[PATCH 1/2] cpukit: RISC-V - make riscv32 code work for riscv64 - v2
Hesham Almatary
heshamelmatary at gmail.com
Mon Oct 30 23:54:52 UTC 2017
* Use #ifdefs for 32/64 bit code
* Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
* Move the code to a new shared riscv folder to be shared between riscv32 and riscv64
* Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv
Update #3109
aclocal/canonical-target-name.m4 | 5 +-
c/src/aclocal/rtems-cpu-subdirs.m4 | 2 +-
cpukit/aclocal/canonical-target-name.m4 | 2 +
cpukit/configure.ac | 2 +-
cpukit/score/cpu/Makefile.am | 2 +-
cpukit/score/cpu/riscv/Makefile.am | 26 +
cpukit/score/cpu/riscv/cpu.c | 124 ++
cpukit/score/cpu/riscv/preinstall.am | 57 +
cpukit/score/cpu/riscv/riscv-context-initialize.c | 67 +
cpukit/score/cpu/riscv/riscv-context-switch.S | 136 ++
cpukit/score/cpu/riscv/riscv-context-validate.S | 200 +++
.../cpu/riscv/riscv-context-volatile-clobber.S | 50 +
cpukit/score/cpu/riscv/riscv-exception-default.c | 39 +
.../score/cpu/riscv/riscv-exception-frame-print.c | 45 +
cpukit/score/cpu/riscv/riscv-exception-handler.S | 221 +++
cpukit/score/cpu/riscv/rtems/asm.h | 120 ++
cpukit/score/cpu/riscv/rtems/score/cpu.h | 605 ++++++++
cpukit/score/cpu/riscv/rtems/score/cpu_asm.h | 90 ++
cpukit/score/cpu/riscv/rtems/score/cpuatomic.h | 31 +
cpukit/score/cpu/riscv/rtems/score/cpuimpl.h | 51 +
cpukit/score/cpu/riscv/rtems/score/riscv-utility.h | 1526 ++++++++++++++++++++
cpukit/score/cpu/riscv/rtems/score/riscv.h | 66 +
cpukit/score/cpu/riscv/rtems/score/types.h | 70 +
cpukit/score/cpu/riscv32/Makefile.am | 26 -
cpukit/score/cpu/riscv32/cpu.c | 124 --
cpukit/score/cpu/riscv32/preinstall.am | 57 -
.../score/cpu/riscv32/riscv-context-initialize.c | 67 -
cpukit/score/cpu/riscv32/riscv-context-switch.S | 139 --
cpukit/score/cpu/riscv32/riscv-context-validate.S | 201 ---
.../cpu/riscv32/riscv-context-volatile-clobber.S | 50 -
cpukit/score/cpu/riscv32/riscv-exception-default.c | 39 -
.../cpu/riscv32/riscv-exception-frame-print.c | 41 -
cpukit/score/cpu/riscv32/riscv-exception-handler.S | 220 ---
cpukit/score/cpu/riscv32/rtems/asm.h | 120 --
cpukit/score/cpu/riscv32/rtems/score/cpu.h | 585 --------
cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h | 90 --
cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h | 31 -
cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h | 51 -
.../score/cpu/riscv32/rtems/score/riscv-utility.h | 1526 --------------------
cpukit/score/cpu/riscv32/rtems/score/riscv.h | 66 -
cpukit/score/cpu/riscv32/rtems/score/types.h | 70 -
41 files changed, 3533 insertions(+), 3507 deletions(-)
create mode 100644 cpukit/score/cpu/riscv/Makefile.am
create mode 100644 cpukit/score/cpu/riscv/cpu.c
create mode 100644 cpukit/score/cpu/riscv/preinstall.am
create mode 100644 cpukit/score/cpu/riscv/riscv-context-initialize.c
create mode 100644 cpukit/score/cpu/riscv/riscv-context-switch.S
create mode 100644 cpukit/score/cpu/riscv/riscv-context-validate.S
create mode 100644 cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S
create mode 100644 cpukit/score/cpu/riscv/riscv-exception-default.c
create mode 100644 cpukit/score/cpu/riscv/riscv-exception-frame-print.c
create mode 100644 cpukit/score/cpu/riscv/riscv-exception-handler.S
create mode 100644 cpukit/score/cpu/riscv/rtems/asm.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpu.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpu_asm.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpuatomic.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpuimpl.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/riscv-utility.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/riscv.h
create mode 100644 cpukit/score/cpu/riscv/rtems/score/types.h
delete mode 100644 cpukit/score/cpu/riscv32/Makefile.am
delete mode 100644 cpukit/score/cpu/riscv32/cpu.c
delete mode 100644 cpukit/score/cpu/riscv32/preinstall.am
delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-initialize.c
delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-switch.S
delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-validate.S
delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S
delete mode 100644 cpukit/score/cpu/riscv32/riscv-exception-default.c
delete mode 100644 cpukit/score/cpu/riscv32/riscv-exception-frame-print.c
delete mode 100644 cpukit/score/cpu/riscv32/riscv-exception-handler.S
delete mode 100644 cpukit/score/cpu/riscv32/rtems/asm.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpu.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/riscv.h
delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/types.h
diff --git a/aclocal/canonical-target-name.m4 b/aclocal/canonical-target-name.m4
index 6870bbf..498610c 100644
--- a/aclocal/canonical-target-name.m4
+++ b/aclocal/canonical-target-name.m4
@@ -12,7 +12,10 @@ case "${target}" in
no_cpu-*rtems*)
RTEMS_CPU=no_cpu
+ riscv*-*rtems*)
+ RTEMS_CPU=riscv
RTEMS_CPU=`echo $target | sed 's%^\([[^-]]*\)-\(.*\)$%\1%'`
esac
diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4 b/c/src/aclocal/rtems-cpu-subdirs.m4
index b5b579e..3ec5884 100644
--- a/c/src/aclocal/rtems-cpu-subdirs.m4
+++ b/c/src/aclocal/rtems-cpu-subdirs.m4
@@ -23,7 +23,7 @@ _RTEMS_CPU_SUBDIR([nios2],[$1]);;
_RTEMS_CPU_SUBDIR([no_cpu],[$1]);;
_RTEMS_CPU_SUBDIR([or1k],[$1]);;
_RTEMS_CPU_SUBDIR([powerpc],[$1]);;
-_RTEMS_CPU_SUBDIR([riscv32],[$1]);;
+_RTEMS_CPU_SUBDIR([riscv],[$1]);;
_RTEMS_CPU_SUBDIR([sh],[$1]);;
_RTEMS_CPU_SUBDIR([sparc],[$1]);;
_RTEMS_CPU_SUBDIR([sparc64],[$1]);;
diff --git a/cpukit/aclocal/canonical-target-name.m4 b/cpukit/aclocal/canonical-target-name.m4
index a237c7b..d3c2531 100644
--- a/cpukit/aclocal/canonical-target-name.m4
+++ b/cpukit/aclocal/canonical-target-name.m4
@@ -8,6 +8,8 @@ AC_DEFUN([RTEMS_CANONICAL_TARGET_CPU],
[AC_REQUIRE([AC_CANONICAL_HOST])
AC_MSG_CHECKING(rtems target cpu)
case "${host}" in
+riscv*-*-rtems*)
+ RTEMS_CPU=riscv;;
*-*-rtems*)
RTEMS_CPU="$host_cpu";;
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 210eebf..427b649 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -459,7 +459,7 @@ score/cpu/moxie/Makefile
score/cpu/nios2/Makefile
score/cpu/or1k/Makefile
score/cpu/powerpc/Makefile
-score/cpu/riscv32/Makefile
+score/cpu/riscv/Makefile
score/cpu/sh/Makefile
score/cpu/sparc/Makefile
score/cpu/sparc64/Makefile
diff --git a/cpukit/score/cpu/Makefile.am b/cpukit/score/cpu/Makefile.am
index 73c6540..4ddbdf0 100644
--- a/cpukit/score/cpu/Makefile.am
+++ b/cpukit/score/cpu/Makefile.am
@@ -14,7 +14,7 @@ DIST_SUBDIRS += nios2
DIST_SUBDIRS += no_cpu
DIST_SUBDIRS += or1k
DIST_SUBDIRS += powerpc
-DIST_SUBDIRS += riscv32
+DIST_SUBDIRS += riscv
DIST_SUBDIRS += sh
DIST_SUBDIRS += sparc
DIST_SUBDIRS += sparc64
diff --git a/cpukit/score/cpu/riscv/Makefile.am b/cpukit/score/cpu/riscv/Makefile.am
new file mode 100644
index 0000000..1de5b2d
--- /dev/null
+++ b/cpukit/score/cpu/riscv/Makefile.am
@@ -0,0 +1,26 @@
+include $(top_srcdir)/automake/compile.am
+include_rtemsdir = $(includedir)/rtems
+include_rtems_HEADERS = rtems/asm.h
+include_rtems_scoredir = $(includedir)/rtems/score
+include_rtems_score_HEADERS = rtems/score/cpu.h
+include_rtems_score_HEADERS += rtems/score/cpuatomic.h
+include_rtems_score_HEADERS += rtems/score/cpuimpl.h
+include_rtems_score_HEADERS += rtems/score/cpu_asm.h
+include_rtems_score_HEADERS += rtems/score/types.h
+include_rtems_score_HEADERS += rtems/score/riscv.h
+include_rtems_score_HEADERS += rtems/score/riscv-utility.h
+noinst_LIBRARIES = libscorecpu.a
+libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
+libscorecpu_a_SOURCES = cpu.c
+libscorecpu_a_SOURCES += riscv-exception-handler.S
+libscorecpu_a_SOURCES += riscv-exception-default.c
+libscorecpu_a_SOURCES += riscv-exception-frame-print.c
+libscorecpu_a_SOURCES += riscv-context-switch.S
+libscorecpu_a_SOURCES += riscv-context-initialize.c
+libscorecpu_a_SOURCES += riscv-context-validate.S
+libscorecpu_a_SOURCES += riscv-context-volatile-clobber.S
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/automake/local.am
diff --git a/cpukit/score/cpu/riscv/cpu.c b/cpukit/score/cpu/riscv/cpu.c
index 0000000..8d2926e
--- /dev/null
+++ b/cpukit/score/cpu/riscv/cpu.c
@@ -0,0 +1,124 @@
+ * RISC-V CPU Dependent Source
+ * Copyright (c) 2015 University of York.
+ * Hesham ALmatary <hesham at alumni.york.ac.uk>
+ * COPYRIGHT (c) 1989-1999.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <rtems/system.h>
+#include <rtems/score/isr.h>
+#include <rtems/score/wkspace.h>
+#include <rtems/score/cpu.h>
+/* bsp_start_vector_table_begin is the start address of the vector table
+ * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
+ * and may differ from one BSP to another.
+extern char bsp_start_vector_table_begin[];
+void init(void);
+void fini(void);
+void _init()
+void _fini()
+ * @brief Performs processor dependent initialization.
+void _CPU_Initialize(void)
+ /* Do nothing */
+void _CPU_ISR_Set_level(unsigned long level)
+ /* Do nothing */
+unsigned long _CPU_ISR_Get_level( void )
+ /* Do nothing */
+ return 0;
+void _CPU_ISR_install_raw_handler(
+ uint32_t vector,
+ proc_ptr new_handler,
+ proc_ptr *old_handler
+ /* Do nothing */
+void _CPU_ISR_install_vector(
+ unsigned long vector,
+ proc_ptr *table =
+ (proc_ptr *) bsp_start_vector_table_begin;
+ proc_ptr current_handler;
+ ISR_Level level;
+ _ISR_Local_disable( level );
+ current_handler = table [vector];
+ /* The current handler is now the old one */
+ if (old_handler != NULL) {
+ *old_handler = (proc_ptr) current_handler;
+ /* Write only if necessary to avoid writes to a maybe read-only
+ * memory */
+ if (current_handler != new_handler) {
+ table [vector] = new_handler;
+ _ISR_Local_enable( level );
+void _CPU_Install_interrupt_stack( void )
+ /* Do nothing */
+void *_CPU_Thread_Idle_body( uintptr_t ignored )
+ do {
+ } while (1);
+ return NULL;
diff --git a/cpukit/score/cpu/riscv/preinstall.am b/cpukit/score/cpu/riscv/preinstall.am
index 0000000..14256ba
--- /dev/null
+++ b/cpukit/score/cpu/riscv/preinstall.am
@@ -0,0 +1,57 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+ $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES = $(PREINSTALL_DIRS)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES = $(PREINSTALL_FILES)
+$(PROJECT_INCLUDE)/rtems/$(dirstamp):
+ @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
+ @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
+$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
+ @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
+ @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
+$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
+$(PROJECT_INCLUDE)/rtems/score/cpuimpl.h: rtems/score/cpuimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuimpl.h
+$(PROJECT_INCLUDE)/rtems/score/cpu_asm.h: rtems/score/cpu_asm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
+$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
+$(PROJECT_INCLUDE)/rtems/score/riscv.h: rtems/score/riscv.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/riscv.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/riscv.h
+$(PROJECT_INCLUDE)/rtems/score/riscv-utility.h: rtems/score/riscv-utility.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/riscv-utility.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/riscv-utility.h
diff --git a/cpukit/score/cpu/riscv/riscv-context-initialize.c b/cpukit/score/cpu/riscv/riscv-context-initialize.c
index 0000000..03fcc5c
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-context-initialize.c
@@ -0,0 +1,67 @@
+ * Hesham Almatary <hesham at alumni.york.ac.uk>
+ * COPYRIGHT (c) 1989-2006.
+ * are met:
+ * SUCH DAMAGE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <rtems/score/riscv-utility.h>
+#include <rtems/score/interr.h>
+void _CPU_Context_Initialize(
+ Context_Control *context,
+ void *stack_area_begin,
+ size_t stack_area_size,
+ unsigned long new_level,
+ void (*entry_point)( void ),
+ bool is_fp,
+ void *tls_area
+ uintptr_t stack = ((uintptr_t) stack_area_begin);
+ /* Account for red-zone */
+ uintptr_t stack_high = stack + stack_area_size - RISCV_GCC_RED_ZONE_SIZE;
+ memset(context, 0, sizeof(*context));
+ /* Stack Pointer - sp/x2 */
+ context->x[2] = stack_high;
+ /* Frame Pointer - fp/x8 */
+ context->x[8] = stack_high;
+ /* Return Address - ra/x1 */
+ context->x[1] = (uintptr_t) entry_point;
+ /* Enable interrupts and FP */
+ context->mstatus = MSTATUS_FS | MSTATUS_MIE;
diff --git a/cpukit/score/cpu/riscv/riscv-context-switch.S b/cpukit/score/cpu/riscv/riscv-context-switch.S
index 0000000..0b1a72c
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-context-switch.S
@@ -0,0 +1,136 @@
+ * riscv32 CPU Dependent Source
+ * are met:
+ * SUCH DAMAGE.
+#endif
+#include <rtems/asm.h>
+.section .text, "ax"
+.align 4
+PUBLIC(_CPU_Context_switch)
+PUBLIC(_CPU_Context_restore)
+PUBLIC(_CPU_Context_restore_fp)
+PUBLIC(_CPU_Context_save_fp)
+PUBLIC(restore)
+SYM(_CPU_Context_switch):
+ /* Disable interrupts and store all registers */
+ csrr t0, mstatus
+ SREG t0, (32 * CPU_SIZEOF_POINTER)(a0)
+ csrci mstatus, MSTATUS_MIE
+ SREG x1, (1 * CPU_SIZEOF_POINTER)(a0)
+ SREG x2, (2 * CPU_SIZEOF_POINTER)(a0)
+ SREG x3, (3 * CPU_SIZEOF_POINTER)(a0)
+ SREG x4, (4 * CPU_SIZEOF_POINTER)(a0)
+ SREG x5, (5 * CPU_SIZEOF_POINTER)(a0)
+ SREG x6, (6 * CPU_SIZEOF_POINTER)(a0)
+ SREG x7, (7 * CPU_SIZEOF_POINTER)(a0)
+ SREG x8, (8 * CPU_SIZEOF_POINTER)(a0)
+ SREG x9, (9 * CPU_SIZEOF_POINTER)(a0)
+ SREG x10, (10 * CPU_SIZEOF_POINTER)(a0)
+ SREG x11, (11 * CPU_SIZEOF_POINTER)(a0)
+ SREG x12, (12 * CPU_SIZEOF_POINTER)(a0)
+ SREG x13, (13 * CPU_SIZEOF_POINTER)(a0)
+ SREG x14, (14 * CPU_SIZEOF_POINTER)(a0)
+ SREG x15, (15 * CPU_SIZEOF_POINTER)(a0)
+ SREG x16, (16 * CPU_SIZEOF_POINTER)(a0)
+ SREG x17, (17 * CPU_SIZEOF_POINTER)(a0)
+ SREG x18, (18 * CPU_SIZEOF_POINTER)(a0)
+ SREG x19, (19 * CPU_SIZEOF_POINTER)(a0)
+ SREG x20, (20 * CPU_SIZEOF_POINTER)(a0)
+ SREG x21, (21 * CPU_SIZEOF_POINTER)(a0)
+ SREG x22, (22 * CPU_SIZEOF_POINTER)(a0)
+ SREG x23, (23 * CPU_SIZEOF_POINTER)(a0)
+ SREG x24, (24 * CPU_SIZEOF_POINTER)(a0)
+ SREG x25, (25 * CPU_SIZEOF_POINTER)(a0)
+ SREG x26, (26 * CPU_SIZEOF_POINTER)(a0)
+ SREG x27, (27 * CPU_SIZEOF_POINTER)(a0)
+ SREG x28, (28 * CPU_SIZEOF_POINTER)(a0)
+ SREG x29, (28 * CPU_SIZEOF_POINTER)(a0)
+ SREG x30, (30 * CPU_SIZEOF_POINTER)(a0)
+ SREG x31, (31 * CPU_SIZEOF_POINTER)(a0)
+ SYM(restore):
+ LREG x1, (1 * CPU_SIZEOF_POINTER)(a1)
+ LREG x2, (2 * CPU_SIZEOF_POINTER)(a1)
+ LREG x3, (3 * CPU_SIZEOF_POINTER)(a1)
+ LREG x4, (4 * CPU_SIZEOF_POINTER)(a1)
+ LREG x5, (5 * CPU_SIZEOF_POINTER)(a1)
+ LREG x6, (6 * CPU_SIZEOF_POINTER)(a1)
+ LREG x7, (7 * CPU_SIZEOF_POINTER)(a1)
+ LREG x8, (8 * CPU_SIZEOF_POINTER)(a1)
+ LREG x9, (9 * CPU_SIZEOF_POINTER)(a1)
+ LREG x10, (10 * CPU_SIZEOF_POINTER)(a1)
+ /* Skip a1/x11 */
+ LREG x12, (12 * CPU_SIZEOF_POINTER)(a1)
+ LREG x13, (13 * CPU_SIZEOF_POINTER)(a1)
+ LREG x14, (14 * CPU_SIZEOF_POINTER)(a1)
+ LREG x15, (15 * CPU_SIZEOF_POINTER)(a1)
+ LREG x16, (16 * CPU_SIZEOF_POINTER)(a1)
+ LREG x17, (17 * CPU_SIZEOF_POINTER)(a1)
+ LREG x18, (18 * CPU_SIZEOF_POINTER)(a1)
+ LREG x19, (19 * CPU_SIZEOF_POINTER)(a1)
+ LREG x20, (20 * CPU_SIZEOF_POINTER)(a1)
+ LREG x21, (21 * CPU_SIZEOF_POINTER)(a1)
+ LREG x22, (22 * CPU_SIZEOF_POINTER)(a1)
+ LREG x23, (23 * CPU_SIZEOF_POINTER)(a1)
+ LREG x24, (24 * CPU_SIZEOF_POINTER)(a1)
+ LREG x25, (25 * CPU_SIZEOF_POINTER)(a1)
+ LREG x26, (26 * CPU_SIZEOF_POINTER)(a1)
+ LREG x27, (27 * CPU_SIZEOF_POINTER)(a1)
+ LREG x28, (28 * CPU_SIZEOF_POINTER)(a1)
+ LREG x29, (29 * CPU_SIZEOF_POINTER)(a1)
+ LREG x30, (30 * CPU_SIZEOF_POINTER)(a1)
+ /* Load mstatus */
+ LREG x31, (32 * CPU_SIZEOF_POINTER)(a1)
+ csrw mstatus, x31
+ LREG x11, (11 * CPU_SIZEOF_POINTER)(a1)
+ ret
+ SYM(_CPU_Context_restore):
+ mv a1, a0
+ j restore
+ /* TODO no FP support for riscv32 yet */
+ SYM(_CPU_Context_restore_fp):
+ nop
+ SYM(_CPU_Context_save_fp):
+ nop
diff --git a/cpukit/score/cpu/riscv/riscv-context-validate.S b/cpukit/score/cpu/riscv/riscv-context-validate.S
index 0000000..f9918e3
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-context-validate.S
@@ -0,0 +1,200 @@
+ * Copyrigh (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
+ * are met:
+ * SUCH DAMAGE.
+#endif
+.section .text
+PUBLIC(_CPU_Context_validate)
+SYM(_CPU_Context_validate):
+ /* RISC-V/RTEMS context has 36 registers of CPU_SIZEOF_POINTER size */
+ addi sp, sp, -1 * 36 * CPU_SIZEOF_POINTER
+ SREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
+ /* Skip x2/sp */
+ SREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
+ SREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
+ SREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
+ SREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
+ SREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
+ SREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
+ SREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
+ SREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
+ SREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
+ SREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
+ SREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
+ SREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
+ SREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
+ SREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
+ SREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
+ SREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
+ SREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
+ SREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
+ SREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
+ SREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
+ SREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
+ SREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
+ SREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
+ SREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
+ SREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
+ SREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
+ SREG x29, (28 * CPU_SIZEOF_POINTER)(sp)
+ SREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
+ SREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
+ /* Fill */
+ /* t0 is used for temporary values */
+ mv t0, x0
+ /* x31 contains the stack pointer */
+ mv x31, sp
+ .macro fill_register reg
+ addi t0, t0, 1
+ mv \reg, t0
+ .endm
+ fill_register x1
+ fill_register x2
+ fill_register x3
+ fill_register x4
+ fill_register x5
+ fill_register x6
+ fill_register x7
+ fill_register x8
+ fill_register x9
+ fill_register x10
+ fill_register x11
+ fill_register x12
+ fill_register x13
+ fill_register x14
+ fill_register x15
+ fill_register x16
+ fill_register x17
+ fill_register x18
+ fill_register x19
+ fill_register x20
+ fill_register x21
+ fill_register x22
+ fill_register x23
+ fill_register x24
+ fill_register x25
+ fill_register x26
+ fill_register x27
+ fill_register x28
+ fill_register x29
+ fill_register x30
+ fill_register x31
+ /* Check */
+check:
+ .macro check_register reg
+ addi t0, t0, 1
+ bne \reg, t0, restore
+ .endm
+ bne x31, sp, restore
+ mv t0, x0
+ check_register x1
+ check_register x2
+ check_register x3
+ check_register x4
+ check_register x5
+ check_register x6
+ check_register x7
+ check_register x8
+ check_register x9
+ check_register x10
+ check_register x11
+ check_register x12
+ check_register x13
+ check_register x14
+ check_register x15
+ check_register x16
+ check_register x17
+ check_register x18
+ check_register x19
+ check_register x20
+ check_register x21
+ check_register x22
+ check_register x23
+ check_register x24
+ check_register x25
+ check_register x26
+ check_register x27
+ check_register x28
+ check_register x29
+ check_register x30
+ check_register x31
+ j check
+ /* Restore */
+restore:
+ LREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
+ /* Skip sp/x2 */
+ LREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
+ LREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
+ LREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
+ LREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
+ LREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
+ LREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
+ LREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
+ LREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
+ LREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
+ LREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
+ LREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
+ LREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
+ LREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
+ LREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
+ LREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
+ LREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
+ LREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
+ LREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
+ LREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
+ LREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
+ LREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
+ LREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
+ LREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
+ LREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
+ LREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
+ LREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
+ LREG x29, (29 * CPU_SIZEOF_POINTER)(sp)
+ LREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
+ LREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
+ addi sp, sp, 36 * CPU_SIZEOF_POINTER
+ ret
diff --git a/cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S b/cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S
index 0000000..58ec25b
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S
@@ -0,0 +1,50 @@
+ * Copyright (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
+ * are met:
+ * SUCH DAMAGE.
+#endif
+.section .text
+PUBLIC(_CPU_Context_volatile_clobber)
+SYM(_CPU_Context_volatile_clobber):
+ .macro clobber_register reg
+ addi t0, t0, -1
+ mv \reg, t0
+ .endm
+ clobber_register a0
+ clobber_register a1
+ clobber_register a2
+ clobber_register a3
+ clobber_register a4
+ clobber_register a5
+ clobber_register a6
+ ret
diff --git a/cpukit/score/cpu/riscv/riscv-exception-default.c b/cpukit/score/cpu/riscv/riscv-exception-default.c
index 0000000..62d0dd3
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-exception-default.c
@@ -0,0 +1,39 @@
+ * Copyright (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
+ * are met:
+ * SUCH DAMAGE.
+#endif
+#include <rtems/fatal.h>
+#include <stdio.h>
+void _RISCV_Exception_default(uint32_t vector, CPU_Exception_frame *frame);
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
diff --git a/cpukit/score/cpu/riscv/riscv-exception-frame-print.c b/cpukit/score/cpu/riscv/riscv-exception-frame-print.c
index 0000000..4d90f58
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-exception-frame-print.c
@@ -0,0 +1,45 @@
+ * are met:
+ * SUCH DAMAGE.
