[PATCH 2/2] sptests/spscheduler01: Test POSIX set/get affinity
Fri Oct 27 07:04:54 UTC 2017
 testsuites/sptests/spscheduler01/init.c            | 120 +++++++++++++++++----
 testsuites/sptests/spscheduler01/spscheduler01.doc |   2 +
 2 files changed, 99 insertions(+), 23 deletions(-)
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index cbdc92ca25..c7e5518c57 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -16,10 +16,15 @@
   #include "config.h"
 #endif
+#define _GNU_SOURCE
 #include <rtems/libcsupport.h>
+#include <errno.h>
 #include <limits.h>
+#include <string.h>
+#include <pthread.h>
 #include "tmacros.h"
@@ -29,12 +34,83 @@ const char rtems_test_name[] = "SPSCHEDULER 1";
 #define RED rtems_build_name('r', 'e', 'd', ' ')
+#define BIG_NUM_CPUS (2 * CHAR_BIT * sizeof(cpu_set_t))
 static const rtems_id invalid_id = 1;
 static rtems_id master_id;
 static rtems_id sema_id;
+static void assert_eno(rtems_status_code sc, int eno)
+  switch (sc) {
+    case RTEMS_SUCCESSFUL:
+      rtems_test_assert(eno == 0);
+      break;
+    case RTEMS_INVALID_ADDRESS:
+      rtems_test_assert(eno == EFAULT);
+      break;
+    case RTEMS_INVALID_ID:
+      rtems_test_assert(eno == ESRCH);
+      break;
+    case RTEMS_INVALID_NUMBER:
+      rtems_test_assert(eno == EINVAL);
+      break;
+    default:
+      rtems_test_assert(0);
+static rtems_status_code task_get_affinity(
+  rtems_id id,
+  size_t cpusetsize,
+  cpu_set_t *cpuset
+  rtems_status_code sc;
+  int eno;
+  cpu_set_t *cpusetbig;
+  sc = rtems_task_get_affinity(id, cpusetsize, cpuset);
+  if (cpuset != NULL) {
+    cpusetbig = CPU_ALLOC(BIG_NUM_CPUS);
+    rtems_test_assert(cpusetbig != NULL);
+    memcpy(cpusetbig, cpuset, cpusetsize);
+  } else {
+    cpusetbig = NULL;
+  eno = pthread_getaffinity_np(id, cpusetsize, cpusetbig);
+    rtems_test_assert(CPU_EQUAL_S(cpusetsize, cpusetbig, cpuset));
+    CPU_FREE(cpusetbig);
+  assert_eno(sc, eno);
+  return sc;
+static rtems_status_code task_set_affinity(
+  rtems_id id,
+  const cpu_set_t *cpuset
+  int eno;
+  sc = rtems_task_set_affinity(id, cpusetsize, cpuset);
+  eno = pthread_setaffinity_np(id, cpusetsize, cpuset);
+  return sc;
 static void test_task_get_set_affinity(void)
   rtems_id self_id = rtems_task_self();
@@ -43,8 +119,7 @@ static void test_task_get_set_affinity(void)
   cpu_set_t cpusetone;
   cpu_set_t cpusetall;
   cpu_set_t cpuset;
-  size_t big = 2 * CHAR_BIT * sizeof(cpu_set_t);
-  size_t cpusetbigsize = CPU_ALLOC_SIZE(big);
+  size_t cpusetbigsize = CPU_ALLOC_SIZE(BIG_NUM_CPUS);
   cpu_set_t *cpusetbigone;
@@ -63,66 +138,66 @@ static void test_task_get_set_affinity(void)
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  sc = rtems_task_get_affinity(RTEMS_SELF, sizeof(cpuset), NULL);
+  sc = task_get_affinity(RTEMS_SELF, sizeof(cpuset), NULL);
   rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
