusBuffer,
+			(size_t) hdr->uiStatusBufferSize);
+#endif
+		break;
+	default:
+		wpa_printf(MSG_DEBUG, "NDIS: Unknown notification type 0x%x",
+			   hdr->dwNotificationType);
+		break;
+static void ndisuio_notification_deinit(struct wpa_driver_ndis_data *drv)
+	NDISUIO_REQUEST_NOTIFICATION req;
+	memset(&req, 0, sizeof(req));
+	req.hMsgQueue = drv->event_queue;
+	req.dwNotificationTypes = 0;
+	if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_REQUEST_NOTIFICATION,
+			     &req, sizeof(req), NULL, 0, NULL, NULL)) {
+		wpa_printf(MSG_INFO, "ndisuio_notification_deinit: "
+			   "IOCTL_NDISUIO_REQUEST_NOTIFICATION failed: %d",
+			   (int) GetLastError());
+	if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_CANCEL_NOTIFICATION,
+			     NULL, 0, NULL, 0, NULL, NULL)) {
+			   "IOCTL_NDISUIO_CANCEL_NOTIFICATION failed: %d",
+	if (drv->event_queue) {
+		eloop_unregister_event(drv->event_queue,
+				       sizeof(drv->event_queue));
+		CloseHandle(drv->event_queue);
+		drv->event_queue = NULL;
+	if (drv->connected_event) {
+		CloseHandle(drv->connected_event);
+		drv->connected_event = NULL;
+static int ndisuio_notification_init(struct wpa_driver_ndis_data *drv)
+	MSGQUEUEOPTIONS opt;
+		CreateEvent(NULL, TRUE, FALSE, TEXT("WpaSupplicantConnected"));
+	if (drv->connected_event == NULL) {
+		wpa_printf(MSG_INFO, "ndisuio_notification_init: "
+			   "CreateEvent failed: %d",
+		return -1;
+	memset(&opt, 0, sizeof(opt));
+	opt.dwSize = sizeof(opt);
+	opt.dwMaxMessages = 5;
+	opt.cbMaxMessage = NDISUIO_MSG_SIZE;
+	opt.bReadAccess = TRUE;
+	drv->event_queue = CreateMsgQueue(NULL, &opt);
+	if (drv->event_queue == NULL) {
+			   "CreateMsgQueue failed: %d",
+		ndisuio_notification_deinit(drv);
+		return -1;
+		NDISUIO_NOTIFICATION_ADAPTER_ARRIVAL |
+#endif
+		NDISUIO_NOTIFICATION_ADAPTER_REMOVAL |
+#endif
+		NDISUIO_NOTIFICATION_MEDIA_CONNECT |
+		NDISUIO_NOTIFICATION_MEDIA_DISCONNECT |
+		NDISUIO_NOTIFICATION_MEDIA_SPECIFIC_NOTIFICATION;
+		return -1;
+	eloop_register_event(drv->event_queue, sizeof(drv->event_queue),
+			     ndisuio_notification_receive, drv, NULL);
+	return 0;
+static int wpa_driver_ndis_get_names(struct wpa_driver_ndis_data *drv)
+	NDISUIO_QUERY_BINDING *b;
+	size_t blen = sizeof(*b) + 1024;
+	int i, error, found = 0;
+	DWORD written;
+	char name[256], desc[256], *dpos;
+	WCHAR *pos;
+	size_t j, len, dlen;
+	b = os_malloc(blen);
+	if (b == NULL)
+		return -1;
+	for (i = 0; ; i++) {
+		os_memset(b, 0, blen);
+		b->BindingIndex = i;
+		if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_QUERY_BINDING,
+				     b, sizeof(NDISUIO_QUERY_BINDING), b, blen,
+				     &written, NULL)) {
+			error = (int) GetLastError();
+			if (error == ERROR_NO_MORE_ITEMS)
+				break;
+			wpa_printf(MSG_DEBUG, "IOCTL_NDISUIO_QUERY_BINDING "
+				   "failed: %d", error);
+			break;
+		pos = (WCHAR *) ((char *) b + b->DeviceNameOffset);
+		len = b->DeviceNameLength;
+		if (len >= sizeof(name))
+			len = sizeof(name) - 1;
+		for (j = 0; j < len; j++)
+			name[j] = (char) pos[j];
+		name[len] = '\0';
+		pos = (WCHAR *) ((char *) b + b->DeviceDescrOffset);
+		len = b->DeviceDescrLength;
+		if (len >= sizeof(desc))
+			len = sizeof(desc) - 1;
+			desc[j] = (char) pos[j];
+		desc[len] = '\0';
+		wpa_printf(MSG_DEBUG, "NDIS: %d - %s - %s", i, name, desc);
+		if (os_strstr(name, drv->ifname)) {
+			wpa_printf(MSG_DEBUG, "NDIS: Interface name match");
+			found = 1;
+			break;
+		if (os_strncmp(desc, drv->ifname, os_strlen(drv->ifname)) == 0)
+			wpa_printf(MSG_DEBUG, "NDIS: Interface description "
+				   "match");
+			found = 1;
+			break;
+	if (!found) {
+		wpa_printf(MSG_DEBUG, "NDIS: Could not find interface '%s'",
+			   drv->ifname);
+		os_free(b);
+		return -1;
+		   os_strncmp(name, "\\DEVICE\\", 8) == 0 ? name + 8 : name,
+		   sizeof(drv->ifname));
+#ifdef _WIN32_WCE
+	drv->adapter_name = wpa_strdup_tchar(drv->ifname);
+	if (drv->adapter_name == NULL) {
+		wpa_printf(MSG_ERROR, "NDIS: Failed to allocate memory for "
+			   "adapter name");
+		os_free(b);
+		return -1;
+	dpos = os_strstr(desc, " - ");
+	if (dpos)
+		dlen = dpos - desc;
+	else
+		dlen = os_strlen(desc);
+	drv->adapter_desc = dup_binstr(desc, dlen);
+	os_free(b);
+	if (drv->adapter_desc == NULL)
+		return -1;
+	wpa_printf(MSG_DEBUG, "NDIS: Adapter description prefix '%s'",
+		   drv->adapter_desc);
+	return 0;
+	PTSTR _names;
+	char *names, *pos, *pos2;
+	ULONG len;
+	BOOLEAN res;
+#define MAX_ADAPTERS 32
+	char *name[MAX_ADAPTERS];
+	char *desc[MAX_ADAPTERS];
+	int num_name, num_desc, i, found_name, found_desc;
+	size_t dlen;
+	wpa_printf(MSG_DEBUG, "NDIS: Packet.dll version: %s",
+		   PacketGetVersion());
+	len = 8192;
+	_names = os_zalloc(len);
+	if (_names == NULL)
+		return -1;
+	res = PacketGetAdapterNames(_names, &len);
+	if (!res && len > 8192) {
+		os_free(_names);
+			return -1;
+	if (!res) {
+		wpa_printf(MSG_ERROR, "NDIS: Failed to get adapter list "
+			   "(PacketGetAdapterNames)");
+		os_free(_names);
+		return -1;
+	names = (char *) _names;
+	if (names[0] && names[1] == '\0' && names[2] && names[3] == '\0') {
+		wpa_printf(MSG_DEBUG, "NDIS: Looks like adapter names are in "
+			   "UNICODE");
+		/* Convert to ASCII */
+		pos2 = pos = names;
+		while (pos2 < names + len) {
+			if (pos2[0] == '\0' && pos2[1] == '\0' &&
+			    pos2[2] == '\0' && pos2[3] == '\0') {
+				pos2 += 4;
+				break;
+			*pos++ = pos2[0];
+			pos2 += 2;
+		os_memcpy(pos + 2, names, pos - names);
+		pos += 2;
+	} else
+		pos = names;
+	num_name = 0;
+	while (pos < names + len) {
+		name[num_name] = pos;
+		while (*pos && pos < names + len)
+			pos++;
+		if (pos + 1 >= names + len) {
+			os_free(names);
+			return -1;
+		pos++;
+		num_name++;
+		if (num_name >= MAX_ADAPTERS) {
+			wpa_printf(MSG_DEBUG, "NDIS: Too many adapters");
+			os_free(names);
+			return -1;
+		if (*pos == '\0') {
+			wpa_printf(MSG_DEBUG, "NDIS: %d adapter names found",
+				   num_name);
+			pos++;
+			break;
+	num_desc = 0;
+		desc[num_desc] = pos;
+			pos++;
+			os_free(names);
+			return -1;
+		pos++;
+		num_desc++;
+		if (num_desc >= MAX_ADAPTERS) {
+			wpa_printf(MSG_DEBUG, "NDIS: Too many adapter "
+				   "descriptions");
+			os_free(names);
+			return -1;
+			wpa_printf(MSG_DEBUG, "NDIS: %d adapter descriptions "
+				   "found", num_name);
+			pos++;
+			break;
+	 * Windows 98 with Packet.dll 3.0 alpha3 does not include adapter
+	 * descriptions. Fill in dummy descriptors to work around this.
+	while (num_desc < num_name)
+		desc[num_desc++] = "dummy description";
+	if (num_name != num_desc) {
+		wpa_printf(MSG_DEBUG, "NDIS: mismatch in adapter name and "
+			   "description counts (%d != %d)",
+			   num_name, num_desc);
+		os_free(names);
+		return -1;
+	found_name = found_desc = -1;
+	for (i = 0; i < num_name; i++) {
+			   i, name[i], desc[i]);
+		if (found_name == -1 && os_strstr(name[i], drv->ifname))
+			found_name = i;
+		if (found_desc == -1 &&
+		    os_strncmp(desc[i], drv->ifname, os_strlen(drv->ifname)) ==
+		    0)
+			found_desc = i;
+	if (found_name < 0 && found_desc >= 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: Matched interface '%s' based on "
+			   "description '%s'",
+			   name[found_desc], desc[found_desc]);
+		found_name = found_desc;
+			   os_strncmp(name[found_desc], "\\Device\\NPF_", 12)
+			   == 0 ? name[found_desc] + 12 : name[found_desc],
+	if (found_name < 0) {
+			   drv->ifname);
+		os_free(names);
+		return -1;
+	i = found_name;
+	pos = os_strrchr(desc[i], '(');
+	if (pos) {
+		dlen = pos - desc[i];
+		pos--;
+		if (pos > desc[i] && *pos == ' ')
+			dlen--;
+	} else {
+		dlen = os_strlen(desc[i]);
+	drv->adapter_desc = dup_binstr(desc[i], dlen);
+	os_free(names);
+		return -1;
+	return 0;
+#if defined(CONFIG_NATIVE_WINDOWS) || defined(__CYGWIN__)
+#ifndef _WIN32_WCE
+ * These structures are undocumented for WinXP; only WinCE version is
+ * documented. These would be included wzcsapi.h if it were available. Some
+ * changes here have been needed to make the structures match with WinXP SP2.
+ * It is unclear whether these work with any other version.
+typedef struct {
+	LPWSTR wszGuid;
+} INTF_KEY_ENTRY, *PINTF_KEY_ENTRY;
+typedef struct {
+	DWORD dwNumIntfs;
+	PINTF_KEY_ENTRY pIntfs;
+} INTFS_KEY_TABLE, *PINTFS_KEY_TABLE;
+typedef struct {
+	DWORD dwDataLen;
+	LPBYTE pData;
+} RAW_DATA, *PRAW_DATA;
+typedef struct {
+	LPWSTR wszGuid;
+	LPWSTR wszDescr;
+	ULONG ulMediaState;
+	ULONG ulMediaType;
+	ULONG ulPhysicalMediaType;
+	INT nInfraMode;
+	INT nAuthMode;
+	INT nWepStatus;
+#ifndef _WIN32_WCE
+	u8 pad[2]; /* why is this needed? */
+	DWORD dwCtlFlags;
+	DWORD dwCapabilities; /* something added for WinXP SP2(?) */
+	RAW_DATA rdSSID;
+	RAW_DATA rdBSSID;
+	RAW_DATA rdBSSIDList;
+	RAW_DATA rdStSSIDList;
+	RAW_DATA rdCtrlData;
+#ifdef UNDER_CE
+	BOOL bInitialized;
+#endif
+	DWORD nWPAMCastCipher;
+	/* add some extra buffer for later additions since this interface is
+	 * far from stable */
+	u8 later_additions[100];
+} INTF_ENTRY, *PINTF_ENTRY;
+#define INTF_ALL 0xffffffff
+#define INTF_ALL_FLAGS 0x0000ffff
+#define INTF_CTLFLAGS 0x00000010
+#define INTFCTL_ENABLED 0x8000
+#ifdef _WIN32_WCE
+static int wpa_driver_ndis_rebind_adapter(struct wpa_driver_ndis_data *drv)
+	HANDLE ndis;
+	TCHAR multi[100];
+	int len;
+	len = _tcslen(drv->adapter_name);
+	if (len > 80)
+		return -1;
+	ndis = CreateFile(DD_NDIS_DEVICE_NAME, GENERIC_READ | GENERIC_WRITE,
+			  0, NULL, OPEN_EXISTING, 0, NULL);
+	if (ndis == INVALID_HANDLE_VALUE) {
+		wpa_printf(MSG_DEBUG, "NDIS: Failed to open file to NDIS "
+			   "device: %d", (int) GetLastError());
+		return -1;
+	len++;
+	memcpy(multi, drv->adapter_name, len * sizeof(TCHAR));
+	memcpy(&multi[len], TEXT("NDISUIO\0"), 9 * sizeof(TCHAR));
+	len += 9;
+	if (!DeviceIoControl(ndis, IOCTL_NDIS_REBIND_ADAPTER,
+			     multi, len * sizeof(TCHAR), NULL, 0, NULL, NULL))
+		wpa_printf(MSG_DEBUG, "NDIS: IOCTL_NDIS_REBIND_ADAPTER "
+			   "failed: 0x%x", (int) GetLastError());
+		wpa_hexdump_ascii(MSG_DEBUG, "NDIS: rebind multi_sz",
+				  (u8 *) multi, len * sizeof(TCHAR));
+		CloseHandle(ndis);
+		return -1;
+	wpa_printf(MSG_DEBUG, "NDIS: Requested NDIS rebind of NDISUIO "
+		   "protocol");
+	return 0;
+static int wpa_driver_ndis_set_wzc(struct wpa_driver_ndis_data *drv,
+				   int enable)
+#ifdef _WIN32_WCE
+	HKEY hk, hk2;
+	LONG ret;
+	DWORD i, hnd, len;
+	TCHAR keyname[256], devname[256];
+#define WZC_DRIVER TEXT("Drivers\\BuiltIn\\ZeroConfig")
+	if (enable) {
+		HANDLE h;
+		h = ActivateDeviceEx(WZC_DRIVER, NULL, 0, NULL);
+		if (h == INVALID_HANDLE_VALUE || h == 0) {
+			wpa_printf(MSG_DEBUG, "NDIS: Failed to re-enable WZC "
+				   "- ActivateDeviceEx failed: %d",
+			return -1;
+		wpa_printf(MSG_DEBUG, "NDIS: WZC re-enabled");
+		return wpa_driver_ndis_rebind_adapter(drv);
+	 * Unfortunately, just disabling the WZC for an interface is not enough
+	 * to free NDISUIO for us, so need to disable and unload WZC completely
+	 * for now when using WinCE with NDISUIO. In addition, must request
+	 * NDISUIO protocol to be rebound to the adapter in order to free the
+	 * NDISUIO binding that WZC hold before us.
+	/* Enumerate HKLM\Drivers\Active\* to find a handle to WZC. */
+	ret = RegOpenKeyEx(HKEY_LOCAL_MACHINE, DEVLOAD_ACTIVE_KEY, 0, 0, &hk);
+	if (ret != ERROR_SUCCESS) {
+		wpa_printf(MSG_DEBUG, "NDIS: RegOpenKeyEx(DEVLOAD_ACTIVE_KEY) "
+			   "failed: %d %d", (int) ret, (int) GetLastError());
+		return -1;
+		len = sizeof(keyname);
+		ret = RegEnumKeyEx(hk, i, keyname, &len, NULL, NULL, NULL,
+				   NULL);
+			wpa_printf(MSG_DEBUG, "NDIS: Could not find active "
+				   "WZC - assuming it is not running.");
+			RegCloseKey(hk);
+			return -1;
+		ret = RegOpenKeyEx(hk, keyname, 0, 0, &hk2);
+			wpa_printf(MSG_DEBUG, "NDIS: RegOpenKeyEx(active dev) "
+				   "failed: %d %d",
+				   (int) ret, (int) GetLastError());
+			continue;
+		len = sizeof(devname);
+		ret = RegQueryValueEx(hk2, DEVLOAD_DEVKEY_VALNAME, NULL, NULL,
+				      (LPBYTE) devname, &len);
+			wpa_printf(MSG_DEBUG, "NDIS: RegQueryValueEx("
+				   "DEVKEY_VALNAME) failed: %d %d",
+			RegCloseKey(hk2);
+			continue;
+		if (_tcscmp(devname, WZC_DRIVER) == 0)
+			break;
+		RegCloseKey(hk2);
+	RegCloseKey(hk);
+	/* Found WZC - get handle to it. */
+	len = sizeof(hnd);
+	ret = RegQueryValueEx(hk2, DEVLOAD_HANDLE_VALNAME, NULL, NULL,
+			      (PUCHAR) &hnd, &len);
+		wpa_printf(MSG_DEBUG, "NDIS: RegQueryValueEx(HANDLE_VALNAME) "
+		RegCloseKey(hk2);
+		return -1;
+	RegCloseKey(hk2);
+	/* Deactivate WZC */
+	if (!DeactivateDevice((HANDLE) hnd)) {
+		wpa_printf(MSG_DEBUG, "NDIS: DeactivateDevice failed: %d",
+		return -1;
+	wpa_printf(MSG_DEBUG, "NDIS: Disabled WZC temporarily");
+	drv->wzc_disabled = 1;
+#else /* _WIN32_WCE */
+	HMODULE hm;
+	DWORD (WINAPI *wzc_enum_interf)(LPWSTR pSrvAddr,
+					PINTFS_KEY_TABLE pIntfs);
+	DWORD (WINAPI *wzc_query_interf)(LPWSTR pSrvAddr, DWORD dwInFlags,
+					 PINTF_ENTRY pIntf,
+					 LPDWORD pdwOutFlags);
+	DWORD (WINAPI *wzc_set_interf)(LPWSTR pSrvAddr, DWORD dwInFlags,
+				       PINTF_ENTRY pIntf, LPDWORD pdwOutFlags);
+	int ret = -1, j;
+	DWORD res;
+	INTFS_KEY_TABLE guids;
+	INTF_ENTRY intf;
+	char guid[128];
+	WCHAR *pos;
+	DWORD flags, i;
+	hm = LoadLibrary(TEXT("wzcsapi.dll"));
+	if (hm == NULL) {
+		wpa_printf(MSG_DEBUG, "NDIS: Failed to load wzcsapi.dll (%u) "
+			   "- WZC probably not running",
+			   (unsigned int) GetLastError());
+		return -1;
+#ifdef _WIN32_WCE
+	wzc_enum_interf = (void *) GetProcAddressA(hm, "WZCEnumInterfaces");
+	wzc_query_interf = (void *) GetProcAddressA(hm, "WZCQueryInterface");
+	wzc_set_interf = (void *) GetProcAddressA(hm, "WZCSetInterface");
+	wzc_enum_interf = (void *) GetProcAddress(hm, "WZCEnumInterfaces");
+	wzc_query_interf = (void *) GetProcAddress(hm, "WZCQueryInterface");
+	wzc_set_interf = (void *) GetProcAddress(hm, "WZCSetInterface");
+	if (wzc_enum_interf == NULL || wzc_query_interf == NULL ||
+	    wzc_set_interf == NULL) {
+		wpa_printf(MSG_DEBUG, "NDIS: WZCEnumInterfaces, "
+			   "WZCQueryInterface, or WZCSetInterface not found "
+			   "in wzcsapi.dll");
+		goto fail;
+	os_memset(&guids, 0, sizeof(guids));
+	res = wzc_enum_interf(NULL, &guids);
+	if (res != 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: WZCEnumInterfaces failed: %d; "
+			   "WZC service is apparently not running",
+			   (int) res);
+		goto fail;
+	wpa_printf(MSG_DEBUG, "NDIS: WZCEnumInterfaces: %d interfaces",
+		   (int) guids.dwNumIntfs);
+	for (i = 0; i < guids.dwNumIntfs; i++) {
+		pos = guids.pIntfs[i].wszGuid;
+		for (j = 0; j < sizeof(guid); j++) {
+			guid[j] = (char) *pos;
+			if (*pos == 0)
+				break;
+			pos++;
+		guid[sizeof(guid) - 1] = '\0';
+		wpa_printf(MSG_DEBUG, "NDIS: intfs %d GUID '%s'",
+			   (int) i, guid);
+		if (os_strstr(drv->ifname, guid) == NULL)
+			continue;
+		wpa_printf(MSG_DEBUG, "NDIS: Current interface found from "
+			   "WZC");
+		break;
+	if (i >= guids.dwNumIntfs) {
+		wpa_printf(MSG_DEBUG, "NDIS: Current interface not found from "
+			   "WZC");
+		goto fail;
+	os_memset(&intf, 0, sizeof(intf));
+	intf.wszGuid = guids.pIntfs[i].wszGuid;
+	/* Set flags to verify that the structure has not changed. */
+	intf.dwCtlFlags = -1;
+	flags = 0;
+	res = wzc_query_interf(NULL, INTFCTL_ENABLED, &intf, &flags);
+	if (res != 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: Could not query flags for the "
+			   "WZC interface: %d (0x%x)",
+			   (int) res, (int) res);
+		wpa_printf(MSG_DEBUG, "NDIS: GetLastError: %u",
+		goto fail;
+	wpa_printf(MSG_DEBUG, "NDIS: WZC interface flags 0x%x dwCtlFlags 0x%x",
+		   (int) flags, (int) intf.dwCtlFlags);
+	if (intf.dwCtlFlags == -1) {
+		wpa_printf(MSG_DEBUG, "NDIS: Looks like wzcsapi has changed "
+			   "again - could not disable WZC");
+		wpa_hexdump(MSG_MSGDUMP, "NDIS: intf",
+			    (u8 *) &intf, sizeof(intf));
+		goto fail;
+	if (enable) {
+		if (!(intf.dwCtlFlags & INTFCTL_ENABLED)) {
+			wpa_printf(MSG_DEBUG, "NDIS: Enabling WZC for this "
+				   "interface");
+			intf.dwCtlFlags |= INTFCTL_ENABLED;
+			res = wzc_set_interf(NULL, INTFCTL_ENABLED, &intf,
+					     &flags);
+			if (res != 0) {
+				wpa_printf(MSG_DEBUG, "NDIS: Failed to enable "
+					   "WZC: %d (0x%x)",
+				goto fail;
+			wpa_printf(MSG_DEBUG, "NDIS: Re-enabled WZC for this "
+				   "interface");
+			drv->wzc_disabled = 0;
+	} else {
+		if (intf.dwCtlFlags & INTFCTL_ENABLED) {
+			wpa_printf(MSG_DEBUG, "NDIS: Disabling WZC for this "
+				   "interface");
+			intf.dwCtlFlags &= ~INTFCTL_ENABLED;
+					     &flags);
+			if (res != 0) {
+				wpa_printf(MSG_DEBUG, "NDIS: Failed to "
+					   "disable WZC: %d (0x%x)",
+				goto fail;
+			wpa_printf(MSG_DEBUG, "NDIS: Disabled WZC temporarily "
+				   "for this interface");
+		} else {
+			wpa_printf(MSG_DEBUG, "NDIS: WZC was not enabled for "
+				   "this interface");
+	ret = 0;
+fail:
+	FreeLibrary(hm);
+	return ret;
+#endif /* _WIN32_WCE */
+#else /* CONFIG_NATIVE_WINDOWS || __CYGWIN__ */
+				   int enable)
+	return 0;
+#endif /* CONFIG_NATIVE_WINDOWS || __CYGWIN__ */
+#ifdef CONFIG_USE_NDISUIO
+ * l2_packet_ndis.c is sharing the same handle to NDISUIO, so we must be able
+ * to export this handle. This is somewhat ugly, but there is no better
+ * mechanism available to pass data from driver interface to l2_packet wrapper.
+static HANDLE driver_ndis_ndisuio_handle = INVALID_HANDLE_VALUE;
+HANDLE driver_ndis_get_ndisuio_handle(void)
+	return driver_ndis_ndisuio_handle;
+#endif /* CONFIG_USE_NDISUIO */
+static int wpa_driver_ndis_adapter_init(struct wpa_driver_ndis_data *drv)
+#ifndef _WIN32_WCE
+#define NDISUIO_DEVICE_NAME TEXT("\\\\.\\\\Ndisuio")
+	DWORD written;
+	drv->ndisuio = CreateFile(NDISUIO_DEVICE_NAME,
+				  GENERIC_READ | GENERIC_WRITE, 0, NULL,
+				  OPEN_EXISTING,
+				  FILE_ATTRIBUTE_NORMAL | FILE_FLAG_OVERLAPPED,
+				  INVALID_HANDLE_VALUE);
+	if (drv->ndisuio == INVALID_HANDLE_VALUE) {
+		wpa_printf(MSG_ERROR, "NDIS: Failed to open connection to "
+			   "NDISUIO: %d", (int) GetLastError());
+		return -1;
+	driver_ndis_ndisuio_handle = drv->ndisuio;
+#ifndef _WIN32_WCE
+	if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_BIND_WAIT, NULL, 0,
+			     NULL, 0, &written, NULL)) {
+		wpa_printf(MSG_ERROR, "NDIS: IOCTL_NDISUIO_BIND_WAIT failed: "
+			   "%d", (int) GetLastError());
+		CloseHandle(drv->ndisuio);
+		drv->ndisuio = INVALID_HANDLE_VALUE;
+		return -1;
+	return 0;
+#else /* CONFIG_USE_NDISUIO */
+	return 0;
+static int wpa_driver_ndis_adapter_open(struct wpa_driver_ndis_data *drv)
+	DWORD written;
+#define MAX_NDIS_DEVICE_NAME_LEN 256
+	WCHAR ifname[MAX_NDIS_DEVICE_NAME_LEN];
+	size_t len, i, pos;
+	const char *prefix = "\\DEVICE\\";
+#ifdef _WIN32_WCE
+	pos = 0;
+	pos = 8;
+	len = pos + os_strlen(drv->ifname);
+	if (len >= MAX_NDIS_DEVICE_NAME_LEN)
+		return -1;
+	for (i = 0; i < pos; i++)
+		ifname[i] = (WCHAR) prefix[i];
+	for (i = pos; i < len; i++)
+		ifname[i] = (WCHAR) drv->ifname[i - pos];
+	ifname[i] = L'\0';
+	if (!DeviceIoControl(drv->ndisuio, IOCTL_NDISUIO_OPEN_DEVICE,
+			     ifname, len * sizeof(WCHAR), NULL, 0, &written,
+			     NULL)) {
+		wpa_printf(MSG_ERROR, "NDIS: IOCTL_NDISUIO_OPEN_DEVICE "
+			   "failed: %d", (int) GetLastError());
+		wpa_hexdump_ascii(MSG_DEBUG, "NDIS: ifname",
+				  (const u8 *) ifname, len * sizeof(WCHAR));
+		return -1;
+	wpa_printf(MSG_DEBUG, "NDIS: Opened NDISUIO device successfully");
+	return 0;
+	char ifname[128];
+	os_snprintf(ifname, sizeof(ifname), "\\Device\\NPF_%s", drv->ifname);
+	drv->adapter = PacketOpenAdapter(ifname);
+	if (drv->adapter == NULL) {
+		wpa_printf(MSG_DEBUG, "NDIS: PacketOpenAdapter failed for "
+			   "'%s'", ifname);
+		return -1;
+	return 0;
+static void wpa_driver_ndis_adapter_close(struct wpa_driver_ndis_data *drv)
+	driver_ndis_ndisuio_handle = INVALID_HANDLE_VALUE;
+	if (drv->ndisuio != INVALID_HANDLE_VALUE)
+	if (drv->adapter)
+		PacketCloseAdapter(drv->adapter);
+static int ndis_add_multicast(struct wpa_driver_ndis_data *drv)
+	if (ndis_set_oid(drv, OID_802_3_MULTICAST_LIST,
+			 (const char *) pae_group_addr, ETH_ALEN) < 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: Failed to add PAE group address "
+			   "to the multicast list");
+		return -1;
+	return 0;
+static void * wpa_driver_ndis_init(void *ctx, const char *ifname)
+	struct wpa_driver_ndis_data *drv;
+	u32 mode;
+	drv = os_zalloc(sizeof(*drv));
+	if (drv == NULL)
+		return NULL;
+	drv->ctx = ctx;
+	 * Compatibility code to strip possible prefix from the GUID. Previous
+	 * versions include \Device\NPF_ prefix for all names, but the internal
+	 * interface name is now only the GUI. Both Packet32 and NDISUIO
+	 * prefixes are supported.
+	if (os_strncmp(ifname, "\\Device\\NPF_", 12) == 0)
+		ifname += 12;
+	else if (os_strncmp(ifname, "\\DEVICE\\", 8) == 0)
+		ifname += 8;
+	os_strlcpy(drv->ifname, ifname, sizeof(drv->ifname));
+	if (wpa_driver_ndis_adapter_init(drv) < 0) {
+		os_free(drv);
+		return NULL;
+	if (wpa_driver_ndis_get_names(drv) < 0) {
+		os_free(drv);
+		return NULL;
+	wpa_driver_ndis_set_wzc(drv, 0);
+	if (wpa_driver_ndis_adapter_open(drv) < 0) {
+		os_free(drv);
+		return NULL;
+	if (ndis_get_oid(drv, OID_802_3_CURRENT_ADDRESS,
+			 (char *) drv->own_addr, ETH_ALEN) < 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: Get OID_802_3_CURRENT_ADDRESS "
+			   "failed");
+		os_free(drv);
+		return NULL;
+	wpa_driver_ndis_get_capability(drv);
+	/* Make sure that the driver does not have any obsolete PMKID entries.
+	wpa_driver_ndis_flush_pmkid(drv);
+	 * Disconnect to make sure that driver re-associates if it was
+	 * connected.
+	wpa_driver_ndis_disconnect(drv);
+	eloop_register_timeout(1, 0, wpa_driver_ndis_poll_timeout, drv, NULL);
+#ifdef CONFIG_NDIS_EVENTS_INTEGRATED
+	drv->events = ndis_events_init(&drv->events_pipe, &drv->event_avail,
+				       drv->ifname, drv->adapter_desc);
+	if (drv->events == NULL) {
+		wpa_driver_ndis_deinit(drv);
+		return NULL;
+	eloop_register_event(drv->event_avail, sizeof(drv->event_avail),
+			     wpa_driver_ndis_event_pipe_cb, drv, NULL);
+#endif /* CONFIG_NDIS_EVENTS_INTEGRATED */
+#ifdef _WIN32_WCE
+	if (ndisuio_notification_init(drv) < 0) {
+		return NULL;
+	/* Set mode here in case card was configured for ad-hoc mode
+	 * previously. */
+		char buf[8];
+		int res;
+			   (int) mode);
+		res = ndis_get_oid(drv, OID_DOT11_CURRENT_OPERATION_MODE, buf,
+				   sizeof(buf));
+		if (res > 0) {
+			wpa_printf(MSG_INFO, "NDIS: The driver seems to use "
+				   "Native 802.11 OIDs. These are not yet "
+				   "fully supported.");
+			drv->native80211 = 1;
+		} else if (!drv->has_capability || drv->capa.enc == 0) {
+			 * Note: This will also happen with NDIS 6 drivers with
+			 * Vista.
+			wpa_printf(MSG_DEBUG, "NDIS: Driver did not provide "
+				   "any wireless capabilities - assume it is "
+				   "a wired interface");
+			drv->wired = 1;
+			drv->capa.flags |= WPA_DRIVER_FLAGS_WIRED;
+			ndis_add_multicast(drv);
+	return drv;
+static void wpa_driver_ndis_deinit(void *priv)
+	if (drv->events) {
+		eloop_unregister_event(drv->event_avail,
+				       sizeof(drv->event_avail));
+		ndis_events_deinit(drv->events);
+#ifdef _WIN32_WCE
+	if (wpa_driver_ndis_radio_off(drv) < 0) {
+		wpa_printf(MSG_DEBUG, "NDIS: failed to disassociate and turn "
+			   "radio off");
+	if (drv->wzc_disabled)
+		wpa_driver_ndis_set_wzc(drv, 1);
+#ifdef _WIN32_WCE
+	os_free(drv->adapter_name);
+	os_free(drv->adapter_desc);
+	os_free(drv);
+static struct wpa_interface_info *
+wpa_driver_ndis_get_interfaces(void *global_priv)
+	struct wpa_interface_info *iface = NULL, *niface;
+	int i, error;
+	DWORD written;
+	char name[256], desc[256];
+	WCHAR *pos;
+	size_t j, len;
+	HANDLE ndisuio;
+	ndisuio = CreateFile(NDISUIO_DEVICE_NAME,
+			     OPEN_EXISTING,
+	if (ndisuio == INVALID_HANDLE_VALUE) {
+		return NULL;
+#ifndef _WIN32_WCE
+	if (!DeviceIoControl(ndisuio, IOCTL_NDISUIO_BIND_WAIT, NULL, 0,
+		CloseHandle(ndisuio);
+		return NULL;
+	if (b == NULL) {
+		return NULL;
+		if (!DeviceIoControl(ndisuio, IOCTL_NDISUIO_QUERY_BINDING,
+				break;
+			break;
+		name[len] = '\0';
+		desc[len] = '\0';
+		niface = os_zalloc(sizeof(*niface));
+		if (niface == NULL)
+			break;
+		niface->drv_name = "ndis";
+		if (os_strncmp(name, "\\DEVICE\\", 8) == 0)
+			niface->ifname = os_strdup(name + 8);
+		else
+			niface->ifname = os_strdup(name);
+		if (niface->ifname == NULL) {
+			os_free(niface);
+			break;
+		niface->desc = os_strdup(desc);
+		niface->next = iface;
+		iface = niface;
+	os_free(b);
+	PTSTR _names;
+	ULONG len;
+	BOOLEAN res;
+	int num_name, num_desc, i;
+	len = 8192;
+		return NULL;
+		os_free(_names);
+			return NULL;
+	if (!res) {
+		os_free(_names);
+		return NULL;
+			   "UNICODE");
+				pos2 += 4;
+				break;
+			*pos++ = pos2[0];
+			pos2 += 2;
+		pos += 2;
+	} else
+		pos = names;
+	num_name = 0;
+			pos++;
+			os_free(names);
+			return NULL;
+		pos++;
+		num_name++;
+			os_free(names);
+			return NULL;
+				   num_name);
+			pos++;
+			break;
+	num_desc = 0;
+			pos++;
+			os_free(names);
+			return NULL;
+		pos++;
+		num_desc++;
+				   "descriptions");
+			os_free(names);
+			return NULL;
+			pos++;
+			break;
+		os_free(names);
+		return NULL;
+			break;
+		if (os_strncmp(name[i], "\\Device\\NPF_", 12) == 0)
+			niface->ifname = os_strdup(name[i] + 12);
+		else
+			niface->ifname = os_strdup(name[i]);
+			os_free(niface);
+			break;
+		niface->desc = os_strdup(desc[i]);
+		iface = niface;
+	return iface;
+static const char *ndis_drv_name = "ndis";
+static const char *ndis_drv_desc = "Windows NDIS driver";
+struct wpa_driver_ops wpa_driver_ndis_ops;
+void driver_ndis_init_ops(void)
+	os_memset(&wpa_driver_ndis_ops, 0, sizeof(wpa_driver_ndis_ops));
+	wpa_driver_ndis_ops.name = ndis_drv_name;
+	wpa_driver_ndis_ops.desc = ndis_drv_desc;
+	wpa_driver_ndis_ops.get_bssid = wpa_driver_ndis_get_bssid;
+	wpa_driver_ndis_ops.get_ssid = wpa_driver_ndis_get_ssid;
+	wpa_driver_ndis_ops.set_key = wpa_driver_ndis_set_key;
+	wpa_driver_ndis_ops.init = wpa_driver_ndis_init;
+	wpa_driver_ndis_ops.deinit = wpa_driver_ndis_deinit;
+	wpa_driver_ndis_ops.deauthenticate = wpa_driver_ndis_deauthenticate;
+	wpa_driver_ndis_ops.associate = wpa_driver_ndis_associate;
+	wpa_driver_ndis_ops.add_pmkid = wpa_driver_ndis_add_pmkid;
+	wpa_driver_ndis_ops.remove_pmkid = wpa_driver_ndis_remove_pmkid;
+	wpa_driver_ndis_ops.flush_pmkid = wpa_driver_ndis_flush_pmkid;
+	wpa_driver_ndis_ops.get_capa = wpa_driver_ndis_get_capa;
+	wpa_driver_ndis_ops.poll = wpa_driver_ndis_poll;
+	wpa_driver_ndis_ops.get_ifname = wpa_driver_ndis_get_ifname;
+	wpa_driver_ndis_ops.get_mac_addr = wpa_driver_ndis_get_mac_addr;
+	wpa_driver_ndis_ops.get_scan_results2 =
+		wpa_driver_ndis_get_scan_results;
+	wpa_driver_ndis_ops.get_interfaces = wpa_driver_ndis_get_interfaces;
+	wpa_driver_ndis_ops.scan2 = wpa_driver_ndis_scan;
diff --git a/freebsd/contrib/wpa/src/drivers/driver_ndis.h b/freebsd/contrib/wpa/src/drivers/driver_ndis.h
new file mode 100644
index 00000000000..89d136d3b42
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver_ndis.h
@@ -0,0 +1,59 @@
+ * WPA Supplicant - Windows/NDIS driver interface
+ * Copyright (c) 2004-2006, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef DRIVER_NDIS_H
+#define DRIVER_NDIS_H
+struct ndis_events_data;
+struct ndis_events_data * ndis_events_init(HANDLE *read_pipe, HANDLE *event,
+					   const char *ifname,
+					   const char *desc);
+void ndis_events_deinit(struct ndis_events_data *events);
+struct ndis_pmkid_entry {
+	struct ndis_pmkid_entry *next;
+	u8 pmkid[16];
+struct wpa_driver_ndis_data {
+	void *ctx;
+	char ifname[100]; /* GUID: {7EE3EFE5-C165-472F-986D-F6FBEDFE8C8D} */
+#ifdef _WIN32_WCE
+	TCHAR *adapter_name;
+	HANDLE event_queue; /* NDISUIO notifier MsgQueue */
+	HANDLE connected_event; /* WpaSupplicantConnected event */
+	u8 own_addr[ETH_ALEN];
+	HANDLE ndisuio;
+	LPADAPTER adapter;
+	int has_capability;
+	int no_of_pmkid;
+	int radio_enabled;
+	struct wpa_driver_capa capa;
+	struct ndis_pmkid_entry *pmkid;
+	char *adapter_desc;
+	int wired;
+	int native80211;
+	int mode;
+	int wzc_disabled;
+	int oid_bssid_set;
+	HANDLE events_pipe, event_avail;
+	struct ndis_events_data *events;
+#endif /* DRIVER_NDIS_H */
diff --git a/freebsd/contrib/wpa/src/drivers/driver_nl80211.h b/freebsd/contrib/wpa/src/drivers/driver_nl80211.h
index 00000000000..5c21e0faf55
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver_nl80211.h
@@ -0,0 +1,277 @@
+ * Driver interaction with Linux nl80211/cfg80211 - definitions
+ * Copyright (c) 2002-2014, Jouni Malinen <j at w1.fi>
+ * Copyright (c) 2003-2004, Instant802 Networks, Inc.
+ * Copyright (c) 2005-2006, Devicescape Software, Inc.
+ * Copyright (c) 2007, Johannes Berg <johannes at sipsolutions.net>
+ * Copyright (c) 2009-2010, Atheros Communications
+#ifndef DRIVER_NL80211_H
+#define DRIVER_NL80211_H
+#include "nl80211_copy.h"
+#include "utils/list.h"
+#include "driver.h"
+#ifdef CONFIG_LIBNL20
+/* libnl 2.0 compatibility code */
+#define nl_handle nl_sock
+#define nl80211_handle_alloc nl_socket_alloc_cb
+#define nl80211_handle_destroy nl_socket_free
+#endif /* CONFIG_LIBNL20 */
+struct nl80211_global {
+	struct dl_list interfaces;
+	int if_add_ifindex;
+	u64 if_add_wdevid;
+	int if_add_wdevid_set;
+	struct netlink_data *netlink;
+	struct nl_cb *nl_cb;
+	struct nl_handle *nl;
+	int nl80211_id;
+	int ioctl_sock; /* socket for ioctl() use */
+	struct nl_handle *nl_event;
+struct nl80211_wiphy_data {
+	struct dl_list list;
+	struct dl_list bsss;
+	struct dl_list drvs;
+	struct nl_handle *nl_beacons;
+	int wiphy_idx;
+struct i802_bss {
+	struct wpa_driver_nl80211_data *drv;
+	struct i802_bss *next;
+	int ifindex;
+	int br_ifindex;
+	u64 wdev_id;
+	char ifname[IFNAMSIZ + 1];
+	char brname[IFNAMSIZ];
+	unsigned int beacon_set:1;
+	unsigned int added_if_into_bridge:1;
+	unsigned int added_bridge:1;
+	unsigned int in_deinit:1;
+	unsigned int wdev_id_set:1;
+	unsigned int added_if:1;
+	unsigned int static_ap:1;
+	u8 addr[ETH_ALEN];
+	int freq;
+	int bandwidth;
+	int if_dynamic;
+	void *ctx;
+	struct nl_handle *nl_preq, *nl_mgmt;
+	struct nl80211_wiphy_data *wiphy_data;
+	struct dl_list wiphy_list;
+struct wpa_driver_nl80211_data {
+	struct nl80211_global *global;
+	char phyname[32];
+	u8 perm_addr[ETH_ALEN];
+	void *ctx;
+	int ifindex;
+	int if_removed;
+	int if_disabled;
+	int ignore_if_down_event;
+	struct rfkill_data *rfkill;
+	u8 *extended_capa, *extended_capa_mask;
+	unsigned int extended_capa_len;
+	int operstate;
+	int scan_complete_events;
+	enum scan_states {
+		NO_SCAN, SCAN_REQUESTED, SCAN_STARTED, SCAN_COMPLETED,
+		SCAN_ABORTED, SCHED_SCAN_STARTED, SCHED_SCAN_STOPPED,
+		SCHED_SCAN_RESULTS
+	} scan_state;
+	u8 auth_bssid[ETH_ALEN];
+	u8 auth_attempt_bssid[ETH_ALEN];
+	u8 prev_bssid[ETH_ALEN];
+	int associated;
+	u8 ssid[SSID_MAX_LEN];
+	size_t ssid_len;
+	enum nl80211_iftype nlmode;
+	enum nl80211_iftype ap_scan_as_station;
+	unsigned int assoc_freq;
+	int monitor_sock;
+	int monitor_ifidx;
+	int monitor_refcount;
+	unsigned int disabled_11b_rates:1;
+	unsigned int pending_remain_on_chan:1;
+	unsigned int in_interface_list:1;
+	unsigned int device_ap_sme:1;
+	unsigned int poll_command_supported:1;
+	unsigned int data_tx_status:1;
+	unsigned int scan_for_auth:1;
+	unsigned int retry_auth:1;
+	unsigned int use_monitor:1;
+	unsigned int ignore_next_local_disconnect:1;
+	unsigned int ignore_next_local_deauth:1;
+	unsigned int hostapd:1;
+	unsigned int start_mode_ap:1;
+	unsigned int start_iface_up:1;
+	unsigned int test_use_roc_tx:1;
+	unsigned int ignore_deauth_event:1;
+	unsigned int vendor_cmd_test_avail:1;
+	unsigned int roaming_vendor_cmd_avail:1;
+	unsigned int dfs_vendor_cmd_avail:1;
+	unsigned int have_low_prio_scan:1;
+	unsigned int force_connect_cmd:1;
+	unsigned int addr_changed:1;
+	unsigned int get_features_vendor_cmd_avail:1;
+	unsigned int set_rekey_offload:1;
+	unsigned int p2p_go_ctwindow_supported:1;
+	unsigned int setband_vendor_cmd_avail:1;
+	unsigned int get_pref_freq_list:1;
+	unsigned int set_prob_oper_freq:1;
+	u64 remain_on_chan_cookie;
+	u64 send_action_cookie;
+	unsigned int last_mgmt_freq;
+	struct wpa_driver_scan_filter *filter_ssids;
+	size_t num_filter_ssids;
+	struct i802_bss *first_bss;
+	int eapol_tx_sock;
+	int eapol_sock; /* socket for EAPOL frames */
+	struct nl_handle *rtnl_sk; /* nl_sock for NETLINK_ROUTE */
+	int default_if_indices[16];
+	int *if_indices;
+	int num_if_indices;
+	/* From failed authentication command */
+	int auth_freq;
+	u8 auth_bssid_[ETH_ALEN];
+	u8 auth_ssid[SSID_MAX_LEN];
+	size_t auth_ssid_len;
+	int auth_alg;
+	u8 *auth_ie;
+	size_t auth_ie_len;
+	u8 auth_wep_key[4][16];
+	size_t auth_wep_key_len[4];
+	int auth_wep_tx_keyidx;
+	int auth_local_state_change;
+	int auth_p2p;
+struct nl_msg;
+void * nl80211_cmd(struct wpa_driver_nl80211_data *drv,
+		   struct nl_msg *msg, int flags, uint8_t cmd);
+struct nl_msg * nl80211_cmd_msg(struct i802_bss *bss, int flags, uint8_t cmd);
+struct nl_msg * nl80211_drv_msg(struct wpa_driver_nl80211_data *drv, int flags,
+				uint8_t cmd);
+struct nl_msg * nl80211_bss_msg(struct i802_bss *bss, int flags, uint8_t cmd);
+int send_and_recv_msgs(struct wpa_driver_nl80211_data *drv, struct nl_msg *msg,
+		       int (*valid_handler)(struct nl_msg *, void *),
+		       void *valid_data);
+int nl80211_create_iface(struct wpa_driver_nl80211_data *drv,
+			 const char *ifname, enum nl80211_iftype iftype,
+			 const u8 *addr, int wds,
+			 int (*handler)(struct nl_msg *, void *),
+			 void *arg, int use_existing);
+void nl80211_remove_iface(struct wpa_driver_nl80211_data *drv, int ifidx);
+unsigned int nl80211_get_assoc_freq(struct wpa_driver_nl80211_data *drv);
+enum chan_width convert2width(int width);
+void nl80211_mark_disconnected(struct wpa_driver_nl80211_data *drv);
+struct i802_bss * get_bss_ifindex(struct wpa_driver_nl80211_data *drv,
+				  int ifindex);
+int is_ap_interface(enum nl80211_iftype nlmode);
+int is_sta_interface(enum nl80211_iftype nlmode);
+int wpa_driver_nl80211_authenticate_retry(struct wpa_driver_nl80211_data *drv);
+int nl80211_get_link_signal(struct wpa_driver_nl80211_data *drv,
+			    struct wpa_signal_info *sig);
+int nl80211_get_link_noise(struct wpa_driver_nl80211_data *drv,
+			   struct wpa_signal_info *sig_change);
+int nl80211_get_wiphy_index(struct i802_bss *bss);
+int wpa_driver_nl80211_set_mode(struct i802_bss *bss,
+				enum nl80211_iftype nlmode);
+int wpa_driver_nl80211_mlme(struct wpa_driver_nl80211_data *drv,
+			    const u8 *addr, int cmd, u16 reason_code,
+			    int local_state_change);
+int nl80211_create_monitor_interface(struct wpa_driver_nl80211_data *drv);
+void nl80211_remove_monitor_interface(struct wpa_driver_nl80211_data *drv);
+int nl80211_send_monitor(struct wpa_driver_nl80211_data *drv,
+			 const void *data, size_t len,
+			 int encrypt, int noack);
+int wpa_driver_nl80211_capa(struct wpa_driver_nl80211_data *drv);
+struct hostapd_hw_modes *
+nl80211_get_hw_feature_data(void *priv, u16 *num_modes, u16 *flags);
+int process_global_event(struct nl_msg *msg, void *arg);
+int process_bss_event(struct nl_msg *msg, void *arg);
+#ifdef ANDROID
+int android_nl_socket_set_nonblocking(struct nl_handle *handle);
+int android_pno_start(struct i802_bss *bss,
+		      struct wpa_driver_scan_params *params);
+int android_pno_stop(struct i802_bss *bss);
+extern int wpa_driver_nl80211_driver_cmd(void *priv, char *cmd, char *buf,
+					 size_t buf_len);
+#ifdef ANDROID_P2P
+int wpa_driver_set_p2p_noa(void *priv, u8 count, int start, int duration);
+int wpa_driver_get_p2p_noa(void *priv, u8 *buf, size_t len);
+int wpa_driver_set_p2p_ps(void *priv, int legacy_ps, int opp_ps, int ctwindow);
+int wpa_driver_set_ap_wps_p2p_ie(void *priv, const struct wpabuf *beacon,
+				 const struct wpabuf *proberesp,
+				 const struct wpabuf *assocresp);
+#endif /* ANDROID_P2P */
+#endif /* ANDROID */
+/* driver_nl80211_scan.c */
+struct nl80211_bss_info_arg {
+	struct wpa_scan_results *res;
+	unsigned int ibss_freq;
+	u8 assoc_bssid[ETH_ALEN];
+int bss_info_handler(struct nl_msg *msg, void *arg);
+void wpa_driver_nl80211_scan_timeout(void *eloop_ctx, void *timeout_ctx);
+int wpa_driver_nl80211_scan(struct i802_bss *bss,
+int wpa_driver_nl80211_sched_scan(void *priv,
+				  struct wpa_driver_scan_params *params,
+				  u32 interval);
+int wpa_driver_nl80211_stop_sched_scan(void *priv);
+struct wpa_scan_results * wpa_driver_nl80211_get_scan_results(void *priv);
+void nl80211_dump_scan(struct wpa_driver_nl80211_data *drv);
+const u8 * nl80211_get_ie(const u8 *ies, size_t ies_len, u8 ie);
+#endif /* DRIVER_NL80211_H */
diff --git a/freebsd/contrib/wpa/src/drivers/driver_wired.c b/freebsd/contrib/wpa/src/drivers/driver_wired.c
index 00000000000..b30d47cf46d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/driver_wired.c
@@ -0,0 +1,681 @@
+#include <machine/rtems-bsd-user-space.h>
+ * Wired Ethernet driver interface
+ * Copyright (c) 2005-2009, Jouni Malinen <j at w1.fi>
+ * Copyright (c) 2004, Gunter Burchardt <tira at isx.de>
+#include "includes.h"
+#include <sys/ioctl.h>
+#include <net/if.h>
+#ifdef __linux__
+#include <netpacket/packet.h>
+#include <net/if_arp.h>
+#endif /* __linux__ */
+#if defined(__FreeBSD__) || defined(__DragonFly__) || defined(__FreeBSD_kernel__)
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#endif /* defined(__FreeBSD__) || defined(__DragonFly__) || defined(__FreeBSD_kernel__) */
+#ifdef __sun__
+#include <sys/sockio.h>
+#endif /* __sun__ */
+#include "common.h"
+#include "eloop.h"
+#ifdef _MSC_VER
+#pragma pack(push, 1)
+#endif /* _MSC_VER */
+struct ieee8023_hdr {
+	u8 dest[6];
+	u8 src[6];
+	u16 ethertype;
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+static const u8 pae_group_addr[ETH_ALEN] =
+{ 0x01, 0x80, 0xc2, 0x00, 0x00, 0x03 };
+struct wpa_driver_wired_data {
+	void *ctx;
+	int sock; /* raw packet socket for driver access */
+	int dhcp_sock; /* socket for dhcp packets */
+	int use_pae_group_addr;
+	int pf_sock;
+	int membership, multi, iff_allmulti, iff_up;
+/* TODO: detecting new devices should eventually be changed from using DHCP
+ * snooping to trigger on any packet from a new layer 2 MAC address, e.g.,
+ * based on ebtables, etc. */
+struct dhcp_message {
+	u_int8_t op;
+	u_int8_t htype;
+	u_int8_t hlen;
+	u_int8_t hops;
+	u_int32_t xid;
+	u_int16_t secs;
+	u_int16_t flags;
+	u_int32_t ciaddr;
+	u_int32_t yiaddr;
+	u_int32_t siaddr;
+	u_int32_t giaddr;
+	u_int8_t chaddr[16];
+	u_int8_t sname[64];
+	u_int8_t file[128];
+	u_int32_t cookie;
+	u_int8_t options[308]; /* 312 - cookie */
+static int wired_multicast_membership(int sock, int ifindex,
+				      const u8 *addr, int add)
+#ifdef __linux__
+	struct packet_mreq mreq;
+	if (sock < 0)
+		return -1;
+	os_memset(&mreq, 0, sizeof(mreq));
+	mreq.mr_ifindex = ifindex;
+	mreq.mr_type = PACKET_MR_MULTICAST;
+	mreq.mr_alen = ETH_ALEN;
+	os_memcpy(mreq.mr_address, addr, ETH_ALEN);
+	if (setsockopt(sock, SOL_PACKET,
+		       add ? PACKET_ADD_MEMBERSHIP : PACKET_DROP_MEMBERSHIP,
+		       &mreq, sizeof(mreq)) < 0) {
+		wpa_printf(MSG_ERROR, "setsockopt: %s", strerror(errno));
+		return -1;
+	return 0;
+#else /* __linux__ */
+	return -1;
+#ifdef __linux__
+static void handle_data(void *ctx, unsigned char *buf, size_t len)
+#ifdef HOSTAPD
+	struct ieee8023_hdr *hdr;
+	u8 *pos, *sa;
+	size_t left;
+	/* must contain at least ieee8023_hdr 6 byte source, 6 byte dest,
+	 * 2 byte ethertype */
+	if (len < 14) {
+		wpa_printf(MSG_MSGDUMP, "handle_data: too short (%lu)",
+			   (unsigned long) len);
+		return;
+	hdr = (struct ieee8023_hdr *) buf;
+	switch (ntohs(hdr->ethertype)) {
+		case ETH_P_PAE:
+			wpa_printf(MSG_MSGDUMP, "Received EAPOL packet");
+			sa = hdr->src;
+			event.new_sta.addr = sa;
+			wpa_supplicant_event(ctx, EVENT_NEW_STA, &event);
+			pos = (u8 *) (hdr + 1);
+			left = len - sizeof(*hdr);
+			drv_event_eapol_rx(ctx, sa, pos, left);
+		break;
+	default:
+		wpa_printf(MSG_DEBUG, "Unknown ethertype 0x%04x in data frame",
+			   ntohs(hdr->ethertype));
+		break;
+#endif /* HOSTAPD */
+static void handle_read(int sock, void *eloop_ctx, void *sock_ctx)
+	int len;
+	unsigned char buf[3000];
+	len = recv(sock, buf, sizeof(buf), 0);
+	if (len < 0) {
+		wpa_printf(MSG_ERROR, "recv: %s", strerror(errno));
+		return;
+	handle_data(eloop_ctx, buf, len);
+static void handle_dhcp(int sock, void *eloop_ctx, void *sock_ctx)
+	int len;
+	struct dhcp_message *msg;
+	u8 *mac_address;
+	if (len < 0) {
+		return;
+	/* must contain at least dhcp_message->chaddr */
+	if (len < 44) {
+		wpa_printf(MSG_MSGDUMP, "handle_dhcp: too short (%d)", len);
+		return;
+	msg = (struct dhcp_message *) buf;
+	mac_address = (u8 *) &(msg->chaddr);
+	wpa_printf(MSG_MSGDUMP, "Got DHCP broadcast packet from " MACSTR,
+		   MAC2STR(mac_address));
+	event.new_sta.addr = mac_address;
+	wpa_supplicant_event(eloop_ctx, EVENT_NEW_STA, &event);
+static int wired_init_sockets(struct wpa_driver_wired_data *drv, u8 *own_addr)
+#ifdef __linux__
+	struct ifreq ifr;
+	struct sockaddr_ll addr;
+	struct sockaddr_in addr2;
+	int n = 1;
+	drv->sock = socket(PF_PACKET, SOCK_RAW, htons(ETH_P_PAE));
+	if (drv->sock < 0) {
+		wpa_printf(MSG_ERROR, "socket[PF_PACKET,SOCK_RAW]: %s",
+			   strerror(errno));
+		return -1;
+	if (eloop_register_read_sock(drv->sock, handle_read, drv->ctx, NULL)) {
+		wpa_printf(MSG_INFO, "Could not register read socket");
+		return -1;
+	os_memset(&ifr, 0, sizeof(ifr));
+	os_strlcpy(ifr.ifr_name, drv->ifname, sizeof(ifr.ifr_name));
+	if (ioctl(drv->sock, SIOCGIFINDEX, &ifr) != 0) {
+		wpa_printf(MSG_ERROR, "ioctl(SIOCGIFINDEX): %s",
+			   strerror(errno));
+		return -1;
+	os_memset(&addr, 0, sizeof(addr));
+	addr.sll_family = AF_PACKET;
+	addr.sll_ifindex = ifr.ifr_ifindex;
+	wpa_printf(MSG_DEBUG, "Opening raw packet socket for ifindex %d",
+		   addr.sll_ifindex);
+	if (bind(drv->sock, (struct sockaddr *) &addr, sizeof(addr)) < 0) {
+		wpa_printf(MSG_ERROR, "bind: %s", strerror(errno));
+		return -1;
+	/* filter multicast address */
+	if (wired_multicast_membership(drv->sock, ifr.ifr_ifindex,
+				       pae_group_addr, 1) < 0) {
+		wpa_printf(MSG_ERROR, "wired: Failed to add multicast group "
+			   "membership");
+		return -1;
+	if (ioctl(drv->sock, SIOCGIFHWADDR, &ifr) != 0) {
+		wpa_printf(MSG_ERROR, "ioctl(SIOCGIFHWADDR): %s",
+			   strerror(errno));
+		return -1;
+	if (ifr.ifr_hwaddr.sa_family != ARPHRD_ETHER) {
+		wpa_printf(MSG_INFO, "Invalid HW-addr family 0x%04x",
+			   ifr.ifr_hwaddr.sa_family);
+		return -1;
+	os_memcpy(own_addr, ifr.ifr_hwaddr.sa_data, ETH_ALEN);
+	/* setup dhcp listen socket for sta detection */
+	if ((drv->dhcp_sock = socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP)) < 0) {
+		wpa_printf(MSG_ERROR, "socket call failed for dhcp: %s",
+			   strerror(errno));
+		return -1;
+	if (eloop_register_read_sock(drv->dhcp_sock, handle_dhcp, drv->ctx,
+				     NULL)) {
+		return -1;
+	os_memset(&addr2, 0, sizeof(addr2));
+	addr2.sin_family = AF_INET;
+	addr2.sin_port = htons(67);
+	addr2.sin_addr.s_addr = INADDR_ANY;
+	if (setsockopt(drv->dhcp_sock, SOL_SOCKET, SO_REUSEADDR, (char *) &n,
+		       sizeof(n)) == -1) {
+		wpa_printf(MSG_ERROR, "setsockopt[SOL_SOCKET,SO_REUSEADDR]: %s",
+			   strerror(errno));
+		return -1;
+	if (setsockopt(drv->dhcp_sock, SOL_SOCKET, SO_BROADCAST, (char *) &n,
+		wpa_printf(MSG_ERROR, "setsockopt[SOL_SOCKET,SO_BROADCAST]: %s",
+			   strerror(errno));
+		return -1;
+	os_strlcpy(ifr.ifr_ifrn.ifrn_name, drv->ifname, IFNAMSIZ);
+	if (setsockopt(drv->dhcp_sock, SOL_SOCKET, SO_BINDTODEVICE,
+		       (char *) &ifr, sizeof(ifr)) < 0) {
+			   "setsockopt[SOL_SOCKET,SO_BINDTODEVICE]: %s",
+			   strerror(errno));
+		return -1;
+	if (bind(drv->dhcp_sock, (struct sockaddr *) &addr2,
+		 sizeof(struct sockaddr)) == -1) {
+		return -1;
+	return 0;
+	return -1;
+static int wired_send_eapol(void *priv, const u8 *addr,
+			    const u8 *data, size_t data_len, int encrypt,
+			    const u8 *own_addr, u32 flags)
+	struct wpa_driver_wired_data *drv = priv;
+	size_t len;
+	u8 *pos;
+	int res;
+	len = sizeof(*hdr) + data_len;
+	hdr = os_zalloc(len);
+	if (hdr == NULL) {
+			   "malloc() failed for wired_send_eapol(len=%lu)",
+		return -1;
+	os_memcpy(hdr->dest, drv->use_pae_group_addr ? pae_group_addr : addr,
+		  ETH_ALEN);
+	os_memcpy(hdr->src, own_addr, ETH_ALEN);
+	hdr->ethertype = htons(ETH_P_PAE);
+	os_memcpy(pos, data, data_len);
+	res = send(drv->sock, (u8 *) hdr, len, 0);
+	os_free(hdr);
+	if (res < 0) {
+			   "wired_send_eapol - packet len: %lu - failed: send: %s",
+			   (unsigned long) len, strerror(errno));
+	return res;
+static void * wired_driver_hapd_init(struct hostapd_data *hapd,
+				     struct wpa_init_params *params)
+	struct wpa_driver_wired_data *drv;
+	drv = os_zalloc(sizeof(struct wpa_driver_wired_data));
+	if (drv == NULL) {
+			   "Could not allocate memory for wired driver data");
+		return NULL;
+	drv->ctx = hapd;
+	os_strlcpy(drv->ifname, params->ifname, sizeof(drv->ifname));
+	drv->use_pae_group_addr = params->use_pae_group_addr;
+	if (wired_init_sockets(drv, params->own_addr)) {
+		os_free(drv);
+		return NULL;
+	return drv;
+static void wired_driver_hapd_deinit(void *priv)
+	if (drv->sock >= 0) {
+		eloop_unregister_read_sock(drv->sock);
+		close(drv->sock);
+	if (drv->dhcp_sock >= 0) {
+		eloop_unregister_read_sock(drv->dhcp_sock);
+		close(drv->dhcp_sock);
+	os_free(drv);
+static int wpa_driver_wired_get_ssid(void *priv, u8 *ssid)
+	ssid[0] = 0;
+	return 0;
+static int wpa_driver_wired_get_bssid(void *priv, u8 *bssid)
+	/* Report PAE group address as the "BSSID" for wired connection. */
+	os_memcpy(bssid, pae_group_addr, ETH_ALEN);
+	return 0;
+static int wpa_driver_wired_get_capa(void *priv, struct wpa_driver_capa *capa)
+	os_memset(capa, 0, sizeof(*capa));
+	capa->flags = WPA_DRIVER_FLAGS_WIRED;
+	return 0;
+static int wpa_driver_wired_get_ifflags(const char *ifname, int *flags)
+	struct ifreq ifr;
+	int s;
+	s = socket(PF_INET, SOCK_DGRAM, 0);
+	if (s < 0) {
+		wpa_printf(MSG_ERROR, "socket: %s", strerror(errno));
+		return -1;
+	os_strlcpy(ifr.ifr_name, ifname, IFNAMSIZ);
+	if (ioctl(s, SIOCGIFFLAGS, (caddr_t) &ifr) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCGIFFLAGS]: %s",
+			   strerror(errno));
+		close(s);
+		return -1;
+	close(s);
+	*flags = ifr.ifr_flags & 0xffff;
+	return 0;
+static int wpa_driver_wired_set_ifflags(const char *ifname, int flags)
+	struct ifreq ifr;
+	int s;
+	if (s < 0) {
+		return -1;
+	ifr.ifr_flags = flags & 0xffff;
+	if (ioctl(s, SIOCSIFFLAGS, (caddr_t) &ifr) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCSIFFLAGS]: %s",
+			   strerror(errno));
+		close(s);
+		return -1;
+	close(s);
+	return 0;
+static int wpa_driver_wired_get_ifstatus(const char *ifname, int *status)
+	struct ifmediareq ifmr;
+	int s;
+	if (s < 0) {
+		return -1;
+	os_memset(&ifmr, 0, sizeof(ifmr));
+	os_strlcpy(ifmr.ifm_name, ifname, IFNAMSIZ);
+	if (ioctl(s, SIOCGIFMEDIA, (caddr_t) &ifmr) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOCGIFMEDIA]: %s",
+			   strerror(errno));
+		close(s);
+		return -1;
+	close(s);
+	*status = (ifmr.ifm_status & (IFM_ACTIVE | IFM_AVALID)) ==
+		(IFM_ACTIVE | IFM_AVALID);
+	return 0;
+#endif /* defined(__FreeBSD__) || defined(__DragonFly__) || defined(FreeBSD_kernel__) */
+static int wpa_driver_wired_multi(const char *ifname, const u8 *addr, int add)
+	struct ifreq ifr;
+	int s;
+#ifdef __sun__
+	return -1;
+	if (s < 0) {
+		return -1;
+#ifdef __linux__
+	ifr.ifr_hwaddr.sa_family = AF_UNSPEC;
+	os_memcpy(ifr.ifr_hwaddr.sa_data, addr, ETH_ALEN);
+		struct sockaddr_dl *dlp;
+		dlp = (struct sockaddr_dl *) &ifr.ifr_addr;
+		dlp->sdl_len = sizeof(struct sockaddr_dl);
+		dlp->sdl_family = AF_LINK;
+		dlp->sdl_index = 0;
+		dlp->sdl_nlen = 0;
+		dlp->sdl_alen = ETH_ALEN;
+		dlp->sdl_slen = 0;
+		os_memcpy(LLADDR(dlp), addr, ETH_ALEN);
+#if defined(__NetBSD__) || defined(__OpenBSD__) || defined(__APPLE__)
+		struct sockaddr *sap;
+		sap = (struct sockaddr *) &ifr.ifr_addr;
+		sap->sa_len = sizeof(struct sockaddr);
+		sap->sa_family = AF_UNSPEC;
+		os_memcpy(sap->sa_data, addr, ETH_ALEN);
+#endif /* defined(__NetBSD__) || defined(__OpenBSD__) || defined(__APPLE__) */
+	if (ioctl(s, add ? SIOCADDMULTI : SIOCDELMULTI, (caddr_t) &ifr) < 0) {
+		wpa_printf(MSG_ERROR, "ioctl[SIOC{ADD/DEL}MULTI]: %s",
+			   strerror(errno));
+		close(s);
+		return -1;
+	close(s);
+	return 0;
+static void * wpa_driver_wired_init(void *ctx, const char *ifname)
+	int flags, status;
+	if (drv == NULL)
+		return NULL;
+	drv->ctx = ctx;
+#ifdef __linux__
+	drv->pf_sock = socket(PF_PACKET, SOCK_DGRAM, 0);
+	if (drv->pf_sock < 0)
+		wpa_printf(MSG_ERROR, "socket(PF_PACKET): %s", strerror(errno));
+	drv->pf_sock = -1;
+	if (wpa_driver_wired_get_ifflags(ifname, &flags) == 0 &&
+	    !(flags & IFF_UP) &&
+	    wpa_driver_wired_set_ifflags(ifname, flags | IFF_UP) == 0) {
+		drv->iff_up = 1;
+	if (wired_multicast_membership(drv->pf_sock,
+				       if_nametoindex(drv->ifname),
+				       pae_group_addr, 1) == 0) {
+		wpa_printf(MSG_DEBUG, "%s: Added multicast membership with "
+			   "packet socket", __func__);
+		drv->membership = 1;
+	} else if (wpa_driver_wired_multi(ifname, pae_group_addr, 1) == 0) {
+			   "SIOCADDMULTI", __func__);
+		drv->multi = 1;
+	} else if (wpa_driver_wired_get_ifflags(ifname, &flags) < 0) {
+		wpa_printf(MSG_INFO, "%s: Could not get interface "
+			   "flags", __func__);
+		os_free(drv);
+		return NULL;
+	} else if (flags & IFF_ALLMULTI) {
+		wpa_printf(MSG_DEBUG, "%s: Interface is already configured "
+			   "for multicast", __func__);
+	} else if (wpa_driver_wired_set_ifflags(ifname,
+						flags | IFF_ALLMULTI) < 0) {
+		wpa_printf(MSG_INFO, "%s: Failed to enable allmulti",
+			   __func__);
+		os_free(drv);
+		return NULL;
+	} else {
+		wpa_printf(MSG_DEBUG, "%s: Enabled allmulti mode",
+			   __func__);
+		drv->iff_allmulti = 1;
+		int status;
+		wpa_printf(MSG_DEBUG, "%s: waiting for link to become active",
+			   __func__);
+		while (wpa_driver_wired_get_ifstatus(ifname, &status) == 0 &&
+		       status == 0)
+			sleep(1);
+	return drv;
+static void wpa_driver_wired_deinit(void *priv)
+	int flags;
+	if (drv->membership &&
+	    wired_multicast_membership(drv->pf_sock,
+				       pae_group_addr, 0) < 0) {
+		wpa_printf(MSG_DEBUG, "%s: Failed to remove PAE multicast "
+			   "group (PACKET)", __func__);
+	if (drv->multi &&
+	    wpa_driver_wired_multi(drv->ifname, pae_group_addr, 0) < 0) {
+			   "group (SIOCDELMULTI)", __func__);
+	if (drv->iff_allmulti &&
+	    (wpa_driver_wired_get_ifflags(drv->ifname, &flags) < 0 ||
+	     wpa_driver_wired_set_ifflags(drv->ifname,
+					  flags & ~IFF_ALLMULTI) < 0)) {
+		wpa_printf(MSG_DEBUG, "%s: Failed to disable allmulti mode",
+			   __func__);
+	if (drv->iff_up &&
+	    wpa_driver_wired_get_ifflags(drv->ifname, &flags) == 0 &&
+	    (flags & IFF_UP) &&
+	    wpa_driver_wired_set_ifflags(drv->ifname, flags & ~IFF_UP) < 0) {
+		wpa_printf(MSG_DEBUG, "%s: Failed to set the interface down",
+			   __func__);
+	if (drv->pf_sock != -1)
+		close(drv->pf_sock);
+	os_free(drv);
+const struct wpa_driver_ops wpa_driver_wired_ops = {
+	.name = "wired",
+	.desc = "Wired Ethernet driver",
+	.hapd_init = wired_driver_hapd_init,
+	.hapd_deinit = wired_driver_hapd_deinit,
+	.hapd_send_eapol = wired_send_eapol,
+	.get_ssid = wpa_driver_wired_get_ssid,
+	.get_bssid = wpa_driver_wired_get_bssid,
+	.get_capa = wpa_driver_wired_get_capa,
+	.init = wpa_driver_wired_init,
+	.deinit = wpa_driver_wired_deinit,
diff --git a/freebsd/contrib/wpa/src/drivers/drivers.c b/freebsd/contrib/wpa/src/drivers/drivers.c
index 00000000000..5a0b58c252a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/drivers.c
@@ -0,0 +1,88 @@
+ * Driver interface list
+ * Copyright (c) 2004-2005, Jouni Malinen <j at w1.fi>
+#include "utils/includes.h"
+#include "utils/common.h"
+#ifdef CONFIG_DRIVER_WEXT
+extern struct wpa_driver_ops wpa_driver_wext_ops; /* driver_wext.c */
+#endif /* CONFIG_DRIVER_WEXT */
+#ifdef CONFIG_DRIVER_NL80211
+extern struct wpa_driver_ops wpa_driver_nl80211_ops; /* driver_nl80211.c */
+#endif /* CONFIG_DRIVER_NL80211 */
+#ifdef CONFIG_DRIVER_HOSTAP
+extern struct wpa_driver_ops wpa_driver_hostap_ops; /* driver_hostap.c */
+#endif /* CONFIG_DRIVER_HOSTAP */
+#ifdef CONFIG_DRIVER_BSD
+extern struct wpa_driver_ops wpa_driver_bsd_ops; /* driver_bsd.c */
+#endif /* CONFIG_DRIVER_BSD */
+#ifdef CONFIG_DRIVER_OPENBSD
+extern struct wpa_driver_ops wpa_driver_openbsd_ops; /* driver_openbsd.c */
+#endif /* CONFIG_DRIVER_OPENBSD */
+#ifdef CONFIG_DRIVER_NDIS
+extern struct wpa_driver_ops wpa_driver_ndis_ops; /* driver_ndis.c */
+#endif /* CONFIG_DRIVER_NDIS */
+#ifdef CONFIG_DRIVER_WIRED
+extern struct wpa_driver_ops wpa_driver_wired_ops; /* driver_wired.c */
+#endif /* CONFIG_DRIVER_WIRED */
+#ifdef CONFIG_DRIVER_MACSEC_QCA
+ /* driver_macsec_qca.c */
+extern struct wpa_driver_ops wpa_driver_macsec_qca_ops;
+#endif /* CONFIG_DRIVER_MACSEC_QCA */
+#ifdef CONFIG_DRIVER_ROBOSWITCH
+/* driver_roboswitch.c */
+extern struct wpa_driver_ops wpa_driver_roboswitch_ops;
+#endif /* CONFIG_DRIVER_ROBOSWITCH */
+#ifdef CONFIG_DRIVER_ATHEROS
+extern struct wpa_driver_ops wpa_driver_atheros_ops; /* driver_atheros.c */
+#endif /* CONFIG_DRIVER_ATHEROS */
+#ifdef CONFIG_DRIVER_NONE
+extern struct wpa_driver_ops wpa_driver_none_ops; /* driver_none.c */
+#endif /* CONFIG_DRIVER_NONE */
+const struct wpa_driver_ops *const wpa_drivers[] =
+	&wpa_driver_nl80211_ops,
+	&wpa_driver_wext_ops,
+	&wpa_driver_hostap_ops,
+	&wpa_driver_bsd_ops,
+	&wpa_driver_openbsd_ops,
+	&wpa_driver_ndis_ops,
+	&wpa_driver_wired_ops,
+	&wpa_driver_macsec_qca_ops,
+	&wpa_driver_roboswitch_ops,
+	&wpa_driver_atheros_ops,
+	&wpa_driver_none_ops,
+	NULL
diff --git a/freebsd/contrib/wpa/src/drivers/linux_defines.h b/freebsd/contrib/wpa/src/drivers/linux_defines.h
index 00000000000..a107479a3e1
--- /dev/null
+++ b/freebsd/contrib/wpa/src/drivers/linux_defines.h
@@ -0,0 +1,46 @@
+ * Linux defines for values that are not yet included in common C libraries
+ * Copyright (c) 2014, Jouni Malinen <j at w1.fi>
+#ifndef LINUX_DEFINES_H
+#define LINUX_DEFINES_H
+#ifndef SO_WIFI_STATUS
+# if defined(__sparc__)
+#  define SO_WIFI_STATUS	0x0025
+# elif defined(__parisc__)
+#  define SO_WIFI_STATUS	0x4022
+# else
+#  define SO_WIFI_STATUS	41
+# endif
+# define SCM_WIFI_STATUS	SO_WIFI_STATUS
+#endif
+#ifndef SO_EE_ORIGIN_TXSTATUS
+#define SO_EE_ORIGIN_TXSTATUS	4
+#endif
+#ifndef PACKET_TX_TIMESTAMP
+#define PACKET_TX_TIMESTAMP	16
+#endif
+#ifndef IFF_LOWER_UP
+#define IFF_LOWER_UP   0x10000         /* driver signals L1 up         */
+#endif
+#ifndef IFF_DORMANT
+#define IFF_DORMANT    0x20000         /* driver signals dormant       */
+#endif
+#ifndef IF_OPER_DORMANT
+#define IF_OPER_DORMANT 5
+#endif
+#ifndef IF_OPER_UP
+#define IF_OPER_UP 6
+#endif
+#endif /* LINUX_DEFINES_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/chap.c b/freebsd/contrib/wpa/src/eap_common/chap.c
index 00000000000..012000f0c2a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/chap.c
@@ -0,0 +1,30 @@
+ * CHAP-MD5 (RFC 1994)
+ * Copyright (c) 2007-2009, Jouni Malinen <j at w1.fi>
+#include "crypto/crypto.h"
+#include "chap.h"
+int chap_md5(u8 id, const u8 *secret, size_t secret_len, const u8 *challenge,
+	      size_t challenge_len, u8 *response)
+	const u8 *addr[3];
+	size_t len[3];
+	addr[0] = &id;
+	len[0] = 1;
+	addr[1] = secret;
+	len[1] = secret_len;
+	addr[2] = challenge;
+	len[2] = challenge_len;
+	return md5_vector(3, addr, len, response);
diff --git a/freebsd/contrib/wpa/src/eap_common/chap.h b/freebsd/contrib/wpa/src/eap_common/chap.h
index 00000000000..a791505f99d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/chap.h
@@ -0,0 +1,17 @@
+#ifndef CHAP_H
+#define CHAP_H
+#define CHAP_MD5_LEN 16
+	     size_t challenge_len, u8 *response);
+#endif /* CHAP_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_common.c b/freebsd/contrib/wpa/src/eap_common/eap_common.c
index 00000000000..fc1909a371e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_common.c
@@ -0,0 +1,290 @@
+ * EAP common peer/server definitions
+ * Copyright (c) 2004-2014, Jouni Malinen <j at w1.fi>
+#include "eap_defs.h"
+#include "eap_common.h"
+ * eap_hdr_len_valid - Validate EAP header length field
+ * @msg: EAP frame (starting with EAP header)
+ * @min_payload: Minimum payload length needed
+ * Returns: 1 for valid header, 0 for invalid
+ * This is a helper function that does minimal validation of EAP messages. The
+ * length field is verified to be large enough to include the header and not
+ * too large to go beyond the end of the buffer.
+int eap_hdr_len_valid(const struct wpabuf *msg, size_t min_payload)
+	const struct eap_hdr *hdr;
+	size_t len;
+	if (msg == NULL)
+		return 0;
+	hdr = wpabuf_head(msg);
+	if (wpabuf_len(msg) < sizeof(*hdr)) {
+		wpa_printf(MSG_INFO, "EAP: Too short EAP frame");
+		return 0;
+	len = be_to_host16(hdr->length);
+	if (len < sizeof(*hdr) + min_payload || len > wpabuf_len(msg)) {
+		wpa_printf(MSG_INFO, "EAP: Invalid EAP length");
+		return 0;
+	return 1;
+ * eap_hdr_validate - Validate EAP header
+ * @vendor: Expected EAP Vendor-Id (0 = IETF)
+ * @eap_type: Expected EAP type number
+ * @plen: Pointer to variable to contain the returned payload length
+ * Returns: Pointer to EAP payload (after type field), or %NULL on failure
+ * This is a helper function for EAP method implementations. This is usually
+ * called in the beginning of struct eap_method::process() function to verify
+ * that the received EAP request packet has a valid header. This function is
+ * able to process both legacy and expanded EAP headers and in most cases, the
+ * caller can just use the returned payload pointer (into *plen) for processing
+ * the payload regardless of whether the packet used the expanded EAP header or
+ * not.
+const u8 * eap_hdr_validate(int vendor, EapType eap_type,
+			    const struct wpabuf *msg, size_t *plen)
+	const u8 *pos;
+	size_t len;
+	if (!eap_hdr_len_valid(msg, 1))
+		return NULL;
+	pos = (const u8 *) (hdr + 1);
+	if (*pos == EAP_TYPE_EXPANDED) {
+		int exp_vendor;
+		u32 exp_type;
+		if (len < sizeof(*hdr) + 8) {
+			wpa_printf(MSG_INFO, "EAP: Invalid expanded EAP "
+				   "length");
+			return NULL;
+		pos++;
+		exp_vendor = WPA_GET_BE24(pos);
+		pos += 3;
+		exp_type = WPA_GET_BE32(pos);
+		pos += 4;
+		if (exp_vendor != vendor || exp_type != (u32) eap_type) {
+			wpa_printf(MSG_INFO, "EAP: Invalid expanded frame "
+				   "type");
+			return NULL;
+		*plen = len - sizeof(*hdr) - 8;
+		return pos;
+	} else {
+		if (vendor != EAP_VENDOR_IETF || *pos != eap_type) {
+			wpa_printf(MSG_INFO, "EAP: Invalid frame type");
+			return NULL;
+		*plen = len - sizeof(*hdr) - 1;
+		return pos + 1;
+ * eap_msg_alloc - Allocate a buffer for an EAP message
+ * @vendor: Vendor-Id (0 = IETF)
+ * @type: EAP type
+ * @payload_len: Payload length in bytes (data after Type)
+ * @code: Message Code (EAP_CODE_*)
+ * @identifier: Identifier
+ * Returns: Pointer to the allocated message buffer or %NULL on error
+ * This function can be used to allocate a buffer for an EAP message and fill
+ * in the EAP header. This function is automatically using expanded EAP header
+ * if the selected Vendor-Id is not IETF. In other words, most EAP methods do
+ * not need to separately select which header type to use when using this
+ * function to allocate the message buffers. The returned buffer has room for
+ * payload_len bytes and has the EAP header and Type field already filled in.
+struct wpabuf * eap_msg_alloc(int vendor, EapType type, size_t payload_len,
+			      u8 code, u8 identifier)
+	struct wpabuf *buf;
+	struct eap_hdr *hdr;
+	size_t len;
+	len = sizeof(struct eap_hdr) + (vendor == EAP_VENDOR_IETF ? 1 : 8) +
+		payload_len;
+	buf = wpabuf_alloc(len);
+	if (buf == NULL)
+		return NULL;
+	hdr = wpabuf_put(buf, sizeof(*hdr));
+	hdr->code = code;
+	hdr->identifier = identifier;
+	hdr->length = host_to_be16(len);
+	if (vendor == EAP_VENDOR_IETF) {
+		wpabuf_put_u8(buf, type);
+	} else {
+		wpabuf_put_u8(buf, EAP_TYPE_EXPANDED);
+		wpabuf_put_be24(buf, vendor);
+		wpabuf_put_be32(buf, type);
+	return buf;
+ * eap_update_len - Update EAP header length
+ * @msg: EAP message from eap_msg_alloc
+ * This function updates the length field in the EAP header to match with the
+ * current length for the buffer. This allows eap_msg_alloc() to be used to
+ * allocate a larger buffer than the exact message length (e.g., if exact
+ * message length is not yet known).
+void eap_update_len(struct wpabuf *msg)
+	hdr = wpabuf_mhead(msg);
+		return;
+	hdr->length = host_to_be16(wpabuf_len(msg));
+ * eap_get_id - Get EAP Identifier from wpabuf
+ * @msg: Buffer starting with an EAP header
+ * Returns: The Identifier field from the EAP header
+u8 eap_get_id(const struct wpabuf *msg)
+	const struct eap_hdr *eap;
+	if (wpabuf_len(msg) < sizeof(*eap))
+		return 0;
+	eap = wpabuf_head(msg);
+	return eap->identifier;
+ * eap_get_type - Get EAP Type from wpabuf
+ * Returns: The EAP Type after the EAP header
+EapType eap_get_type(const struct wpabuf *msg)
+	if (wpabuf_len(msg) < sizeof(struct eap_hdr) + 1)
+		return EAP_TYPE_NONE;
+	return ((const u8 *) wpabuf_head(msg))[sizeof(struct eap_hdr)];
+#ifdef CONFIG_ERP
+int erp_parse_tlvs(const u8 *pos, const u8 *end, struct erp_tlvs *tlvs,
+		   int stop_at_keyname)
+	os_memset(tlvs, 0, sizeof(*tlvs));
+	while (pos < end) {
+		u8 tlv_type, tlv_len;
+		tlv_type = *pos++;
+		switch (tlv_type) {
+		case EAP_ERP_TV_RRK_LIFETIME:
+		case EAP_ERP_TV_RMSK_LIFETIME:
+			/* 4-octet TV */
+			if (pos + 4 > end) {
+				wpa_printf(MSG_DEBUG, "EAP: Too short TV");
+				return -1;
+			pos += 4;
+			break;
+		case EAP_ERP_TLV_DOMAIN_NAME:
+		case EAP_ERP_TLV_KEYNAME_NAI:
+		case EAP_ERP_TLV_CRYPTOSUITES:
+		case EAP_ERP_TLV_AUTHORIZATION_INDICATION:
+		case EAP_ERP_TLV_CALLED_STATION_ID:
+		case EAP_ERP_TLV_CALLING_STATION_ID:
+		case EAP_ERP_TLV_NAS_IDENTIFIER:
+		case EAP_ERP_TLV_NAS_IP_ADDRESS:
+		case EAP_ERP_TLV_NAS_IPV6_ADDRESS:
+			if (pos >= end) {
+				wpa_printf(MSG_DEBUG, "EAP: Too short TLV");
+				return -1;
+			tlv_len = *pos++;
+			if (tlv_len > (unsigned) (end - pos)) {
+				wpa_printf(MSG_DEBUG, "EAP: Truncated TLV");
+				return -1;
+			if (tlv_type == EAP_ERP_TLV_KEYNAME_NAI) {
+				if (tlvs->keyname) {
+						   "EAP: More than one keyName-NAI");
+					return -1;
+				tlvs->keyname = pos;
+				tlvs->keyname_len = tlv_len;
+				if (stop_at_keyname)
+					return 0;
+			} else if (tlv_type == EAP_ERP_TLV_DOMAIN_NAME) {
+				tlvs->domain = pos;
+				tlvs->domain_len = tlv_len;
+			pos += tlv_len;
+			break;
+		default:
+			if (tlv_type >= 128 && tlv_type <= 191) {
+				/* Undefined TLV */
+				if (pos >= end) {
+						   "EAP: Too short TLV");
+					return -1;
+				tlv_len = *pos++;
+						   "EAP: Truncated TLV");
+					return -1;
+				pos += tlv_len;
+				break;
+			wpa_printf(MSG_DEBUG, "EAP: Unknown TV/TLV type %u",
+				   tlv_type);
+			pos = end;
+			break;
+	return 0;
+#endif /* CONFIG_ERP */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_common.h b/freebsd/contrib/wpa/src/eap_common/eap_common.h
index 00000000000..e62f1676476
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_common.h
@@ -0,0 +1,33 @@
+#ifndef EAP_COMMON_H
+#define EAP_COMMON_H
+#include "wpabuf.h"
+struct erp_tlvs {
+	const u8 *keyname;
+	const u8 *domain;
+	u8 keyname_len;
+	u8 domain_len;
+int eap_hdr_len_valid(const struct wpabuf *msg, size_t min_payload);
+			    const struct wpabuf *msg, size_t *plen);
+			      u8 code, u8 identifier);
+void eap_update_len(struct wpabuf *msg);
+u8 eap_get_id(const struct wpabuf *msg);
+EapType eap_get_type(const struct wpabuf *msg);
+		   int stop_at_keyname);
+#endif /* EAP_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_defs.h b/freebsd/contrib/wpa/src/eap_common/eap_defs.h
index 00000000000..54f26ca38f9
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_defs.h
@@ -0,0 +1,118 @@
+ * EAP server/peer: Shared EAP definitions
+#ifndef EAP_DEFS_H
+#define EAP_DEFS_H
+/* RFC 3748 - Extensible Authentication Protocol (EAP) */
+#ifdef _MSC_VER
+struct eap_hdr {
+	u8 code;
+	u8 identifier;
+	be16 length; /* including code and identifier; network byte order */
+	/* followed by length-4 octets of data */
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+enum { EAP_CODE_REQUEST = 1, EAP_CODE_RESPONSE = 2, EAP_CODE_SUCCESS = 3,
+       EAP_CODE_FAILURE = 4, EAP_CODE_INITIATE = 5, EAP_CODE_FINISH = 6 };
+/* EAP Request and Response data begins with one octet Type. Success and
+ * Failure do not have additional data. */
+/* Type field in EAP-Initiate and EAP-Finish messages */
+enum eap_erp_type {
+	EAP_ERP_TYPE_REAUTH_START = 1,
+	EAP_ERP_TYPE_REAUTH = 2,
+/* ERP TV/TLV types */
+enum eap_erp_tlv_type {
+	EAP_ERP_TLV_KEYNAME_NAI = 1,
+	EAP_ERP_TV_RRK_LIFETIME = 2,
+	EAP_ERP_TV_RMSK_LIFETIME = 3,
+	EAP_ERP_TLV_DOMAIN_NAME = 4,
+	EAP_ERP_TLV_CRYPTOSUITES = 5,
+	EAP_ERP_TLV_AUTHORIZATION_INDICATION = 6,
+	EAP_ERP_TLV_CALLED_STATION_ID = 128,
+	EAP_ERP_TLV_CALLING_STATION_ID = 129,
+	EAP_ERP_TLV_NAS_IDENTIFIER = 130,
+	EAP_ERP_TLV_NAS_IP_ADDRESS = 131,
+	EAP_ERP_TLV_NAS_IPV6_ADDRESS = 132,
+/* ERP Cryptosuite */
+enum eap_erp_cryptosuite {
+	EAP_ERP_CS_HMAC_SHA256_64 = 1,
+	EAP_ERP_CS_HMAC_SHA256_128 = 2,
+	EAP_ERP_CS_HMAC_SHA256_256 = 3,
+ * EAP Method Types as allocated by IANA:
+ * http://www.iana.org/assignments/eap-numbers
+typedef enum {
+	EAP_TYPE_NONE = 0,
+	EAP_TYPE_IDENTITY = 1 /* RFC 3748 */,
+	EAP_TYPE_NOTIFICATION = 2 /* RFC 3748 */,
+	EAP_TYPE_NAK = 3 /* Response only, RFC 3748 */,
+	EAP_TYPE_MD5 = 4, /* RFC 3748 */
+	EAP_TYPE_OTP = 5 /* RFC 3748 */,
+	EAP_TYPE_GTC = 6, /* RFC 3748 */
+	EAP_TYPE_TLS = 13 /* RFC 2716 */,
+	EAP_TYPE_LEAP = 17 /* Cisco proprietary */,
+	EAP_TYPE_SIM = 18 /* RFC 4186 */,
+	EAP_TYPE_TTLS = 21 /* RFC 5281 */,
+	EAP_TYPE_AKA = 23 /* RFC 4187 */,
+	EAP_TYPE_PEAP = 25 /* draft-josefsson-pppext-eap-tls-eap-06.txt */,
+	EAP_TYPE_MSCHAPV2 = 26 /* draft-kamath-pppext-eap-mschapv2-00.txt */,
+	EAP_TYPE_TLV = 33 /* draft-josefsson-pppext-eap-tls-eap-07.txt */,
+	EAP_TYPE_TNC = 38 /* TNC IF-T v1.0-r3; note: tentative assignment;
+			   * type 38 has previously been allocated for
+			   * EAP-HTTP Digest, (funk.com) */,
+	EAP_TYPE_FAST = 43 /* RFC 4851 */,
+	EAP_TYPE_PAX = 46 /* RFC 4746 */,
+	EAP_TYPE_PSK = 47 /* RFC 4764 */,
+	EAP_TYPE_SAKE = 48 /* RFC 4763 */,
+	EAP_TYPE_IKEV2 = 49 /* RFC 5106 */,
+	EAP_TYPE_AKA_PRIME = 50 /* RFC 5448 */,
+	EAP_TYPE_GPSK = 51 /* RFC 5433 */,
+	EAP_TYPE_PWD = 52 /* RFC 5931 */,
+	EAP_TYPE_EKE = 53 /* RFC 6124 */,
+	EAP_TYPE_EXPANDED = 254 /* RFC 3748 */
+} EapType;
+/* SMI Network Management Private Enterprise Code for vendor specific types */
+enum {
+	EAP_VENDOR_IETF = 0,
+	EAP_VENDOR_MICROSOFT = 0x000137 /* Microsoft */,
+	EAP_VENDOR_WFA = 0x00372A /* Wi-Fi Alliance (moved to WBA) */,
+	EAP_VENDOR_HOSTAP = 39068 /* hostapd/wpa_supplicant project */,
+	EAP_VENDOR_WFA_NEW = 40808 /* Wi-Fi Alliance */
+#define EAP_VENDOR_UNAUTH_TLS EAP_VENDOR_HOSTAP
+#define EAP_VENDOR_TYPE_UNAUTH_TLS 1
+#define EAP_VENDOR_WFA_UNAUTH_TLS 13
+#define EAP_MSK_LEN 64
+#define EAP_EMSK_LEN 64
+#define EAP_EMSK_NAME_LEN 8
+#define ERP_MAX_KEY_LEN 64
+#endif /* EAP_DEFS_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_peap_common.c b/freebsd/contrib/wpa/src/eap_common/eap_peap_common.c
index 00000000000..08474793b17
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_peap_common.c
@@ -0,0 +1,87 @@
+ * EAP-PEAP common routines
+ * Copyright (c) 2008-2011, Jouni Malinen <j at w1.fi>
+#include "crypto/sha1.h"
+#include "eap_peap_common.h"
+int peap_prfplus(int version, const u8 *key, size_t key_len,
+		 const char *label, const u8 *seed, size_t seed_len,
+		 u8 *buf, size_t buf_len)
+	unsigned char counter = 0;
+	size_t pos, plen;
+	u8 hash[SHA1_MAC_LEN];
+	size_t label_len = os_strlen(label);
+	u8 extra[2];
+	const unsigned char *addr[5];
+	size_t len[5];
+	addr[0] = hash;
+	len[0] = 0;
+	addr[1] = (unsigned char *) label;
+	len[1] = label_len;
+	addr[2] = seed;
+	len[2] = seed_len;
+	if (version == 0) {
+		 * PRF+(K, S, LEN) = T1 | T2 | ... | Tn
+		 * T1 = HMAC-SHA1(K, S | 0x01 | 0x00 | 0x00)
+		 * T2 = HMAC-SHA1(K, T1 | S | 0x02 | 0x00 | 0x00)
+		 * Tn = HMAC-SHA1(K, Tn-1 | S | n | 0x00 | 0x00)
+		extra[0] = 0;
+		extra[1] = 0;
+		addr[3] = &counter;
+		len[3] = 1;
+		addr[4] = extra;
+		len[4] = 2;
+	} else {
+		 * PRF (K,S,LEN) = T1 | T2 | T3 | T4 | ... where:
+		 * T1 = HMAC-SHA1(K, S | LEN | 0x01)
+		 * T2 = HMAC-SHA1 (K, T1 | S | LEN | 0x02)
+		 * T3 = HMAC-SHA1 (K, T2 | S | LEN | 0x03)
+		 * T4 = HMAC-SHA1 (K, T3 | S | LEN | 0x04)
+		extra[0] = buf_len & 0xff;
+		addr[3] = extra;
+		len[3] = 1;
+		addr[4] = &counter;
+		len[4] = 1;
+	pos = 0;
+	while (pos < buf_len) {
+		counter++;
+		plen = buf_len - pos;
+		if (hmac_sha1_vector(key, key_len, 5, addr, len, hash) < 0)
+			return -1;
+		if (plen >= SHA1_MAC_LEN) {
+			os_memcpy(&buf[pos], hash, SHA1_MAC_LEN);
+			pos += SHA1_MAC_LEN;
+		} else {
+			os_memcpy(&buf[pos], hash, plen);
+			break;
+		len[0] = SHA1_MAC_LEN;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_peap_common.h b/freebsd/contrib/wpa/src/eap_common/eap_peap_common.h
index 00000000000..7aad0dff781
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_peap_common.h
@@ -0,0 +1,16 @@
+#ifndef EAP_PEAP_COMMON_H
+#define EAP_PEAP_COMMON_H
+		 u8 *buf, size_t buf_len);
+#endif /* EAP_PEAP_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_psk_common.c b/freebsd/contrib/wpa/src/eap_common/eap_psk_common.c
index 00000000000..eaea191b300
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_psk_common.c
@@ -0,0 +1,70 @@
+ * EAP server/peer: EAP-PSK shared routines
+#include "crypto/aes_wrap.h"
+#include "eap_psk_common.h"
+#define aes_block_size 16
+int eap_psk_key_setup(const u8 *psk, u8 *ak, u8 *kdk)
+	os_memset(ak, 0, aes_block_size);
+	if (aes_128_encrypt_block(psk, ak, ak))
+		return -1;
+	os_memcpy(kdk, ak, aes_block_size);
+	ak[aes_block_size - 1] ^= 0x01;
+	kdk[aes_block_size - 1] ^= 0x02;
+	if (aes_128_encrypt_block(psk, ak, ak) ||
+	    aes_128_encrypt_block(psk, kdk, kdk))
+		return -1;
+	return 0;
+int eap_psk_derive_keys(const u8 *kdk, const u8 *rand_p, u8 *tek, u8 *msk,
+			u8 *emsk)
+	u8 hash[aes_block_size];
+	u8 counter = 1;
+	int i;
+	if (aes_128_encrypt_block(kdk, rand_p, hash))
+		return -1;
+	hash[aes_block_size - 1] ^= counter;
+	if (aes_128_encrypt_block(kdk, hash, tek))
+		return -1;
+	counter++;
+	for (i = 0; i < EAP_MSK_LEN / aes_block_size; i++) {
+		if (aes_128_encrypt_block(kdk, hash, &msk[i * aes_block_size]))
+			return -1;
+		counter++;
+	for (i = 0; i < EAP_EMSK_LEN / aes_block_size; i++) {
+					  &emsk[i * aes_block_size]))
+			return -1;
+		counter++;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_psk_common.h b/freebsd/contrib/wpa/src/eap_common/eap_psk_common.h
index 00000000000..8bc2c3c4cf1
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_psk_common.h
@@ -0,0 +1,72 @@
+ * Copyright (c) 2004-2007, Jouni Malinen <j at w1.fi>
+#ifndef EAP_PSK_COMMON_H
+#define EAP_PSK_COMMON_H
+#define EAP_PSK_RAND_LEN 16
+#define EAP_PSK_MAC_LEN 16
+#define EAP_PSK_TEK_LEN 16
+#define EAP_PSK_PSK_LEN 16
+#define EAP_PSK_AK_LEN 16
+#define EAP_PSK_KDK_LEN 16
+#define EAP_PSK_R_FLAG_CONT 1
+#define EAP_PSK_R_FLAG_DONE_SUCCESS 2
+#define EAP_PSK_R_FLAG_DONE_FAILURE 3
+#define EAP_PSK_E_FLAG 0x20
+#define EAP_PSK_FLAGS_GET_T(flags) (((flags) & 0xc0) >> 6)
+#define EAP_PSK_FLAGS_SET_T(t) ((u8) (t) << 6)
+#ifdef _MSC_VER
+/* EAP-PSK First Message (AS -> Supplicant) */
+struct eap_psk_hdr_1 {
+	u8 flags;
+	u8 rand_s[EAP_PSK_RAND_LEN];
+	/* Followed by variable length ID_S */
+} STRUCT_PACKED;
+/* EAP-PSK Second Message (Supplicant -> AS) */
+struct eap_psk_hdr_2 {
+	u8 flags;
+	u8 rand_p[EAP_PSK_RAND_LEN];
+	u8 mac_p[EAP_PSK_MAC_LEN];
+	/* Followed by variable length ID_P */
+} STRUCT_PACKED;
+/* EAP-PSK Third Message (AS -> Supplicant) */
+struct eap_psk_hdr_3 {
+	u8 flags;
+	u8 mac_s[EAP_PSK_MAC_LEN];
+	/* Followed by variable length PCHANNEL */
+} STRUCT_PACKED;
+/* EAP-PSK Fourth Message (Supplicant -> AS) */
+struct eap_psk_hdr_4 {
+	u8 flags;
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+int __must_check eap_psk_key_setup(const u8 *psk, u8 *ak, u8 *kdk);
+int __must_check eap_psk_derive_keys(const u8 *kdk, const u8 *rand_p, u8 *tek,
+				     u8 *msk, u8 *emsk);
+#endif /* EAP_PSK_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_tlv_common.h b/freebsd/contrib/wpa/src/eap_common/eap_tlv_common.h
index 00000000000..3286055ab7b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_tlv_common.h
@@ -0,0 +1,112 @@
+ * EAP-TLV definitions (draft-josefsson-pppext-eap-tls-eap-10.txt)
+ * Copyright (c) 2004-2008, Jouni Malinen <j at w1.fi>
+#ifndef EAP_TLV_COMMON_H
+#define EAP_TLV_COMMON_H
+/* EAP-TLV TLVs (draft-josefsson-ppext-eap-tls-eap-10.txt) */
+#define EAP_TLV_RESULT_TLV 3 /* Acknowledged Result */
+#define EAP_TLV_NAK_TLV 4
+#define EAP_TLV_ERROR_CODE_TLV 5
+#define EAP_TLV_CONNECTION_BINDING_TLV 6
+#define EAP_TLV_VENDOR_SPECIFIC_TLV 7
+#define EAP_TLV_URI_TLV 8
+#define EAP_TLV_EAP_PAYLOAD_TLV 9
+#define EAP_TLV_INTERMEDIATE_RESULT_TLV 10
+#define EAP_TLV_PAC_TLV 11 /* RFC 5422, Section 4.2 */
+#define EAP_TLV_CRYPTO_BINDING_TLV 12
+#define EAP_TLV_CALLING_STATION_ID_TLV 13
+#define EAP_TLV_CALLED_STATION_ID_TLV 14
+#define EAP_TLV_NAS_PORT_TYPE_TLV 15
+#define EAP_TLV_SERVER_IDENTIFIER_TLV 16
+#define EAP_TLV_IDENTITY_TYPE_TLV 17
+#define EAP_TLV_SERVER_TRUSTED_ROOT_TLV 18
+#define EAP_TLV_REQUEST_ACTION_TLV 19
+#define EAP_TLV_PKCS7_TLV 20
+#define EAP_TLV_RESULT_SUCCESS 1
+#define EAP_TLV_RESULT_FAILURE 2
+#define EAP_TLV_TYPE_MANDATORY 0x8000
+#define EAP_TLV_TYPE_MASK 0x3fff
+#ifdef _MSC_VER
+struct eap_tlv_hdr {
+	be16 tlv_type;
+	be16 length;
+} STRUCT_PACKED;
+struct eap_tlv_nak_tlv {
+	be16 tlv_type;
+	be16 length;
+	be32 vendor_id;
+	be16 nak_type;
+} STRUCT_PACKED;
+struct eap_tlv_result_tlv {
+	be16 tlv_type;
+	be16 length;
+	be16 status;
+} STRUCT_PACKED;
+/* RFC 4851, Section 4.2.7 - Intermediate-Result TLV */
+struct eap_tlv_intermediate_result_tlv {
+	be16 tlv_type;
+	be16 length;
+	be16 status;
+	/* Followed by optional TLVs */
+} STRUCT_PACKED;
+/* RFC 4851, Section 4.2.8 - Crypto-Binding TLV */
+struct eap_tlv_crypto_binding_tlv {
+	be16 tlv_type;
+	be16 length;
+	u8 reserved;
+	u8 version;
+	u8 received_version;
+	u8 subtype;
+	u8 nonce[32];
+	u8 compound_mac[20];
+} STRUCT_PACKED;
+struct eap_tlv_pac_ack_tlv {
+	be16 tlv_type;
+	be16 length;
+	be16 pac_type;
+	be16 pac_len;
+	be16 result;
+} STRUCT_PACKED;
+/* RFC 4851, Section 4.2.9 - Request-Action TLV */
+struct eap_tlv_request_action_tlv {
+	be16 tlv_type;
+	be16 length;
+	be16 action;
+} STRUCT_PACKED;
+/* RFC 5422, Section 4.2.6 - PAC-Type TLV */
+struct eap_tlv_pac_type_tlv {
+	be16 tlv_type; /* PAC_TYPE_PAC_TYPE */
+	be16 length;
+	be16 pac_type;
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+#define EAP_TLV_CRYPTO_BINDING_SUBTYPE_REQUEST 0
+#define EAP_TLV_CRYPTO_BINDING_SUBTYPE_RESPONSE 1
+#define EAP_TLV_ACTION_PROCESS_TLV 1
+#define EAP_TLV_ACTION_NEGOTIATE_EAP 2
+#endif /* EAP_TLV_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_ttls.h b/freebsd/contrib/wpa/src/eap_common/eap_ttls.h
index 00000000000..17901d42db1
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_ttls.h
@@ -0,0 +1,65 @@
+ * EAP server/peer: EAP-TTLS (RFC 5281)
+#ifndef EAP_TTLS_H
+#define EAP_TTLS_H
+struct ttls_avp {
+	be32 avp_code;
+	be32 avp_length; /* 8-bit flags, 24-bit length;
+			  * length includes AVP header */
+	/* optional 32-bit Vendor-ID */
+	/* Data */
+struct ttls_avp_vendor {
+	be32 avp_code;
+	be32 vendor_id;
+	/* Data */
+#define AVP_FLAGS_VENDOR 0x80
+#define AVP_FLAGS_MANDATORY 0x40
+#define AVP_PAD(start, pos) \
+do { \
+	int __pad; \
+	__pad = (4 - (((pos) - (start)) & 3)) & 3; \
+	os_memset((pos), 0, __pad); \
+	pos += __pad; \
+} while (0)
+/* RFC 2865 */
+#define RADIUS_ATTR_USER_NAME 1
+#define RADIUS_ATTR_USER_PASSWORD 2
+#define RADIUS_ATTR_CHAP_PASSWORD 3
+#define RADIUS_ATTR_REPLY_MESSAGE 18
+#define RADIUS_ATTR_CHAP_CHALLENGE 60
+#define RADIUS_ATTR_EAP_MESSAGE 79
+/* RFC 2548 */
+#define RADIUS_VENDOR_ID_MICROSOFT 311
+#define RADIUS_ATTR_MS_CHAP_RESPONSE 1
+#define RADIUS_ATTR_MS_CHAP_ERROR 2
+#define RADIUS_ATTR_MS_CHAP_NT_ENC_PW 6
+#define RADIUS_ATTR_MS_CHAP_CHALLENGE 11
+#define RADIUS_ATTR_MS_CHAP2_RESPONSE 25
+#define RADIUS_ATTR_MS_CHAP2_SUCCESS 26
+#define RADIUS_ATTR_MS_CHAP2_CPW 27
+#define EAP_TTLS_MSCHAPV2_CHALLENGE_LEN 16
+#define EAP_TTLS_MSCHAPV2_RESPONSE_LEN 50
+#define EAP_TTLS_MSCHAP_CHALLENGE_LEN 8
+#define EAP_TTLS_MSCHAP_RESPONSE_LEN 50
+#define EAP_TTLS_CHAP_CHALLENGE_LEN 16
+#define EAP_TTLS_CHAP_PASSWORD_LEN 16
+#endif /* EAP_TTLS_H */
diff --git a/freebsd/contrib/wpa/src/eap_common/eap_wsc_common.h b/freebsd/contrib/wpa/src/eap_common/eap_wsc_common.h
index 00000000000..0e7b6530818
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_common/eap_wsc_common.h
@@ -0,0 +1,27 @@
+ * EAP-WSC definitions for Wi-Fi Protected Setup
+ * Copyright (c) 2007, Jouni Malinen <j at w1.fi>
+#ifndef EAP_WSC_COMMON_H
+#define EAP_WSC_COMMON_H
+#define EAP_VENDOR_TYPE_WSC 1
+#define WSC_FLAGS_MF 0x01
+#define WSC_FLAGS_LF 0x02
+#define WSC_ID_REGISTRAR "WFA-SimpleConfig-Registrar-1-0"
+#define WSC_ID_REGISTRAR_LEN 30
+#define WSC_ID_ENROLLEE "WFA-SimpleConfig-Enrollee-1-0"
+#define WSC_ID_ENROLLEE_LEN 29
+#define WSC_FRAGMENT_SIZE 1400
+struct wpabuf * eap_wsc_build_frag_ack(u8 id, u8 code);
+#endif /* EAP_WSC_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap.c b/freebsd/contrib/wpa/src/eap_peer/eap.c
index 00000000000..cfaf201aa5d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap.c
@@ -0,0 +1,2952 @@
+ * EAP peer state machines (RFC 4137)
+ * This file implements the Peer State Machine as defined in RFC 4137. The used
+ * states and state transitions match mostly with the RFC. However, there are
+ * couple of additional transitions for working around small issues noticed
+ * during testing. These exceptions are explained in comments within the
+ * functions in this file. The method functions, m.func(), are similar to the
+ * ones used in RFC 4137, but some small changes have used here to optimize
+ * operations and to add functionality needed for fast re-authentication
+ * (session resumption).
+#include "pcsc_funcs.h"
+#include "state_machine.h"
+#include "ext_password.h"
+#include "crypto/tls.h"
+#include "crypto/sha256.h"
+#include "common/wpa_ctrl.h"
+#include "eap_common/eap_wsc_common.h"
+#include "eap_i.h"
+#include "eap_config.h"
+#define STATE_MACHINE_DATA struct eap_sm
+#define STATE_MACHINE_DEBUG_PREFIX "EAP"
+#define EAP_MAX_AUTH_ROUNDS 50
+#define EAP_CLIENT_TIMEOUT_DEFAULT 60
+static Boolean eap_sm_allowMethod(struct eap_sm *sm, int vendor,
+				  EapType method);
+static struct wpabuf * eap_sm_buildNak(struct eap_sm *sm, int id);
+static void eap_sm_processIdentity(struct eap_sm *sm,
+				   const struct wpabuf *req);
+static void eap_sm_processNotify(struct eap_sm *sm, const struct wpabuf *req);
+static struct wpabuf * eap_sm_buildNotify(int id);
+static void eap_sm_parseEapReq(struct eap_sm *sm, const struct wpabuf *req);
+#if defined(CONFIG_CTRL_IFACE) || !defined(CONFIG_NO_STDOUT_DEBUG)
+static const char * eap_sm_method_state_txt(EapMethodState state);
+static const char * eap_sm_decision_txt(EapDecision decision);
+#endif /* CONFIG_CTRL_IFACE || !CONFIG_NO_STDOUT_DEBUG */
+static Boolean eapol_get_bool(struct eap_sm *sm, enum eapol_bool_var var)
+	return sm->eapol_cb->get_bool(sm->eapol_ctx, var);
+static void eapol_set_bool(struct eap_sm *sm, enum eapol_bool_var var,
+			   Boolean value)
+	sm->eapol_cb->set_bool(sm->eapol_ctx, var, value);
+static unsigned int eapol_get_int(struct eap_sm *sm, enum eapol_int_var var)
+	return sm->eapol_cb->get_int(sm->eapol_ctx, var);
+static void eapol_set_int(struct eap_sm *sm, enum eapol_int_var var,
+			  unsigned int value)
+	sm->eapol_cb->set_int(sm->eapol_ctx, var, value);
+static struct wpabuf * eapol_get_eapReqData(struct eap_sm *sm)
+	return sm->eapol_cb->get_eapReqData(sm->eapol_ctx);
+static void eap_notify_status(struct eap_sm *sm, const char *status,
+				      const char *parameter)
+	wpa_printf(MSG_DEBUG, "EAP: Status notification: %s (param=%s)",
+		   status, parameter);
+	if (sm->eapol_cb->notify_status)
+		sm->eapol_cb->notify_status(sm->eapol_ctx, status, parameter);
+static void eap_sm_free_key(struct eap_sm *sm)
+	if (sm->eapKeyData) {
+		bin_clear_free(sm->eapKeyData, sm->eapKeyDataLen);
+		sm->eapKeyData = NULL;
+static void eap_deinit_prev_method(struct eap_sm *sm, const char *txt)
+	ext_password_free(sm->ext_pw_buf);
+	sm->ext_pw_buf = NULL;
+	if (sm->m == NULL || sm->eap_method_priv == NULL)
+		return;
+	wpa_printf(MSG_DEBUG, "EAP: deinitialize previously used EAP method "
+		   "(%d, %s) at %s", sm->selectedMethod, sm->m->name, txt);
+	sm->m->deinit(sm, sm->eap_method_priv);
+	sm->eap_method_priv = NULL;
+	sm->m = NULL;
+ * eap_allowed_method - Check whether EAP method is allowed
+ * @sm: Pointer to EAP state machine allocated with eap_peer_sm_init()
+ * @vendor: Vendor-Id for expanded types or 0 = IETF for legacy types
+ * @method: EAP type
+ * Returns: 1 = allowed EAP method, 0 = not allowed
+int eap_allowed_method(struct eap_sm *sm, int vendor, u32 method)
+	struct eap_peer_config *config = eap_get_config(sm);
+	int i;
+	struct eap_method_type *m;
+	if (config == NULL || config->eap_methods == NULL)
+		return 1;
+	m = config->eap_methods;
+	for (i = 0; m[i].vendor != EAP_VENDOR_IETF ||
+		     m[i].method != EAP_TYPE_NONE; i++) {
+		if (m[i].vendor == vendor && m[i].method == method)
+			return 1;
+	return 0;
+ * This state initializes state machine variables when the machine is
+ * activated (portEnabled = TRUE). This is also used when re-starting
+ * authentication (eapRestart == TRUE).
+SM_STATE(EAP, INITIALIZE)
+	SM_ENTRY(EAP, INITIALIZE);
+	if (sm->fast_reauth && sm->m && sm->m->has_reauth_data &&
+	    sm->m->has_reauth_data(sm, sm->eap_method_priv) &&
+	    !sm->prev_failure &&
+	    sm->last_config == eap_get_config(sm)) {
+		wpa_printf(MSG_DEBUG, "EAP: maintaining EAP method data for "
+			   "fast reauthentication");
+		sm->m->deinit_for_reauth(sm, sm->eap_method_priv);
+	} else {
+		sm->last_config = eap_get_config(sm);
+		eap_deinit_prev_method(sm, "INITIALIZE");
+	sm->selectedMethod = EAP_TYPE_NONE;
+	sm->methodState = METHOD_NONE;
+	sm->allowNotifications = TRUE;
+	sm->decision = DECISION_FAIL;
+	sm->ClientTimeout = EAP_CLIENT_TIMEOUT_DEFAULT;
+	eapol_set_int(sm, EAPOL_idleWhile, sm->ClientTimeout);
+	eapol_set_bool(sm, EAPOL_eapSuccess, FALSE);
+	eapol_set_bool(sm, EAPOL_eapFail, FALSE);
+	eap_sm_free_key(sm);
+	os_free(sm->eapSessionId);
+	sm->eapSessionId = NULL;
+	sm->eapKeyAvailable = FALSE;
+	eapol_set_bool(sm, EAPOL_eapRestart, FALSE);
+	sm->lastId = -1; /* new session - make sure this does not match with
+			  * the first EAP-Packet */
+	 * RFC 4137 does not reset eapResp and eapNoResp here. However, this
+	 * seemed to be able to trigger cases where both were set and if EAPOL
+	 * state machine uses eapNoResp first, it may end up not sending a real
+	 * reply correctly. This occurred when the workaround in FAIL state set
+	 * eapNoResp = TRUE.. Maybe that workaround needs to be fixed to do
+	 * something else(?)
+	eapol_set_bool(sm, EAPOL_eapResp, FALSE);
+	eapol_set_bool(sm, EAPOL_eapNoResp, FALSE);
+	sm->num_rounds = 0;
+	sm->prev_failure = 0;
+	sm->expected_failure = 0;
+	sm->reauthInit = FALSE;
+	sm->erp_seq = (u32) -1;
+ * This state is reached whenever service from the lower layer is interrupted
+ * or unavailable (portEnabled == FALSE). Immediate transition to INITIALIZE
+ * occurs when the port becomes enabled.
+SM_STATE(EAP, DISABLED)
+	SM_ENTRY(EAP, DISABLED);
+	 * RFC 4137 does not describe clearing of idleWhile here, but doing so
+	 * allows the timer tick to be stopped more quickly when EAP is not in
+	 * use.
+	eapol_set_int(sm, EAPOL_idleWhile, 0);
+ * The state machine spends most of its time here, waiting for something to
+ * happen. This state is entered unconditionally from INITIALIZE, DISCARD, and
+ * SEND_RESPONSE states.
+SM_STATE(EAP, IDLE)
+	SM_ENTRY(EAP, IDLE);
+ * This state is entered when an EAP packet is received (eapReq == TRUE) to
+ * parse the packet header.
+SM_STATE(EAP, RECEIVED)
+	const struct wpabuf *eapReqData;
+	SM_ENTRY(EAP, RECEIVED);
+	eapReqData = eapol_get_eapReqData(sm);
+	/* parse rxReq, rxSuccess, rxFailure, reqId, reqMethod */
+	eap_sm_parseEapReq(sm, eapReqData);
+	sm->num_rounds++;
+ * This state is entered when a request for a new type comes in. Either the
+ * correct method is started, or a Nak response is built.
+SM_STATE(EAP, GET_METHOD)
+	int reinit;
+	EapType method;
+	const struct eap_method *eap_method;
+	SM_ENTRY(EAP, GET_METHOD);
+	if (sm->reqMethod == EAP_TYPE_EXPANDED)
+		method = sm->reqVendorMethod;
+	else
+		method = sm->reqMethod;
+	eap_method = eap_peer_get_eap_method(sm->reqVendor, method);
+	if (!eap_sm_allowMethod(sm, sm->reqVendor, method)) {
+		wpa_printf(MSG_DEBUG, "EAP: vendor %u method %u not allowed",
+			   sm->reqVendor, method);
+		wpa_msg(sm->msg_ctx, MSG_INFO, WPA_EVENT_EAP_PROPOSED_METHOD
+			"vendor=%u method=%u -> NAK",
+		eap_notify_status(sm, "refuse proposed method",
+				  eap_method ?  eap_method->name : "unknown");
+		goto nak;
+		"vendor=%u method=%u", sm->reqVendor, method);
+	eap_notify_status(sm, "accept proposed method",
+	 * RFC 4137 does not define specific operation for fast
+	 * re-authentication (session resumption). The design here is to allow
+	 * the previously used method data to be maintained for
+	 * re-authentication if the method support session resumption.
+	 * Otherwise, the previously used method data is freed and a new method
+	 * is allocated here.
+	    sm->m && sm->m->vendor == sm->reqVendor &&
+	    sm->m->method == method &&
+	    sm->m->has_reauth_data &&
+	    sm->m->has_reauth_data(sm, sm->eap_method_priv)) {
+		wpa_printf(MSG_DEBUG, "EAP: Using previous method data"
+			   " for fast re-authentication");
+		reinit = 1;
+	} else {
+		eap_deinit_prev_method(sm, "GET_METHOD");
+		reinit = 0;
+	sm->selectedMethod = sm->reqMethod;
+	if (sm->m == NULL)
+		sm->m = eap_method;
+	if (!sm->m) {
+		wpa_printf(MSG_DEBUG, "EAP: Could not find selected method: "
+			   "vendor %d method %d",
+		goto nak;
+	wpa_printf(MSG_DEBUG, "EAP: Initialize selected EAP method: "
+		   "vendor %u method %u (%s)",
+		   sm->reqVendor, method, sm->m->name);
+	if (reinit)
+		sm->eap_method_priv = sm->m->init_for_reauth(
+			sm, sm->eap_method_priv);
+	else
+		sm->eap_method_priv = sm->m->init(sm);
+	if (sm->eap_method_priv == NULL) {
+			"EAP: Failed to initialize EAP method: vendor %u "
+			"method %u (%s)",
+		sm->m = NULL;
+		if (sm->reqMethod == EAP_TYPE_TLS && config &&
+		    (config->pending_req_pin ||
+		     config->pending_req_passphrase)) {
+			 * Return without generating Nak in order to allow
+			 * entering of PIN code or passphrase to retry the
+			 * current EAP packet.
+			wpa_printf(MSG_DEBUG, "EAP: Pending PIN/passphrase "
+				   "request - skip Nak");
+			return;
+		goto nak;
+	sm->methodState = METHOD_INIT;
+	wpa_msg(sm->msg_ctx, MSG_INFO, WPA_EVENT_EAP_METHOD
+		"EAP vendor %u method %u (%s) selected",
+	return;
+nak:
+	wpabuf_free(sm->eapRespData);
+	sm->eapRespData = NULL;
+	sm->eapRespData = eap_sm_buildNak(sm, sm->reqId);
+#ifdef CONFIG_ERP
+static char * eap_home_realm(struct eap_sm *sm)
+	char *realm;
+	size_t i, realm_len;
+	if (!config)
+		return NULL;
+	if (config->identity) {
+		for (i = 0; i < config->identity_len; i++) {
+			if (config->identity[i] == '@')
+				break;
+		if (i < config->identity_len) {
+			realm_len = config->identity_len - i - 1;
+			realm = os_malloc(realm_len + 1);
+			if (realm == NULL)
+				return NULL;
+			os_memcpy(realm, &config->identity[i + 1], realm_len);
+			realm[realm_len] = '\0';
+			return realm;
+	if (config->anonymous_identity) {
+		for (i = 0; i < config->anonymous_identity_len; i++) {
+			if (config->anonymous_identity[i] == '@')
+				break;
+		if (i < config->anonymous_identity_len) {
+			realm_len = config->anonymous_identity_len - i - 1;
+				return NULL;
+			os_memcpy(realm, &config->anonymous_identity[i + 1],
+				  realm_len);
+			return realm;
+	return os_strdup("");
+static struct eap_erp_key *
+eap_erp_get_key(struct eap_sm *sm, const char *realm)
+	struct eap_erp_key *erp;
+	dl_list_for_each(erp, &sm->erp_keys, struct eap_erp_key, list) {
+		char *pos;
+		pos = os_strchr(erp->keyname_nai, '@');
+		if (!pos)
+			continue;
+		pos++;
+		if (os_strcmp(pos, realm) == 0)
+			return erp;
+	return NULL;
+eap_erp_get_key_nai(struct eap_sm *sm, const char *nai)
+		if (os_strcmp(erp->keyname_nai, nai) == 0)
+			return erp;
+	return NULL;
+static void eap_peer_erp_free_key(struct eap_erp_key *erp)
+	dl_list_del(&erp->list);
+	bin_clear_free(erp, sizeof(*erp));
+static void eap_erp_remove_keys_realm(struct eap_sm *sm, const char *realm)
+	while ((erp = eap_erp_get_key(sm, realm)) != NULL) {
+		wpa_printf(MSG_DEBUG, "EAP: Delete old ERP key %s",
+			   erp->keyname_nai);
+		eap_peer_erp_free_key(erp);
+void eap_peer_erp_free_keys(struct eap_sm *sm)
+#ifdef CONFIG_ERP
+	struct eap_erp_key *erp, *tmp;
+	dl_list_for_each_safe(erp, tmp, &sm->erp_keys, struct eap_erp_key, list)
+static void eap_peer_erp_init(struct eap_sm *sm)
+#ifdef CONFIG_ERP
+	u8 *emsk = NULL;
+	size_t emsk_len = 0;
+	u8 EMSKname[EAP_EMSK_NAME_LEN];
+	u8 len[2];
+	char *realm;
+	size_t realm_len, nai_buf_len;
+	struct eap_erp_key *erp = NULL;
+	int pos;
+	realm = eap_home_realm(sm);
+	if (!realm)
+		return;
+	realm_len = os_strlen(realm);
+	wpa_printf(MSG_DEBUG, "EAP: Realm for ERP keyName-NAI: %s", realm);
+	eap_erp_remove_keys_realm(sm, realm);
+	nai_buf_len = 2 * EAP_EMSK_NAME_LEN + 1 + realm_len;
+	if (nai_buf_len > 253) {
+		 * keyName-NAI has a maximum length of 253 octet to fit in
+		 * RADIUS attributes.
+			   "EAP: Too long realm for ERP keyName-NAI maximum length");
+		goto fail;
+	nai_buf_len++; /* null termination */
+	erp = os_zalloc(sizeof(*erp) + nai_buf_len);
+	if (erp == NULL)
+		goto fail;
+	emsk = sm->m->get_emsk(sm, sm->eap_method_priv, &emsk_len);
+	if (!emsk || emsk_len == 0 || emsk_len > ERP_MAX_KEY_LEN) {
+			   "EAP: No suitable EMSK available for ERP");
+		goto fail;
+	wpa_hexdump_key(MSG_DEBUG, "EAP: EMSK", emsk, emsk_len);
+	WPA_PUT_BE16(len, 8);
+	if (hmac_sha256_kdf(sm->eapSessionId, sm->eapSessionIdLen, "EMSK",
+			    len, sizeof(len),
+			    EMSKname, EAP_EMSK_NAME_LEN) < 0) {
+		wpa_printf(MSG_DEBUG, "EAP: Could not derive EMSKname");
+		goto fail;
+	wpa_hexdump(MSG_DEBUG, "EAP: EMSKname", EMSKname, EAP_EMSK_NAME_LEN);
+	pos = wpa_snprintf_hex(erp->keyname_nai, nai_buf_len,
+			       EMSKname, EAP_EMSK_NAME_LEN);
+	erp->keyname_nai[pos] = '@';
+	os_memcpy(&erp->keyname_nai[pos + 1], realm, realm_len);
+	WPA_PUT_BE16(len, emsk_len);
+	if (hmac_sha256_kdf(emsk, emsk_len,
+			    "EAP Re-authentication Root Key at ietf.org",
+			    len, sizeof(len), erp->rRK, emsk_len) < 0) {
+		wpa_printf(MSG_DEBUG, "EAP: Could not derive rRK for ERP");
+		goto fail;
+	erp->rRK_len = emsk_len;
+	wpa_hexdump_key(MSG_DEBUG, "EAP: ERP rRK", erp->rRK, erp->rRK_len);
+	if (hmac_sha256_kdf(erp->rRK, erp->rRK_len,
+			    "EAP Re-authentication Integrity Key at ietf.org",
+			    len, sizeof(len), erp->rIK, erp->rRK_len) < 0) {
+		wpa_printf(MSG_DEBUG, "EAP: Could not derive rIK for ERP");
+		goto fail;
+	erp->rIK_len = erp->rRK_len;
+	wpa_hexdump_key(MSG_DEBUG, "EAP: ERP rIK", erp->rIK, erp->rIK_len);
+	wpa_printf(MSG_DEBUG, "EAP: Stored ERP keys %s", erp->keyname_nai);
+	dl_list_add(&sm->erp_keys, &erp->list);
+	erp = NULL;
+fail:
+	bin_clear_free(emsk, emsk_len);
+	os_free(realm);
+#ifdef CONFIG_ERP
+static int eap_peer_erp_reauth_start(struct eap_sm *sm,
+				     const struct eap_hdr *hdr, size_t len)
+	char *realm;
+	struct wpabuf *msg;
+	u8 hash[SHA256_MAC_LEN];
+	if (!realm)
+		return -1;
+	erp = eap_erp_get_key(sm, realm);
+	os_free(realm);
+	realm = NULL;
+	if (!erp)
+		return -1;
+	if (erp->next_seq >= 65536)
+		return -1; /* SEQ has range of 0..65535 */
+	/* TODO: check rRK lifetime expiration */
+	wpa_printf(MSG_DEBUG, "EAP: Valid ERP key found %s (SEQ=%u)",
+		   erp->keyname_nai, erp->next_seq);
+	msg = eap_msg_alloc(EAP_VENDOR_IETF, (EapType) EAP_ERP_TYPE_REAUTH,
+			    1 + 2 + 2 + os_strlen(erp->keyname_nai) + 1 + 16,
+			    EAP_CODE_INITIATE, hdr->identifier);
+	if (msg == NULL)
+		return -1;
+	wpabuf_put_u8(msg, 0x20); /* Flags: R=0 B=0 L=1 */
+	wpabuf_put_be16(msg, erp->next_seq);
+	wpabuf_put_u8(msg, EAP_ERP_TLV_KEYNAME_NAI);
+	wpabuf_put_u8(msg, os_strlen(erp->keyname_nai));
+	wpabuf_put_str(msg, erp->keyname_nai);
+	wpabuf_put_u8(msg, EAP_ERP_CS_HMAC_SHA256_128); /* Cryptosuite */
+	if (hmac_sha256(erp->rIK, erp->rIK_len,
+			wpabuf_head(msg), wpabuf_len(msg), hash) < 0) {
+		wpabuf_free(msg);
+		return -1;
+	wpabuf_put_data(msg, hash, 16);
+	wpa_printf(MSG_DEBUG, "EAP: Sending EAP-Initiate/Re-auth");
+	sm->erp_seq = erp->next_seq;
+	erp->next_seq++;
+	sm->eapRespData = msg;
+	sm->reauthInit = TRUE;
+	return 0;
+ * The method processing happens here. The request from the authenticator is
+ * processed, and an appropriate response packet is built.
+SM_STATE(EAP, METHOD)
+	struct wpabuf *eapReqData;
+	struct eap_method_ret ret;
+	int min_len = 1;
+	SM_ENTRY(EAP, METHOD);
+	if (sm->m == NULL) {
+		wpa_printf(MSG_WARNING, "EAP::METHOD - method not selected");
+		return;
+	if (sm->m->vendor == EAP_VENDOR_IETF && sm->m->method == EAP_TYPE_LEAP)
+		min_len = 0; /* LEAP uses EAP-Success without payload */
+	if (!eap_hdr_len_valid(eapReqData, min_len))
+		return;
+	 * Get ignore, methodState, decision, allowNotifications, and
+	 * eapRespData. RFC 4137 uses three separate method procedure (check,
+	 * process, and buildResp) in this state. These have been combined into
+	 * a single function call to m->process() in order to optimize EAP
+	 * method implementation interface a bit. These procedures are only
+	 * used from within this METHOD state, so there is no need to keep
+	 * these as separate C functions.
+	 * The RFC 4137 procedures return values as follows:
+	 * ignore = m.check(eapReqData)
+	 * (methodState, decision, allowNotifications) = m.process(eapReqData)
+	 * eapRespData = m.buildResp(reqId)
+	os_memset(&ret, 0, sizeof(ret));
+	ret.ignore = sm->ignore;
+	ret.methodState = sm->methodState;
+	ret.decision = sm->decision;
+	ret.allowNotifications = sm->allowNotifications;
+	sm->eapRespData = sm->m->process(sm, sm->eap_method_priv, &ret,
+					 eapReqData);
+	wpa_printf(MSG_DEBUG, "EAP: method process -> ignore=%s "
+		   "methodState=%s decision=%s eapRespData=%p",
+		   ret.ignore ? "TRUE" : "FALSE",
+		   eap_sm_method_state_txt(ret.methodState),
+		   eap_sm_decision_txt(ret.decision),
+		   sm->eapRespData);
+	sm->ignore = ret.ignore;
+	if (sm->ignore)
+		return;
+	sm->methodState = ret.methodState;
+	sm->decision = ret.decision;
+	sm->allowNotifications = ret.allowNotifications;
+	if (sm->m->isKeyAvailable && sm->m->getKey &&
+	    sm->m->isKeyAvailable(sm, sm->eap_method_priv)) {
+		sm->eapKeyData = sm->m->getKey(sm, sm->eap_method_priv,
+					       &sm->eapKeyDataLen);
+		if (sm->m->getSessionId) {
+			sm->eapSessionId = sm->m->getSessionId(
+				sm, sm->eap_method_priv,
+				&sm->eapSessionIdLen);
+			wpa_hexdump(MSG_DEBUG, "EAP: Session-Id",
+				    sm->eapSessionId, sm->eapSessionIdLen);
+		if (config->erp && sm->m->get_emsk && sm->eapSessionId)
+			eap_peer_erp_init(sm);
+ * This state signals the lower layer that a response packet is ready to be
+ * sent.
+SM_STATE(EAP, SEND_RESPONSE)
+	SM_ENTRY(EAP, SEND_RESPONSE);
+	wpabuf_free(sm->lastRespData);
+	if (sm->eapRespData) {
+		if (sm->workaround)
+			os_memcpy(sm->last_sha1, sm->req_sha1, 20);
+		sm->lastId = sm->reqId;
+		sm->lastRespData = wpabuf_dup(sm->eapRespData);
+		eapol_set_bool(sm, EAPOL_eapResp, TRUE);
+	} else {
+		wpa_printf(MSG_DEBUG, "EAP: No eapRespData available");
+		sm->lastRespData = NULL;
+	eapol_set_bool(sm, EAPOL_eapReq, FALSE);
+ * This state signals the lower layer that the request was discarded, and no
+ * response packet will be sent at this time.
+SM_STATE(EAP, DISCARD)
+	SM_ENTRY(EAP, DISCARD);
+	eapol_set_bool(sm, EAPOL_eapNoResp, TRUE);
+ * Handles requests for Identity method and builds a response.
+SM_STATE(EAP, IDENTITY)
+	SM_ENTRY(EAP, IDENTITY);
+	if (!eap_hdr_len_valid(eapReqData, 1))
+		return;
+	eap_sm_processIdentity(sm, eapReqData);
+	sm->eapRespData = eap_sm_buildIdentity(sm, sm->reqId, 0);
+ * Handles requests for Notification method and builds a response.
+SM_STATE(EAP, NOTIFICATION)
+	SM_ENTRY(EAP, NOTIFICATION);
+		return;
+	eap_sm_processNotify(sm, eapReqData);
+	sm->eapRespData = eap_sm_buildNotify(sm->reqId);
+ * This state retransmits the previous response packet.
+SM_STATE(EAP, RETRANSMIT)
+	SM_ENTRY(EAP, RETRANSMIT);
+	if (sm->lastRespData)
+		sm->eapRespData = wpabuf_dup(sm->lastRespData);
+	else
+ * This state is entered in case of a successful completion of authentication
+ * and state machine waits here until port is disabled or EAP authentication is
+ * restarted.
+SM_STATE(EAP, SUCCESS)
+	SM_ENTRY(EAP, SUCCESS);
+	if (sm->eapKeyData != NULL)
+		sm->eapKeyAvailable = TRUE;
+	eapol_set_bool(sm, EAPOL_eapSuccess, TRUE);
+	 * RFC 4137 does not clear eapReq here, but this seems to be required
+	 * to avoid processing the same request twice when state machine is
+	 * initialized.
+	 * RFC 4137 does not set eapNoResp here, but this seems to be required
+	 * to get EAPOL Supplicant backend state machine into SUCCESS state. In
+	 * addition, either eapResp or eapNoResp is required to be set after
+	 * processing the received EAP frame.
+	wpa_msg(sm->msg_ctx, MSG_INFO, WPA_EVENT_EAP_SUCCESS
+		"EAP authentication completed successfully");
+ * This state is entered in case of a failure and state machine waits here
+ * until port is disabled or EAP authentication is restarted.
+SM_STATE(EAP, FAILURE)
+	SM_ENTRY(EAP, FAILURE);
+	eapol_set_bool(sm, EAPOL_eapFail, TRUE);
+	 * initialized.
+	 * RFC 4137 does not set eapNoResp here. However, either eapResp or
+	 * eapNoResp is required to be set after processing the received EAP
+	 * frame.
+	wpa_msg(sm->msg_ctx, MSG_INFO, WPA_EVENT_EAP_FAILURE
+		"EAP authentication failed");
+	sm->prev_failure = 1;
+static int eap_success_workaround(struct eap_sm *sm, int reqId, int lastId)
+	 * At least Microsoft IAS and Meetinghouse Aegis seem to be sending
+	 * EAP-Success/Failure with lastId + 1 even though RFC 3748 and
+	 * RFC 4137 require that reqId == lastId. In addition, it looks like
+	 * Ringmaster v2.1.2.0 would be using lastId + 2 in EAP-Success.
+	 * Accept this kind of Id if EAP workarounds are enabled. These are
+	 * unauthenticated plaintext messages, so this should have minimal
+	 * security implications (bit easier to fake EAP-Success/Failure).
+	if (sm->workaround && (reqId == ((lastId + 1) & 0xff) ||
+			       reqId == ((lastId + 2) & 0xff))) {
+		wpa_printf(MSG_DEBUG, "EAP: Workaround for unexpected "
+			   "identifier field in EAP Success: "
+			   "reqId=%d lastId=%d (these are supposed to be "
+			   "same)", reqId, lastId);
+		return 1;
+	wpa_printf(MSG_DEBUG, "EAP: EAP-Success Id mismatch - reqId=%d "
+		   "lastId=%d", reqId, lastId);
+	return 0;
+ * RFC 4137 - Appendix A.1: EAP Peer State Machine - State transitions
+static void eap_peer_sm_step_idle(struct eap_sm *sm)
+	 * The first three transitions are from RFC 4137. The last two are
+	 * local additions to handle special cases with LEAP and PEAP server
+	 * not sending EAP-Success in some cases.
+	if (eapol_get_bool(sm, EAPOL_eapReq))
+		SM_ENTER(EAP, RECEIVED);
+	else if ((eapol_get_bool(sm, EAPOL_altAccept) &&
+		  sm->decision != DECISION_FAIL) ||
+		 (eapol_get_int(sm, EAPOL_idleWhile) == 0 &&
+		  sm->decision == DECISION_UNCOND_SUCC))
+		SM_ENTER(EAP, SUCCESS);
+	else if (eapol_get_bool(sm, EAPOL_altReject) ||
+		  sm->decision != DECISION_UNCOND_SUCC) ||
+		 (eapol_get_bool(sm, EAPOL_altAccept) &&
+		  sm->methodState != METHOD_CONT &&
+		  sm->decision == DECISION_FAIL))
+		SM_ENTER(EAP, FAILURE);
+	else if (sm->selectedMethod == EAP_TYPE_LEAP &&
+		 sm->leap_done && sm->decision != DECISION_FAIL &&
+		 sm->methodState == METHOD_DONE)
+	else if (sm->selectedMethod == EAP_TYPE_PEAP &&
+		 sm->peap_done && sm->decision != DECISION_FAIL &&
+static int eap_peer_req_is_duplicate(struct eap_sm *sm)
+	int duplicate;
+	duplicate = (sm->reqId == sm->lastId) && sm->rxReq;
+	if (sm->workaround && duplicate &&
+	    os_memcmp(sm->req_sha1, sm->last_sha1, 20) != 0) {
+		 * RFC 4137 uses (reqId == lastId) as the only verification for
+		 * duplicate EAP requests. However, this misses cases where the
+		 * AS is incorrectly using the same id again; and
+		 * unfortunately, such implementations exist. Use SHA1 hash as
+		 * an extra verification for the packets being duplicate to
+		 * workaround these issues.
+		wpa_printf(MSG_DEBUG, "EAP: AS used the same Id again, but "
+			   "EAP packets were not identical");
+		wpa_printf(MSG_DEBUG, "EAP: workaround - assume this is not a "
+			   "duplicate packet");
+		duplicate = 0;
+	return duplicate;
+static int eap_peer_sm_allow_canned(struct eap_sm *sm)
+	return config && config->phase1 &&
+		os_strstr(config->phase1, "allow_canned_success=1");
+static void eap_peer_sm_step_received(struct eap_sm *sm)
+	int duplicate = eap_peer_req_is_duplicate(sm);
+	 * Two special cases below for LEAP are local additions to work around
+	 * odd LEAP behavior (EAP-Success in the middle of authentication and
+	 * then swapped roles). Other transitions are based on RFC 4137.
+	if (sm->rxSuccess && sm->decision != DECISION_FAIL &&
+	    (sm->reqId == sm->lastId ||
+	     eap_success_workaround(sm, sm->reqId, sm->lastId)))
+	else if (sm->workaround && sm->lastId == -1 && sm->rxSuccess &&
+		 !sm->rxFailure && !sm->rxReq && eap_peer_sm_allow_canned(sm))
+		SM_ENTER(EAP, SUCCESS); /* EAP-Success prior any EAP method */
+	else if (sm->workaround && sm->lastId == -1 && sm->rxFailure &&
+		 !sm->rxReq && sm->methodState != METHOD_CONT &&
+		 eap_peer_sm_allow_canned(sm))
+		SM_ENTER(EAP, FAILURE); /* EAP-Failure prior any EAP method */
+	else if (sm->workaround && sm->rxSuccess && !sm->rxFailure &&
+		SM_ENTER(EAP, SUCCESS); /* EAP-Success after Identity */
+	else if (sm->methodState != METHOD_CONT &&
+		 ((sm->rxFailure &&
+		  (sm->rxSuccess && sm->decision == DECISION_FAIL &&
+		   (sm->selectedMethod != EAP_TYPE_LEAP ||
+		    sm->methodState != METHOD_MAY_CONT))) &&
+	else if (sm->rxReq && duplicate)
+		SM_ENTER(EAP, RETRANSMIT);
+	else if (sm->rxReq && !duplicate &&
+		 sm->reqMethod == EAP_TYPE_NOTIFICATION &&
+		 sm->allowNotifications)
+		SM_ENTER(EAP, NOTIFICATION);
+		 sm->selectedMethod == EAP_TYPE_NONE &&
+		 sm->reqMethod == EAP_TYPE_IDENTITY)
+		SM_ENTER(EAP, IDENTITY);
+		 sm->reqMethod != EAP_TYPE_IDENTITY &&
+		 sm->reqMethod != EAP_TYPE_NOTIFICATION)
+		SM_ENTER(EAP, GET_METHOD);
+		 sm->reqMethod == sm->selectedMethod &&
+		 sm->methodState != METHOD_DONE)
+		SM_ENTER(EAP, METHOD);
+		 (sm->rxSuccess || sm->rxResp))
+	else if (sm->reauthInit)
+		SM_ENTER(EAP, SEND_RESPONSE);
+	else
+		SM_ENTER(EAP, DISCARD);
+static void eap_peer_sm_step_local(struct eap_sm *sm)
+	switch (sm->EAP_state) {
+	case EAP_INITIALIZE:
+		SM_ENTER(EAP, IDLE);
+		break;
+	case EAP_DISABLED:
+		if (eapol_get_bool(sm, EAPOL_portEnabled) &&
+		    !sm->force_disabled)
+			SM_ENTER(EAP, INITIALIZE);
+		break;
+	case EAP_IDLE:
+		eap_peer_sm_step_idle(sm);
+		break;
+	case EAP_RECEIVED:
+		eap_peer_sm_step_received(sm);
+		break;
+	case EAP_GET_METHOD:
+		if (sm->selectedMethod == sm->reqMethod)
+		else
+		break;
+	case EAP_METHOD:
+		 * Note: RFC 4137 uses methodState == DONE && decision == FAIL
+		 * as the condition. eapRespData == NULL here is used to allow
+		 * final EAP method response to be sent without having to change
+		 * all methods to either use methodState MAY_CONT or leaving
+		 * decision to something else than FAIL in cases where the only
+		 * expected response is EAP-Failure.
+		if (sm->ignore)
+		else if (sm->methodState == METHOD_DONE &&
+			 sm->decision == DECISION_FAIL && !sm->eapRespData)
+		else
+		break;
+	case EAP_SEND_RESPONSE:
+		break;
+	case EAP_DISCARD:
+		break;
+	case EAP_IDENTITY:
+		break;
+	case EAP_NOTIFICATION:
+		break;
+	case EAP_RETRANSMIT:
+		break;
+	case EAP_SUCCESS:
+		break;
+	case EAP_FAILURE:
+		break;
+SM_STEP(EAP)
+	/* Global transitions */
+	if (eapol_get_bool(sm, EAPOL_eapRestart) &&
+	    eapol_get_bool(sm, EAPOL_portEnabled))
+		SM_ENTER_GLOBAL(EAP, INITIALIZE);
+	else if (!eapol_get_bool(sm, EAPOL_portEnabled) || sm->force_disabled)
+		SM_ENTER_GLOBAL(EAP, DISABLED);
+	else if (sm->num_rounds > EAP_MAX_AUTH_ROUNDS) {
+		/* RFC 4137 does not place any limit on number of EAP messages
+		 * in an authentication session. However, some error cases have
+		 * ended up in a state were EAP messages were sent between the
+		 * peer and server in a loop (e.g., TLS ACK frame in both
+		 * direction). Since this is quite undesired outcome, limit the
+		 * total number of EAP round-trips and abort authentication if
+		 * this limit is exceeded.
+		if (sm->num_rounds == EAP_MAX_AUTH_ROUNDS + 1) {
+			wpa_msg(sm->msg_ctx, MSG_INFO, "EAP: more than %d "
+				"authentication rounds - abort",
+				EAP_MAX_AUTH_ROUNDS);
+			sm->num_rounds++;
+			SM_ENTER_GLOBAL(EAP, FAILURE);
+	} else {
+		/* Local transitions */
+		eap_peer_sm_step_local(sm);
+				  EapType method)
+	if (!eap_allowed_method(sm, vendor, method)) {
+		wpa_printf(MSG_DEBUG, "EAP: configuration does not allow: "
+			   "vendor %u method %u", vendor, method);
+		return FALSE;
+	if (eap_peer_get_eap_method(vendor, method))
+		return TRUE;
+	wpa_printf(MSG_DEBUG, "EAP: not included in build: "
+	return FALSE;
+static struct wpabuf * eap_sm_build_expanded_nak(
+	struct eap_sm *sm, int id, const struct eap_method *methods,
+	size_t count)
+	struct wpabuf *resp;
+	int found = 0;
+	const struct eap_method *m;
+	wpa_printf(MSG_DEBUG, "EAP: Building expanded EAP-Nak");
+	/* RFC 3748 - 5.3.2: Expanded Nak */
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_EXPANDED,
+			     8 + 8 * (count + 1), EAP_CODE_RESPONSE, id);
+	if (resp == NULL)
+		return NULL;
+	wpabuf_put_be24(resp, EAP_VENDOR_IETF);
+	wpabuf_put_be32(resp, EAP_TYPE_NAK);
+	for (m = methods; m; m = m->next) {
+		if (sm->reqVendor == m->vendor &&
+		    sm->reqVendorMethod == m->method)
+			continue; /* do not allow the current method again */
+		if (eap_allowed_method(sm, m->vendor, m->method)) {
+			wpa_printf(MSG_DEBUG, "EAP: allowed type: "
+				   m->vendor, m->method);
+			wpabuf_put_u8(resp, EAP_TYPE_EXPANDED);
+			wpabuf_put_be24(resp, m->vendor);
+			wpabuf_put_be32(resp, m->method);
+			found++;
+	if (!found) {
+		wpa_printf(MSG_DEBUG, "EAP: no more allowed methods");
+		wpabuf_put_be32(resp, EAP_TYPE_NONE);
+	eap_update_len(resp);
+	return resp;
+	u8 *start;
+	int found = 0, expanded_found = 0;
+	size_t count;
+	const struct eap_method *methods, *m;
+	wpa_printf(MSG_DEBUG, "EAP: Building EAP-Nak (requested type %u "
+		   "vendor=%u method=%u not allowed)", sm->reqMethod,
+		   sm->reqVendor, sm->reqVendorMethod);
+	methods = eap_peer_get_methods(&count);
+	if (methods == NULL)
+		return NULL;
+		return eap_sm_build_expanded_nak(sm, id, methods, count);
+	/* RFC 3748 - 5.3.1: Legacy Nak */
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_NAK,
+			     sizeof(struct eap_hdr) + 1 + count + 1,
+			     EAP_CODE_RESPONSE, id);
+	if (resp == NULL)
+		return NULL;
+	start = wpabuf_put(resp, 0);
+		if (m->vendor == EAP_VENDOR_IETF && m->method == sm->reqMethod)
+			if (m->vendor != EAP_VENDOR_IETF) {
+				if (expanded_found)
+					continue;
+				expanded_found = 1;
+			} else
+				wpabuf_put_u8(resp, m->method);
+			found++;
+	if (!found)
+		wpabuf_put_u8(resp, EAP_TYPE_NONE);
+	wpa_hexdump(MSG_DEBUG, "EAP: allowed methods", start, found);
+	return resp;
+static void eap_sm_processIdentity(struct eap_sm *sm, const struct wpabuf *req)
+	const u8 *pos;
+	size_t msg_len;
+	wpa_msg(sm->msg_ctx, MSG_INFO, WPA_EVENT_EAP_STARTED
+		"EAP authentication started");
+	eap_notify_status(sm, "started", "");
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_IDENTITY, req,
+			       &msg_len);
+	if (pos == NULL)
+		return;
+	 * RFC 3748 - 5.1: Identity
+	 * Data field may contain a displayable message in UTF-8. If this
+	 * includes NUL-character, only the data before that should be
+	 * displayed. Some EAP implementasitons may piggy-back additional
+	 * options after the NUL.
+	/* TODO: could save displayable message so that it can be shown to the
+	 * user in case of interaction is required */
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP: EAP-Request Identity data",
+			  pos, msg_len);
+#ifdef PCSC_FUNCS
+ * Rules for figuring out MNC length based on IMSI for SIM cards that do not
+ * include MNC length field.
+static int mnc_len_from_imsi(const char *imsi)
+	char mcc_str[4];
+	unsigned int mcc;
+	os_memcpy(mcc_str, imsi, 3);
+	mcc_str[3] = '\0';
+	mcc = atoi(mcc_str);
+	if (mcc == 228)
+		return 2; /* Networks in Switzerland use 2-digit MNC */
+	if (mcc == 244)
+		return 2; /* Networks in Finland use 2-digit MNC */
+	return -1;
+static int eap_sm_append_3gpp_realm(struct eap_sm *sm, char *imsi,
+				    size_t max_len, size_t *imsi_len)
+	int mnc_len;
+	char *pos, mnc[4];
+	if (*imsi_len + 36 > max_len) {
+		wpa_printf(MSG_WARNING, "No room for realm in IMSI buffer");
+		return -1;
+	/* MNC (2 or 3 digits) */
+	mnc_len = scard_get_mnc_len(sm->scard_ctx);
+	if (mnc_len < 0)
+		mnc_len = mnc_len_from_imsi(imsi);
+	if (mnc_len < 0) {
+		wpa_printf(MSG_INFO, "Failed to get MNC length from (U)SIM "
+			   "assuming 3");
+		mnc_len = 3;
+	if (mnc_len == 2) {
+		mnc[0] = '0';
+		mnc[1] = imsi[3];
+		mnc[2] = imsi[4];
+	} else if (mnc_len == 3) {
+		mnc[0] = imsi[3];
+		mnc[1] = imsi[4];
+		mnc[2] = imsi[5];
+	mnc[3] = '\0';
+	pos = imsi + *imsi_len;
+	pos += os_snprintf(pos, imsi + max_len - pos,
+			   "@wlan.mnc%s.mcc%c%c%c.3gppnetwork.org",
+			   mnc, imsi[0], imsi[1], imsi[2]);
+	*imsi_len = pos - imsi;
+	return 0;
+static int eap_sm_imsi_identity(struct eap_sm *sm,
+				struct eap_peer_config *conf)
+	enum { EAP_SM_SIM, EAP_SM_AKA, EAP_SM_AKA_PRIME } method = EAP_SM_SIM;
+	char imsi[100];
+	size_t imsi_len;
+	struct eap_method_type *m = conf->eap_methods;
+	int i;
+	imsi_len = sizeof(imsi);
+	if (scard_get_imsi(sm->scard_ctx, imsi, &imsi_len)) {
+		wpa_printf(MSG_WARNING, "Failed to get IMSI from SIM");
+		return -1;
+	wpa_hexdump_ascii(MSG_DEBUG, "IMSI", (u8 *) imsi, imsi_len);
+	if (imsi_len < 7) {
+		wpa_printf(MSG_WARNING, "Too short IMSI for SIM identity");
+		return -1;
+	if (eap_sm_append_3gpp_realm(sm, imsi, sizeof(imsi), &imsi_len) < 0) {
+		wpa_printf(MSG_WARNING, "Could not add realm to SIM identity");
+		return -1;
+	wpa_hexdump_ascii(MSG_DEBUG, "IMSI + realm", (u8 *) imsi, imsi_len);
+	for (i = 0; m && (m[i].vendor != EAP_VENDOR_IETF ||
+			  m[i].method != EAP_TYPE_NONE); i++) {
+		if (m[i].vendor == EAP_VENDOR_IETF &&
+		    m[i].method == EAP_TYPE_AKA_PRIME) {
+			method = EAP_SM_AKA_PRIME;
+			break;
+		    m[i].method == EAP_TYPE_AKA) {
+			method = EAP_SM_AKA;
+			break;
+	os_free(conf->identity);
+	conf->identity = os_malloc(1 + imsi_len);
+	if (conf->identity == NULL) {
+		wpa_printf(MSG_WARNING, "Failed to allocate buffer for "
+			   "IMSI-based identity");
+		return -1;
+	switch (method) {
+	case EAP_SM_SIM:
+		conf->identity[0] = '1';
+		break;
+	case EAP_SM_AKA:
+		conf->identity[0] = '0';
+		break;
+	case EAP_SM_AKA_PRIME:
+		conf->identity[0] = '6';
+		break;
+	os_memcpy(conf->identity + 1, imsi, imsi_len);
+	conf->identity_len = 1 + imsi_len;
+	return 0;
+#endif /* PCSC_FUNCS */
+static int eap_sm_set_scard_pin(struct eap_sm *sm,
+#ifdef PCSC_FUNCS
+	if (scard_set_pin(sm->scard_ctx, conf->pin)) {
+		 * Make sure the same PIN is not tried again in order to avoid
+		 * blocking SIM.
+		os_free(conf->pin);
+		conf->pin = NULL;
+		wpa_printf(MSG_WARNING, "PIN validation failed");
+		eap_sm_request_pin(sm);
+		return -1;
+	return 0;
+#else /* PCSC_FUNCS */
+	return -1;
+static int eap_sm_get_scard_identity(struct eap_sm *sm,
+#ifdef PCSC_FUNCS
+	if (eap_sm_set_scard_pin(sm, conf))
+		return -1;
+	return eap_sm_imsi_identity(sm, conf);
+	return -1;
+ * eap_sm_buildIdentity - Build EAP-Identity/Response for the current network
+ * @id: EAP identifier for the packet
+ * @encrypted: Whether the packet is for encrypted tunnel (EAP phase 2)
+ * Returns: Pointer to the allocated EAP-Identity/Response packet or %NULL on
+ * failure
+ * This function allocates and builds an EAP-Identity/Response packet for the
+ * current network. The caller is responsible for freeing the returned data.
+struct wpabuf * eap_sm_buildIdentity(struct eap_sm *sm, int id, int encrypted)
+	const u8 *identity;
+	size_t identity_len;
+	if (config == NULL) {
+		wpa_printf(MSG_WARNING, "EAP: buildIdentity: configuration "
+			   "was not available");
+		return NULL;
+	if (sm->m && sm->m->get_identity &&
+	    (identity = sm->m->get_identity(sm, sm->eap_method_priv,
+					    &identity_len)) != NULL) {
+		wpa_hexdump_ascii(MSG_DEBUG, "EAP: using method re-auth "
+				  "identity", identity, identity_len);
+	} else if (!encrypted && config->anonymous_identity) {
+		identity = config->anonymous_identity;
+		identity_len = config->anonymous_identity_len;
+		wpa_hexdump_ascii(MSG_DEBUG, "EAP: using anonymous identity",
+				  identity, identity_len);
+	} else {
+		identity = config->identity;
+		identity_len = config->identity_len;
+		wpa_hexdump_ascii(MSG_DEBUG, "EAP: using real identity",
+	if (identity == NULL) {
+		wpa_printf(MSG_WARNING, "EAP: buildIdentity: identity "
+			   "configuration was not available");
+		if (config->pcsc) {
+			if (eap_sm_get_scard_identity(sm, config) < 0)
+				return NULL;
+			wpa_hexdump_ascii(MSG_DEBUG, "permanent identity from "
+					  "IMSI", identity, identity_len);
+		} else {
+			eap_sm_request_identity(sm);
+			return NULL;
+	} else if (config->pcsc) {
+		if (eap_sm_set_scard_pin(sm, config) < 0)
+			return NULL;
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_IDENTITY, identity_len,
+	if (resp == NULL)
+		return NULL;
+	wpabuf_put_data(resp, identity, identity_len);
+	return resp;
+	const u8 *pos;
+	char *msg;
+	size_t i, msg_len;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_NOTIFICATION, req,
+			       &msg_len);
+	if (pos == NULL)
+		return;
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP: EAP-Request Notification data",
+			  pos, msg_len);
+	msg = os_malloc(msg_len + 1);
+	if (msg == NULL)
+		return;
+	for (i = 0; i < msg_len; i++)
+		msg[i] = isprint(pos[i]) ? (char) pos[i] : '_';
+	msg[msg_len] = '\0';
+	wpa_msg(sm->msg_ctx, MSG_INFO, "%s%s",
+		WPA_EVENT_EAP_NOTIFICATION, msg);
+	os_free(msg);
+	wpa_printf(MSG_DEBUG, "EAP: Generating EAP-Response Notification");
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_NOTIFICATION, 0,
+	if (resp == NULL)
+		return NULL;
+	return resp;
+static void eap_peer_initiate(struct eap_sm *sm, const struct eap_hdr *hdr,
+			      size_t len)
+#ifdef CONFIG_ERP
+	const u8 *pos = (const u8 *) (hdr + 1);
+	const u8 *end = ((const u8 *) hdr) + len;
+	struct erp_tlvs parse;
+	if (len < sizeof(*hdr) + 1) {
+		wpa_printf(MSG_DEBUG, "EAP: Ignored too short EAP-Initiate");
+		return;
+	if (*pos != EAP_ERP_TYPE_REAUTH_START) {
+			   "EAP: Ignored unexpected EAP-Initiate Type=%u",
+			   *pos);
+		return;
+	pos++;
+	if (pos >= end) {
+			   "EAP: Too short EAP-Initiate/Re-auth-Start");
+		return;
+	pos++; /* Reserved */
+	wpa_hexdump(MSG_DEBUG, "EAP: EAP-Initiate/Re-auth-Start TVs/TLVs",
+		    pos, end - pos);
+	if (erp_parse_tlvs(pos, end, &parse, 0) < 0)
+		goto invalid;
+	if (parse.domain) {
+				  "EAP: EAP-Initiate/Re-auth-Start - Domain name",
+				  parse.domain, parse.domain_len);
+		/* TODO: Derivation of domain specific keys for local ER */
+	if (eap_peer_erp_reauth_start(sm, hdr, len) == 0)
+		return;
+invalid:
+		   "EAP: EAP-Initiate/Re-auth-Start - No suitable ERP keys available - try to start full EAP authentication");
+	eapol_set_bool(sm, EAPOL_eapTriggerStart, TRUE);
+static void eap_peer_finish(struct eap_sm *sm, const struct eap_hdr *hdr,
+			    size_t len)
+#ifdef CONFIG_ERP
+	const u8 *start;
+	u8 flags;
+	u16 seq;
+	size_t hash_len;
+	int max_len;
+	char nai[254];
+	u8 seed[4];
+	int auth_tag_ok = 0;
+		wpa_printf(MSG_DEBUG, "EAP: Ignored too short EAP-Finish");
+		return;
+	if (*pos != EAP_ERP_TYPE_REAUTH) {
+			   "EAP: Ignored unexpected EAP-Finish Type=%u", *pos);
+		return;
+	if (len < sizeof(*hdr) + 4) {
+			   "EAP: Ignored too short EAP-Finish/Re-auth");
+		return;
+	pos++;
+	flags = *pos++;
+	seq = WPA_GET_BE16(pos);
+	pos += 2;
+	wpa_printf(MSG_DEBUG, "EAP: Flags=0x%x SEQ=%u", flags, seq);
+	if (seq != sm->erp_seq) {
+			   "EAP: Unexpected EAP-Finish/Re-auth SEQ=%u", seq);
+		return;
+	 * Parse TVs/TLVs. Since we do not yet know the length of the
+	 * Authentication Tag, stop parsing if an unknown TV/TLV is seen and
+	 * just try to find the keyName-NAI first so that we can check the
+	 * Authentication Tag.
