[PATCH] Tester - RISC-V: Add spike simulator and scripts/bsp for riscv ports
Hesham Almatary heshamelmatary at gmail.com
Sat Oct 28 02:52:09 UTC 2017
Update #3109
 tester/rtems/rtems-bsps-riscv32.ini           | 25 ++++++++++++
 tester/rtems/rtems-bsps-riscv64.ini           | 25 ++++++++++++
 tester/rtems/testing/bsps/riscv64_generic.ini | 38 ++++++++++++++++++
 tester/rtems/testing/bsps/riscv64_generic.mc  | 53 ++++++++++++++++++++++++
 tester/rtems/testing/bsps/riscv_generic.ini   | 38 ++++++++++++++++++
 tester/rtems/testing/bsps/riscv_generic.mc    | 53 ++++++++++++++++++++++++
 tester/rtems/testing/spike.cfg                | 58 +++++++++++++++++++++++++++
 7 files changed, 290 insertions(+)
 create mode 100644 tester/rtems/rtems-bsps-riscv32.ini
 create mode 100644 tester/rtems/rtems-bsps-riscv64.ini
 create mode 100644 tester/rtems/testing/bsps/riscv64_generic.ini
 create mode 100644 tester/rtems/testing/bsps/riscv64_generic.mc
 create mode 100644 tester/rtems/testing/bsps/riscv_generic.ini
 create mode 100644 tester/rtems/testing/bsps/riscv_generic.mc
 create mode 100644 tester/rtems/testing/spike.cfg
diff --git a/tester/rtems/rtems-bsps-riscv32.ini b/tester/rtems/rtems-bsps-riscv32.ini
new file mode 100644
index 0000000..3740222
--- /dev/null
+++ b/tester/rtems/rtems-bsps-riscv32.ini
@@ -0,0 +1,25 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2017 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-bsp-builder'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# RISC-V RV32 Architecture
+[riscv32]
+bsps = riscv_generic
+exclude = smp
diff --git a/tester/rtems/rtems-bsps-riscv64.ini b/tester/rtems/rtems-bsps-riscv64.ini
index 0000000..0a15f6f
--- /dev/null
+++ b/tester/rtems/rtems-bsps-riscv64.ini
@@ -0,0 +1,25 @@
+# RISC-V RV64 Architecture
+[riscv64]
+bsps = riscv64_generic
+exclude = smp
diff --git a/tester/rtems/testing/bsps/riscv64_generic.ini b/tester/rtems/testing/bsps/riscv64_generic.ini
index 0000000..c596a3a
--- /dev/null
+++ b/tester/rtems/testing/bsps/riscv64_generic.ini
@@ -0,0 +1,38 @@
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The riscv64_generic BSP
+[riscv64_generic]
+bsp           = riscv64_generic
+arch          = riscv64
+tester        = %{_rtscripts}/spike.cfg
+bsp_spike_opts = --isa=RV64IMAFDC -m0x10000000:0x10000000
diff --git a/tester/rtems/testing/bsps/riscv64_generic.mc b/tester/rtems/testing/bsps/riscv64_generic.mc
index 0000000..def8e05
--- /dev/null
+++ b/tester/rtems/testing/bsps/riscv64_generic.mc
@@ -0,0 +1,53 @@
+# All paths in defaults must be Unix format. Do not store any Windows format
+# paths in the defaults.
+# Every entry must describe the type of checking a host must pass.
+# Records:
+#  key: type, attribute, value
+#   type     : none, dir, exe, triplet
+#   attribute: none, required, optional
+#   value    : 'single line', '''multi line'''
+[global]
+bsp:                      none,    none,     'riscv64_generic'
+[riscv64_generic]
+riscv64_generic:      none,    none,  '%{_rtscripts}/spike.cfg'
+riscv64_generic_arch: none,    none,  ''
+riscv64_generic_opts: none,    none,  ''
diff --git a/tester/rtems/testing/bsps/riscv_generic.ini b/tester/rtems/testing/bsps/riscv_generic.ini
index 0000000..626b949
--- /dev/null
+++ b/tester/rtems/testing/bsps/riscv_generic.ini
@@ -0,0 +1,38 @@
+# The riscv_generic BSP
+[riscv_generic]
+bsp           = riscv_generic
+arch          = riscv32
+bsp_spike_opts = --isa=RV32IMAFDC -m0x10000000:0x10000000
diff --git a/tester/rtems/testing/bsps/riscv_generic.mc b/tester/rtems/testing/bsps/riscv_generic.mc
index 0000000..daff7c0
--- /dev/null
+++ b/tester/rtems/testing/bsps/riscv_generic.mc
@@ -0,0 +1,53 @@
+# Records:
+[global]
+bsp:                      none,    none,     'riscv_generic'
+[riscv_generic]
+riscv_generic:      none,    none,  '%{_rtscripts}/spike.cfg'
+riscv_generic_arch: none,    none,  ''
+riscv_generic_opts: none,    none,  ''
diff --git a/tester/rtems/testing/spike.cfg b/tester/rtems/testing/spike.cfg
index 0000000..8ad535e
--- /dev/null
+++ b/tester/rtems/testing/spike.cfg
@@ -0,0 +1,58 @@
+# Spike (riscv-isa-sim) The main simulator for RISC-V
+# Clone/build from https://github.com/riscv/riscv-isa-sim/tree/priv-1.10
+# Use spike command to run the executable in the spike simulator.
+%include %{_configdir}/base.cfg
+%include %{_configdir}/checks.cfg
+# Console.
+%define console_stdio
+%include %{_configdir}/console.cfg
+# RTEMS version
+%include %{_rtdir}/rtems/version.cfg
+%define spike_cmd spike
+%define spike_opts %{bsp_spike_opts}
+# Executable
+%execute %{spike_cmd} %{spike_opts} %{test_executable}
2.7.4
