[PATCH 2/5] powerpc: Replace BSP_panic() with rtems_panic()
Tue Nov 21 14:14:19 UTC 2017
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic().  Remove BSP_panic()
implementations.
Close #3245.
 c/src/lib/libbsp/powerpc/beatnik/include/bsp.h           |  3 +--
 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c     |  2 +-
 c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c          |  2 +-
 c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c     |  4 ++--
 c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c       |  2 +-
 c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c     |  2 +-
 c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c      |  8 ++++----
 c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c      |  6 ------
 c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c      | 16 +---------------
 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c        |  2 +-
 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c    |  6 ------
 c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h  |  1 -
 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c   |  7 -------
 c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h          |  1 -
 c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c         |  2 +-
 c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c     | 10 ++--------
 c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h          |  1 -
 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c         |  2 +-
 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c              |  2 +-
 c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c     |  6 ------
 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c             |  4 ++--
 c/src/lib/libbsp/powerpc/psim/startup/bspstart.c         |  6 ------
 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c          |  2 +-
 c/src/lib/libbsp/powerpc/qemuppc/startup/bsppanic.c      |  6 ------
 c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c      |  2 +-
 c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c        | 14 --------------
 c/src/lib/libbsp/powerpc/shared/irq/irq_init.c           |  4 ++--
 c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c  |  4 ++--
 c/src/lib/libbsp/powerpc/shared/openpic/openpic.c        |  2 +-
 .../lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c  |  2 +-
 c/src/lib/libbsp/powerpc/shared/startup/bspstart.c       |  6 ------
 c/src/lib/libbsp/powerpc/shared/startup/panic.c          |  6 ------
 c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c       |  2 +-
 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c        |  6 ------
 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c      | 14 --------------
 c/src/lib/libbsp/powerpc/tqm8xx/console/console.c        |  2 +-
 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c       | 16 +---------------
 c/src/lib/libbsp/powerpc/virtex4/include/bsp.h           |  1 -
 c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c          |  2 +-
 c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c      | 12 ------------
 c/src/lib/libbsp/powerpc/virtex5/include/bsp.h           |  1 -
 c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c          |  2 +-
 c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c      | 12 ------------
 c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c          |  6 +++---
 c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c        |  8 ++++----
 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c           |  6 +++---
 cpukit/score/cpu/powerpc/rtems/score/cpu.h               |  2 --
 47 files changed, 43 insertions(+), 192 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h b/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h
index 8678404130..e980f1a056 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h
@@ -52,7 +52,7 @@ typedef enum {
  * is cached and repeated calls just return the cached value.
  * If a non-zero argument is passed, the routine panics
- * (BSP_panic) if no recognized bridge is found;
+ * (rtems_panic) if no recognized bridge is found;
 DiscoveryVersion BSP_getDiscoveryVersion(int assertion);
@@ -233,7 +233,6 @@ extern char *BSP_commandline_string;
   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
 extern rtems_configuration_table  BSP_Configuration;
-extern void BSP_panic(char *s);
 extern void bsp_reset(void);
 extern int BSP_disconnect_clock_handler (void);
 extern int BSP_connect_clock_handler (void);
diff --git a/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c b/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c
index 8efe2ce8bd..f77125c4a7 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c
@@ -554,7 +554,7 @@ int i;
 		break;
 		default:
-			BSP_panic("Unable to initialize interrupt controller; unknown chip");
+			rtems_panic("Unable to initialize interrupt controller; unknown chip");
 		break;
diff --git a/c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c b/c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c
index a99fc1cec5..2c0554c988 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/irq/irq_init.c
@@ -100,7 +100,7 @@ int i;
 		 * put something here that will show the failure...