+	if (erp_parse_tlvs(pos, end, &parse, 1) < 0)
+		return;
+	if (!parse.keyname) {
+			   "EAP: No keyName-NAI in EAP-Finish/Re-auth Packet");
+		return;
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP: EAP-Finish/Re-auth - keyName-NAI",
+			  parse.keyname, parse.keyname_len);
+	if (parse.keyname_len > 253) {
+			   "EAP: Too long keyName-NAI in EAP-Finish/Re-auth");
+		return;
+	os_memcpy(nai, parse.keyname, parse.keyname_len);
+	nai[parse.keyname_len] = '\0';
+	erp = eap_erp_get_key_nai(sm, nai);
+	if (!erp) {
+		wpa_printf(MSG_DEBUG, "EAP: No matching ERP key found for %s",
+			   nai);
+		return;
+	/* Is there enough room for Cryptosuite and Authentication Tag? */
+	start = parse.keyname + parse.keyname_len;
+	max_len = end - start;
+	hash_len = 16;
+	if (max_len < 1 + (int) hash_len) {
+			   "EAP: Not enough room for Authentication Tag");
+		if (flags & 0x80)
+			goto no_auth_tag;
+		return;
+	if (end[-17] != EAP_ERP_CS_HMAC_SHA256_128) {
+		wpa_printf(MSG_DEBUG, "EAP: Different Cryptosuite used");
+		if (flags & 0x80)
+			goto no_auth_tag;
+		return;
+	if (hmac_sha256(erp->rIK, erp->rIK_len, (const u8 *) hdr,
+			end - ((const u8 *) hdr) - hash_len, hash) < 0)
+		return;
+	if (os_memcmp(end - hash_len, hash, hash_len) != 0) {
+			   "EAP: Authentication Tag mismatch");
+		return;
+	auth_tag_ok = 1;
+	end -= 1 + hash_len;
+no_auth_tag:
+	 * Parse TVs/TLVs again now that we know the exact part of the buffer
+	 * that contains them.
+	wpa_hexdump(MSG_DEBUG, "EAP: EAP-Finish/Re-Auth TVs/TLVs",
+		    pos, end - pos);
+		return;
+	if (flags & 0x80 || !auth_tag_ok) {
+			   "EAP: EAP-Finish/Re-auth indicated failure");
+			   "EAP: Drop ERP key to try full authentication on next attempt");
+		return;
+	sm->eapKeyDataLen = 0;
+	sm->eapKeyData = os_malloc(erp->rRK_len);
+	if (!sm->eapKeyData)
+		return;
+	sm->eapKeyDataLen = erp->rRK_len;
+	WPA_PUT_BE16(seed, seq);
+	WPA_PUT_BE16(&seed[2], erp->rRK_len);
+			    "Re-authentication Master Session Key at ietf.org",
+			    seed, sizeof(seed),
+			    sm->eapKeyData, erp->rRK_len) < 0) {
+		wpa_printf(MSG_DEBUG, "EAP: Could not derive rMSK for ERP");
+		return;
+	wpa_hexdump_key(MSG_DEBUG, "EAP: ERP rMSK",
+			sm->eapKeyData, sm->eapKeyDataLen);
+		"EAP re-authentication completed successfully");
+	const struct eap_hdr *hdr;
+	size_t plen;
+	const u8 *pos;
+	sm->rxReq = sm->rxResp = sm->rxSuccess = sm->rxFailure = FALSE;
+	sm->reqId = 0;
+	sm->reqMethod = EAP_TYPE_NONE;
+	sm->reqVendor = EAP_VENDOR_IETF;
+	sm->reqVendorMethod = EAP_TYPE_NONE;
+	if (req == NULL || wpabuf_len(req) < sizeof(*hdr))
+		return;
+	hdr = wpabuf_head(req);
+	plen = be_to_host16(hdr->length);
+	if (plen > wpabuf_len(req)) {
+		wpa_printf(MSG_DEBUG, "EAP: Ignored truncated EAP-Packet "
+			   "(len=%lu plen=%lu)",
+			   (unsigned long) wpabuf_len(req),
+			   (unsigned long) plen);
+		return;
+	sm->reqId = hdr->identifier;
+	if (sm->workaround) {
+		const u8 *addr[1];
+		addr[0] = wpabuf_head(req);
+		sha1_vector(1, addr, &plen, sm->req_sha1);
+	switch (hdr->code) {
+	case EAP_CODE_REQUEST:
+		if (plen < sizeof(*hdr) + 1) {
+			wpa_printf(MSG_DEBUG, "EAP: Too short EAP-Request - "
+				   "no Type field");
+			return;
+		sm->rxReq = TRUE;
+		pos = (const u8 *) (hdr + 1);
+		sm->reqMethod = *pos++;
+		if (sm->reqMethod == EAP_TYPE_EXPANDED) {
+			if (plen < sizeof(*hdr) + 8) {
+				wpa_printf(MSG_DEBUG, "EAP: Ignored truncated "
+					   "expanded EAP-Packet (plen=%lu)",
+				return;
+			sm->reqVendor = WPA_GET_BE24(pos);
+			pos += 3;
+			sm->reqVendorMethod = WPA_GET_BE32(pos);
+		wpa_printf(MSG_DEBUG, "EAP: Received EAP-Request id=%d "
+			   "method=%u vendor=%u vendorMethod=%u",
+			   sm->reqId, sm->reqMethod, sm->reqVendor,
+			   sm->reqVendorMethod);
+		break;
+	case EAP_CODE_RESPONSE:
+		if (sm->selectedMethod == EAP_TYPE_LEAP) {
+			 * LEAP differs from RFC 4137 by using reversed roles
+			 * for mutual authentication and because of this, we
+			 * need to accept EAP-Response frames if LEAP is used.
+				wpa_printf(MSG_DEBUG, "EAP: Too short "
+					   "EAP-Response - no Type field");
+				return;
+			sm->rxResp = TRUE;
+			sm->reqMethod = *pos;
+			wpa_printf(MSG_DEBUG, "EAP: Received EAP-Response for "
+				   "LEAP method=%d id=%d",
+				   sm->reqMethod, sm->reqId);
+			break;
+		wpa_printf(MSG_DEBUG, "EAP: Ignored EAP-Response");
+		break;
+	case EAP_CODE_SUCCESS:
+		wpa_printf(MSG_DEBUG, "EAP: Received EAP-Success");
+		eap_notify_status(sm, "completion", "success");
+		sm->rxSuccess = TRUE;
+		break;
+	case EAP_CODE_FAILURE:
+		wpa_printf(MSG_DEBUG, "EAP: Received EAP-Failure");
+		eap_notify_status(sm, "completion", "failure");
+		sm->rxFailure = TRUE;
+		break;
+	case EAP_CODE_INITIATE:
+		eap_peer_initiate(sm, hdr, plen);
+		break;
+	case EAP_CODE_FINISH:
+		eap_peer_finish(sm, hdr, plen);
+		break;
+	default:
+		wpa_printf(MSG_DEBUG, "EAP: Ignored EAP-Packet with unknown "
+			   "code %d", hdr->code);
+		break;
+static void eap_peer_sm_tls_event(void *ctx, enum tls_event ev,
+				  union tls_event_data *data)
+	struct eap_sm *sm = ctx;
+	char *hash_hex = NULL;
+	switch (ev) {
+	case TLS_CERT_CHAIN_SUCCESS:
+		eap_notify_status(sm, "remote certificate verification",
+				  "success");
+		break;
+	case TLS_CERT_CHAIN_FAILURE:
+		wpa_msg(sm->msg_ctx, MSG_INFO, WPA_EVENT_EAP_TLS_CERT_ERROR
+			"reason=%d depth=%d subject='%s' err='%s'",
+			data->cert_fail.reason,
+			data->cert_fail.depth,
+			data->cert_fail.subject,
+			data->cert_fail.reason_txt);
+		break;
+	case TLS_PEER_CERTIFICATE:
+		if (!sm->eapol_cb->notify_cert)
+			break;
+		if (data->peer_cert.hash) {
+			size_t len = data->peer_cert.hash_len * 2 + 1;
+			hash_hex = os_malloc(len);
+			if (hash_hex) {
+				wpa_snprintf_hex(hash_hex, len,
+						 data->peer_cert.hash,
+						 data->peer_cert.hash_len);
+		sm->eapol_cb->notify_cert(sm->eapol_ctx,
+					  data->peer_cert.depth,
+					  data->peer_cert.subject,
+					  data->peer_cert.altsubject,
+					  data->peer_cert.num_altsubject,
+					  hash_hex, data->peer_cert.cert);
+		break;
+	case TLS_ALERT:
+		if (data->alert.is_local)
+			eap_notify_status(sm, "local TLS alert",
+					  data->alert.description);
+		else
+			eap_notify_status(sm, "remote TLS alert",
+		break;
+	os_free(hash_hex);
+ * eap_peer_sm_init - Allocate and initialize EAP peer state machine
+ * @eapol_ctx: Context data to be used with eapol_cb calls
+ * @eapol_cb: Pointer to EAPOL callback functions
+ * @msg_ctx: Context data for wpa_msg() calls
+ * @conf: EAP configuration
+ * Returns: Pointer to the allocated EAP state machine or %NULL on failure
+ * This function allocates and initializes an EAP state machine. In addition,
+ * this initializes TLS library for the new EAP state machine. eapol_cb pointer
+ * will be in use until eap_peer_sm_deinit() is used to deinitialize this EAP
+ * state machine. Consequently, the caller must make sure that this data
+ * structure remains alive while the EAP state machine is active.
+struct eap_sm * eap_peer_sm_init(void *eapol_ctx,
+				 const struct eapol_callbacks *eapol_cb,
+				 void *msg_ctx, struct eap_config *conf)
+	struct eap_sm *sm;
+	struct tls_config tlsconf;
+	sm = os_zalloc(sizeof(*sm));
+	if (sm == NULL)
+		return NULL;
+	sm->eapol_ctx = eapol_ctx;
+	sm->eapol_cb = eapol_cb;
+	sm->msg_ctx = msg_ctx;
+	sm->wps = conf->wps;
+	dl_list_init(&sm->erp_keys);
+	os_memset(&tlsconf, 0, sizeof(tlsconf));
+	tlsconf.opensc_engine_path = conf->opensc_engine_path;
+	tlsconf.pkcs11_engine_path = conf->pkcs11_engine_path;
+	tlsconf.pkcs11_module_path = conf->pkcs11_module_path;
+	tlsconf.openssl_ciphers = conf->openssl_ciphers;
+#ifdef CONFIG_FIPS
+	tlsconf.fips_mode = 1;
+#endif /* CONFIG_FIPS */
+	tlsconf.event_cb = eap_peer_sm_tls_event;
+	tlsconf.cb_ctx = sm;
+	tlsconf.cert_in_cb = conf->cert_in_cb;
+	sm->ssl_ctx = tls_init(&tlsconf);
+	if (sm->ssl_ctx == NULL) {
+		wpa_printf(MSG_WARNING, "SSL: Failed to initialize TLS "
+			   "context.");
+		os_free(sm);
+		return NULL;
+	sm->ssl_ctx2 = tls_init(&tlsconf);
+	if (sm->ssl_ctx2 == NULL) {
+		wpa_printf(MSG_INFO, "SSL: Failed to initialize TLS "
+			   "context (2).");
+		/* Run without separate TLS context within TLS tunnel */
+	return sm;
+ * eap_peer_sm_deinit - Deinitialize and free an EAP peer state machine
+ * This function deinitializes EAP state machine and frees all allocated
+ * resources.
+void eap_peer_sm_deinit(struct eap_sm *sm)
+	if (sm == NULL)
+		return;
+	eap_deinit_prev_method(sm, "EAP deinit");
+	eap_sm_abort(sm);
+	if (sm->ssl_ctx2)
+		tls_deinit(sm->ssl_ctx2);
+	tls_deinit(sm->ssl_ctx);
+	eap_peer_erp_free_keys(sm);
+	os_free(sm);
+ * eap_peer_sm_step - Step EAP peer state machine
+ * Returns: 1 if EAP state was changed or 0 if not
+ * This function advances EAP state machine to a new state to match with the
+ * current variables. This should be called whenever variables used by the EAP
+ * state machine have changed.
+int eap_peer_sm_step(struct eap_sm *sm)
+	int res = 0;
+	do {
+		sm->changed = FALSE;
+		SM_STEP_RUN(EAP);
+		if (sm->changed)
+			res = 1;
+	} while (sm->changed);
+	return res;
+ * eap_sm_abort - Abort EAP authentication
+ * Release system resources that have been allocated for the authentication
+ * session without fully deinitializing the EAP state machine.
+void eap_sm_abort(struct eap_sm *sm)
+	/* This is not clearly specified in the EAP statemachines draft, but
+	 * it seems necessary to make sure that some of the EAPOL variables get
+	 * cleared for the next authentication. */
+#ifdef CONFIG_CTRL_IFACE
+static const char * eap_sm_state_txt(int state)
+	switch (state) {
+		return "INITIALIZE";
+		return "DISABLED";
+	case EAP_IDLE:
+		return "IDLE";
+		return "RECEIVED";
+		return "GET_METHOD";
+	case EAP_METHOD:
+		return "METHOD";
+		return "SEND_RESPONSE";
+	case EAP_DISCARD:
+		return "DISCARD";
+		return "IDENTITY";
+		return "NOTIFICATION";
+		return "RETRANSMIT";
+	case EAP_SUCCESS:
+		return "SUCCESS";
+	case EAP_FAILURE:
+		return "FAILURE";
+	default:
+		return "UNKNOWN";
+#endif /* CONFIG_CTRL_IFACE */
+	switch (state) {
+	case METHOD_NONE:
+		return "NONE";
+	case METHOD_INIT:
+		return "INIT";
+	case METHOD_CONT:
+		return "CONT";
+	case METHOD_MAY_CONT:
+		return "MAY_CONT";
+	case METHOD_DONE:
+		return "DONE";
+	default:
+		return "UNKNOWN";
+	switch (decision) {
+	case DECISION_FAIL:
+		return "FAIL";
+	case DECISION_COND_SUCC:
+		return "COND_SUCC";
+	case DECISION_UNCOND_SUCC:
+		return "UNCOND_SUCC";
+	default:
+		return "UNKNOWN";
+ * eap_sm_get_status - Get EAP state machine status
+ * @buf: Buffer for status information
+ * @buflen: Maximum buffer length
+ * @verbose: Whether to include verbose status information
+ * Returns: Number of bytes written to buf.
+ * Query EAP state machine for status information. This function fills in a
+ * text area with current status information from the EAPOL state machine. If
+ * the buffer (buf) is not large enough, status information will be truncated
+ * to fit the buffer.
+int eap_sm_get_status(struct eap_sm *sm, char *buf, size_t buflen, int verbose)
+	int len, ret;
+	if (sm == NULL)
+		return 0;
+	len = os_snprintf(buf, buflen,
+			  "EAP state=%s\n",
+			  eap_sm_state_txt(sm->EAP_state));
+	if (os_snprintf_error(buflen, len))
+		return 0;
+	if (sm->selectedMethod != EAP_TYPE_NONE) {
+		const char *name;
+		if (sm->m) {
+			name = sm->m->name;
+		} else {
+			const struct eap_method *m =
+				eap_peer_get_eap_method(EAP_VENDOR_IETF,
+							sm->selectedMethod);
+			if (m)
+				name = m->name;
+			else
+				name = "?";
+		ret = os_snprintf(buf + len, buflen - len,
+				  "selectedMethod=%d (EAP-%s)\n",
+				  sm->selectedMethod, name);
+		if (os_snprintf_error(buflen - len, ret))
+			return len;
+		len += ret;
+		if (sm->m && sm->m->get_status) {
+			len += sm->m->get_status(sm, sm->eap_method_priv,
+						 buf + len, buflen - len,
+						 verbose);
+	if (verbose) {
+				  "reqMethod=%d\n"
+				  "methodState=%s\n"
+				  "decision=%s\n"
+				  "ClientTimeout=%d\n",
+				  sm->reqMethod,
+				  eap_sm_method_state_txt(sm->methodState),
+				  eap_sm_decision_txt(sm->decision),
+				  sm->ClientTimeout);
+			return len;
+		len += ret;
+	return len;
+static void eap_sm_request(struct eap_sm *sm, enum wpa_ctrl_req_type field,
+			   const char *msg, size_t msglen)
+	struct eap_peer_config *config;
+	const char *txt = NULL;
+	char *tmp;
+	if (sm == NULL)
+		return;
+	config = eap_get_config(sm);
+		return;
+	switch (field) {
+	case WPA_CTRL_REQ_EAP_IDENTITY:
+		config->pending_req_identity++;
+		break;
+	case WPA_CTRL_REQ_EAP_PASSWORD:
+		config->pending_req_password++;
+		break;
+	case WPA_CTRL_REQ_EAP_NEW_PASSWORD:
+		config->pending_req_new_password++;
+		break;
+	case WPA_CTRL_REQ_EAP_PIN:
+		config->pending_req_pin++;
+		break;
+	case WPA_CTRL_REQ_EAP_OTP:
+		if (msg) {
+			tmp = os_malloc(msglen + 3);
+			if (tmp == NULL)
+				return;
+			tmp[0] = '[';
+			os_memcpy(tmp + 1, msg, msglen);
+			tmp[msglen + 1] = ']';
+			tmp[msglen + 2] = '\0';
+			txt = tmp;
+			os_free(config->pending_req_otp);
+			config->pending_req_otp = tmp;
+			config->pending_req_otp_len = msglen + 3;
+		} else {
+			if (config->pending_req_otp == NULL)
+				return;
+			txt = config->pending_req_otp;
+		break;
+	case WPA_CTRL_REQ_EAP_PASSPHRASE:
+		config->pending_req_passphrase++;
+		break;
+	case WPA_CTRL_REQ_SIM:
+		txt = msg;
+		break;
+	default:
+		return;
+	if (sm->eapol_cb->eap_param_needed)
+		sm->eapol_cb->eap_param_needed(sm->eapol_ctx, field, txt);
+#else /* CONFIG_CTRL_IFACE || !CONFIG_NO_STDOUT_DEBUG */
+#define eap_sm_request(sm, type, msg, msglen) do { } while (0)
+const char * eap_sm_get_method_name(struct eap_sm *sm)
+		return "UNKNOWN";
+	return sm->m->name;
+ * eap_sm_request_identity - Request identity from user (ctrl_iface)
+ * EAP methods can call this function to request identity information for the
+ * current network. This is normally called when the identity is not included
+ * in the network configuration. The request will be sent to monitor programs
+ * through the control interface.
+void eap_sm_request_identity(struct eap_sm *sm)
+	eap_sm_request(sm, WPA_CTRL_REQ_EAP_IDENTITY, NULL, 0);
+ * eap_sm_request_password - Request password from user (ctrl_iface)
+ * EAP methods can call this function to request password information for the
+ * current network. This is normally called when the password is not included
+void eap_sm_request_password(struct eap_sm *sm)
+	eap_sm_request(sm, WPA_CTRL_REQ_EAP_PASSWORD, NULL, 0);
+ * eap_sm_request_new_password - Request new password from user (ctrl_iface)
+ * EAP methods can call this function to request new password information for
+ * the current network. This is normally called when the EAP method indicates
+ * that the current password has expired and password change is required. The
+ * request will be sent to monitor programs through the control interface.
+void eap_sm_request_new_password(struct eap_sm *sm)
+	eap_sm_request(sm, WPA_CTRL_REQ_EAP_NEW_PASSWORD, NULL, 0);
+ * eap_sm_request_pin - Request SIM or smart card PIN from user (ctrl_iface)
+ * EAP methods can call this function to request SIM or smart card PIN
+ * information for the current network. This is normally called when the PIN is
+ * not included in the network configuration. The request will be sent to
+ * monitor programs through the control interface.
+void eap_sm_request_pin(struct eap_sm *sm)
+	eap_sm_request(sm, WPA_CTRL_REQ_EAP_PIN, NULL, 0);
+ * eap_sm_request_otp - Request one time password from user (ctrl_iface)
+ * @msg: Message to be displayed to the user when asking for OTP
+ * @msg_len: Length of the user displayable message
+ * EAP methods can call this function to request open time password (OTP) for
+ * the current network. The request will be sent to monitor programs through
+ * the control interface.
+void eap_sm_request_otp(struct eap_sm *sm, const char *msg, size_t msg_len)
+	eap_sm_request(sm, WPA_CTRL_REQ_EAP_OTP, msg, msg_len);
+ * eap_sm_request_passphrase - Request passphrase from user (ctrl_iface)
+ * EAP methods can call this function to request passphrase for a private key
+ * for the current network. This is normally called when the passphrase is not
+ * included in the network configuration. The request will be sent to monitor
+ * programs through the control interface.
+void eap_sm_request_passphrase(struct eap_sm *sm)
+	eap_sm_request(sm, WPA_CTRL_REQ_EAP_PASSPHRASE, NULL, 0);
+ * eap_sm_request_sim - Request external SIM processing
+ * @req: EAP method specific request
+void eap_sm_request_sim(struct eap_sm *sm, const char *req)
+	eap_sm_request(sm, WPA_CTRL_REQ_SIM, req, os_strlen(req));
+ * eap_sm_notify_ctrl_attached - Notification of attached monitor
+ * Notify EAP state machines that a monitor was attached to the control
+ * interface to trigger re-sending of pending requests for user input.
+void eap_sm_notify_ctrl_attached(struct eap_sm *sm)
+		return;
+	/* Re-send any pending requests for user data since a new control
+	 * interface was added. This handles cases where the EAP authentication
+	 * starts immediately after system startup when the user interface is
+	 * not yet running. */
+	if (config->pending_req_identity)
+	if (config->pending_req_password)
+		eap_sm_request_password(sm);
+	if (config->pending_req_new_password)
+		eap_sm_request_new_password(sm);
+	if (config->pending_req_otp)
+		eap_sm_request_otp(sm, NULL, 0);
+	if (config->pending_req_pin)
+	if (config->pending_req_passphrase)
+		eap_sm_request_passphrase(sm);
+static int eap_allowed_phase2_type(int vendor, int type)
+	if (vendor != EAP_VENDOR_IETF)
+		return 0;
+	return type != EAP_TYPE_PEAP && type != EAP_TYPE_TTLS &&
+		type != EAP_TYPE_FAST;
+ * eap_get_phase2_type - Get EAP type for the given EAP phase 2 method name
+ * @name: EAP method name, e.g., MD5
+ * @vendor: Buffer for returning EAP Vendor-Id
+ * Returns: EAP method type or %EAP_TYPE_NONE if not found
+ * This function maps EAP type names into EAP type numbers that are allowed for
+ * Phase 2, i.e., for tunneled authentication. Phase 2 is used, e.g., with
+ * EAP-PEAP, EAP-TTLS, and EAP-FAST.
+u32 eap_get_phase2_type(const char *name, int *vendor)
+	int v;
+	u32 type = eap_peer_get_type(name, &v);
+	if (eap_allowed_phase2_type(v, type)) {
+		*vendor = v;
+		return type;
+	*vendor = EAP_VENDOR_IETF;
+	return EAP_TYPE_NONE;
+ * eap_get_phase2_types - Get list of allowed EAP phase 2 types
+ * @config: Pointer to a network configuration
+ * @count: Pointer to a variable to be filled with number of returned EAP types
+ * Returns: Pointer to allocated type list or %NULL on failure
+ * This function generates an array of allowed EAP phase 2 (tunneled) types for
+ * the given network configuration.
+struct eap_method_type * eap_get_phase2_types(struct eap_peer_config *config,
+					      size_t *count)
+	struct eap_method_type *buf;
+	u32 method;
+	int vendor;
+	size_t mcount;
+	methods = eap_peer_get_methods(&mcount);
+		return NULL;
+	*count = 0;
+	buf = os_malloc(mcount * sizeof(struct eap_method_type));
+	if (buf == NULL)
+		return NULL;
+		vendor = m->vendor;
+		method = m->method;
+		if (eap_allowed_phase2_type(vendor, method)) {
+			if (vendor == EAP_VENDOR_IETF &&
+			    method == EAP_TYPE_TLS && config &&
+			    config->private_key2 == NULL)
+				continue;
+			buf[*count].vendor = vendor;
+			buf[*count].method = method;
+			(*count)++;
+	return buf;
+ * eap_set_fast_reauth - Update fast_reauth setting
+ * @enabled: 1 = Fast reauthentication is enabled, 0 = Disabled
+void eap_set_fast_reauth(struct eap_sm *sm, int enabled)
+	sm->fast_reauth = enabled;
+ * eap_set_workaround - Update EAP workarounds setting
+ * @workaround: 1 = Enable EAP workarounds, 0 = Disable EAP workarounds
+void eap_set_workaround(struct eap_sm *sm, unsigned int workaround)
+	sm->workaround = workaround;
+ * eap_get_config - Get current network configuration
+ * Returns: Pointer to the current network configuration or %NULL if not found
+ * EAP peer methods should avoid using this function if they can use other
+ * access functions, like eap_get_config_identity() and
+ * eap_get_config_password(), that do not require direct access to
+ * struct eap_peer_config.
+struct eap_peer_config * eap_get_config(struct eap_sm *sm)
+	return sm->eapol_cb->get_config(sm->eapol_ctx);
+ * eap_get_config_identity - Get identity from the network configuration
+ * @len: Buffer for the length of the identity
+ * Returns: Pointer to the identity or %NULL if not found
+const u8 * eap_get_config_identity(struct eap_sm *sm, size_t *len)
+		return NULL;
+	*len = config->identity_len;
+	return config->identity;
+static int eap_get_ext_password(struct eap_sm *sm,
+				struct eap_peer_config *config)
+	char *name;
+	if (config->password == NULL)
+		return -1;
+	name = os_zalloc(config->password_len + 1);
+	if (name == NULL)
+		return -1;
+	os_memcpy(name, config->password, config->password_len);
+	sm->ext_pw_buf = ext_password_get(sm->ext_pw, name);
+	os_free(name);
+	return sm->ext_pw_buf == NULL ? -1 : 0;
+ * eap_get_config_password - Get password from the network configuration
+ * @len: Buffer for the length of the password
+ * Returns: Pointer to the password or %NULL if not found
+const u8 * eap_get_config_password(struct eap_sm *sm, size_t *len)
+		return NULL;
+	if (config->flags & EAP_CONFIG_FLAGS_EXT_PASSWORD) {
+		if (eap_get_ext_password(sm, config) < 0)
+			return NULL;
+		*len = wpabuf_len(sm->ext_pw_buf);
+		return wpabuf_head(sm->ext_pw_buf);
+	*len = config->password_len;
+	return config->password;
+ * eap_get_config_password2 - Get password from the network configuration
+ * @hash: Buffer for returning whether the password is stored as a
+ * NtPasswordHash instead of plaintext password; can be %NULL if this
+ * information is not needed
+const u8 * eap_get_config_password2(struct eap_sm *sm, size_t *len, int *hash)
+		return NULL;
+			return NULL;
+		if (hash)
+			*hash = 0;
+	if (hash)
+		*hash = !!(config->flags & EAP_CONFIG_FLAGS_PASSWORD_NTHASH);
+ * eap_get_config_new_password - Get new password from network configuration
+ * @len: Buffer for the length of the new password
+ * Returns: Pointer to the new password or %NULL if not found
+const u8 * eap_get_config_new_password(struct eap_sm *sm, size_t *len)
+		return NULL;
+	*len = config->new_password_len;
+	return config->new_password;
+ * eap_get_config_otp - Get one-time password from the network configuration
+ * @len: Buffer for the length of the one-time password
+ * Returns: Pointer to the one-time password or %NULL if not found
+const u8 * eap_get_config_otp(struct eap_sm *sm, size_t *len)
+		return NULL;
+	*len = config->otp_len;
+	return config->otp;
+ * eap_clear_config_otp - Clear used one-time password
+ * This function clears a used one-time password (OTP) from the current network
+ * configuration. This should be called when the OTP has been used and is not
+ * needed anymore.
+void eap_clear_config_otp(struct eap_sm *sm)
+		return;
+	os_memset(config->otp, 0, config->otp_len);
+	os_free(config->otp);
+	config->otp = NULL;
+	config->otp_len = 0;
+ * eap_get_config_phase1 - Get phase1 data from the network configuration
+ * Returns: Pointer to the phase1 data or %NULL if not found
+const char * eap_get_config_phase1(struct eap_sm *sm)
+		return NULL;
+	return config->phase1;
+ * eap_get_config_phase2 - Get phase2 data from the network configuration
+const char * eap_get_config_phase2(struct eap_sm *sm)
+		return NULL;
+	return config->phase2;
+int eap_get_config_fragment_size(struct eap_sm *sm)
+		return -1;
+	return config->fragment_size;
+ * eap_key_available - Get key availability (eapKeyAvailable variable)
+ * Returns: 1 if EAP keying material is available, 0 if not
+int eap_key_available(struct eap_sm *sm)
+	return sm ? sm->eapKeyAvailable : 0;
+ * eap_notify_success - Notify EAP state machine about external success trigger
+ * This function is called when external event, e.g., successful completion of
+ * WPA-PSK key handshake, is indicating that EAP state machine should move to
+ * success state. This is mainly used with security modes that do not use EAP
+ * state machine (e.g., WPA-PSK).
+void eap_notify_success(struct eap_sm *sm)
+	if (sm) {
+		sm->decision = DECISION_COND_SUCC;
+		sm->EAP_state = EAP_SUCCESS;
+ * eap_notify_lower_layer_success - Notification of lower layer success
+ * Notify EAP state machines that a lower layer has detected a successful
+ * authentication. This is used to recover from dropped EAP-Success messages.
+void eap_notify_lower_layer_success(struct eap_sm *sm)
+	if (sm == NULL)
+		return;
+	if (eapol_get_bool(sm, EAPOL_eapSuccess) ||
+	    sm->decision == DECISION_FAIL ||
+	    (sm->methodState != METHOD_MAY_CONT &&
+	     sm->methodState != METHOD_DONE))
+		return;
+		"EAP authentication completed successfully (based on lower "
+		"layer success)");
+ * eap_get_eapSessionId - Get Session-Id from EAP state machine
+ * @len: Pointer to variable that will be set to number of bytes in the session
+ * Returns: Pointer to the EAP Session-Id or %NULL on failure
+ * Fetch EAP Session-Id from the EAP state machine. The Session-Id is available
+ * only after a successful authentication. EAP state machine continues to manage
+ * the Session-Id and the caller must not change or free the returned data.
+const u8 * eap_get_eapSessionId(struct eap_sm *sm, size_t *len)
+	if (sm == NULL || sm->eapSessionId == NULL) {
+		*len = 0;
+		return NULL;
+	*len = sm->eapSessionIdLen;
+	return sm->eapSessionId;
+ * eap_get_eapKeyData - Get master session key (MSK) from EAP state machine
+ * @sm: Pointer to EAP state machine allocated with eap_peer_sm_init()
+ * @len: Pointer to variable that will be set to number of bytes in the key
+ * Returns: Pointer to the EAP keying data or %NULL on failure
+ * Fetch EAP keying material (MSK, eapKeyData) from the EAP state machine. The
+ * key is available only after a successful authentication. EAP state machine
+ * continues to manage the key data and the caller must not change or free the
+ * returned data.
+const u8 * eap_get_eapKeyData(struct eap_sm *sm, size_t *len)
+	if (sm == NULL || sm->eapKeyData == NULL) {
+		*len = 0;
+		return NULL;
+	*len = sm->eapKeyDataLen;
+	return sm->eapKeyData;
+ * eap_get_eapKeyData - Get EAP response data
+ * Returns: Pointer to the EAP response (eapRespData) or %NULL on failure
+ * Fetch EAP response (eapRespData) from the EAP state machine. This data is
+ * available when EAP state machine has processed an incoming EAP request. The
+ * EAP state machine does not maintain a reference to the response after this
+ * function is called and the caller is responsible for freeing the data.
+struct wpabuf * eap_get_eapRespData(struct eap_sm *sm)
+	if (sm == NULL || sm->eapRespData == NULL)
+		return NULL;
+	resp = sm->eapRespData;
+	return resp;
+ * eap_sm_register_scard_ctx - Notification of smart card context
+ * @ctx: Context data for smart card operations
+ * Notify EAP state machines of context data for smart card operations. This
+ * context data will be used as a parameter for scard_*() functions.
+void eap_register_scard_ctx(struct eap_sm *sm, void *ctx)
+	if (sm)
+		sm->scard_ctx = ctx;
+ * eap_set_config_blob - Set or add a named configuration blob
+ * @blob: New value for the blob
+ * Adds a new configuration blob or replaces the current value of an existing
+ * blob.
+void eap_set_config_blob(struct eap_sm *sm, struct wpa_config_blob *blob)
+#ifndef CONFIG_NO_CONFIG_BLOBS
+	sm->eapol_cb->set_config_blob(sm->eapol_ctx, blob);
+#endif /* CONFIG_NO_CONFIG_BLOBS */
+ * eap_get_config_blob - Get a named configuration blob
+ * @name: Name of the blob
+ * Returns: Pointer to blob data or %NULL if not found
+const struct wpa_config_blob * eap_get_config_blob(struct eap_sm *sm,
+						   const char *name)
+	return sm->eapol_cb->get_config_blob(sm->eapol_ctx, name);
+#else /* CONFIG_NO_CONFIG_BLOBS */
+	return NULL;
+ * eap_set_force_disabled - Set force_disabled flag
+ * @disabled: 1 = EAP disabled, 0 = EAP enabled
+ * This function is used to force EAP state machine to be disabled when it is
+ * not in use (e.g., with WPA-PSK or plaintext connections).
+void eap_set_force_disabled(struct eap_sm *sm, int disabled)
+	sm->force_disabled = disabled;
+ * eap_set_external_sim - Set external_sim flag
+ * @external_sim: Whether external SIM/USIM processing is used
+void eap_set_external_sim(struct eap_sm *sm, int external_sim)
+	sm->external_sim = external_sim;
+ * eap_notify_pending - Notify that EAP method is ready to re-process a request
+ * An EAP method can perform a pending operation (e.g., to get a response from
+ * an external process). Once the response is available, this function can be
+ * used to request EAPOL state machine to retry delivering the previously
+ * received (and still unanswered) EAP request to EAP state machine.
+void eap_notify_pending(struct eap_sm *sm)
+	sm->eapol_cb->notify_pending(sm->eapol_ctx);
+ * eap_invalidate_cached_session - Mark cached session data invalid
+void eap_invalidate_cached_session(struct eap_sm *sm)
+	if (sm)
+		eap_deinit_prev_method(sm, "invalidate");
+int eap_is_wps_pbc_enrollee(struct eap_peer_config *conf)
+	if (conf->identity_len != WSC_ID_ENROLLEE_LEN ||
+	    os_memcmp(conf->identity, WSC_ID_ENROLLEE, WSC_ID_ENROLLEE_LEN))
+		return 0; /* Not a WPS Enrollee */
+	if (conf->phase1 == NULL || os_strstr(conf->phase1, "pbc=1") == NULL)
+		return 0; /* Not using PBC */
+	return 1;
+int eap_is_wps_pin_enrollee(struct eap_peer_config *conf)
+	if (conf->phase1 == NULL || os_strstr(conf->phase1, "pin=") == NULL)
+		return 0; /* Not using PIN */
+	return 1;
+void eap_sm_set_ext_pw_ctx(struct eap_sm *sm, struct ext_password_data *ext)
+	ext_password_free(sm->ext_pw_buf);
+	sm->ext_pw_buf = NULL;
+	sm->ext_pw = ext;
+ * eap_set_anon_id - Set or add anonymous identity
+ * @id: Anonymous identity (e.g., EAP-SIM pseudonym) or %NULL to clear
+ * @len: Length of anonymous identity in octets
+void eap_set_anon_id(struct eap_sm *sm, const u8 *id, size_t len)
+	if (sm->eapol_cb->set_anon_id)
+		sm->eapol_cb->set_anon_id(sm->eapol_ctx, id, len);
+int eap_peer_was_failure_expected(struct eap_sm *sm)
+	return sm->expected_failure;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap.h b/freebsd/contrib/wpa/src/eap_peer/eap.h
new file mode 100644
index 00000000000..1a645af8b20
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap.h
@@ -0,0 +1,354 @@
+ * EAP peer state machine functions (RFC 4137)
+ * Copyright (c) 2004-2012, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef EAP_H
+#define EAP_H
+#include "common/defs.h"
+#include "eap_common/eap_defs.h"
+#include "eap_peer/eap_methods.h"
+struct eap_sm;
+struct wpa_config_blob;
+struct wpabuf;
+struct eap_method_type {
+	int vendor;
+	u32 method;
+#ifdef IEEE8021X_EAPOL
+ * enum eapol_bool_var - EAPOL boolean state variables for EAP state machine
+ * These variables are used in the interface between EAP peer state machine and
+ * lower layer. These are defined in RFC 4137, Sect. 4.1. Lower layer code is
+ * expected to maintain these variables and register a callback functions for
+ * EAP state machine to get and set the variables.
+enum eapol_bool_var {
+	 * EAPOL_eapSuccess - EAP SUCCESS state reached
+	 * EAP state machine reads and writes this value.
+	EAPOL_eapSuccess,
+	 * EAPOL_eapRestart - Lower layer request to restart authentication
+	 * Set to TRUE in lower layer, FALSE in EAP state machine.
+	EAPOL_eapRestart,
+	 * EAPOL_eapFail - EAP FAILURE state reached
+	 * EAP state machine writes this value.
+	EAPOL_eapFail,
+	 * EAPOL_eapResp - Response to send
+	 * Set to TRUE in EAP state machine, FALSE in lower layer.
+	EAPOL_eapResp,
+	 * EAPOL_eapNoResp - Request has been process; no response to send
+	EAPOL_eapNoResp,
+	 * EAPOL_eapReq - EAP request available from lower layer
+	EAPOL_eapReq,
+	 * EAPOL_portEnabled - Lower layer is ready for communication
+	 * EAP state machines reads this value.
+	EAPOL_portEnabled,
+	 * EAPOL_altAccept - Alternate indication of success (RFC3748)
+	EAPOL_altAccept,
+	 * EAPOL_altReject - Alternate indication of failure (RFC3748)
+	EAPOL_altReject,
+	 * EAPOL_eapTriggerStart - EAP-based trigger to send EAPOL-Start
+	EAPOL_eapTriggerStart
+ * enum eapol_int_var - EAPOL integer state variables for EAP state machine
+enum eapol_int_var {
+	 * EAPOL_idleWhile - Outside time for EAP peer timeout
+	 * This integer variable is used to provide an outside timer that the
+	 * external (to EAP state machine) code must decrement by one every
+	 * second until the value reaches zero. This is used in the same way as
+	 * EAPOL state machine timers. EAP state machine reads and writes this
+	 * value.
+	EAPOL_idleWhile
+ * struct eapol_callbacks - Callback functions from EAP to lower layer
+ * This structure defines the callback functions that EAP state machine
+ * requires from the lower layer (usually EAPOL state machine) for updating
+ * state variables and requesting information. eapol_ctx from
+ * eap_peer_sm_init() call will be used as the ctx parameter for these
+ * callback functions.
+struct eapol_callbacks {
+	 * get_config - Get pointer to the current network configuration
+	 * @ctx: eapol_ctx from eap_peer_sm_init() call
+	struct eap_peer_config * (*get_config)(void *ctx);
+	 * get_bool - Get a boolean EAPOL state variable
+	 * @variable: EAPOL boolean variable to get
+	 * Returns: Value of the EAPOL variable
+	Boolean (*get_bool)(void *ctx, enum eapol_bool_var variable);
+	 * set_bool - Set a boolean EAPOL state variable
+	 * @variable: EAPOL boolean variable to set
+	 * @value: Value for the EAPOL variable
+	void (*set_bool)(void *ctx, enum eapol_bool_var variable,
+			 Boolean value);
+	 * get_int - Get an integer EAPOL state variable
+	 * @variable: EAPOL integer variable to get
+	unsigned int (*get_int)(void *ctx, enum eapol_int_var variable);
+	 * set_int - Set an integer EAPOL state variable
+	 * @variable: EAPOL integer variable to set
+	void (*set_int)(void *ctx, enum eapol_int_var variable,
+			unsigned int value);
+	 * get_eapReqData - Get EAP-Request data
+	 * @len: Pointer to variable that will be set to eapReqDataLen
+	 * Returns: Reference to eapReqData (EAP state machine will not free
+	 * this) or %NULL if eapReqData not available.
+	struct wpabuf * (*get_eapReqData)(void *ctx);
+	 * set_config_blob - Set named configuration blob
+	 * existing blob.
+	void (*set_config_blob)(void *ctx, struct wpa_config_blob *blob);
+	 * get_config_blob - Get a named configuration blob
+	const struct wpa_config_blob * (*get_config_blob)(void *ctx,
+							  const char *name);
+	 * notify_pending - Notify that a pending request can be retried
+	 * response from an external process). Once the response is available,
+	 * this callback function can be used to request EAPOL state machine to
+	 * retry delivering the previously received (and still unanswered) EAP
+	 * request to EAP state machine.
+	void (*notify_pending)(void *ctx);
+	 * eap_param_needed - Notify that EAP parameter is needed
+	 * @field: Field indicator (e.g., WPA_CTRL_REQ_EAP_IDENTITY)
+	 * @txt: User readable text describing the required parameter
+	void (*eap_param_needed)(void *ctx, enum wpa_ctrl_req_type field,
+				 const char *txt);
+	 * notify_cert - Notification of a peer certificate
+	 * @depth: Depth in certificate chain (0 = server)
+	 * @subject: Subject of the peer certificate
+	 * @altsubject: Select fields from AltSubject of the peer certificate
+	 * @num_altsubject: Number of altsubject values
+	 * @cert_hash: SHA-256 hash of the certificate
+	 * @cert: Peer certificate
+	void (*notify_cert)(void *ctx, int depth, const char *subject,
+			    const char *altsubject[], int num_altsubject,
+			    const char *cert_hash, const struct wpabuf *cert);
+	 * notify_status - Notification of the current EAP state
+	 * @status: Step in the process of EAP authentication
+	 * @parameter: Step-specific parameter, e.g., EAP method name
+	void (*notify_status)(void *ctx, const char *status,
+			      const char *parameter);
+#ifdef CONFIG_EAP_PROXY
+	 * eap_proxy_cb - Callback signifying any updates from eap_proxy
+	void (*eap_proxy_cb)(void *ctx);
+#endif /* CONFIG_EAP_PROXY */
+	 * set_anon_id - Set or add anonymous identity
+	void (*set_anon_id)(void *ctx, const u8 *id, size_t len);
+ * struct eap_config - Configuration for EAP state machine
+struct eap_config {
+	 * opensc_engine_path - OpenSC engine for OpenSSL engine support
+	 * Usually, path to engine_opensc.so.
+	const char *opensc_engine_path;
+	 * pkcs11_engine_path - PKCS#11 engine for OpenSSL engine support
+	 * Usually, path to engine_pkcs11.so.
+	const char *pkcs11_engine_path;
+	 * pkcs11_module_path - OpenSC PKCS#11 module for OpenSSL engine
+	 * Usually, path to opensc-pkcs11.so.
+	const char *pkcs11_module_path;
+	 * openssl_ciphers - OpenSSL cipher string
+	 * This is an OpenSSL specific configuration option for configuring the
+	 * default ciphers. If not set, "DEFAULT:!EXP:!LOW" is used as the
+	 * default.
+	const char *openssl_ciphers;
+	 * wps - WPS context data
+	 * This is only used by EAP-WSC and can be left %NULL if not available.
+	struct wps_context *wps;
+	 * cert_in_cb - Include server certificates in callback
+	int cert_in_cb;
+				 void *msg_ctx, struct eap_config *conf);
+void eap_peer_sm_deinit(struct eap_sm *sm);
+int eap_peer_sm_step(struct eap_sm *sm);
+void eap_sm_abort(struct eap_sm *sm);
+		      int verbose);
+const char * eap_sm_get_method_name(struct eap_sm *sm);
+struct wpabuf * eap_sm_buildIdentity(struct eap_sm *sm, int id, int encrypted);
+void eap_sm_request_identity(struct eap_sm *sm);
+void eap_sm_request_password(struct eap_sm *sm);
+void eap_sm_request_new_password(struct eap_sm *sm);
+void eap_sm_request_pin(struct eap_sm *sm);
+void eap_sm_request_otp(struct eap_sm *sm, const char *msg, size_t msg_len);
+void eap_sm_request_passphrase(struct eap_sm *sm);
+void eap_sm_request_sim(struct eap_sm *sm, const char *req);
+void eap_sm_notify_ctrl_attached(struct eap_sm *sm);
+u32 eap_get_phase2_type(const char *name, int *vendor);
+					      size_t *count);
+void eap_set_fast_reauth(struct eap_sm *sm, int enabled);
+void eap_set_workaround(struct eap_sm *sm, unsigned int workaround);
+void eap_set_force_disabled(struct eap_sm *sm, int disabled);
+void eap_set_external_sim(struct eap_sm *sm, int external_sim);
+int eap_key_available(struct eap_sm *sm);
+void eap_notify_success(struct eap_sm *sm);
+void eap_notify_lower_layer_success(struct eap_sm *sm);
+const u8 * eap_get_eapSessionId(struct eap_sm *sm, size_t *len);
+const u8 * eap_get_eapKeyData(struct eap_sm *sm, size_t *len);
+struct wpabuf * eap_get_eapRespData(struct eap_sm *sm);
+void eap_register_scard_ctx(struct eap_sm *sm, void *ctx);
+void eap_invalidate_cached_session(struct eap_sm *sm);
+int eap_is_wps_pbc_enrollee(struct eap_peer_config *conf);
+int eap_is_wps_pin_enrollee(struct eap_peer_config *conf);
+struct ext_password_data;
+void eap_sm_set_ext_pw_ctx(struct eap_sm *sm, struct ext_password_data *ext);
+void eap_set_anon_id(struct eap_sm *sm, const u8 *id, size_t len);
+int eap_peer_was_failure_expected(struct eap_sm *sm);
+void eap_peer_erp_free_keys(struct eap_sm *sm);
+#endif /* IEEE8021X_EAPOL */
+#endif /* EAP_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_config.h b/freebsd/contrib/wpa/src/eap_peer/eap_config.h
index 00000000000..2b1a1d5e4b2
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_config.h
@@ -0,0 +1,774 @@
+ * EAP peer configuration data
+ * Copyright (c) 2003-2013, Jouni Malinen <j at w1.fi>
+#ifndef EAP_CONFIG_H
+#define EAP_CONFIG_H
+ * struct eap_peer_config - EAP peer configuration/credentials
+struct eap_peer_config {
+	 * identity - EAP Identity
+	 * This field is used to set the real user identity or NAI (for
+	 * EAP-PSK/PAX/SAKE/GPSK).
+	u8 *identity;
+	 * identity_len - EAP Identity length
+	 * anonymous_identity -  Anonymous EAP Identity
+	 * This field is used for unencrypted use with EAP types that support
+	 * different tunnelled identity, e.g., EAP-TTLS, in order to reveal the
+	 * real identity (identity field) only to the authentication server.
+	 * If not set, the identity field will be used for both unencrypted and
+	 * protected fields.
+	 * This field can also be used with EAP-SIM/AKA/AKA' to store the
+	 * pseudonym identity.
+	u8 *anonymous_identity;
+	 * anonymous_identity_len - Length of anonymous_identity
+	size_t anonymous_identity_len;
+	 * password - Password string for EAP
+	 * This field can include either the plaintext password (default
+	 * option) or a NtPasswordHash (16-byte MD4 hash of the unicode
+	 * presentation of the password) if flags field has
+	 * EAP_CONFIG_FLAGS_PASSWORD_NTHASH bit set to 1. NtPasswordHash can
+	 * only be used with authentication mechanism that use this hash as the
+	 * starting point for operation: MSCHAP and MSCHAPv2 (EAP-MSCHAPv2,
+	 * EAP-TTLS/MSCHAPv2, EAP-TTLS/MSCHAP, LEAP).
+	 * In addition, this field is used to configure a pre-shared key for
+	 * EAP-PSK/PAX/SAKE/GPSK. The length of the PSK must be 16 for EAP-PSK
+	 * and EAP-PAX and 32 for EAP-SAKE. EAP-GPSK can use a variable length
+	 * PSK.
+	u8 *password;
+	 * password_len - Length of password field
+	size_t password_len;
+	 * ca_cert - File path to CA certificate file (PEM/DER)
+	 * This file can have one or more trusted CA certificates. If ca_cert
+	 * and ca_path are not included, server certificate will not be
+	 * verified. This is insecure and a trusted CA certificate should
+	 * always be configured when using EAP-TLS/TTLS/PEAP. Full path to the
+	 * file should be used since working directory may change when
+	 * wpa_supplicant is run in the background.
+	 * Alternatively, a named configuration blob can be used by setting
+	 * this to blob://blob_name.
+	 * Alternatively, this can be used to only perform matching of the
+	 * server certificate (SHA-256 hash of the DER encoded X.509
+	 * certificate). In this case, the possible CA certificates in the
+	 * server certificate chain are ignored and only the server certificate
+	 * is verified. This is configured with the following format:
+	 * hash:://server/sha256/cert_hash_in_hex
+	 * For example: "hash://server/sha256/
+	 * 5a1bc1296205e6fdbe3979728efe3920798885c1c4590b5f90f43222d239ca6a"
+	 * On Windows, trusted CA certificates can be loaded from the system
+	 * certificate store by setting this to cert_store://name, e.g.,
+	 * ca_cert="cert_store://CA" or ca_cert="cert_store://ROOT".
+	 * Note that when running wpa_supplicant as an application, the user
+	 * certificate store (My user account) is used, whereas computer store
+	 * (Computer account) is used when running wpasvc as a service.
+	u8 *ca_cert;
+	 * ca_path - Directory path for CA certificate files (PEM)
+	 * This path may contain multiple CA certificates in OpenSSL format.
+	 * Common use for this is to point to system trusted CA list which is
+	 * often installed into directory like /etc/ssl/certs. If configured,
+	 * these certificates are added to the list of trusted CAs. ca_cert
+	 * may also be included in that case, but it is not required.
+	u8 *ca_path;
+	 * client_cert - File path to client certificate file (PEM/DER)
+	 * This field is used with EAP method that use TLS authentication.
+	 * Usually, this is only configured for EAP-TLS, even though this could
+	 * in theory be used with EAP-TTLS and EAP-PEAP, too. Full path to the
+	u8 *client_cert;
+	 * private_key - File path to client private key file (PEM/DER/PFX)
+	 * When PKCS#12/PFX file (.p12/.pfx) is used, client_cert should be
+	 * commented out. Both the private key and certificate will be read
+	 * from the PKCS#12 file in this case. Full path to the file should be
+	 * used since working directory may change when wpa_supplicant is run
+	 * in the background.
+	 * Windows certificate store can be used by leaving client_cert out and
+	 * configuring private_key in one of the following formats:
+	 * cert://substring_to_match
+	 * hash://certificate_thumbprint_in_hex
+	 * For example: private_key="hash://63093aa9c47f56ae88334c7b65a4"
+	u8 *private_key;
+	 * private_key_passwd - Password for private key file
+	 * If left out, this will be asked through control interface.
+	char *private_key_passwd;
+	 * dh_file - File path to DH/DSA parameters file (in PEM format)
+	 * This is an optional configuration file for setting parameters for an
+	 * ephemeral DH key exchange. In most cases, the default RSA
+	 * authentication does not use this configuration. However, it is
+	 * possible setup RSA to use ephemeral DH key exchange. In addition,
+	 * ciphers with DSA keys always use ephemeral DH keys. This can be used
+	 * to achieve forward secrecy. If the file is in DSA parameters format,
+	 * it will be automatically converted into DH params. Full path to the
+	u8 *dh_file;
+	 * subject_match - Constraint for server certificate subject
+	 * This substring is matched against the subject of the authentication
+	 * server certificate. If this string is set, the server sertificate is
+	 * only accepted if it contains this string in the subject. The subject
+	 * string is in following format:
+	 * /C=US/ST=CA/L=San Francisco/CN=Test AS/emailAddress=as at n.example.com
+	 * Note: Since this is a substring match, this cannot be used securily
+	 * to do a suffix match against a possible domain name in the CN entry.
+	 * For such a use case, domain_suffix_match should be used instead.
+	u8 *subject_match;
+	 * altsubject_match - Constraint for server certificate alt. subject
+	 * Semicolon separated string of entries to be matched against the
+	 * alternative subject name of the authentication server certificate.
+	 * If this string is set, the server sertificate is only accepted if it
+	 * contains one of the entries in an alternative subject name
+	 * extension.
+	 * altSubjectName string is in following format: TYPE:VALUE
+	 * Example: EMAIL:server at example.com
+	 * Example: DNS:server.example.com;DNS:server2.example.com
+	 * Following types are supported: EMAIL, DNS, URI
+	u8 *altsubject_match;
+	 * domain_suffix_match - Constraint for server domain name
+	 * If set, this FQDN is used as a suffix match requirement for the
+	 * server certificate in SubjectAltName dNSName element(s). If a
+	 * matching dNSName is found, this constraint is met. If no dNSName
+	 * values are present, this constraint is matched against SubjectName CN
+	 * using same suffix match comparison. Suffix match here means that the
+	 * host/domain name is compared one label at a time starting from the
+	 * top-level domain and all the labels in domain_suffix_match shall be
+	 * included in the certificate. The certificate may include additional
+	 * sub-level labels in addition to the required labels.
+	 * For example, domain_suffix_match=example.com would match
+	 * test.example.com but would not match test-example.com.
+	char *domain_suffix_match;
+	 * domain_match - Constraint for server domain name
+	 * If set, this FQDN is used as a full match requirement for the
+	 * using same full match comparison. This behavior is similar to
+	 * domain_suffix_match, but has the requirement of a full match, i.e.,
+	 * no subdomains or wildcard matches are allowed. Case-insensitive
+	 * comparison is used, so "Example.com" matches "example.com", but would
+	 * not match "test.Example.com".
+	char *domain_match;
+	 * ca_cert2 - File path to CA certificate file (PEM/DER) (Phase 2)
+	 * This file can have one or more trusted CA certificates. If ca_cert2
+	 * and ca_path2 are not included, server certificate will not be
+	 * always be configured. Full path to the file should be used since
+	 * working directory may change when wpa_supplicant is run in the
+	 * background.
+	 * This field is like ca_cert, but used for phase 2 (inside
+	 * EAP-TTLS/PEAP/FAST tunnel) authentication.
+	u8 *ca_cert2;
+	 * ca_path2 - Directory path for CA certificate files (PEM) (Phase 2)
+	 * This field is like ca_path, but used for phase 2 (inside
+	u8 *ca_path2;
+	 * client_cert2 - File path to client certificate file
+	 * This field is like client_cert, but used for phase 2 (inside
+	 * EAP-TTLS/PEAP/FAST tunnel) authentication. Full path to the
+	u8 *client_cert2;
+	 * private_key2 - File path to client private key file
+	 * This field is like private_key, but used for phase 2 (inside
+	u8 *private_key2;
+	 * private_key2_passwd -  Password for private key file
+	 * This field is like private_key_passwd, but used for phase 2 (inside
+	char *private_key2_passwd;
+	 * dh_file2 - File path to DH/DSA parameters file (in PEM format)
+	 * This field is like dh_file, but used for phase 2 (inside
+	u8 *dh_file2;
+	 * subject_match2 - Constraint for server certificate subject
+	 * This field is like subject_match, but used for phase 2 (inside
+	u8 *subject_match2;
+	 * altsubject_match2 - Constraint for server certificate alt. subject
+	 * This field is like altsubject_match, but used for phase 2 (inside
+	u8 *altsubject_match2;
+	 * domain_suffix_match2 - Constraint for server domain name
+	 * This field is like domain_suffix_match, but used for phase 2 (inside
+	char *domain_suffix_match2;
+	 * domain_match2 - Constraint for server domain name
+	 * This field is like domain_match, but used for phase 2 (inside
+	char *domain_match2;
+	 * eap_methods - Allowed EAP methods
+	 * (vendor=EAP_VENDOR_IETF,method=EAP_TYPE_NONE) terminated list of
+	 * allowed EAP methods or %NULL if all methods are accepted.
+	struct eap_method_type *eap_methods;
+	 * phase1 - Phase 1 (outer authentication) parameters
+	 * String with field-value pairs, e.g., "peapver=0" or
+	 * "peapver=1 peaplabel=1".
+	 * 'peapver' can be used to force which PEAP version (0 or 1) is used.
+	 * 'peaplabel=1' can be used to force new label, "client PEAP
+	 * encryption",	to be used during key derivation when PEAPv1 or newer.
+	 * Most existing PEAPv1 implementation seem to be using the old label,
+	 * "client EAP encryption", and wpa_supplicant is now using that as the
+	 * default value.
+	 * Some servers, e.g., Radiator, may require peaplabel=1 configuration
+	 * to interoperate with PEAPv1; see eap_testing.txt for more details.
+	 * 'peap_outer_success=0' can be used to terminate PEAP authentication
+	 * on tunneled EAP-Success. This is required with some RADIUS servers
+	 * that implement draft-josefsson-pppext-eap-tls-eap-05.txt (e.g.,
+	 * Lucent NavisRadius v4.4.0 with PEAP in "IETF Draft 5" mode).
+	 * include_tls_length=1 can be used to force wpa_supplicant to include
+	 * TLS Message Length field in all TLS messages even if they are not
+	 * fragmented.
+	 * sim_min_num_chal=3 can be used to configure EAP-SIM to require three
+	 * challenges (by default, it accepts 2 or 3).
+	 * result_ind=1 can be used to enable EAP-SIM and EAP-AKA to use
+	 * protected result indication.
+	 * fast_provisioning option can be used to enable in-line provisioning
+	 * of EAP-FAST credentials (PAC):
+	 * 0 = disabled,
+	 * 1 = allow unauthenticated provisioning,
+	 * 2 = allow authenticated provisioning,
+	 * 3 = allow both unauthenticated and authenticated provisioning
+	 * fast_max_pac_list_len=num option can be used to set the maximum
+	 * number of PAC entries to store in a PAC list (default: 10).
+	 * fast_pac_format=binary option can be used to select binary format
+	 * for storing PAC entries in order to save some space (the default
+	 * text format uses about 2.5 times the size of minimal binary format).
+	 * crypto_binding option can be used to control PEAPv0 cryptobinding
+	 * behavior:
+	 * 0 = do not use cryptobinding (default)
+	 * 1 = use cryptobinding if server supports it
+	 * 2 = require cryptobinding
+	 * EAP-WSC (WPS) uses following options: pin=Device_Password and
+	 * uuid=Device_UUID
+	 * For wired IEEE 802.1X authentication, "allow_canned_success=1" can be
+	 * used to configure a mode that allows EAP-Success (and EAP-Failure)
+	 * without going through authentication step. Some switches use such
+	 * sequence when forcing the port to be authorized/unauthorized or as a
+	 * fallback option if the authentication server is unreachable. By
+	 * default, wpa_supplicant discards such frames to protect against
+	 * potential attacks by rogue devices, but this option can be used to
+	 * disable that protection for cases where the server/authenticator does
+	 * not need to be authenticated.
+	char *phase1;
+	 * phase2 - Phase2 (inner authentication with TLS tunnel) parameters
+	 * String with field-value pairs, e.g., "auth=MSCHAPV2" for EAP-PEAP or
+	 * "autheap=MSCHAPV2 autheap=MD5" for EAP-TTLS. "mschapv2_retry=0" can
+	 * be used to disable MSCHAPv2 password retry in authentication failure
+	 * cases.
+	char *phase2;
+	 * pcsc - Parameters for PC/SC smartcard interface for USIM and GSM SIM
+	 * This field is used to configure PC/SC smartcard interface.
+	 * Currently, the only configuration is whether this field is %NULL (do
+	 * not use PC/SC) or non-NULL (e.g., "") to enable PC/SC.
+	 * This field is used for EAP-SIM and EAP-AKA.
+	char *pcsc;
+	 * pin - PIN for USIM, GSM SIM, and smartcards
+	 * This field is used to configure PIN for SIM and smartcards for
+	 * EAP-SIM and EAP-AKA. In addition, this is used with EAP-TLS if a
+	 * smartcard is used for private key operations.
+	char *pin;
+	 * engine - Enable OpenSSL engine (e.g., for smartcard access)
+	 * This is used if private key operations for EAP-TLS are performed
+	 * using a smartcard.
+	int engine;
+	 * engine_id - Engine ID for OpenSSL engine
+	 * "opensc" to select OpenSC engine or "pkcs11" to select PKCS#11
+	 * engine.
+	char *engine_id;
+	 * engine2 - Enable OpenSSL engine (e.g., for smartcard) (Phase 2)
+	 * This field is like engine, but used for phase 2 (inside
+	int engine2;
+	 * pin2 - PIN for USIM, GSM SIM, and smartcards (Phase 2)
+	 * This field is like pin2, but used for phase 2 (inside
+	char *pin2;
+	 * engine2_id - Engine ID for OpenSSL engine (Phase 2)
+	 * engine.
+	 * This field is like engine_id, but used for phase 2 (inside
+	char *engine2_id;
+	 * key_id - Key ID for OpenSSL engine
+	char *key_id;
+	 * cert_id - Cert ID for OpenSSL engine
+	 * This is used if the certificate operations for EAP-TLS are performed
+	char *cert_id;
+	 * ca_cert_id - CA Cert ID for OpenSSL engine
+	 * This is used if the CA certificate for EAP-TLS is on a smartcard.
+	char *ca_cert_id;
+	 * key2_id - Key ID for OpenSSL engine (phase2)
+	char *key2_id;
+	 * cert2_id - Cert ID for OpenSSL engine (phase2)
+	char *cert2_id;
+	 * ca_cert2_id - CA Cert ID for OpenSSL engine (phase2)
+	char *ca_cert2_id;
+	 * otp - One-time-password
+	 * This field should not be set in configuration step. It is only used
+	 * internally when OTP is entered through the control interface.
+	u8 *otp;
+	 * otp_len - Length of the otp field
+	size_t otp_len;
+	 * pending_req_identity - Whether there is a pending identity request
+	 * internally when control interface is used to request needed
+	 * information.
+	int pending_req_identity;
+	 * pending_req_password - Whether there is a pending password request
+	 * information.
+	int pending_req_password;
+	 * pending_req_pin - Whether there is a pending PIN request
+	 * information.
+	int pending_req_pin;
+	 * pending_req_new_password - Pending password update request
+	 * information.
+	int pending_req_new_password;
+	 * pending_req_passphrase - Pending passphrase request
+	 * information.
+	int pending_req_passphrase;
+	 * pending_req_otp - Whether there is a pending OTP request
+	 * information.
+	char *pending_req_otp;
+	 * pending_req_otp_len - Length of the pending OTP request
+	size_t pending_req_otp_len;
+	 * pac_file - File path or blob name for the PAC entries (EAP-FAST)
+	 * wpa_supplicant will need to be able to create this file and write
+	 * updates to it when PAC is being provisioned or refreshed. Full path
+	 * to the file should be used since working directory may change when
+	char *pac_file;
+	 * mschapv2_retry - MSCHAPv2 retry in progress
+	 * This field is used internally by EAP-MSCHAPv2 and should not be set
+	 * as part of configuration.
+	int mschapv2_retry;
+	 * new_password - New password for password update
+	 * This field is used during MSCHAPv2 password update. This is normally
+	 * requested from the user through the control interface and not set
+	 * from configuration.
+	u8 *new_password;
+	 * new_password_len - Length of new_password field
+	size_t new_password_len;
+	 * fragment_size - Maximum EAP fragment size in bytes (default 1398)
+	 * This value limits the fragment size for EAP methods that support
+	 * fragmentation (e.g., EAP-TLS and EAP-PEAP). This value should be set
+	 * small enough to make the EAP messages fit in MTU of the network
+	 * interface used for EAPOL. The default value is suitable for most
+	 * cases.
+	int fragment_size;
+#define EAP_CONFIG_FLAGS_PASSWORD_NTHASH BIT(0)
+#define EAP_CONFIG_FLAGS_EXT_PASSWORD BIT(1)
+	 * flags - Network configuration flags (bitfield)
+	 * This variable is used for internal flags to describe further details
+	 * for the network parameters.
+	 * bit 0 = password is represented as a 16-byte NtPasswordHash value
+	 *         instead of plaintext password
+	 * bit 1 = password is stored in external storage; the value in the
+	 *         password field is the name of that external entry
+	u32 flags;
+	 * ocsp - Whether to use/require OCSP to check server certificate
+	 * 0 = do not use OCSP stapling (TLS certificate status extension)
+	 * 1 = try to use OCSP stapling, but not require response
+	 * 2 = require valid OCSP stapling response
+	int ocsp;
+	 * external_sim_resp - Response from external SIM processing
+	 * internally when control interface is used to request external
+	 * SIM/USIM processing.
+	char *external_sim_resp;
+	 * sim_num - User selected SIM identifier
+	 * This variable is used for identifying which SIM is used if the system
+	 * has more than one.
+	int sim_num;
+	 * ciphers for this connection. If not set, the default cipher suite
+	 * list is used.
+	char *openssl_ciphers;
+	 * erp - Whether EAP Re-authentication Protocol (ERP) is enabled
+	int erp;
+ * struct wpa_config_blob - Named configuration blob
+ * This data structure is used to provide storage for binary objects to store
+ * abstract information like certificates and private keys inlined with the
+ * configuration data.
+struct wpa_config_blob {
+	 * name - Blob name
+	char *name;
+	 * data - Pointer to binary data
+	u8 *data;
+	 * len - Length of binary data
+	size_t len;
+	 * next - Pointer to next blob in the configuration
+	struct wpa_config_blob *next;
+#endif /* EAP_CONFIG_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_gtc.c b/freebsd/contrib/wpa/src/eap_peer/eap_gtc.c
index 00000000000..2ffc142c1a2
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_gtc.c
@@ -0,0 +1,147 @@
+#include <machine/rtems-bsd-user-space.h>
+ * EAP peer method: EAP-GTC (RFC 3748)
+ * Copyright (c) 2004-2006, Jouni Malinen <j at w1.fi>
+#include "includes.h"
+#include "common.h"
+#include "eap_i.h"
+struct eap_gtc_data {
+	int prefix;
+static void * eap_gtc_init(struct eap_sm *sm)
+	struct eap_gtc_data *data;
+	data = os_zalloc(sizeof(*data));
+	if (data == NULL)
+		return NULL;
+	if (sm->m && sm->m->vendor == EAP_VENDOR_IETF &&
+	    sm->m->method == EAP_TYPE_FAST) {
+		wpa_printf(MSG_DEBUG, "EAP-GTC: EAP-FAST tunnel - use prefix "
+			   "with challenge/response");
+		data->prefix = 1;
+	return data;
+static void eap_gtc_deinit(struct eap_sm *sm, void *priv)
+	struct eap_gtc_data *data = priv;
+	os_free(data);
+static struct wpabuf * eap_gtc_process(struct eap_sm *sm, void *priv,
+				       struct eap_method_ret *ret,
+				       const struct wpabuf *reqData)
+	struct wpabuf *resp;
+	const u8 *pos, *password, *identity;
+	size_t password_len, identity_len, len, plen;
+	int otp;
+	u8 id;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_GTC, reqData, &len);
+	if (pos == NULL) {
+		ret->ignore = TRUE;
+		return NULL;
+	id = eap_get_id(reqData);
+	wpa_hexdump_ascii(MSG_MSGDUMP, "EAP-GTC: Request message", pos, len);
+	if (data->prefix &&
+	    (len < 10 || os_memcmp(pos, "CHALLENGE=", 10) != 0)) {
+		wpa_printf(MSG_DEBUG, "EAP-GTC: Challenge did not start with "
+			   "expected prefix");
+		/* Send an empty response in order to allow tunneled
+		 * acknowledgement of the failure. This will also cover the
+		 * error case which seems to use EAP-MSCHAPv2 like error
+		 * reporting with EAP-GTC inside EAP-FAST tunnel. */
+		resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_GTC,
+				     0, EAP_CODE_RESPONSE, id);
+		return resp;
+	password = eap_get_config_otp(sm, &password_len);
+	if (password)
+		otp = 1;
+	else {
+		password = eap_get_config_password(sm, &password_len);
+		otp = 0;
+	if (password == NULL) {
+		wpa_printf(MSG_INFO, "EAP-GTC: Password not configured");
+		eap_sm_request_otp(sm, (const char *) pos, len);
+		return NULL;
+	ret->ignore = FALSE;
+	ret->methodState = data->prefix ? METHOD_MAY_CONT : METHOD_DONE;
+	ret->decision = DECISION_COND_SUCC;
+	ret->allowNotifications = FALSE;
+	plen = password_len;
+	identity = eap_get_config_identity(sm, &identity_len);
+	if (identity == NULL)
+		return NULL;
+	if (data->prefix)
+		plen += 9 + identity_len + 1;
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_GTC, plen,
+			     EAP_CODE_RESPONSE, id);
+	if (resp == NULL)
+		return NULL;
+	if (data->prefix) {
+		wpabuf_put_data(resp, "RESPONSE=", 9);
+		wpabuf_put_data(resp, identity, identity_len);
+		wpabuf_put_u8(resp, '\0');
+	wpabuf_put_data(resp, password, password_len);
+	wpa_hexdump_ascii_key(MSG_MSGDUMP, "EAP-GTC: Response",
+			      wpabuf_head_u8(resp) + sizeof(struct eap_hdr) +
+			      1, plen);
+	if (otp) {
+		wpa_printf(MSG_DEBUG, "EAP-GTC: Forgetting used password");
+		eap_clear_config_otp(sm);
+	return resp;
+int eap_peer_gtc_register(void)
+	struct eap_method *eap;
+	int ret;
+	eap = eap_peer_method_alloc(EAP_PEER_METHOD_INTERFACE_VERSION,
+				    EAP_VENDOR_IETF, EAP_TYPE_GTC, "GTC");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_gtc_init;
+	eap->deinit = eap_gtc_deinit;
+	eap->process = eap_gtc_process;
+	ret = eap_peer_method_register(eap);
+	if (ret)
+		eap_peer_method_free(eap);
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_i.h b/freebsd/contrib/wpa/src/eap_peer/eap_i.h
index 00000000000..99b44dae4e3
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_i.h
@@ -0,0 +1,389 @@
+ * EAP peer state machines internal structures (RFC 4137)
+ * Copyright (c) 2004-2014, Jouni Malinen <j at w1.fi>
+#ifndef EAP_I_H
+#define EAP_I_H
+#include "wpabuf.h"
+#include "utils/list.h"
+#include "eap_peer/eap.h"
+#include "eap_common/eap_common.h"
+/* RFC 4137 - EAP Peer state machine */
+typedef enum {
+	DECISION_FAIL, DECISION_COND_SUCC, DECISION_UNCOND_SUCC
+} EapDecision;
+typedef enum {
+	METHOD_NONE, METHOD_INIT, METHOD_CONT, METHOD_MAY_CONT, METHOD_DONE
+} EapMethodState;
+ * struct eap_method_ret - EAP return values from struct eap_method::process()
+ * These structure contains OUT variables for the interface between peer state
+ * machine and methods (RFC 4137, Sect. 4.2). eapRespData will be returned as
+ * the return value of struct eap_method::process() so it is not included in
+ * this structure.
+struct eap_method_ret {
+	 * ignore - Whether method decided to drop the current packed (OUT)
+	Boolean ignore;
+	 * methodState - Method-specific state (IN/OUT)
+	EapMethodState methodState;
+	 * decision - Authentication decision (OUT)
+	EapDecision decision;
+	 * allowNotifications - Whether method allows notifications (OUT)
+	Boolean allowNotifications;
+ * struct eap_method - EAP method interface
+ * This structure defines the EAP method interface. Each method will need to
+ * register its own EAP type, EAP name, and set of function pointers for method
+ * specific operations. This interface is based on section 4.4 of RFC 4137.
+struct eap_method {
+	 * vendor - EAP Vendor-ID (EAP_VENDOR_*) (0 = IETF)
+	int vendor;
+	 * method - EAP type number (EAP_TYPE_*)
+	EapType method;
+	 * name - Name of the method (e.g., "TLS")
+	const char *name;
+	 * init - Initialize an EAP method
+	 * Returns: Pointer to allocated private data, or %NULL on failure
+	 * This function is used to initialize the EAP method explicitly
+	 * instead of using METHOD_INIT state as specific in RFC 4137. The
+	 * method is expected to initialize it method-specific state and return
+	 * a pointer that will be used as the priv argument to other calls.
+	void * (*init)(struct eap_sm *sm);
+	 * deinit - Deinitialize an EAP method
+	 * @priv: Pointer to private EAP method data from eap_method::init()
+	 * Deinitialize the EAP method and free any allocated private data.
+	void (*deinit)(struct eap_sm *sm, void *priv);
+	 * process - Process an EAP request
+	 * @ret: Return values from EAP request validation and processing
+	 * @reqData: EAP request to be processed (eapReqData)
+	 * Returns: Pointer to allocated EAP response packet (eapRespData)
+	 * This function is a combination of m.check(), m.process(), and
+	 * m.buildResp() procedures defined in section 4.4 of RFC 4137 In other
+	 * words, this function validates the incoming request, processes it,
+	 * and build a response packet. m.check() and m.process() return values
+	 * are returned through struct eap_method_ret *ret variable. Caller is
+	 * responsible for freeing the returned EAP response packet.
+	struct wpabuf * (*process)(struct eap_sm *sm, void *priv,
+				   const struct wpabuf *reqData);
+	 * isKeyAvailable - Find out whether EAP method has keying material
+	 * Returns: %TRUE if key material (eapKeyData) is available
+	Boolean (*isKeyAvailable)(struct eap_sm *sm, void *priv);
+	 * getKey - Get EAP method specific keying material (eapKeyData)
+	 * @len: Pointer to variable to store key length (eapKeyDataLen)
+	 * Returns: Keying material (eapKeyData) or %NULL if not available
+	 * This function can be used to get the keying material from the EAP
+	 * method. The key may already be stored in the method-specific private
+	 * data or this function may derive the key.
+	u8 * (*getKey)(struct eap_sm *sm, void *priv, size_t *len);
+	 * get_status - Get EAP method status
+	 * Query EAP method for status information. This function fills in a
+	 * text area with current status information from the EAP method. If
+	 * truncated to fit the buffer.
+	int (*get_status)(struct eap_sm *sm, void *priv, char *buf,
+			  size_t buflen, int verbose);
+	 * has_reauth_data - Whether method is ready for fast reauthentication
+	 * Returns: %TRUE or %FALSE based on whether fast reauthentication is
+	 * possible
+	 * This function is an optional handler that only EAP methods
+	 * supporting fast re-authentication need to implement.
+	Boolean (*has_reauth_data)(struct eap_sm *sm, void *priv);
+	 * deinit_for_reauth - Release data that is not needed for fast re-auth
+	 * supporting fast re-authentication need to implement. This is called
+	 * when authentication has been completed and EAP state machine is
+	 * requesting that enough state information is maintained for fast
+	 * re-authentication
+	void (*deinit_for_reauth)(struct eap_sm *sm, void *priv);
+	 * init_for_reauth - Prepare for start of fast re-authentication
+	 * when EAP authentication is started and EAP state machine is
+	 * requesting fast re-authentication to be used.
+	void * (*init_for_reauth)(struct eap_sm *sm, void *priv);
+	 * get_identity - Get method specific identity for re-authentication
+	 * @len: Length of the returned identity
+	 * Returns: Pointer to the method specific identity or %NULL if default
+	 * identity is to be used
+	 * that use method specific identity need to implement.
+	const u8 * (*get_identity)(struct eap_sm *sm, void *priv, size_t *len);
+	 * free - Free EAP method data
+	 * @method: Pointer to the method data registered with
+	 * eap_peer_method_register().
+	 * This function will be called when the EAP method is being
+	 * unregistered. If the EAP method allocated resources during
+	 * registration (e.g., allocated struct eap_method), they should be
+	 * freed in this function. No other method functions will be called
+	 * after this call. If this function is not defined (i.e., function
+	 * pointer is %NULL), a default handler is used to release the method
+	 * data with free(method). This is suitable for most cases.
+	void (*free)(struct eap_method *method);
+#define EAP_PEER_METHOD_INTERFACE_VERSION 1
+	 * version - Version of the EAP peer method interface
+	 * The EAP peer method implementation should set this variable to
+	 * EAP_PEER_METHOD_INTERFACE_VERSION. This is used to verify that the
+	 * EAP method is using supported API version when using dynamically
+	 * loadable EAP methods.
+	int version;
+	 * next - Pointer to the next EAP method
+	 * This variable is used internally in the EAP method registration code
+	 * to create a linked list of registered EAP methods.
+	struct eap_method *next;
+#ifdef CONFIG_DYNAMIC_EAP_METHODS
+	 * dl_handle - Handle for the dynamic library
+	 * to store a handle for the dynamic library. If the method is linked
+	 * in statically, this is %NULL.
+	void *dl_handle;
+#endif /* CONFIG_DYNAMIC_EAP_METHODS */
+	 * get_emsk - Get EAP method specific keying extended material (EMSK)
+	 * @len: Pointer to a variable to store EMSK length
+	 * Returns: EMSK or %NULL if not available
+	 * This function can be used to get the extended keying material from
+	 * the EAP method. The key may already be stored in the method-specific
+	 * private data or this function may derive the key.
+	u8 * (*get_emsk)(struct eap_sm *sm, void *priv, size_t *len);
+	 * getSessionId - Get EAP method specific Session-Id
+	 * @len: Pointer to a variable to store Session-Id length
+	 * Returns: Session-Id or %NULL if not available
+	 * This function can be used to get the Session-Id from the EAP method.
+	 * The Session-Id may already be stored in the method-specific private
+	 * data or this function may derive the Session-Id.
+	u8 * (*getSessionId)(struct eap_sm *sm, void *priv, size_t *len);
+struct eap_erp_key {
+	struct dl_list list;
+	size_t rRK_len;
+	size_t rIK_len;
+	u8 rRK[ERP_MAX_KEY_LEN];
+	u8 rIK[ERP_MAX_KEY_LEN];
+	u32 next_seq;
+	char keyname_nai[];
+ * struct eap_sm - EAP state machine data
+struct eap_sm {
+	enum {
+		EAP_INITIALIZE, EAP_DISABLED, EAP_IDLE, EAP_RECEIVED,
+		EAP_GET_METHOD, EAP_METHOD, EAP_SEND_RESPONSE, EAP_DISCARD,
+		EAP_IDENTITY, EAP_NOTIFICATION, EAP_RETRANSMIT, EAP_SUCCESS,
+		EAP_FAILURE
+	} EAP_state;
+	/* Long-term local variables */
+	EapType selectedMethod;
+	int lastId;
+	struct wpabuf *lastRespData;
+	/* Short-term local variables */
+	Boolean rxReq;
+	Boolean rxSuccess;
+	Boolean rxFailure;
+	int reqId;
+	EapType reqMethod;
+	int reqVendor;
+	u32 reqVendorMethod;
+	Boolean ignore;
+	/* Constants */
+	int ClientTimeout;
+	/* Miscellaneous variables */
+	Boolean allowNotifications; /* peer state machine <-> methods */
+	struct wpabuf *eapRespData; /* peer to lower layer */
+	Boolean eapKeyAvailable; /* peer to lower layer */
+	u8 *eapKeyData; /* peer to lower layer */
+	size_t eapKeyDataLen; /* peer to lower layer */
+	u8 *eapSessionId; /* peer to lower layer */
+	size_t eapSessionIdLen; /* peer to lower layer */
+	const struct eap_method *m; /* selected EAP method */
+	/* not defined in RFC 4137 */
+	Boolean changed;
+	void *eapol_ctx;
+	const struct eapol_callbacks *eapol_cb;
+	void *eap_method_priv;
+	int init_phase2;
+	int fast_reauth;
+	Boolean reauthInit; /* send EAP-Identity/Re-auth */
+	u32 erp_seq;
+	Boolean rxResp /* LEAP only */;
+	Boolean leap_done;
+	Boolean peap_done;
+	u8 req_sha1[20]; /* SHA1() of the current EAP packet */
+	u8 last_sha1[20]; /* SHA1() of the previously received EAP packet; used
+			   * in duplicate request detection. */
+	void *msg_ctx;
+	void *scard_ctx;
+	void *ssl_ctx;
+	void *ssl_ctx2;
+	unsigned int workaround;
+	/* Optional challenges generated in Phase 1 (EAP-FAST) */
+	u8 *peer_challenge, *auth_challenge;
+	int num_rounds;
+	int force_disabled;
+	int prev_failure;
+	struct eap_peer_config *last_config;
+	struct ext_password_data *ext_pw;
+	struct wpabuf *ext_pw_buf;
+	int external_sim;
+	unsigned int expected_failure:1;
+	struct dl_list erp_keys; /* struct eap_erp_key */
+const u8 * eap_get_config_identity(struct eap_sm *sm, size_t *len);
+const u8 * eap_get_config_password(struct eap_sm *sm, size_t *len);
+const u8 * eap_get_config_password2(struct eap_sm *sm, size_t *len, int *hash);
+const u8 * eap_get_config_new_password(struct eap_sm *sm, size_t *len);
+const u8 * eap_get_config_otp(struct eap_sm *sm, size_t *len);
+void eap_clear_config_otp(struct eap_sm *sm);
+const char * eap_get_config_phase1(struct eap_sm *sm);
+const char * eap_get_config_phase2(struct eap_sm *sm);
+int eap_get_config_fragment_size(struct eap_sm *sm);
+struct eap_peer_config * eap_get_config(struct eap_sm *sm);
+void eap_set_config_blob(struct eap_sm *sm, struct wpa_config_blob *blob);
+eap_get_config_blob(struct eap_sm *sm, const char *name);
+void eap_notify_pending(struct eap_sm *sm);
+int eap_allowed_method(struct eap_sm *sm, int vendor, u32 method);
+#endif /* EAP_I_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_leap.c b/freebsd/contrib/wpa/src/eap_peer/eap_leap.c
index 00000000000..e765af1491b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_leap.c
@@ -0,0 +1,415 @@
+ * EAP peer method: LEAP
+ * Copyright (c) 2004-2007, Jouni Malinen <j at w1.fi>
+#include "crypto/ms_funcs.h"
+#include "crypto/crypto.h"
+#include "crypto/random.h"
+#include "eap_i.h"
+#define LEAP_VERSION 1
+#define LEAP_CHALLENGE_LEN 8
+#define LEAP_RESPONSE_LEN 24
+#define LEAP_KEY_LEN 16
+struct eap_leap_data {
+	enum {
+		LEAP_WAIT_CHALLENGE,
+		LEAP_WAIT_SUCCESS,
+		LEAP_WAIT_RESPONSE,
+		LEAP_DONE
+	} state;
+	u8 peer_challenge[LEAP_CHALLENGE_LEN];
+	u8 peer_response[LEAP_RESPONSE_LEN];
+	u8 ap_challenge[LEAP_CHALLENGE_LEN];
+	u8 ap_response[LEAP_RESPONSE_LEN];
+static void * eap_leap_init(struct eap_sm *sm)
+	struct eap_leap_data *data;
+	if (data == NULL)
+		return NULL;
+	data->state = LEAP_WAIT_CHALLENGE;
+	sm->leap_done = FALSE;
+	return data;
+static void eap_leap_deinit(struct eap_sm *sm, void *priv)
+	os_free(priv);
+static struct wpabuf * eap_leap_process_request(struct eap_sm *sm, void *priv,
+	struct eap_leap_data *data = priv;
+	const u8 *pos, *challenge, *identity, *password;
+	u8 challenge_len, *rpos;
+	size_t identity_len, password_len, len;
+	int pwhash;
+	wpa_printf(MSG_DEBUG, "EAP-LEAP: Processing EAP-Request");
+	password = eap_get_config_password2(sm, &password_len, &pwhash);
+	if (identity == NULL || password == NULL)
+		return NULL;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_LEAP, reqData, &len);
+	if (pos == NULL || len < 3) {
+		wpa_printf(MSG_INFO, "EAP-LEAP: Invalid EAP-Request frame");
+		return NULL;
+	if (*pos != LEAP_VERSION) {
+		wpa_printf(MSG_WARNING, "EAP-LEAP: Unsupported LEAP version "
+			   "%d", *pos);
+		return NULL;
+	pos++;
+	pos++; /* skip unused byte */
+	challenge_len = *pos++;
+	if (challenge_len != LEAP_CHALLENGE_LEN || challenge_len > len - 3) {
+		wpa_printf(MSG_INFO, "EAP-LEAP: Invalid challenge "
+			   "(challenge_len=%d reqDataLen=%lu)",
+			   challenge_len, (unsigned long) wpabuf_len(reqData));
+		return NULL;
+	challenge = pos;
+	os_memcpy(data->peer_challenge, challenge, LEAP_CHALLENGE_LEN);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-LEAP: Challenge from AP",
+		    challenge, LEAP_CHALLENGE_LEN);
+	wpa_printf(MSG_DEBUG, "EAP-LEAP: Generating Challenge Response");
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_LEAP,
+			     3 + LEAP_RESPONSE_LEN + identity_len,
+			     EAP_CODE_RESPONSE, eap_get_id(reqData));
+	if (resp == NULL)
+		return NULL;
+	wpabuf_put_u8(resp, LEAP_VERSION);
+	wpabuf_put_u8(resp, 0); /* unused */
+	wpabuf_put_u8(resp, LEAP_RESPONSE_LEN);
+	rpos = wpabuf_put(resp, LEAP_RESPONSE_LEN);
+	if (pwhash)
+		challenge_response(challenge, password, rpos);
+	else
+		nt_challenge_response(challenge, password, password_len, rpos);
+	os_memcpy(data->peer_response, rpos, LEAP_RESPONSE_LEN);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-LEAP: Response",
+		    rpos, LEAP_RESPONSE_LEN);
+	data->state = LEAP_WAIT_SUCCESS;
+	return resp;
+static struct wpabuf * eap_leap_process_success(struct eap_sm *sm, void *priv,
+	u8 *pos;
+	const u8 *identity;
+	size_t identity_len;
+	wpa_printf(MSG_DEBUG, "EAP-LEAP: Processing EAP-Success");
+		return NULL;
+	if (data->state != LEAP_WAIT_SUCCESS) {
+		wpa_printf(MSG_INFO, "EAP-LEAP: EAP-Success received in "
+			   "unexpected state (%d) - ignored", data->state);
+		return NULL;
+			     3 + LEAP_CHALLENGE_LEN + identity_len,
+			     EAP_CODE_REQUEST, eap_get_id(reqData));
+	if (resp == NULL)
+		return NULL;
+	wpabuf_put_u8(resp, LEAP_CHALLENGE_LEN);
+	pos = wpabuf_put(resp, LEAP_CHALLENGE_LEN);
+	if (random_get_bytes(pos, LEAP_CHALLENGE_LEN)) {
+		wpa_printf(MSG_WARNING, "EAP-LEAP: Failed to read random data "
+			   "for challenge");
+		wpabuf_free(resp);
+		return NULL;
+	os_memcpy(data->ap_challenge, pos, LEAP_CHALLENGE_LEN);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-LEAP: Challenge to AP/AS", pos,
+		    LEAP_CHALLENGE_LEN);
+	data->state = LEAP_WAIT_RESPONSE;
+	return resp;
+static struct wpabuf * eap_leap_process_response(struct eap_sm *sm, void *priv,
+	const u8 *pos, *password;
+	u8 response_len, pw_hash[16], pw_hash_hash[16],
+		expected[LEAP_RESPONSE_LEN];
+	size_t password_len, len;
+	int pwhash;
+	wpa_printf(MSG_DEBUG, "EAP-LEAP: Processing EAP-Response");
+		return NULL;
+		wpa_printf(MSG_INFO, "EAP-LEAP: Invalid EAP-Response frame");
+		return NULL;
+			   "%d", *pos);
+		return NULL;
+	pos++;
+	response_len = *pos++;
+	if (response_len != LEAP_RESPONSE_LEN || response_len > len - 3) {
+		wpa_printf(MSG_INFO, "EAP-LEAP: Invalid response "
+			   "(response_len=%d reqDataLen=%lu)",
+			   response_len, (unsigned long) wpabuf_len(reqData));
+		return NULL;
+	wpa_hexdump(MSG_DEBUG, "EAP-LEAP: Response from AP",
+		    pos, LEAP_RESPONSE_LEN);
+	os_memcpy(data->ap_response, pos, LEAP_RESPONSE_LEN);
+	if (pwhash) {
+		if (hash_nt_password_hash(password, pw_hash_hash)) {
+			return NULL;
+	} else {
+		if (nt_password_hash(password, password_len, pw_hash) ||
+		    hash_nt_password_hash(pw_hash, pw_hash_hash)) {
+			return NULL;
+	challenge_response(data->ap_challenge, pw_hash_hash, expected);
+	ret->methodState = METHOD_DONE;
+	if (os_memcmp_const(pos, expected, LEAP_RESPONSE_LEN) != 0) {
+		wpa_printf(MSG_WARNING, "EAP-LEAP: AP sent an invalid "
+			   "response - authentication failed");
+		wpa_hexdump(MSG_DEBUG, "EAP-LEAP: Expected response from AP",
+			    expected, LEAP_RESPONSE_LEN);
+		ret->decision = DECISION_FAIL;
+		return NULL;
+	ret->decision = DECISION_UNCOND_SUCC;
+	/* LEAP is somewhat odd method since it sends EAP-Success in the middle
+	 * of the authentication. Use special variable to transit EAP state
+	 * machine to SUCCESS state. */
+	sm->leap_done = TRUE;
+	data->state = LEAP_DONE;
+	/* No more authentication messages expected; AP will send EAPOL-Key
+	 * frames if encryption is enabled. */
+	return NULL;
+static struct wpabuf * eap_leap_process(struct eap_sm *sm, void *priv,
+	const struct eap_hdr *eap;
+	const u8 *password;
+		wpa_printf(MSG_INFO, "EAP-LEAP: Password not configured");
+		eap_sm_request_password(sm);
+		return NULL;
+	 * LEAP needs to be able to handle EAP-Success frame which does not
+	 * include Type field. Consequently, eap_hdr_validate() cannot be used
+	 * here. This validation will be done separately for EAP-Request and
+	 * EAP-Response frames.
+	eap = wpabuf_head(reqData);
+	if (wpabuf_len(reqData) < sizeof(*eap) ||
+	    be_to_host16(eap->length) > wpabuf_len(reqData)) {
+		wpa_printf(MSG_INFO, "EAP-LEAP: Invalid frame");
+		return NULL;
+	ret->allowNotifications = TRUE;
+	ret->methodState = METHOD_MAY_CONT;
+	switch (eap->code) {
+	case EAP_CODE_REQUEST:
+		return eap_leap_process_request(sm, priv, ret, reqData);
+	case EAP_CODE_SUCCESS:
+		return eap_leap_process_success(sm, priv, ret, reqData);
+	case EAP_CODE_RESPONSE:
+		return eap_leap_process_response(sm, priv, ret, reqData);
+	default:
+		wpa_printf(MSG_INFO, "EAP-LEAP: Unexpected EAP code (%d) - "
+			   "ignored", eap->code);
+		return NULL;
+static Boolean eap_leap_isKeyAvailable(struct eap_sm *sm, void *priv)
+	return data->state == LEAP_DONE;
+static u8 * eap_leap_getKey(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key, pw_hash_hash[16], pw_hash[16];
+	const u8 *addr[5], *password;
+	size_t elen[5], password_len;
+	int pwhash;
+	if (data->state != LEAP_DONE)
+		return NULL;
+		return NULL;
+	key = os_malloc(LEAP_KEY_LEN);
+	if (key == NULL)
+		return NULL;
+	if (pwhash) {
+			os_free(key);
+			return NULL;
+	} else {
+			os_free(key);
+			return NULL;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-LEAP: pw_hash_hash",
+			pw_hash_hash, 16);
+	wpa_hexdump(MSG_DEBUG, "EAP-LEAP: peer_challenge",
+		    data->peer_challenge, LEAP_CHALLENGE_LEN);
+	wpa_hexdump(MSG_DEBUG, "EAP-LEAP: peer_response",
+		    data->peer_response, LEAP_RESPONSE_LEN);
+	wpa_hexdump(MSG_DEBUG, "EAP-LEAP: ap_challenge",
+		    data->ap_challenge, LEAP_CHALLENGE_LEN);
+	wpa_hexdump(MSG_DEBUG, "EAP-LEAP: ap_response",
+		    data->ap_response, LEAP_RESPONSE_LEN);
+	addr[0] = pw_hash_hash;
+	elen[0] = 16;
+	addr[1] = data->ap_challenge;
+	elen[1] = LEAP_CHALLENGE_LEN;
+	addr[2] = data->ap_response;
+	elen[2] = LEAP_RESPONSE_LEN;
+	addr[3] = data->peer_challenge;
+	elen[3] = LEAP_CHALLENGE_LEN;
+	addr[4] = data->peer_response;
+	elen[4] = LEAP_RESPONSE_LEN;
+	md5_vector(5, addr, elen, key);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-LEAP: master key", key, LEAP_KEY_LEN);
+	*len = LEAP_KEY_LEN;
+	os_memset(pw_hash, 0, sizeof(pw_hash));
+	os_memset(pw_hash_hash, 0, sizeof(pw_hash_hash));
+	return key;
+int eap_peer_leap_register(void)
+	int ret;
+				    EAP_VENDOR_IETF, EAP_TYPE_LEAP, "LEAP");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_leap_init;
+	eap->deinit = eap_leap_deinit;
+	eap->process = eap_leap_process;
+	eap->isKeyAvailable = eap_leap_isKeyAvailable;
+	eap->getKey = eap_leap_getKey;
+	if (ret)
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_md5.c b/freebsd/contrib/wpa/src/eap_peer/eap_md5.c
index 00000000000..145bfa8fb41
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_md5.c
@@ -0,0 +1,122 @@
+ * EAP peer method: EAP-MD5 (RFC 3748 and RFC 1994)
+#include "eap_i.h"
+#include "eap_common/chap.h"
+static void * eap_md5_init(struct eap_sm *sm)
+	/* No need for private data. However, must return non-NULL to indicate
+	 * success. */
+	return (void *) 1;
+static void eap_md5_deinit(struct eap_sm *sm, void *priv)
+static struct wpabuf * eap_md5_process(struct eap_sm *sm, void *priv,
+	const u8 *pos, *challenge, *password;
+	u8 *rpos, id;
+	size_t len, challenge_len, password_len;
+		wpa_printf(MSG_INFO, "EAP-MD5: Password not configured");
+		return NULL;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_MD5, reqData, &len);
+	if (pos == NULL || len == 0) {
+		wpa_printf(MSG_INFO, "EAP-MD5: Invalid frame (pos=%p len=%lu)",
+			   pos, (unsigned long) len);
+		return NULL;
+	 * CHAP Challenge:
+	 * Value-Size (1 octet) | Value(Challenge) | Name(optional)
+	if (challenge_len == 0 || challenge_len > len - 1) {
+		wpa_printf(MSG_INFO, "EAP-MD5: Invalid challenge "
+			   "(challenge_len=%lu len=%lu)",
+			   (unsigned long) challenge_len, (unsigned long) len);
+		return NULL;
+	challenge = pos;
+	wpa_hexdump(MSG_MSGDUMP, "EAP-MD5: Challenge",
+		    challenge, challenge_len);
+	wpa_printf(MSG_DEBUG, "EAP-MD5: Generating Challenge Response");
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_MD5, 1 + CHAP_MD5_LEN,
+	if (resp == NULL)
+		return NULL;
+	 * CHAP Response:
+	 * Value-Size (1 octet) | Value(Response) | Name(optional)
+	wpabuf_put_u8(resp, CHAP_MD5_LEN);
+	id = eap_get_id(resp);
+	rpos = wpabuf_put(resp, CHAP_MD5_LEN);
+	if (chap_md5(id, password, password_len, challenge, challenge_len,
+		     rpos)) {
+		wpa_printf(MSG_INFO, "EAP-MD5: CHAP MD5 operation failed");
+		return NULL;
+	wpa_hexdump(MSG_MSGDUMP, "EAP-MD5: Response", rpos, CHAP_MD5_LEN);
+	return resp;
+int eap_peer_md5_register(void)
+	int ret;
+				    EAP_VENDOR_IETF, EAP_TYPE_MD5, "MD5");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_md5_init;
+	eap->deinit = eap_md5_deinit;
+	eap->process = eap_md5_process;
+	if (ret)
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_methods.c b/freebsd/contrib/wpa/src/eap_peer/eap_methods.c
index 00000000000..7af5a535e9e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_methods.c
@@ -0,0 +1,371 @@
+ * EAP peer: Method registration
+#include <dlfcn.h>
+#include "eap_i.h"
+#include "eap_methods.h"
+static struct eap_method *eap_methods = NULL;
+ * eap_peer_get_eap_method - Get EAP method based on type number
+ * @vendor: EAP Vendor-Id (0 = IETF)
+ * @method: EAP type number
+ * Returns: Pointer to EAP method or %NULL if not found
+const struct eap_method * eap_peer_get_eap_method(int vendor, EapType method)
+	struct eap_method *m;
+	for (m = eap_methods; m; m = m->next) {
+		if (m->vendor == vendor && m->method == method)
+			return m;
+	return NULL;
+ * eap_peer_get_type - Get EAP type for the given EAP method name
+ * @name: EAP method name, e.g., TLS
+ * @vendor: Buffer for returning EAP Vendor-Id
+ * Returns: EAP method type or %EAP_TYPE_NONE if not found
+ * This function maps EAP type names into EAP type numbers based on the list of
+ * EAP methods included in the build.
+EapType eap_peer_get_type(const char *name, int *vendor)
+		if (os_strcmp(m->name, name) == 0) {
+			*vendor = m->vendor;
+			return m->method;
+	*vendor = EAP_VENDOR_IETF;
+	return EAP_TYPE_NONE;
+ * eap_get_name - Get EAP method name for the given EAP type
+ * @type: EAP method type
+ * Returns: EAP method name, e.g., TLS, or %NULL if not found
+ * This function maps EAP type numbers into EAP type names based on the list of
+const char * eap_get_name(int vendor, EapType type)
+	if (vendor == EAP_VENDOR_IETF && type == EAP_TYPE_EXPANDED)
+		return "expanded";
+		if (m->vendor == vendor && m->method == type)
+			return m->name;
+	return NULL;
+ * eap_get_names - Get space separated list of names for supported EAP methods
+ * @buf: Buffer for names
+ * @buflen: Buffer length
+ * Returns: Number of characters written into buf (not including nul
+ * termination)
+size_t eap_get_names(char *buf, size_t buflen)
+	char *pos, *end;
+	int ret;
+	if (buflen == 0)
+		return 0;
+	pos = buf;
+	end = pos + buflen;
+		ret = os_snprintf(pos, end - pos, "%s%s",
+				  m == eap_methods ? "" : " ", m->name);
+		if (os_snprintf_error(end - pos, ret))
+			break;
+		pos += ret;
+	buf[buflen - 1] = '\0';
+	return pos - buf;
+ * eap_get_names_as_string_array - Get supported EAP methods as string array
+ * @num: Buffer for returning the number of items in array, not including %NULL
+ * terminator. This parameter can be %NULL if the length is not needed.
+ * Returns: A %NULL-terminated array of strings, or %NULL on error.
+ * This function returns the list of names for all supported EAP methods as an
+ * array of strings. The caller must free the returned array items and the
+ * array.
+char ** eap_get_names_as_string_array(size_t *num)
+	size_t array_len = 0;
+	char **array;
+	int i = 0, j;
+		array_len++;
+	array = os_calloc(array_len + 1, sizeof(char *));
+	if (array == NULL)
+		return NULL;
+		array[i++] = os_strdup(m->name);
+		if (array[i - 1] == NULL) {
+			for (j = 0; j < i; j++)
+				os_free(array[j]);
+			os_free(array);
+			return NULL;
+	array[i] = NULL;
+	if (num)
+		*num = array_len;
+	return array;
+ * eap_peer_get_methods - Get a list of enabled EAP peer methods
+ * @count: Set to number of available methods
+ * Returns: List of enabled EAP peer methods
+const struct eap_method * eap_peer_get_methods(size_t *count)
+	int c = 0;
+		c++;
+	*count = c;
+	return eap_methods;
+ * eap_peer_method_load - Load a dynamic EAP method library (shared object)
+ * @so: File path for the shared object file to load
+ * Returns: 0 on success, -1 on failure
+int eap_peer_method_load(const char *so)
+	void *handle;
+	int (*dyn_init)(void);
+	int ret;
+	handle = dlopen(so, RTLD_LAZY);
+	if (handle == NULL) {
+		wpa_printf(MSG_ERROR, "EAP: Failed to open dynamic EAP method "
+			   "'%s': %s", so, dlerror());
+		return -1;
+	dyn_init = dlsym(handle, "eap_peer_method_dynamic_init");
+	if (dyn_init == NULL) {
+		dlclose(handle);
+		wpa_printf(MSG_ERROR, "EAP: Invalid EAP method '%s' - no "
+			   "eap_peer_method_dynamic_init()", so);
+		return -1;
+	ret = dyn_init();
+	if (ret) {
+		dlclose(handle);
+		wpa_printf(MSG_ERROR, "EAP: Failed to add EAP method '%s' - "
+			   "ret %d", so, ret);
+		return ret;
+	/* Store the handle for this shared object. It will be freed with
+	 * dlclose() when the EAP method is unregistered. */
+	eap_methods->dl_handle = handle;
+	wpa_printf(MSG_DEBUG, "EAP: Loaded dynamic EAP method: '%s'", so);
+	return 0;
+ * eap_peer_method_unload - Unload a dynamic EAP method library (shared object)
+ * @method: Pointer to the dynamically loaded EAP method
+ * This function can be used to unload EAP methods that have been previously
+ * loaded with eap_peer_method_load(). Before unloading the method, all
+ * references to the method must be removed to make sure that no dereferences
+ * of freed memory will occur after unloading.
+int eap_peer_method_unload(struct eap_method *method)
+	struct eap_method *m, *prev;
+	void *handle;
+	m = eap_methods;
+	prev = NULL;
+	while (m) {
+		if (m == method)
+			break;
+		prev = m;
+		m = m->next;
+	if (m == NULL || m->dl_handle == NULL)
+		return -1;
+	if (prev)
+		prev->next = m->next;
+	else
+		eap_methods = m->next;
+	handle = m->dl_handle;
+	if (m->free)
+		m->free(m);
+	else
+		eap_peer_method_free(m);
+	dlclose(handle);
+	return 0;
+ * eap_peer_method_alloc - Allocate EAP peer method structure
+ * @version: Version of the EAP peer method interface (set to
+ * EAP_PEER_METHOD_INTERFACE_VERSION)
+ * @vendor: EAP Vendor-ID (EAP_VENDOR_*) (0 = IETF)
+ * @method: EAP type number (EAP_TYPE_*)
+ * @name: Name of the method (e.g., "TLS")
+ * Returns: Allocated EAP method structure or %NULL on failure
+ * The returned structure should be freed with eap_peer_method_free() when it
+ * is not needed anymore.
+struct eap_method * eap_peer_method_alloc(int version, int vendor,
+					  EapType method, const char *name)
+	eap = os_zalloc(sizeof(*eap));
+	if (eap == NULL)
+		return NULL;
+	eap->version = version;
+	eap->vendor = vendor;
+	eap->method = method;
+	eap->name = name;
+	return eap;
+ * eap_peer_method_free - Free EAP peer method structure
+ * @method: Method structure allocated with eap_peer_method_alloc()
+void eap_peer_method_free(struct eap_method *method)
+	os_free(method);
+ * eap_peer_method_register - Register an EAP peer method
+ * @method: EAP method to register
+ * Returns: 0 on success, -1 on invalid method, or -2 if a matching EAP method
+ * has already been registered
+ * Each EAP peer method needs to call this function to register itself as a
+ * supported EAP method.
+int eap_peer_method_register(struct eap_method *method)
+	struct eap_method *m, *last = NULL;
+	if (method == NULL || method->name == NULL ||
+	    method->version != EAP_PEER_METHOD_INTERFACE_VERSION)
+		return -1;
+		if ((m->vendor == method->vendor &&
+		     m->method == method->method) ||
+		    os_strcmp(m->name, method->name) == 0)
+			return -2;
+		last = m;
+	if (last)
+		last->next = method;
+	else
+		eap_methods = method;
+	return 0;
+ * eap_peer_unregister_methods - Unregister EAP peer methods
+ * This function is called at program termination to unregister all EAP peer
+ * methods.
+void eap_peer_unregister_methods(void)
+	void *handle;
+	while (eap_methods) {
+		m = eap_methods;
+		eap_methods = eap_methods->next;
+		if (m->free)
+			m->free(m);
+		else
+		if (handle)
+			dlclose(handle);
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_methods.h b/freebsd/contrib/wpa/src/eap_peer/eap_methods.h
new file mode 100644
index 00000000000..e35c919abce
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_methods.h
@@ -0,0 +1,111 @@
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef EAP_METHODS_H
+#define EAP_METHODS_H
+#include "eap_common/eap_defs.h"
+const struct eap_method * eap_peer_get_eap_method(int vendor, EapType method);
+const struct eap_method * eap_peer_get_methods(size_t *count);
+					  EapType method, const char *name);
+void eap_peer_method_free(struct eap_method *method);
+int eap_peer_method_register(struct eap_method *method);
+#ifdef IEEE8021X_EAPOL
+EapType eap_peer_get_type(const char *name, int *vendor);
+const char * eap_get_name(int vendor, EapType type);
+size_t eap_get_names(char *buf, size_t buflen);
+char ** eap_get_names_as_string_array(size_t *num);
+void eap_peer_unregister_methods(void);
+#else /* IEEE8021X_EAPOL */
+static inline EapType eap_peer_get_type(const char *name, int *vendor)
+static inline const char * eap_get_name(int vendor, EapType type)
+	return NULL;
+static inline size_t eap_get_names(char *buf, size_t buflen)
+	return 0;
+static inline int eap_peer_register_methods(void)
+	return 0;
+static inline void eap_peer_unregister_methods(void)
+static inline char ** eap_get_names_as_string_array(size_t *num)
+	return NULL;
+int eap_peer_method_load(const char *so);
+int eap_peer_method_unload(struct eap_method *method);
+#else /* CONFIG_DYNAMIC_EAP_METHODS */
+static inline int eap_peer_method_load(const char *so)
+	return 0;
+static inline int eap_peer_method_unload(struct eap_method *method)
+	return 0;
+/* EAP peer method registration calls for statically linked in methods */
+int eap_peer_md5_register(void);
+int eap_peer_tls_register(void);
+int eap_peer_unauth_tls_register(void);
+int eap_peer_wfa_unauth_tls_register(void);
+int eap_peer_mschapv2_register(void);
+int eap_peer_peap_register(void);
+int eap_peer_ttls_register(void);
+int eap_peer_gtc_register(void);
+int eap_peer_otp_register(void);
+int eap_peer_sim_register(void);
+int eap_peer_leap_register(void);
+int eap_peer_psk_register(void);
+int eap_peer_aka_register(void);
+int eap_peer_aka_prime_register(void);
+int eap_peer_fast_register(void);
+int eap_peer_pax_register(void);
+int eap_peer_sake_register(void);
+int eap_peer_gpsk_register(void);
+int eap_peer_wsc_register(void);
+int eap_peer_ikev2_register(void);
+int eap_peer_vendor_test_register(void);
+int eap_peer_tnc_register(void);
+int eap_peer_pwd_register(void);
+int eap_peer_eke_register(void);
+#endif /* EAP_METHODS_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c b/freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c
index 00000000000..18bb04c2863
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c
@@ -0,0 +1,903 @@
+ * EAP peer method: EAP-MSCHAPV2 (draft-kamath-pppext-eap-mschapv2-00.txt)
+ * Copyright (c) 2004-2008, Jouni Malinen <j at w1.fi>
+ * This file implements EAP peer part of EAP-MSCHAPV2 method (EAP type 26).
+ * draft-kamath-pppext-eap-mschapv2-00.txt defines the Microsoft EAP CHAP
+ * Extensions Protocol, Version 2, for mutual authentication and key
+ * derivation. This encapsulates MS-CHAP-v2 protocol which is defined in
+ * RFC 2759. Use of EAP-MSCHAPV2 derived keys with MPPE cipher is described in
+ * RFC 3079.
+#include "common/wpa_ctrl.h"
+#include "mschapv2.h"
+#include "eap_i.h"
+#include "eap_config.h"
+#ifdef _MSC_VER
+#pragma pack(push, 1)
+#endif /* _MSC_VER */
+struct eap_mschapv2_hdr {
+	u8 op_code; /* MSCHAPV2_OP_* */
+	u8 mschapv2_id; /* usually same as EAP identifier; must be changed
+			 * for challenges, but not for success/failure */
+	u8 ms_length[2]; /* Note: misaligned; length - 5 */
+	/* followed by data */
+} STRUCT_PACKED;
+/* Response Data field */
+struct ms_response {
+	u8 peer_challenge[MSCHAPV2_CHAL_LEN];
+	u8 reserved[8];
+	u8 nt_response[MSCHAPV2_NT_RESPONSE_LEN];
+	u8 flags;
+} STRUCT_PACKED;
+/* Change-Password Data field */
+struct ms_change_password {
+	u8 encr_password[516];
+	u8 encr_hash[16];
+	u8 reserved[8];
+	u8 flags[2];
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+#define MSCHAPV2_OP_CHALLENGE 1
+#define MSCHAPV2_OP_RESPONSE 2
+#define MSCHAPV2_OP_SUCCESS 3
+#define MSCHAPV2_OP_FAILURE 4
+#define MSCHAPV2_OP_CHANGE_PASSWORD 7
+#define ERROR_RESTRICTED_LOGON_HOURS 646
+#define ERROR_ACCT_DISABLED 647
+#define ERROR_PASSWD_EXPIRED 648
+#define ERROR_NO_DIALIN_PERMISSION 649
+#define ERROR_AUTHENTICATION_FAILURE 691
+#define ERROR_CHANGING_PASSWORD 709
+#define PASSWD_CHANGE_CHAL_LEN 16
+#define MSCHAPV2_KEY_LEN 16
+struct eap_mschapv2_data {
+	u8 auth_response[MSCHAPV2_AUTH_RESPONSE_LEN];
+	int auth_response_valid;
+	int prev_error;
+	u8 passwd_change_challenge[PASSWD_CHANGE_CHAL_LEN];
+	int passwd_change_challenge_valid;
+	int passwd_change_version;
+	/* Optional challenge values generated in EAP-FAST Phase 1 negotiation
+	u8 *peer_challenge;
+	u8 *auth_challenge;
+	int phase2;
+	u8 master_key[MSCHAPV2_MASTER_KEY_LEN];
+	int master_key_valid;
+	int success;
+	struct wpabuf *prev_challenge;
+static void eap_mschapv2_deinit(struct eap_sm *sm, void *priv);
+static void * eap_mschapv2_init(struct eap_sm *sm)
+	struct eap_mschapv2_data *data;
+	if (data == NULL)
+		return NULL;
+	if (sm->peer_challenge) {
+		data->peer_challenge = os_malloc(MSCHAPV2_CHAL_LEN);
+		if (data->peer_challenge == NULL) {
+			eap_mschapv2_deinit(sm, data);
+			return NULL;
+		os_memcpy(data->peer_challenge, sm->peer_challenge,
+			  MSCHAPV2_CHAL_LEN);
+	if (sm->auth_challenge) {
+		data->auth_challenge = os_malloc(MSCHAPV2_CHAL_LEN);
+		if (data->auth_challenge == NULL) {
+			return NULL;
+		os_memcpy(data->auth_challenge, sm->auth_challenge,
+	data->phase2 = sm->init_phase2;
+	return data;
+	struct eap_mschapv2_data *data = priv;
+	os_free(data->peer_challenge);
+	os_free(data->auth_challenge);
+	wpabuf_free(data->prev_challenge);
+	bin_clear_free(data, sizeof(*data));
+static struct wpabuf * eap_mschapv2_challenge_reply(
+	struct eap_sm *sm, struct eap_mschapv2_data *data, u8 id,
+	u8 mschapv2_id, const u8 *auth_challenge)
+	struct eap_mschapv2_hdr *ms;
+	int ms_len;
+	struct ms_response *r;
+	size_t identity_len, password_len;
+	const u8 *identity, *password;
+	int pwhash;
+	wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Generating Challenge Response");
+		return NULL;
+	ms_len = sizeof(*ms) + 1 + sizeof(*r) + identity_len;
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_MSCHAPV2, ms_len,
+	if (resp == NULL)
+		return NULL;
+	ms = wpabuf_put(resp, sizeof(*ms));
+	ms->op_code = MSCHAPV2_OP_RESPONSE;
+	ms->mschapv2_id = mschapv2_id;
+	if (data->prev_error) {
+		 * TODO: this does not seem to be enough when processing two
+		 * or more failure messages. IAS did not increment mschapv2_id
+		 * in its own packets, but it seemed to expect the peer to
+		 * increment this for all packets(?).
+		ms->mschapv2_id++;
+	WPA_PUT_BE16(ms->ms_length, ms_len);
+	wpabuf_put_u8(resp, sizeof(*r)); /* Value-Size */
+	/* Response */
+	r = wpabuf_put(resp, sizeof(*r));
+	peer_challenge = r->peer_challenge;
+	if (data->peer_challenge) {
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: peer_challenge generated "
+			   "in Phase 1");
+		peer_challenge = data->peer_challenge;
+		os_memset(r->peer_challenge, 0, MSCHAPV2_CHAL_LEN);
+	} else if (random_get_bytes(peer_challenge, MSCHAPV2_CHAL_LEN)) {
+		return NULL;
+	os_memset(r->reserved, 0, 8);
+	if (data->auth_challenge) {
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: auth_challenge generated "
+			   "in Phase 1");
+		auth_challenge = data->auth_challenge;
+	if (mschapv2_derive_response(identity, identity_len, password,
+				     password_len, pwhash, auth_challenge,
+				     peer_challenge, r->nt_response,
+				     data->auth_response, data->master_key)) {
+		wpa_printf(MSG_ERROR, "EAP-MSCHAPV2: Failed to derive "
+			   "response");
+		return NULL;
+	data->auth_response_valid = 1;
+	data->master_key_valid = 1;
+	r->flags = 0; /* reserved, must be zero */
+	wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: TX identifier %d mschapv2_id %d "
+		   "(response)", id, ms->mschapv2_id);
+	return resp;
+ * eap_mschapv2_process - Process an EAP-MSCHAPv2 challenge message
+ * @sm: Pointer to EAP state machine allocated with eap_peer_sm_init()
+ * @data: Pointer to private EAP method data from eap_mschapv2_init()
+ * @req: Pointer to EAP-MSCHAPv2 header from the request
+ * @req_len: Length of the EAP-MSCHAPv2 data
+ * @id: EAP identifier used in the request
+ * Returns: Pointer to allocated EAP response packet (eapRespData) or %NULL if
+ * no reply available
+static struct wpabuf * eap_mschapv2_challenge(
+	struct eap_method_ret *ret, const struct eap_mschapv2_hdr *req,
+	size_t req_len, u8 id)
+	size_t len, challenge_len;
+	const u8 *pos, *challenge;
+	if (eap_get_config_identity(sm, &len) == NULL ||
+	    eap_get_config_password(sm, &len) == NULL)
+		return NULL;
+	wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Received challenge");
+	if (req_len < sizeof(*req) + 1) {
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Too short challenge data "
+			   "(len %lu)", (unsigned long) req_len);
+		return NULL;
+	pos = (const u8 *) (req + 1);
+	len = req_len - sizeof(*req) - 1;
+	if (challenge_len != MSCHAPV2_CHAL_LEN) {
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Invalid challenge length "
+			   "%lu", (unsigned long) challenge_len);
+		return NULL;
+	if (len < challenge_len) {
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Too short challenge"
+			   " packet: len=%lu challenge_len=%lu",
+			   (unsigned long) len, (unsigned long) challenge_len);
+		return NULL;
+	if (data->passwd_change_challenge_valid) {
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Using challenge from the "
+			   "failure message");
+		challenge = data->passwd_change_challenge;
+	} else
+		challenge = pos;
+	pos += challenge_len;
+	len -= challenge_len;
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-MSCHAPV2: Authentication Servername",
+		    pos, len);
+	return eap_mschapv2_challenge_reply(sm, data, id, req->mschapv2_id,
+					    challenge);
+static void eap_mschapv2_password_changed(struct eap_sm *sm,
+					  struct eap_mschapv2_data *data)
+	struct eap_peer_config *config = eap_get_config(sm);
+	if (config && config->new_password) {
+		wpa_msg(sm->msg_ctx, MSG_INFO,
+			WPA_EVENT_PASSWORD_CHANGED
+			"EAP-MSCHAPV2: Password changed successfully");
+		data->prev_error = 0;
+		bin_clear_free(config->password, config->password_len);
+		if (config->flags & EAP_CONFIG_FLAGS_EXT_PASSWORD) {
+			/* TODO: update external storage */
+		} else if (config->flags & EAP_CONFIG_FLAGS_PASSWORD_NTHASH) {
+			config->password = os_malloc(16);
+			config->password_len = 16;
+			if (config->password &&
+			    nt_password_hash(config->new_password,
+					     config->new_password_len,
+					     config->password)) {
+					       config->password_len);
+				config->password = NULL;
+				config->password_len = 0;
+			bin_clear_free(config->new_password,
+				       config->new_password_len);
+		} else {
+			config->password = config->new_password;
+			config->password_len = config->new_password_len;
+		config->new_password = NULL;
+		config->new_password_len = 0;
+ * eap_mschapv2_process - Process an EAP-MSCHAPv2 success message
+ * @id: EAP identifier used in th erequest
+static struct wpabuf * eap_mschapv2_success(struct eap_sm *sm,
+					    struct eap_mschapv2_data *data,
+					    const struct eap_mschapv2_hdr *req,
+	const u8 *pos;
+	size_t len;
+	wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Received success");
+	len = req_len - sizeof(*req);
+	if (!data->auth_response_valid ||
+	    mschapv2_verify_auth_response(data->auth_response, pos, len)) {
+		wpa_printf(MSG_WARNING, "EAP-MSCHAPV2: Invalid authenticator "
+			   "response in success request");
+		return NULL;
+	pos += 2 + 2 * MSCHAPV2_AUTH_RESPONSE_LEN;
+	len -= 2 + 2 * MSCHAPV2_AUTH_RESPONSE_LEN;
+	while (len > 0 && *pos == ' ') {
+		pos++;
+		len--;
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-MSCHAPV2: Success message",
+			  pos, len);
+	wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Authentication succeeded");
+	/* Note: Only op_code of the EAP-MSCHAPV2 header is included in success
+	 * message. */
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_MSCHAPV2, 1,
+	if (resp == NULL) {
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Failed to allocate "
+			   "buffer for success response");
+		return NULL;
+	wpabuf_put_u8(resp, MSCHAPV2_OP_SUCCESS); /* op_code */
+	data->success = 1;
+	if (data->prev_error == ERROR_PASSWD_EXPIRED)
+		eap_mschapv2_password_changed(sm, data);
+	return resp;
+static int eap_mschapv2_failure_txt(struct eap_sm *sm,
+				    struct eap_mschapv2_data *data, char *txt)
+	char *pos, *msg = "";
+	int retry = 1;
+	/* For example:
+	 * E=691 R=1 C=<32 octets hex challenge> V=3 M=Authentication Failure
+	pos = txt;
+	if (pos && os_strncmp(pos, "E=", 2) == 0) {
+		pos += 2;
+		data->prev_error = atoi(pos);
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: error %d",
+			   data->prev_error);
+		pos = os_strchr(pos, ' ');
+		if (pos)
+			pos++;
+	if (pos && os_strncmp(pos, "R=", 2) == 0) {
+		pos += 2;
+		retry = atoi(pos);
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: retry is %sallowed",
+			   retry == 1 ? "" : "not ");
+		if (pos)
+			pos++;
+	if (pos && os_strncmp(pos, "C=", 2) == 0) {
+		int hex_len;
+		pos += 2;
+		hex_len = os_strchr(pos, ' ') - (char *) pos;
+		if (hex_len == PASSWD_CHANGE_CHAL_LEN * 2) {
+			if (hexstr2bin(pos, data->passwd_change_challenge,
+				       PASSWD_CHANGE_CHAL_LEN)) {
+				wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: invalid "
+					   "failure challenge");
+			} else {
+				wpa_hexdump(MSG_DEBUG, "EAP-MSCHAPV2: failure "
+					    "challenge",
+					    data->passwd_change_challenge,
+					    PASSWD_CHANGE_CHAL_LEN);
+				data->passwd_change_challenge_valid = 1;
+		} else {
+			wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: invalid failure "
+				   "challenge len %d", hex_len);
+		if (pos)
+			pos++;
+	} else {
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: required challenge field "
+			   "was not present in failure message");
+	if (pos && os_strncmp(pos, "V=", 2) == 0) {
+		pos += 2;
+		data->passwd_change_version = atoi(pos);
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: password changing "
+			   "protocol version %d", data->passwd_change_version);
+		if (pos)
+			pos++;
+	if (pos && os_strncmp(pos, "M=", 2) == 0) {
+		pos += 2;
+		msg = pos;
+	if (data->prev_error == ERROR_AUTHENTICATION_FAILURE && retry &&
+	    config && config->phase2 &&
+	    os_strstr(config->phase2, "mschapv2_retry=0")) {
+			   "EAP-MSCHAPV2: mark password retry disabled based on local configuration");
+		retry = 0;
+	wpa_msg(sm->msg_ctx, MSG_WARNING,
+		"EAP-MSCHAPV2: failure message: '%s' (retry %sallowed, error "
+		"%d)",
+		msg, retry == 1 ? "" : "not ", data->prev_error);
+	if (data->prev_error == ERROR_PASSWD_EXPIRED &&
+	    data->passwd_change_version == 3 && config) {
+		if (config->new_password == NULL) {
+				"EAP-MSCHAPV2: Password expired - password "
+				"change required");
+			eap_sm_request_new_password(sm);
+	} else if (retry == 1 && config) {
+		/* TODO: could prevent the current password from being used
+		 * again at least for some period of time */
+		if (!config->mschapv2_retry)
+			eap_sm_request_identity(sm);
+		config->mschapv2_retry = 1;
+	} else if (config) {
+		/* TODO: prevent retries using same username/password */
+		config->mschapv2_retry = 0;
+	return retry == 1;
+static struct wpabuf * eap_mschapv2_change_password(
+	struct eap_method_ret *ret, const struct eap_mschapv2_hdr *req, u8 id)
+#ifdef CONFIG_NO_RC4
+		"EAP-MSCHAPV2: RC4 not support in the build - cannot change password");
+	return NULL;
+#else /* CONFIG_NO_RC4 */
+	int ms_len;
+	const u8 *username, *password, *new_password;
+	size_t username_len, password_len, new_password_len;
+	struct ms_change_password *cp;
+	u8 password_hash[16], password_hash_hash[16];
+	int pwhash;
+	username = eap_get_config_identity(sm, &username_len);
+	new_password = eap_get_config_new_password(sm, &new_password_len);
+	if (username == NULL || password == NULL || new_password == NULL)
+		return NULL;
+	username = mschapv2_remove_domain(username, &username_len);
+	ms_len = sizeof(*ms) + sizeof(*cp);
+	if (resp == NULL)
+		return NULL;
+	ms->op_code = MSCHAPV2_OP_CHANGE_PASSWORD;
+	ms->mschapv2_id = req->mschapv2_id + 1;
+	cp = wpabuf_put(resp, sizeof(*cp));
+	/* Encrypted-Password */
+	if (pwhash) {
+		if (encrypt_pw_block_with_password_hash(
+			    new_password, new_password_len,
+			    password, cp->encr_password))
+			goto fail;
+	} else {
+		if (new_password_encrypted_with_old_nt_password_hash(
+			    password, password_len, cp->encr_password))
+			goto fail;
+	/* Encrypted-Hash */
+	if (pwhash) {
+		u8 new_password_hash[16];
+		if (nt_password_hash(new_password, new_password_len,
+				     new_password_hash))
+			goto fail;
+		nt_password_hash_encrypted_with_block(password,
+						      new_password_hash,
+						      cp->encr_hash);
+	} else {
+		if (old_nt_password_hash_encrypted_with_new_nt_password_hash(
+			    password, password_len, cp->encr_hash))
+			goto fail;
+	/* Peer-Challenge */
+	if (random_get_bytes(cp->peer_challenge, MSCHAPV2_CHAL_LEN))
+		goto fail;
+	/* Reserved, must be zero */
+	os_memset(cp->reserved, 0, 8);
+	/* NT-Response */
+	wpa_hexdump(MSG_DEBUG, "EAP-MSCHAPV2: auth_challenge",
+		    data->passwd_change_challenge, PASSWD_CHANGE_CHAL_LEN);
+	wpa_hexdump(MSG_DEBUG, "EAP-MSCHAPV2: peer_challenge",
+		    cp->peer_challenge, MSCHAPV2_CHAL_LEN);
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-MSCHAPV2: username",
+			  username, username_len);
+	wpa_hexdump_ascii_key(MSG_DEBUG, "EAP-MSCHAPV2: new password",
+			      new_password, new_password_len);
+	generate_nt_response(data->passwd_change_challenge, cp->peer_challenge,
+			     username, username_len,
+			     cp->nt_response);
+	wpa_hexdump(MSG_DEBUG, "EAP-MSCHAPV2: NT-Response",
+		    cp->nt_response, MSCHAPV2_NT_RESPONSE_LEN);
+	/* Authenticator response is not really needed yet, but calculate it
+	 * here so that challenges need not be saved. */
+	generate_authenticator_response(new_password, new_password_len,
+					cp->nt_response, data->auth_response);
+	/* Likewise, generate master_key here since we have the needed data
+	 * available. */
+	if (nt_password_hash(new_password, new_password_len, password_hash) ||
+	    hash_nt_password_hash(password_hash, password_hash_hash) ||
+	    get_master_key(password_hash_hash, cp->nt_response,
+			   data->master_key)) {
+		data->auth_response_valid = 0;
+		goto fail;
+	/* Flags */
+	os_memset(cp->flags, 0, 2);
+		   "(change pw)", id, ms->mschapv2_id);
+	return resp;
+fail:
+	return NULL;
+#endif /* CONFIG_NO_RC4 */
+ * eap_mschapv2_process - Process an EAP-MSCHAPv2 failure message
+static struct wpabuf * eap_mschapv2_failure(struct eap_sm *sm,
+	const u8 *msdata = (const u8 *) (req + 1);
+	char *buf;
+	size_t len = req_len - sizeof(*req);
+	int retry = 0;
+	wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Received failure");
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-MSCHAPV2: Failure data",
+			  msdata, len);
+	 * eap_mschapv2_failure_txt() expects a nul terminated string, so we
+	 * must allocate a large enough temporary buffer to create that since
+	 * the received message does not include nul termination.
+	buf = dup_binstr(msdata, len);
+	if (buf) {
+		retry = eap_mschapv2_failure_txt(sm, data, buf);
+		os_free(buf);
+	    data->passwd_change_version == 3) {
+			return eap_mschapv2_change_password(sm, data, ret, req,
+							    id);
+		if (config && config->pending_req_new_password)
+			return NULL;
+	} else if (retry && data->prev_error == ERROR_AUTHENTICATION_FAILURE) {
+		/* TODO: could try to retry authentication, e.g, after having
+		 * changed the username/password. In this case, EAP MS-CHAP-v2
+		 * Failure Response would not be sent here. */
+		return NULL;
+	/* Note: Only op_code of the EAP-MSCHAPV2 header is included in failure
+	 * message. */
+	if (resp == NULL)
+		return NULL;
+	wpabuf_put_u8(resp, MSCHAPV2_OP_FAILURE); /* op_code */
+	return resp;
+static int eap_mschapv2_check_config(struct eap_sm *sm)
+	size_t len;
+	if (eap_get_config_identity(sm, &len) == NULL) {
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Identity not configured");
+		return -1;
+	if (eap_get_config_password(sm, &len) == NULL) {
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Password not configured");
+		return -1;
+	return 0;
+static int eap_mschapv2_check_mslen(struct eap_sm *sm, size_t len,
+				    const struct eap_mschapv2_hdr *ms)
+	size_t ms_len = WPA_GET_BE16(ms->ms_length);
+	if (ms_len == len)
+		return 0;
+	wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Invalid header: len=%lu "
+		   "ms_len=%lu", (unsigned long) len, (unsigned long) ms_len);
+	if (sm->workaround) {
+		/* Some authentication servers use invalid ms_len,
+		 * ignore it for interoperability. */
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: workaround, ignore"
+			   " invalid ms_len %lu (len %lu)",
+			   (unsigned long) ms_len,
+			   (unsigned long) len);
+		return 0;
+	return -1;
+static void eap_mschapv2_copy_challenge(struct eap_mschapv2_data *data,
+	 * Store a copy of the challenge message, so that it can be processed
+	 * again in case retry is allowed after a possible failure.
+	data->prev_challenge = wpabuf_dup(reqData);
+ * eap_mschapv2_process - Process an EAP-MSCHAPv2 request
+ * @priv: Pointer to private EAP method data from eap_mschapv2_init()
+static struct wpabuf * eap_mschapv2_process(struct eap_sm *sm, void *priv,
+	const struct eap_mschapv2_hdr *ms;
+	int using_prev_challenge = 0;
+	const u8 *pos;
+	size_t len;
+	u8 id;
+	if (eap_mschapv2_check_config(sm)) {
+		return NULL;
+	if (config->mschapv2_retry && data->prev_challenge &&
+	    data->prev_error == ERROR_AUTHENTICATION_FAILURE) {
+		wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: Replacing pending packet "
+			   "with the previous challenge");
+		reqData = data->prev_challenge;
+		using_prev_challenge = 1;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_MSCHAPV2, reqData,
+			       &len);
+	if (pos == NULL || len < sizeof(*ms) + 1) {
+		return NULL;
+	ms = (const struct eap_mschapv2_hdr *) pos;
+	if (eap_mschapv2_check_mslen(sm, len, ms)) {
+		return NULL;
+	wpa_printf(MSG_DEBUG, "EAP-MSCHAPV2: RX identifier %d mschapv2_id %d",
+		   id, ms->mschapv2_id);
+	switch (ms->op_code) {
+	case MSCHAPV2_OP_CHALLENGE:
+		if (!using_prev_challenge)
+			eap_mschapv2_copy_challenge(data, reqData);
+		return eap_mschapv2_challenge(sm, data, ret, ms, len, id);
+	case MSCHAPV2_OP_SUCCESS:
+		return eap_mschapv2_success(sm, data, ret, ms, len, id);
+	case MSCHAPV2_OP_FAILURE:
+		return eap_mschapv2_failure(sm, data, ret, ms, len, id);
+	default:
+		wpa_printf(MSG_INFO, "EAP-MSCHAPV2: Unknown op %d - ignored",
+			   ms->op_code);
+		return NULL;
+static Boolean eap_mschapv2_isKeyAvailable(struct eap_sm *sm, void *priv)
+	return data->success && data->master_key_valid;
+static u8 * eap_mschapv2_getKey(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+	int key_len;
+	if (!data->master_key_valid || !data->success)
+		return NULL;
+	key_len = 2 * MSCHAPV2_KEY_LEN;
+	key = os_malloc(key_len);
+	if (key == NULL)
+		return NULL;
+	/* MSK = server MS-MPPE-Recv-Key | MS-MPPE-Send-Key, i.e.,
+	 *	peer MS-MPPE-Send-Key | MS-MPPE-Recv-Key */
+	get_asymetric_start_key(data->master_key, key, MSCHAPV2_KEY_LEN, 1, 0);
+	get_asymetric_start_key(data->master_key, key + MSCHAPV2_KEY_LEN,
+				MSCHAPV2_KEY_LEN, 0, 0);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-MSCHAPV2: Derived key",
+			key, key_len);
+	*len = key_len;
+	return key;
+ * eap_peer_mschapv2_register - Register EAP-MSCHAPv2 peer method
+ * This function is used to register EAP-MSCHAPv2 peer method into the EAP
+ * method list.
+	int ret;
+				    EAP_VENDOR_IETF, EAP_TYPE_MSCHAPV2,
+				    "MSCHAPV2");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_mschapv2_init;
+	eap->deinit = eap_mschapv2_deinit;
+	eap->process = eap_mschapv2_process;
+	eap->isKeyAvailable = eap_mschapv2_isKeyAvailable;
+	eap->getKey = eap_mschapv2_getKey;
+	if (ret)
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_otp.c b/freebsd/contrib/wpa/src/eap_peer/eap_otp.c
index 00000000000..d4d8bc1cc2a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_otp.c
@@ -0,0 +1,103 @@
+ * EAP peer method: EAP-OTP (RFC 3748)
+#include "eap_i.h"
+static void * eap_otp_init(struct eap_sm *sm)
+	 * success. */
+static void eap_otp_deinit(struct eap_sm *sm, void *priv)
+static struct wpabuf * eap_otp_process(struct eap_sm *sm, void *priv,
+	int otp;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_OTP, reqData, &len);
+		return NULL;
+	wpa_hexdump_ascii(MSG_MSGDUMP, "EAP-OTP: Request message",
+			  pos, len);
+	if (password)
+		otp = 1;
+	else {
+		otp = 0;
+		wpa_printf(MSG_INFO, "EAP-OTP: Password not configured");
+		return NULL;
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_OTP, password_len,
+	if (resp == NULL)
+		return NULL;
+	wpa_hexdump_ascii_key(MSG_MSGDUMP, "EAP-OTP: Response",
+			      password, password_len);
+	if (otp) {
+		wpa_printf(MSG_DEBUG, "EAP-OTP: Forgetting used password");
+	return resp;
+	int ret;
+				    EAP_VENDOR_IETF, EAP_TYPE_OTP, "OTP");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_otp_init;
+	eap->deinit = eap_otp_deinit;
+	eap->process = eap_otp_process;
+	if (ret)
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_peap.c b/freebsd/contrib/wpa/src/eap_peer/eap_peap.c
index 00000000000..19afa1cf9a2
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_peap.c
@@ -0,0 +1,1264 @@
+ * EAP peer method: EAP-PEAP (draft-josefsson-pppext-eap-tls-eap-10.txt)
+#include "crypto/sha1.h"
+#include "crypto/tls.h"
+#include "eap_common/eap_tlv_common.h"
+#include "eap_common/eap_peap_common.h"
+#include "eap_i.h"
+#include "eap_tls_common.h"
+#include "tncc.h"
+/* Maximum supported PEAP version
+ * 0 = Microsoft's PEAP version 0; draft-kamath-pppext-peapv0-00.txt
+ * 1 = draft-josefsson-ppext-eap-tls-eap-05.txt
+#define EAP_PEAP_VERSION 1
+static void eap_peap_deinit(struct eap_sm *sm, void *priv);
+struct eap_peap_data {
+	struct eap_ssl_data ssl;
+	int peap_version, force_peap_version, force_new_label;
+	const struct eap_method *phase2_method;
+	void *phase2_priv;
+	int phase2_success;
+	int phase2_eap_success;
+	int phase2_eap_started;
+	struct eap_method_type phase2_type;
+	struct eap_method_type *phase2_types;
+	size_t num_phase2_types;
+	int peap_outer_success; /* 0 = PEAP terminated on Phase 2 inner
+				 * EAP-Success
+				 * 1 = reply with tunneled EAP-Success to inner
+				 * EAP-Success and expect AS to send outer
+				 * (unencrypted) EAP-Success after this
+				 * 2 = reply with PEAP/TLS ACK to inner
+				 * (unencrypted) EAP-Success after this */
+	int resuming; /* starting a resumed session */
+	int reauth; /* reauthentication */
+	u8 *key_data;
+	u8 *session_id;
+	size_t id_len;
+	struct wpabuf *pending_phase2_req;
+	enum { NO_BINDING, OPTIONAL_BINDING, REQUIRE_BINDING } crypto_binding;
+	int crypto_binding_used;
+	u8 binding_nonce[32];
+	u8 ipmk[40];
+	u8 cmk[20];
+	int soh; /* Whether IF-TNCCS-SOH (Statement of Health; Microsoft NAP)
+		  * is enabled. */
+static int eap_peap_parse_phase1(struct eap_peap_data *data,
+				 const char *phase1)
+	const char *pos;
+	pos = os_strstr(phase1, "peapver=");
+	if (pos) {
+		data->force_peap_version = atoi(pos + 8);
+		data->peap_version = data->force_peap_version;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Forced PEAP version %d",
+			   data->force_peap_version);
+	if (os_strstr(phase1, "peaplabel=1")) {
+		data->force_new_label = 1;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Force new label for key "
+			   "derivation");
+	if (os_strstr(phase1, "peap_outer_success=0")) {
+		data->peap_outer_success = 0;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: terminate authentication on "
+			   "tunneled EAP-Success");
+	} else if (os_strstr(phase1, "peap_outer_success=1")) {
+		data->peap_outer_success = 1;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: send tunneled EAP-Success "
+			   "after receiving tunneled EAP-Success");
+	} else if (os_strstr(phase1, "peap_outer_success=2")) {
+		data->peap_outer_success = 2;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: send PEAP/TLS ACK after "
+			   "receiving tunneled EAP-Success");
+	if (os_strstr(phase1, "crypto_binding=0")) {
+		data->crypto_binding = NO_BINDING;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Do not use cryptobinding");
+	} else if (os_strstr(phase1, "crypto_binding=1")) {
+		data->crypto_binding = OPTIONAL_BINDING;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Optional cryptobinding");
+	} else if (os_strstr(phase1, "crypto_binding=2")) {
+		data->crypto_binding = REQUIRE_BINDING;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Require cryptobinding");
+#ifdef EAP_TNC
+	if (os_strstr(phase1, "tnc=soh2")) {
+		data->soh = 2;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: SoH version 2 enabled");
+	} else if (os_strstr(phase1, "tnc=soh1")) {
+		data->soh = 1;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: SoH version 1 enabled");
+	} else if (os_strstr(phase1, "tnc=soh")) {
+		data->soh = 2;
+#endif /* EAP_TNC */
+	return 0;
+static void * eap_peap_init(struct eap_sm *sm)
+	struct eap_peap_data *data;
+	data = os_zalloc(sizeof(*data));
+	if (data == NULL)
+		return NULL;
+	sm->peap_done = FALSE;
+	data->peap_version = EAP_PEAP_VERSION;
+	data->force_peap_version = -1;
+	if (config && config->phase1 &&
+	    eap_peap_parse_phase1(data, config->phase1) < 0) {
+		eap_peap_deinit(sm, data);
+		return NULL;
+	if (eap_peer_select_phase2_methods(config, "auth=",
+					   &data->phase2_types,
+					   &data->num_phase2_types) < 0) {
+		return NULL;
+	data->phase2_type.vendor = EAP_VENDOR_IETF;
+	data->phase2_type.method = EAP_TYPE_NONE;
+	if (eap_peer_tls_ssl_init(sm, &data->ssl, config, EAP_TYPE_PEAP)) {
+		wpa_printf(MSG_INFO, "EAP-PEAP: Failed to initialize SSL.");
+		return NULL;
+	return data;
+static void eap_peap_free_key(struct eap_peap_data *data)
+	if (data->key_data) {
+		bin_clear_free(data->key_data, EAP_TLS_KEY_LEN);
+		data->key_data = NULL;
+	struct eap_peap_data *data = priv;
+	if (data == NULL)
+		return;
+	if (data->phase2_priv && data->phase2_method)
+		data->phase2_method->deinit(sm, data->phase2_priv);
+	os_free(data->phase2_types);
+	eap_peer_tls_ssl_deinit(sm, &data->ssl);
+	eap_peap_free_key(data);
+	os_free(data->session_id);
+	wpabuf_free(data->pending_phase2_req);
+	os_free(data);
+ * eap_tlv_build_nak - Build EAP-TLV NAK message
+ * @id: EAP identifier for the header
+ * @nak_type: TLV type (EAP_TLV_*)
+ * Returns: Buffer to the allocated EAP-TLV NAK message or %NULL on failure
+ * This function builds an EAP-TLV NAK message. The caller is responsible for
+ * freeing the returned buffer.
+static struct wpabuf * eap_tlv_build_nak(int id, u16 nak_type)
+	struct wpabuf *msg;
+	msg = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_TLV, 10,
+			    EAP_CODE_RESPONSE, id);
+	if (msg == NULL)
+		return NULL;
+	wpabuf_put_u8(msg, 0x80); /* Mandatory */
+	wpabuf_put_u8(msg, EAP_TLV_NAK_TLV);
+	wpabuf_put_be16(msg, 6); /* Length */
+	wpabuf_put_be32(msg, 0); /* Vendor-Id */
+	wpabuf_put_be16(msg, nak_type); /* NAK-Type */
+	return msg;
+static int eap_peap_get_isk(struct eap_sm *sm, struct eap_peap_data *data,
+			    u8 *isk, size_t isk_len)
+	u8 *key;
+	size_t key_len;
+	os_memset(isk, 0, isk_len);
+	if (data->phase2_method == NULL || data->phase2_priv == NULL ||
+	    data->phase2_method->isKeyAvailable == NULL ||
+	    data->phase2_method->getKey == NULL)
+		return 0;
+	if (!data->phase2_method->isKeyAvailable(sm, data->phase2_priv) ||
+	    (key = data->phase2_method->getKey(sm, data->phase2_priv,
+					       &key_len)) == NULL) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Could not get key material "
+			   "from Phase 2");
+		return -1;
+	if (key_len > isk_len)
+		key_len = isk_len;
+	os_memcpy(isk, key, key_len);
+	os_free(key);
+	return 0;
+static int eap_peap_derive_cmk(struct eap_sm *sm, struct eap_peap_data *data)
+	u8 *tk;
+	u8 isk[32], imck[60];
+	 * Tunnel key (TK) is the first 60 octets of the key generated by
+	 * phase 1 of PEAP (based on TLS).
+	tk = data->key_data;
+	if (tk == NULL)
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: TK", tk, 60);
+	if (data->reauth &&
+	    tls_connection_resumed(sm->ssl_ctx, data->ssl.conn)) {
+		/* Fast-connect: IPMK|CMK = TK */
+		os_memcpy(data->ipmk, tk, 40);
+		wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: IPMK from TK",
+				data->ipmk, 40);
+		os_memcpy(data->cmk, tk + 40, 20);
+		wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: CMK from TK",
+				data->cmk, 20);
+		return 0;
+	if (eap_peap_get_isk(sm, data, isk, sizeof(isk)) < 0)
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: ISK", isk, sizeof(isk));
+	 * IPMK Seed = "Inner Methods Compound Keys" | ISK
+	 * TempKey = First 40 octets of TK
+	 * IPMK|CMK = PRF+(TempKey, IPMK Seed, 60)
+	 * (note: draft-josefsson-pppext-eap-tls-eap-10.txt includes a space
+	 * in the end of the label just before ISK; is that just a typo?)
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: TempKey", tk, 40);
+	if (peap_prfplus(data->peap_version, tk, 40,
+			 "Inner Methods Compound Keys",
+			 isk, sizeof(isk), imck, sizeof(imck)) < 0)
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: IMCK (IPMKj)",
+			imck, sizeof(imck));
+	os_memcpy(data->ipmk, imck, 40);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: IPMK (S-IPMKj)", data->ipmk, 40);
+	os_memcpy(data->cmk, imck + 40, 20);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: CMK (CMKj)", data->cmk, 20);
+	return 0;
+static int eap_tlv_add_cryptobinding(struct eap_sm *sm,
+				     struct eap_peap_data *data,
+				     struct wpabuf *buf)
+	u8 *mac;
+	u8 eap_type = EAP_TYPE_PEAP;
+	const u8 *addr[2];
+	size_t len[2];
+	u16 tlv_type;
+	/* Compound_MAC: HMAC-SHA1-160(cryptobinding TLV | EAP type) */
+	addr[0] = wpabuf_put(buf, 0);
+	len[0] = 60;
+	addr[1] = &eap_type;
+	len[1] = 1;
+	tlv_type = EAP_TLV_CRYPTO_BINDING_TLV;
+	wpabuf_put_be16(buf, tlv_type);
+	wpabuf_put_be16(buf, 56);
+	wpabuf_put_u8(buf, 0); /* Reserved */
+	wpabuf_put_u8(buf, data->peap_version); /* Version */
+	wpabuf_put_u8(buf, data->peap_version); /* RecvVersion */
+	wpabuf_put_u8(buf, 1); /* SubType: 0 = Request, 1 = Response */
+	wpabuf_put_data(buf, data->binding_nonce, 32); /* Nonce */
+	mac = wpabuf_put(buf, 20); /* Compound_MAC */
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PEAP: Compound_MAC CMK", data->cmk, 20);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PEAP: Compound_MAC data 1",
+		    addr[0], len[0]);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PEAP: Compound_MAC data 2",
+		    addr[1], len[1]);
+	hmac_sha1_vector(data->cmk, 20, 2, addr, len, mac);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PEAP: Compound_MAC", mac, SHA1_MAC_LEN);
+	data->crypto_binding_used = 1;
+	return 0;
+ * eap_tlv_build_result - Build EAP-TLV Result message
+ * @status: Status (EAP_TLV_RESULT_SUCCESS or EAP_TLV_RESULT_FAILURE)
+ * Returns: Buffer to the allocated EAP-TLV Result message or %NULL on failure
+ * This function builds an EAP-TLV Result message. The caller is responsible
+ * for freeing the returned buffer.
+static struct wpabuf * eap_tlv_build_result(struct eap_sm *sm,
+					    int crypto_tlv_used,
+					    int id, u16 status)
+	size_t len;
+	if (data->crypto_binding == NO_BINDING)
+		crypto_tlv_used = 0;
+	len = 6;
+	if (crypto_tlv_used)
+		len += 60; /* Cryptobinding TLV */
+	msg = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_TLV, len,
+	if (msg == NULL)
+		return NULL;
+	wpabuf_put_u8(msg, EAP_TLV_RESULT_TLV);
+	wpabuf_put_be16(msg, 2); /* Length */
+	wpabuf_put_be16(msg, status); /* Status */
+	if (crypto_tlv_used && eap_tlv_add_cryptobinding(sm, data, msg)) {
+		wpabuf_free(msg);
+		return NULL;
+	return msg;
+static int eap_tlv_validate_cryptobinding(struct eap_sm *sm,
+					  const u8 *crypto_tlv,
+					  size_t crypto_tlv_len)
+	u8 buf[61], mac[SHA1_MAC_LEN];
+	const u8 *pos;
+	if (eap_peap_derive_cmk(sm, data) < 0) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Could not derive CMK");
+		return -1;
+	if (crypto_tlv_len != 4 + 56) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Invalid cryptobinding TLV "
+			   "length %d", (int) crypto_tlv_len);
+		return -1;
+	pos = crypto_tlv;
+	pos += 4; /* TLV header */
+	if (pos[1] != data->peap_version) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Cryptobinding TLV Version "
+			   "mismatch (was %d; expected %d)",
+			   pos[1], data->peap_version);
+		return -1;
+	if (pos[3] != 0) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Unexpected Cryptobinding TLV "
+			   "SubType %d", pos[3]);
+		return -1;
+	pos += 4;
+	os_memcpy(data->binding_nonce, pos, 32);
+	pos += 32; /* Nonce */
+	os_memcpy(buf, crypto_tlv, 60);
+	os_memset(buf + 4 + 4 + 32, 0, 20); /* Compound_MAC */
+	buf[60] = EAP_TYPE_PEAP;
+	wpa_hexdump(MSG_DEBUG, "EAP-PEAP: Compound_MAC data",
+		    buf, sizeof(buf));
+	hmac_sha1(data->cmk, 20, buf, sizeof(buf), mac);
+	if (os_memcmp_const(mac, pos, SHA1_MAC_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Invalid Compound_MAC in "
+			   "cryptobinding TLV");
+		wpa_hexdump(MSG_DEBUG, "EAP-PEAP: Received MAC",
+			    pos, SHA1_MAC_LEN);
+		wpa_hexdump(MSG_DEBUG, "EAP-PEAP: Expected MAC",
+			    mac, SHA1_MAC_LEN);
+		return -1;
+	wpa_printf(MSG_DEBUG, "EAP-PEAP: Valid cryptobinding TLV received");
+	return 0;
+ * eap_tlv_process - Process a received EAP-TLV message and generate a response
+ * @ret: Return values from EAP request validation and processing
+ * @req: EAP-TLV request to be processed. The caller must have validated that
+ * the buffer is large enough to contain full request (hdr->length bytes) and
+ * that the EAP type is EAP_TYPE_TLV.
+ * @resp: Buffer to return a pointer to the allocated response message. This
+ * field should be initialized to %NULL before the call. The value will be
+ * updated if a response message is generated. The caller is responsible for
+ * freeing the allocated message.
+ * @force_failure: Force negotiation to fail
+static int eap_tlv_process(struct eap_sm *sm, struct eap_peap_data *data,
+			   const struct wpabuf *req, struct wpabuf **resp,
+			   int force_failure)
+	size_t left, tlv_len;
+	const u8 *pos;
+	const u8 *result_tlv = NULL, *crypto_tlv = NULL;
+	size_t result_tlv_len = 0, crypto_tlv_len = 0;
+	int tlv_type, mandatory;
+	/* Parse TLVs */
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_TLV, req, &left);
+	if (pos == NULL)
+		return -1;
+	wpa_hexdump(MSG_DEBUG, "EAP-TLV: Received TLVs", pos, left);
+	while (left >= 4) {
+		mandatory = !!(pos[0] & 0x80);
+		tlv_type = WPA_GET_BE16(pos) & 0x3fff;
+		pos += 2;
+		tlv_len = WPA_GET_BE16(pos);
+		pos += 2;
+		left -= 4;
+		if (tlv_len > left) {
+			wpa_printf(MSG_DEBUG, "EAP-TLV: TLV underrun "
+				   "(tlv_len=%lu left=%lu)",
+				   (unsigned long) tlv_len,
+				   (unsigned long) left);
+			return -1;
+		switch (tlv_type) {
+		case EAP_TLV_RESULT_TLV:
+			result_tlv = pos;
+			result_tlv_len = tlv_len;
+			break;
+		case EAP_TLV_CRYPTO_BINDING_TLV:
+			crypto_tlv = pos;
+			crypto_tlv_len = tlv_len;
+			break;
+		default:
+			wpa_printf(MSG_DEBUG, "EAP-TLV: Unsupported TLV Type "
+				   "%d%s", tlv_type,
+				   mandatory ? " (mandatory)" : "");
+			if (mandatory) {
+				/* NAK TLV and ignore all TLVs in this packet.