+#endif
+#include <rtems/bspIo.h>
+#include <inttypes.h>
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
+ int i;
+ for ( i = 0; i < 32; ++i ) {
+#if __riscv_xlen == 32
+ printk( "x%02i = 0x%032" PRIx32 "\n", i, frame->x[i]);
+#else /* xlen == 64 */
+ printk( "x%02i = 0x%032" PRIx64 "\n",i, frame->x[i]);
+#endif
diff --git a/cpukit/score/cpu/riscv/riscv-exception-handler.S b/cpukit/score/cpu/riscv/riscv-exception-handler.S
index 0000000..8aba339
--- /dev/null
+++ b/cpukit/score/cpu/riscv/riscv-exception-handler.S
@@ -0,0 +1,221 @@
+ * @file
+ * @ingroup ScoreCPU
+ * @brief RISC-V exception support implementation.
+ * are met:
+ * SUCH DAMAGE.
+#endif
+#include <rtems/score/percpu.h>
+EXTERN(bsp_start_vector_table_begin)
+EXTERN(_Thread_Dispatch)
+PUBLIC(ISR_Handler)
+.align 4
+TYPE_FUNC(ISR_Handler)
+SYM(ISR_Handler):
+ /* Skip x2/sp */
+ /* Exception level related registers */
+ csrr a0, mstatus
+ SREG a0, (32 * CPU_SIZEOF_POINTER)(sp)
+ csrr a0, mcause
+ SREG a0, (33 * CPU_SIZEOF_POINTER)(sp)
+ csrr a1, mepc
+ SREG a1, (34 * CPU_SIZEOF_POINTER)(sp)
+ /* FIXME Only handle interrupts for now (MSB = 1) */
+ andi a0, a0, 0xf
+ /* Increment nesting level */
+ la t0, ISR_NEST_LEVEL
+ /* Disable multitasking */
+ la t1, THREAD_DISPATCH_DISABLE_LEVEL
+ lw t2, (t0)
+ lw t3, (t1)
+ addi t2, t2, 1
+ addi t3, t3, 1
+ sw t2, (t0)
+ sw t3, (t1)
+ /* Save interrupted task stack pointer */
+ addi t4, sp, 36 * CPU_SIZEOF_POINTER
+ SREG t4, (2 * CPU_SIZEOF_POINTER)(sp)
+ /* Keep sp (Exception frame address) in s1 */
+ mv s1, sp
+ /* Call the exception handler from vector table */
+ /* First function arg for C handler is vector number,
+ * and the second is a pointer to exception frame.
+ * a0/mcause/vector number is already loaded above */
+ mv a1, sp
+ /* calculate the offset */
+ la t5, bsp_start_vector_table_begin
+ slli t6, a0, 2
+#else /* xlen = 64 */
+ slli t6, a0, 3
+#endif
+ add t5, t5, t6
+ LREG t5, (t5)
+ /* Do not switch stacks if we are in a nested interrupt. At
+ * this point t2 should be holding ISR_NEST_LEVEL value.
+ li s0, 1
+ bgtu t2, s0, jump_to_c_handler
+ /* Switch to RTEMS dedicated interrupt stack */
+ la sp, INTERRUPT_STACK_HIGH
+ LREG sp, (sp)
+jump_to_c_handler:
+ jalr t5
+ /* Switch back to the interrupted task stack */
+ mv sp, s1
+ /* Decrement nesting level */
+ /* Enable multitasking */
+ Lw t2, (t0)
+ lw t3, (t1)
+ addi t2, t2, -1
+ addi t3, t3, -1
+ sw t2, (t0)
+ sw t3, (t1)
+ /* Check if _ISR_Nest_level > 0 */
+ bgtz t2, exception_frame_restore
+ /* Check if _Thread_Dispatch_disable_level > 0 */
+ bgtz t3, exception_frame_restore
+ /* Check if dispatch needed */
+ la x31, DISPATCH_NEEDED
+ lw x31, (x31)
+ beqz x31, exception_frame_restore
+ la x31, _Thread_Dispatch
+ jalr x31
+ SYM(exception_frame_restore):
+ /* Skip sp/x2 */
+ LREG x31, (32 * CPU_SIZEOF_POINTER)(sp)
+ csrw mstatus, x31
+ /* Load mepc */
+ LREG x31, (34 * CPU_SIZEOF_POINTER)(sp)
+ csrw mepc, x31
+ /* Unwind exception frame */
+ mret
diff --git a/cpukit/score/cpu/riscv/rtems/asm.h b/cpukit/score/cpu/riscv/rtems/asm.h
index 0000000..34b6474
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/asm.h
@@ -0,0 +1,120 @@
+ * @file rtems/asm.h
+ * This include file attempts to address the problems
+ * caused by incompatible flavors of assemblers and
+ * toolsets. It primarily addresses variations in the
+ * use of leading underscores on symbols and the requirement
+ * that register names be preceded by a %.
+ * NOTE: The spacing in the use of these macros
+ * is critical to them working as advertised.
+ * This file is based on similar code found in newlib available
+ * from ftp.cygnus.com. The file which was used had no copyright
+ * notice. This file is freely distributable as long as the source
+ * of the file is noted. This file is:
+ * COPYRIGHT (c) 1994-1997.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef __RISCV_ASM_H
+#define __RISCV_ASM_H
+ * Indicate we are in an assembly file and get the basic CPU definitions.
+#ifndef ASM
+#define ASM
+#endif
+#include <rtems/score/cpuopts.h>
+#include <rtems/score/riscv.h>
+ * Recent versions of GNU cpp define variables which indicate the
+ * need for underscores and percents. If not using GNU cpp or
+ * the version does not support this, then you will obviously
+ * have to define these as appropriate.
+#ifndef __USER_LABEL_PREFIX__
+#define __USER_LABEL_PREFIX__ _
+#endif
+#ifndef __REGISTER_PREFIX__
+#define __REGISTER_PREFIX__
+#endif
+/* ANSI concatenation macros. */
+#define CONCAT1(a, b) CONCAT2(a, b)
+#define CONCAT2(a, b) a ## b
+/* Use the right prefix for global labels. */
+#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
+/* Use the right prefix for registers. */
+#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
+ * define macros for all of the registers on this CPU
+ * EXAMPLE: #define d0 REG (d0)
+ * Define macros to handle section beginning and ends.
+#define BEGIN_CODE_DCL .text
+#define END_CODE_DCL
+#define BEGIN_DATA_DCL .data
+#define END_DATA_DCL
+#define BEGIN_CODE .text
+#define END_CODE
+#define BEGIN_DATA
+#define END_DATA
+#define BEGIN_BSS
+#define END_BSS
+#define END
+ * Following must be tailor for a particular flavor of the C compiler.
+ * They may need to put underscores in front of the symbols.
+#define PUBLIC(sym) .global SYM (sym)
+#define EXTERN(sym) .extern SYM (sym)
+#define TYPE_FUNC(sym) .type SYM (sym), %function
+#endif
diff --git a/cpukit/score/cpu/riscv/rtems/score/cpu.h b/cpukit/score/cpu/riscv/rtems/score/cpu.h
index 0000000..439b8c2
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/cpu.h
@@ -0,0 +1,605 @@
+ * @file rtems/score/cpu.h
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RISCV_CPU_H
+#define _RISCV_CPU_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <rtems/score/riscv.h> /* pick up machine definitions */
+#include <rtems/score/types.h>
+#ifndef ASM
+#include <stdint.h>
+#include <stdio.h> /* for printk */
+#endif
+#define CPU_INLINE_ENABLE_DISPATCH FALSE
+#define CPU_UNROLL_ENQUEUE_PRIORITY TRUE
+#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
+#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
+#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
+#define CPU_ISR_PASSES_FRAME_POINTER 1
+#define CPU_HARDWARE_FP FALSE
+#define CPU_SOFTWARE_FP FALSE
+#define CPU_ALL_TASKS_ARE_FP FALSE
+#define CPU_IDLE_TASK_IS_FP FALSE
+#define CPU_USE_DEFERRED_FP_SWITCH FALSE
+#define CPU_PROVIDES_IDLE_THREAD_BODY TRUE
+#define CPU_STACK_GROWS_UP FALSE
+#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
+#define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES FALSE
+#define CPU_BIG_ENDIAN FALSE
+#define CPU_LITTLE_ENDIAN TRUE
+#define CPU_MODES_INTERRUPT_MASK 0x0000000000000001
+ * Processor defined structures required for cpukit/score.
+#ifndef ASM
+typedef struct {
+ /* riscv has 32 xlen-bit (where xlen can be 32 or 64) general purpose registers (x0-x31)*/
+ unsigned long x[32];
+ /* Special purpose registers */
+ unsigned long mstatus;
+ unsigned long mcause;
+ unsigned long mepc;
+#ifdef RTEMS_SMP
+ * @brief On SMP configurations the thread context must contain a boolean
+ * indicator to signal if this context is executing on a processor.
+ * This field must be updated during a context switch. The context switch
+ * to the heir must wait until the heir context indicates that it is no
+ * longer executing on a processor. The context switch must also check if
+ * a thread dispatch is necessary to honor updates of the heir thread for
+ * this processor. This indicator must be updated using an atomic test and
+ * set operation to ensure that at most one processor uses the heir
+ * context at the same time.
+ * @code
+ * void _CPU_Context_switch(
+ * Context_Control *executing,
+ * Context_Control *heir
+ * save( executing );
+ * executing->is_executing = false;
+ * memory_barrier();
+ * if ( test_and_set( &heir->is_executing ) ) {
+ * do {
+ * Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
+ * if ( cpu_self->dispatch_necessary ) {
+ * heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
+ * } while ( test_and_set( &heir->is_executing ) );
+ * restore( heir );
+ * @endcode
+ volatile bool is_executing;
+#endif
+} Context_Control;
+#define _CPU_Context_Get_SP( _context ) \
+ (_context)->x[2]
+typedef struct {
+ /** TODO FPU registers are listed here */
+ double some_float_register;
+} Context_Control_fp;
+typedef Context_Control CPU_Interrupt_frame;
+#define CPU_CONTEXT_FP_SIZE 0
+Context_Control_fp _CPU_Null_fp_context;
+#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
+#define CPU_STACK_MINIMUM_SIZE 4096
+#else
+#define CPU_STACK_MINIMUM_SIZE 4096 * 2
+#endif
+#define CPU_ALIGNMENT 8
+#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
+#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
+#define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT
+#define CPU_STACK_ALIGNMENT 8
+#define _CPU_Initialize_vectors()
+ * Disable all interrupts for an RTEMS critical section. The previous
+ * level is returned in _level.
+static inline unsigned long riscv_interrupt_disable( void )
+ register unsigned long status = read_csr(mstatus);
+ clear_csr(mstatus, MSTATUS_MIE);
+ return status;
+static inline void riscv_interrupt_enable(unsigned long level)
+ write_csr(mstatus, level);
+#define _CPU_ISR_Disable( _level ) \
+ _level = riscv_interrupt_disable()
+#define _CPU_ISR_Enable( _level ) \
+ riscv_interrupt_enable( _level )
+#define _CPU_ISR_Flash( _level ) \
+ do{ \
+ _CPU_ISR_Enable( _level ); \
+ riscv_interrupt_disable(); \
+ } while(0)
+RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( unsigned long level )
+ return ( level & MSTATUS_MIE ) != 0;
+void _CPU_ISR_Set_level( unsigned long level );
+unsigned long _CPU_ISR_Get_level( void );
+/* end of ISR handler macros */
+/* Context handler macros */
+#define RISCV_GCC_RED_ZONE_SIZE 128
+ bool is_fp,
+ void *tls_area
+#define _CPU_Context_Restart_self( _the_context ) \
+ _CPU_Context_restore( (_the_context) )
+#define _CPU_Context_Fp_start( _base, _offset ) \
+ ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
+#define _CPU_Context_Initialize_fp( _destination ) \
+ *(*(_destination)) = _CPU_Null_fp_context; \
+extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
+RTEMS_NO_RETURN;
+/* end of Fatal Error manager macros */
+#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
+#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
+#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
+#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
+ (_output) = 0; /* do something to prevent warnings */ \
+#endif
+/* end of Bitfield handler macros */
+ * This routine builds the mask which corresponds to the bit fields
+ * as searched by _CPU_Bitfield_Find_first_bit(). See the discussion
+ * for that routine.
+#define _CPU_Priority_Mask( _bit_number ) \
+ (1 << _bit_number)
+#endif
+#define _CPU_Priority_bits_index( _priority ) \
+ (_priority)
+#endif
+#define CPU_MAXIMUM_PROCESSORS 32
+#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
+#define CPU_TIMESTAMP_USE_INT64 TRUE
+#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
+typedef struct {
+ /* There is no CPU specific per-CPU state */
+} CPU_Per_CPU_control;
+#endif /* ASM */
+#define CPU_SIZEOF_POINTER 4
+/* 32-bit load/store instructions */
+#define LREG lw
+#define SREG sw
+#define CPU_EXCEPTION_FRAME_SIZE 128
+#define CPU_SIZEOF_POINTER 8
+/* 64-bit load/store instructions */
+#define LREG ld
+#define SREG sd
+#define CPU_EXCEPTION_FRAME_SIZE 256
+#endif
+#define CPU_PER_CPU_CONTROL_SIZE 0
+#ifndef ASM
+typedef uint16_t Priority_bit_map_Word;
+typedef struct {
+ unsigned long x[32];;
+} CPU_Exception_frame;
+ * @brief Prints the exception frame via printk().
+ * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
+/* end of Priority handler macros */
+/* functions */
+ * _CPU_Initialize
+ * This routine performs CPU dependent initialization.
+ void
+ * _CPU_ISR_install_raw_handler
+ * This routine installs a "raw" interrupt handler directly into the
+ * processor's vector table.
+ uint32_t vector,
+ * _CPU_ISR_install_vector
+ * This routine installs an interrupt vector.
+ * NO_CPU Specific Information:
+ * XXX document implementation including references if appropriate
+ * _CPU_Install_interrupt_stack
+ * This routine installs the hardware interrupt stack pointer.
+ * NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
+ * is TRUE.
+void _CPU_Install_interrupt_stack( void );
+ * _CPU_Thread_Idle_body
+ * This routine is the CPU dependent IDLE thread body.
+ * NOTE: It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
+ * is TRUE.
+void *_CPU_Thread_Idle_body( uintptr_t ignored );
+ * _CPU_Context_switch
+ * This routine switches from the run context to the heir context.
+ * RISCV Specific Information:
+ * Please see the comments in the .c file for a description of how
+ * this function works. There are several things to be aware of.
+void _CPU_Context_switch(
+ Context_Control *run,
+ Context_Control *heir
+ * _CPU_Context_restore
+ * This routine is generally used only to restart self in an
+ * efficient manner. It may simply be a label in _CPU_Context_switch.
+ * NOTE: May be unnecessary to reload some registers.
+void _CPU_Context_restore(
+ Context_Control *new_context
+) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+ * _CPU_Context_save_fp
+ * This routine saves the floating point context passed to it.
+void _CPU_Context_save_fp(
+ void **fp_context_ptr
+ * _CPU_Context_restore_fp
+ * This routine restores the floating point context passed to it.
+void _CPU_Context_restore_fp(
+/* The following routine swaps the endian format of an unsigned int.
+ * It must be static because it is referenced indirectly.
+ * This version will work on any processor, but if there is a better
+ * way for your CPU PLEASE use it. The most common way to do this is to:
+ * swap least significant two bytes with 16-bit rotate
+ * swap upper and lower 16-bits
+ * swap most significant two bytes with 16-bit rotate
+ * Some CPUs have special instructions which swap a 32-bit quantity in
+ * a single instruction (e.g. i486). It is probably best to avoid
+ * an "endian swapping control bit" in the CPU. One good reason is
+ * that interrupts would probably have to be disabled to insure that
+ * an interrupt does not try to access the same "chunk" with the wrong
+ * endian. Another good reason is that on some CPUs, the endian bit
+ * endianness for ALL fetches -- both code and data -- so the code
+ * will be fetched incorrectly.
+static inline uint32_t CPU_swap_u32(
+ uint32_t value
+ uint32_t byte1, byte2, byte3, byte4, swapped;
+ byte4 = (value >> 24) & 0xff;
+ byte3 = (value >> 16) & 0xff;
+ byte2 = (value >> 8) & 0xff;
+ byte1 = value & 0xff;
+ swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
+ return ( swapped );
+#define CPU_swap_u16( value ) \
+ (((value&0xff) << 8) | ((value >> 8)&0xff))
+static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
+ /* TODO */
+static inline void _CPU_Context_validate( uintptr_t pattern )
+ while (1) {
+ /* TODO */
+typedef uint32_t CPU_Counter_ticks;
+CPU_Counter_ticks _CPU_Counter_read( void );
+#ifdef RTEMS_SMP
+ * @brief Performs CPU specific SMP initialization in the context of the boot
+ * processor.
+ * This function is invoked on the boot processor during system
+ * initialization. All interrupt stacks are allocated at this point in case
+ * the CPU port allocates the interrupt stacks. This function is called
+ * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
+ * used.
+ * @return The count of physically or virtually available processors.
+ * Depending on the configuration the application may use not all processors.
+uint32_t _CPU_SMP_Initialize( void );
+ * @brief Starts a processor specified by its index.
+ * initialization.
+ * This function will be called after _CPU_SMP_Initialize().
+ * @param[in] cpu_index The processor index.
+ * @retval true Successful operation.
+ * @retval false Unable to start this processor.
+bool _CPU_SMP_Start_processor( uint32_t cpu_index );
+ * @brief Performs final steps of CPU specific SMP initialization in the
+ * context of the boot processor.
+ * initialization.
+ * This function will be called after all processors requested by the
+ * application have been started.
+ * @param[in] cpu_count The minimum value of the count of processors
+ * requested by the application configuration and the count of physically or
+ * virtually available processors.
+void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
+ * @brief Returns the index of the current processor.
+ * An architecture specific method must be used to obtain the index of the
+ * current processor in the system. The set of processor indices is the
+ * range of integers starting with zero up to the processor count minus one.
+uint32_t _CPU_SMP_Get_current_processor( void );
+ * @brief Sends an inter-processor interrupt to the specified target
+ * processor.
+ * This operation is undefined for target processor indices out of range.
+ * @param[in] target_processor_index The target processor index.
+void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
+ * @brief Broadcasts a processor event.
+ * Some architectures provide a low-level synchronization primitive for
+ * processors in a multi-processor environment. Processors waiting for this
+ * event may go into a low-power state and stop generating system bus
+ * transactions. This function must ensure that preceding store operations
+ * can be observed by other processors.
+ * @see _CPU_SMP_Processor_event_receive().
+void _CPU_SMP_Processor_event_broadcast( void );
+ * @brief Receives a processor event.
+ * This function will wait for the processor event and may wait forever if no
+ * such event arrives.
+ * @see _CPU_SMP_Processor_event_broadcast().
+static inline void _CPU_SMP_Processor_event_receive( void )
+ __asm__ volatile ( "" : : : "memory" );
+ * @brief Gets the is executing indicator of the thread context.
+ * @param[in] context The context.
+static inline bool _CPU_Context_Get_is_executing(
+ const Context_Control *context
+ return context->is_executing;
+ * @brief Sets the is executing indicator of the thread context.
+ * @param[in] is_executing The new value for the is executing indicator.
+static inline void _CPU_Context_Set_is_executing(
+ bool is_executing
+ context->is_executing = is_executing;
+#endif /* RTEMS_SMP */
+#endif /* ASM */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/cpu/riscv/rtems/score/cpu_asm.h b/cpukit/score/cpu/riscv/rtems/score/cpu_asm.h
index 0000000..b5a56f3
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/cpu_asm.h
@@ -0,0 +1,90 @@
+ * @file
+ * @brief riscv32 Assembly File
+ * Very loose template for an include file for the cpu_asm.? file
+ * if it is implemented as a ".S" file (preprocessed by cpp) instead
+ * of a ".s" file (preprocessed by gm4 or gasp).
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_CPU_ASM_H
+#define _RTEMS_SCORE_CPU_ASM_H
+/* pull in the generated offsets */
+#include <rtems/score/offsets.h>
+ * Hardware General Registers
+/* put something here */
+ * Hardware Floating Point Registers
+ * Hardware Control Registers
+ * Calling Convention
+ * Temporary registers
+ * Floating Point Registers - SW Conventions
+ * Temporary floating point registers
+#endif
+/* end of file */
diff --git a/cpukit/score/cpu/riscv/rtems/score/cpuatomic.h b/cpukit/score/cpu/riscv/rtems/score/cpuatomic.h
index 0000000..8ee9606
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/cpuatomic.h
@@ -0,0 +1,31 @@
+ * COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
+#define _RTEMS_SCORE_ATOMIC_CPU_H
+#include <rtems/score/cpustdatomic.h>
+#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/riscv/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/rtems/score/cpuimpl.h
index 0000000..3904c84
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/cpuimpl.h
@@ -0,0 +1,51 @@
+ * @file
+ * @brief CPU Port Implementation API
+ * Copyright (c) 2013 embedded brains GmbH
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_CPUIMPL_H
+#define _RTEMS_SCORE_CPUIMPL_H
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/riscv/rtems/score/riscv-utility.h b/cpukit/score/cpu/riscv/rtems/score/riscv-utility.h
index 0000000..dc4836b
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/riscv-utility.h
@@ -0,0 +1,1526 @@
+/* Copyright (c) 2013, The Regents of the University of California (Regents).
+ * All Rights Reserved.
+ * modification, are permitted provided that the following conditions are met:
+ * 3. Neither the name of the Regents nor the
+ * names of its contributors may be used to endorse or promote products
+ * derived from this software without specific prior written
+ * permission.
+ * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT,
+ * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING LOST
+ * PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
+ * REGENTS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO,THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ * PURPOSE. THE SOFTWARE AND ACCOMPANYING DOCUMENTATION, IF ANY, PROVIDED
+ * HEREUNDER IS PROVIDED "AS IS". REGENTS HAS NO OBLIGATION TO PROVIDE
+ * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
+ * @file
+ * @brief RISCV utility
+ * COPYRIGHT (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
+/* This file is copied from riscv-tools/encoding.h with additions/modifications to work
+ * with RTEMS.
