[PATCH] c-user: Document rtems_panic()
Sebastian Huber
Wed Nov 22 13:10:06 UTC 2017
Close #3244.
c-user/fatal_error.rst | 46 ++++++++++++++++++++++++++++++++++++++++++----
1 file changed, 42 insertions(+), 4 deletions(-)
diff --git a/c-user/fatal_error.rst b/c-user/fatal_error.rst
index 090850d..d8566f0 100644
--- a/c-user/fatal_error.rst
+++ b/c-user/fatal_error.rst
@@ -21,6 +21,8 @@ provided by the fatal error manager are:
- rtems_fatal_ - Invoke the fatal error handler
+- rtems_panic_ - Print a message and invoke the fatal error handler
- rtems_shutdown_executive_ - Shutdown RTEMS
- rtems_exception_frame_print_ - Print the CPU exception frame
@@ -122,6 +124,9 @@ RTEMS_FATAL_SOURCE_EXCEPTION (9)
RTEMS_FATAL_SOURCE_SMP (10)
Fatal source of SMP domain. See :c:type:`SMP_Fatal_code`.
+RTEMS_FATAL_SOURCE_PANIC (11)
+ Fatal source of :c:func:`rtems_panic`, see :ref:`rtems_panic`.
.. _internal_errors:
Internal Error Codes
@@ -453,15 +458,15 @@ sequence, related constants, usage, and status codes.
.. _rtems_fatal:
-FATAL - Invoke the fatal error
+FATAL - Invoke the fatal error handler
CALLING SEQUENCE:
.. code-block:: c
void rtems_fatal(
- rtems_fatal_source fatal_source,
- rtems_fatal_code error_code
+ rtems_fatal_source fatal_source,
+ rtems_fatal_code error_code
) RTEMS_NO_RETURN;
DIRECTIVE STATUS CODES:
@@ -478,6 +483,39 @@ NOTE:
\clearpage
+.. index:: panic
+.. index:: rtems_panic
+.. _rtems_panic:
+PANIC - Print a message and invoke the fatal error handler
+CALLING SEQUENCE:
+ .. code-block:: c
+ void rtems_panic(
+ const char *fmt,
+ ) RTEMS_NO_RETURN RTEMS_PRINTFLIKE( 1, 2 );
+DIRECTIVE STATUS CODES:
+ NONE - This function will not return to the caller.
+DESCRIPTION:
+ This directive prints a message via :c:func:`printk` specified by the
+ format and optional parameters and then terminates the system with the
+ :c:macro:`RTEMS_FATAL_SOURCE_PANIC` fatal source. The fatal code is set to
+ the format string address.
+NOTE:
+ Registered :c:func:`atexit()` or :c:func:`on_exit()` handlers are not
+ called. Use :c:func:`exit()` in case these handlers should be invoked.
+.. raw:: latex
+ \clearpage
.. index:: shutdown RTEMS
.. index:: rtems_shutdown_executive
2.12.3
