[PATCH 1/2] score: Fix _Scheduler_Set_affinity()
Fri Oct 27 07:04:53 UTC 2017
 cpukit/score/src/scheduleredfsmp.c      |  9 ++++-----
 cpukit/score/src/schedulersetaffinity.c |  7 +++++++
 testsuites/sptests/spscheduler01/init.c | 13 ++++++++++++-
 3 files changed, 23 insertions(+), 6 deletions(-)
diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
index 3a1b1a934e..82255b0f95 100644
--- a/cpukit/score/src/scheduleredfsmp.c
+++ b/cpukit/score/src/scheduleredfsmp.c
@@ -753,19 +753,18 @@ bool _Scheduler_EDF_SMP_Set_affinity(
   Scheduler_Context *context;
   Processor_mask     a;
-  Processor_mask     b;
+  uint32_t           count;
   uint32_t           rqi;
   context = _Scheduler_Get_context( scheduler );
   _Processor_mask_And( &a, &context->Processors, affinity );
+  count = _Processor_mask_Count( &a );
-  if ( _Processor_mask_Count( &a ) == 0 ) {
+  if ( count == 0 ) {
     return false;
-  _Processor_mask_And( &b, &_SMP_Online_processors, affinity );
-  if ( _Processor_mask_Count( &b ) == _SMP_Processor_count ) {
+  if ( count == _SMP_Processor_count ) {
     rqi = 0;
   } else {
     rqi = _Processor_mask_Find_last_set( &a );
diff --git a/cpukit/score/src/schedulersetaffinity.c b/cpukit/score/src/schedulersetaffinity.c
index 3d354800b2..00d1a8b207 100644
--- a/cpukit/score/src/schedulersetaffinity.c
+++ b/cpukit/score/src/schedulersetaffinity.c
@@ -36,6 +36,13 @@ bool _Scheduler_Set_affinity(
     return false;
+   * Reduce affinity set to the online processors to be in line with
+   * _Thread_Initialize() which sets the default affinity to the set of online
+   * processors.
+  _Processor_mask_And( &affinity, &_SMP_Online_processors, &affinity );
   scheduler = _Thread_Scheduler_get_home( the_thread );
   _Scheduler_Acquire_critical( scheduler, &lock_context );
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index 9840a3ebc4..cbdc92ca25 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2014, 2016 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2014, 2017 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -41,6 +41,7 @@ static void test_task_get_set_affinity(void)
   rtems_id task_id;
   rtems_status_code sc;
   cpu_set_t cpusetone;
+  cpu_set_t cpusetall;
   cpu_set_t cpuset;
   size_t big = 2 * CHAR_BIT * sizeof(cpu_set_t);
   size_t cpusetbigsize = CPU_ALLOC_SIZE(big);
@@ -50,6 +51,8 @@ static void test_task_get_set_affinity(void)
   CPU_ZERO(&cpusetone);
   CPU_SET(0, &cpusetone);
+  CPU_FILL(&cpusetall);
   sc = rtems_task_create(
     rtems_build_name('T', 'A', 'S', 'K'),
     2,
@@ -97,6 +100,14 @@ static void test_task_get_set_affinity(void)
   rtems_test_assert(CPU_EQUAL(&cpuset, &cpusetone));
+  sc = rtems_task_set_affinity(RTEMS_SELF, sizeof(cpusetall), &cpusetall);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_get_affinity(task_id, sizeof(cpuset), &cpuset);
+  rtems_test_assert(CPU_EQUAL(&cpuset, &cpusetone));
   cpusetbigone = CPU_ALLOC(big);
   rtems_test_assert(cpusetbigone != NULL);
2.12.3
