[PATCH] Implement clock()
Sebastian Huber
Wed Sep 6 06:58:05 UTC 2017
Newlib uses _times_r() in clock(). The problem is that the _times_r()
clock frequency is defined by sysconf(_SC_CLK_TCK). The clock frequency
of clock() is the constant CLOCKS_PER_SEC.
FreeBSD uses getrusage() for clock(). Since RTEMS has only one process,
the implementation can be simplified.
Update #3121.
cpukit/libcsupport/Makefile.am | 1 +
cpukit/libcsupport/src/clock.c | 33 +++++++++++++++++++++++++++++++++
2 files changed, 34 insertions(+)
create mode 100644 cpukit/libcsupport/src/clock.c
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index 6091f08261..66a8aa06da 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -66,6 +66,7 @@ SYSTEM_CALL_C_FILES = src/open.c src/close.c src/read.c src/write.c \
src/fcntl.c src/fpathconf.c src/getdents.c src/fsync.c src/fdatasync.c \
src/pipe.c src/dup.c src/dup2.c src/symlink.c src/readlink.c \
src/chroot.c src/sync.c src/_rename_r.c src/statvfs.c src/utimes.c src/lchown.c
+SYSTEM_CALL_C_FILES += src/clock.c
## Until sys/uio.h is moved to libcsupport, we have to have networking
## enabled to compile these. Hopefully this is a temporary situation.
diff --git a/cpukit/libcsupport/src/clock.c b/cpukit/libcsupport/src/clock.c
new file mode 100644
index 0000000000..f976221a78
--- /dev/null
+++ b/cpukit/libcsupport/src/clock.c
@@ -0,0 +1,33 @@
+ * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <time.h>
+#include <rtems/score/basedefs.h>
+#include <rtems/score/timecounter.h>
+RTEMS_STATIC_ASSERT( CLOCKS_PER_SEC == 1000000, clocks_per_sec );
+clock_t clock( void )
+ struct timeval tv;
+ _Timecounter_Microuptime( &tv );
+ return (clock_t) (tv.tv_sec - 1) * CLOCKS_PER_SEC + tv.tv_usec;
2.12.3
