[PATCH] posix: Fix pthread_create() with user stack
Sebastian Huber
Fri Oct 27 07:03:55 UTC 2017
In case the user provides a stack with address and size, then do not
alter the stack size.
Close #3211.
cpukit/posix/src/pthreadcreate.c | 14 +++++++++++---
1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 2315b7f5ee..5a8cf2d7fb 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -77,6 +77,7 @@ int pthread_create(
const POSIX_API_Control *executing_api;
int schedpolicy = SCHED_RR;
struct sched_param schedparam;
+ size_t stacksize;
Objects_Name name;
int error;
ISR_lock_Context lock_context;
@@ -96,8 +97,15 @@ int pthread_create(
* NOTE: If the user provides the stack we will let it drop below
* twice the minimum.
- if ( the_attr->stackaddr && !_Stack_Is_enough(the_attr->stacksize) )
- return EINVAL;
+ if ( the_attr->stackaddr != NULL ) {
+ if ( !_Stack_Is_enough(the_attr->stacksize) ) {
+ return EINVAL;
+ stacksize = the_attr->stacksize;
+ } else {
+ stacksize = _POSIX_Threads_Ensure_minimum_stack( the_attr->stacksize );
#if 0
int cputime_clock_allowed; /* see time.h */
@@ -200,7 +208,7 @@ int pthread_create(
the_thread,
scheduler,
the_attr->stackaddr,
- _POSIX_Threads_Ensure_minimum_stack(the_attr->stacksize),
+ stacksize,
is_fp,
core_normal_prio,
true, /* preemptible */
2.12.3