-  sc = rtems_task_set_affinity(RTEMS_SELF, sizeof(cpuset), NULL);
+  sc = task_set_affinity(RTEMS_SELF, sizeof(cpuset), NULL);
-  sc = rtems_task_get_affinity(RTEMS_SELF, 0, &cpuset);
+  sc = task_get_affinity(RTEMS_SELF, 0, &cpuset);
   rtems_test_assert(sc == RTEMS_INVALID_NUMBER);
-  sc = rtems_task_set_affinity(RTEMS_SELF, 0, &cpuset);
+  sc = task_set_affinity(RTEMS_SELF, 0, &cpuset);
-  sc = rtems_task_get_affinity(invalid_id, sizeof(cpuset), &cpuset);
+  sc = task_get_affinity(invalid_id, sizeof(cpuset), &cpuset);
   rtems_test_assert(sc == RTEMS_INVALID_ID);
-  sc = rtems_task_set_affinity(invalid_id, sizeof(cpuset), &cpuset);
+  sc = task_set_affinity(invalid_id, sizeof(cpuset), &cpuset);
-  sc = rtems_task_get_affinity(RTEMS_SELF, sizeof(cpuset), &cpuset);
+  sc = task_get_affinity(RTEMS_SELF, sizeof(cpuset), &cpuset);
   rtems_test_assert(CPU_EQUAL(&cpuset, &cpusetone));
-  sc = rtems_task_set_affinity(RTEMS_SELF, sizeof(cpuset), &cpuset);
+  sc = task_set_affinity(RTEMS_SELF, sizeof(cpuset), &cpuset);
-  sc = rtems_task_set_affinity(self_id, sizeof(cpuset), &cpuset);
+  sc = task_set_affinity(self_id, sizeof(cpuset), &cpuset);
-  sc = rtems_task_set_affinity(task_id, sizeof(cpuset), &cpuset);
+  sc = task_set_affinity(task_id, sizeof(cpuset), &cpuset);
-  sc = rtems_task_get_affinity(task_id, sizeof(cpuset), &cpuset);
+  sc = task_get_affinity(task_id, sizeof(cpuset), &cpuset);
-  sc = rtems_task_set_affinity(RTEMS_SELF, sizeof(cpusetall), &cpusetall);
+  sc = task_set_affinity(RTEMS_SELF, sizeof(cpusetall), &cpusetall);
-  cpusetbigone = CPU_ALLOC(big);
+  cpusetbigone = CPU_ALLOC(BIG_NUM_CPUS);
   rtems_test_assert(cpusetbigone != NULL);
-  cpusetbig = CPU_ALLOC(big);
   CPU_ZERO_S(cpusetbigsize, cpusetbigone);
   CPU_SET_S(0, cpusetbigsize, cpusetbigone);
-  sc = rtems_task_get_affinity(task_id, cpusetbigsize, cpusetbig);
+  sc = task_get_affinity(task_id, cpusetbigsize, cpusetbig);
   rtems_test_assert(CPU_EQUAL_S(cpusetbigsize, cpusetbig, cpusetbigone));
-  sc = rtems_task_set_affinity(task_id, cpusetbigsize, cpusetbig);
+  sc = task_set_affinity(task_id, cpusetbigsize, cpusetbig);
   sc = rtems_task_delete(task_id);
@@ -406,8 +481,7 @@ static void test_scheduler_get_processors(void)
   rtems_id scheduler_id;
   cpu_set_t cpuset;
@@ -431,10 +505,10 @@ static void test_scheduler_get_processors(void)
diff --git a/testsuites/sptests/spscheduler01/spscheduler01.doc b/testsuites/sptests/spscheduler01/spscheduler01.doc
index 2182928722..96a96a2d78 100644
--- a/testsuites/sptests/spscheduler01/spscheduler01.doc
+++ b/testsuites/sptests/spscheduler01/spscheduler01.doc
@@ -6,6 +6,8 @@ directives:
   - rtems_task_get_affinity()
   - rtems_task_set_affinity()
+  - pthread_getaffinity_np()
+  - pthread_setaffinity_np()
   - rtems_task_get_scheduler()
   - rtems_task_set_scheduler()
   - rtems_scheduler_ident()
2.12.3