-		BSP_panic("Unable to initialize RTEMS interrupt Management!!! System locked\n");
+		rtems_panic("Unable to initialize RTEMS interrupt Management!!! System locked\n");
 #ifdef TRACE_IRQ_INIT
diff --git a/c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c b/c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c
index b45585a6cf..1d84ac3a01 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c
@@ -112,7 +112,7 @@ printk("config data is %p\n", BSP_pci_configuration.pci_config_data);
 		if ( PCI_VENDOR_ID_MARVELL != ds ) {
 			if ( assertion ) {
 				printk("Host bridge vendor id: 0x%04x\n",ds);
-				BSP_panic("Host bridge vendor @ pci(0,0,0) is not MARVELL");
+				rtems_panic("Host bridge vendor @ pci(0,0,0) is not MARVELL");
 			else return unknown;
@@ -140,7 +140,7 @@ printk("config data is %p\n", BSP_pci_configuration.pci_config_data);
 					printk("Marvell device id 0x%04x, revision 0x%02x; check %s:%u\n",
 							ds, dc,
 							__FILE__,__LINE__);
-					BSP_panic("Unknown Marvell bridge or revision@ pci(0,0,0) is not MARVELL");
+					rtems_panic("Unknown Marvell bridge or revision@ pci(0,0,0) is not MARVELL");
 			break;
diff --git a/c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c b/c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c
index d2a5232a1d..68d7467b22 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c
@@ -193,7 +193,7 @@ extern pci_config_access_functions pci_indirect_functions;
 	pci_initialize();
 	/* check for overflow of an unsigned char */
 	if ( BSP_pci_hose1_bus_base + pci_bus_count() > 255 ) {
-		BSP_panic("Too many PCI busses in the system");
+		rtems_panic("Too many PCI busses in the system");
 	/* readjust total number */
 	ucMaxPCIBus+=BSP_pci_hose1_bus_base;
diff --git a/c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c b/c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c
index f3bc120be8..21d55916cb 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c
@@ -163,7 +163,7 @@ uint32_t	b0,b1,r0,r1,lim,dis;
 		break;
 		default:
-			BSP_panic("Unknown discovery version; switch in file: "__FILE__" not implemented (yet)");
+			rtems_panic("Unknown discovery version; switch in file: "__FILE__" not implemented (yet)");
 		break; /* never get here */
diff --git a/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c b/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c
index 79dd2976d0..56118d01d5 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c
@@ -84,7 +84,7 @@ rtems_pci_io_remap(int bus_from, int bus_to, uint32_t offset)
   unsigned int  bas, lim;
   if ( offset & ((1<<12)-1) ) {
-    BSP_panic("rtems_pci_io_remap(): offset must be 4k aligned");
+    rtems_panic("rtems_pci_io_remap(): offset must be 4k aligned");
     return -1;
@@ -114,12 +114,12 @@ rtems_pci_io_remap(int bus_from, int bus_to, uint32_t offset)
         switch ( b ) {
           default:
             printk("PCI header type %i (@%i/%i/%i)\n", b, bus, dev, fun);
-            BSP_panic("rtems_pci_io_remap(): unknown PCI header type");
+            rtems_panic("rtems_pci_io_remap(): unknown PCI header type");
           return -1; /* keep compiler happy */
           case PCI_HEADER_TYPE_CARDBUS:
-            BSP_panic("rtems_pci_io_remap():  don't know how to deal with Cardbus bridge");
+            rtems_panic("rtems_pci_io_remap():  don't know how to deal with Cardbus bridge");
           return -1;
           case PCI_HEADER_TYPE_NORMAL:
@@ -167,7 +167,7 @@ rtems_pci_io_remap(int bus_from, int bus_to, uint32_t offset)
           switch ( b ) {
             default:
               printk("Unknown IO range type 0x%x (@%i/%i/%i)\n", b, bus, dev, fun);
-              BSP_panic("rtems_pci_io_remap(): unknown IO range type");
+              rtems_panic("rtems_pci_io_remap(): unknown IO range type");
             return -1;
             case PCI_IO_RANGE_TYPE_16:
diff --git a/c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c b/c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c
index cf92b330df..f09d97e720 100644
--- a/c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c
@@ -112,12 +112,6 @@ uint32_t bsp_time_base_frequency;
 /* Legacy */
 uint32_t bsp_clicks_per_usec;
-void BSP_panic(char *s)
-  printk("%s PANIC %s\n",_RTEMS_version, s);
-  __asm__ __volatile ("sc");
 void _BSP_Fatal_error(unsigned int v)