+				*resp = eap_tlv_build_nak(eap_get_id(req),
+							  tlv_type);
+				return *resp == NULL ? -1 : 0;
+			/* Ignore this TLV, but process other TLVs */
+			break;
+		pos += tlv_len;
+		left -= tlv_len;
+	if (left) {
+		wpa_printf(MSG_DEBUG, "EAP-TLV: Last TLV too short in "
+			   "Request (left=%lu)", (unsigned long) left);
+		return -1;
+	/* Process supported TLVs */
+	if (crypto_tlv && data->crypto_binding != NO_BINDING) {
+		wpa_hexdump(MSG_DEBUG, "EAP-PEAP: Cryptobinding TLV",
+			    crypto_tlv, crypto_tlv_len);
+		if (eap_tlv_validate_cryptobinding(sm, data, crypto_tlv - 4,
+						   crypto_tlv_len + 4) < 0) {
+			if (result_tlv == NULL)
+				return -1;
+			force_failure = 1;
+			crypto_tlv = NULL; /* do not include Cryptobinding TLV
+					    * in response, if the received
+					    * cryptobinding was invalid. */
+	} else if (!crypto_tlv && data->crypto_binding == REQUIRE_BINDING) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: No cryptobinding TLV");
+		return -1;
+	if (result_tlv) {
+		int status, resp_status;
+		wpa_hexdump(MSG_DEBUG, "EAP-TLV: Result TLV",
+			    result_tlv, result_tlv_len);
+		if (result_tlv_len < 2) {
+			wpa_printf(MSG_INFO, "EAP-TLV: Too short Result TLV "
+				   "(len=%lu)",
+				   (unsigned long) result_tlv_len);
+			return -1;
+		status = WPA_GET_BE16(result_tlv);
+		if (status == EAP_TLV_RESULT_SUCCESS) {
+			wpa_printf(MSG_INFO, "EAP-TLV: TLV Result - Success "
+				   "- EAP-TLV/Phase2 Completed");
+			if (force_failure) {
+				wpa_printf(MSG_INFO, "EAP-TLV: Earlier failure"
+					   " - force failed Phase 2");
+				resp_status = EAP_TLV_RESULT_FAILURE;
+			} else {
+				resp_status = EAP_TLV_RESULT_SUCCESS;
+		} else if (status == EAP_TLV_RESULT_FAILURE) {
+			wpa_printf(MSG_INFO, "EAP-TLV: TLV Result - Failure");
+		} else {
+			wpa_printf(MSG_INFO, "EAP-TLV: Unknown TLV Result "
+				   "Status %d", status);
+		*resp = eap_tlv_build_result(sm, data, crypto_tlv != NULL,
+					     eap_get_id(req), resp_status);
+	return 0;
+static int eap_peap_phase2_request(struct eap_sm *sm,
+				   struct wpabuf *req,
+				   struct wpabuf **resp)
+	struct eap_hdr *hdr = wpabuf_mhead(req);
+	size_t len = be_to_host16(hdr->length);
+	u8 *pos;
+	struct eap_method_ret iret;
+	if (len <= sizeof(struct eap_hdr)) {
+		wpa_printf(MSG_INFO, "EAP-PEAP: too short "
+			   "Phase 2 request (len=%lu)", (unsigned long) len);
+		return -1;
+	pos = (u8 *) (hdr + 1);
+	wpa_printf(MSG_DEBUG, "EAP-PEAP: Phase 2 Request: type=%d", *pos);
+	switch (*pos) {
+	case EAP_TYPE_IDENTITY:
+		*resp = eap_sm_buildIdentity(sm, hdr->identifier, 1);
+		break;
+	case EAP_TYPE_TLV:
+		os_memset(&iret, 0, sizeof(iret));
+		if (eap_tlv_process(sm, data, &iret, req, resp,
+				    data->phase2_eap_started &&
+				    !data->phase2_eap_success)) {
+			return -1;
+		if (iret.methodState == METHOD_DONE ||
+		    iret.methodState == METHOD_MAY_CONT) {
+			ret->methodState = iret.methodState;
+			ret->decision = iret.decision;
+			data->phase2_success = 1;
+		break;
+	case EAP_TYPE_EXPANDED:
+#ifdef EAP_TNC
+		if (data->soh) {
+			const u8 *epos;
+			size_t eleft;
+			epos = eap_hdr_validate(EAP_VENDOR_MICROSOFT, 0x21,
+						req, &eleft);
+			if (epos) {
+				struct wpabuf *buf;
+					   "EAP-PEAP: SoH EAP Extensions");
+				buf = tncc_process_soh_request(data->soh,
+							       epos, eleft);
+				if (buf) {
+					*resp = eap_msg_alloc(
+						EAP_VENDOR_MICROSOFT, 0x21,
+						wpabuf_len(buf),
+						hdr->identifier);
+					if (*resp == NULL) {
+						return -1;
+					wpabuf_put_buf(*resp, buf);
+					wpabuf_free(buf);
+					break;
+		/* fall through */
+	default:
+		if (data->phase2_type.vendor == EAP_VENDOR_IETF &&
+		    data->phase2_type.method == EAP_TYPE_NONE) {
+			size_t i;
+			for (i = 0; i < data->num_phase2_types; i++) {
+				if (data->phase2_types[i].vendor !=
+				    EAP_VENDOR_IETF ||
+				    data->phase2_types[i].method != *pos)
+					continue;
+					data->phase2_types[i].vendor;
+					data->phase2_types[i].method;
+				wpa_printf(MSG_DEBUG, "EAP-PEAP: Selected "
+					   "Phase 2 EAP vendor %d method %d",
+					   data->phase2_type.vendor,
+					   data->phase2_type.method);
+				break;
+		if (*pos != data->phase2_type.method ||
+		    *pos == EAP_TYPE_NONE) {
+			if (eap_peer_tls_phase2_nak(data->phase2_types,
+						    data->num_phase2_types,
+						    hdr, resp))
+				return -1;
+			return 0;
+		if (data->phase2_priv == NULL) {
+			data->phase2_method = eap_peer_get_eap_method(
+			if (data->phase2_method) {
+				sm->init_phase2 = 1;
+				data->phase2_priv =
+					data->phase2_method->init(sm);
+				sm->init_phase2 = 0;
+		if (data->phase2_priv == NULL || data->phase2_method == NULL) {
+			wpa_printf(MSG_INFO, "EAP-PEAP: failed to initialize "
+				   "Phase 2 EAP method %d", *pos);
+			return -1;
+		data->phase2_eap_started = 1;
+		*resp = data->phase2_method->process(sm, data->phase2_priv,
+						     &iret, req);
+		if ((iret.methodState == METHOD_DONE ||
+		     iret.methodState == METHOD_MAY_CONT) &&
+		    (iret.decision == DECISION_UNCOND_SUCC ||
+		     iret.decision == DECISION_COND_SUCC)) {
+			data->phase2_eap_success = 1;
+		break;
+	if (*resp == NULL &&
+	    (config->pending_req_identity || config->pending_req_password ||
+	     config->pending_req_otp || config->pending_req_new_password)) {
+		data->pending_phase2_req = wpabuf_alloc_copy(hdr, len);
+	return 0;
+static int eap_peap_decrypt(struct eap_sm *sm, struct eap_peap_data *data,
+			    const struct eap_hdr *req,
+			    const struct wpabuf *in_data,
+			    struct wpabuf **out_data)
+	struct wpabuf *in_decrypted = NULL;
+	int res, skip_change = 0;
+	struct eap_hdr *hdr, *rhdr;
+	struct wpabuf *resp = NULL;
+	size_t len;
+	wpa_printf(MSG_DEBUG, "EAP-PEAP: received %lu bytes encrypted data for"
+		   " Phase 2", (unsigned long) wpabuf_len(in_data));
+	if (data->pending_phase2_req) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Pending Phase 2 request - "
+			   "skip decryption and use old data");
+		/* Clear TLS reassembly state. */
+		eap_peer_tls_reset_input(&data->ssl);
+		in_decrypted = data->pending_phase2_req;
+		data->pending_phase2_req = NULL;
+		skip_change = 1;
+		goto continue_req;
+	if (wpabuf_len(in_data) == 0 && sm->workaround &&
+	    data->phase2_success) {
+		 * Cisco ACS seems to be using TLS ACK to terminate
+		 * EAP-PEAPv0/GTC. Try to reply with TLS ACK.
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Received TLS ACK, but "
+			   "expected data - acknowledge with TLS ACK since "
+			   "Phase 2 has been completed");
+		ret->decision = DECISION_COND_SUCC;
+		return 1;
+	} else if (wpabuf_len(in_data) == 0) {
+		/* Received TLS ACK - requesting more fragments */
+		return eap_peer_tls_encrypt(sm, &data->ssl, EAP_TYPE_PEAP,
+					    data->peap_version,
+					    req->identifier, NULL, out_data);
+	res = eap_peer_tls_decrypt(sm, &data->ssl, in_data, &in_decrypted);
+	if (res)
+		return res;
+continue_req:
+	wpa_hexdump_buf(MSG_DEBUG, "EAP-PEAP: Decrypted Phase 2 EAP",
+			in_decrypted);
+	hdr = wpabuf_mhead(in_decrypted);
+	if (wpabuf_len(in_decrypted) == 5 && hdr->code == EAP_CODE_REQUEST &&
+	    be_to_host16(hdr->length) == 5 &&
+	    eap_get_type(in_decrypted) == EAP_TYPE_IDENTITY) {
+		/* At least FreeRADIUS seems to send full EAP header with
+		 * EAP Request Identity */
+		skip_change = 1;
+	if (wpabuf_len(in_decrypted) >= 5 && hdr->code == EAP_CODE_REQUEST &&
+	    eap_get_type(in_decrypted) == EAP_TYPE_TLV) {
+		skip_change = 1;
+	if (data->peap_version == 0 && !skip_change) {
+		struct eap_hdr *nhdr;
+		struct wpabuf *nmsg = wpabuf_alloc(sizeof(struct eap_hdr) +
+						   wpabuf_len(in_decrypted));
+		if (nmsg == NULL) {
+			wpabuf_free(in_decrypted);
+			return 0;
+		nhdr = wpabuf_put(nmsg, sizeof(*nhdr));
+		wpabuf_put_buf(nmsg, in_decrypted);
+		nhdr->code = req->code;
+		nhdr->identifier = req->identifier;
+		nhdr->length = host_to_be16(sizeof(struct eap_hdr) +
+		in_decrypted = nmsg;
+	if (wpabuf_len(in_decrypted) < sizeof(*hdr)) {
+		wpa_printf(MSG_INFO, "EAP-PEAP: Too short Phase 2 "
+			   "EAP frame (len=%lu)",
+			   (unsigned long) wpabuf_len(in_decrypted));
+		return 0;
+	len = be_to_host16(hdr->length);
+	if (len > wpabuf_len(in_decrypted)) {
+		wpa_printf(MSG_INFO, "EAP-PEAP: Length mismatch in "
+			   "Phase 2 EAP frame (len=%lu hdr->length=%lu)",
+			   (unsigned long) wpabuf_len(in_decrypted),
+		return 0;
+	if (len < wpabuf_len(in_decrypted)) {
+		wpa_printf(MSG_INFO, "EAP-PEAP: Odd.. Phase 2 EAP header has "
+			   "shorter length than full decrypted data "
+			   "(%lu < %lu)",
+	wpa_printf(MSG_DEBUG, "EAP-PEAP: received Phase 2: code=%d "
+		   "identifier=%d length=%lu", hdr->code, hdr->identifier,
+	switch (hdr->code) {
+		if (eap_peap_phase2_request(sm, data, ret, in_decrypted,
+					    &resp)) {
+			wpa_printf(MSG_INFO, "EAP-PEAP: Phase2 Request "
+				   "processing failed");
+			return 0;
+		break;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Phase 2 Success");
+		if (data->peap_version == 1) {
+			/* EAP-Success within TLS tunnel is used to indicate
+			 * shutdown of the TLS channel. The authentication has
+			 * been completed. */
+			if (data->phase2_eap_started &&
+			    !data->phase2_eap_success) {
+				wpa_printf(MSG_DEBUG, "EAP-PEAP: Phase 2 "
+					   "Success used to indicate success, "
+					   "but Phase 2 EAP was not yet "
+					   "completed successfully");
+				ret->methodState = METHOD_DONE;
+				return 0;
+			wpa_printf(MSG_DEBUG, "EAP-PEAP: Version 1 - "
+				   "EAP-Success within TLS tunnel - "
+				   "authentication completed");
+			if (data->peap_outer_success == 2) {
+				wpa_printf(MSG_DEBUG, "EAP-PEAP: Use TLS ACK "
+					   "to finish authentication");
+				return 1;
+			} else if (data->peap_outer_success == 1) {
+				/* Reply with EAP-Success within the TLS
+				 * channel to complete the authentication. */
+				resp = wpabuf_alloc(sizeof(struct eap_hdr));
+				if (resp) {
+					rhdr = wpabuf_put(resp, sizeof(*rhdr));
+					rhdr->code = EAP_CODE_SUCCESS;
+					rhdr->identifier = hdr->identifier;
+					rhdr->length =
+						host_to_be16(sizeof(*rhdr));
+			} else {
+				/* No EAP-Success expected for Phase 1 (outer,
+				 * unencrypted auth), so force EAP state
+				 * machine to SUCCESS state. */
+				sm->peap_done = TRUE;
+		} else {
+			/* FIX: ? */
+		break;
+	case EAP_CODE_FAILURE:
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Phase 2 Failure");
+		ret->decision = DECISION_FAIL;
+		ret->allowNotifications = FALSE;
+		/* Reply with EAP-Failure within the TLS channel to complete
+		 * failure reporting. */
+		if (resp) {
+			rhdr->code = EAP_CODE_FAILURE;
+			rhdr->length = host_to_be16(sizeof(*rhdr));
+		break;
+	default:
+		wpa_printf(MSG_INFO, "EAP-PEAP: Unexpected code=%d in "
+			   "Phase 2 EAP header", hdr->code);
+		break;
+	if (resp) {
+		int skip_change2 = 0;
+		struct wpabuf *rmsg, buf;
+		wpa_hexdump_buf_key(MSG_DEBUG,
+				    "EAP-PEAP: Encrypting Phase 2 data", resp);
+		/* PEAP version changes */
+		if (wpabuf_len(resp) >= 5 &&
+		    wpabuf_head_u8(resp)[0] == EAP_CODE_RESPONSE &&
+		    eap_get_type(resp) == EAP_TYPE_TLV)
+			skip_change2 = 1;
+		rmsg = resp;
+		if (data->peap_version == 0 && !skip_change2) {
+			wpabuf_set(&buf, wpabuf_head_u8(resp) +
+				   sizeof(struct eap_hdr),
+				   wpabuf_len(resp) - sizeof(struct eap_hdr));
+			rmsg = &buf;
+		if (eap_peer_tls_encrypt(sm, &data->ssl, EAP_TYPE_PEAP,
+					 data->peap_version, req->identifier,
+					 rmsg, out_data)) {
+			wpa_printf(MSG_INFO, "EAP-PEAP: Failed to encrypt "
+				   "a Phase 2 frame");
+		wpabuf_free(resp);
+	return 0;
+static struct wpabuf * eap_peap_process(struct eap_sm *sm, void *priv,
+					const struct wpabuf *reqData)
+	const struct eap_hdr *req;
+	size_t left;
+	int res;
+	u8 flags, id;
+	struct wpabuf *resp;
+	const u8 *pos;
+	struct wpabuf msg;
+	pos = eap_peer_tls_process_init(sm, &data->ssl, EAP_TYPE_PEAP, ret,
+					reqData, &left, &flags);
+	if (pos == NULL)
+		return NULL;
+	req = wpabuf_head(reqData);
+	id = req->identifier;
+	if (flags & EAP_TLS_FLAGS_START) {
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Start (server ver=%d, own "
+			   "ver=%d)", flags & EAP_TLS_VERSION_MASK,
+			data->peap_version);
+		if ((flags & EAP_TLS_VERSION_MASK) < data->peap_version)
+			data->peap_version = flags & EAP_TLS_VERSION_MASK;
+		if (data->force_peap_version >= 0 &&
+		    data->force_peap_version != data->peap_version) {
+			wpa_printf(MSG_WARNING, "EAP-PEAP: Failed to select "
+				   "forced PEAP version %d",
+			return NULL;
+		wpa_printf(MSG_DEBUG, "EAP-PEAP: Using PEAP version %d",
+		left = 0; /* make sure that this frame is empty, even though it
+			   * should always be, anyway */
+	wpabuf_set(&msg, pos, left);
+	resp = NULL;
+	if (tls_connection_established(sm->ssl_ctx, data->ssl.conn) &&
+	    !data->resuming) {
+		res = eap_peap_decrypt(sm, data, ret, req, &msg, &resp);
+	} else {
+		res = eap_peer_tls_process_helper(sm, &data->ssl,
+						  EAP_TYPE_PEAP,
+						  data->peap_version, id, &msg,
+						  &resp);
+		if (res < 0) {
+				   "EAP-PEAP: TLS processing failed");
+			return resp;
+		if (tls_connection_established(sm->ssl_ctx, data->ssl.conn)) {
+			char *label;
+				   "EAP-PEAP: TLS done, proceed to Phase 2");
+			/* draft-josefsson-ppext-eap-tls-eap-05.txt
+			 * specifies that PEAPv1 would use "client PEAP
+			 * encryption" as the label. However, most existing
+			 * PEAPv1 implementations seem to be using the old
+			 * label, "client EAP encryption", instead. Use the old
+			 * label by default, but allow it to be configured with
+			 * phase1 parameter peaplabel=1. */
+			if (data->force_new_label)
+				label = "client PEAP encryption";
+			else
+				label = "client EAP encryption";
+			wpa_printf(MSG_DEBUG, "EAP-PEAP: using label '%s' in "
+				   "key derivation", label);
+			data->key_data =
+				eap_peer_tls_derive_key(sm, &data->ssl, label,
+							EAP_TLS_KEY_LEN);
+						"EAP-PEAP: Derived key",
+						data->key_data,
+						EAP_TLS_KEY_LEN);
+			} else {
+				wpa_printf(MSG_DEBUG, "EAP-PEAP: Failed to "
+					   "derive key");
+			data->session_id =
+				eap_peer_tls_derive_session_id(sm, &data->ssl,
+							       EAP_TYPE_PEAP,
+							       &data->id_len);
+			if (data->session_id) {
+					    "EAP-PEAP: Derived Session-Id",
+					    data->session_id, data->id_len);
+			} else {
+				wpa_printf(MSG_ERROR, "EAP-PEAP: Failed to "
+					   "derive Session-Id");
+			if (sm->workaround && data->resuming) {
+				 * At least few RADIUS servers (Aegis v1.1.6;
+				 * but not v1.1.4; and Cisco ACS) seem to be
+				 * terminating PEAPv1 (Aegis) or PEAPv0 (Cisco
+				 * ACS) session resumption with outer
+				 * EAP-Success. This does not seem to follow
+				 * draft-josefsson-pppext-eap-tls-eap-05.txt
+				 * section 4.2, so only allow this if EAP
+				 * workarounds are enabled.
+				wpa_printf(MSG_DEBUG, "EAP-PEAP: Workaround - "
+					   "allow outer EAP-Success to "
+					   "terminate PEAP resumption");
+			data->resuming = 0;
+		if (res == 2) {
+			 * Application data included in the handshake message.
+			data->pending_phase2_req = resp;
+			resp = NULL;
+					       &resp);
+	if (ret->methodState == METHOD_DONE) {
+	if (res == 1) {
+		return eap_peer_tls_build_ack(id, EAP_TYPE_PEAP,
+	return resp;
+static Boolean eap_peap_has_reauth_data(struct eap_sm *sm, void *priv)
+	return tls_connection_established(sm->ssl_ctx, data->ssl.conn) &&
+		data->phase2_success;
+static void eap_peap_deinit_for_reauth(struct eap_sm *sm, void *priv)
+	data->crypto_binding_used = 0;
+static void * eap_peap_init_for_reauth(struct eap_sm *sm, void *priv)
+	data->session_id = NULL;
+	if (eap_peer_tls_reauth_init(sm, &data->ssl)) {
+		os_free(data);
+		return NULL;
+	if (data->phase2_priv && data->phase2_method &&
+	    data->phase2_method->init_for_reauth)
+		data->phase2_method->init_for_reauth(sm, data->phase2_priv);
+	data->phase2_success = 0;
+	data->phase2_eap_success = 0;
+	data->phase2_eap_started = 0;
+	data->resuming = 1;
+	data->reauth = 1;
+	return priv;
+static int eap_peap_get_status(struct eap_sm *sm, void *priv, char *buf,
+			       size_t buflen, int verbose)
+	int len, ret;
+	len = eap_peer_tls_status(sm, &data->ssl, buf, buflen, verbose);
+		ret = os_snprintf(buf + len, buflen - len,
+				  "EAP-PEAPv%d Phase2 method=%s\n",
+				  data->phase2_method->name);
+		if (os_snprintf_error(buflen - len, ret))
+			return len;
+		len += ret;
+	return len;
+static Boolean eap_peap_isKeyAvailable(struct eap_sm *sm, void *priv)
+	return data->key_data != NULL && data->phase2_success;
+static u8 * eap_peap_getKey(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+	if (data->key_data == NULL || !data->phase2_success)
+		return NULL;
+	key = os_malloc(EAP_TLS_KEY_LEN);
+	if (key == NULL)
+		return NULL;
+	*len = EAP_TLS_KEY_LEN;
+	if (data->crypto_binding_used) {
+		u8 csk[128];
+		 * Note: It looks like Microsoft implementation requires null
+		 * termination for this label while the one used for deriving
+		 * IPMK|CMK did not use null termination.
+		if (peap_prfplus(data->peap_version, data->ipmk, 40,
+				 "Session Key Generating Function",
+				 (u8 *) "\00", 1, csk, sizeof(csk)) < 0) {
+			os_free(key);
+			return NULL;
+		wpa_hexdump_key(MSG_DEBUG, "EAP-PEAP: CSK", csk, sizeof(csk));
+		os_memcpy(key, csk, EAP_TLS_KEY_LEN);
+		wpa_hexdump(MSG_DEBUG, "EAP-PEAP: Derived key",
+			    key, EAP_TLS_KEY_LEN);
+	} else
+		os_memcpy(key, data->key_data, EAP_TLS_KEY_LEN);
+	return key;
+static u8 * eap_peap_get_session_id(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *id;
+	if (data->session_id == NULL || !data->phase2_success)
+		return NULL;
+	id = os_malloc(data->id_len);
+	if (id == NULL)
+		return NULL;
+	*len = data->id_len;
+	os_memcpy(id, data->session_id, data->id_len);
+	return id;
+	struct eap_method *eap;
+	int ret;
+	eap = eap_peer_method_alloc(EAP_PEER_METHOD_INTERFACE_VERSION,
+				    EAP_VENDOR_IETF, EAP_TYPE_PEAP, "PEAP");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_peap_init;
+	eap->deinit = eap_peap_deinit;
+	eap->process = eap_peap_process;
+	eap->isKeyAvailable = eap_peap_isKeyAvailable;
+	eap->getKey = eap_peap_getKey;
+	eap->get_status = eap_peap_get_status;
+	eap->has_reauth_data = eap_peap_has_reauth_data;
+	eap->deinit_for_reauth = eap_peap_deinit_for_reauth;
+	eap->init_for_reauth = eap_peap_init_for_reauth;
+	eap->getSessionId = eap_peap_get_session_id;
+	ret = eap_peer_method_register(eap);
+	if (ret)
+		eap_peer_method_free(eap);
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_proxy.h b/freebsd/contrib/wpa/src/eap_peer/eap_proxy.h
index 00000000000..23cdbe698b3
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_proxy.h
@@ -0,0 +1,49 @@
+ * EAP proxy definitions
+ * Copyright (c) 2011-2013 Qualcomm Atheros, Inc.
+#ifndef EAP_PROXY_H
+#define EAP_PROXY_H
+struct eap_proxy_sm;
+struct eapol_callbacks;
+struct eap_sm;
+struct eap_peer_config;
+enum eap_proxy_status {
+	EAP_PROXY_FAILURE = 0x00,
+	EAP_PROXY_SUCCESS
+struct eap_proxy_sm *
+eap_proxy_init(void *eapol_ctx, struct eapol_callbacks *eapol_cb,
+	       void *msg_ctx);
+void eap_proxy_deinit(struct eap_proxy_sm *eap_proxy);
+int eap_proxy_key_available(struct eap_proxy_sm *sm);
+const u8 * eap_proxy_get_eapKeyData(struct eap_proxy_sm *sm, size_t *len);
+struct wpabuf * eap_proxy_get_eapRespData(struct eap_proxy_sm *sm);
+int eap_proxy_sm_step(struct eap_proxy_sm *sm, struct eap_sm *eap_sm);
+eap_proxy_packet_update(struct eap_proxy_sm *eap_proxy, u8 *eapReqData,
+			int eapReqDataLen);
+int eap_proxy_sm_get_status(struct eap_proxy_sm *sm, char *buf, size_t buflen,
+			    int verbose);
+int eap_proxy_get_imsi(struct eap_proxy_sm *eap_proxy, char *imsi_buf,
+		       size_t *imsi_len);
+int eap_proxy_notify_config(struct eap_proxy_sm *sm,
+			    struct eap_peer_config *config);
+#endif /* EAP_PROXY_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_psk.c b/freebsd/contrib/wpa/src/eap_peer/eap_psk.c
index 00000000000..f91c9b3932a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_psk.c
@@ -0,0 +1,504 @@
+#include <machine/rtems-bsd-user-space.h>
+ * EAP peer method: EAP-PSK (RFC 4764)
+ * Note: EAP-PSK is an EAP authentication method and as such, completely
+ * different from WPA-PSK. This file is not needed for WPA-PSK functionality.
+#include "includes.h"
+#include "common.h"
+#include "crypto/aes_wrap.h"
+#include "crypto/random.h"
+#include "eap_common/eap_psk_common.h"
+#include "eap_i.h"
+struct eap_psk_data {
+	enum { PSK_INIT, PSK_MAC_SENT, PSK_DONE } state;
+	u8 rand_p[EAP_PSK_RAND_LEN];
+	u8 rand_s[EAP_PSK_RAND_LEN];
+	u8 ak[EAP_PSK_AK_LEN], kdk[EAP_PSK_KDK_LEN], tek[EAP_PSK_TEK_LEN];
+	u8 *id_s, *id_p;
+	size_t id_s_len, id_p_len;
+	u8 msk[EAP_MSK_LEN];
+	u8 emsk[EAP_EMSK_LEN];
+static void * eap_psk_init(struct eap_sm *sm)
+	struct eap_psk_data *data;
+	password = eap_get_config_password(sm, &password_len);
+	if (!password || password_len != 16) {
+		wpa_printf(MSG_INFO, "EAP-PSK: 16-octet pre-shared key not "
+			   "configured");
+		return NULL;
+	if (data == NULL)
+		return NULL;
+	if (eap_psk_key_setup(password, data->ak, data->kdk)) {
+		os_free(data);
+		return NULL;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PSK: AK", data->ak, EAP_PSK_AK_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PSK: KDK", data->kdk, EAP_PSK_KDK_LEN);
+	data->state = PSK_INIT;
+	identity = eap_get_config_identity(sm, &identity_len);
+	if (identity) {
+		data->id_p = os_malloc(identity_len);
+		if (data->id_p)
+			os_memcpy(data->id_p, identity, identity_len);
+		data->id_p_len = identity_len;
+	if (data->id_p == NULL) {
+		wpa_printf(MSG_INFO, "EAP-PSK: could not get own identity");
+		os_free(data);
+		return NULL;
+	return data;
+static void eap_psk_deinit(struct eap_sm *sm, void *priv)
+	struct eap_psk_data *data = priv;
+	os_free(data->id_s);
+	os_free(data->id_p);
+static struct wpabuf * eap_psk_process_1(struct eap_psk_data *data,
+	const struct eap_psk_hdr_1 *hdr1;
+	struct eap_psk_hdr_2 *hdr2;
+	u8 *buf, *pos;
+	size_t buflen, len;
+	const u8 *cpos;
+	wpa_printf(MSG_DEBUG, "EAP-PSK: in INIT state");
+	cpos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_PSK, reqData, &len);
+	hdr1 = (const struct eap_psk_hdr_1 *) cpos;
+	if (cpos == NULL || len < sizeof(*hdr1)) {
+		wpa_printf(MSG_INFO, "EAP-PSK: Invalid first message "
+			   "length (%lu; expected %lu or more)",
+			   (unsigned long) sizeof(*hdr1));
+		ret->ignore = TRUE;
+		return NULL;
+	wpa_printf(MSG_DEBUG, "EAP-PSK: Flags=0x%x", hdr1->flags);
+	if (EAP_PSK_FLAGS_GET_T(hdr1->flags) != 0) {
+		wpa_printf(MSG_INFO, "EAP-PSK: Unexpected T=%d (expected 0)",
+			   EAP_PSK_FLAGS_GET_T(hdr1->flags));
+		return NULL;
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: RAND_S", hdr1->rand_s,
+		    EAP_PSK_RAND_LEN);
+	os_memcpy(data->rand_s, hdr1->rand_s, EAP_PSK_RAND_LEN);
+	data->id_s_len = len - sizeof(*hdr1);
+	data->id_s = os_malloc(data->id_s_len);
+	if (data->id_s == NULL) {
+		wpa_printf(MSG_ERROR, "EAP-PSK: Failed to allocate memory for "
+			   "ID_S (len=%lu)", (unsigned long) data->id_s_len);
+		return NULL;
+	os_memcpy(data->id_s, (u8 *) (hdr1 + 1), data->id_s_len);
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-PSK: ID_S",
+			  data->id_s, data->id_s_len);
+	if (random_get_bytes(data->rand_p, EAP_PSK_RAND_LEN)) {
+		wpa_printf(MSG_ERROR, "EAP-PSK: Failed to get random data");
+		return NULL;
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_PSK,
+			     sizeof(*hdr2) + data->id_p_len, EAP_CODE_RESPONSE,
+			     eap_get_id(reqData));
+	if (resp == NULL)
+		return NULL;
+	hdr2 = wpabuf_put(resp, sizeof(*hdr2));
+	hdr2->flags = EAP_PSK_FLAGS_SET_T(1); /* T=1 */
+	os_memcpy(hdr2->rand_s, hdr1->rand_s, EAP_PSK_RAND_LEN);
+	os_memcpy(hdr2->rand_p, data->rand_p, EAP_PSK_RAND_LEN);
+	wpabuf_put_data(resp, data->id_p, data->id_p_len);
+	/* MAC_P = OMAC1-AES-128(AK, ID_P||ID_S||RAND_S||RAND_P) */
+	buflen = data->id_p_len + data->id_s_len + 2 * EAP_PSK_RAND_LEN;
+	buf = os_malloc(buflen);
+	if (buf == NULL) {
+		return NULL;
+	os_memcpy(buf, data->id_p, data->id_p_len);
+	pos = buf + data->id_p_len;
+	os_memcpy(pos, data->id_s, data->id_s_len);
+	pos += data->id_s_len;
+	os_memcpy(pos, hdr1->rand_s, EAP_PSK_RAND_LEN);
+	pos += EAP_PSK_RAND_LEN;
+	os_memcpy(pos, data->rand_p, EAP_PSK_RAND_LEN);
+	if (omac1_aes_128(data->ak, buf, buflen, hdr2->mac_p)) {
+		os_free(buf);
+		return NULL;
+	os_free(buf);
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: RAND_P", hdr2->rand_p,
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: MAC_P", hdr2->mac_p, EAP_PSK_MAC_LEN);
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-PSK: ID_P",
+			  data->id_p, data->id_p_len);
+	data->state = PSK_MAC_SENT;
+	return resp;
+static struct wpabuf * eap_psk_process_3(struct eap_psk_data *data,
+	const struct eap_psk_hdr_3 *hdr3;
+	struct eap_psk_hdr_4 *hdr4;
+	u8 *buf, *rpchannel, nonce[16], *decrypted;
+	const u8 *pchannel, *tag, *msg;
+	u8 mac[EAP_PSK_MAC_LEN];
+	size_t buflen, left, data_len, len, plen;
+	int failed = 0;
+	const u8 *pos;
+	wpa_printf(MSG_DEBUG, "EAP-PSK: in MAC_SENT state");
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_PSK,
+			       reqData, &len);
+	hdr3 = (const struct eap_psk_hdr_3 *) pos;
+	if (pos == NULL || len < sizeof(*hdr3)) {
+		wpa_printf(MSG_INFO, "EAP-PSK: Invalid third message "
+			   (unsigned long) sizeof(*hdr3));
+		return NULL;
+	left = len - sizeof(*hdr3);
+	pchannel = (const u8 *) (hdr3 + 1);
+	wpa_printf(MSG_DEBUG, "EAP-PSK: Flags=0x%x", hdr3->flags);
+	if (EAP_PSK_FLAGS_GET_T(hdr3->flags) != 2) {
+		wpa_printf(MSG_INFO, "EAP-PSK: Unexpected T=%d (expected 2)",
+			   EAP_PSK_FLAGS_GET_T(hdr3->flags));
+		return NULL;
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: RAND_S", hdr3->rand_s,
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: MAC_S", hdr3->mac_s, EAP_PSK_MAC_LEN);
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: PCHANNEL", pchannel, left);
+	if (left < 4 + 16 + 1) {
+		wpa_printf(MSG_INFO, "EAP-PSK: Too short PCHANNEL data in "
+			   "third message (len=%lu, expected 21)",
+		return NULL;
+	/* MAC_S = OMAC1-AES-128(AK, ID_S||RAND_P) */
+	buflen = data->id_s_len + EAP_PSK_RAND_LEN;
+	if (buf == NULL)
+		return NULL;
+	os_memcpy(buf, data->id_s, data->id_s_len);
+	os_memcpy(buf + data->id_s_len, data->rand_p, EAP_PSK_RAND_LEN);
+	if (omac1_aes_128(data->ak, buf, buflen, mac)) {
+		os_free(buf);
+		return NULL;
+	os_free(buf);
+	if (os_memcmp_const(mac, hdr3->mac_s, EAP_PSK_MAC_LEN) != 0) {
+		wpa_printf(MSG_WARNING, "EAP-PSK: Invalid MAC_S in third "
+			   "message");
+		return NULL;
+	wpa_printf(MSG_DEBUG, "EAP-PSK: MAC_S verified successfully");
+	if (eap_psk_derive_keys(data->kdk, data->rand_p, data->tek,
+				data->msk, data->emsk)) {
+		return NULL;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PSK: TEK", data->tek, EAP_PSK_TEK_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PSK: MSK", data->msk, EAP_MSK_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "EAP-PSK: EMSK", data->emsk, EAP_EMSK_LEN);
+	os_memset(nonce, 0, 12);
+	os_memcpy(nonce + 12, pchannel, 4);
+	pchannel += 4;
+	left -= 4;
+	tag = pchannel;
+	pchannel += 16;
+	left -= 16;
+	msg = pchannel;
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PSK: PCHANNEL - nonce",
+		    nonce, sizeof(nonce));
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PSK: PCHANNEL - hdr",
+		    wpabuf_head(reqData), 5);
+	wpa_hexdump(MSG_MSGDUMP, "EAP-PSK: PCHANNEL - cipher msg", msg, left);
+	decrypted = os_malloc(left);
+	if (decrypted == NULL) {
+		return NULL;
+	os_memcpy(decrypted, msg, left);
+	if (aes_128_eax_decrypt(data->tek, nonce, sizeof(nonce),
+				sizeof(struct eap_hdr) + 1 +
+				sizeof(*hdr3) - EAP_PSK_MAC_LEN, decrypted,
+				left, tag)) {
+		wpa_printf(MSG_WARNING, "EAP-PSK: PCHANNEL decryption failed");
+		os_free(decrypted);
+		return NULL;
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: Decrypted PCHANNEL message",
+		    decrypted, left);
+	/* Verify R flag */
+	switch (decrypted[0] >> 6) {
+	case EAP_PSK_R_FLAG_CONT:
+		wpa_printf(MSG_DEBUG, "EAP-PSK: R flag - CONT - unsupported");
+		failed = 1;
+		break;
+	case EAP_PSK_R_FLAG_DONE_SUCCESS:
+		wpa_printf(MSG_DEBUG, "EAP-PSK: R flag - DONE_SUCCESS");
+		break;
+	case EAP_PSK_R_FLAG_DONE_FAILURE:
+		wpa_printf(MSG_DEBUG, "EAP-PSK: R flag - DONE_FAILURE");
+		wpa_printf(MSG_INFO, "EAP-PSK: Authentication server rejected "
+			   "authentication");
+		failed = 1;
+		break;
+	data_len = 1;
+	if ((decrypted[0] & EAP_PSK_E_FLAG) && left > 1)
+		data_len++;
+	plen = sizeof(*hdr4) + 4 + 16 + data_len;
+	resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_PSK, plen,
+			     EAP_CODE_RESPONSE, eap_get_id(reqData));
+		return NULL;
+	hdr4 = wpabuf_put(resp, sizeof(*hdr4));
+	hdr4->flags = EAP_PSK_FLAGS_SET_T(3); /* T=3 */
+	os_memcpy(hdr4->rand_s, hdr3->rand_s, EAP_PSK_RAND_LEN);
+	rpchannel = wpabuf_put(resp, 4 + 16 + data_len);
+	/* nonce++ */
+	inc_byte_array(nonce, sizeof(nonce));
+	os_memcpy(rpchannel, nonce + 12, 4);
+	if (decrypted[0] & EAP_PSK_E_FLAG) {
+		wpa_printf(MSG_DEBUG, "EAP-PSK: Unsupported E (Ext) flag");
+		failed = 1;
+		rpchannel[4 + 16] = (EAP_PSK_R_FLAG_DONE_FAILURE << 6) |
+			EAP_PSK_E_FLAG;
+		if (left > 1) {
+			/* Add empty EXT_Payload with same EXT_Type */
+			rpchannel[4 + 16 + 1] = decrypted[1];
+	} else if (failed)
+		rpchannel[4 + 16] = EAP_PSK_R_FLAG_DONE_FAILURE << 6;
+	else
+		rpchannel[4 + 16] = EAP_PSK_R_FLAG_DONE_SUCCESS << 6;
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: reply message (plaintext)",
+		    rpchannel + 4 + 16, data_len);
+	if (aes_128_eax_encrypt(data->tek, nonce, sizeof(nonce),
+				wpabuf_head(resp),
+				sizeof(struct eap_hdr) + 1 + sizeof(*hdr4),
+				rpchannel + 4 + 16, data_len, rpchannel + 4)) {
+		return NULL;
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: reply message (PCHANNEL)",
+		    rpchannel, 4 + 16 + data_len);
+	wpa_printf(MSG_DEBUG, "EAP-PSK: Completed %ssuccessfully",
+		   failed ? "un" : "");
+	data->state = PSK_DONE;
+	ret->decision = failed ? DECISION_FAIL : DECISION_UNCOND_SUCC;
+	return resp;
+static struct wpabuf * eap_psk_process(struct eap_sm *sm, void *priv,
+	const u8 *pos;
+	size_t len;
+	pos = eap_hdr_validate(EAP_VENDOR_IETF, EAP_TYPE_PSK, reqData, &len);
+	if (pos == NULL) {
+		return NULL;
+	ret->ignore = FALSE;
+	ret->methodState = METHOD_MAY_CONT;
+	ret->allowNotifications = TRUE;
+	switch (data->state) {
+	case PSK_INIT:
+		resp = eap_psk_process_1(data, ret, reqData);
+		break;
+	case PSK_MAC_SENT:
+		resp = eap_psk_process_3(data, ret, reqData);
+		break;
+	case PSK_DONE:
+		wpa_printf(MSG_DEBUG, "EAP-PSK: in DONE state - ignore "
+			   "unexpected message");
+		return NULL;
+	return resp;
+static Boolean eap_psk_isKeyAvailable(struct eap_sm *sm, void *priv)
+	return data->state == PSK_DONE;
+static u8 * eap_psk_getKey(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+	if (data->state != PSK_DONE)
+		return NULL;
+	key = os_malloc(EAP_MSK_LEN);
+	if (key == NULL)
+		return NULL;
+	*len = EAP_MSK_LEN;
+	os_memcpy(key, data->msk, EAP_MSK_LEN);
+	return key;
+static u8 * eap_psk_get_session_id(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *id;
+		return NULL;
+	*len = 1 + 2 * EAP_PSK_RAND_LEN;
+	id = os_malloc(*len);
+	if (id == NULL)
+		return NULL;
+	id[0] = EAP_TYPE_PSK;
+	os_memcpy(id + 1, data->rand_p, EAP_PSK_RAND_LEN);
+	os_memcpy(id + 1 + EAP_PSK_RAND_LEN, data->rand_s, EAP_PSK_RAND_LEN);
+	wpa_hexdump(MSG_DEBUG, "EAP-PSK: Derived Session-Id", id, *len);
+	return id;
+static u8 * eap_psk_get_emsk(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+		return NULL;
+	key = os_malloc(EAP_EMSK_LEN);
+	if (key == NULL)
+		return NULL;
+	*len = EAP_EMSK_LEN;
+	os_memcpy(key, data->emsk, EAP_EMSK_LEN);
+	return key;
+int eap_peer_psk_register(void)
+	int ret;
+				    EAP_VENDOR_IETF, EAP_TYPE_PSK, "PSK");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_psk_init;
+	eap->deinit = eap_psk_deinit;
+	eap->process = eap_psk_process;
+	eap->isKeyAvailable = eap_psk_isKeyAvailable;
+	eap->getKey = eap_psk_getKey;
+	eap->getSessionId = eap_psk_get_session_id;
+	eap->get_emsk = eap_psk_get_emsk;
+	if (ret)
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_tls.c b/freebsd/contrib/wpa/src/eap_peer/eap_tls.c
new file mode 100644
index 00000000000..8ca6db9ccde
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_tls.c
@@ -0,0 +1,441 @@
+ * EAP peer method: EAP-TLS (RFC 2716)
+ * Copyright (c) 2004-2008, 2012, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "eap_i.h"
+#include "eap_config.h"
+static void eap_tls_deinit(struct eap_sm *sm, void *priv);
+struct eap_tls_data {
+	u8 *key_data;
+	u8 *session_id;
+	size_t id_len;
+	void *ssl_ctx;
+	u8 eap_type;
+static void * eap_tls_init(struct eap_sm *sm)
+	struct eap_tls_data *data;
+	if (config == NULL ||
+	    ((sm->init_phase2 ? config->private_key2 : config->private_key)
+	     == NULL &&
+	     (sm->init_phase2 ? config->engine2 : config->engine) == 0)) {
+		wpa_printf(MSG_INFO, "EAP-TLS: Private key not configured");
+		return NULL;
+	if (data == NULL)
+		return NULL;
+	data->ssl_ctx = sm->init_phase2 && sm->ssl_ctx2 ? sm->ssl_ctx2 :
+		sm->ssl_ctx;
+	if (eap_peer_tls_ssl_init(sm, &data->ssl, config, EAP_TYPE_TLS)) {
+		wpa_printf(MSG_INFO, "EAP-TLS: Failed to initialize SSL.");
+		eap_tls_deinit(sm, data);
+		if (config->engine) {
+			wpa_printf(MSG_DEBUG, "EAP-TLS: Requesting Smartcard "
+				   "PIN");
+			eap_sm_request_pin(sm);
+			sm->ignore = TRUE;
+		} else if (config->private_key && !config->private_key_passwd)
+			wpa_printf(MSG_DEBUG, "EAP-TLS: Requesting private "
+				   "key passphrase");
+			eap_sm_request_passphrase(sm);
+		return NULL;
+	data->eap_type = EAP_TYPE_TLS;
+	return data;
+#ifdef EAP_UNAUTH_TLS
+static void * eap_unauth_tls_init(struct eap_sm *sm)
+	struct eap_peer_config *config = eap_get_config(sm);
+	if (data == NULL)
+		return NULL;
+		sm->ssl_ctx;
+				  EAP_UNAUTH_TLS_TYPE)) {
+		return NULL;
+	data->eap_type = EAP_UNAUTH_TLS_TYPE;
+	return data;
+#endif /* EAP_UNAUTH_TLS */
+#ifdef CONFIG_HS20
+static void * eap_wfa_unauth_tls_init(struct eap_sm *sm)
+	if (data == NULL)
+		return NULL;
+		sm->ssl_ctx;
+				  EAP_WFA_UNAUTH_TLS_TYPE)) {
+		return NULL;
+	data->eap_type = EAP_WFA_UNAUTH_TLS_TYPE;
+	return data;
+#endif /* CONFIG_HS20 */
+static void eap_tls_free_key(struct eap_tls_data *data)
+		bin_clear_free(data->key_data, EAP_TLS_KEY_LEN + EAP_EMSK_LEN);
+	struct eap_tls_data *data = priv;
+	if (data == NULL)
+		return;
+	eap_tls_free_key(data);
+	os_free(data);
+static struct wpabuf * eap_tls_failure(struct eap_sm *sm,
+				       struct eap_tls_data *data,
+				       struct eap_method_ret *ret, int res,
+				       struct wpabuf *resp, u8 id)
+	wpa_printf(MSG_DEBUG, "EAP-TLS: TLS processing failed");
+	if (resp) {
+		 * This is likely an alert message, so send it instead of just
+		 * ACKing the error.
+		return resp;
+	return eap_peer_tls_build_ack(id, data->eap_type, 0);
+static void eap_tls_success(struct eap_sm *sm, struct eap_tls_data *data,
+			    struct eap_method_ret *ret)
+	wpa_printf(MSG_DEBUG, "EAP-TLS: Done");
+	ret->decision = DECISION_UNCOND_SUCC;
+	data->key_data = eap_peer_tls_derive_key(sm, &data->ssl,
+						 "client EAP encryption",
+						 EAP_TLS_KEY_LEN +
+						 EAP_EMSK_LEN);
+		wpa_hexdump_key(MSG_DEBUG, "EAP-TLS: Derived key",
+				data->key_data, EAP_TLS_KEY_LEN);
+		wpa_hexdump_key(MSG_DEBUG, "EAP-TLS: Derived EMSK",
+				data->key_data + EAP_TLS_KEY_LEN,
+				EAP_EMSK_LEN);
+	} else {
+		wpa_printf(MSG_INFO, "EAP-TLS: Failed to derive key");
+	data->session_id = eap_peer_tls_derive_session_id(sm, &data->ssl,
+							  EAP_TYPE_TLS,
+			                                  &data->id_len);
+		wpa_hexdump(MSG_DEBUG, "EAP-TLS: Derived Session-Id",
+	} else {
+		wpa_printf(MSG_ERROR, "EAP-TLS: Failed to derive Session-Id");
+static struct wpabuf * eap_tls_process(struct eap_sm *sm, void *priv,
+	size_t left;
+	int res;
+	u8 flags, id;
+	const u8 *pos;
+	pos = eap_peer_tls_process_init(sm, &data->ssl, data->eap_type, ret,
+	if (pos == NULL)
+		return NULL;
+	id = eap_get_id(reqData);
+		wpa_printf(MSG_DEBUG, "EAP-TLS: Start");
+	resp = NULL;
+	res = eap_peer_tls_process_helper(sm, &data->ssl, data->eap_type, 0,
+					  id, &msg, &resp);
+	if (res < 0) {
+		return eap_tls_failure(sm, data, ret, res, resp, id);
+	if (tls_connection_established(data->ssl_ctx, data->ssl.conn))
+		eap_tls_success(sm, data, ret);
+	if (res == 1) {
+	return resp;
+static Boolean eap_tls_has_reauth_data(struct eap_sm *sm, void *priv)
+	return tls_connection_established(data->ssl_ctx, data->ssl.conn);
+static void eap_tls_deinit_for_reauth(struct eap_sm *sm, void *priv)
+static void * eap_tls_init_for_reauth(struct eap_sm *sm, void *priv)
+		os_free(data);
+		return NULL;
+	return priv;
+static int eap_tls_get_status(struct eap_sm *sm, void *priv, char *buf,
+	return eap_peer_tls_status(sm, &data->ssl, buf, buflen, verbose);
+static Boolean eap_tls_isKeyAvailable(struct eap_sm *sm, void *priv)
+	return data->key_data != NULL;
+static u8 * eap_tls_getKey(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+	if (data->key_data == NULL)
+		return NULL;
+	if (key == NULL)
+		return NULL;
+	return key;
+static u8 * eap_tls_get_emsk(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+		return NULL;
+	if (key == NULL)
+		return NULL;
+	os_memcpy(key, data->key_data + EAP_TLS_KEY_LEN, EAP_EMSK_LEN);
+	return key;
+static u8 * eap_tls_get_session_id(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *id;
+	if (data->session_id == NULL)
+		return NULL;
+	if (id == NULL)
+		return NULL;
+	return id;
+int eap_peer_tls_register(void)
+	int ret;
+				    EAP_VENDOR_IETF, EAP_TYPE_TLS, "TLS");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_tls_init;
+	eap->deinit = eap_tls_deinit;
+	eap->process = eap_tls_process;
+	eap->isKeyAvailable = eap_tls_isKeyAvailable;
+	eap->getKey = eap_tls_getKey;
+	eap->getSessionId = eap_tls_get_session_id;
+	eap->get_status = eap_tls_get_status;
+	eap->has_reauth_data = eap_tls_has_reauth_data;
+	eap->deinit_for_reauth = eap_tls_deinit_for_reauth;
+	eap->init_for_reauth = eap_tls_init_for_reauth;
+	eap->get_emsk = eap_tls_get_emsk;
+	if (ret)
+	return ret;
+int eap_peer_unauth_tls_register(void)
+	int ret;
+				    EAP_VENDOR_UNAUTH_TLS,
+				    EAP_VENDOR_TYPE_UNAUTH_TLS, "UNAUTH-TLS");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_unauth_tls_init;
+	if (ret)
+	return ret;
+#ifdef CONFIG_HS20
+int eap_peer_wfa_unauth_tls_register(void)
+	int ret;
+				    EAP_VENDOR_WFA_NEW,
+				    EAP_VENDOR_WFA_UNAUTH_TLS,
+				    "WFA-UNAUTH-TLS");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_wfa_unauth_tls_init;
+	if (ret)
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c b/freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c
index 00000000000..ff6c937c27f
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c
@@ -0,0 +1,1110 @@
+ * EAP peer: EAP-TLS/PEAP/TTLS/FAST common functions
+ * Copyright (c) 2004-2013, Jouni Malinen <j at w1.fi>
+#include "eap_i.h"
+static struct wpabuf * eap_tls_msg_alloc(EapType type, size_t payload_len,
+					 u8 code, u8 identifier)
+	if (type == EAP_UNAUTH_TLS_TYPE)
+		return eap_msg_alloc(EAP_VENDOR_UNAUTH_TLS,
+				     EAP_VENDOR_TYPE_UNAUTH_TLS, payload_len,
+				     code, identifier);
+	if (type == EAP_WFA_UNAUTH_TLS_TYPE)
+		return eap_msg_alloc(EAP_VENDOR_WFA_NEW,
+				     EAP_VENDOR_WFA_UNAUTH_TLS, payload_len,
+	return eap_msg_alloc(EAP_VENDOR_IETF, type, payload_len, code,
+			     identifier);
+static int eap_tls_check_blob(struct eap_sm *sm, const char **name,
+			      const u8 **data, size_t *data_len)
+	const struct wpa_config_blob *blob;
+	if (*name == NULL || os_strncmp(*name, "blob://", 7) != 0)
+		return 0;
+	blob = eap_get_config_blob(sm, *name + 7);
+	if (blob == NULL) {
+		wpa_printf(MSG_ERROR, "%s: Named configuration blob '%s' not "
+			   "found", __func__, *name + 7);
+		return -1;
+	*name = NULL;
+	*data = blob->data;
+	*data_len = blob->len;
+	return 0;
+static void eap_tls_params_flags(struct tls_connection_params *params,
+				 const char *txt)
+	if (txt == NULL)
+		return;
+	if (os_strstr(txt, "tls_allow_md5=1"))
+		params->flags |= TLS_CONN_ALLOW_SIGN_RSA_MD5;
+	if (os_strstr(txt, "tls_disable_time_checks=1"))
+		params->flags |= TLS_CONN_DISABLE_TIME_CHECKS;
+	if (os_strstr(txt, "tls_disable_session_ticket=1"))
+		params->flags |= TLS_CONN_DISABLE_SESSION_TICKET;
+	if (os_strstr(txt, "tls_disable_session_ticket=0"))
+		params->flags &= ~TLS_CONN_DISABLE_SESSION_TICKET;
+	if (os_strstr(txt, "tls_disable_tlsv1_0=1"))
+		params->flags |= TLS_CONN_DISABLE_TLSv1_0;
+	if (os_strstr(txt, "tls_disable_tlsv1_0=0"))
+		params->flags &= ~TLS_CONN_DISABLE_TLSv1_0;
+	if (os_strstr(txt, "tls_disable_tlsv1_1=1"))
+		params->flags |= TLS_CONN_DISABLE_TLSv1_1;
+	if (os_strstr(txt, "tls_disable_tlsv1_1=0"))
+		params->flags &= ~TLS_CONN_DISABLE_TLSv1_1;
+	if (os_strstr(txt, "tls_disable_tlsv1_2=1"))
+		params->flags |= TLS_CONN_DISABLE_TLSv1_2;
+	if (os_strstr(txt, "tls_disable_tlsv1_2=0"))
+		params->flags &= ~TLS_CONN_DISABLE_TLSv1_2;
+static void eap_tls_params_from_conf1(struct tls_connection_params *params,
+	params->ca_cert = (char *) config->ca_cert;
+	params->ca_path = (char *) config->ca_path;
+	params->client_cert = (char *) config->client_cert;
+	params->private_key = (char *) config->private_key;
+	params->private_key_passwd = (char *) config->private_key_passwd;
+	params->dh_file = (char *) config->dh_file;
+	params->subject_match = (char *) config->subject_match;
+	params->altsubject_match = (char *) config->altsubject_match;
+	params->suffix_match = config->domain_suffix_match;
+	params->domain_match = config->domain_match;
+	params->engine = config->engine;
+	params->engine_id = config->engine_id;
+	params->pin = config->pin;
+	params->key_id = config->key_id;
+	params->cert_id = config->cert_id;
+	params->ca_cert_id = config->ca_cert_id;
+	eap_tls_params_flags(params, config->phase1);
+static void eap_tls_params_from_conf2(struct tls_connection_params *params,
+	params->ca_cert = (char *) config->ca_cert2;
+	params->ca_path = (char *) config->ca_path2;
+	params->client_cert = (char *) config->client_cert2;
+	params->private_key = (char *) config->private_key2;
+	params->private_key_passwd = (char *) config->private_key2_passwd;
+	params->dh_file = (char *) config->dh_file2;
+	params->subject_match = (char *) config->subject_match2;
+	params->altsubject_match = (char *) config->altsubject_match2;
+	params->suffix_match = config->domain_suffix_match2;
+	params->domain_match = config->domain_match2;
+	params->engine = config->engine2;
+	params->engine_id = config->engine2_id;
+	params->pin = config->pin2;
+	params->key_id = config->key2_id;
+	params->cert_id = config->cert2_id;
+	params->ca_cert_id = config->ca_cert2_id;
+	eap_tls_params_flags(params, config->phase2);
+static int eap_tls_params_from_conf(struct eap_sm *sm,
+				    struct eap_ssl_data *data,
+				    struct tls_connection_params *params,
+				    struct eap_peer_config *config, int phase2)
+	os_memset(params, 0, sizeof(*params));
+	if (sm->workaround && data->eap_type != EAP_TYPE_FAST) {
+		 * Some deployed authentication servers seem to be unable to
+		 * handle the TLS Session Ticket extension (they are supposed
+		 * to ignore unrecognized TLS extensions, but end up rejecting
+		 * the ClientHello instead). As a workaround, disable use of
+		 * TLS Sesson Ticket extension for EAP-TLS, EAP-PEAP, and
+		 * EAP-TTLS (EAP-FAST uses session ticket, so any server that
+		 * supports EAP-FAST does not need this workaround).
+	if (phase2) {
+		wpa_printf(MSG_DEBUG, "TLS: using phase2 config options");
+		eap_tls_params_from_conf2(params, config);
+	} else {
+		wpa_printf(MSG_DEBUG, "TLS: using phase1 config options");
+		eap_tls_params_from_conf1(params, config);
+		if (data->eap_type == EAP_TYPE_FAST)
+			params->flags |= TLS_CONN_EAP_FAST;
+	 * Use blob data, if available. Otherwise, leave reference to external
+	 * file as-is.
+	if (eap_tls_check_blob(sm, &params->ca_cert, &params->ca_cert_blob,
+			       &params->ca_cert_blob_len) ||
+	    eap_tls_check_blob(sm, &params->client_cert,
+			       &params->client_cert_blob,
+			       &params->client_cert_blob_len) ||
+	    eap_tls_check_blob(sm, &params->private_key,
+			       &params->private_key_blob,
+			       &params->private_key_blob_len) ||
+	    eap_tls_check_blob(sm, &params->dh_file, &params->dh_blob,
+			       &params->dh_blob_len)) {
+		wpa_printf(MSG_INFO, "SSL: Failed to get configuration blobs");
+		return -1;
+	params->openssl_ciphers = config->openssl_ciphers;
+	return 0;
+static int eap_tls_init_connection(struct eap_sm *sm,
+				   struct tls_connection_params *params)
+	int res;
+	if (config->ocsp)
+		params->flags |= TLS_CONN_REQUEST_OCSP;
+	if (config->ocsp == 2)
+		params->flags |= TLS_CONN_REQUIRE_OCSP;
+	data->conn = tls_connection_init(data->ssl_ctx);
+	if (data->conn == NULL) {
+		wpa_printf(MSG_INFO, "SSL: Failed to initialize new TLS "
+			   "connection");
+		return -1;
+	res = tls_connection_set_params(data->ssl_ctx, data->conn, params);
+	if (res == TLS_SET_PARAMS_ENGINE_PRV_BAD_PIN) {
+		 * At this point with the pkcs11 engine the PIN is wrong. We
+		 * reset the PIN in the configuration to be sure to not use it
+		 * again and the calling function must request a new one.
+			   "TLS: Bad PIN provided, requesting a new one");
+		os_free(config->pin);
+		config->pin = NULL;
+	} else if (res == TLS_SET_PARAMS_ENGINE_PRV_INIT_FAILED) {
+		wpa_printf(MSG_INFO, "TLS: Failed to initialize engine");
+	} else if (res == TLS_SET_PARAMS_ENGINE_PRV_VERIFY_FAILED) {
+		wpa_printf(MSG_INFO, "TLS: Failed to load private key");
+	if (res) {
+		wpa_printf(MSG_INFO, "TLS: Failed to set TLS connection "
+			   "parameters");
+		tls_connection_deinit(data->ssl_ctx, data->conn);
+		data->conn = NULL;
+		return -1;
+	return 0;
+ * eap_peer_tls_ssl_init - Initialize shared TLS functionality
+ * @sm: Pointer to EAP state machine allocated with eap_peer_sm_init()
+ * @data: Data for TLS processing
+ * @config: Pointer to the network configuration
+ * @eap_type: EAP method used in Phase 1 (EAP_TYPE_TLS/PEAP/TTLS/FAST)
+ * Returns: 0 on success, -1 on failure
+ * This function is used to initialize shared TLS functionality for EAP-TLS,
+ * EAP-PEAP, EAP-TTLS, and EAP-FAST.
+int eap_peer_tls_ssl_init(struct eap_sm *sm, struct eap_ssl_data *data,
+			  struct eap_peer_config *config, u8 eap_type)
+	struct tls_connection_params params;
+	if (config == NULL)
+		return -1;
+	data->eap = sm;
+	data->eap_type = eap_type;
+	data->phase2 = sm->init_phase2;
+		sm->ssl_ctx;
+	if (eap_tls_params_from_conf(sm, data, &params, config, data->phase2) <
+	    0)
+		return -1;
+	if (eap_tls_init_connection(sm, data, config, &params) < 0)
+		return -1;
+	data->tls_out_limit = config->fragment_size;
+	if (data->phase2) {
+		/* Limit the fragment size in the inner TLS authentication
+		 * since the outer authentication with EAP-PEAP does not yet
+		 * support fragmentation */
+		if (data->tls_out_limit > 100)
+			data->tls_out_limit -= 100;
+	if (config->phase1 &&
+	    os_strstr(config->phase1, "include_tls_length=1")) {
+		wpa_printf(MSG_DEBUG, "TLS: Include TLS Message Length in "
+			   "unfragmented packets");
+		data->include_tls_length = 1;
+	return 0;
+ * eap_peer_tls_ssl_deinit - Deinitialize shared TLS functionality
+ * This function deinitializes shared TLS functionality that was initialized
+ * with eap_peer_tls_ssl_init().
+void eap_peer_tls_ssl_deinit(struct eap_sm *sm, struct eap_ssl_data *data)
+	eap_peer_tls_reset_input(data);
+	eap_peer_tls_reset_output(data);
+ * eap_peer_tls_derive_key - Derive a key based on TLS session data
+ * @label: Label string for deriving the keys, e.g., "client EAP encryption"
+ * @len: Length of the key material to generate (usually 64 for MSK)
+ * Returns: Pointer to allocated key on success or %NULL on failure
+ * This function uses TLS-PRF to generate pseudo-random data based on the TLS
+ * session data (client/server random and master key). Each key type may use a
+ * different label to bind the key usage into the generated material.
+ * The caller is responsible for freeing the returned buffer.
+u8 * eap_peer_tls_derive_key(struct eap_sm *sm, struct eap_ssl_data *data,
+			     const char *label, size_t len)
+	u8 *out;
+	out = os_malloc(len);
+	if (out == NULL)
+		return NULL;
+	if (tls_connection_prf(data->ssl_ctx, data->conn, label, 0, 0,
+			       out, len)) {
+		os_free(out);
+		return NULL;
+	return out;
+ * eap_peer_tls_derive_session_id - Derive a Session-Id based on TLS data
+ * @len: Pointer to length of the session ID generated
+ * Returns: Pointer to allocated Session-Id on success or %NULL on failure
+ * This function derive the Session-Id based on the TLS session data
+ * (client/server random and method type).
+u8 * eap_peer_tls_derive_session_id(struct eap_sm *sm,
+				    struct eap_ssl_data *data, u8 eap_type,
+				    size_t *len)
+	struct tls_random keys;
+	u8 *out;
+	if (tls_connection_get_random(sm->ssl_ctx, data->conn, &keys))
+		return NULL;
+	if (keys.client_random == NULL || keys.server_random == NULL)
+		return NULL;
+	*len = 1 + keys.client_random_len + keys.server_random_len;
+	out = os_malloc(*len);
+	if (out == NULL)
+		return NULL;
+	/* Session-Id = EAP type || client.random || server.random */
+	out[0] = eap_type;
+	os_memcpy(out + 1, keys.client_random, keys.client_random_len);
+	os_memcpy(out + 1 + keys.client_random_len, keys.server_random,
+		  keys.server_random_len);
+	return out;
+ * eap_peer_tls_reassemble_fragment - Reassemble a received fragment
+ * @in_data: Next incoming TLS segment
+ * Returns: 0 on success, 1 if more data is needed for the full message, or
+ * -1 on error
+static int eap_peer_tls_reassemble_fragment(struct eap_ssl_data *data,
+					    const struct wpabuf *in_data)
+	size_t tls_in_len, in_len;
+	tls_in_len = data->tls_in ? wpabuf_len(data->tls_in) : 0;
+	in_len = in_data ? wpabuf_len(in_data) : 0;
+	if (tls_in_len + in_len == 0) {
+		/* No message data received?! */
+		wpa_printf(MSG_WARNING, "SSL: Invalid reassembly state: "
+			   "tls_in_left=%lu tls_in_len=%lu in_len=%lu",
+			   (unsigned long) data->tls_in_left,
+			   (unsigned long) tls_in_len,
+			   (unsigned long) in_len);
+		return -1;
+	if (tls_in_len + in_len > 65536) {
+		 * Limit length to avoid rogue servers from causing large
+		 * memory allocations.
+		wpa_printf(MSG_INFO, "SSL: Too long TLS fragment (size over "
+			   "64 kB)");
+		return -1;
+	if (in_len > data->tls_in_left) {
+		/* Sender is doing something odd - reject message */
+		wpa_printf(MSG_INFO, "SSL: more data than TLS message length "
+			   "indicated");
+		return -1;
+	if (wpabuf_resize(&data->tls_in, in_len) < 0) {
+		wpa_printf(MSG_INFO, "SSL: Could not allocate memory for TLS "
+			   "data");
+		return -1;
+	if (in_data)
+		wpabuf_put_buf(data->tls_in, in_data);
+	data->tls_in_left -= in_len;
+	if (data->tls_in_left > 0) {
+		wpa_printf(MSG_DEBUG, "SSL: Need %lu bytes more input "
+			   "data", (unsigned long) data->tls_in_left);
+		return 1;
+	return 0;
+ * eap_peer_tls_data_reassemble - Reassemble TLS data
+ * @need_more_input: Variable for returning whether more input data is needed
+ * to reassemble this TLS packet
+ * Returns: Pointer to output data, %NULL on error or when more data is needed
+ * for the full message (in which case, *need_more_input is also set to 1).
+ * This function reassembles TLS fragments. Caller must not free the returned
+ * data buffer since an internal pointer to it is maintained.
+static const struct wpabuf * eap_peer_tls_data_reassemble(
+	struct eap_ssl_data *data, const struct wpabuf *in_data,
+	int *need_more_input)
+	*need_more_input = 0;
+	if (data->tls_in_left > wpabuf_len(in_data) || data->tls_in) {
+		/* Message has fragments */
+		int res = eap_peer_tls_reassemble_fragment(data, in_data);
+		if (res) {
+			if (res == 1)
+				*need_more_input = 1;
+			return NULL;
+		/* Message is now fully reassembled. */
+	} else {
+		/* No fragments in this message, so just make a copy of it. */
+		data->tls_in_left = 0;
+		data->tls_in = wpabuf_dup(in_data);
+		if (data->tls_in == NULL)
+			return NULL;
+	return data->tls_in;
+ * eap_tls_process_input - Process incoming TLS message
+ * @in_data: Message received from the server
+ * @out_data: Buffer for returning a pointer to application data (if available)
+ * Returns: 0 on success, 1 if more input data is needed, 2 if application data
+ * is available, -1 on failure
+static int eap_tls_process_input(struct eap_sm *sm, struct eap_ssl_data *data,
+	const struct wpabuf *msg;
+	int need_more_input;
+	struct wpabuf *appl_data;
+	msg = eap_peer_tls_data_reassemble(data, in_data, &need_more_input);
+	if (msg == NULL)
+		return need_more_input ? 1 : -1;
+	/* Full TLS message reassembled - continue handshake processing */
+	if (data->tls_out) {
+		/* This should not happen.. */
+		wpa_printf(MSG_INFO, "SSL: eap_tls_process_input - pending "
+			   "tls_out data even though tls_out_len = 0");
+		wpabuf_free(data->tls_out);
+		WPA_ASSERT(data->tls_out == NULL);
+	appl_data = NULL;
+	data->tls_out = tls_connection_handshake(data->ssl_ctx, data->conn,
+						 msg, &appl_data);
+	if (appl_data &&
+	    tls_connection_established(data->ssl_ctx, data->conn) &&
+	    !tls_connection_get_failed(data->ssl_ctx, data->conn)) {
+		wpa_hexdump_buf_key(MSG_MSGDUMP, "SSL: Application data",
+				    appl_data);
+		*out_data = appl_data;
+		return 2;
+	wpabuf_free(appl_data);
+	return 0;
+ * eap_tls_process_output - Process outgoing TLS message
+ * @eap_type: EAP type (EAP_TYPE_TLS, EAP_TYPE_PEAP, ...)
+ * @peap_version: Version number for EAP-PEAP/TTLS
+ * @id: EAP identifier for the response
+ * @ret: Return value to use on success
+ * @out_data: Buffer for returning the allocated output buffer
+ * Returns: ret (0 or 1) on success, -1 on failure
+static int eap_tls_process_output(struct eap_ssl_data *data, EapType eap_type,
+				  int peap_version, u8 id, int ret,
+	size_t len;
+	u8 *flags;
+	int more_fragments, length_included;
+	if (data->tls_out == NULL)
+		return -1;
+	len = wpabuf_len(data->tls_out) - data->tls_out_pos;
+	wpa_printf(MSG_DEBUG, "SSL: %lu bytes left to be sent out (of total "
+		   "%lu bytes)",
+		   (unsigned long) len,
+		   (unsigned long) wpabuf_len(data->tls_out));
+	 * Limit outgoing message to the configured maximum size. Fragment
+	 * message if needed.
+	if (len > data->tls_out_limit) {
+		more_fragments = 1;
+		len = data->tls_out_limit;
+		wpa_printf(MSG_DEBUG, "SSL: sending %lu bytes, more fragments "
+			   "will follow", (unsigned long) len);
+	} else
+		more_fragments = 0;
+	length_included = data->tls_out_pos == 0 &&
+		(wpabuf_len(data->tls_out) > data->tls_out_limit ||
+		 data->include_tls_length);
+	if (!length_included &&
+	    eap_type == EAP_TYPE_PEAP && peap_version == 0 &&
+	    !tls_connection_established(data->eap->ssl_ctx, data->conn)) {
+		 * Windows Server 2008 NPS really wants to have the TLS Message
+		 * length included in phase 0 even for unfragmented frames or
+		 * it will get very confused with Compound MAC calculation and
+		 * Outer TLVs.
+		length_included = 1;
+	*out_data = eap_tls_msg_alloc(eap_type, 1 + length_included * 4 + len,
+				      EAP_CODE_RESPONSE, id);
+	if (*out_data == NULL)
+		return -1;
+	flags = wpabuf_put(*out_data, 1);
+	*flags = peap_version;
+	if (more_fragments)
+		*flags |= EAP_TLS_FLAGS_MORE_FRAGMENTS;
+	if (length_included) {
+		*flags |= EAP_TLS_FLAGS_LENGTH_INCLUDED;
+		wpabuf_put_be32(*out_data, wpabuf_len(data->tls_out));
+	wpabuf_put_data(*out_data,
+			wpabuf_head_u8(data->tls_out) + data->tls_out_pos,
+			len);
+	data->tls_out_pos += len;
+	if (!more_fragments)
+	return ret;
+ * eap_peer_tls_process_helper - Process TLS handshake message
+ * @out_data: Buffer for returning a pointer to the response message
+ * is available, or -1 on failure
+ * This function can be used to process TLS handshake messages. It reassembles
+ * the received fragments and uses a TLS library to process the messages. The
+ * response data from the TLS library is fragmented to suitable output messages
+ * that the caller can send out.
+ * out_data is used to return the response message if the return value of this
+ * function is 0, 2, or -1. In case of failure, the message is likely a TLS
+ * alarm message. The caller is responsible for freeing the allocated buffer if
+ * *out_data is not %NULL.
+ * This function is called for each received TLS message during the TLS
+ * handshake after eap_peer_tls_process_init() call and possible processing of
+ * TLS Flags field. Once the handshake has been completed, i.e., when
+ * tls_connection_established() returns 1, EAP method specific decrypting of
+ * the tunneled data is used.
+int eap_peer_tls_process_helper(struct eap_sm *sm, struct eap_ssl_data *data,
+				EapType eap_type, int peap_version,
+				u8 id, const struct wpabuf *in_data,
+	int ret = 0;
+	*out_data = NULL;
+	if (data->tls_out && wpabuf_len(data->tls_out) > 0 &&
+	    wpabuf_len(in_data) > 0) {
+		wpa_printf(MSG_DEBUG, "SSL: Received non-ACK when output "
+			   "fragments are waiting to be sent out");
+		return -1;
+	if (data->tls_out == NULL || wpabuf_len(data->tls_out) == 0) {
+		 * No more data to send out - expect to receive more data from
+		 * the AS.
+		int res = eap_tls_process_input(sm, data, in_data, out_data);
+		if (res) {
+			 * Input processing failed (res = -1) or more data is
+			 * needed (res = 1).
+			return res;
+		 * The incoming message has been reassembled and processed. The
+		 * response was allocated into data->tls_out buffer.
+	if (data->tls_out == NULL) {
+		 * No outgoing fragments remaining from the previous message
+		 * and no new message generated. This indicates an error in TLS
+		 * processing.
+		return -1;
+	if (tls_connection_get_failed(data->ssl_ctx, data->conn)) {
+		/* TLS processing has failed - return error */
+		wpa_printf(MSG_DEBUG, "SSL: Failed - tls_out available to "
+			   "report error (len=%u)",
+			   (unsigned int) wpabuf_len(data->tls_out));
+		ret = -1;
+		/* TODO: clean pin if engine used? */
+		if (wpabuf_len(data->tls_out) == 0) {
+			data->tls_out = NULL;
+			return -1;
+		 * TLS negotiation should now be complete since all other cases
+		 * needing more data should have been caught above based on
+		 * the TLS Message Length field.
+		wpa_printf(MSG_DEBUG, "SSL: No data to be sent out");
+		return 1;
+	/* Send the pending message (in fragments, if needed). */
+	return eap_tls_process_output(data, eap_type, peap_version, id, ret,
+				      out_data);
+ * eap_peer_tls_build_ack - Build a TLS ACK frame
+ * Returns: Pointer to the allocated ACK frame or %NULL on failure
+struct wpabuf * eap_peer_tls_build_ack(u8 id, EapType eap_type,
+				       int peap_version)
+	resp = eap_tls_msg_alloc(eap_type, 1, EAP_CODE_RESPONSE, id);
+	if (resp == NULL)
+		return NULL;
+	wpa_printf(MSG_DEBUG, "SSL: Building ACK (type=%d id=%d ver=%d)",
+		   (int) eap_type, id, peap_version);
+	wpabuf_put_u8(resp, peap_version); /* Flags */
+	return resp;
+ * eap_peer_tls_reauth_init - Re-initialize shared TLS for session resumption
+int eap_peer_tls_reauth_init(struct eap_sm *sm, struct eap_ssl_data *data)
+	return tls_connection_shutdown(data->ssl_ctx, data->conn);
+ * eap_peer_tls_status - Get TLS status
+ * @buf: Buffer for status information
+ * @buflen: Maximum buffer length
+ * @verbose: Whether to include verbose status information
+ * Returns: Number of bytes written to buf.
+int eap_peer_tls_status(struct eap_sm *sm, struct eap_ssl_data *data,
+			char *buf, size_t buflen, int verbose)
+	char version[20], name[128];
+	int len = 0, ret;
+	if (tls_get_version(data->ssl_ctx, data->conn, version,
+			    sizeof(version)) < 0)
+		version[0] = '\0';
+	if (tls_get_cipher(data->ssl_ctx, data->conn, name, sizeof(name)) < 0)
+		name[0] = '\0';
+			  "eap_tls_version=%s\n"
+			  "EAP TLS cipher=%s\n"
+			  "tls_session_reused=%d\n",
+			  version, name,
+			  tls_connection_resumed(data->ssl_ctx, data->conn));
+		return len;
+	len += ret;
+	return len;
+ * eap_peer_tls_process_init - Initial validation/processing of EAP requests
+ * @reqData: EAP request to be processed (eapReqData)
+ * @len: Buffer for returning length of the remaining payload
+ * @flags: Buffer for returning TLS flags
+ * Returns: Pointer to payload after TLS flags and length or %NULL on failure
+ * This function validates the EAP header and processes the optional TLS
+ * Message Length field. If this is the first fragment of a TLS message, the
+ * TLS reassembly code is initialized to receive the indicated number of bytes.
+ * EAP-TLS, EAP-PEAP, EAP-TTLS, and EAP-FAST methods are expected to use this
+ * function as the first step in processing received messages. They will need
+ * to process the flags (apart from Message Length Included) that are returned
+ * through the flags pointer and the message payload that will be returned (and
+ * the length is returned through the len pointer). Return values (ret) are set
+ * for continuation of EAP method processing. The caller is responsible for
+ * setting these to indicate completion (either success or failure) based on
+ * the authentication result.
+const u8 * eap_peer_tls_process_init(struct eap_sm *sm,
+				     EapType eap_type,
+				     const struct wpabuf *reqData,
+				     size_t *len, u8 *flags)
+	const u8 *pos;
+	size_t left;
+	unsigned int tls_msg_len;
+	if (tls_get_errors(data->ssl_ctx)) {
+		wpa_printf(MSG_INFO, "SSL: TLS errors detected");
+		return NULL;
+	if (eap_type == EAP_UNAUTH_TLS_TYPE)
+		pos = eap_hdr_validate(EAP_VENDOR_UNAUTH_TLS,
+				       EAP_VENDOR_TYPE_UNAUTH_TLS, reqData,
+				       &left);
+	else if (eap_type == EAP_WFA_UNAUTH_TLS_TYPE)
+		pos = eap_hdr_validate(EAP_VENDOR_WFA_NEW,
+				       EAP_VENDOR_WFA_UNAUTH_TLS, reqData,
+				       &left);
+	else
+		pos = eap_hdr_validate(EAP_VENDOR_IETF, eap_type, reqData,
+				       &left);
+		return NULL;
+	if (left == 0) {
+		wpa_printf(MSG_DEBUG, "SSL: Invalid TLS message: no Flags "
+			   "octet included");
+		if (!sm->workaround) {
+			return NULL;
+		wpa_printf(MSG_DEBUG, "SSL: Workaround - assume no Flags "
+			   "indicates ACK frame");
+		*flags = 0;
+	} else {
+		*flags = *pos++;
+		left--;
+	wpa_printf(MSG_DEBUG, "SSL: Received packet(len=%lu) - "
+		   "Flags 0x%02x", (unsigned long) wpabuf_len(reqData),
+		   *flags);
+	if (*flags & EAP_TLS_FLAGS_LENGTH_INCLUDED) {
+		if (left < 4) {
+			wpa_printf(MSG_INFO, "SSL: Short frame with TLS "
+				   "length");
+			return NULL;
+		tls_msg_len = WPA_GET_BE32(pos);
+		wpa_printf(MSG_DEBUG, "SSL: TLS Message Length: %d",
+			   tls_msg_len);
+		if (data->tls_in_left == 0) {
+			data->tls_in_total = tls_msg_len;
+			data->tls_in_left = tls_msg_len;
+			wpabuf_free(data->tls_in);
+			data->tls_in = NULL;
+		pos += 4;
+		left -= 4;
+		if (left > tls_msg_len) {
+			wpa_printf(MSG_INFO, "SSL: TLS Message Length (%d "
+				   "bytes) smaller than this fragment (%d "
+				   "bytes)", (int) tls_msg_len, (int) left);
+			return NULL;
+	*len = left;
+	return pos;
+ * eap_peer_tls_reset_input - Reset input buffers
+ * This function frees any allocated memory for input buffers and resets input
+ * state.
+void eap_peer_tls_reset_input(struct eap_ssl_data *data)
+	data->tls_in_left = data->tls_in_total = 0;
+ * eap_peer_tls_reset_output - Reset output buffers
+ * This function frees any allocated memory for output buffers and resets
+ * output state.
+void eap_peer_tls_reset_output(struct eap_ssl_data *data)
+	data->tls_out_pos = 0;
+ * eap_peer_tls_decrypt - Decrypt received phase 2 TLS message
+ * @in_decrypted: Buffer for returning a pointer to the decrypted message
+ * Returns: 0 on success, 1 if more input data is needed, or -1 on failure
+int eap_peer_tls_decrypt(struct eap_sm *sm, struct eap_ssl_data *data,
+			 struct wpabuf **in_decrypted)
+	if (msg == NULL)
+	*in_decrypted = tls_connection_decrypt(data->ssl_ctx, data->conn, msg);
+	if (*in_decrypted == NULL) {
+		wpa_printf(MSG_INFO, "SSL: Failed to decrypt Phase 2 data");
+		return -1;
+	return 0;
+ * eap_peer_tls_encrypt - Encrypt phase 2 TLS message
+ * @in_data: Plaintext phase 2 data to encrypt or %NULL to continue fragments
+ * @out_data: Buffer for returning a pointer to the encrypted response message
+int eap_peer_tls_encrypt(struct eap_sm *sm, struct eap_ssl_data *data,
+			 EapType eap_type, int peap_version, u8 id,
+	if (in_data) {
+		data->tls_out = tls_connection_encrypt(data->ssl_ctx,
+						       data->conn, in_data);
+			wpa_printf(MSG_INFO, "SSL: Failed to encrypt Phase 2 "
+				   "data (in_len=%lu)",
+				   (unsigned long) wpabuf_len(in_data));
+			return -1;
+	return eap_tls_process_output(data, eap_type, peap_version, id, 0,
+				      out_data);
+ * eap_peer_select_phase2_methods - Select phase 2 EAP method
+ * @prefix: 'phase2' configuration prefix, e.g., "auth="
+ * @types: Buffer for returning allocated list of allowed EAP methods
+ * @num_types: Buffer for returning number of allocated EAP methods
+ * This function is used to parse EAP method list and select allowed methods
+ * for Phase2 authentication.
+int eap_peer_select_phase2_methods(struct eap_peer_config *config,
+				   const char *prefix,
+				   struct eap_method_type **types,
+				   size_t *num_types)
+	char *start, *pos, *buf;
+	struct eap_method_type *methods = NULL, *_methods;
+	u32 method;
+	size_t num_methods = 0, prefix_len;
+	if (config == NULL || config->phase2 == NULL)
+		goto get_defaults;
+	start = buf = os_strdup(config->phase2);
+	if (buf == NULL)
+		return -1;
+	prefix_len = os_strlen(prefix);
+	while (start && *start != '\0') {
+		int vendor;
+		pos = os_strstr(start, prefix);
+		if (pos == NULL)
+			break;
+		if (start != pos && *(pos - 1) != ' ') {
+			start = pos + prefix_len;
+			continue;
+		pos = os_strchr(start, ' ');
+		if (pos)
+			*pos++ = '\0';
+		method = eap_get_phase2_type(start, &vendor);
+		if (vendor == EAP_VENDOR_IETF && method == EAP_TYPE_NONE) {
+			wpa_printf(MSG_ERROR, "TLS: Unsupported Phase2 EAP "
+				   "method '%s'", start);
+		} else {
+			num_methods++;
+			_methods = os_realloc_array(methods, num_methods,
+						    sizeof(*methods));
+			if (_methods == NULL) {
+				os_free(methods);
+				os_free(buf);
+				return -1;
+			methods = _methods;
+			methods[num_methods - 1].vendor = vendor;
+			methods[num_methods - 1].method = method;
+		start = pos;
+	os_free(buf);
+get_defaults:
+	if (methods == NULL)
+		methods = eap_get_phase2_types(config, &num_methods);
+	if (methods == NULL) {
+		wpa_printf(MSG_ERROR, "TLS: No Phase2 EAP methods available");
+		return -1;
+	wpa_hexdump(MSG_DEBUG, "TLS: Phase2 EAP types",
+		    (u8 *) methods,
+		    num_methods * sizeof(struct eap_method_type));
+	*types = methods;
+	*num_types = num_methods;
+	return 0;
+ * eap_peer_tls_phase2_nak - Generate EAP-Nak for Phase 2
+ * @hdr: EAP-Request header (and the following EAP type octet)
+ * @resp: Buffer for returning the EAP-Nak message
+int eap_peer_tls_phase2_nak(struct eap_method_type *types, size_t num_types,
+			    struct eap_hdr *hdr, struct wpabuf **resp)
+	u8 *pos = (u8 *) (hdr + 1);
+	size_t i;
+	/* TODO: add support for expanded Nak */
+	wpa_printf(MSG_DEBUG, "TLS: Phase 2 Request: Nak type=%d", *pos);
+	wpa_hexdump(MSG_DEBUG, "TLS: Allowed Phase2 EAP types",
+		    (u8 *) types, num_types * sizeof(struct eap_method_type));
+	*resp = eap_msg_alloc(EAP_VENDOR_IETF, EAP_TYPE_NAK, num_types,
+			      EAP_CODE_RESPONSE, hdr->identifier);
+	if (*resp == NULL)
+		return -1;
+	for (i = 0; i < num_types; i++) {
+		if (types[i].vendor == EAP_VENDOR_IETF &&
+		    types[i].method < 256)
+			wpabuf_put_u8(*resp, types[i].method);
+	eap_update_len(*resp);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h b/freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h
index 00000000000..acd2b783617
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_tls_common.h
@@ -0,0 +1,132 @@
+ * Copyright (c) 2004-2009, 2012, Jouni Malinen <j at w1.fi>
+#ifndef EAP_TLS_COMMON_H
+#define EAP_TLS_COMMON_H
+ * struct eap_ssl_data - TLS data for EAP methods
+struct eap_ssl_data {
+	 * conn - TLS connection context data from tls_connection_init()
+	struct tls_connection *conn;
+	 * tls_out - TLS message to be sent out in fragments
+	struct wpabuf *tls_out;
+	 * tls_out_pos - The current position in the outgoing TLS message
+	size_t tls_out_pos;
+	 * tls_out_limit - Maximum fragment size for outgoing TLS messages
+	size_t tls_out_limit;
+	 * tls_in - Received TLS message buffer for re-assembly
+	struct wpabuf *tls_in;
+	 * tls_in_left - Number of remaining bytes in the incoming TLS message
+	size_t tls_in_left;
+	 * tls_in_total - Total number of bytes in the incoming TLS message
+	size_t tls_in_total;
+	 * phase2 - Whether this TLS connection is used in EAP phase 2 (tunnel)
+	int phase2;
+	 * include_tls_length - Whether the TLS length field is included even
+	 * if the TLS data is not fragmented
+	int include_tls_length;
+	 * eap - EAP state machine allocated with eap_peer_sm_init()
+	struct eap_sm *eap;
+	 * ssl_ctx - TLS library context to use for the connection
+	void *ssl_ctx;
+	 * eap_type - EAP method used in Phase 1 (EAP_TYPE_TLS/PEAP/TTLS/FAST)
+	u8 eap_type;
+/* EAP TLS Flags */
+#define EAP_TLS_FLAGS_LENGTH_INCLUDED 0x80
+#define EAP_TLS_FLAGS_MORE_FRAGMENTS 0x40
+#define EAP_TLS_FLAGS_START 0x20
+#define EAP_TLS_VERSION_MASK 0x07
+ /* could be up to 128 bytes, but only the first 64 bytes are used */
+#define EAP_TLS_KEY_LEN 64
+/* dummy type used as a flag for UNAUTH-TLS */
+#define EAP_UNAUTH_TLS_TYPE 255
+#define EAP_WFA_UNAUTH_TLS_TYPE 254
+			  struct eap_peer_config *config, u8 eap_type);
+void eap_peer_tls_ssl_deinit(struct eap_sm *sm, struct eap_ssl_data *data);
+			     const char *label, size_t len);
+				    size_t *len);
+				struct wpabuf **out_data);
+				       int peap_version);
+int eap_peer_tls_reauth_init(struct eap_sm *sm, struct eap_ssl_data *data);
+			char *buf, size_t buflen, int verbose);
+				     EapType eap_type,
+				     size_t *len, u8 *flags);
+void eap_peer_tls_reset_input(struct eap_ssl_data *data);
+void eap_peer_tls_reset_output(struct eap_ssl_data *data);
+			 const struct wpabuf *in_data,
+			 struct wpabuf **in_decrypted);
+				   size_t *num_types);
+			    struct eap_hdr *hdr, struct wpabuf **resp);
+#endif /* EAP_TLS_COMMON_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/eap_ttls.c b/freebsd/contrib/wpa/src/eap_peer/eap_ttls.c
index 00000000000..55788774792
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/eap_ttls.c
@@ -0,0 +1,1723 @@
+ * EAP peer method: EAP-TTLS (RFC 5281)
+ * Copyright (c) 2004-2011, Jouni Malinen <j at w1.fi>
+#include "crypto/ms_funcs.h"
+#include "crypto/sha1.h"
+#include "crypto/tls.h"
+#include "eap_common/chap.h"
+#include "eap_common/eap_ttls.h"
+#include "mschapv2.h"
+#include "eap_i.h"
+#include "eap_tls_common.h"
+#define EAP_TTLS_VERSION 0
+static void eap_ttls_deinit(struct eap_sm *sm, void *priv);
+struct eap_ttls_data {
+	struct eap_ssl_data ssl;
+	int ttls_version;
+	const struct eap_method *phase2_method;
+	void *phase2_priv;
+	int phase2_success;
+	int phase2_start;
+	enum phase2_types {
+		EAP_TTLS_PHASE2_EAP,
+		EAP_TTLS_PHASE2_MSCHAPV2,
+		EAP_TTLS_PHASE2_MSCHAP,
+		EAP_TTLS_PHASE2_PAP,
+		EAP_TTLS_PHASE2_CHAP
+	} phase2_type;
+	struct eap_method_type phase2_eap_type;
+	struct eap_method_type *phase2_eap_types;
+	size_t num_phase2_eap_types;
+	u8 auth_response[MSCHAPV2_AUTH_RESPONSE_LEN];
+	int auth_response_valid;
+	u8 master_key[MSCHAPV2_MASTER_KEY_LEN]; /* MSCHAPv2 master key */
+	u8 ident;
+	int resuming; /* starting a resumed session */
+	int reauth; /* reauthentication */
+	u8 *key_data;
+	u8 *session_id;
+	size_t id_len;
+	struct wpabuf *pending_phase2_req;
+#ifdef EAP_TNC
+	int ready_for_tnc;
+	int tnc_started;
+#endif /* EAP_TNC */
+static void * eap_ttls_init(struct eap_sm *sm)
+	struct eap_ttls_data *data;
+	char *selected;
+	data = os_zalloc(sizeof(*data));
+	if (data == NULL)
+		return NULL;
+	data->ttls_version = EAP_TTLS_VERSION;
+	selected = "EAP";
+	data->phase2_type = EAP_TTLS_PHASE2_EAP;
+	if (config && config->phase2) {
+		if (os_strstr(config->phase2, "autheap=")) {
+			selected = "EAP";
+		} else if (os_strstr(config->phase2, "auth=MSCHAPV2")) {
+			selected = "MSCHAPV2";
+			data->phase2_type = EAP_TTLS_PHASE2_MSCHAPV2;
+		} else if (os_strstr(config->phase2, "auth=MSCHAP")) {
+			selected = "MSCHAP";
+			data->phase2_type = EAP_TTLS_PHASE2_MSCHAP;
+		} else if (os_strstr(config->phase2, "auth=PAP")) {
+			selected = "PAP";
+			data->phase2_type = EAP_TTLS_PHASE2_PAP;
+		} else if (os_strstr(config->phase2, "auth=CHAP")) {
+			selected = "CHAP";
+			data->phase2_type = EAP_TTLS_PHASE2_CHAP;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: Phase2 type: %s", selected);
+	if (data->phase2_type == EAP_TTLS_PHASE2_EAP) {
+		if (eap_peer_select_phase2_methods(config, "autheap=",
+						   &data->phase2_eap_types,
+						   &data->num_phase2_eap_types)
+		    < 0) {
+			eap_ttls_deinit(sm, data);
+			return NULL;
+		data->phase2_eap_type.vendor = EAP_VENDOR_IETF;
+		data->phase2_eap_type.method = EAP_TYPE_NONE;
+	if (eap_peer_tls_ssl_init(sm, &data->ssl, config, EAP_TYPE_TTLS)) {
+		wpa_printf(MSG_INFO, "EAP-TTLS: Failed to initialize SSL.");
+		return NULL;
+	return data;
+static void eap_ttls_phase2_eap_deinit(struct eap_sm *sm,
+				       struct eap_ttls_data *data)
+	if (data->phase2_priv && data->phase2_method) {
+		data->phase2_method->deinit(sm, data->phase2_priv);
+		data->phase2_method = NULL;
+		data->phase2_priv = NULL;
+static void eap_ttls_free_key(struct eap_ttls_data *data)
+	if (data->key_data) {
+		data->key_data = NULL;
+	struct eap_ttls_data *data = priv;
+	if (data == NULL)
+		return;
+	eap_ttls_phase2_eap_deinit(sm, data);
+	os_free(data->phase2_eap_types);
+	eap_peer_tls_ssl_deinit(sm, &data->ssl);
+	eap_ttls_free_key(data);
+	os_free(data->session_id);
+	wpabuf_free(data->pending_phase2_req);
+	os_free(data);
+static u8 * eap_ttls_avp_hdr(u8 *avphdr, u32 avp_code, u32 vendor_id,
+			     int mandatory, size_t len)
+	struct ttls_avp_vendor *avp;
+	u8 flags;
+	size_t hdrlen;
+	avp = (struct ttls_avp_vendor *) avphdr;
+	flags = mandatory ? AVP_FLAGS_MANDATORY : 0;
+	if (vendor_id) {
+		flags |= AVP_FLAGS_VENDOR;
+		hdrlen = sizeof(*avp);
+		avp->vendor_id = host_to_be32(vendor_id);
+	} else {
+		hdrlen = sizeof(struct ttls_avp);
+	avp->avp_code = host_to_be32(avp_code);
+	avp->avp_length = host_to_be32(((u32) flags << 24) |
+				       (u32) (hdrlen + len));
+	return avphdr + hdrlen;
+static u8 * eap_ttls_avp_add(u8 *start, u8 *avphdr, u32 avp_code,
+			     u32 vendor_id, int mandatory,
+			     const u8 *data, size_t len)
+	u8 *pos;
+	pos = eap_ttls_avp_hdr(avphdr, avp_code, vendor_id, mandatory, len);
+	os_memcpy(pos, data, len);
+	pos += len;
+	AVP_PAD(start, pos);
+	return pos;
+static int eap_ttls_avp_encapsulate(struct wpabuf **resp, u32 avp_code,
+				    int mandatory)
+	struct wpabuf *msg;
+	u8 *avp, *pos;
+	msg = wpabuf_alloc(sizeof(struct ttls_avp) + wpabuf_len(*resp) + 4);
+	if (msg == NULL) {
+		wpabuf_free(*resp);
+		*resp = NULL;
+		return -1;
+	avp = wpabuf_mhead(msg);
+	pos = eap_ttls_avp_hdr(avp, avp_code, 0, mandatory, wpabuf_len(*resp));
+	os_memcpy(pos, wpabuf_head(*resp), wpabuf_len(*resp));
+	pos += wpabuf_len(*resp);
+	AVP_PAD(avp, pos);
+	wpabuf_put(msg, pos - avp);
+	*resp = msg;
+	return 0;
+static int eap_ttls_v0_derive_key(struct eap_sm *sm,
+						 "ttls keying material",
+						 EAP_TLS_KEY_LEN +
+						 EAP_EMSK_LEN);
+	if (!data->key_data) {
+		wpa_printf(MSG_INFO, "EAP-TTLS: Failed to derive key");
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "EAP-TTLS: Derived key",
+	wpa_hexdump_key(MSG_DEBUG, "EAP-TTLS: Derived EMSK",
+			EAP_EMSK_LEN);
+							  EAP_TYPE_TTLS,
+	                                                  &data->id_len);
+		wpa_hexdump(MSG_DEBUG, "EAP-TTLS: Derived Session-Id",
+	} else {
+		wpa_printf(MSG_ERROR, "EAP-TTLS: Failed to derive Session-Id");
+	return 0;
+#ifndef CONFIG_FIPS
+static u8 * eap_ttls_implicit_challenge(struct eap_sm *sm,
+					struct eap_ttls_data *data, size_t len)
+	return eap_peer_tls_derive_key(sm, &data->ssl, "ttls challenge", len);
+#endif /* CONFIG_FIPS */
+static void eap_ttls_phase2_select_eap_method(struct eap_ttls_data *data,
+					      u8 method)
+	size_t i;
+	for (i = 0; i < data->num_phase2_eap_types; i++) {
+		if (data->phase2_eap_types[i].vendor != EAP_VENDOR_IETF ||
+		    data->phase2_eap_types[i].method != method)
+			continue;
+			data->phase2_eap_types[i].vendor;
+			data->phase2_eap_types[i].method;
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Selected "
+			   "Phase 2 EAP vendor %d method %d",
+			   data->phase2_eap_type.vendor,
+			   data->phase2_eap_type.method);
+		break;
+static int eap_ttls_phase2_eap_process(struct eap_sm *sm,
+				       struct eap_hdr *hdr, size_t len,
+				       struct wpabuf **resp)
+	struct wpabuf msg;
+	struct eap_method_ret iret;
+	os_memset(&iret, 0, sizeof(iret));
+	wpabuf_set(&msg, hdr, len);
+	*resp = data->phase2_method->process(sm, data->phase2_priv, &iret,
+					     &msg);
+	if ((iret.methodState == METHOD_DONE ||
+	     iret.methodState == METHOD_MAY_CONT) &&
+	    (iret.decision == DECISION_UNCOND_SUCC ||
+	     iret.decision == DECISION_COND_SUCC ||
+	     iret.decision == DECISION_FAIL)) {
+		ret->methodState = iret.methodState;
+		ret->decision = iret.decision;
+	return 0;
+static int eap_ttls_phase2_request_eap_method(struct eap_sm *sm,
+					      u8 method, struct wpabuf **resp)
+#ifdef EAP_TNC
+	if (data->tnc_started && data->phase2_method &&
+	    data->phase2_priv && method == EAP_TYPE_TNC &&
+	    data->phase2_eap_type.method == EAP_TYPE_TNC)
+		return eap_ttls_phase2_eap_process(sm, data, ret, hdr, len,
+						   resp);
+	if (data->ready_for_tnc && !data->tnc_started &&
+	    method == EAP_TYPE_TNC) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Start TNC after completed "
+			   "EAP method");
+		data->tnc_started = 1;
+	if (data->tnc_started) {
+		if (data->phase2_eap_type.vendor != EAP_VENDOR_IETF ||
+		    data->phase2_eap_type.method == EAP_TYPE_TNC) {
+			wpa_printf(MSG_DEBUG, "EAP-TTLS: Unexpected EAP "
+				   "type %d for TNC", method);
+			return -1;
+		data->phase2_eap_type.method = method;
+			   "Phase 2 EAP vendor %d method %d (TNC)",
+	if (data->phase2_eap_type.vendor == EAP_VENDOR_IETF &&
+	    data->phase2_eap_type.method == EAP_TYPE_NONE)
+		eap_ttls_phase2_select_eap_method(data, method);
+	if (method != data->phase2_eap_type.method || method == EAP_TYPE_NONE)
+		if (eap_peer_tls_phase2_nak(data->phase2_eap_types,
+					    data->num_phase2_eap_types,
+					    hdr, resp))
+			return -1;
+		return 0;
+	if (data->phase2_priv == NULL) {
+		data->phase2_method = eap_peer_get_eap_method(
+			EAP_VENDOR_IETF, method);
+		if (data->phase2_method) {
+			sm->init_phase2 = 1;
+			data->phase2_priv = data->phase2_method->init(sm);
+			sm->init_phase2 = 0;
+	if (data->phase2_priv == NULL || data->phase2_method == NULL) {
+		wpa_printf(MSG_INFO, "EAP-TTLS: failed to initialize "
+			   "Phase 2 EAP method %d", method);
+		return -1;
+	return eap_ttls_phase2_eap_process(sm, data, ret, hdr, len, resp);
+static int eap_ttls_phase2_request_eap(struct eap_sm *sm,
+	size_t len = be_to_host16(hdr->length);
+	u8 *pos;
+	if (len <= sizeof(struct eap_hdr)) {
+		wpa_printf(MSG_INFO, "EAP-TTLS: too short "
+			   "Phase 2 request (len=%lu)", (unsigned long) len);
+		return -1;
+	pos = (u8 *) (hdr + 1);
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: Phase 2 EAP Request: type=%d", *pos);
+	switch (*pos) {
+	case EAP_TYPE_IDENTITY:
+		*resp = eap_sm_buildIdentity(sm, hdr->identifier, 1);
+		break;
+	default:
+		if (eap_ttls_phase2_request_eap_method(sm, data, ret, hdr, len,
+						       *pos, resp) < 0)
+			return -1;
+		break;
+	if (*resp == NULL &&
+	    (config->pending_req_identity || config->pending_req_password ||
+	     config->pending_req_otp)) {
+		return 0;
+		return -1;
+	wpa_hexdump_buf(MSG_DEBUG, "EAP-TTLS: AVP encapsulate EAP Response",
+			*resp);
+	return eap_ttls_avp_encapsulate(resp, RADIUS_ATTR_EAP_MESSAGE, 1);
+static int eap_ttls_phase2_request_mschapv2(struct eap_sm *sm,
+#ifdef CONFIG_FIPS
+	wpa_printf(MSG_ERROR, "EAP-TTLS: MSCHAPV2 not supported in FIPS build");
+	return -1;
+#else /* CONFIG_FIPS */
+#ifdef EAP_MSCHAPv2
+	u8 *buf, *pos, *challenge, *peer_challenge;
+	const u8 *identity, *password;
+	size_t identity_len, password_len;
+	int pwhash;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: Phase 2 MSCHAPV2 Request");
+	password = eap_get_config_password2(sm, &password_len, &pwhash);
+	if (identity == NULL || password == NULL)
+		return -1;
+	msg = wpabuf_alloc(identity_len + 1000);
+			   "EAP-TTLS/MSCHAPV2: Failed to allocate memory");
+		return -1;
+	pos = buf = wpabuf_mhead(msg);
+	/* User-Name */
+	pos = eap_ttls_avp_add(buf, pos, RADIUS_ATTR_USER_NAME, 0, 1,
+			       identity, identity_len);
+	/* MS-CHAP-Challenge */
+	challenge = eap_ttls_implicit_challenge(
+		sm, data, EAP_TTLS_MSCHAPV2_CHALLENGE_LEN + 1);
+	if (challenge == NULL) {
+		wpabuf_free(msg);
+		wpa_printf(MSG_ERROR, "EAP-TTLS/MSCHAPV2: Failed to derive "
+			   "implicit challenge");
+		return -1;
+	pos = eap_ttls_avp_add(buf, pos, RADIUS_ATTR_MS_CHAP_CHALLENGE,
+			       RADIUS_VENDOR_ID_MICROSOFT, 1,
+			       challenge, EAP_TTLS_MSCHAPV2_CHALLENGE_LEN);
+	/* MS-CHAP2-Response */
+	pos = eap_ttls_avp_hdr(pos, RADIUS_ATTR_MS_CHAP2_RESPONSE,
+			       EAP_TTLS_MSCHAPV2_RESPONSE_LEN);
+	data->ident = challenge[EAP_TTLS_MSCHAPV2_CHALLENGE_LEN];
+	*pos++ = data->ident;
+	*pos++ = 0; /* Flags */
+	if (os_get_random(pos, EAP_TTLS_MSCHAPV2_CHALLENGE_LEN) < 0) {
+		os_free(challenge);
+		wpabuf_free(msg);
+		wpa_printf(MSG_ERROR, "EAP-TTLS/MSCHAPV2: Failed to get "
+			   "random data for peer challenge");
+		return -1;
+	peer_challenge = pos;
+	pos += EAP_TTLS_MSCHAPV2_CHALLENGE_LEN;
+	os_memset(pos, 0, 8); /* Reserved, must be zero */
+	pos += 8;
+	if (mschapv2_derive_response(identity, identity_len, password,
+				     password_len, pwhash, challenge,
+				     peer_challenge, pos, data->auth_response,
+				     data->master_key)) {
+		wpabuf_free(msg);
+			   "response");
+		return -1;
+	data->auth_response_valid = 1;
+	pos += 24;
+	AVP_PAD(buf, pos);
+	wpabuf_put(msg, pos - buf);
+	*resp = msg;
+	return 0;
+#else /* EAP_MSCHAPv2 */
+	wpa_printf(MSG_ERROR, "EAP-TTLS: MSCHAPv2 not included in the build");
+	return -1;
+#endif /* EAP_MSCHAPv2 */
+static int eap_ttls_phase2_request_mschap(struct eap_sm *sm,
+#ifdef CONFIG_FIPS
+	wpa_printf(MSG_ERROR, "EAP-TTLS: MSCHAP not supported in FIPS build");
+	return -1;
+	u8 *buf, *pos, *challenge;
+	int pwhash;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: Phase 2 MSCHAP Request");
+		return -1;
+			   "EAP-TTLS/MSCHAP: Failed to allocate memory");
+		return -1;
+	/* User-Name */
+		sm, data, EAP_TTLS_MSCHAP_CHALLENGE_LEN + 1);
+		wpabuf_free(msg);
+		wpa_printf(MSG_ERROR, "EAP-TTLS/MSCHAP: Failed to derive "
+		return -1;
+			       challenge, EAP_TTLS_MSCHAP_CHALLENGE_LEN);
+	/* MS-CHAP-Response */
+	pos = eap_ttls_avp_hdr(pos, RADIUS_ATTR_MS_CHAP_RESPONSE,
+			       EAP_TTLS_MSCHAP_RESPONSE_LEN);
+	data->ident = challenge[EAP_TTLS_MSCHAP_CHALLENGE_LEN];
+	*pos++ = 1; /* Flags: Use NT style passwords */
+	os_memset(pos, 0, 24); /* LM-Response */
+	pos += 24;
+	if (pwhash) {
+		challenge_response(challenge, password, pos); /* NT-Response */
+		wpa_hexdump_key(MSG_DEBUG, "EAP-TTLS: MSCHAP password hash",
+				password, 16);
+	} else {
+		nt_challenge_response(challenge, password, password_len,
+				      pos); /* NT-Response */
+		wpa_hexdump_ascii_key(MSG_DEBUG, "EAP-TTLS: MSCHAP password",
+				      password, password_len);
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: MSCHAP implicit challenge",
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: MSCHAP response", pos, 24);
+	pos += 24;
+	*resp = msg;
+	/* EAP-TTLS/MSCHAP does not provide tunneled success
+	 * notification, so assume that Phase2 succeeds. */
+	ret->methodState = METHOD_DONE;
+	ret->decision = DECISION_COND_SUCC;
+	return 0;
+static int eap_ttls_phase2_request_pap(struct eap_sm *sm,
+	u8 *buf, *pos;
+	size_t pad;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: Phase 2 PAP Request");
+	identity = eap_get_config_identity(sm, &identity_len);
+	password = eap_get_config_password(sm, &password_len);
+		return -1;
+	msg = wpabuf_alloc(identity_len + password_len + 100);
+			   "EAP-TTLS/PAP: Failed to allocate memory");
+		return -1;
+	/* User-Name */
+	/* User-Password; in RADIUS, this is encrypted, but EAP-TTLS encrypts
+	 * the data, so no separate encryption is used in the AVP itself.
+	 * However, the password is padded to obfuscate its length. */
+	pad = password_len == 0 ? 16 : (16 - (password_len & 15)) & 15;
+	pos = eap_ttls_avp_hdr(pos, RADIUS_ATTR_USER_PASSWORD, 0, 1,
+			       password_len + pad);
+	os_memcpy(pos, password, password_len);
+	pos += password_len;
+	os_memset(pos, 0, pad);
+	pos += pad;
+	*resp = msg;
+	/* EAP-TTLS/PAP does not provide tunneled success notification,
+	 * so assume that Phase2 succeeds. */
+	return 0;
+static int eap_ttls_phase2_request_chap(struct eap_sm *sm,
+#ifdef CONFIG_FIPS
+	wpa_printf(MSG_ERROR, "EAP-TTLS: CHAP not supported in FIPS build");
+	return -1;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: Phase 2 CHAP Request");
+		return -1;
+			   "EAP-TTLS/CHAP: Failed to allocate memory");
+		return -1;
+	/* User-Name */
+	/* CHAP-Challenge */
+		sm, data, EAP_TTLS_CHAP_CHALLENGE_LEN + 1);
+		wpabuf_free(msg);
+		wpa_printf(MSG_ERROR, "EAP-TTLS/CHAP: Failed to derive "
+		return -1;
+	pos = eap_ttls_avp_add(buf, pos, RADIUS_ATTR_CHAP_CHALLENGE, 0, 1,
+			       challenge, EAP_TTLS_CHAP_CHALLENGE_LEN);
+	/* CHAP-Password */
+	pos = eap_ttls_avp_hdr(pos, RADIUS_ATTR_CHAP_PASSWORD, 0, 1,
+			       1 + EAP_TTLS_CHAP_PASSWORD_LEN);
+	data->ident = challenge[EAP_TTLS_CHAP_CHALLENGE_LEN];
+	/* MD5(Ident + Password + Challenge) */
+	chap_md5(data->ident, password, password_len, challenge,
+		 EAP_TTLS_CHAP_CHALLENGE_LEN, pos);
+	wpa_hexdump_ascii(MSG_DEBUG, "EAP-TTLS: CHAP username",
+	wpa_hexdump_ascii_key(MSG_DEBUG, "EAP-TTLS: CHAP password",
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: CHAP implicit challenge",
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: CHAP password",
+		    pos, EAP_TTLS_CHAP_PASSWORD_LEN);
+	pos += EAP_TTLS_CHAP_PASSWORD_LEN;
+	*resp = msg;
+	/* EAP-TTLS/CHAP does not provide tunneled success
+	return 0;
+static int eap_ttls_phase2_request(struct eap_sm *sm,
+	int res = 0;
+	size_t len;
+	enum phase2_types phase2_type = data->phase2_type;
+#ifdef EAP_TNC
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Processing TNC");
+		phase2_type = EAP_TTLS_PHASE2_EAP;
+	if (phase2_type == EAP_TTLS_PHASE2_MSCHAPV2 ||
+	    phase2_type == EAP_TTLS_PHASE2_MSCHAP ||
+	    phase2_type == EAP_TTLS_PHASE2_PAP ||
+	    phase2_type == EAP_TTLS_PHASE2_CHAP) {
+		if (eap_get_config_identity(sm, &len) == NULL) {
+				   "EAP-TTLS: Identity not configured");
+			eap_sm_request_identity(sm);
+			if (eap_get_config_password(sm, &len) == NULL)
+				eap_sm_request_password(sm);
+			return 0;
+		if (eap_get_config_password(sm, &len) == NULL) {
+				   "EAP-TTLS: Password not configured");
+			return 0;
+	switch (phase2_type) {
+	case EAP_TTLS_PHASE2_EAP:
+		res = eap_ttls_phase2_request_eap(sm, data, ret, hdr, resp);
+		break;
+	case EAP_TTLS_PHASE2_MSCHAPV2:
+		res = eap_ttls_phase2_request_mschapv2(sm, data, ret, resp);
+		break;
+	case EAP_TTLS_PHASE2_MSCHAP:
+		res = eap_ttls_phase2_request_mschap(sm, data, ret, resp);
+		break;
+	case EAP_TTLS_PHASE2_PAP:
+		res = eap_ttls_phase2_request_pap(sm, data, ret, resp);
+		break;
+	case EAP_TTLS_PHASE2_CHAP:
+		res = eap_ttls_phase2_request_chap(sm, data, ret, resp);
+		break;
+	default:
+		wpa_printf(MSG_ERROR, "EAP-TTLS: Phase 2 - Unknown");
+		res = -1;
+		break;
+	if (res < 0) {
+		ret->decision = DECISION_FAIL;
+	return res;
+struct ttls_parse_avp {
+	u8 *mschapv2;
+	u8 *eapdata;
+	size_t eap_len;
+	int mschapv2_error;
+static int eap_ttls_parse_attr_eap(const u8 *dpos, size_t dlen,
+				   struct ttls_parse_avp *parse)
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: AVP - EAP Message");
+	if (parse->eapdata == NULL) {
+		parse->eapdata = os_malloc(dlen);
+			wpa_printf(MSG_WARNING, "EAP-TTLS: Failed to allocate "
+				   "memory for Phase 2 EAP data");
+			return -1;
+		os_memcpy(parse->eapdata, dpos, dlen);
+		parse->eap_len = dlen;
+	} else {
+		u8 *neweap = os_realloc(parse->eapdata, parse->eap_len + dlen);
+		if (neweap == NULL) {
+			return -1;
+		os_memcpy(neweap + parse->eap_len, dpos, dlen);
+		parse->eapdata = neweap;
+		parse->eap_len += dlen;
+	return 0;
+static int eap_ttls_parse_avp(u8 *pos, size_t left,
+	struct ttls_avp *avp;
+	u32 avp_code, avp_length, vendor_id = 0;
+	u8 avp_flags, *dpos;
+	size_t dlen;
+	avp = (struct ttls_avp *) pos;
+	avp_code = be_to_host32(avp->avp_code);
+	avp_length = be_to_host32(avp->avp_length);
+	avp_flags = (avp_length >> 24) & 0xff;
+	avp_length &= 0xffffff;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: AVP: code=%d flags=0x%02x "
+		   "length=%d", (int) avp_code, avp_flags,
+		   (int) avp_length);
+	if (avp_length > left) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: AVP overflow "
+			   "(len=%d, left=%lu) - dropped",
+			   (int) avp_length, (unsigned long) left);
+		return -1;
+	if (avp_length < sizeof(*avp)) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: Invalid AVP length %d",
+			   avp_length);
+		return -1;
+	dpos = (u8 *) (avp + 1);
+	dlen = avp_length - sizeof(*avp);
+	if (avp_flags & AVP_FLAGS_VENDOR) {
+		if (dlen < 4) {
+			wpa_printf(MSG_WARNING, "EAP-TTLS: Vendor AVP "
+				   "underflow");
+			return -1;
+		vendor_id = WPA_GET_BE32(dpos);
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: AVP vendor_id %d",
+			   (int) vendor_id);
+		dpos += 4;
+		dlen -= 4;
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: AVP data", dpos, dlen);
+	if (vendor_id == 0 && avp_code == RADIUS_ATTR_EAP_MESSAGE) {
+		if (eap_ttls_parse_attr_eap(dpos, dlen, parse) < 0)
+			return -1;
+	} else if (vendor_id == 0 && avp_code == RADIUS_ATTR_REPLY_MESSAGE) {
+		/* This is an optional message that can be displayed to
+		 * the user. */
+		wpa_hexdump_ascii(MSG_DEBUG, "EAP-TTLS: AVP - Reply-Message",
+				  dpos, dlen);
+	} else if (vendor_id == RADIUS_VENDOR_ID_MICROSOFT &&
+		   avp_code == RADIUS_ATTR_MS_CHAP2_SUCCESS) {
+		wpa_hexdump_ascii(MSG_DEBUG, "EAP-TTLS: MS-CHAP2-Success",
+				  dpos, dlen);
+		if (dlen != 43) {
+			wpa_printf(MSG_WARNING, "EAP-TTLS: Unexpected "
+				   "MS-CHAP2-Success length "
+				   "(len=%lu, expected 43)",
+				   (unsigned long) dlen);
+			return -1;
+		parse->mschapv2 = dpos;
+		   avp_code == RADIUS_ATTR_MS_CHAP_ERROR) {
+		wpa_hexdump_ascii(MSG_DEBUG, "EAP-TTLS: MS-CHAP-Error",
+				  dpos, dlen);
+		parse->mschapv2_error = 1;
+	} else if (avp_flags & AVP_FLAGS_MANDATORY) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: Unsupported mandatory AVP "
+			   "code %d vendor_id %d - dropped",
+			   (int) avp_code, (int) vendor_id);
+		return -1;
+	} else {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Ignoring unsupported AVP "
+			   "code %d vendor_id %d",
+	return avp_length;
+static int eap_ttls_parse_avps(struct wpabuf *in_decrypted,
+	u8 *pos;
+	size_t left, pad;
+	int avp_length;
+	pos = wpabuf_mhead(in_decrypted);
+	left = wpabuf_len(in_decrypted);
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: Decrypted Phase 2 AVPs", pos, left);
+	if (left < sizeof(struct ttls_avp)) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: Too short Phase 2 AVP frame"
+			   " len=%lu expected %lu or more - dropped",
+			   (unsigned long) left,
+			   (unsigned long) sizeof(struct ttls_avp));
+		return -1;
+	/* Parse AVPs */
+	os_memset(parse, 0, sizeof(*parse));
+	while (left > 0) {
+		avp_length = eap_ttls_parse_avp(pos, left, parse);
+		if (avp_length < 0)
+			return -1;
+		pad = (4 - (avp_length & 3)) & 3;
+		pos += avp_length + pad;
+		if (left < avp_length + pad)
+			left = 0;
+		else
+			left -= avp_length + pad;
+	return 0;
+static u8 * eap_ttls_fake_identity_request(void)
+	struct eap_hdr *hdr;
+	u8 *buf;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: empty data in beginning of "
+		   "Phase 2 - use fake EAP-Request Identity");
+	buf = os_malloc(sizeof(*hdr) + 1);
+	if (buf == NULL) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: failed to allocate "
+			   "memory for fake EAP-Identity Request");
+		return NULL;
+	hdr = (struct eap_hdr *) buf;
+	hdr->code = EAP_CODE_REQUEST;
+	hdr->identifier = 0;
+	hdr->length = host_to_be16(sizeof(*hdr) + 1);
+	buf[sizeof(*hdr)] = EAP_TYPE_IDENTITY;
+	return buf;
+static int eap_ttls_encrypt_response(struct eap_sm *sm,
+				     struct wpabuf *resp, u8 identifier,
+	if (resp == NULL)
+		return 0;
+	wpa_hexdump_buf_key(MSG_DEBUG, "EAP-TTLS: Encrypting Phase 2 data",
+			    resp);
+	if (eap_peer_tls_encrypt(sm, &data->ssl, EAP_TYPE_TTLS,
+				 data->ttls_version, identifier,
+				 resp, out_data)) {
+		wpa_printf(MSG_INFO, "EAP-TTLS: Failed to encrypt a Phase 2 "
+			   "frame");
+		wpabuf_free(resp);
+		return -1;
+	return 0;
+static int eap_ttls_process_phase2_eap(struct eap_sm *sm,
+				       struct ttls_parse_avp *parse,
+	size_t len;
+		wpa_printf(MSG_WARNING, "EAP-TTLS: No EAP Message in the "
+			   "packet - dropped");
+		return -1;
+	wpa_hexdump(MSG_DEBUG, "EAP-TTLS: Phase 2 EAP",
+		    parse->eapdata, parse->eap_len);
+	hdr = (struct eap_hdr *) parse->eapdata;
+	if (parse->eap_len < sizeof(*hdr)) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: Too short Phase 2 EAP "
+			   "frame (len=%lu, expected %lu or more) - dropped",
+			   (unsigned long) parse->eap_len,
+			   (unsigned long) sizeof(*hdr));
+		return -1;
+	len = be_to_host16(hdr->length);
+	if (len > parse->eap_len) {
+		wpa_printf(MSG_INFO, "EAP-TTLS: Length mismatch in Phase 2 "
+			   "EAP frame (EAP hdr len=%lu, EAP data len in "
+			   "AVP=%lu)",
+			   (unsigned long) parse->eap_len);
+		return -1;
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: received Phase 2: code=%d "
+		   "identifier=%d length=%lu",
+		   hdr->code, hdr->identifier, (unsigned long) len);
+	switch (hdr->code) {
+	case EAP_CODE_REQUEST:
+		if (eap_ttls_phase2_request(sm, data, ret, hdr, resp)) {
+			wpa_printf(MSG_INFO, "EAP-TTLS: Phase2 Request "
+				   "processing failed");
+			return -1;
+		break;
+	default:
+		wpa_printf(MSG_INFO, "EAP-TTLS: Unexpected code=%d in "
+			   "Phase 2 EAP header", hdr->code);
+		return -1;
+	return 0;
+static int eap_ttls_process_phase2_mschapv2(struct eap_sm *sm,
+	if (parse->mschapv2_error) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS/MSCHAPV2: Received "
+			   "MS-CHAP-Error - failed");
+		/* Reply with empty data to ACK error */
+		return 1;
+	if (parse->mschapv2 == NULL) {
+#ifdef EAP_TNC
+		if (data->phase2_success && parse->eapdata) {
+			 * Allow EAP-TNC to be started after successfully
+			 * completed MSCHAPV2.
+			return 1;
+		wpa_printf(MSG_WARNING, "EAP-TTLS: no MS-CHAP2-Success AVP "
+			   "received for Phase2 MSCHAPV2");
+		return -1;
+	if (parse->mschapv2[0] != data->ident) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: Ident mismatch for Phase 2 "
+			   "MSCHAPV2 (received Ident 0x%02x, expected 0x%02x)",
+			   parse->mschapv2[0], data->ident);
+		return -1;
+	if (!data->auth_response_valid ||
+	    mschapv2_verify_auth_response(data->auth_response,
+					  parse->mschapv2 + 1, 42)) {
+		wpa_printf(MSG_WARNING, "EAP-TTLS: Invalid authenticator "
+			   "response in Phase 2 MSCHAPV2 success request");
+		return -1;
+	wpa_printf(MSG_INFO, "EAP-TTLS: Phase 2 MSCHAPV2 "
+		   "authentication succeeded");
+	data->phase2_success = 1;
+	 * Reply with empty data; authentication server will reply
+	 * with EAP-Success after this.
+	return 1;
+	return -1;
+#ifdef EAP_TNC
+static int eap_ttls_process_tnc_start(struct eap_sm *sm,
+	/* TNC uses inner EAP method after non-EAP TTLS phase 2. */
+		wpa_printf(MSG_INFO, "EAP-TTLS: Phase 2 received "
+			   "unexpected tunneled data (no EAP)");
+		return -1;
+	if (!data->ready_for_tnc) {
+			   "EAP after non-EAP, but not ready for TNC");
+		return -1;
+		   "non-EAP method");
+	if (eap_ttls_process_phase2_eap(sm, data, ret, parse, resp) < 0)
+		return -1;
+	return 0;
+static int eap_ttls_process_decrypted(struct eap_sm *sm,
+				      u8 identifier,
+				      struct wpabuf *in_decrypted,
+	struct wpabuf *resp = NULL;
+	struct eap_peer_config *config = eap_get_config(sm);
+	int res;
+#ifdef EAP_TNC
+		if (eap_ttls_process_phase2_eap(sm, data, ret, parse, &resp) <
+		    0)
+			return -1;
+		break;
+		res = eap_ttls_process_phase2_mschapv2(sm, data, ret, parse);
+#ifdef EAP_TNC
+		if (res == 1 && parse->eapdata && data->phase2_success) {
+			 * TNC may be required as the next
+			 * authentication method within the tunnel.
+			ret->methodState = METHOD_MAY_CONT;
+			data->ready_for_tnc = 1;
+			if (eap_ttls_process_tnc_start(sm, data, ret, parse,
+						       &resp) == 0)
+				break;
+		return res;
+#ifdef EAP_TNC
+		if (eap_ttls_process_tnc_start(sm, data, ret, parse, &resp) <
+		    0)
+			return -1;
+		break;
+#else /* EAP_TNC */
+		/* EAP-TTLS/{MSCHAP,PAP,CHAP} should not send any TLS tunneled
+		 * requests to the supplicant */
+		wpa_printf(MSG_INFO, "EAP-TTLS: Phase 2 received unexpected "
+			   "tunneled data");
+		return -1;
+	if (resp) {
+		if (eap_ttls_encrypt_response(sm, data, resp, identifier,
+					      out_data) < 0)
+			return -1;
+	} else if (config->pending_req_identity ||
+		   config->pending_req_password ||
+		   config->pending_req_otp ||
+		   config->pending_req_new_password) {
+		data->pending_phase2_req = wpabuf_dup(in_decrypted);
+	return 0;
+static int eap_ttls_implicit_identity_request(struct eap_sm *sm,
+					      struct eap_method_ret *ret,
+					      u8 identifier,
+	int retval = 0;
+	struct wpabuf *resp;
+	hdr = (struct eap_hdr *) eap_ttls_fake_identity_request();
+	if (hdr == NULL) {
+		return -1;
+	resp = NULL;
+	if (eap_ttls_phase2_request(sm, data, ret, hdr, &resp)) {
+		retval = -1;
+	} else {
+		if (resp == NULL &&
+		     config->pending_req_new_password)) {
+			 * Use empty buffer to force implicit request
+			 * processing when EAP request is re-processed after
+			 * user input.
+			data->pending_phase2_req = wpabuf_alloc(0);
+		retval = eap_ttls_encrypt_response(sm, data, resp, identifier,
+						   out_data);
+	os_free(hdr);
+	if (retval < 0) {
+	return retval;
+static int eap_ttls_phase2_start(struct eap_sm *sm, struct eap_ttls_data *data,
+				 struct eap_method_ret *ret, u8 identifier,
+	data->phase2_start = 0;
+	 * EAP-TTLS does not use Phase2 on fast re-auth; this must be done only
+	 * if TLS part was indeed resuming a previous session. Most
+	 * Authentication Servers terminate EAP-TTLS before reaching this
+	 * point, but some do not. Make wpa_supplicant stop phase 2 here, if
+	 * needed.
+	if (data->reauth &&
+	    tls_connection_resumed(sm->ssl_ctx, data->ssl.conn)) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Session resumption - "
+			   "skip phase 2");
+		*out_data = eap_peer_tls_build_ack(identifier, EAP_TYPE_TTLS,
+						   data->ttls_version);
+		ret->decision = DECISION_UNCOND_SUCC;
+		return 0;
+	return eap_ttls_implicit_identity_request(sm, data, ret, identifier,
+						  out_data);
+static int eap_ttls_decrypt(struct eap_sm *sm, struct eap_ttls_data *data,
+	struct wpabuf *in_decrypted = NULL;
+	int retval = 0;
+	struct ttls_parse_avp parse;
+	os_memset(&parse, 0, sizeof(parse));
+	wpa_printf(MSG_DEBUG, "EAP-TTLS: received %lu bytes encrypted data for"
+		   " Phase 2",
+		   in_data ? (unsigned long) wpabuf_len(in_data) : 0);
+	if (data->pending_phase2_req) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Pending Phase 2 request - "
+			   "skip decryption and use old data");
+		/* Clear TLS reassembly state. */
+		eap_peer_tls_reset_input(&data->ssl);
+		in_decrypted = data->pending_phase2_req;
+		data->pending_phase2_req = NULL;
+		if (wpabuf_len(in_decrypted) == 0) {
+			wpabuf_free(in_decrypted);
+				sm, data, ret, identifier, out_data);
+		goto continue_req;
+	if ((in_data == NULL || wpabuf_len(in_data) == 0) &&
+	    data->phase2_start) {
+		return eap_ttls_phase2_start(sm, data, ret, identifier,
+					     out_data);
+	if (in_data == NULL || wpabuf_len(in_data) == 0) {
+		/* Received TLS ACK - requesting more fragments */
+		return eap_peer_tls_encrypt(sm, &data->ssl, EAP_TYPE_TTLS,
+					    identifier, NULL, out_data);
+	retval = eap_peer_tls_decrypt(sm, &data->ssl, in_data, &in_decrypted);
+	if (retval)
+		goto done;
+continue_req:
+	if (eap_ttls_parse_avps(in_decrypted, &parse) < 0) {
+		retval = -1;
+		goto done;
+	retval = eap_ttls_process_decrypted(sm, data, ret, identifier,
+					    &parse, in_decrypted, out_data);
+done:
+	os_free(parse.eapdata);
+	if (retval < 0) {
+	return retval;
+static int eap_ttls_process_handshake(struct eap_sm *sm,
+				      u8 identifier,
+	int res;
+	res = eap_peer_tls_process_helper(sm, &data->ssl, EAP_TYPE_TTLS,
+					  in_data, out_data);
+	if (res < 0) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: TLS processing failed");
+		return -1;
+	if (tls_connection_established(sm->ssl_ctx, data->ssl.conn)) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: TLS done, proceed to "
+			   "Phase 2");
+		if (data->resuming) {
+			wpa_printf(MSG_DEBUG, "EAP-TTLS: fast reauth - may "
+				   "skip Phase 2");
+		data->phase2_start = 1;
+		eap_ttls_v0_derive_key(sm, data);
+		if (*out_data == NULL || wpabuf_len(*out_data) == 0) {
+			if (eap_ttls_decrypt(sm, data, ret, identifier,
+					     NULL, out_data)) {
+				wpa_printf(MSG_WARNING, "EAP-TTLS: "
+					   "failed to process early "
+					   "start for Phase 2");
+			res = 0;
+		data->resuming = 0;
+	if (res == 2) {
+		 * Application data included in the handshake message.
+		data->pending_phase2_req = *out_data;
+		*out_data = NULL;
+		res = eap_ttls_decrypt(sm, data, ret, identifier, in_data,
+				       out_data);
+	return res;
+static void eap_ttls_check_auth_status(struct eap_sm *sm,
+				       struct eap_method_ret *ret)
+	if (ret->methodState == METHOD_DONE) {
+		ret->allowNotifications = FALSE;
+		if (ret->decision == DECISION_UNCOND_SUCC ||
+		    ret->decision == DECISION_COND_SUCC) {
+			wpa_printf(MSG_DEBUG, "EAP-TTLS: Authentication "
+				   "completed successfully");
+#ifdef EAP_TNC
+			if (!data->ready_for_tnc && !data->tnc_started) {
+	} else if (ret->methodState == METHOD_MAY_CONT &&
+		   (ret->decision == DECISION_UNCOND_SUCC ||
+		    ret->decision == DECISION_COND_SUCC)) {
+				   "completed successfully (MAY_CONT)");
+static struct wpabuf * eap_ttls_process(struct eap_sm *sm, void *priv,
+					const struct wpabuf *reqData)
+	size_t left;
+	int res;
+	u8 flags, id;
+	const u8 *pos;
+	pos = eap_peer_tls_process_init(sm, &data->ssl, EAP_TYPE_TTLS, ret,
+					reqData, &left, &flags);
+	if (pos == NULL)
+		return NULL;
+	id = eap_get_id(reqData);
+	if (flags & EAP_TLS_FLAGS_START) {
+		wpa_printf(MSG_DEBUG, "EAP-TTLS: Start (server ver=%d, own "
+			   "ver=%d)", flags & EAP_TLS_VERSION_MASK,
+		/* RFC 5281, Ch. 9.2:
+		 * "This packet MAY contain additional information in the form
+		 * of AVPs, which may provide useful hints to the client"
+		 * For now, ignore any potential extra data.
+		left = 0;
+	wpabuf_set(&msg, pos, left);
+	resp = NULL;
+	if (tls_connection_established(sm->ssl_ctx, data->ssl.conn) &&
+	    !data->resuming) {
+		res = eap_ttls_decrypt(sm, data, ret, id, &msg, &resp);
+	} else {
+		res = eap_ttls_process_handshake(sm, data, ret, id,
+						 &msg, &resp);
+	eap_ttls_check_auth_status(sm, data, ret);
+	/* FIX: what about res == -1? Could just move all error processing into
+	 * the other functions and get rid of this res==1 case here. */
+	if (res == 1) {
+		return eap_peer_tls_build_ack(id, EAP_TYPE_TTLS,
+	return resp;
+static Boolean eap_ttls_has_reauth_data(struct eap_sm *sm, void *priv)
+	return tls_connection_established(sm->ssl_ctx, data->ssl.conn) &&
+		data->phase2_success;
+static void eap_ttls_deinit_for_reauth(struct eap_sm *sm, void *priv)
+#ifdef EAP_TNC
+	data->ready_for_tnc = 0;
+	data->tnc_started = 0;
+static void * eap_ttls_init_for_reauth(struct eap_sm *sm, void *priv)
+	data->session_id = NULL;
+	if (eap_peer_tls_reauth_init(sm, &data->ssl)) {
+		os_free(data);
+		return NULL;
+	if (data->phase2_priv && data->phase2_method &&
+	    data->phase2_method->init_for_reauth)
+		data->phase2_method->init_for_reauth(sm, data->phase2_priv);
+	data->phase2_success = 0;
+	data->resuming = 1;
+	data->reauth = 1;
+	return priv;
+static int eap_ttls_get_status(struct eap_sm *sm, void *priv, char *buf,
+			       size_t buflen, int verbose)
+	int len, ret;
+	len = eap_peer_tls_status(sm, &data->ssl, buf, buflen, verbose);
+	ret = os_snprintf(buf + len, buflen - len,
+			  "EAP-TTLSv%d Phase2 method=",
+	if (os_snprintf_error(buflen - len, ret))
+		return len;
+	len += ret;
+	switch (data->phase2_type) {
+		ret = os_snprintf(buf + len, buflen - len, "EAP-%s\n",
+				  data->phase2_method ?
+				  data->phase2_method->name : "?");
+		break;
+		ret = os_snprintf(buf + len, buflen - len, "MSCHAPV2\n");
+		break;
+		ret = os_snprintf(buf + len, buflen - len, "MSCHAP\n");
+		break;
+		ret = os_snprintf(buf + len, buflen - len, "PAP\n");
+		break;
+		ret = os_snprintf(buf + len, buflen - len, "CHAP\n");
+		break;
+	default:
+		ret = 0;
+		break;
+		return len;
+	len += ret;
+	return len;
+static Boolean eap_ttls_isKeyAvailable(struct eap_sm *sm, void *priv)
+	return data->key_data != NULL && data->phase2_success;
+static u8 * eap_ttls_getKey(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+	if (data->key_data == NULL || !data->phase2_success)
+		return NULL;
+	key = os_malloc(EAP_TLS_KEY_LEN);
+	if (key == NULL)
+		return NULL;
+	*len = EAP_TLS_KEY_LEN;
+	os_memcpy(key, data->key_data, EAP_TLS_KEY_LEN);
+	return key;
+static u8 * eap_ttls_get_session_id(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *id;
+	if (data->session_id == NULL || !data->phase2_success)
+		return NULL;
+	id = os_malloc(data->id_len);
+	if (id == NULL)
+		return NULL;
+	*len = data->id_len;
+	os_memcpy(id, data->session_id, data->id_len);
+	return id;
+static u8 * eap_ttls_get_emsk(struct eap_sm *sm, void *priv, size_t *len)
+	u8 *key;
+	if (data->key_data == NULL)
+		return NULL;
+	key = os_malloc(EAP_EMSK_LEN);
+	if (key == NULL)
+		return NULL;
+	*len = EAP_EMSK_LEN;
+	os_memcpy(key, data->key_data + EAP_TLS_KEY_LEN, EAP_EMSK_LEN);
+	return key;
+int eap_peer_ttls_register(void)
+	struct eap_method *eap;
+	int ret;
+	eap = eap_peer_method_alloc(EAP_PEER_METHOD_INTERFACE_VERSION,
+				    EAP_VENDOR_IETF, EAP_TYPE_TTLS, "TTLS");
+	if (eap == NULL)
+		return -1;
+	eap->init = eap_ttls_init;
+	eap->deinit = eap_ttls_deinit;
+	eap->process = eap_ttls_process;
+	eap->isKeyAvailable = eap_ttls_isKeyAvailable;
+	eap->getKey = eap_ttls_getKey;
+	eap->getSessionId = eap_ttls_get_session_id;
+	eap->get_status = eap_ttls_get_status;
+	eap->has_reauth_data = eap_ttls_has_reauth_data;
+	eap->deinit_for_reauth = eap_ttls_deinit_for_reauth;
+	eap->init_for_reauth = eap_ttls_init_for_reauth;
+	eap->get_emsk = eap_ttls_get_emsk;
+	ret = eap_peer_method_register(eap);
+	if (ret)
+		eap_peer_method_free(eap);
+	return ret;
diff --git a/freebsd/contrib/wpa/src/eap_peer/mschapv2.c b/freebsd/contrib/wpa/src/eap_peer/mschapv2.c
new file mode 100644
index 00000000000..ba5d763c1c4
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/mschapv2.c
@@ -0,0 +1,126 @@
+#include <machine/rtems-bsd-user-space.h>
+ * MSCHAPV2 (RFC 2759)
+ * Copyright (c) 2004-2008, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "includes.h"
+#include "common.h"
+const u8 * mschapv2_remove_domain(const u8 *username, size_t *len)
+	size_t i;
+	 * MSCHAPv2 does not include optional domain name in the
+	 * challenge-response calculation, so remove domain prefix
+	 * (if present).
+	for (i = 0; i < *len; i++) {
+		if (username[i] == '\\') {
+			*len -= i + 1;
+			return username + i + 1;
+	return username;
+int mschapv2_derive_response(const u8 *identity, size_t identity_len,
+			     const u8 *password, size_t password_len,
+			     int pwhash,
+			     const u8 *auth_challenge,
+			     const u8 *peer_challenge,
+			     u8 *nt_response, u8 *auth_response,
+			     u8 *master_key)
+	const u8 *username;
+	size_t username_len;
+	u8 password_hash[16], password_hash_hash[16];
+	wpa_hexdump_ascii(MSG_DEBUG, "MSCHAPV2: Identity",
+	username_len = identity_len;
+	username = mschapv2_remove_domain(identity, &username_len);
+	wpa_hexdump_ascii(MSG_DEBUG, "MSCHAPV2: Username",
+			  username, username_len);
+	wpa_hexdump(MSG_DEBUG, "MSCHAPV2: auth_challenge",
+		    auth_challenge, MSCHAPV2_CHAL_LEN);
+	wpa_hexdump(MSG_DEBUG, "MSCHAPV2: peer_challenge",
+		    peer_challenge, MSCHAPV2_CHAL_LEN);
+	wpa_hexdump_ascii(MSG_DEBUG, "MSCHAPV2: username",
+	/* Authenticator response is not really needed yet, but calculate it
+	 * here so that challenges need not be saved. */
+	if (pwhash) {
+		wpa_hexdump_key(MSG_DEBUG, "MSCHAPV2: password hash",
+		if (generate_nt_response_pwhash(auth_challenge, peer_challenge,
+						username, username_len,
+						password, nt_response) ||
+		    generate_authenticator_response_pwhash(
+			    password, peer_challenge, auth_challenge,
+			    username, username_len, nt_response,
+			    auth_response))
+			return -1;
+	} else {
+		wpa_hexdump_ascii_key(MSG_DEBUG, "MSCHAPV2: password",
+		if (generate_nt_response(auth_challenge, peer_challenge,
+					 password, password_len,
+					 nt_response) ||
+		    generate_authenticator_response(password, password_len,
+						    peer_challenge,
+						    auth_challenge,
+						    nt_response,
+						    auth_response))
+			return -1;
+	wpa_hexdump(MSG_DEBUG, "MSCHAPV2: NT Response",
+		    nt_response, MSCHAPV2_NT_RESPONSE_LEN);
+	wpa_hexdump(MSG_DEBUG, "MSCHAPV2: Auth Response",
+		    auth_response, MSCHAPV2_AUTH_RESPONSE_LEN);
+	/* Generate master_key here since we have the needed data available. */
+	if (pwhash) {
+		if (hash_nt_password_hash(password, password_hash_hash))
+			return -1;
+	} else {
+		if (nt_password_hash(password, password_len, password_hash) ||
+		    hash_nt_password_hash(password_hash, password_hash_hash))
+			return -1;
+	if (get_master_key(password_hash_hash, nt_response, master_key))
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "MSCHAPV2: Master Key",
+			master_key, MSCHAPV2_MASTER_KEY_LEN);
+	return 0;
+int mschapv2_verify_auth_response(const u8 *auth_response,
+				  const u8 *buf, size_t buf_len)
+	u8 recv_response[MSCHAPV2_AUTH_RESPONSE_LEN];
+	if (buf_len < 2 + 2 * MSCHAPV2_AUTH_RESPONSE_LEN ||
+	    buf[0] != 'S' || buf[1] != '=' ||
+	    hexstr2bin((char *) (buf + 2), recv_response,
+		       MSCHAPV2_AUTH_RESPONSE_LEN) ||
+	    os_memcmp_const(auth_response, recv_response,
+			    MSCHAPV2_AUTH_RESPONSE_LEN) != 0)
+		return -1;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/eap_peer/mschapv2.h b/freebsd/contrib/wpa/src/eap_peer/mschapv2.h
index 00000000000..edd458b402b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/mschapv2.h
@@ -0,0 +1,28 @@
+#ifndef MSCHAPV2_H
+#define MSCHAPV2_H
+#define MSCHAPV2_CHAL_LEN 16
+#define MSCHAPV2_NT_RESPONSE_LEN 24
+#define MSCHAPV2_AUTH_RESPONSE_LEN 20
+#define MSCHAPV2_MASTER_KEY_LEN 16
+const u8 * mschapv2_remove_domain(const u8 *username, size_t *len);
+int mschapv2_derive_response(const u8 *username, size_t username_len,
+			     int pwhash,
+			     u8 *master_key);
+				  const u8 *buf, size_t buf_len);
+#endif /* MSCHAPV2_H */
diff --git a/freebsd/contrib/wpa/src/eap_peer/tncc.h b/freebsd/contrib/wpa/src/eap_peer/tncc.h
index 00000000000..df2a2870f9a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_peer/tncc.h
@@ -0,0 +1,36 @@
+ * EAP-TNC - TNCC (IF-IMC and IF-TNCCS)
+ * Copyright (c) 2007, Jouni Malinen <j at w1.fi>
+#ifndef TNCC_H
+#define TNCC_H
+struct tncc_data;
+struct tncc_data * tncc_init(void);
+void tncc_deinit(struct tncc_data *tncc);
+void tncc_init_connection(struct tncc_data *tncc);
+size_t tncc_total_send_len(struct tncc_data *tncc);
+u8 * tncc_copy_send_buf(struct tncc_data *tncc, u8 *pos);
+char * tncc_if_tnccs_start(struct tncc_data *tncc);
+char * tncc_if_tnccs_end(void);
+enum tncc_process_res {
+	TNCCS_PROCESS_ERROR = -1,
+	TNCCS_PROCESS_OK_NO_RECOMMENDATION = 0,
+	TNCCS_RECOMMENDATION_ERROR,
+	TNCCS_RECOMMENDATION_ALLOW,
+	TNCCS_RECOMMENDATION_NONE,
+	TNCCS_RECOMMENDATION_ISOLATE
+enum tncc_process_res tncc_process_if_tnccs(struct tncc_data *tncc,
+					    const u8 *msg, size_t len);
+struct wpabuf * tncc_process_soh_request(int ver, const u8 *data, size_t len);
+#endif /* TNCC_H */
diff --git a/freebsd/contrib/wpa/src/eap_server/eap_methods.h b/freebsd/contrib/wpa/src/eap_server/eap_methods.h
index 00000000000..0baa3279086
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eap_server/eap_methods.h
@@ -0,0 +1,51 @@
+ * EAP server method registration
+ * Copyright (c) 2004-2009, Jouni Malinen <j at w1.fi>
+#ifndef EAP_SERVER_METHODS_H
+#define EAP_SERVER_METHODS_H
+#include "eap_common/eap_defs.h"
+const struct eap_method * eap_server_get_eap_method(int vendor,
+						    EapType method);
+struct eap_method * eap_server_method_alloc(int version, int vendor,
+					    EapType method, const char *name);
+void eap_server_method_free(struct eap_method *method);
+int eap_server_method_register(struct eap_method *method);
+EapType eap_server_get_type(const char *name, int *vendor);
+void eap_server_unregister_methods(void);
+const char * eap_server_get_name(int vendor, EapType type);
+/* EAP server method registration calls for statically linked in methods */
+int eap_server_identity_register(void);
+int eap_server_md5_register(void);
+int eap_server_tls_register(void);
+int eap_server_unauth_tls_register(void);
+int eap_server_wfa_unauth_tls_register(void);
+int eap_server_mschapv2_register(void);
+int eap_server_peap_register(void);
+int eap_server_tlv_register(void);
+int eap_server_gtc_register(void);
+int eap_server_ttls_register(void);
+int eap_server_sim_register(void);
+int eap_server_aka_register(void);
+int eap_server_aka_prime_register(void);
+int eap_server_pax_register(void);
+int eap_server_psk_register(void);
+int eap_server_sake_register(void);
+int eap_server_gpsk_register(void);
+int eap_server_vendor_test_register(void);
+int eap_server_fast_register(void);
+int eap_server_wsc_register(void);
+int eap_server_ikev2_register(void);
+int eap_server_tnc_register(void);
+int eap_server_pwd_register(void);
+int eap_server_eke_register(void);
+#endif /* EAP_SERVER_METHODS_H */
diff --git a/freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c b/freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c
index 00000000000..e633d7c1a09
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c
@@ -0,0 +1,2152 @@
+ * EAPOL supplicant state machines
+ * Copyright (c) 2004-2012, Jouni Malinen <j at w1.fi>
+#include "state_machine.h"
+#include "wpabuf.h"
+#include "eloop.h"
+#include "crypto/crypto.h"
+#include "crypto/md5.h"
+#include "common/eapol_common.h"
+#include "eap_peer/eap.h"
+#include "eap_peer/eap_proxy.h"
+#include "eapol_supp_sm.h"
+#define STATE_MACHINE_DATA struct eapol_sm
+#define STATE_MACHINE_DEBUG_PREFIX "EAPOL"
+/* IEEE 802.1X-2004 - Supplicant - EAPOL state machines */
+ * struct eapol_sm - Internal data for EAPOL state machines
+struct eapol_sm {
+	/* Timers */
+	unsigned int authWhile;
+	unsigned int heldWhile;
+	unsigned int startWhen;
+	unsigned int idleWhile; /* for EAP state machine */
+	int timer_tick_enabled;
+	/* Global variables */
+	Boolean eapFail;
+	Boolean eapolEap;
+	Boolean eapSuccess;
+	Boolean initialize;
+	Boolean keyDone;
+	Boolean keyRun;
+	PortControl portControl;
+	Boolean portEnabled;
+	PortStatus suppPortStatus;  /* dot1xSuppControlledPortStatus */
+	Boolean portValid;
+	Boolean suppAbort;
+	Boolean suppFail;
+	Boolean suppStart;
+	Boolean suppSuccess;
+	Boolean suppTimeout;
+	/* Supplicant PAE state machine */
+	enum {
+		SUPP_PAE_UNKNOWN = 0,
+		SUPP_PAE_DISCONNECTED = 1,
+		SUPP_PAE_LOGOFF = 2,
+		SUPP_PAE_CONNECTING = 3,
+		SUPP_PAE_AUTHENTICATING = 4,
+		SUPP_PAE_AUTHENTICATED = 5,
+		/* unused(6) */
+		SUPP_PAE_HELD = 7,
+		SUPP_PAE_RESTART = 8,
+		SUPP_PAE_S_FORCE_AUTH = 9,
+		SUPP_PAE_S_FORCE_UNAUTH = 10
+	} SUPP_PAE_state; /* dot1xSuppPaeState */
+	/* Variables */
+	Boolean userLogoff;
+	Boolean logoffSent;
+	unsigned int startCount;
+	Boolean eapRestart;
+	PortControl sPortMode;
+	/* Constants */
+	unsigned int heldPeriod; /* dot1xSuppHeldPeriod */
+	unsigned int startPeriod; /* dot1xSuppStartPeriod */
+	unsigned int maxStart; /* dot1xSuppMaxStart */
+	/* Key Receive state machine */
+	enum {
+		KEY_RX_UNKNOWN = 0,
+		KEY_RX_NO_KEY_RECEIVE, KEY_RX_KEY_RECEIVE
+	} KEY_RX_state;
+	/* Variables */
+	Boolean rxKey;
+	/* Supplicant Backend state machine */
+	enum {
+		SUPP_BE_UNKNOWN = 0,
+		SUPP_BE_INITIALIZE = 1,
+		SUPP_BE_IDLE = 2,
+		SUPP_BE_REQUEST = 3,
+		SUPP_BE_RECEIVE = 4,
+		SUPP_BE_RESPONSE = 5,
+		SUPP_BE_FAIL = 6,
+		SUPP_BE_TIMEOUT = 7,
+		SUPP_BE_SUCCESS = 8
+	} SUPP_BE_state; /* dot1xSuppBackendPaeState */
+	/* Variables */
+	Boolean eapNoResp;
+	Boolean eapReq;
+	Boolean eapResp;
+	/* Constants */
+	unsigned int authPeriod; /* dot1xSuppAuthPeriod */
+	/* Statistics */
+	unsigned int dot1xSuppEapolFramesRx;
+	unsigned int dot1xSuppEapolFramesTx;
+	unsigned int dot1xSuppEapolStartFramesTx;
+	unsigned int dot1xSuppEapolLogoffFramesTx;
+	unsigned int dot1xSuppEapolRespFramesTx;
+	unsigned int dot1xSuppEapolReqIdFramesRx;
+	unsigned int dot1xSuppEapolReqFramesRx;
+	unsigned int dot1xSuppInvalidEapolFramesRx;
+	unsigned int dot1xSuppEapLengthErrorFramesRx;
+	unsigned int dot1xSuppLastEapolFrameVersion;
+	unsigned char dot1xSuppLastEapolFrameSource[6];
+	/* Miscellaneous variables (not defined in IEEE 802.1X-2004) */
+	Boolean changed;
+	struct eap_peer_config *config;
+	Boolean initial_req;
+	u8 *last_rx_key;
+	size_t last_rx_key_len;
+	struct wpabuf *eapReqData; /* for EAP */
+	Boolean altAccept; /* for EAP */
+	Boolean altReject; /* for EAP */
+	Boolean eapTriggerStart;
+	Boolean replay_counter_valid;
+	u8 last_replay_counter[16];
+	struct eapol_config conf;
+	struct eapol_ctx *ctx;
+	enum { EAPOL_CB_IN_PROGRESS = 0, EAPOL_CB_SUCCESS, EAPOL_CB_FAILURE }
+		cb_status;
+	Boolean cached_pmk;
+	Boolean unicast_key_received, broadcast_key_received;
+	Boolean force_authorized_update;
+#ifdef CONFIG_EAP_PROXY
+	Boolean use_eap_proxy;
+	struct eap_proxy_sm *eap_proxy;
+#endif /* CONFIG_EAP_PROXY */
+static void eapol_sm_txLogoff(struct eapol_sm *sm);
+static void eapol_sm_txStart(struct eapol_sm *sm);
+static void eapol_sm_processKey(struct eapol_sm *sm);
+static void eapol_sm_getSuppRsp(struct eapol_sm *sm);
+static void eapol_sm_txSuppRsp(struct eapol_sm *sm);
+static void eapol_sm_abortSupp(struct eapol_sm *sm);
+static void eapol_sm_abort_cached(struct eapol_sm *sm);
+static void eapol_sm_step_timeout(void *eloop_ctx, void *timeout_ctx);
+static void eapol_sm_set_port_authorized(struct eapol_sm *sm);
+static void eapol_sm_set_port_unauthorized(struct eapol_sm *sm);
+/* Port Timers state machine - implemented as a function that will be called
+ * once a second as a registered event loop timeout */
+static void eapol_port_timers_tick(void *eloop_ctx, void *timeout_ctx)
+	struct eapol_sm *sm = timeout_ctx;
+	if (sm->authWhile > 0) {
+		sm->authWhile--;
+		if (sm->authWhile == 0)
+			wpa_printf(MSG_DEBUG, "EAPOL: authWhile --> 0");
+	if (sm->heldWhile > 0) {
+		sm->heldWhile--;
+		if (sm->heldWhile == 0)
+			wpa_printf(MSG_DEBUG, "EAPOL: heldWhile --> 0");
+	if (sm->startWhen > 0) {
+		sm->startWhen--;
+		if (sm->startWhen == 0)
+			wpa_printf(MSG_DEBUG, "EAPOL: startWhen --> 0");
+	if (sm->idleWhile > 0) {
+		sm->idleWhile--;
+		if (sm->idleWhile == 0)
+			wpa_printf(MSG_DEBUG, "EAPOL: idleWhile --> 0");
+	if (sm->authWhile | sm->heldWhile | sm->startWhen | sm->idleWhile) {
+		eloop_register_timeout(1, 0, eapol_port_timers_tick, eloop_ctx,
+				       sm);
+	} else {
+		wpa_printf(MSG_DEBUG, "EAPOL: disable timer tick");
+		sm->timer_tick_enabled = 0;
+	eapol_sm_step(sm);
+static void eapol_enable_timer_tick(struct eapol_sm *sm)
+	if (sm->timer_tick_enabled)
+		return;
+	wpa_printf(MSG_DEBUG, "EAPOL: enable timer tick");
+	sm->timer_tick_enabled = 1;
+	eloop_cancel_timeout(eapol_port_timers_tick, NULL, sm);
+	eloop_register_timeout(1, 0, eapol_port_timers_tick, NULL, sm);
+SM_STATE(SUPP_PAE, LOGOFF)
+	SM_ENTRY(SUPP_PAE, LOGOFF);
+	eapol_sm_txLogoff(sm);
+	sm->logoffSent = TRUE;
+	eapol_sm_set_port_unauthorized(sm);
+SM_STATE(SUPP_PAE, DISCONNECTED)
+	SM_ENTRY(SUPP_PAE, DISCONNECTED);
+	sm->sPortMode = Auto;
+	sm->startCount = 0;
+	sm->eapTriggerStart = FALSE;
+	sm->logoffSent = FALSE;
+	sm->suppAbort = TRUE;
+	sm->unicast_key_received = FALSE;
+	sm->broadcast_key_received = FALSE;
+	 * IEEE Std 802.1X-2004 does not clear heldWhile here, but doing so
+	 * allows the timer tick to be stopped more quickly when the port is
+	 * not enabled. Since this variable is used only within HELD state,
+	 * clearing it on initialization does not change actual state machine
+	 * behavior.
+	sm->heldWhile = 0;
+SM_STATE(SUPP_PAE, CONNECTING)
+	int send_start = sm->SUPP_PAE_state == SUPP_PAE_CONNECTING ||
+		sm->SUPP_PAE_state == SUPP_PAE_HELD;
+	SM_ENTRY(SUPP_PAE, CONNECTING);
+	if (sm->eapTriggerStart)
+		send_start = 1;
+	if (send_start) {
+		sm->startWhen = sm->startPeriod;
+		sm->startCount++;
+	} else {
+		 * Do not send EAPOL-Start immediately since in most cases,
+		 * Authenticator is going to start authentication immediately
+		 * after association and an extra EAPOL-Start is just going to
+		 * delay authentication. Use a short timeout to send the first
+		 * EAPOL-Start if Authenticator does not start authentication.
+		if (sm->conf.wps && !(sm->conf.wps & EAPOL_PEER_IS_WPS20_AP)) {
+			/* Reduce latency on starting WPS negotiation. */
+				   "EAPOL: Using shorter startWhen for WPS");
+			sm->startWhen = 1;
+		} else {
+			sm->startWhen = 2;
+	eapol_enable_timer_tick(sm);
+	sm->eapolEap = FALSE;
+	if (send_start)
+		eapol_sm_txStart(sm);
+SM_STATE(SUPP_PAE, AUTHENTICATING)
+	SM_ENTRY(SUPP_PAE, AUTHENTICATING);
+	sm->suppSuccess = FALSE;
+	sm->suppFail = FALSE;
+	sm->suppTimeout = FALSE;
+	sm->keyRun = FALSE;
+	sm->keyDone = FALSE;
+	sm->suppStart = TRUE;
+SM_STATE(SUPP_PAE, HELD)
+	SM_ENTRY(SUPP_PAE, HELD);
+	sm->heldWhile = sm->heldPeriod;
+	sm->cb_status = EAPOL_CB_FAILURE;
+SM_STATE(SUPP_PAE, AUTHENTICATED)
+	SM_ENTRY(SUPP_PAE, AUTHENTICATED);
+	eapol_sm_set_port_authorized(sm);
+	sm->cb_status = EAPOL_CB_SUCCESS;
+SM_STATE(SUPP_PAE, RESTART)
+	SM_ENTRY(SUPP_PAE, RESTART);
+	sm->eapRestart = TRUE;
+SM_STATE(SUPP_PAE, S_FORCE_AUTH)
+	SM_ENTRY(SUPP_PAE, S_FORCE_AUTH);
+	sm->sPortMode = ForceAuthorized;
+SM_STATE(SUPP_PAE, S_FORCE_UNAUTH)
+	SM_ENTRY(SUPP_PAE, S_FORCE_UNAUTH);
+	sm->sPortMode = ForceUnauthorized;
+SM_STEP(SUPP_PAE)
+	if ((sm->userLogoff && !sm->logoffSent) &&
+	    !(sm->initialize || !sm->portEnabled))
+		SM_ENTER_GLOBAL(SUPP_PAE, LOGOFF);
+	else if (((sm->portControl == Auto) &&
+		  (sm->sPortMode != sm->portControl)) ||
+		 sm->initialize || !sm->portEnabled)
+		SM_ENTER_GLOBAL(SUPP_PAE, DISCONNECTED);
+	else if ((sm->portControl == ForceAuthorized) &&
+		 (sm->sPortMode != sm->portControl) &&
+		SM_ENTER_GLOBAL(SUPP_PAE, S_FORCE_AUTH);
+	else if ((sm->portControl == ForceUnauthorized) &&
+		SM_ENTER_GLOBAL(SUPP_PAE, S_FORCE_UNAUTH);
+	else switch (sm->SUPP_PAE_state) {
+	case SUPP_PAE_UNKNOWN:
+		break;
+	case SUPP_PAE_LOGOFF:
+		if (!sm->userLogoff)
+			SM_ENTER(SUPP_PAE, DISCONNECTED);
+		break;
+	case SUPP_PAE_DISCONNECTED:
+		SM_ENTER(SUPP_PAE, CONNECTING);
+		break;
+	case SUPP_PAE_CONNECTING:
+		if (sm->startWhen == 0 && sm->startCount < sm->maxStart)
+		else if (sm->startWhen == 0 &&
+			 sm->startCount >= sm->maxStart &&
+			 sm->portValid)
+			SM_ENTER(SUPP_PAE, AUTHENTICATED);
+		else if (sm->eapSuccess || sm->eapFail)
+			SM_ENTER(SUPP_PAE, AUTHENTICATING);
+		else if (sm->eapolEap)
+			SM_ENTER(SUPP_PAE, RESTART);
+			 !sm->portValid)
+			SM_ENTER(SUPP_PAE, HELD);
+		break;
+	case SUPP_PAE_AUTHENTICATING:
+		if (sm->eapSuccess && !sm->portValid &&
+		    sm->conf.accept_802_1x_keys &&
+		    sm->conf.required_keys == 0) {
+			wpa_printf(MSG_DEBUG, "EAPOL: IEEE 802.1X for "
+				   "plaintext connection; no EAPOL-Key frames "
+				   "required");
+			sm->portValid = TRUE;
+			if (sm->ctx->eapol_done_cb)
+				sm->ctx->eapol_done_cb(sm->ctx->ctx);
+		if (sm->eapSuccess && sm->portValid)
+		else if (sm->eapFail || (sm->keyDone && !sm->portValid))
+		else if (sm->suppTimeout)
+		else if (sm->eapTriggerStart)
+		break;
+	case SUPP_PAE_HELD:
+		break;
+	case SUPP_PAE_AUTHENTICATED:
+		if (sm->eapolEap && sm->portValid)
+		else if (!sm->portValid)
+		break;
+	case SUPP_PAE_RESTART:
+		if (!sm->eapRestart)
+		break;
+	case SUPP_PAE_S_FORCE_AUTH:
+		break;
+	case SUPP_PAE_S_FORCE_UNAUTH:
+		break;
+SM_STATE(KEY_RX, NO_KEY_RECEIVE)
+	SM_ENTRY(KEY_RX, NO_KEY_RECEIVE);
+SM_STATE(KEY_RX, KEY_RECEIVE)
+	SM_ENTRY(KEY_RX, KEY_RECEIVE);
+	eapol_sm_processKey(sm);
+	sm->rxKey = FALSE;
+SM_STEP(KEY_RX)
+	if (sm->initialize || !sm->portEnabled)
+		SM_ENTER_GLOBAL(KEY_RX, NO_KEY_RECEIVE);
+	switch (sm->KEY_RX_state) {
+	case KEY_RX_UNKNOWN:
+		break;
+	case KEY_RX_NO_KEY_RECEIVE:
+		if (sm->rxKey)
+			SM_ENTER(KEY_RX, KEY_RECEIVE);
+		break;
+	case KEY_RX_KEY_RECEIVE:
+		if (sm->rxKey)
+		break;
+SM_STATE(SUPP_BE, REQUEST)
+	SM_ENTRY(SUPP_BE, REQUEST);
+	sm->authWhile = 0;
+	sm->eapReq = TRUE;
+	eapol_sm_getSuppRsp(sm);
+SM_STATE(SUPP_BE, RESPONSE)
+	SM_ENTRY(SUPP_BE, RESPONSE);
+	eapol_sm_txSuppRsp(sm);
+	sm->eapResp = FALSE;
+SM_STATE(SUPP_BE, SUCCESS)
+	SM_ENTRY(SUPP_BE, SUCCESS);
+	sm->keyRun = TRUE;
+	sm->suppSuccess = TRUE;
+	if (sm->use_eap_proxy) {
+		if (eap_proxy_key_available(sm->eap_proxy)) {
+			/* New key received - clear IEEE 802.1X EAPOL-Key replay
+			 * counter */
+			sm->replay_counter_valid = FALSE;
+		return;
+	if (eap_key_available(sm->eap)) {
+		 * counter */
+SM_STATE(SUPP_BE, FAIL)
+	SM_ENTRY(SUPP_BE, FAIL);
+	sm->suppFail = TRUE;
+SM_STATE(SUPP_BE, TIMEOUT)
+	SM_ENTRY(SUPP_BE, TIMEOUT);
+	sm->suppTimeout = TRUE;
+SM_STATE(SUPP_BE, IDLE)
+	SM_ENTRY(SUPP_BE, IDLE);
+	sm->suppStart = FALSE;
+	sm->initial_req = TRUE;
+SM_STATE(SUPP_BE, INITIALIZE)
+	SM_ENTRY(SUPP_BE, INITIALIZE);
+	eapol_sm_abortSupp(sm);
+	sm->suppAbort = FALSE;
+	 * IEEE Std 802.1X-2004 does not clear authWhile here, but doing so
+	 * not enabled. Since this variable is used only within RECEIVE state,
+	 * behavior.