+#ifndef _RTEMS_SCORE_RISCV_UTILITY_H
+#define _RTEMS_SCORE_RISCV_UTILITY_H
+#define MSTATUS_UIE 0x00000001
+#define MSTATUS_SIE 0x00000002
+#define MSTATUS_HIE 0x00000004
+#define MSTATUS_MIE 0x00000008
+#define MSTATUS_UPIE 0x00000010
+#define MSTATUS_SPIE 0x00000020
+#define MSTATUS_HPIE 0x00000040
+#define MSTATUS_MPIE 0x00000080
+#define MSTATUS_SPP 0x00000100
+#define MSTATUS_HPP 0x00000600
+#define MSTATUS_MPP 0x00001800
+#define MSTATUS_FS 0x00006000
+#define MSTATUS_XS 0x00018000
+#define MSTATUS_MPRV 0x00020000
+#define MSTATUS_SUM 0x00040000
+#define MSTATUS_MXR 0x00080000
+#define MSTATUS_TVM 0x00100000
+#define MSTATUS_TW 0x00200000
+#define MSTATUS_TSR 0x00400000
+#define MSTATUS32_SD 0x80000000
+#define MSTATUS64_SD 0x8000000000000000
+#define SSTATUS_UIE 0x00000001
+#define SSTATUS_SIE 0x00000002
+#define SSTATUS_UPIE 0x00000010
+#define SSTATUS_SPIE 0x00000020
+#define SSTATUS_SPP 0x00000100
+#define SSTATUS_FS 0x00006000
+#define SSTATUS_XS 0x00018000
+#define SSTATUS_SUM 0x00040000
+#define SSTATUS_MXR 0x00080000
+#define SSTATUS32_SD 0x80000000
+#define SSTATUS64_SD 0x8000000000000000
+#define DCSR_XDEBUGVER (3U<<30)
+#define DCSR_NDRESET (1<<29)
+#define DCSR_FULLRESET (1<<28)
+#define DCSR_EBREAKM (1<<15)
+#define DCSR_EBREAKH (1<<14)
+#define DCSR_EBREAKS (1<<13)
+#define DCSR_EBREAKU (1<<12)
+#define DCSR_STOPCYCLE (1<<10)
+#define DCSR_STOPTIME (1<<9)
+#define DCSR_CAUSE (7<<6)
+#define DCSR_DEBUGINT (1<<5)
+#define DCSR_HALT (1<<3)
+#define DCSR_STEP (1<<2)
+#define DCSR_PRV (3<<0)
+#define DCSR_CAUSE_NONE 0
+#define DCSR_CAUSE_SWBP 1
+#define DCSR_CAUSE_HWBP 2
+#define DCSR_CAUSE_DEBUGINT 3
+#define DCSR_CAUSE_STEP 4
+#define DCSR_CAUSE_HALT 5
+#define MCONTROL_TYPE(xlen) (0xfULL<<((xlen)-4))
+#define MCONTROL_DMODE(xlen) (1ULL<<((xlen)-5))
+#define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))
+#define MCONTROL_SELECT (1<<19)
+#define MCONTROL_TIMING (1<<18)
+#define MCONTROL_ACTION (0x3f<<12)
+#define MCONTROL_CHAIN (1<<11)
+#define MCONTROL_MATCH (0xf<<7)
+#define MCONTROL_M (1<<6)
+#define MCONTROL_H (1<<5)
+#define MCONTROL_S (1<<4)
+#define MCONTROL_U (1<<3)
+#define MCONTROL_EXECUTE (1<<2)
+#define MCONTROL_STORE (1<<1)
+#define MCONTROL_LOAD (1<<0)
+#define MCONTROL_TYPE_NONE 0
+#define MCONTROL_TYPE_MATCH 2
+#define MCONTROL_ACTION_DEBUG_EXCEPTION 0
+#define MCONTROL_ACTION_DEBUG_MODE 1
+#define MCONTROL_ACTION_TRACE_START 2
+#define MCONTROL_ACTION_TRACE_STOP 3
+#define MCONTROL_ACTION_TRACE_EMIT 4
+#define MCONTROL_MATCH_EQUAL 0
+#define MCONTROL_MATCH_NAPOT 1
+#define MCONTROL_MATCH_GE 2
+#define MCONTROL_MATCH_LT 3
+#define MCONTROL_MATCH_MASK_LOW 4
+#define MCONTROL_MATCH_MASK_HIGH 5
+#define MIP_SSIP (1 << IRQ_S_SOFT)
+#define MIP_HSIP (1 << IRQ_H_SOFT)
+#define MIP_MSIP (1 << IRQ_M_SOFT)
+#define MIP_STIP (1 << IRQ_S_TIMER)
+#define MIP_HTIP (1 << IRQ_H_TIMER)
+#define MIP_MTIP (1 << IRQ_M_TIMER)
+#define MIP_SEIP (1 << IRQ_S_EXT)
+#define MIP_HEIP (1 << IRQ_H_EXT)
+#define MIP_MEIP (1 << IRQ_M_EXT)
+#define SIP_SSIP MIP_SSIP
+#define SIP_STIP MIP_STIP
+#define PRV_U 0
+#define PRV_S 1
+#define PRV_H 2
+#define PRV_M 3
+#define SPTBR32_MODE 0x80000000
+#define SPTBR32_ASID 0x7FC00000
+#define SPTBR32_PPN 0x003FFFFF
+#define SPTBR64_MODE 0xF000000000000000
+#define SPTBR64_ASID 0x0FFFF00000000000
+#define SPTBR64_PPN 0x00000FFFFFFFFFFF
+#define SPTBR_MODE_OFF 0
+#define SPTBR_MODE_SV32 1
+#define SPTBR_MODE_SV39 8
+#define SPTBR_MODE_SV48 9
+#define SPTBR_MODE_SV57 10
+#define SPTBR_MODE_SV64 11
+#define PMP_R 0x01
+#define PMP_W 0x02
+#define PMP_X 0x04
+#define PMP_A 0x18
+#define PMP_L 0x80
+#define PMP_SHIFT 2
+#define PMP_TOR 0x08
+#define PMP_NA4 0x10
+#define PMP_NAPOT 0x18
+#define IRQ_S_SOFT 1
+#define IRQ_H_SOFT 2
+#define IRQ_M_SOFT 3
+#define IRQ_S_TIMER 5
+#define IRQ_H_TIMER 6
+#define IRQ_M_TIMER 7
+#define IRQ_S_EXT 9
+#define IRQ_H_EXT 10
+#define IRQ_M_EXT 11
+#define IRQ_COP 12
+#define IRQ_HOST 13
+#define DEFAULT_RSTVEC 0x00001000
+#define CLINT_BASE 0x02000000
+#define CLINT_SIZE 0x000c0000
+#define EXT_IO_BASE 0x40000000
+#define DRAM_BASE 0x80000000
+// page table entry (PTE) fields
+#define PTE_V 0x001 // Valid
+#define PTE_R 0x002 // Read
+#define PTE_W 0x004 // Write
+#define PTE_X 0x008 // Execute
+#define PTE_U 0x010 // User
+#define PTE_G 0x020 // Global
+#define PTE_A 0x040 // Accessed
+#define PTE_D 0x080 // Dirty
+#define PTE_SOFT 0x300 // Reserved for Software
+#define PTE_PPN_SHIFT 10
+#define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)
+#ifdef __riscv
+#if __riscv_xlen == 64
+# define MSTATUS_SD MSTATUS64_SD
+# define SSTATUS_SD SSTATUS64_SD
+# define RISCV_PGLEVEL_BITS 9
+# define SPTBR_MODE SPTBR64_MODE
+#else
+# define MSTATUS_SD MSTATUS32_SD
+# define SSTATUS_SD SSTATUS32_SD
+# define RISCV_PGLEVEL_BITS 10
+# define SPTBR_MODE SPTBR32_MODE
+#endif
+#define RISCV_PGSHIFT 12
+#define RISCV_PGSIZE (1 << RISCV_PGSHIFT)
+#ifndef __ASSEMBLER__
+ * @brief Priv Mode registers definitions.
+ * @see RISC-V priv-spec 1.10.
+typedef enum {
+ RISCV_USER_INTERRUPT = 0,
+ RISCV_SUPERVISOR_SW_INTERRUPT = 1,
+ RISCV_MACHINE_SW_INTERRUPT = 3,
+ RISCV_USER_TIMER_INTERRUPT = 4,
+ RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
+ RISCV_MACHINE_TIMER_INTERRUPT = 7,
+ RISCV_USER_EXTERNAL_INTERRUPT = 8,
+ RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
+ RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
+} RISCV_Symbolic_interrupt_name;
+#ifdef __GNUC__
+#define read_csr(reg) ({ unsigned long __tmp; \
+ asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
+ __tmp; })
+#define write_csr(reg, val) ({ \
+ asm volatile ("csrw " #reg ", %0" :: "rK"(val)); })
+#define swap_csr(reg, val) ({ unsigned long __tmp; \
+ asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "rK"(val)); \
+ __tmp; })
+#define set_csr(reg, bit) ({ unsigned long __tmp; \
+ asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
+ __tmp; })
+#define clear_csr(reg, bit) ({ unsigned long __tmp; \
+ asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
+ __tmp; })
+#define rdtime() read_csr(time)
+#define rdcycle() read_csr(cycle)
+#define rdinstret() read_csr(instret)
+#endif
+#endif
+#endif
+#endif
+/* Automatically generated by parse-opcodes. */
+#ifndef RISCV_ENCODING_H
+#define RISCV_ENCODING_H
+#define MATCH_BEQ 0x63
+#define MASK_BEQ 0x707f
+#define MATCH_BNE 0x1063
+#define MASK_BNE 0x707f
+#define MATCH_BLT 0x4063
+#define MASK_BLT 0x707f
+#define MATCH_BGE 0x5063
+#define MASK_BGE 0x707f
+#define MATCH_BLTU 0x6063
+#define MASK_BLTU 0x707f
+#define MATCH_BGEU 0x7063
+#define MASK_BGEU 0x707f
+#define MATCH_JALR 0x67
+#define MASK_JALR 0x707f
+#define MATCH_JAL 0x6f
+#define MASK_JAL 0x7f
+#define MATCH_LUI 0x37
+#define MASK_LUI 0x7f
+#define MATCH_AUIPC 0x17
+#define MASK_AUIPC 0x7f
+#define MATCH_ADDI 0x13
+#define MASK_ADDI 0x707f
+#define MATCH_SLLI 0x1013
+#define MASK_SLLI 0xfc00707f
+#define MATCH_SLTI 0x2013
+#define MASK_SLTI 0x707f
+#define MATCH_SLTIU 0x3013
+#define MASK_SLTIU 0x707f
+#define MATCH_XORI 0x4013
+#define MASK_XORI 0x707f
+#define MATCH_SRLI 0x5013
+#define MASK_SRLI 0xfc00707f
+#define MATCH_SRAI 0x40005013
+#define MASK_SRAI 0xfc00707f
+#define MATCH_ORI 0x6013
+#define MASK_ORI 0x707f
+#define MATCH_ANDI 0x7013
+#define MASK_ANDI 0x707f
+#define MATCH_ADD 0x33
+#define MASK_ADD 0xfe00707f
+#define MATCH_SUB 0x40000033
+#define MASK_SUB 0xfe00707f
+#define MATCH_SLL 0x1033
+#define MASK_SLL 0xfe00707f
+#define MATCH_SLT 0x2033
+#define MASK_SLT 0xfe00707f
+#define MATCH_SLTU 0x3033
+#define MASK_SLTU 0xfe00707f
+#define MATCH_XOR 0x4033
+#define MASK_XOR 0xfe00707f
+#define MATCH_SRL 0x5033
+#define MASK_SRL 0xfe00707f
+#define MATCH_SRA 0x40005033
+#define MASK_SRA 0xfe00707f
+#define MATCH_OR 0x6033
+#define MASK_OR 0xfe00707f
+#define MATCH_AND 0x7033
+#define MASK_AND 0xfe00707f
+#define MATCH_ADDIW 0x1b
+#define MASK_ADDIW 0x707f
+#define MATCH_SLLIW 0x101b
+#define MASK_SLLIW 0xfe00707f
+#define MATCH_SRLIW 0x501b
+#define MASK_SRLIW 0xfe00707f
+#define MATCH_SRAIW 0x4000501b
+#define MASK_SRAIW 0xfe00707f
+#define MATCH_ADDW 0x3b
+#define MASK_ADDW 0xfe00707f
+#define MATCH_SUBW 0x4000003b
+#define MASK_SUBW 0xfe00707f
+#define MATCH_SLLW 0x103b
+#define MASK_SLLW 0xfe00707f
+#define MATCH_SRLW 0x503b
+#define MASK_SRLW 0xfe00707f
+#define MATCH_SRAW 0x4000503b
+#define MASK_SRAW 0xfe00707f
+#define MATCH_LB 0x3
+#define MASK_LB 0x707f
+#define MATCH_LH 0x1003
+#define MASK_LH 0x707f
+#define MATCH_LW 0x2003
+#define MASK_LW 0x707f
+#define MATCH_LD 0x3003
+#define MASK_LD 0x707f
+#define MATCH_LBU 0x4003
+#define MASK_LBU 0x707f
+#define MATCH_LHU 0x5003
+#define MASK_LHU 0x707f
+#define MATCH_LWU 0x6003
+#define MASK_LWU 0x707f
+#define MATCH_SB 0x23
+#define MASK_SB 0x707f
+#define MATCH_SH 0x1023
+#define MASK_SH 0x707f
+#define MATCH_SW 0x2023
+#define MASK_SW 0x707f
+#define MATCH_SD 0x3023
+#define MASK_SD 0x707f
+#define MATCH_FENCE 0xf
+#define MASK_FENCE 0x707f
+#define MATCH_FENCE_I 0x100f
+#define MASK_FENCE_I 0x707f
+#define MATCH_MUL 0x2000033
+#define MASK_MUL 0xfe00707f
+#define MATCH_MULH 0x2001033
+#define MASK_MULH 0xfe00707f
+#define MATCH_MULHSU 0x2002033
+#define MASK_MULHSU 0xfe00707f
+#define MATCH_MULHU 0x2003033
+#define MASK_MULHU 0xfe00707f
+#define MATCH_DIV 0x2004033
+#define MASK_DIV 0xfe00707f
+#define MATCH_DIVU 0x2005033
+#define MASK_DIVU 0xfe00707f
+#define MATCH_REM 0x2006033
+#define MASK_REM 0xfe00707f
+#define MATCH_REMU 0x2007033
+#define MASK_REMU 0xfe00707f
+#define MATCH_MULW 0x200003b
+#define MASK_MULW 0xfe00707f
+#define MATCH_DIVW 0x200403b
+#define MASK_DIVW 0xfe00707f
+#define MATCH_DIVUW 0x200503b
+#define MASK_DIVUW 0xfe00707f
+#define MATCH_REMW 0x200603b
+#define MASK_REMW 0xfe00707f
+#define MATCH_REMUW 0x200703b
+#define MASK_REMUW 0xfe00707f
+#define MATCH_AMOADD_W 0x202f
+#define MASK_AMOADD_W 0xf800707f
+#define MATCH_AMOXOR_W 0x2000202f
+#define MASK_AMOXOR_W 0xf800707f
+#define MATCH_AMOOR_W 0x4000202f
+#define MASK_AMOOR_W 0xf800707f
+#define MATCH_AMOAND_W 0x6000202f
+#define MASK_AMOAND_W 0xf800707f
+#define MATCH_AMOMIN_W 0x8000202f
+#define MASK_AMOMIN_W 0xf800707f
+#define MATCH_AMOMAX_W 0xa000202f
+#define MASK_AMOMAX_W 0xf800707f
+#define MATCH_AMOMINU_W 0xc000202f
+#define MASK_AMOMINU_W 0xf800707f
+#define MATCH_AMOMAXU_W 0xe000202f
+#define MASK_AMOMAXU_W 0xf800707f
+#define MATCH_AMOSWAP_W 0x800202f
+#define MASK_AMOSWAP_W 0xf800707f
+#define MATCH_LR_W 0x1000202f
+#define MASK_LR_W 0xf9f0707f
+#define MATCH_SC_W 0x1800202f
+#define MASK_SC_W 0xf800707f
+#define MATCH_AMOADD_D 0x302f
+#define MASK_AMOADD_D 0xf800707f
+#define MATCH_AMOXOR_D 0x2000302f
+#define MASK_AMOXOR_D 0xf800707f
+#define MATCH_AMOOR_D 0x4000302f
+#define MASK_AMOOR_D 0xf800707f
+#define MATCH_AMOAND_D 0x6000302f
+#define MASK_AMOAND_D 0xf800707f
+#define MATCH_AMOMIN_D 0x8000302f
+#define MASK_AMOMIN_D 0xf800707f
+#define MATCH_AMOMAX_D 0xa000302f
+#define MASK_AMOMAX_D 0xf800707f
+#define MATCH_AMOMINU_D 0xc000302f
+#define MASK_AMOMINU_D 0xf800707f
+#define MATCH_AMOMAXU_D 0xe000302f
+#define MASK_AMOMAXU_D 0xf800707f
+#define MATCH_AMOSWAP_D 0x800302f
+#define MASK_AMOSWAP_D 0xf800707f
+#define MATCH_LR_D 0x1000302f
+#define MASK_LR_D 0xf9f0707f
+#define MATCH_SC_D 0x1800302f
+#define MASK_SC_D 0xf800707f
+#define MATCH_ECALL 0x73
+#define MASK_ECALL 0xffffffff
+#define MATCH_EBREAK 0x100073
+#define MASK_EBREAK 0xffffffff
+#define MATCH_URET 0x200073
+#define MASK_URET 0xffffffff
+#define MATCH_SRET 0x10200073
+#define MASK_SRET 0xffffffff
+#define MATCH_MRET 0x30200073
+#define MASK_MRET 0xffffffff
+#define MATCH_DRET 0x7b200073
+#define MASK_DRET 0xffffffff
+#define MATCH_SFENCE_VMA 0x12000073
+#define MASK_SFENCE_VMA 0xfe007fff
+#define MATCH_WFI 0x10500073
+#define MASK_WFI 0xffffffff
+#define MATCH_CSRRW 0x1073
+#define MASK_CSRRW 0x707f
+#define MATCH_CSRRS 0x2073
+#define MASK_CSRRS 0x707f
+#define MATCH_CSRRC 0x3073
+#define MASK_CSRRC 0x707f
+#define MATCH_CSRRWI 0x5073
+#define MASK_CSRRWI 0x707f
+#define MATCH_CSRRSI 0x6073
+#define MASK_CSRRSI 0x707f
+#define MATCH_CSRRCI 0x7073
+#define MASK_CSRRCI 0x707f
+#define MATCH_FADD_S 0x53
+#define MASK_FADD_S 0xfe00007f
+#define MATCH_FSUB_S 0x8000053
+#define MASK_FSUB_S 0xfe00007f
+#define MATCH_FMUL_S 0x10000053
+#define MASK_FMUL_S 0xfe00007f
+#define MATCH_FDIV_S 0x18000053
+#define MASK_FDIV_S 0xfe00007f
+#define MATCH_FSGNJ_S 0x20000053
+#define MASK_FSGNJ_S 0xfe00707f
+#define MATCH_FSGNJN_S 0x20001053
+#define MASK_FSGNJN_S 0xfe00707f
+#define MATCH_FSGNJX_S 0x20002053
+#define MASK_FSGNJX_S 0xfe00707f
+#define MATCH_FMIN_S 0x28000053
+#define MASK_FMIN_S 0xfe00707f
+#define MATCH_FMAX_S 0x28001053
+#define MASK_FMAX_S 0xfe00707f
+#define MATCH_FSQRT_S 0x58000053
+#define MASK_FSQRT_S 0xfff0007f
+#define MATCH_FADD_D 0x2000053
+#define MASK_FADD_D 0xfe00007f
+#define MATCH_FSUB_D 0xa000053
+#define MASK_FSUB_D 0xfe00007f
+#define MATCH_FMUL_D 0x12000053
+#define MASK_FMUL_D 0xfe00007f
+#define MATCH_FDIV_D 0x1a000053
+#define MASK_FDIV_D 0xfe00007f
+#define MATCH_FSGNJ_D 0x22000053
+#define MASK_FSGNJ_D 0xfe00707f
+#define MATCH_FSGNJN_D 0x22001053
+#define MASK_FSGNJN_D 0xfe00707f
+#define MATCH_FSGNJX_D 0x22002053
+#define MASK_FSGNJX_D 0xfe00707f
+#define MATCH_FMIN_D 0x2a000053
+#define MASK_FMIN_D 0xfe00707f
+#define MATCH_FMAX_D 0x2a001053
+#define MASK_FMAX_D 0xfe00707f
+#define MATCH_FCVT_S_D 0x40100053
+#define MASK_FCVT_S_D 0xfff0007f
+#define MATCH_FCVT_D_S 0x42000053
+#define MASK_FCVT_D_S 0xfff0007f
+#define MATCH_FSQRT_D 0x5a000053
+#define MASK_FSQRT_D 0xfff0007f
+#define MATCH_FADD_Q 0x6000053
+#define MASK_FADD_Q 0xfe00007f
+#define MATCH_FSUB_Q 0xe000053
+#define MASK_FSUB_Q 0xfe00007f
+#define MATCH_FMUL_Q 0x16000053
+#define MASK_FMUL_Q 0xfe00007f
+#define MATCH_FDIV_Q 0x1e000053
+#define MASK_FDIV_Q 0xfe00007f
+#define MATCH_FSGNJ_Q 0x26000053
+#define MASK_FSGNJ_Q 0xfe00707f
+#define MATCH_FSGNJN_Q 0x26001053
+#define MASK_FSGNJN_Q 0xfe00707f
+#define MATCH_FSGNJX_Q 0x26002053
+#define MASK_FSGNJX_Q 0xfe00707f
+#define MATCH_FMIN_Q 0x2e000053
+#define MASK_FMIN_Q 0xfe00707f
+#define MATCH_FMAX_Q 0x2e001053
+#define MASK_FMAX_Q 0xfe00707f
+#define MATCH_FCVT_S_Q 0x40300053
+#define MASK_FCVT_S_Q 0xfff0007f
+#define MATCH_FCVT_Q_S 0x46000053
+#define MASK_FCVT_Q_S 0xfff0007f
+#define MATCH_FCVT_D_Q 0x42300053
+#define MASK_FCVT_D_Q 0xfff0007f
+#define MATCH_FCVT_Q_D 0x46100053
+#define MASK_FCVT_Q_D 0xfff0007f
+#define MATCH_FSQRT_Q 0x5e000053
+#define MASK_FSQRT_Q 0xfff0007f
+#define MATCH_FLE_S 0xa0000053
+#define MASK_FLE_S 0xfe00707f
+#define MATCH_FLT_S 0xa0001053
+#define MASK_FLT_S 0xfe00707f
+#define MATCH_FEQ_S 0xa0002053
+#define MASK_FEQ_S 0xfe00707f
+#define MATCH_FLE_D 0xa2000053
+#define MASK_FLE_D 0xfe00707f
+#define MATCH_FLT_D 0xa2001053
+#define MASK_FLT_D 0xfe00707f
+#define MATCH_FEQ_D 0xa2002053
+#define MASK_FEQ_D 0xfe00707f
+#define MATCH_FLE_Q 0xa6000053
+#define MASK_FLE_Q 0xfe00707f
+#define MATCH_FLT_Q 0xa6001053
+#define MASK_FLT_Q 0xfe00707f
+#define MATCH_FEQ_Q 0xa6002053
+#define MASK_FEQ_Q 0xfe00707f
+#define MATCH_FCVT_W_S 0xc0000053
+#define MASK_FCVT_W_S 0xfff0007f
+#define MATCH_FCVT_WU_S 0xc0100053
+#define MASK_FCVT_WU_S 0xfff0007f
+#define MATCH_FCVT_L_S 0xc0200053
+#define MASK_FCVT_L_S 0xfff0007f
+#define MATCH_FCVT_LU_S 0xc0300053
+#define MASK_FCVT_LU_S 0xfff0007f
+#define MATCH_FMV_X_W 0xe0000053
+#define MASK_FMV_X_W 0xfff0707f
+#define MATCH_FCLASS_S 0xe0001053
+#define MASK_FCLASS_S 0xfff0707f
+#define MATCH_FCVT_W_D 0xc2000053
+#define MASK_FCVT_W_D 0xfff0007f
+#define MATCH_FCVT_WU_D 0xc2100053
+#define MASK_FCVT_WU_D 0xfff0007f
+#define MATCH_FCVT_L_D 0xc2200053
+#define MASK_FCVT_L_D 0xfff0007f
+#define MATCH_FCVT_LU_D 0xc2300053
+#define MASK_FCVT_LU_D 0xfff0007f
+#define MATCH_FMV_X_D 0xe2000053
+#define MASK_FMV_X_D 0xfff0707f
+#define MATCH_FCLASS_D 0xe2001053
+#define MASK_FCLASS_D 0xfff0707f
+#define MATCH_FCVT_W_Q 0xc6000053
+#define MASK_FCVT_W_Q 0xfff0007f
+#define MATCH_FCVT_WU_Q 0xc6100053
+#define MASK_FCVT_WU_Q 0xfff0007f
+#define MATCH_FCVT_L_Q 0xc6200053
+#define MASK_FCVT_L_Q 0xfff0007f
+#define MATCH_FCVT_LU_Q 0xc6300053
+#define MASK_FCVT_LU_Q 0xfff0007f
+#define MATCH_FMV_X_Q 0xe6000053
+#define MASK_FMV_X_Q 0xfff0707f
+#define MATCH_FCLASS_Q 0xe6001053
+#define MASK_FCLASS_Q 0xfff0707f
+#define MATCH_FCVT_S_W 0xd0000053
+#define MASK_FCVT_S_W 0xfff0007f
+#define MATCH_FCVT_S_WU 0xd0100053
+#define MASK_FCVT_S_WU 0xfff0007f
+#define MATCH_FCVT_S_L 0xd0200053
+#define MASK_FCVT_S_L 0xfff0007f
+#define MATCH_FCVT_S_LU 0xd0300053
+#define MASK_FCVT_S_LU 0xfff0007f
+#define MATCH_FMV_W_X 0xf0000053
+#define MASK_FMV_W_X 0xfff0707f
+#define MATCH_FCVT_D_W 0xd2000053
+#define MASK_FCVT_D_W 0xfff0007f
+#define MATCH_FCVT_D_WU 0xd2100053
+#define MASK_FCVT_D_WU 0xfff0007f
+#define MATCH_FCVT_D_L 0xd2200053
+#define MASK_FCVT_D_L 0xfff0007f
+#define MATCH_FCVT_D_LU 0xd2300053
+#define MASK_FCVT_D_LU 0xfff0007f
+#define MATCH_FMV_D_X 0xf2000053
+#define MASK_FMV_D_X 0xfff0707f
+#define MATCH_FCVT_Q_W 0xd6000053
+#define MASK_FCVT_Q_W 0xfff0007f
+#define MATCH_FCVT_Q_WU 0xd6100053
+#define MASK_FCVT_Q_WU 0xfff0007f
+#define MATCH_FCVT_Q_L 0xd6200053
+#define MASK_FCVT_Q_L 0xfff0007f
+#define MATCH_FCVT_Q_LU 0xd6300053
+#define MASK_FCVT_Q_LU 0xfff0007f
+#define MATCH_FMV_Q_X 0xf6000053
+#define MASK_FMV_Q_X 0xfff0707f
+#define MATCH_FLW 0x2007
+#define MASK_FLW 0x707f
+#define MATCH_FLD 0x3007
+#define MASK_FLD 0x707f
+#define MATCH_FLQ 0x4007
+#define MASK_FLQ 0x707f
+#define MATCH_FSW 0x2027
+#define MASK_FSW 0x707f
+#define MATCH_FSD 0x3027
+#define MASK_FSD 0x707f
+#define MATCH_FSQ 0x4027
+#define MASK_FSQ 0x707f
+#define MATCH_FMADD_S 0x43
+#define MASK_FMADD_S 0x600007f
+#define MATCH_FMSUB_S 0x47
+#define MASK_FMSUB_S 0x600007f
+#define MATCH_FNMSUB_S 0x4b
+#define MASK_FNMSUB_S 0x600007f
+#define MATCH_FNMADD_S 0x4f
+#define MASK_FNMADD_S 0x600007f
+#define MATCH_FMADD_D 0x2000043
+#define MASK_FMADD_D 0x600007f
+#define MATCH_FMSUB_D 0x2000047
+#define MASK_FMSUB_D 0x600007f
+#define MATCH_FNMSUB_D 0x200004b
+#define MASK_FNMSUB_D 0x600007f
+#define MATCH_FNMADD_D 0x200004f
+#define MASK_FNMADD_D 0x600007f
+#define MATCH_FMADD_Q 0x6000043
+#define MASK_FMADD_Q 0x600007f
+#define MATCH_FMSUB_Q 0x6000047
+#define MASK_FMSUB_Q 0x600007f
+#define MATCH_FNMSUB_Q 0x600004b
+#define MASK_FNMSUB_Q 0x600007f
+#define MATCH_FNMADD_Q 0x600004f
+#define MASK_FNMADD_Q 0x600007f
+#define MATCH_C_NOP 0x1
+#define MASK_C_NOP 0xffff
+#define MATCH_C_ADDI16SP 0x6101
+#define MASK_C_ADDI16SP 0xef83
+#define MATCH_C_JR 0x8002
+#define MASK_C_JR 0xf07f
+#define MATCH_C_JALR 0x9002
+#define MASK_C_JALR 0xf07f
+#define MATCH_C_EBREAK 0x9002
+#define MASK_C_EBREAK 0xffff
+#define MATCH_C_LD 0x6000
+#define MASK_C_LD 0xe003
+#define MATCH_C_SD 0xe000
+#define MASK_C_SD 0xe003
+#define MATCH_C_ADDIW 0x2001
+#define MASK_C_ADDIW 0xe003
+#define MATCH_C_LDSP 0x6002
+#define MASK_C_LDSP 0xe003
+#define MATCH_C_SDSP 0xe002
+#define MASK_C_SDSP 0xe003
+#define MATCH_C_ADDI4SPN 0x0
+#define MASK_C_ADDI4SPN 0xe003
+#define MATCH_C_FLD 0x2000
+#define MASK_C_FLD 0xe003
+#define MATCH_C_LW 0x4000
+#define MASK_C_LW 0xe003
+#define MATCH_C_FLW 0x6000
+#define MASK_C_FLW 0xe003
+#define MATCH_C_FSD 0xa000
+#define MASK_C_FSD 0xe003
+#define MATCH_C_SW 0xc000
+#define MASK_C_SW 0xe003
+#define MATCH_C_FSW 0xe000
+#define MASK_C_FSW 0xe003
+#define MATCH_C_ADDI 0x1
+#define MASK_C_ADDI 0xe003
+#define MATCH_C_JAL 0x2001
+#define MASK_C_JAL 0xe003
+#define MATCH_C_LI 0x4001
+#define MASK_C_LI 0xe003
+#define MATCH_C_LUI 0x6001
+#define MASK_C_LUI 0xe003
+#define MATCH_C_SRLI 0x8001
+#define MASK_C_SRLI 0xec03
+#define MATCH_C_SRAI 0x8401
+#define MASK_C_SRAI 0xec03
+#define MATCH_C_ANDI 0x8801
+#define MASK_C_ANDI 0xec03
+#define MATCH_C_SUB 0x8c01
+#define MASK_C_SUB 0xfc63
+#define MATCH_C_XOR 0x8c21
+#define MASK_C_XOR 0xfc63
+#define MATCH_C_OR 0x8c41
+#define MASK_C_OR 0xfc63
+#define MATCH_C_AND 0x8c61
+#define MASK_C_AND 0xfc63
+#define MATCH_C_SUBW 0x9c01
+#define MASK_C_SUBW 0xfc63
+#define MATCH_C_ADDW 0x9c21
+#define MASK_C_ADDW 0xfc63
+#define MATCH_C_J 0xa001
+#define MASK_C_J 0xe003
+#define MATCH_C_BEQZ 0xc001
+#define MASK_C_BEQZ 0xe003
+#define MATCH_C_BNEZ 0xe001
+#define MASK_C_BNEZ 0xe003
+#define MATCH_C_SLLI 0x2
+#define MASK_C_SLLI 0xe003
+#define MATCH_C_FLDSP 0x2002
+#define MASK_C_FLDSP 0xe003
+#define MATCH_C_LWSP 0x4002
+#define MASK_C_LWSP 0xe003
+#define MATCH_C_FLWSP 0x6002
+#define MASK_C_FLWSP 0xe003
+#define MATCH_C_MV 0x8002
+#define MASK_C_MV 0xf003
+#define MATCH_C_ADD 0x9002
+#define MASK_C_ADD 0xf003
+#define MATCH_C_FSDSP 0xa002
+#define MASK_C_FSDSP 0xe003
+#define MATCH_C_SWSP 0xc002
+#define MASK_C_SWSP 0xe003
+#define MATCH_C_FSWSP 0xe002
+#define MASK_C_FSWSP 0xe003
+#define MATCH_CUSTOM0 0xb
+#define MASK_CUSTOM0 0x707f
+#define MATCH_CUSTOM0_RS1 0x200b
+#define MASK_CUSTOM0_RS1 0x707f
+#define MATCH_CUSTOM0_RS1_RS2 0x300b
+#define MASK_CUSTOM0_RS1_RS2 0x707f
+#define MATCH_CUSTOM0_RD 0x400b
+#define MASK_CUSTOM0_RD 0x707f
+#define MATCH_CUSTOM0_RD_RS1 0x600b
+#define MASK_CUSTOM0_RD_RS1 0x707f
+#define MATCH_CUSTOM0_RD_RS1_RS2 0x700b
+#define MASK_CUSTOM0_RD_RS1_RS2 0x707f
+#define MATCH_CUSTOM1 0x2b
+#define MASK_CUSTOM1 0x707f
+#define MATCH_CUSTOM1_RS1 0x202b
+#define MASK_CUSTOM1_RS1 0x707f
+#define MATCH_CUSTOM1_RS1_RS2 0x302b
+#define MASK_CUSTOM1_RS1_RS2 0x707f
+#define MATCH_CUSTOM1_RD 0x402b
+#define MASK_CUSTOM1_RD 0x707f
+#define MATCH_CUSTOM1_RD_RS1 0x602b
+#define MASK_CUSTOM1_RD_RS1 0x707f
+#define MATCH_CUSTOM1_RD_RS1_RS2 0x702b
+#define MASK_CUSTOM1_RD_RS1_RS2 0x707f
+#define MATCH_CUSTOM2 0x5b
+#define MASK_CUSTOM2 0x707f
+#define MATCH_CUSTOM2_RS1 0x205b
+#define MASK_CUSTOM2_RS1 0x707f
+#define MATCH_CUSTOM2_RS1_RS2 0x305b
+#define MASK_CUSTOM2_RS1_RS2 0x707f
+#define MATCH_CUSTOM2_RD 0x405b
+#define MASK_CUSTOM2_RD 0x707f
+#define MATCH_CUSTOM2_RD_RS1 0x605b
+#define MASK_CUSTOM2_RD_RS1 0x707f
+#define MATCH_CUSTOM2_RD_RS1_RS2 0x705b
+#define MASK_CUSTOM2_RD_RS1_RS2 0x707f
+#define MATCH_CUSTOM3 0x7b
+#define MASK_CUSTOM3 0x707f
+#define MATCH_CUSTOM3_RS1 0x207b
+#define MASK_CUSTOM3_RS1 0x707f
+#define MATCH_CUSTOM3_RS1_RS2 0x307b
+#define MASK_CUSTOM3_RS1_RS2 0x707f
+#define MATCH_CUSTOM3_RD 0x407b
+#define MASK_CUSTOM3_RD 0x707f
+#define MATCH_CUSTOM3_RD_RS1 0x607b
+#define MASK_CUSTOM3_RD_RS1 0x707f
+#define MATCH_CUSTOM3_RD_RS1_RS2 0x707b
+#define MASK_CUSTOM3_RD_RS1_RS2 0x707f
+#define CSR_FFLAGS 0x1
+#define CSR_FRM 0x2
+#define CSR_FCSR 0x3
+#define CSR_CYCLE 0xc00
+#define CSR_TIME 0xc01
+#define CSR_INSTRET 0xc02
+#define CSR_HPMCOUNTER3 0xc03
+#define CSR_HPMCOUNTER4 0xc04
+#define CSR_HPMCOUNTER5 0xc05
+#define CSR_HPMCOUNTER6 0xc06
+#define CSR_HPMCOUNTER7 0xc07
+#define CSR_HPMCOUNTER8 0xc08
+#define CSR_HPMCOUNTER9 0xc09
+#define CSR_HPMCOUNTER10 0xc0a
+#define CSR_HPMCOUNTER11 0xc0b
+#define CSR_HPMCOUNTER12 0xc0c
+#define CSR_HPMCOUNTER13 0xc0d
+#define CSR_HPMCOUNTER14 0xc0e
+#define CSR_HPMCOUNTER15 0xc0f
+#define CSR_HPMCOUNTER16 0xc10
+#define CSR_HPMCOUNTER17 0xc11
+#define CSR_HPMCOUNTER18 0xc12
+#define CSR_HPMCOUNTER19 0xc13
+#define CSR_HPMCOUNTER20 0xc14
+#define CSR_HPMCOUNTER21 0xc15
+#define CSR_HPMCOUNTER22 0xc16
+#define CSR_HPMCOUNTER23 0xc17
+#define CSR_HPMCOUNTER24 0xc18
+#define CSR_HPMCOUNTER25 0xc19
+#define CSR_HPMCOUNTER26 0xc1a
+#define CSR_HPMCOUNTER27 0xc1b
+#define CSR_HPMCOUNTER28 0xc1c
+#define CSR_HPMCOUNTER29 0xc1d
+#define CSR_HPMCOUNTER30 0xc1e
+#define CSR_HPMCOUNTER31 0xc1f
+#define CSR_SSTATUS 0x100
+#define CSR_SIE 0x104
+#define CSR_STVEC 0x105
+#define CSR_SCOUNTEREN 0x106
+#define CSR_SSCRATCH 0x140
+#define CSR_SEPC 0x141
+#define CSR_SCAUSE 0x142
+#define CSR_SBADADDR 0x143
+#define CSR_SIP 0x144
+#define CSR_SPTBR 0x180
+#define CSR_MSTATUS 0x300
+#define CSR_MISA 0x301
+#define CSR_MEDELEG 0x302
+#define CSR_MIDELEG 0x303
+#define CSR_MIE 0x304
+#define CSR_MTVEC 0x305
+#define CSR_MCOUNTEREN 0x306
+#define CSR_MSCRATCH 0x340
+#define CSR_MEPC 0x341
+#define CSR_MCAUSE 0x342
+#define CSR_MBADADDR 0x343
+#define CSR_MIP 0x344
+#define CSR_PMPCFG0 0x3a0
+#define CSR_PMPCFG1 0x3a1
+#define CSR_PMPCFG2 0x3a2
+#define CSR_PMPCFG3 0x3a3
+#define CSR_PMPADDR0 0x3b0
+#define CSR_PMPADDR1 0x3b1
+#define CSR_PMPADDR2 0x3b2
+#define CSR_PMPADDR3 0x3b3
+#define CSR_PMPADDR4 0x3b4
+#define CSR_PMPADDR5 0x3b5
+#define CSR_PMPADDR6 0x3b6
+#define CSR_PMPADDR7 0x3b7
+#define CSR_PMPADDR8 0x3b8
+#define CSR_PMPADDR9 0x3b9
+#define CSR_PMPADDR10 0x3ba
+#define CSR_PMPADDR11 0x3bb
+#define CSR_PMPADDR12 0x3bc
+#define CSR_PMPADDR13 0x3bd
+#define CSR_PMPADDR14 0x3be
+#define CSR_PMPADDR15 0x3bf
+#define CSR_TSELECT 0x7a0
+#define CSR_TDATA1 0x7a1
+#define CSR_TDATA2 0x7a2
+#define CSR_TDATA3 0x7a3
+#define CSR_DCSR 0x7b0
+#define CSR_DPC 0x7b1
+#define CSR_DSCRATCH 0x7b2
+#define CSR_MCYCLE 0xb00
+#define CSR_MINSTRET 0xb02
+#define CSR_MHPMCOUNTER3 0xb03
+#define CSR_MHPMCOUNTER4 0xb04
+#define CSR_MHPMCOUNTER5 0xb05
+#define CSR_MHPMCOUNTER6 0xb06
+#define CSR_MHPMCOUNTER7 0xb07
+#define CSR_MHPMCOUNTER8 0xb08
+#define CSR_MHPMCOUNTER9 0xb09
+#define CSR_MHPMCOUNTER10 0xb0a
+#define CSR_MHPMCOUNTER11 0xb0b
+#define CSR_MHPMCOUNTER12 0xb0c
+#define CSR_MHPMCOUNTER13 0xb0d
+#define CSR_MHPMCOUNTER14 0xb0e
+#define CSR_MHPMCOUNTER15 0xb0f
+#define CSR_MHPMCOUNTER16 0xb10
+#define CSR_MHPMCOUNTER17 0xb11
+#define CSR_MHPMCOUNTER18 0xb12
+#define CSR_MHPMCOUNTER19 0xb13
+#define CSR_MHPMCOUNTER20 0xb14
+#define CSR_MHPMCOUNTER21 0xb15
+#define CSR_MHPMCOUNTER22 0xb16
+#define CSR_MHPMCOUNTER23 0xb17
+#define CSR_MHPMCOUNTER24 0xb18
+#define CSR_MHPMCOUNTER25 0xb19
+#define CSR_MHPMCOUNTER26 0xb1a
+#define CSR_MHPMCOUNTER27 0xb1b
+#define CSR_MHPMCOUNTER28 0xb1c
+#define CSR_MHPMCOUNTER29 0xb1d
+#define CSR_MHPMCOUNTER30 0xb1e
+#define CSR_MHPMCOUNTER31 0xb1f
+#define CSR_MHPMEVENT3 0x323
+#define CSR_MHPMEVENT4 0x324
+#define CSR_MHPMEVENT5 0x325
+#define CSR_MHPMEVENT6 0x326
+#define CSR_MHPMEVENT7 0x327
+#define CSR_MHPMEVENT8 0x328
+#define CSR_MHPMEVENT9 0x329
+#define CSR_MHPMEVENT10 0x32a
+#define CSR_MHPMEVENT11 0x32b
+#define CSR_MHPMEVENT12 0x32c
+#define CSR_MHPMEVENT13 0x32d
+#define CSR_MHPMEVENT14 0x32e
+#define CSR_MHPMEVENT15 0x32f
+#define CSR_MHPMEVENT16 0x330
+#define CSR_MHPMEVENT17 0x331
+#define CSR_MHPMEVENT18 0x332
+#define CSR_MHPMEVENT19 0x333
+#define CSR_MHPMEVENT20 0x334
+#define CSR_MHPMEVENT21 0x335
+#define CSR_MHPMEVENT22 0x336
+#define CSR_MHPMEVENT23 0x337
+#define CSR_MHPMEVENT24 0x338
+#define CSR_MHPMEVENT25 0x339
+#define CSR_MHPMEVENT26 0x33a
+#define CSR_MHPMEVENT27 0x33b
+#define CSR_MHPMEVENT28 0x33c
+#define CSR_MHPMEVENT29 0x33d
+#define CSR_MHPMEVENT30 0x33e
+#define CSR_MHPMEVENT31 0x33f
+#define CSR_MVENDORID 0xf11
+#define CSR_MARCHID 0xf12
+#define CSR_MIMPID 0xf13
+#define CSR_MHARTID 0xf14
+#define CSR_CYCLEH 0xc80
+#define CSR_TIMEH 0xc81
+#define CSR_INSTRETH 0xc82
+#define CSR_HPMCOUNTER3H 0xc83
+#define CSR_HPMCOUNTER4H 0xc84
+#define CSR_HPMCOUNTER5H 0xc85
+#define CSR_HPMCOUNTER6H 0xc86
+#define CSR_HPMCOUNTER7H 0xc87
+#define CSR_HPMCOUNTER8H 0xc88
+#define CSR_HPMCOUNTER9H 0xc89
+#define CSR_HPMCOUNTER10H 0xc8a
+#define CSR_HPMCOUNTER11H 0xc8b
+#define CSR_HPMCOUNTER12H 0xc8c
+#define CSR_HPMCOUNTER13H 0xc8d
+#define CSR_HPMCOUNTER14H 0xc8e
+#define CSR_HPMCOUNTER15H 0xc8f
+#define CSR_HPMCOUNTER16H 0xc90
+#define CSR_HPMCOUNTER17H 0xc91
+#define CSR_HPMCOUNTER18H 0xc92
+#define CSR_HPMCOUNTER19H 0xc93
+#define CSR_HPMCOUNTER20H 0xc94
+#define CSR_HPMCOUNTER21H 0xc95
+#define CSR_HPMCOUNTER22H 0xc96
+#define CSR_HPMCOUNTER23H 0xc97
+#define CSR_HPMCOUNTER24H 0xc98
+#define CSR_HPMCOUNTER25H 0xc99
+#define CSR_HPMCOUNTER26H 0xc9a
+#define CSR_HPMCOUNTER27H 0xc9b
+#define CSR_HPMCOUNTER28H 0xc9c
+#define CSR_HPMCOUNTER29H 0xc9d
+#define CSR_HPMCOUNTER30H 0xc9e
+#define CSR_HPMCOUNTER31H 0xc9f
+#define CSR_MCYCLEH 0xb80
+#define CSR_MINSTRETH 0xb82
+#define CSR_MHPMCOUNTER3H 0xb83
+#define CSR_MHPMCOUNTER4H 0xb84
