[PATCH 2/3] posix: Remove POSIX_API_Control::schedparam
Tue Oct 17 10:11:54 UTC 2017
Move sporadic server scheduler parameters to
POSIX_API_Control::Sporadic.  Remove redundant scheduler priority
parameter.
Update #2514.
 cpukit/posix/include/rtems/posix/pthreadattrimpl.h | 18 +++++++++++++++
 cpukit/posix/include/rtems/posix/pthreadimpl.h     |  4 ++--
 cpukit/posix/include/rtems/posix/threadsup.h       | 20 +++++++++++++---
 cpukit/posix/src/pthread.c                         |  6 -----
 cpukit/posix/src/pthreadcreate.c                   |  8 ++++++-
 cpukit/posix/src/pthreadgetattrnp.c                | 24 +++++++++++++++----
 cpukit/posix/src/pthreadgetschedparam.c            |  4 ++--
 cpukit/posix/src/pthreadsetschedparam.c            | 27 ++++++++++++----------
 testsuites/psxtests/psxgetattrnp01/init.c          |  6 +----
 9 files changed, 81 insertions(+), 36 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/pthreadattrimpl.h b/cpukit/posix/include/rtems/posix/pthreadattrimpl.h
index a52be931a1..1e5105deab 100644
--- a/cpukit/posix/include/rtems/posix/pthreadattrimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadattrimpl.h
@@ -24,6 +24,8 @@
+#include <rtems/posix/priorityimpl.h>
+#include <rtems/posix/threadsup.h>
 #ifdef __cplusplus
 extern "C" {
@@ -61,6 +63,22 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Initialize_attributes(
+RTEMS_INLINE_ROUTINE void _POSIX_Threads_Get_sched_param_sporadic(
+  const Thread_Control    *the_thread,
+  const POSIX_API_Control *api,
+  const Scheduler_Control *scheduler,
+  struct sched_param      *param
+  param->sched_ss_low_priority = _POSIX_Priority_From_core(
+    scheduler,
+    api->Sporadic.Low_priority.priority
+  param->sched_ss_repl_period = api->Sporadic.sched_ss_repl_period;
+  param->sched_ss_init_budget = api->Sporadic.sched_ss_init_budget;
+  param->sched_ss_max_repl = api->Sporadic.sched_ss_max_repl;
 #ifdef __cplusplus
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index bae9e344a0..82593d3097 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -54,12 +54,12 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Sporadic_timer_insert(
   the_thread->cpu_time_budget =
-    _Timespec_To_ticks( &api->schedparam.sched_ss_init_budget );
+    _Timespec_To_ticks( &api->Sporadic.sched_ss_init_budget );
   _Watchdog_Per_CPU_insert_ticks(
     &api->Sporadic.Timer,
     _Per_CPU_Get(),
-    _Timespec_To_ticks( &api->schedparam.sched_ss_repl_period )
+    _Timespec_To_ticks( &api->Sporadic.sched_ss_repl_period )
diff --git a/cpukit/posix/include/rtems/posix/threadsup.h b/cpukit/posix/include/rtems/posix/threadsup.h
index 816ef566d8..b3b3910084 100644
--- a/cpukit/posix/include/rtems/posix/threadsup.h
+++ b/cpukit/posix/include/rtems/posix/threadsup.h
@@ -46,9 +46,6 @@ typedef struct {
   /** The scheduler policy. */
   int schedpolicy;
-  /** The scheduler parameters */
-  struct sched_param schedparam;
    * @brief Control block for the sporadic server scheduling policy.
@@ -67,6 +64,23 @@ typedef struct {
      * policy.
     Priority_Node Low_priority;
+     * @brief Replenishment period for sporadic server.
+    struct timespec sched_ss_repl_period;
+     * @brief Initial budget for sporadic server.
+    struct timespec sched_ss_init_budget;
+     * @brief Maximum pending replenishments.
+     * Only used by pthread_getschedparam() and pthread_getattr_np().
+    int sched_ss_max_repl;
   } Sporadic;
   /** This is the set of signals which are currently unblocked. */
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 291b19532d..8bd44ca03a 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -126,12 +126,6 @@ static bool _POSIX_Threads_Create_extension(
   api = created->API_Extensions[ THREAD_API_POSIX ];
-  /* XXX check all fields are touched */
-  api->schedparam.sched_priority = _POSIX_Priority_From_core(
-    _Thread_Scheduler_get_home( created ),
-    _Thread_Get_priority( created )
    *  If the thread is not a posix thread, then all posix signals are blocked
    *  by default.
