[PATCH] source-builder/sb/bootstrap.py: Do not reference bsp_specs to find BSPs
Joel Sherrill
joel at rtems.org
Wed Nov 22 15:33:34 UTC 2017
Updates #3520.
source-builder/sb/bootstrap.py | 13 +++++++++++--
1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/source-builder/sb/bootstrap.py b/source-builder/sb/bootstrap.py
index 9095f3c..8fda3b8 100644
--- a/source-builder/sb/bootstrap.py
+++ b/source-builder/sb/bootstrap.py
@@ -34,6 +34,14 @@ import options
import path
import version
+def _collect_dirs(path_, dir):
+ confs = []
+ for root, dirs, files in os.walk(path.host(path_), topdown = True):
+ for f in dirs:
+ if f == dir:
+ confs += [path.shell(path.join(root, f))]
+ return confs
def _collect(path_, file):
confs = []
@@ -130,7 +138,7 @@ class autoreconf:
def bspopts(self):
if _grep(self.configure, 'RTEMS_CHECK_BSPDIR'):
- bsp_specs = _collect(self.cwd, 'bsp_specs')
+ bsps = _collect_dirs(self.cwd, 'custom')
try:
acinclude = path.join(self.cwd, 'acinclude.m4')
b = open(path.host(acinclude), 'w')
@@ -138,8 +146,9 @@ class autoreconf:
b.write('AC_DEFUN([RTEMS_CHECK_BSPDIR],' + os.linesep)
b.write('[' + os.linesep)
b.write(' case "$1" in' + os.linesep)
- for bs in sorted(bsp_specs):
+ for bs in sorted(bsps):
dir = path.dirname(bs)[len(self.cwd) + 1:]
+ dir = os.path.dirname(dir)
b.write(' %s )%s' % (dir, os.linesep))
b.write(' AC_CONFIG_SUBDIRS([%s]);;%s' % (dir, os.linesep))
b.write(' *)' + os.linesep)
1.8.3.1