   printk("%s PANIC ERROR %x\n",_RTEMS_version, v);
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c b/c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c
index f1ffcac9e1..db89f5e65f 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c
@@ -51,20 +51,6 @@ static int mpc83xx_decrementer_exception_handler( BSP_Exception_frame *frame, un
   return 0;
-  rtems_interrupt_level level;
-  rtems_interrupt_disable(level);
-  (void) level;
-  printk("%s PANIC %s\n", rtems_get_version_string(), s);
-  while (1) {
-    /* Do nothing */
 void _BSP_Fatal_error(unsigned n)
@@ -145,7 +131,7 @@ void bsp_start( void)
   /* Install default handler for the decrementer exception */
   sc = ppc_exc_set_handler( ASM_DEC_VECTOR, mpc83xx_decrementer_exception_handler);
   if (sc != RTEMS_SUCCESSFUL) {
-    BSP_panic("cannot install decrementer exception handler");
+    rtems_panic("cannot install decrementer exception handler");
   /* Initalize interrupt support */
diff --git a/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c b/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c
index 4165df1b14..d48855a979 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c
@@ -85,7 +85,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
-    BSP_panic(
+    rtems_panic(
       "Unable to initialize RTEMS interrupt management!!! System locked\n"
diff --git a/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c b/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
index 8facb27ffb..dc53ed7543 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
@@ -207,12 +207,6 @@ static void BSP_ask_for_reset(void)
   while(1) {};
-  BSP_ask_for_reset();
   printk("%s FATAL ERROR %x\n",_RTEMS_version, v);
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h b/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
index e2ba856fe7..675796becf 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h
@@ -206,7 +206,6 @@ extern char *BSP_commandline_string;
 #define BSP_Convert_decrementer( _value ) \
 /* extern int printk(const char *, ...) __attribute__((format(printf, 1, 2))); */
diff --git a/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c
index 3aa165961e..b1f02190a5 100644
--- a/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c
@@ -103,13 +103,6 @@ static void _BSP_GPLED1_off(void)
   csr->bcsr0 |=  GP1_LED;		/* Turn off GP1 LED */
-  _BSP_GPLED1_on();
   _BSP_GPLED0_on();
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h b/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
index 43b64f4845..3fbfcb3120 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
@@ -291,7 +291,6 @@ extern char *BSP_commandline_string;
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c b/c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c
index 460c3c9a1d..c40692e688 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/mvme3100/irq/irq_init.c
@@ -133,6 +133,6 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
index 41edaf5743..f22290882d 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
@@ -105,12 +105,6 @@ int i;
 BSP_output_char_function_type     BSP_output_char = BSP_output_char_via_serial;
 BSP_polling_getchar_function_type BSP_poll_char = NULL;
-  printk("\n%s PANIC %s\n",_RTEMS_version, s);
   printk("\n%s PANIC ERROR %x\n",_RTEMS_version, v);
@@ -186,7 +180,7 @@ BSP_calc_freqs( void )
     break;
     default:
-      BSP_panic("Unknown PLL sys-clock ratio; something's wrong here");
+      rtems_panic("Unknown PLL sys-clock ratio; something's wrong here");
   switch ( e500_ratio ) {
@@ -195,7 +189,7 @@ BSP_calc_freqs( void )
     break;
     default:
-      BSP_panic("Unknown PLL e500-clock ratio; something's wrong here");
+      rtems_panic("Unknown PLL e500-clock ratio; something's wrong here");
   printk("Core Complex Bus (CCB) Clock Freq: %10u Hz\n", BSP_bus_frequency);
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h b/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h
index 0ed628a6e1..c1b17cee10 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h
@@ -136,7 +136,6 @@ extern unsigned int BSP_time_base_divisor;
 extern int BSP_disconnect_clock_handler(void);
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c b/c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c
index 5bfe08df9b..ede4014f22 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c