+#define CSR_MHPMCOUNTER5H 0xb85
+#define CSR_MHPMCOUNTER6H 0xb86
+#define CSR_MHPMCOUNTER7H 0xb87
+#define CSR_MHPMCOUNTER8H 0xb88
+#define CSR_MHPMCOUNTER9H 0xb89
+#define CSR_MHPMCOUNTER10H 0xb8a
+#define CSR_MHPMCOUNTER11H 0xb8b
+#define CSR_MHPMCOUNTER12H 0xb8c
+#define CSR_MHPMCOUNTER13H 0xb8d
+#define CSR_MHPMCOUNTER14H 0xb8e
+#define CSR_MHPMCOUNTER15H 0xb8f
+#define CSR_MHPMCOUNTER16H 0xb90
+#define CSR_MHPMCOUNTER17H 0xb91
+#define CSR_MHPMCOUNTER18H 0xb92
+#define CSR_MHPMCOUNTER19H 0xb93
+#define CSR_MHPMCOUNTER20H 0xb94
+#define CSR_MHPMCOUNTER21H 0xb95
+#define CSR_MHPMCOUNTER22H 0xb96
+#define CSR_MHPMCOUNTER23H 0xb97
+#define CSR_MHPMCOUNTER24H 0xb98
+#define CSR_MHPMCOUNTER25H 0xb99
+#define CSR_MHPMCOUNTER26H 0xb9a
+#define CSR_MHPMCOUNTER27H 0xb9b
+#define CSR_MHPMCOUNTER28H 0xb9c
+#define CSR_MHPMCOUNTER29H 0xb9d
+#define CSR_MHPMCOUNTER30H 0xb9e
+#define CSR_MHPMCOUNTER31H 0xb9f
+#define CAUSE_MISALIGNED_FETCH 0x0
+#define CAUSE_FETCH_ACCESS 0x1
+#define CAUSE_ILLEGAL_INSTRUCTION 0x2
+#define CAUSE_BREAKPOINT 0x3
+#define CAUSE_MISALIGNED_LOAD 0x4
+#define CAUSE_LOAD_ACCESS 0x5
+#define CAUSE_MISALIGNED_STORE 0x6
+#define CAUSE_STORE_ACCESS 0x7
+#define CAUSE_USER_ECALL 0x8
+#define CAUSE_SUPERVISOR_ECALL 0x9
+#define CAUSE_HYPERVISOR_ECALL 0xa
+#define CAUSE_MACHINE_ECALL 0xb
+#define CAUSE_FETCH_PAGE_FAULT 0xc
+#define CAUSE_LOAD_PAGE_FAULT 0xd
+#define CAUSE_STORE_PAGE_FAULT 0xf
+#endif
+#ifdef DECLARE_INSN
+DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
+DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
+DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
+DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
+DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
+DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
+DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
+DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
+DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
+DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
+DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
+DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
+DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
+DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
+DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
+DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
+DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
+DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
+DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
+DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
+DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
+DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
+DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
+DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
+DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
+DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
+DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
+DECLARE_INSN( or , MATCH_OR, MASK_OR)
+DECLARE_INSN( and , MATCH_AND, MASK_AND)
+DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
+DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
+DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
+DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
+DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
+DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
+DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
+DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
+DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
+DECLARE_INSN(lb, MATCH_LB, MASK_LB)
+DECLARE_INSN(lh, MATCH_LH, MASK_LH)
+DECLARE_INSN(lw, MATCH_LW, MASK_LW)
+DECLARE_INSN(ld, MATCH_LD, MASK_LD)
+DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
+DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
+DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
+DECLARE_INSN(sb, MATCH_SB, MASK_SB)
+DECLARE_INSN(sh, MATCH_SH, MASK_SH)
+DECLARE_INSN(sw, MATCH_SW, MASK_SW)
+DECLARE_INSN(sd, MATCH_SD, MASK_SD)
+DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
+DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
+DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
+DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
+DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
+DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
+DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
+DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
+DECLARE_INSN(rem, MATCH_REM, MASK_REM)
+DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
+DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
+DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
+DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
+DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
+DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
+DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
+DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
+DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
+DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
+DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
+DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
+DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
+DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
+DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
+DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
+DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
+DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
+DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
+DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
+DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
+DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
+DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
+DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
+DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
+DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
+DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
+DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
+DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
+DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
+DECLARE_INSN(uret, MATCH_URET, MASK_URET)
+DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
+DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
+DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
+DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
+DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
+DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
+DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
+DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
+DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
+DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
+DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
+DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
+DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
+DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
+DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
+DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
+DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
+DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
+DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
+DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
+DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
+DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
+DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
+DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
+DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
+DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
+DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
+DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
+DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
+DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
+DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
+DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
+DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
+DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
+DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
+DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
+DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
+DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
+DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
+DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
+DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
+DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
+DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
+DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
+DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
+DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
+DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
+DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
+DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
+DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
+DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
+DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
+DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
+DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
+DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
+DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
+DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
+DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
+DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
+DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
+DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
+DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
+DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
+DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
+DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
+DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
+DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
+DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
+DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
+DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
+DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
+DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
+DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
+DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
+DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
+DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
+DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
+DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
+DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
+DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
+DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
+DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
+DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
+DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
+DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
+DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
+DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
+DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
+DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
+DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
+DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
+DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
+DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
+DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
+DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
+DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
+DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
+DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
+DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
+DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
+DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
+DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
+DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
+DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
+DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
+DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
+DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
+DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
+DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
+DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
+DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
+DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
+DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
+DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
+DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
+DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
+DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
+DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
+DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
+DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
+DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
+DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
+DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
+DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
+DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
+DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
+DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
+DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
+DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
+DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
+DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
+DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
+DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
+DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
+DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
+DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
+DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
+DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
+DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
+DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
+DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
+DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
+DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
+DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
+DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
+DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
+DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
+DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
+DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
+DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
+DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
+DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
+DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
+DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
+DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
+DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
+DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
+DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
+DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
+DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
+DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
+DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
+DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
+DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
+DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
+DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
+DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
+DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
+DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
+DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
+DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
+DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
+DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
+#endif
+#ifdef DECLARE_CSR
+DECLARE_CSR(fflags, CSR_FFLAGS)
+DECLARE_CSR(frm, CSR_FRM)
+DECLARE_CSR(fcsr, CSR_FCSR)
+DECLARE_CSR(cycle, CSR_CYCLE)
+DECLARE_CSR(time, CSR_TIME)
+DECLARE_CSR(instret, CSR_INSTRET)
+DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
+DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
+DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
+DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
+DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
+DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
+DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
+DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
+DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
+DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
+DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
+DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
+DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
+DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
+DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
+DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
+DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
+DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
+DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
+DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
+DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
+DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
+DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
+DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
+DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
+DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
+DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
+DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
+DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
+DECLARE_CSR(sstatus, CSR_SSTATUS)
+DECLARE_CSR(sie, CSR_SIE)
+DECLARE_CSR(stvec, CSR_STVEC)
+DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
+DECLARE_CSR(sscratch, CSR_SSCRATCH)
+DECLARE_CSR(sepc, CSR_SEPC)
+DECLARE_CSR(scause, CSR_SCAUSE)
+DECLARE_CSR(sbadaddr, CSR_SBADADDR)
+DECLARE_CSR(sip, CSR_SIP)
+DECLARE_CSR(sptbr, CSR_SPTBR)
+DECLARE_CSR(mstatus, CSR_MSTATUS)
+DECLARE_CSR(misa, CSR_MISA)
+DECLARE_CSR(medeleg, CSR_MEDELEG)
+DECLARE_CSR(mideleg, CSR_MIDELEG)
+DECLARE_CSR(mie, CSR_MIE)
+DECLARE_CSR(mtvec, CSR_MTVEC)
+DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
+DECLARE_CSR(mscratch, CSR_MSCRATCH)
+DECLARE_CSR(mepc, CSR_MEPC)
+DECLARE_CSR(mcause, CSR_MCAUSE)
+DECLARE_CSR(mbadaddr, CSR_MBADADDR)
+DECLARE_CSR(mip, CSR_MIP)
+DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
+DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
+DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
+DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
+DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
+DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
+DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
+DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
+DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
+DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
+DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
+DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
+DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
+DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
+DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
+DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
+DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
+DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
+DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
+DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
+DECLARE_CSR(tselect, CSR_TSELECT)
+DECLARE_CSR(tdata1, CSR_TDATA1)
+DECLARE_CSR(tdata2, CSR_TDATA2)
+DECLARE_CSR(tdata3, CSR_TDATA3)
+DECLARE_CSR(dcsr, CSR_DCSR)
+DECLARE_CSR(dpc, CSR_DPC)
+DECLARE_CSR(dscratch, CSR_DSCRATCH)
+DECLARE_CSR(mcycle, CSR_MCYCLE)
+DECLARE_CSR(minstret, CSR_MINSTRET)
+DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
+DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
+DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
+DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
+DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
+DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
+DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
+DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
+DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
+DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
+DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
+DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
+DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
+DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
+DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
+DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
+DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
+DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
+DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
+DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
+DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
+DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
+DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
+DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
+DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
+DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
+DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
+DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
+DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
+DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
+DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
+DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
+DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
+DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
+DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
+DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
+DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
+DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
+DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
+DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
+DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
+DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
+DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
+DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
+DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
+DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
+DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
+DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
+DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
+DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
+DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
+DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
+DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
+DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
+DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
+DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
+DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
+DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
+DECLARE_CSR(mvendorid, CSR_MVENDORID)
+DECLARE_CSR(marchid, CSR_MARCHID)
+DECLARE_CSR(mimpid, CSR_MIMPID)
+DECLARE_CSR(mhartid, CSR_MHARTID)
+DECLARE_CSR(cycleh, CSR_CYCLEH)
+DECLARE_CSR(timeh, CSR_TIMEH)
+DECLARE_CSR(instreth, CSR_INSTRETH)
+DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
+DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
+DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
+DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
+DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
+DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
+DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
+DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
+DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
+DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
+DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
+DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
+DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
+DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
+DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
+DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
+DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
+DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
+DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
+DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
+DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
+DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
+DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
+DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
+DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
+DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
+DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
+DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
+DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
+DECLARE_CSR(mcycleh, CSR_MCYCLEH)
+DECLARE_CSR(minstreth, CSR_MINSTRETH)
+DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
+DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
+DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
+DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
+DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
+DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
+DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
+DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
+DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
+DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
+DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
+DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
+DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
+DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
+DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
+DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
+DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
+DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
+DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
+DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
+DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
+DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
+DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
+DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
+DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
+DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
+DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
+DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
+DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
+#endif
+#ifdef DECLARE_CAUSE
+DECLARE_CAUSE("misaligned fetch", CAUSE_MISALIGNED_FETCH)
+DECLARE_CAUSE("fetch access", CAUSE_FETCH_ACCESS)
+DECLARE_CAUSE("illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
+DECLARE_CAUSE("breakpoint", CAUSE_BREAKPOINT)
+DECLARE_CAUSE("misaligned load", CAUSE_MISALIGNED_LOAD)
+DECLARE_CAUSE("load access", CAUSE_LOAD_ACCESS)
+DECLARE_CAUSE("misaligned store", CAUSE_MISALIGNED_STORE)
+DECLARE_CAUSE("store access", CAUSE_STORE_ACCESS)
+DECLARE_CAUSE("user_ecall", CAUSE_USER_ECALL)
+DECLARE_CAUSE("supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
+DECLARE_CAUSE("hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
+DECLARE_CAUSE("machine_ecall", CAUSE_MACHINE_ECALL)
+DECLARE_CAUSE("fetch page fault", CAUSE_FETCH_PAGE_FAULT)
+DECLARE_CAUSE("load page fault", CAUSE_LOAD_PAGE_FAULT)
+DECLARE_CAUSE("store page fault", CAUSE_STORE_PAGE_FAULT)
+#endif
diff --git a/cpukit/score/cpu/riscv/rtems/score/riscv.h b/cpukit/score/cpu/riscv/rtems/score/riscv.h
new file mode 100644
index 0000000..6e7f137
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/riscv.h
@@ -0,0 +1,66 @@
+ * @file rtems/score/riscv.h
+ * This file contains information pertaining to the riscv32 processor.