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index d8cafe52ce..0de566f7c2 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -241,8 +241,14 @@ int pthread_create(
   api->created_with_explicit_scheduler =
     ( the_attr->inheritsched == PTHREAD_EXPLICIT_SCHED );
   api->schedpolicy = the_attr->schedpolicy;
-  api->schedparam = the_attr->schedparam;
   _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
+  api->Sporadic.sched_ss_repl_period =
+    the_attr->schedparam.sched_ss_repl_period;
+  api->Sporadic.sched_ss_init_budget =
+    the_attr->schedparam.sched_ss_init_budget;
+  api->Sporadic.sched_ss_max_repl =
+    the_attr->schedparam.sched_ss_max_repl;
   if ( schedpolicy == SCHED_SPORADIC ) {
     _POSIX_Threads_Sporadic_timer( &api->Sporadic.Timer );
diff --git a/cpukit/posix/src/pthreadgetattrnp.c b/cpukit/posix/src/pthreadgetattrnp.c
index d815fc8c53..bebf35e4d6 100644
--- a/cpukit/posix/src/pthreadgetattrnp.c
+++ b/cpukit/posix/src/pthreadgetattrnp.c
@@ -24,6 +24,8 @@
+#include <rtems/posix/pthreadattrimpl.h>
@@ -32,10 +34,11 @@ int pthread_getattr_np(
   pthread_attr_t *attr
-  Thread_Control    *the_thread;
-  ISR_lock_Context   lock_context;
-  POSIX_API_Control *api;
-  bool               ok;
+  Thread_Control          *the_thread;
+  ISR_lock_Context         lock_context;
+  POSIX_API_Control       *api;
+  const Scheduler_Control *scheduler;
+  bool                     ok;
   if ( attr == NULL ) {
     return EINVAL;
@@ -65,7 +68,18 @@ int pthread_getattr_np(
   attr->schedpolicy = api->schedpolicy;
-  attr->schedparam = api->schedparam;
+  scheduler = _Thread_Scheduler_get_home( the_thread );
+  attr->schedparam.sched_priority = _POSIX_Priority_From_core(
+    scheduler,
+    _Thread_Get_priority( the_thread )
+  _POSIX_Threads_Get_sched_param_sporadic(
+    the_thread,
+    api,
+    scheduler,
+    &attr->schedparam
   attr->cputime_clock_allowed = 1;
   if ( _Thread_Is_joinable( the_thread ) ) {
diff --git a/cpukit/posix/src/pthreadgetschedparam.c b/cpukit/posix/src/pthreadgetschedparam.c
index f172caecd4..a5494b5922 100644
--- a/cpukit/posix/src/pthreadgetschedparam.c
+++ b/cpukit/posix/src/pthreadgetschedparam.c
@@ -25,6 +25,7 @@
@@ -57,9 +58,8 @@ int pthread_getschedparam(
   _Thread_Wait_acquire_critical( the_thread, &queue_context );
   *policy = api->schedpolicy;
-  *param  = api->schedparam;
+  _POSIX_Threads_Get_sched_param_sporadic( the_thread, api, scheduler, param );
   priority = the_thread->Real_priority.priority;
   _Thread_Wait_release( the_thread, &queue_context );
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 3bd5bc4f3a..c22d4f59b1 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -41,28 +41,28 @@ static int _POSIX_Set_sched_param(
+  int                      normal_prio;
   int                      low_prio;
-  int                      high_prio;
   bool                     valid;
   Priority_Control         core_normal_prio;
   Priority_Control         core_low_prio;
-  if ( policy == SCHED_SPORADIC ) {
-    low_prio = param->sched_ss_low_priority;
-    high_prio = param->sched_priority;
-  } else {
-    low_prio = param->sched_priority;
-    high_prio = low_prio;
+  normal_prio = param->sched_priority;
-  core_normal_prio = _POSIX_Priority_To_core( scheduler, low_prio, &valid );
+  core_normal_prio = _POSIX_Priority_To_core( scheduler, normal_prio, &valid );
   if ( !valid ) {
     return EINVAL;
-  core_low_prio = _POSIX_Priority_To_core( scheduler, high_prio, &valid );
+  if ( policy == SCHED_SPORADIC ) {
+    low_prio = param->sched_ss_low_priority;
+  } else {
+    low_prio = normal_prio;
+  core_low_prio = _POSIX_Priority_To_core( scheduler, low_prio, &valid );
   if ( !valid ) {
     return EINVAL;
@@ -95,13 +95,16 @@ static int _POSIX_Set_sched_param(
   api->schedpolicy = policy;
-  api->schedparam  = *param;
   the_thread->budget_algorithm = budget_algorithm;
   the_thread->budget_callout   = budget_callout;
+  _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
+  api->Sporadic.sched_ss_repl_period = param->sched_ss_repl_period;
+  api->Sporadic.sched_ss_init_budget = param->sched_ss_init_budget;
+  api->Sporadic.sched_ss_max_repl = param->sched_ss_max_repl;
-    _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
     _POSIX_Threads_Sporadic_timer_insert( the_thread, api );
   } else {
diff --git a/testsuites/psxtests/psxgetattrnp01/init.c b/testsuites/psxtests/psxgetattrnp01/init.c
index afde4a210e..19981573d1 100644
--- a/testsuites/psxtests/psxgetattrnp01/init.c
+++ b/testsuites/psxtests/psxgetattrnp01/init.c
@@ -62,11 +62,7 @@ static int attribute_compare(
   if ( attr1->schedpolicy != attr2->schedpolicy )
     return 1;
-  if (memcmp(
-    &attr1->schedparam,
-    &attr2->schedparam,
-    sizeof(struct sched_param)
+  if ( attr1->schedparam.sched_priority != attr2->schedparam.sched_priority )
     return 1;
   #if HAVE_DECL_PTHREAD_ATTR_SETGUARDSIZE
2.12.3