+SM_STATE(SUPP_BE, RECEIVE)
+	SM_ENTRY(SUPP_BE, RECEIVE);
+	sm->authWhile = sm->authPeriod;
+	sm->eapNoResp = FALSE;
+	sm->initial_req = FALSE;
+SM_STEP(SUPP_BE)
+	if (sm->initialize || sm->suppAbort)
+		SM_ENTER_GLOBAL(SUPP_BE, INITIALIZE);
+	else switch (sm->SUPP_BE_state) {
+	case SUPP_BE_UNKNOWN:
+		break;
+	case SUPP_BE_REQUEST:
+		 * IEEE Std 802.1X-2004 has transitions from REQUEST to FAIL
+		 * and SUCCESS based on eapFail and eapSuccess, respectively.
+		 * However, IEEE Std 802.1X-2004 is also specifying that
+		 * eapNoResp should be set in conjunction with eapSuccess and
+		 * eapFail which would mean that more than one of the
+		 * transitions here would be activated at the same time.
+		 * Skipping RESPONSE and/or RECEIVE states in these cases can
+		 * cause problems and the direct transitions to do not seem
+		 * correct. Because of this, the conditions for these
+		 * transitions are verified only after eapNoResp. They are
+		 * unlikely to be used since eapNoResp should always be set if
+		 * either of eapSuccess or eapFail is set.
+		if (sm->eapResp && sm->eapNoResp) {
+			wpa_printf(MSG_DEBUG, "EAPOL: SUPP_BE REQUEST: both "
+				   "eapResp and eapNoResp set?!");
+		if (sm->eapResp)
+			SM_ENTER(SUPP_BE, RESPONSE);
+		else if (sm->eapNoResp)
+			SM_ENTER(SUPP_BE, RECEIVE);
+		else if (sm->eapFail)
+			SM_ENTER(SUPP_BE, FAIL);
+		else if (sm->eapSuccess)
+			SM_ENTER(SUPP_BE, SUCCESS);
+		break;
+	case SUPP_BE_RESPONSE:
+		break;
+	case SUPP_BE_SUCCESS:
+		SM_ENTER(SUPP_BE, IDLE);
+		break;
+	case SUPP_BE_FAIL:
+		break;
+	case SUPP_BE_TIMEOUT:
+		break;
+	case SUPP_BE_IDLE:
+		if (sm->eapFail && sm->suppStart)
+		else if (sm->eapolEap && sm->suppStart)
+			SM_ENTER(SUPP_BE, REQUEST);
+		else if (sm->eapSuccess && sm->suppStart)
+		break;
+	case SUPP_BE_INITIALIZE:
+		break;
+	case SUPP_BE_RECEIVE:
+		if (sm->eapolEap)
+		else if (sm->authWhile == 0)
+			SM_ENTER(SUPP_BE, TIMEOUT);
+		break;
+	wpa_printf(MSG_DEBUG, "EAPOL: txLogoff");
+	sm->ctx->eapol_send(sm->ctx->eapol_send_ctx,
+			    IEEE802_1X_TYPE_EAPOL_LOGOFF, (u8 *) "", 0);
+	sm->dot1xSuppEapolLogoffFramesTx++;
+	sm->dot1xSuppEapolFramesTx++;
+	wpa_printf(MSG_DEBUG, "EAPOL: txStart");
+			    IEEE802_1X_TYPE_EAPOL_START, (u8 *) "", 0);
+	sm->dot1xSuppEapolStartFramesTx++;
+#define IEEE8021X_ENCR_KEY_LEN 32
+#define IEEE8021X_SIGN_KEY_LEN 32
+struct eap_key_data {
+	u8 encr_key[IEEE8021X_ENCR_KEY_LEN];
+	u8 sign_key[IEEE8021X_SIGN_KEY_LEN];
+	struct ieee802_1x_hdr *hdr;
+	struct ieee802_1x_eapol_key *key;
+	struct eap_key_data keydata;
+	u8 orig_key_sign[IEEE8021X_KEY_SIGN_LEN], datakey[32];
+#ifndef CONFIG_NO_RC4
+	u8 ekey[IEEE8021X_KEY_IV_LEN + IEEE8021X_ENCR_KEY_LEN];
+#endif /* CONFIG_NO_RC4 */
+	int key_len, res, sign_key_len, encr_key_len;
+	u16 rx_key_length;
+	size_t plen;
+	wpa_printf(MSG_DEBUG, "EAPOL: processKey");
+	if (sm->last_rx_key == NULL)
+		return;
+	if (!sm->conf.accept_802_1x_keys) {
+		wpa_printf(MSG_WARNING, "EAPOL: Received IEEE 802.1X EAPOL-Key"
+			   " even though this was not accepted - "
+			   "ignoring this packet");
+		return;
+	if (sm->last_rx_key_len < sizeof(*hdr) + sizeof(*key))
+		return;
+	hdr = (struct ieee802_1x_hdr *) sm->last_rx_key;
+	key = (struct ieee802_1x_eapol_key *) (hdr + 1);
+	plen = be_to_host16(hdr->length);
+	if (sizeof(*hdr) + plen > sm->last_rx_key_len || plen < sizeof(*key)) {
+		wpa_printf(MSG_WARNING, "EAPOL: Too short EAPOL-Key frame");
+		return;
+	rx_key_length = WPA_GET_BE16(key->key_length);
+	wpa_printf(MSG_DEBUG, "EAPOL: RX IEEE 802.1X ver=%d type=%d len=%d "
+		   "EAPOL-Key: type=%d key_length=%d key_index=0x%x",
+		   hdr->version, hdr->type, be_to_host16(hdr->length),
+		   key->type, rx_key_length, key->key_index);
+	eapol_sm_notify_lower_layer_success(sm, 1);
+	sign_key_len = IEEE8021X_SIGN_KEY_LEN;
+	encr_key_len = IEEE8021X_ENCR_KEY_LEN;
+	res = eapol_sm_get_key(sm, (u8 *) &keydata, sizeof(keydata));
+	if (res < 0) {
+		wpa_printf(MSG_DEBUG, "EAPOL: Could not get master key for "
+			   "decrypting EAPOL-Key keys");
+		return;
+	if (res == 16) {
+		/* LEAP derives only 16 bytes of keying material. */
+		res = eapol_sm_get_key(sm, (u8 *) &keydata, 16);
+		if (res) {
+			wpa_printf(MSG_DEBUG, "EAPOL: Could not get LEAP "
+				   "master key for decrypting EAPOL-Key keys");
+			return;
+		sign_key_len = 16;
+		encr_key_len = 16;
+		os_memcpy(keydata.sign_key, keydata.encr_key, 16);
+	} else if (res) {
+		wpa_printf(MSG_DEBUG, "EAPOL: Could not get enough master key "
+			   "data for decrypting EAPOL-Key keys (res=%d)", res);
+		return;
+	/* The key replay_counter must increase when same master key */
+	if (sm->replay_counter_valid &&
+	    os_memcmp(sm->last_replay_counter, key->replay_counter,
+		      IEEE8021X_REPLAY_COUNTER_LEN) >= 0) {
+		wpa_printf(MSG_WARNING, "EAPOL: EAPOL-Key replay counter did "
+			   "not increase - ignoring key");
+		wpa_hexdump(MSG_DEBUG, "EAPOL: last replay counter",
+			    sm->last_replay_counter,
+			    IEEE8021X_REPLAY_COUNTER_LEN);
+		wpa_hexdump(MSG_DEBUG, "EAPOL: received replay counter",
+			    key->replay_counter, IEEE8021X_REPLAY_COUNTER_LEN);
+		return;
+	/* Verify key signature (HMAC-MD5) */
+	os_memcpy(orig_key_sign, key->key_signature, IEEE8021X_KEY_SIGN_LEN);
+	os_memset(key->key_signature, 0, IEEE8021X_KEY_SIGN_LEN);
+	hmac_md5(keydata.sign_key, sign_key_len,
+		 sm->last_rx_key, sizeof(*hdr) + be_to_host16(hdr->length),
+		 key->key_signature);
+	if (os_memcmp_const(orig_key_sign, key->key_signature,
+			    IEEE8021X_KEY_SIGN_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "EAPOL: Invalid key signature in "
+			   "EAPOL-Key packet");
+		os_memcpy(key->key_signature, orig_key_sign,
+			  IEEE8021X_KEY_SIGN_LEN);
+		return;
+	wpa_printf(MSG_DEBUG, "EAPOL: EAPOL-Key key signature verified");
+	key_len = plen - sizeof(*key);
+	if (key_len > 32 || rx_key_length > 32) {
+		wpa_printf(MSG_WARNING, "EAPOL: Too long key data length %d",
+			   key_len ? key_len : rx_key_length);
+		return;
+	if (key_len == rx_key_length) {
+#ifdef CONFIG_NO_RC4
+		if (encr_key_len) {
+			/* otherwise unused */
+		wpa_printf(MSG_ERROR, "EAPOL: RC4 not supported in the build");
+		return;
+#else /* CONFIG_NO_RC4 */
+		os_memcpy(ekey, key->key_iv, IEEE8021X_KEY_IV_LEN);
+		os_memcpy(ekey + IEEE8021X_KEY_IV_LEN, keydata.encr_key,
+			  encr_key_len);
+		os_memcpy(datakey, key + 1, key_len);
+		rc4_skip(ekey, IEEE8021X_KEY_IV_LEN + encr_key_len, 0,
+			 datakey, key_len);
+		wpa_hexdump_key(MSG_DEBUG, "EAPOL: Decrypted(RC4) key",
+	} else if (key_len == 0) {
+		 * IEEE 802.1X-2004 specifies that least significant Key Length
+		 * octets from MS-MPPE-Send-Key are used as the key if the key
+		 * data is not present. This seems to be meaning the beginning
+		 * of the MS-MPPE-Send-Key. In addition, MS-MPPE-Send-Key in
+		 * Supplicant corresponds to MS-MPPE-Recv-Key in Authenticator.
+		 * Anyway, taking the beginning of the keying material from EAP
+		 * seems to interoperate with Authenticators.
+		key_len = rx_key_length;
+		os_memcpy(datakey, keydata.encr_key, key_len);
+		wpa_hexdump_key(MSG_DEBUG, "EAPOL: using part of EAP keying "
+				"material data encryption key",
+	} else {
+		wpa_printf(MSG_DEBUG, "EAPOL: Invalid key data length %d "
+			   "(key_length=%d)", key_len, rx_key_length);
+		return;
+	sm->replay_counter_valid = TRUE;
+	os_memcpy(sm->last_replay_counter, key->replay_counter,
+	wpa_printf(MSG_DEBUG, "EAPOL: Setting dynamic WEP key: %s keyidx %d "
+		   "len %d",
+		   key->key_index & IEEE8021X_KEY_INDEX_FLAG ?
+		   "unicast" : "broadcast",
+		   key->key_index & IEEE8021X_KEY_INDEX_MASK, key_len);
+	if (sm->ctx->set_wep_key &&
+	    sm->ctx->set_wep_key(sm->ctx->ctx,
+				 key->key_index & IEEE8021X_KEY_INDEX_FLAG,
+				 datakey, key_len) < 0) {
+		wpa_printf(MSG_WARNING, "EAPOL: Failed to set WEP key to the "
+			   " driver.");
+	} else {
+		if (key->key_index & IEEE8021X_KEY_INDEX_FLAG)
+			sm->unicast_key_received = TRUE;
+		else
+			sm->broadcast_key_received = TRUE;
+		if ((sm->unicast_key_received ||
+		     !(sm->conf.required_keys & EAPOL_REQUIRE_KEY_UNICAST)) &&
+		    (sm->broadcast_key_received ||
+		     !(sm->conf.required_keys & EAPOL_REQUIRE_KEY_BROADCAST)))
+			wpa_printf(MSG_DEBUG, "EAPOL: all required EAPOL-Key "
+				   "frames received");
+	wpa_printf(MSG_DEBUG, "EAPOL: getSuppRsp");
+	/* EAP layer processing; no special code is needed, since Supplicant
+	 * Backend state machine is waiting for eapNoResp or eapResp to be set
+	 * and these are only set in the EAP state machine when the processing
+	 * has finished. */
+	wpa_printf(MSG_DEBUG, "EAPOL: txSuppRsp");
+		/* Get EAP Response from EAP Proxy */
+		resp = eap_proxy_get_eapRespData(sm->eap_proxy);
+		if (resp == NULL) {
+			wpa_printf(MSG_WARNING, "EAPOL: txSuppRsp - EAP Proxy "
+				   "response data not available");
+			return;
+	} else
+	resp = eap_get_eapRespData(sm->eap);
+		wpa_printf(MSG_WARNING, "EAPOL: txSuppRsp - EAP response data "
+			   "not available");
+		return;
+	/* Send EAP-Packet from the EAP layer to the Authenticator */
+			    IEEE802_1X_TYPE_EAP_PACKET, wpabuf_head(resp),
+			    wpabuf_len(resp));
+	/* eapRespData is not used anymore, so free it here */
+	if (sm->initial_req)
+		sm->dot1xSuppEapolReqIdFramesRx++;
+	else
+		sm->dot1xSuppEapolReqFramesRx++;
+	sm->dot1xSuppEapolRespFramesTx++;
+	/* release system resources that may have been allocated for the
+	 * authentication session */
+	os_free(sm->last_rx_key);
+	sm->last_rx_key = NULL;
+	wpabuf_free(sm->eapReqData);
+	sm->eapReqData = NULL;
+	eap_sm_abort(sm->eap);
+	eapol_sm_step(timeout_ctx);
+	int cb;
+	cb = sm->suppPortStatus != Authorized || sm->force_authorized_update;
+	sm->force_authorized_update = FALSE;
+	sm->suppPortStatus = Authorized;
+	if (cb && sm->ctx->port_cb)
+		sm->ctx->port_cb(sm->ctx->ctx, 1);
+	int cb;
+	cb = sm->suppPortStatus != Unauthorized || sm->force_authorized_update;
+	sm->suppPortStatus = Unauthorized;
+		sm->ctx->port_cb(sm->ctx->ctx, 0);
+ * eapol_sm_step - EAPOL state machine step function
+ * @sm: Pointer to EAPOL state machine allocated with eapol_sm_init()
+ * This function is called to notify the state machine about changed external
+ * variables. It will step through the EAPOL state machines in loop to process
+ * all triggered state changes.
+void eapol_sm_step(struct eapol_sm *sm)
+	int i;
+	/* In theory, it should be ok to run this in loop until !changed.
+	 * However, it is better to use a limit on number of iterations to
+	 * allow events (e.g., SIGTERM) to stop the program cleanly if the
+	 * state machine were to generate a busy loop. */
+	for (i = 0; i < 100; i++) {
+		sm->changed = FALSE;
+		SM_STEP_RUN(SUPP_PAE);
+		SM_STEP_RUN(KEY_RX);
+		SM_STEP_RUN(SUPP_BE);
+			/* Drive the EAP proxy state machine */
+			if (eap_proxy_sm_step(sm->eap_proxy, sm->eap))
+				sm->changed = TRUE;
+		} else
+		if (eap_peer_sm_step(sm->eap))
+		if (!sm->changed)
+			break;
+	if (sm->changed) {
+		/* restart EAPOL state machine step from timeout call in order
+		 * to allow other events to be processed. */
+		eloop_cancel_timeout(eapol_sm_step_timeout, NULL, sm);
+		eloop_register_timeout(0, 0, eapol_sm_step_timeout, NULL, sm);
+	if (sm->ctx->cb && sm->cb_status != EAPOL_CB_IN_PROGRESS) {
+		enum eapol_supp_result result;
+		if (sm->cb_status == EAPOL_CB_SUCCESS)
+			result = EAPOL_SUPP_RESULT_SUCCESS;
+		else if (eap_peer_was_failure_expected(sm->eap))
+			result = EAPOL_SUPP_RESULT_EXPECTED_FAILURE;
+		else
+			result = EAPOL_SUPP_RESULT_FAILURE;
+		sm->cb_status = EAPOL_CB_IN_PROGRESS;
+		sm->ctx->cb(sm, result, sm->ctx->cb_ctx);
+#ifdef CONFIG_CTRL_IFACE
+static const char *eapol_supp_pae_state(int state)
+	switch (state) {
+		return "LOGOFF";
+		return "DISCONNECTED";
+		return "CONNECTING";
+		return "AUTHENTICATING";
+		return "HELD";
+		return "AUTHENTICATED";
+		return "RESTART";
+	default:
+		return "UNKNOWN";
+static const char *eapol_supp_be_state(int state)
+	switch (state) {
+		return "REQUEST";
+		return "RESPONSE";
+		return "SUCCESS";
+		return "FAIL";
+		return "TIMEOUT";
+		return "IDLE";
+		return "INITIALIZE";
+		return "RECEIVE";
+	default:
+		return "UNKNOWN";
+static const char * eapol_port_status(PortStatus status)
+	if (status == Authorized)
+		return "Authorized";
+	else
+		return "Unauthorized";
+#endif /* CONFIG_CTRL_IFACE */
+#if defined(CONFIG_CTRL_IFACE) || !defined(CONFIG_NO_STDOUT_DEBUG)
+static const char * eapol_port_control(PortControl ctrl)
+	switch (ctrl) {
+	case Auto:
+		return "Auto";
+	case ForceUnauthorized:
+		return "ForceUnauthorized";
+	case ForceAuthorized:
+		return "ForceAuthorized";
+	default:
+		return "Unknown";
+#endif /* CONFIG_CTRL_IFACE || !CONFIG_NO_STDOUT_DEBUG */
+ * eapol_sm_configure - Set EAPOL variables
+ * @heldPeriod: dot1xSuppHeldPeriod
+ * @authPeriod: dot1xSuppAuthPeriod
+ * @startPeriod: dot1xSuppStartPeriod
+ * @maxStart: dot1xSuppMaxStart
+ * Set configurable EAPOL state machine variables. Each variable can be set to
+ * the given value or ignored if set to -1 (to set only some of the variables).
+void eapol_sm_configure(struct eapol_sm *sm, int heldPeriod, int authPeriod,
+			int startPeriod, int maxStart)
+	if (sm == NULL)
+		return;
+	if (heldPeriod >= 0)
+		sm->heldPeriod = heldPeriod;
+	if (authPeriod >= 0)
+		sm->authPeriod = authPeriod;
+	if (startPeriod >= 0)
+		sm->startPeriod = startPeriod;
+	if (maxStart >= 0)
+		sm->maxStart = maxStart;
+ * eapol_sm_get_method_name - Get EAPOL method name
+ * Returns: Static string containing name of current eap method or NULL
+const char * eapol_sm_get_method_name(struct eapol_sm *sm)
+	if (sm->SUPP_PAE_state != SUPP_PAE_AUTHENTICATED ||
+	    sm->suppPortStatus != Authorized)
+		return NULL;
+	return eap_sm_get_method_name(sm->eap);
+ * eapol_sm_get_status - Get EAPOL state machine status
+ * @buf: Buffer for status information
+ * @buflen: Maximum buffer length
+ * @verbose: Whether to include verbose status information
+ * Returns: Number of bytes written to buf.
+ * Query EAPOL state machine for status information. This function fills in a
+ * text area with current status information from the EAPOL state machine. If
+ * the buffer (buf) is not large enough, status information will be truncated
+ * to fit the buffer.
+int eapol_sm_get_status(struct eapol_sm *sm, char *buf, size_t buflen,
+			int verbose)
+	int len, ret;
+	if (sm == NULL)
+		return 0;
+	len = os_snprintf(buf, buflen,
+			  "Supplicant PAE state=%s\n"
+			  "suppPortStatus=%s\n",
+			  eapol_supp_pae_state(sm->SUPP_PAE_state),
+			  eapol_port_status(sm->suppPortStatus));
+	if (os_snprintf_error(buflen, len))
+		return 0;
+	if (verbose) {
+				  "heldPeriod=%u\n"
+				  "authPeriod=%u\n"
+				  "startPeriod=%u\n"
+				  "maxStart=%u\n"
+				  "portControl=%s\n"
+				  "Supplicant Backend state=%s\n",
+				  sm->heldPeriod,
+				  sm->authPeriod,
+				  sm->startPeriod,
+				  sm->maxStart,
+				  eapol_port_control(sm->portControl),
+				  eapol_supp_be_state(sm->SUPP_BE_state));
+			return len;
+		len += ret;
+		len += eap_proxy_sm_get_status(sm->eap_proxy,
+					       buf + len, buflen - len,
+					       verbose);
+	else
+	len += eap_sm_get_status(sm->eap, buf + len, buflen - len, verbose);
+	return len;
+ * eapol_sm_get_mib - Get EAPOL state machine MIBs
+ * @buf: Buffer for MIB information
+ * Query EAPOL state machine for MIB information. This function fills in a
+ * text area with current MIB information from the EAPOL state machine. If
+ * the buffer (buf) is not large enough, MIB information will be truncated to
+ * fit the buffer.
+int eapol_sm_get_mib(struct eapol_sm *sm, char *buf, size_t buflen)
+	size_t len;
+	int ret;
+	if (sm == NULL)
+		return 0;
+	ret = os_snprintf(buf, buflen,
+			  "dot1xSuppPaeState=%d\n"
+			  "dot1xSuppHeldPeriod=%u\n"
+			  "dot1xSuppAuthPeriod=%u\n"
+			  "dot1xSuppStartPeriod=%u\n"
+			  "dot1xSuppMaxStart=%u\n"
+			  "dot1xSuppSuppControlledPortStatus=%s\n"
+			  "dot1xSuppBackendPaeState=%d\n",
+			  sm->SUPP_PAE_state,
+			  sm->heldPeriod,
+			  sm->authPeriod,
+			  sm->startPeriod,
+			  sm->maxStart,
+			  sm->suppPortStatus == Authorized ?
+			  "Authorized" : "Unauthorized",
+			  sm->SUPP_BE_state);
+	if (os_snprintf_error(buflen, ret))
+		return 0;
+	len = ret;
+			  "dot1xSuppEapolFramesRx=%u\n"
+			  "dot1xSuppEapolFramesTx=%u\n"
+			  "dot1xSuppEapolStartFramesTx=%u\n"
+			  "dot1xSuppEapolLogoffFramesTx=%u\n"
+			  "dot1xSuppEapolRespFramesTx=%u\n"
+			  "dot1xSuppEapolReqIdFramesRx=%u\n"
+			  "dot1xSuppEapolReqFramesRx=%u\n"
+			  "dot1xSuppInvalidEapolFramesRx=%u\n"
+			  "dot1xSuppEapLengthErrorFramesRx=%u\n"
+			  "dot1xSuppLastEapolFrameVersion=%u\n"
+			  "dot1xSuppLastEapolFrameSource=" MACSTR "\n",
+			  sm->dot1xSuppEapolFramesRx,
+			  sm->dot1xSuppEapolFramesTx,
+			  sm->dot1xSuppEapolStartFramesTx,
+			  sm->dot1xSuppEapolLogoffFramesTx,
+			  sm->dot1xSuppEapolRespFramesTx,
+			  sm->dot1xSuppEapolReqIdFramesRx,
+			  sm->dot1xSuppEapolReqFramesRx,
+			  sm->dot1xSuppInvalidEapolFramesRx,
+			  sm->dot1xSuppEapLengthErrorFramesRx,
+			  sm->dot1xSuppLastEapolFrameVersion,
+			  MAC2STR(sm->dot1xSuppLastEapolFrameSource));
+		return len;
+	len += ret;
+	return len;
+ * eapol_sm_rx_eapol - Process received EAPOL frames
+ * @src: Source MAC address of the EAPOL packet
+ * @buf: Pointer to the beginning of the EAPOL data (EAPOL header)
+ * @len: Length of the EAPOL frame
+ * Returns: 1 = EAPOL frame processed, 0 = not for EAPOL state machine,
+ * -1 failure
+int eapol_sm_rx_eapol(struct eapol_sm *sm, const u8 *src, const u8 *buf,
+		      size_t len)
+	const struct ieee802_1x_hdr *hdr;
+	const struct ieee802_1x_eapol_key *key;
+	int data_len;
+	int res = 1;
+	size_t plen;
+	if (sm == NULL)
+		return 0;
+	sm->dot1xSuppEapolFramesRx++;
+	if (len < sizeof(*hdr)) {
+		sm->dot1xSuppInvalidEapolFramesRx++;
+		return 0;
+	hdr = (const struct ieee802_1x_hdr *) buf;
+	sm->dot1xSuppLastEapolFrameVersion = hdr->version;
+	os_memcpy(sm->dot1xSuppLastEapolFrameSource, src, ETH_ALEN);
+	if (hdr->version < EAPOL_VERSION) {
+		/* TODO: backwards compatibility */
+	if (plen > len - sizeof(*hdr)) {
+		sm->dot1xSuppEapLengthErrorFramesRx++;
+		return 0;
+#ifdef CONFIG_WPS
+	if (sm->conf.wps && sm->conf.workaround &&
+	    plen < len - sizeof(*hdr) &&
+	    hdr->type == IEEE802_1X_TYPE_EAP_PACKET &&
+	    len - sizeof(*hdr) > sizeof(struct eap_hdr)) {
+		const struct eap_hdr *ehdr =
+			(const struct eap_hdr *) (hdr + 1);
+		u16 elen;
+		elen = be_to_host16(ehdr->length);
+		if (elen > plen && elen <= len - sizeof(*hdr)) {
+			 * Buffalo WHR-G125 Ver.1.47 seems to send EAP-WPS
+			 * packets with too short EAPOL header length field
+			 * (14 octets). This is fixed in firmware Ver.1.49.
+			 * As a workaround, fix the EAPOL header based on the
+			 * correct length in the EAP packet.
+			wpa_printf(MSG_DEBUG, "EAPOL: Workaround - fix EAPOL "
+				   "payload length based on EAP header: "
+				   "%d -> %d", (int) plen, elen);
+			plen = elen;
+#endif /* CONFIG_WPS */
+	data_len = plen + sizeof(*hdr);
+	switch (hdr->type) {
+	case IEEE802_1X_TYPE_EAP_PACKET:
+		if (sm->conf.workaround) {
+			 * An AP has been reported to send out EAP message with
+			 * undocumented code 10 at some point near the
+			 * completion of EAP authentication. This can result in
+			 * issues with the unexpected EAP message triggering
+			 * restart of EAPOL authentication. Avoid this by
+			 * skipping the message without advancing the state
+			 * machine.
+			if (plen >= sizeof(*ehdr) && ehdr->code == 10) {
+				wpa_printf(MSG_DEBUG, "EAPOL: Ignore EAP packet with unknown code 10");
+				break;
+		if (sm->cached_pmk) {
+			/* Trying to use PMKSA caching, but Authenticator did
+			 * not seem to have a matching entry. Need to restart
+			 * EAPOL state machines.
+			eapol_sm_abort_cached(sm);
+		sm->eapReqData = wpabuf_alloc_copy(hdr + 1, plen);
+		if (sm->eapReqData) {
+			wpa_printf(MSG_DEBUG, "EAPOL: Received EAP-Packet "
+				   "frame");
+			sm->eapolEap = TRUE;
+				eap_proxy_packet_update(
+					sm->eap_proxy,
+					wpabuf_mhead_u8(sm->eapReqData),
+					wpabuf_len(sm->eapReqData));
+				wpa_printf(MSG_DEBUG, "EAPOL: eap_proxy "
+					   "EAP Req updated");
+		break;
+	case IEEE802_1X_TYPE_EAPOL_KEY:
+		if (plen < sizeof(*key)) {
+			wpa_printf(MSG_DEBUG, "EAPOL: Too short EAPOL-Key "
+				   "frame received");
+			break;
+		key = (const struct ieee802_1x_eapol_key *) (hdr + 1);
+		if (key->type == EAPOL_KEY_TYPE_WPA ||
+		    key->type == EAPOL_KEY_TYPE_RSN) {
+			/* WPA Supplicant takes care of this frame. */
+			wpa_printf(MSG_DEBUG, "EAPOL: Ignoring WPA EAPOL-Key "
+				   "frame in EAPOL state machines");
+			res = 0;
+			break;
+		if (key->type != EAPOL_KEY_TYPE_RC4) {
+			wpa_printf(MSG_DEBUG, "EAPOL: Ignored unknown "
+				   "EAPOL-Key type %d", key->type);
+			break;
+		sm->last_rx_key = os_malloc(data_len);
+		if (sm->last_rx_key) {
+			wpa_printf(MSG_DEBUG, "EAPOL: Received EAPOL-Key "
+				   "frame");
+			os_memcpy(sm->last_rx_key, buf, data_len);
+			sm->last_rx_key_len = data_len;
+			sm->rxKey = TRUE;
+		break;
+#ifdef CONFIG_MACSEC
+	case IEEE802_1X_TYPE_EAPOL_MKA:
+		wpa_printf(MSG_EXCESSIVE,
+			   "EAPOL type %d will be handled by MKA",
+			   hdr->type);
+		break;
+#endif /* CONFIG_MACSEC */
+	default:
+		wpa_printf(MSG_DEBUG, "EAPOL: Received unknown EAPOL type %d",
+			   hdr->type);
+		break;
+	return res;
+ * eapol_sm_notify_tx_eapol_key - Notification about transmitted EAPOL packet
+ * Notify EAPOL state machine about transmitted EAPOL packet from an external
+ * component, e.g., WPA. This will update the statistics.
+void eapol_sm_notify_tx_eapol_key(struct eapol_sm *sm)
+	if (sm)
+ * eapol_sm_notify_portEnabled - Notification about portEnabled change
+ * @enabled: New portEnabled value
+ * Notify EAPOL state machine about new portEnabled value.
+void eapol_sm_notify_portEnabled(struct eapol_sm *sm, Boolean enabled)
+	if (sm == NULL)
+		return;
+	wpa_printf(MSG_DEBUG, "EAPOL: External notification - "
+		   "portEnabled=%d", enabled);
+	if (sm->portEnabled != enabled)
+		sm->force_authorized_update = TRUE;
+	sm->portEnabled = enabled;
+ * eapol_sm_notify_portValid - Notification about portValid change
+ * @valid: New portValid value
+ * Notify EAPOL state machine about new portValid value.
+void eapol_sm_notify_portValid(struct eapol_sm *sm, Boolean valid)
+	if (sm == NULL)
+		return;
+		   "portValid=%d", valid);
+	sm->portValid = valid;
+ * eapol_sm_notify_eap_success - Notification of external EAP success trigger
+ * @success: %TRUE = set success, %FALSE = clear success
+ * Notify the EAPOL state machine that external event has forced EAP state to
+ * success (success = %TRUE). This can be cleared by setting success = %FALSE.
+ * This function is called to update EAP state when WPA-PSK key handshake has
+ * been completed successfully since WPA-PSK does not use EAP state machine.
+void eapol_sm_notify_eap_success(struct eapol_sm *sm, Boolean success)
+	if (sm == NULL)
+		return;
+		   "EAP success=%d", success);
+	sm->eapSuccess = success;
+	sm->altAccept = success;
+	if (success)
+		eap_notify_success(sm->eap);
+ * eapol_sm_notify_eap_fail - Notification of external EAP failure trigger
+ * @fail: %TRUE = set failure, %FALSE = clear failure
+ * Notify EAPOL state machine that external event has forced EAP state to
+ * failure (fail = %TRUE). This can be cleared by setting fail = %FALSE.
+void eapol_sm_notify_eap_fail(struct eapol_sm *sm, Boolean fail)
+	if (sm == NULL)
+		return;
+		   "EAP fail=%d", fail);
+	sm->eapFail = fail;
+	sm->altReject = fail;
+ * eapol_sm_notify_config - Notification of EAPOL configuration change
+ * @config: Pointer to current network EAP configuration
+ * @conf: Pointer to EAPOL configuration data
+ * Notify EAPOL state machine that configuration has changed. config will be
+ * stored as a backpointer to network configuration. This can be %NULL to clear
+ * the stored pointed. conf will be copied to local EAPOL/EAP configuration
+ * data. If conf is %NULL, this part of the configuration change will be
+ * skipped.
+void eapol_sm_notify_config(struct eapol_sm *sm,
+			    struct eap_peer_config *config,
+			    const struct eapol_config *conf)
+	if (sm == NULL)
+		return;
+	sm->config = config;
+	sm->use_eap_proxy = eap_proxy_notify_config(sm->eap_proxy, config) > 0;
+	if (conf == NULL)
+		return;
+	sm->conf.accept_802_1x_keys = conf->accept_802_1x_keys;
+	sm->conf.required_keys = conf->required_keys;
+	sm->conf.fast_reauth = conf->fast_reauth;
+	sm->conf.workaround = conf->workaround;
+	sm->conf.wps = conf->wps;
+		/* Using EAP Proxy, so skip EAP state machine update */
+		return;
+	if (sm->eap) {
+		eap_set_fast_reauth(sm->eap, conf->fast_reauth);
+		eap_set_workaround(sm->eap, conf->workaround);
+		eap_set_force_disabled(sm->eap, conf->eap_disabled);
+		eap_set_external_sim(sm->eap, conf->external_sim);
+ * eapol_sm_get_key - Get master session key (MSK) from EAP
+ * @key: Pointer for key buffer
+ * @len: Number of bytes to copy to key
+ * Returns: 0 on success (len of key available), maximum available key len
+ * (>0) if key is available but it is shorter than len, or -1 on failure.
+ * Fetch EAP keying material (MSK, eapKeyData) from EAP state machine. The key
+ * is available only after a successful authentication.
+int eapol_sm_get_key(struct eapol_sm *sm, u8 *key, size_t len)
+	const u8 *eap_key;
+	size_t eap_len;
+	if (sm && sm->use_eap_proxy) {
+		/* Get key from EAP proxy */
+		if (sm == NULL || !eap_proxy_key_available(sm->eap_proxy)) {
+			wpa_printf(MSG_DEBUG, "EAPOL: EAP key not available");
+			return -1;
+		eap_key = eap_proxy_get_eapKeyData(sm->eap_proxy, &eap_len);
+		if (eap_key == NULL) {
+			wpa_printf(MSG_DEBUG, "EAPOL: Failed to get "
+				   "eapKeyData");
+			return -1;
+		goto key_fetched;
+	if (sm == NULL || !eap_key_available(sm->eap)) {
+		return -1;
+	eap_key = eap_get_eapKeyData(sm->eap, &eap_len);
+		wpa_printf(MSG_DEBUG, "EAPOL: Failed to get eapKeyData");
+		return -1;
+key_fetched:
+	if (len > eap_len) {
+		wpa_printf(MSG_DEBUG, "EAPOL: Requested key length (%lu) not "
+			   "available (len=%lu)",
+			   (unsigned long) len, (unsigned long) eap_len);
+		return eap_len;
+	os_memcpy(key, eap_key, len);
+	wpa_printf(MSG_DEBUG, "EAPOL: Successfully fetched key (len=%lu)",
+		   (unsigned long) len);
+	return 0;
+ * eapol_sm_get_session_id - Get EAP Session-Id
+ * @len: Pointer to variable that will be set to number of bytes in the session
+ * Returns: Pointer to the EAP Session-Id or %NULL on failure
+ * The Session-Id is available only after a successful authentication.
+const u8 * eapol_sm_get_session_id(struct eapol_sm *sm, size_t *len)
+		wpa_printf(MSG_DEBUG, "EAPOL: EAP Session-Id not available");
+		return NULL;
+	return eap_get_eapSessionId(sm->eap, len);
+ * eapol_sm_notify_logoff - Notification of logon/logoff commands
+ * @logoff: Whether command was logoff
+ * Notify EAPOL state machines that user requested logon/logoff.
+void eapol_sm_notify_logoff(struct eapol_sm *sm, Boolean logoff)
+	if (sm) {
+		sm->userLogoff = logoff;
+		if (!logoff) {
+			/* If there is a delayed txStart queued, start now. */
+			sm->startWhen = 0;
+ * eapol_sm_notify_pmkid_attempt - Notification of successful PMKSA caching
+ * Notify EAPOL state machines that PMKSA caching was successful. This is used
+ * to move EAPOL and EAP state machines into authenticated/successful state.
+void eapol_sm_notify_cached(struct eapol_sm *sm)
+	if (sm == NULL)
+		return;
+	wpa_printf(MSG_DEBUG, "EAPOL: PMKSA caching was used - skip EAPOL");
+	sm->eapSuccess = TRUE;
+ * eapol_sm_notify_pmkid_attempt - Notification of PMKSA caching
+ * Notify EAPOL state machines if PMKSA caching is used.
+void eapol_sm_notify_pmkid_attempt(struct eapol_sm *sm)
+	if (sm == NULL)
+		return;
+	wpa_printf(MSG_DEBUG, "RSN: Trying to use cached PMKSA");
+	sm->cached_pmk = TRUE;
+	wpa_printf(MSG_DEBUG, "RSN: Authenticator did not accept PMKID, "
+		   "doing full EAP authentication");
+	if (sm == NULL)
+		return;
+	sm->cached_pmk = FALSE;
+	sm->SUPP_PAE_state = SUPP_PAE_CONNECTING;
+	/* Make sure we do not start sending EAPOL-Start frames first, but
+	 * instead move to RESTART state to start EAPOL authentication. */
+	sm->startWhen = 3;
+	if (sm->ctx->aborted_cached)
+		sm->ctx->aborted_cached(sm->ctx->ctx);
+ * eapol_sm_register_scard_ctx - Notification of smart card context
+ * @ctx: Context data for smart card operations
+ * Notify EAPOL state machines of context data for smart card operations. This
+ * context data will be used as a parameter for scard_*() functions.
+void eapol_sm_register_scard_ctx(struct eapol_sm *sm, void *ctx)
+	if (sm) {
+		sm->ctx->scard_ctx = ctx;
+		eap_register_scard_ctx(sm->eap, ctx);
+ * eapol_sm_notify_portControl - Notification of portControl changes
+ * @portControl: New value for portControl variable
+ * Notify EAPOL state machines that portControl variable has changed.
+void eapol_sm_notify_portControl(struct eapol_sm *sm, PortControl portControl)
+	if (sm == NULL)
+		return;
+		   "portControl=%s", eapol_port_control(portControl));
+	sm->portControl = portControl;
+ * eapol_sm_notify_ctrl_attached - Notification of attached monitor
+ * Notify EAPOL state machines that a monitor was attached to the control
+ * interface to trigger re-sending of pending requests for user input.
+void eapol_sm_notify_ctrl_attached(struct eapol_sm *sm)
+	if (sm == NULL)
+		return;
+	eap_sm_notify_ctrl_attached(sm->eap);
+ * eapol_sm_notify_ctrl_response - Notification of received user input
+ * Notify EAPOL state machines that a control response, i.e., user
+ * input, was received in order to trigger retrying of a pending EAP request.
+void eapol_sm_notify_ctrl_response(struct eapol_sm *sm)
+	if (sm == NULL)
+		return;
+	if (sm->eapReqData && !sm->eapReq) {
+		wpa_printf(MSG_DEBUG, "EAPOL: received control response (user "
+			   "input) notification - retrying pending EAP "
+			   "Request");
+ * eapol_sm_request_reauth - Request reauthentication
+ * This function can be used to request EAPOL reauthentication, e.g., when the
+ * current PMKSA entry is nearing expiration.
+void eapol_sm_request_reauth(struct eapol_sm *sm)
+	if (sm == NULL || sm->SUPP_PAE_state != SUPP_PAE_AUTHENTICATED)
+		return;
+ * eapol_sm_notify_lower_layer_success - Notification of lower layer success
+ * @in_eapol_sm: Whether the caller is already running inside EAPOL state
+ * machine loop (eapol_sm_step())
+ * Notify EAPOL (and EAP) state machines that a lower layer has detected a
+ * successful authentication. This is used to recover from dropped EAP-Success
+ * messages.
+void eapol_sm_notify_lower_layer_success(struct eapol_sm *sm, int in_eapol_sm)
+	if (sm == NULL)
+		return;
+	eap_notify_lower_layer_success(sm->eap);
+	if (!in_eapol_sm)
+ * eapol_sm_invalidate_cached_session - Mark cached EAP session data invalid
+void eapol_sm_invalidate_cached_session(struct eapol_sm *sm)
+	if (sm)
+		eap_invalidate_cached_session(sm->eap);
+static struct eap_peer_config * eapol_sm_get_config(void *ctx)
+	struct eapol_sm *sm = ctx;
+	return sm ? sm->config : NULL;
+static struct wpabuf * eapol_sm_get_eapReqData(void *ctx)
+	if (sm == NULL || sm->eapReqData == NULL)
+		return NULL;
+	return sm->eapReqData;
+static Boolean eapol_sm_get_bool(void *ctx, enum eapol_bool_var variable)
+	if (sm == NULL)
+		return FALSE;
+	switch (variable) {
+	case EAPOL_eapSuccess:
+		return sm->eapSuccess;
+	case EAPOL_eapRestart:
+		return sm->eapRestart;
+	case EAPOL_eapFail:
+		return sm->eapFail;
+	case EAPOL_eapResp:
+		return sm->eapResp;
+	case EAPOL_eapNoResp:
+		return sm->eapNoResp;
+	case EAPOL_eapReq:
+		return sm->eapReq;
+	case EAPOL_portEnabled:
+		return sm->portEnabled;
+	case EAPOL_altAccept:
+		return sm->altAccept;
+	case EAPOL_altReject:
+		return sm->altReject;
+	case EAPOL_eapTriggerStart:
+		return sm->eapTriggerStart;
+	return FALSE;
+static void eapol_sm_set_bool(void *ctx, enum eapol_bool_var variable,
+			      Boolean value)
+	if (sm == NULL)
+		return;
+		sm->eapSuccess = value;
+		break;
+		sm->eapRestart = value;
+		break;
+		sm->eapFail = value;
+		break;
+		sm->eapResp = value;
+		break;
+		sm->eapNoResp = value;
+		break;
+		sm->eapReq = value;
+		break;
+		sm->portEnabled = value;
+		break;
+		sm->altAccept = value;
+		break;
+		sm->altReject = value;
+		break;
+		sm->eapTriggerStart = value;
+		break;
+static unsigned int eapol_sm_get_int(void *ctx, enum eapol_int_var variable)
+	if (sm == NULL)
+		return 0;
+	case EAPOL_idleWhile:
+		return sm->idleWhile;
+	return 0;
+static void eapol_sm_set_int(void *ctx, enum eapol_int_var variable,
+			     unsigned int value)
+	if (sm == NULL)
+		return;
+		sm->idleWhile = value;
+		break;
+static void eapol_sm_set_config_blob(void *ctx, struct wpa_config_blob *blob)
+#ifndef CONFIG_NO_CONFIG_BLOBS
+	if (sm && sm->ctx && sm->ctx->set_config_blob)
+		sm->ctx->set_config_blob(sm->ctx->ctx, blob);
+#endif /* CONFIG_NO_CONFIG_BLOBS */
+static const struct wpa_config_blob *
+eapol_sm_get_config_blob(void *ctx, const char *name)
+	if (sm && sm->ctx && sm->ctx->get_config_blob)
+		return sm->ctx->get_config_blob(sm->ctx->ctx, name);
+	else
+		return NULL;
+#else /* CONFIG_NO_CONFIG_BLOBS */
+	return NULL;
+static void eapol_sm_notify_pending(void *ctx)
+	if (sm == NULL)
+		return;
+		wpa_printf(MSG_DEBUG, "EAPOL: received notification from EAP "
+			   "state machine - retrying pending EAP Request");
+static void eapol_sm_eap_param_needed(void *ctx, enum wpa_ctrl_req_type field,
+				      const char *txt)
+	wpa_printf(MSG_DEBUG, "EAPOL: EAP parameter needed");
+	if (sm->ctx->eap_param_needed)
+		sm->ctx->eap_param_needed(sm->ctx->ctx, field, txt);
+#else /* CONFIG_CTRL_IFACE || !CONFIG_NO_STDOUT_DEBUG */
+#define eapol_sm_eap_param_needed NULL
+static void eapol_sm_notify_cert(void *ctx, int depth, const char *subject,
+				 const char *altsubject[],
+				 int num_altsubject, const char *cert_hash,
+				 const struct wpabuf *cert)
+	if (sm->ctx->cert_cb)
+		sm->ctx->cert_cb(sm->ctx->ctx, depth, subject, altsubject,
+				 num_altsubject, cert_hash, cert);
+static void eapol_sm_notify_status(void *ctx, const char *status,
+				   const char *parameter)
+	if (sm->ctx->status_cb)
+		sm->ctx->status_cb(sm->ctx->ctx, status, parameter);
+static void eapol_sm_eap_proxy_cb(void *ctx)
+	if (sm->ctx->eap_proxy_cb)
+		sm->ctx->eap_proxy_cb(sm->ctx->ctx);
+static void eapol_sm_set_anon_id(void *ctx, const u8 *id, size_t len)
+	if (sm->ctx->set_anon_id)
+		sm->ctx->set_anon_id(sm->ctx->ctx, id, len);
+static const struct eapol_callbacks eapol_cb =
+	eapol_sm_get_config,
+	eapol_sm_get_bool,
+	eapol_sm_set_bool,
+	eapol_sm_get_int,
+	eapol_sm_set_int,
+	eapol_sm_get_eapReqData,
+	eapol_sm_set_config_blob,
+	eapol_sm_get_config_blob,
+	eapol_sm_notify_pending,
+	eapol_sm_eap_param_needed,
+	eapol_sm_notify_cert,
+	eapol_sm_notify_status,
+	eapol_sm_eap_proxy_cb,
+	eapol_sm_set_anon_id
+ * eapol_sm_init - Initialize EAPOL state machine
+ * @ctx: Pointer to EAPOL context data; this needs to be an allocated buffer
+ * and EAPOL state machine will free it in eapol_sm_deinit()
+ * Returns: Pointer to the allocated EAPOL state machine or %NULL on failure
+ * Allocate and initialize an EAPOL state machine.
+struct eapol_sm *eapol_sm_init(struct eapol_ctx *ctx)
+	struct eapol_sm *sm;
+	struct eap_config conf;
+	sm = os_zalloc(sizeof(*sm));
+	if (sm == NULL)
+		return NULL;
+	sm->ctx = ctx;
+	sm->portControl = Auto;
+	sm->heldPeriod = 60;
+	sm->startPeriod = 30;
+	sm->maxStart = 3;
+	sm->authPeriod = 30;
+	os_memset(&conf, 0, sizeof(conf));
+	conf.opensc_engine_path = ctx->opensc_engine_path;
+	conf.pkcs11_engine_path = ctx->pkcs11_engine_path;
+	conf.pkcs11_module_path = ctx->pkcs11_module_path;
+	conf.openssl_ciphers = ctx->openssl_ciphers;
+	conf.wps = ctx->wps;
+	conf.cert_in_cb = ctx->cert_in_cb;
+	sm->eap = eap_peer_sm_init(sm, &eapol_cb, sm->ctx->msg_ctx, &conf);
+	if (sm->eap == NULL) {
+		os_free(sm);
+		return NULL;
+	sm->use_eap_proxy = FALSE;
+	sm->eap_proxy = eap_proxy_init(sm, &eapol_cb, sm->ctx->msg_ctx);
+	if (sm->eap_proxy == NULL) {
+		wpa_printf(MSG_ERROR, "Unable to initialize EAP Proxy");
+	/* Initialize EAPOL state machines */
+	sm->initialize = TRUE;
+	sm->initialize = FALSE;
+	return sm;
+ * eapol_sm_deinit - Deinitialize EAPOL state machine
+ * Deinitialize and free EAPOL state machine.
+void eapol_sm_deinit(struct eapol_sm *sm)
+	if (sm == NULL)
+		return;
+	eap_peer_sm_deinit(sm->eap);
+	eap_proxy_deinit(sm->eap_proxy);
+	os_free(sm->ctx);
+	os_free(sm);
+void eapol_sm_set_ext_pw_ctx(struct eapol_sm *sm,
+			     struct ext_password_data *ext)
+	if (sm && sm->eap)
+		eap_sm_set_ext_pw_ctx(sm->eap, ext);
+int eapol_sm_failed(struct eapol_sm *sm)
+	if (sm == NULL)
+		return 0;
+	return !sm->eapSuccess && sm->eapFail;
+int eapol_sm_get_eap_proxy_imsi(struct eapol_sm *sm, char *imsi, size_t *len)
+		return -1;
+	return eap_proxy_get_imsi(sm->eap_proxy, imsi, len);
+#else /* CONFIG_EAP_PROXY */
+	return -1;
+void eapol_sm_erp_flush(struct eapol_sm *sm)
+	if (sm)
+		eap_peer_erp_free_keys(sm->eap);
diff --git a/freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h b/freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h
index 00000000000..1309ff7547e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.h
@@ -0,0 +1,443 @@
+#ifndef EAPOL_SUPP_SM_H
+#define EAPOL_SUPP_SM_H
+#include "common/defs.h"
+typedef enum { Unauthorized, Authorized } PortStatus;
+typedef enum { Auto, ForceUnauthorized, ForceAuthorized } PortControl;
+ * struct eapol_config - Per network configuration for EAPOL state machines
+struct eapol_config {
+	 * accept_802_1x_keys - Accept IEEE 802.1X (non-WPA) EAPOL-Key frames
+	 * This variable should be set to 1 when using EAPOL state machines
+	 * with non-WPA security policy to generate dynamic WEP keys. When
+	 * using WPA, this should be set to 0 so that WPA state machine can
+	 * process the EAPOL-Key frames.
+	int accept_802_1x_keys;
+#define EAPOL_REQUIRE_KEY_UNICAST BIT(0)
+#define EAPOL_REQUIRE_KEY_BROADCAST BIT(1)
+	 * required_keys - Which EAPOL-Key packets are required
+	 * This variable determines which EAPOL-Key packets are required before
+	 * marking connection authenticated. This is a bit field of
+	 * EAPOL_REQUIRE_KEY_UNICAST and EAPOL_REQUIRE_KEY_BROADCAST flags.
+	int required_keys;
+	 * fast_reauth - Whether fast EAP reauthentication is enabled
+	int fast_reauth;
+	 * workaround - Whether EAP workarounds are enabled
+	unsigned int workaround;
+	 * eap_disabled - Whether EAP is disabled
+	int eap_disabled;
+	 * external_sim - Use external processing for SIM/USIM operations
+	int external_sim;
+#define EAPOL_LOCAL_WPS_IN_USE BIT(0)
+#define EAPOL_PEER_IS_WPS20_AP BIT(1)
+	 * wps - Whether this connection is used for WPS
+	int wps;
+struct eapol_sm;
+struct wpa_config_blob;
+enum eapol_supp_result {
+	EAPOL_SUPP_RESULT_FAILURE,
+	EAPOL_SUPP_RESULT_SUCCESS,
+	EAPOL_SUPP_RESULT_EXPECTED_FAILURE
+ * struct eapol_ctx - Global (for all networks) EAPOL state machine context
+struct eapol_ctx {
+	 * ctx - Pointer to arbitrary upper level context
+	void *ctx;
+	 * preauth - IEEE 802.11i/RSN pre-authentication
+	 * This EAPOL state machine is used for IEEE 802.11i/RSN
+	 * pre-authentication
+	int preauth;
+	 * cb - Function to be called when EAPOL negotiation has been completed
+	 * @eapol: Pointer to EAPOL state machine data
+	 * @result: Whether the authentication was completed successfully
+	 * @ctx: Pointer to context data (cb_ctx)
+	 * This optional callback function will be called when the EAPOL
+	 * authentication has been completed. This allows the owner of the
+	 * EAPOL state machine to process the key and terminate the EAPOL state
+	 * machine. Currently, this is used only in RSN pre-authentication.
+	void (*cb)(struct eapol_sm *eapol, enum eapol_supp_result result,
+		   void *ctx);
+	 * cb_ctx - Callback context for cb()
+	void *cb_ctx;
+	 * msg_ctx - Callback context for wpa_msg() calls
+	void *msg_ctx;
+	 * scard_ctx - Callback context for PC/SC scard_*() function calls
+	 * This context can be updated with eapol_sm_register_scard_ctx().
+	void *scard_ctx;
+	 * eapol_send_ctx - Callback context for eapol_send() calls
+	void *eapol_send_ctx;
+	 * eapol_done_cb - Function to be called at successful completion
+	 * @ctx: Callback context (ctx)
+	 * This function is called at the successful completion of EAPOL
+	 * authentication. If dynamic WEP keys are used, this is called only
+	 * after all the expected keys have been received.
+	void (*eapol_done_cb)(void *ctx);
+	 * eapol_send - Send EAPOL packets
+	 * @ctx: Callback context (eapol_send_ctx)
+	 * @type: EAPOL type (IEEE802_1X_TYPE_*)
+	 * @buf: Pointer to EAPOL payload
+	 * @len: Length of the EAPOL payload
+	 * Returns: 0 on success, -1 on failure
+	int (*eapol_send)(void *ctx, int type, const u8 *buf, size_t len);
+	 * set_wep_key - Configure WEP keys
+	 * @unicast: Non-zero = unicast, 0 = multicast/broadcast key
+	 * @keyidx: Key index (0..3)
+	 * @key: WEP key
+	 * @keylen: Length of the WEP key
+	int (*set_wep_key)(void *ctx, int unicast, int keyidx,
+			   const u8 *key, size_t keylen);
+	 * set_config_blob - Set or add a named configuration blob
+	 * @blob: New value for the blob
+	 * Adds a new configuration blob or replaces the current value of an
+	 * existing blob.
+	void (*set_config_blob)(void *ctx, struct wpa_config_blob *blob);
+	 * get_config_blob - Get a named configuration blob
+	 * @name: Name of the blob
+	 * Returns: Pointer to blob data or %NULL if not found
+	const struct wpa_config_blob * (*get_config_blob)(void *ctx,
+							  const char *name);
+	 * aborted_cached - Notify that cached PMK attempt was aborted
+	void (*aborted_cached)(void *ctx);
+	 * opensc_engine_path - Path to the OpenSSL engine for opensc
+	 * This is an OpenSSL specific configuration option for loading OpenSC
+	 * engine (engine_opensc.so); if %NULL, this engine is not loaded.
+	const char *opensc_engine_path;
+	 * pkcs11_engine_path - Path to the OpenSSL engine for PKCS#11
+	 * This is an OpenSSL specific configuration option for loading PKCS#11
+	 * engine (engine_pkcs11.so); if %NULL, this engine is not loaded.
+	const char *pkcs11_engine_path;
+	 * pkcs11_module_path - Path to the OpenSSL OpenSC/PKCS#11 module
+	 * This is an OpenSSL specific configuration option for configuring
+	 * path to OpenSC/PKCS#11 engine (opensc-pkcs11.so); if %NULL, this
+	 * module is not loaded.
+	const char *pkcs11_module_path;
+	 * openssl_ciphers - OpenSSL cipher string
+	 * This is an OpenSSL specific configuration option for configuring the
+	 * default ciphers. If not set, "DEFAULT:!EXP:!LOW" is used as the
+	 * default.
+	const char *openssl_ciphers;
+	 * wps - WPS context data
+	 * This is only used by EAP-WSC and can be left %NULL if not available.
+	struct wps_context *wps;
+	 * eap_param_needed - Notify that EAP parameter is needed
+	 * @field: Field indicator (e.g., WPA_CTRL_REQ_EAP_IDENTITY)
+	 * @txt: User readable text describing the required parameter
+	void (*eap_param_needed)(void *ctx, enum wpa_ctrl_req_type field,
+				 const char *txt);
+	 * port_cb - Set port authorized/unauthorized callback (optional)
+	 * @authorized: Whether the supplicant port is now in authorized state
+	void (*port_cb)(void *ctx, int authorized);
+	 * cert_cb - Notification of a peer certificate
+	 * @depth: Depth in certificate chain (0 = server)
+	 * @subject: Subject of the peer certificate
+	 * @altsubject: Select fields from AltSubject of the peer certificate
+	 * @num_altsubject: Number of altsubject values
+	 * @cert_hash: SHA-256 hash of the certificate
+	 * @cert: Peer certificate
+	void (*cert_cb)(void *ctx, int depth, const char *subject,
+			const char *altsubject[], int num_altsubject,
+			const char *cert_hash, const struct wpabuf *cert);
+	 * cert_in_cb - Include server certificates in callback
+	int cert_in_cb;
+	 * status_cb - Notification of a change in EAP status
+	 * @status: Step in the process of EAP authentication
+	 * @parameter: Step-specific parameter, e.g., EAP method name
+	void (*status_cb)(void *ctx, const char *status,
+			  const char *parameter);
+	 * eap_proxy_cb - Callback signifying any updates from eap_proxy
+	 * @ctx: eapol_ctx from eap_peer_sm_init() call
+	void (*eap_proxy_cb)(void *ctx);
+	 * set_anon_id - Set or add anonymous identity
+	 * @id: Anonymous identity (e.g., EAP-SIM pseudonym)
+	 * @len: Length of anonymous identity in octets
+	void (*set_anon_id)(void *ctx, const u8 *id, size_t len);
+struct eap_peer_config;
+struct ext_password_data;
+#ifdef IEEE8021X_EAPOL
+struct eapol_sm *eapol_sm_init(struct eapol_ctx *ctx);
+void eapol_sm_deinit(struct eapol_sm *sm);
+void eapol_sm_step(struct eapol_sm *sm);
+			int verbose);
+int eapol_sm_get_mib(struct eapol_sm *sm, char *buf, size_t buflen);
+			int startPeriod, int maxStart);
+		      size_t len);
+void eapol_sm_notify_tx_eapol_key(struct eapol_sm *sm);
+void eapol_sm_notify_portEnabled(struct eapol_sm *sm, Boolean enabled);
+void eapol_sm_notify_portValid(struct eapol_sm *sm, Boolean valid);
+void eapol_sm_notify_eap_success(struct eapol_sm *sm, Boolean success);
+void eapol_sm_notify_eap_fail(struct eapol_sm *sm, Boolean fail);
+			    const struct eapol_config *conf);
+int eapol_sm_get_key(struct eapol_sm *sm, u8 *key, size_t len);
+const u8 * eapol_sm_get_session_id(struct eapol_sm *sm, size_t *len);
+void eapol_sm_notify_logoff(struct eapol_sm *sm, Boolean logoff);
+void eapol_sm_notify_cached(struct eapol_sm *sm);
+void eapol_sm_notify_pmkid_attempt(struct eapol_sm *sm);
+void eapol_sm_register_scard_ctx(struct eapol_sm *sm, void *ctx);
+void eapol_sm_notify_portControl(struct eapol_sm *sm, PortControl portControl);
+void eapol_sm_notify_ctrl_attached(struct eapol_sm *sm);
+void eapol_sm_notify_ctrl_response(struct eapol_sm *sm);
+void eapol_sm_request_reauth(struct eapol_sm *sm);
+void eapol_sm_notify_lower_layer_success(struct eapol_sm *sm, int in_eapol_sm);
+void eapol_sm_invalidate_cached_session(struct eapol_sm *sm);
+const char * eapol_sm_get_method_name(struct eapol_sm *sm);
+			     struct ext_password_data *ext);
+int eapol_sm_failed(struct eapol_sm *sm);
+void eapol_sm_erp_flush(struct eapol_sm *sm);
+int eapol_sm_get_eap_proxy_imsi(struct eapol_sm *sm, char *imsi, size_t *len);
+#else /* IEEE8021X_EAPOL */
+static inline struct eapol_sm *eapol_sm_init(struct eapol_ctx *ctx)
+	free(ctx);
+	return (struct eapol_sm *) 1;
+static inline void eapol_sm_deinit(struct eapol_sm *sm)
+static inline void eapol_sm_step(struct eapol_sm *sm)
+static inline int eapol_sm_get_status(struct eapol_sm *sm, char *buf,
+				      size_t buflen, int verbose)
+	return 0;
+static inline int eapol_sm_get_mib(struct eapol_sm *sm, char *buf,
+				   size_t buflen)
+	return 0;
+static inline void eapol_sm_configure(struct eapol_sm *sm, int heldPeriod,
+				      int authPeriod, int startPeriod,
+				      int maxStart)
+static inline int eapol_sm_rx_eapol(struct eapol_sm *sm, const u8 *src,
+				    const u8 *buf, size_t len)
+	return 0;
+static inline void eapol_sm_notify_tx_eapol_key(struct eapol_sm *sm)
+static inline void eapol_sm_notify_portEnabled(struct eapol_sm *sm,
+					       Boolean enabled)
+static inline void eapol_sm_notify_portValid(struct eapol_sm *sm,
+					     Boolean valid)
+static inline void eapol_sm_notify_eap_success(struct eapol_sm *sm,
+					       Boolean success)
+static inline void eapol_sm_notify_eap_fail(struct eapol_sm *sm, Boolean fail)
+static inline void eapol_sm_notify_config(struct eapol_sm *sm,
+					  struct eapol_config *conf)
+static inline int eapol_sm_get_key(struct eapol_sm *sm, u8 *key, size_t len)
+	return -1;
+static inline const u8 *
+eapol_sm_get_session_id(struct eapol_sm *sm, size_t *len)
+	return NULL;
+static inline void eapol_sm_notify_logoff(struct eapol_sm *sm, Boolean logoff)
+static inline void eapol_sm_notify_cached(struct eapol_sm *sm)
+static inline void eapol_sm_notify_pmkid_attempt(struct eapol_sm *sm)
+#define eapol_sm_register_scard_ctx(sm, ctx) do { } while (0)
+static inline void eapol_sm_notify_portControl(struct eapol_sm *sm,
+					       PortControl portControl)
+static inline void eapol_sm_notify_ctrl_attached(struct eapol_sm *sm)
+static inline void eapol_sm_notify_ctrl_response(struct eapol_sm *sm)
+static inline void eapol_sm_request_reauth(struct eapol_sm *sm)
+static inline void eapol_sm_notify_lower_layer_success(struct eapol_sm *sm,
+						       int in_eapol_sm)
+static inline void eapol_sm_invalidate_cached_session(struct eapol_sm *sm)
+static inline const char * eapol_sm_get_method_name(struct eapol_sm *sm)
+	return NULL;
+static inline void eapol_sm_set_ext_pw_ctx(struct eapol_sm *sm,
+static inline int eapol_sm_failed(struct eapol_sm *sm)
+	return 0;
+static inline void eapol_sm_erp_flush(struct eapol_sm *sm)
+#endif /* IEEE8021X_EAPOL */
+#endif /* EAPOL_SUPP_SM_H */
diff --git a/freebsd/contrib/wpa/src/fst/fst.h b/freebsd/contrib/wpa/src/fst/fst.h
new file mode 100644
index 00000000000..0c0e435b974
--- /dev/null
+++ b/freebsd/contrib/wpa/src/fst/fst.h
@@ -0,0 +1,296 @@
+ * FST module - interface definitions
+ * Copyright (c) 2014, Qualcomm Atheros, Inc.
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef FST_H
+#define FST_H
+#ifdef CONFIG_FST
+#include "fst/fst_ctrl_iface.h"
+/* FST module hostap integration API */
+#define US_IN_MS           1000
+#define LLT_UNIT_US        32 /* See 10.32.2.2  Transitioning between states */
+#define FST_LLT_MS_TO_VAL(m) (((u32) (m)) * US_IN_MS / LLT_UNIT_US)
+#define FST_LLT_VAL_TO_MS(v) (((u32) (v)) * LLT_UNIT_US / US_IN_MS)
+#define FST_MAX_LLT_MS       FST_LLT_VAL_TO_MS(-1)
+#define FST_MAX_PRIO_VALUE   ((u8) -1)
+#define FST_MAX_GROUP_ID_LEN IFNAMSIZ
+#define FST_DEFAULT_LLT_CFG_VALUE 50
+struct hostapd_hw_modes;
+struct ieee80211_mgmt;
+struct fst_iface;
+struct fst_group;
+struct fst_session;
+struct fst_get_peer_ctx;
+struct fst_ctrl_handle;
+struct fst_wpa_obj {
+	void *ctx;
+	 * get_bssid - Get BSSID of the interface
+	 * @ctx: User context %ctx
+	 * Returns: BSSID for success, %NULL for failure.
+	 * NOTE: For AP it returns the own BSSID, while for STA - the BSSID of
+	 * the associated AP.
+	const u8 * (*get_bssid)(void *ctx);
+	 * get_channel_info - Get current channel info
+	 * @hw_mode: OUT, current HW mode
+	 * @channel: OUT, current channel
+	void (*get_channel_info)(void *ctx, enum hostapd_hw_mode *hw_mode,
+				 u8 *channel);
+	 * get_hw_modes - Get hardware modes
+	 * @modes: OUT, pointer on array of hw modes
+	 * Returns: Number of hw modes available.
+	int (*get_hw_modes)(void *ctx, struct hostapd_hw_modes **modes);
+	 * set_ies - Set interface's MB IE
+	 * @fst_ies: MB IE buffer (owned by FST module)
+	void (*set_ies)(void *ctx, const struct wpabuf *fst_ies);
+	 * send_action - Send FST Action frame via the interface
+	 * @addr: Address of the destination STA
+	 * @data: Action frame buffer
+	 * Returns: 0 for success, negative error code for failure.
+	int (*send_action)(void *ctx, const u8 *addr, struct wpabuf *data);
+	 * get_mb_ie - Get last MB IE received from STA
+	 * @addr: Address of the STA
+	 * Returns: MB IE buffer, %NULL if no MB IE received from the STA
+	const struct wpabuf * (*get_mb_ie)(void *ctx, const u8 *addr);
+	 * update_mb_ie - Update last MB IE received from STA
+	 * @buf: Buffer that contains the MB IEs data
+	 * @size: Size of data in %buf
+	void (*update_mb_ie)(void *ctx, const u8 *addr,
+			     const u8 *buf, size_t size);
+	 * get_peer_first - Get MAC address of the 1st connected STA
+	 * @get_ctx: Context to be used for %get_peer_next call
+	 * @mb_only: %TRUE if only multi-band capable peer should be reported
+	 * Returns: Address of the 1st connected STA, %NULL if no STAs connected
+	const u8 * (*get_peer_first)(void *ctx,
+				     struct fst_get_peer_ctx **get_ctx,
+				     Boolean mb_only);
+	 * get_peer_next - Get MAC address of the next connected STA
+	 * @get_ctx: Context received from %get_peer_first or previous
+	 *           %get_peer_next call
+	 * Returns: Address of the next connected STA, %NULL if no more STAs
+	 *          connected
+	const u8 * (*get_peer_next)(void *ctx,
+				    Boolean mb_only);
+ * fst_global_init - Global FST module initiator
+ * Note: The purpose of this function is to allocate and initiate global
+ *       FST module data structures (linked lists, static data etc.)
+ *       This function should be called prior to the 1st %fst_attach call.
+int fst_global_init(void);
+ * fst_global_deinit - Global FST module de-initiator
+ * Note: The purpose of this function is to deallocate and de-initiate global
+void fst_global_deinit(void);
+ * struct fst_ctrl - Notification interface for FST module
+struct fst_ctrl {
+	 * init - Initialize the notification interface
+	int (*init)(void);
+	 * deinit - Deinitialize the notification interface
+	void (*deinit)(void);
+	 * on_group_created - Notify about FST group creation
+	int (*on_group_created)(struct fst_group *g);
+	 * on_group_deleted - Notify about FST group deletion
+	void (*on_group_deleted)(struct fst_group *g);
+	 * on_iface_added - Notify about interface addition
+	int (*on_iface_added)(struct fst_iface *i);
+	 * on_iface_removed - Notify about interface removal
+	void (*on_iface_removed)(struct fst_iface *i);
+	 * on_session_added - Notify about FST session addition
+	int (*on_session_added)(struct fst_session *s);
+	 * on_session_removed - Notify about FST session removal
+	void (*on_session_removed)(struct fst_session *s);
+	 * on_event - Notify about FST event
+	 * @event_type: Event type
+	 * @i: Interface object that relates to the event or NULL
+	 * @g: Group object that relates to the event or NULL
+	 * @extra - Event specific data (see fst_ctrl_iface.h for more info)
+	void (*on_event)(enum fst_event_type event_type, struct fst_iface *i,
+			 struct fst_session *s,
+			 const union fst_event_extra *extra);
+struct fst_ctrl_handle * fst_global_add_ctrl(const struct fst_ctrl *ctrl);
+void fst_global_del_ctrl(struct fst_ctrl_handle *h);
+ * NOTE: These values have to be read from configuration file
+struct fst_iface_cfg {
+	char group_id[FST_MAX_GROUP_ID_LEN + 1];
+	u8 priority;
+	u32 llt;
+ * fst_attach - Attach interface to an FST group according to configuration read
+ * @ifname: Interface name
+ * @own_addr: Own interface MAC address
+ * @iface_obj: Callbacks to be used by FST module to communicate with
+ *             hostapd/wpa_supplicant
+ * @cfg: FST-related interface configuration read from the configuration file
+ * Returns: FST interface object for success, %NULL for failure.
+struct fst_iface * fst_attach(const char *ifname,
+			      const u8 *own_addr,
+			      const struct fst_wpa_obj *iface_obj,
+			      const struct fst_iface_cfg *cfg);
+ * fst_detach - Detach an interface
+ * @iface: FST interface object
+void fst_detach(struct fst_iface *iface);
+/* FST module inputs */
+ * fst_rx_action - FST Action frames handler
+ * @mgmt: Action frame arrived
+ * @len: Action frame length
+void fst_rx_action(struct fst_iface *iface, const struct ieee80211_mgmt *mgmt,
+		   size_t len);
+ * fst_notify_peer_connected - FST STA connect handler
+ * @addr: Address of the connected STA
+void fst_notify_peer_connected(struct fst_iface *iface, const u8 *addr);
+ * fst_notify_peer_disconnected - FST STA disconnect handler
+ * @addr: Address of the disconnected STA
+void fst_notify_peer_disconnected(struct fst_iface *iface, const u8 *addr);
+/* FST module auxiliary routines */
+ * fst_are_ifaces_aggregated - Determines whether 2 interfaces belong to the
+ *                             same FST group
+ * @iface1: 1st FST interface object
+ * @iface1: 2nd FST interface object
+ * Returns: %TRUE if the interfaces belong to the same FST group,
+ *          %FALSE otherwise
+Boolean fst_are_ifaces_aggregated(struct fst_iface *iface1,
+				  struct fst_iface *iface2);
+#else /* CONFIG_FST */
+static inline int fst_global_init(void)
+	return 0;
+static inline int fst_global_start(void)
+	return 0;
+static inline void fst_global_stop(void)
+static inline void fst_global_deinit(void)
+#endif /* CONFIG_FST */
+#endif /* FST_H */
diff --git a/freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h b/freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h
index 00000000000..e2133f5062b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/fst/fst_ctrl_aux.h
@@ -0,0 +1,91 @@
+ * FST module - miscellaneous definitions
+#ifndef FST_CTRL_AUX_H
+#define FST_CTRL_AUX_H
+/* FST module control interface API */
+#define FST_INVALID_SESSION_ID ((u32) -1)
+#define FST_MAX_GROUP_ID_SIZE   32
+#define FST_MAX_INTERFACE_SIZE  32
+enum fst_session_state {
+	FST_SESSION_STATE_INITIAL,
+	FST_SESSION_STATE_SETUP_COMPLETION,
+	FST_SESSION_STATE_TRANSITION_DONE,
+	FST_SESSION_STATE_TRANSITION_CONFIRMED,
+	FST_SESSION_STATE_LAST
+enum fst_event_type {
+	EVENT_FST_IFACE_STATE_CHANGED,  /* An interface has been either attached
+					 * to or detached from an FST group */
+	EVENT_FST_ESTABLISHED,          /* FST Session has been established */
+	EVENT_FST_SETUP,                /* FST Session request received */
+	EVENT_FST_SESSION_STATE_CHANGED,/* FST Session state has been changed */
+	EVENT_PEER_STATE_CHANGED        /* FST related generic event occurred,
+					 * see struct fst_hostap_event_data for
+					 *  more info */
+enum fst_initiator {
+	FST_INITIATOR_UNDEFINED,
+	FST_INITIATOR_LOCAL,
+	FST_INITIATOR_REMOTE,
+union fst_event_extra {
+	struct fst_event_extra_iface_state {
+		Boolean attached;
+		char ifname[FST_MAX_INTERFACE_SIZE];
+		char group_id[FST_MAX_GROUP_ID_SIZE];
+	} iface_state; /* for EVENT_FST_IFACE_STATE_CHANGED */
+	struct fst_event_extra_peer_state {
+		Boolean connected;
+		u8 addr[ETH_ALEN];
+	} peer_state; /* for EVENT_PEER_STATE_CHANGED */
+	struct fst_event_extra_session_state {
+		enum fst_session_state old_state;
+		enum fst_session_state new_state;
+		union fst_session_state_switch_extra {
+			struct {
+				enum fst_reason {
+					REASON_TEARDOWN,
+					REASON_SETUP,
+					REASON_SWITCH,
+					REASON_STT,
+					REASON_REJECT,
+					REASON_ERROR_PARAMS,
+					REASON_RESET,
+					REASON_DETACH_IFACE,
+				} reason;
+				u8 reject_code; /* REASON_REJECT */
+				/* REASON_SWITCH,
+				 * REASON_TEARDOWN,
+				 * REASON_REJECT
+				enum fst_initiator initiator;
+			} to_initial;
+		} extra;
+	} session_state; /* for EVENT_FST_SESSION_STATE_CHANGED */
+/* helpers - prints enum in string form */
+#define FST_NAME_UNKNOWN "UNKNOWN"
+const char * fst_get_str_name(unsigned index, const char *names[],
+			      size_t names_size);
+const char * fst_session_event_type_name(enum fst_event_type);
+const char * fst_reason_name(enum fst_reason reason);
+const char * fst_session_state_name(enum fst_session_state state);
+#endif /* FST_CTRL_AUX_H */
diff --git a/freebsd/contrib/wpa/src/fst/fst_ctrl_iface.h b/freebsd/contrib/wpa/src/fst/fst_ctrl_iface.h
index 00000000000..4d0cd9fce4e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/fst/fst_ctrl_iface.h
@@ -0,0 +1,45 @@
+ * FST module - internal Control interface definitions
+#ifndef FST_CTRL_IFACE_H
+#define FST_CTRL_IFACE_H
+#include "fst/fst_ctrl_aux.h"
+#ifdef CONFIG_FST
+/* receiver */
+int fst_ctrl_iface_mb_info(const u8 *addr, char *buf, size_t buflen);
+int fst_ctrl_iface_receive(const char *txtaddr, char *buf, size_t buflen);
+extern const struct fst_ctrl *fst_ctrl_cli;
+static inline int
+fst_ctrl_iface_mb_info(const u8 *addr, char *buf, size_t buflen)
+	return 0;
+int fst_read_next_int_param(const char *params, Boolean *valid, char **endp);
+int fst_read_next_text_param(const char *params, char *buf, size_t buflen,
+			     char **endp);
+int fst_read_peer_addr(const char *mac, u8 *peer_addr);
+struct fst_iface_cfg;
+int fst_parse_attach_command(const char *cmd, char *ifname, size_t ifname_size,
+			     struct fst_iface_cfg *cfg);
+int fst_parse_detach_command(const char *cmd, char *ifname, size_t ifname_size);
+int fst_iface_detach(const char *ifname);
+#endif /* CTRL_IFACE_FST_H */
diff --git a/freebsd/contrib/wpa/src/l2_packet/l2_packet.h b/freebsd/contrib/wpa/src/l2_packet/l2_packet.h
index 00000000000..2a452458214
--- /dev/null
+++ b/freebsd/contrib/wpa/src/l2_packet/l2_packet.h
@@ -0,0 +1,154 @@
+ * WPA Supplicant - Layer2 packet interface definition
+ * Copyright (c) 2003-2005, Jouni Malinen <j at w1.fi>
+ * This file defines an interface for layer 2 (link layer) packet sending and
+ * receiving. l2_packet_linux.c is one implementation for such a layer 2
+ * implementation using Linux packet sockets and l2_packet_pcap.c another one
+ * using libpcap and libdnet. When porting %wpa_supplicant to other operating
+ * systems, a new l2_packet implementation may need to be added.
+#ifndef L2_PACKET_H
+#define L2_PACKET_H
+ * struct l2_packet_data - Internal l2_packet data structure
+ * This structure is used by the l2_packet implementation to store its private
+ * data. Other files use a pointer to this data when calling the l2_packet
+ * functions, but the contents of this structure should not be used directly
+ * outside l2_packet implementation.
+struct l2_packet_data;
+#ifdef _MSC_VER
+#pragma pack(push, 1)
+#endif /* _MSC_VER */
+struct l2_ethhdr {
+	u8 h_dest[ETH_ALEN];
+	u8 h_source[ETH_ALEN];
+	be16 h_proto;
+} STRUCT_PACKED;
+#ifdef _MSC_VER
+#pragma pack(pop)
+enum l2_packet_filter_type {
+	L2_PACKET_FILTER_DHCP,
+	L2_PACKET_FILTER_NDISC,
+ * l2_packet_init - Initialize l2_packet interface
+ * @own_addr: Optional own MAC address if available from driver interface or
+ *	%NULL if not available
+ * @protocol: Ethernet protocol number in host byte order
+ * @rx_callback: Callback function that will be called for each received packet
+ * @rx_callback_ctx: Callback data (ctx) for calls to rx_callback()
+ * @l2_hdr: 1 = include layer 2 header, 0 = do not include header
+ * Returns: Pointer to internal data or %NULL on failure
+ * rx_callback function will be called with src_addr pointing to the source
+ * address (MAC address) of the the packet. If l2_hdr is set to 0, buf
+ * points to len bytes of the payload after the layer 2 header and similarly,
+ * TX buffers start with payload. This behavior can be changed by setting
+ * l2_hdr=1 to include the layer 2 header in the data buffer.
+struct l2_packet_data * l2_packet_init(
+	const char *ifname, const u8 *own_addr, unsigned short protocol,
+	void (*rx_callback)(void *ctx, const u8 *src_addr,
+			    const u8 *buf, size_t len),
+	void *rx_callback_ctx, int l2_hdr);
+ * l2_packet_init_bridge - Like l2_packet_init() but with bridge workaround
+ * This version of l2_packet_init() can be used to enable a workaround for Linux
+ * packet socket in case of a station interface in a bridge.
+struct l2_packet_data * l2_packet_init_bridge(
+	const char *br_ifname, const char *ifname, const u8 *own_addr,
+	unsigned short protocol,
+ * l2_packet_deinit - Deinitialize l2_packet interface
+ * @l2: Pointer to internal l2_packet data from l2_packet_init()
+void l2_packet_deinit(struct l2_packet_data *l2);
+ * l2_packet_get_own_addr - Get own layer 2 address
+ * @addr: Buffer for the own address (6 bytes)
+int l2_packet_get_own_addr(struct l2_packet_data *l2, u8 *addr);
+ * l2_packet_send - Send a packet
+ * @dst_addr: Destination address for the packet (only used if l2_hdr == 0)
+ * @proto: Protocol/ethertype for the packet in host byte order (only used if
+ * l2_hdr == 0)
+ * @buf: Packet contents to be sent; including layer 2 header if l2_hdr was
+ * set to 1 in l2_packet_init() call. Otherwise, only the payload of the packet
+ * is included.
+ * @len: Length of the buffer (including l2 header only if l2_hdr == 1)
+ * Returns: >=0 on success, <0 on failure
+int l2_packet_send(struct l2_packet_data *l2, const u8 *dst_addr, u16 proto,
+		   const u8 *buf, size_t len);
+ * l2_packet_get_ip_addr - Get the current IP address from the interface
+ * @buf: Buffer for the IP address in text format
+ * @len: Maximum buffer length
+ * This function can be used to get the current IP address from the interface
+ * bound to the l2_packet. This is mainly for status information and the IP
+ * address will be stored as an ASCII string. This function is not essential
+ * for %wpa_supplicant operation, so full implementation is not required.
+ * l2_packet implementation will need to define the function, but it can return
+ * -1 if the IP address information is not available.
+int l2_packet_get_ip_addr(struct l2_packet_data *l2, char *buf, size_t len);
+ * l2_packet_notify_auth_start - Notify l2_packet about start of authentication
+ * This function is called when authentication is expected to start, e.g., when
+ * association has been completed, in order to prepare l2_packet implementation
+ * for EAPOL frames. This function is used mainly if the l2_packet code needs
+ * to do polling in which case it can increasing polling frequency. This can
+ * also be an empty function if the l2_packet implementation does not benefit
+ * from knowing about the starting authentication.
+void l2_packet_notify_auth_start(struct l2_packet_data *l2);
+ * l2_packet_set_packet_filter - Set socket filter for l2_packet
+ * @type: enum l2_packet_filter_type, type of filter
+ * This function is used to set the socket filter for l2_packet socket.
+int l2_packet_set_packet_filter(struct l2_packet_data *l2,
+				enum l2_packet_filter_type type);
+#endif /* L2_PACKET_H */
diff --git a/freebsd/contrib/wpa/src/l2_packet/l2_packet_freebsd.c b/freebsd/contrib/wpa/src/l2_packet/l2_packet_freebsd.c
index 00000000000..555abc5e46a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/l2_packet/l2_packet_freebsd.c
@@ -0,0 +1,331 @@
+#include <machine/rtems-bsd-user-space.h>
+ * WPA Supplicant - Layer2 packet handling with FreeBSD
+ * Copyright (c) 2005, Sam Leffler <sam at errno.com>
+#include "includes.h"
+#if defined(__APPLE__) || defined(__GLIBC__)
+#include <net/bpf.h>
+#endif /* __APPLE__ */
+#include <pcap.h>
+#include <sys/ioctl.h>
+#ifdef __sun__
+#include <libdlpi.h>
+#else /* __sun__ */
+#include <sys/sysctl.h>
+#endif /* __sun__ */
+#include <net/if.h>
+#include <net/if_dl.h>
+#include <net/route.h>
+#include <netinet/in.h>
+#include "common.h"
+#include "eloop.h"
+#include "l2_packet.h"
+static const u8 pae_group_addr[ETH_ALEN] =
+{ 0x01, 0x80, 0xc2, 0x00, 0x00, 0x03 };
+struct l2_packet_data {
+	pcap_t *pcap;
+	char ifname[100];
+	u8 own_addr[ETH_ALEN];
+	void *rx_callback_ctx;
+	int l2_hdr; /* whether to include layer 2 (Ethernet) header data
+		     * buffers */
+	os_memcpy(addr, l2->own_addr, ETH_ALEN);
+	return 0;
+	if (!l2->l2_hdr) {
+		int ret;
+		struct l2_ethhdr *eth = os_malloc(sizeof(*eth) + len);
+		if (eth == NULL)
+			return -1;
+		os_memcpy(eth->h_dest, dst_addr, ETH_ALEN);
+		os_memcpy(eth->h_source, l2->own_addr, ETH_ALEN);
+		eth->h_proto = htons(proto);
+		os_memcpy(eth + 1, buf, len);
+		ret = pcap_inject(l2->pcap, (u8 *) eth, len + sizeof(*eth));
+		os_free(eth);
+		return ret;
+	} else
+		return pcap_inject(l2->pcap, buf, len);
+static void l2_packet_receive(int sock, void *eloop_ctx, void *sock_ctx)
+	struct l2_packet_data *l2 = eloop_ctx;
+	pcap_t *pcap = sock_ctx;
+	struct pcap_pkthdr hdr;
+	const u_char *packet;
+	struct l2_ethhdr *ethhdr;
+	unsigned char *buf;
+	size_t len;
+	packet = pcap_next(pcap, &hdr);
+	if (packet == NULL || hdr.caplen < sizeof(*ethhdr))
+		return;
+	ethhdr = (struct l2_ethhdr *) packet;
+	if (l2->l2_hdr) {
+		buf = (unsigned char *) ethhdr;
+		len = hdr.caplen;
+	} else {
+		buf = (unsigned char *) (ethhdr + 1);
+		len = hdr.caplen - sizeof(*ethhdr);
+	l2->rx_callback(l2->rx_callback_ctx, ethhdr->h_source, buf, len);
+static int l2_packet_init_libpcap(struct l2_packet_data *l2,
+				  unsigned short protocol)
+	bpf_u_int32 pcap_maskp, pcap_netp;
+	char pcap_filter[200], pcap_err[PCAP_ERRBUF_SIZE];
+	struct bpf_program pcap_fp;
+	pcap_lookupnet(l2->ifname, &pcap_netp, &pcap_maskp, pcap_err);
+	l2->pcap = pcap_open_live(l2->ifname, 2500, 0, 10, pcap_err);
+	if (l2->pcap == NULL) {
+		fprintf(stderr, "pcap_open_live: %s\n", pcap_err);
+		fprintf(stderr, "ifname='%s'\n", l2->ifname);
+		return -1;
+	if (pcap_datalink(l2->pcap) != DLT_EN10MB &&
+	    pcap_set_datalink(l2->pcap, DLT_EN10MB) < 0) {
+		fprintf(stderr, "pcap_set_datalink(DLT_EN10MB): %s\n",
+			pcap_geterr(l2->pcap));
+		return -1;
+	os_snprintf(pcap_filter, sizeof(pcap_filter),
+		    "not ether src " MACSTR " and "
+		    "( ether dst " MACSTR " or ether dst " MACSTR " ) and "
+		    "ether proto 0x%x",
+		    MAC2STR(l2->own_addr), /* do not receive own packets */
+		    MAC2STR(l2->own_addr), MAC2STR(pae_group_addr),
+		    protocol);
+	if (pcap_compile(l2->pcap, &pcap_fp, pcap_filter, 1, pcap_netp) < 0) {
+		fprintf(stderr, "pcap_compile: %s\n", pcap_geterr(l2->pcap));
+		return -1;
+	if (pcap_setfilter(l2->pcap, &pcap_fp) < 0) {
+		fprintf(stderr, "pcap_setfilter: %s\n", pcap_geterr(l2->pcap));
+		return -1;
+	pcap_freecode(&pcap_fp);
+#ifndef __sun__
+	 * When libpcap uses BPF we must enable "immediate mode" to
+	 * receive frames right away; otherwise the system may
+	 * buffer them for us.
+		unsigned int on = 1;
+		if (ioctl(pcap_fileno(l2->pcap), BIOCIMMEDIATE, &on) < 0) {
+			fprintf(stderr, "%s: cannot enable immediate mode on "
+				"interface %s: %s\n",
+				__func__, l2->ifname, strerror(errno));
+			/* XXX should we fail? */
+	eloop_register_read_sock(pcap_get_selectable_fd(l2->pcap),
+				 l2_packet_receive, l2, l2->pcap);
+	return 0;
+static int eth_get(const char *device, u8 ea[ETH_ALEN])
+#ifdef __sun__
+	dlpi_handle_t dh;
+	u32 physaddrlen = DLPI_PHYSADDR_MAX;
+	u8 physaddr[DLPI_PHYSADDR_MAX];
+	int retval;
+	retval = dlpi_open(device, &dh, 0);
+	if (retval != DLPI_SUCCESS) {
+		wpa_printf(MSG_ERROR, "dlpi_open error: %s",
+			   dlpi_strerror(retval));
+		return -1;
+	retval = dlpi_get_physaddr(dh, DL_CURR_PHYS_ADDR, physaddr,
+				   &physaddrlen);
+		wpa_printf(MSG_ERROR, "dlpi_get_physaddr error: %s",
+		dlpi_close(dh);
+		return -1;
+	os_memcpy(ea, physaddr, ETH_ALEN);
+	dlpi_close(dh);
+	struct if_msghdr *ifm;
+	struct sockaddr_dl *sdl;
+	u_char *p, *buf;
+	size_t len;
+	int mib[] = { CTL_NET, AF_ROUTE, 0, AF_LINK, NET_RT_IFLIST, 0 };
+	if (sysctl(mib, 6, NULL, &len, NULL, 0) < 0)
+		return -1;
+	if ((buf = os_malloc(len)) == NULL)
+		return -1;
+	if (sysctl(mib, 6, buf, &len, NULL, 0) < 0) {
+		os_free(buf);
+		return -1;
+	for (p = buf; p < buf + len; p += ifm->ifm_msglen) {
+		ifm = (struct if_msghdr *)p;
+		sdl = (struct sockaddr_dl *)(ifm + 1);
+		if (ifm->ifm_type != RTM_IFINFO ||
+		    (ifm->ifm_addrs & RTA_IFP) == 0)
+			continue;
+		if (sdl->sdl_family != AF_LINK || sdl->sdl_nlen == 0 ||
+		    os_memcmp(sdl->sdl_data, device, sdl->sdl_nlen) != 0)
+			continue;
+		os_memcpy(ea, LLADDR(sdl), sdl->sdl_alen);
+		break;
+	os_free(buf);
+	if (p >= buf + len) {
+		errno = ESRCH;
+		return -1;
+	return 0;
+	struct l2_packet_data *l2;
+	l2 = os_zalloc(sizeof(struct l2_packet_data));
+	if (l2 == NULL)
+		return NULL;
+	os_strlcpy(l2->ifname, ifname, sizeof(l2->ifname));
+	l2->rx_callback = rx_callback;
+	l2->rx_callback_ctx = rx_callback_ctx;
+	l2->l2_hdr = l2_hdr;
+	if (eth_get(l2->ifname, l2->own_addr) < 0) {
+		fprintf(stderr, "Failed to get link-level address for "
+			"interface '%s'.\n", l2->ifname);
+		os_free(l2);
+		return NULL;
+	if (l2_packet_init_libpcap(l2, protocol)) {
+		os_free(l2);
+		return NULL;
+	return l2;
+	return l2_packet_init(br_ifname, own_addr, protocol, rx_callback,
+			      rx_callback_ctx, l2_hdr);
+	if (l2 != NULL) {
+		if (l2->pcap) {
+			eloop_unregister_read_sock(
+				pcap_get_selectable_fd(l2->pcap));
+			pcap_close(l2->pcap);
+		os_free(l2);
+	pcap_if_t *devs, *dev;
+	struct pcap_addr *addr;
+	struct sockaddr_in *saddr;
+	int found = 0;
+	char err[PCAP_ERRBUF_SIZE + 1];
+	if (pcap_findalldevs(&devs, err) < 0) {
+		wpa_printf(MSG_DEBUG, "pcap_findalldevs: %s\n", err);
+		return -1;
+	for (dev = devs; dev && !found; dev = dev->next) {
+		if (os_strcmp(dev->name, l2->ifname) != 0)
+			continue;
+		addr = dev->addresses;
+		while (addr) {
+			saddr = (struct sockaddr_in *) addr->addr;
+			if (saddr && saddr->sin_family == AF_INET) {
+				os_strlcpy(buf, inet_ntoa(saddr->sin_addr),
+					   len);
+				found = 1;
+				break;
+			addr = addr->next;
+	pcap_freealldevs(devs);
+	return found ? 0 : -1;
+	return -1;
diff --git a/freebsd/contrib/wpa/src/p2p/p2p.h b/freebsd/contrib/wpa/src/p2p/p2p.h
index 00000000000..b4060be477b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/p2p/p2p.h
@@ -0,0 +1,2343 @@
+ * Wi-Fi Direct - P2P module
+ * Copyright (c) 2009-2010, Atheros Communications
+#ifndef P2P_H
+#define P2P_H
+#include "common/ieee802_11_defs.h"
+#include "wps/wps.h"
+/* P2P ASP Setup Capability */
+#define P2PS_SETUP_NONE 0
+#define P2PS_SETUP_NEW BIT(0)
+#define P2PS_SETUP_CLIENT BIT(1)
+#define P2PS_SETUP_GROUP_OWNER BIT(2)
+#define P2PS_WILD_HASH_STR "org.wi-fi.wfds"
+#define P2PS_HASH_LEN 6
+#define P2P_MAX_QUERY_HASH 6
+#define P2PS_FEATURE_CAPAB_CPT_MAX 2
+ * P2P_MAX_PREF_CHANNELS - Maximum number of preferred channels
+#define P2P_MAX_PREF_CHANNELS 100
+ * P2P_MAX_REG_CLASSES - Maximum number of regulatory classes
+#define P2P_MAX_REG_CLASSES 10
+ * P2P_MAX_REG_CLASS_CHANNELS - Maximum number of channels per regulatory class
+#define P2P_MAX_REG_CLASS_CHANNELS 20
+ * struct p2p_channels - List of supported channels
+struct p2p_channels {
+	 * struct p2p_reg_class - Supported regulatory class
+	struct p2p_reg_class {
+		 * reg_class - Regulatory class (IEEE 802.11-2007, Annex J)
+		u8 reg_class;
+		 * channel - Supported channels
+		u8 channel[P2P_MAX_REG_CLASS_CHANNELS];
+		 * channels - Number of channel entries in use
+		size_t channels;
+	} reg_class[P2P_MAX_REG_CLASSES];
+	 * reg_classes - Number of reg_class entries in use
+	size_t reg_classes;
+enum p2p_wps_method {
+	WPS_NOT_READY, WPS_PIN_DISPLAY, WPS_PIN_KEYPAD, WPS_PBC, WPS_NFC,
+	WPS_P2PS
+ * struct p2p_go_neg_results - P2P Group Owner Negotiation results
+struct p2p_go_neg_results {
+	 * status - Negotiation result (Status Code)
+	 * 0 (P2P_SC_SUCCESS) indicates success. Non-zero values indicate
+	 * failed negotiation.
+	int status;
+	 * role_go - Whether local end is Group Owner
+	int role_go;
+	 * freq - Frequency of the group operational channel in MHz
+	int freq;
+	int ht40;
+	int vht;
+	 * ssid - SSID of the group
+	u8 ssid[SSID_MAX_LEN];
+	 * ssid_len - Length of SSID in octets
+	size_t ssid_len;
+	 * psk - WPA pre-shared key (256 bits) (GO only)
+	u8 psk[32];
+	 * psk_set - Whether PSK field is configured (GO only)
+	int psk_set;
+	 * passphrase - WPA2-Personal passphrase for the group (GO only)
+	char passphrase[64];
+	 * peer_device_addr - P2P Device Address of the peer
+	u8 peer_device_addr[ETH_ALEN];
+	 * peer_interface_addr - P2P Interface Address of the peer
+	u8 peer_interface_addr[ETH_ALEN];
+	 * wps_method - WPS method to be used during provisioning
+	enum p2p_wps_method wps_method;
+#define P2P_MAX_CHANNELS 50
+	 * freq_list - Zero-terminated list of possible operational channels
+	int freq_list[P2P_MAX_CHANNELS];
+	 * persistent_group - Whether the group should be made persistent
+	 * 0 = not persistent
+	 * 1 = persistent group without persistent reconnect
+	 * 2 = persistent group with persistent reconnect
+	int persistent_group;
+	 * peer_config_timeout - Peer configuration timeout (in 10 msec units)
+	unsigned int peer_config_timeout;
+struct p2ps_provision {
+	 * pd_seeker - P2PS provision discovery seeker role
+	unsigned int pd_seeker:1;
+	 * status - Remote returned provisioning status code
+	int status;
+	 * adv_id - P2PS Advertisement ID
+	u32 adv_id;
+	 * session_id - P2PS Session ID
+	u32 session_id;
+	 * method - WPS Method (to be) used to establish session
+	u16 method;
+	 * conncap - Connection Capabilities negotiated between P2P peers
+	u8 conncap;
+	 * role - Info about the roles to be used for this connection
+	u8 role;
+	 * session_mac - MAC address of the peer that started the session
+	u8 session_mac[ETH_ALEN];
+	 * adv_mac - MAC address of the peer advertised the service
+	u8 adv_mac[ETH_ALEN];
+	 * cpt_mask - Supported Coordination Protocol Transport mask
+	 * A bitwise mask of supported ASP Coordination Protocol Transports.
+	 * This property is set together and corresponds with cpt_priority.
+	u8 cpt_mask;
+	 * cpt_priority - Coordination Protocol Transport priority list
+	 * Priorities of supported ASP Coordination Protocol Transports.
+	 * This property is set together and corresponds with cpt_mask.
+	 * The CPT priority list is 0 terminated.
+	u8 cpt_priority[P2PS_FEATURE_CAPAB_CPT_MAX + 1];
+	 * info - Vendor defined extra Provisioning information
+	char info[0];
+struct p2ps_advertisement {
+	struct p2ps_advertisement *next;
+	 * svc_info - Pointer to (internal) Service defined information
+	char *svc_info;
+	 * id - P2PS Advertisement ID
+	u32 id;
+	 * config_methods - WPS Methods which are allowed for this service
+	u16 config_methods;
+	 * state - Current state of the service: 0 - Out Of Service, 1-255 Vendor defined
+	u8 state;
+	 * auto_accept - Automatically Accept provisioning request if possible.
+	u8 auto_accept;
+	 * hash - 6 octet Service Name has to match against incoming Probe Requests
+	u8 hash[P2PS_HASH_LEN];
+	 * cpt_mask - supported Coordination Protocol Transport mask
+	u8 cpt_mask;
+	 * Priorities of supported ASP Coordinatin Protocol Transports.
+	 * svc_name - NULL Terminated UTF-8 Service Name, and svc_info storage
+	char svc_name[0];
+struct p2p_data;
+enum p2p_scan_type {
+	P2P_SCAN_SOCIAL,
+	P2P_SCAN_FULL,
+	P2P_SCAN_SPECIFIC,
+	P2P_SCAN_SOCIAL_PLUS_ONE
+#define P2P_MAX_WPS_VENDOR_EXT 10
+ * struct p2p_peer_info - P2P peer information
+struct p2p_peer_info {
+	 * p2p_device_addr - P2P Device Address of the peer
+	u8 p2p_device_addr[ETH_ALEN];
+	 * pri_dev_type - Primary Device Type
+	u8 pri_dev_type[8];
+	 * device_name - Device Name (0..32 octets encoded in UTF-8)
+	char device_name[WPS_DEV_NAME_MAX_LEN + 1];
+	 * manufacturer - Manufacturer (0..64 octets encoded in UTF-8)
+	char manufacturer[WPS_MANUFACTURER_MAX_LEN + 1];
+	 * model_name - Model Name (0..32 octets encoded in UTF-8)
+	char model_name[WPS_MODEL_NAME_MAX_LEN + 1];
+	 * model_number - Model Number (0..32 octets encoded in UTF-8)
+	char model_number[WPS_MODEL_NUMBER_MAX_LEN + 1];
+	 * serial_number - Serial Number (0..32 octets encoded in UTF-8)
+	char serial_number[WPS_SERIAL_NUMBER_MAX_LEN + 1];
+	 * level - Signal level
+	int level;
+	 * config_methods - WPS Configuration Methods
+	 * dev_capab - Device Capabilities
+	u8 dev_capab;
+	 * group_capab - Group Capabilities
+	u8 group_capab;
+	 * wps_sec_dev_type_list - WPS secondary device type list
+	 * This list includes from 0 to 16 Secondary Device Types as indicated
+	 * by wps_sec_dev_type_list_len (8 * number of types).
+	u8 wps_sec_dev_type_list[WPS_SEC_DEV_TYPE_MAX_LEN];
+	 * wps_sec_dev_type_list_len - Length of secondary device type list
+	size_t wps_sec_dev_type_list_len;
+	struct wpabuf *wps_vendor_ext[P2P_MAX_WPS_VENDOR_EXT];
+	 * wfd_subelems - Wi-Fi Display subelements from WFD IE(s)
+	struct wpabuf *wfd_subelems;
+	 * vendor_elems - Unrecognized vendor elements
+	 * This buffer includes any other vendor element than P2P, WPS, and WFD
+	 * IE(s) from the frame that was used to discover the peer.
+	struct wpabuf *vendor_elems;
+	 * p2ps_instance - P2PS Application Service Info
+	struct wpabuf *p2ps_instance;
+enum p2p_prov_disc_status {
+	P2P_PROV_DISC_SUCCESS,
+	P2P_PROV_DISC_TIMEOUT,
+	P2P_PROV_DISC_REJECTED,
+	P2P_PROV_DISC_TIMEOUT_JOIN,
+	P2P_PROV_DISC_INFO_UNAVAILABLE,
+struct p2p_channel {
+	u8 op_class;
+	u8 chan;
+ * struct p2p_config - P2P configuration
+ * This configuration is provided to the P2P module during initialization with
+ * p2p_init().
+struct p2p_config {
+	 * country - Country code to use in P2P operations
+	char country[3];
+	 * reg_class - Regulatory class for own listen channel
+	u8 reg_class;
+	 * channel - Own listen channel
+	u8 channel;
+	 * channel_forced - the listen channel was forced by configuration
+	 *                  or by control interface and cannot be overridden
+	u8 channel_forced;
+	 * Regulatory class for own operational channel
+	u8 op_reg_class;
+	 * op_channel - Own operational channel
+	u8 op_channel;
+	 * cfg_op_channel - Whether op_channel is hardcoded in configuration
+	u8 cfg_op_channel;
+	 * channels - Own supported regulatory classes and channels
+	 * List of supposerted channels per regulatory class. The regulatory
+	 * classes are defined in IEEE Std 802.11-2007 Annex J and the
+	 * numbering of the clases depends on the configured country code.
+	struct p2p_channels channels;
+	 * cli_channels - Additional client channels
+	 * This list of channels (if any) will be used when advertising local
+	 * channels during GO Negotiation or Invitation for the cases where the
+	 * local end may become the client. This may allow the peer to become a
+	 * GO on additional channels if it supports these options. The main use
+	 * case for this is to include passive-scan channels on devices that may
+	 * not know their current location and have configured most channels to
+	 * not allow initiation of radition (i.e., another device needs to take
+	 * master responsibilities).
+	struct p2p_channels cli_channels;
+	 * num_pref_chan - Number of pref_chan entries
+	unsigned int num_pref_chan;
+	 * pref_chan - Preferred channels for GO Negotiation
+	struct p2p_channel *pref_chan;
+	 * pri_dev_type - Primary Device Type (see WPS)
+	 * P2P_SEC_DEVICE_TYPES - Maximum number of secondary device types
+#define P2P_SEC_DEVICE_TYPES 5
+	 * sec_dev_type - Optional secondary device types
+	u8 sec_dev_type[P2P_SEC_DEVICE_TYPES][8];
+	 * num_sec_dev_types - Number of sec_dev_type entries
+	size_t num_sec_dev_types;
+	 * dev_addr - P2P Device Address
+	u8 dev_addr[ETH_ALEN];
+	 * dev_name - Device Name
+	char *dev_name;
+	char *manufacturer;
+	char *model_name;
+	char *model_number;
+	char *serial_number;
+	u8 uuid[16];
+	 * concurrent_operations - Whether concurrent operations are supported
+	int concurrent_operations;
+	 * max_peers - Maximum number of discovered peers to remember
+	 * If more peers are discovered, older entries will be removed to make
+	 * room for the new ones.
+	size_t max_peers;
+	 * p2p_intra_bss - Intra BSS communication is supported
+	int p2p_intra_bss;
+	 * ssid_postfix - Postfix data to add to the SSID
+	 * This data will be added to the end of the SSID after the
+	 * DIRECT-<random two octets> prefix.
+	u8 ssid_postfix[SSID_MAX_LEN - 9];
+	 * ssid_postfix_len - Length of the ssid_postfix data
+	size_t ssid_postfix_len;
+	 * max_listen - Maximum listen duration in ms
+	unsigned int max_listen;
+	 * passphrase_len - Passphrase length (8..63)
+	 * This parameter controls the length of the random passphrase that is
+	 * generated at the GO.
+	unsigned int passphrase_len;
+	 * cb_ctx - Context to use with callback functions
+	void *cb_ctx;
+	 * debug_print - Debug print
+	 * @ctx: Callback context from cb_ctx
+	 * @level: Debug verbosity level (MSG_*)
+	 * @msg: Debug message
+	void (*debug_print)(void *ctx, int level, const char *msg);
+	/* Callbacks to request lower layer driver operations */
+	 * p2p_scan - Request a P2P scan/search
+	 * @type: Scan type
+	 * @freq: Specific frequency (MHz) to scan or 0 for no restriction
+	 * @num_req_dev_types: Number of requested device types
+	 * @req_dev_types: Array containing requested device types
+	 * @dev_id: Device ID to search for or %NULL to find all devices
+	 * @pw_id: Device Password ID
+	 * This callback function is used to request a P2P scan or search
+	 * operation to be completed. Type type argument specifies which type
+	 * of scan is to be done. @P2P_SCAN_SOCIAL indicates that only the
+	 * social channels (1, 6, 11) should be scanned. @P2P_SCAN_FULL
+	 * indicates that all channels are to be scanned. @P2P_SCAN_SPECIFIC
+	 * request a scan of a single channel specified by freq.
+	 * @P2P_SCAN_SOCIAL_PLUS_ONE request scan of all the social channels
+	 * plus one extra channel specified by freq.
+	 * The full scan is used for the initial scan to find group owners from
+	 * all. The other types are used during search phase scan of the social
+	 * channels (with potential variation if the Listen channel of the
+	 * target peer is known or if other channels are scanned in steps).
+	 * The scan results are returned after this call by calling
+	 * p2p_scan_res_handler() for each scan result that has a P2P IE and
+	 * then calling p2p_scan_res_handled() to indicate that all scan
+	 * results have been indicated.
+	int (*p2p_scan)(void *ctx, enum p2p_scan_type type, int freq,
+			unsigned int num_req_dev_types,
+			const u8 *req_dev_types, const u8 *dev_id, u16 pw_id);
+	 * send_probe_resp - Transmit a Probe Response frame
+	 * @buf: Probe Response frame (including the header and body)
+	 * @freq: Forced frequency (in MHz) to use or 0.
+	 * This function is used to reply to Probe Request frames that were
+	 * indicated with a call to p2p_probe_req_rx(). The response is to be
+	 * sent on the same channel, unless otherwise specified, or to be
+	 * dropped if the driver is not listening to Probe Request frames
+	 * anymore.
+	 * Alternatively, the responsibility for building the Probe Response
+	 * frames in Listen state may be in another system component in which
+	 * case this function need to be implemented (i.e., the function
+	 * pointer can be %NULL). The WPS and P2P IEs to be added for Probe
+	 * Response frames in such a case are available from the
+	 * start_listen() callback. It should be noted that the received Probe
+	 * Request frames must be indicated by calling p2p_probe_req_rx() even
+	 * if this send_probe_resp() is not used.
+	int (*send_probe_resp)(void *ctx, const struct wpabuf *buf,
+			       unsigned int freq);
+	 * send_action - Transmit an Action frame
+	 * @freq: Frequency in MHz for the channel on which to transmit
+	 * @dst: Destination MAC address (Address 1)
+	 * @src: Source MAC address (Address 2)
+	 * @bssid: BSSID (Address 3)
+	 * @buf: Frame body (starting from Category field)
+	 * @len: Length of buf in octets
+	 * @wait_time: How many msec to wait for a response frame
+	 * The Action frame may not be transmitted immediately and the status
+	 * of the transmission must be reported by calling
+	 * p2p_send_action_cb() once the frame has either been transmitted or
+	 * it has been dropped due to excessive retries or other failure to
+	 * transmit.
+	int (*send_action)(void *ctx, unsigned int freq, const u8 *dst,
+			   const u8 *src, const u8 *bssid, const u8 *buf,
+			   size_t len, unsigned int wait_time);
+	 * send_action_done - Notify that Action frame sequence was completed
+	 * This function is called when the Action frame sequence that was
+	 * started with send_action() has been completed, i.e., when there is
+	 * no need to wait for a response from the destination peer anymore.
+	void (*send_action_done)(void *ctx);
+	 * start_listen - Start Listen state
+	 * @freq: Frequency of the listen channel in MHz
+	 * @duration: Duration for the Listen state in milliseconds
+	 * @probe_resp_ie: IE(s) to be added to Probe Response frames
+	 * This Listen state may not start immediately since the driver may
+	 * have other pending operations to complete first. Once the Listen
+	 * state has started, p2p_listen_cb() must be called to notify the P2P
+	 * module. Once the Listen state is stopped, p2p_listen_end() must be
+	 * called to notify the P2P module that the driver is not in the Listen
+	 * state anymore.
+	 * If the send_probe_resp() is not used for generating the response,
+	 * the IEs from probe_resp_ie need to be added to the end of the Probe
+	 * Response frame body. If send_probe_resp() is used, the probe_resp_ie
+	 * information can be ignored.
+	int (*start_listen)(void *ctx, unsigned int freq,
+			    unsigned int duration,
+			    const struct wpabuf *probe_resp_ie);
+	 * stop_listen - Stop Listen state
+	 * This callback can be used to stop a Listen state operation that was
+	 * previously requested with start_listen().
+	void (*stop_listen)(void *ctx);
+	 * get_noa - Get current Notice of Absence attribute payload
+	 * @interface_addr: P2P Interface Address of the GO
+	 * @buf: Buffer for returning NoA
+	 * @buf_len: Buffer length in octets
+	 * Returns: Number of octets used in buf, 0 to indicate no NoA is being
+	 * advertized, or -1 on failure
+	 * This function is used to fetch the current Notice of Absence
+	 * attribute value from GO.
+	int (*get_noa)(void *ctx, const u8 *interface_addr, u8 *buf,
+		       size_t buf_len);
+	/* Callbacks to notify events to upper layer management entity */
+	 * dev_found - Notification of a found P2P Device
+	 * @addr: Source address of the message triggering this notification
+	 * @info: P2P peer information
+	 * @new_device: Inform if the peer is newly found
+	 * This callback is used to notify that a new P2P Device has been
+	 * found. This may happen, e.g., during Search state based on scan
+	 * results or during Listen state based on receive Probe Request and
+	 * Group Owner Negotiation Request.
+	void (*dev_found)(void *ctx, const u8 *addr,
+			  const struct p2p_peer_info *info,
+			  int new_device);
+	 * dev_lost - Notification of a lost P2P Device
+	 * @dev_addr: P2P Device Address of the lost P2P Device
+	 * This callback is used to notify that a P2P Device has been deleted.
+	void (*dev_lost)(void *ctx, const u8 *dev_addr);
+	 * find_stopped - Notification of a p2p_find operation stopping
+	void (*find_stopped)(void *ctx);
+	 * go_neg_req_rx - Notification of a receive GO Negotiation Request
+	 * @src: Source address of the message triggering this notification
+	 * @dev_passwd_id: WPS Device Password ID
+	 * @go_intent: Peer's GO Intent
+	 * This callback is used to notify that a P2P Device is requesting
+	 * group owner negotiation with us, but we do not have all the
+	 * necessary information to start GO Negotiation. This indicates that
+	 * the local user has not authorized the connection yet by providing a
+	 * PIN or PBC button press. This information can be provided with a
+	 * call to p2p_connect().
+	void (*go_neg_req_rx)(void *ctx, const u8 *src, u16 dev_passwd_id,
+			      u8 go_intent);
+	 * go_neg_completed - Notification of GO Negotiation results
+	 * @res: GO Negotiation results
+	 * This callback is used to notify that Group Owner Negotiation has
+	 * been completed. Non-zero struct p2p_go_neg_results::status indicates
+	 * failed negotiation. In case of success, this function is responsible
+	 * for creating a new group interface (or using the existing interface
+	 * depending on driver features), setting up the group interface in
+	 * proper mode based on struct p2p_go_neg_results::role_go and
+	 * initializing WPS provisioning either as a Registrar (if GO) or as an
+	 * Enrollee. Successful WPS provisioning must be indicated by calling
+	 * p2p_wps_success_cb(). The callee is responsible for timing out group
+	 * formation if WPS provisioning cannot be completed successfully
+	 * within 15 seconds.
+	void (*go_neg_completed)(void *ctx, struct p2p_go_neg_results *res);
+	 * sd_request - Callback on Service Discovery Request
+	 * @freq: Frequency (in MHz) of the channel
+	 * @sa: Source address of the request
+	 * @dialog_token: Dialog token
+	 * @update_indic: Service Update Indicator from the source of request
+	 * @tlvs: P2P Service Request TLV(s)
+	 * @tlvs_len: Length of tlvs buffer in octets
+	 * This callback is used to indicate reception of a service discovery
+	 * request. Response to the query must be indicated by calling
+	 * p2p_sd_response() with the context information from the arguments to
+	 * this callback function.
+	 * This callback handler can be set to %NULL to indicate that service
+	 * discovery is not supported.
+	void (*sd_request)(void *ctx, int freq, const u8 *sa, u8 dialog_token,
+			   u16 update_indic, const u8 *tlvs, size_t tlvs_len);
+	 * sd_response - Callback on Service Discovery Response
+	 * @update_indic: Service Update Indicator from the source of response
+	 * @tlvs: P2P Service Response TLV(s)
+	 * response. This callback handler can be set to %NULL if no service
+	 * discovery requests are used. The information provided with this call
+	 * is replies to the queries scheduled with p2p_sd_request().
+	void (*sd_response)(void *ctx, const u8 *sa, u16 update_indic,
+			    const u8 *tlvs, size_t tlvs_len);
+	 * prov_disc_req - Callback on Provisiong Discovery Request
+	 * @peer: Source address of the request
+	 * @config_methods: Requested WPS Config Method
+	 * @dev_addr: P2P Device Address of the found P2P Device
+	 * @pri_dev_type: Primary Device Type
+	 * @dev_name: Device Name
+	 * @supp_config_methods: Supported configuration Methods
+	 * @dev_capab: Device Capabilities
+	 * @group_capab: Group Capabilities
+	 * @group_id: P2P Group ID (or %NULL if not included)
+	 * @group_id_len: Length of P2P Group ID
+	 * This callback is used to indicate reception of a Provision Discovery
+	 * Request frame that the P2P module accepted.
+	void (*prov_disc_req)(void *ctx, const u8 *peer, u16 config_methods,
+			      const u8 *dev_addr, const u8 *pri_dev_type,
+			      const char *dev_name, u16 supp_config_methods,
+			      u8 dev_capab, u8 group_capab,
+			      const u8 *group_id, size_t group_id_len);
+	 * prov_disc_resp - Callback on Provisiong Discovery Response
+	 * @peer: Source address of the response
+	 * @config_methods: Value from p2p_prov_disc_req() or 0 on failure
+	 * Response frame for a pending request scheduled with
+	 * p2p_prov_disc_req(). This callback handler can be set to %NULL if
+	 * provision discovery is not used.
+	void (*prov_disc_resp)(void *ctx, const u8 *peer, u16 config_methods);
+	 * prov_disc_fail - Callback on Provision Discovery failure
+	 * @status: Cause of failure, will not be %P2P_PROV_DISC_SUCCESS
+	 * @adv_id: If non-zero, then the adv_id of the PD Request
+	 * @adv_mac: P2P Device Address of the advertizer
+	 * @deferred_session_resp: Deferred session response sent by advertizer
+	 * This callback is used to indicate either a failure or no response
+	 * to an earlier provision discovery request.
+	 * This callback handler can be set to %NULL if provision discovery
+	 * is not used or failures do not need to be indicated.
+	void (*prov_disc_fail)(void *ctx, const u8 *peer,
+			       enum p2p_prov_disc_status status,
+			       u32 adv_id, const u8 *adv_mac,
+			       const char *deferred_session_resp);
+	 * invitation_process - Optional callback for processing Invitations
+	 * @sa: Source address of the Invitation Request
+	 * @bssid: P2P Group BSSID from the request or %NULL if not included
+	 * @go_dev_addr: GO Device Address from P2P Group ID
+	 * @ssid: SSID from P2P Group ID
+	 * @ssid_len: Length of ssid buffer in octets
+	 * @go: Variable for returning whether the local end is GO in the group
+	 * @group_bssid: Buffer for returning P2P Group BSSID (if local end GO)
+	 * @force_freq: Variable for returning forced frequency for the group
+	 * @persistent_group: Whether this is an invitation to reinvoke a
+	 *	persistent group (instead of invitation to join an active
+	 *	group)
+	 * @channels: Available operating channels for the group
+	 * @dev_pw_id: Device Password ID for NFC static handover or -1 if not
+	 *	used
+	 * Returns: Status code (P2P_SC_*)
+	 * This optional callback can be used to implement persistent reconnect
+	 * by allowing automatic restarting of persistent groups without user
+	 * interaction. If this callback is not implemented (i.e., is %NULL),
+	 * the received Invitation Request frames are replied with
+	 * %P2P_SC_REQ_RECEIVED status and indicated to upper layer with the
+	 * invitation_result() callback.
+	 * If the requested parameters are acceptable and the group is known,
+	 * %P2P_SC_SUCCESS may be returned. If the requested group is unknown,
+	 * %P2P_SC_FAIL_UNKNOWN_GROUP should be returned. %P2P_SC_REQ_RECEIVED
+	 * can be returned if there is not enough data to provide immediate
+	 * response, i.e., if some sort of user interaction is needed. The
+	 * invitation_received() callback will be called in that case
+	 * immediately after this call.
+	u8 (*invitation_process)(void *ctx, const u8 *sa, const u8 *bssid,
+				 const u8 *go_dev_addr, const u8 *ssid,
+				 size_t ssid_len, int *go, u8 *group_bssid,
+				 int *force_freq, int persistent_group,
+				 const struct p2p_channels *channels,
+				 int dev_pw_id);
+	 * invitation_received - Callback on Invitation Request RX
+	 * @bssid: P2P Group BSSID or %NULL if not received
+	 * @ssid: SSID of the group
+	 * @ssid_len: Length of ssid in octets
+	 * @status: Response Status
+	 * @op_freq: Operational frequency for the group
+	 * This callback is used to indicate sending of an Invitation Response
+	 * for a received Invitation Request. If status == 0 (success), the
+	 * upper layer code is responsible for starting the group. status == 1
+	 * indicates need to get user authorization for the group. Other status
+	 * values indicate that the invitation request was rejected.
+	void (*invitation_received)(void *ctx, const u8 *sa, const u8 *bssid,
+				    const u8 *ssid, size_t ssid_len,
+				    const u8 *go_dev_addr, u8 status,
+				    int op_freq);
+	 * invitation_result - Callback on Invitation result
+	 * @status: Negotiation result (Status Code)
+	 * @addr: Peer address
+	 * @freq: Frequency (in MHz) indicated during invitation or 0
+	 * @peer_oper_freq: Operating frequency (in MHz) advertized by the peer
+	 * during invitation or 0
+	 * This callback is used to indicate result of an Invitation procedure
+	 * started with a call to p2p_invite(). The indicated status code is
+	 * the value received from the peer in Invitation Response with 0
+	 * (P2P_SC_SUCCESS) indicating success or -1 to indicate a timeout or a
+	 * local failure in transmitting the Invitation Request.
+	void (*invitation_result)(void *ctx, int status, const u8 *bssid,
+				  const u8 *addr, int freq, int peer_oper_freq);
+	 * go_connected - Check whether we are connected to a GO
+	 * @dev_addr: P2P Device Address of a GO
+	 * Returns: 1 if we are connected as a P2P client to the specified GO
+	 * or 0 if not.
+	int (*go_connected)(void *ctx, const u8 *dev_addr);
+	 * presence_resp - Callback on Presence Response
+	 * @src: Source address (GO's P2P Interface Address)
+	 * @status: Result of the request (P2P_SC_*)
+	 * @noa: Returned NoA value
+	 * @noa_len: Length of the NoA buffer in octets
+	void (*presence_resp)(void *ctx, const u8 *src, u8 status,
+			      const u8 *noa, size_t noa_len);
+	 * is_concurrent_session_active - Check whether concurrent session is
+	 * active on other virtual interfaces
+	 * Returns: 1 if concurrent session is active on other virtual interface
+	 * or 0 if not.
+	int (*is_concurrent_session_active)(void *ctx);
+	 * is_p2p_in_progress - Check whether P2P operation is in progress
+	 * Returns: 1 if P2P operation (e.g., group formation) is in progress
+	 * or 0 if not.
+	int (*is_p2p_in_progress)(void *ctx);
+	 * Determine if we have a persistent group we share with remote peer
+	 * and allocate interface for this group if needed
+	 * @addr: Peer device address to search for
+	 * @ssid: Persistent group SSID or %NULL if any
+	 * @ssid_len: Length of @ssid
+	 * @go_dev_addr: Buffer for returning GO P2P Device Address
+	 * @ret_ssid: Buffer for returning group SSID
+	 * @ret_ssid_len: Buffer for returning length of @ssid
+	 * @intended_iface_addr: Buffer for returning intended iface address
+	 * Returns: 1 if a matching persistent group was found, 0 otherwise
+	int (*get_persistent_group)(void *ctx, const u8 *addr, const u8 *ssid,
+				    size_t ssid_len, u8 *go_dev_addr,
+				    u8 *ret_ssid, size_t *ret_ssid_len,
+				    u8 *intended_iface_addr);
+	 * Get information about a possible local GO role
+	 * @intended_addr: Buffer for returning intended GO interface address
+	 * @ssid: Buffer for returning group SSID
+	 * @ssid_len: Buffer for returning length of @ssid
+	 * @group_iface: Buffer for returning whether a separate group interface
+	 *	would be used
+	 * Returns: 1 if GO info found, 0 otherwise
+	 * This is used to compose New Group settings (SSID, and intended
+	 * address) during P2PS provisioning if results of provisioning *might*
+	 * result in our being an autonomous GO.
+	int (*get_go_info)(void *ctx, u8 *intended_addr,
+			   u8 *ssid, size_t *ssid_len, int *group_iface);
+	 * remove_stale_groups - Remove stale P2PS groups
+	 * Because P2PS stages *potential* GOs, and remote devices can remove
+	 * credentials unilaterally, we need to make sure we don't let stale
+	 * unusable groups build up.
+	int (*remove_stale_groups)(void *ctx, const u8 *peer, const u8 *go,
+				   const u8 *ssid, size_t ssid_len);
+	 * p2ps_prov_complete - P2PS provisioning complete
+	 * When P2PS provisioning completes (successfully or not) we must
+	 * transmit all of the results to the upper layers.
+	void (*p2ps_prov_complete)(void *ctx, u8 status, const u8 *dev,
+				   const u8 *adv_mac, const u8 *ses_mac,
+				   const u8 *grp_mac, u32 adv_id, u32 ses_id,
+				   u8 conncap, int passwd_id,
+				   const u8 *persist_ssid,
+				   size_t persist_ssid_size, int response_done,
+				   int prov_start, const char *session_info,
+				   const u8 *feat_cap, size_t feat_cap_len);
+	 * prov_disc_resp_cb - Callback for indicating completion of PD Response
+	 * Returns: 1 if operation was started, 0 otherwise
+	 * This callback can be used to perform any pending actions after
+	 * provisioning. It is mainly used for P2PS pending group creation.
+	int (*prov_disc_resp_cb)(void *ctx);
+	 * p2ps_group_capability - Determine group capability
+	 * This function can be used to determine group capability based on
+	 * information from P2PS PD exchange and the current state of ongoing
+	 * groups and driver capabilities.
+	 * P2PS_SETUP_* bitmap is used as the parameters and return value.
+	u8 (*p2ps_group_capability)(void *ctx, u8 incoming, u8 role);
+	 * get_pref_freq_list - Get preferred frequency list for an interface
+	 * @go: Whether the use if for GO role
+	 * @len: Length of freq_list in entries (both IN and OUT)
+	 * @freq_list: Buffer for returning the preferred frequencies (MHz)
+	 * Returns: 0 on success, -1 on failure
+	 * This function can be used to query the preferred frequency list from
+	 * the driver specific to a particular interface type.
+	int (*get_pref_freq_list)(void *ctx, int go,
+				  unsigned int *len, unsigned int *freq_list);
+/* P2P module initialization/deinitialization */
+ * p2p_init - Initialize P2P module
+ * @cfg: P2P module configuration
+ * Returns: Pointer to private data or %NULL on failure
+ * This function is used to initialize global P2P module context (one per
+ * device). The P2P module will keep a copy of the configuration data, so the
+ * caller does not need to maintain this structure. However, the callback
+ * functions and the context parameters to them must be kept available until
+ * the P2P module is deinitialized with p2p_deinit().
+struct p2p_data * p2p_init(const struct p2p_config *cfg);
+ * p2p_deinit - Deinitialize P2P module
+ * @p2p: P2P module context from p2p_init()
+void p2p_deinit(struct p2p_data *p2p);
+ * p2p_flush - Flush P2P module state
+ * This command removes the P2P module state like peer device entries.
+void p2p_flush(struct p2p_data *p2p);
+ * p2p_unauthorize - Unauthorize the specified peer device
+ * @addr: P2P peer entry to be unauthorized
+ * This command removes any connection authorization from the specified P2P
+ * peer device address. This can be used, e.g., to cancel effect of a previous
+ * p2p_authorize() or p2p_connect() call that has not yet resulted in completed
+ * GO Negotiation.
+int p2p_unauthorize(struct p2p_data *p2p, const u8 *addr);
+ * p2p_set_dev_name - Set device name
+ * This function can be used to update the P2P module configuration with
+ * information that was not available at the time of the p2p_init() call.
+int p2p_set_dev_name(struct p2p_data *p2p, const char *dev_name);
+int p2p_set_manufacturer(struct p2p_data *p2p, const char *manufacturer);
+int p2p_set_model_name(struct p2p_data *p2p, const char *model_name);
+int p2p_set_model_number(struct p2p_data *p2p, const char *model_number);
+int p2p_set_serial_number(struct p2p_data *p2p, const char *serial_number);
+void p2p_set_config_methods(struct p2p_data *p2p, u16 config_methods);
+void p2p_set_uuid(struct p2p_data *p2p, const u8 *uuid);
+ * p2p_set_pri_dev_type - Set primary device type
+int p2p_set_pri_dev_type(struct p2p_data *p2p, const u8 *pri_dev_type);
+ * p2p_set_sec_dev_types - Set secondary device types
+int p2p_set_sec_dev_types(struct p2p_data *p2p, const u8 dev_types[][8],
+			  size_t num_dev_types);
+int p2p_set_country(struct p2p_data *p2p, const char *country);
+/* Commands from upper layer management entity */
+enum p2p_discovery_type {
+	P2P_FIND_START_WITH_FULL,
+	P2P_FIND_ONLY_SOCIAL,
+	P2P_FIND_PROGRESSIVE
+ * p2p_find - Start P2P Find (Device Discovery)
+ * @timeout: Timeout for find operation in seconds or 0 for no timeout
+ * @type: Device Discovery type
+ * @req_dev_types: Requested device types array, must be an array
+ *	containing num_req_dev_types * WPS_DEV_TYPE_LEN bytes; %NULL if no
+ *	requested device types.
+ * @search_delay: Extra delay in milliseconds between search iterations
+ * @seek_count: Number of ASP Service Strings in the seek_string array
+ * @seek_string: ASP Service Strings to query for in Probe Requests
+ * @freq: Requested first scan frequency (in MHz) to modify type ==
+ *	P2P_FIND_START_WITH_FULL behavior. 0 = Use normal full scan.
+ *	If p2p_find is already in progress, this parameter is ignored and full
+ *	scan will be executed.
+int p2p_find(struct p2p_data *p2p, unsigned int timeout,
+	     enum p2p_discovery_type type,
+	     unsigned int num_req_dev_types, const u8 *req_dev_types,
+	     const u8 *dev_id, unsigned int search_delay,
+	     u8 seek_count, const char **seek_string, int freq);
+ * p2p_notify_scan_trigger_status - Indicate scan trigger status
+ * @status: 0 on success, -1 on failure
+void p2p_notify_scan_trigger_status(struct p2p_data *p2p, int status);
+ * p2p_stop_find - Stop P2P Find (Device Discovery)
+void p2p_stop_find(struct p2p_data *p2p);
+ * p2p_stop_find_for_freq - Stop P2P Find for next oper on specific freq
+ * @freq: Frequency in MHz for next operation
+ * This is like p2p_stop_find(), but Listen state is not stopped if we are
+ * already on the same frequency.
+void p2p_stop_find_for_freq(struct p2p_data *p2p, int freq);
+ * p2p_listen - Start P2P Listen state for specified duration
+ * @timeout: Listen state duration in milliseconds
+ * This function can be used to request the P2P module to keep the device
+ * discoverable on the listen channel for an extended set of time. At least in
+ * its current form, this is mainly used for testing purposes and may not be of
+ * much use for normal P2P operations.
+int p2p_listen(struct p2p_data *p2p, unsigned int timeout);
+ * p2p_stop_listen - Stop P2P Listen
+void p2p_stop_listen(struct p2p_data *p2p);
+ * p2p_connect - Start P2P group formation (GO negotiation)
+ * @peer_addr: MAC address of the peer P2P client
+ * @wps_method: WPS method to be used in provisioning
+ * @go_intent: Local GO intent value (1..15)
+ * @own_interface_addr: Intended interface address to use with the group
+ * @force_freq: The only allowed channel frequency in MHz or 0
+ * @persistent_group: Whether to create a persistent group (0 = no, 1 =
+ * persistent group without persistent reconnect, 2 = persistent group with
+ * persistent reconnect)
+ * @force_ssid: Forced SSID for the group if we become GO or %NULL to generate
+ *	a new SSID
+ * @force_ssid_len: Length of $force_ssid buffer
+ * @pd_before_go_neg: Whether to send Provision Discovery prior to GO
+ *	Negotiation as an interoperability workaround when initiating group
+ *	formation
+ * @pref_freq: Preferred operating frequency in MHz or 0 (this is only used if
+ *	force_freq == 0)
+int p2p_connect(struct p2p_data *p2p, const u8 *peer_addr,
+		enum p2p_wps_method wps_method,
+		int go_intent, const u8 *own_interface_addr,
+		unsigned int force_freq, int persistent_group,
+		const u8 *force_ssid, size_t force_ssid_len,
+		int pd_before_go_neg, unsigned int pref_freq, u16 oob_pw_id);
+ * p2p_authorize - Authorize P2P group formation (GO negotiation)
+ *	a new SSID
+ * This is like p2p_connect(), but the actual group negotiation is not
+ * initiated automatically, i.e., the other end is expected to do that.
+int p2p_authorize(struct p2p_data *p2p, const u8 *peer_addr,
+		  unsigned int pref_freq, u16 oob_pw_id);
+ * p2p_reject - Reject peer device (explicitly block connection attempts)
+int p2p_reject(struct p2p_data *p2p, const u8 *peer_addr);
+ * p2p_prov_disc_req - Send Provision Discovery Request
+ * @p2ps_prov: Provisioning info for P2PS
+ * @config_methods: WPS Config Methods value (only one bit set)
+ * @join: Whether this is used by a client joining an active group
+ * @force_freq: Forced TX frequency for the frame (mainly for the join case)
+ * @user_initiated_pd: Flag to indicate if initiated by user or not
+ * This function can be used to request a discovered P2P peer to display a PIN
+ * (config_methods = WPS_CONFIG_DISPLAY) or be prepared to enter a PIN from us
+ * (config_methods = WPS_CONFIG_KEYPAD). The Provision Discovery Request frame
+ * is transmitted once immediately and if no response is received, the frame
+ * will be sent again whenever the target device is discovered during device
+ * dsicovery (start with a p2p_find() call). Response from the peer is
+ * indicated with the p2p_config::prov_disc_resp() callback.
+int p2p_prov_disc_req(struct p2p_data *p2p, const u8 *peer_addr,
+		      struct p2ps_provision *p2ps_prov, u16 config_methods,
+		      int join, int force_freq,
+		      int user_initiated_pd);
+ * p2p_sd_request - Schedule a service discovery query
+ * @dst: Destination peer or %NULL to apply for all peers
+ * @tlvs: P2P Service Query TLV(s)
+ * Returns: Reference to the query or %NULL on failure
+ * Response to the query is indicated with the p2p_config::sd_response()
+ * callback.
+void * p2p_sd_request(struct p2p_data *p2p, const u8 *dst,
+		      const struct wpabuf *tlvs);
+#ifdef CONFIG_WIFI_DISPLAY
+void * p2p_sd_request_wfd(struct p2p_data *p2p, const u8 *dst,
+#endif /* CONFIG_WIFI_DISPLAY */
+ * p2p_sd_cancel_request - Cancel a pending service discovery query
+ * @req: Query reference from p2p_sd_request()
+ * Returns: 0 if request for cancelled; -1 if not found
+int p2p_sd_cancel_request(struct p2p_data *p2p, void *req);
+ * p2p_sd_response - Send response to a service discovery query
+ * @freq: Frequency from p2p_config::sd_request() callback
+ * @dst: Destination address from p2p_config::sd_request() callback
+ * @dialog_token: Dialog token from p2p_config::sd_request() callback
+ * @resp_tlvs: P2P Service Response TLV(s)
+ * This function is called as a response to the request indicated with
+ * p2p_config::sd_request() callback.
+void p2p_sd_response(struct p2p_data *p2p, int freq, const u8 *dst,
+		     u8 dialog_token, const struct wpabuf *resp_tlvs);
+ * p2p_sd_service_update - Indicate a change in local services
+ * This function needs to be called whenever there is a change in availability
+ * of the local services. This will increment the Service Update Indicator
+ * value which will be used in SD Request and Response frames.
+void p2p_sd_service_update(struct p2p_data *p2p);
+enum p2p_invite_role {
+	P2P_INVITE_ROLE_GO,
+	P2P_INVITE_ROLE_ACTIVE_GO,
+	P2P_INVITE_ROLE_CLIENT
+ * p2p_invite - Invite a P2P Device into a group
+ * @peer: Device Address of the peer P2P Device
+ * @role: Local role in the group
+ * @bssid: Group BSSID or %NULL if not known
+ * @ssid: Group SSID
+ * @go_dev_addr: Forced GO Device Address or %NULL if none
+ * @persistent_group: Whether this is to reinvoke a persistent group
+ * @dev_pw_id: Device Password ID from OOB Device Password (NFC) static handover
+ *	case or -1 if not used
+int p2p_invite(struct p2p_data *p2p, const u8 *peer, enum p2p_invite_role role,
+	       const u8 *bssid, const u8 *ssid, size_t ssid_len,
+	       unsigned int force_freq, const u8 *go_dev_addr,
+	       int persistent_group, unsigned int pref_freq, int dev_pw_id);
+ * p2p_presence_req - Request GO presence
+ * @go_interface_addr: GO P2P Interface Address
+ * @own_interface_addr: Own P2P Interface Address for this group
+ * @freq: Group operating frequence (in MHz)
+ * @duration1: Preferred presence duration in microseconds
+ * @interval1: Preferred presence interval in microseconds
+ * @duration2: Acceptable presence duration in microseconds
+ * @interval2: Acceptable presence interval in microseconds
+ * If both duration and interval values are zero, the parameter pair is not
+ * specified (i.e., to remove Presence Request, use duration1 = interval1 = 0).
+int p2p_presence_req(struct p2p_data *p2p, const u8 *go_interface_addr,
+		     const u8 *own_interface_addr, unsigned int freq,
+		     u32 duration1, u32 interval1, u32 duration2,
+		     u32 interval2);
+ * p2p_ext_listen - Set Extended Listen Timing
+ * @period: Availability period in milliseconds (1-65535; 0 to disable)
+ * @interval: Availability interval in milliseconds (1-65535; 0 to disable)
+ * This function can be used to enable or disable (period = interval = 0)
+ * Extended Listen Timing. When enabled, the P2P Device will become
+ * discoverable (go into Listen State) every @interval milliseconds for at
+ * least @period milliseconds.
+int p2p_ext_listen(struct p2p_data *p2p, unsigned int period,
+		   unsigned int interval);
+/* Event notifications from upper layer management operations */
+ * p2p_wps_success_cb - Report successfully completed WPS provisioning
+ * @mac_addr: Peer address
+ * This function is used to report successfully completed WPS provisioning
+ * during group formation in both GO/Registrar and client/Enrollee roles.
+void p2p_wps_success_cb(struct p2p_data *p2p, const u8 *mac_addr);
+ * p2p_group_formation_failed - Report failed WPS provisioning
+ * This function is used to report failed group formation. This can happen
+ * either due to failed WPS provisioning or due to 15 second timeout during
+ * the provisioning phase.
+void p2p_group_formation_failed(struct p2p_data *p2p);
+ * p2p_get_provisioning_info - Get any stored provisioning info
+ * @addr: Peer P2P Device Address
+ * Returns: WPS provisioning information (WPS config method) or 0 if no
+ * information is available
+ * This function is used to retrieve stored WPS provisioning info for the given
+ * peer.
+u16 p2p_get_provisioning_info(struct p2p_data *p2p, const u8 *addr);
+ * p2p_clear_provisioning_info - Clear any stored provisioning info
+ * @iface_addr: Peer P2P Device Address
+ * This function is used to clear stored WPS provisioning info for the given
+ * peer.
+void p2p_clear_provisioning_info(struct p2p_data *p2p, const u8 *addr);
+/* Event notifications from lower layer driver operations */
+ * enum p2p_probe_req_status
+ * @P2P_PREQ_MALFORMED: frame was not well-formed
+ * @P2P_PREQ_NOT_LISTEN: device isn't in listen state, frame ignored
+ * @P2P_PREQ_NOT_P2P: frame was not a P2P probe request
+ * @P2P_PREQ_P2P_NOT_PROCESSED: frame was P2P but wasn't processed
+ * @P2P_PREQ_P2P_PROCESSED: frame has been processed by P2P
+enum p2p_probe_req_status {
+	P2P_PREQ_MALFORMED,
+	P2P_PREQ_NOT_LISTEN,
+	P2P_PREQ_NOT_P2P,
+	P2P_PREQ_NOT_PROCESSED,
+	P2P_PREQ_PROCESSED
+ * p2p_probe_req_rx - Report reception of a Probe Request frame
+ * @addr: Source MAC address
+ * @dst: Destination MAC address if available or %NULL
+ * @bssid: BSSID if available or %NULL
+ * @ie: Information elements from the Probe Request frame body
+ * @ie_len: Length of ie buffer in octets
+ * @rx_freq: Probe Request frame RX frequency
+ * Returns: value indicating the type and status of the probe request
+p2p_probe_req_rx(struct p2p_data *p2p, const u8 *addr, const u8 *dst,
+		 const u8 *bssid, const u8 *ie, size_t ie_len,
+		 unsigned int rx_freq);
+ * p2p_rx_action - Report received Action frame
+ * @da: Destination address of the received Action frame
+ * @sa: Source address of the received Action frame
+ * @bssid: Address 3 of the received Action frame
+ * @category: Category of the received Action frame
+ * @data: Action frame body after the Category field
+ * @len: Length of the data buffer in octets
+ * @freq: Frequency (in MHz) on which the frame was received
+void p2p_rx_action(struct p2p_data *p2p, const u8 *da, const u8 *sa,
+		   const u8 *bssid, u8 category,
+		   const u8 *data, size_t len, int freq);
+ * p2p_scan_res_handler - Indicate a P2P scan results
+ * @bssid: BSSID of the scan result
+ * @freq: Frequency of the channel on which the device was found in MHz
+ * @rx_time: Time when the result was received
+ * @level: Signal level (signal strength of the received Beacon/Probe Response
+ *	frame)
+ * @ies: Pointer to IEs from the scan result
+ * @ies_len: Length of the ies buffer
+ * Returns: 0 to continue or 1 to stop scan result indication
+ * This function is called to indicate a scan result entry with P2P IE from a
+ * scan requested with struct p2p_config::p2p_scan(). This can be called during
+ * the actual scan process (i.e., whenever a new device is found) or as a
+ * sequence of calls after the full scan has been completed. The former option
+ * can result in optimized operations, but may not be supported by all
+ * driver/firmware designs. The ies buffer need to include at least the P2P IE,
+ * but it is recommended to include all IEs received from the device. The
+ * caller does not need to check that the IEs contain a P2P IE before calling
+ * this function since frames will be filtered internally if needed.
+ * This function will return 1 if it wants to stop scan result iteration (and
+ * scan in general if it is still in progress). This is used to allow faster
+ * start of a pending operation, e.g., to start a pending GO negotiation.
+int p2p_scan_res_handler(struct p2p_data *p2p, const u8 *bssid, int freq,
+			 struct os_reltime *rx_time, int level, const u8 *ies,
+			 size_t ies_len);
+ * p2p_scan_res_handled - Indicate end of scan results
+ * This function is called to indicate that all P2P scan results from a scan
+ * have been reported with zero or more calls to p2p_scan_res_handler(). This
+ * function must be called as a response to successful
+ * struct p2p_config::p2p_scan() call if none of the p2p_scan_res_handler()
+ * calls stopped iteration.
+void p2p_scan_res_handled(struct p2p_data *p2p);
+enum p2p_send_action_result {
+	P2P_SEND_ACTION_SUCCESS /* Frame was send and acknowledged */,
+	P2P_SEND_ACTION_NO_ACK /* Frame was sent, but not acknowledged */,
+	P2P_SEND_ACTION_FAILED /* Frame was not sent due to a failure */
+ * p2p_send_action_cb - Notify TX status of an Action frame
+ * @freq: Channel frequency in MHz
+ * @result: Result of the transmission attempt
+ * This function is used to indicate the result of an Action frame transmission
+ * that was requested with struct p2p_config::send_action() callback.
+void p2p_send_action_cb(struct p2p_data *p2p, unsigned int freq, const u8 *dst,
+			enum p2p_send_action_result result);
+ * p2p_listen_cb - Indicate the start of a requested Listen state
+ * @freq: Listen channel frequency in MHz
+ * This function is used to indicate that a Listen state requested with
+ * struct p2p_config::start_listen() callback has started.
+void p2p_listen_cb(struct p2p_data *p2p, unsigned int freq,
+		   unsigned int duration);
+ * p2p_listen_end - Indicate the end of a requested Listen state
+ * Returns: 0 if no operations were started, 1 if an operation was started
+ * struct p2p_config::start_listen() callback has ended.
+int p2p_listen_end(struct p2p_data *p2p, unsigned int freq);
+void p2p_deauth_notif(struct p2p_data *p2p, const u8 *bssid, u16 reason_code,
+		      const u8 *ie, size_t ie_len);
+void p2p_disassoc_notif(struct p2p_data *p2p, const u8 *bssid, u16 reason_code,
+/* Per-group P2P state for GO */
+struct p2p_group;
+ * struct p2p_group_config - P2P group configuration
+ * This configuration is provided to the P2P module during initialization of
+ * the per-group information with p2p_group_init().
+struct p2p_group_config {
+	 * persistent_group - Whether the group is persistent
+	 * 0 = not a persistent group
+	 * interface_addr - P2P Interface Address of the group
+	u8 interface_addr[ETH_ALEN];
+	 * max_clients - Maximum number of clients in the group
+	unsigned int max_clients;
+	 * ssid - Group SSID
+	size_t ssid_len;
+	 * freq - Operating channel of the group
+	int freq;
+	void *cb_ctx;
+	 * ie_update - Notification of IE update
+	 * @beacon_ies: P2P IE for Beacon frames or %NULL if no change
+	 * @proberesp_ies: P2P Ie for Probe Response frames
+	 * P2P module uses this callback function to notify whenever the P2P IE
+	 * in Beacon or Probe Response frames should be updated based on group
+	 * events.
+	 * The callee is responsible for freeing the returned buffer(s) with
+	 * wpabuf_free().
+	void (*ie_update)(void *ctx, struct wpabuf *beacon_ies,
+			  struct wpabuf *proberesp_ies);
+	 * idle_update - Notification of changes in group idle state
+	 * @idle: Whether the group is idle (no associated stations)
+	void (*idle_update)(void *ctx, int idle);
+ * p2p_group_init - Initialize P2P group
+ * @config: P2P group configuration (will be freed by p2p_group_deinit())
+ * This function is used to initialize per-group P2P module context. Currently,
+ * this is only used to manage GO functionality and P2P clients do not need to
+ * create an instance of this per-group information.
+struct p2p_group * p2p_group_init(struct p2p_data *p2p,
+				  struct p2p_group_config *config);
+ * p2p_group_deinit - Deinitialize P2P group
+ * @group: P2P group context from p2p_group_init()
+void p2p_group_deinit(struct p2p_group *group);
+ * p2p_group_notif_assoc - Notification of P2P client association with GO
+ * @addr: Interface address of the P2P client
+ * @ie: IEs from the (Re)association Request frame
+ * @len: Length of the ie buffer in octets
+int p2p_group_notif_assoc(struct p2p_group *group, const u8 *addr,
+			  const u8 *ie, size_t len);
+ * p2p_group_assoc_resp_ie - Build P2P IE for (re)association response
+ * @status: Status value (P2P_SC_SUCCESS if association succeeded)
+ * Returns: P2P IE for (Re)association Response or %NULL on failure
+ * The caller is responsible for freeing the returned buffer with
+ * wpabuf_free().
+struct wpabuf * p2p_group_assoc_resp_ie(struct p2p_group *group, u8 status);
+ * p2p_group_notif_disassoc - Notification of P2P client disassociation from GO
+void p2p_group_notif_disassoc(struct p2p_group *group, const u8 *addr);
+ * p2p_group_notif_formation_done - Notification of completed group formation
+void p2p_group_notif_formation_done(struct p2p_group *group);
+ * p2p_group_notif_noa - Notification of NoA change
+ * @noa: Notice of Absence attribute payload, %NULL if none
+ * @noa_len: Length of noa buffer in octets
+ * Notify the P2P group management about a new NoA contents. This will be
+ * inserted into the P2P IEs in Beacon and Probe Response frames with rest of
+ * the group information.
+int p2p_group_notif_noa(struct p2p_group *group, const u8 *noa,
+			size_t noa_len);
+ * p2p_group_match_dev_type - Match device types in group with requested type
+ * @wps: WPS TLVs from Probe Request frame (concatenated WPS IEs)
+ * Returns: 1 on match, 0 on mismatch
+ * This function can be used to match the Requested Device Type attribute in
+ * WPS IE with the device types of a group member for deciding whether a GO
+ * should reply to a Probe Request frame. Match will be reported if the WPS IE
+ * is not requested any specific device type.
+int p2p_group_match_dev_type(struct p2p_group *group, struct wpabuf *wps);
+ * p2p_group_match_dev_id - Match P2P Device Address in group with requested device id
+int p2p_group_match_dev_id(struct p2p_group *group, struct wpabuf *p2p);
+ * p2p_group_go_discover - Send GO Discoverability Request to a group client
+ * Returns: 0 on success (frame scheduled); -1 if client was not found
+int p2p_group_go_discover(struct p2p_group *group, const u8 *dev_id,
+			  const u8 *searching_dev, int rx_freq);
+/* Generic helper functions */
+ * p2p_ie_text - Build text format description of P2P IE
+ * @p2p_ie: P2P IE
+ * @buf: Buffer for returning text
+ * @end: Pointer to the end of the buf area
+ * Returns: Number of octets written to the buffer or -1 on failure
+ * This function can be used to parse P2P IE contents into text format
+ * field=value lines.
+int p2p_ie_text(struct wpabuf *p2p_ie, char *buf, char *end);
+ * p2p_scan_result_text - Build text format description of P2P IE
+ * @ies: Information elements from scan results
+ * @ies_len: ies buffer length in octets
+int p2p_scan_result_text(const u8 *ies, size_t ies_len, char *buf, char *end);
+ * p2p_parse_dev_addr_in_p2p_ie - Parse P2P Device Address from a concatenated
+ * P2P IE
+ * @p2p_ie: P2P IE
+ * @dev_addr: Buffer for returning P2P Device Address
+ * Returns: 0 on success or -1 if P2P Device Address could not be parsed
+int p2p_parse_dev_addr_in_p2p_ie(struct wpabuf *p2p_ie, u8 *dev_addr);
+ * p2p_parse_dev_addr - Parse P2P Device Address from P2P IE(s)
+int p2p_parse_dev_addr(const u8 *ies, size_t ies_len, u8 *dev_addr);
+ * p2p_assoc_req_ie - Build P2P IE for (Re)Association Request frame
+ * @bssid: BSSID
+ * @buf: Buffer for writing the P2P IE
+ * @len: Maximum buf length in octets
+ * @p2p_group: Whether this is for association with a P2P GO
+ * @p2p_ie: Reassembled P2P IE data from scan results or %NULL if none
+ * Returns: Number of octets written into buf or -1 on failure
+int p2p_assoc_req_ie(struct p2p_data *p2p, const u8 *bssid, u8 *buf,
+		     size_t len, int p2p_group, struct wpabuf *p2p_ie);
+ * p2p_scan_ie - Build P2P IE for Probe Request
+ * @ies: Buffer for writing P2P IE
+ * @dev_id: Device ID to search for or %NULL for any
+void p2p_scan_ie(struct p2p_data *p2p, struct wpabuf *ies, const u8 *dev_id);
+ * p2p_scan_ie_buf_len - Get maximum buffer length needed for p2p_scan_ie
+ * Returns: Number of octets that p2p_scan_ie() may add to the buffer
+size_t p2p_scan_ie_buf_len(struct p2p_data *p2p);
+ * p2p_go_params - Generate random P2P group parameters
+ * @params: Buffer for parameters
+int p2p_go_params(struct p2p_data *p2p, struct p2p_go_neg_results *params);
+ * p2p_get_group_capab - Get Group Capability from P2P IE data
+ * @p2p_ie: P2P IE(s) contents
+ * Returns: Group Capability
+u8 p2p_get_group_capab(const struct wpabuf *p2p_ie);
+ * p2p_get_cross_connect_disallowed - Does WLAN AP disallows cross connection
+ * Returns: 0 if cross connection is allow, 1 if not
+int p2p_get_cross_connect_disallowed(const struct wpabuf *p2p_ie);
+ * p2p_get_go_dev_addr - Get P2P Device Address from P2P IE data
+ * Returns: Pointer to P2P Device Address or %NULL if not included
+const u8 * p2p_get_go_dev_addr(const struct wpabuf *p2p_ie);
+ * p2p_get_peer_info - Get P2P peer information
+ * @addr: P2P Device Address of the peer or %NULL to indicate the first peer
+ * @next: Whether to select the peer entry following the one indicated by addr
+ * Returns: Pointer to peer info or %NULL if not found
+const struct p2p_peer_info * p2p_get_peer_info(struct p2p_data *p2p,
+					       const u8 *addr, int next);
+ * p2p_get_peer_info_txt - Get internal P2P peer information in text format
+ * @info: Pointer to P2P peer info from p2p_get_peer_info()
+ * @buflen: Maximum buffer length
+ * Note: This information is internal to the P2P module and subject to change.
+ * As such, this should not really be used by external programs for purposes
+ * other than debugging.
+int p2p_get_peer_info_txt(const struct p2p_peer_info *info,
+			  char *buf, size_t buflen);
+ * p2p_peer_known - Check whether P2P peer is known
+ * Returns: 1 if the specified device is in the P2P peer table or 0 if not
+int p2p_peer_known(struct p2p_data *p2p, const u8 *addr);
+ * p2p_set_client_discoverability - Set client discoverability capability
+ * @enabled: Whether client discoverability will be enabled
+ * This function can be used to disable (and re-enable) client discoverability.
+ * This capability is enabled by default and should not be disabled in normal
+ * use cases, i.e., this is mainly for testing purposes.
+void p2p_set_client_discoverability(struct p2p_data *p2p, int enabled);
+ * p2p_set_managed_oper - Set managed P2P Device operations capability
+ * @enabled: Whether managed P2P Device operations will be enabled
+void p2p_set_managed_oper(struct p2p_data *p2p, int enabled);
+ * p2p_config_get_random_social - Return a random social channel
+ * @p2p: P2P config
+ * @op_class: Selected operating class
+ * @op_channel: Selected social channel
+ * This function is used before p2p_init is called. A random social channel
+ * from supports bands 2.4 GHz (channels 1,6,11) and 60 GHz (channel 2) is
+ * returned on success.
+int p2p_config_get_random_social(struct p2p_config *p2p, u8 *op_class,
+				 u8 *op_channel);
+int p2p_set_listen_channel(struct p2p_data *p2p, u8 reg_class, u8 channel,
+			   u8 forced);
+u8 p2p_get_listen_channel(struct p2p_data *p2p);
+int p2p_set_ssid_postfix(struct p2p_data *p2p, const u8 *postfix, size_t len);
+int p2p_get_interface_addr(struct p2p_data *p2p, const u8 *dev_addr,
+			   u8 *iface_addr);
+int p2p_get_dev_addr(struct p2p_data *p2p, const u8 *iface_addr,
+			   u8 *dev_addr);
+void p2p_set_peer_filter(struct p2p_data *p2p, const u8 *addr);
+ * p2p_set_cross_connect - Set cross connection capability
+ * @enabled: Whether cross connection will be enabled
+void p2p_set_cross_connect(struct p2p_data *p2p, int enabled);
+int p2p_get_oper_freq(struct p2p_data *p2p, const u8 *iface_addr);
+ * p2p_set_intra_bss_dist - Set intra BSS distribution
+ * @enabled: Whether intra BSS distribution will be enabled
+void p2p_set_intra_bss_dist(struct p2p_data *p2p, int enabled);
+int p2p_channels_includes_freq(const struct p2p_channels *channels,
+int p2p_channels_to_freqs(const struct p2p_channels *channels,
+			  int *freq_list, unsigned int max_len);
+ * p2p_supported_freq - Check whether channel is supported for P2P
+ * Returns: 0 if channel not usable for P2P, 1 if usable for P2P
+int p2p_supported_freq(struct p2p_data *p2p, unsigned int freq);
+ * p2p_supported_freq_go - Check whether channel is supported for P2P GO operation
+int p2p_supported_freq_go(struct p2p_data *p2p, unsigned int freq);
+ * p2p_supported_freq_cli - Check whether channel is supported for P2P client operation
+int p2p_supported_freq_cli(struct p2p_data *p2p, unsigned int freq);
+ * p2p_get_pref_freq - Get channel from preferred channel list
+ * @channels: List of channels
+ * Returns: Preferred channel
+unsigned int p2p_get_pref_freq(struct p2p_data *p2p,
+			       const struct p2p_channels *channels);
+void p2p_update_channel_list(struct p2p_data *p2p,
+			     const struct p2p_channels *chan,
+			     const struct p2p_channels *cli_chan);
+ * p2p_set_best_channels - Update best channel information
+ * @freq_24: Frequency (MHz) of best channel in 2.4 GHz band
+ * @freq_5: Frequency (MHz) of best channel in 5 GHz band
+ * @freq_overall: Frequency (MHz) of best channel overall
+void p2p_set_best_channels(struct p2p_data *p2p, int freq_24, int freq_5,
+			   int freq_overall);
+ * p2p_set_own_freq_preference - Set own preference for channel
+ * @freq: Frequency (MHz) of the preferred channel or 0 if no preference
+ * This function can be used to set a preference on the operating channel based
+ * on frequencies used on the other virtual interfaces that share the same
+ * radio. If non-zero, this is used to try to avoid multi-channel concurrency.
+void p2p_set_own_freq_preference(struct p2p_data *p2p, int freq);
+const u8 * p2p_get_go_neg_peer(struct p2p_data *p2p);
+ * p2p_get_group_num_members - Get number of members in group
+ * Returns: Number of members in the group
+unsigned int p2p_get_group_num_members(struct p2p_group *group);
+ * p2p_client_limit_reached - Check if client limit is reached
+ * Returns: 1 if no of clients limit reached
+int p2p_client_limit_reached(struct p2p_group *group);
+ * p2p_iterate_group_members - Iterate group members
+ * @next: iteration pointer, must be a pointer to a void * that is set to %NULL
+ *	on the first call and not modified later
+ * Returns: A P2P Device Address for each call and %NULL for no more members
+const u8 * p2p_iterate_group_members(struct p2p_group *group, void **next);
+ * p2p_group_get_dev_addr - Get a P2P Device Address of a client in a group
+ * @addr: P2P Interface Address of the client
+ * Returns: P2P Device Address of the client if found or %NULL if no match
+ * found
+const u8 * p2p_group_get_dev_addr(struct p2p_group *group, const u8 *addr);
+ * p2p_group_is_client_connected - Check whether a specific client is connected
+ * @addr: P2P Device Address of the client
+ * Returns: 1 if client is connected or 0 if not
+int p2p_group_is_client_connected(struct p2p_group *group, const u8 *dev_addr);
+ * p2p_group_get_config - Get the group configuration
+ * Returns: The group configuration pointer
+const struct p2p_group_config * p2p_group_get_config(struct p2p_group *group);
+ * p2p_loop_on_all_groups - Run the given callback on all groups
+ * @group_callback: The callback function pointer
+ * @user_data: Some user data pointer which can be %NULL
+ * The group_callback function can stop the iteration by returning 0.
