Build Failure on All BSPs on Master
Fri Oct 6 17:00:32 UTC 2017
Hi
Every BSP (> 100 so far) in my build sweep is failing when linking psx02
with this:
/home/joel/rtems-work/rtems-testing/rtems/build-arm-tms570ls3137_hdk-rtems/arm-rtems4.12/c/tms570ls3137_hdk/testsuites/psxtests/psx02/../../../../../../../rtems/c/src/../../testsuites/psxtests/psx02/init.c:92:
undefined reference to `sigpending'
/home/joel/rtems-work/rtems-testing/rtems/build-arm-tms570ls3137_hdk-rtems/arm-rtems4.12/c/tms570ls3137_hdk/testsuites/psxtests/psx02/../../../../../../../rtems/c/src/../../testsuites/psxtests/psx02/init.c:101:
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171006/c66a874c/attachment.html>