@@ -136,7 +136,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
   printk("Done setup irq mngt configuration\n");
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
index bef0173aa3..8ef5876047 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
@@ -254,7 +254,7 @@ int pci_initialize(void)
       if (++numPCIDevs > PCI_MAX_DEVICES) {
-	 BSP_panic("Too many PCI devices found; increase PCI_MAX_DEVICES in pci.h\n");
+	 rtems_panic("Too many PCI devices found; increase PCI_MAX_DEVICES in pci.h\n");
       if (!deviceFound) deviceFound=1;
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
index 1fb238b123..66fcd2b130 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
@@ -111,12 +111,6 @@ static unsigned char ConfVPD_buff[200];
 static char cmdline_buf[CMDLINE_BUF_SIZE];
 char *BSP_commandline_string = cmdline_buf;
diff --git a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
index 197d8b5ebe..3d2a82f2c0 100644
--- a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
@@ -80,7 +80,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
-    BSP_panic(
+    rtems_panic(
@@ -95,7 +95,7 @@ static int psim_exception_handler(
   unsigned exception_number
-  BSP_panic("Unexpected interrupt occured");
+  rtems_panic("Unexpected interrupt occured");
   return 0;
diff --git a/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c b/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c
index 134a850bb3..b0dc1e639e 100644
--- a/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/psim/startup/bspstart.c
@@ -60,12 +60,6 @@ unsigned int BSP_time_base_divisor;
 extern unsigned long __rtems_end[];
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
index f1c6d5568a..24b15dcd49 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c
@@ -31,7 +31,7 @@ static int qemuppc_exception_handler(
   return 0;
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/startup/bsppanic.c b/c/src/lib/libbsp/powerpc/qemuppc/startup/bsppanic.c
index c6a7267c72..37486007fd 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/startup/bsppanic.c
+++ b/c/src/lib/libbsp/powerpc/qemuppc/startup/bsppanic.c
@@ -7,12 +7,6 @@ __outb(int port, unsigned char v)
   *((volatile unsigned char *)(0x80000000 + port)) = v;
-  __outb (0x92, 0x01);
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c b/c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c
index 9dc2639ee8..bbb7f3a562 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c
@@ -99,7 +99,7 @@ void bsp_start( void )
   sc = ppc_exc_set_handler( ASM_DEC_VECTOR, default_decrementer_exception_handler);
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c b/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
index 859171dd30..3030d3761f 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
@@ -52,20 +52,6 @@ uint32_t bsp_time_base_frequency;
 uint32_t qoriq_clock_frequency;
-  rtems_interrupt_local_disable(level);
-  (void) level;
-  while (1) {
-    /* Do nothing */
diff --git a/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c b/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c
index a58cd246c4..1a44992a5b 100644
--- a/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c
@@ -208,7 +208,7 @@ void VIA_isa_bridge_interrupts_setup(void)
 loop_exit:
-  if (!found) BSP_panic("VIA_82C586 PCI/ISA bridge not found!n");
+  if (!found) rtems_panic("VIA_82C586 PCI/ISA bridge not found!n");
   tmp = inb(0x810);
   if  ( !(tmp & 0x2)) {
@@ -355,7 +355,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
diff --git a/c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c b/c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c
index 80901223b8..4a9c393f7f 100644
--- a/c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c
+++ b/c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c
@@ -263,8 +263,8 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
 #error "Configuration Error -- BSP with ISA + PCI IRQs MUST define BSP_PCI_ISA_BRIDGE_IRQ"
 #endif
 #else
-	BSP_panic("MUST have an OpenPIC if BSP has PCI IRQs but no ISA IRQs");
-	/* BSP_panic() never returns but the 'return' statement silences
+	rtems_panic("MUST have an OpenPIC if BSP has PCI IRQs but no ISA IRQs");
+	/* rtems_panic() never returns but the 'return' statement silences
 	 * a compiler warning about 'irq' possibly being used w/o initialization.