+void p2p_loop_on_all_groups(struct p2p_data *p2p,
+			    int (*group_callback)(struct p2p_group *group,
+						  void *user_data),
+			    void *user_data);
+ * p2p_get_peer_found - Get P2P peer info structure of a found peer
+ * Returns: The first P2P peer info available or %NULL if no such peer exists
+p2p_get_peer_found(struct p2p_data *p2p, const u8 *addr, int next);
+ * p2p_remove_wps_vendor_extensions - Remove WPS vendor extensions
+void p2p_remove_wps_vendor_extensions(struct p2p_data *p2p);
+ * p2p_add_wps_vendor_extension - Add a WPS vendor extension
+ * @vendor_ext: The vendor extensions to add
+ * The wpabuf structures in the array are owned by the P2P
+ * module after this call.
+int p2p_add_wps_vendor_extension(struct p2p_data *p2p,
+				 const struct wpabuf *vendor_ext);
+ * p2p_set_oper_channel - Set the P2P operating channel
+ * @op_reg_class: Operating regulatory class to set
+ * @op_channel: operating channel to set
+ * @cfg_op_channel : Whether op_channel is hardcoded in configuration
+int p2p_set_oper_channel(struct p2p_data *p2p, u8 op_reg_class, u8 op_channel,
+			 int cfg_op_channel);
+ * p2p_set_pref_chan - Set P2P preferred channel list
+ * @num_pref_chan: Number of entries in pref_chan list
+ * @pref_chan: Preferred channels or %NULL to remove preferences
+int p2p_set_pref_chan(struct p2p_data *p2p, unsigned int num_pref_chan,
+		      const struct p2p_channel *pref_chan);
+ * p2p_set_no_go_freq - Set no GO channel ranges
+ * @list: Channel ranges or %NULL to remove restriction
+int p2p_set_no_go_freq(struct p2p_data *p2p,
+		       const struct wpa_freq_range_list *list);
+ * p2p_in_progress - Check whether a P2P operation is progress
+ * Returns: 0 if P2P module is idle, 1 if an operation is in progress but not
+ * in search state, or 2 if search state operation is in progress
+int p2p_in_progress(struct p2p_data *p2p);
+const char * p2p_wps_method_text(enum p2p_wps_method method);
+ * p2p_set_config_timeout - Set local config timeouts
+ * @go_timeout: Time in 10 ms units it takes to start the GO mode
+ * @client_timeout: Time in 10 ms units it takes to start the client mode
+void p2p_set_config_timeout(struct p2p_data *p2p, u8 go_timeout,
+			    u8 client_timeout);
+int p2p_set_wfd_ie_beacon(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_probe_req(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_probe_resp(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_assoc_req(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_invitation(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_prov_disc_req(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_prov_disc_resp(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_ie_go_neg(struct p2p_data *p2p, struct wpabuf *ie);
+int p2p_set_wfd_dev_info(struct p2p_data *p2p, const struct wpabuf *elem);
+int p2p_set_wfd_assoc_bssid(struct p2p_data *p2p, const struct wpabuf *elem);
+int p2p_set_wfd_coupled_sink_info(struct p2p_data *p2p,
+				  const struct wpabuf *elem);
+struct wpabuf * wifi_display_encaps(struct wpabuf *subelems);
+ * p2p_set_disc_int - Set min/max discoverable interval for p2p_find
+ * @min_disc_int: minDiscoverableInterval (in units of 100 TU); default 1
+ * @max_disc_int: maxDiscoverableInterval (in units of 100 TU); default 3
+ * @max_disc_tu: Maximum number of TUs (1.024 ms) for discoverable interval; or
+ *	-1 not to limit
+ * Returns: 0 on success, or -1 on failure
+ * This function can be used to configure minDiscoverableInterval and
+ * maxDiscoverableInterval parameters for the Listen state during device
+ * discovery (p2p_find). A random number of 100 TU units is picked for each
+ * Listen state iteration from [min_disc_int,max_disc_int] range.
+ * max_disc_tu can be used to futher limit the discoverable duration. However,
+ * it should be noted that use of this parameter is not recommended since it
+ * would not be compliant with the P2P specification.
+int p2p_set_disc_int(struct p2p_data *p2p, int min_disc_int, int max_disc_int,
+		     int max_disc_tu);
+ * p2p_get_state_txt - Get current P2P state for debug purposes
+ * Returns: Name of the current P2P module state
+ * It should be noted that the P2P module state names are internal information
+ * and subject to change at any point, i.e., this information should be used
+ * mainly for debugging purposes.
+const char * p2p_get_state_txt(struct p2p_data *p2p);
+struct wpabuf * p2p_build_nfc_handover_req(struct p2p_data *p2p,
+					   int client_freq,
+struct wpabuf * p2p_build_nfc_handover_sel(struct p2p_data *p2p,
+					   int client_freq,
+struct p2p_nfc_params {
+	int sel;
+	const u8 *wsc_attr;
+	size_t wsc_len;
+	const u8 *p2p_attr;
+	size_t p2p_len;
+	enum {
+		NO_ACTION, JOIN_GROUP, AUTH_JOIN, INIT_GO_NEG, RESP_GO_NEG,
+		BOTH_GO, PEER_CLIENT
+	} next_step;
+	struct p2p_peer_info *peer;
+	u8 oob_dev_pw[WPS_OOB_PUBKEY_HASH_LEN + 2 +
+		      WPS_OOB_DEVICE_PASSWORD_LEN];
+	size_t oob_dev_pw_len;
+	int go_freq;
+	u8 go_dev_addr[ETH_ALEN];
+	u8 go_ssid[SSID_MAX_LEN];
+	size_t go_ssid_len;
+int p2p_process_nfc_connection_handover(struct p2p_data *p2p,
+					struct p2p_nfc_params *params);
+void p2p_set_authorized_oob_dev_pw_id(struct p2p_data *p2p, u16 dev_pw_id,
+				      int go_intent,
+				      const u8 *own_interface_addr);
+int p2p_set_passphrase_len(struct p2p_data *p2p, unsigned int len);
+void p2p_loop_on_known_peers(struct p2p_data *p2p,
+			     void (*peer_callback)(struct p2p_peer_info *peer,
+						   void *user_data),
+			     void *user_data);
+void p2p_set_vendor_elems(struct p2p_data *p2p, struct wpabuf **vendor_elem);
+void p2p_set_intended_addr(struct p2p_data *p2p, const u8 *intended_addr);
+struct p2ps_advertisement *
+p2p_service_p2ps_id(struct p2p_data *p2p, u32 adv_id);
+int p2p_service_add_asp(struct p2p_data *p2p, int auto_accept, u32 adv_id,
+			const char *adv_str, u8 svc_state,
+			u16 config_methods, const char *svc_info,
+			const u8 *cpt_priority);
+int p2p_service_del_asp(struct p2p_data *p2p, u32 adv_id);
+void p2p_service_flush_asp(struct p2p_data *p2p);
+struct p2ps_advertisement * p2p_get_p2ps_adv_list(struct p2p_data *p2p);
+ * p2p_expire_peers - Periodic cleanup function to expire peers
+ * This is a cleanup function that the entity calling p2p_init() is
+ * expected to call periodically to clean up expired peer entries.
+void p2p_expire_peers(struct p2p_data *p2p);
+void p2p_set_own_pref_freq_list(struct p2p_data *p2p,
+				const unsigned int *pref_freq_list,
+				unsigned int size);
+ * p2p_group_get_common_freqs - Get the group common frequencies
+ * @common_freqs: On return will hold the group common frequencies
+ * @num: On return will hold the number of group common frequencies
+ * Returns: 0 on success, -1 otherwise
+int p2p_group_get_common_freqs(struct p2p_group *group, int *common_freqs,
+			       unsigned int *num);
+#endif /* P2P_H */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/peerkey.c b/freebsd/contrib/wpa/src/rsn_supp/peerkey.c
new file mode 100644
index 00000000000..87263f8675b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/peerkey.c
@@ -0,0 +1,1157 @@
+#include <machine/rtems-bsd-user-space.h>
+ * WPA Supplicant - PeerKey for Direct Link Setup (DLS)
+ * Copyright (c) 2006-2015, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "includes.h"
+#ifdef CONFIG_PEERKEY
+#include "common.h"
+#include "eloop.h"
+#include "crypto/sha1.h"
+#include "crypto/sha256.h"
+#include "crypto/random.h"
+#include "common/ieee802_11_defs.h"
+#include "wpa.h"
+#include "wpa_i.h"
+#include "wpa_ie.h"
+#include "peerkey.h"
+static u8 * wpa_add_ie(u8 *pos, const u8 *ie, size_t ie_len)
+	os_memcpy(pos, ie, ie_len);
+	return pos + ie_len;
+static u8 * wpa_add_kde(u8 *pos, u32 kde, const u8 *data, size_t data_len)
+	*pos++ = WLAN_EID_VENDOR_SPECIFIC;
+	*pos++ = RSN_SELECTOR_LEN + data_len;
+	RSN_SELECTOR_PUT(pos, kde);
+	pos += RSN_SELECTOR_LEN;
+	os_memcpy(pos, data, data_len);
+	pos += data_len;
+	return pos;
+static void wpa_supplicant_smk_timeout(void *eloop_ctx, void *timeout_ctx)
+#if 0
+	struct wpa_sm *sm = eloop_ctx;
+	struct wpa_peerkey *peerkey = timeout_ctx;
+#endif
+	/* TODO: time out SMK and any STK that was generated using this SMK */
+static void wpa_supplicant_peerkey_free(struct wpa_sm *sm,
+					struct wpa_peerkey *peerkey)
+	eloop_cancel_timeout(wpa_supplicant_smk_timeout, sm, peerkey);
+	os_free(peerkey);
+static int wpa_supplicant_send_smk_error(struct wpa_sm *sm, const u8 *dst,
+					 const u8 *peer,
+					 u16 mui, u16 error_type, int ver)
+	size_t rlen;
+	struct wpa_eapol_key *err;
+	struct wpa_eapol_key_192 *err192;
+	struct rsn_error_kde error;
+	u8 *rbuf, *pos;
+	size_t kde_len;
+	u16 key_info;
+	kde_len = 2 + RSN_SELECTOR_LEN + sizeof(error);
+	if (peer)
+		kde_len += 2 + RSN_SELECTOR_LEN + ETH_ALEN;
+	rbuf = wpa_sm_alloc_eapol(sm, IEEE802_1X_TYPE_EAPOL_KEY,
+				  NULL, sizeof(*err) + kde_len, &rlen,
+				  (void *) &err);
+	if (rbuf == NULL)
+		return -1;
+	err192 = (struct wpa_eapol_key_192 *) err;
+	err->type = EAPOL_KEY_TYPE_RSN;
+	key_info = ver | WPA_KEY_INFO_SMK_MESSAGE | WPA_KEY_INFO_MIC |
+		WPA_KEY_INFO_SECURE | WPA_KEY_INFO_ERROR |
+		WPA_KEY_INFO_REQUEST;
+	WPA_PUT_BE16(err->key_info, key_info);
+	WPA_PUT_BE16(err->key_length, 0);
+	os_memcpy(err->replay_counter, sm->request_counter,
+		  WPA_REPLAY_COUNTER_LEN);
+	inc_byte_array(sm->request_counter, WPA_REPLAY_COUNTER_LEN);
+	WPA_PUT_BE16(err->key_data_length, (u16) kde_len);
+	pos = (u8 *) (err + 1);
+	if (peer) {
+		/* Peer MAC Address KDE */
+		pos = wpa_add_kde(pos, RSN_KEY_DATA_MAC_ADDR, peer, ETH_ALEN);
+	/* Error KDE */
+	error.mui = host_to_be16(mui);
+	error.error_type = host_to_be16(error_type);
+	wpa_add_kde(pos, RSN_KEY_DATA_ERROR, (u8 *) &error, sizeof(error));
+	if (peer) {
+		wpa_printf(MSG_DEBUG, "RSN: Sending EAPOL-Key SMK Error (peer "
+			   MACSTR " mui %d error_type %d)",
+			   MAC2STR(peer), mui, error_type);
+	} else {
+		wpa_printf(MSG_DEBUG, "RSN: Sending EAPOL-Key SMK Error "
+			   "(mui %d error_type %d)", mui, error_type);
+	wpa_eapol_key_send(sm, sm->ptk.kck, sm->ptk.kck_len, ver, dst,
+			   ETH_P_EAPOL, rbuf, rlen, err192->key_mic);
+	return 0;
+static int wpa_supplicant_send_smk_m3(struct wpa_sm *sm,
+				      const unsigned char *src_addr,
+				      const struct wpa_eapol_key *key,
+				      int ver, struct wpa_peerkey *peerkey)
+	size_t rlen;
+	struct wpa_eapol_key *reply;
+	struct wpa_eapol_key_192 *reply192;
+	u8 *rbuf, *pos;
+	size_t kde_len;
+	u16 key_info;
+	/* KDEs: Peer RSN IE, Initiator MAC Address, Initiator Nonce */
+	kde_len = peerkey->rsnie_p_len +
+		2 + RSN_SELECTOR_LEN + ETH_ALEN +
+		2 + RSN_SELECTOR_LEN + WPA_NONCE_LEN;
+				  NULL, sizeof(*reply) + kde_len, &rlen,
+				  (void *) &reply);
+	if (rbuf == NULL)
+		return -1;
+	reply192 = (struct wpa_eapol_key_192 *) reply;
+	reply->type = EAPOL_KEY_TYPE_RSN;
+		WPA_KEY_INFO_SECURE;
+	WPA_PUT_BE16(reply->key_info, key_info);
+	WPA_PUT_BE16(reply->key_length, 0);
+	os_memcpy(reply->replay_counter, key->replay_counter,
+	os_memcpy(reply->key_nonce, peerkey->pnonce, WPA_NONCE_LEN);
+	WPA_PUT_BE16(reply->key_data_length, (u16) kde_len);
+	pos = (u8 *) (reply + 1);
+	/* Peer RSN IE */
+	pos = wpa_add_ie(pos, peerkey->rsnie_p, peerkey->rsnie_p_len);
+	/* Initiator MAC Address KDE */
+	pos = wpa_add_kde(pos, RSN_KEY_DATA_MAC_ADDR, peerkey->addr, ETH_ALEN);
+	/* Initiator Nonce */
+	wpa_add_kde(pos, RSN_KEY_DATA_NONCE, peerkey->inonce, WPA_NONCE_LEN);
+	wpa_printf(MSG_DEBUG, "RSN: Sending EAPOL-Key SMK M3");
+	wpa_eapol_key_send(sm, sm->ptk.kck, sm->ptk.kck_len, ver, src_addr,
+			   ETH_P_EAPOL, rbuf, rlen, reply192->key_mic);
+	return 0;
+static int wpa_supplicant_process_smk_m2(
+	struct wpa_sm *sm, const unsigned char *src_addr,
+	const struct wpa_eapol_key *key, size_t extra_len, int ver)
+	struct wpa_peerkey *peerkey;
+	struct wpa_eapol_ie_parse kde;
+	struct wpa_ie_data ie;
+	int cipher;
+	struct rsn_ie_hdr *hdr;
+	u8 *pos;
+	wpa_printf(MSG_DEBUG, "RSN: Received SMK M2");
+	if (!sm->peerkey_enabled || sm->proto != WPA_PROTO_RSN) {
+		wpa_printf(MSG_INFO, "RSN: SMK handshake not allowed for "
+			   "the current network");
+		return -1;
+	if (wpa_supplicant_parse_ies((const u8 *) (key + 1), extra_len, &kde) <
+	    0) {
+		wpa_printf(MSG_INFO, "RSN: Failed to parse KDEs in SMK M2");
+		return -1;
+	if (kde.rsn_ie == NULL || kde.mac_addr == NULL ||
+	    kde.mac_addr_len < ETH_ALEN) {
+		wpa_printf(MSG_INFO, "RSN: No RSN IE or MAC address KDE in "
+			   "SMK M2");
+		return -1;
+	wpa_printf(MSG_DEBUG, "RSN: SMK M2 - SMK initiator " MACSTR,
+		   MAC2STR(kde.mac_addr));
+	if (kde.rsn_ie_len > PEERKEY_MAX_IE_LEN) {
+		wpa_printf(MSG_INFO, "RSN: Too long Initiator RSN IE in SMK "
+			   "M2");
+		return -1;
+	if (wpa_parse_wpa_ie_rsn(kde.rsn_ie, kde.rsn_ie_len, &ie) < 0) {
+		wpa_printf(MSG_INFO, "RSN: Failed to parse RSN IE in SMK M2");
+		return -1;
+	cipher = wpa_pick_pairwise_cipher(ie.pairwise_cipher &
+					  sm->allowed_pairwise_cipher, 0);
+	if (cipher < 0) {
+		wpa_printf(MSG_INFO, "RSN: No acceptable cipher in SMK M2");
+		wpa_supplicant_send_smk_error(sm, src_addr, kde.mac_addr,
+					      STK_MUI_SMK, STK_ERR_CPHR_NS,
+					      ver);
+		return -1;
+	wpa_printf(MSG_DEBUG, "RSN: Using %s for PeerKey",
+		   wpa_cipher_txt(cipher));
+	/* TODO: find existing entry and if found, use that instead of adding
+	 * a new one; how to handle the case where both ends initiate at the
+	 * same time? */
+	peerkey = os_zalloc(sizeof(*peerkey));
+	if (peerkey == NULL)
+		return -1;
+	os_memcpy(peerkey->addr, kde.mac_addr, ETH_ALEN);
+	os_memcpy(peerkey->inonce, key->key_nonce, WPA_NONCE_LEN);
+	os_memcpy(peerkey->rsnie_i, kde.rsn_ie, kde.rsn_ie_len);
+	peerkey->rsnie_i_len = kde.rsn_ie_len;
+	peerkey->cipher = cipher;
+	peerkey->akmp = ie.key_mgmt;
+	if (random_get_bytes(peerkey->pnonce, WPA_NONCE_LEN)) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_WARNING,
+			"WPA: Failed to get random data for PNonce");
+		wpa_supplicant_peerkey_free(sm, peerkey);
+		return -1;
+	hdr = (struct rsn_ie_hdr *) peerkey->rsnie_p;
+	hdr->elem_id = WLAN_EID_RSN;
+	WPA_PUT_LE16(hdr->version, RSN_VERSION);
+	pos = (u8 *) (hdr + 1);
+	/* Group Suite can be anything for SMK RSN IE; receiver will just
+	 * ignore it. */
+	RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_CCMP);
+	/* Include only the selected cipher in pairwise cipher suite */
+	WPA_PUT_LE16(pos, 1);
+	pos += 2;
+	RSN_SELECTOR_PUT(pos, wpa_cipher_to_suite(WPA_PROTO_RSN, cipher));
+	hdr->len = (pos - peerkey->rsnie_p) - 2;
+	peerkey->rsnie_p_len = pos - peerkey->rsnie_p;
+	wpa_hexdump(MSG_DEBUG, "WPA: RSN IE for SMK handshake",
+		    peerkey->rsnie_p, peerkey->rsnie_p_len);
+	wpa_supplicant_send_smk_m3(sm, src_addr, key, ver, peerkey);
+	peerkey->next = sm->peerkey;
+	sm->peerkey = peerkey;
+	return 0;
+ * rsn_smkid - Derive SMK identifier
+ * @smk: Station master key (32 bytes)
+ * @pnonce: Peer Nonce
+ * @mac_p: Peer MAC address
+ * @inonce: Initiator Nonce
+ * @mac_i: Initiator MAC address
+ * @akmp: Negotiated AKM
+ * 8.5.1.4 Station to station (STK) key hierarchy
+ * SMKID = HMAC-SHA1-128(SMK, "SMK Name" || PNonce || MAC_P || INonce || MAC_I)
+static void rsn_smkid(const u8 *smk, const u8 *pnonce, const u8 *mac_p,
+		      const u8 *inonce, const u8 *mac_i, u8 *smkid,
+		      int akmp)
+	char *title = "SMK Name";
+	const u8 *addr[5];
+	const size_t len[5] = { 8, WPA_NONCE_LEN, ETH_ALEN, WPA_NONCE_LEN,
+				ETH_ALEN };
+	unsigned char hash[SHA256_MAC_LEN];
+	addr[0] = (u8 *) title;
+	addr[1] = pnonce;
+	addr[2] = mac_p;
+	addr[3] = inonce;
+	addr[4] = mac_i;
+#ifdef CONFIG_IEEE80211W
+	if (wpa_key_mgmt_sha256(akmp))
+		hmac_sha256_vector(smk, PMK_LEN, 5, addr, len, hash);
+	else
+#endif /* CONFIG_IEEE80211W */
+		hmac_sha1_vector(smk, PMK_LEN, 5, addr, len, hash);
+	os_memcpy(smkid, hash, PMKID_LEN);
+static void wpa_supplicant_send_stk_1_of_4(struct wpa_sm *sm,
+	size_t mlen;
+	struct wpa_eapol_key *msg;
+	u8 *mbuf;
+	size_t kde_len;
+	u16 key_info, ver;
+	kde_len = 2 + RSN_SELECTOR_LEN + PMKID_LEN;
+	mbuf = wpa_sm_alloc_eapol(sm, IEEE802_1X_TYPE_EAPOL_KEY, NULL,
+				  sizeof(*msg) + kde_len, &mlen,
+				  (void *) &msg);
+	if (mbuf == NULL)
+		return;
+	msg->type = EAPOL_KEY_TYPE_RSN;
+	if (peerkey->cipher != WPA_CIPHER_TKIP)
+		ver = WPA_KEY_INFO_TYPE_HMAC_SHA1_AES;
+	else
+		ver = WPA_KEY_INFO_TYPE_HMAC_MD5_RC4;
+	key_info = ver | WPA_KEY_INFO_KEY_TYPE | WPA_KEY_INFO_ACK;
+	WPA_PUT_BE16(msg->key_info, key_info);
+		WPA_PUT_BE16(msg->key_length, 16);
+	else
+		WPA_PUT_BE16(msg->key_length, 32);
+	os_memcpy(msg->replay_counter, peerkey->replay_counter,
+	inc_byte_array(peerkey->replay_counter, WPA_REPLAY_COUNTER_LEN);
+	WPA_PUT_BE16(msg->key_data_length, kde_len);
+	wpa_add_kde((u8 *) (msg + 1), RSN_KEY_DATA_PMKID,
+		    peerkey->smkid, PMKID_LEN);
+	if (random_get_bytes(peerkey->inonce, WPA_NONCE_LEN)) {
+			"RSN: Failed to get random data for INonce (STK)");
+		os_free(mbuf);
+		return;
+	wpa_hexdump(MSG_DEBUG, "RSN: INonce for STK 4-Way Handshake",
+		    peerkey->inonce, WPA_NONCE_LEN);
+	os_memcpy(msg->key_nonce, peerkey->inonce, WPA_NONCE_LEN);
+	wpa_printf(MSG_DEBUG, "RSN: Sending EAPOL-Key STK 1/4 to " MACSTR,
+		   MAC2STR(peerkey->addr));
+	wpa_eapol_key_send(sm, NULL, 0, ver, peerkey->addr, ETH_P_EAPOL,
+			   mbuf, mlen, NULL);
+static void wpa_supplicant_send_stk_3_of_4(struct wpa_sm *sm,
+	size_t mlen;
+	u8 *mbuf, *pos;
+	size_t kde_len;
+	be32 lifetime;
+	kde_len = peerkey->rsnie_i_len +
+		2 + RSN_SELECTOR_LEN + sizeof(lifetime);
+				  (void *) &msg);
+	if (mbuf == NULL)
+		return;
+	else
+	key_info = ver | WPA_KEY_INFO_KEY_TYPE | WPA_KEY_INFO_ACK |
+		WPA_KEY_INFO_MIC | WPA_KEY_INFO_SECURE;
+	else
+	pos = (u8 *) (msg + 1);
+	pos = wpa_add_ie(pos, peerkey->rsnie_i, peerkey->rsnie_i_len);
+	lifetime = host_to_be32(peerkey->lifetime);
+	wpa_add_kde(pos, RSN_KEY_DATA_LIFETIME,
+		    (u8 *) &lifetime, sizeof(lifetime));
+	wpa_printf(MSG_DEBUG, "RSN: Sending EAPOL-Key STK 3/4 to " MACSTR,
+	wpa_eapol_key_send(sm, peerkey->stk.kck, peerkey->stk.kck_len, ver,
+			   peerkey->addr, ETH_P_EAPOL, mbuf, mlen,
+			   msg->key_mic);
+static int wpa_supplicant_process_smk_m4(struct wpa_peerkey *peerkey,
+					 struct wpa_eapol_ie_parse *kde)
+	wpa_printf(MSG_DEBUG, "RSN: Received SMK M4 (Initiator " MACSTR ")",
+		   MAC2STR(kde->mac_addr));
+	if (os_memcmp(kde->smk + PMK_LEN, peerkey->pnonce, WPA_NONCE_LEN) != 0)
+		wpa_printf(MSG_INFO, "RSN: PNonce in SMK KDE does not "
+			   "match with the one used in SMK M3");
+		return -1;
+	if (os_memcmp(kde->nonce, peerkey->inonce, WPA_NONCE_LEN) != 0) {
+		wpa_printf(MSG_INFO, "RSN: INonce in SMK M4 did not "
+			   "match with the one received in SMK M2");
+		return -1;
+	return 0;
+static int wpa_supplicant_process_smk_m5(struct wpa_sm *sm,
+					 int ver,
+					 struct wpa_peerkey *peerkey,
+	int cipher;
+	wpa_printf(MSG_DEBUG, "RSN: Received SMK M5 (Peer " MACSTR ")",
+	if (kde->rsn_ie == NULL || kde->rsn_ie_len > PEERKEY_MAX_IE_LEN ||
+	    wpa_parse_wpa_ie_rsn(kde->rsn_ie, kde->rsn_ie_len, &ie) < 0) {
+		wpa_printf(MSG_INFO, "RSN: No RSN IE in SMK M5");
+		/* TODO: abort negotiation */
+		return -1;
+	if (os_memcmp(key->key_nonce, peerkey->inonce, WPA_NONCE_LEN) != 0) {
+		wpa_printf(MSG_INFO, "RSN: Key Nonce in SMK M5 does "
+			   "not match with INonce used in SMK M1");
+		return -1;
+	if (os_memcmp(kde->smk + PMK_LEN, peerkey->inonce, WPA_NONCE_LEN) != 0)
+		wpa_printf(MSG_INFO, "RSN: INonce in SMK KDE does not "
+			   "match with the one used in SMK M1");
+		return -1;
+	os_memcpy(peerkey->rsnie_p, kde->rsn_ie, kde->rsn_ie_len);
+	peerkey->rsnie_p_len = kde->rsn_ie_len;
+	os_memcpy(peerkey->pnonce, kde->nonce, WPA_NONCE_LEN);
+	if (cipher < 0) {
+		wpa_printf(MSG_INFO, "RSN: SMK Peer STA " MACSTR " selected "
+			   "unacceptable cipher", MAC2STR(kde->mac_addr));
+		wpa_supplicant_send_smk_error(sm, src_addr, kde->mac_addr,
+					      ver);
+		return -1;
+	return 0;
+static int wpa_supplicant_process_smk_m45(
+	u32 lifetime;
+		wpa_printf(MSG_DEBUG, "RSN: SMK handshake not allowed for "
+		return -1;
+	    0) {
+		wpa_printf(MSG_INFO, "RSN: Failed to parse KDEs in SMK M4/M5");
+		return -1;
+	if (kde.mac_addr == NULL || kde.mac_addr_len < ETH_ALEN ||
+	    kde.nonce == NULL || kde.nonce_len < WPA_NONCE_LEN ||
+	    kde.smk == NULL || kde.smk_len < PMK_LEN + WPA_NONCE_LEN ||
+	    kde.lifetime == NULL || kde.lifetime_len < 4) {
+		wpa_printf(MSG_INFO, "RSN: No MAC Address, Nonce, SMK, or "
+			   "Lifetime KDE in SMK M4/M5");
+		return -1;
+	for (peerkey = sm->peerkey; peerkey; peerkey = peerkey->next) {
+		if (os_memcmp(peerkey->addr, kde.mac_addr, ETH_ALEN) == 0 &&
+		    os_memcmp(peerkey->initiator ? peerkey->inonce :
+			   peerkey->pnonce,
+			   key->key_nonce, WPA_NONCE_LEN) == 0)
+			break;
+	if (peerkey == NULL) {
+		wpa_printf(MSG_INFO, "RSN: No matching SMK handshake found "
+			   "for SMK M4/M5: peer " MACSTR,
+		return -1;
+	if (peerkey->initiator) {
+		if (wpa_supplicant_process_smk_m5(sm, src_addr, key, ver,
+						  peerkey, &kde) < 0)
+			return -1;
+	} else {
+		if (wpa_supplicant_process_smk_m4(peerkey, &kde) < 0)
+			return -1;
+	os_memcpy(peerkey->smk, kde.smk, PMK_LEN);
+	peerkey->smk_complete = 1;
+	wpa_hexdump_key(MSG_DEBUG, "RSN: SMK", peerkey->smk, PMK_LEN);
+	lifetime = WPA_GET_BE32(kde.lifetime);
+	wpa_printf(MSG_DEBUG, "RSN: SMK lifetime %u seconds", lifetime);
+	if (lifetime > 1000000000)
+		lifetime = 1000000000; /* avoid overflowing eloop time */
+	peerkey->lifetime = lifetime;
+	eloop_register_timeout(lifetime, 0, wpa_supplicant_smk_timeout,
+			       sm, peerkey);
+		rsn_smkid(peerkey->smk, peerkey->pnonce, peerkey->addr,
+			  peerkey->inonce, sm->own_addr, peerkey->smkid,
+			  peerkey->akmp);
+		wpa_supplicant_send_stk_1_of_4(sm, peerkey);
+	} else {
+		rsn_smkid(peerkey->smk, peerkey->pnonce, sm->own_addr,
+			  peerkey->inonce, peerkey->addr, peerkey->smkid,
+			  peerkey->akmp);
+	wpa_hexdump(MSG_DEBUG, "RSN: SMKID", peerkey->smkid, PMKID_LEN);
+	return 0;
+static int wpa_supplicant_process_smk_error(
+	const struct wpa_eapol_key *key, size_t extra_len)
+	u8 peer[ETH_ALEN];
+	u16 error_type;
+	wpa_printf(MSG_DEBUG, "RSN: Received SMK Error");
+		return -1;
+	    0) {
+		wpa_printf(MSG_INFO, "RSN: Failed to parse KDEs in SMK Error");
+		return -1;
+	if (kde.error == NULL || kde.error_len < sizeof(error)) {
+		wpa_printf(MSG_INFO, "RSN: No Error KDE in SMK Error");
+		return -1;
+	if (kde.mac_addr && kde.mac_addr_len >= ETH_ALEN)
+		os_memcpy(peer, kde.mac_addr, ETH_ALEN);
+	else
+		os_memset(peer, 0, ETH_ALEN);
+	os_memcpy(&error, kde.error, sizeof(error));
+	error_type = be_to_host16(error.error_type);
+	wpa_msg(sm->ctx->msg_ctx, MSG_INFO,
+		"RSN: SMK Error KDE received: MUI %d error_type %d peer "
+		MACSTR,
+		be_to_host16(error.mui), error_type,
+		MAC2STR(peer));
+	    (error_type == STK_ERR_STA_NR || error_type == STK_ERR_STA_NRSN ||
+	     error_type == STK_ERR_CPHR_NS)) {
+			    0)
+				break;
+			wpa_printf(MSG_DEBUG, "RSN: No matching SMK handshake "
+				   "found for SMK Error");
+			return -1;
+		/* TODO: abort SMK/STK handshake and remove all related keys */
+	return 0;
+static void wpa_supplicant_process_stk_1_of_4(struct wpa_sm *sm,
+					      u16 ver, const u8 *key_data,
+					      size_t key_data_len)
+	struct wpa_eapol_ie_parse ie;
+	size_t kde_buf_len;
+	struct wpa_ptk *stk;
+	u8 buf[8], *kde_buf, *pos;
+	be32 lifetime;
+	wpa_printf(MSG_DEBUG, "RSN: RX message 1 of STK 4-Way Handshake from "
+		   MACSTR " (ver=%d)", MAC2STR(peerkey->addr), ver);
+	os_memset(&ie, 0, sizeof(ie));
+	/* RSN: msg 1/4 should contain SMKID for the selected SMK */
+	wpa_hexdump(MSG_DEBUG, "RSN: msg 1/4 key data", key_data, key_data_len);
+	if (wpa_supplicant_parse_ies(key_data, key_data_len, &ie) < 0 ||
+	    ie.pmkid == NULL) {
+		wpa_printf(MSG_DEBUG, "RSN: No SMKID in STK 1/4");
+		return;
+	if (os_memcmp_const(ie.pmkid, peerkey->smkid, PMKID_LEN) != 0) {
+		wpa_hexdump(MSG_DEBUG, "RSN: Unknown SMKID in STK 1/4",
+			    ie.pmkid, PMKID_LEN);
+		return;
+			"RSN: Failed to get random data for PNonce");
+		return;
+	wpa_hexdump(MSG_DEBUG, "WPA: Renewed PNonce",
+		    peerkey->pnonce, WPA_NONCE_LEN);
+	/* Calculate STK which will be stored as a temporary STK until it has
+	 * been verified when processing message 3/4. */
+	stk = &peerkey->tstk;
+	wpa_pmk_to_ptk(peerkey->smk, PMK_LEN, "Peer key expansion",
+		       sm->own_addr, peerkey->addr,
+		       peerkey->pnonce, key->key_nonce,
+		       stk, peerkey->akmp, peerkey->cipher);
+	/* Supplicant: swap tx/rx Mic keys */
+	os_memcpy(buf, &stk->tk[16], 8);
+	os_memcpy(&stk->tk[16], &stk->tk[24], 8);
+	os_memcpy(&stk->tk[24], buf, 8);
+	peerkey->tstk_set = 1;
+	kde_buf_len = peerkey->rsnie_p_len +
+		2 + RSN_SELECTOR_LEN + sizeof(lifetime) +
+		2 + RSN_SELECTOR_LEN + PMKID_LEN;
+	kde_buf = os_malloc(kde_buf_len);
+	if (kde_buf == NULL)
+		return;
+	pos = kde_buf;
+	pos = wpa_add_kde(pos, RSN_KEY_DATA_LIFETIME,
+	wpa_add_kde(pos, RSN_KEY_DATA_PMKID, peerkey->smkid, PMKID_LEN);
+	if (wpa_supplicant_send_2_of_4(sm, peerkey->addr, key, ver,
+				       peerkey->pnonce, kde_buf, kde_buf_len,
+				       stk)) {
+		os_free(kde_buf);
+		return;
+	os_free(kde_buf);
+static void wpa_supplicant_update_smk_lifetime(struct wpa_sm *sm,
+	u32 lifetime;
+	if (kde->lifetime == NULL || kde->lifetime_len < sizeof(lifetime))
+		return;
+	lifetime = WPA_GET_BE32(kde->lifetime);
+	if (lifetime >= peerkey->lifetime) {
+		wpa_printf(MSG_DEBUG, "RSN: Peer used SMK lifetime %u seconds "
+			   "which is larger than or equal to own value %u "
+			   "seconds - ignored", lifetime, peerkey->lifetime);
+		return;
+	wpa_printf(MSG_DEBUG, "RSN: Peer used shorter SMK lifetime %u seconds "
+		   "(own was %u seconds) - updated",
+		   lifetime, peerkey->lifetime);
+			       sm, peerkey);
+static void wpa_supplicant_process_stk_2_of_4(struct wpa_sm *sm,
+	wpa_printf(MSG_DEBUG, "RSN: RX message 2 of STK 4-Way Handshake from "
+	os_memset(&kde, 0, sizeof(kde));
+	/* RSN: msg 2/4 should contain SMKID for the selected SMK and RSN IE
+	 * from the peer. It may also include Lifetime KDE. */
+	wpa_hexdump(MSG_DEBUG, "RSN: msg 2/4 key data", key_data, key_data_len);
+	if (wpa_supplicant_parse_ies(key_data, key_data_len, &kde) < 0 ||
+	    kde.pmkid == NULL || kde.rsn_ie == NULL) {
+		wpa_printf(MSG_DEBUG, "RSN: No SMKID or RSN IE in STK 2/4");
+		return;
+	if (os_memcmp_const(kde.pmkid, peerkey->smkid, PMKID_LEN) != 0) {
+		wpa_hexdump(MSG_DEBUG, "RSN: Unknown SMKID in STK 2/4",
+			    kde.pmkid, PMKID_LEN);
+		return;
+	if (kde.rsn_ie_len != peerkey->rsnie_p_len ||
+	    os_memcmp(kde.rsn_ie, peerkey->rsnie_p, kde.rsn_ie_len) != 0) {
+		wpa_printf(MSG_INFO, "RSN: Peer RSN IE in SMK and STK "
+			   "handshakes did not match");
+		wpa_hexdump(MSG_DEBUG, "RSN: Peer RSN IE in SMK handshake",
+		wpa_hexdump(MSG_DEBUG, "RSN: Peer RSN IE in STK handshake",
+			    kde.rsn_ie, kde.rsn_ie_len);
+		return;
+	wpa_supplicant_update_smk_lifetime(sm, peerkey, &kde);
+	wpa_supplicant_send_stk_3_of_4(sm, peerkey);
+	os_memcpy(peerkey->pnonce, key->key_nonce, WPA_NONCE_LEN);
+static void wpa_supplicant_process_stk_3_of_4(struct wpa_sm *sm,
+	size_t key_len;
+	const u8 *_key;
+	u8 key_buf[32], rsc[6];
+	wpa_printf(MSG_DEBUG, "RSN: RX message 3 of STK 4-Way Handshake from "
+	/* RSN: msg 3/4 should contain Initiator RSN IE. It may also include
+	 * Lifetime KDE. */
+	wpa_hexdump(MSG_DEBUG, "RSN: msg 3/4 key data", key_data, key_data_len);
+	if (wpa_supplicant_parse_ies(key_data, key_data_len, &kde) < 0) {
+		wpa_printf(MSG_DEBUG, "RSN: Failed to parse key data in "
+			   "STK 3/4");
+		return;
+	if (kde.rsn_ie_len != peerkey->rsnie_i_len ||
+	    os_memcmp(kde.rsn_ie, peerkey->rsnie_i, kde.rsn_ie_len) != 0) {
+		wpa_printf(MSG_INFO, "RSN: Initiator RSN IE in SMK and STK "
+		wpa_hexdump(MSG_DEBUG, "RSN: Initiator RSN IE in SMK "
+			    "handshake",
+			    peerkey->rsnie_i, peerkey->rsnie_i_len);
+		wpa_hexdump(MSG_DEBUG, "RSN: Initiator RSN IE in STK "
+			    "handshake",
+		return;
+	if (os_memcmp(peerkey->inonce, key->key_nonce, WPA_NONCE_LEN) != 0) {
+		wpa_printf(MSG_WARNING, "RSN: INonce from message 1 of STK "
+			   "4-Way Handshake differs from 3 of STK 4-Way "
+			   "Handshake - drop packet (src=" MACSTR ")",
+		return;
+	if (wpa_supplicant_send_4_of_4(sm, peerkey->addr, key, ver,
+				       WPA_GET_BE16(key->key_info),
+				       &peerkey->stk))
+		return;
+	_key = peerkey->stk.tk;
+	if (peerkey->cipher == WPA_CIPHER_TKIP) {
+		/* Swap Tx/Rx keys for Michael MIC */
+		os_memcpy(key_buf, _key, 16);
+		os_memcpy(key_buf + 16, _key + 24, 8);
+		os_memcpy(key_buf + 24, _key + 16, 8);
+		_key = key_buf;
+		key_len = 32;
+	} else
+		key_len = 16;
+	os_memset(rsc, 0, 6);
+	if (wpa_sm_set_key(sm, peerkey->cipher, peerkey->addr, 0, 1,
+			   rsc, sizeof(rsc), _key, key_len) < 0) {
+		os_memset(key_buf, 0, sizeof(key_buf));
+		wpa_printf(MSG_WARNING, "RSN: Failed to set STK to the "
+			   "driver.");
+		return;
+static void wpa_supplicant_process_stk_4_of_4(struct wpa_sm *sm,
+					      u16 ver)
+	u8 rsc[6];
+	wpa_printf(MSG_DEBUG, "RSN: RX message 4 of STK 4-Way Handshake from "
+			   rsc, sizeof(rsc), peerkey->stk.tk,
+			   peerkey->cipher == WPA_CIPHER_TKIP ? 32 : 16) < 0) {
+			   "driver.");
+		return;
+ * peerkey_verify_eapol_key_mic - Verify PeerKey MIC
+ * @sm: Pointer to WPA state machine data from wpa_sm_init()
+ * @peerkey: Pointer to the PeerKey data for the peer
+ * @key: Pointer to the EAPOL-Key frame header
+ * @ver: Version bits from EAPOL-Key Key Info
+ * @buf: Pointer to the beginning of EAPOL-Key frame
+ * @len: Length of the EAPOL-Key frame
+ * Returns: 0 on success, -1 on failure
+int peerkey_verify_eapol_key_mic(struct wpa_sm *sm,
+				 struct wpa_eapol_key_192 *key, u16 ver,
+				 const u8 *buf, size_t len)
+	u8 mic[WPA_EAPOL_KEY_MIC_MAX_LEN];
+	size_t mic_len = 16;
+	int ok = 0;
+	if (peerkey->initiator && !peerkey->stk_set) {
+			       peerkey->inonce, key->key_nonce,
+			       &peerkey->stk, peerkey->akmp, peerkey->cipher);
+		peerkey->stk_set = 1;
+	os_memcpy(mic, key->key_mic, mic_len);
+	if (peerkey->tstk_set) {
+		os_memset(key->key_mic, 0, mic_len);
+		wpa_eapol_key_mic(peerkey->tstk.kck, peerkey->tstk.kck_len,
+				  sm->key_mgmt, ver, buf, len, key->key_mic);
+		if (os_memcmp_const(mic, key->key_mic, mic_len) != 0) {
+			wpa_printf(MSG_WARNING, "RSN: Invalid EAPOL-Key MIC "
+				   "when using TSTK - ignoring TSTK");
+		} else {
+			ok = 1;
+			peerkey->tstk_set = 0;
+			os_memcpy(&peerkey->stk, &peerkey->tstk,
+				  sizeof(peerkey->stk));
+			os_memset(&peerkey->tstk, 0, sizeof(peerkey->tstk));
+	if (!ok && peerkey->stk_set) {
+		wpa_eapol_key_mic(peerkey->stk.kck, peerkey->stk.kck_len,
+				   "- dropping packet");
+			return -1;
+		ok = 1;
+	if (!ok) {
+		wpa_printf(MSG_WARNING, "RSN: Could not verify EAPOL-Key MIC "
+		return -1;
+	os_memcpy(peerkey->replay_counter, key->replay_counter,
+	peerkey->replay_counter_set = 1;
+	return 0;
+ * wpa_sm_stkstart - Send EAPOL-Key Request for STK handshake (STK M1)
+ * @peer: MAC address of the peer STA
+ * Send an EAPOL-Key Request to the current authenticator to start STK
+ * handshake with the peer.
+int wpa_sm_stkstart(struct wpa_sm *sm, const u8 *peer)
+	size_t rlen, kde_len;
+	struct wpa_eapol_key *req;
+	int key_info, ver;
+	u8 bssid[ETH_ALEN], *rbuf, *pos, *count_pos;
+	u16 count;
+	if (sm->proto != WPA_PROTO_RSN || !sm->ptk_set || !sm->peerkey_enabled)
+		return -1;
+	if (sm->ap_rsn_ie &&
+	    wpa_parse_wpa_ie_rsn(sm->ap_rsn_ie, sm->ap_rsn_ie_len, &ie) == 0 &&
+	    !(ie.capabilities & WPA_CAPABILITY_PEERKEY_ENABLED)) {
+		wpa_printf(MSG_DEBUG, "RSN: Current AP does not support STK");
+		return -1;
+	if (sm->pairwise_cipher != WPA_CIPHER_TKIP)
+	else
+	if (wpa_sm_get_bssid(sm, bssid) < 0) {
+		wpa_printf(MSG_WARNING, "Failed to read BSSID for EAPOL-Key "
+			   "SMK M1");
+		return -1;
+	 * a new one */
+		return -1;
+	peerkey->initiator = 1;
+	os_memcpy(peerkey->addr, peer, ETH_ALEN);
+	peerkey->akmp = sm->key_mgmt;
+	/* SMK M1:
+	 * EAPOL-Key(S=1, M=1, A=0, I=0, K=0, SM=1, KeyRSC=0, Nonce=INonce,
+	 *           MIC=MIC, DataKDs=(RSNIE_I, MAC_P KDE))
+	hdr = (struct rsn_ie_hdr *) peerkey->rsnie_i;
+	 * ignore it. */
+	count_pos = pos;
+	pos += 2;
+	count = rsn_cipher_put_suites(pos, sm->allowed_pairwise_cipher);
+	pos += count * RSN_SELECTOR_LEN;
+	WPA_PUT_LE16(count_pos, count);
+	hdr->len = (pos - peerkey->rsnie_i) - 2;
+	peerkey->rsnie_i_len = pos - peerkey->rsnie_i;
+	kde_len = peerkey->rsnie_i_len + 2 + RSN_SELECTOR_LEN + ETH_ALEN;
+	rbuf = wpa_sm_alloc_eapol(sm, IEEE802_1X_TYPE_EAPOL_KEY, NULL,
+				  sizeof(*req) + kde_len, &rlen,
+				  (void *) &req);
+	if (rbuf == NULL) {
+		return -1;
+	req->type = EAPOL_KEY_TYPE_RSN;
+	key_info = WPA_KEY_INFO_SMK_MESSAGE | WPA_KEY_INFO_MIC |
+		WPA_KEY_INFO_SECURE | WPA_KEY_INFO_REQUEST | ver;
+	WPA_PUT_BE16(req->key_info, key_info);
+	WPA_PUT_BE16(req->key_length, 0);
+	os_memcpy(req->replay_counter, sm->request_counter,
+			"WPA: Failed to get random data for INonce");
+		os_free(rbuf);
+		return -1;
+	os_memcpy(req->key_nonce, peerkey->inonce, WPA_NONCE_LEN);
+	wpa_hexdump(MSG_DEBUG, "WPA: INonce for SMK handshake",
+		    req->key_nonce, WPA_NONCE_LEN);
+	WPA_PUT_BE16(req->key_data_length, (u16) kde_len);
+	pos = (u8 *) (req + 1);
+	/* Initiator RSN IE */
+	/* Peer MAC address KDE */
+	wpa_add_kde(pos, RSN_KEY_DATA_MAC_ADDR, peer, ETH_ALEN);
+	wpa_printf(MSG_INFO, "RSN: Sending EAPOL-Key SMK M1 Request (peer "
+		   MACSTR ")", MAC2STR(peer));
+	wpa_eapol_key_send(sm, sm->ptk.kck, sm->ptk.kck_len, ver, bssid,
+			   ETH_P_EAPOL, rbuf, rlen, req->key_mic);
+	return 0;
+ * peerkey_deinit - Free PeerKey values
+void peerkey_deinit(struct wpa_sm *sm)
+	struct wpa_peerkey *prev, *peerkey = sm->peerkey;
+	while (peerkey) {
+		prev = peerkey;
+		peerkey = peerkey->next;
+		wpa_supplicant_peerkey_free(sm, prev);
+	sm->peerkey = NULL;
+void peerkey_rx_eapol_4way(struct wpa_sm *sm, struct wpa_peerkey *peerkey,
+			   struct wpa_eapol_key *key, u16 key_info, u16 ver,
+			   const u8 *key_data, size_t key_data_len)
+	if ((key_info & (WPA_KEY_INFO_MIC | WPA_KEY_INFO_ACK)) ==
+	    (WPA_KEY_INFO_MIC | WPA_KEY_INFO_ACK)) {
+		/* 3/4 STK 4-Way Handshake */
+		wpa_supplicant_process_stk_3_of_4(sm, peerkey, key, ver,
+						  key_data, key_data_len);
+	} else if (key_info & WPA_KEY_INFO_ACK) {
+		/* 1/4 STK 4-Way Handshake */
+		wpa_supplicant_process_stk_1_of_4(sm, peerkey, key, ver,
+	} else if (key_info & WPA_KEY_INFO_SECURE) {
+		/* 4/4 STK 4-Way Handshake */
+		wpa_supplicant_process_stk_4_of_4(sm, peerkey, key, ver);
+	} else {
+		/* 2/4 STK 4-Way Handshake */
+		wpa_supplicant_process_stk_2_of_4(sm, peerkey, key, ver,
+void peerkey_rx_eapol_smk(struct wpa_sm *sm, const u8 *src_addr,
+			  struct wpa_eapol_key *key, size_t extra_len,
+			  u16 key_info, u16 ver)
+	if (key_info & WPA_KEY_INFO_ERROR) {
+		/* SMK Error */
+		wpa_supplicant_process_smk_error(sm, src_addr, key, extra_len);
+		/* SMK M2 */
+		wpa_supplicant_process_smk_m2(sm, src_addr, key, extra_len,
+					      ver);
+	} else {
+		/* SMK M4 or M5 */
+		wpa_supplicant_process_smk_m45(sm, src_addr, key, extra_len,
+					       ver);
+#endif /* CONFIG_PEERKEY */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/peerkey.h b/freebsd/contrib/wpa/src/rsn_supp/peerkey.h
index 00000000000..6ccd948baac
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/peerkey.h
@@ -0,0 +1,82 @@
+#ifndef PEERKEY_H
+#define PEERKEY_H
+#define PEERKEY_MAX_IE_LEN 80
+struct wpa_peerkey {
+	struct wpa_peerkey *next;
+	int initiator; /* whether this end was initator for SMK handshake */
+	u8 addr[ETH_ALEN]; /* other end MAC address */
+	u8 inonce[WPA_NONCE_LEN]; /* Initiator Nonce */
+	u8 pnonce[WPA_NONCE_LEN]; /* Peer Nonce */
+	u8 rsnie_i[PEERKEY_MAX_IE_LEN]; /* Initiator RSN IE */
+	size_t rsnie_i_len;
+	u8 rsnie_p[PEERKEY_MAX_IE_LEN]; /* Peer RSN IE */
+	size_t rsnie_p_len;
+	u8 smk[PMK_LEN];
+	int smk_complete;
+	u8 smkid[PMKID_LEN];
+	u32 lifetime;
+	int cipher; /* Selected cipher (WPA_CIPHER_*) */
+	u8 replay_counter[WPA_REPLAY_COUNTER_LEN];
+	int replay_counter_set;
+	int akmp;
+	struct wpa_ptk stk, tstk;
+	int stk_set, tstk_set;
+				 const u8 *buf, size_t len);
+			   const u8 *key_data, size_t key_data_len);
+			  u16 key_info, u16 ver);
+void peerkey_deinit(struct wpa_sm *sm);
+#else /* CONFIG_PEERKEY */
+static inline int
+peerkey_verify_eapol_key_mic(struct wpa_sm *sm,
+			     struct wpa_eapol_key *key, u16 ver,
+	return -1;
+static inline void
+peerkey_rx_eapol_4way(struct wpa_sm *sm, struct wpa_peerkey *peerkey,
+static inline void
+peerkey_rx_eapol_smk(struct wpa_sm *sm, const u8 *src_addr,
+static inline void peerkey_deinit(struct wpa_sm *sm)
+#endif /* PEERKEY_H */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c b/freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c
index 00000000000..e9bf319a4b1
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c
@@ -0,0 +1,539 @@
+ * WPA Supplicant - RSN PMKSA cache
+ * Copyright (c) 2004-2009, 2011-2015, Jouni Malinen <j at w1.fi>
+#include "eloop.h"
+#include "eapol_supp/eapol_supp_sm.h"
+#include "wpa.h"
+#include "wpa_i.h"
+#include "pmksa_cache.h"
+#ifdef IEEE8021X_EAPOL
+static const int pmksa_cache_max_entries = 32;
+struct rsn_pmksa_cache {
+	struct rsn_pmksa_cache_entry *pmksa; /* PMKSA cache */
+	int pmksa_count; /* number of entries in PMKSA cache */
+	struct wpa_sm *sm; /* TODO: get rid of this reference(?) */
+	void (*free_cb)(struct rsn_pmksa_cache_entry *entry, void *ctx,
+			enum pmksa_free_reason reason);
+	void *ctx;
+static void pmksa_cache_set_expiration(struct rsn_pmksa_cache *pmksa);
+static void _pmksa_cache_free_entry(struct rsn_pmksa_cache_entry *entry)
+	bin_clear_free(entry, sizeof(*entry));
+static void pmksa_cache_free_entry(struct rsn_pmksa_cache *pmksa,
+				   struct rsn_pmksa_cache_entry *entry,
+	wpa_sm_remove_pmkid(pmksa->sm, entry->aa, entry->pmkid);
+	pmksa->pmksa_count--;
+	pmksa->free_cb(entry, pmksa->ctx, reason);
+	_pmksa_cache_free_entry(entry);
+static void pmksa_cache_expire(void *eloop_ctx, void *timeout_ctx)
+	struct rsn_pmksa_cache *pmksa = eloop_ctx;
+	struct os_reltime now;
+	os_get_reltime(&now);
+	while (pmksa->pmksa && pmksa->pmksa->expiration <= now.sec) {
+		struct rsn_pmksa_cache_entry *entry = pmksa->pmksa;
+		pmksa->pmksa = entry->next;
+		wpa_printf(MSG_DEBUG, "RSN: expired PMKSA cache entry for "
+			   MACSTR, MAC2STR(entry->aa));
+		pmksa_cache_free_entry(pmksa, entry, PMKSA_EXPIRE);
+	pmksa_cache_set_expiration(pmksa);
+static void pmksa_cache_reauth(void *eloop_ctx, void *timeout_ctx)
+	pmksa->sm->cur_pmksa = NULL;
+	eapol_sm_request_reauth(pmksa->sm->eapol);
+	int sec;
+	struct rsn_pmksa_cache_entry *entry;
+	eloop_cancel_timeout(pmksa_cache_expire, pmksa, NULL);
+	eloop_cancel_timeout(pmksa_cache_reauth, pmksa, NULL);
+	if (pmksa->pmksa == NULL)
+		return;
+	sec = pmksa->pmksa->expiration - now.sec;
+	if (sec < 0)
+		sec = 0;
+	eloop_register_timeout(sec + 1, 0, pmksa_cache_expire, pmksa, NULL);
+	entry = pmksa->sm->cur_pmksa ? pmksa->sm->cur_pmksa :
+		pmksa_cache_get(pmksa, pmksa->sm->bssid, NULL, NULL);
+	if (entry) {
+		sec = pmksa->pmksa->reauth_time - now.sec;
+		if (sec < 0)
+			sec = 0;
+		eloop_register_timeout(sec, 0, pmksa_cache_reauth, pmksa,
+				       NULL);
+ * pmksa_cache_add - Add a PMKSA cache entry
+ * @pmksa: Pointer to PMKSA cache data from pmksa_cache_init()
+ * @pmk: The new pairwise master key
+ * @pmk_len: PMK length in bytes, usually PMK_LEN (32)
+ * @kck: Key confirmation key or %NULL if not yet derived
+ * @kck_len: KCK length in bytes
+ * @aa: Authenticator address
+ * @spa: Supplicant address
+ * @network_ctx: Network configuration context for this PMK
+ * @akmp: WPA_KEY_MGMT_* used in key derivation
+ * Returns: Pointer to the added PMKSA cache entry or %NULL on error
+ * This function create a PMKSA entry for a new PMK and adds it to the PMKSA
+ * cache. If an old entry is already in the cache for the same Authenticator,
+ * this entry will be replaced with the new entry. PMKID will be calculated
+ * based on the PMK and the driver interface is notified of the new PMKID.
+struct rsn_pmksa_cache_entry *
+pmksa_cache_add(struct rsn_pmksa_cache *pmksa, const u8 *pmk, size_t pmk_len,
+		const u8 *kck, size_t kck_len,
+		const u8 *aa, const u8 *spa, void *network_ctx, int akmp)
+	struct rsn_pmksa_cache_entry *entry, *pos, *prev;
+	if (pmk_len > PMK_LEN)
+		return NULL;
+	if (wpa_key_mgmt_suite_b(akmp) && !kck)
+		return NULL;
+	entry = os_zalloc(sizeof(*entry));
+	if (entry == NULL)
+		return NULL;
+	os_memcpy(entry->pmk, pmk, pmk_len);
+	entry->pmk_len = pmk_len;
+	if (akmp == WPA_KEY_MGMT_IEEE8021X_SUITE_B_192)
+		rsn_pmkid_suite_b_192(kck, kck_len, aa, spa, entry->pmkid);
+	else if (wpa_key_mgmt_suite_b(akmp))
+		rsn_pmkid_suite_b(kck, kck_len, aa, spa, entry->pmkid);
+	else
+		rsn_pmkid(pmk, pmk_len, aa, spa, entry->pmkid,
+			  wpa_key_mgmt_sha256(akmp));
+	entry->expiration = now.sec + pmksa->sm->dot11RSNAConfigPMKLifetime;
+	entry->reauth_time = now.sec + pmksa->sm->dot11RSNAConfigPMKLifetime *
+		pmksa->sm->dot11RSNAConfigPMKReauthThreshold / 100;
+	entry->akmp = akmp;
+	os_memcpy(entry->aa, aa, ETH_ALEN);
+	entry->network_ctx = network_ctx;
+	/* Replace an old entry for the same Authenticator (if found) with the
+	 * new entry */
+	pos = pmksa->pmksa;
+	prev = NULL;
+	while (pos) {
+		if (os_memcmp(aa, pos->aa, ETH_ALEN) == 0) {
+			if (pos->pmk_len == pmk_len &&
+			    os_memcmp_const(pos->pmk, pmk, pmk_len) == 0 &&
+			    os_memcmp_const(pos->pmkid, entry->pmkid,
+					    PMKID_LEN) == 0) {
+				wpa_printf(MSG_DEBUG, "WPA: reusing previous "
+					   "PMKSA entry");
+				os_free(entry);
+				return pos;
+			if (prev == NULL)
+				pmksa->pmksa = pos->next;
+			else
+				prev->next = pos->next;
+			 * If OKC is used, there may be other PMKSA cache
+			 * entries based on the same PMK. These needs to be
+			 * flushed so that a new entry can be created based on
+			 * the new PMK. Only clear other entries if they have a
+			 * matching PMK and this PMK has been used successfully
+			 * with the current AP, i.e., if opportunistic flag has
+			 * been cleared in wpa_supplicant_key_neg_complete().
+			wpa_printf(MSG_DEBUG, "RSN: Replace PMKSA entry for "
+				   "the current AP and any PMKSA cache entry "
+				   "that was based on the old PMK");
+			if (!pos->opportunistic)
+				pmksa_cache_flush(pmksa, network_ctx, pos->pmk,
+						  pos->pmk_len);
+			pmksa_cache_free_entry(pmksa, pos, PMKSA_REPLACE);
+			break;
+		prev = pos;
+		pos = pos->next;
+	if (pmksa->pmksa_count >= pmksa_cache_max_entries && pmksa->pmksa) {
+		/* Remove the oldest entry to make room for the new entry */
+		if (pos == pmksa->sm->cur_pmksa) {
+			 * Never remove the current PMKSA cache entry, since
+			 * it's in use, and removing it triggers a needless
+			 * deauthentication.
+			pos = pos->next;
+			pmksa->pmksa->next = pos ? pos->next : NULL;
+		} else
+		if (pos) {
+			wpa_printf(MSG_DEBUG, "RSN: removed the oldest idle "
+				   "PMKSA cache entry (for " MACSTR ") to "
+				   "make room for new one",
+				   MAC2STR(pos->aa));
+			pmksa_cache_free_entry(pmksa, pos, PMKSA_FREE);
+	/* Add the new entry; order by expiration time */
+	prev = NULL;
+	while (pos) {
+		if (pos->expiration > entry->expiration)
+			break;
+		prev = pos;
+		pos = pos->next;
+	if (prev == NULL) {
+		entry->next = pmksa->pmksa;
+		pmksa->pmksa = entry;
+	} else {
+		entry->next = prev->next;
+		prev->next = entry;
+	pmksa->pmksa_count++;
+	wpa_printf(MSG_DEBUG, "RSN: Added PMKSA cache entry for " MACSTR
+		   " network_ctx=%p", MAC2STR(entry->aa), network_ctx);
+	wpa_sm_add_pmkid(pmksa->sm, entry->aa, entry->pmkid);
+	return entry;
+ * pmksa_cache_flush - Flush PMKSA cache entries for a specific network
+ * @network_ctx: Network configuration context or %NULL to flush all entries
+ * @pmk: PMK to match for or %NYLL to match all PMKs
+void pmksa_cache_flush(struct rsn_pmksa_cache *pmksa, void *network_ctx,
+		       const u8 *pmk, size_t pmk_len)
+	struct rsn_pmksa_cache_entry *entry, *prev = NULL, *tmp;
+	int removed = 0;
+	entry = pmksa->pmksa;
+	while (entry) {
+		if ((entry->network_ctx == network_ctx ||
+		     network_ctx == NULL) &&
+		    (pmk == NULL ||
+		     (pmk_len == entry->pmk_len &&
+		      os_memcmp(pmk, entry->pmk, pmk_len) == 0))) {
+			wpa_printf(MSG_DEBUG, "RSN: Flush PMKSA cache entry "
+				   "for " MACSTR, MAC2STR(entry->aa));
+			if (prev)
+				prev->next = entry->next;
+			else
+			tmp = entry;
+			entry = entry->next;
+			pmksa_cache_free_entry(pmksa, tmp, PMKSA_FREE);
+			removed++;
+		} else {
+			prev = entry;
+	if (removed)
+ * pmksa_cache_deinit - Free all entries in PMKSA cache
+void pmksa_cache_deinit(struct rsn_pmksa_cache *pmksa)
+	struct rsn_pmksa_cache_entry *entry, *prev;
+	if (pmksa == NULL)
+		return;
+	pmksa->pmksa = NULL;
+	while (entry) {
+		prev = entry;
+		os_free(prev);
+	os_free(pmksa);
+ * pmksa_cache_get - Fetch a PMKSA cache entry
+ * @aa: Authenticator address or %NULL to match any
+ * @pmkid: PMKID or %NULL to match any
+ * @network_ctx: Network context or %NULL to match any
+ * Returns: Pointer to PMKSA cache entry or %NULL if no match was found
+struct rsn_pmksa_cache_entry * pmksa_cache_get(struct rsn_pmksa_cache *pmksa,
+					       const u8 *aa, const u8 *pmkid,
+					       const void *network_ctx)
+	while (entry) {
+		if ((aa == NULL || os_memcmp(entry->aa, aa, ETH_ALEN) == 0) &&
+		    (pmkid == NULL ||
+		     os_memcmp(entry->pmkid, pmkid, PMKID_LEN) == 0) &&
+		    (network_ctx == NULL || network_ctx == entry->network_ctx))
+			return entry;
+	return NULL;
+static struct rsn_pmksa_cache_entry *
+pmksa_cache_clone_entry(struct rsn_pmksa_cache *pmksa,
+			const struct rsn_pmksa_cache_entry *old_entry,
+			const u8 *aa)
+	struct rsn_pmksa_cache_entry *new_entry;
+	new_entry = pmksa_cache_add(pmksa, old_entry->pmk, old_entry->pmk_len,
+				    NULL, 0,
+				    aa, pmksa->sm->own_addr,
+				    old_entry->network_ctx, old_entry->akmp);
+	if (new_entry == NULL)
+		return NULL;
+	/* TODO: reorder entries based on expiration time? */
+	new_entry->expiration = old_entry->expiration;
+	new_entry->opportunistic = 1;
+	return new_entry;
+ * pmksa_cache_get_opportunistic - Try to get an opportunistic PMKSA entry
+ * @aa: Authenticator address for the new AP
+ * Returns: Pointer to a new PMKSA cache entry or %NULL if not available
+ * Try to create a new PMKSA cache entry opportunistically by guessing that the
+ * new AP is sharing the same PMK as another AP that has the same SSID and has
+ * already an entry in PMKSA cache.
+pmksa_cache_get_opportunistic(struct rsn_pmksa_cache *pmksa, void *network_ctx,
+			      const u8 *aa)
+	wpa_printf(MSG_DEBUG, "RSN: Consider " MACSTR " for OKC", MAC2STR(aa));
+	if (network_ctx == NULL)
+		return NULL;
+	while (entry) {
+		if (entry->network_ctx == network_ctx) {
+			entry = pmksa_cache_clone_entry(pmksa, entry, aa);
+			if (entry) {
+				wpa_printf(MSG_DEBUG, "RSN: added "
+					   "opportunistic PMKSA cache entry "
+					   "for " MACSTR, MAC2STR(aa));
+			return entry;
+	return NULL;
+ * pmksa_cache_get_current - Get the current used PMKSA entry
+ * Returns: Pointer to the current PMKSA cache entry or %NULL if not available
+struct rsn_pmksa_cache_entry * pmksa_cache_get_current(struct wpa_sm *sm)
+	if (sm == NULL)
+		return NULL;
+	return sm->cur_pmksa;
+ * pmksa_cache_clear_current - Clear the current PMKSA entry selection
+void pmksa_cache_clear_current(struct wpa_sm *sm)
+	if (sm == NULL)
+		return;
+	sm->cur_pmksa = NULL;
+ * pmksa_cache_set_current - Set the current PMKSA entry selection
+ * @pmkid: PMKID for selecting PMKSA or %NULL if not used
+ * @bssid: BSSID for PMKSA or %NULL if not used
+ * @try_opportunistic: Whether to allow opportunistic PMKSA caching
+ * Returns: 0 if PMKSA was found or -1 if no matching entry was found
+int pmksa_cache_set_current(struct wpa_sm *sm, const u8 *pmkid,
+			    const u8 *bssid, void *network_ctx,
+			    int try_opportunistic)
+	struct rsn_pmksa_cache *pmksa = sm->pmksa;
+	wpa_printf(MSG_DEBUG, "RSN: PMKSA cache search - network_ctx=%p "
+		   "try_opportunistic=%d", network_ctx, try_opportunistic);
+	if (pmkid)
+		wpa_hexdump(MSG_DEBUG, "RSN: Search for PMKID",
+			    pmkid, PMKID_LEN);
+	if (bssid)
+		wpa_printf(MSG_DEBUG, "RSN: Search for BSSID " MACSTR,
+			   MAC2STR(bssid));
+	if (pmkid)
+		sm->cur_pmksa = pmksa_cache_get(pmksa, NULL, pmkid,
+						network_ctx);
+	if (sm->cur_pmksa == NULL && bssid)
+		sm->cur_pmksa = pmksa_cache_get(pmksa, bssid, NULL,
+						network_ctx);
+	if (sm->cur_pmksa == NULL && try_opportunistic && bssid)
+		sm->cur_pmksa = pmksa_cache_get_opportunistic(pmksa,
+							      network_ctx,
+							      bssid);
+	if (sm->cur_pmksa) {
+		wpa_hexdump(MSG_DEBUG, "RSN: PMKSA cache entry found - PMKID",
+			    sm->cur_pmksa->pmkid, PMKID_LEN);
+		return 0;
+	wpa_printf(MSG_DEBUG, "RSN: No PMKSA cache entry found");
+	return -1;
+ * pmksa_cache_list - Dump text list of entries in PMKSA cache
+ * @buf: Buffer for the list
+ * @len: Length of the buffer
+ * Returns: number of bytes written to buffer
+ * This function is used to generate a text format representation of the
+ * current PMKSA cache contents for the ctrl_iface PMKSA command.
+int pmksa_cache_list(struct rsn_pmksa_cache *pmksa, char *buf, size_t len)
+	int i, ret;
+	char *pos = buf;
+	ret = os_snprintf(pos, buf + len - pos,
+			  "Index / AA / PMKID / expiration (in seconds) / "
+			  "opportunistic\n");
+	if (os_snprintf_error(buf + len - pos, ret))
+		return pos - buf;
+	pos += ret;
+	i = 0;
+	while (entry) {
+		i++;
+		ret = os_snprintf(pos, buf + len - pos, "%d " MACSTR " ",
+				  i, MAC2STR(entry->aa));
+			return pos - buf;
+		pos += ret;
+		pos += wpa_snprintf_hex(pos, buf + len - pos, entry->pmkid,
+					PMKID_LEN);
+		ret = os_snprintf(pos, buf + len - pos, " %d %d\n",
+				  (int) (entry->expiration - now.sec),
+				  entry->opportunistic);
+			return pos - buf;
+		pos += ret;
+	return pos - buf;
+ * pmksa_cache_init - Initialize PMKSA cache
+ * @free_cb: Callback function to be called when a PMKSA cache entry is freed
+ * @ctx: Context pointer for free_cb function
+ * Returns: Pointer to PMKSA cache data or %NULL on failure
+struct rsn_pmksa_cache *
+pmksa_cache_init(void (*free_cb)(struct rsn_pmksa_cache_entry *entry,
+				 void *ctx, enum pmksa_free_reason reason),
+		 void *ctx, struct wpa_sm *sm)
+	struct rsn_pmksa_cache *pmksa;
+	pmksa = os_zalloc(sizeof(*pmksa));
+	if (pmksa) {
+		pmksa->free_cb = free_cb;
+		pmksa->ctx = ctx;
+		pmksa->sm = sm;
+	return pmksa;
+#endif /* IEEE8021X_EAPOL */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h b/freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h
index 00000000000..f8e040e067d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.h
@@ -0,0 +1,134 @@
+ * wpa_supplicant - WPA2/RSN PMKSA cache functions
+ * Copyright (c) 2003-2009, 2011-2012, Jouni Malinen <j at w1.fi>
+#ifndef PMKSA_CACHE_H
+#define PMKSA_CACHE_H
+ * struct rsn_pmksa_cache_entry - PMKSA cache entry
+struct rsn_pmksa_cache_entry {
+	struct rsn_pmksa_cache_entry *next;
+	u8 pmkid[PMKID_LEN];
+	u8 pmk[PMK_LEN];
+	size_t pmk_len;
+	os_time_t expiration;
+	int akmp; /* WPA_KEY_MGMT_* */
+	u8 aa[ETH_ALEN];
+	os_time_t reauth_time;
+	 * network_ctx - Network configuration context
+	 * This field is only used to match PMKSA cache entries to a specific
+	 * network configuration (e.g., a specific SSID and security policy).
+	 * This can be a pointer to the configuration entry, but PMKSA caching
+	 * code does not dereference the value and this could be any kind of
+	 * identifier.
+	void *network_ctx;
+	int opportunistic;
+struct rsn_pmksa_cache;
+enum pmksa_free_reason {
+	PMKSA_FREE,
+	PMKSA_REPLACE,
+	PMKSA_EXPIRE,
+		 void *ctx, struct wpa_sm *sm);
+void pmksa_cache_deinit(struct rsn_pmksa_cache *pmksa);
+					       const void *network_ctx);
+int pmksa_cache_list(struct rsn_pmksa_cache *pmksa, char *buf, size_t len);
+		const u8 *aa, const u8 *spa, void *network_ctx, int akmp);
+struct rsn_pmksa_cache_entry * pmksa_cache_get_current(struct wpa_sm *sm);
+void pmksa_cache_clear_current(struct wpa_sm *sm);
+			    int try_opportunistic);
+			      void *network_ctx, const u8 *aa);
+		       const u8 *pmk, size_t pmk_len);
+#else /* IEEE8021X_EAPOL */
+static inline struct rsn_pmksa_cache *
+	return (void *) -1;
+static inline void pmksa_cache_deinit(struct rsn_pmksa_cache *pmksa)
+static inline struct rsn_pmksa_cache_entry *
+pmksa_cache_get(struct rsn_pmksa_cache *pmksa, const u8 *aa, const u8 *pmkid,
+	return NULL;
+pmksa_cache_get_current(struct wpa_sm *sm)
+	return NULL;
+static inline int pmksa_cache_list(struct rsn_pmksa_cache *pmksa, char *buf,
+				   size_t len)
+	return -1;
+	return NULL;
+static inline void pmksa_cache_clear_current(struct wpa_sm *sm)
+static inline int pmksa_cache_set_current(struct wpa_sm *sm, const u8 *pmkid,
+					  const u8 *bssid,
+	return -1;
+static inline void pmksa_cache_flush(struct rsn_pmksa_cache *pmksa,
+#endif /* PMKSA_CACHE_H */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/preauth.c b/freebsd/contrib/wpa/src/rsn_supp/preauth.c
index 00000000000..f6b3cf5c2b3
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/preauth.c
@@ -0,0 +1,543 @@
+ * RSN pre-authentication (supplicant)
+ * Copyright (c) 2003-2015, Jouni Malinen <j at w1.fi>
+#include "wpa.h"
+#include "eloop.h"
+#include "l2_packet/l2_packet.h"
+#include "preauth.h"
+#include "wpa_i.h"
+#define PMKID_CANDIDATE_PRIO_SCAN 1000
+struct rsn_pmksa_candidate {
+	struct dl_list list;
+	u8 bssid[ETH_ALEN];
+	int priority;
+ * pmksa_candidate_free - Free all entries in PMKSA candidate list
+void pmksa_candidate_free(struct wpa_sm *sm)
+	struct rsn_pmksa_candidate *entry, *n;
+	if (sm == NULL)
+		return;
+	dl_list_for_each_safe(entry, n, &sm->pmksa_candidates,
+			      struct rsn_pmksa_candidate, list) {
+		dl_list_del(&entry->list);
+		os_free(entry);
+static void rsn_preauth_receive(void *ctx, const u8 *src_addr,
+	struct wpa_sm *sm = ctx;
+	wpa_printf(MSG_DEBUG, "RX pre-auth from " MACSTR, MAC2STR(src_addr));
+	wpa_hexdump(MSG_MSGDUMP, "RX pre-auth", buf, len);
+	if (sm->preauth_eapol == NULL ||
+	    is_zero_ether_addr(sm->preauth_bssid) ||
+	    os_memcmp(sm->preauth_bssid, src_addr, ETH_ALEN) != 0) {
+		wpa_printf(MSG_WARNING, "RSN pre-auth frame received from "
+			   "unexpected source " MACSTR " - dropped",
+			   MAC2STR(src_addr));
+		return;
+	eapol_sm_rx_eapol(sm->preauth_eapol, src_addr, buf, len);
+static void rsn_preauth_eapol_cb(struct eapol_sm *eapol,
+				 enum eapol_supp_result result,
+				 void *ctx)
+	u8 pmk[PMK_LEN];
+	if (result == EAPOL_SUPP_RESULT_SUCCESS) {
+		int res, pmk_len;
+		pmk_len = PMK_LEN;
+		res = eapol_sm_get_key(eapol, pmk, PMK_LEN);
+		if (res) {
+			 * EAP-LEAP is an exception from other EAP methods: it
+			 * uses only 16-byte PMK.
+			res = eapol_sm_get_key(eapol, pmk, 16);
+			pmk_len = 16;
+		if (res == 0) {
+			wpa_hexdump_key(MSG_DEBUG, "RSN: PMK from pre-auth",
+					pmk, pmk_len);
+			sm->pmk_len = pmk_len;
+			pmksa_cache_add(sm->pmksa, pmk, pmk_len,
+					NULL, 0,
+					sm->preauth_bssid, sm->own_addr,
+					sm->network_ctx,
+					WPA_KEY_MGMT_IEEE8021X);
+		} else {
+				"RSN: failed to get master session key from "
+				"pre-auth EAPOL state machines");
+			result = EAPOL_SUPP_RESULT_FAILURE;
+	wpa_msg(sm->ctx->msg_ctx, MSG_INFO, "RSN: pre-authentication with "
+		MACSTR " %s", MAC2STR(sm->preauth_bssid),
+		result == EAPOL_SUPP_RESULT_SUCCESS ? "completed successfully" :
+		"failed");
+	rsn_preauth_deinit(sm);
+	rsn_preauth_candidate_process(sm);
+static void rsn_preauth_timeout(void *eloop_ctx, void *timeout_ctx)
+		MACSTR " timed out", MAC2STR(sm->preauth_bssid));
+static int rsn_preauth_eapol_send(void *ctx, int type, const u8 *buf,
+				  size_t len)
+	u8 *msg;
+	size_t msglen;
+	int res;
+	/* TODO: could add l2_packet_sendmsg that allows fragments to avoid
+	 * extra copy here */
+	if (sm->l2_preauth == NULL)
+		return -1;
+	msg = wpa_sm_alloc_eapol(sm, type, buf, len, &msglen, NULL);
+	if (msg == NULL)
+		return -1;
+	wpa_hexdump(MSG_MSGDUMP, "TX EAPOL (preauth)", msg, msglen);
+	res = l2_packet_send(sm->l2_preauth, sm->preauth_bssid,
+			     ETH_P_RSN_PREAUTH, msg, msglen);
+	os_free(msg);
+	return res;
+ * rsn_preauth_init - Start new RSN pre-authentication
+ * @dst: Authenticator address (BSSID) with which to preauthenticate
+ * @eap_conf: Current EAP configuration
+ * Returns: 0 on success, -1 on another pre-authentication is in progress,
+ * -2 on layer 2 packet initialization failure, -3 on EAPOL state machine
+ * initialization failure, -4 on memory allocation failure
+ * This function request an RSN pre-authentication with a given destination
+ * address. This is usually called for PMKSA candidates found from scan results
+ * or from driver reports. In addition, ctrl_iface PREAUTH command can trigger
+ * pre-authentication.
+int rsn_preauth_init(struct wpa_sm *sm, const u8 *dst,
+		     struct eap_peer_config *eap_conf)
+	struct eapol_config eapol_conf;
+	struct eapol_ctx *ctx;
+	int ret;
+	if (sm->preauth_eapol)
+		return -1;
+	wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG,
+		"RSN: starting pre-authentication with " MACSTR, MAC2STR(dst));
+	sm->l2_preauth = l2_packet_init(sm->ifname, sm->own_addr,
+					rsn_preauth_receive, sm, 0);
+	if (sm->l2_preauth == NULL) {
+		wpa_printf(MSG_WARNING, "RSN: Failed to initialize L2 packet "
+			   "processing for pre-authentication");
+		return -2;
+	if (sm->bridge_ifname) {
+		sm->l2_preauth_br = l2_packet_init(sm->bridge_ifname,
+						   sm->own_addr,
+		if (sm->l2_preauth_br == NULL) {
+			wpa_printf(MSG_WARNING, "RSN: Failed to initialize L2 "
+				   "packet processing (bridge) for "
+				   "pre-authentication");
+			ret = -2;
+			goto fail;
+	ctx = os_zalloc(sizeof(*ctx));
+	if (ctx == NULL) {
+		wpa_printf(MSG_WARNING, "Failed to allocate EAPOL context.");
+		ret = -4;
+		goto fail;
+	ctx->ctx = sm->ctx->ctx;
+	ctx->msg_ctx = sm->ctx->ctx;
+	ctx->preauth = 1;
+	ctx->cb = rsn_preauth_eapol_cb;
+	ctx->cb_ctx = sm;
+	ctx->scard_ctx = sm->scard_ctx;
+	ctx->eapol_send = rsn_preauth_eapol_send;
+	ctx->eapol_send_ctx = sm;
+	ctx->set_config_blob = sm->ctx->set_config_blob;
+	ctx->get_config_blob = sm->ctx->get_config_blob;
+	sm->preauth_eapol = eapol_sm_init(ctx);
+	if (sm->preauth_eapol == NULL) {
+		os_free(ctx);
+		wpa_printf(MSG_WARNING, "RSN: Failed to initialize EAPOL "
+			   "state machines for pre-authentication");
+		ret = -3;
+		goto fail;
+	os_memset(&eapol_conf, 0, sizeof(eapol_conf));
+	eapol_conf.accept_802_1x_keys = 0;
+	eapol_conf.required_keys = 0;
+	eapol_conf.fast_reauth = sm->fast_reauth;
+	eapol_conf.workaround = sm->eap_workaround;
+	eapol_sm_notify_config(sm->preauth_eapol, eap_conf, &eapol_conf);
+	 * Use a shorter startPeriod with preauthentication since the first
+	 * preauth EAPOL-Start frame may end up being dropped due to race
+	 * condition in the AP between the data receive and key configuration
+	 * after the 4-Way Handshake.
+	eapol_sm_configure(sm->preauth_eapol, -1, -1, 5, 6);
+	os_memcpy(sm->preauth_bssid, dst, ETH_ALEN);
+	eapol_sm_notify_portValid(sm->preauth_eapol, TRUE);
+	/* 802.1X::portControl = Auto */
+	eapol_sm_notify_portEnabled(sm->preauth_eapol, TRUE);
+	eloop_register_timeout(sm->dot11RSNAConfigSATimeout, 0,
+			       rsn_preauth_timeout, sm, NULL);
+	return 0;
+fail:
+	if (sm->l2_preauth_br) {
+		l2_packet_deinit(sm->l2_preauth_br);
+		sm->l2_preauth_br = NULL;
+	l2_packet_deinit(sm->l2_preauth);
+	sm->l2_preauth = NULL;
+	return ret;
+ * rsn_preauth_deinit - Abort RSN pre-authentication
+ * This function aborts the current RSN pre-authentication (if one is started)
+ * and frees resources allocated for it.
+void rsn_preauth_deinit(struct wpa_sm *sm)
+	if (sm == NULL || !sm->preauth_eapol)
+		return;
+	eloop_cancel_timeout(rsn_preauth_timeout, sm, NULL);
+	eapol_sm_deinit(sm->preauth_eapol);
+	sm->preauth_eapol = NULL;
+	os_memset(sm->preauth_bssid, 0, ETH_ALEN);
+ * rsn_preauth_candidate_process - Process PMKSA candidates
+ * Go through the PMKSA candidates and start pre-authentication if a candidate
+ * without an existing PMKSA cache entry is found. Processed candidates will be
+ * removed from the list.
+void rsn_preauth_candidate_process(struct wpa_sm *sm)
+	struct rsn_pmksa_candidate *candidate, *n;
+	if (dl_list_empty(&sm->pmksa_candidates))
+		return;
+	/* TODO: drop priority for old candidate entries */
+	wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: processing PMKSA candidate "
+		"list");
+	if (sm->preauth_eapol ||
+	    sm->proto != WPA_PROTO_RSN ||
+	    wpa_sm_get_state(sm) != WPA_COMPLETED ||
+	    (sm->key_mgmt != WPA_KEY_MGMT_IEEE8021X &&
+	     sm->key_mgmt != WPA_KEY_MGMT_IEEE8021X_SHA256 &&
+	     sm->key_mgmt != WPA_KEY_MGMT_IEEE8021X_SUITE_B &&
+	     sm->key_mgmt != WPA_KEY_MGMT_IEEE8021X_SUITE_B_192)) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: not in suitable "
+			"state for new pre-authentication");
+		return; /* invalid state for new pre-auth */
+	dl_list_for_each_safe(candidate, n, &sm->pmksa_candidates,
+		struct rsn_pmksa_cache_entry *p = NULL;
+		p = pmksa_cache_get(sm->pmksa, candidate->bssid, NULL, NULL);
+		if (os_memcmp(sm->bssid, candidate->bssid, ETH_ALEN) != 0 &&
+		    (p == NULL || p->opportunistic)) {
+			wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: PMKSA "
+				"candidate " MACSTR
+				" selected for pre-authentication",
+				MAC2STR(candidate->bssid));
+			dl_list_del(&candidate->list);
+			rsn_preauth_init(sm, candidate->bssid,
+					 sm->eap_conf_ctx);
+			os_free(candidate);
+			return;
+		wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: PMKSA candidate "
+			MACSTR " does not need pre-authentication anymore",
+		/* Some drivers (e.g., NDIS) expect to get notified about the
+		 * PMKIDs again, so report the existing data now. */
+		if (p) {
+			wpa_sm_add_pmkid(sm, candidate->bssid, p->pmkid);
+	wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: no more pending PMKSA "
+		"candidates");
+ * pmksa_candidate_add - Add a new PMKSA candidate
+ * @bssid: BSSID (authenticator address) of the candidate
+ * @prio: Priority (the smaller number, the higher priority)
+ * @preauth: Whether the candidate AP advertises support for pre-authentication
+ * This function is used to add PMKSA candidates for RSN pre-authentication. It
+ * is called from scan result processing and from driver events for PMKSA
+ * candidates, i.e., EVENT_PMKID_CANDIDATE events to wpa_supplicant_event().
+void pmksa_candidate_add(struct wpa_sm *sm, const u8 *bssid,
+			 int prio, int preauth)
+	struct rsn_pmksa_candidate *cand, *pos;
+	if (sm->network_ctx && sm->proactive_key_caching)
+		pmksa_cache_get_opportunistic(sm->pmksa, sm->network_ctx,
+					      bssid);
+	if (!preauth) {
+		wpa_printf(MSG_DEBUG, "RSN: Ignored PMKID candidate without "
+			   "preauth flag");
+		return;
+	/* If BSSID already on candidate list, update the priority of the old
+	 * entry. Do not override priority based on normal scan results. */
+	cand = NULL;
+	dl_list_for_each(pos, &sm->pmksa_candidates,
+		if (os_memcmp(pos->bssid, bssid, ETH_ALEN) == 0) {
+			cand = pos;
+			break;
+	if (cand) {
+		dl_list_del(&cand->list);
+		if (prio < PMKID_CANDIDATE_PRIO_SCAN)
+			cand->priority = prio;
+	} else {
+		cand = os_zalloc(sizeof(*cand));
+		if (cand == NULL)
+			return;
+		os_memcpy(cand->bssid, bssid, ETH_ALEN);
+	/* Add candidate to the list; order by increasing priority value. i.e.,
+	 * highest priority (smallest value) first. */
+		if (cand->priority <= pos->priority) {
+			if (!pos->list.prev) {
+				 * This cannot really happen in pracrice since
+				 * pos was fetched from the list and the prev
+				 * pointer must be set. It looks like clang
+				 * static analyzer gets confused with the
+				 * dl_list_del(&cand->list) call above and ends
+				 * up assuming pos->list.prev could be NULL.
+				os_free(cand);
+				return;
+			dl_list_add(pos->list.prev, &cand->list);
+			cand = NULL;
+			break;
+	if (cand)
+		dl_list_add_tail(&sm->pmksa_candidates, &cand->list);
+	wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: added PMKSA cache "
+		"candidate " MACSTR " prio %d", MAC2STR(bssid), prio);
+/* TODO: schedule periodic scans if current AP supports preauth */
+ * rsn_preauth_scan_results - Start processing scan results for canditates
+ * Returns: 0 if ready to process results or -1 to skip processing
+ * This functions is used to notify RSN code about start of new scan results
+ * processing. The actual scan results will be provided by calling
+ * rsn_preauth_scan_result() for each BSS if this function returned 0.
+int rsn_preauth_scan_results(struct wpa_sm *sm)
+	if (sm->ssid_len == 0)
+		return -1;
+	 * TODO: is it ok to free all candidates? What about the entries
+	 * received from EVENT_PMKID_CANDIDATE?
+	pmksa_candidate_free(sm);
+	return 0;
+ * rsn_preauth_scan_result - Processing scan result for PMKSA canditates
+ * Add all suitable APs (Authenticators) from scan results into PMKSA
+ * candidate list.
+void rsn_preauth_scan_result(struct wpa_sm *sm, const u8 *bssid,
+			     const u8 *ssid, const u8 *rsn)
+	if (ssid[1] != sm->ssid_len ||
+	    os_memcmp(ssid + 2, sm->ssid, sm->ssid_len) != 0)
+		return; /* Not for the current SSID */
+	if (os_memcmp(bssid, sm->bssid, ETH_ALEN) == 0)
+		return; /* Ignore current AP */
+	if (wpa_parse_wpa_ie(rsn, 2 + rsn[1], &ie))
+		return;
+	pmksa = pmksa_cache_get(sm->pmksa, bssid, NULL, NULL);
+	if (pmksa && (!pmksa->opportunistic ||
+		      !(ie.capabilities & WPA_CAPABILITY_PREAUTH)))
+		return;
+	/* Give less priority to candidates found from normal scan results. */
+	pmksa_candidate_add(sm, bssid, PMKID_CANDIDATE_PRIO_SCAN,
+			    ie.capabilities & WPA_CAPABILITY_PREAUTH);
+#ifdef CONFIG_CTRL_IFACE
+ * rsn_preauth_get_status - Get pre-authentication status
+ * @buf: Buffer for status information
+ * @buflen: Maximum buffer length
+ * @verbose: Whether to include verbose status information
+ * Returns: Number of bytes written to buf.
+ * Query WPA2 pre-authentication for status information. This function fills in
+ * a text area with current status information. If the buffer (buf) is not
+ * large enough, status information will be truncated to fit the buffer.
+int rsn_preauth_get_status(struct wpa_sm *sm, char *buf, size_t buflen,
+			   int verbose)
+	char *pos = buf, *end = buf + buflen;
+	int res, ret;
+	if (sm->preauth_eapol) {
+		ret = os_snprintf(pos, end - pos, "Pre-authentication "
+				  "EAPOL state machines:\n");
+		if (os_snprintf_error(end - pos, ret))
+			return pos - buf;
+		pos += ret;
+		res = eapol_sm_get_status(sm->preauth_eapol,
+					  pos, end - pos, verbose);
+		if (res >= 0)
+			pos += res;
+	return pos - buf;
+#endif /* CONFIG_CTRL_IFACE */
+ * rsn_preauth_in_progress - Verify whether pre-authentication is in progress
+int rsn_preauth_in_progress(struct wpa_sm *sm)
+	return sm->preauth_eapol != NULL;
diff --git a/freebsd/contrib/wpa/src/rsn_supp/preauth.h b/freebsd/contrib/wpa/src/rsn_supp/preauth.h
index 00000000000..277f0663b0f
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/preauth.h
@@ -0,0 +1,79 @@
+ * wpa_supplicant - WPA2/RSN pre-authentication functions
+ * Copyright (c) 2003-2009, Jouni Malinen <j at w1.fi>
+#ifndef PREAUTH_H
+#define PREAUTH_H
+struct wpa_scan_results;
+void pmksa_candidate_free(struct wpa_sm *sm);
+		     struct eap_peer_config *eap_conf);
+void rsn_preauth_deinit(struct wpa_sm *sm);
+int rsn_preauth_scan_results(struct wpa_sm *sm);
+			     const u8 *ssid, const u8 *rsn);
+			 int prio, int preauth);
+void rsn_preauth_candidate_process(struct wpa_sm *sm);
+			   int verbose);
+int rsn_preauth_in_progress(struct wpa_sm *sm);
+static inline void pmksa_candidate_free(struct wpa_sm *sm)
+static inline void rsn_preauth_candidate_process(struct wpa_sm *sm)
+static inline int rsn_preauth_init(struct wpa_sm *sm, const u8 *dst,
+	return -1;
+static inline void rsn_preauth_deinit(struct wpa_sm *sm)
+static inline int rsn_preauth_scan_results(struct wpa_sm *sm)
+	return -1;
+static inline void rsn_preauth_scan_result(struct wpa_sm *sm, const u8 *bssid,
+static inline void pmksa_candidate_add(struct wpa_sm *sm,
+				       const u8 *bssid,
+static inline int rsn_preauth_get_status(struct wpa_sm *sm, char *buf,
+					 size_t buflen, int verbose)
+	return 0;
+static inline int rsn_preauth_in_progress(struct wpa_sm *sm)
+	return 0;
+#endif /* PREAUTH_H */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa.c b/freebsd/contrib/wpa/src/rsn_supp/wpa.c
index 00000000000..a738c986446
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa.c
@@ -0,0 +1,2979 @@
+ * WPA Supplicant - WPA state machine and EAPOL-Key processing
+#include "crypto/aes_wrap.h"
+#include "crypto/crypto.h"
+#include "wpa.h"
+#include "eloop.h"
+#include "wpa_i.h"
+ * wpa_eapol_key_send - Send WPA/RSN EAPOL-Key message
+ * @kck: Key Confirmation Key (KCK, part of PTK)
+ * @kck_len: KCK length in octets
+ * @ver: Version field from Key Info
+ * @dest: Destination address for the frame
+ * @proto: Ethertype (usually ETH_P_EAPOL)
+ * @msg: EAPOL-Key message
+ * @msg_len: Length of message
+ * @key_mic: Pointer to the buffer to which the EAPOL-Key MIC is written
+void wpa_eapol_key_send(struct wpa_sm *sm, const u8 *kck, size_t kck_len,
+			int ver, const u8 *dest, u16 proto,
+			u8 *msg, size_t msg_len, u8 *key_mic)
+	size_t mic_len = wpa_mic_len(sm->key_mgmt);
+	if (is_zero_ether_addr(dest) && is_zero_ether_addr(sm->bssid)) {
+		 * Association event was not yet received; try to fetch
+		 * BSSID from the driver.
+		if (wpa_sm_get_bssid(sm, sm->bssid) < 0) {
+			wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG,
+				"WPA: Failed to read BSSID for "
+				"EAPOL-Key destination address");
+		} else {
+			dest = sm->bssid;
+				"WPA: Use BSSID (" MACSTR
+				") as the destination for EAPOL-Key",
+				MAC2STR(dest));
+	if (key_mic &&
+	    wpa_eapol_key_mic(kck, kck_len, sm->key_mgmt, ver, msg, msg_len,
+			      key_mic)) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_ERROR,
+			"WPA: Failed to generate EAPOL-Key version %d key_mgmt 0x%x MIC",
+			ver, sm->key_mgmt);
+		goto out;
+	wpa_hexdump_key(MSG_DEBUG, "WPA: KCK", kck, kck_len);
+	wpa_hexdump(MSG_DEBUG, "WPA: Derived Key MIC", key_mic, mic_len);
+	wpa_hexdump(MSG_MSGDUMP, "WPA: TX EAPOL-Key", msg, msg_len);
+	wpa_sm_ether_send(sm, dest, proto, msg, msg_len);
+	eapol_sm_notify_tx_eapol_key(sm->eapol);
+out:
+	os_free(msg);
+ * wpa_sm_key_request - Send EAPOL-Key Request
+ * @error: Indicate whether this is an Michael MIC error report
+ * @pairwise: 1 = error report for pairwise packet, 0 = for group packet
+ * Send an EAPOL-Key Request to the current authenticator. This function is
+ * used to request rekeying and it is usually called when a local Michael MIC
+ * failure is detected.
+void wpa_sm_key_request(struct wpa_sm *sm, int error, int pairwise)
+	size_t mic_len, hdrlen, rlen;
+	u8 bssid[ETH_ALEN], *rbuf, *key_mic;
+	if (sm->key_mgmt == WPA_KEY_MGMT_OSEN ||
+	    wpa_key_mgmt_suite_b(sm->key_mgmt))
+		ver = WPA_KEY_INFO_TYPE_AKM_DEFINED;
+	else if (wpa_key_mgmt_ft(sm->key_mgmt) ||
+		 wpa_key_mgmt_sha256(sm->key_mgmt))
+		ver = WPA_KEY_INFO_TYPE_AES_128_CMAC;
+	else if (sm->pairwise_cipher != WPA_CIPHER_TKIP)
+	else
+			"Failed to read BSSID for EAPOL-Key request");
+		return;
+	mic_len = wpa_mic_len(sm->key_mgmt);
+	hdrlen = mic_len == 24 ? sizeof(*reply192) : sizeof(*reply);
+				  hdrlen, &rlen, (void *) &reply);
+	if (rbuf == NULL)
+		return;
+	reply->type = (sm->proto == WPA_PROTO_RSN ||
+		       sm->proto == WPA_PROTO_OSEN) ?
+		EAPOL_KEY_TYPE_RSN : EAPOL_KEY_TYPE_WPA;
+	key_info = WPA_KEY_INFO_REQUEST | ver;
+	if (sm->ptk_set)
+		key_info |= WPA_KEY_INFO_MIC;
+	if (error)
+		key_info |= WPA_KEY_INFO_ERROR;
+	if (pairwise)
+		key_info |= WPA_KEY_INFO_KEY_TYPE;
+	os_memcpy(reply->replay_counter, sm->request_counter,
+		  WPA_REPLAY_COUNTER_LEN);
+	inc_byte_array(sm->request_counter, WPA_REPLAY_COUNTER_LEN);
+	if (mic_len == 24)
+		WPA_PUT_BE16(reply192->key_data_length, 0);
+	else
+		WPA_PUT_BE16(reply->key_data_length, 0);
+	if (!(key_info & WPA_KEY_INFO_MIC))
+		key_mic = NULL;
+	else
+		key_mic = reply192->key_mic; /* same offset in reply */
+		"WPA: Sending EAPOL-Key Request (error=%d "
+		"pairwise=%d ptk_set=%d len=%lu)",
+		error, pairwise, sm->ptk_set, (unsigned long) rlen);
+			   ETH_P_EAPOL, rbuf, rlen, key_mic);
+static void wpa_supplicant_key_mgmt_set_pmk(struct wpa_sm *sm)
+#ifdef CONFIG_IEEE80211R
+	if (sm->key_mgmt == WPA_KEY_MGMT_FT_IEEE8021X) {
+		if (wpa_sm_key_mgmt_set_pmk(sm, sm->xxkey, sm->xxkey_len))
+				"RSN: Cannot set low order 256 bits of MSK for key management offload");
+	} else {
+#endif /* CONFIG_IEEE80211R */
+		if (wpa_sm_key_mgmt_set_pmk(sm, sm->pmk, sm->pmk_len))
+				"RSN: Cannot set PMK for key management offload");
+static int wpa_supplicant_get_pmk(struct wpa_sm *sm,
+				  const unsigned char *src_addr,
+				  const u8 *pmkid)
+	int abort_cached = 0;
+	if (pmkid && !sm->cur_pmksa) {
+		/* When using drivers that generate RSN IE, wpa_supplicant may
+		 * not have enough time to get the association information
+		 * event before receiving this 1/4 message, so try to find a
+		 * matching PMKSA cache entry here. */
+		sm->cur_pmksa = pmksa_cache_get(sm->pmksa, src_addr, pmkid,
+						NULL);
+				"RSN: found matching PMKID from PMKSA cache");
+		} else {
+				"RSN: no matching PMKID found");
+			abort_cached = 1;
+	if (pmkid && sm->cur_pmksa &&
+	    os_memcmp_const(pmkid, sm->cur_pmksa->pmkid, PMKID_LEN) == 0) {
+		wpa_hexdump(MSG_DEBUG, "RSN: matched PMKID", pmkid, PMKID_LEN);
+		wpa_sm_set_pmk_from_pmksa(sm);
+		wpa_hexdump_key(MSG_DEBUG, "RSN: PMK from PMKSA cache",
+				sm->pmk, sm->pmk_len);
+		eapol_sm_notify_cached(sm->eapol);
+		sm->xxkey_len = 0;
+	} else if (wpa_key_mgmt_wpa_ieee8021x(sm->key_mgmt) && sm->eapol) {
+		int res, pmk_len;
+		res = eapol_sm_get_key(sm->eapol, sm->pmk, PMK_LEN);
+		if (res) {
+			res = eapol_sm_get_key(sm->eapol, sm->pmk, 16);
+			pmk_len = 16;
+		} else {
+			u8 buf[2 * PMK_LEN];
+			if (eapol_sm_get_key(sm->eapol, buf, 2 * PMK_LEN) == 0)
+				os_memcpy(sm->xxkey, buf + PMK_LEN, PMK_LEN);
+				sm->xxkey_len = PMK_LEN;
+				os_memset(buf, 0, sizeof(buf));
+		if (res == 0) {
+			struct rsn_pmksa_cache_entry *sa = NULL;
+			wpa_hexdump_key(MSG_DEBUG, "WPA: PMK from EAPOL state "
+					"machines", sm->pmk, pmk_len);
+			wpa_supplicant_key_mgmt_set_pmk(sm);
+			if (sm->proto == WPA_PROTO_RSN &&
+			    !wpa_key_mgmt_suite_b(sm->key_mgmt) &&
+			    !wpa_key_mgmt_ft(sm->key_mgmt)) {
+				sa = pmksa_cache_add(sm->pmksa,
+						     sm->pmk, pmk_len,
+						     NULL, 0,
+						     src_addr, sm->own_addr,
+						     sm->network_ctx,
+						     sm->key_mgmt);
+			if (!sm->cur_pmksa && pmkid &&
+			    pmksa_cache_get(sm->pmksa, src_addr, pmkid, NULL))
+					"RSN: the new PMK matches with the "
+					"PMKID");
+				abort_cached = 0;
+			} else if (sa && !sm->cur_pmksa && pmkid) {
+				 * It looks like the authentication server
+				 * derived mismatching MSK. This should not
+				 * really happen, but bugs happen.. There is not
+				 * much we can do here without knowing what
+				 * exactly caused the server to misbehave.
+				wpa_dbg(sm->ctx->msg_ctx, MSG_INFO,
+					"RSN: PMKID mismatch - authentication server may have derived different MSK?!");
+				return -1;
+			if (!sm->cur_pmksa)
+				sm->cur_pmksa = sa;
+		} else {
+				"WPA: Failed to get master session key from "
+				"EAPOL state machines - key handshake "
+				"aborted");
+					"RSN: Cancelled PMKSA caching "
+					"attempt");
+				abort_cached = 1;
+			} else if (!abort_cached) {
+				return -1;
+	if (abort_cached && wpa_key_mgmt_wpa_ieee8021x(sm->key_mgmt) &&
+	    !wpa_key_mgmt_ft(sm->key_mgmt) && sm->key_mgmt != WPA_KEY_MGMT_OSEN)
+		/* Send EAPOL-Start to trigger full EAP authentication. */
+		u8 *buf;
+		size_t buflen;
+			"RSN: no PMKSA entry found - trigger "
+			"full EAP authentication");
+		buf = wpa_sm_alloc_eapol(sm, IEEE802_1X_TYPE_EAPOL_START,
+					 NULL, 0, &buflen, NULL);
+		if (buf) {
+			wpa_sm_ether_send(sm, sm->bssid, ETH_P_EAPOL,
+					  buf, buflen);
+			os_free(buf);
+			return -2;
+		return -1;
+	return 0;
+ * wpa_supplicant_send_2_of_4 - Send message 2 of WPA/RSN 4-Way Handshake
+ * @dst: Destination address for the frame
+ * @nonce: Nonce value for the EAPOL-Key frame
+ * @wpa_ie: WPA/RSN IE
+ * @wpa_ie_len: Length of the WPA/RSN IE
+ * @ptk: PTK to use for keyed hash and encryption
+int wpa_supplicant_send_2_of_4(struct wpa_sm *sm, const unsigned char *dst,
+			       int ver, const u8 *nonce,
+			       const u8 *wpa_ie, size_t wpa_ie_len,
+			       struct wpa_ptk *ptk)
+	struct wpa_eapol_key *reply;
+	struct wpa_eapol_key_192 *reply192;
+	u8 *rbuf, *key_mic;
+	u8 *rsn_ie_buf = NULL;
+	if (wpa_ie == NULL) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_WARNING, "WPA: No wpa_ie set - "
+			"cannot generate msg 2/4");
+		return -1;
+	if (wpa_key_mgmt_ft(sm->key_mgmt)) {
+		int res;
+		 * Add PMKR1Name into RSN IE (PMKID-List) and add MDIE and
+		 * FTIE from (Re)Association Response.
+		rsn_ie_buf = os_malloc(wpa_ie_len + 2 + 2 + PMKID_LEN +
+				       sm->assoc_resp_ies_len);
+		if (rsn_ie_buf == NULL)
+			return -1;
+		os_memcpy(rsn_ie_buf, wpa_ie, wpa_ie_len);
+		res = wpa_insert_pmkid(rsn_ie_buf, wpa_ie_len,
+				       sm->pmk_r1_name);
+		if (res < 0) {
+			os_free(rsn_ie_buf);
+			return -1;
+		wpa_ie_len += res;
+		if (sm->assoc_resp_ies) {
+			os_memcpy(rsn_ie_buf + wpa_ie_len, sm->assoc_resp_ies,
+			wpa_ie_len += sm->assoc_resp_ies_len;
+		wpa_ie = rsn_ie_buf;
+	wpa_hexdump(MSG_DEBUG, "WPA: WPA IE for msg 2/4", wpa_ie, wpa_ie_len);
+				  NULL, hdrlen + wpa_ie_len,
+				  &rlen, (void *) &reply);
+		return -1;
+	reply192 = (struct wpa_eapol_key_192 *) reply;
+	WPA_PUT_BE16(reply->key_info,
+		     ver | WPA_KEY_INFO_KEY_TYPE | WPA_KEY_INFO_MIC);
+	if (sm->proto == WPA_PROTO_RSN || sm->proto == WPA_PROTO_OSEN)
+		WPA_PUT_BE16(reply->key_length, 0);
+	else
+		os_memcpy(reply->key_length, key->key_length, 2);
+	os_memcpy(reply->replay_counter, key->replay_counter,
+	wpa_hexdump(MSG_DEBUG, "WPA: Replay Counter", reply->replay_counter,
+	key_mic = reply192->key_mic; /* same offset for reply and reply192 */
+	if (mic_len == 24) {
+		WPA_PUT_BE16(reply192->key_data_length, wpa_ie_len);
+		os_memcpy(reply192 + 1, wpa_ie, wpa_ie_len);
+	} else {
+		WPA_PUT_BE16(reply->key_data_length, wpa_ie_len);
+		os_memcpy(reply + 1, wpa_ie, wpa_ie_len);
+	os_memcpy(reply->key_nonce, nonce, WPA_NONCE_LEN);
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Sending EAPOL-Key 2/4");
+	wpa_eapol_key_send(sm, ptk->kck, ptk->kck_len, ver, dst, ETH_P_EAPOL,
+			   rbuf, rlen, key_mic);
+	return 0;
+static int wpa_derive_ptk(struct wpa_sm *sm, const unsigned char *src_addr,
+			  const struct wpa_eapol_key *key, struct wpa_ptk *ptk)
+		return wpa_derive_ptk_ft(sm, src_addr, key, ptk);
+	return wpa_pmk_to_ptk(sm->pmk, sm->pmk_len, "Pairwise key expansion",
+			      sm->own_addr, sm->bssid, sm->snonce,
+			      key->key_nonce, ptk, sm->key_mgmt,
+			      sm->pairwise_cipher);
+static void wpa_supplicant_process_1_of_4(struct wpa_sm *sm,
+	struct wpa_ptk *ptk;
+	int res;
+	u8 *kde, *kde_buf = NULL;
+	size_t kde_len;
+	if (wpa_sm_get_network_ctx(sm) == NULL) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_WARNING, "WPA: No SSID info "
+			"found (msg 1 of 4)");
+		return;
+	wpa_sm_set_state(sm, WPA_4WAY_HANDSHAKE);
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: RX message 1 of 4-Way "
+		"Handshake from " MACSTR " (ver=%d)", MAC2STR(src_addr), ver);
+	if (sm->proto == WPA_PROTO_RSN || sm->proto == WPA_PROTO_OSEN) {
+		/* RSN: msg 1/4 should contain PMKID for the selected PMK */
+		if (wpa_supplicant_parse_ies(key_data, key_data_len, &ie) < 0)
+			goto failed;
+		if (ie.pmkid) {
+			wpa_hexdump(MSG_DEBUG, "RSN: PMKID from "
+				    "Authenticator", ie.pmkid, PMKID_LEN);
+	res = wpa_supplicant_get_pmk(sm, src_addr, ie.pmkid);
+	if (res == -2) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: Do not reply to "
+			"msg 1/4 - requesting full EAP authentication");
+		return;
+	if (res)
+		goto failed;
+	if (sm->renew_snonce) {
+		if (random_get_bytes(sm->snonce, WPA_NONCE_LEN)) {
+				"WPA: Failed to get random data for SNonce");
+			goto failed;
+		sm->renew_snonce = 0;
+		wpa_hexdump(MSG_DEBUG, "WPA: Renewed SNonce",
+			    sm->snonce, WPA_NONCE_LEN);
+	/* Calculate PTK which will be stored as a temporary PTK until it has
+	ptk = &sm->tptk;
+	wpa_derive_ptk(sm, src_addr, key, ptk);
+	if (sm->pairwise_cipher == WPA_CIPHER_TKIP) {
+		u8 buf[8];
+		os_memcpy(buf, &ptk->tk[16], 8);
+		os_memcpy(&ptk->tk[16], &ptk->tk[24], 8);
+		os_memcpy(&ptk->tk[24], buf, 8);
+	sm->tptk_set = 1;
+	kde = sm->assoc_wpa_ie;
+	kde_len = sm->assoc_wpa_ie_len;
+#ifdef CONFIG_P2P
+	if (sm->p2p) {
+		kde_buf = os_malloc(kde_len + 2 + RSN_SELECTOR_LEN + 1);
+		if (kde_buf) {
+			u8 *pos;
+			wpa_printf(MSG_DEBUG, "P2P: Add IP Address Request KDE "
+				   "into EAPOL-Key 2/4");
+			os_memcpy(kde_buf, kde, kde_len);
+			kde = kde_buf;
+			pos = kde + kde_len;
+			*pos++ = WLAN_EID_VENDOR_SPECIFIC;
+			*pos++ = RSN_SELECTOR_LEN + 1;
+			RSN_SELECTOR_PUT(pos, WFA_KEY_DATA_IP_ADDR_REQ);
+			pos += RSN_SELECTOR_LEN;
+			*pos++ = 0x01;
+			kde_len = pos - kde;
+#endif /* CONFIG_P2P */
+	if (wpa_supplicant_send_2_of_4(sm, sm->bssid, key, ver, sm->snonce,
+				       kde, kde_len, ptk))
+		goto failed;
+	os_free(kde_buf);
+	os_memcpy(sm->anonce, key->key_nonce, WPA_NONCE_LEN);
+	return;
+failed:
+	os_free(kde_buf);
+	wpa_sm_deauthenticate(sm, WLAN_REASON_UNSPECIFIED);
+static void wpa_sm_start_preauth(void *eloop_ctx, void *timeout_ctx)
+	struct wpa_sm *sm = eloop_ctx;
+static void wpa_supplicant_key_neg_complete(struct wpa_sm *sm,
+					    const u8 *addr, int secure)
+		"WPA: Key negotiation completed with "
+		MACSTR " [PTK=%s GTK=%s]", MAC2STR(addr),
+		wpa_cipher_txt(sm->pairwise_cipher),
+		wpa_cipher_txt(sm->group_cipher));
+	wpa_sm_cancel_auth_timeout(sm);
+	wpa_sm_set_state(sm, WPA_COMPLETED);
+	if (secure) {
+		wpa_sm_mlme_setprotection(
+			sm, addr, MLME_SETPROTECTION_PROTECT_TYPE_RX_TX,
+			MLME_SETPROTECTION_KEY_TYPE_PAIRWISE);
+		eapol_sm_notify_portValid(sm->eapol, TRUE);
+		if (wpa_key_mgmt_wpa_psk(sm->key_mgmt))
+			eapol_sm_notify_eap_success(sm->eapol, TRUE);
+		 * Start preauthentication after a short wait to avoid a
+		 * possible race condition between the data receive and key
+		 * configuration after the 4-Way Handshake. This increases the
+		 * likelihood of the first preauth EAPOL-Start frame getting to
+		 * the target AP.
+		eloop_register_timeout(1, 0, wpa_sm_start_preauth, sm, NULL);
+	if (sm->cur_pmksa && sm->cur_pmksa->opportunistic) {
+			"RSN: Authenticator accepted "
+			"opportunistic PMKSA entry - marking it valid");
+		sm->cur_pmksa->opportunistic = 0;
+		/* Prepare for the next transition */
+		wpa_ft_prepare_auth_request(sm, NULL);
+static void wpa_sm_rekey_ptk(void *eloop_ctx, void *timeout_ctx)
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Request PTK rekeying");
+	wpa_sm_key_request(sm, 0, 1);
+static int wpa_supplicant_install_ptk(struct wpa_sm *sm,
+				      const struct wpa_eapol_key *key)
+	int keylen, rsclen;
+	enum wpa_alg alg;
+	const u8 *key_rsc;
+	u8 null_rsc[8] = { 0, 0, 0, 0, 0, 0, 0, 0 };
+		"WPA: Installing PTK to the driver");
+	if (sm->pairwise_cipher == WPA_CIPHER_NONE) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Pairwise Cipher "
+			"Suite: NONE - do not use pairwise keys");
+		return 0;
+	if (!wpa_cipher_valid_pairwise(sm->pairwise_cipher)) {
+			"WPA: Unsupported pairwise cipher %d",
+		return -1;
+	alg = wpa_cipher_to_alg(sm->pairwise_cipher);
+	keylen = wpa_cipher_key_len(sm->pairwise_cipher);
+	rsclen = wpa_cipher_rsc_len(sm->pairwise_cipher);
+		key_rsc = null_rsc;
+	} else {
+		key_rsc = key->key_rsc;
+		wpa_hexdump(MSG_DEBUG, "WPA: RSC", key_rsc, rsclen);
+	if (wpa_sm_set_key(sm, alg, sm->bssid, 0, 1, key_rsc, rsclen,
+			   sm->ptk.tk, keylen) < 0) {
+			"WPA: Failed to set PTK to the "
+			"driver (alg=%d keylen=%d bssid=" MACSTR ")",
+			alg, keylen, MAC2STR(sm->bssid));
+		return -1;
+	/* TK is not needed anymore in supplicant */
+	os_memset(sm->ptk.tk, 0, WPA_TK_MAX_LEN);
+	if (sm->wpa_ptk_rekey) {
+		eloop_cancel_timeout(wpa_sm_rekey_ptk, sm, NULL);
+		eloop_register_timeout(sm->wpa_ptk_rekey, 0, wpa_sm_rekey_ptk,
+				       sm, NULL);
+	return 0;
+static int wpa_supplicant_check_group_cipher(struct wpa_sm *sm,
+					     int group_cipher,
+					     int keylen, int maxkeylen,
+					     int *key_rsc_len,
+					     enum wpa_alg *alg)
+	int klen;
+	*alg = wpa_cipher_to_alg(group_cipher);
+	if (*alg == WPA_ALG_NONE) {
+			"WPA: Unsupported Group Cipher %d",
+			group_cipher);
+		return -1;
+	*key_rsc_len = wpa_cipher_rsc_len(group_cipher);
+	klen = wpa_cipher_key_len(group_cipher);
+	if (keylen != klen || maxkeylen < klen) {
+			"WPA: Unsupported %s Group Cipher key length %d (%d)",
+			wpa_cipher_txt(group_cipher), keylen, maxkeylen);
+		return -1;
+	return 0;
+struct wpa_gtk_data {
+	enum wpa_alg alg;
+	int tx, key_rsc_len, keyidx;
+	u8 gtk[32];
+	int gtk_len;
+static int wpa_supplicant_install_gtk(struct wpa_sm *sm,
+				      const struct wpa_gtk_data *gd,
+				      const u8 *key_rsc)
+	const u8 *_gtk = gd->gtk;
+	u8 gtk_buf[32];
+	wpa_hexdump_key(MSG_DEBUG, "WPA: Group Key", gd->gtk, gd->gtk_len);
+		"WPA: Installing GTK to the driver (keyidx=%d tx=%d len=%d)",
+		gd->keyidx, gd->tx, gd->gtk_len);
+	wpa_hexdump(MSG_DEBUG, "WPA: RSC", key_rsc, gd->key_rsc_len);
+	if (sm->group_cipher == WPA_CIPHER_TKIP) {
+		os_memcpy(gtk_buf, gd->gtk, 16);
+		os_memcpy(gtk_buf + 16, gd->gtk + 24, 8);
+		os_memcpy(gtk_buf + 24, gd->gtk + 16, 8);
+		_gtk = gtk_buf;
+		if (wpa_sm_set_key(sm, gd->alg, NULL,
+				   gd->keyidx, 1, key_rsc, gd->key_rsc_len,
+				   _gtk, gd->gtk_len) < 0) {
+				"WPA: Failed to set GTK to the driver "
+				"(Group only)");
+			os_memset(gtk_buf, 0, sizeof(gtk_buf));
+			return -1;
+	} else if (wpa_sm_set_key(sm, gd->alg, broadcast_ether_addr,
+				  gd->keyidx, gd->tx, key_rsc, gd->key_rsc_len,
+			"WPA: Failed to set GTK to "
+			"the driver (alg=%d keylen=%d keyidx=%d)",
+			gd->alg, gd->gtk_len, gd->keyidx);
+		return -1;
+	return 0;
+static int wpa_supplicant_gtk_tx_bit_workaround(const struct wpa_sm *sm,
+						int tx)
+	if (tx && sm->pairwise_cipher != WPA_CIPHER_NONE) {
+		/* Ignore Tx bit for GTK if a pairwise key is used. One AP
+		 * seemed to set this bit (incorrectly, since Tx is only when
+		 * doing Group Key only APs) and without this workaround, the
+		 * data connection does not work because wpa_supplicant
+		 * configured non-zero keyidx to be used for unicast. */
+			"WPA: Tx bit set for GTK, but pairwise "
+			"keys are used - ignore Tx bit");
+		return 0;
+	return tx;
+static int wpa_supplicant_pairwise_gtk(struct wpa_sm *sm,
+				       const u8 *gtk, size_t gtk_len,
+				       int key_info)
+	struct wpa_gtk_data gd;
+	 * IEEE Std 802.11i-2004 - 8.5.2 EAPOL-Key frames - Figure 43x
+	 * GTK KDE format:
+	 * KeyID[bits 0-1], Tx [bit 2], Reserved [bits 3-7]
+	 * Reserved [bits 0-7]
+	 * GTK
+	os_memset(&gd, 0, sizeof(gd));
+	wpa_hexdump_key(MSG_DEBUG, "RSN: received GTK in pairwise handshake",
+			gtk, gtk_len);
+	if (gtk_len < 2 || gtk_len - 2 > sizeof(gd.gtk))
+		return -1;
+	gd.keyidx = gtk[0] & 0x3;
+	gd.tx = wpa_supplicant_gtk_tx_bit_workaround(sm,
+						     !!(gtk[0] & BIT(2)));
+	gtk += 2;
+	gtk_len -= 2;
+	os_memcpy(gd.gtk, gtk, gtk_len);
+	gd.gtk_len = gtk_len;
+	if (sm->group_cipher != WPA_CIPHER_GTK_NOT_USED &&
+	    (wpa_supplicant_check_group_cipher(sm, sm->group_cipher,
+					       gtk_len, gtk_len,
+					       &gd.key_rsc_len, &gd.alg) ||
+	     wpa_supplicant_install_gtk(sm, &gd, key->key_rsc))) {
+			"RSN: Failed to install GTK");
+		return -1;
+	wpa_supplicant_key_neg_complete(sm, sm->bssid,
+					key_info & WPA_KEY_INFO_SECURE);
+	return 0;
+static int ieee80211w_set_keys(struct wpa_sm *sm,
+			       struct wpa_eapol_ie_parse *ie)
+#ifdef CONFIG_IEEE80211W
+	if (!wpa_cipher_valid_mgmt_group(sm->mgmt_group_cipher))
+		return 0;
+	if (ie->igtk) {
+		size_t len;
+		const struct wpa_igtk_kde *igtk;
+		u16 keyidx;
+		len = wpa_cipher_key_len(sm->mgmt_group_cipher);
+		if (ie->igtk_len != WPA_IGTK_KDE_PREFIX_LEN + len)
+			return -1;
+		igtk = (const struct wpa_igtk_kde *) ie->igtk;
+		keyidx = WPA_GET_LE16(igtk->keyid);
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: IGTK keyid %d "
+			"pn %02x%02x%02x%02x%02x%02x",
+			keyidx, MAC2STR(igtk->pn));
+		wpa_hexdump_key(MSG_DEBUG, "WPA: IGTK",
+				igtk->igtk, len);
+		if (keyidx > 4095) {
+				"WPA: Invalid IGTK KeyID %d", keyidx);
+			return -1;
+		if (wpa_sm_set_key(sm, wpa_cipher_to_alg(sm->mgmt_group_cipher),
+				   broadcast_ether_addr,
+				   keyidx, 0, igtk->pn, sizeof(igtk->pn),
+				   igtk->igtk, len) < 0) {
+				"WPA: Failed to configure IGTK to the driver");
+			return -1;
+	return 0;
+#else /* CONFIG_IEEE80211W */
+	return 0;
+#endif /* CONFIG_IEEE80211W */
+static void wpa_report_ie_mismatch(struct wpa_sm *sm,
+				   const char *reason, const u8 *src_addr,
+				   const u8 *rsn_ie, size_t rsn_ie_len)
+	wpa_msg(sm->ctx->msg_ctx, MSG_WARNING, "WPA: %s (src=" MACSTR ")",
+		reason, MAC2STR(src_addr));
+	if (sm->ap_wpa_ie) {
+		wpa_hexdump(MSG_INFO, "WPA: WPA IE in Beacon/ProbeResp",
+			    sm->ap_wpa_ie, sm->ap_wpa_ie_len);
+	if (wpa_ie) {
+		if (!sm->ap_wpa_ie) {
+				"WPA: No WPA IE in Beacon/ProbeResp");
+		wpa_hexdump(MSG_INFO, "WPA: WPA IE in 3/4 msg",
+			    wpa_ie, wpa_ie_len);
+	if (sm->ap_rsn_ie) {
+		wpa_hexdump(MSG_INFO, "WPA: RSN IE in Beacon/ProbeResp",
+			    sm->ap_rsn_ie, sm->ap_rsn_ie_len);
+	if (rsn_ie) {
+		if (!sm->ap_rsn_ie) {
+				"WPA: No RSN IE in Beacon/ProbeResp");
+		wpa_hexdump(MSG_INFO, "WPA: RSN IE in 3/4 msg",
+			    rsn_ie, rsn_ie_len);
+	wpa_sm_deauthenticate(sm, WLAN_REASON_IE_IN_4WAY_DIFFERS);
+static int ft_validate_mdie(struct wpa_sm *sm,
+			    struct wpa_eapol_ie_parse *ie,
+			    const u8 *assoc_resp_mdie)
+	struct rsn_mdie *mdie;
+	mdie = (struct rsn_mdie *) (ie->mdie + 2);
+	if (ie->mdie == NULL || ie->mdie_len < 2 + sizeof(*mdie) ||
+	    os_memcmp(mdie->mobility_domain, sm->mobility_domain,
+		      MOBILITY_DOMAIN_ID_LEN) != 0) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "FT: MDIE in msg 3/4 did "
+			"not match with the current mobility domain");
+		return -1;
+	if (assoc_resp_mdie &&
+	    (assoc_resp_mdie[1] != ie->mdie[1] ||
+	     os_memcmp(assoc_resp_mdie, ie->mdie, 2 + ie->mdie[1]) != 0)) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "FT: MDIE mismatch");
+		wpa_hexdump(MSG_DEBUG, "FT: MDIE in EAPOL-Key msg 3/4",
+			    ie->mdie, 2 + ie->mdie[1]);
+		wpa_hexdump(MSG_DEBUG, "FT: MDIE in (Re)Association Response",
+			    assoc_resp_mdie, 2 + assoc_resp_mdie[1]);
+		return -1;
+	return 0;
+static int ft_validate_ftie(struct wpa_sm *sm,
+			    const u8 *assoc_resp_ftie)
+	if (ie->ftie == NULL) {
+			"FT: No FTIE in EAPOL-Key msg 3/4");
+		return -1;
+	if (assoc_resp_ftie == NULL)
+		return 0;
+	if (assoc_resp_ftie[1] != ie->ftie[1] ||
+	    os_memcmp(assoc_resp_ftie, ie->ftie, 2 + ie->ftie[1]) != 0) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "FT: FTIE mismatch");
+		wpa_hexdump(MSG_DEBUG, "FT: FTIE in EAPOL-Key msg 3/4",
+			    ie->ftie, 2 + ie->ftie[1]);
+		wpa_hexdump(MSG_DEBUG, "FT: FTIE in (Re)Association Response",
+			    assoc_resp_ftie, 2 + assoc_resp_ftie[1]);
+		return -1;
+	return 0;
+static int ft_validate_rsnie(struct wpa_sm *sm,
+	struct wpa_ie_data rsn;
+	if (!ie->rsn_ie)
+		return 0;
+	 * Verify that PMKR1Name from EAPOL-Key message 3/4
+	 * matches with the value we derived.
+	if (wpa_parse_wpa_ie_rsn(ie->rsn_ie, ie->rsn_ie_len, &rsn) < 0 ||
+	    rsn.num_pmkid != 1 || rsn.pmkid == NULL) {
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "FT: No PMKR1Name in "
+			"FT 4-way handshake message 3/4");
+		return -1;
+	if (os_memcmp_const(rsn.pmkid, sm->pmk_r1_name, WPA_PMK_NAME_LEN) != 0)
+			"FT: PMKR1Name mismatch in "
+		wpa_hexdump(MSG_DEBUG, "FT: PMKR1Name from Authenticator",
+			    rsn.pmkid, WPA_PMK_NAME_LEN);
+		wpa_hexdump(MSG_DEBUG, "FT: Derived PMKR1Name",
+			    sm->pmk_r1_name, WPA_PMK_NAME_LEN);
+		return -1;
+	return 0;
+static int wpa_supplicant_validate_ie_ft(struct wpa_sm *sm,
+	const u8 *pos, *end, *mdie = NULL, *ftie = NULL;
+		pos = sm->assoc_resp_ies;
+		end = pos + sm->assoc_resp_ies_len;
+		while (pos + 2 < end) {
+			if (pos + 2 + pos[1] > end)
+				break;
+			switch (*pos) {
+			case WLAN_EID_MOBILITY_DOMAIN:
+				mdie = pos;
+				break;
+			case WLAN_EID_FAST_BSS_TRANSITION:
+				ftie = pos;
+				break;
+			pos += 2 + pos[1];
+	if (ft_validate_mdie(sm, src_addr, ie, mdie) < 0 ||
+	    ft_validate_ftie(sm, src_addr, ie, ftie) < 0 ||
+	    ft_validate_rsnie(sm, src_addr, ie) < 0)
+		return -1;
+	return 0;
+static int wpa_supplicant_validate_ie(struct wpa_sm *sm,
+	if (sm->ap_wpa_ie == NULL && sm->ap_rsn_ie == NULL) {
+			"WPA: No WPA/RSN IE for this AP known. "
+			"Trying to get from scan results");
+		if (wpa_sm_get_beacon_ie(sm) < 0) {
+				"WPA: Could not find AP from "
+				"the scan results");
+		} else {
+				"WPA: Found the current AP from "
+				"updated scan results");
+	if (ie->wpa_ie == NULL && ie->rsn_ie == NULL &&
+	    (sm->ap_wpa_ie || sm->ap_rsn_ie)) {
+		wpa_report_ie_mismatch(sm, "IE in 3/4 msg does not match "
+				       "with IE in Beacon/ProbeResp (no IE?)",
+				       src_addr, ie->wpa_ie, ie->wpa_ie_len,
+				       ie->rsn_ie, ie->rsn_ie_len);
+		return -1;
+	if ((ie->wpa_ie && sm->ap_wpa_ie &&
+	     (ie->wpa_ie_len != sm->ap_wpa_ie_len ||
+	      os_memcmp(ie->wpa_ie, sm->ap_wpa_ie, ie->wpa_ie_len) != 0)) ||
+	    (ie->rsn_ie && sm->ap_rsn_ie &&
+	     wpa_compare_rsn_ie(wpa_key_mgmt_ft(sm->key_mgmt),
+				sm->ap_rsn_ie, sm->ap_rsn_ie_len,
+				ie->rsn_ie, ie->rsn_ie_len))) {
+				       "with IE in Beacon/ProbeResp",
+		return -1;
+	if (sm->proto == WPA_PROTO_WPA &&
+	    ie->rsn_ie && sm->ap_rsn_ie == NULL && sm->rsn_enabled) {
+		wpa_report_ie_mismatch(sm, "Possible downgrade attack "
+				       "detected - RSN was enabled and RSN IE "
+				       "was in msg 3/4, but not in "
+				       "Beacon/ProbeResp",
+		return -1;
+	if (wpa_key_mgmt_ft(sm->key_mgmt) &&
+	    wpa_supplicant_validate_ie_ft(sm, src_addr, ie) < 0)
+		return -1;
+	return 0;
+ * wpa_supplicant_send_4_of_4 - Send message 4 of WPA/RSN 4-Way Handshake
+ * @sm: Pointer to WPA state machine data from wpa_sm_init()
+ * @key: Pointer to the EAPOL-Key frame header
+ * @ver: Version bits from EAPOL-Key Key Info
+ * @key_info: Key Info
+ * Returns: 0 on success, -1 on failure
+int wpa_supplicant_send_4_of_4(struct wpa_sm *sm, const unsigned char *dst,
+			       u16 ver, u16 key_info,
+	if (rbuf == NULL)
+		return -1;
+	key_info &= WPA_KEY_INFO_SECURE;
+	key_info |= ver | WPA_KEY_INFO_KEY_TYPE | WPA_KEY_INFO_MIC;
+	WPA_PUT_BE16(reply->key_info, key_info);
+	else
+	else
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Sending EAPOL-Key 4/4");
+	return 0;
+static void wpa_supplicant_process_3_of_4(struct wpa_sm *sm,
+					  u16 ver, const u8 *key_data,
+					  size_t key_data_len)
+	u16 key_info, keylen;
+	struct wpa_eapol_ie_parse ie;
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: RX message 3 of 4-Way "
+		"Handshake from " MACSTR " (ver=%d)", MAC2STR(sm->bssid), ver);
+	key_info = WPA_GET_BE16(key->key_info);
+	wpa_hexdump(MSG_DEBUG, "WPA: IE KeyData", key_data, key_data_len);
+		goto failed;
+	if (ie.gtk && !(key_info & WPA_KEY_INFO_ENCR_KEY_DATA)) {
+			"WPA: GTK IE in unencrypted key data");
+		goto failed;
+	if (ie.igtk && !(key_info & WPA_KEY_INFO_ENCR_KEY_DATA)) {
+			"WPA: IGTK KDE in unencrypted key data");
+		goto failed;
+	if (ie.igtk &&
+	    wpa_cipher_valid_mgmt_group(sm->mgmt_group_cipher) &&
+	    ie.igtk_len != WPA_IGTK_KDE_PREFIX_LEN +
+	    (unsigned int) wpa_cipher_key_len(sm->mgmt_group_cipher)) {
+			"WPA: Invalid IGTK KDE length %lu",
+			(unsigned long) ie.igtk_len);
+		goto failed;
+	if (wpa_supplicant_validate_ie(sm, sm->bssid, &ie) < 0)
+		goto failed;
+	if (os_memcmp(sm->anonce, key->key_nonce, WPA_NONCE_LEN) != 0) {
+			"WPA: ANonce from message 1 of 4-Way Handshake "
+			"differs from 3 of 4-Way Handshake - drop packet (src="
+			MACSTR ")", MAC2STR(sm->bssid));
+		goto failed;
+	keylen = WPA_GET_BE16(key->key_length);
+	if (keylen != wpa_cipher_key_len(sm->pairwise_cipher)) {
+			"WPA: Invalid %s key length %d (src=" MACSTR
+			")", wpa_cipher_txt(sm->pairwise_cipher), keylen,
+			MAC2STR(sm->bssid));
+		goto failed;
+#ifdef CONFIG_P2P
+	if (ie.ip_addr_alloc) {
+		os_memcpy(sm->p2p_ip_addr, ie.ip_addr_alloc, 3 * 4);
+		wpa_hexdump(MSG_DEBUG, "P2P: IP address info",
+			    sm->p2p_ip_addr, sizeof(sm->p2p_ip_addr));
+	if (wpa_supplicant_send_4_of_4(sm, sm->bssid, key, ver, key_info,
+				       &sm->ptk)) {
+		goto failed;
+	/* SNonce was successfully used in msg 3/4, so mark it to be renewed
+	 * for the next 4-Way Handshake. If msg 3 is received again, the old
+	 * SNonce will still be used to avoid changing PTK. */
+	sm->renew_snonce = 1;
+	if (key_info & WPA_KEY_INFO_INSTALL) {
+		if (wpa_supplicant_install_ptk(sm, key))
+			goto failed;
+	if (key_info & WPA_KEY_INFO_SECURE) {
+			sm, sm->bssid, MLME_SETPROTECTION_PROTECT_TYPE_RX,
+	wpa_sm_set_state(sm, WPA_GROUP_HANDSHAKE);
+	if (sm->group_cipher == WPA_CIPHER_GTK_NOT_USED) {
+	} else if (ie.gtk &&
+	    wpa_supplicant_pairwise_gtk(sm, key,
+					ie.gtk, ie.gtk_len, key_info) < 0) {
+			"RSN: Failed to configure GTK");
+		goto failed;
+	if (ieee80211w_set_keys(sm, &ie) < 0) {
+			"RSN: Failed to configure IGTK");
+		goto failed;
+	if (ie.gtk)
+		wpa_sm_set_rekey_offload(sm);
+	if (sm->proto == WPA_PROTO_RSN && wpa_key_mgmt_suite_b(sm->key_mgmt)) {
+		struct rsn_pmksa_cache_entry *sa;
+		sa = pmksa_cache_add(sm->pmksa, sm->pmk, sm->pmk_len,
+				     sm->ptk.kck, sm->ptk.kck_len,
+				     sm->bssid, sm->own_addr,
+				     sm->network_ctx, sm->key_mgmt);
+	sm->msg_3_of_4_ok = 1;
+	return;
+failed:
+static int wpa_supplicant_process_1_of_2_rsn(struct wpa_sm *sm,
+					     const u8 *keydata,
+					     size_t keydatalen,
+					     u16 key_info,
+					     struct wpa_gtk_data *gd)
+	int maxkeylen;
+	wpa_hexdump(MSG_DEBUG, "RSN: msg 1/2 key data", keydata, keydatalen);
+	if (wpa_supplicant_parse_ies(keydata, keydatalen, &ie) < 0)
+		return -1;
+		return -1;
+	if (ie.gtk == NULL) {
+			"WPA: No GTK IE in Group Key msg 1/2");
+		return -1;
+	maxkeylen = gd->gtk_len = ie.gtk_len - 2;
+	if (wpa_supplicant_check_group_cipher(sm, sm->group_cipher,
+					      gd->gtk_len, maxkeylen,
+					      &gd->key_rsc_len, &gd->alg))
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "RSN: received GTK in group key handshake",
+			ie.gtk, ie.gtk_len);
+	gd->keyidx = ie.gtk[0] & 0x3;
+	gd->tx = wpa_supplicant_gtk_tx_bit_workaround(sm,
+						      !!(ie.gtk[0] & BIT(2)));
+	if (ie.gtk_len - 2 > sizeof(gd->gtk)) {
+			"RSN: Too long GTK in GTK IE (len=%lu)",
+			(unsigned long) ie.gtk_len - 2);
+		return -1;
+	os_memcpy(gd->gtk, ie.gtk + 2, ie.gtk_len - 2);
+	return 0;
+static int wpa_supplicant_process_1_of_2_wpa(struct wpa_sm *sm,
+					     const u8 *key_data,
+					     size_t key_data_len, u16 key_info,
+					     u16 ver, struct wpa_gtk_data *gd)
+	size_t maxkeylen;
+	u16 gtk_len;
+	gtk_len = WPA_GET_BE16(key->key_length);
+	maxkeylen = key_data_len;
+	if (ver == WPA_KEY_INFO_TYPE_HMAC_SHA1_AES) {
+		if (maxkeylen < 8) {
+				"WPA: Too short maxkeylen (%lu)",
+				(unsigned long) maxkeylen);
+			return -1;
+		maxkeylen -= 8;
+	if (gtk_len > maxkeylen ||
+	    wpa_supplicant_check_group_cipher(sm, sm->group_cipher,
+					      gtk_len, maxkeylen,
+		return -1;
+	gd->gtk_len = gtk_len;
+	gd->keyidx = (key_info & WPA_KEY_INFO_KEY_INDEX_MASK) >>
+		WPA_KEY_INFO_KEY_INDEX_SHIFT;
+	if (ver == WPA_KEY_INFO_TYPE_HMAC_MD5_RC4 && sm->ptk.kek_len == 16) {
+#ifdef CONFIG_NO_RC4
+			"WPA: RC4 not supported in the build");
+		return -1;
+#else /* CONFIG_NO_RC4 */
+		u8 ek[32];
+		if (key_data_len > sizeof(gd->gtk)) {
+				"WPA: RC4 key data too long (%lu)",
+				(unsigned long) key_data_len);
+			return -1;
+		os_memcpy(ek, key->key_iv, 16);
+		os_memcpy(ek + 16, sm->ptk.kek, sm->ptk.kek_len);
+		os_memcpy(gd->gtk, key_data, key_data_len);
+		if (rc4_skip(ek, 32, 256, gd->gtk, key_data_len)) {
+			os_memset(ek, 0, sizeof(ek));
+				"WPA: RC4 failed");
+			return -1;
+#endif /* CONFIG_NO_RC4 */
+	} else if (ver == WPA_KEY_INFO_TYPE_HMAC_SHA1_AES) {
+		if (maxkeylen % 8) {
+				"WPA: Unsupported AES-WRAP len %lu",
+			return -1;
+		if (maxkeylen > sizeof(gd->gtk)) {
+				"WPA: AES-WRAP key data "
+				"too long (keydatalen=%lu maxkeylen=%lu)",
+				(unsigned long) key_data_len,
+			return -1;
+		if (aes_unwrap(sm->ptk.kek, sm->ptk.kek_len, maxkeylen / 8,
+			       key_data, gd->gtk)) {
+				"WPA: AES unwrap failed - could not decrypt "
+				"GTK");
+			return -1;
+	} else {
+			"WPA: Unsupported key_info type %d", ver);
+		return -1;
+		sm, !!(key_info & WPA_KEY_INFO_TXRX));
+	return 0;
+static int wpa_supplicant_send_2_of_2(struct wpa_sm *sm,
+				      int ver, u16 key_info)
+	rbuf = wpa_sm_alloc_eapol(sm, IEEE802_1X_TYPE_EAPOL_KEY, NULL,
+	if (rbuf == NULL)
+		return -1;
+	key_info &= WPA_KEY_INFO_KEY_INDEX_MASK;
+	key_info |= ver | WPA_KEY_INFO_MIC | WPA_KEY_INFO_SECURE;
+	else
+	else
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Sending EAPOL-Key 2/2");
+	wpa_eapol_key_send(sm, sm->ptk.kck, sm->ptk.kck_len, ver, sm->bssid,
+	return 0;
+static void wpa_supplicant_process_1_of_2(struct wpa_sm *sm,
+					  size_t key_data_len, u16 ver)
+	u16 key_info;
+	int rekey, ret;
+	if (!sm->msg_3_of_4_ok) {
+			"WPA: Group Key Handshake started prior to completion of 4-way handshake");
+		goto failed;
+	rekey = wpa_sm_get_state(sm) == WPA_COMPLETED;
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: RX message 1 of Group Key "
+		ret = wpa_supplicant_process_1_of_2_rsn(sm, key_data,
+							key_data_len, key_info,
+							&gd);
+	} else {
+		ret = wpa_supplicant_process_1_of_2_wpa(sm, key, key_data,
+							key_data_len,
+							key_info, ver, &gd);
+	if (ret)
+		goto failed;
+	if (wpa_supplicant_install_gtk(sm, &gd, key->key_rsc) ||
+	    wpa_supplicant_send_2_of_2(sm, key, ver, key_info))
+		goto failed;
+	if (rekey) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Group rekeying "
+			"completed with " MACSTR " [GTK=%s]",
+			MAC2STR(sm->bssid), wpa_cipher_txt(sm->group_cipher));
+	} else {
+						key_info &
+						WPA_KEY_INFO_SECURE);
+	return;
+failed:
+static int wpa_supplicant_verify_eapol_key_mic(struct wpa_sm *sm,
+					       struct wpa_eapol_key_192 *key,
+					       u16 ver,
+					       const u8 *buf, size_t len)
+	u8 mic[WPA_EAPOL_KEY_MIC_MAX_LEN];
+	int ok = 0;
+	os_memcpy(mic, key->key_mic, mic_len);
+	if (sm->tptk_set) {
+		os_memset(key->key_mic, 0, mic_len);
+		wpa_eapol_key_mic(sm->tptk.kck, sm->tptk.kck_len, sm->key_mgmt,
+				  ver, buf, len, key->key_mic);
+		if (os_memcmp_const(mic, key->key_mic, mic_len) != 0) {
+				"WPA: Invalid EAPOL-Key MIC "
+				"when using TPTK - ignoring TPTK");
+		} else {
+			ok = 1;
+			sm->tptk_set = 0;
+			sm->ptk_set = 1;
+			os_memcpy(&sm->ptk, &sm->tptk, sizeof(sm->ptk));
+			os_memset(&sm->tptk, 0, sizeof(sm->tptk));
+	if (!ok && sm->ptk_set) {
+		wpa_eapol_key_mic(sm->ptk.kck, sm->ptk.kck_len, sm->key_mgmt,
+				"WPA: Invalid EAPOL-Key MIC - "
+				"dropping packet");
+			return -1;
+		ok = 1;
+	if (!ok) {
+			"WPA: Could not verify EAPOL-Key MIC - "
+		return -1;
+	os_memcpy(sm->rx_replay_counter, key->replay_counter,
+	sm->rx_replay_counter_set = 1;
+	return 0;
+/* Decrypt RSN EAPOL-Key key data (RC4 or AES-WRAP) */
+static int wpa_supplicant_decrypt_key_data(struct wpa_sm *sm,
+					   struct wpa_eapol_key *key, u16 ver,
+					   u8 *key_data, size_t *key_data_len)
+	wpa_hexdump(MSG_DEBUG, "RSN: encrypted key data",
+		    key_data, *key_data_len);
+	if (!sm->ptk_set) {
+			"WPA: PTK not available, cannot decrypt EAPOL-Key Key "
+			"Data");
+		return -1;
+	/* Decrypt key data here so that this operation does not need
+	 * to be implemented separately for each message type. */
+		return -1;
+		u8 ek[32];
+		if (rc4_skip(ek, 32, 256, key_data, *key_data_len)) {
+			return -1;
+	} else if (ver == WPA_KEY_INFO_TYPE_HMAC_SHA1_AES ||
+		   ver == WPA_KEY_INFO_TYPE_AES_128_CMAC ||
+		   sm->key_mgmt == WPA_KEY_MGMT_OSEN ||
+		   wpa_key_mgmt_suite_b(sm->key_mgmt)) {
+		u8 *buf;
+		if (*key_data_len < 8 || *key_data_len % 8) {
+				"WPA: Unsupported AES-WRAP len %u",
+				(unsigned int) *key_data_len);
+			return -1;
+		*key_data_len -= 8; /* AES-WRAP adds 8 bytes */
+		buf = os_malloc(*key_data_len);
+		if (buf == NULL) {
+				"WPA: No memory for AES-UNWRAP buffer");
+			return -1;
+		if (aes_unwrap(sm->ptk.kek, sm->ptk.kek_len, *key_data_len / 8,
+			       key_data, buf)) {
+			os_free(buf);
+				"WPA: AES unwrap failed - "
+				"could not decrypt EAPOL-Key key data");
+			return -1;
+		os_memcpy(key_data, buf, *key_data_len);
+		os_free(buf);
+		WPA_PUT_BE16(key->key_data_length, *key_data_len);
+	} else {
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "WPA: decrypted EAPOL-Key key data",
+	return 0;
+ * wpa_sm_aborted_cached - Notify WPA that PMKSA caching was aborted
+void wpa_sm_aborted_cached(struct wpa_sm *sm)
+	if (sm && sm->cur_pmksa) {
+			"RSN: Cancelling PMKSA caching attempt");
+static void wpa_eapol_key_dump(struct wpa_sm *sm,
+			       unsigned int key_data_len,
+			       const u8 *mic, unsigned int mic_len)
+#ifndef CONFIG_NO_STDOUT_DEBUG
+	u16 key_info = WPA_GET_BE16(key->key_info);
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "  EAPOL-Key type=%d", key->type);
+		"  key_info 0x%x (ver=%d keyidx=%d rsvd=%d %s%s%s%s%s%s%s%s)",
+		key_info, key_info & WPA_KEY_INFO_TYPE_MASK,
+		(key_info & WPA_KEY_INFO_KEY_INDEX_MASK) >>
+		WPA_KEY_INFO_KEY_INDEX_SHIFT,
+		(key_info & (BIT(13) | BIT(14) | BIT(15))) >> 13,
+		key_info & WPA_KEY_INFO_KEY_TYPE ? "Pairwise" : "Group",
+		key_info & WPA_KEY_INFO_INSTALL ? " Install" : "",
+		key_info & WPA_KEY_INFO_ACK ? " Ack" : "",
+		key_info & WPA_KEY_INFO_MIC ? " MIC" : "",
+		key_info & WPA_KEY_INFO_SECURE ? " Secure" : "",
+		key_info & WPA_KEY_INFO_ERROR ? " Error" : "",
+		key_info & WPA_KEY_INFO_REQUEST ? " Request" : "",
+		key_info & WPA_KEY_INFO_ENCR_KEY_DATA ? " Encr" : "");
+		"  key_length=%u key_data_length=%u",
+		WPA_GET_BE16(key->key_length), key_data_len);
+	wpa_hexdump(MSG_DEBUG, "  replay_counter",
+		    key->replay_counter, WPA_REPLAY_COUNTER_LEN);
+	wpa_hexdump(MSG_DEBUG, "  key_nonce", key->key_nonce, WPA_NONCE_LEN);
+	wpa_hexdump(MSG_DEBUG, "  key_iv", key->key_iv, 16);
+	wpa_hexdump(MSG_DEBUG, "  key_rsc", key->key_rsc, 8);
+	wpa_hexdump(MSG_DEBUG, "  key_id (reserved)", key->key_id, 8);
+	wpa_hexdump(MSG_DEBUG, "  key_mic", mic, mic_len);
+#endif /* CONFIG_NO_STDOUT_DEBUG */
+ * wpa_sm_rx_eapol - Process received WPA EAPOL frames
+ * @src_addr: Source MAC address of the EAPOL packet
+ * @buf: Pointer to the beginning of the EAPOL data (EAPOL header)
+ * @len: Length of the EAPOL frame
+ * Returns: 1 = WPA EAPOL-Key processed, 0 = not a WPA EAPOL-Key, -1 failure
+ * This function is called for each received EAPOL frame. Other than EAPOL-Key
+ * frames can be skipped if filtering is done elsewhere. wpa_sm_rx_eapol() is
+ * only processing WPA and WPA2 EAPOL-Key frames.
+ * The received EAPOL-Key packets are validated and valid packets are replied
+ * to. In addition, key material (PTK, GTK) is configured at the end of a
+ * successful key handshake.
+int wpa_sm_rx_eapol(struct wpa_sm *sm, const u8 *src_addr,
+	size_t plen, data_len, key_data_len;
+	const struct ieee802_1x_hdr *hdr;
+	struct wpa_eapol_key *key;
+	struct wpa_eapol_key_192 *key192;
+	u16 key_info, ver;
+	u8 *tmp = NULL;
+	int ret = -1;
+	struct wpa_peerkey *peerkey = NULL;
+	u8 *key_data;
+	size_t mic_len, keyhdrlen;
+	sm->ft_completed = 0;
+	keyhdrlen = mic_len == 24 ? sizeof(*key192) : sizeof(*key);
+	if (len < sizeof(*hdr) + keyhdrlen) {
+			"WPA: EAPOL frame too short to be a WPA "
+			"EAPOL-Key (len %lu, expecting at least %lu)",
+			(unsigned long) len,
+			(unsigned long) sizeof(*hdr) + keyhdrlen);
+		return 0;
+	hdr = (const struct ieee802_1x_hdr *) buf;
+	plen = be_to_host16(hdr->length);
+	data_len = plen + sizeof(*hdr);
+		"IEEE 802.1X RX: version=%d type=%d length=%lu",
+		hdr->version, hdr->type, (unsigned long) plen);
+	if (hdr->version < EAPOL_VERSION) {
+		/* TODO: backwards compatibility */
+	if (hdr->type != IEEE802_1X_TYPE_EAPOL_KEY) {
+			"WPA: EAPOL frame (type %u) discarded, "
+			"not a Key frame", hdr->type);
+		ret = 0;
+		goto out;
+	wpa_hexdump(MSG_MSGDUMP, "WPA: RX EAPOL-Key", buf, len);
+	if (plen > len - sizeof(*hdr) || plen < keyhdrlen) {
+			"WPA: EAPOL frame payload size %lu "
+			"invalid (frame size %lu)",
+			(unsigned long) plen, (unsigned long) len);
+		ret = 0;
+		goto out;
+	if (data_len < len) {
+			"WPA: ignoring %lu bytes after the IEEE 802.1X data",
+			(unsigned long) len - data_len);
+	 * Make a copy of the frame since we need to modify the buffer during
+	 * MAC validation and Key Data decryption.
+	tmp = os_malloc(data_len);
+	if (tmp == NULL)
+		goto out;
+	os_memcpy(tmp, buf, data_len);
+	key = (struct wpa_eapol_key *) (tmp + sizeof(struct ieee802_1x_hdr));
+	key192 = (struct wpa_eapol_key_192 *)
+		(tmp + sizeof(struct ieee802_1x_hdr));
+		key_data = (u8 *) (key192 + 1);
+	else
+		key_data = (u8 *) (key + 1);
+	if (key->type != EAPOL_KEY_TYPE_WPA && key->type != EAPOL_KEY_TYPE_RSN)
+			"WPA: EAPOL-Key type (%d) unknown, discarded",
+			key->type);
+		ret = 0;
+		goto out;
+		key_data_len = WPA_GET_BE16(key192->key_data_length);
+	else
+		key_data_len = WPA_GET_BE16(key->key_data_length);
+	wpa_eapol_key_dump(sm, key, key_data_len, key192->key_mic, mic_len);
+	if (key_data_len > plen - keyhdrlen) {
+		wpa_msg(sm->ctx->msg_ctx, MSG_INFO, "WPA: Invalid EAPOL-Key "
+			"frame - key_data overflow (%u > %u)",
+			(unsigned int) key_data_len,
+			(unsigned int) (plen - keyhdrlen));
+		goto out;
+	eapol_sm_notify_lower_layer_success(sm->eapol, 0);
+	ver = key_info & WPA_KEY_INFO_TYPE_MASK;
+	if (ver != WPA_KEY_INFO_TYPE_HMAC_MD5_RC4 &&
+#if defined(CONFIG_IEEE80211R) || defined(CONFIG_IEEE80211W)
+	    ver != WPA_KEY_INFO_TYPE_AES_128_CMAC &&
+#endif /* CONFIG_IEEE80211R || CONFIG_IEEE80211W */
+	    ver != WPA_KEY_INFO_TYPE_HMAC_SHA1_AES &&
+	    sm->key_mgmt != WPA_KEY_MGMT_OSEN) {
+			"WPA: Unsupported EAPOL-Key descriptor version %d",
+			ver);
+		goto out;
+	if (sm->key_mgmt == WPA_KEY_MGMT_OSEN &&
+	    ver != WPA_KEY_INFO_TYPE_AKM_DEFINED) {
+			"OSEN: Unsupported EAPOL-Key descriptor version %d",
+			ver);
+		goto out;
+	if (wpa_key_mgmt_suite_b(sm->key_mgmt) &&
+			"RSN: Unsupported EAPOL-Key descriptor version %d (expected AKM defined = 0)",
+			ver);
+		goto out;
+		/* IEEE 802.11r uses a new key_info type (AES-128-CMAC). */
+		if (ver != WPA_KEY_INFO_TYPE_AES_128_CMAC) {
+				"FT: AP did not use AES-128-CMAC");
+			goto out;
+	} else
+	if (wpa_key_mgmt_sha256(sm->key_mgmt)) {
+		if (ver != WPA_KEY_INFO_TYPE_AES_128_CMAC &&
+		    sm->key_mgmt != WPA_KEY_MGMT_OSEN &&
+		    !wpa_key_mgmt_suite_b(sm->key_mgmt)) {
+				"WPA: AP did not use the "
+				"negotiated AES-128-CMAC");
+			goto out;
+	} else
+	if (sm->pairwise_cipher == WPA_CIPHER_CCMP &&
+	    ver != WPA_KEY_INFO_TYPE_HMAC_SHA1_AES) {
+			"WPA: CCMP is used, but EAPOL-Key "
+			"descriptor version (%d) is not 2", ver);
+		if (sm->group_cipher != WPA_CIPHER_CCMP &&
+		    !(key_info & WPA_KEY_INFO_KEY_TYPE)) {
+			/* Earlier versions of IEEE 802.11i did not explicitly
+			 * require version 2 descriptor for all EAPOL-Key
+			 * packets, so allow group keys to use version 1 if
+			 * CCMP is not used for them. */
+				"WPA: Backwards compatibility: allow invalid "
+				"version for non-CCMP group keys");
+		} else if (ver == WPA_KEY_INFO_TYPE_AES_128_CMAC) {
+				"WPA: Interoperability workaround: allow incorrect (should have been HMAC-SHA1), but stronger (is AES-128-CMAC), descriptor version to be used");
+		} else
+			goto out;
+	} else if (sm->pairwise_cipher == WPA_CIPHER_GCMP &&
+			"WPA: GCMP is used, but EAPOL-Key "
+		goto out;
+#ifdef CONFIG_PEERKEY
+	for (peerkey = sm->peerkey; peerkey; peerkey = peerkey->next) {
+		if (os_memcmp(peerkey->addr, src_addr, ETH_ALEN) == 0)
+			break;
+	if (!(key_info & WPA_KEY_INFO_SMK_MESSAGE) && peerkey) {
+		if (!peerkey->initiator && peerkey->replay_counter_set &&
+		    os_memcmp(key->replay_counter, peerkey->replay_counter,
+			      WPA_REPLAY_COUNTER_LEN) <= 0) {
+				"RSN: EAPOL-Key Replay Counter did not "
+				"increase (STK) - dropping packet");
+			goto out;
+		} else if (peerkey->initiator) {
+			u8 _tmp[WPA_REPLAY_COUNTER_LEN];
+			os_memcpy(_tmp, key->replay_counter,
+			inc_byte_array(_tmp, WPA_REPLAY_COUNTER_LEN);
+			if (os_memcmp(_tmp, peerkey->replay_counter,
+				      WPA_REPLAY_COUNTER_LEN) != 0) {
+					"RSN: EAPOL-Key Replay "
+					"Counter did not match (STK) - "
+				goto out;
+	if (peerkey && peerkey->initiator && (key_info & WPA_KEY_INFO_ACK)) {
+			"RSN: Ack bit in key_info from STK peer");
+		goto out;
+#endif /* CONFIG_PEERKEY */
+	if (!peerkey && sm->rx_replay_counter_set &&
+	    os_memcmp(key->replay_counter, sm->rx_replay_counter,
+			"WPA: EAPOL-Key Replay Counter did not increase - "
+		goto out;
+	if (!(key_info & (WPA_KEY_INFO_ACK | WPA_KEY_INFO_SMK_MESSAGE))
+	    && (peerkey == NULL || !peerkey->initiator)
+			"WPA: No Ack bit in key_info");
+		goto out;
+	if (key_info & WPA_KEY_INFO_REQUEST) {
+			"WPA: EAPOL-Key with Request bit - dropped");
+		goto out;
+	if ((key_info & WPA_KEY_INFO_MIC) && !peerkey &&
+	    wpa_supplicant_verify_eapol_key_mic(sm, key192, ver, tmp, data_len))
+		goto out;
+	if ((key_info & WPA_KEY_INFO_MIC) && peerkey &&
+	    peerkey_verify_eapol_key_mic(sm, peerkey, key192, ver, tmp,
+					 data_len))
+		goto out;
+	if ((sm->proto == WPA_PROTO_RSN || sm->proto == WPA_PROTO_OSEN) &&
+	    (key_info & WPA_KEY_INFO_ENCR_KEY_DATA)) {
+		if (wpa_supplicant_decrypt_key_data(sm, key, ver, key_data,
+						    &key_data_len))
+			goto out;
+	if (key_info & WPA_KEY_INFO_KEY_TYPE) {
+		if (key_info & WPA_KEY_INFO_KEY_INDEX_MASK) {
+				"WPA: Ignored EAPOL-Key (Pairwise) with "
+				"non-zero key index");
+			goto out;
+		if (peerkey) {
+			/* PeerKey 4-Way Handshake */
+			peerkey_rx_eapol_4way(sm, peerkey, key, key_info, ver,
+					      key_data, key_data_len);
+		} else if (key_info & WPA_KEY_INFO_MIC) {
+			/* 3/4 4-Way Handshake */
+			wpa_supplicant_process_3_of_4(sm, key, ver, key_data,
+						      key_data_len);
+		} else {
+			/* 1/4 4-Way Handshake */
+			wpa_supplicant_process_1_of_4(sm, src_addr, key,
+						      ver, key_data,
+						      key_data_len);
+	} else if (key_info & WPA_KEY_INFO_SMK_MESSAGE) {
+		/* PeerKey SMK Handshake */
+		peerkey_rx_eapol_smk(sm, src_addr, key, key_data_len, key_info,
+				     ver);
+	} else {
+		if (key_info & WPA_KEY_INFO_MIC) {
+			/* 1/2 Group Key Handshake */
+			wpa_supplicant_process_1_of_2(sm, src_addr, key,
+						      key_data, key_data_len,
+						      ver);
+		} else {
+				"WPA: EAPOL-Key (Group) without Mic bit - "
+				"dropped");
+	ret = 1;
+out:
+	bin_clear_free(tmp, data_len);
+	return ret;
+static u32 wpa_key_mgmt_suite(struct wpa_sm *sm)
+	switch (sm->key_mgmt) {
+	case WPA_KEY_MGMT_IEEE8021X:
+		return ((sm->proto == WPA_PROTO_RSN ||
+			RSN_AUTH_KEY_MGMT_UNSPEC_802_1X :
+			WPA_AUTH_KEY_MGMT_UNSPEC_802_1X);
+	case WPA_KEY_MGMT_PSK:
+		return (sm->proto == WPA_PROTO_RSN ?
