Failures with rtems-bsp-builder
Tue Oct 31 11:57:47 UTC 2017
Hi
I am seeing failures in the main output but nothing more detailed. I tried
the configurations I thought were failing by hand but they work.
Any ideas? Anyone else seeing this?
[   1/1565] arm/altcycv_devkit (debug)                         Configuring
run: %s: arm/altcycv_devkit.debug\
         /home/joel/rtems-work/rtems/configure --target=arm-rtems4.12\
         --enable-rtemsbsp=altcycv_devkit --prefix=/home/joel/rtems-\
         work/bsps --enable-debug
[   1/1565] arm/altcycv_devkit (debug)                         Building
         make -j 12
[   1/1565] arm/altcycv_devkit (debug)                         FAIL
[   1/1565] arm/altcycv_devkit (debug)                         Warnings:0
exes:0  objs:6  libs:0
  arm/altcycv_devkit.debug: Failure Report:
   1 debug arm/altcycv_devkit build:
      configure: /home/joel/rtems-work/rtems/configure --target=arm-\
      rtems4.12 --enable-rtemsbsp=altcycv_devkit --prefix=/home/joel\
      /rtems-work/bsps --enable-debug
[   1/1565] arm/altcycv_devkit (debug)                         Finished
(duration:0:00:31.921409)
[   1/1565] arm/altcycv_devkit (debug)                         Status:
Pass:    0  Fail:    1 (configure:0 build:1)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171031/b08c0898/attachment.html>