+ * COPYRIGHT (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
+ * Based on code with the following copyright...
+ * COPYRIGHT (c) 1989-1999, 2010.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_RISCV_H
+#define _RTEMS_SCORE_RISCV_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * This file contains the information required to build
+ * RTEMS for a particular member of the RISCV family.
+ * It does this by setting variables to indicate which
+ * implementation dependent features are present in a particular
+ * member of the family.
+ * This is a good place to list all the known CPU models
+ * that this port supports and which RTEMS CPU model they correspond
+ * to.
+* Define the name of the CPU family and specific model.
+#define CPU_NAME "RISCV"
+#define CPU_MODEL_NAME "RISCV"
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_RISCV_H */
diff --git a/cpukit/score/cpu/riscv/rtems/score/types.h b/cpukit/score/cpu/riscv/rtems/score/types.h
index 0000000..d1440fb
--- /dev/null
+++ b/cpukit/score/cpu/riscv/rtems/score/types.h
@@ -0,0 +1,70 @@
+ * @file
+ * @brief RISC-V Architecture Types API
+ * This include file contains type definitions pertaining to the
+ * RISC-V processor family.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_TYPES_H
+#define _RTEMS_SCORE_TYPES_H
+#include <rtems/score/basedefs.h>
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup ScoreCPU
+ * This section defines the basic types for this processor.
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
+typedef uint16_t Priority_bit_map_Word;
+typedef void riscv_isr;
+typedef void ( *riscv_isr_entry )( void );
+#ifdef __cplusplus
+#endif
+#endif /* !ASM */
+#endif
diff --git a/cpukit/score/cpu/riscv32/Makefile.am b/cpukit/score/cpu/riscv32/Makefile.am
deleted file mode 100644
index 1de5b2d..0000000
--- a/cpukit/score/cpu/riscv32/Makefile.am
+++ /dev/null
@@ -1,26 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-include_rtemsdir = $(includedir)/rtems
-include_rtems_HEADERS = rtems/asm.h
-include_rtems_scoredir = $(includedir)/rtems/score
-include_rtems_score_HEADERS = rtems/score/cpu.h
-include_rtems_score_HEADERS += rtems/score/cpuatomic.h
-include_rtems_score_HEADERS += rtems/score/cpuimpl.h
-include_rtems_score_HEADERS += rtems/score/cpu_asm.h
-include_rtems_score_HEADERS += rtems/score/types.h
-include_rtems_score_HEADERS += rtems/score/riscv.h
-include_rtems_score_HEADERS += rtems/score/riscv-utility.h
-noinst_LIBRARIES = libscorecpu.a
-libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
-libscorecpu_a_SOURCES = cpu.c
-libscorecpu_a_SOURCES += riscv-exception-handler.S
-libscorecpu_a_SOURCES += riscv-exception-default.c
-libscorecpu_a_SOURCES += riscv-exception-frame-print.c
-libscorecpu_a_SOURCES += riscv-context-switch.S
-libscorecpu_a_SOURCES += riscv-context-initialize.c
-libscorecpu_a_SOURCES += riscv-context-validate.S
-libscorecpu_a_SOURCES += riscv-context-volatile-clobber.S
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/score/cpu/riscv32/cpu.c b/cpukit/score/cpu/riscv32/cpu.c
index 7061d10..0000000
--- a/cpukit/score/cpu/riscv32/cpu.c
+++ /dev/null
@@ -1,124 +0,0 @@
- * riscv32 CPU Dependent Source
- * Copyright (c) 2015 University of York.
- * Hesham ALmatary <hesham at alumni.york.ac.uk>
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/wkspace.h>
-#include <rtems/score/cpu.h>
-/* bsp_start_vector_table_begin is the start address of the vector table
- * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
- * and may differ from one BSP to another.
-extern char bsp_start_vector_table_begin[];
-void init(void);
-void fini(void);
-void _init()
-void _fini()
- * @brief Performs processor dependent initialization.
-void _CPU_Initialize(void)
- /* Do nothing */
-void _CPU_ISR_Set_level(uint32_t level)
- /* Do nothing */
-uint32_t _CPU_ISR_Get_level( void )
- /* Do nothing */
- return 0;
-void _CPU_ISR_install_raw_handler(
- uint32_t vector,
- proc_ptr new_handler,
- proc_ptr *old_handler
- /* Do nothing */
-void _CPU_ISR_install_vector(
- uint32_t vector,
- proc_ptr *table =
- (proc_ptr *) bsp_start_vector_table_begin;
- proc_ptr current_handler;
- ISR_Level level;
- _ISR_Local_disable( level );
- current_handler = table [vector];
- /* The current handler is now the old one */
- if (old_handler != NULL) {
- *old_handler = (proc_ptr) current_handler;
- /* Write only if necessary to avoid writes to a maybe read-only
- * memory */
- if (current_handler != new_handler) {
- table [vector] = new_handler;
- _ISR_Local_enable( level );
-void _CPU_Install_interrupt_stack( void )
- /* Do nothing */
-void *_CPU_Thread_Idle_body( uintptr_t ignored )
- do {
- } while (1);
- return NULL;
diff --git a/cpukit/score/cpu/riscv32/preinstall.am b/cpukit/score/cpu/riscv32/preinstall.am
index 14256ba..0000000
--- a/cpukit/score/cpu/riscv32/preinstall.am
+++ /dev/null
@@ -1,57 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
- $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES = $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-$(PROJECT_INCLUDE)/rtems/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
- @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
-$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
-$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
- @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
-$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
-$(PROJECT_INCLUDE)/rtems/score/cpuimpl.h: rtems/score/cpuimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuimpl.h
-$(PROJECT_INCLUDE)/rtems/score/cpu_asm.h: rtems/score/cpu_asm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
-$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
-$(PROJECT_INCLUDE)/rtems/score/riscv.h: rtems/score/riscv.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/riscv.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/riscv.h
-$(PROJECT_INCLUDE)/rtems/score/riscv-utility.h: rtems/score/riscv-utility.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/riscv-utility.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/riscv-utility.h
diff --git a/cpukit/score/cpu/riscv32/riscv-context-initialize.c b/cpukit/score/cpu/riscv32/riscv-context-initialize.c
index f4c3361..0000000
--- a/cpukit/score/cpu/riscv32/riscv-context-initialize.c
+++ /dev/null
@@ -1,67 +0,0 @@
- * Hesham Almatary <hesham at alumni.york.ac.uk>
- * COPYRIGHT (c) 1989-2006.
- * are met:
- * SUCH DAMAGE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <string.h>
-#include <rtems/score/riscv-utility.h>
-#include <rtems/score/interr.h>
-void _CPU_Context_Initialize(
- Context_Control *context,
- void *stack_area_begin,
- size_t stack_area_size,
- uint32_t new_level,
- void (*entry_point)( void ),
- bool is_fp,
- void *tls_area
- uintptr_t stack = ((uintptr_t) stack_area_begin);
- /* Account for red-zone */
- uintptr_t stack_high = stack + stack_area_size - RISCV_GCC_RED_ZONE_SIZE;
- memset(context, 0, sizeof(*context));
- /* Stack Pointer - sp/x2 */
- context->x[2] = stack_high;
- /* Frame Pointer - fp/x8 */
- context->x[8] = stack_high;
- /* Return Address - ra/x1 */
- context->x[1] = (uintptr_t) entry_point;
- /* Enable interrupts and FP */
- context->mstatus = MSTATUS_FS | MSTATUS_MIE;
diff --git a/cpukit/score/cpu/riscv32/riscv-context-switch.S b/cpukit/score/cpu/riscv32/riscv-context-switch.S
index acb7fba..0000000
--- a/cpukit/score/cpu/riscv32/riscv-context-switch.S
+++ /dev/null
@@ -1,139 +0,0 @@
- * are met:
- * SUCH DAMAGE.
-#endif
-#include <rtems/asm.h>
-.section .text, "ax"
-.align 4
-# define LREG lw
-# define SREG sw
-PUBLIC(_CPU_Context_switch)
-PUBLIC(_CPU_Context_restore)
-PUBLIC(_CPU_Context_restore_fp)
-PUBLIC(_CPU_Context_save_fp)
-PUBLIC(restore)
-SYM(_CPU_Context_switch):
- /* Disable interrupts and store all registers */
- csrr t0, mstatus
- SREG t0, (32 * CPU_SIZEOF_POINTER)(a0)
- csrci mstatus, MSTATUS_MIE
- SREG x1, (1 * CPU_SIZEOF_POINTER)(a0)
- SREG x2, (2 * CPU_SIZEOF_POINTER)(a0)
- SREG x3, (3 * CPU_SIZEOF_POINTER)(a0)
- SREG x4, (4 * CPU_SIZEOF_POINTER)(a0)
- SREG x5, (5 * CPU_SIZEOF_POINTER)(a0)
- SREG x6, (6 * CPU_SIZEOF_POINTER)(a0)
- SREG x7, (7 * CPU_SIZEOF_POINTER)(a0)
- SREG x8, (8 * CPU_SIZEOF_POINTER)(a0)
- SREG x9, (9 * CPU_SIZEOF_POINTER)(a0)
- SREG x10, (10 * CPU_SIZEOF_POINTER)(a0)
- SREG x11, (11 * CPU_SIZEOF_POINTER)(a0)
- SREG x12, (12 * CPU_SIZEOF_POINTER)(a0)
- SREG x13, (13 * CPU_SIZEOF_POINTER)(a0)
- SREG x14, (14 * CPU_SIZEOF_POINTER)(a0)
- SREG x15, (15 * CPU_SIZEOF_POINTER)(a0)
- SREG x16, (16 * CPU_SIZEOF_POINTER)(a0)
- SREG x17, (17 * CPU_SIZEOF_POINTER)(a0)
- SREG x18, (18 * CPU_SIZEOF_POINTER)(a0)
- SREG x19, (19 * CPU_SIZEOF_POINTER)(a0)
- SREG x20, (20 * CPU_SIZEOF_POINTER)(a0)
- SREG x21, (21 * CPU_SIZEOF_POINTER)(a0)
- SREG x22, (22 * CPU_SIZEOF_POINTER)(a0)
- SREG x23, (23 * CPU_SIZEOF_POINTER)(a0)
- SREG x24, (24 * CPU_SIZEOF_POINTER)(a0)
- SREG x25, (25 * CPU_SIZEOF_POINTER)(a0)
- SREG x26, (26 * CPU_SIZEOF_POINTER)(a0)
- SREG x27, (27 * CPU_SIZEOF_POINTER)(a0)
- SREG x28, (28 * CPU_SIZEOF_POINTER)(a0)
- SREG x29, (28 * CPU_SIZEOF_POINTER)(a0)
- SREG x30, (30 * CPU_SIZEOF_POINTER)(a0)
- SREG x31, (31 * CPU_SIZEOF_POINTER)(a0)
- SYM(restore):
- LREG x1, (1 * CPU_SIZEOF_POINTER)(a1)
- LREG x2, (2 * CPU_SIZEOF_POINTER)(a1)
- LREG x3, (3 * CPU_SIZEOF_POINTER)(a1)
- LREG x4, (4 * CPU_SIZEOF_POINTER)(a1)
- LREG x5, (5 * CPU_SIZEOF_POINTER)(a1)
- LREG x6, (6 * CPU_SIZEOF_POINTER)(a1)
- LREG x7, (7 * CPU_SIZEOF_POINTER)(a1)
- LREG x8, (8 * CPU_SIZEOF_POINTER)(a1)
- LREG x9, (9 * CPU_SIZEOF_POINTER)(a1)
- LREG x10, (10 * CPU_SIZEOF_POINTER)(a1)
- /* Skip a1/x11 */
- LREG x12, (12 * CPU_SIZEOF_POINTER)(a1)
- LREG x13, (13 * CPU_SIZEOF_POINTER)(a1)
- LREG x14, (14 * CPU_SIZEOF_POINTER)(a1)
- LREG x15, (15 * CPU_SIZEOF_POINTER)(a1)
- LREG x16, (16 * CPU_SIZEOF_POINTER)(a1)
- LREG x17, (17 * CPU_SIZEOF_POINTER)(a1)
- LREG x18, (18 * CPU_SIZEOF_POINTER)(a1)
- LREG x19, (19 * CPU_SIZEOF_POINTER)(a1)
- LREG x20, (20 * CPU_SIZEOF_POINTER)(a1)
- LREG x21, (21 * CPU_SIZEOF_POINTER)(a1)
- LREG x22, (22 * CPU_SIZEOF_POINTER)(a1)
- LREG x23, (23 * CPU_SIZEOF_POINTER)(a1)
- LREG x24, (24 * CPU_SIZEOF_POINTER)(a1)
- LREG x25, (25 * CPU_SIZEOF_POINTER)(a1)
- LREG x26, (26 * CPU_SIZEOF_POINTER)(a1)
- LREG x27, (27 * CPU_SIZEOF_POINTER)(a1)
- LREG x28, (28 * CPU_SIZEOF_POINTER)(a1)
- LREG x29, (29 * CPU_SIZEOF_POINTER)(a1)
- LREG x30, (30 * CPU_SIZEOF_POINTER)(a1)
- /* Load mstatus */
- LREG x31, (32 * CPU_SIZEOF_POINTER)(a1)
- csrw mstatus, x31
- LREG x11, (11 * CPU_SIZEOF_POINTER)(a1)
- ret
- SYM(_CPU_Context_restore):
- mv a1, a0
- j restore
- /* TODO no FP support for riscv32 yet */
- SYM(_CPU_Context_restore_fp):
- nop
- SYM(_CPU_Context_save_fp):
- nop
diff --git a/cpukit/score/cpu/riscv32/riscv-context-validate.S b/cpukit/score/cpu/riscv32/riscv-context-validate.S
index 8e9a5d3..0000000
--- a/cpukit/score/cpu/riscv32/riscv-context-validate.S
+++ /dev/null
@@ -1,201 +0,0 @@
- * Copyrigh (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
- * are met:
- * SUCH DAMAGE.
-#endif
-.section .text
-#define SREG sw
-#define LREG lw
-PUBLIC(_CPU_Context_validate)
-SYM(_CPU_Context_validate):
- addi sp, sp, -144
- SREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
- /* Skip x2/sp */
- SREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
- SREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
- SREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
- SREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
- SREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
- SREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
- SREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
- SREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
- SREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
- SREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
- SREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
- SREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
- SREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
- SREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
- SREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
- SREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
- SREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
- SREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
- SREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
- SREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
- SREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
- SREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
- SREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
- SREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
- SREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
- SREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
- SREG x29, (28 * CPU_SIZEOF_POINTER)(sp)
- SREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
- SREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
- /* Fill */
- /* t0 is used for temporary values */
- mv t0, x0
- /* x31 contains the stack pointer */
- mv x31, sp
- .macro fill_register reg
- addi t0, t0, 1
- mv \reg, t0
- .endm
- fill_register x1
- fill_register x2
- fill_register x3
- fill_register x4
- fill_register x5
- fill_register x6
- fill_register x7
- fill_register x8
- fill_register x9
- fill_register x10
- fill_register x11
- fill_register x12
- fill_register x13
- fill_register x14
- fill_register x15
- fill_register x16
- fill_register x17
- fill_register x18
- fill_register x19
- fill_register x20
- fill_register x21
- fill_register x22
- fill_register x23
- fill_register x24
- fill_register x25
- fill_register x26
- fill_register x27
- fill_register x28
- fill_register x29
- fill_register x30
- fill_register x31
- /* Check */
-check:
- .macro check_register reg
- addi t0, t0, 1
- bne \reg, t0, restore
- .endm
- bne x31, sp, restore
- mv t0, x0
- check_register x1
- check_register x2
- check_register x3
- check_register x4
- check_register x5
- check_register x6
- check_register x7
- check_register x8
- check_register x9
- check_register x10
- check_register x11
- check_register x12
- check_register x13
- check_register x14
- check_register x15
- check_register x16
- check_register x17
- check_register x18
- check_register x19
- check_register x20
- check_register x21
- check_register x22
- check_register x23
- check_register x24
- check_register x25
- check_register x26
- check_register x27
- check_register x28
- check_register x29
- check_register x30
- check_register x31
- j check
- /* Restore */
-restore:
- LREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
- /* Skip sp/x2 */
- LREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
- LREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
- LREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
- LREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
- LREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
- LREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
- LREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
- LREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
- LREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
- LREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
- LREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
- LREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
- LREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
- LREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
- LREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
- LREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
- LREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
- LREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
- LREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
- LREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
- LREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
- LREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
- LREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
- LREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
- LREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
- LREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
- LREG x29, (29 * CPU_SIZEOF_POINTER)(sp)
- LREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
- LREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
- addi sp, sp, 144
- ret
diff --git a/cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S b/cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S
index 58ec25b..0000000
--- a/cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S
+++ /dev/null
@@ -1,50 +0,0 @@
- * Copyright (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
- * are met:
- * SUCH DAMAGE.
-#endif
-.section .text
-PUBLIC(_CPU_Context_volatile_clobber)
-SYM(_CPU_Context_volatile_clobber):
- .macro clobber_register reg
- addi t0, t0, -1
- mv \reg, t0
- .endm
- clobber_register a0
- clobber_register a1
- clobber_register a2
- clobber_register a3
- clobber_register a4
- clobber_register a5
- clobber_register a6
- ret
diff --git a/cpukit/score/cpu/riscv32/riscv-exception-default.c b/cpukit/score/cpu/riscv32/riscv-exception-default.c
index 62d0dd3..0000000
--- a/cpukit/score/cpu/riscv32/riscv-exception-default.c
+++ /dev/null
@@ -1,39 +0,0 @@
- * Copyright (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
- * are met:
- * SUCH DAMAGE.
-#endif
-#include <rtems/fatal.h>
-#include <stdio.h>
-void _RISCV_Exception_default(uint32_t vector, CPU_Exception_frame *frame);
- rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
diff --git a/cpukit/score/cpu/riscv32/riscv-exception-frame-print.c b/cpukit/score/cpu/riscv32/riscv-exception-frame-print.c
index 377616c..0000000
--- a/cpukit/score/cpu/riscv32/riscv-exception-frame-print.c
+++ /dev/null
@@ -1,41 +0,0 @@
- * are met:
- * SUCH DAMAGE.
-#endif
-#include <rtems/bspIo.h>
-#include <inttypes.h>
-void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
- int i;
- for ( i = 0; i < 32; ++i ) {
- printk( "x%02i = 0x%016" PRIx32 "\n", i, frame->x[i]);
diff --git a/cpukit/score/cpu/riscv32/riscv-exception-handler.S b/cpukit/score/cpu/riscv32/riscv-exception-handler.S
index 69bab1f..0000000
--- a/cpukit/score/cpu/riscv32/riscv-exception-handler.S
+++ /dev/null
@@ -1,220 +0,0 @@
- * @file
- * @ingroup ScoreCPU
- * @brief riscv32 exception support implementation.
- * are met:
- * SUCH DAMAGE.
-#endif
-#include <rtems/score/percpu.h>
-# define LREG lw
-# define SREG sw
-EXTERN(bsp_start_vector_table_begin)
-EXTERN(_Thread_Dispatch)
-PUBLIC(ISR_Handler)
-.align 4
-TYPE_FUNC(ISR_Handler)
-SYM(ISR_Handler):
- addi sp, sp, -144
- /* Skip x2/sp */
- /* Exception level related registers */
- csrr a0, mstatus
- SREG a0, (32 * CPU_SIZEOF_POINTER)(sp)
- csrr a0, mcause
- SREG a0, (33 * CPU_SIZEOF_POINTER)(sp)
- csrr a1, mepc
- SREG a1, (34 * CPU_SIZEOF_POINTER)(sp)
- /* FIXME Only handle interrupts for now (MSB = 1) */
- andi a0, a0, 0xf
- /* Increment nesting level */
- la t0, ISR_NEST_LEVEL
- /* Disable multitasking */
- la t1, THREAD_DISPATCH_DISABLE_LEVEL
- LREG t2, (t0)
- LREG t3, (t1)
- addi t2, t2, 1
- addi t3, t3, 1
- SREG t2, (t0)
- SREG t3, (t1)
- /* Save interrupted task stack pointer */
- addi t4, sp, 144
- SREG t4, (2 * CPU_SIZEOF_POINTER)(sp)
- /* Keep sp (Exception frame address) in s1 */
- mv s1, sp
- /* Call the exception handler from vector table */
- /* First function arg for C handler is vector number,
- * and the second is a pointer to exception frame.
- * a0/mcause/vector number is already loaded above */
- mv a1, sp
- /* calculate the offset */
- la t5, bsp_start_vector_table_begin
- slli t6, a0, 2
- add t5, t5, t6
- LREG t5, (t5)
- /* Do not switch stacks if we are in a nested interrupt. At
- * this point t2 should be holding ISR_NEST_LEVEL value.
- li s0, 1
- bgtu t2, s0, jump_to_c_handler
- /* Switch to RTEMS dedicated interrupt stack */
- la sp, INTERRUPT_STACK_HIGH
- LREG sp, (sp)
-jump_to_c_handler:
- jalr t5
- /* Switch back to the interrupted task stack */
- mv sp, s1
- /* Decrement nesting level */
- /* Enable multitasking */
- LREG t2, (t0)
- LREG t3, (t1)
- addi t2, t2, -1
- addi t3, t3, -1
- SREG t2, (t0)
- SREG t3, (t1)
- /* Check if _ISR_Nest_level > 0 */
- bgtz t2, exception_frame_restore
- /* Check if _Thread_Dispatch_disable_level > 0 */
- bgtz t3, exception_frame_restore
- /* Check if dispatch needed */
- la x31, DISPATCH_NEEDED
- LREG x31, (x31)
- beqz x31, exception_frame_restore
- la x31, _Thread_Dispatch
- jalr x31
- SYM(exception_frame_restore):
- /* Skip sp/x2 */
- LREG x31, (32 * CPU_SIZEOF_POINTER)(sp)
- csrw mstatus, x31
- /* Load mepc */
- LREG x31, (34 * CPU_SIZEOF_POINTER)(sp)
- csrw mepc, x31
- /* Unwind exception frame */
- addi sp, sp, 144
- mret
diff --git a/cpukit/score/cpu/riscv32/rtems/asm.h b/cpukit/score/cpu/riscv32/rtems/asm.h
index 34b6474..0000000
--- a/cpukit/score/cpu/riscv32/rtems/asm.h
+++ /dev/null
@@ -1,120 +0,0 @@
- * @file rtems/asm.h
- * This include file attempts to address the problems
- * caused by incompatible flavors of assemblers and
- * toolsets. It primarily addresses variations in the
- * use of leading underscores on symbols and the requirement
- * that register names be preceded by a %.