+			RSN_AUTH_KEY_MGMT_PSK_OVER_802_1X :
+			WPA_AUTH_KEY_MGMT_PSK_OVER_802_1X);
+	case WPA_KEY_MGMT_FT_IEEE8021X:
+		return RSN_AUTH_KEY_MGMT_FT_802_1X;
+	case WPA_KEY_MGMT_FT_PSK:
+		return RSN_AUTH_KEY_MGMT_FT_PSK;
+	case WPA_KEY_MGMT_IEEE8021X_SHA256:
+		return RSN_AUTH_KEY_MGMT_802_1X_SHA256;
+	case WPA_KEY_MGMT_PSK_SHA256:
+		return RSN_AUTH_KEY_MGMT_PSK_SHA256;
+	case WPA_KEY_MGMT_CCKM:
+			RSN_AUTH_KEY_MGMT_CCKM:
+			WPA_AUTH_KEY_MGMT_CCKM);
+	case WPA_KEY_MGMT_WPA_NONE:
+		return WPA_AUTH_KEY_MGMT_NONE;
+	case WPA_KEY_MGMT_IEEE8021X_SUITE_B:
+		return RSN_AUTH_KEY_MGMT_802_1X_SUITE_B;
+	case WPA_KEY_MGMT_IEEE8021X_SUITE_B_192:
+		return RSN_AUTH_KEY_MGMT_802_1X_SUITE_B_192;
+	default:
+		return 0;
+#define RSN_SUITE "%02x-%02x-%02x-%d"
+#define RSN_SUITE_ARG(s) \
+((s) >> 24) & 0xff, ((s) >> 16) & 0xff, ((s) >> 8) & 0xff, (s) & 0xff
+ * wpa_sm_get_mib - Dump text list of MIB entries
+ * @buf: Buffer for the list
+ * @buflen: Length of the buffer
+ * Returns: Number of bytes written to buffer
+ * This function is used fetch dot11 MIB variables.
+int wpa_sm_get_mib(struct wpa_sm *sm, char *buf, size_t buflen)
+	char pmkid_txt[PMKID_LEN * 2 + 1];
+	int rsna, ret;
+	size_t len;
+	if (sm->cur_pmksa) {
+		wpa_snprintf_hex(pmkid_txt, sizeof(pmkid_txt),
+				 sm->cur_pmksa->pmkid, PMKID_LEN);
+	} else
+		pmkid_txt[0] = '\0';
+	if ((wpa_key_mgmt_wpa_psk(sm->key_mgmt) ||
+	     wpa_key_mgmt_wpa_ieee8021x(sm->key_mgmt)) &&
+	    sm->proto == WPA_PROTO_RSN)
+		rsna = 1;
+	else
+		rsna = 0;
+	ret = os_snprintf(buf, buflen,
+			  "dot11RSNAOptionImplemented=TRUE\n"
+			  "dot11RSNAPreauthenticationImplemented=TRUE\n"
+			  "dot11RSNAEnabled=%s\n"
+			  "dot11RSNAPreauthenticationEnabled=%s\n"
+			  "dot11RSNAConfigVersion=%d\n"
+			  "dot11RSNAConfigPairwiseKeysSupported=5\n"
+			  "dot11RSNAConfigGroupCipherSize=%d\n"
+			  "dot11RSNAConfigPMKLifetime=%d\n"
+			  "dot11RSNAConfigPMKReauthThreshold=%d\n"
+			  "dot11RSNAConfigNumberOfPTKSAReplayCounters=1\n"
+			  "dot11RSNAConfigSATimeout=%d\n",
+			  rsna ? "TRUE" : "FALSE",
+			  RSN_VERSION,
+			  wpa_cipher_key_len(sm->group_cipher) * 8,
+			  sm->dot11RSNAConfigPMKLifetime,
+			  sm->dot11RSNAConfigPMKReauthThreshold,
+			  sm->dot11RSNAConfigSATimeout);
+	if (os_snprintf_error(buflen, ret))
+		return 0;
+	len = ret;
+		buf + len, buflen - len,
+		"dot11RSNAAuthenticationSuiteSelected=" RSN_SUITE "\n"
+		"dot11RSNAPairwiseCipherSelected=" RSN_SUITE "\n"
+		"dot11RSNAGroupCipherSelected=" RSN_SUITE "\n"
+		"dot11RSNAPMKIDUsed=%s\n"
+		"dot11RSNAAuthenticationSuiteRequested=" RSN_SUITE "\n"
+		"dot11RSNAPairwiseCipherRequested=" RSN_SUITE "\n"
+		"dot11RSNAGroupCipherRequested=" RSN_SUITE "\n"
+		"dot11RSNAConfigNumberOfGTKSAReplayCounters=0\n"
+		"dot11RSNA4WayHandshakeFailures=%u\n",
+		RSN_SUITE_ARG(wpa_key_mgmt_suite(sm)),
+		RSN_SUITE_ARG(wpa_cipher_to_suite(sm->proto,
+						  sm->pairwise_cipher)),
+						  sm->group_cipher)),
+		pmkid_txt,
+		sm->dot11RSNA4WayHandshakeFailures);
+	if (!os_snprintf_error(buflen - len, ret))
+		len += ret;
+	return (int) len;
+static void wpa_sm_pmksa_free_cb(struct rsn_pmksa_cache_entry *entry,
+				 void *ctx, enum pmksa_free_reason reason)
+	struct wpa_sm *sm = ctx;
+	int deauth = 0;
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "RSN: PMKSA cache entry free_cb: "
+		MACSTR " reason=%d", MAC2STR(entry->aa), reason);
+	if (sm->cur_pmksa == entry) {
+			"RSN: %s current PMKSA entry",
+			reason == PMKSA_REPLACE ? "replaced" : "removed");
+		pmksa_cache_clear_current(sm);
+		 * If an entry is simply being replaced, there's no need to
+		 * deauthenticate because it will be immediately re-added.
+		 * This happens when EAP authentication is completed again
+		 * (reauth or failed PMKSA caching attempt).
+		if (reason != PMKSA_REPLACE)
+			deauth = 1;
+	if (reason == PMKSA_EXPIRE &&
+	    (sm->pmk_len == entry->pmk_len &&
+	     os_memcmp(sm->pmk, entry->pmk, sm->pmk_len) == 0)) {
+			"RSN: deauthenticating due to expired PMK");
+		deauth = 1;
+	if (deauth) {
+		os_memset(sm->pmk, 0, sizeof(sm->pmk));
+ * wpa_sm_init - Initialize WPA state machine
+ * @ctx: Context pointer for callbacks; this needs to be an allocated buffer
+ * Returns: Pointer to the allocated WPA state machine data
+ * This function is used to allocate a new WPA state machine and the returned
+ * value is passed to all WPA state machine calls.
+struct wpa_sm * wpa_sm_init(struct wpa_sm_ctx *ctx)
+	struct wpa_sm *sm;
+	sm = os_zalloc(sizeof(*sm));
+	if (sm == NULL)
+		return NULL;
+	dl_list_init(&sm->pmksa_candidates);
+	sm->ctx = ctx;
+	sm->dot11RSNAConfigPMKLifetime = 43200;
+	sm->dot11RSNAConfigPMKReauthThreshold = 70;
+	sm->dot11RSNAConfigSATimeout = 60;
+	sm->pmksa = pmksa_cache_init(wpa_sm_pmksa_free_cb, sm, sm);
+	if (sm->pmksa == NULL) {
+			"RSN: PMKSA cache initialization failed");
+		os_free(sm);
+		return NULL;
+	return sm;
+ * wpa_sm_deinit - Deinitialize WPA state machine
+void wpa_sm_deinit(struct wpa_sm *sm)
+	if (sm == NULL)
+		return;
+	pmksa_cache_deinit(sm->pmksa);
+	eloop_cancel_timeout(wpa_sm_start_preauth, sm, NULL);
+	os_free(sm->assoc_wpa_ie);
+	os_free(sm->ap_wpa_ie);
+	os_free(sm->ap_rsn_ie);
+	wpa_sm_drop_sa(sm);
+	os_free(sm->ctx);
+	peerkey_deinit(sm);
+	os_free(sm->assoc_resp_ies);
+	os_free(sm);
+ * wpa_sm_notify_assoc - Notify WPA state machine about association
+ * @bssid: The BSSID of the new association
+ * This function is called to let WPA state machine know that the connection
+ * was established.
+void wpa_sm_notify_assoc(struct wpa_sm *sm, const u8 *bssid)
+	int clear_ptk = 1;
+	if (sm == NULL)
+		return;
+		"WPA: Association event - clear replay counter");
+	os_memcpy(sm->bssid, bssid, ETH_ALEN);
+	os_memset(sm->rx_replay_counter, 0, WPA_REPLAY_COUNTER_LEN);
+	sm->rx_replay_counter_set = 0;
+	if (os_memcmp(sm->preauth_bssid, bssid, ETH_ALEN) == 0)
+		rsn_preauth_deinit(sm);
+	if (wpa_ft_is_completed(sm)) {
+		 * Clear portValid to kick EAPOL state machine to re-enter
+		 * AUTHENTICATED state to get the EAPOL port Authorized.
+		eapol_sm_notify_portValid(sm->eapol, FALSE);
+		wpa_supplicant_key_neg_complete(sm, sm->bssid, 1);
+		clear_ptk = 0;
+	if (clear_ptk) {
+		 * IEEE 802.11, 8.4.10: Delete PTK SA on (re)association if
+		 * this is not part of a Fast BSS Transition.
+		wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Clear old PTK");
+		sm->ptk_set = 0;
+		os_memset(&sm->ptk, 0, sizeof(sm->ptk));
+		sm->tptk_set = 0;
+#ifdef CONFIG_TDLS
+	wpa_tdls_assoc(sm);
+#endif /* CONFIG_TDLS */
+#ifdef CONFIG_P2P
+	os_memset(sm->p2p_ip_addr, 0, sizeof(sm->p2p_ip_addr));
+ * wpa_sm_notify_disassoc - Notify WPA state machine about disassociation
+ * was lost. This will abort any existing pre-authentication session.
+void wpa_sm_notify_disassoc(struct wpa_sm *sm)
+	if (wpa_sm_get_state(sm) == WPA_4WAY_HANDSHAKE)
+		sm->dot11RSNA4WayHandshakeFailures++;
+#ifdef CONFIG_TDLS
+	wpa_tdls_disassoc(sm);
+	/* Keys are not needed in the WPA state machine anymore */
+	sm->msg_3_of_4_ok = 0;
+ * wpa_sm_set_pmk - Set PMK
+ * @pmk: The new PMK
+ * @pmk_len: The length of the new PMK in bytes
+ * @bssid: AA to add into PMKSA cache or %NULL to not cache the PMK
+ * Configure the PMK for WPA state machine.
+void wpa_sm_set_pmk(struct wpa_sm *sm, const u8 *pmk, size_t pmk_len,
+		    const u8 *bssid)
+	if (sm == NULL)
+		return;
+	sm->pmk_len = pmk_len;
+	os_memcpy(sm->pmk, pmk, pmk_len);
+	/* Set XXKey to be PSK for FT key derivation */
+	sm->xxkey_len = pmk_len;
+	os_memcpy(sm->xxkey, pmk, pmk_len);
+	if (bssid) {
+		pmksa_cache_add(sm->pmksa, pmk, pmk_len, NULL, 0,
+				bssid, sm->own_addr,
+ * wpa_sm_set_pmk_from_pmksa - Set PMK based on the current PMKSA
+ * Take the PMK from the current PMKSA into use. If no PMKSA is active, the PMK
+ * will be cleared.
+void wpa_sm_set_pmk_from_pmksa(struct wpa_sm *sm)
+	if (sm == NULL)
+		return;
+		sm->pmk_len = sm->cur_pmksa->pmk_len;
+		os_memcpy(sm->pmk, sm->cur_pmksa->pmk, sm->pmk_len);
+	} else {
+		sm->pmk_len = PMK_LEN;
+		os_memset(sm->pmk, 0, PMK_LEN);
+ * wpa_sm_set_fast_reauth - Set fast reauthentication (EAP) enabled/disabled
+ * @fast_reauth: Whether fast reauthentication (EAP) is allowed
+void wpa_sm_set_fast_reauth(struct wpa_sm *sm, int fast_reauth)
+	if (sm)
+		sm->fast_reauth = fast_reauth;
+ * wpa_sm_set_scard_ctx - Set context pointer for smartcard callbacks
+ * @scard_ctx: Context pointer for smartcard related callback functions
+void wpa_sm_set_scard_ctx(struct wpa_sm *sm, void *scard_ctx)
+	if (sm == NULL)
+		return;
+	sm->scard_ctx = scard_ctx;
+		eapol_sm_register_scard_ctx(sm->preauth_eapol, scard_ctx);
+ * wpa_sm_set_config - Notification of current configration change
+ * @config: Pointer to current network configuration
+ * Notify WPA state machine that configuration has changed. config will be
+ * stored as a backpointer to network configuration. This can be %NULL to clear
+ * the stored pointed.
+void wpa_sm_set_config(struct wpa_sm *sm, struct rsn_supp_config *config)
+	if (!sm)
+		return;
+	if (config) {
+		sm->network_ctx = config->network_ctx;
+		sm->peerkey_enabled = config->peerkey_enabled;
+		sm->allowed_pairwise_cipher = config->allowed_pairwise_cipher;
+		sm->proactive_key_caching = config->proactive_key_caching;
+		sm->eap_workaround = config->eap_workaround;
+		sm->eap_conf_ctx = config->eap_conf_ctx;
+		if (config->ssid) {
+			os_memcpy(sm->ssid, config->ssid, config->ssid_len);
+			sm->ssid_len = config->ssid_len;
+		} else
+			sm->ssid_len = 0;
+		sm->wpa_ptk_rekey = config->wpa_ptk_rekey;
+		sm->p2p = config->p2p;
+	} else {
+		sm->network_ctx = NULL;
+		sm->peerkey_enabled = 0;
+		sm->allowed_pairwise_cipher = 0;
+		sm->proactive_key_caching = 0;
+		sm->eap_workaround = 0;
+		sm->eap_conf_ctx = NULL;
+		sm->ssid_len = 0;
+		sm->wpa_ptk_rekey = 0;
+		sm->p2p = 0;
+ * wpa_sm_set_own_addr - Set own MAC address
+ * @addr: Own MAC address
+void wpa_sm_set_own_addr(struct wpa_sm *sm, const u8 *addr)
+	if (sm)
+		os_memcpy(sm->own_addr, addr, ETH_ALEN);
+ * wpa_sm_set_ifname - Set network interface name
+ * @ifname: Interface name
+ * @bridge_ifname: Optional bridge interface name (for pre-auth)
+void wpa_sm_set_ifname(struct wpa_sm *sm, const char *ifname,
+		       const char *bridge_ifname)
+	if (sm) {
+		sm->ifname = ifname;
+		sm->bridge_ifname = bridge_ifname;
+ * wpa_sm_set_eapol - Set EAPOL state machine pointer
+ * @eapol: Pointer to EAPOL state machine allocated with eapol_sm_init()
+void wpa_sm_set_eapol(struct wpa_sm *sm, struct eapol_sm *eapol)
+	if (sm)
+		sm->eapol = eapol;
+ * wpa_sm_set_param - Set WPA state machine parameters
+ * @param: Parameter field
+ * @value: Parameter value
+int wpa_sm_set_param(struct wpa_sm *sm, enum wpa_sm_conf_params param,
+		     unsigned int value)
+	int ret = 0;
+	if (sm == NULL)
+		return -1;
+	switch (param) {
+	case RSNA_PMK_LIFETIME:
+		if (value > 0)
+			sm->dot11RSNAConfigPMKLifetime = value;
+		else
+			ret = -1;
+		break;
+	case RSNA_PMK_REAUTH_THRESHOLD:
+		if (value > 0 && value <= 100)
+			sm->dot11RSNAConfigPMKReauthThreshold = value;
+		else
+			ret = -1;
+		break;
+	case RSNA_SA_TIMEOUT:
+		if (value > 0)
+			sm->dot11RSNAConfigSATimeout = value;
+		else
+			ret = -1;
+		break;
+	case WPA_PARAM_PROTO:
+		sm->proto = value;
+		break;
+	case WPA_PARAM_PAIRWISE:
+		sm->pairwise_cipher = value;
+		break;
+	case WPA_PARAM_GROUP:
+		sm->group_cipher = value;
+		break;
+	case WPA_PARAM_KEY_MGMT:
+		sm->key_mgmt = value;
+		break;
+	case WPA_PARAM_MGMT_GROUP:
+		sm->mgmt_group_cipher = value;
+		break;
+	case WPA_PARAM_RSN_ENABLED:
+		sm->rsn_enabled = value;
+		break;
+	case WPA_PARAM_MFP:
+		sm->mfp = value;
+		break;
+	default:
+		break;
+	return ret;
+ * wpa_sm_get_status - Get WPA state machine
+ * Query WPA state machine for status information. This function fills in
+int wpa_sm_get_status(struct wpa_sm *sm, char *buf, size_t buflen,
+		      int verbose)
+	int ret;
+			  "pairwise_cipher=%s\n"
+			  "group_cipher=%s\n"
+			  "key_mgmt=%s\n",
+			  wpa_cipher_txt(sm->group_cipher),
+			  wpa_key_mgmt_txt(sm->key_mgmt, sm->proto));
+		return pos - buf;
+	pos += ret;
+	if (sm->mfp != NO_MGMT_FRAME_PROTECTION && sm->ap_rsn_ie) {
+		if (wpa_parse_wpa_ie_rsn(sm->ap_rsn_ie, sm->ap_rsn_ie_len, &rsn)
+		    >= 0 &&
+		    rsn.capabilities & (WPA_CAPABILITY_MFPR |
+					WPA_CAPABILITY_MFPC)) {
+			ret = os_snprintf(pos, end - pos, "pmf=%d\n",
+					  (rsn.capabilities &
+					   WPA_CAPABILITY_MFPR) ? 2 : 1);
+				return pos - buf;
+			pos += ret;
+	return pos - buf;
+int wpa_sm_pmf_enabled(struct wpa_sm *sm)
+	if (sm->mfp == NO_MGMT_FRAME_PROTECTION || !sm->ap_rsn_ie)
+		return 0;
+	if (wpa_parse_wpa_ie_rsn(sm->ap_rsn_ie, sm->ap_rsn_ie_len, &rsn) >= 0 &&
+	    rsn.capabilities & (WPA_CAPABILITY_MFPR | WPA_CAPABILITY_MFPC))
+		return 1;
+	return 0;
+ * wpa_sm_set_assoc_wpa_ie_default - Generate own WPA/RSN IE from configuration
+ * @wpa_ie: Pointer to buffer for WPA/RSN IE
+ * @wpa_ie_len: Pointer to the length of the wpa_ie buffer
+int wpa_sm_set_assoc_wpa_ie_default(struct wpa_sm *sm, u8 *wpa_ie,
+				    size_t *wpa_ie_len)
+	int res;
+	if (sm == NULL)
+		return -1;
+	res = wpa_gen_wpa_ie(sm, wpa_ie, *wpa_ie_len);
+	if (res < 0)
+		return -1;
+	*wpa_ie_len = res;
+	wpa_hexdump(MSG_DEBUG, "WPA: Set own WPA IE default",
+		    wpa_ie, *wpa_ie_len);
+	if (sm->assoc_wpa_ie == NULL) {
+		 * Make a copy of the WPA/RSN IE so that 4-Way Handshake gets
+		 * the correct version of the IE even if PMKSA caching is
+		 * aborted (which would remove PMKID from IE generation).
+		sm->assoc_wpa_ie = os_malloc(*wpa_ie_len);
+			return -1;
+		os_memcpy(sm->assoc_wpa_ie, wpa_ie, *wpa_ie_len);
+		sm->assoc_wpa_ie_len = *wpa_ie_len;
+	return 0;
+ * wpa_sm_set_assoc_wpa_ie - Set own WPA/RSN IE from (Re)AssocReq
+ * @ie: Pointer to IE data (starting from id)
+ * @len: IE length
+ * Inform WPA state machine about the WPA/RSN IE used in (Re)Association
+ * Request frame. The IE will be used to override the default value generated
+ * with wpa_sm_set_assoc_wpa_ie_default().
+int wpa_sm_set_assoc_wpa_ie(struct wpa_sm *sm, const u8 *ie, size_t len)
+	if (sm == NULL)
+		return -1;
+	if (ie == NULL || len == 0) {
+			"WPA: clearing own WPA/RSN IE");
+		sm->assoc_wpa_ie = NULL;
+		sm->assoc_wpa_ie_len = 0;
+	} else {
+		wpa_hexdump(MSG_DEBUG, "WPA: set own WPA/RSN IE", ie, len);
+		sm->assoc_wpa_ie = os_malloc(len);
+			return -1;
+		os_memcpy(sm->assoc_wpa_ie, ie, len);
+		sm->assoc_wpa_ie_len = len;
+	return 0;
+ * wpa_sm_set_ap_wpa_ie - Set AP WPA IE from Beacon/ProbeResp
+ * @len: IE length
+ * Inform WPA state machine about the WPA IE used in Beacon / Probe Response
+ * frame.
+int wpa_sm_set_ap_wpa_ie(struct wpa_sm *sm, const u8 *ie, size_t len)
+	if (sm == NULL)
+		return -1;
+			"WPA: clearing AP WPA IE");
+		sm->ap_wpa_ie = NULL;
+		sm->ap_wpa_ie_len = 0;
+	} else {
+		wpa_hexdump(MSG_DEBUG, "WPA: set AP WPA IE", ie, len);
+		sm->ap_wpa_ie = os_malloc(len);
+		if (sm->ap_wpa_ie == NULL)
+			return -1;
+		os_memcpy(sm->ap_wpa_ie, ie, len);
+		sm->ap_wpa_ie_len = len;
+	return 0;
+ * wpa_sm_set_ap_rsn_ie - Set AP RSN IE from Beacon/ProbeResp
+ * @len: IE length
+ * Inform WPA state machine about the RSN IE used in Beacon / Probe Response
+ * frame.
+int wpa_sm_set_ap_rsn_ie(struct wpa_sm *sm, const u8 *ie, size_t len)
+	if (sm == NULL)
+		return -1;
+			"WPA: clearing AP RSN IE");
+		sm->ap_rsn_ie = NULL;
+		sm->ap_rsn_ie_len = 0;
+	} else {
+		wpa_hexdump(MSG_DEBUG, "WPA: set AP RSN IE", ie, len);
+		sm->ap_rsn_ie = os_malloc(len);
+		if (sm->ap_rsn_ie == NULL)
+			return -1;
+		os_memcpy(sm->ap_rsn_ie, ie, len);
+		sm->ap_rsn_ie_len = len;
+	return 0;
+ * wpa_sm_parse_own_wpa_ie - Parse own WPA/RSN IE
+ * @data: Pointer to data area for parsing results
+ * Returns: 0 on success, -1 if IE is not known, or -2 on parsing failure
+ * Parse the contents of the own WPA or RSN IE from (Re)AssocReq and write the
+ * parsed data into data.
+int wpa_sm_parse_own_wpa_ie(struct wpa_sm *sm, struct wpa_ie_data *data)
+	if (sm == NULL)
+		return -1;
+			"WPA: No WPA/RSN IE available from association info");
+		return -1;
+	if (wpa_parse_wpa_ie(sm->assoc_wpa_ie, sm->assoc_wpa_ie_len, data))
+		return -2;
+	return 0;
+int wpa_sm_pmksa_cache_list(struct wpa_sm *sm, char *buf, size_t len)
+	return pmksa_cache_list(sm->pmksa, buf, len);
+void wpa_sm_drop_sa(struct wpa_sm *sm)
+	wpa_dbg(sm->ctx->msg_ctx, MSG_DEBUG, "WPA: Clear old PMK and PTK");
+	sm->ptk_set = 0;
+	sm->tptk_set = 0;
+	os_memset(sm->xxkey, 0, sizeof(sm->xxkey));
+	os_memset(sm->pmk_r0, 0, sizeof(sm->pmk_r0));
+	os_memset(sm->pmk_r1, 0, sizeof(sm->pmk_r1));
+int wpa_sm_has_ptk(struct wpa_sm *sm)
+	if (sm == NULL)
+		return 0;
+	return sm->ptk_set;
+void wpa_sm_update_replay_ctr(struct wpa_sm *sm, const u8 *replay_ctr)
+	os_memcpy(sm->rx_replay_counter, replay_ctr, WPA_REPLAY_COUNTER_LEN);
+void wpa_sm_pmksa_cache_flush(struct wpa_sm *sm, void *network_ctx)
+	pmksa_cache_flush(sm->pmksa, network_ctx, NULL, 0);
+#ifdef CONFIG_WNM
+int wpa_wnmsleep_install_key(struct wpa_sm *sm, u8 subelem_id, u8 *buf)
+	u16 keyinfo;
+	u8 keylen;  /* plaintext key len */
+	u8 *key_rsc;
+	if (subelem_id == WNM_SLEEP_SUBELEM_GTK) {
+		keylen = wpa_cipher_key_len(sm->group_cipher);
+		gd.key_rsc_len = wpa_cipher_rsc_len(sm->group_cipher);
+		gd.alg = wpa_cipher_to_alg(sm->group_cipher);
+		if (gd.alg == WPA_ALG_NONE) {
+			wpa_printf(MSG_DEBUG, "Unsupported group cipher suite");
+			return -1;
+		key_rsc = buf + 5;
+		keyinfo = WPA_GET_LE16(buf + 2);
+		gd.gtk_len = keylen;
+		if (gd.gtk_len != buf[4]) {
+			wpa_printf(MSG_DEBUG, "GTK len mismatch len %d vs %d",
+				   gd.gtk_len, buf[4]);
+			return -1;
+		gd.keyidx = keyinfo & 0x03; /* B0 - B1 */
+		         sm, !!(keyinfo & WPA_KEY_INFO_TXRX));
+		os_memcpy(gd.gtk, buf + 13, gd.gtk_len);
+		wpa_hexdump_key(MSG_DEBUG, "Install GTK (WNM SLEEP)",
+				gd.gtk, gd.gtk_len);
+		if (wpa_supplicant_install_gtk(sm, &gd, key_rsc)) {
+			wpa_printf(MSG_DEBUG, "Failed to install the GTK in "
+				   "WNM mode");
+			return -1;
+	} else if (subelem_id == WNM_SLEEP_SUBELEM_IGTK) {
+		struct wpa_igtk_kde igd;
+		u16 keyidx;
+		os_memset(&igd, 0, sizeof(igd));
+		keylen = wpa_cipher_key_len(sm->mgmt_group_cipher);
+		os_memcpy(igd.keyid, buf + 2, 2);
+		os_memcpy(igd.pn, buf + 4, 6);
+		keyidx = WPA_GET_LE16(igd.keyid);
+		os_memcpy(igd.igtk, buf + 10, keylen);
+		wpa_hexdump_key(MSG_DEBUG, "Install IGTK (WNM SLEEP)",
+				igd.igtk, keylen);
+				   keyidx, 0, igd.pn, sizeof(igd.pn),
+				   igd.igtk, keylen) < 0) {
+			wpa_printf(MSG_DEBUG, "Failed to install the IGTK in "
+				   "WNM mode");
+			return -1;
+	} else {
+		wpa_printf(MSG_DEBUG, "Unknown element id");
+		return -1;
+	return 0;
+#endif /* CONFIG_WNM */
+int wpa_sm_rx_eapol_peerkey(struct wpa_sm *sm, const u8 *src_addr,
+	struct wpa_peerkey *peerkey;
+			break;
+	if (!peerkey)
+		return 0;
+	wpa_sm_rx_eapol(sm, src_addr, buf, len);
+	return 1;
+#ifdef CONFIG_P2P
+int wpa_sm_get_p2p_ip_addr(struct wpa_sm *sm, u8 *buf)
+	if (sm == NULL || WPA_GET_BE32(sm->p2p_ip_addr) == 0)
+		return -1;
+	os_memcpy(buf, sm->p2p_ip_addr, 3 * 4);
+	return 0;
+void wpa_sm_set_rx_replay_ctr(struct wpa_sm *sm, const u8 *rx_replay_counter)
+	if (rx_replay_counter == NULL)
+		return;
+	os_memcpy(sm->rx_replay_counter, rx_replay_counter,
+		  WPA_REPLAY_COUNTER_LEN);
+	wpa_printf(MSG_DEBUG, "Updated key replay counter");
+void wpa_sm_set_ptk_kck_kek(struct wpa_sm *sm,
+			    const u8 *ptk_kck, size_t ptk_kck_len,
+			    const u8 *ptk_kek, size_t ptk_kek_len)
+	if (ptk_kck && ptk_kck_len <= WPA_KCK_MAX_LEN) {
+		os_memcpy(sm->ptk.kck, ptk_kck, ptk_kck_len);
+		sm->ptk.kck_len = ptk_kck_len;
+		wpa_printf(MSG_DEBUG, "Updated PTK KCK");
+	if (ptk_kek && ptk_kek_len <= WPA_KEK_MAX_LEN) {
+		os_memcpy(sm->ptk.kek, ptk_kek, ptk_kek_len);
+		sm->ptk.kek_len = ptk_kek_len;
+		wpa_printf(MSG_DEBUG, "Updated PTK KEK");
+	sm->ptk_set = 1;
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa.h b/freebsd/contrib/wpa/src/rsn_supp/wpa.h
new file mode 100644
index 00000000000..e163b7010b7
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa.h
@@ -0,0 +1,421 @@
+ * wpa_supplicant - WPA definitions
+ * Copyright (c) 2003-2015, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef WPA_H
+#define WPA_H
+#include "common/defs.h"
+#include "common/eapol_common.h"
+#include "common/wpa_common.h"
+#include "common/ieee802_11_defs.h"
+struct wpa_sm;
+struct eapol_sm;
+struct wpa_config_blob;
+struct hostapd_freq_params;
+struct wpa_sm_ctx {
+	void *ctx; /* pointer to arbitrary upper level context */
+	void *msg_ctx; /* upper level context for wpa_msg() calls */
+	void (*set_state)(void *ctx, enum wpa_states state);
+	enum wpa_states (*get_state)(void *ctx);
+	void (*deauthenticate)(void * ctx, int reason_code);
+	int (*set_key)(void *ctx, enum wpa_alg alg,
+		       const u8 *addr, int key_idx, int set_tx,
+		       const u8 *seq, size_t seq_len,
+		       const u8 *key, size_t key_len);
+	void * (*get_network_ctx)(void *ctx);
+	int (*get_bssid)(void *ctx, u8 *bssid);
+	int (*ether_send)(void *ctx, const u8 *dest, u16 proto, const u8 *buf,
+			  size_t len);
+	int (*get_beacon_ie)(void *ctx);
+	void (*cancel_auth_timeout)(void *ctx);
+	u8 * (*alloc_eapol)(void *ctx, u8 type, const void *data, u16 data_len,
+			    size_t *msg_len, void **data_pos);
+	int (*add_pmkid)(void *ctx, const u8 *bssid, const u8 *pmkid);
+	int (*remove_pmkid)(void *ctx, const u8 *bssid, const u8 *pmkid);
+	void (*set_config_blob)(void *ctx, struct wpa_config_blob *blob);
+	const struct wpa_config_blob * (*get_config_blob)(void *ctx,
+							  const char *name);
+	int (*mlme_setprotection)(void *ctx, const u8 *addr,
+				  int protection_type, int key_type);
+	int (*update_ft_ies)(void *ctx, const u8 *md, const u8 *ies,
+			     size_t ies_len);
+	int (*send_ft_action)(void *ctx, u8 action, const u8 *target_ap,
+			      const u8 *ies, size_t ies_len);
+	int (*mark_authenticated)(void *ctx, const u8 *target_ap);
+#ifdef CONFIG_TDLS
+	int (*tdls_get_capa)(void *ctx, int *tdls_supported,
+			     int *tdls_ext_setup, int *tdls_chan_switch);
+	int (*send_tdls_mgmt)(void *ctx, const u8 *dst,
+			      u8 action_code, u8 dialog_token,
+			      u16 status_code, u32 peer_capab,
+			      int initiator, const u8 *buf, size_t len);
+	int (*tdls_oper)(void *ctx, int oper, const u8 *peer);
+	int (*tdls_peer_addset)(void *ctx, const u8 *addr, int add, u16 aid,
+				u16 capability, const u8 *supp_rates,
+				size_t supp_rates_len,
+				const struct ieee80211_ht_capabilities *ht_capab,
+				const struct ieee80211_vht_capabilities *vht_capab,
+				u8 qosinfo, int wmm, const u8 *ext_capab,
+				size_t ext_capab_len, const u8 *supp_channels,
+				size_t supp_channels_len,
+				const u8 *supp_oper_classes,
+				size_t supp_oper_classes_len);
+	int (*tdls_enable_channel_switch)(
+		void *ctx, const u8 *addr, u8 oper_class,
+		const struct hostapd_freq_params *params);
+	int (*tdls_disable_channel_switch)(void *ctx, const u8 *addr);
+	void (*set_rekey_offload)(void *ctx, const u8 *kek, size_t kek_len,
+				  const u8 *kck, size_t kck_len,
+				  const u8 *replay_ctr);
+	int (*key_mgmt_set_pmk)(void *ctx, const u8 *pmk, size_t pmk_len);
+enum wpa_sm_conf_params {
+	RSNA_PMK_LIFETIME /* dot11RSNAConfigPMKLifetime */,
+	RSNA_PMK_REAUTH_THRESHOLD /* dot11RSNAConfigPMKReauthThreshold */,
+	RSNA_SA_TIMEOUT /* dot11RSNAConfigSATimeout */,
+	WPA_PARAM_PROTO,
+	WPA_PARAM_PAIRWISE,
+	WPA_PARAM_GROUP,
+	WPA_PARAM_KEY_MGMT,
+	WPA_PARAM_MGMT_GROUP,
+	WPA_PARAM_RSN_ENABLED,
+	WPA_PARAM_MFP
+struct rsn_supp_config {
+	void *network_ctx;
+	int peerkey_enabled;
+	int allowed_pairwise_cipher; /* bitfield of WPA_CIPHER_* */
+	int proactive_key_caching;
+	int eap_workaround;
+	void *eap_conf_ctx;
+	const u8 *ssid;
+	size_t ssid_len;
+	int wpa_ptk_rekey;
+	int p2p;
+#ifndef CONFIG_NO_WPA
+struct wpa_sm * wpa_sm_init(struct wpa_sm_ctx *ctx);
+void wpa_sm_deinit(struct wpa_sm *sm);
+void wpa_sm_notify_assoc(struct wpa_sm *sm, const u8 *bssid);
+void wpa_sm_notify_disassoc(struct wpa_sm *sm);
+		    const u8 *bssid);
+void wpa_sm_set_pmk_from_pmksa(struct wpa_sm *sm);
+void wpa_sm_set_fast_reauth(struct wpa_sm *sm, int fast_reauth);
+void wpa_sm_set_scard_ctx(struct wpa_sm *sm, void *scard_ctx);
+void wpa_sm_set_config(struct wpa_sm *sm, struct rsn_supp_config *config);
+void wpa_sm_set_own_addr(struct wpa_sm *sm, const u8 *addr);
+		       const char *bridge_ifname);
+void wpa_sm_set_eapol(struct wpa_sm *sm, struct eapol_sm *eapol);
+int wpa_sm_set_assoc_wpa_ie(struct wpa_sm *sm, const u8 *ie, size_t len);
+				    size_t *wpa_ie_len);
+int wpa_sm_set_ap_wpa_ie(struct wpa_sm *sm, const u8 *ie, size_t len);
+int wpa_sm_set_ap_rsn_ie(struct wpa_sm *sm, const u8 *ie, size_t len);
+int wpa_sm_get_mib(struct wpa_sm *sm, char *buf, size_t buflen);
+		     unsigned int value);
+		      int verbose);
+int wpa_sm_pmf_enabled(struct wpa_sm *sm);
+void wpa_sm_key_request(struct wpa_sm *sm, int error, int pairwise);
+int wpa_parse_wpa_ie(const u8 *wpa_ie, size_t wpa_ie_len,
+		     struct wpa_ie_data *data);
+void wpa_sm_aborted_cached(struct wpa_sm *sm);
+		    const u8 *buf, size_t len);
+int wpa_sm_parse_own_wpa_ie(struct wpa_sm *sm, struct wpa_ie_data *data);
+int wpa_sm_pmksa_cache_list(struct wpa_sm *sm, char *buf, size_t len);
+void wpa_sm_drop_sa(struct wpa_sm *sm);
+int wpa_sm_has_ptk(struct wpa_sm *sm);
+void wpa_sm_update_replay_ctr(struct wpa_sm *sm, const u8 *replay_ctr);
+void wpa_sm_pmksa_cache_flush(struct wpa_sm *sm, void *network_ctx);
+int wpa_sm_get_p2p_ip_addr(struct wpa_sm *sm, u8 *buf);
+void wpa_sm_set_rx_replay_ctr(struct wpa_sm *sm, const u8 *rx_replay_counter);
+			    const u8 *ptk_kek, size_t ptk_kek_len);
+#else /* CONFIG_NO_WPA */
+static inline struct wpa_sm * wpa_sm_init(struct wpa_sm_ctx *ctx)
+	return (struct wpa_sm *) 1;
+static inline void wpa_sm_deinit(struct wpa_sm *sm)
+static inline void wpa_sm_notify_assoc(struct wpa_sm *sm, const u8 *bssid)
+static inline void wpa_sm_notify_disassoc(struct wpa_sm *sm)
+static inline void wpa_sm_set_pmk(struct wpa_sm *sm, const u8 *pmk,
+				  size_t pmk_len)
+static inline void wpa_sm_set_pmk_from_pmksa(struct wpa_sm *sm)
+static inline void wpa_sm_set_fast_reauth(struct wpa_sm *sm, int fast_reauth)
+static inline void wpa_sm_set_scard_ctx(struct wpa_sm *sm, void *scard_ctx)
+static inline void wpa_sm_set_config(struct wpa_sm *sm,
+				     struct rsn_supp_config *config)
+static inline void wpa_sm_set_own_addr(struct wpa_sm *sm, const u8 *addr)
+static inline void wpa_sm_set_ifname(struct wpa_sm *sm, const char *ifname,
+static inline void wpa_sm_set_eapol(struct wpa_sm *sm, struct eapol_sm *eapol)
+static inline int wpa_sm_set_assoc_wpa_ie(struct wpa_sm *sm, const u8 *ie,
+					  size_t len)
+	return -1;
+static inline int wpa_sm_set_assoc_wpa_ie_default(struct wpa_sm *sm,
+						  u8 *wpa_ie,
+	return -1;
+static inline int wpa_sm_set_ap_wpa_ie(struct wpa_sm *sm, const u8 *ie,
+				       size_t len)
+	return -1;
+static inline int wpa_sm_set_ap_rsn_ie(struct wpa_sm *sm, const u8 *ie,
+				       size_t len)
+	return -1;
+static inline int wpa_sm_get_mib(struct wpa_sm *sm, char *buf, size_t buflen)
+	return 0;
+static inline int wpa_sm_set_param(struct wpa_sm *sm,
+				   enum wpa_sm_conf_params param,
+	return -1;
+static inline int wpa_sm_get_status(struct wpa_sm *sm, char *buf,
+				    size_t buflen, int verbose)
+	return 0;
+static inline int wpa_sm_pmf_enabled(struct wpa_sm *sm)
+	return 0;
+static inline void wpa_sm_key_request(struct wpa_sm *sm, int error,
+				      int pairwise)
+static inline int wpa_parse_wpa_ie(const u8 *wpa_ie, size_t wpa_ie_len,
+	return -1;
+static inline void wpa_sm_aborted_cached(struct wpa_sm *sm)
+static inline int wpa_sm_rx_eapol(struct wpa_sm *sm, const u8 *src_addr,
+	return -1;
+static inline int wpa_sm_parse_own_wpa_ie(struct wpa_sm *sm,
+	return -1;
+static inline int wpa_sm_pmksa_cache_list(struct wpa_sm *sm, char *buf,
+					  size_t len)
+	return -1;
+static inline void wpa_sm_drop_sa(struct wpa_sm *sm)
+static inline int wpa_sm_has_ptk(struct wpa_sm *sm)
+	return 0;
+static inline void wpa_sm_update_replay_ctr(struct wpa_sm *sm,
+static inline void wpa_sm_pmksa_cache_flush(struct wpa_sm *sm,
+					    void *network_ctx)
+static inline void wpa_sm_set_rx_replay_ctr(struct wpa_sm *sm,
+					    const u8 *rx_replay_counter)
+static inline void wpa_sm_set_ptk_kck_kek(struct wpa_sm *sm, const u8 *ptk_kck,
+					  const u8 *ptk_kek)
+#endif /* CONFIG_NO_WPA */
+int wpa_sm_stkstart(struct wpa_sm *sm, const u8 *peer);
+#else /* CONFIG_PEERKEY */
+static inline int wpa_sm_stkstart(struct wpa_sm *sm, const u8 *peer)
+	return -1;
+static inline int wpa_sm_rx_eapol_peerkey(struct wpa_sm *sm, const u8 *src_addr,
+	return 0;
+#ifdef CONFIG_IEEE80211R
+int wpa_sm_set_ft_params(struct wpa_sm *sm, const u8 *ies, size_t ies_len);
+int wpa_ft_prepare_auth_request(struct wpa_sm *sm, const u8 *mdie);
+int wpa_ft_process_response(struct wpa_sm *sm, const u8 *ies, size_t ies_len,
+			    int ft_action, const u8 *target_ap,
+			    const u8 *ric_ies, size_t ric_ies_len);
+int wpa_ft_is_completed(struct wpa_sm *sm);
+void wpa_reset_ft_completed(struct wpa_sm *sm);
+int wpa_ft_validate_reassoc_resp(struct wpa_sm *sm, const u8 *ies,
+				 size_t ies_len, const u8 *src_addr);
+int wpa_ft_start_over_ds(struct wpa_sm *sm, const u8 *target_ap,
+			 const u8 *mdie);
+#else /* CONFIG_IEEE80211R */
+static inline int
+wpa_sm_set_ft_params(struct wpa_sm *sm, const u8 *ies, size_t ies_len)
+	return 0;
+static inline int wpa_ft_prepare_auth_request(struct wpa_sm *sm,
+					      const u8 *mdie)
+	return 0;
+static inline int
+wpa_ft_process_response(struct wpa_sm *sm, const u8 *ies, size_t ies_len,
+			int ft_action, const u8 *target_ap)
+	return 0;
+static inline int wpa_ft_is_completed(struct wpa_sm *sm)
+	return 0;
+static inline void wpa_reset_ft_completed(struct wpa_sm *sm)
+static inline int
+wpa_ft_validate_reassoc_resp(struct wpa_sm *sm, const u8 *ies, size_t ies_len,
+			     const u8 *src_addr)
+	return -1;
+#endif /* CONFIG_IEEE80211R */
+/* tdls.c */
+void wpa_tdls_ap_ies(struct wpa_sm *sm, const u8 *ies, size_t len);
+void wpa_tdls_assoc_resp_ies(struct wpa_sm *sm, const u8 *ies, size_t len);
+int wpa_tdls_start(struct wpa_sm *sm, const u8 *addr);
+void wpa_tdls_remove(struct wpa_sm *sm, const u8 *addr);
+int wpa_tdls_teardown_link(struct wpa_sm *sm, const u8 *addr, u16 reason_code);
+int wpa_tdls_send_discovery_request(struct wpa_sm *sm, const u8 *addr);
+int wpa_tdls_init(struct wpa_sm *sm);
+void wpa_tdls_teardown_peers(struct wpa_sm *sm);
+void wpa_tdls_deinit(struct wpa_sm *sm);
+void wpa_tdls_enable(struct wpa_sm *sm, int enabled);
+void wpa_tdls_disable_unreachable_link(struct wpa_sm *sm, const u8 *addr);
+const char * wpa_tdls_get_link_status(struct wpa_sm *sm, const u8 *addr);
+int wpa_tdls_is_external_setup(struct wpa_sm *sm);
+int wpa_tdls_enable_chan_switch(struct wpa_sm *sm, const u8 *addr,
+				u8 oper_class,
+				struct hostapd_freq_params *freq_params);
+int wpa_tdls_disable_chan_switch(struct wpa_sm *sm, const u8 *addr);
+int wpa_wnmsleep_install_key(struct wpa_sm *sm, u8 subelem_id, u8 *buf);
+#endif /* WPA_H */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c b/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c
index 00000000000..509a20e0a91
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c
@@ -0,0 +1,849 @@
+#include <machine/rtems-bsd-user-space.h>
+ * WPA Supplicant - IEEE 802.11r - Fast BSS Transition
+ * Copyright (c) 2006-2015, Jouni Malinen <j at w1.fi>
+#include "includes.h"
+#include "common.h"
+#include "crypto/aes_wrap.h"
+#include "crypto/random.h"
+#include "common/ieee802_11_common.h"
+#include "wpa.h"
+#include "wpa_i.h"
+int wpa_derive_ptk_ft(struct wpa_sm *sm, const unsigned char *src_addr,
+		      const struct wpa_eapol_key *key, struct wpa_ptk *ptk)
+	u8 ptk_name[WPA_PMK_NAME_LEN];
+	const u8 *anonce = key->key_nonce;
+	if (sm->xxkey_len == 0) {
+		wpa_printf(MSG_DEBUG, "FT: XXKey not available for key "
+			   "derivation");
+		return -1;
+	wpa_derive_pmk_r0(sm->xxkey, sm->xxkey_len, sm->ssid,
+			  sm->ssid_len, sm->mobility_domain,
+			  sm->r0kh_id, sm->r0kh_id_len, sm->own_addr,
+			  sm->pmk_r0, sm->pmk_r0_name);
+	wpa_hexdump_key(MSG_DEBUG, "FT: PMK-R0", sm->pmk_r0, PMK_LEN);
+	wpa_hexdump(MSG_DEBUG, "FT: PMKR0Name",
+		    sm->pmk_r0_name, WPA_PMK_NAME_LEN);
+	wpa_derive_pmk_r1(sm->pmk_r0, sm->pmk_r0_name, sm->r1kh_id,
+			  sm->own_addr, sm->pmk_r1, sm->pmk_r1_name);
+	wpa_hexdump_key(MSG_DEBUG, "FT: PMK-R1", sm->pmk_r1, PMK_LEN);
+	wpa_hexdump(MSG_DEBUG, "FT: PMKR1Name", sm->pmk_r1_name,
+		    WPA_PMK_NAME_LEN);
+	return wpa_pmk_r1_to_ptk(sm->pmk_r1, sm->snonce, anonce, sm->own_addr,
+				 sm->bssid, sm->pmk_r1_name, ptk, ptk_name,
+				 sm->key_mgmt, sm->pairwise_cipher);
+ * wpa_sm_set_ft_params - Set FT (IEEE 802.11r) parameters
+ * @ies: Association Response IEs or %NULL to clear FT parameters
+ * @ies_len: Length of ies buffer in octets
+	struct wpa_ft_ies ft;
+	if (sm == NULL)
+		return 0;
+	if (wpa_ft_parse_ies(ies, ies_len, &ft) < 0)
+		return -1;
+	if (ft.mdie && ft.mdie_len < MOBILITY_DOMAIN_ID_LEN + 1)
+		return -1;
+	if (ft.mdie) {
+		wpa_hexdump(MSG_DEBUG, "FT: Mobility domain",
+			    ft.mdie, MOBILITY_DOMAIN_ID_LEN);
+		os_memcpy(sm->mobility_domain, ft.mdie,
+			  MOBILITY_DOMAIN_ID_LEN);
+		sm->mdie_ft_capab = ft.mdie[MOBILITY_DOMAIN_ID_LEN];
+		wpa_printf(MSG_DEBUG, "FT: Capability and Policy: 0x%02x",
+			   sm->mdie_ft_capab);
+	} else
+		os_memset(sm->mobility_domain, 0, MOBILITY_DOMAIN_ID_LEN);
+	if (ft.r0kh_id) {
+		wpa_hexdump(MSG_DEBUG, "FT: R0KH-ID",
+			    ft.r0kh_id, ft.r0kh_id_len);
+		os_memcpy(sm->r0kh_id, ft.r0kh_id, ft.r0kh_id_len);
+		sm->r0kh_id_len = ft.r0kh_id_len;
+	} else {
+		/* FIX: When should R0KH-ID be cleared? We need to keep the
+		 * old R0KH-ID in order to be able to use this during FT. */
+		 * os_memset(sm->r0kh_id, 0, FT_R0KH_ID_LEN);
+		 * sm->r0kh_id_len = 0;
+	if (ft.r1kh_id) {
+		wpa_hexdump(MSG_DEBUG, "FT: R1KH-ID",
+			    ft.r1kh_id, FT_R1KH_ID_LEN);
+		os_memcpy(sm->r1kh_id, ft.r1kh_id, FT_R1KH_ID_LEN);
+	} else
+		os_memset(sm->r1kh_id, 0, FT_R1KH_ID_LEN);
+	sm->assoc_resp_ies = os_malloc(ft.mdie_len + 2 + ft.ftie_len + 2);
+	if (sm->assoc_resp_ies) {
+		u8 *pos = sm->assoc_resp_ies;
+		if (ft.mdie) {
+			os_memcpy(pos, ft.mdie - 2, ft.mdie_len + 2);
+			pos += ft.mdie_len + 2;
+		if (ft.ftie) {
+			os_memcpy(pos, ft.ftie - 2, ft.ftie_len + 2);
+			pos += ft.ftie_len + 2;
+		sm->assoc_resp_ies_len = pos - sm->assoc_resp_ies;
+		wpa_hexdump(MSG_DEBUG, "FT: Stored MDIE and FTIE from "
+			    "(Re)Association Response",
+			    sm->assoc_resp_ies, sm->assoc_resp_ies_len);
+	return 0;
+ * wpa_ft_gen_req_ies - Generate FT (IEEE 802.11r) IEs for Auth/ReAssoc Request
+ * @len: Buffer for returning the length of the IEs
+ * @anonce: ANonce or %NULL if not yet available
+ * @pmk_name: PMKR0Name or PMKR1Name to be added into the RSN IE PMKID List
+ * @kck: 128-bit KCK for MIC or %NULL if no MIC is used
+ * @kck_len: KCK length in octets
+ * @target_ap: Target AP address
+ * @ric_ies: Optional IE(s), e.g., WMM TSPEC(s), for RIC-Request or %NULL
+ * @ric_ies_len: Length of ric_ies buffer in octets
+ * @ap_mdie: Mobility Domain IE from the target AP
+ * Returns: Pointer to buffer with IEs or %NULL on failure
+ * Caller is responsible for freeing the returned buffer with os_free();
+static u8 * wpa_ft_gen_req_ies(struct wpa_sm *sm, size_t *len,
+			       const u8 *anonce, const u8 *pmk_name,
+			       const u8 *target_ap,
+			       const u8 *ric_ies, size_t ric_ies_len,
+			       const u8 *ap_mdie)
+	size_t buf_len;
+	u8 *buf, *pos, *ftie_len, *ftie_pos;
+	struct rsn_ftie *ftie;
+	struct rsn_ie_hdr *rsnie;
+	u16 capab;
+	buf_len = 2 + sizeof(struct rsn_mdie) + 2 + sizeof(struct rsn_ftie) +
+		2 + sm->r0kh_id_len + ric_ies_len + 100;
+	buf = os_zalloc(buf_len);
+	if (buf == NULL)
+		return NULL;
+	pos = buf;
+	/* RSNIE[PMKR0Name/PMKR1Name] */
+	rsnie = (struct rsn_ie_hdr *) pos;
+	rsnie->elem_id = WLAN_EID_RSN;
+	WPA_PUT_LE16(rsnie->version, RSN_VERSION);
+	pos = (u8 *) (rsnie + 1);
+	/* Group Suite Selector */
+	if (!wpa_cipher_valid_group(sm->group_cipher)) {
+		wpa_printf(MSG_WARNING, "FT: Invalid group cipher (%d)",
+			   sm->group_cipher);
+		os_free(buf);
+		return NULL;
+	RSN_SELECTOR_PUT(pos, wpa_cipher_to_suite(WPA_PROTO_RSN,
+						  sm->group_cipher));
+	pos += RSN_SELECTOR_LEN;
+	/* Pairwise Suite Count */
+	WPA_PUT_LE16(pos, 1);
+	pos += 2;
+	/* Pairwise Suite List */
+	if (!wpa_cipher_valid_pairwise(sm->pairwise_cipher)) {
+		wpa_printf(MSG_WARNING, "FT: Invalid pairwise cipher (%d)",
+			   sm->pairwise_cipher);
+		os_free(buf);
+		return NULL;
+						  sm->pairwise_cipher));
+	/* Authenticated Key Management Suite Count */
+	pos += 2;
+	/* Authenticated Key Management Suite List */
+	if (sm->key_mgmt == WPA_KEY_MGMT_FT_IEEE8021X)
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_FT_802_1X);
+	else if (sm->key_mgmt == WPA_KEY_MGMT_FT_PSK)
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_FT_PSK);
+	else if (sm->key_mgmt == WPA_KEY_MGMT_FT_SAE)
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_FT_SAE);
+	else {
+		wpa_printf(MSG_WARNING, "FT: Invalid key management type (%d)",
+			   sm->key_mgmt);
+		os_free(buf);
+		return NULL;
+	/* RSN Capabilities */
+	capab = 0;
+#ifdef CONFIG_IEEE80211W
+	if (sm->mgmt_group_cipher == WPA_CIPHER_AES_128_CMAC)
+		capab |= WPA_CAPABILITY_MFPC;
+#endif /* CONFIG_IEEE80211W */
+	WPA_PUT_LE16(pos, capab);
+	pos += 2;
+	/* PMKID Count */
+	pos += 2;
+	/* PMKID List [PMKR0Name/PMKR1Name] */
+	os_memcpy(pos, pmk_name, WPA_PMK_NAME_LEN);
+	pos += WPA_PMK_NAME_LEN;
+	if (sm->mgmt_group_cipher == WPA_CIPHER_AES_128_CMAC) {
+		/* Management Group Cipher Suite */
+		RSN_SELECTOR_PUT(pos, RSN_CIPHER_SUITE_AES_128_CMAC);
+	rsnie->len = (pos - (u8 *) rsnie) - 2;
+	/* MDIE */
+	*pos++ = WLAN_EID_MOBILITY_DOMAIN;
+	*pos++ = sizeof(*mdie);
+	mdie = (struct rsn_mdie *) pos;
+	pos += sizeof(*mdie);
+	os_memcpy(mdie->mobility_domain, sm->mobility_domain,
+	mdie->ft_capab = ap_mdie && ap_mdie[1] >= 3 ? ap_mdie[4] :
+		sm->mdie_ft_capab;
+	/* FTIE[SNonce, [R1KH-ID,] R0KH-ID ] */
+	ftie_pos = pos;
+	*pos++ = WLAN_EID_FAST_BSS_TRANSITION;
+	ftie_len = pos++;
+	ftie = (struct rsn_ftie *) pos;
+	pos += sizeof(*ftie);
+	os_memcpy(ftie->snonce, sm->snonce, WPA_NONCE_LEN);
+	if (anonce)
+		os_memcpy(ftie->anonce, anonce, WPA_NONCE_LEN);
+	if (kck) {
+		/* R1KH-ID sub-element in third FT message */
+		*pos++ = FTIE_SUBELEM_R1KH_ID;
+		*pos++ = FT_R1KH_ID_LEN;
+		os_memcpy(pos, sm->r1kh_id, FT_R1KH_ID_LEN);
+		pos += FT_R1KH_ID_LEN;
+	/* R0KH-ID sub-element */
+	*pos++ = FTIE_SUBELEM_R0KH_ID;
+	*pos++ = sm->r0kh_id_len;
+	os_memcpy(pos, sm->r0kh_id, sm->r0kh_id_len);
+	pos += sm->r0kh_id_len;
+	*ftie_len = pos - ftie_len - 1;
+	if (ric_ies) {
+		/* RIC Request */
+		os_memcpy(pos, ric_ies, ric_ies_len);
+		pos += ric_ies_len;
+	if (kck) {
+		 * IEEE Std 802.11r-2008, 11A.8.4
+		 * MIC shall be calculated over:
+		 * non-AP STA MAC address
+		 * Target AP MAC address
+		 * Transaction seq number (5 for ReassocReq, 3 otherwise)
+		 * RSN IE
+		 * MDIE
+		 * FTIE (with MIC field set to 0)
+		 * RIC-Request (if present)
+		/* Information element count */
+		ftie->mic_control[1] = 3 + ieee802_11_ie_count(ric_ies,
+							       ric_ies_len);
+		if (wpa_ft_mic(kck, kck_len, sm->own_addr, target_ap, 5,
+			       ((u8 *) mdie) - 2, 2 + sizeof(*mdie),
+			       ftie_pos, 2 + *ftie_len,
+			       (u8 *) rsnie, 2 + rsnie->len, ric_ies,
+			       ric_ies_len, ftie->mic) < 0) {
+			wpa_printf(MSG_INFO, "FT: Failed to calculate MIC");
+			os_free(buf);
+			return NULL;
+	*len = pos - buf;
+	return buf;
+static int wpa_ft_install_ptk(struct wpa_sm *sm, const u8 *bssid)
+	int keylen;
+	enum wpa_alg alg;
+	u8 null_rsc[6] = { 0, 0, 0, 0, 0, 0 };
+	wpa_printf(MSG_DEBUG, "FT: Installing PTK to the driver.");
+		wpa_printf(MSG_WARNING, "FT: Unsupported pairwise cipher %d",
+		return -1;
+	alg = wpa_cipher_to_alg(sm->pairwise_cipher);
+	keylen = wpa_cipher_key_len(sm->pairwise_cipher);
+	if (wpa_sm_set_key(sm, alg, bssid, 0, 1, null_rsc,
+			   sizeof(null_rsc), (u8 *) sm->ptk.tk, keylen) < 0) {
+		wpa_printf(MSG_WARNING, "FT: Failed to set PTK to the driver");
+		return -1;
+	return 0;
+ * wpa_ft_prepare_auth_request - Generate over-the-air auth request
+ * @mdie: Target AP MDIE
+	u8 *ft_ies;
+	size_t ft_ies_len;
+	/* Generate a new SNonce */
+	if (random_get_bytes(sm->snonce, WPA_NONCE_LEN)) {
+		wpa_printf(MSG_INFO, "FT: Failed to generate a new SNonce");
+		return -1;
+	ft_ies = wpa_ft_gen_req_ies(sm, &ft_ies_len, NULL, sm->pmk_r0_name,
+				    NULL, 0, sm->bssid, NULL, 0, mdie);
+	if (ft_ies) {
+		wpa_sm_update_ft_ies(sm, sm->mobility_domain,
+				     ft_ies, ft_ies_len);
+		os_free(ft_ies);
+	return 0;
+	u8 *ft_ies;
+	struct wpa_ft_ies parse;
+	struct rsn_mdie *mdie;
+	int ret;
+	const u8 *bssid;
+	wpa_hexdump(MSG_DEBUG, "FT: Response IEs", ies, ies_len);
+	wpa_hexdump(MSG_DEBUG, "FT: RIC IEs", ric_ies, ric_ies_len);
+	if (ft_action) {
+		if (!sm->over_the_ds_in_progress) {
+			wpa_printf(MSG_DEBUG, "FT: No over-the-DS in progress "
+				   "- drop FT Action Response");
+			return -1;
+		if (os_memcmp(target_ap, sm->target_ap, ETH_ALEN) != 0) {
+				   "with this Target AP - drop FT Action "
+				   "Response");
+			return -1;
+	if (!wpa_key_mgmt_ft(sm->key_mgmt)) {
+		wpa_printf(MSG_DEBUG, "FT: Reject FT IEs since FT is not "
+			   "enabled for this connection");
+		return -1;
+	if (wpa_ft_parse_ies(ies, ies_len, &parse) < 0) {
+		wpa_printf(MSG_DEBUG, "FT: Failed to parse IEs");
+		return -1;
+	mdie = (struct rsn_mdie *) parse.mdie;
+	if (mdie == NULL || parse.mdie_len < sizeof(*mdie) ||
+	    os_memcmp(mdie->mobility_domain, sm->mobility_domain,
+		      MOBILITY_DOMAIN_ID_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "FT: Invalid MDIE");
+		return -1;
+	ftie = (struct rsn_ftie *) parse.ftie;
+	if (ftie == NULL || parse.ftie_len < sizeof(*ftie)) {
+		wpa_printf(MSG_DEBUG, "FT: Invalid FTIE");
+		return -1;
+	if (os_memcmp(ftie->snonce, sm->snonce, WPA_NONCE_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "FT: SNonce mismatch in FTIE");
+		wpa_hexdump(MSG_DEBUG, "FT: Received SNonce",
+			    ftie->snonce, WPA_NONCE_LEN);
+		wpa_hexdump(MSG_DEBUG, "FT: Expected SNonce",
+			    sm->snonce, WPA_NONCE_LEN);
+		return -1;
+	if (parse.r0kh_id == NULL) {
+		wpa_printf(MSG_DEBUG, "FT: No R0KH-ID subelem in FTIE");
+		return -1;
+	if (parse.r0kh_id_len != sm->r0kh_id_len ||
+	    os_memcmp_const(parse.r0kh_id, sm->r0kh_id, parse.r0kh_id_len) != 0)
+		wpa_printf(MSG_DEBUG, "FT: R0KH-ID in FTIE did not match with "
+			   "the current R0KH-ID");
+		wpa_hexdump(MSG_DEBUG, "FT: R0KH-ID in FTIE",
+			    parse.r0kh_id, parse.r0kh_id_len);
+		wpa_hexdump(MSG_DEBUG, "FT: The current R0KH-ID",
+			    sm->r0kh_id, sm->r0kh_id_len);
+		return -1;
+	if (parse.r1kh_id == NULL) {
+		wpa_printf(MSG_DEBUG, "FT: No R1KH-ID subelem in FTIE");
+		return -1;
+	if (parse.rsn_pmkid == NULL ||
+	    os_memcmp_const(parse.rsn_pmkid, sm->pmk_r0_name, WPA_PMK_NAME_LEN))
+		wpa_printf(MSG_DEBUG, "FT: No matching PMKR0Name (PMKID) in "
+			   "RSNIE");
+		return -1;
+	os_memcpy(sm->r1kh_id, parse.r1kh_id, FT_R1KH_ID_LEN);
+	wpa_hexdump(MSG_DEBUG, "FT: R1KH-ID", sm->r1kh_id, FT_R1KH_ID_LEN);
+	wpa_hexdump(MSG_DEBUG, "FT: SNonce", sm->snonce, WPA_NONCE_LEN);
+	wpa_hexdump(MSG_DEBUG, "FT: ANonce", ftie->anonce, WPA_NONCE_LEN);
+	os_memcpy(sm->anonce, ftie->anonce, WPA_NONCE_LEN);
+		    sm->pmk_r1_name, WPA_PMK_NAME_LEN);
+	bssid = target_ap;
+	if (wpa_pmk_r1_to_ptk(sm->pmk_r1, sm->snonce, ftie->anonce,
+			      sm->own_addr, bssid, sm->pmk_r1_name, &sm->ptk,
+			      ptk_name, sm->key_mgmt, sm->pairwise_cipher) < 0)
+		return -1;
+	ft_ies = wpa_ft_gen_req_ies(sm, &ft_ies_len, ftie->anonce,
+				    sm->pmk_r1_name,
+				    sm->ptk.kck, sm->ptk.kck_len, bssid,
+				    ric_ies, ric_ies_len,
+				    parse.mdie ? parse.mdie - 2 : NULL);
+	if (ft_ies) {
+		os_free(ft_ies);
+	wpa_sm_mark_authenticated(sm, bssid);
+	ret = wpa_ft_install_ptk(sm, bssid);
+	if (ret) {
+		 * Some drivers do not support key configuration when we are
+		 * not associated with the target AP. Work around this by
+		 * trying again after the following reassociation gets
+		 * completed.
+		wpa_printf(MSG_DEBUG, "FT: Failed to set PTK prior to "
+			   "association - try again after reassociation");
+		sm->set_ptk_after_assoc = 1;
+	} else
+		sm->set_ptk_after_assoc = 0;
+	sm->ft_completed = 1;
+	if (ft_action) {
+		 * The caller is expected trigger re-association with the
+		 * Target AP.
+		os_memcpy(sm->bssid, target_ap, ETH_ALEN);
+	return 0;
+	if (sm == NULL)
+		return 0;
+		return 0;
+	return sm->ft_completed;
+	if (sm != NULL)
+static int wpa_ft_process_gtk_subelem(struct wpa_sm *sm, const u8 *gtk_elem,
+				      size_t gtk_elem_len)
+	u8 gtk[32];
+	int keyidx;
+	enum wpa_alg alg;
+	size_t gtk_len, keylen, rsc_len;
+	if (gtk_elem == NULL) {
+		wpa_printf(MSG_DEBUG, "FT: No GTK included in FTIE");
+		return 0;
+	wpa_hexdump_key(MSG_DEBUG, "FT: Received GTK in Reassoc Resp",
+			gtk_elem, gtk_elem_len);
+	if (gtk_elem_len < 11 + 24 || (gtk_elem_len - 11) % 8 ||
+	    gtk_elem_len - 19 > sizeof(gtk)) {
+		wpa_printf(MSG_DEBUG, "FT: Invalid GTK sub-elem "
+			   "length %lu", (unsigned long) gtk_elem_len);
+		return -1;
+	gtk_len = gtk_elem_len - 19;
+	if (aes_unwrap(sm->ptk.kek, sm->ptk.kek_len, gtk_len / 8, gtk_elem + 11,
+		       gtk)) {
+		wpa_printf(MSG_WARNING, "FT: AES unwrap failed - could not "
+			   "decrypt GTK");
+		return -1;
+	rsc_len = wpa_cipher_rsc_len(sm->group_cipher);
+	alg = wpa_cipher_to_alg(sm->group_cipher);
+	if (alg == WPA_ALG_NONE) {
+		wpa_printf(MSG_WARNING, "WPA: Unsupported Group Cipher %d",
+		return -1;
+	if (gtk_len < keylen) {
+		wpa_printf(MSG_DEBUG, "FT: Too short GTK in FTIE");
+		return -1;
+	/* Key Info[2] | Key Length[1] | RSC[8] | Key[5..32]. */
+	keyidx = WPA_GET_LE16(gtk_elem) & 0x03;
+	if (gtk_elem[2] != keylen) {
+		wpa_printf(MSG_DEBUG, "FT: GTK length mismatch: received %d "
+			   "negotiated %lu",
+			   gtk_elem[2], (unsigned long) keylen);
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "FT: GTK from Reassoc Resp", gtk, keylen);
+	if (sm->group_cipher == WPA_CIPHER_TKIP) {
+		/* Swap Tx/Rx keys for Michael MIC */
+		u8 tmp[8];
+		os_memcpy(tmp, gtk + 16, 8);
+		os_memcpy(gtk + 16, gtk + 24, 8);
+		os_memcpy(gtk + 24, tmp, 8);
+	if (wpa_sm_set_key(sm, alg, broadcast_ether_addr, keyidx, 0,
+			   gtk_elem + 3, rsc_len, gtk, keylen) < 0) {
+		wpa_printf(MSG_WARNING, "WPA: Failed to set GTK to the "
+			   "driver.");
+		return -1;
+	return 0;
+static int wpa_ft_process_igtk_subelem(struct wpa_sm *sm, const u8 *igtk_elem,
+				       size_t igtk_elem_len)
+	u8 igtk[WPA_IGTK_LEN];
+	u16 keyidx;
+	if (sm->mgmt_group_cipher != WPA_CIPHER_AES_128_CMAC)
+		return 0;
+	if (igtk_elem == NULL) {
+		wpa_printf(MSG_DEBUG, "FT: No IGTK included in FTIE");
+		return 0;
+	wpa_hexdump_key(MSG_DEBUG, "FT: Received IGTK in Reassoc Resp",
+			igtk_elem, igtk_elem_len);
+	if (igtk_elem_len != 2 + 6 + 1 + WPA_IGTK_LEN + 8) {
+		wpa_printf(MSG_DEBUG, "FT: Invalid IGTK sub-elem "
+			   "length %lu", (unsigned long) igtk_elem_len);
+		return -1;
+	if (igtk_elem[8] != WPA_IGTK_LEN) {
+		wpa_printf(MSG_DEBUG, "FT: Invalid IGTK sub-elem Key Length "
+			   "%d", igtk_elem[8]);
+		return -1;
+	if (aes_unwrap(sm->ptk.kek, sm->ptk.kek_len, WPA_IGTK_LEN / 8,
+		       igtk_elem + 9, igtk)) {
+			   "decrypt IGTK");
+		return -1;
+	/* KeyID[2] | IPN[6] | Key Length[1] | Key[16+8] */
+	keyidx = WPA_GET_LE16(igtk_elem);
+	wpa_hexdump_key(MSG_DEBUG, "FT: IGTK from Reassoc Resp", igtk,
+			WPA_IGTK_LEN);
+	if (wpa_sm_set_key(sm, WPA_ALG_IGTK, broadcast_ether_addr, keyidx, 0,
+			   igtk_elem + 2, 6, igtk, WPA_IGTK_LEN) < 0) {
+		wpa_printf(MSG_WARNING, "WPA: Failed to set IGTK to the "
+			   "driver.");
+		return -1;
+	return 0;
+	unsigned int count;
+		return -1;
+		return -1;
+		return -1;
+		return -1;
+		return -1;
+	if (os_memcmp(ftie->anonce, sm->anonce, WPA_NONCE_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "FT: ANonce mismatch in FTIE");
+		wpa_hexdump(MSG_DEBUG, "FT: Received ANonce",
+			    ftie->anonce, WPA_NONCE_LEN);
+		wpa_hexdump(MSG_DEBUG, "FT: Expected ANonce",
+			    sm->anonce, WPA_NONCE_LEN);
+		return -1;
+		return -1;
+		return -1;
+		return -1;
+	if (os_memcmp_const(parse.r1kh_id, sm->r1kh_id, FT_R1KH_ID_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "FT: Unknown R1KH-ID used in "
+			   "ReassocResp");
+		return -1;
+	    os_memcmp_const(parse.rsn_pmkid, sm->pmk_r1_name, WPA_PMK_NAME_LEN))
+		wpa_printf(MSG_DEBUG, "FT: No matching PMKR1Name (PMKID) in "
+			   "RSNIE (pmkid=%d)", !!parse.rsn_pmkid);
+		return -1;
+	count = 3;
+	if (parse.ric)
+		count += ieee802_11_ie_count(parse.ric, parse.ric_len);
+	if (ftie->mic_control[1] != count) {
+		wpa_printf(MSG_DEBUG, "FT: Unexpected IE count in MIC "
+			   "Control: received %u expected %u",
+			   ftie->mic_control[1], count);
+		return -1;
+	if (wpa_ft_mic(sm->ptk.kck, sm->ptk.kck_len, sm->own_addr, src_addr, 6,
+		       parse.mdie - 2, parse.mdie_len + 2,
+		       parse.ftie - 2, parse.ftie_len + 2,
+		       parse.rsn - 2, parse.rsn_len + 2,
+		       parse.ric, parse.ric_len,
+		       mic) < 0) {
+		wpa_printf(MSG_DEBUG, "FT: Failed to calculate MIC");
+		return -1;
+	if (os_memcmp_const(mic, ftie->mic, 16) != 0) {
+		wpa_printf(MSG_DEBUG, "FT: Invalid MIC in FTIE");
+		wpa_hexdump(MSG_MSGDUMP, "FT: Received MIC", ftie->mic, 16);
+		wpa_hexdump(MSG_MSGDUMP, "FT: Calculated MIC", mic, 16);
+		return -1;
+	if (wpa_ft_process_gtk_subelem(sm, parse.gtk, parse.gtk_len) < 0)
+		return -1;
+	if (wpa_ft_process_igtk_subelem(sm, parse.igtk, parse.igtk_len) < 0)
+		return -1;
+	if (sm->set_ptk_after_assoc) {
+		wpa_printf(MSG_DEBUG, "FT: Try to set PTK again now that we "
+			   "are associated");
+		if (wpa_ft_install_ptk(sm, src_addr) < 0)
+			return -1;
+	if (parse.ric) {
+		wpa_hexdump(MSG_MSGDUMP, "FT: RIC Response",
+			    parse.ric, parse.ric_len);
+		/* TODO: parse response and inform driver about results when
+		 * using wpa_supplicant SME */
+	wpa_printf(MSG_DEBUG, "FT: Completed successfully");
+	return 0;
+ * wpa_ft_start_over_ds - Generate over-the-DS auth request
+ * @sm: Pointer to WPA state machine data from wpa_sm_init()
+ * @target_ap: Target AP Address
+ * @mdie: Mobility Domain IE from the target AP
+ * Returns: 0 on success, -1 on failure
+			 const u8 *mdie)
+	u8 *ft_ies;
+	wpa_printf(MSG_DEBUG, "FT: Request over-the-DS with " MACSTR,
+		   MAC2STR(target_ap));
+		return -1;
+				    NULL, 0, target_ap, NULL, 0, mdie);
+	if (ft_ies) {
+		sm->over_the_ds_in_progress = 1;
+		os_memcpy(sm->target_ap, target_ap, ETH_ALEN);
+		wpa_sm_send_ft_action(sm, 1, target_ap, ft_ies, ft_ies_len);
+		os_free(ft_ies);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h b/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h
index 00000000000..965a9c1d577
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa_i.h
@@ -0,0 +1,371 @@
+ * Internal WPA/RSN supplicant state machine definitions
+ * Copyright (c) 2004-2015, Jouni Malinen <j at w1.fi>
+#ifndef WPA_I_H
+#define WPA_I_H
+#include "utils/list.h"
+struct wpa_peerkey;
+struct wpa_tdls_peer;
+struct wpa_eapol_key;
+ * struct wpa_sm - Internal WPA state machine data
+struct wpa_sm {
+	u8 pmk[PMK_LEN];
+	size_t pmk_len;
+	struct wpa_ptk ptk, tptk;
+	int ptk_set, tptk_set;
+	unsigned int msg_3_of_4_ok:1;
+	u8 snonce[WPA_NONCE_LEN];
+	u8 anonce[WPA_NONCE_LEN]; /* ANonce from the last 1/4 msg */
+	int renew_snonce;
+	u8 rx_replay_counter[WPA_REPLAY_COUNTER_LEN];
+	int rx_replay_counter_set;
+	u8 request_counter[WPA_REPLAY_COUNTER_LEN];
+	struct eapol_sm *eapol; /* EAPOL state machine from upper level code */
+	struct rsn_pmksa_cache *pmksa; /* PMKSA cache */
+	struct rsn_pmksa_cache_entry *cur_pmksa; /* current PMKSA entry */
+	struct dl_list pmksa_candidates;
+	struct l2_packet_data *l2_preauth;
+	struct l2_packet_data *l2_preauth_br;
+	struct l2_packet_data *l2_tdls;
+	u8 preauth_bssid[ETH_ALEN]; /* current RSN pre-auth peer or
+				     * 00:00:00:00:00:00 if no pre-auth is
+				     * in progress */
+	struct eapol_sm *preauth_eapol;
+	struct wpa_sm_ctx *ctx;
+	void *scard_ctx; /* context for smartcard callbacks */
+	int fast_reauth; /* whether EAP fast re-authentication is enabled */
+	u8 ssid[32];
+	size_t ssid_len;
+	int p2p;
+	u8 own_addr[ETH_ALEN];
+	const char *ifname;
+	const char *bridge_ifname;
+	u8 bssid[ETH_ALEN];
+	unsigned int dot11RSNAConfigPMKLifetime;
+	unsigned int dot11RSNAConfigPMKReauthThreshold;
+	unsigned int dot11RSNAConfigSATimeout;
+	unsigned int dot11RSNA4WayHandshakeFailures;
+	/* Selected configuration (based on Beacon/ProbeResp WPA IE) */
+	unsigned int proto;
+	unsigned int pairwise_cipher;
+	unsigned int group_cipher;
+	unsigned int key_mgmt;
+	unsigned int mgmt_group_cipher;
+	int rsn_enabled; /* Whether RSN is enabled in configuration */
+	int mfp; /* 0 = disabled, 1 = optional, 2 = mandatory */
+	u8 *assoc_wpa_ie; /* Own WPA/RSN IE from (Re)AssocReq */
+	size_t assoc_wpa_ie_len;
+	u8 *ap_wpa_ie, *ap_rsn_ie;
+	size_t ap_wpa_ie_len, ap_rsn_ie_len;
+#ifdef CONFIG_TDLS
+	struct wpa_tdls_peer *tdls;
+	int tdls_prohibited;
+	int tdls_chan_switch_prohibited;
+	int tdls_disabled;
+	/* The driver supports TDLS */
+	int tdls_supported;
+	 * The driver requires explicit discovery/setup/teardown frames sent
+	 * to it via tdls_mgmt.
+	int tdls_external_setup;
+	/* The driver supports TDLS channel switching */
+	int tdls_chan_switch;
+	u8 xxkey[PMK_LEN]; /* PSK or the second 256 bits of MSK */
+	size_t xxkey_len;
+	u8 pmk_r0[PMK_LEN];
+	u8 pmk_r0_name[WPA_PMK_NAME_LEN];
+	u8 pmk_r1[PMK_LEN];
+	u8 pmk_r1_name[WPA_PMK_NAME_LEN];
+	u8 mobility_domain[MOBILITY_DOMAIN_ID_LEN];
+	u8 r0kh_id[FT_R0KH_ID_MAX_LEN];
+	size_t r0kh_id_len;
+	u8 r1kh_id[FT_R1KH_ID_LEN];
+	int ft_completed;
+	int over_the_ds_in_progress;
+	u8 target_ap[ETH_ALEN]; /* over-the-DS target AP */
+	int set_ptk_after_assoc;
+	u8 mdie_ft_capab; /* FT Capability and Policy from target AP MDIE */
+	u8 *assoc_resp_ies; /* MDIE and FTIE from (Re)Association Response */
+	size_t assoc_resp_ies_len;
+#ifdef CONFIG_P2P
+	u8 p2p_ip_addr[3 * 4];
+#endif /* CONFIG_P2P */
+static inline void wpa_sm_set_state(struct wpa_sm *sm, enum wpa_states state)
+	WPA_ASSERT(sm->ctx->set_state);
+	sm->ctx->set_state(sm->ctx->ctx, state);
+static inline enum wpa_states wpa_sm_get_state(struct wpa_sm *sm)
+	WPA_ASSERT(sm->ctx->get_state);
+	return sm->ctx->get_state(sm->ctx->ctx);
+static inline void wpa_sm_deauthenticate(struct wpa_sm *sm, int reason_code)
+	WPA_ASSERT(sm->ctx->deauthenticate);
+	sm->ctx->deauthenticate(sm->ctx->ctx, reason_code);
+static inline int wpa_sm_set_key(struct wpa_sm *sm, enum wpa_alg alg,
+	WPA_ASSERT(sm->ctx->set_key);
+	return sm->ctx->set_key(sm->ctx->ctx, alg, addr, key_idx, set_tx,
+				seq, seq_len, key, key_len);
+static inline void * wpa_sm_get_network_ctx(struct wpa_sm *sm)
+	WPA_ASSERT(sm->ctx->get_network_ctx);
+	return sm->ctx->get_network_ctx(sm->ctx->ctx);
+static inline int wpa_sm_get_bssid(struct wpa_sm *sm, u8 *bssid)
+	WPA_ASSERT(sm->ctx->get_bssid);
+	return sm->ctx->get_bssid(sm->ctx->ctx, bssid);
+static inline int wpa_sm_ether_send(struct wpa_sm *sm, const u8 *dest,
+				    u16 proto, const u8 *buf, size_t len)
+	WPA_ASSERT(sm->ctx->ether_send);
+	return sm->ctx->ether_send(sm->ctx->ctx, dest, proto, buf, len);
+static inline int wpa_sm_get_beacon_ie(struct wpa_sm *sm)
+	WPA_ASSERT(sm->ctx->get_beacon_ie);
+	return sm->ctx->get_beacon_ie(sm->ctx->ctx);
+static inline void wpa_sm_cancel_auth_timeout(struct wpa_sm *sm)
+	WPA_ASSERT(sm->ctx->cancel_auth_timeout);
+	sm->ctx->cancel_auth_timeout(sm->ctx->ctx);
+static inline u8 * wpa_sm_alloc_eapol(struct wpa_sm *sm, u8 type,
+				      const void *data, u16 data_len,
+	WPA_ASSERT(sm->ctx->alloc_eapol);
+	return sm->ctx->alloc_eapol(sm->ctx->ctx, type, data, data_len,
+				    msg_len, data_pos);
+static inline int wpa_sm_add_pmkid(struct wpa_sm *sm, const u8 *bssid,
+				   const u8 *pmkid)
+	WPA_ASSERT(sm->ctx->add_pmkid);
+	return sm->ctx->add_pmkid(sm->ctx->ctx, bssid, pmkid);
+static inline int wpa_sm_remove_pmkid(struct wpa_sm *sm, const u8 *bssid,
+				      const u8 *pmkid)
+	WPA_ASSERT(sm->ctx->remove_pmkid);
+	return sm->ctx->remove_pmkid(sm->ctx->ctx, bssid, pmkid);
+static inline int wpa_sm_mlme_setprotection(struct wpa_sm *sm, const u8 *addr,
+					    int protect_type, int key_type)
+	WPA_ASSERT(sm->ctx->mlme_setprotection);
+	return sm->ctx->mlme_setprotection(sm->ctx->ctx, addr, protect_type,
+					   key_type);
+static inline int wpa_sm_update_ft_ies(struct wpa_sm *sm, const u8 *md,
+	if (sm->ctx->update_ft_ies)
+		return sm->ctx->update_ft_ies(sm->ctx->ctx, md, ies, ies_len);
+	return -1;
+static inline int wpa_sm_send_ft_action(struct wpa_sm *sm, u8 action,
+	if (sm->ctx->send_ft_action)
+		return sm->ctx->send_ft_action(sm->ctx->ctx, action, target_ap,
+					       ies, ies_len);
+	return -1;
+static inline int wpa_sm_mark_authenticated(struct wpa_sm *sm,
+					    const u8 *target_ap)
+	if (sm->ctx->mark_authenticated)
+		return sm->ctx->mark_authenticated(sm->ctx->ctx, target_ap);
+	return -1;
+static inline void wpa_sm_set_rekey_offload(struct wpa_sm *sm)
+	if (!sm->ctx->set_rekey_offload)
+		return;
+	sm->ctx->set_rekey_offload(sm->ctx->ctx, sm->ptk.kek, sm->ptk.kek_len,
+				   sm->rx_replay_counter);
+#ifdef CONFIG_TDLS
+static inline int wpa_sm_tdls_get_capa(struct wpa_sm *sm,
+				       int *tdls_supported,
+				       int *tdls_chan_switch)
+	if (sm->ctx->tdls_get_capa)
+		return sm->ctx->tdls_get_capa(sm->ctx->ctx, tdls_supported,
+					      tdls_ext_setup, tdls_chan_switch);
+	return -1;
+static inline int wpa_sm_send_tdls_mgmt(struct wpa_sm *sm, const u8 *dst,
+					size_t len)
+	if (sm->ctx->send_tdls_mgmt)
+		return sm->ctx->send_tdls_mgmt(sm->ctx->ctx, dst, action_code,
+					       dialog_token, status_code,
+					       peer_capab, initiator, buf,
+					       len);
+	return -1;
+static inline int wpa_sm_tdls_oper(struct wpa_sm *sm, int oper,
+				   const u8 *peer)
+	if (sm->ctx->tdls_oper)
+		return sm->ctx->tdls_oper(sm->ctx->ctx, oper, peer);
+	return -1;
+static inline int
+wpa_sm_tdls_peer_addset(struct wpa_sm *sm, const u8 *addr, int add,
+			u16 aid, u16 capability, const u8 *supp_rates,
+			size_t supp_channels_len, const u8 *supp_oper_classes,
+	if (sm->ctx->tdls_peer_addset)
+		return sm->ctx->tdls_peer_addset(sm->ctx->ctx, addr, add,
+						 aid, capability, supp_rates,
+						 supp_rates_len, ht_capab,
+						 vht_capab, qosinfo, wmm,
+						 ext_capab, ext_capab_len,
+						 supp_channels,
+						 supp_channels_len,
+						 supp_oper_classes,
+						 supp_oper_classes_len);
+	return -1;
+static inline int
+wpa_sm_tdls_enable_channel_switch(struct wpa_sm *sm, const u8 *addr,
+				  u8 oper_class,
+				  const struct hostapd_freq_params *freq_params)
+	if (sm->ctx->tdls_enable_channel_switch)
+		return sm->ctx->tdls_enable_channel_switch(sm->ctx->ctx, addr,
+							   oper_class,
+							   freq_params);
+	return -1;
+static inline int
+wpa_sm_tdls_disable_channel_switch(struct wpa_sm *sm, const u8 *addr)
+	if (sm->ctx->tdls_disable_channel_switch)
+		return sm->ctx->tdls_disable_channel_switch(sm->ctx->ctx, addr);
+	return -1;
+static inline int wpa_sm_key_mgmt_set_pmk(struct wpa_sm *sm,
+					  const u8 *pmk, size_t pmk_len)
+	if (!sm->proactive_key_caching)
+		return 0;
+	if (!sm->ctx->key_mgmt_set_pmk)
+		return -1;
+	return sm->ctx->key_mgmt_set_pmk(sm->ctx->ctx, pmk, pmk_len);
+void wpa_eapol_key_send(struct wpa_sm *sm, const u8 *kck, size_t kck_len,
+			int ver, const u8 *dest, u16 proto,
+			u8 *msg, size_t msg_len, u8 *key_mic);
+int wpa_supplicant_send_2_of_4(struct wpa_sm *sm, const unsigned char *dst,
+			       int ver, const u8 *nonce,
+			       const u8 *wpa_ie, size_t wpa_ie_len,
+			       struct wpa_ptk *ptk);
+int wpa_supplicant_send_4_of_4(struct wpa_sm *sm, const unsigned char *dst,
+			       u16 ver, u16 key_info,
+		      const struct wpa_eapol_key *key, struct wpa_ptk *ptk);
+void wpa_tdls_assoc(struct wpa_sm *sm);
+void wpa_tdls_disassoc(struct wpa_sm *sm);
+#endif /* WPA_I_H */
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c b/freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c
index 00000000000..2a22d7de019
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c
@@ -0,0 +1,607 @@
+ * wpa_supplicant - WPA/RSN IE and KDE processing
+#include "wpa.h"
+#include "pmksa_cache.h"
+#include "wpa_i.h"
+#include "wpa_ie.h"
+ * wpa_parse_wpa_ie - Parse WPA/RSN IE
+ * @wpa_ie: Pointer to WPA or RSN IE
+ * @wpa_ie_len: Length of the WPA/RSN IE
+ * Parse the contents of WPA or RSN IE and write the parsed data into data.
+	if (wpa_ie_len >= 1 && wpa_ie[0] == WLAN_EID_RSN)
+		return wpa_parse_wpa_ie_rsn(wpa_ie, wpa_ie_len, data);
+	if (wpa_ie_len >= 6 && wpa_ie[0] == WLAN_EID_VENDOR_SPECIFIC &&
+	    wpa_ie[1] >= 4 && WPA_GET_BE32(&wpa_ie[2]) == OSEN_IE_VENDOR_TYPE)
+	else
+		return wpa_parse_wpa_ie_wpa(wpa_ie, wpa_ie_len, data);
+static int wpa_gen_wpa_ie_wpa(u8 *wpa_ie, size_t wpa_ie_len,
+			      int pairwise_cipher, int group_cipher,
+			      int key_mgmt)
+	u8 *pos;
+	struct wpa_ie_hdr *hdr;
+	u32 suite;
+	if (wpa_ie_len < sizeof(*hdr) + WPA_SELECTOR_LEN +
+	    2 + WPA_SELECTOR_LEN + 2 + WPA_SELECTOR_LEN)
+		return -1;
+	hdr = (struct wpa_ie_hdr *) wpa_ie;
+	hdr->elem_id = WLAN_EID_VENDOR_SPECIFIC;
+	RSN_SELECTOR_PUT(hdr->oui, WPA_OUI_TYPE);
+	WPA_PUT_LE16(hdr->version, WPA_VERSION);
+	pos = (u8 *) (hdr + 1);
+	suite = wpa_cipher_to_suite(WPA_PROTO_WPA, group_cipher);
+	if (suite == 0) {
+		wpa_printf(MSG_WARNING, "Invalid group cipher (%d).",
+			   group_cipher);
+		return -1;
+	RSN_SELECTOR_PUT(pos, suite);
+	pos += WPA_SELECTOR_LEN;
+	*pos++ = 1;
+	*pos++ = 0;
+	suite = wpa_cipher_to_suite(WPA_PROTO_WPA, pairwise_cipher);
+	if (suite == 0 ||
+	    (!wpa_cipher_valid_pairwise(pairwise_cipher) &&
+	     pairwise_cipher != WPA_CIPHER_NONE)) {
+		wpa_printf(MSG_WARNING, "Invalid pairwise cipher (%d).",
+			   pairwise_cipher);
+		return -1;
+	*pos++ = 1;
+	*pos++ = 0;
+	if (key_mgmt == WPA_KEY_MGMT_IEEE8021X) {
+		RSN_SELECTOR_PUT(pos, WPA_AUTH_KEY_MGMT_UNSPEC_802_1X);
+	} else if (key_mgmt == WPA_KEY_MGMT_PSK) {
+		RSN_SELECTOR_PUT(pos, WPA_AUTH_KEY_MGMT_PSK_OVER_802_1X);
+	} else if (key_mgmt == WPA_KEY_MGMT_WPA_NONE) {
+		RSN_SELECTOR_PUT(pos, WPA_AUTH_KEY_MGMT_NONE);
+	} else if (key_mgmt == WPA_KEY_MGMT_CCKM) {
+		RSN_SELECTOR_PUT(pos, WPA_AUTH_KEY_MGMT_CCKM);
+	} else {
+		wpa_printf(MSG_WARNING, "Invalid key management type (%d).",
+			   key_mgmt);
+		return -1;
+	/* WPA Capabilities; use defaults, so no need to include it */
+	hdr->len = (pos - wpa_ie) - 2;
+	WPA_ASSERT((size_t) (pos - wpa_ie) <= wpa_ie_len);
+	return pos - wpa_ie;
+static int wpa_gen_wpa_ie_rsn(u8 *rsn_ie, size_t rsn_ie_len,
+			      int key_mgmt, int mgmt_group_cipher,
+			      struct wpa_sm *sm)
+	u8 *pos;
+	struct rsn_ie_hdr *hdr;
+	u16 capab;
+	u32 suite;
+	if (rsn_ie_len < sizeof(*hdr) + RSN_SELECTOR_LEN +
+	    2 + RSN_SELECTOR_LEN + 2 + RSN_SELECTOR_LEN + 2 +
+	    (sm->cur_pmksa ? 2 + PMKID_LEN : 0)) {
+		wpa_printf(MSG_DEBUG, "RSN: Too short IE buffer (%lu bytes)",
+			   (unsigned long) rsn_ie_len);
+		return -1;
+	hdr = (struct rsn_ie_hdr *) rsn_ie;
+	hdr->elem_id = WLAN_EID_RSN;
+	WPA_PUT_LE16(hdr->version, RSN_VERSION);
+	suite = wpa_cipher_to_suite(WPA_PROTO_RSN, group_cipher);
+	if (suite == 0) {
+			   group_cipher);
+		return -1;
+	*pos++ = 1;
+	*pos++ = 0;
+	suite = wpa_cipher_to_suite(WPA_PROTO_RSN, pairwise_cipher);
+	if (suite == 0 ||
+			   pairwise_cipher);
+		return -1;
+	*pos++ = 1;
+	*pos++ = 0;
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_UNSPEC_802_1X);
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_PSK_OVER_802_1X);
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_CCKM);
+	} else if (key_mgmt == WPA_KEY_MGMT_FT_IEEE8021X) {
+	} else if (key_mgmt == WPA_KEY_MGMT_FT_PSK) {
+	} else if (key_mgmt == WPA_KEY_MGMT_IEEE8021X_SHA256) {
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_802_1X_SHA256);
+	} else if (key_mgmt == WPA_KEY_MGMT_PSK_SHA256) {
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_PSK_SHA256);
+#ifdef CONFIG_SAE
+	} else if (key_mgmt == WPA_KEY_MGMT_SAE) {
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_SAE);
+	} else if (key_mgmt == WPA_KEY_MGMT_FT_SAE) {
+#endif /* CONFIG_SAE */
+	} else if (key_mgmt == WPA_KEY_MGMT_IEEE8021X_SUITE_B_192) {
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_802_1X_SUITE_B_192);
+	} else if (key_mgmt == WPA_KEY_MGMT_IEEE8021X_SUITE_B) {
+		RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_802_1X_SUITE_B);
+	} else {
+			   key_mgmt);
+		return -1;
+	capab = 0;
+	if (sm->mfp)
+	if (sm->mfp == 2)
+		capab |= WPA_CAPABILITY_MFPR;
+	pos += 2;
+	if (sm->cur_pmksa) {
+		/* PMKID Count (2 octets, little endian) */
+		*pos++ = 1;
+		*pos++ = 0;
+		/* PMKID */
+		os_memcpy(pos, sm->cur_pmksa->pmkid, PMKID_LEN);
+		pos += PMKID_LEN;
+	if (wpa_cipher_valid_mgmt_group(mgmt_group_cipher)) {
+		if (!sm->cur_pmksa) {
+			/* PMKID Count */
+			WPA_PUT_LE16(pos, 0);
+			pos += 2;
+							  mgmt_group_cipher));
+	hdr->len = (pos - rsn_ie) - 2;
+	WPA_ASSERT((size_t) (pos - rsn_ie) <= rsn_ie_len);
+	return pos - rsn_ie;
+#ifdef CONFIG_HS20
+static int wpa_gen_wpa_ie_osen(u8 *wpa_ie, size_t wpa_ie_len,
+			       int key_mgmt)
+	u8 *pos, *len;
+	u32 suite;
+	if (wpa_ie_len < 2 + 4 + RSN_SELECTOR_LEN +
+	    2 + RSN_SELECTOR_LEN + 2 + RSN_SELECTOR_LEN)
+		return -1;
+	pos = wpa_ie;
+	*pos++ = WLAN_EID_VENDOR_SPECIFIC;
+	len = pos++; /* to be filled */
+	WPA_PUT_BE24(pos, OUI_WFA);
+	pos += 3;
+	*pos++ = HS20_OSEN_OUI_TYPE;
+	/* Group Data Cipher Suite */
+	if (suite == 0) {
+			   group_cipher);
+		return -1;
+	/* Pairwise Cipher Suite Count and List */
+	pos += 2;
+	if (suite == 0 ||
+			   pairwise_cipher);
+		return -1;
+	/* AKM Suite Count and List */
+	pos += 2;
+	RSN_SELECTOR_PUT(pos, RSN_AUTH_KEY_MGMT_OSEN);
+	*len = pos - len - 1;
+#endif /* CONFIG_HS20 */
+ * wpa_gen_wpa_ie - Generate WPA/RSN IE based on current security policy
+ * @wpa_ie: Pointer to memory area for the generated WPA/RSN IE
+ * @wpa_ie_len: Maximum length of the generated WPA/RSN IE
+ * Returns: Length of the generated WPA/RSN IE or -1 on failure
+int wpa_gen_wpa_ie(struct wpa_sm *sm, u8 *wpa_ie, size_t wpa_ie_len)
+	if (sm->proto == WPA_PROTO_RSN)
+		return wpa_gen_wpa_ie_rsn(wpa_ie, wpa_ie_len,
+					  sm->pairwise_cipher,
+					  sm->group_cipher,
+					  sm->key_mgmt, sm->mgmt_group_cipher,
+					  sm);
+#ifdef CONFIG_HS20
+	else if (sm->proto == WPA_PROTO_OSEN)
+		return wpa_gen_wpa_ie_osen(wpa_ie, wpa_ie_len,
+					   sm->group_cipher,
+					   sm->key_mgmt);
+	else
+		return wpa_gen_wpa_ie_wpa(wpa_ie, wpa_ie_len,
+					  sm->group_cipher,
+					  sm->key_mgmt);
+ * wpa_parse_vendor_specific - Parse Vendor Specific IEs
+ * @pos: Pointer to the IE header
+ * @end: Pointer to the end of the Key Data buffer
+ * @ie: Pointer to parsed IE data
+ * Returns: 0 on success, 1 if end mark is found, -1 on failure
+static int wpa_parse_vendor_specific(const u8 *pos, const u8 *end,
+				     struct wpa_eapol_ie_parse *ie)
+	unsigned int oui;
+	if (pos[1] < 4) {
+		wpa_printf(MSG_MSGDUMP, "Too short vendor specific IE ignored (len=%u)",
+			   pos[1]);
+		return 1;
+	oui = WPA_GET_BE24(&pos[2]);
+	if (oui == OUI_MICROSOFT && pos[5] == WMM_OUI_TYPE && pos[1] > 4) {
+		if (pos[6] == WMM_OUI_SUBTYPE_INFORMATION_ELEMENT) {
+			ie->wmm = &pos[2];
+			ie->wmm_len = pos[1];
+			wpa_hexdump(MSG_DEBUG, "WPA: WMM IE",
+				    ie->wmm, ie->wmm_len);
+		} else if (pos[6] == WMM_OUI_SUBTYPE_PARAMETER_ELEMENT) {
+			wpa_hexdump(MSG_DEBUG, "WPA: WMM Parameter Element",
+	return 0;
+ * wpa_parse_generic - Parse EAPOL-Key Key Data Generic IEs
+static int wpa_parse_generic(const u8 *pos, const u8 *end,
+	if (pos[1] == 0)
+		return 1;
+	if (pos[1] >= 6 &&
+	    RSN_SELECTOR_GET(pos + 2) == WPA_OUI_TYPE &&
+	    pos[2 + WPA_SELECTOR_LEN] == 1 &&
+	    pos[2 + WPA_SELECTOR_LEN + 1] == 0) {
+		ie->wpa_ie = pos;
+		ie->wpa_ie_len = pos[1] + 2;
+		wpa_hexdump(MSG_DEBUG, "WPA: WPA IE in EAPOL-Key",
+			    ie->wpa_ie, ie->wpa_ie_len);
+		return 0;
+	if (pos + 1 + RSN_SELECTOR_LEN < end &&
+	    pos[1] >= RSN_SELECTOR_LEN + PMKID_LEN &&
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_PMKID) {
+		ie->pmkid = pos + 2 + RSN_SELECTOR_LEN;
+		wpa_hexdump(MSG_DEBUG, "WPA: PMKID in EAPOL-Key",
+			    pos, pos[1] + 2);
+		return 0;
+	if (pos[1] > RSN_SELECTOR_LEN + 2 &&
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_GROUPKEY) {
+		ie->gtk = pos + 2 + RSN_SELECTOR_LEN;
+		ie->gtk_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump_key(MSG_DEBUG, "WPA: GTK in EAPOL-Key",
+				pos, pos[1] + 2);
+		return 0;
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_MAC_ADDR) {
+		ie->mac_addr = pos + 2 + RSN_SELECTOR_LEN;
+		ie->mac_addr_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump(MSG_DEBUG, "WPA: MAC Address in EAPOL-Key",
+			    pos, pos[1] + 2);
+		return 0;
+#ifdef CONFIG_PEERKEY
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_SMK) {
+		ie->smk = pos + 2 + RSN_SELECTOR_LEN;
+		ie->smk_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump_key(MSG_DEBUG, "WPA: SMK in EAPOL-Key",
+				pos, pos[1] + 2);
+		return 0;
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_NONCE) {
+		ie->nonce = pos + 2 + RSN_SELECTOR_LEN;
+		ie->nonce_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump(MSG_DEBUG, "WPA: Nonce in EAPOL-Key",
+			    pos, pos[1] + 2);
+		return 0;
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_LIFETIME) {
+		ie->lifetime = pos + 2 + RSN_SELECTOR_LEN;
+		ie->lifetime_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump(MSG_DEBUG, "WPA: Lifetime in EAPOL-Key",
+			    pos, pos[1] + 2);
+		return 0;
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_ERROR) {
+		ie->error = pos + 2 + RSN_SELECTOR_LEN;
+		ie->error_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump(MSG_DEBUG, "WPA: Error in EAPOL-Key",
+			    pos, pos[1] + 2);
+		return 0;
+#endif /* CONFIG_PEERKEY */
+	    RSN_SELECTOR_GET(pos + 2) == RSN_KEY_DATA_IGTK) {
+		ie->igtk = pos + 2 + RSN_SELECTOR_LEN;
+		ie->igtk_len = pos[1] - RSN_SELECTOR_LEN;
+		wpa_hexdump_key(MSG_DEBUG, "WPA: IGTK in EAPOL-Key",
+				pos, pos[1] + 2);
+		return 0;
+#ifdef CONFIG_P2P
+	if (pos[1] >= RSN_SELECTOR_LEN + 1 &&
+	    RSN_SELECTOR_GET(pos + 2) == WFA_KEY_DATA_IP_ADDR_REQ) {
+		ie->ip_addr_req = pos + 2 + RSN_SELECTOR_LEN;
+		wpa_hexdump(MSG_DEBUG, "WPA: IP Address Request in EAPOL-Key",
+			    ie->ip_addr_req, pos[1] - RSN_SELECTOR_LEN);
+		return 0;
+	if (pos[1] >= RSN_SELECTOR_LEN + 3 * 4 &&
+	    RSN_SELECTOR_GET(pos + 2) == WFA_KEY_DATA_IP_ADDR_ALLOC) {
+		ie->ip_addr_alloc = pos + 2 + RSN_SELECTOR_LEN;
+			    "WPA: IP Address Allocation in EAPOL-Key",
+			    ie->ip_addr_alloc, pos[1] - RSN_SELECTOR_LEN);
+		return 0;
+	return 0;
+ * wpa_supplicant_parse_ies - Parse EAPOL-Key Key Data IEs
+ * @buf: Pointer to the Key Data buffer
+ * @len: Key Data Length
+int wpa_supplicant_parse_ies(const u8 *buf, size_t len,
+	const u8 *pos, *end;
+	int ret = 0;
+	os_memset(ie, 0, sizeof(*ie));
+	for (pos = buf, end = pos + len; pos + 1 < end; pos += 2 + pos[1]) {
+		if (pos[0] == 0xdd &&
+		    ((pos == buf + len - 1) || pos[1] == 0)) {
+			/* Ignore padding */
+			break;
+		if (pos + 2 + pos[1] > end) {
+			wpa_printf(MSG_DEBUG, "WPA: EAPOL-Key Key Data "
+				   "underflow (ie=%d len=%d pos=%d)",
+				   pos[0], pos[1], (int) (pos - buf));
+			wpa_hexdump_key(MSG_DEBUG, "WPA: Key Data",
+					buf, len);
+			ret = -1;
+			break;
+		if (*pos == WLAN_EID_RSN) {
+			ie->rsn_ie = pos;
+			ie->rsn_ie_len = pos[1] + 2;
+			wpa_hexdump(MSG_DEBUG, "WPA: RSN IE in EAPOL-Key",
+				    ie->rsn_ie, ie->rsn_ie_len);
+		} else if (*pos == WLAN_EID_MOBILITY_DOMAIN &&
+			   pos[1] >= sizeof(struct rsn_mdie)) {
+			ie->mdie = pos;
+			ie->mdie_len = pos[1] + 2;
+			wpa_hexdump(MSG_DEBUG, "WPA: MDIE in EAPOL-Key",
+				    ie->mdie, ie->mdie_len);
+		} else if (*pos == WLAN_EID_FAST_BSS_TRANSITION &&
+			   pos[1] >= sizeof(struct rsn_ftie)) {
+			ie->ftie = pos;
+			ie->ftie_len = pos[1] + 2;
+			wpa_hexdump(MSG_DEBUG, "WPA: FTIE in EAPOL-Key",
+				    ie->ftie, ie->ftie_len);
+		} else if (*pos == WLAN_EID_TIMEOUT_INTERVAL && pos[1] >= 5) {
+			if (pos[2] == WLAN_TIMEOUT_REASSOC_DEADLINE) {
+				ie->reassoc_deadline = pos;
+				wpa_hexdump(MSG_DEBUG, "WPA: Reassoc Deadline "
+					    "in EAPOL-Key",
+					    ie->reassoc_deadline, pos[1] + 2);
+			} else if (pos[2] == WLAN_TIMEOUT_KEY_LIFETIME) {
+				ie->key_lifetime = pos;
+				wpa_hexdump(MSG_DEBUG, "WPA: KeyLifetime "
+					    "in EAPOL-Key",
+					    ie->key_lifetime, pos[1] + 2);
+			} else {
+				wpa_hexdump(MSG_DEBUG, "WPA: Unrecognized "
+					    "EAPOL-Key Key Data IE",
+					    pos, 2 + pos[1]);
+		} else if (*pos == WLAN_EID_LINK_ID) {
+			if (pos[1] >= 18) {
+				ie->lnkid = pos;
+				ie->lnkid_len = pos[1] + 2;
+		} else if (*pos == WLAN_EID_EXT_CAPAB) {
+			ie->ext_capab = pos;
+			ie->ext_capab_len = pos[1] + 2;
+		} else if (*pos == WLAN_EID_SUPP_RATES) {
+			ie->supp_rates = pos;
+			ie->supp_rates_len = pos[1] + 2;
+		} else if (*pos == WLAN_EID_EXT_SUPP_RATES) {
+			ie->ext_supp_rates = pos;
+			ie->ext_supp_rates_len = pos[1] + 2;
+		} else if (*pos == WLAN_EID_HT_CAP &&
+			   pos[1] >= sizeof(struct ieee80211_ht_capabilities)) {
+			ie->ht_capabilities = pos + 2;
+		} else if (*pos == WLAN_EID_VHT_AID) {
+			if (pos[1] >= 2)
+				ie->aid = WPA_GET_LE16(pos + 2) & 0x3fff;
+		} else if (*pos == WLAN_EID_VHT_CAP &&
+			   pos[1] >= sizeof(struct ieee80211_vht_capabilities))
+			ie->vht_capabilities = pos + 2;
+		} else if (*pos == WLAN_EID_QOS && pos[1] >= 1) {
+			ie->qosinfo = pos[2];
+		} else if (*pos == WLAN_EID_SUPPORTED_CHANNELS) {
+			ie->supp_channels = pos + 2;
+			ie->supp_channels_len = pos[1];
+		} else if (*pos == WLAN_EID_SUPPORTED_OPERATING_CLASSES) {
+			 * The value of the Length field of the Supported
+			 * Operating Classes element is between 2 and 253.
+			 * Silently skip invalid elements to avoid interop
+			 * issues when trying to use the value.
+			if (pos[1] >= 2 && pos[1] <= 253) {
+				ie->supp_oper_classes = pos + 2;
+				ie->supp_oper_classes_len = pos[1];
+		} else if (*pos == WLAN_EID_VENDOR_SPECIFIC) {
+			ret = wpa_parse_generic(pos, end, ie);
+			if (ret < 0)
+				break;
+			if (ret > 0) {
+				ret = 0;
+				break;
+			ret = wpa_parse_vendor_specific(pos, end, ie);
+			if (ret < 0)
+				break;
+			if (ret > 0) {
+				ret = 0;
+				break;
+		} else {
+			wpa_hexdump(MSG_DEBUG, "WPA: Unrecognized EAPOL-Key "
+				    "Key Data IE", pos, 2 + pos[1]);
+	return ret;
diff --git a/freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h b/freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h
index 00000000000..fe95af0abc5
--- /dev/null
+++ b/freebsd/contrib/wpa/src/rsn_supp/wpa_ie.h
@@ -0,0 +1,72 @@
+ * wpa_supplicant - WPA/RSN IE and KDE definitions
+ * Copyright (c) 2004-2007, Jouni Malinen <j at w1.fi>
+#ifndef WPA_IE_H
+#define WPA_IE_H
+struct wpa_sm;
+struct wpa_eapol_ie_parse {
+	const u8 *wpa_ie;
+	size_t wpa_ie_len;
+	const u8 *rsn_ie;
+	size_t rsn_ie_len;
+	const u8 *pmkid;
+	const u8 *gtk;
+	size_t gtk_len;
+	const u8 *mac_addr;
+	size_t mac_addr_len;
+	const u8 *smk;
+	size_t smk_len;
+	const u8 *nonce;
+	size_t nonce_len;
+	const u8 *lifetime;
+	size_t lifetime_len;
+	const u8 *error;
+	size_t error_len;
+	const u8 *igtk;
+	size_t igtk_len;
+	const u8 *mdie;
+	size_t mdie_len;
+	const u8 *ftie;
+	size_t ftie_len;
+	const u8 *reassoc_deadline;
+	const u8 *key_lifetime;
+	const u8 *lnkid;
+	size_t lnkid_len;
+	const u8 *ext_capab;
+	size_t ext_capab_len;
+	const u8 *supp_rates;
+	size_t supp_rates_len;
+	const u8 *ext_supp_rates;
+	size_t ext_supp_rates_len;
+	const u8 *ht_capabilities;
+	const u8 *vht_capabilities;
+	const u8 *supp_channels;
+	size_t supp_channels_len;
+	const u8 *supp_oper_classes;
+	size_t supp_oper_classes_len;
+	u8 qosinfo;
+	u16 aid;
+	const u8 *wmm;
+	size_t wmm_len;
+#ifdef CONFIG_P2P
+	const u8 *ip_addr_req;
+	const u8 *ip_addr_alloc;
+			     struct wpa_eapol_ie_parse *ie);
+int wpa_gen_wpa_ie(struct wpa_sm *sm, u8 *wpa_ie, size_t wpa_ie_len);
+#endif /* WPA_IE_H */
diff --git a/freebsd/contrib/wpa/src/tls/tlsv1_client.h b/freebsd/contrib/wpa/src/tls/tlsv1_client.h
index 00000000000..a4e25e96993
--- /dev/null
+++ b/freebsd/contrib/wpa/src/tls/tlsv1_client.h
@@ -0,0 +1,54 @@
+ * TLS v1.0/v1.1/v1.2 client (RFC 2246, RFC 4346, RFC 5246)
+ * Copyright (c) 2006-2011, Jouni Malinen <j at w1.fi>
+#ifndef TLSV1_CLIENT_H
+#define TLSV1_CLIENT_H
+#include "tlsv1_cred.h"
+struct tlsv1_client;
+int tlsv1_client_global_init(void);
+void tlsv1_client_global_deinit(void);
+struct tlsv1_client * tlsv1_client_init(void);
+void tlsv1_client_deinit(struct tlsv1_client *conn);
+int tlsv1_client_established(struct tlsv1_client *conn);
+int tlsv1_client_prf(struct tlsv1_client *conn, const char *label,
+		     int server_random_first, u8 *out, size_t out_len);
+u8 * tlsv1_client_handshake(struct tlsv1_client *conn,
+			    const u8 *in_data, size_t in_len,
+			    size_t *out_len, u8 **appl_data,
+			    size_t *appl_data_len, int *need_more_data);
+int tlsv1_client_encrypt(struct tlsv1_client *conn,
+			 u8 *out_data, size_t out_len);
+struct wpabuf * tlsv1_client_decrypt(struct tlsv1_client *conn,
+				     int *need_more_data);
+int tlsv1_client_get_cipher(struct tlsv1_client *conn, char *buf,
+			    size_t buflen);
+int tlsv1_client_shutdown(struct tlsv1_client *conn);
+int tlsv1_client_resumed(struct tlsv1_client *conn);
+int tlsv1_client_hello_ext(struct tlsv1_client *conn, int ext_type,
+			   const u8 *data, size_t data_len);
+int tlsv1_client_get_random(struct tlsv1_client *conn, struct tls_random *data);
+int tlsv1_client_get_keyblock_size(struct tlsv1_client *conn);
+int tlsv1_client_set_cipher_list(struct tlsv1_client *conn, u8 *ciphers);
+int tlsv1_client_set_cred(struct tlsv1_client *conn,
+			  struct tlsv1_credentials *cred);
+void tlsv1_client_set_time_checks(struct tlsv1_client *conn, int enabled);
+typedef int (*tlsv1_client_session_ticket_cb)
+(void *ctx, const u8 *ticket, size_t len, const u8 *client_random,
+ const u8 *server_random, u8 *master_secret);
+void tlsv1_client_set_session_ticket_cb(struct tlsv1_client *conn,
+					tlsv1_client_session_ticket_cb cb,
+					void *ctx);
+#endif /* TLSV1_CLIENT_H */
diff --git a/freebsd/contrib/wpa/src/tls/tlsv1_cred.h b/freebsd/contrib/wpa/src/tls/tlsv1_cred.h
index 00000000000..68fbdc92300
--- /dev/null
+++ b/freebsd/contrib/wpa/src/tls/tlsv1_cred.h
@@ -0,0 +1,40 @@
+ * TLSv1 credentials
+ * Copyright (c) 2006-2007, Jouni Malinen <j at w1.fi>
+#ifndef TLSV1_CRED_H
+#define TLSV1_CRED_H
+struct tlsv1_credentials {
+	struct x509_certificate *trusted_certs;
+	struct x509_certificate *cert;
+	struct crypto_private_key *key;
+	/* Diffie-Hellman parameters */
+	u8 *dh_p; /* prime */
+	size_t dh_p_len;
+	u8 *dh_g; /* generator */
+	size_t dh_g_len;
+struct tlsv1_credentials * tlsv1_cred_alloc(void);
+void tlsv1_cred_free(struct tlsv1_credentials *cred);
+int tlsv1_set_ca_cert(struct tlsv1_credentials *cred, const char *cert,
+		      const u8 *cert_blob, size_t cert_blob_len,
+		      const char *path);
+int tlsv1_set_cert(struct tlsv1_credentials *cred, const char *cert,
+		   const u8 *cert_blob, size_t cert_blob_len);
+int tlsv1_set_private_key(struct tlsv1_credentials *cred,
+			  const char *private_key,
+			  const char *private_key_passwd,
+			  const u8 *private_key_blob,
+			  size_t private_key_blob_len);
+int tlsv1_set_dhparams(struct tlsv1_credentials *cred, const char *dh_file,
+		       const u8 *dh_blob, size_t dh_blob_len);
+#endif /* TLSV1_CRED_H */
diff --git a/freebsd/contrib/wpa/src/tls/tlsv1_server.h b/freebsd/contrib/wpa/src/tls/tlsv1_server.h
index 00000000000..10e7699312b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/tls/tlsv1_server.h
@@ -0,0 +1,53 @@
+ * TLS v1.0/v1.1/v1.2 server (RFC 2246, RFC 4346, RFC 5246)
+#ifndef TLSV1_SERVER_H
+#define TLSV1_SERVER_H
+struct tlsv1_server;
+int tlsv1_server_global_init(void);
+void tlsv1_server_global_deinit(void);
+struct tlsv1_server * tlsv1_server_init(struct tlsv1_credentials *cred);
+void tlsv1_server_deinit(struct tlsv1_server *conn);
+int tlsv1_server_established(struct tlsv1_server *conn);
+int tlsv1_server_prf(struct tlsv1_server *conn, const char *label,
+u8 * tlsv1_server_handshake(struct tlsv1_server *conn,
+			    const u8 *in_data, size_t in_len, size_t *out_len);
+int tlsv1_server_encrypt(struct tlsv1_server *conn,
+int tlsv1_server_decrypt(struct tlsv1_server *conn,
+int tlsv1_server_get_cipher(struct tlsv1_server *conn, char *buf,
+			    size_t buflen);
+int tlsv1_server_shutdown(struct tlsv1_server *conn);
+int tlsv1_server_resumed(struct tlsv1_server *conn);
+int tlsv1_server_get_random(struct tlsv1_server *conn, struct tls_random *data);
+int tlsv1_server_get_keyblock_size(struct tlsv1_server *conn);
+int tlsv1_server_set_cipher_list(struct tlsv1_server *conn, u8 *ciphers);
+int tlsv1_server_set_verify(struct tlsv1_server *conn, int verify_peer);
+typedef int (*tlsv1_server_session_ticket_cb)
+void tlsv1_server_set_session_ticket_cb(struct tlsv1_server *conn,
+					tlsv1_server_session_ticket_cb cb,
+					void *ctx);
+void tlsv1_server_set_log_cb(struct tlsv1_server *conn,
+			     void (*cb)(void *ctx, const char *msg), void *ctx);
+void tlsv1_server_set_test_flags(struct tlsv1_server *conn, u32 flags);
+#endif /* TLSV1_SERVER_H */
diff --git a/freebsd/contrib/wpa/src/utils/base64.c b/freebsd/contrib/wpa/src/utils/base64.c
index 00000000000..4127950f485
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/base64.c
@@ -0,0 +1,159 @@
+ * Base64 encoding/decoding (RFC1341)
+ * Copyright (c) 2005-2011, Jouni Malinen <j at w1.fi>
+#include "os.h"
+#include "base64.h"
+static const unsigned char base64_table[65] =
+	"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
+ * base64_encode - Base64 encode
+ * @src: Data to be encoded
+ * @len: Length of the data to be encoded
+ * @out_len: Pointer to output length variable, or %NULL if not used
+ * Returns: Allocated buffer of out_len bytes of encoded data,
+ * or %NULL on failure
+ * Caller is responsible for freeing the returned buffer. Returned buffer is
+ * nul terminated to make it easier to use as a C string. The nul terminator is
+ * not included in out_len.
+unsigned char * base64_encode(const unsigned char *src, size_t len,
+			      size_t *out_len)
+	unsigned char *out, *pos;
+	const unsigned char *end, *in;
+	size_t olen;
+	int line_len;
+	olen = len * 4 / 3 + 4; /* 3-byte blocks to 4-byte */
+	olen += olen / 72; /* line feeds */
+	olen++; /* nul termination */
+	if (olen < len)
+		return NULL; /* integer overflow */
+	out = os_malloc(olen);
+	if (out == NULL)
+		return NULL;
+	end = src + len;
+	in = src;
+	pos = out;
+	line_len = 0;
+	while (end - in >= 3) {
+		*pos++ = base64_table[(in[0] >> 2) & 0x3f];
+		*pos++ = base64_table[(((in[0] & 0x03) << 4) |
+				       (in[1] >> 4)) & 0x3f];
+		*pos++ = base64_table[(((in[1] & 0x0f) << 2) |
+				       (in[2] >> 6)) & 0x3f];
+		*pos++ = base64_table[in[2] & 0x3f];
+		in += 3;
+		line_len += 4;
+		if (line_len >= 72) {
+			*pos++ = '\n';
+			line_len = 0;
+	if (end - in) {
+		if (end - in == 1) {
+			*pos++ = base64_table[((in[0] & 0x03) << 4) & 0x3f];
+			*pos++ = '=';
+		} else {
+			*pos++ = base64_table[((in[1] & 0x0f) << 2) & 0x3f];
+		*pos++ = '=';
+		line_len += 4;
+	if (line_len)
+		*pos++ = '\n';
+	*pos = '\0';
+	if (out_len)
+		*out_len = pos - out;
+	return out;
+ * base64_decode - Base64 decode
+ * @src: Data to be decoded
+ * @len: Length of the data to be decoded
+ * Returns: Allocated buffer of out_len bytes of decoded data,
+unsigned char * base64_decode(const unsigned char *src, size_t len,
+			      size_t *out_len)
+	unsigned char dtable[256], *out, *pos, block[4], tmp;
+	size_t i, count, olen;
+	int pad = 0;
+	os_memset(dtable, 0x80, 256);
+	for (i = 0; i < sizeof(base64_table) - 1; i++)
+		dtable[base64_table[i]] = (unsigned char) i;
+	dtable['='] = 0;
+	count = 0;
+	for (i = 0; i < len; i++) {
+		if (dtable[src[i]] != 0x80)
+			count++;
+	if (count == 0 || count % 4)
+		return NULL;
+	olen = count / 4 * 3;
+	pos = out = os_malloc(olen);
+	if (out == NULL)
+		return NULL;
+	count = 0;
+		tmp = dtable[src[i]];
+		if (tmp == 0x80)
+			continue;
+		if (src[i] == '=')
+			pad++;
+		block[count] = tmp;
+		count++;
+		if (count == 4) {
+			*pos++ = (block[0] << 2) | (block[1] >> 4);
+			*pos++ = (block[1] << 4) | (block[2] >> 2);
+			*pos++ = (block[2] << 6) | block[3];
+			count = 0;
+			if (pad) {
+				if (pad == 1)
+					pos--;
+				else if (pad == 2)
+					pos -= 2;
+				else {
+					/* Invalid padding */
+					os_free(out);
+					return NULL;
+				break;
+	return out;
diff --git a/freebsd/contrib/wpa/src/utils/base64.h b/freebsd/contrib/wpa/src/utils/base64.h
new file mode 100644
index 00000000000..aa21fd0fc1b
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/base64.h
@@ -0,0 +1,17 @@
+ * Copyright (c) 2005, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef BASE64_H
+#define BASE64_H
+			      size_t *out_len);
+			      size_t *out_len);
+#endif /* BASE64_H */
diff --git a/freebsd/contrib/wpa/src/utils/build_config.h b/freebsd/contrib/wpa/src/utils/build_config.h
index 00000000000..c6f4e4379ae
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/build_config.h
@@ -0,0 +1,50 @@
+ * wpa_supplicant/hostapd - Build time configuration defines
+ * Copyright (c) 2005-2006, Jouni Malinen <j at w1.fi>
+ * This header file can be used to define configuration defines that were
+ * originally defined in Makefile. This is mainly meant for IDE use or for
+ * systems that do not have suitable 'make' tool. In these cases, it may be
+ * easier to have a single place for defining all the needed C pre-processor
+ * defines.
+#ifndef BUILD_CONFIG_H
+#define BUILD_CONFIG_H
+/* Insert configuration defines, e.g., #define EAP_MD5, here, if needed. */
+#ifdef CONFIG_WIN32_DEFAULTS
+#define CONFIG_NATIVE_WINDOWS
+#define CONFIG_ANSI_C_EXTRA
+#define CONFIG_WINPCAP
+#define IEEE8021X_EAPOL
+#define PKCS12_FUNCS
+#define PCSC_FUNCS
+#define CONFIG_CTRL_IFACE
+#define CONFIG_CTRL_IFACE_NAMED_PIPE
+#define CONFIG_DRIVER_NDIS
+#define CONFIG_NDIS_EVENTS_INTEGRATED
+#define CONFIG_DEBUG_FILE
+#define EAP_MD5
+#define EAP_TLS
+#define EAP_MSCHAPv2
+#define EAP_PEAP
+#define EAP_TTLS
+#define EAP_GTC
+#define EAP_OTP
+#define EAP_LEAP
+#define EAP_TNC
+#define _CRT_SECURE_NO_DEPRECATE
+#ifdef USE_INTERNAL_CRYPTO
+#define CONFIG_TLS_INTERNAL_CLIENT
+#define CONFIG_INTERNAL_LIBTOMMATH
+#define CONFIG_CRYPTO_INTERNAL
+#endif /* USE_INTERNAL_CRYPTO */
+#endif /* CONFIG_WIN32_DEFAULTS */
+#endif /* BUILD_CONFIG_H */
diff --git a/freebsd/contrib/wpa/src/utils/common.c b/freebsd/contrib/wpa/src/utils/common.c
index 00000000000..9665bd3c749
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/common.c
@@ -0,0 +1,1127 @@
+ * wpa_supplicant/hostapd / common helper functions, etc.
+ * Copyright (c) 2002-2007, Jouni Malinen <j at w1.fi>
+#include "common/ieee802_11_defs.h"
+static int hex2num(char c)
+	if (c >= '0' && c <= '9')
+		return c - '0';
+	if (c >= 'a' && c <= 'f')
+		return c - 'a' + 10;
+	if (c >= 'A' && c <= 'F')
+		return c - 'A' + 10;
+	return -1;
+int hex2byte(const char *hex)
+	int a, b;
+	a = hex2num(*hex++);
+	if (a < 0)
+		return -1;
+	b = hex2num(*hex++);
+	if (b < 0)
+		return -1;
+	return (a << 4) | b;
+static const char * hwaddr_parse(const char *txt, u8 *addr)
+	size_t i;
+	for (i = 0; i < ETH_ALEN; i++) {
+		int a;
+		a = hex2byte(txt);
+		if (a < 0)
+			return NULL;
+		txt += 2;
+		addr[i] = a;
+		if (i < ETH_ALEN - 1 && *txt++ != ':')
+			return NULL;
+	return txt;
+ * hwaddr_aton - Convert ASCII string to MAC address (colon-delimited format)
+ * @txt: MAC address as a string (e.g., "00:11:22:33:44:55")
+ * @addr: Buffer for the MAC address (ETH_ALEN = 6 bytes)
+ * Returns: 0 on success, -1 on failure (e.g., string not a MAC address)
+int hwaddr_aton(const char *txt, u8 *addr)
+	return hwaddr_parse(txt, addr) ? 0 : -1;
+ * hwaddr_masked_aton - Convert ASCII string with optional mask to MAC address (colon-delimited format)
+ * @txt: MAC address with optional mask as a string (e.g., "00:11:22:33:44:55/ff:ff:ff:ff:00:00")
+ * @mask: Buffer for the MAC address mask (ETH_ALEN = 6 bytes)
+ * @maskable: Flag to indicate whether a mask is allowed
+int hwaddr_masked_aton(const char *txt, u8 *addr, u8 *mask, u8 maskable)
+	const char *r;
+	/* parse address part */
+	r = hwaddr_parse(txt, addr);
+	if (!r)
+		return -1;
+	/* check for optional mask */
+	if (*r == '\0' || isspace(*r)) {
+		/* no mask specified, assume default */
+		os_memset(mask, 0xff, ETH_ALEN);
+	} else if (maskable && *r == '/') {
+		/* mask specified and allowed */
+		r = hwaddr_parse(r + 1, mask);
+		/* parser error? */
+		if (!r)
+			return -1;
+	} else {
+		/* mask specified but not allowed or trailing garbage */
+		return -1;
+	return 0;
+ * hwaddr_compact_aton - Convert ASCII string to MAC address (no colon delimitors format)
+ * @txt: MAC address as a string (e.g., "001122334455")
+int hwaddr_compact_aton(const char *txt, u8 *addr)
+	int i;
+	for (i = 0; i < 6; i++) {
+		int a, b;
+		a = hex2num(*txt++);
+		if (a < 0)
+			return -1;
+		b = hex2num(*txt++);
+		if (b < 0)
+			return -1;
+		*addr++ = (a << 4) | b;
+	return 0;
+ * hwaddr_aton2 - Convert ASCII string to MAC address (in any known format)
+ * @txt: MAC address as a string (e.g., 00:11:22:33:44:55 or 0011.2233.4455)
+ * Returns: Characters used (> 0) on success, -1 on failure
+int hwaddr_aton2(const char *txt, u8 *addr)
+	int i;
+	const char *pos = txt;
+		int a, b;
+		while (*pos == ':' || *pos == '.' || *pos == '-')
+			pos++;
+		a = hex2num(*pos++);
+		if (a < 0)
+			return -1;
+		b = hex2num(*pos++);
+		if (b < 0)
+			return -1;
+	return pos - txt;
+ * hexstr2bin - Convert ASCII hex string into binary data
+ * @hex: ASCII hex string (e.g., "01ab")
+ * @buf: Buffer for the binary data
+ * @len: Length of the text to convert in bytes (of buf); hex will be double
+ * this size
+ * Returns: 0 on success, -1 on failure (invalid hex string)
+int hexstr2bin(const char *hex, u8 *buf, size_t len)
+	size_t i;
+	int a;
+	const char *ipos = hex;
+	u8 *opos = buf;
+		a = hex2byte(ipos);
+		if (a < 0)
+			return -1;
+		*opos++ = a;
+		ipos += 2;
+	return 0;
+int hwaddr_mask_txt(char *buf, size_t len, const u8 *addr, const u8 *mask)
+	size_t i;
+	int print_mask = 0;
+	int res;
+		if (mask[i] != 0xff) {
+			print_mask = 1;
+			break;
+	if (print_mask)
+		res = os_snprintf(buf, len, MACSTR "/" MACSTR,
+				  MAC2STR(addr), MAC2STR(mask));
+	else
+		res = os_snprintf(buf, len, MACSTR, MAC2STR(addr));
+	if (os_snprintf_error(len, res))
+		return -1;
+	return res;
+ * inc_byte_array - Increment arbitrary length byte array by one
+ * @counter: Pointer to byte array
+ * @len: Length of the counter in bytes
+ * This function increments the last byte of the counter by one and continues
+ * rolling over to more significant bytes if the byte was incremented from
+ * 0xff to 0x00.
+void inc_byte_array(u8 *counter, size_t len)
+	int pos = len - 1;
+	while (pos >= 0) {
+		counter[pos]++;
+		if (counter[pos] != 0)
+			break;
+		pos--;
+void wpa_get_ntp_timestamp(u8 *buf)
+	struct os_time now;
+	u32 sec, usec;
+	be32 tmp;
+	/* 64-bit NTP timestamp (time from 1900-01-01 00:00:00) */
+	os_get_time(&now);
+	sec = now.sec + 2208988800U; /* Epoch to 1900 */
+	/* Estimate 2^32/10^6 = 4295 - 1/32 - 1/512 */
+	usec = now.usec;
+	usec = 4295 * usec - (usec >> 5) - (usec >> 9);
+	tmp = host_to_be32(sec);
+	os_memcpy(buf, (u8 *) &tmp, 4);
+	tmp = host_to_be32(usec);
+	os_memcpy(buf + 4, (u8 *) &tmp, 4);
+ * wpa_scnprintf - Simpler-to-use snprintf function
+ * @buf: Output buffer
+ * @size: Buffer size
+ * @fmt: format
+ * Simpler snprintf version that doesn't require further error checks - the
+ * return value only indicates how many bytes were actually written, excluding
+ * the NULL byte (i.e., 0 on error, size-1 if buffer is not big enough).
+int wpa_scnprintf(char *buf, size_t size, const char *fmt, ...)
+	va_list ap;
+	int ret;
+	if (!size)
+		return 0;
+	va_start(ap, fmt);
+	ret = vsnprintf(buf, size, fmt, ap);
+	va_end(ap);
+	if (ret < 0)
+		return 0;
+	if ((size_t) ret >= size)
+		return size - 1;
+	return ret;
+int wpa_snprintf_hex_sep(char *buf, size_t buf_size, const u8 *data, size_t len,
+			 char sep)
+	size_t i;
+	char *pos = buf, *end = buf + buf_size;
+	int ret;
+	if (buf_size == 0)
+		return 0;
+		ret = os_snprintf(pos, end - pos, "%02x%c",
+				  data[i], sep);
+		if (os_snprintf_error(end - pos, ret)) {
+			end[-1] = '\0';
+			return pos - buf;
+		pos += ret;
+	pos[-1] = '\0';
+	return pos - buf;
+static inline int _wpa_snprintf_hex(char *buf, size_t buf_size, const u8 *data,
+				    size_t len, int uppercase)
+	size_t i;
+	int ret;
+		return 0;
+		ret = os_snprintf(pos, end - pos, uppercase ? "%02X" : "%02x",
+				  data[i]);
+			end[-1] = '\0';
+			return pos - buf;
+		pos += ret;
+	end[-1] = '\0';
+	return pos - buf;
+ * wpa_snprintf_hex - Print data as a hex string into a buffer
+ * @buf: Memory area to use as the output buffer
+ * @buf_size: Maximum buffer size in bytes (should be at least 2 * len + 1)
+ * @data: Data to be printed
+ * @len: Length of data in bytes
+ * Returns: Number of bytes written
+int wpa_snprintf_hex(char *buf, size_t buf_size, const u8 *data, size_t len)
+	return _wpa_snprintf_hex(buf, buf_size, data, len, 0);
+ * wpa_snprintf_hex_uppercase - Print data as a upper case hex string into buf
+int wpa_snprintf_hex_uppercase(char *buf, size_t buf_size, const u8 *data,
+			       size_t len)
+	return _wpa_snprintf_hex(buf, buf_size, data, len, 1);
+#ifdef CONFIG_ANSI_C_EXTRA
+#ifdef _WIN32_WCE
+void perror(const char *s)
+	wpa_printf(MSG_ERROR, "%s: GetLastError: %d",
+		   s, (int) GetLastError());
+#endif /* _WIN32_WCE */
+int optind = 1;
+int optopt;
+char *optarg;
+int getopt(int argc, char *const argv[], const char *optstring)
+	static int optchr = 1;
+	char *cp;
+	if (optchr == 1) {
+		if (optind >= argc) {
+			/* all arguments processed */
+			return EOF;
+		if (argv[optind][0] != '-' || argv[optind][1] == '\0') {
+			/* no option characters */
+			return EOF;
+	if (os_strcmp(argv[optind], "--") == 0) {
+		/* no more options */
+		optind++;
+		return EOF;
+	optopt = argv[optind][optchr];
+	cp = os_strchr(optstring, optopt);
+	if (cp == NULL || optopt == ':') {
+		if (argv[optind][++optchr] == '\0') {
+			optchr = 1;
+			optind++;
+		return '?';
+	if (cp[1] == ':') {
+		/* Argument required */
+		optchr = 1;
+		if (argv[optind][optchr + 1]) {
+			/* No space between option and argument */
+			optarg = &argv[optind++][optchr + 1];
+		} else if (++optind >= argc) {
+			/* option requires an argument */
+			return '?';
+		} else {
+			/* Argument in the next argv */
+			optarg = argv[optind++];
+	} else {
+		/* No argument */
+			optchr = 1;
+			optind++;
+		optarg = NULL;
+	return *cp;
+#endif /* CONFIG_ANSI_C_EXTRA */
+#ifdef CONFIG_NATIVE_WINDOWS
+ * wpa_unicode2ascii_inplace - Convert unicode string into ASCII
+ * @str: Pointer to string to convert
+ * This function converts a unicode string to ASCII using the same
+ * buffer for output. If UNICODE is not set, the buffer is not
+ * modified.
+void wpa_unicode2ascii_inplace(TCHAR *str)
+#ifdef UNICODE
+	char *dst = (char *) str;
+	while (*str)
+		*dst++ = (char) *str++;
+	*dst = '\0';
+#endif /* UNICODE */
+TCHAR * wpa_strdup_tchar(const char *str)
+#ifdef UNICODE
+	TCHAR *buf;
+	buf = os_malloc((strlen(str) + 1) * sizeof(TCHAR));
+	if (buf == NULL)
+		return NULL;
+	wsprintf(buf, L"%S", str);
+	return buf;
+#else /* UNICODE */
+	return os_strdup(str);
+#endif /* CONFIG_NATIVE_WINDOWS */
+void printf_encode(char *txt, size_t maxlen, const u8 *data, size_t len)
+	char *end = txt + maxlen;
+	size_t i;
+		if (txt + 4 >= end)
+			break;
+		switch (data[i]) {
+		case '\"':
+			*txt++ = '\\';
+			*txt++ = '\"';
+			break;
+		case '\\':
+			*txt++ = '\\';
+			*txt++ = '\\';
+			break;
+		case '\033':
+			*txt++ = '\\';
+			*txt++ = 'e';
+			break;
+		case '\n':
+			*txt++ = '\\';
+			*txt++ = 'n';
+			break;
+		case '\r':
+			*txt++ = '\\';
+			*txt++ = 'r';
+			break;
+		case '\t':
+			*txt++ = '\\';
+			*txt++ = 't';
+			break;
+		default:
+			if (data[i] >= 32 && data[i] <= 127) {
+				*txt++ = data[i];
+			} else {
+				txt += os_snprintf(txt, end - txt, "\\x%02x",
+						   data[i]);
+			break;
+	*txt = '\0';
+size_t printf_decode(u8 *buf, size_t maxlen, const char *str)
+	const char *pos = str;
+	size_t len = 0;
+	int val;
+	while (*pos) {
+		if (len + 1 >= maxlen)
+			break;
+		switch (*pos) {
+		case '\\':
+			pos++;
+			switch (*pos) {
+			case '\\':
+				buf[len++] = '\\';
+				pos++;
+				break;
+			case '"':
+				buf[len++] = '"';
+				pos++;
+				break;
+			case 'n':
+				buf[len++] = '\n';
+				pos++;
+				break;
+			case 'r':
+				buf[len++] = '\r';
+				pos++;
+				break;
+			case 't':
+				buf[len++] = '\t';
+				pos++;
+				break;
+			case 'e':
+				buf[len++] = '\033';
+				pos++;
+				break;
+			case 'x':
+				pos++;
+				val = hex2byte(pos);
+				if (val < 0) {
+					val = hex2num(*pos);
+					if (val < 0)
+						break;
+					buf[len++] = val;
+					pos++;
+				} else {
+					buf[len++] = val;
+					pos += 2;
+				break;
+			case '0':
+			case '1':
+			case '2':
+			case '3':
+			case '4':
+			case '5':
+			case '6':
+			case '7':
+				val = *pos++ - '0';
+				if (*pos >= '0' && *pos <= '7')
+					val = val * 8 + (*pos++ - '0');
+				buf[len++] = val;
+				break;
+			default:
+				break;
+			break;
+		default:
+			buf[len++] = *pos++;
+			break;
+	if (maxlen > len)
+		buf[len] = '\0';
+	return len;
+ * wpa_ssid_txt - Convert SSID to a printable string
+ * @ssid: SSID (32-octet string)
+ * @ssid_len: Length of ssid in octets
+ * Returns: Pointer to a printable string
+ * This function can be used to convert SSIDs into printable form. In most
+ * cases, SSIDs do not use unprintable characters, but IEEE 802.11 standard
+ * does not limit the used character set, so anything could be used in an SSID.
+ * This function uses a static buffer, so only one call can be used at the
+ * time, i.e., this is not re-entrant and the returned buffer must be used
+ * before calling this again.
+const char * wpa_ssid_txt(const u8 *ssid, size_t ssid_len)
+	static char ssid_txt[SSID_MAX_LEN * 4 + 1];
+	if (ssid == NULL) {
+		ssid_txt[0] = '\0';
+		return ssid_txt;
+	printf_encode(ssid_txt, sizeof(ssid_txt), ssid, ssid_len);
+	return ssid_txt;
+void * __hide_aliasing_typecast(void *foo)
+	return foo;
+char * wpa_config_parse_string(const char *value, size_t *len)
+	if (*value == '"') {
+		const char *pos;
+		char *str;
+		value++;
+		pos = os_strrchr(value, '"');
+		if (pos == NULL || pos[1] != '\0')
+			return NULL;
+		*len = pos - value;
+		str = dup_binstr(value, *len);
+		if (str == NULL)
+			return NULL;
+		return str;
+	} else if (*value == 'P' && value[1] == '"') {
+		const char *pos;
+		char *tstr, *str;
+		size_t tlen;
+		value += 2;
+			return NULL;
+		tlen = pos - value;
+		tstr = dup_binstr(value, tlen);
+		if (tstr == NULL)
+			return NULL;
+		str = os_malloc(tlen + 1);
+		if (str == NULL) {
+			os_free(tstr);
+			return NULL;
+		*len = printf_decode((u8 *) str, tlen + 1, tstr);
+		os_free(tstr);
+		return str;
+	} else {
+		u8 *str;
+		size_t tlen, hlen = os_strlen(value);
+		if (hlen & 1)
+			return NULL;
+		tlen = hlen / 2;
+		if (str == NULL)
+			return NULL;
+		if (hexstr2bin(value, str, tlen)) {
+			os_free(str);
+			return NULL;
+		str[tlen] = '\0';
+		*len = tlen;
+		return (char *) str;
+int is_hex(const u8 *data, size_t len)
+	size_t i;
+		if (data[i] < 32 || data[i] >= 127)
+			return 1;
+	return 0;
+size_t merge_byte_arrays(u8 *res, size_t res_len,
+			 const u8 *src1, size_t src1_len,
+			 const u8 *src2, size_t src2_len)
+	size_t len = 0;
+	os_memset(res, 0, res_len);
+	if (src1) {
+		if (src1_len >= res_len) {
+			os_memcpy(res, src1, res_len);
+			return res_len;
+		os_memcpy(res, src1, src1_len);
+		len += src1_len;
+	if (src2) {
+		if (len + src2_len >= res_len) {
+			os_memcpy(res + len, src2, res_len - len);
+			return res_len;
+		os_memcpy(res + len, src2, src2_len);
+		len += src2_len;
+	return len;
+char * dup_binstr(const void *src, size_t len)
+	char *res;
+	if (src == NULL)
+		return NULL;
+	res = os_malloc(len + 1);
+	if (res == NULL)
+		return NULL;
+	os_memcpy(res, src, len);
+	res[len] = '\0';
+	return res;
+int freq_range_list_parse(struct wpa_freq_range_list *res, const char *value)
+	struct wpa_freq_range *freq = NULL, *n;
+	unsigned int count = 0;
+	const char *pos, *pos2, *pos3;
+	 * Comma separated list of frequency ranges.
+	 * For example: 2412-2432,2462,5000-6000
+	pos = value;
+	while (pos && pos[0]) {
+		n = os_realloc_array(freq, count + 1,
+				     sizeof(struct wpa_freq_range));
+		if (n == NULL) {
+			os_free(freq);
+			return -1;
+		freq = n;
+		freq[count].min = atoi(pos);
+		pos2 = os_strchr(pos, '-');
+		pos3 = os_strchr(pos, ',');
+		if (pos2 && (!pos3 || pos2 < pos3)) {
+			pos2++;
+			freq[count].max = atoi(pos2);
+		} else
+			freq[count].max = freq[count].min;
+		pos = pos3;
+		if (pos)
+			pos++;
+		count++;
+	os_free(res->range);
+	res->range = freq;
+	res->num = count;
+	return 0;
+int freq_range_list_includes(const struct wpa_freq_range_list *list,
+			     unsigned int freq)
+	unsigned int i;
+	if (list == NULL)
+		return 0;
+	for (i = 0; i < list->num; i++) {
+		if (freq >= list->range[i].min && freq <= list->range[i].max)
+			return 1;
+	return 0;
+char * freq_range_list_str(const struct wpa_freq_range_list *list)
+	char *buf, *pos, *end;
+	size_t maxlen;
+	unsigned int i;
+	int res;
+	if (list->num == 0)
+		return NULL;
+	maxlen = list->num * 30;
+	buf = os_malloc(maxlen);
+	if (buf == NULL)
+		return NULL;
+	pos = buf;
+	end = buf + maxlen;
+		struct wpa_freq_range *range = &list->range[i];
+		if (range->min == range->max)
+			res = os_snprintf(pos, end - pos, "%s%u",
+					  i == 0 ? "" : ",", range->min);
+		else
+			res = os_snprintf(pos, end - pos, "%s%u-%u",
+					  range->min, range->max);
+		if (os_snprintf_error(end - pos, res)) {
+			os_free(buf);
+			return NULL;
+		pos += res;
+	return buf;
+int int_array_len(const int *a)
+	int i;
+	for (i = 0; a && a[i]; i++)
+	return i;
+void int_array_concat(int **res, const int *a)
+	int reslen, alen, i;
+	int *n;
+	reslen = int_array_len(*res);
+	alen = int_array_len(a);
+	n = os_realloc_array(*res, reslen + alen + 1, sizeof(int));
+	if (n == NULL) {
+		os_free(*res);
+		*res = NULL;
+		return;
+	for (i = 0; i <= alen; i++)
+		n[reslen + i] = a[i];
+	*res = n;
+static int freq_cmp(const void *a, const void *b)
+	int _a = *(int *) a;
+	int _b = *(int *) b;
+	if (_a == 0)
+		return 1;
+	if (_b == 0)
+		return -1;
+	return _a - _b;
+void int_array_sort_unique(int *a)
+	int alen;
+	int i, j;
+	if (a == NULL)
+		return;
+	qsort(a, alen, sizeof(int), freq_cmp);
+	i = 0;
+	j = 1;
+	while (a[i] && a[j]) {
+		if (a[i] == a[j]) {
+			j++;
+			continue;
+		a[++i] = a[j++];
+	if (a[i])
+		i++;
+	a[i] = 0;
+void int_array_add_unique(int **res, int a)
+	int reslen;
+	int *n;
+	for (reslen = 0; *res && (*res)[reslen]; reslen++) {
+		if ((*res)[reslen] == a)
+			return; /* already in the list */
+	n = os_realloc_array(*res, reslen + 2, sizeof(int));
+	if (n == NULL) {
+		os_free(*res);
+		*res = NULL;
+		return;
+	n[reslen] = a;
+	n[reslen + 1] = 0;
+	*res = n;
+void str_clear_free(char *str)
+	if (str) {
+		size_t len = os_strlen(str);
+		os_memset(str, 0, len);
+		os_free(str);
+void bin_clear_free(void *bin, size_t len)
+	if (bin) {
+		os_memset(bin, 0, len);
+		os_free(bin);
+int random_mac_addr(u8 *addr)
+	if (os_get_random(addr, ETH_ALEN) < 0)
+		return -1;
+	addr[0] &= 0xfe; /* unicast */
+	addr[0] |= 0x02; /* locally administered */
+	return 0;
+int random_mac_addr_keep_oui(u8 *addr)
+	if (os_get_random(addr + 3, 3) < 0)
+		return -1;
+	return 0;
+ * cstr_token - Get next token from const char string
+ * @str: a constant string to tokenize
+ * @delim: a string of delimiters
+ * @last: a pointer to a character following the returned token
+ *      It has to be set to NULL for the first call and passed for any
+ *      futher call.
+ * Returns: a pointer to token position in str or NULL
+ * This function is similar to str_token, but it can be used with both
+ * char and const char strings. Differences:
+ * - The str buffer remains unmodified
+ * - The returned token is not a NULL terminated string, but a token
+ *   position in str buffer. If a return value is not NULL a size
+ *   of the returned token could be calculated as (last - token).
+const char * cstr_token(const char *str, const char *delim, const char **last)
+	const char *end, *token = str;
+	if (!str || !delim || !last)
+		return NULL;
+	if (*last)
+		token = *last;
+	while (*token && os_strchr(delim, *token))
+		token++;
+	if (!*token)
+		return NULL;
+	end = token + 1;
+	while (*end && !os_strchr(delim, *end))
+		end++;
+	*last = end;
+	return token;
+ * str_token - Get next token from a string
+ * @buf: String to tokenize. Note that the string might be modified.
+ * @delim: String of delimiters
+ * @context: Pointer to save our context. Should be initialized with
+ *	NULL on the first call, and passed for any further call.
+ * Returns: The next token, NULL if there are no more valid tokens.