 	return -1;
diff --git a/c/src/lib/libbsp/powerpc/shared/openpic/openpic.c b/c/src/lib/libbsp/powerpc/shared/openpic/openpic.c
index 15a37d1444..556014964b 100644
--- a/c/src/lib/libbsp/powerpc/shared/openpic/openpic.c
+++ b/c/src/lib/libbsp/powerpc/shared/openpic/openpic.c
@@ -178,7 +178,7 @@ void openpic_init(int main_pic, unsigned char *polarities, unsigned char *senses
     const char *version, *vendor, *device;
     if (!OpenPIC)
-	BSP_panic("No OpenPIC found");
+	rtems_panic("No OpenPIC found");
     t = openpic_read(&OpenPIC->Global.Feature_Reporting0);
     switch (t & OPENPIC_FEATURE_VERSION_MASK) {
diff --git a/c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c b/c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c
index 80d5461dcb..0a1c04a2e2 100644
--- a/c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c
+++ b/c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c
@@ -188,7 +188,7 @@ void detect_host_bridge(void)
 #if BSP_PCI_IRQ_NUMBER > 0
   if (OpenPIC == (volatile struct OpenPIC *)0) {
-    BSP_panic("OpenPic Not found\n");
+    rtems_panic("OpenPic Not found\n");
 #endif
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
index 5a069b84f4..8a3695ab47 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
@@ -84,12 +84,6 @@ unsigned int BSP_processor_frequency;
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/panic.c b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
index b1a926827b..636dbe6fd0 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/panic.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
@@ -18,12 +18,6 @@ rebootQuestion(void)
   bsp_reset();
-  rebootQuestion();
 #define THESRC _Internal_errors_What_happened.the_source
 #define THEERR _Internal_errors_What_happened.the_error
diff --git a/c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c b/c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c
index 5036cb17d1..158a899b2a 100644
--- a/c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c
+++ b/c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c
@@ -429,7 +429,7 @@ int err;
 #error  "BSP_PCI_VME_DRIVER_DOES_EOI/BSP_PIC_DO_EOI feature can only be used with vmeUniverse"
 #endif
   if ( vmeUniverse0PciIrqLine < 0 )
-	BSP_panic("Unable to get universe interrupt line info from PCI config");
+	rtems_panic("Unable to get universe interrupt line info from PCI config");
   _BSP_vme_bridge_irq = vmeUniverse0PciIrqLine;
 #endif
   return 0;
diff --git a/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c b/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c
index 4016c6175f..98bf9e0539 100644
--- a/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c
@@ -42,12 +42,6 @@ uint32_t   bsp_clock_speed;	       /* Serial clocks per second */
 uint32_t   bsp_timer_least_valid;
 uint32_t   bsp_timer_average_overhead;
diff --git a/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c b/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c
index f729ae60d1..2a88329516 100644
--- a/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c
@@ -33,20 +33,6 @@ LINKER_SYMBOL(bsp_exc_vector_base);
 uint32_t bsp_time_base_frequency = 10000000;
-  (void) level;
-  while (1) {
-    /* Do nothing */
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/console/console.c b/c/src/lib/libbsp/powerpc/tqm8xx/console/console.c
index 7810bc1bd1..5a681b19fb 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/console/console.c
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/console/console.c
@@ -526,7 +526,7 @@ sccInitialize (int chan)
   rxBuf[chan] = malloc(sizeof(*rxBuf[chan]) + 2*PPC_CACHE_ALIGNMENT);
   if (rxBuf[chan] == NULL) {
-    BSP_panic("Cannot allocate console rx buffer\n");
+    rtems_panic("Cannot allocate console rx buffer\n");
   else {
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c b/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c
index beec6f97e4..4cc368ad82 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c
@@ -51,20 +51,6 @@ uint32_t   bsp_timer_average_overhead; /* Average overhead of timer in ticks */
 uint32_t   bsp_timer_least_valid;      /* Least valid number from timer      */
 bool       bsp_timer_internal_clock;   /* TRUE, when timer runs with CPU clk */
-void BSP_panic( char *s)
-  rtems_interrupt_disable( level);
-  (void) level; /* avoid set but not used warning */
-  printk( "%s PANIC %s\n", _RTEMS_version, s);
-  while (1) {
-    /* Do nothing */
 void _BSP_Fatal_error( unsigned n)
@@ -169,7 +155,7 @@ void bsp_start( void)
   if (RTEMS_SUCCESSFUL !=
       bsp_tqm_get_cib_uint32("cu",
 			     &BSP_bus_frequency)) {
-    BSP_panic("Cannot determine BUS frequency\n");
+    rtems_panic("Cannot determine BUS frequency\n");
   bsp_time_base_frequency = BSP_bus_frequency / 16;
diff --git a/c/src/lib/libbsp/powerpc/virtex4/include/bsp.h b/c/src/lib/libbsp/powerpc/virtex4/include/bsp.h
index 67bf6c62c1..747dfdf83a 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/virtex4/include/bsp.h