- * NOTE: The spacing in the use of these macros
- * is critical to them working as advertised.
- * This file is based on similar code found in newlib available
- * from ftp.cygnus.com. The file which was used had no copyright
- * notice. This file is freely distributable as long as the source
- * of the file is noted. This file is:
- * COPYRIGHT (c) 1994-1997.
- * are met:
- * SUCH DAMAGE.
-#ifndef __RISCV_ASM_H
-#define __RISCV_ASM_H
- * Indicate we are in an assembly file and get the basic CPU definitions.
-#ifndef ASM
-#define ASM
-#endif
-#include <rtems/score/cpuopts.h>
-#include <rtems/score/riscv.h>
- * Recent versions of GNU cpp define variables which indicate the
- * need for underscores and percents. If not using GNU cpp or
- * the version does not support this, then you will obviously
- * have to define these as appropriate.
-#ifndef __USER_LABEL_PREFIX__
-#define __USER_LABEL_PREFIX__ _
-#endif
-#ifndef __REGISTER_PREFIX__
-#define __REGISTER_PREFIX__
-#endif
-/* ANSI concatenation macros. */
-#define CONCAT1(a, b) CONCAT2(a, b)
-#define CONCAT2(a, b) a ## b
-/* Use the right prefix for global labels. */
-#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
-/* Use the right prefix for registers. */
-#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
- * define macros for all of the registers on this CPU
- * EXAMPLE: #define d0 REG (d0)
- * Define macros to handle section beginning and ends.
-#define BEGIN_CODE_DCL .text
-#define END_CODE_DCL
-#define BEGIN_DATA_DCL .data
-#define END_DATA_DCL
-#define BEGIN_CODE .text
-#define END_CODE
-#define BEGIN_DATA
-#define END_DATA
-#define BEGIN_BSS
-#define END_BSS
-#define END
- * Following must be tailor for a particular flavor of the C compiler.
- * They may need to put underscores in front of the symbols.
-#define PUBLIC(sym) .global SYM (sym)
-#define EXTERN(sym) .extern SYM (sym)
-#define TYPE_FUNC(sym) .type SYM (sym), %function
-#endif
diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu.h b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
index f77db55..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/cpu.h
+++ /dev/null
@@ -1,585 +0,0 @@
- * @file rtems/score/cpu.h
- * are met:
- * SUCH DAMAGE.
-#ifndef _RISCV_CPU_H
-#define _RISCV_CPU_H
-#ifdef __cplusplus
-extern "C" {
-#endif
-#include <rtems/score/riscv.h> /* pick up machine definitions */
-#include <rtems/score/types.h>
-#ifndef ASM
-#include <stdint.h>
-#include <stdio.h> /* for printk */
-#endif
-#define CPU_INLINE_ENABLE_DISPATCH FALSE
-#define CPU_UNROLL_ENQUEUE_PRIORITY TRUE
-#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
-#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
-#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
-#define CPU_ISR_PASSES_FRAME_POINTER 1
-#define CPU_HARDWARE_FP FALSE
-#define CPU_SOFTWARE_FP FALSE
-#define CPU_ALL_TASKS_ARE_FP FALSE
-#define CPU_IDLE_TASK_IS_FP FALSE
-#define CPU_USE_DEFERRED_FP_SWITCH FALSE
-#define CPU_PROVIDES_IDLE_THREAD_BODY TRUE
-#define CPU_STACK_GROWS_UP FALSE
-#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
-#define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES FALSE
-#define CPU_BIG_ENDIAN FALSE
-#define CPU_LITTLE_ENDIAN TRUE
-#define CPU_MODES_INTERRUPT_MASK 0x00000001
- * Processor defined structures required for cpukit/score.
-#ifndef ASM
-typedef struct {
- /* riscv32 has 32 32-bit general purpose registers (x0-x31). */
- uint32_t x[32];
- /* Special purpose registers */
- uint32_t mstatus;
- uint32_t mcause;
- uint32_t mepc;
-#ifdef RTEMS_SMP
- * @brief On SMP configurations the thread context must contain a boolean
- * indicator to signal if this context is executing on a processor.
- * This field must be updated during a context switch. The context switch
- * to the heir must wait until the heir context indicates that it is no
- * longer executing on a processor. The context switch must also check if
- * a thread dispatch is necessary to honor updates of the heir thread for
- * this processor. This indicator must be updated using an atomic test and
- * set operation to ensure that at most one processor uses the heir
- * context at the same time.
- * @code
- * void _CPU_Context_switch(
- * Context_Control *executing,
- * Context_Control *heir
- * save( executing );
- * executing->is_executing = false;
- * memory_barrier();
- * if ( test_and_set( &heir->is_executing ) ) {
- * do {
- * Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
- * if ( cpu_self->dispatch_necessary ) {
- * heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
- * } while ( test_and_set( &heir->is_executing ) );
- * restore( heir );
- * @endcode
- volatile bool is_executing;
-#endif
-} Context_Control;
-#define _CPU_Context_Get_SP( _context ) \
- (_context)->x[2]
-typedef struct {
- /** TODO FPU registers are listed here */
- double some_float_register;
-} Context_Control_fp;
-typedef Context_Control CPU_Interrupt_frame;
-#define CPU_CONTEXT_FP_SIZE 0
-Context_Control_fp _CPU_Null_fp_context;
-#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
-#define CPU_STACK_MINIMUM_SIZE 4096
-#define CPU_ALIGNMENT 8
-#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
-#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
-#define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT
-#define CPU_STACK_ALIGNMENT 8
-#define _CPU_Initialize_vectors()
- * Disable all interrupts for an RTEMS critical section. The previous
- * level is returned in _level.
-static inline uint32_t riscv_interrupt_disable( void )
- register uint32_t status = read_csr(mstatus);
- clear_csr(mstatus, MSTATUS_MIE);
- return status;
-static inline void riscv_interrupt_enable(uint32_t level)
- write_csr(mstatus, level);
-#define _CPU_ISR_Disable( _level ) \
- _level = riscv_interrupt_disable()
-#define _CPU_ISR_Enable( _level ) \
- riscv_interrupt_enable( _level )
-#define _CPU_ISR_Flash( _level ) \
- do{ \
- _CPU_ISR_Enable( _level ); \
- riscv_interrupt_disable(); \
- } while(0)
-RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
- return ( level & MSTATUS_MIE ) != 0;
-void _CPU_ISR_Set_level( uint32_t level );
-uint32_t _CPU_ISR_Get_level( void );
-/* end of ISR handler macros */
-/* Context handler macros */
-#define RISCV_GCC_RED_ZONE_SIZE 128
- bool is_fp,
- void *tls_area
-#define _CPU_Context_Restart_self( _the_context ) \
- _CPU_Context_restore( (_the_context) )
-#define _CPU_Context_Fp_start( _base, _offset ) \
- ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
-#define _CPU_Context_Initialize_fp( _destination ) \
- *(*(_destination)) = _CPU_Null_fp_context; \
-extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
-RTEMS_NO_RETURN;
-/* end of Fatal Error manager macros */
-#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
-#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
-#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
-#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
- (_output) = 0; /* do something to prevent warnings */ \
-#endif
-/* end of Bitfield handler macros */
- * This routine builds the mask which corresponds to the bit fields
- * as searched by _CPU_Bitfield_Find_first_bit(). See the discussion
- * for that routine.
-#define _CPU_Priority_Mask( _bit_number ) \
- (1 << _bit_number)
-#endif
-#define _CPU_Priority_bits_index( _priority ) \
- (_priority)
-#endif
-#define CPU_MAXIMUM_PROCESSORS 32
-#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
-#define CPU_TIMESTAMP_USE_INT64 TRUE
-#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
-typedef struct {
- /* There is no CPU specific per-CPU state */
-} CPU_Per_CPU_control;
-#endif /* ASM */
-#define CPU_SIZEOF_POINTER 4
-#define CPU_EXCEPTION_FRAME_SIZE 128
-#define CPU_PER_CPU_CONTROL_SIZE 0
-#ifndef ASM
-typedef uint16_t Priority_bit_map_Word;
-typedef struct {
- uint32_t x[32];;
-} CPU_Exception_frame;
- * @brief Prints the exception frame via printk().
- * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
-void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
-/* end of Priority handler macros */
-/* functions */
- * _CPU_Initialize
- * This routine performs CPU dependent initialization.
- void
- * _CPU_ISR_install_raw_handler
- * This routine installs a "raw" interrupt handler directly into the
- * processor's vector table.
- uint32_t vector,
- * _CPU_ISR_install_vector
- * This routine installs an interrupt vector.
- * NO_CPU Specific Information:
- * XXX document implementation including references if appropriate
- uint32_t vector,
- * _CPU_Install_interrupt_stack
- * This routine installs the hardware interrupt stack pointer.
- * NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
- * is TRUE.
-void _CPU_Install_interrupt_stack( void );
- * _CPU_Thread_Idle_body
- * This routine is the CPU dependent IDLE thread body.
- * NOTE: It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
- * is TRUE.
-void *_CPU_Thread_Idle_body( uintptr_t ignored );
- * _CPU_Context_switch
- * This routine switches from the run context to the heir context.
- * RISCV Specific Information:
- * Please see the comments in the .c file for a description of how
- * this function works. There are several things to be aware of.
-void _CPU_Context_switch(
- Context_Control *run,
- Context_Control *heir
- * _CPU_Context_restore
- * This routine is generally used only to restart self in an
- * efficient manner. It may simply be a label in _CPU_Context_switch.
- * NOTE: May be unnecessary to reload some registers.
-void _CPU_Context_restore(
- Context_Control *new_context
-) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
- * _CPU_Context_save_fp
- * This routine saves the floating point context passed to it.
-void _CPU_Context_save_fp(
- void **fp_context_ptr
- * _CPU_Context_restore_fp
- * This routine restores the floating point context passed to it.
-void _CPU_Context_restore_fp(
-/* The following routine swaps the endian format of an unsigned int.
- * It must be static because it is referenced indirectly.
- * This version will work on any processor, but if there is a better
- * way for your CPU PLEASE use it. The most common way to do this is to:
- * swap least significant two bytes with 16-bit rotate
- * swap upper and lower 16-bits
- * swap most significant two bytes with 16-bit rotate
- * Some CPUs have special instructions which swap a 32-bit quantity in
- * a single instruction (e.g. i486). It is probably best to avoid
- * an "endian swapping control bit" in the CPU. One good reason is
- * that interrupts would probably have to be disabled to insure that
- * an interrupt does not try to access the same "chunk" with the wrong
- * endian. Another good reason is that on some CPUs, the endian bit
- * endianness for ALL fetches -- both code and data -- so the code
- * will be fetched incorrectly.
-static inline unsigned int CPU_swap_u32(
- unsigned int value
- uint32_t byte1, byte2, byte3, byte4, swapped;
- byte4 = (value >> 24) & 0xff;
- byte3 = (value >> 16) & 0xff;
- byte2 = (value >> 8) & 0xff;
- byte1 = value & 0xff;
- swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
- return ( swapped );
-#define CPU_swap_u16( value ) \
- (((value&0xff) << 8) | ((value >> 8)&0xff))
-static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
- /* TODO */
-static inline void _CPU_Context_validate( uintptr_t pattern )
- while (1) {
- /* TODO */
-typedef uint32_t CPU_Counter_ticks;
-CPU_Counter_ticks _CPU_Counter_read( void );
-#ifdef RTEMS_SMP
- * @brief Performs CPU specific SMP initialization in the context of the boot
- * processor.
- * This function is invoked on the boot processor during system
- * initialization. All interrupt stacks are allocated at this point in case
- * the CPU port allocates the interrupt stacks. This function is called
- * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
- * used.
- * @return The count of physically or virtually available processors.
- * Depending on the configuration the application may use not all processors.
-uint32_t _CPU_SMP_Initialize( void );
- * @brief Starts a processor specified by its index.
- * initialization.
- * This function will be called after _CPU_SMP_Initialize().
- * @param[in] cpu_index The processor index.
- * @retval true Successful operation.
- * @retval false Unable to start this processor.
-bool _CPU_SMP_Start_processor( uint32_t cpu_index );
- * @brief Performs final steps of CPU specific SMP initialization in the
- * context of the boot processor.
- * initialization.
- * This function will be called after all processors requested by the
- * application have been started.
- * @param[in] cpu_count The minimum value of the count of processors
- * requested by the application configuration and the count of physically or
- * virtually available processors.
-void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
- * @brief Returns the index of the current processor.
- * An architecture specific method must be used to obtain the index of the
- * current processor in the system. The set of processor indices is the
- * range of integers starting with zero up to the processor count minus one.
-uint32_t _CPU_SMP_Get_current_processor( void );
- * @brief Sends an inter-processor interrupt to the specified target
- * processor.
- * This operation is undefined for target processor indices out of range.
- * @param[in] target_processor_index The target processor index.
-void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
- * @brief Broadcasts a processor event.
- * Some architectures provide a low-level synchronization primitive for
- * processors in a multi-processor environment. Processors waiting for this
- * event may go into a low-power state and stop generating system bus
- * transactions. This function must ensure that preceding store operations
- * can be observed by other processors.
- * @see _CPU_SMP_Processor_event_receive().
-void _CPU_SMP_Processor_event_broadcast( void );
- * @brief Receives a processor event.
- * This function will wait for the processor event and may wait forever if no
- * such event arrives.
- * @see _CPU_SMP_Processor_event_broadcast().
-static inline void _CPU_SMP_Processor_event_receive( void )
- __asm__ volatile ( "" : : : "memory" );
- * @brief Gets the is executing indicator of the thread context.
- * @param[in] context The context.
-static inline bool _CPU_Context_Get_is_executing(
- const Context_Control *context
- return context->is_executing;
- * @brief Sets the is executing indicator of the thread context.
- * @param[in] is_executing The new value for the is executing indicator.
-static inline void _CPU_Context_Set_is_executing(
- bool is_executing
- context->is_executing = is_executing;
-#endif /* RTEMS_SMP */
-#endif /* ASM */
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h b/cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h
index b5a56f3..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h
+++ /dev/null
@@ -1,90 +0,0 @@
- * @file
- * @brief riscv32 Assembly File
- * Very loose template for an include file for the cpu_asm.? file
- * if it is implemented as a ".S" file (preprocessed by cpp) instead
- * of a ".s" file (preprocessed by gm4 or gasp).
- * are met:
- * SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_CPU_ASM_H
-#define _RTEMS_SCORE_CPU_ASM_H
-/* pull in the generated offsets */
-#include <rtems/score/offsets.h>
- * Hardware General Registers
-/* put something here */
- * Hardware Floating Point Registers
- * Hardware Control Registers
- * Calling Convention
- * Temporary registers
- * Floating Point Registers - SW Conventions
- * Temporary floating point registers
-#endif
-/* end of file */
diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h b/cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h
index 8ee9606..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h
+++ /dev/null
@@ -1,31 +0,0 @@
- * COPYRIGHT (c) 2012-2013 Deng Hengyi.
- * are met:
- * SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
-#define _RTEMS_SCORE_ATOMIC_CPU_H
-#include <rtems/score/cpustdatomic.h>
-#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h
index 3904c84..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h
+++ /dev/null
@@ -1,51 +0,0 @@
- * @file
- * @brief CPU Port Implementation API
- * Copyright (c) 2013 embedded brains GmbH
- * are met:
- * SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_CPUIMPL_H
-#define _RTEMS_SCORE_CPUIMPL_H
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef __cplusplus
-#endif
-#endif /* ASM */
-#endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h b/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
index dc4836b..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
+++ /dev/null
@@ -1,1526 +0,0 @@
-/* Copyright (c) 2013, The Regents of the University of California (Regents).
- * All Rights Reserved.
- * modification, are permitted provided that the following conditions are met:
- * 3. Neither the name of the Regents nor the
- * names of its contributors may be used to endorse or promote products
- * derived from this software without specific prior written
- * permission.
- * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT,
- * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING LOST
- * PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
- * REGENTS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO,THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
- * PURPOSE. THE SOFTWARE AND ACCOMPANYING DOCUMENTATION, IF ANY, PROVIDED
- * HEREUNDER IS PROVIDED "AS IS". REGENTS HAS NO OBLIGATION TO PROVIDE
- * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
- * @file
- * @brief RISCV utility
- * COPYRIGHT (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-/* This file is copied from riscv-tools/encoding.h with additions/modifications to work
- * with RTEMS.
-#ifndef _RTEMS_SCORE_RISCV_UTILITY_H
-#define _RTEMS_SCORE_RISCV_UTILITY_H
-#define MSTATUS_UIE 0x00000001
-#define MSTATUS_SIE 0x00000002
-#define MSTATUS_HIE 0x00000004
-#define MSTATUS_MIE 0x00000008
-#define MSTATUS_UPIE 0x00000010
-#define MSTATUS_SPIE 0x00000020
-#define MSTATUS_HPIE 0x00000040
-#define MSTATUS_MPIE 0x00000080
-#define MSTATUS_SPP 0x00000100
-#define MSTATUS_HPP 0x00000600
-#define MSTATUS_MPP 0x00001800
-#define MSTATUS_FS 0x00006000
-#define MSTATUS_XS 0x00018000
-#define MSTATUS_MPRV 0x00020000
-#define MSTATUS_SUM 0x00040000
-#define MSTATUS_MXR 0x00080000
-#define MSTATUS_TVM 0x00100000
-#define MSTATUS_TW 0x00200000
-#define MSTATUS_TSR 0x00400000
-#define MSTATUS32_SD 0x80000000
-#define MSTATUS64_SD 0x8000000000000000
-#define SSTATUS_UIE 0x00000001
-#define SSTATUS_SIE 0x00000002
-#define SSTATUS_UPIE 0x00000010
-#define SSTATUS_SPIE 0x00000020
-#define SSTATUS_SPP 0x00000100
-#define SSTATUS_FS 0x00006000
-#define SSTATUS_XS 0x00018000
-#define SSTATUS_SUM 0x00040000
-#define SSTATUS_MXR 0x00080000
-#define SSTATUS32_SD 0x80000000
-#define SSTATUS64_SD 0x8000000000000000
-#define DCSR_XDEBUGVER (3U<<30)
-#define DCSR_NDRESET (1<<29)
-#define DCSR_FULLRESET (1<<28)
-#define DCSR_EBREAKM (1<<15)
-#define DCSR_EBREAKH (1<<14)
-#define DCSR_EBREAKS (1<<13)
-#define DCSR_EBREAKU (1<<12)
-#define DCSR_STOPCYCLE (1<<10)
-#define DCSR_STOPTIME (1<<9)
-#define DCSR_CAUSE (7<<6)
-#define DCSR_DEBUGINT (1<<5)
-#define DCSR_HALT (1<<3)
-#define DCSR_STEP (1<<2)
-#define DCSR_PRV (3<<0)
-#define DCSR_CAUSE_NONE 0
-#define DCSR_CAUSE_SWBP 1
-#define DCSR_CAUSE_HWBP 2
-#define DCSR_CAUSE_DEBUGINT 3
-#define DCSR_CAUSE_STEP 4
-#define DCSR_CAUSE_HALT 5
-#define MCONTROL_TYPE(xlen) (0xfULL<<((xlen)-4))
-#define MCONTROL_DMODE(xlen) (1ULL<<((xlen)-5))
-#define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))
-#define MCONTROL_SELECT (1<<19)
-#define MCONTROL_TIMING (1<<18)
-#define MCONTROL_ACTION (0x3f<<12)
-#define MCONTROL_CHAIN (1<<11)
-#define MCONTROL_MATCH (0xf<<7)
-#define MCONTROL_M (1<<6)
-#define MCONTROL_H (1<<5)
-#define MCONTROL_S (1<<4)
-#define MCONTROL_U (1<<3)
-#define MCONTROL_EXECUTE (1<<2)
-#define MCONTROL_STORE (1<<1)
-#define MCONTROL_LOAD (1<<0)
-#define MCONTROL_TYPE_NONE 0
-#define MCONTROL_TYPE_MATCH 2
-#define MCONTROL_ACTION_DEBUG_EXCEPTION 0
-#define MCONTROL_ACTION_DEBUG_MODE 1
-#define MCONTROL_ACTION_TRACE_START 2
-#define MCONTROL_ACTION_TRACE_STOP 3
-#define MCONTROL_ACTION_TRACE_EMIT 4
-#define MCONTROL_MATCH_EQUAL 0
-#define MCONTROL_MATCH_NAPOT 1
-#define MCONTROL_MATCH_GE 2
-#define MCONTROL_MATCH_LT 3
-#define MCONTROL_MATCH_MASK_LOW 4
-#define MCONTROL_MATCH_MASK_HIGH 5
-#define MIP_SSIP (1 << IRQ_S_SOFT)
-#define MIP_HSIP (1 << IRQ_H_SOFT)
-#define MIP_MSIP (1 << IRQ_M_SOFT)
-#define MIP_STIP (1 << IRQ_S_TIMER)
-#define MIP_HTIP (1 << IRQ_H_TIMER)
-#define MIP_MTIP (1 << IRQ_M_TIMER)
-#define MIP_SEIP (1 << IRQ_S_EXT)
-#define MIP_HEIP (1 << IRQ_H_EXT)
-#define MIP_MEIP (1 << IRQ_M_EXT)
-#define SIP_SSIP MIP_SSIP
-#define SIP_STIP MIP_STIP
-#define PRV_U 0
-#define PRV_S 1
-#define PRV_H 2
-#define PRV_M 3
-#define SPTBR32_MODE 0x80000000
-#define SPTBR32_ASID 0x7FC00000
-#define SPTBR32_PPN 0x003FFFFF
-#define SPTBR64_MODE 0xF000000000000000
-#define SPTBR64_ASID 0x0FFFF00000000000
-#define SPTBR64_PPN 0x00000FFFFFFFFFFF
-#define SPTBR_MODE_OFF 0
-#define SPTBR_MODE_SV32 1
-#define SPTBR_MODE_SV39 8
-#define SPTBR_MODE_SV48 9
-#define SPTBR_MODE_SV57 10
-#define SPTBR_MODE_SV64 11
-#define PMP_R 0x01
-#define PMP_W 0x02
-#define PMP_X 0x04
-#define PMP_A 0x18
-#define PMP_L 0x80
-#define PMP_SHIFT 2
-#define PMP_TOR 0x08
-#define PMP_NA4 0x10
-#define PMP_NAPOT 0x18
-#define IRQ_S_SOFT 1
-#define IRQ_H_SOFT 2
-#define IRQ_M_SOFT 3
-#define IRQ_S_TIMER 5
-#define IRQ_H_TIMER 6
-#define IRQ_M_TIMER 7
-#define IRQ_S_EXT 9
-#define IRQ_H_EXT 10
-#define IRQ_M_EXT 11
-#define IRQ_COP 12
-#define IRQ_HOST 13
-#define DEFAULT_RSTVEC 0x00001000
-#define CLINT_BASE 0x02000000
-#define CLINT_SIZE 0x000c0000
-#define EXT_IO_BASE 0x40000000
-#define DRAM_BASE 0x80000000
-// page table entry (PTE) fields
-#define PTE_V 0x001 // Valid
-#define PTE_R 0x002 // Read
-#define PTE_W 0x004 // Write
-#define PTE_X 0x008 // Execute
-#define PTE_U 0x010 // User
-#define PTE_G 0x020 // Global
-#define PTE_A 0x040 // Accessed
-#define PTE_D 0x080 // Dirty
-#define PTE_SOFT 0x300 // Reserved for Software
-#define PTE_PPN_SHIFT 10
-#define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)
-#ifdef __riscv
-#if __riscv_xlen == 64
-# define MSTATUS_SD MSTATUS64_SD
-# define SSTATUS_SD SSTATUS64_SD
-# define RISCV_PGLEVEL_BITS 9
-# define SPTBR_MODE SPTBR64_MODE
-#else
-# define MSTATUS_SD MSTATUS32_SD
-# define SSTATUS_SD SSTATUS32_SD
-# define RISCV_PGLEVEL_BITS 10
-# define SPTBR_MODE SPTBR32_MODE
-#endif
-#define RISCV_PGSHIFT 12
-#define RISCV_PGSIZE (1 << RISCV_PGSHIFT)
-#ifndef __ASSEMBLER__
- * @brief Priv Mode registers definitions.
- * @see RISC-V priv-spec 1.10.