+char * str_token(char *str, const char *delim, char **context)
+	char *token = (char *) cstr_token(str, delim, (const char **) context);
+	if (token && **context)
+		*(*context)++ = '\0';
+	return token;
+size_t utf8_unescape(const char *inp, size_t in_size,
+		     char *outp, size_t out_size)
+	size_t res_size = 0;
+	if (!inp || !outp)
+		return 0;
+	if (!in_size)
+		in_size = os_strlen(inp);
+	/* Advance past leading single quote */
+	if (*inp == '\'' && in_size) {
+		inp++;
+		in_size--;
+	while (in_size--) {
+		if (res_size >= out_size)
+			return 0;
+		switch (*inp) {
+		case '\'':
+			/* Terminate on bare single quote */
+			*outp = '\0';
+			return res_size;
+		case '\\':
+			if (!in_size--)
+				return 0;
+			inp++;
+			/* fall through */
+		default:
+			*outp++ = *inp++;
+			res_size++;
+	/* NUL terminate if space allows */
+	if (res_size < out_size)
+		*outp = '\0';
+	return res_size;
+size_t utf8_escape(const char *inp, size_t in_size,
+		return 0;
+	/* inp may or may not be NUL terminated, but must be if 0 size
+	 * is specified */
+	if (!in_size)
+		if (res_size++ >= out_size)
+			return 0;
+		switch (*inp) {
+		case '\\':
+		case '\'':
+				return 0;
+			*outp++ = '\\';
+		default:
+			*outp++ = *inp++;
+			break;
+		*outp = '\0';
+	return res_size;
+int is_ctrl_char(char c)
+	return c > 0 && c < 32;
diff --git a/freebsd/contrib/wpa/src/utils/common.h b/freebsd/contrib/wpa/src/utils/common.h
index 00000000000..0b9cc3d8820
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/common.h
@@ -0,0 +1,559 @@
+#ifndef COMMON_H
+#define COMMON_H
+#include "os.h"
+#if defined(__linux__) || defined(__GLIBC__)
+#include <endian.h>
+#include <byteswap.h>
+#endif /* __linux__ */
+#if defined(__FreeBSD__) || defined(__NetBSD__) || defined(__DragonFly__) || \
+    defined(__OpenBSD__)
+#include <sys/types.h>
+#include <sys/endian.h>
+#define __BYTE_ORDER	_BYTE_ORDER
+#define	__LITTLE_ENDIAN	_LITTLE_ENDIAN
+#define	__BIG_ENDIAN	_BIG_ENDIAN
+#ifdef __OpenBSD__
+#define bswap_16 swap16
+#define bswap_32 swap32
+#define bswap_64 swap64
+#else /* __OpenBSD__ */
+#define bswap_16 bswap16
+#define bswap_32 bswap32
+#define bswap_64 bswap64
+#endif /* __OpenBSD__ */
+#endif /* defined(__FreeBSD__) || defined(__NetBSD__) ||
+	* defined(__DragonFly__) || defined(__OpenBSD__) */
+#ifdef __APPLE__
+#include <machine/endian.h>
+static inline unsigned short bswap_16(unsigned short v)
+	return ((v & 0xff) << 8) | (v >> 8);
+static inline unsigned int bswap_32(unsigned int v)
+	return ((v & 0xff) << 24) | ((v & 0xff00) << 8) |
+		((v & 0xff0000) >> 8) | (v >> 24);
+#endif /* __APPLE__ */
+#include <winsock.h>
+typedef int socklen_t;
+#ifndef MSG_DONTWAIT
+#define MSG_DONTWAIT 0 /* not supported */
+#endif
+#ifdef _MSC_VER
+#define inline __inline
+#undef vsnprintf
+#define vsnprintf _vsnprintf
+#undef close
+#define close closesocket
+#endif /* _MSC_VER */
+/* Define platform specific integer types */
+#ifdef _MSC_VER
+typedef UINT64 u64;
+typedef UINT32 u32;
+typedef UINT16 u16;
+typedef UINT8 u8;
+typedef INT64 s64;
+typedef INT32 s32;
+typedef INT16 s16;
+typedef INT8 s8;
+#define WPA_TYPES_DEFINED
+#ifdef __vxworks
+typedef unsigned long long u64;
+typedef UINT8 u8;
+typedef long long s64;
+typedef INT32 s32;
+typedef INT16 s16;
+typedef INT8 s8;
+#endif /* __vxworks */
+#ifndef WPA_TYPES_DEFINED
+#ifdef CONFIG_USE_INTTYPES_H
+#include <inttypes.h>
+#else
+#include <stdint.h>
+#endif
+typedef uint64_t u64;
+typedef uint32_t u32;
+typedef uint16_t u16;
+typedef uint8_t u8;
+typedef int64_t s64;
+typedef int32_t s32;
+typedef int16_t s16;
+typedef int8_t s8;
+#endif /* !WPA_TYPES_DEFINED */
+/* Define platform specific byte swapping macros */
+#if defined(__CYGWIN__) || defined(CONFIG_NATIVE_WINDOWS)
+static inline unsigned short wpa_swap_16(unsigned short v)
+static inline unsigned int wpa_swap_32(unsigned int v)
+#define le_to_host16(n) (n)
+#define host_to_le16(n) (n)
+#define be_to_host16(n) wpa_swap_16(n)
+#define host_to_be16(n) wpa_swap_16(n)
+#define le_to_host32(n) (n)
+#define host_to_le32(n) (n)
+#define be_to_host32(n) wpa_swap_32(n)
+#define host_to_be32(n) wpa_swap_32(n)
+#define WPA_BYTE_SWAP_DEFINED
+#endif /* __CYGWIN__ || CONFIG_NATIVE_WINDOWS */
+#ifndef WPA_BYTE_SWAP_DEFINED
+#ifndef __BYTE_ORDER
+#ifndef __LITTLE_ENDIAN
+#ifndef __BIG_ENDIAN
+#define __LITTLE_ENDIAN 1234
+#define __BIG_ENDIAN 4321
+#if defined(sparc)
+#define __BYTE_ORDER __BIG_ENDIAN
+#endif
+#endif /* __BIG_ENDIAN */
+#endif /* __LITTLE_ENDIAN */
+#endif /* __BYTE_ORDER */
+#if __BYTE_ORDER == __LITTLE_ENDIAN
+#define le_to_host16(n) ((__force u16) (le16) (n))
+#define host_to_le16(n) ((__force le16) (u16) (n))
+#define be_to_host16(n) bswap_16((__force u16) (be16) (n))
+#define host_to_be16(n) ((__force be16) bswap_16((n)))
+#define le_to_host32(n) ((__force u32) (le32) (n))
+#define host_to_le32(n) ((__force le32) (u32) (n))
+#define be_to_host32(n) bswap_32((__force u32) (be32) (n))
+#define host_to_be32(n) ((__force be32) bswap_32((n)))
+#define le_to_host64(n) ((__force u64) (le64) (n))
+#define host_to_le64(n) ((__force le64) (u64) (n))
+#define be_to_host64(n) bswap_64((__force u64) (be64) (n))
+#define host_to_be64(n) ((__force be64) bswap_64((n)))
+#elif __BYTE_ORDER == __BIG_ENDIAN
+#define le_to_host16(n) bswap_16(n)
+#define host_to_le16(n) bswap_16(n)
+#define be_to_host16(n) (n)
+#define host_to_be16(n) (n)
+#define le_to_host32(n) bswap_32(n)
+#define host_to_le32(n) bswap_32(n)
+#define be_to_host32(n) (n)
+#define host_to_be32(n) (n)
+#define le_to_host64(n) bswap_64(n)
+#define host_to_le64(n) bswap_64(n)
+#define be_to_host64(n) (n)
+#define host_to_be64(n) (n)
+#ifndef WORDS_BIGENDIAN
+#define WORDS_BIGENDIAN
+#endif
+#else
+#error Could not determine CPU byte order
+#endif
+#endif /* !WPA_BYTE_SWAP_DEFINED */
+/* Macros for handling unaligned memory accesses */
+static inline u16 WPA_GET_BE16(const u8 *a)
+	return (a[0] << 8) | a[1];
+static inline void WPA_PUT_BE16(u8 *a, u16 val)
+	a[0] = val >> 8;
+	a[1] = val & 0xff;
+static inline u16 WPA_GET_LE16(const u8 *a)
+	return (a[1] << 8) | a[0];
+static inline void WPA_PUT_LE16(u8 *a, u16 val)
+	a[1] = val >> 8;
+	a[0] = val & 0xff;
+static inline u32 WPA_GET_BE24(const u8 *a)
+	return (a[0] << 16) | (a[1] << 8) | a[2];
+static inline void WPA_PUT_BE24(u8 *a, u32 val)
+	a[0] = (val >> 16) & 0xff;
+	a[1] = (val >> 8) & 0xff;
+	a[2] = val & 0xff;
+static inline u32 WPA_GET_BE32(const u8 *a)
+	return ((u32) a[0] << 24) | (a[1] << 16) | (a[2] << 8) | a[3];
+static inline void WPA_PUT_BE32(u8 *a, u32 val)
+	a[0] = (val >> 24) & 0xff;
+	a[1] = (val >> 16) & 0xff;
+	a[2] = (val >> 8) & 0xff;
+	a[3] = val & 0xff;
+static inline u32 WPA_GET_LE32(const u8 *a)
+	return ((u32) a[3] << 24) | (a[2] << 16) | (a[1] << 8) | a[0];
+static inline void WPA_PUT_LE32(u8 *a, u32 val)
+	a[3] = (val >> 24) & 0xff;
+	a[2] = (val >> 16) & 0xff;
+static inline u64 WPA_GET_BE64(const u8 *a)
+	return (((u64) a[0]) << 56) | (((u64) a[1]) << 48) |
+		(((u64) a[2]) << 40) | (((u64) a[3]) << 32) |
+		(((u64) a[4]) << 24) | (((u64) a[5]) << 16) |
+		(((u64) a[6]) << 8) | ((u64) a[7]);
+static inline void WPA_PUT_BE64(u8 *a, u64 val)
+	a[0] = val >> 56;
+	a[1] = val >> 48;
+	a[2] = val >> 40;
+	a[3] = val >> 32;
+	a[4] = val >> 24;
+	a[5] = val >> 16;
+	a[6] = val >> 8;
+	a[7] = val & 0xff;
+static inline u64 WPA_GET_LE64(const u8 *a)
+	return (((u64) a[7]) << 56) | (((u64) a[6]) << 48) |
+		(((u64) a[5]) << 40) | (((u64) a[4]) << 32) |
+		(((u64) a[3]) << 24) | (((u64) a[2]) << 16) |
+		(((u64) a[1]) << 8) | ((u64) a[0]);
+static inline void WPA_PUT_LE64(u8 *a, u64 val)
+	a[7] = val >> 56;
+	a[6] = val >> 48;
+	a[5] = val >> 40;
+	a[4] = val >> 32;
+	a[3] = val >> 24;
+	a[2] = val >> 16;
+	a[1] = val >> 8;
+#ifndef ETH_ALEN
+#define ETH_ALEN 6
+#endif
+#ifndef ETH_HLEN
+#define ETH_HLEN 14
+#endif
+#ifndef IFNAMSIZ
+#define IFNAMSIZ 16
+#endif
+#ifndef ETH_P_ALL
+#define ETH_P_ALL 0x0003
+#endif
+#ifndef ETH_P_80211_ENCAP
+#define ETH_P_80211_ENCAP 0x890d /* TDLS comes under this category */
+#endif
+#ifndef ETH_P_PAE
+#define ETH_P_PAE 0x888E /* Port Access Entity (IEEE 802.1X) */
+#endif /* ETH_P_PAE */
+#ifndef ETH_P_EAPOL
+#define ETH_P_EAPOL ETH_P_PAE
+#endif /* ETH_P_EAPOL */
+#ifndef ETH_P_RSN_PREAUTH
+#define ETH_P_RSN_PREAUTH 0x88c7
+#endif /* ETH_P_RSN_PREAUTH */
+#ifndef ETH_P_RRB
+#define ETH_P_RRB 0x890D
+#endif /* ETH_P_RRB */
+#ifdef __GNUC__
+#define PRINTF_FORMAT(a,b) __attribute__ ((format (printf, (a), (b))))
+#define STRUCT_PACKED __attribute__ ((packed))
+#else
+#endif
+#if !defined(_MSC_VER) || _MSC_VER < 1400
+/* snprintf - used in number of places; sprintf() is _not_ a good replacement
+ * due to possible buffer overflow; see, e.g.,
+ * http://www.ijs.si/software/snprintf/ for portable implementation of
+ * snprintf. */
+int snprintf(char *str, size_t size, const char *format, ...);
+/* vsnprintf - only used for wpa_msg() in wpa_supplicant.c */
+int vsnprintf(char *str, size_t size, const char *format, va_list ap);
+#endif /* !defined(_MSC_VER) || _MSC_VER < 1400 */
+/* getopt - only used in main.c */
+int getopt(int argc, char *const argv[], const char *optstring);
+extern char *optarg;
+extern int optind;
+#ifndef CONFIG_NO_SOCKLEN_T_TYPEDEF
+#ifndef __socklen_t_defined
+#endif
+#endif
+/* inline - define as __inline or just define it to be empty, if needed */
+#ifdef CONFIG_NO_INLINE
+#define inline
+#else
+#endif
+#ifndef __func__
+#define __func__ "__func__ not defined"
+#endif
+#ifndef bswap_16
+#define bswap_16(a) ((((u16) (a) << 8) & 0xff00) | (((u16) (a) >> 8) & 0xff))
+#endif
+#ifndef bswap_32
+#define bswap_32(a) ((((u32) (a) << 24) & 0xff000000) | \
+		     (((u32) (a) << 8) & 0xff0000) | \
+     		     (((u32) (a) >> 8) & 0xff00) | \
+     		     (((u32) (a) >> 24) & 0xff))
+#endif
+#endif
+#ifdef _WIN32_WCE
+void perror(const char *s);
+#ifndef MAC2STR
+#define MAC2STR(a) (a)[0], (a)[1], (a)[2], (a)[3], (a)[4], (a)[5]
+#define MACSTR "%02x:%02x:%02x:%02x:%02x:%02x"
+ * Compact form for string representation of MAC address
+ * To be used, e.g., for constructing dbus paths for P2P Devices
+#define COMPACT_MACSTR "%02x%02x%02x%02x%02x%02x"
+#endif
+#ifndef BIT
+#define BIT(x) (1U << (x))
+#endif
+ * Definitions for sparse validation
+ * (http://kernel.org/pub/linux/kernel/people/josh/sparse/)
+#ifdef __CHECKER__
+#define __force __attribute__((force))
+#define __bitwise __attribute__((bitwise))
+#else
+#define __force
+#define __bitwise
+#endif
+typedef u16 __bitwise be16;
+typedef u16 __bitwise le16;
+typedef u32 __bitwise be32;
+typedef u32 __bitwise le32;
+typedef u64 __bitwise be64;
+typedef u64 __bitwise le64;
+#ifndef __must_check
+#if __GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
+#define __must_check __attribute__((__warn_unused_result__))
+#else
+#endif /* __GNUC__ */
+#endif /* __must_check */
+#ifndef __maybe_unused
+#define __maybe_unused __attribute__((unused))
+#else
+int hwaddr_aton(const char *txt, u8 *addr);
+int hwaddr_masked_aton(const char *txt, u8 *addr, u8 *mask, u8 maskable);
+int hwaddr_compact_aton(const char *txt, u8 *addr);
+int hwaddr_aton2(const char *txt, u8 *addr);
+int hex2byte(const char *hex);
+int hexstr2bin(const char *hex, u8 *buf, size_t len);
+void inc_byte_array(u8 *counter, size_t len);
+void wpa_get_ntp_timestamp(u8 *buf);
+int wpa_scnprintf(char *buf, size_t size, const char *fmt, ...);
+			 char sep);
+int wpa_snprintf_hex(char *buf, size_t buf_size, const u8 *data, size_t len);
+			       size_t len);
+int hwaddr_mask_txt(char *buf, size_t len, const u8 *addr, const u8 *mask);
+void wpa_unicode2ascii_inplace(TCHAR *str);
+TCHAR * wpa_strdup_tchar(const char *str);
+#else /* CONFIG_NATIVE_WINDOWS */
+#define wpa_unicode2ascii_inplace(s) do { } while (0)
+#define wpa_strdup_tchar(s) strdup((s))
+void printf_encode(char *txt, size_t maxlen, const u8 *data, size_t len);
+size_t printf_decode(u8 *buf, size_t maxlen, const char *str);
+const char * wpa_ssid_txt(const u8 *ssid, size_t ssid_len);
+char * wpa_config_parse_string(const char *value, size_t *len);
+int is_hex(const u8 *data, size_t len);
+			 const u8 *src2, size_t src2_len);
+char * dup_binstr(const void *src, size_t len);
+static inline int is_zero_ether_addr(const u8 *a)
+	return !(a[0] | a[1] | a[2] | a[3] | a[4] | a[5]);
+static inline int is_broadcast_ether_addr(const u8 *a)
+	return (a[0] & a[1] & a[2] & a[3] & a[4] & a[5]) == 0xff;
+static inline int is_multicast_ether_addr(const u8 *a)
+	return a[0] & 0x01;
+#define broadcast_ether_addr (const u8 *) "\xff\xff\xff\xff\xff\xff"
+#include "wpa_debug.h"
+struct wpa_freq_range_list {
+	struct wpa_freq_range {
+		unsigned int min;
+		unsigned int max;
+	} *range;
+	unsigned int num;
+int freq_range_list_parse(struct wpa_freq_range_list *res, const char *value);
+			     unsigned int freq);
+char * freq_range_list_str(const struct wpa_freq_range_list *list);
+int int_array_len(const int *a);
+void int_array_concat(int **res, const int *a);
+void int_array_sort_unique(int *a);
+void int_array_add_unique(int **res, int a);
+#define ARRAY_SIZE(a) (sizeof(a) / sizeof((a)[0]))
+void str_clear_free(char *str);
+void bin_clear_free(void *bin, size_t len);
+int random_mac_addr(u8 *addr);
+int random_mac_addr_keep_oui(u8 *addr);
+const char * cstr_token(const char *str, const char *delim, const char **last);
+char * str_token(char *str, const char *delim, char **context);
+		   char *outp, size_t out_size);
+int is_ctrl_char(char c);
+ * gcc 4.4 ends up generating strict-aliasing warnings about some very common
+ * networking socket uses that do not really result in a real problem and
+ * cannot be easily avoided with union-based type-punning due to struct
+ * definitions including another struct in system header files. To avoid having
+ * to fully disable strict-aliasing warnings, provide a mechanism to hide the
+ * typecast from aliasing for now. A cleaner solution will hopefully be found
+ * in the future to handle these cases.
+void * __hide_aliasing_typecast(void *foo);
+#define aliasing_hide_typecast(a,t) (t *) __hide_aliasing_typecast((a))
+#ifdef CONFIG_VALGRIND
+#include <valgrind/memcheck.h>
+#define WPA_MEM_DEFINED(ptr, len) VALGRIND_MAKE_MEM_DEFINED((ptr), (len))
+#else /* CONFIG_VALGRIND */
+#define WPA_MEM_DEFINED(ptr, len) do { } while (0)
+#endif /* CONFIG_VALGRIND */
+#endif /* COMMON_H */
diff --git a/freebsd/contrib/wpa/src/utils/eloop.c b/freebsd/contrib/wpa/src/utils/eloop.c
index 00000000000..5b1cc862e6f
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/eloop.c
@@ -0,0 +1,1144 @@
+#include <machine/rtems-bsd-user-space.h>
+ * Event loop based on select() loop
+ * Copyright (c) 2002-2009, Jouni Malinen <j at w1.fi>
+#include "includes.h"
+#include <assert.h>
+#include "common.h"
+#include "trace.h"
+#include "list.h"
+#include "eloop.h"
+#if defined(CONFIG_ELOOP_POLL) && defined(CONFIG_ELOOP_EPOLL)
+#error Do not define both of poll and epoll
+#endif
+#if !defined(CONFIG_ELOOP_POLL) && !defined(CONFIG_ELOOP_EPOLL)
+#define CONFIG_ELOOP_SELECT
+#endif
+#ifdef CONFIG_ELOOP_POLL
+#include <poll.h>
+#endif /* CONFIG_ELOOP_POLL */
+#ifdef CONFIG_ELOOP_EPOLL
+#include <sys/epoll.h>
+#endif /* CONFIG_ELOOP_EPOLL */
+struct eloop_sock {
+	int sock;
+	void *eloop_data;
+	void *user_data;
+	eloop_sock_handler handler;
+	WPA_TRACE_REF(eloop);
+	WPA_TRACE_REF(user);
+	WPA_TRACE_INFO
+struct eloop_timeout {
+	struct dl_list list;
+	struct os_reltime time;
+	void *eloop_data;
+	void *user_data;
+	eloop_timeout_handler handler;
+	WPA_TRACE_INFO
+struct eloop_signal {
+	int sig;
+	void *user_data;
+	eloop_signal_handler handler;
+	int signaled;
+struct eloop_sock_table {
+	int count;
+	struct eloop_sock *table;
+	eloop_event_type type;
+	int changed;
+struct eloop_data {
+	int max_sock;
+	int count; /* sum of all table counts */
+	int max_pollfd_map; /* number of pollfds_map currently allocated */
+	int max_poll_fds; /* number of pollfds currently allocated */
+	struct pollfd *pollfds;
+	struct pollfd **pollfds_map;
+	int epollfd;
+	int epoll_max_event_num;
+	int epoll_max_fd;
+	struct eloop_sock *epoll_table;
+	struct epoll_event *epoll_events;
+	struct eloop_sock_table readers;
+	struct eloop_sock_table writers;
+	struct eloop_sock_table exceptions;
+	struct dl_list timeout;
+	int signal_count;
+	struct eloop_signal *signals;
+	int signaled;
+	int pending_terminate;
+	int terminate;
+static struct eloop_data eloop;
+#ifdef WPA_TRACE
+static void eloop_sigsegv_handler(int sig)
+	wpa_trace_show("eloop SIGSEGV");
+	abort();
+static void eloop_trace_sock_add_ref(struct eloop_sock_table *table)
+	int i;
+	if (table == NULL || table->table == NULL)
+		return;
+	for (i = 0; i < table->count; i++) {
+		wpa_trace_add_ref(&table->table[i], eloop,
+				  table->table[i].eloop_data);
+		wpa_trace_add_ref(&table->table[i], user,
+				  table->table[i].user_data);
+static void eloop_trace_sock_remove_ref(struct eloop_sock_table *table)
+	int i;
+		return;
+		wpa_trace_remove_ref(&table->table[i], eloop,
+		wpa_trace_remove_ref(&table->table[i], user,
+#else /* WPA_TRACE */
+#define eloop_trace_sock_add_ref(table) do { } while (0)
+#define eloop_trace_sock_remove_ref(table) do { } while (0)
+#endif /* WPA_TRACE */
+int eloop_init(void)
+	os_memset(&eloop, 0, sizeof(eloop));
+	dl_list_init(&eloop.timeout);
+	eloop.epollfd = epoll_create1(0);
+	if (eloop.epollfd < 0) {
+		wpa_printf(MSG_ERROR, "%s: epoll_create1 failed. %s\n",
+			   __func__, strerror(errno));
+		return -1;
+	eloop.readers.type = EVENT_TYPE_READ;
+	eloop.writers.type = EVENT_TYPE_WRITE;
+	eloop.exceptions.type = EVENT_TYPE_EXCEPTION;
+#ifdef WPA_TRACE
+	signal(SIGSEGV, eloop_sigsegv_handler);
+	return 0;
+static int eloop_sock_table_add_sock(struct eloop_sock_table *table,
+                                     int sock, eloop_sock_handler handler,
+                                     void *eloop_data, void *user_data)
+	struct eloop_sock *temp_table;
+	struct epoll_event ev, *temp_events;
+	int next;
+	struct eloop_sock *tmp;
+	int new_max_sock;
+	if (sock > eloop.max_sock)
+		new_max_sock = sock;
+	else
+		new_max_sock = eloop.max_sock;
+	if (table == NULL)
+		return -1;
+	if (new_max_sock >= eloop.max_pollfd_map) {
+		struct pollfd **nmap;
+		nmap = os_realloc_array(eloop.pollfds_map, new_max_sock + 50,
+					sizeof(struct pollfd *));
+		if (nmap == NULL)
+			return -1;
+		eloop.max_pollfd_map = new_max_sock + 50;
+		eloop.pollfds_map = nmap;
+	if (eloop.count + 1 > eloop.max_poll_fds) {
+		struct pollfd *n;
+		int nmax = eloop.count + 1 + 50;
+		n = os_realloc_array(eloop.pollfds, nmax,
+				     sizeof(struct pollfd));
+		if (n == NULL)
+			return -1;
+		eloop.max_poll_fds = nmax;
+		eloop.pollfds = n;
+	if (new_max_sock >= eloop.epoll_max_fd) {
+		next = eloop.epoll_max_fd == 0 ? 16 : eloop.epoll_max_fd * 2;
+		temp_table = os_realloc_array(eloop.epoll_table, next,
+					      sizeof(struct eloop_sock));
+		if (temp_table == NULL)
+			return -1;
+		eloop.epoll_max_fd = next;
+		eloop.epoll_table = temp_table;
+	if (eloop.count + 1 > eloop.epoll_max_event_num) {
+		next = eloop.epoll_max_event_num == 0 ? 8 :
+			eloop.epoll_max_event_num * 2;
+		temp_events = os_realloc_array(eloop.epoll_events, next,
+					       sizeof(struct epoll_event));
+		if (temp_events == NULL) {
+			wpa_printf(MSG_ERROR, "%s: malloc for epoll failed. "
+				   "%s\n", __func__, strerror(errno));
+			return -1;
+		eloop.epoll_max_event_num = next;
+		eloop.epoll_events = temp_events;
+	eloop_trace_sock_remove_ref(table);
+	tmp = os_realloc_array(table->table, table->count + 1,
+	if (tmp == NULL) {
+		eloop_trace_sock_add_ref(table);
+		return -1;
+	tmp[table->count].sock = sock;
+	tmp[table->count].eloop_data = eloop_data;
+	tmp[table->count].user_data = user_data;
+	tmp[table->count].handler = handler;
+	wpa_trace_record(&tmp[table->count]);
+	table->count++;
+	table->table = tmp;
+	eloop.max_sock = new_max_sock;
+	eloop.count++;
+	table->changed = 1;
+	os_memset(&ev, 0, sizeof(ev));
+	switch (table->type) {
+	case EVENT_TYPE_READ:
+		ev.events = EPOLLIN;
+		break;
+	case EVENT_TYPE_WRITE:
+		ev.events = EPOLLOUT;
+		break;
+	 * Exceptions are always checked when using epoll, but I suppose it's
+	 * possible that someone registered a socket *only* for exception
+	 * handling.
+	case EVENT_TYPE_EXCEPTION:
+		ev.events = EPOLLERR | EPOLLHUP;
+		break;
+	ev.data.fd = sock;
+	if (epoll_ctl(eloop.epollfd, EPOLL_CTL_ADD, sock, &ev) < 0) {
+		wpa_printf(MSG_ERROR, "%s: epoll_ctl(ADD) for fd=%d "
+			   "failed. %s\n", __func__, sock, strerror(errno));
+		return -1;
+	os_memcpy(&eloop.epoll_table[sock], &table->table[table->count - 1],
+	return 0;
+static void eloop_sock_table_remove_sock(struct eloop_sock_table *table,
+                                         int sock)
+	int i;
+	if (table == NULL || table->table == NULL || table->count == 0)
+		return;
+		if (table->table[i].sock == sock)
+			break;
+	if (i == table->count)
+		return;
+	if (i != table->count - 1) {
+		os_memmove(&table->table[i], &table->table[i + 1],
+			   (table->count - i - 1) *
+	table->count--;
+	eloop.count--;
+	if (epoll_ctl(eloop.epollfd, EPOLL_CTL_DEL, sock, NULL) < 0) {
+		wpa_printf(MSG_ERROR, "%s: epoll_ctl(DEL) for fd=%d "
+		return;
+	os_memset(&eloop.epoll_table[sock], 0, sizeof(struct eloop_sock));
+static struct pollfd * find_pollfd(struct pollfd **pollfds_map, int fd, int mx)
+	if (fd < mx && fd >= 0)
+		return pollfds_map[fd];
+	return NULL;
+static int eloop_sock_table_set_fds(struct eloop_sock_table *readers,
+				    struct eloop_sock_table *writers,
+				    struct eloop_sock_table *exceptions,
+				    struct pollfd *pollfds,
+				    struct pollfd **pollfds_map,
+				    int max_pollfd_map)
+	int i;
+	int nxt = 0;
+	int fd;
+	struct pollfd *pfd;
+	/* Clear pollfd lookup map. It will be re-populated below. */
+	os_memset(pollfds_map, 0, sizeof(struct pollfd *) * max_pollfd_map);
+	if (readers && readers->table) {
+		for (i = 0; i < readers->count; i++) {
+			fd = readers->table[i].sock;
+			assert(fd >= 0 && fd < max_pollfd_map);
+			pollfds[nxt].fd = fd;
+			pollfds[nxt].events = POLLIN;
+			pollfds[nxt].revents = 0;
+			pollfds_map[fd] = &(pollfds[nxt]);
+			nxt++;
+	if (writers && writers->table) {
+		for (i = 0; i < writers->count; i++) {
+			 * See if we already added this descriptor, update it
+			 * if so.
+			fd = writers->table[i].sock;
+			pfd = pollfds_map[fd];
+			if (!pfd) {
+				pfd = &(pollfds[nxt]);
+				pfd->events = 0;
+				pfd->fd = fd;
+				pollfds[i].revents = 0;
+				pollfds_map[fd] = pfd;
+				nxt++;
+			pfd->events |= POLLOUT;
+	 * Exceptions are always checked when using poll, but I suppose it's
+	 * handling. Set the POLLIN bit in this case.
+	if (exceptions && exceptions->table) {
+		for (i = 0; i < exceptions->count; i++) {
+			 * See if we already added this descriptor, just use it
+			 * if so.
+			fd = exceptions->table[i].sock;
+			if (!pfd) {
+				pfd->events = POLLIN;
+				pfd->fd = fd;
+				nxt++;
+	return nxt;
+static int eloop_sock_table_dispatch_table(struct eloop_sock_table *table,
+					   int max_pollfd_map,
+					   short int revents)
+	int i;
+	if (!table || !table->table)
+		return 0;
+	table->changed = 0;
+		pfd = find_pollfd(pollfds_map, table->table[i].sock,
+				  max_pollfd_map);
+		if (!pfd)
+			continue;
+		if (!(pfd->revents & revents))
+			continue;
+		table->table[i].handler(table->table[i].sock,
+					table->table[i].eloop_data,
+		if (table->changed)
+			return 1;
+	return 0;
+static void eloop_sock_table_dispatch(struct eloop_sock_table *readers,
+	if (eloop_sock_table_dispatch_table(readers, pollfds_map,
+					    max_pollfd_map, POLLIN | POLLERR |
+					    POLLHUP))
+		return; /* pollfds may be invalid at this point */
+	if (eloop_sock_table_dispatch_table(writers, pollfds_map,
+					    max_pollfd_map, POLLOUT))
+	eloop_sock_table_dispatch_table(exceptions, pollfds_map,
+					max_pollfd_map, POLLERR | POLLHUP);
+#ifdef CONFIG_ELOOP_SELECT
+static void eloop_sock_table_set_fds(struct eloop_sock_table *table,
+				     fd_set *fds)
+	int i;
+	FD_ZERO(fds);
+	if (table->table == NULL)
+		return;
+		assert(table->table[i].sock >= 0);
+		FD_SET(table->table[i].sock, fds);
+static void eloop_sock_table_dispatch(struct eloop_sock_table *table,
+				      fd_set *fds)
+	int i;
+		return;
+		if (FD_ISSET(table->table[i].sock, fds)) {
+				break;
+#endif /* CONFIG_ELOOP_SELECT */
+static void eloop_sock_table_dispatch(struct epoll_event *events, int nfds)
+	int i;
+	for (i = 0; i < nfds; i++) {
+		table = &eloop.epoll_table[events[i].data.fd];
+		if (table->handler == NULL)
+			continue;
+		table->handler(table->sock, table->eloop_data,
+			       table->user_data);
+		if (eloop.readers.changed ||
+		    eloop.writers.changed ||
+		    eloop.exceptions.changed)
+			break;
+static void eloop_sock_table_destroy(struct eloop_sock_table *table)
+	if (table) {
+		int i;
+		for (i = 0; i < table->count && table->table; i++) {
+			wpa_printf(MSG_INFO, "ELOOP: remaining socket: "
+				   "sock=%d eloop_data=%p user_data=%p "
+				   "handler=%p",
+				   table->table[i].sock,
+				   table->table[i].user_data,
+				   table->table[i].handler);
+			wpa_trace_dump_funcname("eloop unregistered socket "
+						"handler",
+			wpa_trace_dump("eloop sock", &table->table[i]);
+		os_free(table->table);
+int eloop_register_read_sock(int sock, eloop_sock_handler handler,
+	return eloop_register_sock(sock, EVENT_TYPE_READ, handler,
+				   eloop_data, user_data);
+void eloop_unregister_read_sock(int sock)
+	eloop_unregister_sock(sock, EVENT_TYPE_READ);
+static struct eloop_sock_table *eloop_get_sock_table(eloop_event_type type)
+	switch (type) {
+		return &eloop.readers;
+		return &eloop.writers;
+		return &eloop.exceptions;
+	return NULL;
+int eloop_register_sock(int sock, eloop_event_type type,
+			eloop_sock_handler handler,
+	struct eloop_sock_table *table;
+	assert(sock >= 0);
+	table = eloop_get_sock_table(type);
+	return eloop_sock_table_add_sock(table, sock, handler,
+void eloop_unregister_sock(int sock, eloop_event_type type)
+	eloop_sock_table_remove_sock(table, sock);
+int eloop_register_timeout(unsigned int secs, unsigned int usecs,
+			   eloop_timeout_handler handler,
+	struct eloop_timeout *timeout, *tmp;
+	os_time_t now_sec;
+	timeout = os_zalloc(sizeof(*timeout));
+	if (timeout == NULL)
+		return -1;
+	if (os_get_reltime(&timeout->time) < 0) {
+		os_free(timeout);
+		return -1;
+	now_sec = timeout->time.sec;
+	timeout->time.sec += secs;
+	if (timeout->time.sec < now_sec) {
+		 * Integer overflow - assume long enough timeout to be assumed
+		 * to be infinite, i.e., the timeout would never happen.
+		wpa_printf(MSG_DEBUG, "ELOOP: Too long timeout (secs=%u) to "
+			   "ever happen - ignore it", secs);
+		os_free(timeout);
+		return 0;
+	timeout->time.usec += usecs;
+	while (timeout->time.usec >= 1000000) {
+		timeout->time.sec++;
+		timeout->time.usec -= 1000000;
+	timeout->eloop_data = eloop_data;
+	timeout->user_data = user_data;
+	timeout->handler = handler;
+	wpa_trace_add_ref(timeout, eloop, eloop_data);
+	wpa_trace_add_ref(timeout, user, user_data);
+	wpa_trace_record(timeout);
+	/* Maintain timeouts in order of increasing time */
+	dl_list_for_each(tmp, &eloop.timeout, struct eloop_timeout, list) {
+		if (os_reltime_before(&timeout->time, &tmp->time)) {
+			dl_list_add(tmp->list.prev, &timeout->list);
+			return 0;
+	dl_list_add_tail(&eloop.timeout, &timeout->list);
+	return 0;
+static void eloop_remove_timeout(struct eloop_timeout *timeout)
+	dl_list_del(&timeout->list);
+	wpa_trace_remove_ref(timeout, eloop, timeout->eloop_data);
+	wpa_trace_remove_ref(timeout, user, timeout->user_data);
+	os_free(timeout);
+int eloop_cancel_timeout(eloop_timeout_handler handler,
+	struct eloop_timeout *timeout, *prev;
+	int removed = 0;
+	dl_list_for_each_safe(timeout, prev, &eloop.timeout,
+			      struct eloop_timeout, list) {
+		if (timeout->handler == handler &&
+		    (timeout->eloop_data == eloop_data ||
+		     eloop_data == ELOOP_ALL_CTX) &&
+		    (timeout->user_data == user_data ||
+		     user_data == ELOOP_ALL_CTX)) {
+			eloop_remove_timeout(timeout);
+			removed++;
+	return removed;
+int eloop_cancel_timeout_one(eloop_timeout_handler handler,
+			     void *eloop_data, void *user_data,
+			     struct os_reltime *remaining)
+	int removed = 0;
+	struct os_reltime now;
+	os_get_reltime(&now);
+	remaining->sec = remaining->usec = 0;
+		    (timeout->eloop_data == eloop_data) &&
+		    (timeout->user_data == user_data)) {
+			removed = 1;
+			if (os_reltime_before(&now, &timeout->time))
+				os_reltime_sub(&timeout->time, &now, remaining);
+			break;
+	return removed;
+int eloop_is_timeout_registered(eloop_timeout_handler handler,
+	struct eloop_timeout *tmp;
+		if (tmp->handler == handler &&
+		    tmp->eloop_data == eloop_data &&
+		    tmp->user_data == user_data)
+			return 1;
+	return 0;
+int eloop_deplete_timeout(unsigned int req_secs, unsigned int req_usecs,
+			  eloop_timeout_handler handler, void *eloop_data,
+			  void *user_data)
+	struct os_reltime now, requested, remaining;
+		    tmp->user_data == user_data) {
+			requested.sec = req_secs;
+			requested.usec = req_usecs;
+			os_reltime_sub(&tmp->time, &now, &remaining);
+			if (os_reltime_before(&requested, &remaining)) {
+				eloop_cancel_timeout(handler, eloop_data,
+						     user_data);
+				eloop_register_timeout(requested.sec,
+						       requested.usec,
+						       handler, eloop_data,
+						       user_data);
+				return 1;
+			return 0;
+	return -1;
+int eloop_replenish_timeout(unsigned int req_secs, unsigned int req_usecs,
+			    void *user_data)
+			if (os_reltime_before(&remaining, &requested)) {
+						     user_data);
+						       requested.usec,
+						       user_data);
+				return 1;
+			return 0;
+	return -1;
+#ifndef CONFIG_NATIVE_WINDOWS
+static void eloop_handle_alarm(int sig)
+	wpa_printf(MSG_ERROR, "eloop: could not process SIGINT or SIGTERM in "
+		   "two seconds. Looks like there\n"
+		   "is a bug that ends up in a busy loop that "
+		   "prevents clean shutdown.\n"
+		   "Killing program forcefully.\n");
+	exit(1);
+static void eloop_handle_signal(int sig)
+	int i;
+	if ((sig == SIGINT || sig == SIGTERM) && !eloop.pending_terminate) {
+		/* Use SIGALRM to break out from potential busy loops that
+		 * would not allow the program to be killed. */
+		eloop.pending_terminate = 1;
+		signal(SIGALRM, eloop_handle_alarm);
+		alarm(2);
+	eloop.signaled++;
+	for (i = 0; i < eloop.signal_count; i++) {
+		if (eloop.signals[i].sig == sig) {
+			eloop.signals[i].signaled++;
+			break;
+static void eloop_process_pending_signals(void)
+	int i;
+	if (eloop.signaled == 0)
+		return;
+	eloop.signaled = 0;
+	if (eloop.pending_terminate) {
+		alarm(0);
+		eloop.pending_terminate = 0;
+		if (eloop.signals[i].signaled) {
+			eloop.signals[i].signaled = 0;
+			eloop.signals[i].handler(eloop.signals[i].sig,
+						 eloop.signals[i].user_data);
+int eloop_register_signal(int sig, eloop_signal_handler handler,
+			  void *user_data)
+	struct eloop_signal *tmp;
+	tmp = os_realloc_array(eloop.signals, eloop.signal_count + 1,
+			       sizeof(struct eloop_signal));
+	if (tmp == NULL)
+		return -1;
+	tmp[eloop.signal_count].sig = sig;
+	tmp[eloop.signal_count].user_data = user_data;
+	tmp[eloop.signal_count].handler = handler;
+	tmp[eloop.signal_count].signaled = 0;
+	eloop.signal_count++;
+	eloop.signals = tmp;
+	signal(sig, eloop_handle_signal);
+	return 0;
+int eloop_register_signal_terminate(eloop_signal_handler handler,
+				    void *user_data)
+	int ret = eloop_register_signal(SIGINT, handler, user_data);
+	if (ret == 0)
+		ret = eloop_register_signal(SIGTERM, handler, user_data);
+	return ret;
+int eloop_register_signal_reconfig(eloop_signal_handler handler,
+				   void *user_data)
+	return 0;
+	return eloop_register_signal(SIGHUP, handler, user_data);
+void eloop_run(void)
+	int num_poll_fds;
+	int timeout_ms = 0;
+	fd_set *rfds, *wfds, *efds;
+	struct timeval _tv;
+	int timeout_ms = -1;
+	int res;
+	struct os_reltime tv, now;
+	rfds = os_malloc(sizeof(*rfds));
+	wfds = os_malloc(sizeof(*wfds));
+	efds = os_malloc(sizeof(*efds));
+	if (rfds == NULL || wfds == NULL || efds == NULL)
+		goto out;
+	while (!eloop.terminate &&
+	       (!dl_list_empty(&eloop.timeout) || eloop.readers.count > 0 ||
+		eloop.writers.count > 0 || eloop.exceptions.count > 0)) {
+		struct eloop_timeout *timeout;
+			 * This may happen in some corner cases where a signal
+			 * is received during a blocking operation. We need to
+			 * process the pending signals and exit if requested to
+			 * avoid hitting the SIGALRM limit if the blocking
+			 * operation took more than two seconds.
+			eloop_process_pending_signals();
+			if (eloop.terminate)
+				break;
+		timeout = dl_list_first(&eloop.timeout, struct eloop_timeout,
+					list);
+		if (timeout) {
+				os_reltime_sub(&timeout->time, &now, &tv);
+			else
+				tv.sec = tv.usec = 0;
+#if defined(CONFIG_ELOOP_POLL) || defined(CONFIG_ELOOP_EPOLL)
+			timeout_ms = tv.sec * 1000 + tv.usec / 1000;
+#endif /* defined(CONFIG_ELOOP_POLL) || defined(CONFIG_ELOOP_EPOLL) */
+			_tv.tv_sec = tv.sec;
+			_tv.tv_usec = tv.usec;
+		num_poll_fds = eloop_sock_table_set_fds(
+			&eloop.readers, &eloop.writers, &eloop.exceptions,
+			eloop.pollfds, eloop.pollfds_map,
+			eloop.max_pollfd_map);
+		res = poll(eloop.pollfds, num_poll_fds,
+			   timeout ? timeout_ms : -1);
+		eloop_sock_table_set_fds(&eloop.readers, rfds);
+		eloop_sock_table_set_fds(&eloop.writers, wfds);
+		eloop_sock_table_set_fds(&eloop.exceptions, efds);
+		res = select(eloop.max_sock + 1, rfds, wfds, efds,
+			     timeout ? &_tv : NULL);
+		if (eloop.count == 0) {
+			res = 0;
+		} else {
+			res = epoll_wait(eloop.epollfd, eloop.epoll_events,
+					 eloop.count, timeout_ms);
+		if (res < 0 && errno != EINTR && errno != 0) {
+			wpa_printf(MSG_ERROR, "eloop: %s: %s",
+				   "poll"
+				   "select"
+				   "epoll"
+				   , strerror(errno));
+			goto out;
+		eloop.readers.changed = 0;
+		eloop.writers.changed = 0;
+		eloop.exceptions.changed = 0;
+		/* check if some registered timeouts have occurred */
+					list);
+		if (timeout) {
+			if (!os_reltime_before(&now, &timeout->time)) {
+				void *eloop_data = timeout->eloop_data;
+				void *user_data = timeout->user_data;
+				eloop_timeout_handler handler =
+					timeout->handler;
+				handler(eloop_data, user_data);
+		if (res <= 0)
+			continue;
+		    eloop.exceptions.changed) {
+			  * Sockets may have been closed and reopened with the
+			  * same FD in the signal or timeout handlers, so we
+			  * must skip the previous results and check again
+			  * whether any of the currently registered sockets have
+			  * events.
+			continue;
+		eloop_sock_table_dispatch(&eloop.readers, &eloop.writers,
+					  &eloop.exceptions, eloop.pollfds_map,
+		eloop_sock_table_dispatch(&eloop.readers, rfds);
+		eloop_sock_table_dispatch(&eloop.writers, wfds);
+		eloop_sock_table_dispatch(&eloop.exceptions, efds);
+		eloop_sock_table_dispatch(eloop.epoll_events, res);
+	eloop.terminate = 0;
+out:
+	os_free(rfds);
+	os_free(wfds);
+	os_free(efds);
+	return;
+void eloop_terminate(void)
+	eloop.terminate = 1;
+void eloop_destroy(void)
+		int sec, usec;
+		sec = timeout->time.sec - now.sec;
+		usec = timeout->time.usec - now.usec;
+		if (timeout->time.usec < now.usec) {
+			sec--;
+			usec += 1000000;
+		wpa_printf(MSG_INFO, "ELOOP: remaining timeout: %d.%06d "
+			   "eloop_data=%p user_data=%p handler=%p",
+			   sec, usec, timeout->eloop_data, timeout->user_data,
+			   timeout->handler);
+		wpa_trace_dump_funcname("eloop unregistered timeout handler",
+		wpa_trace_dump("eloop timeout", timeout);
+	eloop_sock_table_destroy(&eloop.readers);
+	eloop_sock_table_destroy(&eloop.writers);
+	eloop_sock_table_destroy(&eloop.exceptions);
+	os_free(eloop.signals);
+	os_free(eloop.pollfds);
+	os_free(eloop.pollfds_map);
+	os_free(eloop.epoll_table);
+	os_free(eloop.epoll_events);
+	close(eloop.epollfd);
+int eloop_terminated(void)
+	return eloop.terminate || eloop.pending_terminate;
+void eloop_wait_for_read_sock(int sock)
+	struct pollfd pfd;
+	if (sock < 0)
+		return;
+	os_memset(&pfd, 0, sizeof(pfd));
+	pfd.fd = sock;
+	pfd.events = POLLIN;
+	poll(&pfd, 1, -1);
+#if defined(CONFIG_ELOOP_SELECT) || defined(CONFIG_ELOOP_EPOLL)
+	 * We can use epoll() here. But epoll() requres 4 system calls.
+	 * epoll_create1(), epoll_ctl() for ADD, epoll_wait, and close() for
+	 * epoll fd. So select() is better for performance here.
+	fd_set rfds;
+	if (sock < 0)
+		return;
+	FD_ZERO(&rfds);
+	FD_SET(sock, &rfds);
+	select(sock + 1, &rfds, NULL, NULL, NULL);
+#endif /* defined(CONFIG_ELOOP_SELECT) || defined(CONFIG_ELOOP_EPOLL) */
+#undef CONFIG_ELOOP_SELECT
diff --git a/freebsd/contrib/wpa/src/utils/eloop.h b/freebsd/contrib/wpa/src/utils/eloop.h
index 00000000000..07b8c0dc335
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/eloop.h
@@ -0,0 +1,359 @@
+ * Event loop
+ * Copyright (c) 2002-2006, Jouni Malinen <j at w1.fi>
+ * This file defines an event loop interface that supports processing events
+ * from registered timeouts (i.e., do something after N seconds), sockets
+ * (e.g., a new packet available for reading), and signals. eloop.c is an
+ * implementation of this interface using select() and sockets. This is
+ * suitable for most UNIX/POSIX systems. When porting to other operating
+ * systems, it may be necessary to replace that implementation with OS specific
+ * mechanisms.
+#ifndef ELOOP_H
+#define ELOOP_H
+ * ELOOP_ALL_CTX - eloop_cancel_timeout() magic number to match all timeouts
+#define ELOOP_ALL_CTX (void *) -1
+ * eloop_event_type - eloop socket event type for eloop_register_sock()
+ * @EVENT_TYPE_READ: Socket has data available for reading
+ * @EVENT_TYPE_WRITE: Socket has room for new data to be written
+ * @EVENT_TYPE_EXCEPTION: An exception has been reported
+typedef enum {
+	EVENT_TYPE_READ = 0,
+	EVENT_TYPE_WRITE,
+	EVENT_TYPE_EXCEPTION
+} eloop_event_type;
+ * eloop_sock_handler - eloop socket event callback type
+ * @sock: File descriptor number for the socket
+ * @eloop_ctx: Registered callback context data (eloop_data)
+ * @sock_ctx: Registered callback context data (user_data)
+typedef void (*eloop_sock_handler)(int sock, void *eloop_ctx, void *sock_ctx);
+ * eloop_event_handler - eloop generic event callback type
+typedef void (*eloop_event_handler)(void *eloop_data, void *user_ctx);
+ * eloop_timeout_handler - eloop timeout event callback type
+typedef void (*eloop_timeout_handler)(void *eloop_data, void *user_ctx);
+ * eloop_signal_handler - eloop signal event callback type
+ * @sig: Signal number
+ * @signal_ctx: Registered callback context data (user_data from
+ * eloop_register_signal(), eloop_register_signal_terminate(), or
+ * eloop_register_signal_reconfig() call)
+typedef void (*eloop_signal_handler)(int sig, void *signal_ctx);
+ * eloop_init() - Initialize global event loop data
+ * This function must be called before any other eloop_* function.
+int eloop_init(void);
+ * eloop_register_read_sock - Register handler for read events
+ * @handler: Callback function to be called when data is available for reading
+ * @eloop_data: Callback context data (eloop_ctx)
+ * @user_data: Callback context data (sock_ctx)
+ * Register a read socket notifier for the given file descriptor. The handler
+ * function will be called whenever data is available for reading from the
+ * socket. The handler function is responsible for clearing the event after
+ * having processed it in order to avoid eloop from calling the handler again
+ * for the same event.
+			     void *eloop_data, void *user_data);
+ * eloop_unregister_read_sock - Unregister handler for read events
+ * Unregister a read socket notifier that was previously registered with
+ * eloop_register_read_sock().
+void eloop_unregister_read_sock(int sock);
+ * eloop_register_sock - Register handler for socket events
+ * @type: Type of event to wait for
+ * @handler: Callback function to be called when the event is triggered
+ * Register an event notifier for the given socket's file descriptor. The
+ * handler function will be called whenever the that event is triggered for the
+ * eloop_unregister_sock - Unregister handler for socket events
+ * @type: Type of event for which sock was registered
+ * Unregister a socket event notifier that was previously registered with
+ * eloop_register_sock().
+void eloop_unregister_sock(int sock, eloop_event_type type);
+ * eloop_register_event - Register handler for generic events
+ * @event: Event to wait (eloop implementation specific)
+ * @event_size: Size of event data
+ * @handler: Callback function to be called when event is triggered
+ * @eloop_data: Callback context data (eloop_data)
+ * @user_data: Callback context data (user_data)
+ * Register an event handler for the given event. This function is used to
+ * register eloop implementation specific events which are mainly targeted for
+ * operating system specific code (driver interface and l2_packet) since the
+ * portable code will not be able to use such an OS-specific call. The handler
+ * function will be called whenever the event is triggered. The handler
+ * function is responsible for clearing the event after having processed it in
+ * order to avoid eloop from calling the handler again for the same event.
+ * In case of Windows implementation (eloop_win.c), event pointer is of HANDLE
+ * type, i.e., void*. The callers are likely to have 'HANDLE h' type variable,
+ * and they would call this function with eloop_register_event(h, sizeof(h),
+int eloop_register_event(void *event, size_t event_size,
+			 eloop_event_handler handler,
+ * eloop_unregister_event - Unregister handler for a generic event
+ * @event: Event to cancel (eloop implementation specific)
+ * Unregister a generic event notifier that was previously registered with
+ * eloop_register_event().
+void eloop_unregister_event(void *event, size_t event_size);
+ * eloop_register_timeout - Register timeout
+ * @secs: Number of seconds to the timeout
+ * @usecs: Number of microseconds to the timeout
+ * @handler: Callback function to be called when timeout occurs
+ * Register a timeout that will cause the handler function to be called after
+ * given time.
+ * eloop_cancel_timeout - Cancel timeouts
+ * @handler: Matching callback function
+ * @eloop_data: Matching eloop_data or %ELOOP_ALL_CTX to match all
+ * @user_data: Matching user_data or %ELOOP_ALL_CTX to match all
+ * Returns: Number of cancelled timeouts
+ * Cancel matching <handler,eloop_data,user_data> timeouts registered with
+ * eloop_register_timeout(). ELOOP_ALL_CTX can be used as a wildcard for
+ * cancelling all timeouts regardless of eloop_data/user_data.
+ * eloop_cancel_timeout_one - Cancel a single timeout
+ * @remaining: Time left on the cancelled timer
+ * Cancel matching <handler,eloop_data,user_data> timeout registered with
+ * eloop_register_timeout() and return the remaining time left.
+			     struct os_reltime *remaining);
+ * eloop_is_timeout_registered - Check if a timeout is already registered
+ * Returns: 1 if the timeout is registered, 0 if the timeout is not registered
+ * Determine if a matching <handler,eloop_data,user_data> timeout is registered
+ * with eloop_register_timeout().
+ * eloop_deplete_timeout - Deplete a timeout that is already registered
+ * @req_secs: Requested number of seconds to the timeout
+ * @req_usecs: Requested number of microseconds to the timeout
+ * Returns: 1 if the timeout is depleted, 0 if no change is made, -1 if no
+ * timeout matched
+ * Find a registered matching <handler,eloop_data,user_data> timeout. If found,
+ * deplete the timeout if remaining time is more than the requested time.
+			  void *user_data);
+ * eloop_replenish_timeout - Replenish a timeout that is already registered
+ * Returns: 1 if the timeout is replenished, 0 if no change is made, -1 if no
+ * timeout matched
+ * replenish the timeout if remaining time is less than the requested time.
+			    void *user_data);
+ * eloop_register_signal - Register handler for signals
+ * @sig: Signal number (e.g., SIGHUP)
+ * @handler: Callback function to be called when the signal is received
+ * @user_data: Callback context data (signal_ctx)
+ * Register a callback function that will be called when a signal is received.
+ * The callback function is actually called only after the system signal
+ * handler has returned. This means that the normal limits for sighandlers
+ * (i.e., only "safe functions" allowed) do not apply for the registered
+ * callback.
+			  void *user_data);
+ * eloop_register_signal_terminate - Register handler for terminate signals
+ * Register a callback function that will be called when a process termination
+ * signal is received. The callback function is actually called only after the
+ * system signal handler has returned. This means that the normal limits for
+ * sighandlers (i.e., only "safe functions" allowed) do not apply for the
+ * registered callback.
+ * This function is a more portable version of eloop_register_signal() since
+ * the knowledge of exact details of the signals is hidden in eloop
+ * implementation. In case of operating systems using signal(), this function
+ * registers handlers for SIGINT and SIGTERM.
+				    void *user_data);
+ * eloop_register_signal_reconfig - Register handler for reconfig signals
+ * Register a callback function that will be called when a reconfiguration /
+ * hangup signal is received. The callback function is actually called only
+ * after the system signal handler has returned. This means that the normal
+ * limits for sighandlers (i.e., only "safe functions" allowed) do not apply
+ * for the registered callback.
+ * registers a handler for SIGHUP.
+				   void *user_data);
+ * eloop_run - Start the event loop
+ * Start the event loop and continue running as long as there are any
+ * registered event handlers. This function is run after event loop has been
+ * initialized with event_init() and one or more events have been registered.
+void eloop_run(void);
+ * eloop_terminate - Terminate event loop
+ * Terminate event loop even if there are registered events. This can be used
+ * to request the program to be terminated cleanly.
+void eloop_terminate(void);
+ * eloop_destroy - Free any resources allocated for the event loop
+ * After calling eloop_destroy(), other eloop_* functions must not be called
+ * before re-running eloop_init().
+void eloop_destroy(void);
+ * eloop_terminated - Check whether event loop has been terminated
+ * Returns: 1 = event loop terminate, 0 = event loop still running
+ * This function can be used to check whether eloop_terminate() has been called
+ * to request termination of the event loop. This is normally used to abort
+ * operations that may still be queued to be run when eloop_terminate() was
+ * called.
+int eloop_terminated(void);
+ * eloop_wait_for_read_sock - Wait for a single reader
+ * Do a blocking wait for a single read socket.
+void eloop_wait_for_read_sock(int sock);
+#endif /* ELOOP_H */
diff --git a/freebsd/contrib/wpa/src/utils/ext_password.h b/freebsd/contrib/wpa/src/utils/ext_password.h
new file mode 100644
index 00000000000..e3e46ea0843
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/ext_password.h
@@ -0,0 +1,33 @@
+ * External password backend
+ * Copyright (c) 2012, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef EXT_PASSWORD_H
+#define EXT_PASSWORD_H
+struct ext_password_data;
+#ifdef CONFIG_EXT_PASSWORD
+struct ext_password_data * ext_password_init(const char *backend,
+					     const char *params);
+void ext_password_deinit(struct ext_password_data *data);
+struct wpabuf * ext_password_get(struct ext_password_data *data,
+				 const char *name);
+void ext_password_free(struct wpabuf *pw);
+#else /* CONFIG_EXT_PASSWORD */
+#define ext_password_init(b, p) ((void *) 1)
+#define ext_password_deinit(d) do { } while (0)
+#define ext_password_get(d, n) (NULL)
+#define ext_password_free(p) do { } while (0)
+#endif /* CONFIG_EXT_PASSWORD */
+#endif /* EXT_PASSWORD_H */
diff --git a/freebsd/contrib/wpa/src/utils/includes.h b/freebsd/contrib/wpa/src/utils/includes.h
index 00000000000..75513fc8c1e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/includes.h
@@ -0,0 +1,45 @@
+ * wpa_supplicant/hostapd - Default include files
+ * Copyright (c) 2005-2006, Jouni Malinen <j at w1.fi>
+ * This header file is included into all C files so that commonly used header
+ * files can be selected with OS specific ifdef blocks in one place instead of
+ * having to have OS/C library specific selection in many files.
+#ifndef INCLUDES_H
+#define INCLUDES_H
+/* Include possible build time configuration before including anything else */
+#include "build_config.h"
+#include <stdlib.h>
+#include <stddef.h>
+#include <stdio.h>
+#include <stdarg.h>
+#include <string.h>
+#ifndef _WIN32_WCE
+#include <signal.h>
+#include <errno.h>
+#include <ctype.h>
+#ifndef _MSC_VER
+#include <unistd.h>
+#include <sys/socket.h>
+#include <netinet/in.h>
+#include <arpa/inet.h>
+#ifndef __vxworks
+#include <sys/uio.h>
+#include <sys/time.h>
+#endif /* INCLUDES_H */
diff --git a/freebsd/contrib/wpa/src/utils/ip_addr.h b/freebsd/contrib/wpa/src/utils/ip_addr.h
index 00000000000..0670411ccde
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/ip_addr.h
@@ -0,0 +1,27 @@
+ * IP address processing
+ * Copyright (c) 2003-2006, Jouni Malinen <j at w1.fi>
+#ifndef IP_ADDR_H
+#define IP_ADDR_H
+struct hostapd_ip_addr {
+	int af; /* AF_INET / AF_INET6 */
+	union {
+		struct in_addr v4;
+#ifdef CONFIG_IPV6
+		struct in6_addr v6;
+#endif /* CONFIG_IPV6 */
+		u8 max_len[16];
+	} u;
+const char * hostapd_ip_txt(const struct hostapd_ip_addr *addr, char *buf,
+			    size_t buflen);
+int hostapd_parse_ip_addr(const char *txt, struct hostapd_ip_addr *addr);
+#endif /* IP_ADDR_H */
diff --git a/freebsd/contrib/wpa/src/utils/list.h b/freebsd/contrib/wpa/src/utils/list.h
index 00000000000..ee2f4856950
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/list.h
@@ -0,0 +1,97 @@
+ * Doubly-linked list
+ * Copyright (c) 2009, Jouni Malinen <j at w1.fi>
+#ifndef LIST_H
+#define LIST_H
+ * struct dl_list - Doubly-linked list
+struct dl_list {
+	struct dl_list *next;
+	struct dl_list *prev;
+#define DL_LIST_HEAD_INIT(l) { &(l), &(l) }
+static inline void dl_list_init(struct dl_list *list)
+	list->next = list;
+	list->prev = list;
+static inline void dl_list_add(struct dl_list *list, struct dl_list *item)
+	item->next = list->next;
+	item->prev = list;
+	list->next->prev = item;
+	list->next = item;
+static inline void dl_list_add_tail(struct dl_list *list, struct dl_list *item)
+	dl_list_add(list->prev, item);
+static inline void dl_list_del(struct dl_list *item)
+	item->next->prev = item->prev;
+	item->prev->next = item->next;
+	item->next = NULL;
+	item->prev = NULL;
+static inline int dl_list_empty(struct dl_list *list)
+	return list->next == list;
+static inline unsigned int dl_list_len(struct dl_list *list)
+	struct dl_list *item;
+	int count = 0;
+	for (item = list->next; item != list; item = item->next)
+		count++;
+	return count;
+#ifndef offsetof
+#define offsetof(type, member) ((long) &((type *) 0)->member)
+#endif
+#define dl_list_entry(item, type, member) \
+	((type *) ((char *) item - offsetof(type, member)))
+#define dl_list_first(list, type, member) \
+	(dl_list_empty((list)) ? NULL : \
+	 dl_list_entry((list)->next, type, member))
+#define dl_list_last(list, type, member) \
+	 dl_list_entry((list)->prev, type, member))
+#define dl_list_for_each(item, list, type, member) \
+	for (item = dl_list_entry((list)->next, type, member); \
+	     &item->member != (list); \
+	     item = dl_list_entry(item->member.next, type, member))
+#define dl_list_for_each_safe(item, n, list, type, member) \
+	for (item = dl_list_entry((list)->next, type, member), \
+		     n = dl_list_entry(item->member.next, type, member); \
+	     item = n, n = dl_list_entry(n->member.next, type, member))
+#define dl_list_for_each_reverse(item, list, type, member) \
+	for (item = dl_list_entry((list)->prev, type, member); \
+	     item = dl_list_entry(item->member.prev, type, member))
+#define DEFINE_DL_LIST(name) \
+	struct dl_list name = { &(name), &(name) }
+#endif /* LIST_H */
diff --git a/freebsd/contrib/wpa/src/utils/os.h b/freebsd/contrib/wpa/src/utils/os.h
index 00000000000..9e496fb6597
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/os.h
@@ -0,0 +1,664 @@
+ * OS specific functions
+ * Copyright (c) 2005-2009, Jouni Malinen <j at w1.fi>
+#ifndef OS_H
+#define OS_H
+typedef long os_time_t;
+ * os_sleep - Sleep (sec, usec)
+ * @sec: Number of seconds to sleep
+ * @usec: Number of microseconds to sleep
+void os_sleep(os_time_t sec, os_time_t usec);
+struct os_time {
+	os_time_t sec;
+	os_time_t usec;
+struct os_reltime {
+	os_time_t sec;
+	os_time_t usec;
+ * os_get_time - Get current time (sec, usec)
+ * @t: Pointer to buffer for the time
+ * Returns: 0 on success, -1 on failure
+int os_get_time(struct os_time *t);
+ * os_get_reltime - Get relative time (sec, usec)
+int os_get_reltime(struct os_reltime *t);
+/* Helpers for handling struct os_time */
+static inline int os_time_before(struct os_time *a, struct os_time *b)
+	return (a->sec < b->sec) ||
+	       (a->sec == b->sec && a->usec < b->usec);
+static inline void os_time_sub(struct os_time *a, struct os_time *b,
+			       struct os_time *res)
+	res->sec = a->sec - b->sec;
+	res->usec = a->usec - b->usec;
+	if (res->usec < 0) {
+		res->sec--;
+		res->usec += 1000000;
+/* Helpers for handling struct os_reltime */
+static inline int os_reltime_before(struct os_reltime *a,
+				    struct os_reltime *b)
+static inline void os_reltime_sub(struct os_reltime *a, struct os_reltime *b,
+				  struct os_reltime *res)
+		res->sec--;
+static inline void os_reltime_age(struct os_reltime *start,
+				  struct os_reltime *age)
+	os_reltime_sub(&now, start, age);
+static inline int os_reltime_expired(struct os_reltime *now,
+				     struct os_reltime *ts,
+				     os_time_t timeout_secs)
+	struct os_reltime age;
+	os_reltime_sub(now, ts, &age);
+	return (age.sec > timeout_secs) ||
+	       (age.sec == timeout_secs && age.usec > 0);
+static inline int os_reltime_initialized(struct os_reltime *t)
+	return t->sec != 0 || t->usec != 0;
+ * os_mktime - Convert broken-down time into seconds since 1970-01-01
+ * @year: Four digit year
+ * @month: Month (1 .. 12)
+ * @day: Day of month (1 .. 31)
+ * @hour: Hour (0 .. 23)
+ * @min: Minute (0 .. 59)
+ * @sec: Second (0 .. 60)
+ * @t: Buffer for returning calendar time representation (seconds since
+ * 1970-01-01 00:00:00)
+ * Note: The result is in seconds from Epoch, i.e., in UTC, not in local time
+ * which is used by POSIX mktime().
+int os_mktime(int year, int month, int day, int hour, int min, int sec,
+	      os_time_t *t);
+struct os_tm {
+	int sec; /* 0..59 or 60 for leap seconds */
+	int min; /* 0..59 */
+	int hour; /* 0..23 */
+	int day; /* 1..31 */
+	int month; /* 1..12 */
+	int year; /* Four digit year */
+int os_gmtime(os_time_t t, struct os_tm *tm);
+ * os_daemonize - Run in the background (detach from the controlling terminal)
+ * @pid_file: File name to write the process ID to or %NULL to skip this
+int os_daemonize(const char *pid_file);
+ * os_daemonize_terminate - Stop running in the background (remove pid file)
+void os_daemonize_terminate(const char *pid_file);
+ * os_get_random - Get cryptographically strong pseudo random data
+ * @buf: Buffer for pseudo random data
+ * @len: Length of the buffer
+int os_get_random(unsigned char *buf, size_t len);
+ * os_random - Get pseudo random value (not necessarily very strong)
+ * Returns: Pseudo random value
+unsigned long os_random(void);
+ * os_rel2abs_path - Get an absolute path for a file
+ * @rel_path: Relative path to a file
+ * Returns: Absolute path for the file or %NULL on failure
+ * This function tries to convert a relative path of a file to an absolute path
+ * in order for the file to be found even if current working directory has
+ * changed. The returned value is allocated and caller is responsible for
+ * freeing it. It is acceptable to just return the same path in an allocated
+ * buffer, e.g., return strdup(rel_path). This function is only used to find
+ * configuration files when os_daemonize() may have changed the current working
+ * directory and relative path would be pointing to a different location.
+char * os_rel2abs_path(const char *rel_path);
+ * os_program_init - Program initialization (called at start)
+ * This function is called when a programs starts. If there are any OS specific
+ * processing that is needed, it can be placed here. It is also acceptable to
+ * just return 0 if not special processing is needed.
+int os_program_init(void);
+ * os_program_deinit - Program deinitialization (called just before exit)
+ * This function is called just before a program exists. If there are any OS
+ * specific processing, e.g., freeing resourced allocated in os_program_init(),
+ * it should be done here. It is also acceptable for this function to do
+ * nothing.
+void os_program_deinit(void);
+ * os_setenv - Set environment variable
+ * @name: Name of the variable
+ * @value: Value to set to the variable
+ * @overwrite: Whether existing variable should be overwritten
+ * Returns: 0 on success, -1 on error
+ * This function is only used for wpa_cli action scripts. OS wrapper does not
+ * need to implement this if such functionality is not needed.
+int os_setenv(const char *name, const char *value, int overwrite);
+ * os_unsetenv - Delete environent variable
+int os_unsetenv(const char *name);
+ * os_readfile - Read a file to an allocated memory buffer
+ * @name: Name of the file to read
+ * @len: For returning the length of the allocated buffer
+ * Returns: Pointer to the allocated buffer or %NULL on failure
+ * This function allocates memory and reads the given file to this buffer. Both
+ * binary and text files can be read with this function. The caller is
+ * responsible for freeing the returned buffer with os_free().
+char * os_readfile(const char *name, size_t *len);
+ * os_file_exists - Check whether the specified file exists
+ * @fname: Path and name of the file
+ * Returns: 1 if the file exists or 0 if not
+int os_file_exists(const char *fname);
+ * os_fdatasync - Sync a file's (for a given stream) state with storage device
+ * @stream: the stream to be flushed
+ * Returns: 0 if the operation succeeded or -1 on failure
+int os_fdatasync(FILE *stream);
+ * os_zalloc - Allocate and zero memory
+ * @size: Number of bytes to allocate
+ * Returns: Pointer to allocated and zeroed memory or %NULL on failure
+ * Caller is responsible for freeing the returned buffer with os_free().
+void * os_zalloc(size_t size);
+ * os_calloc - Allocate and zero memory for an array
+ * @nmemb: Number of members in the array
+ * @size: Number of bytes in each member
+ * This function can be used as a wrapper for os_zalloc(nmemb * size) when an
+ * allocation is used for an array. The main benefit over os_zalloc() is in
+ * having an extra check to catch integer overflows in multiplication.
+static inline void * os_calloc(size_t nmemb, size_t size)
+	if (size && nmemb > (~(size_t) 0) / size)
+		return NULL;
+	return os_zalloc(nmemb * size);
+ * The following functions are wrapper for standard ANSI C or POSIX functions.
+ * By default, they are just defined to use the standard function name and no
+ * os_*.c implementation is needed for them. This avoids extra function calls
+ * by allowing the C pre-processor take care of the function name mapping.
+ * If the target system uses a C library that does not provide these functions,
+ * build_config.h can be used to define the wrappers to use a different
+ * function name. This can be done on function-by-function basis since the
+ * defines here are only used if build_config.h does not define the os_* name.
+ * If needed, os_*.c file can be used to implement the functions that are not
+ * included in the C library on the target system. Alternatively,
+ * OS_NO_C_LIB_DEFINES can be defined to skip all defines here in which case
+ * these functions need to be implemented in os_*.c file for the target system.
+#ifdef OS_NO_C_LIB_DEFINES
+ * os_malloc - Allocate dynamic memory
+ * @size: Size of the buffer to allocate
+ * Returns: Allocated buffer or %NULL on failure
+void * os_malloc(size_t size);
+ * os_realloc - Re-allocate dynamic memory
+ * @ptr: Old buffer from os_malloc() or os_realloc()
+ * @size: Size of the new buffer
+ * If re-allocation fails, %NULL is returned and the original buffer (ptr) is
+ * not freed and caller is still responsible for freeing it.
+void * os_realloc(void *ptr, size_t size);
+ * os_free - Free dynamic memory
+ * @ptr: Old buffer from os_malloc() or os_realloc(); can be %NULL
+void os_free(void *ptr);
+ * os_memcpy - Copy memory area
+ * @dest: Destination
+ * @src: Source
+ * @n: Number of bytes to copy
+ * Returns: dest
+ * The memory areas src and dst must not overlap. os_memmove() can be used with
+ * overlapping memory.
+void * os_memcpy(void *dest, const void *src, size_t n);
+ * os_memmove - Copy memory area
+ * @src: Source
+ * Returns: dest
+ * The memory areas src and dst may overlap.
+void * os_memmove(void *dest, const void *src, size_t n);
+ * os_memset - Fill memory with a constant byte
+ * @s: Memory area to be filled
+ * @c: Constant byte
+ * @n: Number of bytes started from s to fill with c
+ * Returns: s
+void * os_memset(void *s, int c, size_t n);
+ * os_memcmp - Compare memory areas
+ * @s1: First buffer
+ * @s2: Second buffer
+ * @n: Maximum numbers of octets to compare
+ * Returns: An integer less than, equal to, or greater than zero if s1 is
+ * found to be less than, to match, or be greater than s2. Only first n
+ * characters will be compared.
+int os_memcmp(const void *s1, const void *s2, size_t n);
+ * os_strdup - Duplicate a string
+ * @s: Source string
+ * Returns: Allocated buffer with the string copied into it or %NULL on failure
+char * os_strdup(const char *s);
+ * os_strlen - Calculate the length of a string
+ * @s: '\0' terminated string
+ * Returns: Number of characters in s (not counting the '\0' terminator)
+size_t os_strlen(const char *s);
+ * os_strcasecmp - Compare two strings ignoring case
+ * @s1: First string
+ * @s2: Second string
+ * found to be less than, to match, or be greatred than s2
+int os_strcasecmp(const char *s1, const char *s2);
+ * os_strncasecmp - Compare two strings ignoring case
+ * @n: Maximum numbers of characters to compare
+int os_strncasecmp(const char *s1, const char *s2, size_t n);
+ * os_strchr - Locate the first occurrence of a character in string
+ * @s: String
+ * @c: Character to search for
+ * Returns: Pointer to the matched character or %NULL if not found
+char * os_strchr(const char *s, int c);
+ * os_strrchr - Locate the last occurrence of a character in string
+ * @s: String
+char * os_strrchr(const char *s, int c);
+ * os_strcmp - Compare two strings
+int os_strcmp(const char *s1, const char *s2);
+ * os_strncmp - Compare two strings
+int os_strncmp(const char *s1, const char *s2, size_t n);
+ * os_strstr - Locate a substring
+ * @haystack: String (haystack) to search from
+ * @needle: Needle to search from haystack
+ * Returns: Pointer to the beginning of the substring or %NULL if not found
+char * os_strstr(const char *haystack, const char *needle);
+ * os_snprintf - Print to a memory buffer
+ * @str: Memory buffer to print into
+ * @size: Maximum length of the str buffer
+ * @format: printf format
+ * Returns: Number of characters printed (not including trailing '\0').
+ * If the output buffer is truncated, number of characters which would have
+ * been written is returned. Since some C libraries return -1 in such a case,
+ * the caller must be prepared on that value, too, to indicate truncation.
+ * Note: Some C library implementations of snprintf() may not guarantee null
+ * termination in case the output is truncated. The OS wrapper function of
+ * os_snprintf() should provide this guarantee, i.e., to null terminate the
+ * output buffer if a C library version of the function is used and if that
+ * function does not guarantee null termination.
+ * If the target system does not include snprintf(), see, e.g.,
+ * http://www.ijs.si/software/snprintf/ for an example of a portable
+ * implementation of snprintf.
+int os_snprintf(char *str, size_t size, const char *format, ...);
+#else /* OS_NO_C_LIB_DEFINES */
+#ifdef WPA_TRACE
+#ifndef os_malloc
+#define os_malloc(s) malloc((s))
+#endif
+#ifndef os_realloc
+#define os_realloc(p, s) realloc((p), (s))
+#endif
+#ifndef os_free
+#define os_free(p) free((p))
+#endif
+#ifndef os_strdup
+#ifdef _MSC_VER
+#define os_strdup(s) _strdup(s)
+#else
+#define os_strdup(s) strdup(s)
+#endif
+#endif
+#ifndef os_memcpy
+#define os_memcpy(d, s, n) memcpy((d), (s), (n))
+#endif
+#ifndef os_memmove
+#define os_memmove(d, s, n) memmove((d), (s), (n))
+#endif
+#ifndef os_memset
+#define os_memset(s, c, n) memset(s, c, n)
+#endif
+#ifndef os_memcmp
+#define os_memcmp(s1, s2, n) memcmp((s1), (s2), (n))
+#endif
+#ifndef os_strlen
+#define os_strlen(s) strlen(s)
+#endif
+#ifndef os_strcasecmp
+#ifdef _MSC_VER
+#define os_strcasecmp(s1, s2) _stricmp((s1), (s2))
+#else
+#define os_strcasecmp(s1, s2) strcasecmp((s1), (s2))
+#endif
+#endif
+#ifndef os_strncasecmp
+#ifdef _MSC_VER
+#define os_strncasecmp(s1, s2, n) _strnicmp((s1), (s2), (n))
+#else
+#define os_strncasecmp(s1, s2, n) strncasecmp((s1), (s2), (n))
+#endif
+#endif
+#ifndef os_strchr
+#define os_strchr(s, c) strchr((s), (c))
+#endif
+#ifndef os_strcmp
+#define os_strcmp(s1, s2) strcmp((s1), (s2))
+#endif
+#ifndef os_strncmp
+#define os_strncmp(s1, s2, n) strncmp((s1), (s2), (n))
+#endif
+#ifndef os_strrchr
+#define os_strrchr(s, c) strrchr((s), (c))
+#endif
+#ifndef os_strstr
+#define os_strstr(h, n) strstr((h), (n))
+#endif
+#ifndef os_snprintf
+#ifdef _MSC_VER
+#define os_snprintf _snprintf
+#else
+#define os_snprintf snprintf
+#endif
+#endif
+#endif /* OS_NO_C_LIB_DEFINES */
+static inline int os_snprintf_error(size_t size, int res)
+	return res < 0 || (unsigned int) res >= size;
+static inline void * os_realloc_array(void *ptr, size_t nmemb, size_t size)
+		return NULL;
+	return os_realloc(ptr, nmemb * size);
+ * os_remove_in_array - Remove a member from an array by index
+ * @ptr: Pointer to the array
+ * @nmemb: Current member count of the array
+ * @size: The size per member of the array
+ * @idx: Index of the member to be removed
+static inline void os_remove_in_array(void *ptr, size_t nmemb, size_t size,
+				      size_t idx)
+	if (idx < nmemb - 1)
+		os_memmove(((unsigned char *) ptr) + idx * size,
+			   ((unsigned char *) ptr) + (idx + 1) * size,
+			   (nmemb - idx - 1) * size);
+ * os_strlcpy - Copy a string with size bound and NUL-termination
+ * @src: Source
+ * @siz: Size of the target buffer
+ * Returns: Total length of the target string (length of src) (not including
+ * NUL-termination)
+ * This function matches in behavior with the strlcpy(3) function in OpenBSD.
+size_t os_strlcpy(char *dest, const char *src, size_t siz);
+ * os_memcmp_const - Constant time memory comparison
+ * @a: First buffer to compare
+ * @b: Second buffer to compare
+ * @len: Number of octets to compare
+ * Returns: 0 if buffers are equal, non-zero if not
+ * This function is meant for comparing passwords or hash values where
+ * difference in execution time could provide external observer information
+ * about the location of the difference in the memory buffers. The return value
+ * does not behave like os_memcmp(), i.e., os_memcmp_const() cannot be used to
+ * sort items into a defined order. Unlike os_memcmp(), execution time of
+ * os_memcmp_const() does not depend on the contents of the compared memory
+ * buffers, but only on the total compared length.
+int os_memcmp_const(const void *a, const void *b, size_t len);
+ * os_exec - Execute an external program
+ * @program: Path to the program
+ * @arg: Command line argument string
+ * @wait_completion: Whether to wait until the program execution completes
+int os_exec(const char *program, const char *arg, int wait_completion);
+#ifdef OS_REJECT_C_LIB_FUNCTIONS
+#define malloc OS_DO_NOT_USE_malloc
+#define realloc OS_DO_NOT_USE_realloc
+#define free OS_DO_NOT_USE_free
+#define memcpy OS_DO_NOT_USE_memcpy
+#define memmove OS_DO_NOT_USE_memmove
+#define memset OS_DO_NOT_USE_memset
+#define memcmp OS_DO_NOT_USE_memcmp
+#undef strdup
+#define strdup OS_DO_NOT_USE_strdup
+#define strlen OS_DO_NOT_USE_strlen
+#define strcasecmp OS_DO_NOT_USE_strcasecmp
+#define strncasecmp OS_DO_NOT_USE_strncasecmp
+#undef strchr
+#define strchr OS_DO_NOT_USE_strchr
+#undef strcmp
+#define strcmp OS_DO_NOT_USE_strcmp
+#undef strncmp
+#define strncmp OS_DO_NOT_USE_strncmp
+#undef strncpy
+#define strncpy OS_DO_NOT_USE_strncpy
+#define strrchr OS_DO_NOT_USE_strrchr
+#define strstr OS_DO_NOT_USE_strstr
+#undef snprintf
+#define snprintf OS_DO_NOT_USE_snprintf
+#define strcpy OS_DO_NOT_USE_strcpy
+#endif /* OS_REJECT_C_LIB_FUNCTIONS */
+#if defined(WPA_TRACE_BFD) && defined(CONFIG_TESTING_OPTIONS)
+#define TEST_FAIL() testing_test_fail()
+int testing_test_fail(void);
+#else
+#define TEST_FAIL() 0
+#endif
+#endif /* OS_H */
diff --git a/freebsd/contrib/wpa/src/utils/os_unix.c b/freebsd/contrib/wpa/src/utils/os_unix.c
index 00000000000..a3abce4c123
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/os_unix.c
@@ -0,0 +1,851 @@
+ * OS specific functions for UNIX/POSIX systems
+#include <time.h>
+#include <sys/wait.h>
+#ifdef ANDROID
+#include <sys/capability.h>
+#include <sys/prctl.h>
+#include <private/android_filesystem_config.h>
+#endif /* ANDROID */
+#ifdef __MACH__
+#include <CoreServices/CoreServices.h>
+#include <mach/mach.h>
+#include <mach/mach_time.h>
+#endif /* __MACH__ */
+#include "os.h"
+#ifdef WPA_TRACE
+#include "trace.h"
+#include "list.h"
+static struct dl_list alloc_list = DL_LIST_HEAD_INIT(alloc_list);
+#define ALLOC_MAGIC 0xa84ef1b2
+#define FREED_MAGIC 0x67fd487a
+struct os_alloc_trace {
+	unsigned int magic;
+	size_t len;
+	WPA_TRACE_INFO
+} __attribute__((aligned(16)));
+	if (sec)
+		sleep(sec);
+	if (usec)
+		usleep(usec);
+	int res;
+	struct timeval tv;
+	res = gettimeofday(&tv, NULL);
+	t->sec = tv.tv_sec;
+	t->usec = tv.tv_usec;
+	return res;
+#ifndef __MACH__
+#if defined(CLOCK_BOOTTIME)
+	static clockid_t clock_id = CLOCK_BOOTTIME;
+#elif defined(CLOCK_MONOTONIC)
+	static clockid_t clock_id = CLOCK_MONOTONIC;
+#else
+	static clockid_t clock_id = CLOCK_REALTIME;
+#endif
+	struct timespec ts;
+	int res;
+	while (1) {
+		res = clock_gettime(clock_id, &ts);
+		if (res == 0) {
+			t->sec = ts.tv_sec;
+			t->usec = ts.tv_nsec / 1000;
+			return 0;
+		switch (clock_id) {
+#ifdef CLOCK_BOOTTIME
+		case CLOCK_BOOTTIME:
+			clock_id = CLOCK_MONOTONIC;
+			break;
+#endif
+#ifdef CLOCK_MONOTONIC
+		case CLOCK_MONOTONIC:
+			clock_id = CLOCK_REALTIME;
+			break;
+#endif
+		case CLOCK_REALTIME:
+			return -1;
+#else /* __MACH__ */
+	uint64_t abstime, nano;
+	static mach_timebase_info_data_t info = { 0, 0 };
+	if (!info.denom) {
+		if (mach_timebase_info(&info) != KERN_SUCCESS)
+			return -1;
+	abstime = mach_absolute_time();
+	nano = (abstime * info.numer) / info.denom;
+	t->sec = nano / NSEC_PER_SEC;
+	t->usec = (nano - (((uint64_t) t->sec) * NSEC_PER_SEC)) / NSEC_PER_USEC;
+	return 0;
+	      os_time_t *t)
+	struct tm tm, *tm1;
+	time_t t_local, t1, t2;
+	os_time_t tz_offset;
+	if (year < 1970 || month < 1 || month > 12 || day < 1 || day > 31 ||
+	    hour < 0 || hour > 23 || min < 0 || min > 59 || sec < 0 ||
+	    sec > 60)
+		return -1;
+	memset(&tm, 0, sizeof(tm));
+	tm.tm_year = year - 1900;
+	tm.tm_mon = month - 1;
+	tm.tm_mday = day;
+	tm.tm_hour = hour;
+	tm.tm_min = min;
+	tm.tm_sec = sec;
+	t_local = mktime(&tm);
+	/* figure out offset to UTC */
+	tm1 = localtime(&t_local);
+	if (tm1) {
+		t1 = mktime(tm1);
+		tm1 = gmtime(&t_local);
+		if (tm1) {
+			t2 = mktime(tm1);
+			tz_offset = t2 - t1;
+		} else
+			tz_offset = 0;
+	} else
+		tz_offset = 0;
+	*t = (os_time_t) t_local - tz_offset;
+	return 0;
+	struct tm *tm2;
+	time_t t2 = t;
+	tm2 = gmtime(&t2);
+	if (tm2 == NULL)
+		return -1;
+	tm->sec = tm2->tm_sec;
+	tm->min = tm2->tm_min;
+	tm->hour = tm2->tm_hour;
+	tm->day = tm2->tm_mday;
+	tm->month = tm2->tm_mon + 1;
+	tm->year = tm2->tm_year + 1900;
+	return 0;
+#ifdef __APPLE__
+#include <fcntl.h>
+static int os_daemon(int nochdir, int noclose)
+	int devnull;
+	if (chdir("/") < 0)
+		return -1;
+	devnull = open("/dev/null", O_RDWR);
+	if (devnull < 0)
+		return -1;
+	if (dup2(devnull, STDIN_FILENO) < 0) {
+		close(devnull);
+		return -1;
+	if (dup2(devnull, STDOUT_FILENO) < 0) {
+		close(devnull);
+		return -1;
+	if (dup2(devnull, STDERR_FILENO) < 0) {
+		close(devnull);
+		return -1;
+	return 0;
+#else /* __APPLE__ */
+#define os_daemon daemon
+#endif /* __APPLE__ */
+#ifdef __FreeBSD__
+#include <err.h>
+#include <libutil.h>
+#include <stdint.h>
+#endif /* __FreeBSD__ */
+#if defined(__uClinux__) || defined(__sun__)
+	return -1;
+#else /* defined(__uClinux__) || defined(__sun__) */
+#ifdef __FreeBSD__
+	pid_t otherpid;
+	struct pidfh *pfh;
+	pfh = pidfile_open(pid_file, 0600, &otherpid);
+	if (pfh == NULL) {
+		if (errno == EEXIST) {
+			errx(1, "Daemon already running, pid: %jd.",
+			    (intmax_t)otherpid);
+		warn("Cannot open or create pidfile.");
+	if (os_daemon(0, 0)) {
+		perror("daemon");
+#ifdef __FreeBSD__
+		pidfile_remove(pfh);
+		return -1;
+#ifndef __FreeBSD__
+	if (pid_file) {
+		FILE *f = fopen(pid_file, "w");
+		if (f) {
+			fprintf(f, "%u\n", getpid());
+			fclose(f);
+#else /* __FreeBSD__ */
+	pidfile_write(pfh);
+	return -0;
+#endif /* defined(__uClinux__) || defined(__sun__) */
+	if (pid_file)
+		unlink(pid_file);
+	FILE *f;
+	size_t rc;
+	if (TEST_FAIL())
+		return -1;
+	f = fopen("/dev/urandom", "rb");
+	if (f == NULL) {
+		printf("Could not open /dev/urandom.\n");
+		return -1;
+	rc = fread(buf, 1, len, f);
+	fclose(f);
+	return rc != len ? -1 : 0;
+	return random();
+	char *buf = NULL, *cwd, *ret;
+	size_t len = 128, cwd_len, rel_len, ret_len;
+	int last_errno;
+	if (!rel_path)
+		return NULL;
+	if (rel_path[0] == '/')
+		return os_strdup(rel_path);
+	for (;;) {
+		buf = os_malloc(len);
+		if (buf == NULL)
+			return NULL;
+		cwd = getcwd(buf, len);
+		if (cwd == NULL) {
+			last_errno = errno;
+			os_free(buf);
+			if (last_errno != ERANGE)
+				return NULL;
+			len *= 2;
+			if (len > 2000)
+				return NULL;
+		} else {
+			buf[len - 1] = '\0';
+			break;
+	cwd_len = os_strlen(cwd);
+	rel_len = os_strlen(rel_path);
+	ret_len = cwd_len + 1 + rel_len + 1;
+	ret = os_malloc(ret_len);
+	if (ret) {
+		os_memcpy(ret, cwd, cwd_len);
+		ret[cwd_len] = '/';
+		os_memcpy(ret + cwd_len + 1, rel_path, rel_len);
+		ret[ret_len - 1] = '\0';
+	os_free(buf);
+	return ret;
+#ifdef ANDROID
+	 * We ignore errors here since errors are normal if we
+	 * are already running as non-root.
+#ifdef ANDROID_SETGROUPS_OVERRIDE
+	gid_t groups[] = { ANDROID_SETGROUPS_OVERRIDE };
+#else /* ANDROID_SETGROUPS_OVERRIDE */
+	gid_t groups[] = { AID_INET, AID_WIFI, AID_KEYSTORE };
+#endif /* ANDROID_SETGROUPS_OVERRIDE */
+	struct __user_cap_header_struct header;
+	struct __user_cap_data_struct cap;
+	setgroups(ARRAY_SIZE(groups), groups);
+	prctl(PR_SET_KEEPCAPS, 1, 0, 0, 0);
+	setgid(AID_WIFI);
+	setuid(AID_WIFI);
+	header.version = _LINUX_CAPABILITY_VERSION;
+	header.pid = 0;
+	cap.effective = cap.permitted =
+		(1 << CAP_NET_ADMIN) | (1 << CAP_NET_RAW);
+	cap.inheritable = 0;
+	capset(&header, &cap);
+	return 0;
+#ifdef WPA_TRACE
+	struct os_alloc_trace *a;
+	unsigned long total = 0;
+	dl_list_for_each(a, &alloc_list, struct os_alloc_trace, list) {
+		total += a->len;
+		if (a->magic != ALLOC_MAGIC) {
+			wpa_printf(MSG_INFO, "MEMLEAK[%p]: invalid magic 0x%x "
+				   "len %lu",
+				   a, a->magic, (unsigned long) a->len);
+			continue;
+		wpa_printf(MSG_INFO, "MEMLEAK[%p]: len %lu",
+			   a, (unsigned long) a->len);
+		wpa_trace_dump("memleak", a);
+	if (total)
+		wpa_printf(MSG_INFO, "MEMLEAK: total %lu bytes",
+			   (unsigned long) total);
+	return setenv(name, value, overwrite);
+#if defined(__FreeBSD__) || defined(__NetBSD__) || defined(__APPLE__) || \
+    defined(__OpenBSD__)
+	unsetenv(name);
+	return 0;
+#else
+	return unsetenv(name);
+#endif
+	FILE *f;
+	char *buf;
+	long pos;
+	f = fopen(name, "rb");
+	if (f == NULL)
+		return NULL;
+	if (fseek(f, 0, SEEK_END) < 0 || (pos = ftell(f)) < 0) {
+		fclose(f);
+		return NULL;
+	*len = pos;
+	if (fseek(f, 0, SEEK_SET) < 0) {
+		fclose(f);
+		return NULL;
+	buf = os_malloc(*len);
+	if (buf == NULL) {
+		fclose(f);
+		return NULL;
+	if (fread(buf, 1, *len, f) != *len) {
+		fclose(f);
+		os_free(buf);
+		return NULL;
+	fclose(f);
+	return buf;
+	FILE *f = fopen(fname, "rb");
+	if (f == NULL)
+		return 0;
+	fclose(f);
+	return 1;
+	if (!fflush(stream)) {
+#ifdef __linux__
+		return fdatasync(fileno(stream));
+#else /* !__linux__ */
+#ifdef F_FULLFSYNC
+		/* OS X does not implement fdatasync(). */
+		return fcntl(fileno(stream), F_FULLFSYNC);
+#else /* F_FULLFSYNC */
+		return fsync(fileno(stream));
+#endif /* F_FULLFSYNC */
+#endif /* __linux__ */
+	return -1;
+#ifndef WPA_TRACE
+	return calloc(1, size);
+	const char *s = src;
+	size_t left = siz;
+	if (left) {
+		/* Copy string up to the maximum size of the dest buffer */
+		while (--left != 0) {
+			if ((*dest++ = *s++) == '\0')
+				break;
+	if (left == 0) {
+		/* Not enough room for the string; force NUL-termination */
+		if (siz != 0)
+			*dest = '\0';
+		while (*s++)
+			; /* determine total src string length */
+	return s - src - 1;
+	const u8 *aa = a;
+	const u8 *bb = b;
+	size_t i;
+	u8 res;
+	for (res = 0, i = 0; i < len; i++)
+		res |= aa[i] ^ bb[i];
+	return res;
+#ifdef WPA_TRACE
+char wpa_trace_fail_func[256] = { 0 };
+unsigned int wpa_trace_fail_after;
+static int testing_fail_alloc(void)
+	const char *func[WPA_TRACE_LEN];
+	size_t i, res, len;
+	char *pos, *next;
+	int match;
+	if (!wpa_trace_fail_after)
+		return 0;
+	res = wpa_trace_calling_func(func, WPA_TRACE_LEN);
+	i = 0;
+	if (i < res && os_strcmp(func[i], __func__) == 0)
+		i++;
+	if (i < res && os_strcmp(func[i], "os_malloc") == 0)
+		i++;
+	if (i < res && os_strcmp(func[i], "os_zalloc") == 0)
+		i++;
+	if (i < res && os_strcmp(func[i], "os_calloc") == 0)
+		i++;
+	if (i < res && os_strcmp(func[i], "os_realloc") == 0)
+		i++;
+	if (i < res && os_strcmp(func[i], "os_realloc_array") == 0)
+		i++;
+	if (i < res && os_strcmp(func[i], "os_strdup") == 0)
+		i++;
+	pos = wpa_trace_fail_func;
+	match = 0;
+	while (i < res) {
+		int allow_skip = 1;
+		int maybe = 0;
+		if (*pos == '=') {
+			allow_skip = 0;
+			pos++;
+		} else if (*pos == '?') {
+			maybe = 1;
+			pos++;
+		next = os_strchr(pos, ';');
+		if (next)
+			len = next - pos;
+		else
+			len = os_strlen(pos);
+		if (os_memcmp(pos, func[i], len) != 0) {
+			if (maybe && next) {
+				pos = next + 1;
+				continue;
+			if (allow_skip) {
+				i++;
+				continue;
+			return 0;
+		if (!next) {
+			match = 1;
+			break;
+		pos = next + 1;
+		i++;
+	if (!match)
+		return 0;
+	wpa_trace_fail_after--;
+	if (wpa_trace_fail_after == 0) {
+		wpa_printf(MSG_INFO, "TESTING: fail allocation at %s",
+			   wpa_trace_fail_func);
+		for (i = 0; i < res; i++)
+			wpa_printf(MSG_INFO, "backtrace[%d] = %s",
+				   (int) i, func[i]);
+		return 1;
+	return 0;
+char wpa_trace_test_fail_func[256] = { 0 };
+unsigned int wpa_trace_test_fail_after;
+	char *pos, *next;
+	int match;
+	if (!wpa_trace_test_fail_after)
+		return 0;
+	i = 0;
+		i++;
+	pos = wpa_trace_test_fail_func;
+	match = 0;
+	while (i < res) {
+		int maybe = 0;
+			allow_skip = 0;
+			pos++;
+			maybe = 1;
+			pos++;
+		if (next)
+			len = next - pos;
+		else
+				pos = next + 1;
+				continue;
+			if (allow_skip) {
+				i++;
+				continue;
+			return 0;
+		if (!next) {
+			match = 1;
+			break;
+		pos = next + 1;
+		i++;
+	if (!match)
+		return 0;
+	wpa_trace_test_fail_after--;
+	if (wpa_trace_test_fail_after == 0) {
+		wpa_printf(MSG_INFO, "TESTING: fail at %s",
+			   wpa_trace_test_fail_func);
+		return 1;
+	return 0;
+#else
+static inline int testing_fail_alloc(void)
+	return 0;
+#endif
+	if (testing_fail_alloc())
+		return NULL;
+	a = malloc(sizeof(*a) + size);
+	if (a == NULL)
+		return NULL;
+	a->magic = ALLOC_MAGIC;
+	dl_list_add(&alloc_list, &a->list);
+	a->len = size;
+	wpa_trace_record(a);
+	return a + 1;
+	size_t copy_len;
+	void *n;
+	if (ptr == NULL)
+		return os_malloc(size);
+	a = (struct os_alloc_trace *) ptr - 1;
+		wpa_printf(MSG_INFO, "REALLOC[%p]: invalid magic 0x%x%s",
+			   a, a->magic,
+			   a->magic == FREED_MAGIC ? " (already freed)" : "");
+		wpa_trace_show("Invalid os_realloc() call");
+		abort();
+	n = os_malloc(size);
+	if (n == NULL)
+		return NULL;
+	copy_len = a->len;
+	if (copy_len > size)
+		copy_len = size;
+	os_memcpy(n, a + 1, copy_len);
+	os_free(ptr);
+	return n;
+	if (ptr == NULL)
+		return;
+		wpa_printf(MSG_INFO, "FREE[%p]: invalid magic 0x%x%s",
+			   a, a->magic,
+		wpa_trace_show("Invalid os_free() call");
+		abort();
+	dl_list_del(&a->list);
+	a->magic = FREED_MAGIC;
+	wpa_trace_check_ref(ptr);
+	free(a);
+	void *ptr = os_malloc(size);
+	if (ptr)
+		os_memset(ptr, 0, size);
+	return ptr;
+	size_t len;
+	char *d;
+	len = os_strlen(s);
+	d = os_malloc(len + 1);
+	if (d == NULL)
+		return NULL;
+	os_memcpy(d, s, len);
+	d[len] = '\0';
+	return d;
+#endif /* WPA_TRACE */
+	pid_t pid;
+	int pid_status;
+	pid = fork();
+	if (pid < 0) {
+		perror("fork");
+		return -1;
+	if (pid == 0) {
+		/* run the external command in the child process */
+		const int MAX_ARG = 30;
+		char *_program, *_arg, *pos;
+		char *argv[MAX_ARG + 1];
+		int i;
+		_program = os_strdup(program);
+		_arg = os_strdup(arg);
+		argv[0] = _program;
+		i = 1;
+		pos = _arg;
+		while (i < MAX_ARG && pos && *pos) {
+			while (*pos == ' ')
+				pos++;
+			if (*pos == '\0')
+				break;
+			argv[i++] = pos;
+			pos = os_strchr(pos, ' ');
+			if (pos)
+				*pos++ = '\0';
+		argv[i] = NULL;
+		execv(program, argv);
+		perror("execv");
+		os_free(_program);
+		os_free(_arg);
+		exit(0);
+		return -1;
+	if (wait_completion) {
+		/* wait for the child process to complete in the parent */
+		waitpid(pid, &pid_status, 0);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/utils/pcsc_funcs.h b/freebsd/contrib/wpa/src/utils/pcsc_funcs.h
index 00000000000..eacd2a2d70f
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/pcsc_funcs.h
@@ -0,0 +1,42 @@
+ * WPA Supplicant / PC/SC smartcard interface for USIM, GSM SIM
+ * Copyright (c) 2004-2006, 2012, Jouni Malinen <j at w1.fi>
+#ifndef PCSC_FUNCS_H
+#define PCSC_FUNCS_H
+#ifdef PCSC_FUNCS
+struct scard_data * scard_init(const char *reader);
+void scard_deinit(struct scard_data *scard);
+int scard_set_pin(struct scard_data *scard, const char *pin);
+int scard_get_imsi(struct scard_data *scard, char *imsi, size_t *len);
+int scard_get_mnc_len(struct scard_data *scard);
+int scard_gsm_auth(struct scard_data *scard, const unsigned char *_rand,
+		   unsigned char *sres, unsigned char *kc);
+int scard_umts_auth(struct scard_data *scard, const unsigned char *_rand,
+		    const unsigned char *autn,
+		    unsigned char *res, size_t *res_len,
+		    unsigned char *ik, unsigned char *ck, unsigned char *auts);
+int scard_get_pin_retry_counter(struct scard_data *scard);
+int scard_supports_umts(struct scard_data *scard);
+#else /* PCSC_FUNCS */
+#define scard_init(r) NULL
+#define scard_deinit(s) do { } while (0)
+#define scard_set_pin(s, p) -1
+#define scard_get_imsi(s, i, l) -1
+#define scard_get_mnc_len(s) -1
+#define scard_gsm_auth(s, r, s2, k) -1
+#define scard_umts_auth(s, r, a, r2, rl, i, c, a2) -1
+#define scard_get_pin_retry_counter(s) -1
+#define scard_supports_umts(s) 0
+#endif /* PCSC_FUNCS */
+#endif /* PCSC_FUNCS_H */
diff --git a/freebsd/contrib/wpa/src/utils/platform.h b/freebsd/contrib/wpa/src/utils/platform.h
index 00000000000..46cfe785e18
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/platform.h
@@ -0,0 +1,21 @@
+#ifndef PLATFORM_H
+#define PLATFORM_H
+#include "includes.h"
+#include "common.h"
+#define le16_to_cpu		le_to_host16
+#define le32_to_cpu		le_to_host32
+#define get_unaligned(p)					\
+	struct packed_dummy_struct {				\
+		typeof(*(p)) __val;				\
+	} __attribute__((packed)) *__ptr = (void *) (p);	\
+	__ptr->__val;						\
+#define get_unaligned_le16(p)	le16_to_cpu(get_unaligned((uint16_t *)(p)))
+#define get_unaligned_le32(p)	le32_to_cpu(get_unaligned((uint32_t *)(p)))
+#endif /* PLATFORM_H */
diff --git a/freebsd/contrib/wpa/src/utils/state_machine.h b/freebsd/contrib/wpa/src/utils/state_machine.h
index 00000000000..a5143157845
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/state_machine.h
@@ -0,0 +1,138 @@
+ * wpa_supplicant/hostapd - State machine definitions
+ * Copyright (c) 2002-2005, Jouni Malinen <j at w1.fi>
+ * This file includes a set of pre-processor macros that can be used to
+ * implement a state machine. In addition to including this header file, each
+ * file implementing a state machine must define STATE_MACHINE_DATA to be the
+ * data structure including state variables (enum machine_state,
+ * Boolean changed), and STATE_MACHINE_DEBUG_PREFIX to be a string that is used
+ * as a prefix for all debug messages. If SM_ENTRY_MA macro is used to define
+ * a group of state machines with shared data structure, STATE_MACHINE_ADDR
+ * needs to be defined to point to the MAC address used in debug output.
+ * SM_ENTRY_M macro can be used to define similar group of state machines
+ * without this additional debug info.
+#ifndef STATE_MACHINE_H
+#define STATE_MACHINE_H
+ * SM_STATE - Declaration of a state machine function
+ * @machine: State machine name
+ * @state: State machine state
+ * This macro is used to declare a state machine function. It is used in place
+ * of a C function definition to declare functions to be run when the state is
+ * entered by calling SM_ENTER or SM_ENTER_GLOBAL.
+#define SM_STATE(machine, state) \
+static void sm_ ## machine ## _ ## state ## _Enter(STATE_MACHINE_DATA *sm, \
+	int global)
+ * SM_ENTRY - State machine function entry point
+ * This macro is used inside each state machine function declared with
+ * SM_STATE. SM_ENTRY should be in the beginning of the function body, but
+ * after declaration of possible local variables. This macro prints debug
+ * information about state transition and update the state machine state.
+#define SM_ENTRY(machine, state) \
+if (!global || sm->machine ## _state != machine ## _ ## state) { \
+	sm->changed = TRUE; \
+	wpa_printf(MSG_DEBUG, STATE_MACHINE_DEBUG_PREFIX ": " #machine \
+		   " entering state " #state); \
+sm->machine ## _state = machine ## _ ## state;
+ * SM_ENTRY_M - State machine function entry point for state machine group
+ * @_state: State machine state
+ * @data: State variable prefix (full variable: prefix_state)
+ * This macro is like SM_ENTRY, but for state machine groups that use a shared
+ * data structure for more than one state machine. Both machine and prefix
+ * parameters are set to "sub-state machine" name. prefix is used to allow more
+ * than one state variable to be stored in the same data structure.
+#define SM_ENTRY_M(machine, _state, data) \
+if (!global || sm->data ## _ ## state != machine ## _ ## _state) { \
+	wpa_printf(MSG_DEBUG, STATE_MACHINE_DEBUG_PREFIX ": " \
+		   #machine " entering state " #_state); \
+sm->data ## _ ## state = machine ## _ ## _state;
+ * SM_ENTRY_MA - State machine function entry point for state machine group
+ * This macro is like SM_ENTRY_M, but a MAC address is included in debug
+ * output. STATE_MACHINE_ADDR has to be defined to point to the MAC address to
+ * be included in debug.
+#define SM_ENTRY_MA(machine, _state, data) \
+	wpa_printf(MSG_DEBUG, STATE_MACHINE_DEBUG_PREFIX ": " MACSTR " " \
+		   #machine " entering state " #_state, \
+		   MAC2STR(STATE_MACHINE_ADDR)); \
+ * SM_ENTER - Enter a new state machine state
+ * This macro expands to a function call to a state machine function defined
+ * with SM_STATE macro. SM_ENTER is used in a state machine step function to
+ * move the state machine to a new state.
+#define SM_ENTER(machine, state) \
+sm_ ## machine ## _ ## state ## _Enter(sm, 0)
+ * SM_ENTER_GLOBAL - Enter a new state machine state based on global rule
+ * This macro is like SM_ENTER, but this is used when entering a new state
+ * based on a global (not specific to any particular state) rule. A separate
+ * macro is used to avoid unwanted debug message floods when the same global
+ * rule is forcing a state machine to remain in on state.
+#define SM_ENTER_GLOBAL(machine, state) \
+sm_ ## machine ## _ ## state ## _Enter(sm, 1)
+ * SM_STEP - Declaration of a state machine step function
+ * This macro is used to declare a state machine step function. It is used in
+ * place of a C function definition to declare a function that is used to move
+ * state machine to a new state based on state variables. This function uses
+ * SM_ENTER and SM_ENTER_GLOBAL macros to enter new state.
+#define SM_STEP(machine) \
+static void sm_ ## machine ## _Step(STATE_MACHINE_DATA *sm)
+ * SM_STEP_RUN - Call the state machine step function
+ * This macro expands to a function call to a state machine step function
+ * defined with SM_STEP macro.
+#define SM_STEP_RUN(machine) sm_ ## machine ## _Step(sm)
+#endif /* STATE_MACHINE_H */
diff --git a/freebsd/contrib/wpa/src/utils/trace.h b/freebsd/contrib/wpa/src/utils/trace.h
index 00000000000..43ed86c1997
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/trace.h
@@ -0,0 +1,69 @@
+ * Backtrace debugging
+#ifndef TRACE_H
+#define TRACE_H
+#define WPA_TRACE_LEN 16
+#ifdef WPA_TRACE
+#include <execinfo.h>
+#include "list.h"
+#define WPA_TRACE_INFO void *btrace[WPA_TRACE_LEN]; int btrace_num;
+struct wpa_trace_ref {
+	struct dl_list list;
+	const void *addr;
+	WPA_TRACE_INFO
+#define WPA_TRACE_REF(name) struct wpa_trace_ref wpa_trace_ref_##name
+#define wpa_trace_dump(title, ptr) \
+	wpa_trace_dump_func((title), (ptr)->btrace, (ptr)->btrace_num)
+void wpa_trace_dump_func(const char *title, void **btrace, int btrace_num);
+#define wpa_trace_record(ptr) \
+	(ptr)->btrace_num = backtrace((ptr)->btrace, WPA_TRACE_LEN)
+void wpa_trace_show(const char *title);
+#define wpa_trace_add_ref(ptr, name, addr) \
+	wpa_trace_add_ref_func(&(ptr)->wpa_trace_ref_##name, (addr))
+void wpa_trace_add_ref_func(struct wpa_trace_ref *ref, const void *addr);
+#define wpa_trace_remove_ref(ptr, name, addr)	\
+	do { \
+		if ((addr)) \
+			dl_list_del(&(ptr)->wpa_trace_ref_##name.list); \
+	} while (0)
+void wpa_trace_check_ref(const void *addr);
+size_t wpa_trace_calling_func(const char *buf[], size_t len);
+#else /* WPA_TRACE */
+#define WPA_TRACE_REF(n)
+#define wpa_trace_dump(title, ptr) do { } while (0)
+#define wpa_trace_record(ptr) do { } while (0)
+#define wpa_trace_show(title) do { } while (0)
+#define wpa_trace_add_ref(ptr, name, addr) do { } while (0)
+#define wpa_trace_remove_ref(ptr, name, addr) do { } while (0)
+#define wpa_trace_check_ref(addr) do { } while (0)
+#ifdef WPA_TRACE_BFD
+void wpa_trace_dump_funcname(const char *title, void *pc);
+#else /* WPA_TRACE_BFD */
+#define wpa_trace_dump_funcname(title, pc) do { } while (0)
+#endif /* WPA_TRACE_BFD */
+#endif /* TRACE_H */
diff --git a/freebsd/contrib/wpa/src/utils/uuid.c b/freebsd/contrib/wpa/src/utils/uuid.c
index 00000000000..a1dedf6e329
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/uuid.c
@@ -0,0 +1,73 @@
+#include <machine/rtems-bsd-user-space.h>
+ * Universally Unique IDentifier (UUID)
+ * Copyright (c) 2008, Jouni Malinen <j at w1.fi>
+#include "uuid.h"
+int uuid_str2bin(const char *str, u8 *bin)
+	const char *pos;
+	u8 *opos;
+	pos = str;
+	opos = bin;
+	if (hexstr2bin(pos, opos, 4))
+		return -1;
+	pos += 8;
+	opos += 4;
+	if (*pos++ != '-' || hexstr2bin(pos, opos, 2))
+		return -1;
+	pos += 4;
+	opos += 2;
+		return -1;
+	pos += 4;
+	opos += 2;
+		return -1;
+	pos += 4;
+	opos += 2;
+	if (*pos++ != '-' || hexstr2bin(pos, opos, 6))
+		return -1;
+	return 0;
+int uuid_bin2str(const u8 *bin, char *str, size_t max_len)
+	int len;
+	len = os_snprintf(str, max_len, "%02x%02x%02x%02x-%02x%02x-%02x%02x-"
+			  "%02x%02x-%02x%02x%02x%02x%02x%02x",
+			  bin[0], bin[1], bin[2], bin[3],
+			  bin[4], bin[5], bin[6], bin[7],
+			  bin[8], bin[9], bin[10], bin[11],
+			  bin[12], bin[13], bin[14], bin[15]);
+	if (os_snprintf_error(max_len, len))
+		return -1;
+	return 0;
+int is_nil_uuid(const u8 *uuid)
+	int i;
+	for (i = 0; i < UUID_LEN; i++)
+		if (uuid[i])
+			return 0;
+	return 1;
diff --git a/freebsd/contrib/wpa/src/utils/uuid.h b/freebsd/contrib/wpa/src/utils/uuid.h
index 00000000000..5e860cbc593
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/uuid.h
@@ -0,0 +1,18 @@
+#ifndef UUID_H
+#define UUID_H
+#define UUID_LEN 16
+int uuid_str2bin(const char *str, u8 *bin);
+int uuid_bin2str(const u8 *bin, char *str, size_t max_len);
+int is_nil_uuid(const u8 *uuid);
+#endif /* UUID_H */
diff --git a/freebsd/contrib/wpa/src/utils/wpa_debug.c b/freebsd/contrib/wpa/src/utils/wpa_debug.c
index 00000000000..1b725ad53fe
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/wpa_debug.c
@@ -0,0 +1,862 @@
+ * wpa_supplicant/hostapd / Debug prints
+ * Copyright (c) 2002-2013, Jouni Malinen <j at w1.fi>
+#ifdef CONFIG_DEBUG_SYSLOG
+#include <syslog.h>
+static int wpa_debug_syslog = 0;
+#endif /* CONFIG_DEBUG_SYSLOG */
+#ifdef CONFIG_DEBUG_LINUX_TRACING
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <stdio.h>
+static FILE *wpa_debug_tracing_file = NULL;
+#define WPAS_TRACE_PFX "wpas <%d>: "
+#endif /* CONFIG_DEBUG_LINUX_TRACING */
+int wpa_debug_level = MSG_INFO;
+int wpa_debug_show_keys = 0;
+int wpa_debug_timestamp = 0;
+#ifdef CONFIG_ANDROID_LOG
+#include <android/log.h>
+#ifndef ANDROID_LOG_NAME
+#define ANDROID_LOG_NAME	"wpa_supplicant"
+#endif /* ANDROID_LOG_NAME */
+static int wpa_to_android_level(int level)
+	if (level == MSG_ERROR)
+		return ANDROID_LOG_ERROR;
+	if (level == MSG_WARNING)
+		return ANDROID_LOG_WARN;
+	if (level == MSG_INFO)
+		return ANDROID_LOG_INFO;
+	return ANDROID_LOG_DEBUG;
+#endif /* CONFIG_ANDROID_LOG */
+#ifndef CONFIG_NO_STDOUT_DEBUG
+#ifdef CONFIG_DEBUG_FILE
+static FILE *out_file = NULL;
+#endif /* CONFIG_DEBUG_FILE */
+void wpa_debug_print_timestamp(void)
+#ifndef CONFIG_ANDROID_LOG
+	struct os_time tv;
+	if (!wpa_debug_timestamp)
+		return;
+	os_get_time(&tv);
+	if (out_file) {
+		fprintf(out_file, "%ld.%06u: ", (long) tv.sec,
+			(unsigned int) tv.usec);
+	} else
+	printf("%ld.%06u: ", (long) tv.sec, (unsigned int) tv.usec);
+#ifndef LOG_HOSTAPD
+#define LOG_HOSTAPD LOG_DAEMON
+#endif /* LOG_HOSTAPD */
+void wpa_debug_open_syslog(void)
+	openlog("wpa_supplicant", LOG_PID | LOG_NDELAY, LOG_HOSTAPD);
+	wpa_debug_syslog++;
+void wpa_debug_close_syslog(void)
+	if (wpa_debug_syslog)
+		closelog();
+static int syslog_priority(int level)
+	switch (level) {
+	case MSG_MSGDUMP:
+	case MSG_DEBUG:
+		return LOG_DEBUG;
+	case MSG_INFO:
+		return LOG_NOTICE;
+	case MSG_WARNING:
+		return LOG_WARNING;
+	case MSG_ERROR:
+		return LOG_ERR;
+	return LOG_INFO;
+int wpa_debug_open_linux_tracing(void)
+	int mounts, trace_fd;
+	char buf[4096] = {};
+	ssize_t buflen;
+	char *line, *tmp1, *path = NULL;
+	mounts = open("/proc/mounts", O_RDONLY);
+	if (mounts < 0) {
+		printf("no /proc/mounts\n");
+		return -1;
+	buflen = read(mounts, buf, sizeof(buf) - 1);
+	close(mounts);
+	if (buflen < 0) {
+		printf("failed to read /proc/mounts\n");
+		return -1;
+	line = strtok_r(buf, "\n", &tmp1);
+	while (line) {
+		char *tmp2, *tmp_path, *fstype;
+		/* "<dev> <mountpoint> <fs type> ..." */
+		strtok_r(line, " ", &tmp2);
+		tmp_path = strtok_r(NULL, " ", &tmp2);
+		fstype = strtok_r(NULL, " ", &tmp2);
+		if (strcmp(fstype, "debugfs") == 0) {
+			path = tmp_path;
+			break;
+		line = strtok_r(NULL, "\n", &tmp1);
+	if (path == NULL) {
+		printf("debugfs mountpoint not found\n");
+		return -1;
+	snprintf(buf, sizeof(buf) - 1, "%s/tracing/trace_marker", path);
+	trace_fd = open(buf, O_WRONLY);
+	if (trace_fd < 0) {
+		printf("failed to open trace_marker file\n");
+		return -1;
+	wpa_debug_tracing_file = fdopen(trace_fd, "w");
+	if (wpa_debug_tracing_file == NULL) {
+		close(trace_fd);
+		printf("failed to fdopen()\n");
+		return -1;
+	return 0;
+void wpa_debug_close_linux_tracing(void)
+		return;
+	fclose(wpa_debug_tracing_file);
+	wpa_debug_tracing_file = NULL;
+ * wpa_printf - conditional printf
+ * @level: priority level (MSG_*) of the message
+ * @fmt: printf format string, followed by optional arguments
+ * This function is used to print conditional debugging and error messages. The
+ * output may be directed to stdout, stderr, and/or syslog based on
+ * configuration.
+ * Note: New line '\n' is added to the end of the text when printing to stdout.
+void wpa_printf(int level, const char *fmt, ...)
+	va_list ap;
+	va_start(ap, fmt);
+	if (level >= wpa_debug_level) {
+		__android_log_vprint(wpa_to_android_level(level),
+				     ANDROID_LOG_NAME, fmt, ap);
+#else /* CONFIG_ANDROID_LOG */
+		if (wpa_debug_syslog) {
+			vsyslog(syslog_priority(level), fmt, ap);
+		} else {
+		wpa_debug_print_timestamp();
+		if (out_file) {
+			vfprintf(out_file, fmt, ap);
+			fprintf(out_file, "\n");
+		} else {
+		vprintf(fmt, ap);
+		printf("\n");
+	va_end(ap);
+	if (wpa_debug_tracing_file != NULL) {
+		fprintf(wpa_debug_tracing_file, WPAS_TRACE_PFX, level);
+		vfprintf(wpa_debug_tracing_file, fmt, ap);
+		fprintf(wpa_debug_tracing_file, "\n");
+		fflush(wpa_debug_tracing_file);
+		va_end(ap);
+static void _wpa_hexdump(int level, const char *title, const u8 *buf,
+			 size_t len, int show)
+	size_t i;
+			WPAS_TRACE_PFX "%s - hexdump(len=%lu):",
+			level, title, (unsigned long) len);
+			fprintf(wpa_debug_tracing_file, " [NULL]\n");
+		} else if (!show) {
+			fprintf(wpa_debug_tracing_file, " [REMOVED]\n");
+		} else {
+			for (i = 0; i < len; i++)
+					" %02x", buf[i]);
+	if (level < wpa_debug_level)
+		return;
+		const char *display;
+		char *strbuf = NULL;
+		size_t slen = len;
+			display = " [NULL]";
+		} else if (len == 0) {
+			display = "";
+		} else if (show && len) {
+			/* Limit debug message length for Android log */
+			if (slen > 32)
+				slen = 32;
+			strbuf = os_malloc(1 + 3 * slen);
+			if (strbuf == NULL) {
+				wpa_printf(MSG_ERROR, "wpa_hexdump: Failed to "
+					   "allocate message buffer");
+				return;
+			for (i = 0; i < slen; i++)
+				os_snprintf(&strbuf[i * 3], 4, " %02x",
+					    buf[i]);
+			display = strbuf;
+		} else {
+			display = " [REMOVED]";
+		__android_log_print(wpa_to_android_level(level),
+				    ANDROID_LOG_NAME,
+				    "%s - hexdump(len=%lu):%s%s",
+				    title, (long unsigned int) len, display,
+				    len > slen ? " ..." : "");
+		bin_clear_free(strbuf, 1 + 3 * slen);
+		return;
+			display = "";
+			strbuf = os_malloc(1 + 3 * len);
+				return;
+					    buf[i]);
+			display = strbuf;
+		} else {
+		syslog(syslog_priority(level), "%s - hexdump(len=%lu):%s",
+		       title, (unsigned long) len, display);
+		bin_clear_free(strbuf, 1 + 3 * len);
+		return;
+	if (out_file) {
+		fprintf(out_file, "%s - hexdump(len=%lu):",
+			title, (unsigned long) len);
+			fprintf(out_file, " [NULL]");
+		} else if (show) {
+				fprintf(out_file, " %02x", buf[i]);
+		} else {
+			fprintf(out_file, " [REMOVED]");
+	} else {
+	printf("%s - hexdump(len=%lu):", title, (unsigned long) len);
+		printf(" [NULL]");
+			printf(" %02x", buf[i]);
+	} else {
+		printf(" [REMOVED]");
+	printf("\n");
+void wpa_hexdump(int level, const char *title, const void *buf, size_t len)
+	_wpa_hexdump(level, title, buf, len, 1);
+void wpa_hexdump_key(int level, const char *title, const void *buf, size_t len)
+	_wpa_hexdump(level, title, buf, len, wpa_debug_show_keys);
+static void _wpa_hexdump_ascii(int level, const char *title, const void *buf,
+	size_t i, llen;
+	const u8 *pos = buf;
+	const size_t line_len = 16;
+			WPAS_TRACE_PFX "%s - hexdump_ascii(len=%lu):",
+		} else {
+			/* can do ascii processing in userspace */
+					" %02x", pos[i]);
+		return;
+	_wpa_hexdump(level, title, buf, len, show);
+	if (out_file) {
+		if (!show) {
+			fprintf(out_file,
+				"%s - hexdump_ascii(len=%lu): [REMOVED]\n",
+			return;
+			fprintf(out_file,
+				"%s - hexdump_ascii(len=%lu): [NULL]\n",
+			return;
+		fprintf(out_file, "%s - hexdump_ascii(len=%lu):\n",
+		while (len) {
+			llen = len > line_len ? line_len : len;
+			fprintf(out_file, "    ");
+			for (i = 0; i < llen; i++)
+				fprintf(out_file, " %02x", pos[i]);
+			for (i = llen; i < line_len; i++)
+			for (i = 0; i < llen; i++) {
+				if (isprint(pos[i]))
+					fprintf(out_file, "%c", pos[i]);
+				else
+					fprintf(out_file, "_");
+			pos += llen;
+			len -= llen;
+	} else {
+	if (!show) {
+		printf("%s - hexdump_ascii(len=%lu): [REMOVED]\n",
+		return;
+		printf("%s - hexdump_ascii(len=%lu): [NULL]\n",
+		return;
+	printf("%s - hexdump_ascii(len=%lu):\n", title, (unsigned long) len);
+	while (len) {
+		printf("    ");
+			printf(" %02x", pos[i]);
+			printf("   ");
+		printf("   ");
+				printf("%c", pos[i]);
+			else
+				printf("_");
+			printf(" ");
+		printf("\n");
+		pos += llen;
+		len -= llen;
+void wpa_hexdump_ascii(int level, const char *title, const void *buf,
+		       size_t len)
+	_wpa_hexdump_ascii(level, title, buf, len, 1);
+void wpa_hexdump_ascii_key(int level, const char *title, const void *buf,
+			   size_t len)
+	_wpa_hexdump_ascii(level, title, buf, len, wpa_debug_show_keys);
+static char *last_path = NULL;
+int wpa_debug_reopen_file(void)
+	int rv;
+	if (last_path) {
+		char *tmp = os_strdup(last_path);
+		wpa_debug_close_file();
+		rv = wpa_debug_open_file(tmp);
+		os_free(tmp);
+	} else {
+		wpa_printf(MSG_ERROR, "Last-path was not set, cannot "
+			   "re-open log file.");
+		rv = -1;
+	return rv;
+#else /* CONFIG_DEBUG_FILE */
+	return 0;
+int wpa_debug_open_file(const char *path)
+	if (!path)
+		return 0;
+	if (last_path == NULL || os_strcmp(last_path, path) != 0) {
+		/* Save our path to enable re-open */
+		os_free(last_path);
+		last_path = os_strdup(path);
+	out_file = fopen(path, "a");
+	if (out_file == NULL) {
+		wpa_printf(MSG_ERROR, "wpa_debug_open_file: Failed to open "
+			   "output file, using standard output");
+		return -1;
+#ifndef _WIN32
+	setvbuf(out_file, NULL, _IOLBF, 0);
+#endif /* _WIN32 */
+	(void)path;
+	return 0;
+void wpa_debug_close_file(void)
+	if (!out_file)
+		return;
+	fclose(out_file);
+	out_file = NULL;
+	last_path = NULL;
+void wpa_debug_setup_stdout(void)
+#ifndef _WIN32
+	setvbuf(stdout, NULL, _IOLBF, 0);
+#endif /* CONFIG_NO_STDOUT_DEBUG */
+#ifndef CONFIG_NO_WPA_MSG
+static wpa_msg_cb_func wpa_msg_cb = NULL;
+void wpa_msg_register_cb(wpa_msg_cb_func func)
+	wpa_msg_cb = func;
+static wpa_msg_get_ifname_func wpa_msg_ifname_cb = NULL;
+void wpa_msg_register_ifname_cb(wpa_msg_get_ifname_func func)
+	wpa_msg_ifname_cb = func;
+void wpa_msg(void *ctx, int level, const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	char prefix[130];
+	buflen = vsnprintf(NULL, 0, fmt, ap) + 1;
+	va_end(ap);
+	buf = os_malloc(buflen);
+		wpa_printf(MSG_ERROR, "wpa_msg: Failed to allocate message "
+			   "buffer");
+		return;
+	prefix[0] = '\0';
+	if (wpa_msg_ifname_cb) {
+		const char *ifname = wpa_msg_ifname_cb(ctx);
+		if (ifname) {
+			int res = os_snprintf(prefix, sizeof(prefix), "%s: ",
+					      ifname);
+			if (os_snprintf_error(sizeof(prefix), res))
+				prefix[0] = '\0';
+	len = vsnprintf(buf, buflen, fmt, ap);
+	va_end(ap);
+	wpa_printf(level, "%s%s", prefix, buf);
+	if (wpa_msg_cb)
+		wpa_msg_cb(ctx, level, WPA_MSG_PER_INTERFACE, buf, len);
+	bin_clear_free(buf, buflen);
+void wpa_msg_ctrl(void *ctx, int level, const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	if (!wpa_msg_cb)
+		return;
+	va_end(ap);
+		wpa_printf(MSG_ERROR, "wpa_msg_ctrl: Failed to allocate "
+			   "message buffer");
+		return;
+	va_end(ap);
+void wpa_msg_global(void *ctx, int level, const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	va_end(ap);
+		wpa_printf(MSG_ERROR, "wpa_msg_global: Failed to allocate "
+		return;
+	va_end(ap);
+	wpa_printf(level, "%s", buf);
+	if (wpa_msg_cb)
+		wpa_msg_cb(ctx, level, WPA_MSG_GLOBAL, buf, len);
+void wpa_msg_global_ctrl(void *ctx, int level, const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	if (!wpa_msg_cb)
+		return;
+	va_end(ap);
+			   "wpa_msg_global_ctrl: Failed to allocate message buffer");
+		return;
+	va_end(ap);
+void wpa_msg_no_global(void *ctx, int level, const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	va_end(ap);
+		wpa_printf(MSG_ERROR, "wpa_msg_no_global: Failed to allocate "
+		return;
+	va_end(ap);
+	if (wpa_msg_cb)
+		wpa_msg_cb(ctx, level, WPA_MSG_NO_GLOBAL, buf, len);
+void wpa_msg_global_only(void *ctx, int level, const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	va_end(ap);
+		wpa_printf(MSG_ERROR, "%s: Failed to allocate message buffer",
+			   __func__);
+		return;
+	va_end(ap);
+	if (wpa_msg_cb)
+		wpa_msg_cb(ctx, level, WPA_MSG_ONLY_GLOBAL, buf, len);
+	os_free(buf);
+#endif /* CONFIG_NO_WPA_MSG */
+#ifndef CONFIG_NO_HOSTAPD_LOGGER
+static hostapd_logger_cb_func hostapd_logger_cb = NULL;
+void hostapd_logger_register_cb(hostapd_logger_cb_func func)
+	hostapd_logger_cb = func;
+void hostapd_logger(void *ctx, const u8 *addr, unsigned int module, int level,
+		    const char *fmt, ...)
+	va_list ap;
+	char *buf;
+	int buflen;
+	int len;
+	va_end(ap);
+		wpa_printf(MSG_ERROR, "hostapd_logger: Failed to allocate "
+		return;
+	va_end(ap);
+	if (hostapd_logger_cb)
+		hostapd_logger_cb(ctx, addr, module, level, buf, len);
+	else if (addr)
+		wpa_printf(MSG_DEBUG, "hostapd_logger: STA " MACSTR " - %s",
+			   MAC2STR(addr), buf);
+	else
+		wpa_printf(MSG_DEBUG, "hostapd_logger: %s", buf);
+#endif /* CONFIG_NO_HOSTAPD_LOGGER */
+const char * debug_level_str(int level)
+	switch (level) {
+	case MSG_EXCESSIVE:
+		return "EXCESSIVE";
+	case MSG_MSGDUMP:
+		return "MSGDUMP";
+	case MSG_DEBUG:
+		return "DEBUG";
+	case MSG_INFO:
+		return "INFO";
+	case MSG_WARNING:
+		return "WARNING";
+	case MSG_ERROR:
+		return "ERROR";
+	default:
+		return "?";
+int str_to_debug_level(const char *s)
+	if (os_strcasecmp(s, "EXCESSIVE") == 0)
+		return MSG_EXCESSIVE;
+	if (os_strcasecmp(s, "MSGDUMP") == 0)
+		return MSG_MSGDUMP;
+	if (os_strcasecmp(s, "DEBUG") == 0)
+		return MSG_DEBUG;
+	if (os_strcasecmp(s, "INFO") == 0)
+		return MSG_INFO;
+	if (os_strcasecmp(s, "WARNING") == 0)
+		return MSG_WARNING;
+	if (os_strcasecmp(s, "ERROR") == 0)
+		return MSG_ERROR;
+	return -1;
diff --git a/freebsd/contrib/wpa/src/utils/wpa_debug.h b/freebsd/contrib/wpa/src/utils/wpa_debug.h
index 00000000000..17d8f963802
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/wpa_debug.h
@@ -0,0 +1,370 @@
+#ifndef WPA_DEBUG_H
+#define WPA_DEBUG_H
+#include "wpabuf.h"
+extern int wpa_debug_level;
+extern int wpa_debug_show_keys;
+extern int wpa_debug_timestamp;
+/* Debugging function - conditional printf and hex dump. Driver wrappers can
+ * use these for debugging purposes. */
+enum {
+	MSG_EXCESSIVE, MSG_MSGDUMP, MSG_DEBUG, MSG_INFO, MSG_WARNING, MSG_ERROR
+#ifdef CONFIG_NO_STDOUT_DEBUG
+#define wpa_debug_print_timestamp() do { } while (0)
+#define wpa_printf(args...) do { } while (0)
+#define wpa_hexdump(l,t,b,le) do { } while (0)
+#define wpa_hexdump_buf(l,t,b) do { } while (0)
+#define wpa_hexdump_key(l,t,b,le) do { } while (0)
+#define wpa_hexdump_buf_key(l,t,b) do { } while (0)
+#define wpa_hexdump_ascii(l,t,b,le) do { } while (0)
+#define wpa_hexdump_ascii_key(l,t,b,le) do { } while (0)
+#define wpa_debug_open_file(p) do { } while (0)
+#define wpa_debug_close_file() do { } while (0)
+#define wpa_debug_setup_stdout() do { } while (0)
+#define wpa_dbg(args...) do { } while (0)
+static inline int wpa_debug_reopen_file(void)
+	return 0;
+#else /* CONFIG_NO_STDOUT_DEBUG */
+int wpa_debug_open_file(const char *path);
+int wpa_debug_reopen_file(void);
+void wpa_debug_close_file(void);
+void wpa_debug_setup_stdout(void);
+ * wpa_debug_printf_timestamp - Print timestamp for debug output
+ * This function prints a timestamp in seconds_from_1970.microsoconds
+ * format if debug output has been configured to include timestamps in debug
+ * messages.
+void wpa_debug_print_timestamp(void);
+ * configuration.
+PRINTF_FORMAT(2, 3);
+ * wpa_hexdump - conditional hex dump
+ * @title: title of for the message
+ * @buf: data buffer to be dumped
+ * @len: length of the buf
+ * configuration. The contents of buf is printed out has hex dump.
+void wpa_hexdump(int level, const char *title, const void *buf, size_t len);
+static inline void wpa_hexdump_buf(int level, const char *title,
+				   const struct wpabuf *buf)
+	wpa_hexdump(level, title, buf ? wpabuf_head(buf) : NULL,
+		    buf ? wpabuf_len(buf) : 0);
+ * wpa_hexdump_key - conditional hex dump, hide keys
+ * configuration. The contents of buf is printed out has hex dump. This works
+ * like wpa_hexdump(), but by default, does not include secret keys (passwords,
+ * etc.) in debug output.
+void wpa_hexdump_key(int level, const char *title, const void *buf, size_t len);
+static inline void wpa_hexdump_buf_key(int level, const char *title,
+	wpa_hexdump_key(level, title, buf ? wpabuf_head(buf) : NULL,
+ * wpa_hexdump_ascii - conditional hex dump
+ * configuration. The contents of buf is printed out has hex dump with both
+ * the hex numbers and ASCII characters (for printable range) are shown. 16
+ * bytes per line will be shown.
+		       size_t len);
+ * wpa_hexdump_ascii_key - conditional hex dump, hide keys
+ * bytes per line will be shown. This works like wpa_hexdump_ascii(), but by
+ * default, does not include secret keys (passwords, etc.) in debug output.
+			   size_t len);
+ * wpa_dbg() behaves like wpa_msg(), but it can be removed from build to reduce
+ * binary size. As such, it should be used with debugging messages that are not
+ * needed in the control interface while wpa_msg() has to be used for anything
+ * that needs to shown to control interface monitors.
+#define wpa_dbg(args...) wpa_msg(args)
+#ifdef CONFIG_NO_WPA_MSG
+#define wpa_msg(args...) do { } while (0)
+#define wpa_msg_ctrl(args...) do { } while (0)
+#define wpa_msg_global(args...) do { } while (0)
+#define wpa_msg_global_ctrl(args...) do { } while (0)
+#define wpa_msg_no_global(args...) do { } while (0)
+#define wpa_msg_global_only(args...) do { } while (0)
+#define wpa_msg_register_cb(f) do { } while (0)
+#define wpa_msg_register_ifname_cb(f) do { } while (0)
+#else /* CONFIG_NO_WPA_MSG */
+ * wpa_msg - Conditional printf for default target and ctrl_iface monitors
+ * @ctx: Pointer to context data; this is the ctx variable registered
+ *	with struct wpa_driver_ops::init()
+ * configuration. This function is like wpa_printf(), but it also sends the
+ * same message to all attached ctrl_iface monitors.
+void wpa_msg(void *ctx, int level, const char *fmt, ...) PRINTF_FORMAT(3, 4);
+ * wpa_msg_ctrl - Conditional printf for ctrl_iface monitors
+ * This function is like wpa_msg(), but it sends the output only to the
+ * attached ctrl_iface monitors. In other words, it can be used for frequent
+ * events that do not need to be sent to syslog.
+PRINTF_FORMAT(3, 4);
+ * wpa_msg_global - Global printf for ctrl_iface monitors
+ * This function is like wpa_msg(), but it sends the output as a global event,
+ * i.e., without being specific to an interface. For backwards compatibility,
+ * an old style event is also delivered on one of the interfaces (the one
+ * specified by the context data).
+ * wpa_msg_global_ctrl - Conditional global printf for ctrl_iface monitors
+ * This function is like wpa_msg_global(), but it sends the output only to the
+ * attached global ctrl_iface monitors. In other words, it can be used for
+ * frequent events that do not need to be sent to syslog.
+ * wpa_msg_no_global - Conditional printf for ctrl_iface monitors
+ * This function is like wpa_msg(), but it does not send the output as a global
+ * event.
+ * wpa_msg_global_only - Conditional printf for ctrl_iface monitors
+ * This function is like wpa_msg_global(), but it sends the output only as a
+ * global event.
+enum wpa_msg_type {
+	WPA_MSG_PER_INTERFACE,
+	WPA_MSG_GLOBAL,
+	WPA_MSG_NO_GLOBAL,
+	WPA_MSG_ONLY_GLOBAL,
+typedef void (*wpa_msg_cb_func)(void *ctx, int level, enum wpa_msg_type type,
+				const char *txt, size_t len);
+ * wpa_msg_register_cb - Register callback function for wpa_msg() messages
+ * @func: Callback function (%NULL to unregister)
+void wpa_msg_register_cb(wpa_msg_cb_func func);
+typedef const char * (*wpa_msg_get_ifname_func)(void *ctx);
+void wpa_msg_register_ifname_cb(wpa_msg_get_ifname_func func);
+#ifdef CONFIG_NO_HOSTAPD_LOGGER
+#define hostapd_logger(args...) do { } while (0)
+#define hostapd_logger_register_cb(f) do { } while (0)
+#else /* CONFIG_NO_HOSTAPD_LOGGER */
+		    const char *fmt, ...) PRINTF_FORMAT(5, 6);
+typedef void (*hostapd_logger_cb_func)(void *ctx, const u8 *addr,
+				       unsigned int module, int level,
+ * hostapd_logger_register_cb - Register callback function for hostapd_logger()
+void hostapd_logger_register_cb(hostapd_logger_cb_func func);
+#define HOSTAPD_MODULE_IEEE80211	0x00000001
+#define HOSTAPD_MODULE_IEEE8021X	0x00000002
+#define HOSTAPD_MODULE_RADIUS		0x00000004
+#define HOSTAPD_MODULE_WPA		0x00000008
+#define HOSTAPD_MODULE_DRIVER		0x00000010
+#define HOSTAPD_MODULE_IAPP		0x00000020
+#define HOSTAPD_MODULE_MLME		0x00000040
+enum hostapd_logger_level {
+	HOSTAPD_LEVEL_DEBUG_VERBOSE = 0,
+	HOSTAPD_LEVEL_DEBUG = 1,
+	HOSTAPD_LEVEL_INFO = 2,
+	HOSTAPD_LEVEL_NOTICE = 3,
+	HOSTAPD_LEVEL_WARNING = 4
+void wpa_debug_open_syslog(void);
+void wpa_debug_close_syslog(void);
+#else /* CONFIG_DEBUG_SYSLOG */
+static inline void wpa_debug_open_syslog(void)
+static inline void wpa_debug_close_syslog(void)
+int wpa_debug_open_linux_tracing(void);
+void wpa_debug_close_linux_tracing(void);
+#else /* CONFIG_DEBUG_LINUX_TRACING */
+static inline int wpa_debug_open_linux_tracing(void)
+	return 0;
+static inline void wpa_debug_close_linux_tracing(void)
+#ifdef EAPOL_TEST
+#define WPA_ASSERT(a)						       \
+	do {							       \
+		if (!(a)) {					       \
+			printf("WPA_ASSERT FAILED '" #a "' "	       \
+			       "%s %s:%d\n",			       \
+			       __FUNCTION__, __FILE__, __LINE__);      \
+			exit(1);				       \
+	} while (0)
+#else
+#define WPA_ASSERT(a) do { } while (0)
+#endif
+const char * debug_level_str(int level);
+int str_to_debug_level(const char *s);
+#endif /* WPA_DEBUG_H */
diff --git a/freebsd/contrib/wpa/src/utils/wpabuf.c b/freebsd/contrib/wpa/src/utils/wpabuf.c
new file mode 100644
index 00000000000..c6e22aebf63
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/wpabuf.c
@@ -0,0 +1,314 @@
+ * Dynamic data buffer
+ * Copyright (c) 2007-2012, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "trace.h"
+#ifdef WPA_TRACE
+#define WPABUF_MAGIC 0x51a974e3
+struct wpabuf_trace {
+} __attribute__((aligned(8)));
+static struct wpabuf_trace * wpabuf_get_trace(const struct wpabuf *buf)
+	return (struct wpabuf_trace *)
+		((const u8 *) buf - sizeof(struct wpabuf_trace));
+static void wpabuf_overflow(const struct wpabuf *buf, size_t len)
+#ifdef WPA_TRACE
+	struct wpabuf_trace *trace = wpabuf_get_trace(buf);
+	if (trace->magic != WPABUF_MAGIC) {
+		wpa_printf(MSG_ERROR, "wpabuf: invalid magic %x",
+			   trace->magic);
+	wpa_printf(MSG_ERROR, "wpabuf %p (size=%lu used=%lu) overflow len=%lu",
+		   buf, (unsigned long) buf->size, (unsigned long) buf->used,
+		   (unsigned long) len);
+	wpa_trace_show("wpabuf overflow");
+	abort();
+int wpabuf_resize(struct wpabuf **_buf, size_t add_len)
+	struct wpabuf *buf = *_buf;
+#ifdef WPA_TRACE
+	struct wpabuf_trace *trace;
+		*_buf = wpabuf_alloc(add_len);
+		return *_buf == NULL ? -1 : 0;
+#ifdef WPA_TRACE
+	trace = wpabuf_get_trace(buf);
+			   trace->magic);
+		wpa_trace_show("wpabuf_resize invalid magic");
+		abort();
+	if (buf->used + add_len > buf->size) {
+		unsigned char *nbuf;
+		if (buf->flags & WPABUF_FLAG_EXT_DATA) {
+			nbuf = os_realloc(buf->buf, buf->used + add_len);
+			if (nbuf == NULL)
+				return -1;
+			os_memset(nbuf + buf->used, 0, add_len);
+			buf->buf = nbuf;
+		} else {
+#ifdef WPA_TRACE
+			nbuf = os_realloc(trace, sizeof(struct wpabuf_trace) +
+					  sizeof(struct wpabuf) +
+					  buf->used + add_len);
+			if (nbuf == NULL)
+				return -1;
+			trace = (struct wpabuf_trace *) nbuf;
+			buf = (struct wpabuf *) (trace + 1);
+			os_memset(nbuf + sizeof(struct wpabuf_trace) +
+				  sizeof(struct wpabuf) + buf->used, 0,
+				  add_len);
+			nbuf = os_realloc(buf, sizeof(struct wpabuf) +
+			if (nbuf == NULL)
+				return -1;
+			buf = (struct wpabuf *) nbuf;
+			os_memset(nbuf + sizeof(struct wpabuf) + buf->used, 0,
+				  add_len);
+			buf->buf = (u8 *) (buf + 1);
+			*_buf = buf;
+		buf->size = buf->used + add_len;
+	return 0;
+ * wpabuf_alloc - Allocate a wpabuf of the given size
+ * @len: Length for the allocated buffer
+ * Returns: Buffer to the allocated wpabuf or %NULL on failure
+struct wpabuf * wpabuf_alloc(size_t len)
+#ifdef WPA_TRACE
+	struct wpabuf_trace *trace = os_zalloc(sizeof(struct wpabuf_trace) +
+					       sizeof(struct wpabuf) + len);
+	struct wpabuf *buf;
+	if (trace == NULL)
+		return NULL;
+	trace->magic = WPABUF_MAGIC;
+	struct wpabuf *buf = os_zalloc(sizeof(struct wpabuf) + len);
+	if (buf == NULL)
+		return NULL;
+	buf->size = len;
+	return buf;
+struct wpabuf * wpabuf_alloc_ext_data(u8 *data, size_t len)
+#ifdef WPA_TRACE
+					       sizeof(struct wpabuf));
+		return NULL;
+	struct wpabuf *buf = os_zalloc(sizeof(struct wpabuf));
+	if (buf == NULL)
+		return NULL;
+	buf->size = len;
+	buf->used = len;
+	buf->buf = data;
+	buf->flags |= WPABUF_FLAG_EXT_DATA;
+	return buf;
+struct wpabuf * wpabuf_alloc_copy(const void *data, size_t len)
+	struct wpabuf *buf = wpabuf_alloc(len);
+	if (buf)
+		wpabuf_put_data(buf, data, len);
+	return buf;
+struct wpabuf * wpabuf_dup(const struct wpabuf *src)
+	struct wpabuf *buf = wpabuf_alloc(wpabuf_len(src));
+	if (buf)
+		wpabuf_put_data(buf, wpabuf_head(src), wpabuf_len(src));
+	return buf;
+ * wpabuf_free - Free a wpabuf
+ * @buf: wpabuf buffer
+void wpabuf_free(struct wpabuf *buf)
+#ifdef WPA_TRACE
+	if (buf == NULL)
+		return;
+		wpa_printf(MSG_ERROR, "wpabuf_free: invalid magic %x",
+			   trace->magic);
+		wpa_trace_show("wpabuf_free magic mismatch");
+		abort();
+		os_free(buf->buf);
+	os_free(trace);
+	if (buf == NULL)
+		return;
+	os_free(buf);
+void wpabuf_clear_free(struct wpabuf *buf)
+	if (buf) {
+		os_memset(wpabuf_mhead(buf), 0, wpabuf_len(buf));
+		wpabuf_free(buf);
+void * wpabuf_put(struct wpabuf *buf, size_t len)
+	void *tmp = wpabuf_mhead_u8(buf) + wpabuf_len(buf);
+	buf->used += len;
+	if (buf->used > buf->size) {
+		wpabuf_overflow(buf, len);
+	return tmp;
+ * wpabuf_concat - Concatenate two buffers into a newly allocated one
+ * Returns: wpabuf with concatenated a + b data or %NULL on failure
+ * Both buffers a and b will be freed regardless of the return value. Input
+ * buffers can be %NULL which is interpreted as an empty buffer.
+struct wpabuf * wpabuf_concat(struct wpabuf *a, struct wpabuf *b)
+	struct wpabuf *n = NULL;
+	size_t len = 0;
+	if (b == NULL)
+		return a;
+	if (a)
+		len += wpabuf_len(a);
+	if (b)
+		len += wpabuf_len(b);
+	n = wpabuf_alloc(len);
+	if (n) {
+		if (a)
+			wpabuf_put_buf(n, a);
+		if (b)
+			wpabuf_put_buf(n, b);
+	wpabuf_free(a);
+	wpabuf_free(b);
+	return n;
+ * wpabuf_zeropad - Pad buffer with 0x00 octets (prefix) to specified length
+ * @buf: Buffer to be padded
+ * @len: Length for the padded buffer
+ * Returns: wpabuf padded to len octets or %NULL on failure
+ * If buf is longer than len octets or of same size, it will be returned as-is.
+ * Otherwise a new buffer is allocated and prefixed with 0x00 octets followed
+ * by the source data. The source buffer will be freed on error, i.e., caller
+ * will only be responsible on freeing the returned buffer. If buf is %NULL,
+ * %NULL will be returned.
+struct wpabuf * wpabuf_zeropad(struct wpabuf *buf, size_t len)
+	struct wpabuf *ret;
+	size_t blen;
+	if (buf == NULL)
+		return NULL;
+	blen = wpabuf_len(buf);
+	if (blen >= len)
+		return buf;
+	ret = wpabuf_alloc(len);
+	if (ret) {
+		os_memset(wpabuf_put(ret, len - blen), 0, len - blen);
+		wpabuf_put_buf(ret, buf);
+	wpabuf_free(buf);
+	return ret;
+void wpabuf_printf(struct wpabuf *buf, char *fmt, ...)
+	va_list ap;
+	int res;
+	res = vsnprintf(tmp, buf->size - buf->used, fmt, ap);
+	va_end(ap);
+	if (res < 0 || (size_t) res >= buf->size - buf->used)
+		wpabuf_overflow(buf, res);
+	buf->used += res;
diff --git a/freebsd/contrib/wpa/src/utils/wpabuf.h b/freebsd/contrib/wpa/src/utils/wpabuf.h
index 00000000000..c3ef1bae366
--- /dev/null
+++ b/freebsd/contrib/wpa/src/utils/wpabuf.h
@@ -0,0 +1,163 @@
+#ifndef WPABUF_H
+#define WPABUF_H
+/* wpabuf::buf is a pointer to external data */
+#define WPABUF_FLAG_EXT_DATA BIT(0)
+ * Internal data structure for wpabuf. Please do not touch this directly from
+ * elsewhere. This is only defined in header file to allow inline functions
+ * from this file to access data.
+struct wpabuf {
+	size_t size; /* total size of the allocated buffer */
+	size_t used; /* length of data in the buffer */
+	u8 *buf; /* pointer to the head of the buffer */
+	unsigned int flags;
+	/* optionally followed by the allocated buffer */
+int wpabuf_resize(struct wpabuf **buf, size_t add_len);
+struct wpabuf * wpabuf_alloc(size_t len);
+struct wpabuf * wpabuf_alloc_ext_data(u8 *data, size_t len);
+struct wpabuf * wpabuf_alloc_copy(const void *data, size_t len);
+struct wpabuf * wpabuf_dup(const struct wpabuf *src);
+void wpabuf_free(struct wpabuf *buf);
+void wpabuf_clear_free(struct wpabuf *buf);
+void * wpabuf_put(struct wpabuf *buf, size_t len);
+struct wpabuf * wpabuf_concat(struct wpabuf *a, struct wpabuf *b);
+struct wpabuf * wpabuf_zeropad(struct wpabuf *buf, size_t len);
+void wpabuf_printf(struct wpabuf *buf, char *fmt, ...) PRINTF_FORMAT(2, 3);
+ * wpabuf_size - Get the currently allocated size of a wpabuf buffer
+ * Returns: Currently allocated size of the buffer
+static inline size_t wpabuf_size(const struct wpabuf *buf)
+	return buf->size;
+ * wpabuf_len - Get the current length of a wpabuf buffer data
+ * Returns: Currently used length of the buffer
+static inline size_t wpabuf_len(const struct wpabuf *buf)
+	return buf->used;
+ * wpabuf_tailroom - Get size of available tail room in the end of the buffer
+ * Returns: Tail room (in bytes) of available space in the end of the buffer
+static inline size_t wpabuf_tailroom(const struct wpabuf *buf)
+	return buf->size - buf->used;
+ * wpabuf_head - Get pointer to the head of the buffer data
+ * Returns: Pointer to the head of the buffer data
+static inline const void * wpabuf_head(const struct wpabuf *buf)
+	return buf->buf;
+static inline const u8 * wpabuf_head_u8(const struct wpabuf *buf)
+	return wpabuf_head(buf);
+ * wpabuf_mhead - Get modifiable pointer to the head of the buffer data
+static inline void * wpabuf_mhead(struct wpabuf *buf)
+	return buf->buf;
+static inline u8 * wpabuf_mhead_u8(struct wpabuf *buf)
+	return wpabuf_mhead(buf);
+static inline void wpabuf_put_u8(struct wpabuf *buf, u8 data)
+	u8 *pos = wpabuf_put(buf, 1);
+	*pos = data;
+static inline void wpabuf_put_le16(struct wpabuf *buf, u16 data)
+	u8 *pos = wpabuf_put(buf, 2);
+	WPA_PUT_LE16(pos, data);
+static inline void wpabuf_put_le32(struct wpabuf *buf, u32 data)
+	u8 *pos = wpabuf_put(buf, 4);
+	WPA_PUT_LE32(pos, data);
+static inline void wpabuf_put_be16(struct wpabuf *buf, u16 data)
+	WPA_PUT_BE16(pos, data);
+static inline void wpabuf_put_be24(struct wpabuf *buf, u32 data)
+	u8 *pos = wpabuf_put(buf, 3);
+	WPA_PUT_BE24(pos, data);
+static inline void wpabuf_put_be32(struct wpabuf *buf, u32 data)
+	WPA_PUT_BE32(pos, data);
+static inline void wpabuf_put_data(struct wpabuf *buf, const void *data,
+				   size_t len)
+	if (data)
+		os_memcpy(wpabuf_put(buf, len), data, len);
+static inline void wpabuf_put_buf(struct wpabuf *dst,
+				  const struct wpabuf *src)
+	wpabuf_put_data(dst, wpabuf_head(src), wpabuf_len(src));
+static inline void wpabuf_set(struct wpabuf *buf, const void *data, size_t len)
+	buf->buf = (u8 *) data;
+	buf->flags = WPABUF_FLAG_EXT_DATA;
+	buf->size = buf->used = len;
+static inline void wpabuf_put_str(struct wpabuf *dst, const char *str)
+	wpabuf_put_data(dst, str, os_strlen(str));
+#endif /* WPABUF_H */
diff --git a/freebsd/contrib/wpa/src/wps/http.h b/freebsd/contrib/wpa/src/wps/http.h
index 00000000000..2fee3a8f87a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/http.h
@@ -0,0 +1,29 @@
+ * HTTP for WPS
+ * Copyright (c) 2000-2003 Intel Corporation
+ * Copyright (c) 2006-2007 Sony Corporation
+ * Copyright (c) 2008-2009 Atheros Communications
+ * Copyright (c) 2009, Jouni Malinen <j at w1.fi>
+ * See wps_upnp.c for more details on licensing and code history.
+#ifndef HTTP_H
+#define HTTP_H
+enum http_reply_code {
+	HTTP_OK = 200,
+	HTTP_BAD_REQUEST = 400,
+	UPNP_INVALID_ACTION = 401,
+	UPNP_INVALID_ARGS = 402,
+	HTTP_NOT_FOUND = 404,
+	HTTP_PRECONDITION_FAILED = 412,
+	HTTP_INTERNAL_SERVER_ERROR = 500,
+	HTTP_UNIMPLEMENTED = 501,
+	UPNP_ACTION_FAILED = 501,
+	UPNP_ARG_VALUE_INVALID = 600,
+	UPNP_ARG_VALUE_OUT_OF_RANGE = 601,
+	UPNP_OUT_OF_MEMORY = 603
+#endif /* HTTP_H */
diff --git a/freebsd/contrib/wpa/src/wps/http_client.c b/freebsd/contrib/wpa/src/wps/http_client.c
index 00000000000..c4f26dc9e2c
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/http_client.c
@@ -0,0 +1,364 @@
+ * http_client - HTTP client
+#include <fcntl.h>
+#include "eloop.h"
+#include "httpread.h"
+#include "http_client.h"
+#define HTTP_CLIENT_TIMEOUT_SEC 30
+struct http_client {
+	struct sockaddr_in dst;
+	int sd;
+	struct wpabuf *req;
+	size_t req_pos;
+	size_t max_response;
+	void (*cb)(void *ctx, struct http_client *c,
+		   enum http_client_event event);
+	void *cb_ctx;
+	struct httpread *hread;
+	struct wpabuf body;
+static void http_client_timeout(void *eloop_data, void *user_ctx)
+	struct http_client *c = eloop_data;
+	wpa_printf(MSG_DEBUG, "HTTP: Timeout (c=%p)", c);
+	c->cb(c->cb_ctx, c, HTTP_CLIENT_TIMEOUT);
+static void http_client_got_response(struct httpread *handle, void *cookie,
+				     enum httpread_event e)
+	struct http_client *c = cookie;
+	wpa_printf(MSG_DEBUG, "HTTP: httpread callback: handle=%p cookie=%p "
+		   "e=%d", handle, cookie, e);
+	eloop_cancel_timeout(http_client_timeout, c, NULL);
+	switch (e) {
+	case HTTPREAD_EVENT_FILE_READY:
+		if (httpread_hdr_type_get(c->hread) == HTTPREAD_HDR_TYPE_REPLY)
+			int reply_code = httpread_reply_code_get(c->hread);
+			if (reply_code == 200 /* OK */) {
+				wpa_printf(MSG_DEBUG, "HTTP: Response OK from "
+					   "%s:%d",
+					   inet_ntoa(c->dst.sin_addr),
+					   ntohs(c->dst.sin_port));
+				c->cb(c->cb_ctx, c, HTTP_CLIENT_OK);
+			} else {
+				wpa_printf(MSG_DEBUG, "HTTP: Error %d from "
+					   "%s:%d", reply_code,
+				c->cb(c->cb_ctx, c, HTTP_CLIENT_INVALID_REPLY);
+		} else
+		break;
+	case HTTPREAD_EVENT_TIMEOUT:
+		break;
+	case HTTPREAD_EVENT_ERROR:
+		c->cb(c->cb_ctx, c, HTTP_CLIENT_FAILED);
+		break;
+static void http_client_tx_ready(int sock, void *eloop_ctx, void *sock_ctx)
+	struct http_client *c = eloop_ctx;
+	int res;
+	size_t send_len;
+	send_len = wpabuf_len(c->req) - c->req_pos;
+	wpa_printf(MSG_DEBUG, "HTTP: Send client request to %s:%d (%lu of %lu "
+		   "bytes remaining)",
+		   inet_ntoa(c->dst.sin_addr), ntohs(c->dst.sin_port),
+		   (unsigned long) wpabuf_len(c->req),
+		   (unsigned long) send_len);
+	res = send(c->sd, wpabuf_head_u8(c->req) + c->req_pos, send_len, 0);
+	if (res < 0) {
+		wpa_printf(MSG_DEBUG, "HTTP: Failed to send buffer: %s",
+			   strerror(errno));
+		eloop_unregister_sock(c->sd, EVENT_TYPE_WRITE);
+		return;
+	if ((size_t) res < send_len) {
+		wpa_printf(MSG_DEBUG, "HTTP: Sent %d of %lu bytes; %lu bytes "
+			   "remaining",
+			   res, (unsigned long) wpabuf_len(c->req),
+			   (unsigned long) send_len - res);
+		c->req_pos += res;
+		return;
+	wpa_printf(MSG_DEBUG, "HTTP: Full client request sent to %s:%d",
+		   inet_ntoa(c->dst.sin_addr), ntohs(c->dst.sin_port));
+	wpabuf_free(c->req);
+	c->req = NULL;
+	c->hread = httpread_create(c->sd, http_client_got_response, c,
+				   c->max_response, HTTP_CLIENT_TIMEOUT_SEC);
+	if (c->hread == NULL) {
+		return;
+struct http_client * http_client_addr(struct sockaddr_in *dst,
+				      struct wpabuf *req, size_t max_response,
+						 struct http_client *c,
+						 enum http_client_event event),
+				      void *cb_ctx)
+	struct http_client *c;
+	c = os_zalloc(sizeof(*c));
+	if (c == NULL)
+		return NULL;
+	c->sd = -1;
+	c->dst = *dst;
+	c->max_response = max_response;
+	c->cb = cb;
+	c->cb_ctx = cb_ctx;
+	c->sd = socket(AF_INET, SOCK_STREAM, 0);
+	if (c->sd < 0)
+		goto fail;
+	if (fcntl(c->sd, F_SETFL, O_NONBLOCK) != 0) {
+		wpa_printf(MSG_DEBUG, "HTTP: fnctl(O_NONBLOCK) failed: %s",
+			   strerror(errno));
+		goto fail;
+	if (connect(c->sd, (struct sockaddr *) dst, sizeof(*dst))) {
+		if (errno != EINPROGRESS) {
+			wpa_printf(MSG_DEBUG, "HTTP: Failed to connect: %s",
+				   strerror(errno));
+			goto fail;
+		 * Continue connecting in the background; eloop will call us
+		 * once the connection is ready (or failed).
+	if (eloop_register_sock(c->sd, EVENT_TYPE_WRITE, http_client_tx_ready,
+				c, NULL) ||
+	    eloop_register_timeout(HTTP_CLIENT_TIMEOUT_SEC, 0,
+				   http_client_timeout, c, NULL))
+		goto fail;
+	c->req = req;
+	return c;
+fail:
+	http_client_free(c);
+	return NULL;
+char * http_client_url_parse(const char *url, struct sockaddr_in *dst,
+			     char **ret_path)
+	char *u, *addr, *port, *path;
+	u = os_strdup(url);
+	if (u == NULL)
+		return NULL;
+	os_memset(dst, 0, sizeof(*dst));
+	dst->sin_family = AF_INET;
+	addr = u + 7;
+	path = os_strchr(addr, '/');
+	port = os_strchr(addr, ':');
+		path = "/";
+	} else {
+		*path = '\0'; /* temporary nul termination for address */
+		if (port > path)
+			port = NULL;
+	if (port)
+		*port++ = '\0';
+	if (inet_aton(addr, &dst->sin_addr) == 0) {
+		/* TODO: name lookup */
+		wpa_printf(MSG_DEBUG, "HTTP: Unsupported address in URL '%s' "
+			   "(addr='%s' port='%s')",
+			   url, addr, port);
+		os_free(u);
+		return NULL;
+	if (port)
+		dst->sin_port = htons(atoi(port));
+	else
+		dst->sin_port = htons(80);
+	if (*path == '\0') {
+		/* remove temporary nul termination for address */
+		*path = '/';
+	*ret_path = path;
+	return u;
+struct http_client * http_client_url(const char *url,
+				     void *cb_ctx)
+	char *u, *path;
+	struct wpabuf *req_buf = NULL;
+	if (os_strncmp(url, "http://", 7) != 0)
+		return NULL;
+	u = http_client_url_parse(url, &dst, &path);
+	if (u == NULL)
+		return NULL;
+	if (req == NULL) {
+		req_buf = wpabuf_alloc(os_strlen(url) + 1000);
+		if (req_buf == NULL) {
+			os_free(u);
+			return NULL;
+		req = req_buf;
+		wpabuf_printf(req,
+			      "GET %s HTTP/1.1\r\n"
+			      "Cache-Control: no-cache\r\n"
+			      "Pragma: no-cache\r\n"
+			      "Accept: text/xml, application/xml\r\n"
+			      "User-Agent: wpa_supplicant\r\n"
+			      "Host: %s:%d\r\n"
+			      "\r\n",
+			      path, inet_ntoa(dst.sin_addr),
+			      ntohs(dst.sin_port));
+	os_free(u);
+	c = http_client_addr(&dst, req, max_response, cb, cb_ctx);
+	if (c == NULL) {
+		wpabuf_free(req_buf);
+		return NULL;
+	return c;
+void http_client_free(struct http_client *c)
+	if (c == NULL)
+		return;
+	httpread_destroy(c->hread);
+	if (c->sd >= 0) {
+		close(c->sd);
+	os_free(c);
+struct wpabuf * http_client_get_body(struct http_client *c)
+		return NULL;
+	wpabuf_set(&c->body, httpread_data_get(c->hread),
+		   httpread_length_get(c->hread));
+	return &c->body;
+char * http_client_get_hdr_line(struct http_client *c, const char *tag)
+		return NULL;
+	return httpread_hdr_line_get(c->hread, tag);
+char * http_link_update(char *url, const char *base)
+	char *n;
+	size_t len;
+	const char *pos;
+	/* RFC 2396, Chapter 5.2 */
+	/* TODO: consider adding all cases described in RFC 2396 */
+	if (url == NULL)
+		return NULL;
+	if (os_strncmp(url, "http://", 7) == 0)
+		return url; /* absolute link */
+	if (os_strncmp(base, "http://", 7) != 0)
+		return url; /* unable to handle base URL */
+	len = os_strlen(url) + 1 + os_strlen(base) + 1;
+	n = os_malloc(len);
+	if (n == NULL)
+		return url; /* failed */
+	if (url[0] == '/') {
+		pos = os_strchr(base + 7, '/');
+		if (pos == NULL) {
+			os_snprintf(n, len, "%s%s", base, url);
+		} else {
+			os_memcpy(n, base, pos - base);
+			os_memcpy(n + (pos - base), url, os_strlen(url) + 1);
+	} else {
+		pos = os_strrchr(base + 7, '/');
+			os_snprintf(n, len, "%s/%s", base, url);
+		} else {
+			os_memcpy(n, base, pos - base + 1);
+			os_memcpy(n + (pos - base) + 1, url, os_strlen(url) +
+				  1);
+	os_free(url);
+	return n;
diff --git a/freebsd/contrib/wpa/src/wps/http_client.h b/freebsd/contrib/wpa/src/wps/http_client.h
index 00000000000..ddee2adb699
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/http_client.h
@@ -0,0 +1,40 @@
+#ifndef HTTP_CLIENT_H
+#define HTTP_CLIENT_H
+struct http_client;
+enum http_client_event {
+	HTTP_CLIENT_FAILED,
+	HTTP_CLIENT_TIMEOUT,
+	HTTP_CLIENT_OK,
+	HTTP_CLIENT_INVALID_REPLY,
+			     char **path);
+				      void *cb_ctx);
+				     void *cb_ctx);
+void http_client_free(struct http_client *c);
+struct wpabuf * http_client_get_body(struct http_client *c);
+char * http_client_get_hdr_line(struct http_client *c, const char *tag);
+char * http_link_update(char *url, const char *base);
+#endif /* HTTP_CLIENT_H */
diff --git a/freebsd/contrib/wpa/src/wps/http_server.c b/freebsd/contrib/wpa/src/wps/http_server.c
index 00000000000..edef1b2c36d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/http_server.c
@@ -0,0 +1,316 @@
+ * http_server - HTTP server
+#include <fcntl.h>
+#include "eloop.h"
+#include "http_server.h"
+#define HTTP_SERVER_TIMEOUT 30
+#define HTTP_SERVER_MAX_REQ_LEN 8000
+#define HTTP_SERVER_MAX_CONNECTIONS 10
+struct http_request {
+	struct http_request *next;
+	struct http_server *srv;
+	int fd;
+	struct sockaddr_in cli;
+struct http_server {
+	void (*cb)(void *ctx, struct http_request *req);
+	void *cb_ctx;
+	int fd;
+	int port;
+	struct http_request *requests;
+	unsigned int request_count;
+static void http_request_cb(struct httpread *handle, void *cookie,
+			    enum httpread_event en)
+	struct http_request *req = cookie;
+	struct http_server *srv = req->srv;
+	if (en == HTTPREAD_EVENT_FILE_READY) {
+		wpa_printf(MSG_DEBUG, "HTTP: Request from %s:%d received",
+			   inet_ntoa(req->cli.sin_addr),
+			   ntohs(req->cli.sin_port));
+		srv->cb(srv->cb_ctx, req);
+		return;
+	wpa_printf(MSG_DEBUG, "HTTP: Request from %s:%d could not be received "
+		   "completely", inet_ntoa(req->cli.sin_addr),
+	http_request_deinit(req);
+static struct http_request * http_request_init(struct http_server *srv, int fd,
+					       struct sockaddr_in *cli)
+	struct http_request *req;
+	if (srv->request_count >= HTTP_SERVER_MAX_CONNECTIONS) {
+		wpa_printf(MSG_DEBUG, "HTTP: Too many concurrent requests");
+		return NULL;
+	req = os_zalloc(sizeof(*req));
+	if (req == NULL)
+		return NULL;
+	req->srv = srv;
+	req->fd = fd;
+	req->cli = *cli;
+	req->hread = httpread_create(req->fd, http_request_cb, req,
+				     HTTP_SERVER_MAX_REQ_LEN,
+				     HTTP_SERVER_TIMEOUT);
+	if (req->hread == NULL) {
+		return NULL;
+	return req;
+void http_request_deinit(struct http_request *req)
+	struct http_request *r, *p;
+	if (req == NULL)
+		return;
+	srv = req->srv;
+	p = NULL;
+	r = srv->requests;
+	while (r) {
+		if (r == req) {
+			if (p)
+				p->next = r->next;
+			else
+				srv->requests = r->next;
+			srv->request_count--;
+			break;
+		p = r;
+		r = r->next;
+	httpread_destroy(req->hread);
+	close(req->fd);
+	os_free(req);
+static void http_request_free_all(struct http_request *req)
+	struct http_request *prev;
+	while (req) {
+		prev = req;
+		req = req->next;
+		http_request_deinit(prev);
+void http_request_send(struct http_request *req, struct wpabuf *resp)
+	int res;
+	wpa_printf(MSG_DEBUG, "HTTP: Send %lu byte response to %s:%d",
+		   (unsigned long) wpabuf_len(resp),
+	res = send(req->fd, wpabuf_head(resp), wpabuf_len(resp), 0);
+	if (res < 0) {
+		wpa_printf(MSG_DEBUG, "HTTP: Send failed: %s",
+			   strerror(errno));
+	} else if ((size_t) res < wpabuf_len(resp)) {
+		wpa_printf(MSG_DEBUG, "HTTP: Sent only %d of %lu bytes",
+			   res, (unsigned long) wpabuf_len(resp));
+		/* TODO: add eloop handler for sending rest of the data */
+	wpabuf_free(resp);
+void http_request_send_and_deinit(struct http_request *req,
+				  struct wpabuf *resp)
+	http_request_send(req, resp);
+enum httpread_hdr_type http_request_get_type(struct http_request *req)
+	return httpread_hdr_type_get(req->hread);
+char * http_request_get_uri(struct http_request *req)
+	return httpread_uri_get(req->hread);
+char * http_request_get_hdr(struct http_request *req)
+	return httpread_hdr_get(req->hread);
+char * http_request_get_data(struct http_request *req)
+	return httpread_data_get(req->hread);
+char * http_request_get_hdr_line(struct http_request *req, const char *tag)
+	return httpread_hdr_line_get(req->hread, tag);
+struct sockaddr_in * http_request_get_cli_addr(struct http_request *req)
+	return &req->cli;
+static void http_server_cb(int sd, void *eloop_ctx, void *sock_ctx)
+	struct sockaddr_in addr;
+	socklen_t addr_len = sizeof(addr);
+	struct http_server *srv = eloop_ctx;
+	int conn;
+	conn = accept(srv->fd, (struct sockaddr *) &addr, &addr_len);
+	if (conn < 0) {
+		wpa_printf(MSG_DEBUG, "HTTP: Failed to accept new connection: "
+			   "%s", strerror(errno));
+		return;
+	wpa_printf(MSG_DEBUG, "HTTP: Connection from %s:%d",
+		   inet_ntoa(addr.sin_addr), ntohs(addr.sin_port));
+	req = http_request_init(srv, conn, &addr);
+		close(conn);
+		return;
+	req->next = srv->requests;
+	srv->requests = req;
+	srv->request_count++;
+struct http_server * http_server_init(struct in_addr *addr, int port,
+						 struct http_request *req),
+				      void *cb_ctx)
+	struct sockaddr_in sin;
+	int on = 1;
+	srv = os_zalloc(sizeof(*srv));
+	if (srv == NULL)
+		return NULL;
+	srv->cb = cb;
+	srv->cb_ctx = cb_ctx;
+	srv->fd = socket(AF_INET, SOCK_STREAM, 0);
+	if (srv->fd < 0)
+		goto fail;
+	if (setsockopt(srv->fd, SOL_SOCKET, SO_REUSEADDR, &on, sizeof(on)) < 0)
+			   "HTTP: setsockopt(SO_REUSEADDR) failed: %s",
+			   strerror(errno));
+		/* try to continue anyway */
+	if (fcntl(srv->fd, F_SETFL, O_NONBLOCK) < 0)
+		goto fail;
+	if (port < 0)
+		srv->port = 49152;
+	else
+		srv->port = port;
+	os_memset(&sin, 0, sizeof(sin));
+	sin.sin_family = AF_INET;
+	sin.sin_addr.s_addr = addr->s_addr;
+	for (;;) {
+		sin.sin_port = htons(srv->port);
+		if (bind(srv->fd, (struct sockaddr *) &sin, sizeof(sin)) == 0)
+			break;
+		if (errno == EADDRINUSE) {
+			/* search for unused port */
+			if (++srv->port == 65535 || port >= 0)
+				goto fail;
+			continue;
+		wpa_printf(MSG_DEBUG, "HTTP: Failed to bind server port %d: "
+			   "%s", srv->port, strerror(errno));
+		goto fail;
+	if (listen(srv->fd, 10 /* max backlog */) < 0 ||
+	    fcntl(srv->fd, F_SETFL, O_NONBLOCK) < 0 ||
+	    eloop_register_sock(srv->fd, EVENT_TYPE_READ, http_server_cb,
+				srv, NULL))
+		goto fail;
+	wpa_printf(MSG_DEBUG, "HTTP: Started server on %s:%d",
+		   inet_ntoa(*addr), srv->port);
+	return srv;
+fail:
+	http_server_deinit(srv);
+	return NULL;
+void http_server_deinit(struct http_server *srv)
+	if (srv == NULL)
+		return;
+	if (srv->fd >= 0) {
+		eloop_unregister_sock(srv->fd, EVENT_TYPE_READ);
+		close(srv->fd);
+	http_request_free_all(srv->requests);
+	os_free(srv);
+int http_server_get_port(struct http_server *srv)
+	return srv->port;
diff --git a/freebsd/contrib/wpa/src/wps/http_server.h b/freebsd/contrib/wpa/src/wps/http_server.h
index 00000000000..4b2b749f16f
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/http_server.h
@@ -0,0 +1,33 @@
+#ifndef HTTP_SERVER_H
+#define HTTP_SERVER_H
+struct http_server;
+struct http_request;
+void http_request_deinit(struct http_request *req);
+void http_request_send(struct http_request *req, struct wpabuf *resp);
+				  struct wpabuf *resp);
+enum httpread_hdr_type http_request_get_type(struct http_request *req);
+char * http_request_get_uri(struct http_request *req);
+char * http_request_get_hdr(struct http_request *req);
+char * http_request_get_data(struct http_request *req);
+char * http_request_get_hdr_line(struct http_request *req, const char *tag);
+struct sockaddr_in * http_request_get_cli_addr(struct http_request *req);
+				      void *cb_ctx);
+void http_server_deinit(struct http_server *srv);
+int http_server_get_port(struct http_server *srv);
+#endif /* HTTP_SERVER_H */
diff --git a/freebsd/contrib/wpa/src/wps/httpread.c b/freebsd/contrib/wpa/src/wps/httpread.c
index 00000000000..74a1a4f5522
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/httpread.c
@@ -0,0 +1,850 @@
+ * httpread - Manage reading file(s) from HTTP/TCP socket
+ * Author: Ted Merrill
+ * Copyright 2008 Atheros Communications
+ * The files are buffered via internal callbacks from eloop, then presented to
+ * an application callback routine when completely read into memory. May also
+ * be used if no file is expected but just to get the header, including HTTP
+ * replies (e.g. HTTP/1.1 200 OK etc.).