@@ -70,7 +70,6 @@ extern rtems_configuration_table BSP_Configuration;     /* owned by BSP */
 #endif /* ASM */
 void BSP_ask_for_reset(void);
-void BSP_panic(char *s);
 void _BSP_Fatal_error(unsigned int v);
diff --git a/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c b/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c
index 97f8c5879f..5feafaf4b6 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c
@@ -321,6 +321,6 @@ void BSP_rtems_irq_mngt_init(unsigned cpuId)
    * initialize interrupt management
   if (!BSP_rtems_irq_mngt_set(&initialConfig)) {
diff --git a/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
index 1c4c531091..8a8004d850 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c
@@ -133,18 +133,6 @@ void BSP_ask_for_reset(void)
-  RTEMS_UNUSED rtems_interrupt_level level;
-  printk("\n%s PANIC %s\n", rtems_get_version_string(), s);
diff --git a/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h b/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
index b0df844863..490ed8fd6e 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
@@ -99,7 +99,6 @@ void zero_bss(void);
 #endif /* ASM */
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c b/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c
index cba95dfb7f..1fea9214aa 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c
@@ -338,6 +338,6 @@ void BSP_rtems_irq_mngt_init(unsigned cpuId)
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
index 93f99adda0..ff7a384e34 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c
@@ -147,18 +147,6 @@ void BSP_ask_for_reset(void)
diff --git a/c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c b/c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c
index 5d6e174084..e986f236d2 100644
--- a/c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c
+++ b/c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c
@@ -1602,15 +1602,15 @@ rtems_irq_connect_data	xx;
 	if ( shared ) {
 #if BSP_SHARED_HANDLER_SUPPORT > 0
 		if (!BSP_install_rtems_shared_irq_handler(&xx))
-			BSP_panic("unable to install vmeTsi148 shared irq handler");
+			rtems_panic("unable to install vmeTsi148 shared irq handler");
 #else
         uprintf(stderr,"vmeTsi148: WARNING: your BSP doesn't support sharing interrupts\n");
 		if (!BSP_install_rtems_irq_handler(&xx))
-			BSP_panic("unable to install vmeTsi148 irq handler");
+			rtems_panic("unable to install vmeTsi148 irq handler");
 #endif
 	} else {
diff --git a/c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c b/c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c
index 0914eda922..a5f25b41de 100644
--- a/c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c
+++ b/c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c
@@ -283,7 +283,7 @@ extern int k_vsprintf(char *, char *, va_list);
 char	buf[200];
 	rval = k_vsprintf(buf,fmt,ap);
 	if (rval > sizeof(buf))
-			BSP_panic("vmeUniverse/uprintk: buffer overrun");
+			rtems_panic("vmeUniverse/uprintk: buffer overrun");
 	printk(buf);
 	return rval;
@@ -2032,15 +2032,15 @@ rtems_irq_connect_data	aarrggh;
 	if ( shared ) {
 		if (!BSP_install_rtems_shared_irq_handler(&aarrggh))
-			BSP_panic("unable to install vmeUniverse shared irq handler");
+			rtems_panic("unable to install vmeUniverse shared irq handler");
 #else
 		uprintf(stderr,"vmeUniverse: WARNING: your BSP doesn't support sharing interrupts\n");
 		if (!BSP_install_rtems_irq_handler(&aarrggh))
-			BSP_panic("unable to install vmeUniverse irq handler");
+			rtems_panic("unable to install vmeUniverse irq handler");
 #endif
 	} else {
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c b/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c
index 3ba7e8f505..351edb4ffe 100644
--- a/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c
+++ b/c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c
@@ -141,7 +141,7 @@ void CPU_rtems_irq_mng_init(unsigned cpuId)
-      BSP_panic("Unable to initialize RTEMS interrupt Management\n");
+      rtems_panic("Unable to initialize RTEMS interrupt Management\n");
@@ -155,11 +155,11 @@ void CPU_rtems_irq_mng_init(unsigned cpuId)
     vectorDesc.off         = nop_raw_enable;
     vectorDesc.isOn        = raw_is_connected;
     if (!mpc5xx_set_exception (&vectorDesc)) {
-      BSP_panic("Unable to initialize RTEMS decrementer raw exception\n");
+      rtems_panic("Unable to initialize RTEMS decrementer raw exception\n");
     vectorDesc.exceptIndex = ASM_EXT_VECTOR;
     vectorDesc.hdl.vector  = ASM_EXT_VECTOR;
-      BSP_panic("Unable to initialize RTEMS external raw exception\n");
+      rtems_panic("Unable to initialize RTEMS external raw exception\n");
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index cacd3ea105..b8f00bf910 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -675,8 +675,6 @@ static inline void _CPU_ISR_Set_level( uint32_t   level )
   _CPU_MSR_SET(msr);
-void BSP_panic(char *);
 /* Fatal Error manager macros */
2.12.3
