sptimecounter01 use of stack allocator/deallocator
Wed Nov 22 07:43:14 UTC 2017
On 21/11/17 16:23, Joel Sherrill wrote:
> On Tue, Nov 21, 2017 at 1:12 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 20/11/17 17:53, Joel Sherrill wrote:
>         The purpose of defining these to NULL isn't documented in this
>         test and renders this test broken for what seems to be a
>         reason orthogonal to the test's apparent purpose.
>     This test runs in a minimal environment (test runs in boot_card())
>     to verify the static initialization of the timecounter infrastructure.
>     Running in boot_card() is probably your problem, e.g. not
>     bsp_start() invocation.
> Actually, I spotted this based on redefine warnings, not running the
> test. I will add
> undef's before the defines. This should run fine since the starting stack
> is in the right place.
Maybe we need
BSP_TASK_STACK_ALLOCATOR_INIT
BSP_TASK_STACK_DEALLOCATOR
confdefs.h defines.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