+ * This does not attempt to be an optimally efficient implementation, but does
+ * attempt to be of reasonably small size and memory consumption; assuming that
+ * only small files are to be read. A maximum file size is provided by
+ * application and enforced.
+ * It is assumed that the application does not expect any of the following:
+ * -- transfer encoding other than chunked
+ * -- trailer fields
+ * It is assumed that, even if the other side requested that the connection be
+ * kept open, that we will close it (thus HTTP messages sent by application
+ * should have the connection closed field); this is allowed by HTTP/1.1 and
+ * simplifies things for us.
+ * Other limitations:
+ * -- HTTP header may not exceed a hard-coded size.
+ * Notes:
+ * This code would be massively simpler without some of the new features of
+ * HTTP/1.1, especially chunked data.
+#include "eloop.h"
+/* Tunable parameters */
+#define HTTPREAD_READBUF_SIZE 1024      /* read in chunks of this size */
+#define HTTPREAD_HEADER_MAX_SIZE 4096   /* max allowed for headers */
+#define HTTPREAD_BODYBUF_DELTA 4096     /* increase allocation by this */
+/* control instance -- actual definition (opaque to application)
+struct httpread {
+	/* information from creation */
+	int sd;         /* descriptor of TCP socket to read from */
+	void (*cb)(struct httpread *handle, void *cookie,
+		    enum httpread_event e);  /* call on event */
+	void *cookie;   /* pass to callback */
+	int max_bytes;          /* maximum file size else abort it */
+	int timeout_seconds;            /* 0 or total duration timeout period */
+	/* dynamically used information follows */
+	int got_hdr;            /* nonzero when header is finalized */
+	char hdr[HTTPREAD_HEADER_MAX_SIZE+1];   /* headers stored here */
+	int hdr_nbytes;
+	enum httpread_hdr_type hdr_type;
+	int version;            /* 1 if we've seen 1.1 */
+	int reply_code;         /* for type REPLY, e.g. 200 for HTTP/1.1 200 OK */
+	int got_content_length; /* true if we know content length for sure */
+	int content_length;     /* body length,  iff got_content_length */
+	int chunked;            /* nonzero for chunked data */
+	char *uri;
+	int got_body;           /* nonzero when body is finalized */
+	char *body;
+	int body_nbytes;
+	int body_alloc_nbytes;  /* amount allocated */
+	int got_file;           /* here when we are done */
+	/* The following apply if data is chunked: */
+	int in_chunk_data;      /* 0=in/at header, 1=in the data or tail*/
+	int chunk_start;        /* offset in body of chunk hdr or data */
+	int chunk_size;         /* data of chunk (not hdr or ending CRLF)*/
+	int in_trailer;         /* in header fields after data (chunked only)*/
+	enum trailer_state {
+		trailer_line_begin = 0,
+		trailer_empty_cr,       /* empty line + CR */
+		trailer_nonempty,
+		trailer_nonempty_cr,
+	} trailer_state;
+/* Check words for equality, where words consist of graphical characters
+ * delimited by whitespace
+ * Returns nonzero if "equal" doing case insensitive comparison.
+static int word_eq(char *s1, char *s2)
+	int c1;
+	int c2;
+	int end1 = 0;
+	int end2 = 0;
+	for (;;) {
+		c1 = *s1++;
+		c2 = *s2++;
+		if (isalpha(c1) && isupper(c1))
+			c1 = tolower(c1);
+		if (isalpha(c2) && isupper(c2))
+			c2 = tolower(c2);
+		end1 = !isgraph(c1);
+		end2 = !isgraph(c2);
+		if (end1 || end2 || c1 != c2)
+			break;
+	return end1 && end2;  /* reached end of both words? */
+static void httpread_timeout_handler(void *eloop_data, void *user_ctx);
+/* httpread_destroy -- if h is non-NULL, clean up
+ * This must eventually be called by the application following
+ * call of the application's callback and may be called
+ * earlier if desired.
+void httpread_destroy(struct httpread *h)
+	wpa_printf(MSG_DEBUG, "httpread_destroy(%p)", h);
+	if (!h)
+		return;
+	eloop_cancel_timeout(httpread_timeout_handler, NULL, h);
+	eloop_unregister_sock(h->sd, EVENT_TYPE_READ);
+	os_free(h->body);
+	os_free(h->uri);
+	os_memset(h, 0, sizeof(*h));  /* aid debugging */
+	h->sd = -1;     /* aid debugging */
+	os_free(h);
+/* httpread_timeout_handler -- called on excessive total duration
+	struct httpread *h = user_ctx;
+	wpa_printf(MSG_DEBUG, "httpread timeout (%p)", h);
+	(*h->cb)(h, h->cookie, HTTPREAD_EVENT_TIMEOUT);
+/* Analyze options only so far as is needed to correctly obtain the file.
+ * The application can look at the raw header to find other options.
+static int httpread_hdr_option_analyze(
+	struct httpread *h,
+	char *hbp       /* pointer to current line in header buffer */
+	if (word_eq(hbp, "CONTENT-LENGTH:")) {
+		while (isgraph(*hbp))
+			hbp++;
+		while (*hbp == ' ' || *hbp == '\t')
+			hbp++;
+		if (!isdigit(*hbp))
+			return -1;
+		h->content_length = atol(hbp);
+		if (h->content_length < 0 || h->content_length > h->max_bytes) {
+				   "httpread: Unacceptable Content-Length %d",
+				   h->content_length);
+			return -1;
+		h->got_content_length = 1;
+		return 0;
+	if (word_eq(hbp, "TRANSFER_ENCODING:") ||
+	    word_eq(hbp, "TRANSFER-ENCODING:")) {
+			hbp++;
+			hbp++;
+		/* There should (?) be no encodings of interest
+		 * other than chunked...
+		if (word_eq(hbp, "CHUNKED")) {
+			h->chunked = 1;
+			h->in_chunk_data = 0;
+			/* ignore possible ;<parameters> */
+		return 0;
+	/* skip anything we don't know, which is a lot */
+	return 0;
+static int httpread_hdr_analyze(struct httpread *h)
+	char *hbp = h->hdr;      /* pointer into h->hdr */
+	int standard_first_line = 1;
+	/* First line is special */
+	h->hdr_type = HTTPREAD_HDR_TYPE_UNKNOWN;
+	if (!isgraph(*hbp))
+		goto bad;
+	if (os_strncmp(hbp, "HTTP/", 5) == 0) {
+		h->hdr_type = HTTPREAD_HDR_TYPE_REPLY;
+		standard_first_line = 0;
+		hbp += 5;
+		if (hbp[0] == '1' && hbp[1] == '.' &&
+		    isdigit(hbp[2]) && hbp[2] != '0')
+			h->version = 1;
+			hbp++;
+			hbp++;
+			goto bad;
+		h->reply_code = atol(hbp);
+	} else if (word_eq(hbp, "GET"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_GET;
+	else if (word_eq(hbp, "HEAD"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_HEAD;
+	else if (word_eq(hbp, "POST"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_POST;
+	else if (word_eq(hbp, "PUT"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_PUT;
+	else if (word_eq(hbp, "DELETE"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_DELETE;
+	else if (word_eq(hbp, "TRACE"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_TRACE;
+	else if (word_eq(hbp, "CONNECT"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_CONNECT;
+	else if (word_eq(hbp, "NOTIFY"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_NOTIFY;
+	else if (word_eq(hbp, "M-SEARCH"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_M_SEARCH;
+	else if (word_eq(hbp, "M-POST"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_M_POST;
+	else if (word_eq(hbp, "SUBSCRIBE"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_SUBSCRIBE;
+	else if (word_eq(hbp, "UNSUBSCRIBE"))
+		h->hdr_type = HTTPREAD_HDR_TYPE_UNSUBSCRIBE;
+	else {
+	if (standard_first_line) {
+		char *rawuri;
+		char *uri;
+		/* skip type */
+			hbp++;
+			hbp++;
+		/* parse uri.
+		 * Find length, allocate memory for translated
+		 * copy, then translate by changing %<hex><hex>
+		 * into represented value.
+		rawuri = hbp;
+			hbp++;
+		h->uri = os_malloc((hbp - rawuri) + 1);
+		if (h->uri == NULL)
+			goto bad;
+		uri = h->uri;
+		while (rawuri < hbp) {
+			int c = *rawuri;
+			if (c == '%' &&
+			    isxdigit(rawuri[1]) && isxdigit(rawuri[2])) {
+				*uri++ = hex2byte(rawuri + 1);
+				rawuri += 3;
+			} else {
+				*uri++ = c;
+				rawuri++;
+		*uri = 0;       /* null terminate */
+			hbp++;
+		/* get version */
+		if (0 == strncmp(hbp, "HTTP/", 5)) {
+			hbp += 5;
+				h->version = 1;
+	/* skip rest of line */
+	while (*hbp)
+		if (*hbp++ == '\n')
+			break;
+	/* Remainder of lines are options, in any order;
+	 * or empty line to terminate
+	for (;;) {
+		/* Empty line to terminate */
+		if (hbp[0] == '\n' ||
+		    (hbp[0] == '\r' && hbp[1] == '\n'))
+			break;
+			goto bad;
+		if (httpread_hdr_option_analyze(h, hbp))
+			goto bad;
+		/* skip line */
+		while (*hbp)
+				break;
+	/* chunked overrides content-length always */
+	if (h->chunked)
+		h->got_content_length = 0;
+	/* For some types, we should not try to read a body
+	 * This is in addition to the application determining
+	 * that we should not read a body.
+	switch (h->hdr_type) {
+	case HTTPREAD_HDR_TYPE_REPLY:
+		/* Some codes can have a body and some not.
+		 * For now, just assume that any other than 200
+		 * do not...
+		if (h->reply_code != 200)
+			h->max_bytes = 0;
+		break;
+	case HTTPREAD_HDR_TYPE_GET:
+	case HTTPREAD_HDR_TYPE_HEAD:
+		/* in practice it appears that it is assumed
+		 * that GETs have a body length of 0... ?
+		if (h->chunked == 0 && h->got_content_length == 0)
+			h->max_bytes = 0;
+		break;
+	case HTTPREAD_HDR_TYPE_POST:
+	case HTTPREAD_HDR_TYPE_PUT:
+	case HTTPREAD_HDR_TYPE_DELETE:
+	case HTTPREAD_HDR_TYPE_TRACE:
+	case HTTPREAD_HDR_TYPE_CONNECT:
+	case HTTPREAD_HDR_TYPE_NOTIFY:
+	case HTTPREAD_HDR_TYPE_M_SEARCH:
+	case HTTPREAD_HDR_TYPE_M_POST:
+	case HTTPREAD_HDR_TYPE_SUBSCRIBE:
+	case HTTPREAD_HDR_TYPE_UNSUBSCRIBE:
+	default:
+		break;
+	return 0;
+bad:
+	/* Error */
+	return -1;
+/* httpread_read_handler -- called when socket ready to read
+ * Note: any extra data we read past end of transmitted file is ignored;
+ * if we were to support keeping connections open for multiple files then
+ * this would have to be addressed.
+static void httpread_read_handler(int sd, void *eloop_ctx, void *sock_ctx)
+	struct httpread *h = sock_ctx;
+	int nread;
+	char *rbp;      /* pointer into read buffer */
+	char *hbp;      /* pointer into header buffer */
+	char *bbp;      /* pointer into body buffer */
+	char readbuf[HTTPREAD_READBUF_SIZE];  /* temp use to read into */
+	/* read some at a time, then search for the interal
+	 * boundaries between header and data and etc.
+	wpa_printf(MSG_DEBUG, "httpread: Trying to read more data(%p)", h);
+	nread = read(h->sd, readbuf, sizeof(readbuf));
+	if (nread < 0) {
+		wpa_printf(MSG_DEBUG, "httpread failed: %s", strerror(errno));
+		goto bad;
+	wpa_hexdump_ascii(MSG_MSGDUMP, "httpread - read", readbuf, nread);
+	if (nread == 0) {
+		/* end of transmission... this may be normal
+		 * or may be an error... in some cases we can't
+		 * tell which so we must assume it is normal then.
+		if (!h->got_hdr) {
+			/* Must at least have completed header */
+			wpa_printf(MSG_DEBUG, "httpread premature eof(%p)", h);
+			goto bad;
+		if (h->chunked || h->got_content_length) {
+			/* Premature EOF; e.g. dropped connection */
+				   "httpread premature eof(%p) %d/%d",
+				   h, h->body_nbytes,
+			goto bad;
+		/* No explicit length, hopefully we have all the data
+		 * although dropped connections can cause false
+		 * end
+		wpa_printf(MSG_DEBUG, "httpread ok eof(%p)", h);
+		h->got_body = 1;
+		goto got_file;
+	rbp = readbuf;
+	/* Header consists of text lines (terminated by both CR and LF)
+	 * and an empty line (CR LF only).
+		hbp = h->hdr + h->hdr_nbytes;
+		/* add to headers until:
+		 *      -- we run out of data in read buffer
+		 *      -- or, we run out of header buffer room
+		 *      -- or, we get double CRLF in headers
+		for (;;) {
+			if (nread == 0)
+				goto get_more;
+			if (h->hdr_nbytes == HTTPREAD_HEADER_MAX_SIZE) {
+					   "httpread: Too long header");
+				goto bad;
+			*hbp++ = *rbp++;
+			nread--;
+			h->hdr_nbytes++;
+			if (h->hdr_nbytes >= 4 &&
+			    hbp[-1] == '\n' &&
+			    hbp[-2] == '\r' &&
+			    hbp[-3] == '\n' &&
+			    hbp[-4] == '\r' ) {
+				h->got_hdr = 1;
+				*hbp = 0;       /* null terminate */
+				break;
+		/* here we've just finished reading the header */
+		if (httpread_hdr_analyze(h)) {
+			wpa_printf(MSG_DEBUG, "httpread bad hdr(%p)", h);
+			goto bad;
+		if (h->max_bytes == 0) {
+			wpa_printf(MSG_DEBUG, "httpread no body hdr end(%p)",
+				   h);
+			goto got_file;
+		if (h->got_content_length && h->content_length == 0) {
+				   "httpread zero content length(%p)", h);
+			goto got_file;
+	/* Certain types of requests never have data and so
+	 * must be specially recognized.
+	if (!os_strncasecmp(h->hdr, "SUBSCRIBE", 9) ||
+	    !os_strncasecmp(h->hdr, "UNSUBSCRIBE", 11) ||
+	    !os_strncasecmp(h->hdr, "HEAD", 4) ||
+	    !os_strncasecmp(h->hdr, "GET", 3)) {
+		if (!h->got_body) {
+			wpa_printf(MSG_DEBUG, "httpread NO BODY for sp. type");
+		h->got_body = 1;
+		goto got_file;
+	/* Data can be just plain binary data, or if "chunked"
+	 * consists of chunks each with a header, ending with
+	 * an ending header.
+	if (nread == 0)
+		goto get_more;
+		/* Here to get (more of) body */
+		/* ensure we have enough room for worst case for body
+		 * plus a null termination character
+		if (h->body_alloc_nbytes < (h->body_nbytes + nread + 1)) {
+			char *new_body;
+			int new_alloc_nbytes;
+			if (h->body_nbytes >= h->max_bytes) {
+					   "httpread: body_nbytes=%d >= max_bytes=%d",
+					   h->body_nbytes, h->max_bytes);
+				goto bad;
+			new_alloc_nbytes = h->body_alloc_nbytes +
+				HTTPREAD_BODYBUF_DELTA;
+			/* For content-length case, the first time
+			 * through we allocate the whole amount
+			 * we need.
+			    new_alloc_nbytes < (h->content_length + 1))
+				new_alloc_nbytes = h->content_length + 1;
+			if (new_alloc_nbytes < h->body_alloc_nbytes ||
+			    new_alloc_nbytes > h->max_bytes +
+			    HTTPREAD_BODYBUF_DELTA) {
+					   "httpread: Unacceptable body length %d (body_alloc_nbytes=%u max_bytes=%u)",
+					   new_alloc_nbytes,
+					   h->body_alloc_nbytes,
+					   h->max_bytes);
+				goto bad;
+			if ((new_body = os_realloc(h->body, new_alloc_nbytes))
+			    == NULL) {
+					   "httpread: Failed to reallocate buffer (len=%d)",
+					   new_alloc_nbytes);
+				goto bad;
+			h->body = new_body;
+			h->body_alloc_nbytes = new_alloc_nbytes;
+		/* add bytes */
+		bbp = h->body + h->body_nbytes;
+		for (;;) {
+			int ncopy;
+			/* See if we need to stop */
+			if (h->chunked && h->in_chunk_data == 0) {
+				/* in chunk header */
+				char *cbp = h->body + h->chunk_start;
+				if (bbp-cbp >= 2 && bbp[-2] == '\r' &&
+				    bbp[-1] == '\n') {
+					/* end of chunk hdr line */
+					/* hdr line consists solely
+					 * of a hex numeral and CFLF
+					if (!isxdigit(*cbp)) {
+							   "httpread: Unexpected chunk header value (not a hex digit)");
+						goto bad;
+					h->chunk_size = strtoul(cbp, NULL, 16);
+					if (h->chunk_size < 0 ||
+					    h->chunk_size > h->max_bytes) {
+							   "httpread: Invalid chunk size %d",
+							   h->chunk_size);
+						goto bad;
+					/* throw away chunk header
+					 * so we have only real data
+					h->body_nbytes = h->chunk_start;
+					bbp = cbp;
+					if (h->chunk_size == 0) {
+						/* end of chunking */
+						/* trailer follows */
+						h->in_trailer = 1;
+							   "httpread end chunks(%p)",
+							   h);
+						break;
+					h->in_chunk_data = 1;
+					/* leave chunk_start alone */
+			} else if (h->chunked) {
+				/* in chunk data */
+				if ((h->body_nbytes - h->chunk_start) ==
+				    (h->chunk_size + 2)) {
+					/* end of chunk reached,
+					 * new chunk starts
+					/* check chunk ended w/ CRLF
+					 * which we'll throw away
+					if (bbp[-1] == '\n' &&
+					    bbp[-2] == '\r') {
+					} else {
+							   "httpread: Invalid chunk end");
+						goto bad;
+					h->body_nbytes -= 2;
+					bbp -= 2;
+					h->chunk_start = h->body_nbytes;
+					h->chunk_size = 0; /* just in case */
+			} else if (h->got_content_length &&
+				   h->body_nbytes >= h->content_length) {
+				h->got_body = 1;
+					   "httpread got content(%p)", h);
+				goto got_file;
+			if (nread <= 0)
+				break;
+			/* Now transfer. Optimize using memcpy where we can. */
+			if (h->chunked && h->in_chunk_data) {
+				/* copy up to remainder of chunk data
+				 * plus the required CR+LF at end
+				ncopy = (h->chunk_start + h->chunk_size + 2) -
+					h->body_nbytes;
+				/*in chunk header -- don't optimize */
+				*bbp++ = *rbp++;
+				nread--;
+				h->body_nbytes++;
+				continue;
+			} else if (h->got_content_length) {
+				ncopy = h->content_length - h->body_nbytes;
+			} else {
+				ncopy = nread;
+			/* Note: should never be 0 */
+			if (ncopy < 0) {
+					   "httpread: Invalid ncopy=%d", ncopy);
+				goto bad;
+			if (ncopy > nread)
+				ncopy = nread;
+			os_memcpy(bbp, rbp, ncopy);
+			bbp += ncopy;
+			h->body_nbytes += ncopy;
+			rbp += ncopy;
+			nread -= ncopy;
+		}       /* body copy loop */
+	}       /* !got_body */
+	if (h->chunked && h->in_trailer) {
+		/* If "chunked" then there is always a trailer,
+		 * consisting of zero or more non-empty lines
+		 * ending with CR LF and then an empty line w/ CR LF.
+		 * We do NOT support trailers except to skip them --
+		 * this is supported (generally) by the http spec.
+		for (;;) {
+			int c;
+			if (nread <= 0)
+				break;
+			c = *rbp++;
+			nread--;
+			switch (h->trailer_state) {
+			case trailer_line_begin:
+				if (c == '\r')
+					h->trailer_state = trailer_empty_cr;
+				else
+					h->trailer_state = trailer_nonempty;
+				break;
+			case trailer_empty_cr:
+				/* end empty line */
+				if (c == '\n') {
+					h->trailer_state = trailer_line_begin;
+					h->in_trailer = 0;
+						   h);
+					h->got_body = 1;
+					goto got_file;
+				break;
+			case trailer_nonempty:
+				if (c == '\r')
+					h->trailer_state = trailer_nonempty_cr;
+				break;
+			case trailer_nonempty_cr:
+				if (c == '\n')
+				else
+				break;
+	goto get_more;
+bad:
+	/* Error */
+	wpa_printf(MSG_DEBUG, "httpread read/parse failure (%p)", h);
+	(*h->cb)(h, h->cookie, HTTPREAD_EVENT_ERROR);
+	return;
+get_more:
+	wpa_printf(MSG_DEBUG, "httpread: get more (%p)", h);
+	return;
+got_file:
+	wpa_printf(MSG_DEBUG, "httpread got file %d bytes type %d",
+		   h->body_nbytes, h->hdr_type);
+	wpa_hexdump_ascii(MSG_MSGDUMP, "httpread: body",
+			  h->body, h->body_nbytes);
+	/* Null terminate for convenience of some applications */
+	if (h->body)
+		h->body[h->body_nbytes] = 0; /* null terminate */
+	h->got_file = 1;
+	/* Assume that we do NOT support keeping connection alive,
+	 * and just in case somehow we don't get destroyed right away,
+	 * unregister now.
+	/* The application can destroy us whenever they feel like...
+	 * cancel timeout.
+	(*h->cb)(h, h->cookie, HTTPREAD_EVENT_FILE_READY);
+/* httpread_create -- start a new reading session making use of eloop.
+ * The new instance will use the socket descriptor for reading (until
+ * it gets a file and not after) but will not close the socket, even
+ * when the instance is destroyed (the application must do that).
+ * Return NULL on error.
+ * Provided that httpread_create successfully returns a handle,
+ * the callback fnc is called to handle httpread_event events.
+ * The caller should do destroy on any errors or unknown events.
+ * Pass max_bytes == 0 to not read body at all (required for e.g.
+ * reply to HEAD request).
+struct httpread * httpread_create(
+	int sd,	 /* descriptor of TCP socket to read from */
+		   enum httpread_event e),  /* call on event */
+	void *cookie,    /* pass to callback */
+	int max_bytes,	  /* maximum body size else abort it */
+	int timeout_seconds     /* 0; or total duration timeout period */
+	struct httpread *h = NULL;
+	h = os_zalloc(sizeof(*h));
+	if (h == NULL)
+		goto fail;
+	h->sd = sd;
+	h->cb = cb;
+	h->cookie = cookie;
+	h->max_bytes = max_bytes;
+	h->timeout_seconds = timeout_seconds;
+	if (timeout_seconds > 0 &&
+	    eloop_register_timeout(timeout_seconds, 0,
+				   httpread_timeout_handler, NULL, h)) {
+		/* No way to recover (from malloc failure) */
+		goto fail;
+	if (eloop_register_sock(sd, EVENT_TYPE_READ, httpread_read_handler,
+				NULL, h)) {
+		goto fail;
+	return h;
+fail:
+	/* Error */
+	httpread_destroy(h);
+	return NULL;
+/* httpread_hdr_type_get -- When file is ready, returns header type. */
+enum httpread_hdr_type httpread_hdr_type_get(struct httpread *h)
+	return h->hdr_type;
+/* httpread_uri_get -- When file is ready, uri_get returns (translated) URI
+ * or possibly NULL (which would be an error).
+char * httpread_uri_get(struct httpread *h)
+	return h->uri;
+/* httpread_reply_code_get -- When reply is ready, returns reply code */
+int httpread_reply_code_get(struct httpread *h)
+	return h->reply_code;
+/* httpread_length_get -- When file is ready, returns file length. */
+int httpread_length_get(struct httpread *h)
+	return h->body_nbytes;
+/* httpread_data_get -- When file is ready, returns file content
+ * with null byte appened.
+ * Might return NULL in some error condition.
+void * httpread_data_get(struct httpread *h)
+	return h->body ? h->body : "";
+/* httpread_hdr_get -- When file is ready, returns header content
+ * with null byte appended.
+char * httpread_hdr_get(struct httpread *h)
+	return h->hdr;
+/* httpread_hdr_line_get -- When file is ready, returns pointer
+ * to line within header content matching the given tag
+ * (after the tag itself and any spaces/tabs).
+ * The tag should end with a colon for reliable matching.
+ * If not found, returns NULL;
+char * httpread_hdr_line_get(struct httpread *h, const char *tag)
+	int tag_len = os_strlen(tag);
+	char *hdr = h->hdr;
+	hdr = os_strchr(hdr, '\n');
+	if (hdr == NULL)
+		return NULL;
+	hdr++;
+	for (;;) {
+		if (!os_strncasecmp(hdr, tag, tag_len)) {
+			hdr += tag_len;
+			while (*hdr == ' ' || *hdr == '\t')
+				hdr++;
+			return hdr;
+		if (hdr == NULL)
+			return NULL;
+		hdr++;
diff --git a/freebsd/contrib/wpa/src/wps/httpread.h b/freebsd/contrib/wpa/src/wps/httpread.h
index 00000000000..454b618bf4a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/httpread.h
@@ -0,0 +1,117 @@
+#ifndef HTTPREAD_H
+#define HTTPREAD_H
+/* event types (passed to callback) */
+enum httpread_event {
+	HTTPREAD_EVENT_FILE_READY = 1,        /* including reply ready */
+	HTTPREAD_EVENT_TIMEOUT = 2,
+	HTTPREAD_EVENT_ERROR = 3      /* misc. error, esp malloc error */
+/* header type detected
+ * available to callback via call to httpread_reply_code_get()
+enum httpread_hdr_type {
+	HTTPREAD_HDR_TYPE_UNKNOWN = 0,      /* none of the following */
+	HTTPREAD_HDR_TYPE_REPLY = 1,        /* hdr begins w/ HTTP/ */
+	HTTPREAD_HDR_TYPE_GET = 2,          /* hdr begins with GET<sp> */
+	HTTPREAD_HDR_TYPE_HEAD = 3,         /* hdr begins with HEAD<sp> */
+	HTTPREAD_HDR_TYPE_POST = 4,         /* hdr begins with POST<sp> */
+	HTTPREAD_HDR_TYPE_PUT = 5,          /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_DELETE = 6,       /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_TRACE = 7,        /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_CONNECT = 8,      /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_NOTIFY = 9,       /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_M_SEARCH = 10,    /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_M_POST = 11,      /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_SUBSCRIBE = 12,   /* hdr begins with ... */
+	HTTPREAD_HDR_TYPE_UNSUBSCRIBE = 13, /* hdr begins with ... */
+	HTTPREAD_N_HDR_TYPES    /* keep last */
+/* control instance -- opaque struct declaration
+struct httpread;
+void httpread_destroy(struct httpread *h);
+	int max_bytes,          /* maximum file size else abort it */
+enum httpread_hdr_type httpread_hdr_type_get(struct httpread *h);
+char *httpread_uri_get(struct httpread *h);
+int httpread_reply_code_get(struct httpread *h);
+int httpread_length_get(struct httpread *h);
+void * httpread_data_get(struct httpread *h);
+char * httpread_hdr_get(struct httpread *h);
+char * httpread_hdr_line_get(struct httpread *h, const char *tag);
+#endif /* HTTPREAD_H */
diff --git a/freebsd/contrib/wpa/src/wps/upnp_xml.c b/freebsd/contrib/wpa/src/wps/upnp_xml.c
index 00000000000..af583ff6418
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/upnp_xml.c
@@ -0,0 +1,254 @@
+#include <machine/rtems-bsd-user-space.h>
+ * UPnP XML helper routines
+#include "includes.h"
+#include "common.h"
+#include "base64.h"
+#include "http.h"
+#include "upnp_xml.h"
+ * XML parsing and formatting
+ * XML is a markup language based on unicode; usually (and in our case,
+ * always!) based on utf-8. utf-8 uses a variable number of bytes per
+ * character. utf-8 has the advantage that all non-ASCII unicode characters are
+ * represented by sequences of non-ascii (high bit set) bytes, whereas ASCII
+ * characters are single ascii bytes, thus we can use typical text processing.
+ * (One other interesting thing about utf-8 is that it is possible to look at
+ * any random byte and determine if it is the first byte of a character as
+ * versus a continuation byte).
+ * The base syntax of XML uses a few ASCII punctionation characters; any
+ * characters that would appear in the payload data are rewritten using
+ * sequences, e.g., & for ampersand(&) and &lt for left angle bracket (<).
+ * Five such escapes total (more can be defined but that does not apply to our
+ * case). Thus we can safely parse for angle brackets etc.
+ * XML describes tree structures of tagged data, with each element beginning
+ * with an opening tag <label> and ending with a closing tag </label> with
+ * matching label. (There is also a self-closing tag <label/> which is supposed
+ * to be equivalent to <label></label>, i.e., no payload, but we are unlikely
+ * to see it for our purpose).
+ * Actually the opening tags are a little more complicated because they can
+ * contain "attributes" after the label (delimited by ascii space or tab chars)
+ * of the form attribute_label="value" or attribute_label='value'; as it turns
+ * out we do not have to read any of these attributes, just ignore them.
+ * Labels are any sequence of chars other than space, tab, right angle bracket
+ * (and ?), but may have an inner structure of <namespace><colon><plain_label>.
+ * As it turns out, we can ignore the namespaces, in fact we can ignore the
+ * entire tree hierarchy, because the plain labels we are looking for will be
+ * unique (not in general, but for this application). We do however have to be
+ * careful to skip over the namespaces.
+ * In generating XML we have to be more careful, but that is easy because
+ * everything we do is pretty canned. The only real care to take is to escape
+ * any special chars in our payload.
+ * xml_next_tag - Advance to next tag
+ * @in: Input
+ * @out: OUT: start of tag just after '<'
+ * @out_tagname: OUT: start of name of tag, skipping namespace
+ * @end: OUT: one after tag
+ * Returns: 0 on success, 1 on failure
+ * A tag has form:
+ *     <left angle bracket><...><right angle bracket>
+ * Within the angle brackets, there is an optional leading forward slash (which
+ * makes the tag an ending tag), then an optional leading label (followed by
+ * colon) and then the tag name itself.
+ * Note that angle brackets present in the original data must have been encoded
+ * as < and > so they will not trouble us.
+int xml_next_tag(const char *in, const char **out,
+		 const char **out_tagname, const char **end)
+	while (*in && *in != '<')
+		in++;
+	if (*in != '<')
+		return 1;
+	*out = ++in;
+	if (*in == '/')
+		in++;
+	*out_tagname = in; /* maybe */
+	while (isalnum(*in) || *in == '-')
+		in++;
+	if (*in == ':')
+		*out_tagname = ++in;
+	while (*in && *in != '>')
+		in++;
+	if (*in != '>')
+		return 1;
+	*end = ++in;
+	return 0;
+/* xml_data_encode -- format data for xml file, escaping special characters.
+ * Note that we assume we are using utf8 both as input and as output!
+ * In utf8, characters may be classed as follows:
+ *     0xxxxxxx(2) -- 1 byte ascii char
+ *     11xxxxxx(2) -- 1st byte of multi-byte char w/ unicode value >= 0x80
+ *         110xxxxx(2) -- 1st byte of 2 byte sequence (5 payload bits here)
+ *         1110xxxx(2) -- 1st byte of 3 byte sequence (4 payload bits here)
+ *         11110xxx(2) -- 1st byte of 4 byte sequence (3 payload bits here)
+ *      10xxxxxx(2) -- extension byte (6 payload bits per byte)
+ *      Some values implied by the above are however illegal because they
+ *      do not represent unicode chars or are not the shortest encoding.
+ * Actually, we can almost entirely ignore the above and just do
+ * text processing same as for ascii text.
+ * XML is written with arbitrary unicode characters, except that five
+ * characters have special meaning and so must be escaped where they
+ * appear in payload data... which we do here.
+void xml_data_encode(struct wpabuf *buf, const char *data, int len)
+	int i;
+	for (i = 0; i < len; i++) {
+		u8 c = ((u8 *) data)[i];
+		if (c == '<') {
+			wpabuf_put_str(buf, "<");
+			continue;
+		if (c == '>') {
+			wpabuf_put_str(buf, ">");
+			continue;
+		if (c == '&') {
+			wpabuf_put_str(buf, "&");
+			continue;
+		if (c == '\'') {
+			wpabuf_put_str(buf, "'");
+			continue;
+		if (c == '"') {
+			wpabuf_put_str(buf, """);
+			continue;
+		 * We could try to represent control characters using the
+		 * sequence: &#x; where x is replaced by a hex numeral, but not
+		 * clear why we would do this.
+		wpabuf_put_u8(buf, c);
+/* xml_add_tagged_data -- format tagged data as a new xml line.
+ * tag must not have any special chars.
+ * data may have special chars, which are escaped.
+void xml_add_tagged_data(struct wpabuf *buf, const char *tag, const char *data)
+	wpabuf_printf(buf, "<%s>", tag);
+	xml_data_encode(buf, data, os_strlen(data));
+	wpabuf_printf(buf, "</%s>\n", tag);
+/* A POST body looks something like (per upnp spec):
+ * <?xml version="1.0"?>
+ * <s:Envelope
+ *     xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"
+ *     s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
+ *   <s:Body>
+ *     <u:actionName xmlns:u="urn:schemas-upnp-org:service:serviceType:v">
+ *       <argumentName>in arg value</argumentName>
+ *       other in args and their values go here, if any
+ *     </u:actionName>
+ *   </s:Body>
+ * </s:Envelope>
+ * where :
+ *      s: might be some other namespace name followed by colon
+ *      u: might be some other namespace name followed by colon
+ *      actionName will be replaced according to action requested
+ *      schema following actionName will be WFA scheme instead
+ *      argumentName will be actual argument name
+ *      (in arg value) will be actual argument value
+char * xml_get_first_item(const char *doc, const char *item)
+	const char *match = item;
+	int match_len = os_strlen(item);
+	const char *tag, *tagname, *end;
+	char *value;
+	 * This is crude: ignore any possible tag name conflicts and go right
+	 * to the first tag of this name. This should be ok for the limited
+	 * domain of UPnP messages.
+	for (;;) {
+		if (xml_next_tag(doc, &tag, &tagname, &end))
+			return NULL;
+		doc = end;
+		if (!os_strncasecmp(tagname, match, match_len) &&
+		    *tag != '/' &&
+		    (tagname[match_len] == '>' ||
+		     !isgraph(tagname[match_len]))) {
+			break;
+	end = doc;
+	while (*end && *end != '<')
+		end++;
+	value = os_zalloc(1 + (end - doc));
+	if (value == NULL)
+		return NULL;
+	os_memcpy(value, doc, end - doc);
+	return value;
+struct wpabuf * xml_get_base64_item(const char *data, const char *name,
+				    enum http_reply_code *ret)
+	char *msg;
+	unsigned char *decoded;
+	size_t len;
+	msg = xml_get_first_item(data, name);
+	if (msg == NULL) {
+		*ret = UPNP_ARG_VALUE_INVALID;
+		return NULL;
+	decoded = base64_decode((unsigned char *) msg, os_strlen(msg), &len);
+	os_free(msg);
+	if (decoded == NULL) {
+		*ret = UPNP_OUT_OF_MEMORY;
+		return NULL;
+	buf = wpabuf_alloc_ext_data(decoded, len);
+	if (buf == NULL) {
+		os_free(decoded);
+		return NULL;
+	return buf;
diff --git a/freebsd/contrib/wpa/src/wps/upnp_xml.h b/freebsd/contrib/wpa/src/wps/upnp_xml.h
index 00000000000..616af3dadc8
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/upnp_xml.h
@@ -0,0 +1,25 @@
+#ifndef UPNP_XML_H
+#define UPNP_XML_H
+#include "http.h"
+void xml_data_encode(struct wpabuf *buf, const char *data, int len);
+			 const char *data);
+		 const char **out_tagname, const char **end);
+char * xml_get_first_item(const char *doc, const char *item);
+				    enum http_reply_code *ret);
+#endif /* UPNP_XML_H */
diff --git a/freebsd/contrib/wpa/src/wps/wps.c b/freebsd/contrib/wpa/src/wps/wps.c
index 00000000000..fb6d8f6541a
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps.c
@@ -0,0 +1,664 @@
+ * Wi-Fi Protected Setup
+ * Copyright (c) 2007-2009, Jouni Malinen <j at w1.fi>
+#include "crypto/dh_group5.h"
+#include "common/ieee802_11_defs.h"
+#include "wps_i.h"
+#include "wps_dev_attr.h"
+#ifdef CONFIG_WPS_TESTING
+int wps_version_number = 0x20;
+int wps_testing_dummy_cred = 0;
+int wps_corrupt_pkhash = 0;
+#endif /* CONFIG_WPS_TESTING */
+ * wps_init - Initialize WPS Registration protocol data
+ * @cfg: WPS configuration
+ * Returns: Pointer to allocated data or %NULL on failure
+ * This function is used to initialize WPS data for a registration protocol
+ * instance (i.e., each run of registration protocol as a Registrar of
+ * Enrollee. The caller is responsible for freeing this data after the
+ * registration run has been completed by calling wps_deinit().
+struct wps_data * wps_init(const struct wps_config *cfg)
+	struct wps_data *data = os_zalloc(sizeof(*data));
+	if (data == NULL)
+		return NULL;
+	data->wps = cfg->wps;
+	data->registrar = cfg->registrar;
+	if (cfg->registrar) {
+		os_memcpy(data->uuid_r, cfg->wps->uuid, WPS_UUID_LEN);
+	} else {
+		os_memcpy(data->mac_addr_e, cfg->wps->dev.mac_addr, ETH_ALEN);
+		os_memcpy(data->uuid_e, cfg->wps->uuid, WPS_UUID_LEN);
+	if (cfg->pin) {
+		data->dev_pw_id = cfg->dev_pw_id;
+		data->dev_password = os_malloc(cfg->pin_len);
+		if (data->dev_password == NULL) {
+			os_free(data);
+			return NULL;
+		os_memcpy(data->dev_password, cfg->pin, cfg->pin_len);
+		data->dev_password_len = cfg->pin_len;
+		wpa_hexdump_key(MSG_DEBUG, "WPS: AP PIN dev_password",
+				data->dev_password, data->dev_password_len);
+#ifdef CONFIG_WPS_NFC
+	if (cfg->pin == NULL &&
+	    cfg->dev_pw_id == DEV_PW_NFC_CONNECTION_HANDOVER)
+	if (cfg->wps->ap && !cfg->registrar && cfg->wps->ap_nfc_dev_pw_id) {
+		/* Keep AP PIN as alternative Device Password */
+		data->alt_dev_pw_id = data->dev_pw_id;
+		data->alt_dev_password = data->dev_password;
+		data->alt_dev_password_len = data->dev_password_len;
+		data->dev_pw_id = cfg->wps->ap_nfc_dev_pw_id;
+			os_malloc(wpabuf_len(cfg->wps->ap_nfc_dev_pw));
+			os_free(data);
+			return NULL;
+			  wpabuf_head(cfg->wps->ap_nfc_dev_pw),
+			  wpabuf_len(cfg->wps->ap_nfc_dev_pw));
+		data->dev_password_len = wpabuf_len(cfg->wps->ap_nfc_dev_pw);
+		wpa_hexdump_key(MSG_DEBUG, "WPS: NFC dev_password",
+#endif /* CONFIG_WPS_NFC */
+	data->pbc = cfg->pbc;
+	if (cfg->pbc) {
+		/* Use special PIN '00000000' for PBC */
+		data->dev_pw_id = DEV_PW_PUSHBUTTON;
+		bin_clear_free(data->dev_password, data->dev_password_len);
+		data->dev_password = (u8 *) os_strdup("00000000");
+			os_free(data);
+			return NULL;
+		data->dev_password_len = 8;
+	data->state = data->registrar ? RECV_M1 : SEND_M1;
+	if (cfg->assoc_wps_ie) {
+		struct wps_parse_attr attr;
+		wpa_hexdump_buf(MSG_DEBUG, "WPS: WPS IE from (Re)AssocReq",
+				cfg->assoc_wps_ie);
+		if (wps_parse_msg(cfg->assoc_wps_ie, &attr) < 0) {
+			wpa_printf(MSG_DEBUG, "WPS: Failed to parse WPS IE "
+				   "from (Re)AssocReq");
+		} else if (attr.request_type == NULL) {
+			wpa_printf(MSG_DEBUG, "WPS: No Request Type attribute "
+				   "in (Re)AssocReq WPS IE");
+		} else {
+			wpa_printf(MSG_DEBUG, "WPS: Request Type (from WPS IE "
+				   "in (Re)AssocReq WPS IE): %d",
+				   *attr.request_type);
+			data->request_type = *attr.request_type;
+	if (cfg->new_ap_settings) {
+		data->new_ap_settings =
+			os_malloc(sizeof(*data->new_ap_settings));
+		if (data->new_ap_settings == NULL) {
+				       data->dev_password_len);
+			os_free(data);
+			return NULL;
+		os_memcpy(data->new_ap_settings, cfg->new_ap_settings,
+			  sizeof(*data->new_ap_settings));
+	if (cfg->peer_addr)
+		os_memcpy(data->peer_dev.mac_addr, cfg->peer_addr, ETH_ALEN);
+	if (cfg->p2p_dev_addr)
+		os_memcpy(data->p2p_dev_addr, cfg->p2p_dev_addr, ETH_ALEN);
+	data->use_psk_key = cfg->use_psk_key;
+	data->pbc_in_m1 = cfg->pbc_in_m1;
+	if (cfg->peer_pubkey_hash) {
+		os_memcpy(data->peer_pubkey_hash, cfg->peer_pubkey_hash,
+			  WPS_OOB_PUBKEY_HASH_LEN);
+		data->peer_pubkey_hash_set = 1;
+	return data;
+ * wps_deinit - Deinitialize WPS Registration protocol data
+ * @data: WPS Registration protocol data from wps_init()
+void wps_deinit(struct wps_data *data)
+	if (data->registrar && data->nfc_pw_token)
+		wps_registrar_remove_nfc_pw_token(data->wps->registrar,
+						  data->nfc_pw_token);
+	if (data->wps_pin_revealed) {
+		wpa_printf(MSG_DEBUG, "WPS: Full PIN information revealed and "
+			   "negotiation failed");
+		if (data->registrar)
+			wps_registrar_invalidate_pin(data->wps->registrar,
+						     data->uuid_e);
+	} else if (data->registrar)
+		wps_registrar_unlock_pin(data->wps->registrar, data->uuid_e);
+	wpabuf_free(data->dh_privkey);
+	wpabuf_free(data->dh_pubkey_e);
+	wpabuf_free(data->dh_pubkey_r);
+	wpabuf_free(data->last_msg);
+	bin_clear_free(data->alt_dev_password, data->alt_dev_password_len);
+	bin_clear_free(data->new_psk, data->new_psk_len);
+	wps_device_data_free(&data->peer_dev);
+	bin_clear_free(data->new_ap_settings, sizeof(*data->new_ap_settings));
+	dh5_free(data->dh_ctx);
+	os_free(data);
+ * wps_process_msg - Process a WPS message
+ * @wps: WPS Registration protocol data from wps_init()
+ * @op_code: Message OP Code
+ * @msg: Message data
+ * Returns: Processing result
+ * This function is used to process WPS messages with OP Codes WSC_ACK,
+ * WSC_NACK, WSC_MSG, and WSC_Done. The caller (e.g., EAP server/peer) is
+ * responsible for reassembling the messages before calling this function.
+ * Response to this message is built by calling wps_get_msg().
+enum wps_process_res wps_process_msg(struct wps_data *wps,
+				     enum wsc_op_code op_code,
+				     const struct wpabuf *msg)
+	if (wps->registrar)
+		return wps_registrar_process_msg(wps, op_code, msg);
+	else
+		return wps_enrollee_process_msg(wps, op_code, msg);
+ * wps_get_msg - Build a WPS message
+ * @op_code: Buffer for returning message OP Code
+ * Returns: The generated WPS message or %NULL on failure
+ * This function is used to build a response to a message processed by calling
+ * wps_process_msg(). The caller is responsible for freeing the buffer.
+struct wpabuf * wps_get_msg(struct wps_data *wps, enum wsc_op_code *op_code)
+		return wps_registrar_get_msg(wps, op_code);
+	else
+		return wps_enrollee_get_msg(wps, op_code);
+ * wps_is_selected_pbc_registrar - Check whether WPS IE indicates active PBC
+ * @msg: WPS IE contents from Beacon or Probe Response frame
+ * Returns: 1 if PBC Registrar is active, 0 if not
+int wps_is_selected_pbc_registrar(const struct wpabuf *msg)
+	 * In theory, this could also verify that attr.sel_reg_config_methods
+	 * includes WPS_CONFIG_PUSHBUTTON, but some deployed AP implementations
+	 * do not set Selected Registrar Config Methods attribute properly, so
+	 * it is safer to just use Device Password ID here.
+	if (wps_parse_msg(msg, &attr) < 0 ||
+	    !attr.selected_registrar || *attr.selected_registrar == 0 ||
+	    !attr.dev_password_id ||
+	    WPA_GET_BE16(attr.dev_password_id) != DEV_PW_PUSHBUTTON)
+		return 0;
+#ifdef CONFIG_WPS_STRICT
+	if (!attr.sel_reg_config_methods ||
+	    !(WPA_GET_BE16(attr.sel_reg_config_methods) &
+	      WPS_CONFIG_PUSHBUTTON))
+		return 0;
+#endif /* CONFIG_WPS_STRICT */
+	return 1;
+static int is_selected_pin_registrar(struct wps_parse_attr *attr)
+	 * includes WPS_CONFIG_LABEL, WPS_CONFIG_DISPLAY, or WPS_CONFIG_KEYPAD,
+	 * but some deployed AP implementations do not set Selected Registrar
+	 * Config Methods attribute properly, so it is safer to just use
+	 * Device Password ID here.
+	if (!attr->selected_registrar || *attr->selected_registrar == 0)
+		return 0;
+	if (attr->dev_password_id != NULL &&
+	    WPA_GET_BE16(attr->dev_password_id) == DEV_PW_PUSHBUTTON)
+		return 0;
+	if (!attr->sel_reg_config_methods ||
+	    !(WPA_GET_BE16(attr->sel_reg_config_methods) &
+	      (WPS_CONFIG_LABEL | WPS_CONFIG_DISPLAY | WPS_CONFIG_KEYPAD)))
+		return 0;
+	return 1;
+ * wps_is_selected_pin_registrar - Check whether WPS IE indicates active PIN
+ * Returns: 1 if PIN Registrar is active, 0 if not
+int wps_is_selected_pin_registrar(const struct wpabuf *msg)
+	if (wps_parse_msg(msg, &attr) < 0)
+		return 0;
+	return is_selected_pin_registrar(&attr);
+ * wps_is_addr_authorized - Check whether WPS IE authorizes MAC address
+ * @addr: MAC address to search for
+ * @ver1_compat: Whether to use version 1 compatibility mode
+ * Returns: 2 if the specified address is explicit authorized, 1 if address is
+ * authorized (broadcast), 0 if not
+int wps_is_addr_authorized(const struct wpabuf *msg, const u8 *addr,
+			   int ver1_compat)
+	unsigned int i;
+	const u8 *pos;
+	const u8 bcast[ETH_ALEN] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff };
+		return 0;
+	if (!attr.version2 && ver1_compat) {
+		 * Version 1.0 AP - AuthorizedMACs not used, so revert back to
+		 * old mechanism of using SelectedRegistrar.
+	if (!attr.authorized_macs)
+		return 0;
+	pos = attr.authorized_macs;
+	for (i = 0; i < attr.authorized_macs_len / ETH_ALEN; i++) {
+		if (os_memcmp(pos, addr, ETH_ALEN) == 0)
+			return 2;
+		if (os_memcmp(pos, bcast, ETH_ALEN) == 0)
+			return 1;
+		pos += ETH_ALEN;
+	return 0;
+ * wps_ap_priority_compar - Prioritize WPS IE from two APs
+ * @wps_a: WPS IE contents from Beacon or Probe Response frame
+ * @wps_b: WPS IE contents from Beacon or Probe Response frame
+ * Returns: 1 if wps_b is considered more likely selection for WPS
+ * provisioning, -1 if wps_a is considered more like, or 0 if no preference
+int wps_ap_priority_compar(const struct wpabuf *wps_a,
+			   const struct wpabuf *wps_b)
+	int sel_a, sel_b;
+	if (wps_a == NULL || wps_parse_msg(wps_a, &attr) < 0)
+		return 1;
+	sel_a = attr.selected_registrar && *attr.selected_registrar != 0;
+	if (wps_b == NULL || wps_parse_msg(wps_b, &attr) < 0)
+		return -1;
+	sel_b = attr.selected_registrar && *attr.selected_registrar != 0;
+	if (sel_a && !sel_b)
+		return -1;
+	if (!sel_a && sel_b)
+		return 1;
+	return 0;
+ * wps_get_uuid_e - Get UUID-E from WPS IE
+ * Returns: Pointer to UUID-E or %NULL if not included
+ * The returned pointer is to the msg contents and it remains valid only as
+ * long as the msg buffer is valid.
+const u8 * wps_get_uuid_e(const struct wpabuf *msg)
+		return NULL;
+	return attr.uuid_e;
+ * wps_is_20 - Check whether WPS attributes claim support for WPS 2.0
+int wps_is_20(const struct wpabuf *msg)
+	if (msg == NULL || wps_parse_msg(msg, &attr) < 0)
+		return 0;
+	return attr.version2 != NULL;
+ * wps_build_assoc_req_ie - Build WPS IE for (Re)Association Request
+ * @req_type: Value for Request Type attribute
+ * Returns: WPS IE or %NULL on failure
+ * The caller is responsible for freeing the buffer.
+struct wpabuf * wps_build_assoc_req_ie(enum wps_request_type req_type)
+	struct wpabuf *ie;
+	u8 *len;
+	wpa_printf(MSG_DEBUG, "WPS: Building WPS IE for (Re)Association "
+		   "Request");
+	ie = wpabuf_alloc(100);
+	if (ie == NULL)
+		return NULL;
+	wpabuf_put_u8(ie, WLAN_EID_VENDOR_SPECIFIC);
+	len = wpabuf_put(ie, 1);
+	wpabuf_put_be32(ie, WPS_DEV_OUI_WFA);
+	if (wps_build_version(ie) ||
+	    wps_build_req_type(ie, req_type) ||
+	    wps_build_wfa_ext(ie, 0, NULL, 0)) {
+		wpabuf_free(ie);
+		return NULL;
+	*len = wpabuf_len(ie) - 2;
+	return ie;
+ * wps_build_assoc_resp_ie - Build WPS IE for (Re)Association Response
+struct wpabuf * wps_build_assoc_resp_ie(void)
+	u8 *len;
+		   "Response");
+	if (ie == NULL)
+		return NULL;
+	    wps_build_resp_type(ie, WPS_RESP_AP) ||
+		wpabuf_free(ie);
+		return NULL;
+	return ie;
+ * wps_build_probe_req_ie - Build WPS IE for Probe Request
+ * @pw_id: Password ID (DEV_PW_PUSHBUTTON for active PBC and DEV_PW_DEFAULT for
+ * most other use cases)
+ * @dev: Device attributes
+ * @uuid: Own UUID
+ * @num_req_dev_types: Number of requested device types
+ * @req_dev_types: Requested device types (8 * num_req_dev_types octets) or
+ *	%NULL if none
+struct wpabuf * wps_build_probe_req_ie(u16 pw_id, struct wps_device_data *dev,
+				       const u8 *uuid,
+				       enum wps_request_type req_type,
+				       unsigned int num_req_dev_types,
+				       const u8 *req_dev_types)
+	wpa_printf(MSG_DEBUG, "WPS: Building WPS IE for Probe Request");
+	ie = wpabuf_alloc(500);
+	if (ie == NULL)
+		return NULL;
+	    wps_build_config_methods(ie, dev->config_methods) ||
+	    wps_build_uuid_e(ie, uuid) ||
+	    wps_build_primary_dev_type(dev, ie) ||
+	    wps_build_rf_bands(dev, ie, 0) ||
+	    wps_build_assoc_state(NULL, ie) ||
+	    wps_build_config_error(ie, WPS_CFG_NO_ERROR) ||
+	    wps_build_dev_password_id(ie, pw_id) ||
+	    wps_build_manufacturer(dev, ie) ||
+	    wps_build_model_name(dev, ie) ||
+	    wps_build_model_number(dev, ie) ||
+	    wps_build_dev_name(dev, ie) ||
+	    wps_build_wfa_ext(ie, req_type == WPS_REQ_ENROLLEE, NULL, 0) ||
+	    wps_build_req_dev_type(dev, ie, num_req_dev_types, req_dev_types)
+	    wps_build_secondary_dev_type(dev, ie)
+		wpabuf_free(ie);
+		return NULL;
+	return wps_ie_encapsulate(ie);
+void wps_free_pending_msgs(struct upnp_pending_message *msgs)
+	struct upnp_pending_message *p, *prev;
+	p = msgs;
+	while (p) {
+		prev = p;
+		p = p->next;
+		wpabuf_free(prev->msg);
+		os_free(prev);
+int wps_attr_text(struct wpabuf *data, char *buf, char *end)
+	char *pos = buf;
+	int ret;
+	if (wps_parse_msg(data, &attr) < 0)
+		return -1;
+	if (attr.wps_state) {
+		if (*attr.wps_state == WPS_STATE_NOT_CONFIGURED)
+			ret = os_snprintf(pos, end - pos,
+					  "wps_state=unconfigured\n");
+		else if (*attr.wps_state == WPS_STATE_CONFIGURED)
+					  "wps_state=configured\n");
+		else
+			ret = 0;
+		if (os_snprintf_error(end - pos, ret))
+			return pos - buf;
+		pos += ret;
+	if (attr.ap_setup_locked && *attr.ap_setup_locked) {
+				  "wps_ap_setup_locked=1\n");
+			return pos - buf;
+		pos += ret;
+	if (attr.selected_registrar && *attr.selected_registrar) {
+				  "wps_selected_registrar=1\n");
+			return pos - buf;
+		pos += ret;
+	if (attr.dev_password_id) {
+				  "wps_device_password_id=%u\n",
+				  WPA_GET_BE16(attr.dev_password_id));
+			return pos - buf;
+		pos += ret;
+	if (attr.sel_reg_config_methods) {
+				  "wps_selected_registrar_config_methods="
+				  "0x%04x\n",
+				  WPA_GET_BE16(attr.sel_reg_config_methods));
+			return pos - buf;
+		pos += ret;
+	if (attr.primary_dev_type) {
+		char devtype[WPS_DEV_TYPE_BUFSIZE];
+				  "wps_primary_device_type=%s\n",
+				  wps_dev_type_bin2str(attr.primary_dev_type,
+						       devtype,
+						       sizeof(devtype)));
+			return pos - buf;
+		pos += ret;
+	if (attr.dev_name) {
+		char *str = os_malloc(attr.dev_name_len + 1);
+		size_t i;
+		if (str == NULL)
+			return pos - buf;
+		for (i = 0; i < attr.dev_name_len; i++) {
+			if (attr.dev_name[i] == 0 ||
+			    is_ctrl_char(attr.dev_name[i]))
+				str[i] = '_';
+			else
+				str[i] = attr.dev_name[i];
+		str[i] = '\0';
+		ret = os_snprintf(pos, end - pos, "wps_device_name=%s\n", str);
+		os_free(str);
+			return pos - buf;
+		pos += ret;
+	if (attr.config_methods) {
+				  "wps_config_methods=0x%04x\n",
+				  WPA_GET_BE16(attr.config_methods));
+			return pos - buf;
+		pos += ret;
+	return pos - buf;
+const char * wps_ei_str(enum wps_error_indication ei)
+	switch (ei) {
+	case WPS_EI_NO_ERROR:
+		return "No Error";
+	case WPS_EI_SECURITY_TKIP_ONLY_PROHIBITED:
+		return "TKIP Only Prohibited";
+	case WPS_EI_SECURITY_WEP_PROHIBITED:
+		return "WEP Prohibited";
+	case WPS_EI_AUTH_FAILURE:
+		return "Authentication Failure";
+	default:
+		return "Unknown";
diff --git a/freebsd/contrib/wpa/src/wps/wps.h b/freebsd/contrib/wpa/src/wps/wps.h
new file mode 100644
index 00000000000..2c91d1678c1
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps.h
@@ -0,0 +1,1041 @@
+ * Copyright (c) 2007-2013, Jouni Malinen <j at w1.fi>
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#ifndef WPS_H
+#define WPS_H
+#include "wps_defs.h"
+ * enum wsc_op_code - EAP-WSC OP-Code values
+enum wsc_op_code {
+	WSC_UPnP = 0 /* No OP Code in UPnP transport */,
+	WSC_Start = 0x01,
+	WSC_ACK = 0x02,
+	WSC_NACK = 0x03,
+	WSC_MSG = 0x04,
+	WSC_Done = 0x05,
+	WSC_FRAG_ACK = 0x06
+struct wps_registrar;
+struct upnp_wps_device_sm;
+struct wps_er;
+struct wps_parse_attr;
+ * struct wps_credential - WPS Credential
+ * @ssid: SSID
+ * @ssid_len: Length of SSID
+ * @auth_type: Authentication Type (WPS_AUTH_OPEN, .. flags)
+ * @encr_type: Encryption Type (WPS_ENCR_NONE, .. flags)
+ * @key_idx: Key index
+ * @key: Key
+ * @key_len: Key length in octets
+ * @mac_addr: MAC address of the Credential receiver
+ * @cred_attr: Unparsed Credential attribute data (used only in cred_cb());
+ *	this may be %NULL, if not used
+ * @cred_attr_len: Length of cred_attr in octets
+struct wps_credential {
+	u8 ssid[SSID_MAX_LEN];
+	size_t ssid_len;
+	u16 auth_type;
+	u16 encr_type;
+	u8 key_idx;
+	u8 key[64];
+	size_t key_len;
+	u8 mac_addr[ETH_ALEN];
+	const u8 *cred_attr;
+	size_t cred_attr_len;
+#define WPS_DEV_TYPE_LEN 8
+#define WPS_DEV_TYPE_BUFSIZE 21
+#define WPS_SEC_DEV_TYPE_MAX_LEN 128
+/* maximum number of advertised WPS vendor extension attributes */
+#define MAX_WPS_VENDOR_EXTENSIONS 10
+/* maximum size of WPS Vendor extension attribute */
+#define WPS_MAX_VENDOR_EXT_LEN 1024
+/* maximum number of parsed WPS vendor extension attributes */
+#define MAX_WPS_PARSE_VENDOR_EXT 10
+ * struct wps_device_data - WPS Device Data
+ * @mac_addr: Device MAC address
+ * @device_name: Device Name (0..32 octets encoded in UTF-8)
+ * @manufacturer: Manufacturer (0..64 octets encoded in UTF-8)
+ * @model_name: Model Name (0..32 octets encoded in UTF-8)
+ * @model_number: Model Number (0..32 octets encoded in UTF-8)
+ * @serial_number: Serial Number (0..32 octets encoded in UTF-8)
+ * @pri_dev_type: Primary Device Type
+ * @sec_dev_type: Array of secondary device types
+ * @num_sec_dev_type: Number of secondary device types
+ * @os_version: OS Version
+ * @rf_bands: RF bands (WPS_RF_24GHZ, WPS_RF_50GHZ, WPS_RF_60GHZ flags)
+ * @p2p: Whether the device is a P2P device
+struct wps_device_data {
+	char *device_name;
+	char *manufacturer;
+	char *model_name;
+	char *model_number;
+	char *serial_number;
+	u8 pri_dev_type[WPS_DEV_TYPE_LEN];
+#define WPS_SEC_DEVICE_TYPES 5
+	u8 sec_dev_type[WPS_SEC_DEVICE_TYPES][WPS_DEV_TYPE_LEN];
+	u8 num_sec_dev_types;
+	u32 os_version;
+	u8 rf_bands;
+	u16 config_methods;
+	struct wpabuf *vendor_ext_m1;
+	struct wpabuf *vendor_ext[MAX_WPS_VENDOR_EXTENSIONS];
+	int p2p;
+ * struct wps_config - WPS configuration for a single registration protocol run
+struct wps_config {
+	 * wps - Pointer to long term WPS context
+	struct wps_context *wps;
+	 * registrar - Whether this end is a Registrar
+	int registrar;
+	 * pin - Enrollee Device Password (%NULL for Registrar or PBC)
+	const u8 *pin;
+	 * pin_len - Length on pin in octets
+	size_t pin_len;
+	 * pbc - Whether this is protocol run uses PBC
+	int pbc;
+	 * assoc_wps_ie: (Re)AssocReq WPS IE (in AP; %NULL if not AP)
+	const struct wpabuf *assoc_wps_ie;
+	 * new_ap_settings - New AP settings (%NULL if not used)
+	 * This parameter provides new AP settings when using a wireless
+	 * stations as a Registrar to configure the AP. %NULL means that AP
+	 * will not be reconfigured, i.e., the station will only learn the
+	 * current AP settings by using AP PIN.
+	const struct wps_credential *new_ap_settings;
+	 * peer_addr: MAC address of the peer in AP; %NULL if not AP
+	const u8 *peer_addr;
+	 * use_psk_key - Use PSK format key in Credential
+	 * Force PSK format to be used instead of ASCII passphrase when
+	 * building Credential for an Enrollee. The PSK value is set in
+	 * struct wpa_context::psk.
+	int use_psk_key;
+	 * dev_pw_id - Device Password ID for Enrollee when PIN is used
+	u16 dev_pw_id;
+	 * p2p_dev_addr - P2P Device Address from (Re)Association Request
+	 * On AP/GO, this is set to the P2P Device Address of the associating
+	 * P2P client if a P2P IE is included in the (Re)Association Request
+	 * frame and the P2P Device Address is included. Otherwise, this is set
+	 * to %NULL to indicate the station does not have a P2P Device Address.
+	const u8 *p2p_dev_addr;
+	 * pbc_in_m1 - Do not remove PushButton config method in M1 (AP)
+	 * This can be used to enable a workaround to allow Windows 7 to use
+	 * PBC with the AP.
+	int pbc_in_m1;
+	 * peer_pubkey_hash - Peer public key hash or %NULL if not known
+	const u8 *peer_pubkey_hash;
+struct wps_data * wps_init(const struct wps_config *cfg);
+void wps_deinit(struct wps_data *data);
+ * enum wps_process_res - WPS message processing result
+enum wps_process_res {
+	 * WPS_DONE - Processing done
+	WPS_DONE,
+	 * WPS_CONTINUE - Processing continues
+	WPS_CONTINUE,
+	 * WPS_FAILURE - Processing failed
+	WPS_FAILURE,
+	 * WPS_PENDING - Processing continues, but waiting for an external
+	 *	event (e.g., UPnP message from an external Registrar)
+	WPS_PENDING
+				     const struct wpabuf *msg);
+struct wpabuf * wps_get_msg(struct wps_data *wps, enum wsc_op_code *op_code);
+int wps_is_selected_pbc_registrar(const struct wpabuf *msg);
+int wps_is_selected_pin_registrar(const struct wpabuf *msg);
+			   const struct wpabuf *wps_b);
+			   int ver1_compat);
+const u8 * wps_get_uuid_e(const struct wpabuf *msg);
+int wps_is_20(const struct wpabuf *msg);
+struct wpabuf * wps_build_assoc_req_ie(enum wps_request_type req_type);
+struct wpabuf * wps_build_assoc_resp_ie(void);
+				       const u8 *uuid,
+				       const u8 *req_dev_types);
+ * struct wps_registrar_config - WPS Registrar configuration
+struct wps_registrar_config {
+	 * new_psk_cb - Callback for new PSK
+	 * @ctx: Higher layer context data (cb_ctx)
+	 * @mac_addr: MAC address of the Enrollee
+	 * @p2p_dev_addr: P2P Device Address of the Enrollee or all zeros if not
+	 * @psk: The new PSK
+	 * @psk_len: The length of psk in octets
+	 * Returns: 0 on success, -1 on failure
+	 * This callback is called when a new per-device PSK is provisioned.
+	int (*new_psk_cb)(void *ctx, const u8 *mac_addr, const u8 *p2p_dev_addr,
+			  const u8 *psk, size_t psk_len);
+	 * set_ie_cb - Callback for WPS IE changes
+	 * @beacon_ie: WPS IE for Beacon
+	 * @probe_resp_ie: WPS IE for Probe Response
+	 * This callback is called whenever the WPS IE in Beacon or Probe
+	 * Response frames needs to be changed (AP only). Callee is responsible
+	 * for freeing the buffers.
+	int (*set_ie_cb)(void *ctx, struct wpabuf *beacon_ie,
+			 struct wpabuf *probe_resp_ie);
+	 * pin_needed_cb - Callback for requesting a PIN
+	 * @uuid_e: UUID-E of the unknown Enrollee
+	 * @dev: Device Data from the unknown Enrollee
+	 * This callback is called whenever an unknown Enrollee requests to use
+	 * PIN method and a matching PIN (Device Password) is not found in
+	 * Registrar data.
+	void (*pin_needed_cb)(void *ctx, const u8 *uuid_e,
+			      const struct wps_device_data *dev);
+	 * reg_success_cb - Callback for reporting successful registration
+	 * @uuid_e: UUID-E of the Enrollee
+	 * @dev_pw: Device Password (PIN) used during registration
+	 * @dev_pw_len: Length of dev_pw in octets
+	 * This callback is called whenever an Enrollee completes registration
+	 * successfully.
+	void (*reg_success_cb)(void *ctx, const u8 *mac_addr,
+			       const u8 *uuid_e, const u8 *dev_pw,
+			       size_t dev_pw_len);
+	 * set_sel_reg_cb - Callback for reporting selected registrar changes
+	 * @sel_reg: Whether the Registrar is selected
+	 * @dev_passwd_id: Device Password ID to indicate with method or
+	 *	specific password the Registrar intends to use
+	 * @sel_reg_config_methods: Bit field of active config methods
+	 * This callback is called whenever the Selected Registrar state
+	 * changes (e.g., a new PIN becomes available or PBC is invoked). This
+	 * callback is only used by External Registrar implementation;
+	 * set_ie_cb() is used by AP implementation in similar caes, but it
+	 * provides the full WPS IE data instead of just the minimal Registrar
+	 * state information.
+	void (*set_sel_reg_cb)(void *ctx, int sel_reg, u16 dev_passwd_id,
+			       u16 sel_reg_config_methods);
+	 * enrollee_seen_cb - Callback for reporting Enrollee based on ProbeReq
+	 * @addr: MAC address of the Enrollee
+	 * @uuid_e: UUID of the Enrollee
+	 * @pri_dev_type: Primary device type
+	 * @config_methods: Config Methods
+	 * @dev_password_id: Device Password ID
+	 * @request_type: Request Type
+	 * @dev_name: Device Name (if available)
+	void (*enrollee_seen_cb)(void *ctx, const u8 *addr, const u8 *uuid_e,
+				 const u8 *pri_dev_type, u16 config_methods,
+				 u16 dev_password_id, u8 request_type,
+				 const char *dev_name);
+	 * cb_ctx: Higher layer context data for Registrar callbacks
+	void *cb_ctx;
+	 * skip_cred_build: Do not build credential
+	 * This option can be used to disable internal code that builds
+	 * Credential attribute into M8 based on the current network
+	 * configuration and Enrollee capabilities. The extra_cred data will
+	 * then be used as the Credential(s).
+	int skip_cred_build;
+	 * extra_cred: Additional Credential attribute(s)
+	 * This optional data (set to %NULL to disable) can be used to add
+	 * Credential attribute(s) for other networks into M8. If
+	 * skip_cred_build is set, this will also override the automatically
+	 * generated Credential attribute.
+	const u8 *extra_cred;
+	 * extra_cred_len: Length of extra_cred in octets
+	size_t extra_cred_len;
+	 * disable_auto_conf - Disable auto-configuration on first registration
+	 * By default, the AP that is started in not configured state will
+	 * generate a random PSK and move to configured state when the first
+	 * registration protocol run is completed successfully. This option can
+	 * be used to disable this functionality and leave it up to an external
+	 * program to take care of configuration. This requires the extra_cred
+	 * to be set with a suitable Credential and skip_cred_build being used.
+	int disable_auto_conf;
+	 * static_wep_only - Whether the BSS supports only static WEP
+	int static_wep_only;
+	 * dualband - Whether this is a concurrent dualband AP
+	int dualband;
+	 * force_per_enrollee_psk - Force per-Enrollee random PSK
+	 * This forces per-Enrollee random PSK to be generated even if a default
+	 * PSK is set for a network.
+	int force_per_enrollee_psk;
+ * enum wps_event - WPS event types
+enum wps_event {
+	 * WPS_EV_M2D - M2D received (Registrar did not know us)
+	WPS_EV_M2D,
+	 * WPS_EV_FAIL - Registration failed
+	WPS_EV_FAIL,
+	 * WPS_EV_SUCCESS - Registration succeeded
+	WPS_EV_SUCCESS,
+	 * WPS_EV_PWD_AUTH_FAIL - Password authentication failed
+	WPS_EV_PWD_AUTH_FAIL,
+	 * WPS_EV_PBC_OVERLAP - PBC session overlap detected
+	WPS_EV_PBC_OVERLAP,
+	 * WPS_EV_PBC_TIMEOUT - PBC walktime expired before protocol run start
+	WPS_EV_PBC_TIMEOUT,
+	 * WPS_EV_PBC_ACTIVE - PBC mode was activated
+	WPS_EV_PBC_ACTIVE,
+	 * WPS_EV_PBC_DISABLE - PBC mode was disabled
+	WPS_EV_PBC_DISABLE,
+	 * WPS_EV_ER_AP_ADD - ER: AP added
+	WPS_EV_ER_AP_ADD,
+	 * WPS_EV_ER_AP_REMOVE - ER: AP removed
+	WPS_EV_ER_AP_REMOVE,
+	 * WPS_EV_ER_ENROLLEE_ADD - ER: Enrollee added
+	WPS_EV_ER_ENROLLEE_ADD,
+	 * WPS_EV_ER_ENROLLEE_REMOVE - ER: Enrollee removed
+	WPS_EV_ER_ENROLLEE_REMOVE,
+	 * WPS_EV_ER_AP_SETTINGS - ER: AP Settings learned
+	WPS_EV_ER_AP_SETTINGS,
+	 * WPS_EV_ER_SET_SELECTED_REGISTRAR - ER: SetSelectedRegistrar event
+	WPS_EV_ER_SET_SELECTED_REGISTRAR,
+	 * WPS_EV_AP_PIN_SUCCESS - External Registrar used correct AP PIN
+	WPS_EV_AP_PIN_SUCCESS
+ * union wps_event_data - WPS event data
+union wps_event_data {
+	 * struct wps_event_m2d - M2D event data
+	struct wps_event_m2d {
+		const u8 *manufacturer;
+		size_t manufacturer_len;
+		const u8 *model_name;
+		size_t model_name_len;
+		const u8 *model_number;
+		size_t model_number_len;
+		const u8 *serial_number;
+		size_t serial_number_len;
+		const u8 *dev_name;
+		size_t dev_name_len;
+		const u8 *primary_dev_type; /* 8 octets */
+		u16 config_error;
+		u16 dev_password_id;
+	} m2d;
+	 * struct wps_event_fail - Registration failure information
+	 * @msg: enum wps_msg_type
+	struct wps_event_fail {
+		int msg;
+		u16 config_error;
+		u16 error_indication;
+		u8 peer_macaddr[ETH_ALEN];
+	} fail;
+	struct wps_event_success {
+	} success;
+	struct wps_event_pwd_auth_fail {
+		int enrollee;
+		int part;
+	} pwd_auth_fail;
+	struct wps_event_er_ap {
+		const u8 *uuid;
+		const u8 *mac_addr;
+		const char *friendly_name;
+		const char *manufacturer;
+		const char *manufacturer_url;
+		const char *model_description;
+		const char *model_name;
+		const char *model_number;
+		const char *model_url;
+		const char *serial_number;
+		const char *upc;
+		const u8 *pri_dev_type;
+		u8 wps_state;
+	} ap;
+	struct wps_event_er_enrollee {
+		const u8 *uuid;
+		int m1_received;
+		u16 dev_passwd_id;
+		const char *dev_name;
+	} enrollee;
+	struct wps_event_er_ap_settings {
+		const u8 *uuid;
+		const struct wps_credential *cred;
+	} ap_settings;
+	struct wps_event_er_set_selected_registrar {
+		const u8 *uuid;
+		int sel_reg;
+		u16 sel_reg_config_methods;
+		enum {
+			WPS_ER_SET_SEL_REG_START,
+			WPS_ER_SET_SEL_REG_DONE,
+			WPS_ER_SET_SEL_REG_FAILED
+		} state;
+	} set_sel_reg;
+ * struct upnp_pending_message - Pending PutWLANResponse messages
+ * @next: Pointer to next pending message or %NULL
+ * @addr: NewWLANEventMAC
+ * @msg: NewMessage
+ * @type: Message Type
+struct upnp_pending_message {
+	struct upnp_pending_message *next;
+	u8 addr[ETH_ALEN];
+	struct wpabuf *msg;
+	enum wps_msg_type type;
+ * struct wps_context - Long term WPS context data
+ * This data is stored at the higher layer Authenticator or Supplicant data
+ * structures and it is maintained over multiple registration protocol runs.
+struct wps_context {
+	 * ap - Whether the local end is an access point
+	int ap;
+	 * registrar - Pointer to WPS registrar data from wps_registrar_init()
+	struct wps_registrar *registrar;
+	 * wps_state - Current WPS state
+	enum wps_state wps_state;
+	 * ap_setup_locked - Whether AP setup is locked (only used at AP)
+	int ap_setup_locked;
+	 * uuid - Own UUID
+	u8 uuid[16];
+	 * ssid - SSID
+	 * This SSID is used by the Registrar to fill in information for
+	 * Credentials. In addition, AP uses it when acting as an Enrollee to
+	 * notify Registrar of the current configuration.
+	 * ssid_len - Length of ssid in octets
+	size_t ssid_len;
+	 * dev - Own WPS device data
+	struct wps_device_data dev;
+	 * dh_ctx - Context data for Diffie-Hellman operation
+	void *dh_ctx;
+	 * dh_privkey - Diffie-Hellman private key
+	struct wpabuf *dh_privkey;
+	 * dh_pubkey_oob - Diffie-Hellman public key
+	struct wpabuf *dh_pubkey;
+	 * config_methods - Enabled configuration methods
+	 * Bit field of WPS_CONFIG_*
+	 * encr_types - Enabled encryption types (bit field of WPS_ENCR_*)
+	u16 encr_types;
+	 * auth_types - Authentication types (bit field of WPS_AUTH_*)
+	u16 auth_types;
+	 * encr_types - Current AP encryption type (WPS_ENCR_*)
+	u16 ap_encr_type;
+	 * ap_auth_type - Current AP authentication types (WPS_AUTH_*)
+	u16 ap_auth_type;
+	 * network_key - The current Network Key (PSK) or %NULL to generate new
+	 * If %NULL, Registrar will generate per-device PSK. In addition, AP
+	 * uses this when acting as an Enrollee to notify Registrar of the
+	 * current configuration.
+	 * When using WPA/WPA2-Person, this key can be either the ASCII
+	 * passphrase (8..63 characters) or the 32-octet PSK (64 hex
+	 * characters). When this is set to the ASCII passphrase, the PSK can
+	 * be provided in the psk buffer and used per-Enrollee to control which
+	 * key type is included in the Credential (e.g., to reduce calculation
+	 * need on low-powered devices by provisioning PSK while still allowing
+	 * other devices to get the passphrase).
+	u8 *network_key;
+	 * network_key_len - Length of network_key in octets
+	size_t network_key_len;
+	 * psk - The current network PSK
+	 * This optional value can be used to provide the current PSK if
+	 * network_key is set to the ASCII passphrase.
+	u8 psk[32];
+	 * psk_set - Whether psk value is set
+	int psk_set;
+	 * ap_settings - AP Settings override for M7 (only used at AP)
+	 * If %NULL, AP Settings attributes will be generated based on the
+	 * current network configuration.
+	u8 *ap_settings;
+	 * ap_settings_len - Length of ap_settings in octets
+	size_t ap_settings_len;
+	 * friendly_name - Friendly Name (required for UPnP)
+	char *friendly_name;
+	 * manufacturer_url - Manufacturer URL (optional for UPnP)
+	char *manufacturer_url;
+	 * model_description - Model Description (recommended for UPnP)
+	char *model_description;
+	 * model_url - Model URL (optional for UPnP)
+	char *model_url;
+	 * upc - Universal Product Code (optional for UPnP)
+	char *upc;
+	 * cred_cb - Callback to notify that new Credentials were received
+	 * @cred: The received Credential
+	 * Return: 0 on success, -1 on failure
+	int (*cred_cb)(void *ctx, const struct wps_credential *cred);
+	 * event_cb - Event callback (state information about progress)
+	 * @event: Event type
+	 * @data: Event data
+	void (*event_cb)(void *ctx, enum wps_event event,
+			 union wps_event_data *data);
+	 * rf_band_cb - Fetch currently used RF band
+	 * Return: Current used RF band or 0 if not known
+	int (*rf_band_cb)(void *ctx);
+	 * cb_ctx: Higher layer context data for callbacks
+	void *cb_ctx;
+	struct upnp_wps_device_sm *wps_upnp;
+	/* Pending messages from UPnP PutWLANResponse */
+	struct upnp_pending_message *upnp_msgs;
+	u16 ap_nfc_dev_pw_id;
+	struct wpabuf *ap_nfc_dh_pubkey;
+	struct wpabuf *ap_nfc_dh_privkey;
+	struct wpabuf *ap_nfc_dev_pw;
+struct wps_registrar *
+wps_registrar_init(struct wps_context *wps,
+		   const struct wps_registrar_config *cfg);
+void wps_registrar_deinit(struct wps_registrar *reg);
+int wps_registrar_add_pin(struct wps_registrar *reg, const u8 *addr,
+			  const u8 *uuid, const u8 *pin, size_t pin_len,
+			  int timeout);
+int wps_registrar_invalidate_pin(struct wps_registrar *reg, const u8 *uuid);
+int wps_registrar_wps_cancel(struct wps_registrar *reg);
+int wps_registrar_unlock_pin(struct wps_registrar *reg, const u8 *uuid);
+int wps_registrar_button_pushed(struct wps_registrar *reg,
+				const u8 *p2p_dev_addr);
+void wps_registrar_complete(struct wps_registrar *registrar, const u8 *uuid_e,
+			    const u8 *dev_pw, size_t dev_pw_len);
+void wps_registrar_probe_req_rx(struct wps_registrar *reg, const u8 *addr,
+				const struct wpabuf *wps_data,
+				int p2p_wildcard);
+int wps_registrar_update_ie(struct wps_registrar *reg);
+int wps_registrar_get_info(struct wps_registrar *reg, const u8 *addr,
+			   char *buf, size_t buflen);
+int wps_registrar_config_ap(struct wps_registrar *reg,
+			    struct wps_credential *cred);
+int wps_registrar_add_nfc_pw_token(struct wps_registrar *reg,
+				   const u8 *pubkey_hash, u16 pw_id,
+				   const u8 *dev_pw, size_t dev_pw_len,
+				   int pk_hash_provided_oob);
+int wps_registrar_add_nfc_password_token(struct wps_registrar *reg,
+					 const u8 *oob_dev_pw,
+					 size_t oob_dev_pw_len);
+void wps_registrar_flush(struct wps_registrar *reg);
+int wps_build_credential_wrap(struct wpabuf *msg,
+			      const struct wps_credential *cred);
+unsigned int wps_pin_checksum(unsigned int pin);
+unsigned int wps_pin_valid(unsigned int pin);
+unsigned int wps_generate_pin(void);
+int wps_pin_str_valid(const char *pin);
+void wps_free_pending_msgs(struct upnp_pending_message *msgs);
+struct wpabuf * wps_get_oob_cred(struct wps_context *wps, int rf_band,
+				 int channel);
+int wps_oob_use_cred(struct wps_context *wps, struct wps_parse_attr *attr);
+int wps_attr_text(struct wpabuf *data, char *buf, char *end);
+const char * wps_ei_str(enum wps_error_indication ei);
+struct wps_er * wps_er_init(struct wps_context *wps, const char *ifname,
+			    const char *filter);
+void wps_er_refresh(struct wps_er *er);
+void wps_er_deinit(struct wps_er *er, void (*cb)(void *ctx), void *ctx);
+void wps_er_set_sel_reg(struct wps_er *er, int sel_reg, u16 dev_passwd_id,
+int wps_er_pbc(struct wps_er *er, const u8 *uuid, const u8 *addr);
+const u8 * wps_er_get_sta_uuid(struct wps_er *er, const u8 *addr);
+int wps_er_learn(struct wps_er *er, const u8 *uuid, const u8 *addr,
+		 const u8 *pin, size_t pin_len);
+int wps_er_set_config(struct wps_er *er, const u8 *uuid, const u8 *addr,
+int wps_er_config(struct wps_er *er, const u8 *uuid, const u8 *addr,
+		  const u8 *pin, size_t pin_len,
+struct wpabuf * wps_er_config_token_from_cred(struct wps_context *wps,
+struct wpabuf * wps_er_nfc_config_token(struct wps_er *er, const u8 *uuid,
+					const u8 *addr);
+struct wpabuf * wps_er_nfc_handover_sel(struct wps_er *er,
+					struct wps_context *wps, const u8 *uuid,
+					const u8 *addr, struct wpabuf *pubkey);
+int wps_dev_type_str2bin(const char *str, u8 dev_type[WPS_DEV_TYPE_LEN]);
+char * wps_dev_type_bin2str(const u8 dev_type[WPS_DEV_TYPE_LEN], char *buf,
+			    size_t buf_len);
+void uuid_gen_mac_addr(const u8 *mac_addr, u8 *uuid);
+u16 wps_config_methods_str2bin(const char *str);
+struct wpabuf * wps_build_nfc_pw_token(u16 dev_pw_id,
+				       const struct wpabuf *pubkey,
+				       const struct wpabuf *dev_pw);
+struct wpabuf * wps_nfc_token_build(int ndef, int id, struct wpabuf *pubkey,
+				    struct wpabuf *dev_pw);
+int wps_nfc_gen_dh(struct wpabuf **pubkey, struct wpabuf **privkey);
+struct wpabuf * wps_nfc_token_gen(int ndef, int *id, struct wpabuf **pubkey,
+				  struct wpabuf **privkey,
+				  struct wpabuf **dev_pw);
+struct wpabuf * wps_build_nfc_handover_req(struct wps_context *ctx,
+					   struct wpabuf *nfc_dh_pubkey);
+struct wpabuf * wps_build_nfc_handover_sel(struct wps_context *ctx,
+					   struct wpabuf *nfc_dh_pubkey,
+					   const u8 *bssid, int freq);
+struct wpabuf * wps_build_nfc_handover_req_p2p(struct wps_context *ctx,
+struct wpabuf * wps_build_nfc_handover_sel_p2p(struct wps_context *ctx,
+					       int nfc_dev_pw_id,
+					       struct wpabuf *nfc_dev_pw);
+/* ndef.c */
+struct wpabuf * ndef_parse_wifi(const struct wpabuf *buf);
+struct wpabuf * ndef_build_wifi(const struct wpabuf *buf);
+struct wpabuf * ndef_parse_p2p(const struct wpabuf *buf);
+struct wpabuf * ndef_build_p2p(const struct wpabuf *buf);
+int wps_validate_beacon(const struct wpabuf *wps_ie);
+int wps_validate_beacon_probe_resp(const struct wpabuf *wps_ie, int probe,
+				   const u8 *addr);
+int wps_validate_probe_req(const struct wpabuf *wps_ie, const u8 *addr);
+int wps_validate_assoc_req(const struct wpabuf *wps_ie);
+int wps_validate_assoc_resp(const struct wpabuf *wps_ie);
+int wps_validate_m1(const struct wpabuf *tlvs);
+int wps_validate_m2(const struct wpabuf *tlvs);
+int wps_validate_m2d(const struct wpabuf *tlvs);
+int wps_validate_m3(const struct wpabuf *tlvs);
+int wps_validate_m4(const struct wpabuf *tlvs);
+int wps_validate_m4_encr(const struct wpabuf *tlvs, int wps2);
+int wps_validate_m5(const struct wpabuf *tlvs);
+int wps_validate_m5_encr(const struct wpabuf *tlvs, int wps2);
+int wps_validate_m6(const struct wpabuf *tlvs);
+int wps_validate_m6_encr(const struct wpabuf *tlvs, int wps2);
+int wps_validate_m7(const struct wpabuf *tlvs);
+int wps_validate_m7_encr(const struct wpabuf *tlvs, int ap, int wps2);
+int wps_validate_m8(const struct wpabuf *tlvs);
+int wps_validate_m8_encr(const struct wpabuf *tlvs, int ap, int wps2);
+int wps_validate_wsc_ack(const struct wpabuf *tlvs);
+int wps_validate_wsc_nack(const struct wpabuf *tlvs);
+int wps_validate_wsc_done(const struct wpabuf *tlvs);
+int wps_validate_upnp_set_selected_registrar(const struct wpabuf *tlvs);
+#else /* CONFIG_WPS_STRICT */
+static inline int wps_validate_beacon(const struct wpabuf *wps_ie){
+	return 0;
+static inline int wps_validate_beacon_probe_resp(const struct wpabuf *wps_ie,
+						 int probe, const u8 *addr)
+	return 0;
+static inline int wps_validate_probe_req(const struct wpabuf *wps_ie,
+					 const u8 *addr)
+	return 0;
+static inline int wps_validate_assoc_req(const struct wpabuf *wps_ie)
+	return 0;
+static inline int wps_validate_assoc_resp(const struct wpabuf *wps_ie)
+	return 0;
+static inline int wps_validate_m1(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m2(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m2d(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m3(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m4(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m4_encr(const struct wpabuf *tlvs, int wps2)
+	return 0;
+static inline int wps_validate_m5(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m5_encr(const struct wpabuf *tlvs, int wps2)
+	return 0;
+static inline int wps_validate_m6(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m6_encr(const struct wpabuf *tlvs, int wps2)
+	return 0;
+static inline int wps_validate_m7(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m7_encr(const struct wpabuf *tlvs, int ap,
+				       int wps2)
+	return 0;
+static inline int wps_validate_m8(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_m8_encr(const struct wpabuf *tlvs, int ap,
+				       int wps2)
+	return 0;
+static inline int wps_validate_wsc_ack(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_wsc_nack(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_wsc_done(const struct wpabuf *tlvs)
+	return 0;
+static inline int wps_validate_upnp_set_selected_registrar(
+	const struct wpabuf *tlvs)
+	return 0;
+#endif /* WPS_H */
diff --git a/freebsd/contrib/wpa/src/wps/wps_attr_build.c b/freebsd/contrib/wpa/src/wps/wps_attr_build.c
index 00000000000..742e082c298
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps_attr_build.c
@@ -0,0 +1,487 @@
+ * Wi-Fi Protected Setup - attribute building
+ * Copyright (c) 2008, Jouni Malinen <j at w1.fi>
+#include "crypto/aes_wrap.h"
+#include "crypto/crypto.h"
+#include "crypto/sha256.h"
+#include "crypto/random.h"
+#include "wps_i.h"
+int wps_build_public_key(struct wps_data *wps, struct wpabuf *msg)
+	struct wpabuf *pubkey;
+	wpa_printf(MSG_DEBUG, "WPS:  * Public Key");
+	wpabuf_free(wps->dh_privkey);
+	wps->dh_privkey = NULL;
+	if (wps->dev_pw_id != DEV_PW_DEFAULT && wps->wps->dh_privkey &&
+	    wps->wps->dh_ctx) {
+		wpa_printf(MSG_DEBUG, "WPS: Using pre-configured DH keys");
+		if (wps->wps->dh_pubkey == NULL) {
+				   "WPS: wps->wps->dh_pubkey == NULL");
+			return -1;
+		wps->dh_privkey = wpabuf_dup(wps->wps->dh_privkey);
+		wps->dh_ctx = wps->wps->dh_ctx;
+		wps->wps->dh_ctx = NULL;
+		pubkey = wpabuf_dup(wps->wps->dh_pubkey);
+	} else if ((wps->dev_pw_id >= 0x10 ||
+		    wps->dev_pw_id == DEV_PW_NFC_CONNECTION_HANDOVER) &&
+		   (wps->wps->ap ||
+		    (wps->wps->ap_nfc_dh_pubkey &&
+		     wps->wps->ap_nfc_dev_pw_id ==
+		     DEV_PW_NFC_CONNECTION_HANDOVER &&
+		     wps->dev_pw_id == DEV_PW_NFC_CONNECTION_HANDOVER)) &&
+		   (wps->dev_pw_id == wps->wps->ap_nfc_dev_pw_id ||
+		    wps->wps->ap_nfc_dh_pubkey)) {
+		wpa_printf(MSG_DEBUG, "WPS: Using NFC password token DH keys");
+		if (wps->wps->ap_nfc_dh_privkey == NULL) {
+				   "WPS: wps->wps->ap_nfc_dh_privkey == NULL");
+			return -1;
+		if (wps->wps->ap_nfc_dh_pubkey == NULL) {
+				   "WPS: wps->wps->ap_nfc_dh_pubkey == NULL");
+			return -1;
+		wps->dh_privkey = wpabuf_dup(wps->wps->ap_nfc_dh_privkey);
+		pubkey = wpabuf_dup(wps->wps->ap_nfc_dh_pubkey);
+		wps->dh_ctx = dh5_init_fixed(wps->dh_privkey, pubkey);
+	} else {
+		wpa_printf(MSG_DEBUG, "WPS: Generate new DH keys");
+		dh5_free(wps->dh_ctx);
+		wps->dh_ctx = dh5_init(&wps->dh_privkey, &pubkey);
+		pubkey = wpabuf_zeropad(pubkey, 192);
+	if (wps->dh_ctx == NULL || wps->dh_privkey == NULL || pubkey == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Failed to initialize "
+			   "Diffie-Hellman handshake");
+		wpabuf_free(pubkey);
+		return -1;
+	wpa_hexdump_buf_key(MSG_DEBUG, "WPS: DH Private Key", wps->dh_privkey);
+	wpa_hexdump_buf(MSG_DEBUG, "WPS: DH own Public Key", pubkey);
+	wpabuf_put_be16(msg, ATTR_PUBLIC_KEY);
+	wpabuf_put_be16(msg, wpabuf_len(pubkey));
+	wpabuf_put_buf(msg, pubkey);
+	if (wps->registrar) {
+		wpabuf_free(wps->dh_pubkey_r);
+		wps->dh_pubkey_r = pubkey;
+	} else {
+		wpabuf_free(wps->dh_pubkey_e);
+		wps->dh_pubkey_e = pubkey;
+	return 0;
+int wps_build_req_type(struct wpabuf *msg, enum wps_request_type type)
+	wpa_printf(MSG_DEBUG, "WPS:  * Request Type");
+	wpabuf_put_be16(msg, ATTR_REQUEST_TYPE);
+	wpabuf_put_be16(msg, 1);
+	wpabuf_put_u8(msg, type);
+	return 0;
+int wps_build_resp_type(struct wpabuf *msg, enum wps_response_type type)
+	wpa_printf(MSG_DEBUG, "WPS:  * Response Type (%d)", type);
+	wpabuf_put_be16(msg, ATTR_RESPONSE_TYPE);
+	return 0;
+int wps_build_config_methods(struct wpabuf *msg, u16 methods)
+	wpa_printf(MSG_DEBUG, "WPS:  * Config Methods (%x)", methods);
+	wpabuf_put_be16(msg, ATTR_CONFIG_METHODS);
+	wpabuf_put_be16(msg, 2);
+	wpabuf_put_be16(msg, methods);
+	return 0;
+int wps_build_uuid_e(struct wpabuf *msg, const u8 *uuid)
+	if (wpabuf_tailroom(msg) < 4 + WPS_UUID_LEN)
+		return -1;
+	wpa_printf(MSG_DEBUG, "WPS:  * UUID-E");
+	wpabuf_put_be16(msg, ATTR_UUID_E);
+	wpabuf_put_be16(msg, WPS_UUID_LEN);
+	wpabuf_put_data(msg, uuid, WPS_UUID_LEN);
+	return 0;
+int wps_build_dev_password_id(struct wpabuf *msg, u16 id)
+	wpa_printf(MSG_DEBUG, "WPS:  * Device Password ID (%d)", id);
+	wpabuf_put_be16(msg, ATTR_DEV_PASSWORD_ID);
+	wpabuf_put_be16(msg, id);
+	return 0;
+int wps_build_config_error(struct wpabuf *msg, u16 err)
+	wpa_printf(MSG_DEBUG, "WPS:  * Configuration Error (%d)", err);
+	wpabuf_put_be16(msg, ATTR_CONFIG_ERROR);
+	wpabuf_put_be16(msg, err);
+	return 0;
+int wps_build_authenticator(struct wps_data *wps, struct wpabuf *msg)
+	u8 hash[SHA256_MAC_LEN];
+	const u8 *addr[2];
+	size_t len[2];
+	if (wps->last_msg == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Last message not available for "
+			   "building authenticator");
+		return -1;
+	/* Authenticator = HMAC-SHA256_AuthKey(M_prev || M_curr*)
+	 * (M_curr* is M_curr without the Authenticator attribute)
+	addr[0] = wpabuf_head(wps->last_msg);
+	len[0] = wpabuf_len(wps->last_msg);
+	addr[1] = wpabuf_head(msg);
+	len[1] = wpabuf_len(msg);
+	hmac_sha256_vector(wps->authkey, WPS_AUTHKEY_LEN, 2, addr, len, hash);
+	wpa_printf(MSG_DEBUG, "WPS:  * Authenticator");
+	wpabuf_put_be16(msg, ATTR_AUTHENTICATOR);
+	wpabuf_put_be16(msg, WPS_AUTHENTICATOR_LEN);
+	wpabuf_put_data(msg, hash, WPS_AUTHENTICATOR_LEN);
+	return 0;
+int wps_build_version(struct wpabuf *msg)
+	 * Note: This attribute is deprecated and set to hardcoded 0x10 for
+	 * backwards compatibility reasons. The real version negotiation is
+	 * done with Version2.
+	if (wpabuf_tailroom(msg) < 5)
+		return -1;
+	wpa_printf(MSG_DEBUG, "WPS:  * Version (hardcoded 0x10)");
+	wpabuf_put_be16(msg, ATTR_VERSION);
+	wpabuf_put_u8(msg, 0x10);
+	return 0;
+int wps_build_wfa_ext(struct wpabuf *msg, int req_to_enroll,
+		      const u8 *auth_macs, size_t auth_macs_count)
+	u8 *len;
+	if (WPS_VERSION == 0x10)
+		return 0;
+	    7 + 3 + (req_to_enroll ? 3 : 0) +
+	    (auth_macs ? 2 + auth_macs_count * ETH_ALEN : 0))
+		return -1;
+	wpabuf_put_be16(msg, ATTR_VENDOR_EXT);
+	len = wpabuf_put(msg, 2); /* to be filled */
+	wpabuf_put_be24(msg, WPS_VENDOR_ID_WFA);
+	wpa_printf(MSG_DEBUG, "WPS:  * Version2 (0x%x)", WPS_VERSION);
+	wpabuf_put_u8(msg, WFA_ELEM_VERSION2);
+	wpabuf_put_u8(msg, 1);
+	wpabuf_put_u8(msg, WPS_VERSION);
+	if (req_to_enroll) {
+		wpa_printf(MSG_DEBUG, "WPS:  * Request to Enroll (1)");
+		wpabuf_put_u8(msg, WFA_ELEM_REQUEST_TO_ENROLL);
+	if (auth_macs && auth_macs_count) {
+		size_t i;
+		wpa_printf(MSG_DEBUG, "WPS:  * AuthorizedMACs (count=%d)",
+			   (int) auth_macs_count);
+		wpabuf_put_u8(msg, WFA_ELEM_AUTHORIZEDMACS);
+		wpabuf_put_u8(msg, auth_macs_count * ETH_ALEN);
+		wpabuf_put_data(msg, auth_macs, auth_macs_count * ETH_ALEN);
+		for (i = 0; i < auth_macs_count; i++)
+			wpa_printf(MSG_DEBUG, "WPS:    AuthorizedMAC: " MACSTR,
+				   MAC2STR(&auth_macs[i * ETH_ALEN]));
+	WPA_PUT_BE16(len, (u8 *) wpabuf_put(msg, 0) - len - 2);
+	if (WPS_VERSION > 0x20) {
+			return -1;
+		wpa_printf(MSG_DEBUG, "WPS:  * Extensibility Testing - extra "
+			   "attribute");
+		wpabuf_put_be16(msg, ATTR_EXTENSIBILITY_TEST);
+		wpabuf_put_u8(msg, 42);
+	return 0;
+int wps_build_msg_type(struct wpabuf *msg, enum wps_msg_type msg_type)
+	wpa_printf(MSG_DEBUG, "WPS:  * Message Type (%d)", msg_type);
+	wpabuf_put_be16(msg, ATTR_MSG_TYPE);
+	wpabuf_put_u8(msg, msg_type);
+	return 0;
+int wps_build_enrollee_nonce(struct wps_data *wps, struct wpabuf *msg)
+	wpa_printf(MSG_DEBUG, "WPS:  * Enrollee Nonce");
+	wpabuf_put_be16(msg, ATTR_ENROLLEE_NONCE);
+	wpabuf_put_be16(msg, WPS_NONCE_LEN);
+	wpabuf_put_data(msg, wps->nonce_e, WPS_NONCE_LEN);
+	return 0;
+int wps_build_registrar_nonce(struct wps_data *wps, struct wpabuf *msg)
+	wpa_printf(MSG_DEBUG, "WPS:  * Registrar Nonce");
+	wpabuf_put_be16(msg, ATTR_REGISTRAR_NONCE);
+	wpabuf_put_data(msg, wps->nonce_r, WPS_NONCE_LEN);
+	return 0;
+int wps_build_auth_type_flags(struct wps_data *wps, struct wpabuf *msg)
+	u16 auth_types = WPS_AUTH_TYPES;
+	/* WPA/WPA2-Enterprise enrollment not supported through WPS */
+	auth_types &= ~WPS_AUTH_WPA;
+	auth_types &= ~WPS_AUTH_WPA2;
+	auth_types &= ~WPS_AUTH_SHARED;
+	wpa_printf(MSG_DEBUG, "WPS:  * Authentication Type Flags");
+	wpabuf_put_be16(msg, ATTR_AUTH_TYPE_FLAGS);
+	wpabuf_put_be16(msg, auth_types);
+	return 0;
+int wps_build_encr_type_flags(struct wps_data *wps, struct wpabuf *msg)
+	u16 encr_types = WPS_ENCR_TYPES;
+	encr_types &= ~WPS_ENCR_WEP;
+	wpa_printf(MSG_DEBUG, "WPS:  * Encryption Type Flags");
+	wpabuf_put_be16(msg, ATTR_ENCR_TYPE_FLAGS);
+	wpabuf_put_be16(msg, encr_types);
+	return 0;
+int wps_build_conn_type_flags(struct wps_data *wps, struct wpabuf *msg)
+	wpa_printf(MSG_DEBUG, "WPS:  * Connection Type Flags");
+	wpabuf_put_be16(msg, ATTR_CONN_TYPE_FLAGS);
+	wpabuf_put_u8(msg, WPS_CONN_ESS);
+	return 0;
+int wps_build_assoc_state(struct wps_data *wps, struct wpabuf *msg)
+	wpa_printf(MSG_DEBUG, "WPS:  * Association State");
+	wpabuf_put_be16(msg, ATTR_ASSOC_STATE);
+	wpabuf_put_be16(msg, WPS_ASSOC_NOT_ASSOC);
+	return 0;
+int wps_build_key_wrap_auth(struct wps_data *wps, struct wpabuf *msg)
+	wpa_printf(MSG_DEBUG, "WPS:  * Key Wrap Authenticator");
+	hmac_sha256(wps->authkey, WPS_AUTHKEY_LEN, wpabuf_head(msg),
+		    wpabuf_len(msg), hash);
+	wpabuf_put_be16(msg, ATTR_KEY_WRAP_AUTH);
+	wpabuf_put_be16(msg, WPS_KWA_LEN);
+	wpabuf_put_data(msg, hash, WPS_KWA_LEN);
+	return 0;
+int wps_build_encr_settings(struct wps_data *wps, struct wpabuf *msg,
+			    struct wpabuf *plain)
+	size_t pad_len;
+	const size_t block_size = 16;
+	u8 *iv, *data;
+	wpa_printf(MSG_DEBUG, "WPS:  * Encrypted Settings");
+	/* PKCS#5 v2.0 pad */
+	pad_len = block_size - wpabuf_len(plain) % block_size;
+	os_memset(wpabuf_put(plain, pad_len), pad_len, pad_len);
+	wpabuf_put_be16(msg, ATTR_ENCR_SETTINGS);
+	wpabuf_put_be16(msg, block_size + wpabuf_len(plain));
+	iv = wpabuf_put(msg, block_size);
+	if (random_get_bytes(iv, block_size) < 0)
+		return -1;
+	data = wpabuf_put(msg, 0);
+	wpabuf_put_buf(msg, plain);
+	if (aes_128_cbc_encrypt(wps->keywrapkey, iv, data, wpabuf_len(plain)))
+		return -1;
+	return 0;
+#ifdef CONFIG_WPS_OOB
+int wps_build_oob_dev_pw(struct wpabuf *msg, u16 dev_pw_id,
+			 const struct wpabuf *pubkey, const u8 *dev_pw,
+	size_t hash_len;
+	const u8 *addr[1];
+	u8 pubkey_hash[WPS_HASH_LEN];
+	wpa_printf(MSG_DEBUG, "WPS:  * OOB Device Password (dev_pw_id=%u)",
+		   dev_pw_id);
+	addr[0] = wpabuf_head(pubkey);
+	hash_len = wpabuf_len(pubkey);
+	sha256_vector(1, addr, &hash_len, pubkey_hash);
+	if (wps_corrupt_pkhash) {
+		wpa_hexdump(MSG_DEBUG, "WPS: Real Public Key Hash",
+			    pubkey_hash, WPS_OOB_PUBKEY_HASH_LEN);
+		wpa_printf(MSG_INFO, "WPS: Testing - corrupt public key hash");
+		pubkey_hash[WPS_OOB_PUBKEY_HASH_LEN - 2]++;
+	wpabuf_put_be16(msg, ATTR_OOB_DEVICE_PASSWORD);
+	wpabuf_put_be16(msg, WPS_OOB_PUBKEY_HASH_LEN + 2 + dev_pw_len);
+	wpa_hexdump(MSG_DEBUG, "WPS: Public Key Hash",
+	wpabuf_put_data(msg, pubkey_hash, WPS_OOB_PUBKEY_HASH_LEN);
+	wpabuf_put_be16(msg, dev_pw_id);
+	if (dev_pw) {
+		wpa_hexdump_key(MSG_DEBUG, "WPS: OOB Device Password",
+				dev_pw, dev_pw_len);
+		wpabuf_put_data(msg, dev_pw, dev_pw_len);
+	return 0;
+#endif /* CONFIG_WPS_OOB */
+/* Encapsulate WPS IE data with one (or more, if needed) IE headers */
+struct wpabuf * wps_ie_encapsulate(struct wpabuf *data)
+	const u8 *pos, *end;
+	ie = wpabuf_alloc(wpabuf_len(data) + 100);
+	if (ie == NULL) {
+		wpabuf_free(data);
+		return NULL;
+	pos = wpabuf_head(data);
+	end = pos + wpabuf_len(data);
+	while (end > pos) {
+		size_t frag_len = end - pos;
+		if (frag_len > 251)
+			frag_len = 251;
+		wpabuf_put_u8(ie, 4 + frag_len);
+		wpabuf_put_data(ie, pos, frag_len);
+		pos += frag_len;
+	return ie;
+int wps_build_mac_addr(struct wpabuf *msg, const u8 *addr)
+	wpa_printf(MSG_DEBUG, "WPS:  * MAC Address (" MACSTR ")",
+		   MAC2STR(addr));
+	wpabuf_put_be16(msg, ATTR_MAC_ADDR);
+	wpabuf_put_be16(msg, ETH_ALEN);
+	wpabuf_put_data(msg, addr, ETH_ALEN);
+	return 0;
+int wps_build_rf_bands_attr(struct wpabuf *msg, u8 rf_bands)
+	wpa_printf(MSG_DEBUG, "WPS:  * RF Bands (%x)", rf_bands);
+	wpabuf_put_be16(msg, ATTR_RF_BANDS);
+	wpabuf_put_u8(msg, rf_bands);
+	return 0;
+int wps_build_ap_channel(struct wpabuf *msg, u16 ap_channel)
+	wpa_printf(MSG_DEBUG, "WPS:  * AP Channel (%u)", ap_channel);
+	wpabuf_put_be16(msg, ATTR_AP_CHANNEL);
+	wpabuf_put_be16(msg, ap_channel);
+	return 0;
diff --git a/freebsd/contrib/wpa/src/wps/wps_attr_parse.c b/freebsd/contrib/wpa/src/wps/wps_attr_parse.c
index 00000000000..748fe0ac078
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps_attr_parse.c
@@ -0,0 +1,665 @@
+#include <machine/rtems-bsd-user-space.h>
+ * Wi-Fi Protected Setup - attribute parsing
+#include "includes.h"
+#include "common.h"
+#include "wps_attr_parse.h"
+#ifndef CONFIG_WPS_STRICT
+#define WPS_WORKAROUNDS
+static int wps_set_vendor_ext_wfa_subelem(struct wps_parse_attr *attr,
+					  u8 id, u8 len, const u8 *pos)
+	wpa_printf(MSG_EXCESSIVE, "WPS: WFA subelement id=%u len=%u",
+		   id, len);
+	switch (id) {
+	case WFA_ELEM_VERSION2:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Version2 length "
+				   "%u", len);
+			return -1;
+		attr->version2 = pos;
+		break;
+	case WFA_ELEM_AUTHORIZEDMACS:
+		attr->authorized_macs = pos;
+		attr->authorized_macs_len = len;
+		break;
+	case WFA_ELEM_NETWORK_KEY_SHAREABLE:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Network Key "
+				   "Shareable length %u", len);
+			return -1;
+		attr->network_key_shareable = pos;
+		break;
+	case WFA_ELEM_REQUEST_TO_ENROLL:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Request to Enroll "
+				   "length %u", len);
+			return -1;
+		attr->request_to_enroll = pos;
+		break;
+	case WFA_ELEM_SETTINGS_DELAY_TIME:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Settings Delay "
+				   "Time length %u", len);
+			return -1;
+		attr->settings_delay_time = pos;
+		break;
+	case WFA_ELEM_REGISTRAR_CONFIGURATION_METHODS:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Registrar Configuration Methods length %u",
+				   len);
+			return -1;
+		attr->registrar_configuration_methods = pos;
+		break;
+	default:
+		wpa_printf(MSG_MSGDUMP, "WPS: Skipped unknown WFA Vendor "
+			   "Extension subelement %u", id);
+		break;
+	return 0;
+static int wps_parse_vendor_ext_wfa(struct wps_parse_attr *attr, const u8 *pos,
+				    u16 len)
+	const u8 *end = pos + len;
+	u8 id, elen;
+	while (pos + 2 <= end) {
+		id = *pos++;
+		elen = *pos++;
+		if (pos + elen > end)
+			break;
+		if (wps_set_vendor_ext_wfa_subelem(attr, id, elen, pos) < 0)
+			return -1;
+		pos += elen;
+	return 0;
+static int wps_parse_vendor_ext(struct wps_parse_attr *attr, const u8 *pos,
+				u16 len)
+	u32 vendor_id;
+	if (len < 3) {
+		wpa_printf(MSG_DEBUG, "WPS: Skip invalid Vendor Extension");
+		return 0;
+	vendor_id = WPA_GET_BE24(pos);
+	switch (vendor_id) {
+	case WPS_VENDOR_ID_WFA:
+		return wps_parse_vendor_ext_wfa(attr, pos + 3, len - 3);
+	/* Handle unknown vendor extensions */
+	wpa_printf(MSG_MSGDUMP, "WPS: Unknown Vendor Extension (Vendor ID %u)",
+		   vendor_id);
+	if (len > WPS_MAX_VENDOR_EXT_LEN) {
+		wpa_printf(MSG_DEBUG, "WPS: Too long Vendor Extension (%u)",
+			   len);
+		return -1;
+	if (attr->num_vendor_ext >= MAX_WPS_PARSE_VENDOR_EXT) {
+		wpa_printf(MSG_DEBUG, "WPS: Skipped Vendor Extension "
+			   "attribute (max %d vendor extensions)",
+			   MAX_WPS_PARSE_VENDOR_EXT);
+		return -1;
+	attr->vendor_ext[attr->num_vendor_ext] = pos;
+	attr->vendor_ext_len[attr->num_vendor_ext] = len;
+	attr->num_vendor_ext++;
+	return 0;
+static int wps_set_attr(struct wps_parse_attr *attr, u16 type,
+			const u8 *pos, u16 len)
+	switch (type) {
+	case ATTR_VERSION:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Version length %u",
+				   len);
+			return -1;
+		attr->version = pos;
+		break;
+	case ATTR_MSG_TYPE:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Message Type "
+			return -1;
+		attr->msg_type = pos;
+		break;
+	case ATTR_ENROLLEE_NONCE:
+		if (len != WPS_NONCE_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Enrollee Nonce "
+			return -1;
+		attr->enrollee_nonce = pos;
+		break;
+	case ATTR_REGISTRAR_NONCE:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Registrar Nonce "
+			return -1;
+		attr->registrar_nonce = pos;
+		break;
+	case ATTR_UUID_E:
+		if (len != WPS_UUID_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid UUID-E length %u",
+				   len);
+			return -1;
+		attr->uuid_e = pos;
+		break;
+	case ATTR_UUID_R:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid UUID-R length %u",
+				   len);
+			return -1;
+		attr->uuid_r = pos;
+		break;
+	case ATTR_AUTH_TYPE_FLAGS:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Authentication "
+				   "Type Flags length %u", len);
+			return -1;
+		attr->auth_type_flags = pos;
+		break;
+	case ATTR_ENCR_TYPE_FLAGS:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Encryption Type "
+				   "Flags length %u", len);
+			return -1;
+		attr->encr_type_flags = pos;
+		break;
+	case ATTR_CONN_TYPE_FLAGS:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Connection Type "
+			return -1;
+		attr->conn_type_flags = pos;
+		break;
+	case ATTR_CONFIG_METHODS:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Config Methods "
+			return -1;
+		attr->config_methods = pos;
+		break;
+	case ATTR_SELECTED_REGISTRAR_CONFIG_METHODS:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Selected "
+				   "Registrar Config Methods length %u", len);
+			return -1;
+		attr->sel_reg_config_methods = pos;
+		break;
+	case ATTR_PRIMARY_DEV_TYPE:
+		if (len != WPS_DEV_TYPE_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Primary Device "
+				   "Type length %u", len);
+			return -1;
+		attr->primary_dev_type = pos;
+		break;
+	case ATTR_RF_BANDS:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid RF Bands length "
+				   "%u", len);
+			return -1;
+		attr->rf_bands = pos;
+		break;
+	case ATTR_ASSOC_STATE:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Association State "
+			return -1;
+		attr->assoc_state = pos;
+		break;
+	case ATTR_CONFIG_ERROR:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Configuration "
+				   "Error length %u", len);
+			return -1;
+		attr->config_error = pos;
+		break;
+	case ATTR_DEV_PASSWORD_ID:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Device Password "
+				   "ID length %u", len);
+			return -1;
+		attr->dev_password_id = pos;
+		break;
+	case ATTR_OOB_DEVICE_PASSWORD:
+		if (len < WPS_OOB_PUBKEY_HASH_LEN + 2 ||
+		    len > WPS_OOB_PUBKEY_HASH_LEN + 2 +
+		    WPS_OOB_DEVICE_PASSWORD_LEN ||
+		    (len < WPS_OOB_PUBKEY_HASH_LEN + 2 +
+		     WPS_OOB_DEVICE_PASSWORD_MIN_LEN &&
+		     WPA_GET_BE16(pos + WPS_OOB_PUBKEY_HASH_LEN) !=
+		     DEV_PW_NFC_CONNECTION_HANDOVER)) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid OOB Device "
+				   "Password length %u", len);
+			return -1;
+		attr->oob_dev_password = pos;
+		attr->oob_dev_password_len = len;
+		break;
+	case ATTR_OS_VERSION:
+		if (len != 4) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid OS Version length "
+				   "%u", len);
+			return -1;
+		attr->os_version = pos;
+		break;
+	case ATTR_WPS_STATE:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Wi-Fi Protected "
+				   "Setup State length %u", len);
+			return -1;
+		attr->wps_state = pos;
+		break;
+	case ATTR_AUTHENTICATOR:
+		if (len != WPS_AUTHENTICATOR_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Authenticator "
+			return -1;
+		attr->authenticator = pos;
+		break;
+	case ATTR_R_HASH1:
+		if (len != WPS_HASH_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid R-Hash1 length %u",
+				   len);
+			return -1;
+		attr->r_hash1 = pos;
+		break;
+	case ATTR_R_HASH2:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid R-Hash2 length %u",
+				   len);
+			return -1;
+		attr->r_hash2 = pos;
+		break;
+	case ATTR_E_HASH1:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid E-Hash1 length %u",
+				   len);
+			return -1;
+		attr->e_hash1 = pos;
+		break;
+	case ATTR_E_HASH2:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid E-Hash2 length %u",
+				   len);
+			return -1;
+		attr->e_hash2 = pos;
+		break;
+	case ATTR_R_SNONCE1:
+		if (len != WPS_SECRET_NONCE_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid R-SNonce1 length "
+				   "%u", len);
+			return -1;
+		attr->r_snonce1 = pos;
+		break;
+	case ATTR_R_SNONCE2:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid R-SNonce2 length "
+				   "%u", len);
+			return -1;
+		attr->r_snonce2 = pos;
+		break;
+	case ATTR_E_SNONCE1:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid E-SNonce1 length "
+				   "%u", len);
+			return -1;
+		attr->e_snonce1 = pos;
+		break;
+	case ATTR_E_SNONCE2:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid E-SNonce2 length "
+				   "%u", len);
+			return -1;
+		attr->e_snonce2 = pos;
+		break;
+	case ATTR_KEY_WRAP_AUTH:
+		if (len != WPS_KWA_LEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Key Wrap "
+				   "Authenticator length %u", len);
+			return -1;
+		attr->key_wrap_auth = pos;
+		break;
+	case ATTR_AUTH_TYPE:
+		if (len != 2) {
+			return -1;
+		attr->auth_type = pos;
+		break;
+	case ATTR_ENCR_TYPE:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Encryption "
+			return -1;
+		attr->encr_type = pos;
+		break;
+	case ATTR_NETWORK_INDEX:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Network Index "
+			return -1;
+		attr->network_idx = pos;
+		break;
+	case ATTR_NETWORK_KEY_INDEX:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Network Key Index "
+			return -1;
+		attr->network_key_idx = pos;
+		break;
+	case ATTR_MAC_ADDR:
+		if (len != ETH_ALEN) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid MAC Address "
+			return -1;
+		attr->mac_addr = pos;
+		break;
+	case ATTR_SELECTED_REGISTRAR:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Selected Registrar"
+				   " length %u", len);
+			return -1;
+		attr->selected_registrar = pos;
+		break;
+	case ATTR_REQUEST_TYPE:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Request Type "
+			return -1;
+		attr->request_type = pos;
+		break;
+	case ATTR_RESPONSE_TYPE:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Response Type "
+			return -1;
+		attr->response_type = pos;
+		break;
+	case ATTR_MANUFACTURER:
+		attr->manufacturer = pos;
+		if (len > WPS_MANUFACTURER_MAX_LEN)
+			attr->manufacturer_len = WPS_MANUFACTURER_MAX_LEN;
+		else
+			attr->manufacturer_len = len;
+		break;
+	case ATTR_MODEL_NAME:
+		attr->model_name = pos;
+		if (len > WPS_MODEL_NAME_MAX_LEN)
+			attr->model_name_len = WPS_MODEL_NAME_MAX_LEN;
+		else
+			attr->model_name_len = len;
+		break;
+	case ATTR_MODEL_NUMBER:
+		attr->model_number = pos;
+		if (len > WPS_MODEL_NUMBER_MAX_LEN)
+			attr->model_number_len = WPS_MODEL_NUMBER_MAX_LEN;
+		else
+			attr->model_number_len = len;
+		break;
+	case ATTR_SERIAL_NUMBER:
+		attr->serial_number = pos;
+		if (len > WPS_SERIAL_NUMBER_MAX_LEN)
+			attr->serial_number_len = WPS_SERIAL_NUMBER_MAX_LEN;
+		else
+			attr->serial_number_len = len;
+		break;
+	case ATTR_DEV_NAME:
+		if (len > WPS_DEV_NAME_MAX_LEN) {
+				   "WPS: Ignore too long Device Name (len=%u)",
+				   len);
+			break;
+		attr->dev_name = pos;
+		attr->dev_name_len = len;
+		break;
+	case ATTR_PUBLIC_KEY:
+		 * The Public Key attribute is supposed to be exactly 192 bytes
+		 * in length. Allow couple of bytes shorter one to try to
+		 * interoperate with implementations that do not use proper
+		 * zero-padding.
+		if (len < 190 || len > 192) {
+				   "WPS: Ignore Public Key with unexpected length %u",
+				   len);
+			break;
+		attr->public_key = pos;
+		attr->public_key_len = len;
+		break;
+	case ATTR_ENCR_SETTINGS:
+		attr->encr_settings = pos;
+		attr->encr_settings_len = len;
+		break;
+	case ATTR_CRED:
+		if (attr->num_cred >= MAX_CRED_COUNT) {
+			wpa_printf(MSG_DEBUG, "WPS: Skipped Credential "
+				   "attribute (max %d credentials)",
+				   MAX_CRED_COUNT);
+			break;
+		attr->cred[attr->num_cred] = pos;
+		attr->cred_len[attr->num_cred] = len;
+		attr->num_cred++;
+		break;
+	case ATTR_SSID:
+		if (len > SSID_MAX_LEN) {
+				   "WPS: Ignore too long SSID (len=%u)", len);
+			break;
+		attr->ssid = pos;
+		attr->ssid_len = len;
+		break;
+	case ATTR_NETWORK_KEY:
+		attr->network_key = pos;
+		attr->network_key_len = len;
+		break;
+	case ATTR_AP_SETUP_LOCKED:
+		if (len != 1) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid AP Setup Locked "
+			return -1;
+		attr->ap_setup_locked = pos;
+		break;
+	case ATTR_REQUESTED_DEV_TYPE:
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Requested Device "
+			return -1;
+		if (attr->num_req_dev_type >= MAX_REQ_DEV_TYPE_COUNT) {
+			wpa_printf(MSG_DEBUG, "WPS: Skipped Requested Device "
+				   "Type attribute (max %u types)",
+				   MAX_REQ_DEV_TYPE_COUNT);
+			break;
+		attr->req_dev_type[attr->num_req_dev_type] = pos;
+		attr->num_req_dev_type++;
+		break;
+	case ATTR_SECONDARY_DEV_TYPE_LIST:
+		if (len > WPS_SEC_DEV_TYPE_MAX_LEN ||
+		    (len % WPS_DEV_TYPE_LEN) > 0) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid Secondary Device "
+			return -1;
+		attr->sec_dev_type_list = pos;
+		attr->sec_dev_type_list_len = len;
+		break;
+	case ATTR_VENDOR_EXT:
+		if (wps_parse_vendor_ext(attr, pos, len) < 0)
+			return -1;
+		break;
+	case ATTR_AP_CHANNEL:
+		if (len != 2) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid AP Channel "
+			return -1;
+		attr->ap_channel = pos;
+		break;
+	default:
+		wpa_printf(MSG_DEBUG, "WPS: Unsupported attribute type 0x%x "
+			   "len=%u", type, len);
+		break;
+	return 0;
+int wps_parse_msg(const struct wpabuf *msg, struct wps_parse_attr *attr)
+	u16 type, len;
+#ifdef WPS_WORKAROUNDS
+	u16 prev_type = 0;
+#endif /* WPS_WORKAROUNDS */
+	os_memset(attr, 0, sizeof(*attr));
+	pos = wpabuf_head(msg);
+	end = pos + wpabuf_len(msg);
+	while (pos < end) {
+		if (end - pos < 4) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid message - "
+				   "%lu bytes remaining",
+				   (unsigned long) (end - pos));
+			return -1;
+		type = WPA_GET_BE16(pos);
+		pos += 2;
+		len = WPA_GET_BE16(pos);
+		pos += 2;
+		wpa_printf(MSG_EXCESSIVE, "WPS: attr type=0x%x len=%u",
+			   type, len);
+		if (len > end - pos) {
+			wpa_printf(MSG_DEBUG, "WPS: Attribute overflow");
+			wpa_hexdump_buf(MSG_MSGDUMP, "WPS: Message data", msg);
+			 * Some deployed APs seem to have a bug in encoding of
+			 * Network Key attribute in the Credential attribute
+			 * where they add an extra octet after the Network Key
+			 * attribute at least when open network is being
+			 * provisioned.
+			if ((type & 0xff00) != 0x1000 &&
+			    prev_type == ATTR_NETWORK_KEY) {
+				wpa_printf(MSG_DEBUG, "WPS: Workaround - try "
+					   "to skip unexpected octet after "
+					   "Network Key");
+				pos -= 3;
+				continue;
+			return -1;
+		if (type == 0 && len == 0) {
+			 * Mac OS X 10.6 seems to be adding 0x00 padding to the
+			 * end of M1. Skip those to avoid interop issues.
+			int i;
+			for (i = 0; i < end - pos; i++) {
+				if (pos[i])
+					break;
+			if (i == end - pos) {
+				wpa_printf(MSG_DEBUG, "WPS: Workaround - skip "
+					   "unexpected message padding");
+				break;
+		if (wps_set_attr(attr, type, pos, len) < 0)
+			return -1;
+		prev_type = type;
+		pos += len;
+	return 0;
diff --git a/freebsd/contrib/wpa/src/wps/wps_attr_parse.h b/freebsd/contrib/wpa/src/wps/wps_attr_parse.h
index 00000000000..8188fe9173d
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps_attr_parse.h
@@ -0,0 +1,104 @@
+ * Copyright (c) 2008-2012, Jouni Malinen <j at w1.fi>
+#ifndef WPS_ATTR_PARSE_H
+#define WPS_ATTR_PARSE_H
+#include "wps.h"
+struct wps_parse_attr {
+	/* fixed length fields */
+	const u8 *version; /* 1 octet */
+	const u8 *version2; /* 1 octet */
+	const u8 *msg_type; /* 1 octet */
+	const u8 *enrollee_nonce; /* WPS_NONCE_LEN (16) octets */
+	const u8 *registrar_nonce; /* WPS_NONCE_LEN (16) octets */
+	const u8 *uuid_r; /* WPS_UUID_LEN (16) octets */
+	const u8 *uuid_e; /* WPS_UUID_LEN (16) octets */
+	const u8 *auth_type_flags; /* 2 octets */
+	const u8 *encr_type_flags; /* 2 octets */
+	const u8 *conn_type_flags; /* 1 octet */
+	const u8 *config_methods; /* 2 octets */
+	const u8 *sel_reg_config_methods; /* 2 octets */
+	const u8 *rf_bands; /* 1 octet */
+	const u8 *assoc_state; /* 2 octets */
+	const u8 *config_error; /* 2 octets */
+	const u8 *dev_password_id; /* 2 octets */
+	const u8 *os_version; /* 4 octets */
+	const u8 *wps_state; /* 1 octet */
+	const u8 *authenticator; /* WPS_AUTHENTICATOR_LEN (8) octets */
+	const u8 *r_hash1; /* WPS_HASH_LEN (32) octets */
+	const u8 *r_hash2; /* WPS_HASH_LEN (32) octets */
+	const u8 *e_hash1; /* WPS_HASH_LEN (32) octets */
+	const u8 *e_hash2; /* WPS_HASH_LEN (32) octets */
+	const u8 *r_snonce1; /* WPS_SECRET_NONCE_LEN (16) octets */
+	const u8 *r_snonce2; /* WPS_SECRET_NONCE_LEN (16) octets */
+	const u8 *e_snonce1; /* WPS_SECRET_NONCE_LEN (16) octets */
+	const u8 *e_snonce2; /* WPS_SECRET_NONCE_LEN (16) octets */
+	const u8 *key_wrap_auth; /* WPS_KWA_LEN (8) octets */
+	const u8 *auth_type; /* 2 octets */
+	const u8 *encr_type; /* 2 octets */
+	const u8 *network_idx; /* 1 octet */
+	const u8 *network_key_idx; /* 1 octet */
+	const u8 *mac_addr; /* ETH_ALEN (6) octets */
+	const u8 *selected_registrar; /* 1 octet (Bool) */
+	const u8 *request_type; /* 1 octet */
+	const u8 *response_type; /* 1 octet */
+	const u8 *ap_setup_locked; /* 1 octet */
+	const u8 *settings_delay_time; /* 1 octet */
+	const u8 *network_key_shareable; /* 1 octet (Bool) */
+	const u8 *request_to_enroll; /* 1 octet (Bool) */
+	const u8 *ap_channel; /* 2 octets */
+	const u8 *registrar_configuration_methods; /* 2 octets */
+	/* variable length fields */
+	const u8 *public_key;
+	const u8 *encr_settings;
+	const u8 *ssid; /* <= 32 octets */
+	const u8 *network_key; /* <= 64 octets */
+	const u8 *authorized_macs; /* <= 30 octets */
+	const u8 *sec_dev_type_list; /* <= 128 octets */
+	const u8 *oob_dev_password; /* 38..54 octets */
+	u16 manufacturer_len;
+	u16 model_name_len;
+	u16 model_number_len;
+	u16 serial_number_len;
+	u16 dev_name_len;
+	u16 public_key_len;
+	u16 encr_settings_len;
+	u16 ssid_len;
+	u16 network_key_len;
+	u16 authorized_macs_len;
+	u16 sec_dev_type_list_len;
+	u16 oob_dev_password_len;
+	/* attributes that can occur multiple times */
+#define MAX_CRED_COUNT 10
+#define MAX_REQ_DEV_TYPE_COUNT 10
+	unsigned int num_cred;
+	unsigned int num_req_dev_type;
+	unsigned int num_vendor_ext;
+	u16 cred_len[MAX_CRED_COUNT];
+	u16 vendor_ext_len[MAX_WPS_PARSE_VENDOR_EXT];
+	const u8 *cred[MAX_CRED_COUNT];
+	const u8 *req_dev_type[MAX_REQ_DEV_TYPE_COUNT];
+	const u8 *vendor_ext[MAX_WPS_PARSE_VENDOR_EXT];
+int wps_parse_msg(const struct wpabuf *msg, struct wps_parse_attr *attr);
+#endif /* WPS_ATTR_PARSE_H */
diff --git a/freebsd/contrib/wpa/src/wps/wps_attr_process.c b/freebsd/contrib/wpa/src/wps/wps_attr_process.c
index 00000000000..329649dfd23
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps_attr_process.c
@@ -0,0 +1,274 @@
+ * Wi-Fi Protected Setup - attribute processing
+#include "wps_i.h"
+int wps_process_authenticator(struct wps_data *wps, const u8 *authenticator,
+	size_t len[2];
+	if (authenticator == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: No Authenticator attribute "
+			   "included");
+		return -1;
+			   "validating authenticator");
+		return -1;
+	len[1] = wpabuf_len(msg) - 4 - WPS_AUTHENTICATOR_LEN;
+	if (os_memcmp_const(hash, authenticator, WPS_AUTHENTICATOR_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "WPS: Incorrect Authenticator");
+		return -1;
+	return 0;
+int wps_process_key_wrap_auth(struct wps_data *wps, struct wpabuf *msg,
+			      const u8 *key_wrap_auth)
+	const u8 *head;
+	size_t len;
+	if (key_wrap_auth == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: No KWA in decrypted attribute");
+		return -1;
+	head = wpabuf_head(msg);
+	len = wpabuf_len(msg) - 4 - WPS_KWA_LEN;
+	if (head + len != key_wrap_auth - 4) {
+		wpa_printf(MSG_DEBUG, "WPS: KWA not in the end of the "
+			   "decrypted attribute");
+		return -1;
+	hmac_sha256(wps->authkey, WPS_AUTHKEY_LEN, head, len, hash);
+	if (os_memcmp_const(hash, key_wrap_auth, WPS_KWA_LEN) != 0) {
+		wpa_printf(MSG_DEBUG, "WPS: Invalid KWA");
+		return -1;
+	return 0;
+static int wps_process_cred_network_idx(struct wps_credential *cred,
+					const u8 *idx)
+	if (idx == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Credential did not include "
+			   "Network Index");
+		return -1;
+	wpa_printf(MSG_DEBUG, "WPS: Network Index: %d", *idx);
+	return 0;
+static int wps_process_cred_ssid(struct wps_credential *cred, const u8 *ssid,
+				 size_t ssid_len)
+	if (ssid == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Credential did not include SSID");
+		return -1;
+	/* Remove zero-padding since some Registrar implementations seem to use
+	 * hardcoded 32-octet length for this attribute */
+	while (ssid_len > 0 && ssid[ssid_len - 1] == 0)
+		ssid_len--;
+	wpa_hexdump_ascii(MSG_DEBUG, "WPS: SSID", ssid, ssid_len);
+	if (ssid_len <= sizeof(cred->ssid)) {
+		os_memcpy(cred->ssid, ssid, ssid_len);
+		cred->ssid_len = ssid_len;
+	return 0;
+static int wps_process_cred_auth_type(struct wps_credential *cred,
+				      const u8 *auth_type)
+	if (auth_type == NULL) {
+			   "Authentication Type");
+		return -1;
+	cred->auth_type = WPA_GET_BE16(auth_type);
+	wpa_printf(MSG_DEBUG, "WPS: Authentication Type: 0x%x",
+		   cred->auth_type);
+	return 0;
+static int wps_process_cred_encr_type(struct wps_credential *cred,
+				      const u8 *encr_type)
+	if (encr_type == NULL) {
+			   "Encryption Type");
+		return -1;
+	cred->encr_type = WPA_GET_BE16(encr_type);
+	wpa_printf(MSG_DEBUG, "WPS: Encryption Type: 0x%x",
+		   cred->encr_type);
+	return 0;
+static int wps_process_cred_network_key_idx(struct wps_credential *cred,
+					    const u8 *key_idx)
+	if (key_idx == NULL)
+		return 0; /* optional attribute */
+	wpa_printf(MSG_DEBUG, "WPS: Network Key Index: %d", *key_idx);
+	cred->key_idx = *key_idx;
+	return 0;
+static int wps_process_cred_network_key(struct wps_credential *cred,
+					const u8 *key, size_t key_len)
+	if (key == NULL) {
+			   "Network Key");
+		if (cred->auth_type == WPS_AUTH_OPEN &&
+		    cred->encr_type == WPS_ENCR_NONE) {
+			wpa_printf(MSG_DEBUG, "WPS: Workaround - Allow "
+				   "missing mandatory Network Key attribute "
+				   "for open network");
+			return 0;
+		return -1;
+	wpa_hexdump_key(MSG_DEBUG, "WPS: Network Key", key, key_len);
+	if (key_len <= sizeof(cred->key)) {
+		os_memcpy(cred->key, key, key_len);
+		cred->key_len = key_len;
+	return 0;
+static int wps_process_cred_mac_addr(struct wps_credential *cred,
+				     const u8 *mac_addr)
+	if (mac_addr == NULL) {
+			   "MAC Address");
+		return -1;
+	wpa_printf(MSG_DEBUG, "WPS: MAC Address " MACSTR, MAC2STR(mac_addr));
+	os_memcpy(cred->mac_addr, mac_addr, ETH_ALEN);
+	return 0;
+static int wps_workaround_cred_key(struct wps_credential *cred)
+	if (cred->auth_type & (WPS_AUTH_WPAPSK | WPS_AUTH_WPA2PSK) &&
+	    cred->key_len > 8 && cred->key_len < 64 &&
+	    cred->key[cred->key_len - 1] == 0) {
+#ifdef CONFIG_WPS_STRICT
+		wpa_printf(MSG_INFO, "WPS: WPA/WPA2-Personal passphrase uses "
+			   "forbidden NULL termination");
+		wpa_hexdump_ascii_key(MSG_INFO, "WPS: Network Key",
+				      cred->key, cred->key_len);
+		return -1;
+		 * A deployed external registrar is known to encode ASCII
+		 * passphrases incorrectly. Remove the extra NULL termination
+		 * to fix the encoding.
+		wpa_printf(MSG_DEBUG, "WPS: Workaround - remove NULL "
+			   "termination from ASCII passphrase");
+		cred->key_len--;
+#endif /* CONFIG_WPS_STRICT */
+	return 0;
+int wps_process_cred(struct wps_parse_attr *attr,
+	wpa_printf(MSG_DEBUG, "WPS: Process Credential");
+	/* TODO: support multiple Network Keys */
+	if (wps_process_cred_network_idx(cred, attr->network_idx) ||
+	    wps_process_cred_ssid(cred, attr->ssid, attr->ssid_len) ||
+	    wps_process_cred_auth_type(cred, attr->auth_type) ||
+	    wps_process_cred_encr_type(cred, attr->encr_type) ||
+	    wps_process_cred_network_key_idx(cred, attr->network_key_idx) ||
+	    wps_process_cred_network_key(cred, attr->network_key,
+					 attr->network_key_len) ||
+	    wps_process_cred_mac_addr(cred, attr->mac_addr))
+		return -1;
+	return wps_workaround_cred_key(cred);
+int wps_process_ap_settings(struct wps_parse_attr *attr,
+	wpa_printf(MSG_DEBUG, "WPS: Processing AP Settings");
+	os_memset(cred, 0, sizeof(*cred));
+	/* TODO: optional attributes New Password and Device Password ID */
+	if (wps_process_cred_ssid(cred, attr->ssid, attr->ssid_len) ||
+		return -1;
diff --git a/freebsd/contrib/wpa/src/wps/wps_common.c b/freebsd/contrib/wpa/src/wps/wps_common.c
new file mode 100644
index 00000000000..b6c8389290e
--- /dev/null
+++ b/freebsd/contrib/wpa/src/wps/wps_common.c
@@ -0,0 +1,911 @@
+ * Wi-Fi Protected Setup - common functionality
+ * This software may be distributed under the terms of the BSD license.
+ * See README for more details.
+#include "common/defs.h"
+#include "common/ieee802_11_common.h"
+#include "crypto/dh_group5.h"
+#include "crypto/sha1.h"
+#include "wps_i.h"
+#include "wps_dev_attr.h"
+void wps_kdf(const u8 *key, const u8 *label_prefix, size_t label_prefix_len,
+	     const char *label, u8 *res, size_t res_len)
+	u8 i_buf[4], key_bits[4];
+	const u8 *addr[4];
+	size_t len[4];
+	int i, iter;
+	u8 hash[SHA256_MAC_LEN], *opos;
+	size_t left;
+	WPA_PUT_BE32(key_bits, res_len * 8);
+	addr[0] = i_buf;
+	len[0] = sizeof(i_buf);
+	addr[1] = label_prefix;
+	len[1] = label_prefix_len;
+	addr[2] = (const u8 *) label;
+	len[2] = os_strlen(label);
+	addr[3] = key_bits;
+	len[3] = sizeof(key_bits);
+	iter = (res_len + SHA256_MAC_LEN - 1) / SHA256_MAC_LEN;
+	opos = res;
+	left = res_len;
+	for (i = 1; i <= iter; i++) {
+		WPA_PUT_BE32(i_buf, i);
+		hmac_sha256_vector(key, SHA256_MAC_LEN, 4, addr, len, hash);
+		if (i < iter) {
+			os_memcpy(opos, hash, SHA256_MAC_LEN);
+			opos += SHA256_MAC_LEN;
+			left -= SHA256_MAC_LEN;
+		} else
+			os_memcpy(opos, hash, left);
+int wps_derive_keys(struct wps_data *wps)
+	struct wpabuf *pubkey, *dh_shared;
+	u8 dhkey[SHA256_MAC_LEN], kdk[SHA256_MAC_LEN];
+	const u8 *addr[3];
+	size_t len[3];
+	u8 keys[WPS_AUTHKEY_LEN + WPS_KEYWRAPKEY_LEN + WPS_EMSK_LEN];
+	if (wps->dh_privkey == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Own DH private key not available");
+		return -1;
+	pubkey = wps->registrar ? wps->dh_pubkey_e : wps->dh_pubkey_r;
+	if (pubkey == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Peer DH public key not available");
+		return -1;
+	wpa_hexdump_buf(MSG_DEBUG, "WPS: DH peer Public Key", pubkey);
+	dh_shared = dh5_derive_shared(wps->dh_ctx, pubkey, wps->dh_privkey);
+	wps->dh_ctx = NULL;
+	dh_shared = wpabuf_zeropad(dh_shared, 192);
+	if (dh_shared == NULL) {
+		wpa_printf(MSG_DEBUG, "WPS: Failed to derive DH shared key");
+		return -1;
+	/* Own DH private key is not needed anymore */
+	wpa_hexdump_buf_key(MSG_DEBUG, "WPS: DH shared key", dh_shared);
+	/* DHKey = SHA-256(g^AB mod p) */
+	addr[0] = wpabuf_head(dh_shared);
+	len[0] = wpabuf_len(dh_shared);
+	sha256_vector(1, addr, len, dhkey);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: DHKey", dhkey, sizeof(dhkey));
+	wpabuf_free(dh_shared);
+	/* KDK = HMAC-SHA-256_DHKey(N1 || EnrolleeMAC || N2) */
+	addr[0] = wps->nonce_e;
+	len[0] = WPS_NONCE_LEN;
+	addr[1] = wps->mac_addr_e;
+	len[1] = ETH_ALEN;
+	addr[2] = wps->nonce_r;
+	len[2] = WPS_NONCE_LEN;
+	hmac_sha256_vector(dhkey, sizeof(dhkey), 3, addr, len, kdk);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: KDK", kdk, sizeof(kdk));
+	wps_kdf(kdk, NULL, 0, "Wi-Fi Easy and Secure Key Derivation",
+		keys, sizeof(keys));
+	os_memcpy(wps->authkey, keys, WPS_AUTHKEY_LEN);
+	os_memcpy(wps->keywrapkey, keys + WPS_AUTHKEY_LEN, WPS_KEYWRAPKEY_LEN);
+	os_memcpy(wps->emsk, keys + WPS_AUTHKEY_LEN + WPS_KEYWRAPKEY_LEN,
+		  WPS_EMSK_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: AuthKey",
+			wps->authkey, WPS_AUTHKEY_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: KeyWrapKey",
+			wps->keywrapkey, WPS_KEYWRAPKEY_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: EMSK", wps->emsk, WPS_EMSK_LEN);
+	return 0;
+void wps_derive_psk(struct wps_data *wps, const u8 *dev_passwd,
+		    size_t dev_passwd_len)
+	hmac_sha256(wps->authkey, WPS_AUTHKEY_LEN, dev_passwd,
+		    (dev_passwd_len + 1) / 2, hash);
+	os_memcpy(wps->psk1, hash, WPS_PSK_LEN);
+		    dev_passwd + (dev_passwd_len + 1) / 2,
+		    dev_passwd_len / 2, hash);
+	os_memcpy(wps->psk2, hash, WPS_PSK_LEN);
+	wpa_hexdump_ascii_key(MSG_DEBUG, "WPS: Device Password",
+			      dev_passwd, dev_passwd_len);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: PSK1", wps->psk1, WPS_PSK_LEN);
+	wpa_hexdump_key(MSG_DEBUG, "WPS: PSK2", wps->psk2, WPS_PSK_LEN);
+struct wpabuf * wps_decrypt_encr_settings(struct wps_data *wps, const u8 *encr,
+					  size_t encr_len)
+	struct wpabuf *decrypted;
+	size_t i;
+	u8 pad;
+	const u8 *pos;
+	/* AES-128-CBC */
+	if (encr == NULL || encr_len < 2 * block_size || encr_len % block_size)
+		wpa_printf(MSG_DEBUG, "WPS: No Encrypted Settings received");
+		return NULL;
+	decrypted = wpabuf_alloc(encr_len - block_size);
+	if (decrypted == NULL)
+		return NULL;
+	wpa_hexdump(MSG_MSGDUMP, "WPS: Encrypted Settings", encr, encr_len);
+	wpabuf_put_data(decrypted, encr + block_size, encr_len - block_size);
+	if (aes_128_cbc_decrypt(wps->keywrapkey, encr, wpabuf_mhead(decrypted),
+				wpabuf_len(decrypted))) {
+		wpabuf_free(decrypted);
+		return NULL;
+	wpa_hexdump_buf_key(MSG_MSGDUMP, "WPS: Decrypted Encrypted Settings",
+			    decrypted);
+	pos = wpabuf_head_u8(decrypted) + wpabuf_len(decrypted) - 1;
+	pad = *pos;
+	if (pad > wpabuf_len(decrypted)) {
+		wpa_printf(MSG_DEBUG, "WPS: Invalid PKCS#5 v2.0 pad value");
+		return NULL;
+	for (i = 0; i < pad; i++) {
+		if (*pos-- != pad) {
+			wpa_printf(MSG_DEBUG, "WPS: Invalid PKCS#5 v2.0 pad "
+				   "string");
+			return NULL;
+	decrypted->used -= pad;
+	return decrypted;
+ * wps_pin_checksum - Compute PIN checksum
+ * @pin: Seven digit PIN (i.e., eight digit PIN without the checksum digit)
+ * Returns: Checksum digit
+	unsigned int accum = 0;
+	while (pin) {
+		accum += 3 * (pin % 10);
+		pin /= 10;
+		accum += pin % 10;
+		pin /= 10;
+	return (10 - accum % 10) % 10;
+ * wps_pin_valid - Check whether a PIN has a valid checksum
+ * @pin: Eight digit PIN (i.e., including the checksum digit)
+ * Returns: 1 if checksum digit is valid, or 0 if not
+	return wps_pin_checksum(pin / 10) == (pin % 10);
+ * wps_generate_pin - Generate a random PIN
+ * Returns: Eight digit PIN (i.e., including the checksum digit)
+	unsigned int val;
+	/* Generate seven random digits for the PIN */
+	if (random_get_bytes((unsigned char *) &val, sizeof(val)) < 0) {
+		struct os_time now;
+		os_get_time(&now);
+		val = os_random() ^ now.sec ^ now.usec;
+	val %= 10000000;
+	/* Append checksum digit */
+	return val * 10 + wps_pin_checksum(val);
+	const char *p;
+	size_t len;
+	p = pin;
+	while (*p >= '0' && *p <= '9')
+		p++;
+	if (*p != '\0')
+		return 0;
+	len = p - pin;
+	return len == 4 || len == 8;
+void wps_fail_event(struct wps_context *wps, enum wps_msg_type msg,
+		    u16 config_error, u16 error_indication, const u8 *mac_addr)
+	union wps_event_data data;
+	if (wps->event_cb == NULL)
+		return;
+	os_memset(&data, 0, sizeof(data));
+	data.fail.msg = msg;
+	data.fail.config_error = config_error;
+	data.fail.error_indication = error_indication;
+	os_memcpy(data.fail.peer_macaddr, mac_addr, ETH_ALEN);
+	wps->event_cb(wps->cb_ctx, WPS_EV_FAIL, &data);
+void wps_success_event(struct wps_context *wps, const u8 *mac_addr)
+		return;
+	os_memcpy(data.success.peer_macaddr, mac_addr, ETH_ALEN);
+	wps->event_cb(wps->cb_ctx, WPS_EV_SUCCESS, &data);
+void wps_pwd_auth_fail_event(struct wps_context *wps, int enrollee, int part,
+		return;
+	data.pwd_auth_fail.enrollee = enrollee;
+	data.pwd_auth_fail.part = part;
+	os_memcpy(data.pwd_auth_fail.peer_macaddr, mac_addr, ETH_ALEN);
+	wps->event_cb(wps->cb_ctx, WPS_EV_PWD_AUTH_FAIL, &data);
+void wps_pbc_overlap_event(struct wps_context *wps)
+		return;
+	wps->event_cb(wps->cb_ctx, WPS_EV_PBC_OVERLAP, NULL);
+void wps_pbc_timeout_event(struct wps_context *wps)
+		return;
+	wps->event_cb(wps->cb_ctx, WPS_EV_PBC_TIMEOUT, NULL);
+void wps_pbc_active_event(struct wps_context *wps)
+		return;
+	wps->event_cb(wps->cb_ctx, WPS_EV_PBC_ACTIVE, NULL);
+void wps_pbc_disable_event(struct wps_context *wps)
+		return;
+	wps->event_cb(wps->cb_ctx, WPS_EV_PBC_DISABLE, NULL);
+				 int channel)
+	struct wps_data data;
+	struct wpabuf *plain;
+	plain = wpabuf_alloc(500);
+	if (plain == NULL) {
+		wpa_printf(MSG_ERROR, "WPS: Failed to allocate memory for OOB "
+			   "credential");
+		return NULL;
+	data.wps = wps;
+	data.auth_type = wps->auth_types;
+	data.encr_type = wps->encr_types;
+	if (wps_build_cred(&data, plain) ||
+	    (rf_band && wps_build_rf_bands_attr(plain, rf_band)) ||
+	    (channel && wps_build_ap_channel(plain, channel)) ||
+	    wps_build_mac_addr(plain, wps->dev.mac_addr) ||
+	    wps_build_wfa_ext(plain, 0, NULL, 0)) {
+		os_free(data.new_psk);
+		wpabuf_free(plain);
+		return NULL;
+	if (wps->wps_state == WPS_STATE_NOT_CONFIGURED && data.new_psk &&
+	    wps->ap) {
+		struct wps_credential cred;
+		wpa_printf(MSG_DEBUG, "WPS: Moving to Configured state based "
+			   "on credential token generation");
+		os_memset(&cred, 0, sizeof(cred));
+		os_memcpy(cred.ssid, wps->ssid, wps->ssid_len);
+		cred.ssid_len = wps->ssid_len;
+		cred.auth_type = WPS_AUTH_WPAPSK | WPS_AUTH_WPA2PSK;
+		cred.encr_type = WPS_ENCR_TKIP | WPS_ENCR_AES;
+		os_memcpy(cred.key, data.new_psk, data.new_psk_len);
+		cred.key_len = data.new_psk_len;
+		wps->wps_state = WPS_STATE_CONFIGURED;
+				      "WPS: Generated random passphrase",
+				      data.new_psk, data.new_psk_len);
+		if (wps->cred_cb)
+			wps->cred_cb(wps->cb_ctx, &cred);
+	return plain;
+	struct wpabuf *data;
+	data = wpabuf_alloc(200);
+	if (data == NULL)
+		return NULL;
+	if (wps_build_oob_dev_pw(data, dev_pw_id, pubkey,
+				 wpabuf_head(dev_pw), wpabuf_len(dev_pw)) ||
+	    wps_build_wfa_ext(data, 0, NULL, 0)) {
+		wpa_printf(MSG_ERROR, "WPS: Failed to build NFC password "
+			   "token");
+		return NULL;
+	return data;
+	struct wpabuf msg;
+	size_t i;
+	for (i = 0; i < attr->num_cred; i++) {
+		struct wps_credential local_cred;
+		struct wps_parse_attr cattr;
+		os_memset(&local_cred, 0, sizeof(local_cred));
+		wpabuf_set(&msg, attr->cred[i], attr->cred_len[i]);
+		if (wps_parse_msg(&msg, &cattr) < 0 ||
+		    wps_process_cred(&cattr, &local_cred)) {
+			wpa_printf(MSG_ERROR, "WPS: Failed to parse OOB "
+				   "credential");
+			return -1;
+		wps->cred_cb(wps->cb_ctx, &local_cred);
+	return 0;
+	const char *pos;
+	/* <categ>-<OUI>-<subcateg> */
+	WPA_PUT_BE16(dev_type, atoi(str));
+	pos = os_strchr(str, '-');
+	if (pos == NULL)
+		return -1;
+	pos++;
+	if (hexstr2bin(pos, &dev_type[2], 4))
+		return -1;
+	pos = os_strchr(pos, '-');
+	if (pos == NULL)
+		return -1;
+	pos++;
+	WPA_PUT_BE16(&dev_type[6], atoi(pos));
+	return 0;
+			    size_t buf_len)
+	int ret;
+	ret = os_snprintf(buf, buf_len, "%u-%08X-%u",
+			  WPA_GET_BE16(dev_type), WPA_GET_BE32(&dev_type[2]),
+			  WPA_GET_BE16(&dev_type[6]));
+	if (os_snprintf_error(buf_len, ret))
+		return NULL;
+	return buf;
+	size_t len[2];
+	u8 hash[SHA1_MAC_LEN];
+	u8 nsid[16] = {
+		0x52, 0x64, 0x80, 0xf8,
+		0xc9, 0x9b,
+		0x4b, 0xe5,
+		0xa6, 0x55,
+		0x58, 0xed, 0x5f, 0x5d, 0x60, 0x84
+	addr[0] = nsid;
+	len[0] = sizeof(nsid);
+	addr[1] = mac_addr;
+	len[1] = 6;
+	sha