-typedef enum {
- RISCV_USER_INTERRUPT = 0,
- RISCV_SUPERVISOR_SW_INTERRUPT = 1,
- RISCV_MACHINE_SW_INTERRUPT = 3,
- RISCV_USER_TIMER_INTERRUPT = 4,
- RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
- RISCV_MACHINE_TIMER_INTERRUPT = 7,
- RISCV_USER_EXTERNAL_INTERRUPT = 8,
- RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
- RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
-} RISCV_Symbolic_interrupt_name;
-#ifdef __GNUC__
-#define read_csr(reg) ({ unsigned long __tmp; \
- asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
- __tmp; })
-#define write_csr(reg, val) ({ \
- asm volatile ("csrw " #reg ", %0" :: "rK"(val)); })
-#define swap_csr(reg, val) ({ unsigned long __tmp; \
- asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "rK"(val)); \
- __tmp; })
-#define set_csr(reg, bit) ({ unsigned long __tmp; \
- asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
- __tmp; })
-#define clear_csr(reg, bit) ({ unsigned long __tmp; \
- asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
- __tmp; })
-#define rdtime() read_csr(time)
-#define rdcycle() read_csr(cycle)
-#define rdinstret() read_csr(instret)
-#endif
-#endif
-#endif
-#endif
-/* Automatically generated by parse-opcodes. */
-#ifndef RISCV_ENCODING_H
-#define RISCV_ENCODING_H
-#define MATCH_BEQ 0x63
-#define MASK_BEQ 0x707f
-#define MATCH_BNE 0x1063
-#define MASK_BNE 0x707f
-#define MATCH_BLT 0x4063
-#define MASK_BLT 0x707f
-#define MATCH_BGE 0x5063
-#define MASK_BGE 0x707f
-#define MATCH_BLTU 0x6063
-#define MASK_BLTU 0x707f
-#define MATCH_BGEU 0x7063
-#define MASK_BGEU 0x707f
-#define MATCH_JALR 0x67
-#define MASK_JALR 0x707f
-#define MATCH_JAL 0x6f
-#define MASK_JAL 0x7f
-#define MATCH_LUI 0x37
-#define MASK_LUI 0x7f
-#define MATCH_AUIPC 0x17
-#define MASK_AUIPC 0x7f
-#define MATCH_ADDI 0x13
-#define MASK_ADDI 0x707f
-#define MATCH_SLLI 0x1013
-#define MASK_SLLI 0xfc00707f
-#define MATCH_SLTI 0x2013
-#define MASK_SLTI 0x707f
-#define MATCH_SLTIU 0x3013
-#define MASK_SLTIU 0x707f
-#define MATCH_XORI 0x4013
-#define MASK_XORI 0x707f
-#define MATCH_SRLI 0x5013
-#define MASK_SRLI 0xfc00707f
-#define MATCH_SRAI 0x40005013
-#define MASK_SRAI 0xfc00707f
-#define MATCH_ORI 0x6013
-#define MASK_ORI 0x707f
-#define MATCH_ANDI 0x7013
-#define MASK_ANDI 0x707f
-#define MATCH_ADD 0x33
-#define MASK_ADD 0xfe00707f
-#define MATCH_SUB 0x40000033
-#define MASK_SUB 0xfe00707f
-#define MATCH_SLL 0x1033
-#define MASK_SLL 0xfe00707f
-#define MATCH_SLT 0x2033
-#define MASK_SLT 0xfe00707f
-#define MATCH_SLTU 0x3033
-#define MASK_SLTU 0xfe00707f
-#define MATCH_XOR 0x4033
-#define MASK_XOR 0xfe00707f
-#define MATCH_SRL 0x5033
-#define MASK_SRL 0xfe00707f
-#define MATCH_SRA 0x40005033
-#define MASK_SRA 0xfe00707f
-#define MATCH_OR 0x6033
-#define MASK_OR 0xfe00707f
-#define MATCH_AND 0x7033
-#define MASK_AND 0xfe00707f
-#define MATCH_ADDIW 0x1b
-#define MASK_ADDIW 0x707f
-#define MATCH_SLLIW 0x101b
-#define MASK_SLLIW 0xfe00707f
-#define MATCH_SRLIW 0x501b
-#define MASK_SRLIW 0xfe00707f
-#define MATCH_SRAIW 0x4000501b
-#define MASK_SRAIW 0xfe00707f
-#define MATCH_ADDW 0x3b
-#define MASK_ADDW 0xfe00707f
-#define MATCH_SUBW 0x4000003b
-#define MASK_SUBW 0xfe00707f
-#define MATCH_SLLW 0x103b
-#define MASK_SLLW 0xfe00707f
-#define MATCH_SRLW 0x503b
-#define MASK_SRLW 0xfe00707f
-#define MATCH_SRAW 0x4000503b
-#define MASK_SRAW 0xfe00707f
-#define MATCH_LB 0x3
-#define MASK_LB 0x707f
-#define MATCH_LH 0x1003
-#define MASK_LH 0x707f
-#define MATCH_LW 0x2003
-#define MASK_LW 0x707f
-#define MATCH_LD 0x3003
-#define MASK_LD 0x707f
-#define MATCH_LBU 0x4003
-#define MASK_LBU 0x707f
-#define MATCH_LHU 0x5003
-#define MASK_LHU 0x707f
-#define MATCH_LWU 0x6003
-#define MASK_LWU 0x707f
-#define MATCH_SB 0x23
-#define MASK_SB 0x707f
-#define MATCH_SH 0x1023
-#define MASK_SH 0x707f
-#define MATCH_SW 0x2023
-#define MASK_SW 0x707f
-#define MATCH_SD 0x3023
-#define MASK_SD 0x707f
-#define MATCH_FENCE 0xf
-#define MASK_FENCE 0x707f
-#define MATCH_FENCE_I 0x100f
-#define MASK_FENCE_I 0x707f
-#define MATCH_MUL 0x2000033
-#define MASK_MUL 0xfe00707f
-#define MATCH_MULH 0x2001033
-#define MASK_MULH 0xfe00707f
-#define MATCH_MULHSU 0x2002033
-#define MASK_MULHSU 0xfe00707f
-#define MATCH_MULHU 0x2003033
-#define MASK_MULHU 0xfe00707f
-#define MATCH_DIV 0x2004033
-#define MASK_DIV 0xfe00707f
-#define MATCH_DIVU 0x2005033
-#define MASK_DIVU 0xfe00707f
-#define MATCH_REM 0x2006033
-#define MASK_REM 0xfe00707f
-#define MATCH_REMU 0x2007033
-#define MASK_REMU 0xfe00707f
-#define MATCH_MULW 0x200003b
-#define MASK_MULW 0xfe00707f
-#define MATCH_DIVW 0x200403b
-#define MASK_DIVW 0xfe00707f
-#define MATCH_DIVUW 0x200503b
-#define MASK_DIVUW 0xfe00707f
-#define MATCH_REMW 0x200603b
-#define MASK_REMW 0xfe00707f
-#define MATCH_REMUW 0x200703b
-#define MASK_REMUW 0xfe00707f
-#define MATCH_AMOADD_W 0x202f
-#define MASK_AMOADD_W 0xf800707f
-#define MATCH_AMOXOR_W 0x2000202f
-#define MASK_AMOXOR_W 0xf800707f
-#define MATCH_AMOOR_W 0x4000202f
-#define MASK_AMOOR_W 0xf800707f
-#define MATCH_AMOAND_W 0x6000202f
-#define MASK_AMOAND_W 0xf800707f
-#define MATCH_AMOMIN_W 0x8000202f
-#define MASK_AMOMIN_W 0xf800707f
-#define MATCH_AMOMAX_W 0xa000202f
-#define MASK_AMOMAX_W 0xf800707f
-#define MATCH_AMOMINU_W 0xc000202f
-#define MASK_AMOMINU_W 0xf800707f
-#define MATCH_AMOMAXU_W 0xe000202f
-#define MASK_AMOMAXU_W 0xf800707f
-#define MATCH_AMOSWAP_W 0x800202f
-#define MASK_AMOSWAP_W 0xf800707f
-#define MATCH_LR_W 0x1000202f
-#define MASK_LR_W 0xf9f0707f
-#define MATCH_SC_W 0x1800202f
-#define MASK_SC_W 0xf800707f
-#define MATCH_AMOADD_D 0x302f
-#define MASK_AMOADD_D 0xf800707f
-#define MATCH_AMOXOR_D 0x2000302f
-#define MASK_AMOXOR_D 0xf800707f
-#define MATCH_AMOOR_D 0x4000302f
-#define MASK_AMOOR_D 0xf800707f
-#define MATCH_AMOAND_D 0x6000302f
-#define MASK_AMOAND_D 0xf800707f
-#define MATCH_AMOMIN_D 0x8000302f
-#define MASK_AMOMIN_D 0xf800707f
-#define MATCH_AMOMAX_D 0xa000302f
-#define MASK_AMOMAX_D 0xf800707f
-#define MATCH_AMOMINU_D 0xc000302f
-#define MASK_AMOMINU_D 0xf800707f
-#define MATCH_AMOMAXU_D 0xe000302f
-#define MASK_AMOMAXU_D 0xf800707f
-#define MATCH_AMOSWAP_D 0x800302f
-#define MASK_AMOSWAP_D 0xf800707f
-#define MATCH_LR_D 0x1000302f
-#define MASK_LR_D 0xf9f0707f
-#define MATCH_SC_D 0x1800302f
-#define MASK_SC_D 0xf800707f
-#define MATCH_ECALL 0x73
-#define MASK_ECALL 0xffffffff
-#define MATCH_EBREAK 0x100073
-#define MASK_EBREAK 0xffffffff
-#define MATCH_URET 0x200073
-#define MASK_URET 0xffffffff
-#define MATCH_SRET 0x10200073
-#define MASK_SRET 0xffffffff
-#define MATCH_MRET 0x30200073
-#define MASK_MRET 0xffffffff
-#define MATCH_DRET 0x7b200073
-#define MASK_DRET 0xffffffff
-#define MATCH_SFENCE_VMA 0x12000073
-#define MASK_SFENCE_VMA 0xfe007fff
-#define MATCH_WFI 0x10500073
-#define MASK_WFI 0xffffffff
-#define MATCH_CSRRW 0x1073
-#define MASK_CSRRW 0x707f
-#define MATCH_CSRRS 0x2073
-#define MASK_CSRRS 0x707f
-#define MATCH_CSRRC 0x3073
-#define MASK_CSRRC 0x707f
-#define MATCH_CSRRWI 0x5073
-#define MASK_CSRRWI 0x707f
-#define MATCH_CSRRSI 0x6073
-#define MASK_CSRRSI 0x707f
-#define MATCH_CSRRCI 0x7073
-#define MASK_CSRRCI 0x707f
-#define MATCH_FADD_S 0x53
-#define MASK_FADD_S 0xfe00007f
-#define MATCH_FSUB_S 0x8000053
-#define MASK_FSUB_S 0xfe00007f
-#define MATCH_FMUL_S 0x10000053
-#define MASK_FMUL_S 0xfe00007f
-#define MATCH_FDIV_S 0x18000053
-#define MASK_FDIV_S 0xfe00007f
-#define MATCH_FSGNJ_S 0x20000053
-#define MASK_FSGNJ_S 0xfe00707f
-#define MATCH_FSGNJN_S 0x20001053
-#define MASK_FSGNJN_S 0xfe00707f
-#define MATCH_FSGNJX_S 0x20002053
-#define MASK_FSGNJX_S 0xfe00707f
-#define MATCH_FMIN_S 0x28000053
-#define MASK_FMIN_S 0xfe00707f
-#define MATCH_FMAX_S 0x28001053
-#define MASK_FMAX_S 0xfe00707f
-#define MATCH_FSQRT_S 0x58000053
-#define MASK_FSQRT_S 0xfff0007f
-#define MATCH_FADD_D 0x2000053
-#define MASK_FADD_D 0xfe00007f
-#define MATCH_FSUB_D 0xa000053
-#define MASK_FSUB_D 0xfe00007f
-#define MATCH_FMUL_D 0x12000053
-#define MASK_FMUL_D 0xfe00007f
-#define MATCH_FDIV_D 0x1a000053
-#define MASK_FDIV_D 0xfe00007f
-#define MATCH_FSGNJ_D 0x22000053
-#define MASK_FSGNJ_D 0xfe00707f
-#define MATCH_FSGNJN_D 0x22001053
-#define MASK_FSGNJN_D 0xfe00707f
-#define MATCH_FSGNJX_D 0x22002053
-#define MASK_FSGNJX_D 0xfe00707f
-#define MATCH_FMIN_D 0x2a000053
-#define MASK_FMIN_D 0xfe00707f
-#define MATCH_FMAX_D 0x2a001053
-#define MASK_FMAX_D 0xfe00707f
-#define MATCH_FCVT_S_D 0x40100053
-#define MASK_FCVT_S_D 0xfff0007f
-#define MATCH_FCVT_D_S 0x42000053
-#define MASK_FCVT_D_S 0xfff0007f
-#define MATCH_FSQRT_D 0x5a000053
-#define MASK_FSQRT_D 0xfff0007f
-#define MATCH_FADD_Q 0x6000053
-#define MASK_FADD_Q 0xfe00007f
-#define MATCH_FSUB_Q 0xe000053
-#define MASK_FSUB_Q 0xfe00007f
-#define MATCH_FMUL_Q 0x16000053
-#define MASK_FMUL_Q 0xfe00007f
-#define MATCH_FDIV_Q 0x1e000053
-#define MASK_FDIV_Q 0xfe00007f
-#define MATCH_FSGNJ_Q 0x26000053
-#define MASK_FSGNJ_Q 0xfe00707f
-#define MATCH_FSGNJN_Q 0x26001053
-#define MASK_FSGNJN_Q 0xfe00707f
-#define MATCH_FSGNJX_Q 0x26002053
-#define MASK_FSGNJX_Q 0xfe00707f
-#define MATCH_FMIN_Q 0x2e000053
-#define MASK_FMIN_Q 0xfe00707f
-#define MATCH_FMAX_Q 0x2e001053
-#define MASK_FMAX_Q 0xfe00707f
-#define MATCH_FCVT_S_Q 0x40300053
-#define MASK_FCVT_S_Q 0xfff0007f
-#define MATCH_FCVT_Q_S 0x46000053
-#define MASK_FCVT_Q_S 0xfff0007f
-#define MATCH_FCVT_D_Q 0x42300053
-#define MASK_FCVT_D_Q 0xfff0007f
-#define MATCH_FCVT_Q_D 0x46100053
-#define MASK_FCVT_Q_D 0xfff0007f
-#define MATCH_FSQRT_Q 0x5e000053
-#define MASK_FSQRT_Q 0xfff0007f
-#define MATCH_FLE_S 0xa0000053
-#define MASK_FLE_S 0xfe00707f
-#define MATCH_FLT_S 0xa0001053
-#define MASK_FLT_S 0xfe00707f
-#define MATCH_FEQ_S 0xa0002053
-#define MASK_FEQ_S 0xfe00707f
-#define MATCH_FLE_D 0xa2000053
-#define MASK_FLE_D 0xfe00707f
-#define MATCH_FLT_D 0xa2001053
-#define MASK_FLT_D 0xfe00707f
-#define MATCH_FEQ_D 0xa2002053
-#define MASK_FEQ_D 0xfe00707f
-#define MATCH_FLE_Q 0xa6000053
-#define MASK_FLE_Q 0xfe00707f
-#define MATCH_FLT_Q 0xa6001053
-#define MASK_FLT_Q 0xfe00707f
-#define MATCH_FEQ_Q 0xa6002053
-#define MASK_FEQ_Q 0xfe00707f
-#define MATCH_FCVT_W_S 0xc0000053
-#define MASK_FCVT_W_S 0xfff0007f
-#define MATCH_FCVT_WU_S 0xc0100053
-#define MASK_FCVT_WU_S 0xfff0007f
-#define MATCH_FCVT_L_S 0xc0200053
-#define MASK_FCVT_L_S 0xfff0007f
-#define MATCH_FCVT_LU_S 0xc0300053
-#define MASK_FCVT_LU_S 0xfff0007f
-#define MATCH_FMV_X_W 0xe0000053
-#define MASK_FMV_X_W 0xfff0707f
-#define MATCH_FCLASS_S 0xe0001053
-#define MASK_FCLASS_S 0xfff0707f
-#define MATCH_FCVT_W_D 0xc2000053
-#define MASK_FCVT_W_D 0xfff0007f
-#define MATCH_FCVT_WU_D 0xc2100053
-#define MASK_FCVT_WU_D 0xfff0007f
-#define MATCH_FCVT_L_D 0xc2200053
-#define MASK_FCVT_L_D 0xfff0007f
-#define MATCH_FCVT_LU_D 0xc2300053
-#define MASK_FCVT_LU_D 0xfff0007f
-#define MATCH_FMV_X_D 0xe2000053
-#define MASK_FMV_X_D 0xfff0707f
-#define MATCH_FCLASS_D 0xe2001053
-#define MASK_FCLASS_D 0xfff0707f
-#define MATCH_FCVT_W_Q 0xc6000053
-#define MASK_FCVT_W_Q 0xfff0007f
-#define MATCH_FCVT_WU_Q 0xc6100053
-#define MASK_FCVT_WU_Q 0xfff0007f
-#define MATCH_FCVT_L_Q 0xc6200053
-#define MASK_FCVT_L_Q 0xfff0007f
-#define MATCH_FCVT_LU_Q 0xc6300053
-#define MASK_FCVT_LU_Q 0xfff0007f
-#define MATCH_FMV_X_Q 0xe6000053
-#define MASK_FMV_X_Q 0xfff0707f
-#define MATCH_FCLASS_Q 0xe6001053
-#define MASK_FCLASS_Q 0xfff0707f
-#define MATCH_FCVT_S_W 0xd0000053
-#define MASK_FCVT_S_W 0xfff0007f
-#define MATCH_FCVT_S_WU 0xd0100053
-#define MASK_FCVT_S_WU 0xfff0007f
-#define MATCH_FCVT_S_L 0xd0200053
-#define MASK_FCVT_S_L 0xfff0007f
-#define MATCH_FCVT_S_LU 0xd0300053
-#define MASK_FCVT_S_LU 0xfff0007f
-#define MATCH_FMV_W_X 0xf0000053
-#define MASK_FMV_W_X 0xfff0707f
-#define MATCH_FCVT_D_W 0xd2000053
-#define MASK_FCVT_D_W 0xfff0007f
-#define MATCH_FCVT_D_WU 0xd2100053
-#define MASK_FCVT_D_WU 0xfff0007f
-#define MATCH_FCVT_D_L 0xd2200053
-#define MASK_FCVT_D_L 0xfff0007f
-#define MATCH_FCVT_D_LU 0xd2300053
-#define MASK_FCVT_D_LU 0xfff0007f
-#define MATCH_FMV_D_X 0xf2000053
-#define MASK_FMV_D_X 0xfff0707f
-#define MATCH_FCVT_Q_W 0xd6000053
-#define MASK_FCVT_Q_W 0xfff0007f
-#define MATCH_FCVT_Q_WU 0xd6100053
-#define MASK_FCVT_Q_WU 0xfff0007f
-#define MATCH_FCVT_Q_L 0xd6200053
-#define MASK_FCVT_Q_L 0xfff0007f
-#define MATCH_FCVT_Q_LU 0xd6300053
-#define MASK_FCVT_Q_LU 0xfff0007f
-#define MATCH_FMV_Q_X 0xf6000053
-#define MASK_FMV_Q_X 0xfff0707f
-#define MATCH_FLW 0x2007
-#define MASK_FLW 0x707f
-#define MATCH_FLD 0x3007
-#define MASK_FLD 0x707f
-#define MATCH_FLQ 0x4007
-#define MASK_FLQ 0x707f
-#define MATCH_FSW 0x2027
-#define MASK_FSW 0x707f
-#define MATCH_FSD 0x3027
-#define MASK_FSD 0x707f
-#define MATCH_FSQ 0x4027
-#define MASK_FSQ 0x707f
-#define MATCH_FMADD_S 0x43
-#define MASK_FMADD_S 0x600007f
-#define MATCH_FMSUB_S 0x47
-#define MASK_FMSUB_S 0x600007f
-#define MATCH_FNMSUB_S 0x4b
-#define MASK_FNMSUB_S 0x600007f
-#define MATCH_FNMADD_S 0x4f
-#define MASK_FNMADD_S 0x600007f
-#define MATCH_FMADD_D 0x2000043
-#define MASK_FMADD_D 0x600007f
-#define MATCH_FMSUB_D 0x2000047
-#define MASK_FMSUB_D 0x600007f
-#define MATCH_FNMSUB_D 0x200004b
-#define MASK_FNMSUB_D 0x600007f
-#define MATCH_FNMADD_D 0x200004f
-#define MASK_FNMADD_D 0x600007f
-#define MATCH_FMADD_Q 0x6000043
-#define MASK_FMADD_Q 0x600007f
-#define MATCH_FMSUB_Q 0x6000047
-#define MASK_FMSUB_Q 0x600007f
-#define MATCH_FNMSUB_Q 0x600004b
-#define MASK_FNMSUB_Q 0x600007f
-#define MATCH_FNMADD_Q 0x600004f
-#define MASK_FNMADD_Q 0x600007f
-#define MATCH_C_NOP 0x1
-#define MASK_C_NOP 0xffff
-#define MATCH_C_ADDI16SP 0x6101
-#define MASK_C_ADDI16SP 0xef83
-#define MATCH_C_JR 0x8002
-#define MASK_C_JR 0xf07f
-#define MATCH_C_JALR 0x9002
-#define MASK_C_JALR 0xf07f
-#define MATCH_C_EBREAK 0x9002
-#define MASK_C_EBREAK 0xffff
-#define MATCH_C_LD 0x6000
-#define MASK_C_LD 0xe003
-#define MATCH_C_SD 0xe000
-#define MASK_C_SD 0xe003
-#define MATCH_C_ADDIW 0x2001
-#define MASK_C_ADDIW 0xe003
-#define MATCH_C_LDSP 0x6002
-#define MASK_C_LDSP 0xe003
-#define MATCH_C_SDSP 0xe002
-#define MASK_C_SDSP 0xe003
-#define MATCH_C_ADDI4SPN 0x0
-#define MASK_C_ADDI4SPN 0xe003
-#define MATCH_C_FLD 0x2000
-#define MASK_C_FLD 0xe003
-#define MATCH_C_LW 0x4000
-#define MASK_C_LW 0xe003
-#define MATCH_C_FLW 0x6000
-#define MASK_C_FLW 0xe003
-#define MATCH_C_FSD 0xa000
-#define MASK_C_FSD 0xe003
-#define MATCH_C_SW 0xc000
-#define MASK_C_SW 0xe003
-#define MATCH_C_FSW 0xe000
-#define MASK_C_FSW 0xe003
-#define MATCH_C_ADDI 0x1
-#define MASK_C_ADDI 0xe003
-#define MATCH_C_JAL 0x2001
-#define MASK_C_JAL 0xe003
-#define MATCH_C_LI 0x4001
-#define MASK_C_LI 0xe003
-#define MATCH_C_LUI 0x6001
-#define MASK_C_LUI 0xe003
-#define MATCH_C_SRLI 0x8001
-#define MASK_C_SRLI 0xec03
-#define MATCH_C_SRAI 0x8401
-#define MASK_C_SRAI 0xec03
-#define MATCH_C_ANDI 0x8801
-#define MASK_C_ANDI 0xec03
-#define MATCH_C_SUB 0x8c01
-#define MASK_C_SUB 0xfc63
-#define MATCH_C_XOR 0x8c21
-#define MASK_C_XOR 0xfc63
-#define MATCH_C_OR 0x8c41
-#define MASK_C_OR 0xfc63
-#define MATCH_C_AND 0x8c61
-#define MASK_C_AND 0xfc63
-#define MATCH_C_SUBW 0x9c01
-#define MASK_C_SUBW 0xfc63
-#define MATCH_C_ADDW 0x9c21
-#define MASK_C_ADDW 0xfc63
-#define MATCH_C_J 0xa001
-#define MASK_C_J 0xe003
-#define MATCH_C_BEQZ 0xc001
-#define MASK_C_BEQZ 0xe003
-#define MATCH_C_BNEZ 0xe001
-#define MASK_C_BNEZ 0xe003
-#define MATCH_C_SLLI 0x2
-#define MASK_C_SLLI 0xe003
-#define MATCH_C_FLDSP 0x2002
-#define MASK_C_FLDSP 0xe003
-#define MATCH_C_LWSP 0x4002
-#define MASK_C_LWSP 0xe003
-#define MATCH_C_FLWSP 0x6002
-#define MASK_C_FLWSP 0xe003
-#define MATCH_C_MV 0x8002
-#define MASK_C_MV 0xf003
-#define MATCH_C_ADD 0x9002
-#define MASK_C_ADD 0xf003
-#define MATCH_C_FSDSP 0xa002
-#define MASK_C_FSDSP 0xe003
-#define MATCH_C_SWSP 0xc002
-#define MASK_C_SWSP 0xe003
-#define MATCH_C_FSWSP 0xe002
-#define MASK_C_FSWSP 0xe003
-#define MATCH_CUSTOM0 0xb
-#define MASK_CUSTOM0 0x707f
-#define MATCH_CUSTOM0_RS1 0x200b
-#define MASK_CUSTOM0_RS1 0x707f
-#define MATCH_CUSTOM0_RS1_RS2 0x300b
-#define MASK_CUSTOM0_RS1_RS2 0x707f
-#define MATCH_CUSTOM0_RD 0x400b
-#define MASK_CUSTOM0_RD 0x707f
-#define MATCH_CUSTOM0_RD_RS1 0x600b
-#define MASK_CUSTOM0_RD_RS1 0x707f
-#define MATCH_CUSTOM0_RD_RS1_RS2 0x700b
-#define MASK_CUSTOM0_RD_RS1_RS2 0x707f
-#define MATCH_CUSTOM1 0x2b
-#define MASK_CUSTOM1 0x707f
-#define MATCH_CUSTOM1_RS1 0x202b
-#define MASK_CUSTOM1_RS1 0x707f
-#define MATCH_CUSTOM1_RS1_RS2 0x302b
-#define MASK_CUSTOM1_RS1_RS2 0x707f
-#define MATCH_CUSTOM1_RD 0x402b
-#define MASK_CUSTOM1_RD 0x707f
-#define MATCH_CUSTOM1_RD_RS1 0x602b
-#define MASK_CUSTOM1_RD_RS1 0x707f
-#define MATCH_CUSTOM1_RD_RS1_RS2 0x702b
-#define MASK_CUSTOM1_RD_RS1_RS2 0x707f
-#define MATCH_CUSTOM2 0x5b
-#define MASK_CUSTOM2 0x707f
-#define MATCH_CUSTOM2_RS1 0x205b
-#define MASK_CUSTOM2_RS1 0x707f
-#define MATCH_CUSTOM2_RS1_RS2 0x305b
-#define MASK_CUSTOM2_RS1_RS2 0x707f
-#define MATCH_CUSTOM2_RD 0x405b
-#define MASK_CUSTOM2_RD 0x707f
-#define MATCH_CUSTOM2_RD_RS1 0x605b
-#define MASK_CUSTOM2_RD_RS1 0x707f
-#define MATCH_CUSTOM2_RD_RS1_RS2 0x705b
-#define MASK_CUSTOM2_RD_RS1_RS2 0x707f
-#define MATCH_CUSTOM3 0x7b
-#define MASK_CUSTOM3 0x707f
-#define MATCH_CUSTOM3_RS1 0x207b
-#define MASK_CUSTOM3_RS1 0x707f
-#define MATCH_CUSTOM3_RS1_RS2 0x307b
-#define MASK_CUSTOM3_RS1_RS2 0x707f
-#define MATCH_CUSTOM3_RD 0x407b
-#define MASK_CUSTOM3_RD 0x707f
-#define MATCH_CUSTOM3_RD_RS1 0x607b
-#define MASK_CUSTOM3_RD_RS1 0x707f
-#define MATCH_CUSTOM3_RD_RS1_RS2 0x707b
-#define MASK_CUSTOM3_RD_RS1_RS2 0x707f
-#define CSR_FFLAGS 0x1
-#define CSR_FRM 0x2
-#define CSR_FCSR 0x3
-#define CSR_CYCLE 0xc00
-#define CSR_TIME 0xc01
-#define CSR_INSTRET 0xc02
-#define CSR_HPMCOUNTER3 0xc03
-#define CSR_HPMCOUNTER4 0xc04
-#define CSR_HPMCOUNTER5 0xc05
-#define CSR_HPMCOUNTER6 0xc06
-#define CSR_HPMCOUNTER7 0xc07
-#define CSR_HPMCOUNTER8 0xc08
-#define CSR_HPMCOUNTER9 0xc09
-#define CSR_HPMCOUNTER10 0xc0a
-#define CSR_HPMCOUNTER11 0xc0b
-#define CSR_HPMCOUNTER12 0xc0c
-#define CSR_HPMCOUNTER13 0xc0d
-#define CSR_HPMCOUNTER14 0xc0e
-#define CSR_HPMCOUNTER15 0xc0f
-#define CSR_HPMCOUNTER16 0xc10
-#define CSR_HPMCOUNTER17 0xc11
-#define CSR_HPMCOUNTER18 0xc12
-#define CSR_HPMCOUNTER19 0xc13
-#define CSR_HPMCOUNTER20 0xc14
-#define CSR_HPMCOUNTER21 0xc15
-#define CSR_HPMCOUNTER22 0xc16
-#define CSR_HPMCOUNTER23 0xc17
-#define CSR_HPMCOUNTER24 0xc18
-#define CSR_HPMCOUNTER25 0xc19
-#define CSR_HPMCOUNTER26 0xc1a
-#define CSR_HPMCOUNTER27 0xc1b
-#define CSR_HPMCOUNTER28 0xc1c
-#define CSR_HPMCOUNTER29 0xc1d
-#define CSR_HPMCOUNTER30 0xc1e
-#define CSR_HPMCOUNTER31 0xc1f
-#define CSR_SSTATUS 0x100
-#define CSR_SIE 0x104
-#define CSR_STVEC 0x105
-#define CSR_SCOUNTEREN 0x106
-#define CSR_SSCRATCH 0x140
-#define CSR_SEPC 0x141
-#define CSR_SCAUSE 0x142
-#define CSR_SBADADDR 0x143
-#define CSR_SIP 0x144
-#define CSR_SPTBR 0x180
-#define CSR_MSTATUS 0x300
-#define CSR_MISA 0x301
-#define CSR_MEDELEG 0x302
-#define CSR_MIDELEG 0x303
-#define CSR_MIE 0x304
-#define CSR_MTVEC 0x305
-#define CSR_MCOUNTEREN 0x306
-#define CSR_MSCRATCH 0x340
-#define CSR_MEPC 0x341
-#define CSR_MCAUSE 0x342
-#define CSR_MBADADDR 0x343
-#define CSR_MIP 0x344
-#define CSR_PMPCFG0 0x3a0
-#define CSR_PMPCFG1 0x3a1
-#define CSR_PMPCFG2 0x3a2
-#define CSR_PMPCFG3 0x3a3
-#define CSR_PMPADDR0 0x3b0
-#define CSR_PMPADDR1 0x3b1
-#define CSR_PMPADDR2 0x3b2
-#define CSR_PMPADDR3 0x3b3
-#define CSR_PMPADDR4 0x3b4
-#define CSR_PMPADDR5 0x3b5
-#define CSR_PMPADDR6 0x3b6
-#define CSR_PMPADDR7 0x3b7
-#define CSR_PMPADDR8 0x3b8
-#define CSR_PMPADDR9 0x3b9
-#define CSR_PMPADDR10 0x3ba
-#define CSR_PMPADDR11 0x3bb
-#define CSR_PMPADDR12 0x3bc
-#define CSR_PMPADDR13 0x3bd
-#define CSR_PMPADDR14 0x3be
-#define CSR_PMPADDR15 0x3bf
-#define CSR_TSELECT 0x7a0
-#define CSR_TDATA1 0x7a1
-#define CSR_TDATA2 0x7a2
-#define CSR_TDATA3 0x7a3
-#define CSR_DCSR 0x7b0
-#define CSR_DPC 0x7b1
-#define CSR_DSCRATCH 0x7b2
-#define CSR_MCYCLE 0xb00
-#define CSR_MINSTRET 0xb02
-#define CSR_MHPMCOUNTER3 0xb03
-#define CSR_MHPMCOUNTER4 0xb04
-#define CSR_MHPMCOUNTER5 0xb05
-#define CSR_MHPMCOUNTER6 0xb06
-#define CSR_MHPMCOUNTER7 0xb07
-#define CSR_MHPMCOUNTER8 0xb08
-#define CSR_MHPMCOUNTER9 0xb09
-#define CSR_MHPMCOUNTER10 0xb0a
-#define CSR_MHPMCOUNTER11 0xb0b
-#define CSR_MHPMCOUNTER12 0xb0c
-#define CSR_MHPMCOUNTER13 0xb0d
-#define CSR_MHPMCOUNTER14 0xb0e
-#define CSR_MHPMCOUNTER15 0xb0f
-#define CSR_MHPMCOUNTER16 0xb10
-#define CSR_MHPMCOUNTER17 0xb11
-#define CSR_MHPMCOUNTER18 0xb12
-#define CSR_MHPMCOUNTER19 0xb13
-#define CSR_MHPMCOUNTER20 0xb14
-#define CSR_MHPMCOUNTER21 0xb15
-#define CSR_MHPMCOUNTER22 0xb16
-#define CSR_MHPMCOUNTER23 0xb17
-#define CSR_MHPMCOUNTER24 0xb18
-#define CSR_MHPMCOUNTER25 0xb19
-#define CSR_MHPMCOUNTER26 0xb1a
-#define CSR_MHPMCOUNTER27 0xb1b
-#define CSR_MHPMCOUNTER28 0xb1c
-#define CSR_MHPMCOUNTER29 0xb1d
-#define CSR_MHPMCOUNTER30 0xb1e
-#define CSR_MHPMCOUNTER31 0xb1f
-#define CSR_MHPMEVENT3 0x323
-#define CSR_MHPMEVENT4 0x324
-#define CSR_MHPMEVENT5 0x325
-#define CSR_MHPMEVENT6 0x326
-#define CSR_MHPMEVENT7 0x327
-#define CSR_MHPMEVENT8 0x328
-#define CSR_MHPMEVENT9 0x329
-#define CSR_MHPMEVENT10 0x32a
-#define CSR_MHPMEVENT11 0x32b
-#define CSR_MHPMEVENT12 0x32c
-#define CSR_MHPMEVENT13 0x32d
-#define CSR_MHPMEVENT14 0x32e
-#define CSR_MHPMEVENT15 0x32f
-#define CSR_MHPMEVENT16 0x330
-#define CSR_MHPMEVENT17 0x331
-#define CSR_MHPMEVENT18 0x332
-#define CSR_MHPMEVENT19 0x333
-#define CSR_MHPMEVENT20 0x334
-#define CSR_MHPMEVENT21 0x335
-#define CSR_MHPMEVENT22 0x336
-#define CSR_MHPMEVENT23 0x337
-#define CSR_MHPMEVENT24 0x338
-#define CSR_MHPMEVENT25 0x339
-#define CSR_MHPMEVENT26 0x33a
-#define CSR_MHPMEVENT27 0x33b
-#define CSR_MHPMEVENT28 0x33c
-#define CSR_MHPMEVENT29 0x33d
-#define CSR_MHPMEVENT30 0x33e
-#define CSR_MHPMEVENT31 0x33f
-#define CSR_MVENDORID 0xf11
-#define CSR_MARCHID 0xf12
-#define CSR_MIMPID 0xf13
-#define CSR_MHARTID 0xf14
-#define CSR_CYCLEH 0xc80
-#define CSR_TIMEH 0xc81
-#define CSR_INSTRETH 0xc82
-#define CSR_HPMCOUNTER3H 0xc83
-#define CSR_HPMCOUNTER4H 0xc84
-#define CSR_HPMCOUNTER5H 0xc85
-#define CSR_HPMCOUNTER6H 0xc86
-#define CSR_HPMCOUNTER7H 0xc87
-#define CSR_HPMCOUNTER8H 0xc88
-#define CSR_HPMCOUNTER9H 0xc89
-#define CSR_HPMCOUNTER10H 0xc8a
-#define CSR_HPMCOUNTER11H 0xc8b
-#define CSR_HPMCOUNTER12H 0xc8c
-#define CSR_HPMCOUNTER13H 0xc8d
-#define CSR_HPMCOUNTER14H 0xc8e
-#define CSR_HPMCOUNTER15H 0xc8f
-#define CSR_HPMCOUNTER16H 0xc90
-#define CSR_HPMCOUNTER17H 0xc91
-#define CSR_HPMCOUNTER18H 0xc92
-#define CSR_HPMCOUNTER19H 0xc93
-#define CSR_HPMCOUNTER20H 0xc94
-#define CSR_HPMCOUNTER21H 0xc95
-#define CSR_HPMCOUNTER22H 0xc96
-#define CSR_HPMCOUNTER23H 0xc97
-#define CSR_HPMCOUNTER24H 0xc98
-#define CSR_HPMCOUNTER25H 0xc99
-#define CSR_HPMCOUNTER26H 0xc9a
-#define CSR_HPMCOUNTER27H 0xc9b
-#define CSR_HPMCOUNTER28H 0xc9c
-#define CSR_HPMCOUNTER29H 0xc9d
-#define CSR_HPMCOUNTER30H 0xc9e
-#define CSR_HPMCOUNTER31H 0xc9f
-#define CSR_MCYCLEH 0xb80
-#define CSR_MINSTRETH 0xb82
-#define CSR_MHPMCOUNTER3H 0xb83
-#define CSR_MHPMCOUNTER4H 0xb84
-#define CSR_MHPMCOUNTER5H 0xb85
-#define CSR_MHPMCOUNTER6H 0xb86
-#define CSR_MHPMCOUNTER7H 0xb87
-#define CSR_MHPMCOUNTER8H 0xb88
-#define CSR_MHPMCOUNTER9H 0xb89
-#define CSR_MHPMCOUNTER10H 0xb8a
-#define CSR_MHPMCOUNTER11H 0xb8b
-#define CSR_MHPMCOUNTER12H 0xb8c
-#define CSR_MHPMCOUNTER13H 0xb8d
-#define CSR_MHPMCOUNTER14H 0xb8e
-#define CSR_MHPMCOUNTER15H 0xb8f
-#define CSR_MHPMCOUNTER16H 0xb90
-#define CSR_MHPMCOUNTER17H 0xb91
-#define CSR_MHPMCOUNTER18H 0xb92
-#define CSR_MHPMCOUNTER19H 0xb93
-#define CSR_MHPMCOUNTER20H 0xb94
-#define CSR_MHPMCOUNTER21H 0xb95
-#define CSR_MHPMCOUNTER22H 0xb96
-#define CSR_MHPMCOUNTER23H 0xb97
-#define CSR_MHPMCOUNTER24H 0xb98
-#define CSR_MHPMCOUNTER25H 0xb99
-#define CSR_MHPMCOUNTER26H 0xb9a
-#define CSR_MHPMCOUNTER27H 0xb9b
-#define CSR_MHPMCOUNTER28H 0xb9c
-#define CSR_MHPMCOUNTER29H 0xb9d
-#define CSR_MHPMCOUNTER30H 0xb9e
-#define CSR_MHPMCOUNTER31H 0xb9f
-#define CAUSE_MISALIGNED_FETCH 0x0
-#define CAUSE_FETCH_ACCESS 0x1
-#define CAUSE_ILLEGAL_INSTRUCTION 0x2
-#define CAUSE_BREAKPOINT 0x3
-#define CAUSE_MISALIGNED_LOAD 0x4
-#define CAUSE_LOAD_ACCESS 0x5
-#define CAUSE_MISALIGNED_STORE 0x6
-#define CAUSE_STORE_ACCESS 0x7
-#define CAUSE_USER_ECALL 0x8
-#define CAUSE_SUPERVISOR_ECALL 0x9
-#define CAUSE_HYPERVISOR_ECALL 0xa
-#define CAUSE_MACHINE_ECALL 0xb
-#define CAUSE_FETCH_PAGE_FAULT 0xc
-#define CAUSE_LOAD_PAGE_FAULT 0xd
-#define CAUSE_STORE_PAGE_FAULT 0xf
-#endif
-#ifdef DECLARE_INSN
-DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
-DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
-DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
-DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
-DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
-DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
-DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
-DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
-DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
-DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
-DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
-DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
-DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
-DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
-DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
-DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
-DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
-DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
-DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
-DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
-DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
-DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
-DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
-DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
-DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
-DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
-DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
-DECLARE_INSN( or , MATCH_OR, MASK_OR)
-DECLARE_INSN( and , MATCH_AND, MASK_AND)
-DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
-DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
-DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
-DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
-DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
-DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
-DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
-DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
-DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
-DECLARE_INSN(lb, MATCH_LB, MASK_LB)
-DECLARE_INSN(lh, MATCH_LH, MASK_LH)
-DECLARE_INSN(lw, MATCH_LW, MASK_LW)
-DECLARE_INSN(ld, MATCH_LD, MASK_LD)
-DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
-DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
-DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
-DECLARE_INSN(sb, MATCH_SB, MASK_SB)
-DECLARE_INSN(sh, MATCH_SH, MASK_SH)
-DECLARE_INSN(sw, MATCH_SW, MASK_SW)
-DECLARE_INSN(sd, MATCH_SD, MASK_SD)
-DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
-DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
-DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
-DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
-DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
-DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
-DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
-DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
-DECLARE_INSN(rem, MATCH_REM, MASK_REM)
-DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
-DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
-DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
-DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
-DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
-DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
-DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
-DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
-DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
-DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
-DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
-DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
-DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
-DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
-DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
-DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
-DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
-DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
-DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
-DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
-DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
-DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
-DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
-DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
-DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
-DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
-DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
-DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
-DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
-DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
-DECLARE_INSN(uret, MATCH_URET, MASK_URET)
-DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
-DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
-DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
-DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
-DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
-DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
-DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
-DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
-DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
-DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
-DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
-DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
-DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
-DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
-DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
-DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
-DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
-DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
-DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
-DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
-DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
-DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
-DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
-DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
-DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
-DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
-DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
-DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
-DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
-DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
-DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
-DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
-DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
-DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
-DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
-DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
-DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
-DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
-DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
-DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
-DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
-DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
-DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
-DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
-DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
-DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
-DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
-DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
-DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
-DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
-DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
-DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
-DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
-DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
-DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
-DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
-DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
-DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
-DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
-DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
-DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
-DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
-DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
-DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
-DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
-DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
-DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
-DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
-DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
-DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
-DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
-DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
-DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
-DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
-DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
-DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
-DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
-DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
-DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
-DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
-DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
-DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
-DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
-DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
-DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
-DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
-DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
-DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
-DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
-DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
-DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
-DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
-DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
-DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
-DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
-DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
-DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
-DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
-DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
-DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
-DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
-DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
-DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
-DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
-DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
-DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
-DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
-DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
-DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
-DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
-DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
-DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
-DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
-DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
-DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
-DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
-DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
-DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
-DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
-DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
-DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
-DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
-DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
-DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
-DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
-DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
-DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
-DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
-DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
-DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
-DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
-DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
-DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
-DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
-DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
-DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
-DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
-DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
-DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
-DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
-DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
-DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
-DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
-DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
-DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
-DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
-DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
-DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
-DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
-DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
-DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
-DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
-DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
-DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
-DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
-DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
-DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
-DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
-DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
-DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
-DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
-DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
-DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
-DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
-DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
-DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
-DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
-DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
-DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
-DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
-DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
-DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
-DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
-#endif
-#ifdef DECLARE_CSR
-DECLARE_CSR(fflags, CSR_FFLAGS)
-DECLARE_CSR(frm, CSR_FRM)
-DECLARE_CSR(fcsr, CSR_FCSR)
-DECLARE_CSR(cycle, CSR_CYCLE)
-DECLARE_CSR(time, CSR_TIME)
-DECLARE_CSR(instret, CSR_INSTRET)
-DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
-DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
-DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
-DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
-DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
-DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
-DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
-DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
-DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
-DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
-DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
-DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
-DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
-DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
-DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
-DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
-DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
-DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
-DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
-DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
-DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
-DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
-DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
-DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
-DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
-DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
-DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
-DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
-DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
-DECLARE_CSR(sstatus, CSR_SSTATUS)
-DECLARE_CSR(sie, CSR_SIE)
-DECLARE_CSR(stvec, CSR_STVEC)
-DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
-DECLARE_CSR(sscratch, CSR_SSCRATCH)
-DECLARE_CSR(sepc, CSR_SEPC)
-DECLARE_CSR(scause, CSR_SCAUSE)
-DECLARE_CSR(sbadaddr, CSR_SBADADDR)
-DECLARE_CSR(sip, CSR_SIP)
-DECLARE_CSR(sptbr, CSR_SPTBR)
-DECLARE_CSR(mstatus, CSR_MSTATUS)
-DECLARE_CSR(misa, CSR_MISA)
-DECLARE_CSR(medeleg, CSR_MEDELEG)
-DECLARE_CSR(mideleg, CSR_MIDELEG)
-DECLARE_CSR(mie, CSR_MIE)
-DECLARE_CSR(mtvec, CSR_MTVEC)
-DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
-DECLARE_CSR(mscratch, CSR_MSCRATCH)
-DECLARE_CSR(mepc, CSR_MEPC)
-DECLARE_CSR(mcause, CSR_MCAUSE)
-DECLARE_CSR(mbadaddr, CSR_MBADADDR)
-DECLARE_CSR(mip, CSR_MIP)
-DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
-DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
-DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
-DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
-DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
-DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
-DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
-DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
-DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
-DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
-DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
-DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
-DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
-DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
-DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
-DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
-DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
-DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
-DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
-DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
-DECLARE_CSR(tselect, CSR_TSELECT)
-DECLARE_CSR(tdata1, CSR_TDATA1)
-DECLARE_CSR(tdata2, CSR_TDATA2)
-DECLARE_CSR(tdata3, CSR_TDATA3)
-DECLARE_CSR(dcsr, CSR_DCSR)
-DECLARE_CSR(dpc, CSR_DPC)
-DECLARE_CSR(dscratch, CSR_DSCRATCH)
-DECLARE_CSR(mcycle, CSR_MCYCLE)
-DECLARE_CSR(minstret, CSR_MINSTRET)
-DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
-DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
-DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
-DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
-DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
-DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
-DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
-DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
-DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
-DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
-DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
-DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
-DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
-DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
-DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
-DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
-DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
-DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
-DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
-DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
-DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
-DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
-DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
-DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
-DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
-DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
-DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
-DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
-DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
-DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
-DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
-DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
-DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
-DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
-DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
-DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
-DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
-DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
-DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
-DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
-DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
-DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
-DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
-DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
-DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
-DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
-DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
-DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
-DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
-DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
-DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
-DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
-DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
-DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
-DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
-DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
-DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
-DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
-DECLARE_CSR(mvendorid, CSR_MVENDORID)
-DECLARE_CSR(marchid, CSR_MARCHID)
-DECLARE_CSR(mimpid, CSR_MIMPID)
-DECLARE_CSR(mhartid, CSR_MHARTID)
-DECLARE_CSR(cycleh, CSR_CYCLEH)
-DECLARE_CSR(timeh, CSR_TIMEH)
-DECLARE_CSR(instreth, CSR_INSTRETH)
-DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
-DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
-DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
-DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
-DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
-DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
-DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
-DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
-DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
-DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
-DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
-DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
-DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
-DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
-DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
-DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
-DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
-DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
-DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
-DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
-DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
-DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
-DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
-DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
-DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
-DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
-DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
-DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
-DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
-DECLARE_CSR(mcycleh, CSR_MCYCLEH)
-DECLARE_CSR(minstreth, CSR_MINSTRETH)
-DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
-DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
-DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
-DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
-DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
-DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
-DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
-DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
-DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
-DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
-DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
-DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
-DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
-DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
-DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
-DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
-DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
-DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
-DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
-DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
-DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
-DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
-DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
-DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
-DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
-DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
-DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
-DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
-DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
-#endif
-#ifdef DECLARE_CAUSE
-DECLARE_CAUSE("misaligned fetch", CAUSE_MISALIGNED_FETCH)
-DECLARE_CAUSE("fetch access", CAUSE_FETCH_ACCESS)
-DECLARE_CAUSE("illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
-DECLARE_CAUSE("breakpoint", CAUSE_BREAKPOINT)
-DECLARE_CAUSE("misaligned load", CAUSE_MISALIGNED_LOAD)
-DECLARE_CAUSE("load access", CAUSE_LOAD_ACCESS)
-DECLARE_CAUSE("misaligned store", CAUSE_MISALIGNED_STORE)
-DECLARE_CAUSE("store access", CAUSE_STORE_ACCESS)
-DECLARE_CAUSE("user_ecall", CAUSE_USER_ECALL)
-DECLARE_CAUSE("supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
-DECLARE_CAUSE("hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
-DECLARE_CAUSE("machine_ecall", CAUSE_MACHINE_ECALL)
-DECLARE_CAUSE("fetch page fault", CAUSE_FETCH_PAGE_FAULT)
-DECLARE_CAUSE("load page fault", CAUSE_LOAD_PAGE_FAULT)
-DECLARE_CAUSE("store page fault", CAUSE_STORE_PAGE_FAULT)
-#endif
diff --git a/cpukit/score/cpu/riscv32/rtems/score/riscv.h b/cpukit/score/cpu/riscv32/rtems/score/riscv.h
deleted file mode 100644
index 6e7f137..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/riscv.h
+++ /dev/null
@@ -1,66 +0,0 @@
- * @file rtems/score/riscv.h
- * This file contains information pertaining to the riscv32 processor.
- * COPYRIGHT (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
- * Based on code with the following copyright...
- * COPYRIGHT (c) 1989-1999, 2010.
- * On-Line Applications Research Corporation (OAR).
- * Redistribution and use in source and binary forms, with or without
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_RISCV_H
-#define _RTEMS_SCORE_RISCV_H
-#ifdef __cplusplus
-extern "C" {
-#endif
- * This file contains the information required to build
- * RTEMS for a particular member of the RISCV family.
- * It does this by setting variables to indicate which
- * implementation dependent features are present in a particular
- * member of the family.
- * This is a good place to list all the known CPU models
- * that this port supports and which RTEMS CPU model they correspond
- * to.
-* Define the name of the CPU family and specific model.
-#define CPU_NAME "RISCV"
-#define CPU_MODEL_NAME "RISCV"
-#ifdef __cplusplus
-#endif
-#endif /* _RTEMS_SCORE_RISCV_H */
diff --git a/cpukit/score/cpu/riscv32/rtems/score/types.h b/cpukit/score/cpu/riscv32/rtems/score/types.h
index fe23b4f..0000000
--- a/cpukit/score/cpu/riscv32/rtems/score/types.h
+++ /dev/null
@@ -1,70 +0,0 @@
- * @file
- * @brief riscv32 Architecture Types API
- * This include file contains type definitions pertaining to the
- * RISC-V processor family.
- * are met:
- * SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_TYPES_H
-#define _RTEMS_SCORE_TYPES_H
-#include <rtems/score/basedefs.h>
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @addtogroup ScoreCPU
- * This section defines the basic types for this processor.
-/** Type that can store a 32-bit integer or a pointer. */
-typedef uintptr_t CPU_Uint32ptr;
-typedef uint16_t Priority_bit_map_Word;
-typedef void riscv_isr;
-typedef void ( *riscv_isr_entry )( void );
-#ifdef __cplusplus
-#endif
-#endif /* !ASM */
-#endif
2.7.4
